[GRASS-SVN] r49119 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Nov 6 05:33:10 EST 2011
Author: martinl
Date: 2011-11-06 02:33:10 -0800 (Sun, 06 Nov 2011)
New Revision: 49119
grass/trunk/lib/vector/Vlib/read_ogr.c
vlib: avoid double-check of constraints in Vect_read_next_line_ogr()
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c 2011-11-06 04:04:48 UTC (rev 49118)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c 2011-11-06 10:33:10 UTC (rev 49119)
@@ -20,6 +20,13 @@
#ifdef HAVE_OGR
#include <ogr_api.h>
+static int cache_feature(struct Map_info *, OGRGeometryH, int);
+static int read_line(const struct Map_info *, OGRGeometryH, long,
+ struct line_pnts *);
+static int get_line_type(const struct Map_info *, long);
+static int read_next_line_ogr(struct Map_info *, struct line_pnts *,
+ struct line_cats *, int);
\brief Recursively read feature and add all elements to points_cache and types_cache.
@@ -32,7 +39,7 @@
\return 0 on success
\return 1 on error
-static int cache_feature(struct Map_info *Map, OGRGeometryH hGeom, int ftype)
+int cache_feature(struct Map_info *Map, OGRGeometryH hGeom, int ftype)
int line, i, np, ng, tp;
OGRwkbGeometryType type;
@@ -118,26 +125,8 @@
- \brief Read next feature from OGR layer. Skip empty features (level 1)
- This function implements sequential access.
- The action of this routine can be modified by:
- - Vect_read_constraint_region()
- - Vect_read_constraint_type()
- - Vect_remove_constraints()
- \param Map pointer to Map_info structure
- \param[out] line_p container used to store line points within
- \param[out] line_c container used to store line categories within
- \return feature type
- \return -2 no more features (EOF)
- \return -1 out of memory
-int V1_read_next_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
- struct line_cats *line_c)
+int read_next_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
+ struct line_cats *line_c, int ignore_constraint)
int itype;
struct bound_box lbox, mbox;
@@ -153,7 +142,7 @@
if (line_c != NULL)
Vect_reset_cats(line_c);
- if (Map->Constraint_region_flag)
+ if (Map->Constraint_region_flag && !ignore_constraint)
Vect_get_constraint_box(Map, &mbox);
fInfo = &(Map->fInfo.ogr);
@@ -161,7 +150,6 @@
/* Read feature to cache if necessary */
while (fInfo->lines_next == fInfo->lines_num) {
hFeature = OGR_L_GetNextFeature(fInfo->layer);
if (hFeature == NULL) {
return -2;
} /* no more features */
@@ -193,7 +181,7 @@
/* Constraint on Type of line
* Default is all of Point, Line, Area and whatever else comes along
- if (Map->Constraint_type_flag) {
+ if (Map->Constraint_type_flag && !ignore_constraint) {
if (!(itype & Map->Constraint_type)) {
fInfo->lines_next++;
continue;
@@ -201,7 +189,7 @@
/* Constraint on specified region */
- if (Map->Constraint_region_flag) {
+ if (Map->Constraint_region_flag && !ignore_constraint) {
Vect_line_box(fInfo->lines[fInfo->lines_next],
&lbox);
@@ -227,6 +215,30 @@
+ \brief Read next feature from OGR layer. Skip empty features (level 1)
+ This function implements sequential access.
+ The action of this routine can be modified by:
+ - Vect_read_constraint_region()
+ - Vect_read_constraint_type()
+ - Vect_remove_constraints()
+ \param Map pointer to Map_info structure
+ \param[out] line_p container used to store line points within
+ \param[out] line_c container used to store line categories within
+ \return feature type
+ \return -2 no more features (EOF)
+ \return -1 out of memory
+int V1_read_next_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
+ struct line_cats *line_c)
+ return read_next_line_ogr(Map, line_p, line_c, FALSE);
\brief Read next feature from OGR layer (topology level).
@@ -301,11 +313,12 @@
Vect_cat_set(line_c, 1, (int) Line->offset);
- return GV_CENTROID;
+ ret = GV_CENTROID;
+ else {
+ ret = read_next_line_ogr(Map, line_p, line_c, TRUE);
- ret = V1_read_next_line_ogr(Map, line_p, line_c);
Vect_line_box(line_p, &lbox);
if (!Vect_box_overlap(&lbox, &mbox)) {
@@ -328,8 +341,8 @@
\return -1 on error
-static int read_line(const struct Map_info *Map, OGRGeometryH hGeom, long offset,
- struct line_pnts *Points)
+int read_line(const struct Map_info *Map, OGRGeometryH hGeom, long offset,
+ struct line_pnts *Points)
int i, nPoints;
int eType, line;
@@ -401,7 +414,7 @@
\return -1 on error
-static int get_line_type(const struct Map_info *Map, long FID)
+int get_line_type(const struct Map_info *Map, long FID)
int eType;
OGRFeatureH hFeat;
