[GRASS-SVN] r49148 - in grass/trunk: db/db.columns db/db.connect
db/db.copy db/db.createdb db/db.drivers db/db.execute db/db.login
db/db.select db/db.tables display/d.barscale display/d.colorlist
display/d.colors display/d.colortable display/d.erase display/d.font
display/d.fontlist display/d.geodesic display/d.graph display/d.grid
display/d.his display/d.histogram display/d.info display/d.labels
display/d.legend display/d.linegraph display/d.measure display/d.mon
display/d.path display/d.rast display/d.rast.arrow display/d.rast.num
display/d.rgb display/d.rhumbline display/d.text display/d.thematic.area
display/d.title display/d.vect display/d.what.rast display/d.what.vect
display/d.where display/d.zoom doc/vector general/g.access general/g.copy
general/g.filename general/g.findetc general/g.findfile general/g.gisenv
general/g.gui general/g.list general/g.mapsets general/g.message
general/g.mkfontcap general/g.mlist general/g.mremove general/g.parser
general/g.pnmcat general/g.
proj general/g.region general/g.remove general/g.rename general/g.setproj
general/g.tempfile general/g.version imagery/i.albedo imagery/i.aster.toar
imagery/i.atcorr imagery/i.biomass imagery/i.cca imagery/i.class
imagery/i.cluster imagery/i.eb.eta imagery/i.eb.evapfr imagery/i.eb.netrad
imagery/i.eb.soilheatflux imagery/i.emissivity imagery/i.evapo.mh
imagery/i.evapo.pm imagery/i.evapo.pt imagery/i.evapo.time imagery/i.fft
imagery/i.gensig imagery/i.gensigset imagery/i.group imagery/i.his.rgb
imagery/i.ifft imagery/i.landsat.acca imagery/i.landsat.toar
imagery/i.latlong imagery/i.maxlik imagery/i.modis.qc imagery/i.pca
imagery/i.points imagery/i.rectify imagery/i.rgb.his imagery/i.smap
imagery/i.sunhours imagery/i.target imagery/i.vi imagery/i.vpoints
imagery/i.zc lib/cairodriver lib/htmldriver lib/init lib/pngdriver
lib/psdriver lib/vector misc/m.cogo misc/m.measure misc/m.nviz.image
misc/m.nviz.script misc/m.transform ps/ps.map raster/r.basins.fill
raster/r.bitpattern ras
ter/r.buffer raster/r.category raster/r.circle raster/r.clump raster/r.coin
raster/r.colors raster/r.colors.out raster/r.composite raster/r.compress
raster/r.cost raster/r.covar raster/r.cross raster/r.describe
raster/r.digit raster/r.distance raster/r.drain raster/r.external
raster/r.external.out raster/r.fill.dir raster/r.flow raster/r.grow
raster/r.grow.distance raster/r.gwflow raster/r.his raster/r.horizon
raster/r.in.arc raster/r.in.ascii raster/r.in.bin raster/r.in.gdal
raster/r.in.gridatb raster/r.in.lidar raster/r.in.mat raster/r.in.png
raster/r.in.poly raster/r.in.xyz raster/r.info raster/r.kappa raster/r.lake
raster/r.li raster/r.los raster/r.mapcalc raster/r.mfilter raster/r.mode
raster/r.neighbors raster/r.null raster/r.out.arc raster/r.out.ascii
raster/r.out.bin raster/r.out.gdal raster/r.out.gridatb raster/r.out.mpeg
raster/r.out.png raster/r.out.pov raster/r.out.ppm raster/r.out.ppm3
raster/r.out.tiff raster/r.out.vrml raster/r.param.scale raster/r.patch
raste
r/r.profile raster/r.proj raster/r.quant raster/r.quantile raster/r.random
raster/r.random.cells raster/r.random.surface raster/r.reclass
raster/r.recode raster/r.region raster/r.regression.line raster/r.report
raster/r.resamp.bspline raster/r.resamp.filter raster/r.resamp.interp
raster/r.resamp.rst raster/r.resamp.stats raster/r.resample raster/r.ros
raster/r.series raster/r.slope.aspect raster/r.solute.transport
raster/r.spread raster/r.spreadpath raster/r.statistics
raster/r.statistics3 raster/r.stats raster/r.sun raster/r.sunmask
raster/r.support raster/r.surf.area raster/r.surf.contour
raster/r.surf.fractal raster/r.surf.gauss raster/r.surf.idw
raster/r.surf.idw2 raster/r.surf.random raster/r.terraflow raster/r.texture
raster/r.thin raster/r.timestamp raster/r.to.vect raster/r.topidx
raster/r.topmodel raster/r.transect raster/r.univar raster/r.uslek
raster/r.usler raster/r.volume raster/r.walk raster/r.water.outlet
raster/r.what raster/r.what.color raster3d/r3.cross.ras
t raster3d/r3.gwflow raster3d/r3.in.ascii raster3d/r3.in.v5d
raster3d/r3.mask raster3d/r3.mkdspf raster3d/r3.out.ascii
raster3d/r3.out.v5d raster3d/r3.out.vtk raster3d/r3.showdspf
raster3d/r3.stats raster3d/r3.timestamp scripts/d.correlate
scripts/d.out.gpsdrive scripts/d.polar scripts/d.rast.edit
scripts/d.rast.leg scripts/d.redraw scripts/d.shadedmap
scripts/d.vect.thematic scripts/db.dropcolumn scripts/db.droptable
scripts/db.in.ogr scripts/db.out.ogr scripts/db.test scripts/g.extension
scripts/i.fusion.brovey scripts/i.in.spotvgt scripts/i.landsat.rgb
scripts/i.oif scripts/i.tasscap scripts/m.proj scripts/r.blend
scripts/r.buffer scripts/r.colors.stddev scripts/r.fillnulls scripts/r.grow
scripts/r.in.srtm scripts/r.in.wms scripts/r.mapcalculator scripts/r.mask
scripts/r.out.xyz scripts/r.pack scripts/r.plane scripts/r.shaded.relief
scripts/r.tileset scripts/r.unpack scripts/r3.mapcalculator
scripts/v.build.all scripts/v.centroids scripts/v.convert.all
scripts/v.db.addcol
umn scripts/v.db.addtable scripts/v.db.dropcolumn scripts/v.db.droptable
scripts/v.db.join scripts/v.db.reconnect.all scripts/v.db.renamecolumn
scripts/v.db.univar scripts/v.db.update scripts/v.dissolve
scripts/v.in.geonames scripts/v.in.gns scripts/v.in.gps scripts/v.in.lines
scripts/v.in.mapgen scripts/v.in.sites.all scripts/v.in.wfs scripts/v.krige
scripts/v.out.gps scripts/v.rast.stats scripts/v.report scripts/v.what.vect
scripts/wxpyimgview sites/s.in.ascii sites/s.out.ascii vector/v.buffer
vector/v.build vector/v.build.polylines vector/v.category vector/v.class
vector/v.clean vector/v.colors vector/v.colors.out vector/v.convert
vector/v.db.connect vector/v.db.select vector/v.delaunay vector/v.distance
vector/v.drape vector/v.edit vector/v.external vector/v.external.out
vector/v.extract vector/v.extrude vector/v.generalize vector/v.hull
vector/v.in.ascii vector/v.in.db vector/v.in.dwg vector/v.in.dxf
vector/v.in.lidar vector/v.in.ogr vector/v.info vector/v.kcv vector/v.
kernel vector/v.label vector/v.label.sa vector/v.lidar.edgedetection
vector/v.lrs vector/v.mkgrid vector/v.neighbors vector/v.net
vector/v.net.alloc vector/v.net.allpairs vector/v.net.bridge
vector/v.net.centrality vector/v.net.components vector/v.net.connectivity
vector/v.net.distance vector/v.net.flow vector/v.net.iso vector/v.net.path
vector/v.net.salesman vector/v.net.spanningtree vector/v.net.steiner
vector/v.net.timetable vector/v.net.visibility vector/v.normal
vector/v.out.ascii vector/v.out.dxf vector/v.out.ogr vector/v.out.svg
vector/v.out.vtk vector/v.outlier vector/v.overlay vector/v.parallel
vector/v.patch vector/v.perturb vector/v.proj vector/v.qcount
vector/v.random vector/v.reclass vector/v.sample vector/v.segment
vector/v.select vector/v.support vector/v.surf.bspline vector/v.surf.idw
vector/v.surf.rst vector/v.to.3d vector/v.to.db vector/v.to.points
vector/v.to.rast vector/v.to.rast3 vector/v.transform vector/v.type
vector/v.univar vector/v.vect.stats vector
/v.vol.rst vector/v.voronoi vector/v.what vector/v.what.rast
visualization/wximgview visualization/xganim visualization/ximgview
svn_grass at osgeo.org
Tue Nov 8 16:24:20 EST 2011
Author: neteler
Date: 2011-11-08 13:24:20 -0800 (Tue, 08 Nov 2011)
New Revision: 49148
grass/trunk/db/db.columns/db.columns.html
grass/trunk/db/db.connect/db.connect.html
grass/trunk/db/db.copy/db.copy.html
grass/trunk/db/db.createdb/db.createdb.html
grass/trunk/db/db.drivers/db.drivers.html
grass/trunk/db/db.execute/db.execute.html
grass/trunk/db/db.login/db.login.html
grass/trunk/db/db.select/db.select.html
grass/trunk/db/db.tables/db.tables.html
grass/trunk/display/d.barscale/d.barscale.html
grass/trunk/display/d.colorlist/d.colorlist.html
grass/trunk/display/d.colors/d.colors.html
grass/trunk/display/d.colortable/d.colortable.html
grass/trunk/display/d.erase/d.erase.html
grass/trunk/display/d.font/d.font.html
grass/trunk/display/d.fontlist/d.fontlist.html
grass/trunk/display/d.geodesic/d.geodesic.html
grass/trunk/display/d.graph/d.graph.html
grass/trunk/display/d.grid/d.grid.html
grass/trunk/display/d.his/d.his.html
grass/trunk/display/d.histogram/d.histogram.html
grass/trunk/display/d.info/d.info.html
grass/trunk/display/d.labels/d.labels.html
grass/trunk/display/d.legend/d.legend.html
grass/trunk/display/d.linegraph/d.linegraph.html
grass/trunk/display/d.measure/d.measure.html
grass/trunk/display/d.mon/d.mon.html
grass/trunk/display/d.path/d.path.html
grass/trunk/display/d.rast.arrow/d.rast.arrow.html
grass/trunk/display/d.rast.num/d.rast.num.html
grass/trunk/display/d.rast/d.rast.html
grass/trunk/display/d.rgb/d.rgb.html
grass/trunk/display/d.rhumbline/d.rhumbline.html
grass/trunk/display/d.text/d.text.html
grass/trunk/display/d.thematic.area/d.thematic.area.html
grass/trunk/display/d.title/d.title.html
grass/trunk/display/d.vect/d.vect.html
grass/trunk/display/d.what.rast/d.what.rast.html
grass/trunk/display/d.what.vect/d.what.vect.html
grass/trunk/display/d.where/d.where.html
grass/trunk/display/d.zoom/d.zoom.html
grass/trunk/doc/vector/v.modules.html
grass/trunk/doc/vector/vector.html
grass/trunk/general/g.access/g.access.html
grass/trunk/general/g.copy/g.copy.html
grass/trunk/general/g.filename/g.filename.html
grass/trunk/general/g.findetc/g.findetc.html
grass/trunk/general/g.findfile/g.findfile.html
grass/trunk/general/g.gisenv/g.gisenv.html
grass/trunk/general/g.gui/g.gui.html
grass/trunk/general/g.list/g.list.html
grass/trunk/general/g.mapsets/g.mapsets.html
grass/trunk/general/g.message/g.message.html
grass/trunk/general/g.mkfontcap/g.mkfontcap.html
grass/trunk/general/g.mlist/g.mlist.html
grass/trunk/general/g.mremove/g.mremove.html
grass/trunk/general/g.parser/g.parser.html
grass/trunk/general/g.pnmcat/g.pnmcat.html
grass/trunk/general/g.proj/g.proj.html
grass/trunk/general/g.region/g.region.html
grass/trunk/general/g.remove/g.remove.html
grass/trunk/general/g.rename/g.rename.html
grass/trunk/general/g.setproj/g.setproj.html
grass/trunk/general/g.tempfile/g.tempfile.html
grass/trunk/general/g.version/g.version.html
grass/trunk/imagery/i.albedo/i.albedo.html
grass/trunk/imagery/i.aster.toar/i.aster.toar.html
grass/trunk/imagery/i.atcorr/i.atcorr.html
grass/trunk/imagery/i.biomass/i.biomass.html
grass/trunk/imagery/i.cca/i.cca.html
grass/trunk/imagery/i.class/i.class.html
grass/trunk/imagery/i.cluster/i.cluster.html
grass/trunk/imagery/i.eb.eta/i.eb.eta.html
grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html
grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html
grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
grass/trunk/imagery/i.emissivity/i.emissivity.html
grass/trunk/imagery/i.evapo.mh/i.evapo.mh.html
grass/trunk/imagery/i.evapo.pm/i.evapo.pm.html
grass/trunk/imagery/i.evapo.pt/i.evapo.pt.html
grass/trunk/imagery/i.evapo.time/i.evapo.time.html
grass/trunk/imagery/i.fft/i.fft.html
grass/trunk/imagery/i.gensig/i.gensig.html
grass/trunk/imagery/i.gensigset/i.gensigset.html
grass/trunk/imagery/i.group/i.group.html
grass/trunk/imagery/i.his.rgb/i.his.rgb.html
grass/trunk/imagery/i.ifft/i.ifft.html
grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html
grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html
grass/trunk/imagery/i.latlong/i.latlong.html
grass/trunk/imagery/i.maxlik/i.maxlik.html
grass/trunk/imagery/i.modis.qc/i.modis.qc.html
grass/trunk/imagery/i.pca/i.pca.html
grass/trunk/imagery/i.points/i.points.html
grass/trunk/imagery/i.rectify/i.rectify.html
grass/trunk/imagery/i.rgb.his/i.rgb.his.html
grass/trunk/imagery/i.smap/i.smap.html
grass/trunk/imagery/i.sunhours/i.sunhours.html
grass/trunk/imagery/i.target/i.target.html
grass/trunk/imagery/i.vi/i.vi.html
grass/trunk/imagery/i.vpoints/i.vpoints.html
grass/trunk/imagery/i.zc/i.zc.html
grass/trunk/lib/cairodriver/cairodriver.html
grass/trunk/lib/htmldriver/htmldriver.html
grass/trunk/lib/init/grass7.html
grass/trunk/lib/init/helptext.html
grass/trunk/lib/init/variables.html
grass/trunk/lib/pngdriver/pngdriver.html
grass/trunk/lib/psdriver/psdriver.html
grass/trunk/lib/vector/vectorascii.html
grass/trunk/misc/m.cogo/m.cogo.html
grass/trunk/misc/m.measure/m.measure.html
grass/trunk/misc/m.nviz.image/m.nviz.image.html
grass/trunk/misc/m.nviz.script/m.nviz.script.html
grass/trunk/misc/m.transform/m.transform.html
grass/trunk/ps/ps.map/ps.map.html
grass/trunk/raster/r.basins.fill/r.basins.fill.html
grass/trunk/raster/r.bitpattern/r.bitpattern.html
grass/trunk/raster/r.buffer/r.buffer2.html
grass/trunk/raster/r.category/r.category.html
grass/trunk/raster/r.circle/r.circle.html
grass/trunk/raster/r.clump/r.clump.html
grass/trunk/raster/r.coin/r.coin.html
grass/trunk/raster/r.colors.out/r.colors.out.html
grass/trunk/raster/r.colors.out/r3.colors.out.html
grass/trunk/raster/r.colors/r.colors.html
grass/trunk/raster/r.colors/r3.colors.html
grass/trunk/raster/r.composite/r.composite.html
grass/trunk/raster/r.compress/r.compress.html
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.covar/r.covar.html
grass/trunk/raster/r.cross/r.cross.html
grass/trunk/raster/r.describe/r.describe.html
grass/trunk/raster/r.digit/r.digit.html
grass/trunk/raster/r.distance/r.distance.html
grass/trunk/raster/r.drain/r.drain.html
grass/trunk/raster/r.external.out/r.external.out.html
grass/trunk/raster/r.external/r.external.html
grass/trunk/raster/r.fill.dir/r.fill.dir.html
grass/trunk/raster/r.flow/r.flow.html
grass/trunk/raster/r.grow.distance/r.grow.distance.html
grass/trunk/raster/r.grow/r.grow.html
grass/trunk/raster/r.gwflow/r.gwflow.html
grass/trunk/raster/r.his/r.his.html
grass/trunk/raster/r.horizon/r.horizon.html
grass/trunk/raster/r.in.arc/r.in.arc.html
grass/trunk/raster/r.in.ascii/r.in.ascii.html
grass/trunk/raster/r.in.bin/r.in.bin.html
grass/trunk/raster/r.in.gdal/r.in.gdal.html
grass/trunk/raster/r.in.gridatb/r.in.gridatb.html
grass/trunk/raster/r.in.lidar/r.in.lidar.html
grass/trunk/raster/r.in.mat/r.in.mat.html
grass/trunk/raster/r.in.png/r.in.png.html
grass/trunk/raster/r.in.poly/r.in.poly.html
grass/trunk/raster/r.in.xyz/r.in.xyz.html
grass/trunk/raster/r.info/r.info.html
grass/trunk/raster/r.kappa/r.kappa.html
grass/trunk/raster/r.lake/r.lake.html
grass/trunk/raster/r.li/r.li.html
grass/trunk/raster/r.los/r.los.html
grass/trunk/raster/r.mapcalc/r.mapcalc.html
grass/trunk/raster/r.mapcalc/r3.mapcalc.html
grass/trunk/raster/r.mfilter/r.mfilter.html
grass/trunk/raster/r.mode/r.mode.html
grass/trunk/raster/r.neighbors/r.neighbors.html
grass/trunk/raster/r.null/r.null.html
grass/trunk/raster/r.out.arc/r.out.arc.html
grass/trunk/raster/r.out.ascii/r.out.ascii.html
grass/trunk/raster/r.out.bin/r.out.bin.html
grass/trunk/raster/r.out.gdal/r.out.gdal.html
grass/trunk/raster/r.out.gridatb/r.out.gridatb.html
grass/trunk/raster/r.out.mpeg/r.out.mpeg.html
grass/trunk/raster/r.out.png/r.out.png.html
grass/trunk/raster/r.out.pov/r.out.pov.html
grass/trunk/raster/r.out.ppm/r.out.ppm.html
grass/trunk/raster/r.out.ppm3/r.out.ppm3.html
grass/trunk/raster/r.out.tiff/r.out.tiff.html
grass/trunk/raster/r.out.vrml/r.out.vrml.html
grass/trunk/raster/r.param.scale/r.param.scale.html
grass/trunk/raster/r.patch/r.patch.html
grass/trunk/raster/r.profile/r.profile.html
grass/trunk/raster/r.proj/r.proj.html
grass/trunk/raster/r.quant/r.quant.html
grass/trunk/raster/r.quantile/r.quantile.html
grass/trunk/raster/r.random.cells/r.random.cells.html
grass/trunk/raster/r.random.surface/r.random.surface.html
grass/trunk/raster/r.random/r.random.html
grass/trunk/raster/r.reclass/r.reclass.html
grass/trunk/raster/r.recode/r.recode.html
grass/trunk/raster/r.region/r.region.html
grass/trunk/raster/r.regression.line/r.regression.line.html
grass/trunk/raster/r.report/r.report.html
grass/trunk/raster/r.resamp.bspline/r.resamp.bspline.html
grass/trunk/raster/r.resamp.filter/r.resamp.filter.html
grass/trunk/raster/r.resamp.interp/r.resamp.interp.html
grass/trunk/raster/r.resamp.rst/r.resamp.rst.html
grass/trunk/raster/r.resamp.stats/r.resamp.stats.html
grass/trunk/raster/r.resample/r.resample.html
grass/trunk/raster/r.ros/r.ros.html
grass/trunk/raster/r.series/r.series.html
grass/trunk/raster/r.slope.aspect/r.slope.aspect.html
grass/trunk/raster/r.solute.transport/r.solute.transport.html
grass/trunk/raster/r.spread/r.spread.html
grass/trunk/raster/r.spreadpath/r.spreadpath.html
grass/trunk/raster/r.statistics/r.statistics.html
grass/trunk/raster/r.statistics3/r.statistics3.html
grass/trunk/raster/r.stats/r.stats.html
grass/trunk/raster/r.sun/r.sun.html
grass/trunk/raster/r.sunmask/r.sunmask.html
grass/trunk/raster/r.support/r.support.html
grass/trunk/raster/r.surf.area/r.surf.area.html
grass/trunk/raster/r.surf.contour/r.surf.contour.html
grass/trunk/raster/r.surf.fractal/r.surf.fractal.html
grass/trunk/raster/r.surf.gauss/r.surf.gauss.html
grass/trunk/raster/r.surf.idw/r.surf.idw.html
grass/trunk/raster/r.surf.idw2/r.surf.idw2.html
grass/trunk/raster/r.surf.random/r.surf.random.html
grass/trunk/raster/r.terraflow/r.terraflow.html
grass/trunk/raster/r.texture/r.texture.html
grass/trunk/raster/r.thin/r.thin.html
grass/trunk/raster/r.timestamp/r.timestamp.html
grass/trunk/raster/r.to.vect/r.to.vect.html
grass/trunk/raster/r.topidx/r.topidx.html
grass/trunk/raster/r.topmodel/r.topmodel.html
grass/trunk/raster/r.transect/r.transect.html
grass/trunk/raster/r.univar/r.univar.html
grass/trunk/raster/r.univar/r3.univar.html
grass/trunk/raster/r.uslek/r.uslek.html
grass/trunk/raster/r.usler/r.usler.html
grass/trunk/raster/r.volume/r.volume.html
grass/trunk/raster/r.walk/r.walk.html
grass/trunk/raster/r.water.outlet/r.water.outlet.html
grass/trunk/raster/r.what.color/r.what.color.html
grass/trunk/raster/r.what/r.what.html
grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html
grass/trunk/raster3d/r3.gwflow/r3.gwflow.html
grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html
grass/trunk/raster3d/r3.in.v5d/r3.in.v5d.html
grass/trunk/raster3d/r3.mask/r3.mask.html
grass/trunk/raster3d/r3.mkdspf/r3.mkdspf.html
grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html
grass/trunk/raster3d/r3.out.v5d/r3.out.v5d.html
grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html
grass/trunk/raster3d/r3.showdspf/r3.showdspf.html
grass/trunk/raster3d/r3.showdspf/r3.showdspf_opengl_mods.html
grass/trunk/raster3d/r3.stats/r3.stats.html
grass/trunk/raster3d/r3.timestamp/r3.timestamp.html
grass/trunk/scripts/d.correlate/d.correlate.html
grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html
grass/trunk/scripts/d.polar/d.polar.html
grass/trunk/scripts/d.rast.edit/d.rast.edit.html
grass/trunk/scripts/d.rast.leg/d.rast.leg.html
grass/trunk/scripts/d.redraw/d.redraw.html
grass/trunk/scripts/d.shadedmap/d.shadedmap.html
grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html
grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html
grass/trunk/scripts/db.droptable/db.droptable.html
grass/trunk/scripts/db.in.ogr/db.in.ogr.html
grass/trunk/scripts/db.out.ogr/db.out.ogr.html
grass/trunk/scripts/db.test/db.test.html
grass/trunk/scripts/g.extension/g.extension.html
grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.html
grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.html
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html
grass/trunk/scripts/i.oif/i.oif.html
grass/trunk/scripts/i.tasscap/i.tasscap.html
grass/trunk/scripts/m.proj/m.proj.html
grass/trunk/scripts/r.blend/r.blend.html
grass/trunk/scripts/r.buffer/r.buffer.html
grass/trunk/scripts/r.colors.stddev/r.colors.stddev.html
grass/trunk/scripts/r.fillnulls/r.fillnulls.html
grass/trunk/scripts/r.grow/r.grow.html
grass/trunk/scripts/r.in.srtm/r.in.srtm.html
grass/trunk/scripts/r.in.wms/r.in.wms.html
grass/trunk/scripts/r.mapcalculator/r.mapcalculator.html
grass/trunk/scripts/r.mask/r.mask.html
grass/trunk/scripts/r.out.xyz/r.out.xyz.html
grass/trunk/scripts/r.pack/r.pack.html
grass/trunk/scripts/r.plane/r.plane.html
grass/trunk/scripts/r.shaded.relief/r.shaded.relief.html
grass/trunk/scripts/r.tileset/r.tileset.html
grass/trunk/scripts/r.unpack/r.unpack.html
grass/trunk/scripts/r3.mapcalculator/r3.mapcalculator.html
grass/trunk/scripts/v.build.all/v.build.all.html
grass/trunk/scripts/v.centroids/v.centroids.html
grass/trunk/scripts/v.convert.all/v.convert.all.html
grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.html
grass/trunk/scripts/v.db.addtable/v.db.addtable.html
grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.html
grass/trunk/scripts/v.db.droptable/v.db.droptable.html
grass/trunk/scripts/v.db.join/v.db.join.html
grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html
grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.html
grass/trunk/scripts/v.db.univar/v.db.univar.html
grass/trunk/scripts/v.db.update/v.db.update.html
grass/trunk/scripts/v.dissolve/v.dissolve.html
grass/trunk/scripts/v.in.geonames/v.in.geonames.html
grass/trunk/scripts/v.in.gns/v.in.gns.html
grass/trunk/scripts/v.in.gps/v.in.gps.html
grass/trunk/scripts/v.in.lines/v.in.lines.html
grass/trunk/scripts/v.in.mapgen/v.in.mapgen.html
grass/trunk/scripts/v.in.sites.all/v.in.sites.all.html
grass/trunk/scripts/v.in.wfs/v.in.wfs.html
grass/trunk/scripts/v.krige/v.krige.html
grass/trunk/scripts/v.out.gps/v.out.gps.html
grass/trunk/scripts/v.rast.stats/v.rast.stats.html
grass/trunk/scripts/v.report/v.report.html
grass/trunk/scripts/v.what.vect/v.what.vect.html
grass/trunk/scripts/wxpyimgview/wxpyimgview.html
grass/trunk/sites/s.in.ascii/s.in.ascii.html
grass/trunk/sites/s.out.ascii/s.out.ascii.html
grass/trunk/vector/v.buffer/v.buffer.html
grass/trunk/vector/v.build.polylines/v.build.polylines.html
grass/trunk/vector/v.build/v.build.html
grass/trunk/vector/v.category/v.category.html
grass/trunk/vector/v.class/v.class.html
grass/trunk/vector/v.clean/v.clean.html
grass/trunk/vector/v.colors.out/v.colors.out.html
grass/trunk/vector/v.colors/v.colors.html
grass/trunk/vector/v.convert/v.convert.html
grass/trunk/vector/v.db.connect/v.db.connect.html
grass/trunk/vector/v.db.select/v.db.select.html
grass/trunk/vector/v.delaunay/v.delaunay.html
grass/trunk/vector/v.distance/v.distance.html
grass/trunk/vector/v.drape/v.drape.html
grass/trunk/vector/v.edit/v.edit.html
grass/trunk/vector/v.external.out/v.external.out.html
grass/trunk/vector/v.external/v.external.html
grass/trunk/vector/v.extract/v.extract.html
grass/trunk/vector/v.extrude/v.extrude.html
grass/trunk/vector/v.generalize/v.generalize.html
grass/trunk/vector/v.hull/v.hull.html
grass/trunk/vector/v.in.ascii/v.in.ascii.html
grass/trunk/vector/v.in.db/v.in.db.html
grass/trunk/vector/v.in.dwg/v.in.dwg.html
grass/trunk/vector/v.in.dxf/v.in.dxf.html
grass/trunk/vector/v.in.lidar/v.in.lidar.html
grass/trunk/vector/v.in.ogr/v.in.ogr.html
grass/trunk/vector/v.info/v.info.html
grass/trunk/vector/v.kcv/v.kcv.html
grass/trunk/vector/v.kernel/v.kernel.html
grass/trunk/vector/v.label.sa/v.label.sa.html
grass/trunk/vector/v.label/v.label.html
grass/trunk/vector/v.lidar.edgedetection/v.lidar.edgedetection.html
grass/trunk/vector/v.lrs/lrs.html
grass/trunk/vector/v.mkgrid/v.mkgrid.html
grass/trunk/vector/v.neighbors/v.neighbors.html
grass/trunk/vector/v.net.alloc/v.net.alloc.html
grass/trunk/vector/v.net.allpairs/v.net.allpairs.html
grass/trunk/vector/v.net.bridge/v.net.bridge.html
grass/trunk/vector/v.net.centrality/v.net.centrality.html
grass/trunk/vector/v.net.components/v.net.components.html
grass/trunk/vector/v.net.connectivity/v.net.connectivity.html
grass/trunk/vector/v.net.distance/v.net.distance.html
grass/trunk/vector/v.net.flow/v.net.flow.html
grass/trunk/vector/v.net.iso/v.net.iso.html
grass/trunk/vector/v.net.path/v.net.path.html
grass/trunk/vector/v.net.salesman/v.net.salesman.html
grass/trunk/vector/v.net.spanningtree/v.net.spanningtree.html
grass/trunk/vector/v.net.steiner/v.net.steiner.html
grass/trunk/vector/v.net.timetable/v.net.timetable.html
grass/trunk/vector/v.net.visibility/v.net.visibility.html
grass/trunk/vector/v.net/v.net.html
grass/trunk/vector/v.normal/v.normal.html
grass/trunk/vector/v.out.ascii/v.out.ascii.html
grass/trunk/vector/v.out.dxf/v.out.dxf.html
grass/trunk/vector/v.out.ogr/v.out.ogr.html
grass/trunk/vector/v.out.svg/v.out.svg.html
grass/trunk/vector/v.out.vtk/v.out.vtk.html
grass/trunk/vector/v.outlier/v.outlier.html
grass/trunk/vector/v.overlay/v.overlay.html
grass/trunk/vector/v.parallel/v.parallel.html
grass/trunk/vector/v.patch/v.patch.html
grass/trunk/vector/v.perturb/v.perturb.html
grass/trunk/vector/v.proj/v.proj.html
grass/trunk/vector/v.qcount/v.qcount.html
grass/trunk/vector/v.random/v.random.html
grass/trunk/vector/v.reclass/v.reclass.html
grass/trunk/vector/v.sample/v.sample.html
grass/trunk/vector/v.segment/v.segment.html
grass/trunk/vector/v.select/v.select.html
grass/trunk/vector/v.support/v.support.html
grass/trunk/vector/v.surf.bspline/v.surf.bspline.html
grass/trunk/vector/v.surf.idw/v.surf.idw.html
grass/trunk/vector/v.surf.rst/v.surf.rst.html
grass/trunk/vector/v.to.3d/description.html
grass/trunk/vector/v.to.3d/v.to.3d.html
grass/trunk/vector/v.to.db/v.to.db.html
grass/trunk/vector/v.to.points/v.to.points.html
grass/trunk/vector/v.to.rast/v.to.rast.html
grass/trunk/vector/v.to.rast3/v.to.rast3.html
grass/trunk/vector/v.transform/v.transform.html
grass/trunk/vector/v.type/v.type.html
grass/trunk/vector/v.univar/v.univar.html
grass/trunk/vector/v.vect.stats/v.vect.stats.html
grass/trunk/vector/v.vol.rst/v.vol.rst.html
grass/trunk/vector/v.voronoi/v.voronoi.html
grass/trunk/vector/v.what.rast/v.what.rast.html
grass/trunk/vector/v.what/v.what.html
grass/trunk/visualization/wximgview/wximgview.html
grass/trunk/visualization/xganim/xganim.html
grass/trunk/visualization/ximgview/ximgview.html
avoid caps HTML tags
Modified: grass/trunk/db/db.columns/db.columns.html
--- grass/trunk/db/db.columns/db.columns.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.columns/db.columns.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,14 +17,12 @@
</pre></div>
<p>
<em>If database parameters are already set</em><br>
<div class="code"><pre>
db.columns table=markveggy
</pre></div>
<p>
<em>List columns from Shape file with DBF attribute table</em><br>
db.columns table=network driver=dbf database=/daten/grassdata/fire/PERMANENT/dbf/
Modified: grass/trunk/db/db.connect/db.connect.html
--- grass/trunk/db/db.connect/db.connect.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.connect/db.connect.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -9,14 +9,11 @@
Values are stored in the mapset's <tt>VAR</tt> file;
the connection is not tested for validity.
-<p>
-The <b>-p</b> flag will display the current connection parameters.
-<p>
-The <b>-c</b> flag will silently check if the connection parameters have
+<p>The <b>-p</b> flag will display the current connection parameters.
+<p>The <b>-c</b> flag will silently check if the connection parameters have
been set, and if not will set them to use GRASS's default values.
(useful in scripts before you attempt to create a new database table)
-<p>
-To connect a vector map to a database table, use <em>v.db.connect</em>
+<p>To connect a vector map to a database table, use <em>v.db.connect</em>
or <em>v.db.addtable</em>.
@@ -42,8 +39,7 @@
db.connect -p
db.tables -p
</pre></div>
-<p>
-The SQLite database is created automatically when used the first time.
+<p>The SQLite database is created automatically when used the first time.
<h3>ODBC</h3>
@@ -122,5 +118,4 @@
Radim Blazek, ITC-Irst, Trento, Italy
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/db/db.copy/db.copy.html
--- grass/trunk/db/db.copy/db.copy.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.copy/db.copy.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -71,5 +71,4 @@
Radim Blazek, ITC-irst, Trento, Italy
-<p>
Modified: grass/trunk/db/db.createdb/db.createdb.html
--- grass/trunk/db/db.createdb/db.createdb.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.createdb/db.createdb.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,7 +13,6 @@
</pre></div>
<p>
<em>Create a new PostgreSQL database (if PostgreSQL connection is established
through pg driver)</em><br>
Modified: grass/trunk/db/db.drivers/db.drivers.html
--- grass/trunk/db/db.drivers/db.drivers.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.drivers/db.drivers.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
<h2>EXAMPLE</h2>
Show all installed GRASS database drivers:
-<p>
-<div class="code"><pre>
+<p><div class="code"><pre>
db.drivers -p
</pre></div>
Modified: grass/trunk/db/db.execute/db.execute.html
--- grass/trunk/db/db.execute/db.execute.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.execute/db.execute.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,18 +6,15 @@
<em>db.execute</em> only executes SQL statements and does not return
any data. If you need data returned from the database, use <em>db.select</em>.
-<p>
-If parameters for database connection are already set with
+<p>If parameters for database connection are already set with
<a href="db.connect.html">db.connect</a>, they are taken as default values and
do not need to be specified each time.
-<p>
-If you have a large number of SQL commands to process, it is much much faster
+<p>If you have a large number of SQL commands to process, it is much much faster
to place all the SQL statements into a text file and use <em>db.execute</em>'s
<b>input</b> file parameter than it is to process each statement individually
in a loop. If multiple instruction lines are given, each SQL line must end
with a semicolon.
-<p>
-Please see the individual <a href="sql.html">sql driver</a> pages for how to create
+<p>Please see the individual <a href="sql.html">sql driver</a> pages for how to create
a new database.
<h2>EXAMPLES</h2>
@@ -27,63 +24,53 @@
echo 'create table soils (cat integer, soiltype varchar(10) )' | db.execute
</pre></div>
-<p>
-<em>Create a new table using a file with SQL statements:</em><br>
+<p><em>Create a new table using a file with SQL statements:</em><br>
db.execute driver=odbc database=g60test input=file.sql
</pre></div>
-<p>
-<em>Insert new row into attribute table:</em><br>
+<p><em>Insert new row into attribute table:</em><br>
echo "INSERT INTO nobugs (id,name,east_gb,north_gb) values (30,'Ala',1657340,5072301)" | db.execute
</pre></div>
-<p>
-<em>Update attribute entries to new value based on SQL rule:</em><br>
+<p><em>Update attribute entries to new value based on SQL rule:</em><br>
echo "UPDATE roads SET travelcost=5 WHERE cat=1" | db.execute
</pre></div>
-<p>
echo "UPDATE dourokukan SET testc=50 WHERE testc is NULL" | db.execute
</pre></div>
-<p>
-<em>Delete selected rows from attribute table:</em><br>
+<p><em>Delete selected rows from attribute table:</em><br>
echo "DELETE FROM gsod_stationlist WHERE latitude < -91" | db.execute
</pre></div>
-<p>
-<em>Add new column to attribute table:</em><br>
+<p><em>Add new column to attribute table:</em><br>
echo "ALTER TABLE roads ADD COLUMN length double" | db.execute
</pre></div>
-<p>
-<em>Column type conversion - update new column from existing column (all drivers except for DBF):</em><br>
+<p><em>Column type conversion - update new column from existing column (all drivers except for DBF):</em><br>
# 'z_value' is varchar and 'z' is double precision:
echo "update geodetic_pts SET z = CAST(z_value AS numeric)" | db.execute
</pre></div>
-<p>
-<em>Drop column from attribute table:</em><br>
+<p><em>Drop column from attribute table:</em><br>
echo "ALTER TABLE roads DROP COLUMN length" | db.execute
</pre></div>
-<p>
-<em>Drop table (not supported by all drivers)</em><br>
+<p><em>Drop table (not supported by all drivers)</em><br>
echo "DROP TABLE fmacopy" | db.execute
</pre></div>
-<p>
-<em>Update attribute with multiple SQL instructions in file (e.g., file.sql,
+<p><em>Update attribute with multiple SQL instructions in file (e.g., file.sql,
instruction line must end with a semicolon):</em><br>
UPDATE roads SET travelcost=5 WHERE cat=1;
@@ -92,8 +79,7 @@
cat file.sql | db.execute
</pre></div>
-<p>
-<em>Join table 'myroads' into table 'extratab' based on common 'cat' column values (not supported by DBF driver):</em><br>
+<p><em>Join table 'myroads' into table 'extratab' based on common 'cat' column values (not supported by DBF driver):</em><br>
echo "UPDATE extratab SET names=(SELECT label FROM myroads WHERE extratab.cat=myroads.cat);" | db.execute
</pre></div>
Modified: grass/trunk/db/db.login/db.login.html
--- grass/trunk/db/db.login/db.login.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.login/db.login.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,16 +17,14 @@
db.login user=bacava
</pre></div>
-<p>
-Example 2: Username and password specified (note that the command
+<p>Example 2: Username and password specified (note that the command
lines history will store the password in this way):
db.login user=bacava pass=secret
</pre></div>
-<p>
-Example 3: Username and empty password specified (note that the command
+<p>Example 3: Username and empty password specified (note that the command
Modified: grass/trunk/db/db.select/db.select.html
--- grass/trunk/db/db.select/db.select.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.select/db.select.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -22,28 +22,24 @@
</pre></div>
<p>
<em>Select all from table roads</em><br>
db.select -c driver=odbc database=g51test table=roads input=file.sql > result.csv
</pre></div>
<p>
<em>Select some string attribute, exclude others:</em><br>
echo "SELECT * FROM archsites WHERE str1 <> 'No Name'" | db.select
</pre></div>
<p>
<em>Select some string attribute with ZERO length:</em><br>
echo "SELECT * FROM archsites WHERE str1 IS NULL" | db.select
</pre></div>
<p>
<em>Select coordinates from PostGIS table:</em><br>
echo "SELECT x(geo),y(geo) FROM localizzazione" | db.select
Modified: grass/trunk/db/db.tables/db.tables.html
--- grass/trunk/db/db.tables/db.tables.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/db/db.tables/db.tables.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -16,7 +16,6 @@
</pre></div>
<p>
<em>List all tables of existing dbf database</em><br>
db.tables driver=dbf database=/home/user/grassdata/fire/PERMANENT/dbf
Modified: grass/trunk/display/d.barscale/d.barscale.html
--- grass/trunk/display/d.barscale/d.barscale.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.barscale/d.barscale.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,17 +17,16 @@
<h2>SEE ALSO</h2>
<em>
-<a href="d.graph.html">d.graph</A><br>
-<a href="d.grid.html">d.grid</A><br>
-<a href="d.legend.html">d.legend</A><br>
-<a href="d.measure.html">d.measure</A><br>
-<a href="d.where.html">d.where</A><br>
-<a href="g.region.html">g.region</A><br>
+<a href="d.graph.html">d.graph</a><br>
+<a href="d.grid.html">d.grid</a><br>
+<a href="d.legend.html">d.legend</a><br>
+<a href="d.measure.html">d.measure</a><br>
+<a href="d.where.html">d.where</a><br>
+<a href="g.region.html">g.region</a><br>
</em>
<h2>AUTHOR</h2>
unknown.
-<p>
Modified: grass/trunk/display/d.colorlist/d.colorlist.html
--- grass/trunk/display/d.colorlist/d.colorlist.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.colorlist/d.colorlist.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,7 +6,7 @@
<h2>SEE ALSO</h2>
-<em><a href="d.colors.html">d.colors</A></em><br>
+<em><a href="d.colors.html">d.colors</a></em><br>
<h2>AUTHOR</h2>
Modified: grass/trunk/display/d.colors/d.colors.html
--- grass/trunk/display/d.colors/d.colors.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.colors/d.colors.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,16 +6,14 @@
raster map to the graphics monitor and then running the program
<em>d.colors</em>.
-<p>
-Any color changes made using <em>d.colors</em> will not immediately be
+<p>Any color changes made using <em>d.colors</em> will not immediately be
shown on the graphics display; however, any color changes saved will
still alter the map's color table and will appear next time the raster
-map layer is redisplayed (see <em><a href="d.colortable.html">d.colortable</A></em>).
+map layer is redisplayed (see <em><a href="d.colortable.html">d.colortable</a></em>).
-<p>
-The user must first display the relevant raster map layer to the
+<p>The user must first display the relevant raster map layer to the
active frame on the graphics monitor (e.g., using
-<em><a href="d.rast.html">d.rast</A></em>) before running
+<em><a href="d.rast.html">d.rast</a></em>) before running
<em>d.colors</em>. The user can then either enter the name of the
raster map layer whose color table is to be changed on the command
line (e.g., by typing: <tt>d.colors map=soils</tt>), or type
@@ -24,11 +22,10 @@
<em>d.colors</em> will ask the user to enter the name of an existing
raster map layer using the standard GRASS interface.
-<p>
-In either case, the user is then presented with the <em>d.colors</em>
+<p>In either case, the user is then presented with the <em>d.colors</em>
command menu, shown below.
<!-- This menu is the same as the category and color
-changing portion of the <em><a href="d.display.html">d.display</A></em>
+changing portion of the <em><a href="d.display.html">d.display</a></em>
menu. -->
The <em>d.colors</em> commands are listed beneath the Category
Pointer Movement, Color Modification, Replotting Screen, and Quitting
@@ -86,7 +83,6 @@
current color.
<p>
Changing colors - The color associated with the current category can be
changed with the
<b>"R, r, G, g, B,"</b>
@@ -107,7 +103,6 @@
intensities are listed on the text screen in as percentages.
<p>
Keys <b>I</b> and <b>i</b> increase and decrease the
percentage change that each keystroke of one of the color
keys (<em>R, r, G, g, B, b</em>) causes in its respective
@@ -116,7 +111,6 @@
red component of the current category by 10%.
<p>
Highlight - The
<b>h</b>
key toggles between the current category color and the current
@@ -130,14 +124,12 @@
at any one time.
<p>
Saving the current color table -
Pressing the <b>c</b> key will save the current color table as you have
modified it. This table will then be used next time you
display or paint this raster map layer.
<p>
Color table toggle - Different types of color tables are suitable for
different raster map layers.
The key
@@ -146,7 +138,6 @@
scale; smooth changing color wave; random colors; and the saved color table.
<p>
Color table shift - The entire table is shifted up and down using the
<b>+</b>
and
@@ -154,7 +145,6 @@
keys.
<p>
Quitting the <em>d.colors</em> program - Pressing the
<b>Q</b> key will cause you to quit the <em>d.colors</em>
program. If colors have been modified but not saved,
@@ -172,7 +162,6 @@
<h2>NOTES</h2>
<p>
The map whose color table is to be altered with
<em>d.colors</em> must already be on display in the active
display frame on the graphics monitor before
@@ -180,8 +169,7 @@
command <em><a href="d.rast.html">d.rast</a> map=name</em> (where <em>name</em> is a raster map
layer whose color table the user wishes to alter).
-<p>
-Some color monitors may not support the full range of colors required
+<p>Some color monitors may not support the full range of colors required
to display all of the map's categories listed in the map's color table.
However, regardless of whether the user can see the color changes he is
effecting to a map's color table, any changes to a map's color table
@@ -190,9 +178,9 @@
<h2>SEE ALSO</h2>
<em>
-<a href="d.colortable.html">d.colortable</A>,
-<a href="d.rast.html">d.rast</A>,
-<a href="r.colors.html">r.colors</A>
+<a href="d.colortable.html">d.colortable</a>,
+<a href="d.rast.html">d.rast</a>,
+<a href="r.colors.html">r.colors</a>
</em>
<h2>AUTHOR</h2>
@@ -200,6 +188,5 @@
James Westervelt, U.S. Army Construction Engineering
Research Laboratory
-<p>
Modified: grass/trunk/display/d.colortable/d.colortable.html
--- grass/trunk/display/d.colortable/d.colortable.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.colortable/d.colortable.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,16 +6,14 @@
an available raster map layer in the user's current mapset search path
and location.
-<p>
-If the <em>values</em> of both <em>lines</em> and <em>cols</em> are
+<p>If the <em>values</em> of both <em>lines</em> and <em>cols</em> are
not specified by the user, <em>d.colortable</em>
divides the active frame equally among the number of categories
present in the named raster map layer. If one option is specified,
the other is automatically set to accommodate all categories.
If both are specified, as many categories as possible are displayed.
-<p>
-If the user specifies the name of a map on the command line but does not
+<p>If the user specifies the name of a map on the command line but does not
specify the values of other parameters, parameter default values will be used.
Alternately, if the user types simply <em>d.colortable</em> on the command line
without any program arguments, the program will prompt the user for parameter
@@ -55,24 +53,22 @@
(a total of six cells),
only six of the ten map categories will be displayed.
-<p>
-The user should run the GRASS program
-<em><a href="d.erase.html">d.erase</A></em> between
+<p>The user should run the GRASS program
+<em><a href="d.erase.html">d.erase</a></em> between
runs of <em>d.colortable</em> to avoid confusion.
<h2>SEE ALSO</h2>
<em>
-<a href="d.colors.html">d.colors</A><br>
-<a href="d.erase.html">d.erase</A><br>
+<a href="d.colors.html">d.colors</a><br>
+<a href="d.erase.html">d.erase</a><br>
</em>
<h2>AUTHOR</h2>
James Westervelt, U.S. Army Construction Engineering Research Laboratory
-<p>
Modified: grass/trunk/display/d.erase/d.erase.html
--- grass/trunk/display/d.erase/d.erase.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.erase/d.erase.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -18,5 +18,4 @@
Laboratory
-<p>
Modified: grass/trunk/display/d.font/d.font.html
--- grass/trunk/display/d.font/d.font.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.font/d.font.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,25 +1,22 @@
<h2>DESCRIPTION</h2>
<em>d.font</em> allows the user to select use of a specific text font for
display of text on the graphics monitor.
The GRASS program
-<em><a href="../html/show.fonts.sh.html">show.fonts.sh</A></em>
+<em><a href="../html/show.fonts.sh.html">show.fonts.sh</a></em>
is a UNIX Bourne shell macro which
names and displays the fonts that can be selected using <em>d.font</em>.
If the user does not specify a font when using other GRASS programs
that display text, the font type <em>romans</em> is used by default.
-<p>
-The user can run this program either non-interactively or interactively.
+<p>The user can run this program either non-interactively or interactively.
If the user specifies a font type name on the command line the program will
run non-interactively.
Alternately, the user can simply type <b>d.font</b> on the command line;
in this case, the program will prompt the user for a display
text font type.
-<p>
-<b>Parameter:</b>
+<p><b>Parameter:</b>
<dl>
<dt><b>font=</b><em>name</em>
<dd>Name of a font type, from among the font types italicized below.
@@ -56,16 +53,15 @@
<h2>SEE ALSO</h2>
-<em><a href="d.text.html">d.text</A></em><br>
-<em><a href="d.title.html">d.title</A></em>
+<em><a href="d.text.html">d.text</a></em><br>
+<em><a href="d.title.html">d.title</a></em>
<h2>AUTHOR</h2>
Research Laboratory
-<p>
-<em>d.font</em> uses the public domain version of the Hershey Fonts created
+<p><em>d.font</em> uses the public domain version of the Hershey Fonts created
by Dr. A.V. Hershey while working at the U.S. National Bureau of
Standards.
Modified: grass/trunk/display/d.fontlist/d.fontlist.html
--- grass/trunk/display/d.fontlist/d.fontlist.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.fontlist/d.fontlist.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,8 @@
<h2>SEE ALSO</h2>
-<em><a href="parser.html">parser</A></em>
+<em><a href="parser.html">parser</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/display/d.geodesic/d.geodesic.html
--- grass/trunk/display/d.geodesic/d.geodesic.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.geodesic/d.geodesic.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,13 +15,11 @@
to be drawn. The default line color (black) and text color (red)
will be used.
-<p>
-Alternately, the user can specify the starting and ending coordinates
+<p>Alternately, the user can specify the starting and ending coordinates
of the geodesic, line color, and text color on the command line,
and run the program non-interactively.
-<p>
-Once the user indicates the starting and ending coordinates
+<p>Once the user indicates the starting and ending coordinates
of the geodesic, the line and its length (in miles) are displayed to
the user's graphics monitor. If the text color is set to <em>none</em>,
the great circle distance is not displayed.
@@ -35,8 +33,7 @@
d.geodesic coor=55:58W,33:18S,26:43E,60:37N lcolor=yellow tcolor=red
</pre></div>
-<p>
-<center>
+<p><center>
<img src="d_geodesic.png" border=1><br>
<i>Geodesic line (great circle line)</i>
</center>
@@ -48,7 +45,7 @@
<h2>SEE ALSO</h2>
-<em><a href="d.rhumbline.html">d.rhumbline</A></em>
+<em><a href="d.rhumbline.html">d.rhumbline</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/display/d.graph/d.graph.html
--- grass/trunk/display/d.graph/d.graph.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.graph/d.graph.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,7 +8,6 @@
Coordinates are given either as a percentage of frame height and width
(default) or in geographic coordinates (with the <b>-m</b> flag).
<p>
The program can be run interactively or non-interactively.
The user can run the program completely non-interactively
by specifying the name of a graphics file containing the
@@ -22,15 +21,13 @@
graphics commands from standard input (i.e., the keyboard) and
will (silently) prompt the user for these graphics commands.
-<p>
-Alternately, the user can simply type <b>d.graph</b> on the command line,
+<p>Alternately, the user can simply type <b>d.graph</b> on the command line,
and be prompted for the values of all parameters<!-- (the user can still
input graphics commands from either an input file or standard input
using this form)-->. In this case, the user is presented with the standard
GRASS GUI interface.
-<p>
-The default coordinate system used is 0-100 percent of the active frame
+<p>The default coordinate system used is 0-100 percent of the active frame
in x and similarly 0-100 in y,
regardless of the graphics monitor display frame size and aspect.
The (0,0) location is the lower left corner of the active graphics
@@ -40,8 +37,7 @@
<h2>COMMANDS</h2>
-<p>
-The graphics language is simple, and uses the following commands:
+<p>The graphics language is simple, and uses the following commands:
<br>
<dl>
<dd>[
@@ -172,8 +168,7 @@
Note that the coordinates in the <em><a href="grass_logo.txt">grass_logo.txt</a></em> file were
taken directly off an image drawn by hand on graph paper.
<!-- formerly names "grass.logo.sh" in GRASS 5 code. -->
-<p>
-A dynamic example can be found in the <em>d.polar</em> shell script.
+<p>A dynamic example can be found in the <em>d.polar</em> shell script.
<h3>Draw a "star" symbol at a given map coordinate</h3>
@@ -222,14 +217,14 @@
<h2>SEE ALSO</h2>
-<em><a href="d.font.html">d.font</A></em><br>
-<em><a href="d.frame.html">d.frame</A></em><br>
-<em><a href="d.labels.html">d.labels</A></em><br>
-<!-- <em><a href="d.mapgraph.html">d.mapgraph</A></em><br> superseded by -m -->
-<em><a href="d.polar.html">d.polar</A></em><br>
-<em><a href="d.where.html">d.where</A></em><br>
-<!-- <em><a href="grass.logo.sh.html">grass.logo.sh</A></em><br> -->
+<em><a href="d.font.html">d.font</a></em><br>
+<em><a href="d.frame.html">d.frame</a></em><br>
+<em><a href="d.labels.html">d.labels</a></em><br>
+<!-- <em><a href="d.mapgraph.html">d.mapgraph</a></em><br> superseded by -m -->
+<em><a href="d.polar.html">d.polar</a></em><br>
+<em><a href="d.where.html">d.where</a></em><br>
+<!-- <em><a href="grass.logo.sh.html">grass.logo.sh</a></em><br> -->
<h2>AUTHOR</h2>
Modified: grass/trunk/display/d.grid/d.grid.html
--- grass/trunk/display/d.grid/d.grid.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.grid/d.grid.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,7 +7,6 @@
the contents of the active display frame.
<p>
<em>d.grid</em> can be run non-interactively or
interactively. If the user specifies the grid
<em>size</em> and (optionally) the grid <em>color</em> on
@@ -26,25 +25,21 @@
of <em>d.grid</em>; multiple invocations of <em>d.grid</em>
will therefore result in the drawing of multiple grids
inside the active graphics frame. (A command like
-<em><a href="d.erase.html">d.erase</A></em>, which erases the
+<em><a href="d.erase.html">d.erase</a></em>, which erases the
entire contents of the active display frame, must be run to
erase previously drawn grids from the display frame.)
-<p>
-If the user provides a
+<p>If the user provides a
<em>-g</em> flag a geographic (projected) grid
will be drawn. With the <em>-g</em> flag the <em>size</em>
argument accepts both decimal degrees and colon separated
ddd:mm:ss coordinates (eg. <tt>00:30:00</tt> for half of a degree).
-<p>
-A geographic grid cannot be drawn for a <em>latitude/longitude</em>
+<p>A geographic grid cannot be drawn for a <em>latitude/longitude</em>
or <em>XY</em> projection.
-<p>
-Colors may be standard named GRASS colors (red, green, aqua, etc.) or
+<p>Colors may be standard named GRASS colors (red, green, aqua, etc.) or
a numerical R:G:B triplet, where component values range from 0-255.<br>
-<p>
-The grid drawing may be turned off by using the <em>-n</em> flag.<br>
+<p>The grid drawing may be turned off by using the <em>-n</em> flag.<br>
The border drawing may be turned off by using the <em>-b</em> flag.<br>
The coordinate text may be turned off by using the <em>-t</em> flag.<br>
@@ -67,13 +62,13 @@
<h2>SEE ALSO</h2>
-<em><a href="d.barscale.html">d.barscale</A></em><br>
-<em><a href="d.legend.html">d.legend</A></em><br>
-<em><a href="d.geodesic.html">d.geodesic</A></em><br>
-<em><a href="d.rhumbline.html">d.rhumbline</A></em><br>
-<em><a href="d.erase.html">d.erase</A></em><br>
-<em><a href="d.rast.html">d.rast</A></em><br>
+<em><a href="d.barscale.html">d.barscale</a></em><br>
+<em><a href="d.legend.html">d.legend</a></em><br>
+<em><a href="d.geodesic.html">d.geodesic</a></em><br>
+<em><a href="d.rhumbline.html">d.rhumbline</a></em><br>
+<em><a href="d.erase.html">d.erase</a></em><br>
+<em><a href="d.rast.html">d.rast</a></em><br>
Modified: grass/trunk/display/d.his/d.his.html
--- grass/trunk/display/d.his/d.his.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.his/d.his.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,7 +7,6 @@
map layers.
<p>
The human brain automatically interprets the vast amount of
visual information available according to basic rules.
Color, or <em>hue</em>, is used to categorize objects.
@@ -31,7 +30,6 @@
monitor.
<p>
Alternately, the user can run the program interactively by
typing <b>d.his</b> without naming parameter values on the
command line. In this case, the program will prompt the
@@ -39,7 +37,6 @@
GUI interface.
<p>
While any raster map layer can be used to represent the hue
information, map layers with a few very distinct colors
work best. Only raster map layers representing
@@ -48,7 +45,6 @@
intensity and saturation information.
<p>
For example, a visually pleasing image can be
made by using a watershed map for the <em>hue</em> factor,
an aspect map for the <em>intensity</em> factor, and an
@@ -58,8 +54,7 @@
an aircraft looking at a terrain on a sunny day with a bit
of haze in the valleys.
-<p>
-The <b>brighten</b> option does not truly represent a percentage,
+<p>The <b>brighten</b> option does not truly represent a percentage,
but calling it that makes the option easy to understand, and it
sounds better than <i>Normalized Scaling Factor</i>.
@@ -74,8 +69,8 @@
should have an appropriate gray-scale color table
associated with it. You can ensure this by using the color
manipulation capabilities of
-<em><a href="d.colors.html">d.colors</A></em> or
-<em><a href="r.colors.html">r.colors</A></em>.
+<em><a href="d.colors.html">d.colors</a></em> or
+<em><a href="r.colors.html">r.colors</a></em>.
Finally, the color is made somewhat gray-based on the
<em>red</em> intensity of that cell in the
@@ -99,16 +94,14 @@
</pre>
<p>
Either (but not both) of the intensity or the saturation
map layers may be omitted. This means that it is possible
to produce output images that represent combinations of
<em>his, hi,</em> or <em>hs</em>.
-<p>
-Users wishing to store the result in new raster map layers
+<p>Users wishing to store the result in new raster map layers
instead of displaying it on the monitor should use the
-program <em><a href="r.his.html">r.his</A></em>.
+program <em><a href="r.his.html">r.his</a></em>.
<h2>EXAMPLE</h2>
@@ -125,19 +118,18 @@
<h2>SEE ALSO</h2>
<em>
-<a href="d.colors.html">d.colors</A>,
-<a href="d.frame.html">d.frame</A>,
-<a href="d.rgb.html">d.rgb</A>,
-<a href="r.colors.html">r.colors</A>,
-<a href="r.his.html">r.his</A>,
-<a href="i.his.rgb.html">i.his.rgb</A>,
-<a href="i.rgb.his.html">i.rgb.his</A>
+<a href="d.colors.html">d.colors</a>,
+<a href="d.frame.html">d.frame</a>,
+<a href="d.rgb.html">d.rgb</a>,
+<a href="r.colors.html">r.colors</a>,
+<a href="r.his.html">r.his</a>,
+<a href="i.his.rgb.html">i.his.rgb</a>,
+<a href="i.rgb.his.html">i.rgb.his</a>
</em>
<h2>AUTHOR</h2>
-<p>
Modified: grass/trunk/display/d.histogram/d.histogram.html
--- grass/trunk/display/d.histogram/d.histogram.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.histogram/d.histogram.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,8 +12,7 @@
<em>d.histogram</em> respects the current geographic region settings
and the current MASK (if one exists).
-<p>
-<em>d.histogram</em> uses the colors in the map's color look-up table
+<p><em>d.histogram</em> uses the colors in the map's color look-up table
(i.e., the map's <em>colr</em> or <em>colr2</em> file).
<h2>SEE ALSO</h2>
@@ -36,5 +35,4 @@
<br> 10560 Arrowhead Drive
<br> Fairfax, Virginia 22030
-<p>
Modified: grass/trunk/display/d.info/d.info.html
--- grass/trunk/display/d.info/d.info.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.info/d.info.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,8 +10,7 @@
Where four numbers are given the format is: left, right, top, bottom.
<br><br>
Note: GRASS display pixel coordinates are measured from the top left.
-<p>
-<br>
+<p><br>
<h2>SEE ALSO</h2>
Modified: grass/trunk/display/d.labels/d.labels.html
--- grass/trunk/display/d.labels/d.labels.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.labels/d.labels.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,7 +4,7 @@
active display frame on the graphics monitor. Each label has components
which determine the text, the location of the text on the image, its
size, and the background for the text. This file can be generated with
-the <em><a href="v.label.html">v.label</A></em> program or simply created
+the <em><a href="v.label.html">v.label</a></em> program or simply created
by the user as an ASCII file (using a text editor) and placed in the
appropriate directory under the user's current mapset and location
(i.e. <tt>$MAPSET/paint/labels/</tt>).
@@ -16,21 +16,20 @@
<!-- The unused information found in a label file is printed to standard
output. -->
This extra information is used by such programs as
-<em><a href="ps.map.html">ps.map</A></em>.
+<em><a href="ps.map.html">ps.map</a></em>.
-<p>
-This module was formerly known as <em>d.paint.labels</em>.
+<p>This module was formerly known as <em>d.paint.labels</em>.
The the old version of <em>d.labels</em> from GRASS 5, which provided
interactive placement and modification of paint labels, still needs to
have its functionality merged into this module.
<h2>SEE ALSO</h2>
-<em><a href="d.title.html">d.title</A></em><br>
-<em><a href="ps.map.html">ps.map</A></em><br>
-<em><a href="v.label.html">v.label</A></em>
+<em><a href="d.title.html">d.title</a></em><br>
+<em><a href="ps.map.html">ps.map</a></em><br>
+<em><a href="v.label.html">v.label</a></em>
<br>
<h2>AUTHOR</h2>
@@ -39,5 +38,4 @@
Research Laboratory
-<p>
Modified: grass/trunk/display/d.legend/d.legend.html
--- grass/trunk/display/d.legend/d.legend.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.legend/d.legend.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,7 +4,6 @@
raster map layer in the active frame on the graphics
monitor.
<p>
The user can run <em>d.legend</em> either non-interactively
or interactively. If the user specifies the name of a
raster <b>map</b> layer on the command line, the program
@@ -13,7 +12,6 @@
the user specifies other values on the command line.
<p>
Alternately, the user can simply type <b>d.legend</b> on the command line;
in this case, the program will prompt the user for parameter values
using the standard GRASS GUI interface.
@@ -23,49 +21,40 @@
The legend's default size is based on the dimensions of the
active frame, specifically its height. <em>d.legend</em> will only
obscure those portions of the active frame that directly underlie the legend.
-<p>
-When using the mouse or <b>at</b> to size & place the legend, a user may
+<p>When using the mouse or <b>at</b> to size & place the legend, a user may
create a horizontal legend by making the box wider than it is tall.
-<p>
-Raster maps based on floating point values will display smoothed, from greatest
+<p>Raster maps based on floating point values will display smoothed, from greatest
to smallest value, while categorial raster maps will display in order, from
top to bottom. Horizontal legends will always be smoothed. If the box is defined
with inverted y-values or an inverted <b>range</b>, the legend will automatically
flip. If this is not the desired result, the <b>-f</b> flag may be used to flip
it back.
-<p>
-If the user attempts to display a very long legend in a relatively short
+<p>If the user attempts to display a very long legend in a relatively short
display frame, the legend may appear in unreadably small text, or even revert
to a smooth gradient legend. Use the <b>lines</b>, <b>thin</b>, <b>use</b>, <b>range</b>,
and/or <b>-n</b> options to reduce the number of categories to be displayed,
or the <b>-s</b> flag to force a smooth gradient legend.
-<p>
-The <b>lines</b> option will display the first number of categories, as defined
+<p>The <b>lines</b> option will display the first number of categories, as defined
by <em>value</em>, contained in the raster map. When used with the <b>-n</b> flag,
it takes on a new meaning: "up to category #". When used with both
<b>thin</b> and the <b>-n</b> flag, its meaning becomes more obscure. When
using <b>lines</b>, auto-scaled text similar to "4 of 16 categories" will be placed at
the bottom of the legend.
-<p>
-The <b>thin</b> option sets the thinning factor. For raster maps with a 0th
+<p>The <b>thin</b> option sets the thinning factor. For raster maps with a 0th
category, <b>thin=</b><em>10</em> gives cats [0,10,20,...]. For raster maps
starting at category 1, <b>thin=</b><em>10</em> gives cats [1,11,21,...].
-<p>
-The <b>use</b> option lets the user create a legend made up of arbitrary category
+<p>The <b>use</b> option lets the user create a legend made up of arbitrary category
values. e.g. <b>use=</b><em>1000,100,10,0,-10,-100,-1000</em>
-<p>
-The <b>range</b> option lets the user define the minimum and maximum categories
+<p>The <b>range</b> option lets the user define the minimum and maximum categories
to be used in the legend. It may also be used to define the limits of a smooth
gradient legend created from a raster containing floating point values. Note
the color scale will remain faithful to the category values as defined with
-<em><a href="r.colors.html">r.colors</A></em>, and the <b>range</b> may be
-extended to the limits defined by the <em><a href="r.colors.html">r.colors</A></em>
+<em><a href="r.colors.html">r.colors</a></em>, and the <b>range</b> may be
+extended to the limits defined by the <em><a href="r.colors.html">r.colors</a></em>
color map.
-<p>
-The flag <b>-n</b> is useful for categorial maps, as it suppresses the
+<p>The flag <b>-n</b> is useful for categorial maps, as it suppresses the
drawing of non-existing categories (otherwise the full range is shown).
-<p>
-Vertical legends produced with <em>d.legend</em> will place text labels to the
+<p>Vertical legends produced with <em>d.legend</em> will place text labels to the
right of the legend box, horizontal legends will place text below. This text
will be auto-scaled to fit within the frame, reducing the size of the legend
if necessary. Legends positioned with the mouse or with the <b>at</b> option
@@ -74,17 +63,14 @@
height of the box. The <b>-c</b> and <b>-v</b> flags may be used to suppress the
display of category numbers and labels respectively, or used together to
suppress all text of categorial raster maps.
-<p>
-The text produced from floating-point raster maps will automatically create
+<p>The text produced from floating-point raster maps will automatically create
output with a meaningful number of significant digits. For very small values,
numbers will be expressed in scientific notation, e.g. "1.7e-9".
-<p>
-Legends placed with the mouse are not saved to the display window's history
+<p>Legends placed with the mouse are not saved to the display window's history
for automatic redraw. By setting the Debug level to 1 (see
-<em><a href="g.gisenv.html">g.gisenv</A></em>) the corresponding <b>at</b>
+<em><a href="g.gisenv.html">g.gisenv</a></em>) the corresponding <b>at</b>
setting can be determined.
-<p>
-Note that old scripts which relied on setting <b>lines</b> greater than the
+<p>Note that old scripts which relied on setting <b>lines</b> greater than the
number of categories to scale the legend may no longer produce the desired
output, although the auto-scaling should still produce something that looks
good in this case.
@@ -92,20 +78,20 @@
<h2>SEE ALSO</h2>
-<em><a href="d.colortable.html">d.colortable</A></em><br>
-<em><a href="d.grid.html">d.grid</A></em><br>
-<!-- <em><a href="d.rast.labels.html">d.rast.labels</A></em><br> -->
-<em><a href="d.rast.leg.html">d.rast.leg</A></em><br>
-<em><a href="d.vect.thematic.html">d.vect.thematic</A></em><br>
-<em><a href="d.what.rast.html">d.what.rast</A></em><br>
-<em><a href="g.gisenv.html">g.gisenv</A></em><br>
-<em><a href="r.reclass.html">r.reclass</A></em><br>
+<em><a href="d.colortable.html">d.colortable</a></em><br>
+<em><a href="d.grid.html">d.grid</a></em><br>
+<!-- <em><a href="d.rast.labels.html">d.rast.labels</a></em><br> -->
+<em><a href="d.rast.leg.html">d.rast.leg</a></em><br>
+<em><a href="d.vect.thematic.html">d.vect.thematic</a></em><br>
+<em><a href="d.what.rast.html">d.what.rast</a></em><br>
+<em><a href="g.gisenv.html">g.gisenv</a></em><br>
+<em><a href="r.reclass.html">r.reclass</a></em><br>
<h2>AUTHORS</h2>
Modified: grass/trunk/display/d.linegraph/d.linegraph.html
--- grass/trunk/display/d.linegraph/d.linegraph.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.linegraph/d.linegraph.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,8 +2,7 @@
<em>d.linegraph</em> is a primitive program to draw simple x,y line graphs
based on numerical data contained in separate files.
-<p>
-Data file format<br>
+<p>Data file format<br>
The X and Y data files for the graph are essentially a column of numbers in
each file, with one input number per line. The program expects that each X
value will have a corresponding Y value, therefore the number of lines in
@@ -17,8 +16,7 @@
with dissimilar units, the graph produced comparing the two will be
deceptive.
-<p>
-<dl>
+<p><dl>
<dt><b>directoryname</b>
<dd>Path to the directory where the input files are located. If this option
is not used, the <em>d.linegraph</em> looks for files in the current directory.
@@ -64,18 +62,15 @@
Since the command line parser is not amiable to multiple word inputs, to
input titles of more than one word, use the underscore character ("") to
represent spaces (" ").
-<p>
-Example: "titleCensusdata1990" would be printed over the graph as "Census
+<p>Example: "titleCensusdata1990" would be printed over the graph as "Census
data 1990".
-<p>
-The way the program locates and labels tic marks is less than perfect: 1)
+<p>The way the program locates and labels tic marks is less than perfect: 1)
although distances between Y tics is proportional to the value, they are
not proportional on the X axis; 2) decimal values between -1 and 1 can be
printed on the X axis, but not on Y. (With respect to the later, the input
for Y values can all be multiplied by a factor of 10 before graphing).
-<p>
-It might be easier to use a 3rd party tool such as xgraph or GNUplot instead
+<p>It might be easier to use a 3rd party tool such as xgraph or GNUplot instead
of <em>d.linegraph</em>.
(You can make GNUplot output pretty by using its SVG or PostScript output
@@ -83,13 +78,12 @@
<h2>SEE ALSO</h2>
<em>
-<a href="d.text.html">d.text</A>,
-<a href="v.label.html">v.label</A>
+<a href="d.text.html">d.text</a>,
+<a href="v.label.html">v.label</a>
</em>
<h2>AUTHOR</h2>
Chris Rewerts, Agricultural Engineering, Purdue University
-<p>
Modified: grass/trunk/display/d.measure/d.measure.html
--- grass/trunk/display/d.measure/d.measure.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.measure/d.measure.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -25,8 +25,8 @@
overlay (not overwrite) whatever display currently appears
in the active frame on the graphics monitor. The user can,
for example, run
-<em><a href="d.rast.html">d.rast</A></em> or
-<em><a href="d.vect.html">d.vect</A></em> prior to running
+<em><a href="d.rast.html">d.rast</a></em> or
+<em><a href="d.vect.html">d.vect</a></em> prior to running
<em>d.measure</em>, and use raster and/or vector maps as a backdrop.
<h2>NOTES</h2>
@@ -43,12 +43,12 @@
<h2>SEE ALSO</h2>
-<em><a href="d.graph.html">d.graph</A></em><br>
-<em><a href="d.vect.html">d.vect</A></em><br>
-<em><a href="g.proj.html">g.proj</A></em>
+<em><a href="d.graph.html">d.graph</a></em><br>
+<em><a href="d.vect.html">d.vect</a></em><br>
+<em><a href="g.proj.html">g.proj</a></em>
<h2>AUTHORS</h2>
Modified: grass/trunk/display/d.mon/d.mon.html
--- grass/trunk/display/d.mon/d.mon.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.mon/d.mon.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,14 +14,12 @@
<em><a href="variables.html">variables</a></em> or the specific
<em><a href="variables.html#rendering">driver documentation</a></em>.
-<p>
-When a monitor is <em>started</em>, it is therefore also
+<p>When a monitor is <em>started</em>, it is therefore also
(automatically) <em>selected</em> for output, unless the
<b>-s</b> flag is set by the user; the user can also
explictly <b>select</b> a monitor that has been started.
-<p>
-The desired monitor should be started once and need not be restarted
+<p>The desired monitor should be started once and need not be restarted
unless it is stopped for some reason. A monitor may continue to run
for any length of time, even when no GRASS session is being run.
@@ -43,8 +41,7 @@
explictly selecting the monitor for output. Only running monitors can
be selected for graphics output.
-<p>
-The user can run multiple graphics monitors by simply starting each of
+<p>The user can run multiple graphics monitors by simply starting each of
the graphics monitors he wishes to direct output to.
<h3>Release a monitor</h3>
@@ -109,12 +106,10 @@
</em>
-<p>
- See also <em><a href="variables.html">variables</a></em> list
+<p> See also <em><a href="variables.html">variables</a></em> list
<h2>AUTHOR</h2>
Martin Landa, Czech Republic
-<p>
Modified: grass/trunk/display/d.path/d.path.html
--- grass/trunk/display/d.path/d.path.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.path/d.path.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,8 +13,7 @@
if the <b>coor</b> option is used they can be specified non-interactively.
The actions bound to the mouse buttons are described in the terminal
window when running the command.
-<p>
-To calculate shortest path non-interactively and save the path to a new vector
+<p>To calculate shortest path non-interactively and save the path to a new vector
map, use the <em>v.net.path</em> module.
<h2>EXAMPLE</h2>
@@ -41,5 +40,4 @@
-<p>
Modified: grass/trunk/display/d.rast/d.rast.html
--- grass/trunk/display/d.rast/d.rast.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.rast/d.rast.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -19,5 +19,4 @@
Research Laboratory
-<p>
Modified: grass/trunk/display/d.rast.arrow/d.rast.arrow.html
--- grass/trunk/display/d.rast.arrow/d.rast.arrow.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.rast.arrow/d.rast.arrow.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,15 +10,13 @@
This allows the arrows to be drawn over any other maps already displayed
<p>
<em>d.rast.arrow</em> will draw an arrow over each displayed cell
to indicate in which direction the cell slopes. If the aspect
layer has a category value denoting locations of "unknown" aspect,
<em>d.rast.arrow</em> draws a question mark over the displayed cells
of that category.
Cells containing null data will be marked with an "X".
-<p>
-If you specify the <em>magnitude_map</em> option, arrow lengths
+<p>If you specify the <em>magnitude_map</em> option, arrow lengths
denoting magnitude will be extracted from the cell values of the specified
map. In this case the tail of the arrow will be centered on the source cell.
You may adjust the overall scale using the <em>scale</em> option.
@@ -28,21 +26,18 @@
the magnitude map to suit your needs (absolute value, inverted direction and
so on).
-<p>
-<h2>NOTES</h2>
+<p><h2>NOTES</h2>
By default, arrows are drawn at the size of a cell and cannot be seen if
the raster map is relatively close in scale. You can use the <em>skip</em>
option to draw arrows every n-th cell in both directions if you are working
with relatively high resolutions. It may be useful to disable the grid in
this case, which is accomplished by setting its color to "<tt>none</tt>".
-<p>
-For GRASS and Compass type aspect maps, the cell values of the aspect map
+<p>For GRASS and Compass type aspect maps, the cell values of the aspect map
will determine the corresponding direction in 360 degrees. ANSWERS type
aspect maps will be plotted in multiples of 15 degrees, and AGNPS type
aspect maps will be displayed in D8 representation, i.e. the eight multiples
of 45 degrees.
-<p>
-GRASS aspect maps are measured using Cartesian conventions, i.e. in degrees
+<p>GRASS aspect maps are measured using Cartesian conventions, i.e. in degrees
counterclockwise from east. e.g.:
@@ -53,10 +48,8 @@
</pre></div>
They can be created from a raster elevation map with <em>r.slope.aspect</em>.
-<p>
-Compass type aspect maps are measured in degrees clockwise from north.
-<p>
-This module uses oceanographic conventions, i.e. arrows point downslope or
+<p>Compass type aspect maps are measured in degrees clockwise from north.
+<p>This module uses oceanographic conventions, i.e. arrows point downslope or
direction "to", as opposed to atmospheric conventions (direction "from").
@@ -73,12 +66,12 @@
<h2>SEE ALSO</h2>
-<em><a href="d.rast.edit.html">d.rast.edit</A></em><br>
-<em><a href="d.rast.num.html">d.rast.num</A></em><br>
-<em><a href="g.region.html">g.region</A></em><br>
-<em><a href="r.slope.aspect.html">r.slope.aspect</A></em><br>
+<em><a href="d.rast.edit.html">d.rast.edit</a></em><br>
+<em><a href="d.rast.num.html">d.rast.num</a></em><br>
+<em><a href="g.region.html">g.region</a></em><br>
+<em><a href="r.slope.aspect.html">r.slope.aspect</a></em><br>
<br>
<h2>AUTHORS</h2>
Modified: grass/trunk/display/d.rast.num/d.rast.num.html
--- grass/trunk/display/d.rast.num/d.rast.num.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.rast.num/d.rast.num.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,12 +8,10 @@
to fit within a single cell. A grid outlining each map cell will also
be overlain in a user-specified color, unless it has been set to "none".
-<p>
-If no grid color is given the default will be used. If no map layer
+<p>If no grid color is given the default will be used. If no map layer
is specified, the program will use whatever raster map layer is
currently displayed in the active frame on the graphics monitor.
-<p>
-If the <b>-f</b> flag is given the displayed number will take on the color
+<p>If the <b>-f</b> flag is given the displayed number will take on the color
of the base map in that cell.
@@ -27,7 +25,6 @@
<h2>SEE ALSO</h2>
<em><a href="d.frame.html">d.frame</a></em>,
<em><a href="d.grid.html">d.grid</a></em>,
<em><a href="d.rast.html">d.rast</a></em>,
Modified: grass/trunk/display/d.rgb/d.rgb.html
--- grass/trunk/display/d.rgb/d.rgb.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.rgb/d.rgb.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -9,7 +9,7 @@
<h2>OPTIONS</h2>
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
@@ -26,7 +26,7 @@
</dl>
-<H3>Parameters:</H3>
+<h3>Parameters:</h3>
<dl>
<dt><b>red=</b><em>name</em>
@@ -50,11 +50,9 @@
if the graphics device does not have a reasonable sampling
of the RGB color-space.
<p>
If color quality of satellite image color composites seems to appear poor,
-run <em><a href="r.colors.html">r.colors</A></em> on the selected satellite
-channels.<p>
-Example:
+run <em><a href="r.colors.html">r.colors</a></em> on the selected satellite
+channels.<p>Example:
<dl>
<dd><b>r.info -r</b> <em>image.1</em><br>
<tt>min=0<br>
@@ -74,18 +72,18 @@
<br><br><br>
To write out the color composite to a R/G/B raster maps, use
-<em><a href="r.composite.html">r.composite</A></em>.
+<em><a href="r.composite.html">r.composite</a></em>.
<h2>SEE ALSO</h2>
-<em><a href="d.his.html">d.his</A></em><br>
-<em><a href="r.blend.html">r.blend</A></em><br>
-<em><a href="r.mapcalc.html">r.mapcalc</A></em><br>
-<em><a href="r.colors.html">r.colors</A></em><br>
+<em><a href="d.his.html">d.his</a></em><br>
+<em><a href="r.blend.html">r.blend</a></em><br>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em><br>
+<em><a href="r.colors.html">r.colors</a></em><br>
<h2>AUTHOR</h2>
Modified: grass/trunk/display/d.rhumbline/d.rhumbline.html
--- grass/trunk/display/d.rhumbline/d.rhumbline.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.rhumbline/d.rhumbline.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,8 +12,7 @@
coordinate locations must fall within the boundaries of the
user's current geographic region.
-<p>
-The user has to specify the starting and ending
+<p>The user has to specify the starting and ending
longitude/latitude coordinates of the rhumbline and
(optionally) the color in which the rhumbline will be
displayed; in this case, the program will run
@@ -28,8 +27,7 @@
d.rhumbline coor=55:58W,33:18S,26:43E,60:37N lcolor=yellow tcolor=red
</pre></div>
-<p>
-<center>
+<p><center>
<img src="d_rhumbline.png" border=1><br>
<i>Rhumbline (loxodrome)</i>
</center>
@@ -41,7 +39,7 @@
<h2>SEE ALSO</h2>
<h2>AUTHOR</h2>
Modified: grass/trunk/display/d.text/d.text.html
--- grass/trunk/display/d.text/d.text.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.text/d.text.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,7 +12,7 @@
line, and then assigns values to these options on lines
within the standard input).
-<H3>Commands:</H3>
+<h3>Commands:</h3>
<dl>
@@ -35,17 +35,16 @@
allow the drawing of 20 lines, and 50 would allow the
drawing of 2 lines.
-<p>
-<dt><b>.F</b> <em>font</em>
+<p><dt><b>.F</b> <em>font</em>
<dd>
(where <em>font</em> is one of the fonts known by the GRASS program
-<em><a href="d.font.html">d.font</A></em>) manipulates
+<em><a href="d.font.html">d.font</a></em>) manipulates
the font type. Available fonts are listed in the GRASS manual entry for
-<em><a href="d.font.html">d.font</A></em>.
+<em><a href="d.font.html">d.font</a></em>.
The default font type used (if unspecified by the user)
is <em>romans</em>.
<!-- Run the GRASS macro
-<em><A HREF="show.fonts.sh.html">show.fonts.sh</A></em>
+<em><A HREF="show.fonts.sh.html">show.fonts.sh</a></em>
to see what these fonts look like. -->
<dt><b>.R </b> <em>rotation</em>
@@ -71,7 +70,6 @@
active frame's vertical space per line:
<p>
<pre>
<b>d.text</b> << EOF
.C yellow
@@ -89,20 +87,19 @@
<h2>NOTES</h2>
Note that the GRASS command
-<em><a href="d.title.html">d.title</A></em> creates map TITLEs in a format
+<em><a href="d.title.html">d.title</a></em> creates map TITLEs in a format
suitable for input to <em>d.text</em>.
<p>
<em>d.text</em> needs escape sequences that can be used
within lines to change colors, boldness, and perhaps size.
<h2>SEE ALSO</h2>
-<!-- <em><a href="show.fonts.sh.html">show.fonts.sh</A></em><br> -->
+<!-- <em><a href="show.fonts.sh.html">show.fonts.sh</a></em><br> -->
<h2>AUTHOR</h2>
@@ -110,7 +107,6 @@
James Westervelt,
Research Laboratory
-<p>
-Updates by Huidae Cho
+<p>Updates by Huidae Cho
Modified: grass/trunk/display/d.thematic.area/d.thematic.area.html
--- grass/trunk/display/d.thematic.area/d.thematic.area.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.thematic.area/d.thematic.area.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,10 +20,10 @@
<h2>SEE ALSO</h2>
-<em><a href="v.class.html">v.class</A></em>
-<em><a href="v.univar.html">v.univar</A></em>
+<em><a href="v.class.html">v.class</a></em>
+<em><a href="v.univar.html">v.univar</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/display/d.title/d.title.html
--- grass/trunk/display/d.title/d.title.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.title/d.title.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,10 +1,10 @@
<em>d.title</em> generates to standard output a string which can be used by
-<em><a href="d.text.html">d.text</A></em> to draw a TITLE for the raster map
+<em><a href="d.text.html">d.text</a></em> to draw a TITLE for the raster map
layer <em>name</em> in the active display frame on the graphics monitor.
Output created by <em>d.title</em> can be redirected into a file, or piped
-directly into <em><a href="d.text.html">d.text</A></em> to display the map
+directly into <em><a href="d.text.html">d.text</a></em> to display the map
TITLE created by <em>d.title</em>. The map TITLE created will include the
map layer's name, TITLE, MAPSET, LOCATION_NAME, geographic region boundary
coordinates, and cell resolution.
@@ -16,7 +16,7 @@
<h2>NOTES</h2>
The text created with
will not necessarily fit within the
active display frame on the graphics monitor;
the user should choose a text size appropriate to this frame.
@@ -29,28 +29,27 @@
active display frame on the graphics monitor might type the following:
<dl>
<dd> <b>d.title map=</b><em>soils</em> <b>color=</b><em>red</em> <b>size=</b><em>5</em> <b>> TITLE.file</b>
-<dd> <b><a href="d.text.html">d.text</A> < TITLE.file</b>
+<dd> <b><a href="d.text.html">d.text</a> < TITLE.file</b>
</dl>
Alternately, the user might pipe <em>d.title</em> output directly
-into <em><a href="d.text.html">d.text</A>:</em>
+into <em><a href="d.text.html">d.text</a>:</em>
<dl>
<dd>
<b>d.title map=</b><em>soils</em> <b>color=</b><em>red</em> <b>size=</b><em>5</em> |
</dl>
-<p>
-A file created by <em>d.title</em> can be displayed
-with <em><a href="d.text.html">d.text</A></em>.
+<p>A file created by <em>d.title</em> can be displayed
+with <em><a href="d.text.html">d.text</a></em>.
Information contained in this file takes precedence over the
<em>color</em> and <em>size</em> parameters for
-<em><a href="d.text.html">d.text</A></em>.
+<em><a href="d.text.html">d.text</a></em>.
<h2>SEE ALSO</h2>
<h2>AUTHOR</h2>
@@ -58,5 +57,4 @@
Research Laboratory
-<p>
Modified: grass/trunk/display/d.vect/d.vect.html
--- grass/trunk/display/d.vect/d.vect.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.vect/d.vect.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,26 +10,22 @@
which allow the user to specify vector type, colors, data fields, SQL
queries, label size and justification, etc.
-<p>
-By default <em>d.vect</em> fills in holes in polygons (islands). If
+<p>By default <em>d.vect</em> fills in holes in polygons (islands). If
you only want to show active areas limit the features with, e.g.,
d.vect map=vector_map cats=1-999999
</pre></div>
-<p>
-In order to display attributes in the map, <tt>display=attr</tt> must be
+<p>In order to display attributes in the map, <tt>display=attr</tt> must be
specified in addition to the column name (<b>attrcolumn</b> parameter).
-<p>
-Colors may be specified
+<p>Colors may be specified
by <em><a href="v.colors.html">v.colors</a></em> as a color table or
in an attribute table column named 'GRASSRGB' (which is
a <tt>varchar(11)</tt> column containing <tt>RRR:GGG:BBB</tt> values),
see the flag <b>-a</b>.
-<p>
-A table for a vector map might look like this:
+<p>A table for a vector map might look like this:
db.select sql="select * from testisola"
@@ -42,29 +38,24 @@
190|TENNA|123:45:67
</pre></div>
-<p>
-To add the GRASSRGB color column, use <em><a href="v.db.addcolumn.html">v.db.addcolumn</a></em>:
+<p>To add the GRASSRGB color column, use <em><a href="v.db.addcolumn.html">v.db.addcolumn</a></em>:
v.db.addcolumn map=testisola columns="GRASSRGB varchar(11)"
</pre></div>
-<p>
-To add/change a color, use <em><a href="v.db.update.html">v.db.update</a></em>:
+<p>To add/change a color, use <em><a href="v.db.update.html">v.db.update</a></em>:
v.db.update map=testisola column=GRASSRGB value="123:45:237" where="cat=139"
</pre></div>
-<p>
-A much simpler method of color coding is by using the <b>-c</b> flag
+<p>A much simpler method of color coding is by using the <b>-c</b> flag
which displays vector elements of like category number with a random
color.
-<p>
-This module can use FreeType/TrueType fonts if they have already been selected with
+<p>This module can use FreeType/TrueType fonts if they have already been selected with
-<p>
-Parameter <b>width</b> is set by default to '0'. XDRIVER specifies the
+<p>Parameter <b>width</b> is set by default to '0'. XDRIVER specifies the
precise behaviour for non-zero line width, but drivers have some
freedom as to how zero-width lines are handled, so they can use the
hardware's "thin line" drawing primitive, if it has one. A
@@ -87,8 +78,7 @@
d.vect -c map=soils where="label='VBF'" display=shape,attr attrcolumn=label
</pre></div>
-<p>
-3D points, 3D lines and 3D polygons colorized according to z height:
+<p>3D points, 3D lines and 3D polygons colorized according to z height:
g.region rast=elevation.10m
r.random input=elevation.10m n=5000 vector=random3d -d
@@ -127,5 +117,4 @@
Support for color tables by Martin Landa, Czech Technical University in Prague (8/2011)<br>
and many other GRASS developers
-<p>
Modified: grass/trunk/display/d.what.rast/d.what.rast.html
--- grass/trunk/display/d.what.rast/d.what.rast.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.what.rast/d.what.rast.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,7 +5,6 @@
user-named raster map layer(s).
<p>
The program will query the contents of raster map layer(s)
named by the user on the command line. These map layers
must exist in the user's current mapset search path. If
@@ -15,7 +14,6 @@
<p>
The program activates the mouse, and expects the user to
indicate the cell location(s) to be queried by depressing a
mouse button over desired location(s) within the current
@@ -31,18 +29,14 @@
output below.
<p>
<dl>
<dt><b>d.rast map=</b><em>soils</em>
-<p>
-<dd>To first display the <em>soils</em> map in the active frame.</dd>
+<p><dd>To first display the <em>soils</em> map in the active frame.</dd>
</dl>
-<p>
-<dl>
+<p><dl>
<dt><b>d.what.rast map=</b><em>soils,aspect</em><br>
-<p>
-<dd>User then moves the mouse to desired location on the
+<p><dd>User then moves the mouse to desired location on the
displayed <em>soils</em> map layer, and presses the left
mouse button to query the category contents of the
<em>soils</em> and <em>aspect</em> maps at this geographic
@@ -56,21 +50,18 @@
aspect in PERMANENT (20)15 degrees north of west
</pre>
-<p>
-The first line of output gives the easting (E) and northing (N) coordinates
+<p>The first line of output gives the easting (E) and northing (N) coordinates
of the geographic location at which the user clicked the mouse.
Subsequent lines give the selected map(s) name and mapset, map category value
(within parentheses), and map category label corresponding to this
user-selected map location.
<p>
The query may be repeated as often as desired using the
left mouse button. The right button on the mouse is used
to quit the <em>d.what.rast</em> session.
<p>
Users can set the <b>-t</b> flag to obtain a terse output
from <em>d.what.rast</em>. This is useful when the user
wishes output to be parsed by another program (like
@@ -81,11 +72,9 @@
command
<p>
<dl>
<dt><b>d.what.rast -t map=</b><em>soils,aspect</em>
-<p>
-<dd> produces output in the form shown below. The first line of
+<p><dd> produces output in the form shown below. The first line of
output gives the easting, northing, and the mouse button
return value (see NOTES below). Each
subsequent line gives the map name and its mapset, the
@@ -102,7 +91,6 @@
</pre>
<p>
Users can also use this program inside of shell scripts
that require as input a map category value and a mouse
button depressed. Users can choose an option to run
@@ -118,28 +106,23 @@
3 indicates that the right mouse button was pressed.
<p>
<em>d.what.rast</em> will always print its output to the
terminal screen. <em>d.what.rast</em> output can be
redirected into a file; however, if it is, the output will
go both to the screen and to the file. For example:
<p>
<dl>
<dt><b>d.what.rast map=</b><em>soils,aspect</em><b> > what.out</b>
-<p>
-<dd>will both send <em>d.what.rast</em> output to the screen
+<p><dd>will both send <em>d.what.rast</em> output to the screen
and capture its output in the file named
<em>what.out</em>.</dd>
</dl>
<p>
The maximum number of raster map layers that can be queried at one time is 15.
<p>
<em><a href="d.what.vect.html">d.what.vect</a></em>
allows the user to interactively query the category
contents of multiple vector map layers at user-specified
Modified: grass/trunk/display/d.what.vect/d.what.vect.html
--- grass/trunk/display/d.what.vect/d.what.vect.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.what.vect/d.what.vect.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,15 +4,13 @@
outputs the category value(s) associated with user-specified location(s)
in user-specified vector map layer(s).
-<p>
-The program activates the mouse, and expects the user to indicate the
+<p>The program activates the mouse, and expects the user to indicate the
location(s) to be queried by depressing a mouse button over desired location(s)
within the current geographic region in the active display frame on the
graphic monitor. Query results from map(s) are by default displayed in a new
monitor, where label values can be added or changed. Using parameter <b>-x</b>
informations will be displayed as plain text to terminal window.
-<p>
-This module always reports standard acres, even when the location uses
+<p>This module always reports standard acres, even when the location uses
US Survey feet as the map unit.
<h2>EXAMPLE</h2>
@@ -23,13 +21,9 @@
reference.
<p>
-<b>d.vect map=</b><em>roads</em><p>
-Displays the <em>roads</em> vector map layer on the graphics monitor.
+<b>d.vect map=</b><em>roads</em><p>Displays the <em>roads</em> vector map layer on the graphics monitor.
<p>
-<b>d.what.vect map=</b><em>roads,geology</em><p>
-After typing this, the user moves the mouse to a desired location
+<b>d.what.vect map=</b><em>roads,geology</em><p>After typing this, the user moves the mouse to a desired location
on the displayed <em>roads</em> map layer, and presses the left mouse
button to query the category value of the <em>roads</em> and the
<em>geology</em> vector map at this location.
@@ -38,7 +32,6 @@
to this user-selected map location, for the vector map queried by the user.
<p>
The query may be repeated as often as desired using the left mouse button. The
middle mouse button toggles the flash color.
The right button on the mouse is used to quit the <em>d.what.vect</em> session.
@@ -61,5 +54,4 @@
Upgrades by Dennis Finch, National Park Service
and Radim Blazek, ITC-Irst, Trento, Italy
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/display/d.where/d.where.html
--- grass/trunk/display/d.where/d.where.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.where/d.where.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,22 +1,19 @@
<em>d.where</em> is an <em>interactive</em> program that
allows the user, using the pointing device (mouse), to
identify the geographic coordinates associated with point
locations within the current geographic region in the
-<p>
-Each mouse click will output the easting and northing of the point
+<p>Each mouse click will output the easting and northing of the point
currently located beneath the mouse pointer.
A mouse-button menu is presented so the user knows which
mouse buttons to use. The output is always printed to the
terminal screen; if the output is redirected into a file,
it will be written to the file as well.
-<p>
-Mouse buttons:
+<p>Mouse buttons:
<pre>
Left: where am i
@@ -44,11 +41,11 @@
<h2>SEE ALSO</h2>
-<em><a href="d.what.vect.html">d.what.vect</A></em><br>
-<em><a href="v.what.rast.html">v.what.rast</A></em><br>
-<em><a href="v.what.vect.html">v.what.vect</A></em>
+<em><a href="d.what.vect.html">d.what.vect</a></em><br>
+<em><a href="v.what.rast.html">v.what.rast</a></em><br>
+<em><a href="v.what.vect.html">v.what.vect</a></em>
<h2>AUTHORS</h2>
Modified: grass/trunk/display/d.zoom/d.zoom.html
--- grass/trunk/display/d.zoom/d.zoom.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/display/d.zoom/d.zoom.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,12 +11,10 @@
or pan the region. The graphics display is updated by the module.
<p>
After the user types the command <b>d.zoom</b> a mouse-button menu will appear
directing the user.
<p>
Additionally the region settings can be modified by
running <em><a href="g.region.html">g.region</a></em>.
Modified: grass/trunk/doc/vector/v.modules.html
--- grass/trunk/doc/vector/v.modules.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/doc/vector/v.modules.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,16 +1,14 @@
-<HEAD>
-<TITLE>GRASS 5.1/7 Vector - Modules Status</TITLE>
-</HEAD>
-<BODY>
-<p>
-<H1>GRASS 5.1/7 Vector - Modules Status</H1>
+<head>
+<title>GRASS 5.1/7 Vector - Modules Status</title>
+</head>
+<body>
+<p><H1>GRASS 5.1/7 Vector - Modules Status</H1>
This document describes the status of update from vector 4.0 (GRASS 4.0 and 5.0) to vector 5.0 (GRASS 5.1/7) format
and sites (GRASS 5.0) to vector 5.0 (GRASS 5.1/7) format.
-<p>
-You are welcome to upgrade some modules. To avoid duplicate work please send
-information to <a href=mailto:blazek at itc.it>blazek at itc.it</A>
+<p>You are welcome to upgrade some modules. To avoid duplicate work please send
+information to <a href=mailto:blazek at itc.it>blazek at itc.it</a>
before you start.
<HR>
Modified: grass/trunk/doc/vector/vector.html
--- grass/trunk/doc/vector/vector.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/doc/vector/vector.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,33 +1,28 @@
-<HEAD>
-<TITLE>GRASS 5.7/6 Vector Format and API</TITLE>
-</HEAD>
-<BODY>
-<p>
-<H1>GRASS 5.7/6 Vector Format and API</H1>
+<head>
+<title>GRASS 5.7/6 Vector Format and API</title>
+</head>
+<body>
+<p><H1>GRASS 5.7/6 Vector Format and API</H1>
The API is described in
+<p><a href="http://grass.itc.it/devel/index.php#prog">GRASS 6 Programmer's Manual</a>
<p>
-<a href="http://grass.itc.it/devel/index.php#prog">GRASS 6 Programmer's Manual</a>
-<p>
source code file:<br>
lib/vector/vectorlib.dox
<HR>
-<h2><A NAME="ascii">Vector ASCII Format Specification</A></h2>
+<h2><A NAME="ascii">Vector ASCII Format Specification</a></h2>
<p>
<i>format notes here are outdated and to be merged into<br>
vector/v.in.ascii/description.html</i>
-<p>
-The ASCII format in the new version contains support for categories,
+<p>The ASCII format in the new version contains support for categories,
z-coordinates, and the new types centroid, face, and kernel.
Points and centroids are saved as one coordinate pair instead of two.
File is saved in old dig_ascii directory but the name will be probably changed.
-<H3>Head</H3>
+<h3>Head</h3>
The head of the file is similar as the head file of vector binary
format but contains bounding box also. Key words are:<br>
<pre>
@@ -46,7 +41,7 @@
MAP THRESH
</pre>
-<H3>Body</H3>
+<h3>Body</h3>
The body begins with the row:
<pre>
VERTI:
@@ -95,11 +90,11 @@
</pre>
<HR>
-<h2><A NAME="example">Vector module programming example</A></h2>
+<h2><A NAME="example">Vector module programming example</a></h2>
<a href=v.example/>Vector module C programming example</a>
-<h2><A NAME="status">Vector module upgrade status</A></h2>
+<h2><A NAME="status">Vector module upgrade status</a></h2>
<a href=v.modules.html>Vector upgrade status</a> (partially outdated)
Modified: grass/trunk/general/g.access/g.access.html
--- grass/trunk/general/g.access/g.access.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.access/g.access.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,7 +10,6 @@
current mapset.
<p>
The user may, for example, allow only users in the same
UNIX group to read data files in the mapset, or restrict
the mapset to personal use only.
@@ -24,8 +23,7 @@
under the PERMANENT mapset directory. The <em>g.access</em> command,
therefore, will not allow you to restrict access to the PERMANENT mapset.
-<p>
-The <em><a href="g.mapsets.html">g.mapsets</A></em> command isn't smart
+<p>The <em><a href="g.mapsets.html">g.mapsets</a></em> command isn't smart
enough to tell if access to a specified mapset is restricted, and the user
is therefore allowed to include the names of restricted mapsets in his
search path. However, the data in a restricted mapset is still protected;
@@ -36,7 +34,7 @@
UNIX manual entries for <em>chmod</em> and <em>group</em>
<br>
-<em><a href="g.mapsets.html">g.mapsets</A></em>
+<em><a href="g.mapsets.html">g.mapsets</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/general/g.copy/g.copy.html
--- grass/trunk/general/g.copy/g.copy.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.copy/g.copy.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -18,13 +18,11 @@
called <em>rds.old</em>, the user could type:
<p>
<div class="code"><pre>
g.copy rast=soils,soils.ph vect=roads,rds.old
</pre></div>
<p>
Data files can also be specified by their mapsets. For
example, the below command copies the raster map named
<em>soils</em> from the mapset <em>wilson</em> to a new
@@ -32,13 +30,11 @@
current mapset:
<p>
g.copy rast='soils at wilson',soils
</pre></div>
<p>
If no mapset name is specified, <em>g.copy</em> searches
for the named <em>from</em> map in each of the mapset
directories listed in the user's current mapset search path
@@ -60,7 +56,6 @@
listing.
<p>
If a file has support files (e.g., as do raster data
files), these support files will also be copied.
Modified: grass/trunk/general/g.filename/g.filename.html
--- grass/trunk/general/g.filename/g.filename.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.filename/g.filename.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,11 +3,9 @@
<em>g.filename</em> is designed for Bourne shell scripts that need to know
the full file name, including it's path, for mapset elements, like raster,
vector and site maps, region definitions and imagery groups.
-<p>
-The list of element names to search for is not fixed; any subdirectory of the
+<p>The list of element names to search for is not fixed; any subdirectory of the
mapset directory is a valid element name.
-<p>
-However, the user can find the list of standard GRASS element names in
+<p>However, the user can find the list of standard GRASS element names in
the file $GISBASE/etc/element_list. This is the file which
g.remove/g.rename/g.copy use to determine which files need to be
deleted/renamed/copied for a given entity type.
@@ -15,7 +13,7 @@
<!-- unused
<h2>OPTIONS</h2>
<dl>
<dt><b>element=</b><em>name</em>
@@ -64,7 +62,6 @@
base files as well as use existing ones.
<p>
If the mapset is the current mapset, <em>g.filename</em>
automatically creates the <em>element</em> specified if it
doesn't already exist. This makes it easy to add new files
@@ -73,17 +70,16 @@
program will not create a new mapset, however, if that
specified does not currently exist.)
-<p>
-The program exits with a 0 if everything is ok; it exits
+<p>The program exits with a 0 if everything is ok; it exits
with a non-zero value if there is an error, in which case
file=<em>'full_file_pathname'</em> is not output.
<h2>SEE ALSO</h2>
-<em><a href="g.ask.html">g.ask</A></em><br>
-<em><a href="g.findfile.html">g.findfile</A></em><br>
+<em><a href="g.ask.html">g.ask</a></em><br>
+<em><a href="g.findfile.html">g.findfile</a></em><br>
<h2>AUTHOR</h2>
Modified: grass/trunk/general/g.findetc/g.findetc.html
--- grass/trunk/general/g.findetc/g.findetc.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.findetc/g.findetc.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,19 +6,18 @@
is designed for addon scripts that are installed outside the GRASS application
directory, such as a user's home or a system addon directory.
<p>
<h2>OUTPUT</h2>
<em>g.findetc</em> writes the full path to the file or directory to standard output
<h2>SEE ALSO</h2>
-<em><a href="g.filename.html">g.filename</A></em><br>
-<em><a href="g.mapsets.html">g.mapsets</A></em><br>
+<em><a href="g.filename.html">g.filename</a></em><br>
+<em><a href="g.mapsets.html">g.mapsets</a></em><br>
<h2>AUTHOR</h2>
Modified: grass/trunk/general/g.findfile/g.findfile.html
--- grass/trunk/general/g.findfile/g.findfile.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.findfile/g.findfile.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,11 +4,9 @@
that need to search for mapset <em>elements</em>, including: raster,
vector maps, region definitions
and <em><a href="i.group.html">imagery</a></em> groups.
-<p>
-The list of <b>element</b> names to search for is not fixed; any
+<p>The list of <b>element</b> names to search for is not fixed; any
subdirectory of the mapset directory is a valid <b>element</b> name.
-<p>
-However, the user can find the list of standard GRASS <b>element</b>
+<p>However, the user can find the list of standard GRASS <b>element</b>
names in the file <tt>$GISBASE/etc/element_list</tt>. This is the file
which <em><a href="g.remove.html">g.remove</a></em>, <em><a href="g.rename.html">g.rename</a></em>
and <em><a href="g.copy.html">g.copy</a></em> use to determine which files
@@ -35,8 +33,7 @@
eval `g.findfile element=name mapset=name file=name`
</pre></div>
-<p>
-For example (raster map):
+<p>For example (raster map):
eval `g.findfile element=cell file=elevation`
</pre></div>
@@ -84,5 +81,4 @@
Michael Shapiro,
U.S.Army Construction Engineering Research Laboratory
-<p>
Modified: grass/trunk/general/g.gisenv/g.gisenv.html
--- grass/trunk/general/g.gisenv/g.gisenv.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.gisenv/g.gisenv.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -24,15 +24,13 @@
user's current mapset (i.e., <tt>$MAPSET</tt>)
is <tt>/opt/grassdata/spearfish/PERMANENT</tt>.
-<p>
-If the user specifies a <em>variable_name</em> on the command line
+<p>If the user specifies a <em>variable_name</em> on the command line
(e.g., <tt>g.gisenv MAPSET</tt>), only the value for that particular
GRASS variable is output to standard output. Possible variable names
depend on the user's system, see <em><a href="variables.html">variables
list</a></em> for details.
-<p>
-While other variables may be associated with each GRASS session (e.g.,
+<p>While other variables may be associated with each GRASS session (e.g.,
GRASS_GUI, GIS_LOCK, and other variables), those stated below
are essential.
@@ -84,8 +82,7 @@
stored under the <em>current mapset</em> (specified by the
variable <tt>$MAPSET</tt>).
-<p>
-Each "mapset" stores GRASS data base elements (i.e., the
+<p>Each "mapset" stores GRASS data base elements (i.e., the
directories in which GRASS data files are stored). Any maps created
or modified by the user in the current GRASS session will be stored
here. The <tt>$MAPSET</tt> directory <tt>PERMANENT</tt> is generally
@@ -104,8 +101,7 @@
<tt>$MAPSET</tt>), but may <em>use</em> data available under other
mapsets under the same <tt>$LOCATION_NAME</tt>.
-<p>
-All of these names must be legal names on the user's current system.
+<p>All of these names must be legal names on the user's current system.
<!--For UNIX users, names less than 14 characters and containing no
non-printing or space codes are permissible. Examples of permissible
names include: <em>one</em>, <em>mymap</em>, <em>VeGe_map</em>, and
@@ -169,5 +165,4 @@
Michael Shapiro,
-<p>
Modified: grass/trunk/general/g.gui/g.gui.html
--- grass/trunk/general/g.gui/g.gui.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.gui/g.gui.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,11 +1,9 @@
-<p>
-This program allows user to start a selected graphical user interface (GUI)
+<p>This program allows user to start a selected graphical user interface (GUI)
from the command line prompt.
-<p>
-GRASS 7 has a new GUI based on wxWidgets, written in Python:
+<p>GRASS 7 has a new GUI based on wxWidgets, written in Python:
<ul>
<li><b>wxpython</b> - New wxPython based GUI aka
@@ -13,8 +11,7 @@
</ul>
The old <em>gis.m</em> and <em>d.m</em> Tcl/Tk GUIs from GRASS 6 have been removed.
-<p>
-If the <b>-u</b> update flag is given or the <em>g.gisenv</em>
+<p>If the <b>-u</b> update flag is given or the <em>g.gisenv</em>
<tt>GUI</tt> variable is missing, then the <tt>GUI</tt> variable is
permanently changed and the selected GUI will be used as the default
UI from then on.
@@ -45,5 +42,4 @@
Martin Landa, FBK-irst, Trento, Italy<br>
Hamish Bowman, Otago University, Dunedin, New Zealand (fine tuning)
-<p>
-<i>$Date$</i>
+<p><i>$Date$</i>
Modified: grass/trunk/general/g.list/g.list.html
--- grass/trunk/general/g.list/g.list.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.list/g.list.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,12 +11,10 @@
find out which mapsets are in the cuurent search path, use
<em><a href="g.mapsets.html">'g.mapsets</a> -p'</em>.
-<p>
-If the <b>mapset</b> option is set to "." then only maps from the
+<p>If the <b>mapset</b> option is set to "." then only maps from the
current mapset will be displayed.
-<p>
-If the user requests that files from a mapset to which
+<p>If the user requests that files from a mapset to which
access has been restricted (see
<em><a href="g.access.html">g.access</a></em>)
be listed, no files from this mapset will be listed.
@@ -31,7 +29,6 @@
</pre></div>
<p>
List all raster and vector maps from mapset "user":
<br>
@@ -52,5 +49,4 @@
Research Laboratory
-<p>
Modified: grass/trunk/general/g.mapsets/g.mapsets.html
--- grass/trunk/general/g.mapsets/g.mapsets.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.mapsets/g.mapsets.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
For basic information about Grass <em>mapset</em>, <em>location</em>
and <em>data base</em> refer to <a href="helptext.html">GRASS Quickstart</a>.
-<p>
-A <em>mapset</em> holds a distinct set of data layers,
+<p>A <em>mapset</em> holds a distinct set of data layers,
each relevant to the same (or a subset of the same) geographic region,
and each drawn in the same map coordinate system.
At the outset of every GRASS session, the user identifies a
@@ -17,8 +16,7 @@
<em><a href="g.gisenv.html">g.gisenv</a></em> for changing the mapset
with a session)
-<p>
-The user can add, modify, and delete data layers that exist
+<p>The user can add, modify, and delete data layers that exist
under his <em>current mapset</em>. Although the user can
also <em>access</em> (i.e., use) data that are stored under
<em>other</em> mapsets in the same GRASS location using the
@@ -40,8 +38,7 @@
be called in such a manner.
-<p>
-<em>g.mapsets</em> shows the user available mapsets under
+<p><em>g.mapsets</em> shows the user available mapsets under
the current GRASS location, lists mapsets to which the user
currently has access, and lists the order in which
accessible mapsets will be accessed by GRASS programs
@@ -50,8 +47,7 @@
path, or modify the order in which mapsets will be
accessed.
-<p>
-When the user specifies the name of a data base element file
+<p>When the user specifies the name of a data base element file
(e.g., a particular vector map, raster map,
<a href="i.group.html">imagery</a> group file, etc.)
to a GRASS program, the program searches for the named file
@@ -70,8 +66,7 @@
ensures that a new file named <em>my.soils</em> is to be a copy of
the file <em>soils.file</em> from the mapset PERMANENT.)
-<p>
-It is common for a user to have the special mapset
+<p>It is common for a user to have the special mapset
<b>PERMANENT</b> included in his mapset search path, as
this mapset typically contains finished base maps relevant
to many applications. Often, other mapsets which contain
@@ -83,8 +78,7 @@
<em>Soil_Maps</em> should then be included in the user's
<em>search path</em> variable.
-<p>
-The <em>mapset search path</em> is saved as part of the
+<p>The <em>mapset search path</em> is saved as part of the
current mapset. When the user works with that mapset in
subsequent GRASS sessions, the previously saved mapset
search path will be used (and will continue to be used
@@ -101,12 +95,10 @@
list available mapsets, and prompt the user for a new
mapset search path listing.
-<p>
-The <em>addmapset</em> parameter allows for extending an existing
+<p>The <em>addmapset</em> parameter allows for extending an existing
<em>mapset search path</em>.
-<p>
-Users can restrict others' access to their mapset files
+<p>Users can restrict others' access to their mapset files
through use of the GRASS program
<em><a href="g.access.html">g.access</a></em>.
@@ -130,9 +122,7 @@
Michael Shapiro,
Research Laboratory
-<p>
-Greg Koerper,
+<p>Greg Koerper,
ManTech Environmental Technology, Inc.
-<p>
Modified: grass/trunk/general/g.message/g.message.html
--- grass/trunk/general/g.message/g.message.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.message/g.message.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,14 +1,12 @@
<h2>DESCRIPTION</h2>
-<p>
-This program is to be used in shell/perl/python scripts, so the author does not
+<p>This program is to be used in shell/perl/python scripts, so the author does not
need to use the <tt>echo</tt> program. The advantage of <em>g.message</em> is
that it formats messages just like other GRASS modules do and that its
functionality is influenced by the <tt>GRASS_VERBOSE</tt> and
<tt>GRASS_MESSAGE_FORMAT</tt> environment variables.
-<p>
-The program can be used for standard informative messages as well as warnings
+<p>The program can be used for standard informative messages as well as warnings
(<b>-w</b> flag) and fatal errors (<b>-e</b> flag). For debugging
purposes, the <b>-d</b> flag will cause <em>g.message</em> to print a debugging
message at the given level.
@@ -18,32 +16,25 @@
Messages containing "<tt>=</tt>" must use the full <b>message=</b> syntax so
the parser doesn't get confused.
-<p>
-If you want a long message (multi-line) to be dealt with as a single
+<p>If you want a long message (multi-line) to be dealt with as a single
paragraph, use a single call to <em>g.message</em> with text split in the
script using the backslash as the last character. (In shell scripts don't
close the "quote")
-<p>
-A blank line may be obtained with: <tt>g.message ""</tt>
-<p>
-Redundant whitespace will be stripped away.
-<p>
-It's advisable to single quote the messages that are to be printed literally.
+<p>A blank line may be obtained with: <tt>g.message ""</tt>
+<p>Redundant whitespace will be stripped away.
+<p>It's advisable to single quote the messages that are to be printed literally.
It prevents a number of characters (most notably, space and the dollar sign
'<tt>$</tt>') from being treated specifically by the Shell.
-<p>
-When it is necessary to include, for example, a variable's value as part of
+<p>When it is necessary to include, for example, a variable's value as part of
the message, the double quotes may be used, which do not deprive the
dollar sign of its special variable-expansion powers.
-<p>
-While it is known that the interactive Bash instances may treat the
+<p>While it is known that the interactive Bash instances may treat the
exclamation mark '<tt>!</tt>' character specifically (making single quoting
of it necessary), it shouldn't be the case for the non-interactive
instances of Bash. None the less, to avoid context-based confusion later on
you are enouraged to single-quote messages that do not require
<tt>$VARIABLE</tt> expansion.
<p>
<h3>VERBOSITY LEVELS</h3>
Controlled by the "<tt>GRASS_VERBOSE</tt>" environment variable. Typically this
is set using the <tt>--quiet</tt> or <tt>--verbose</tt> command line options.
@@ -77,5 +68,4 @@
Jachym Cepicky
-<p>
Modified: grass/trunk/general/g.mkfontcap/g.mkfontcap.html
--- grass/trunk/general/g.mkfontcap/g.mkfontcap.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.mkfontcap/g.mkfontcap.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,7 +1,6 @@
-<p>
-<em>g.mkfontcap</em> is a utilty to generate a GRASS font configuration file
+<p><em>g.mkfontcap</em> is a utilty to generate a GRASS font configuration file
("fontcap") containing details of the fonts available on the current system.
If <a href="http://freetype.sourceforge.net/">Freetype</a> is not installed,
the font list will be limited to the set of Hershey stroke fonts supplied
@@ -17,15 +16,13 @@
/System/Library/Fonts
${WINDIR}/Fonts
</pre></div>
-<p>
-These correspond to directories where fonts can be found on some common
+<p>These correspond to directories where fonts can be found on some common
operating systems. Extra directories to search can easily by added using the
<em>extradirs</em> parameter, which accepts a comma-separated list. An extra
directory may optionally contain an environment variable <em>at the start</em>
of the string, if enclosed in ${xxx} syntax (see examples above).
-<p>
-The module will normally write to the standard fontcap file location,
+<p>The module will normally write to the standard fontcap file location,
<tt>$GISBASE/etc/fontcap</tt>. If the environment variable
<strong>GRASS_FONT_CAP</strong> is set, the output will instead be written
to the file specified by that variable. This is useful if you don't have
@@ -39,12 +36,10 @@
g.mkfontcap
</pre></div>
-<p>
-to create a personal copy and then to make GRASS use that file
+<p>to create a personal copy and then to make GRASS use that file
instead of the system copy.
-<p>
-The output list of fonts is sorted first by type (Stroke fonts first,
+<p>The output list of fonts is sorted first by type (Stroke fonts first,
followed by Freetype) and within each type by the short name of the font.
<h2>SEE ALSO</h2>
Modified: grass/trunk/general/g.mlist/g.mlist.html
--- grass/trunk/general/g.mlist/g.mlist.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.mlist/g.mlist.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>g.mlist</em> searches for data files matching a pattern given by
wildcards or POSIX Extended Regular Expressions.
-<p>
-See the <em>g.list</em> help page for discussion of module options.
+<p>See the <em>g.list</em> help page for discussion of module options.
<h2>EXAMPLES</h2>
@@ -83,8 +82,7 @@
<h2>SEE ALSO</h2>
<em><a href="g.list.html">g.list</a></em>
-<p>
-<a href="http://en.wikipedia.org/wiki/Regular_expression">Regular expressions</a>
+<p><a href="http://en.wikipedia.org/wiki/Regular_expression">Regular expressions</a>
(aka regex) - from Wikipedia, the free encyclopedia
@@ -93,5 +91,4 @@
Huidae Cho<br>
grass4u at gmail.com
-<p>
Modified: grass/trunk/general/g.mremove/g.mremove.html
--- grass/trunk/general/g.mremove/g.mremove.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.mremove/g.mremove.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,8 +15,7 @@
<h2>SEE ALSO</h2>
-<p>
-<a href="http://en.wikipedia.org/wiki/Regular_expression">Regular expression</a> (from Wikipedia, the free encyclopedia)
+<p><a href="http://en.wikipedia.org/wiki/Regular_expression">Regular expression</a> (from Wikipedia, the free encyclopedia)
<h2>AUTHOR</h2>
Modified: grass/trunk/general/g.parser/g.parser.html
--- grass/trunk/general/g.parser/g.parser.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.parser/g.parser.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -44,11 +44,9 @@
and the value of flag with key <b>f</b> will be available in variable
<b>GIS_FLAG_F</b>.
-<p>
-For flags, the value will be "1" if the flag was given, and "0" otherwise.
+<p>For flags, the value will be "1" if the flag was given, and "0" otherwise.
-<p>
-If the <b>-s</b> switch is used, the options and flags are written to
+<p>If the <b>-s</b> switch is used, the options and flags are written to
stdout in the form <em>opt_<name>=<value></em> and
<em>flag_<name>=<value></em>, preceded by the string
<b>@ARGS_PARSED@</b>. If this string doesn't appear as the first line
@@ -57,8 +55,7 @@
<em>g.parser</em> to stdout should be copied to the script's stdout
verbatim.
-<p>
-Typical header definitions are as follows:
+<p>Typical header definitions are as follows:
#%module
@@ -96,23 +93,20 @@
done
</pre></div>
-<p>
-A "<tt>guisection</tt>" field may be added to each option and flag to specify
+<p>A "<tt>guisection</tt>" field may be added to each option and flag to specify
that the options should appear in multiple tabs in the auto-generated GUI.
Any options without a <tt>guisection</tt> field go into the "Options" tab.
For example:
<pre>#% guisection: tabname</pre>
would put that option in a tab named <i>tabname</i>.
-<p>
-A "<tt>key_desc</tt>" field may be added to each option to specify the text that
+<p>A "<tt>key_desc</tt>" field may be added to each option to specify the text that
appears in the module's usage help section. For example:
<pre>#% key_desc: filename</pre>
added to an <b>input</b> option would create the usage summary
<tt>[input=filename]</tt>.
-<p>
-If a script is run with --o, G_parser() will
+<p>If a script is run with --o, G_parser() will
set <tt>GRASS_OVERWRITE=1</tt>, which has the same effect as passing
--o to every module which is run from the script. Similarly, passing
--q or --v will set <tt>GRASS_VERBOSE</tt> to 0 or 3 respectively,
@@ -420,15 +414,13 @@
</em>
and the <tt>SUBMITTING_SCRIPTS</tt> file in the GRASS source code.
-<p>
-Related Wiki pages:
+<p>Related Wiki pages:
<a href="http://grass.osgeo.org/wiki/Category:Linking_to_other_languages">Using GRASS with other programming languages</a>
<h2>AUTHOR</h2>
Glynn Clements
-<p>
</body>
</html>
Modified: grass/trunk/general/g.pnmcat/g.pnmcat.html
--- grass/trunk/general/g.pnmcat/g.pnmcat.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.pnmcat/g.pnmcat.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,16 +1,12 @@
-<p>
-Concatenate PNM tiles into a single image.
-<p>
-This module is for use by NVIZ' "Maximum resolution PPM" option.
-<p>
-It concatenates a grid of <rows> x <cols> binary PPM
+<p>Concatenate PNM tiles into a single image.
+<p>This module is for use by NVIZ' "Maximum resolution PPM" option.
+<p>It concatenates a grid of <rows> x <cols> binary PPM
images into a single image. The images must all be named
<base>_<row>_<col>.ppm, where <row> and
<col> start from one, with row one being the bottom row, and
where <base> is the value of the <em>base=</em> option.
-<p>
-All images within a row must have the same height, and the widths must
+<p>All images within a row must have the same height, and the widths must
sum to the value of the <em>width=</em> option. The heights of the individual
rows must sum to the value of the <em>height=</em> option. All images must be
in "P6" (binary PPM) format.
Modified: grass/trunk/general/g.proj/g.proj.html
--- grass/trunk/general/g.proj/g.proj.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.proj/g.proj.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,7 +2,7 @@
<p><em>g.proj</em> provides a means of converting a co-ordinate system
description (i.e. projection information) between various formats.
-If compiled without <a href="http://www.gdal.org/ogr/">OGR</A> present, the
+If compiled without <a href="http://www.gdal.org/ogr/">OGR</a> present, the
functionality is limited to:
<ul>
<li>Reporting the projection information for the current location,
@@ -105,31 +105,27 @@
g.proj -p
</pre></div>
-<p>
-Create a '.prj' file in ESRI format corresponding to the current location:<br>
+<p>Create a '.prj' file in ESRI format corresponding to the current location:<br>
g.proj -wef > irish_grid.prj
</pre></div>
-<p>
-Read the projection information from a geotiff file and print it in PROJ.4
+<p>Read the projection information from a geotiff file and print it in PROJ.4
format:<br>
g.proj -jf georef=ASTER_DEM20020508161837.tif
</pre></div>
-<p>
-Convert the PROJ.4 projection description contained in a text file to WKT
+<p>Convert the PROJ.4 projection description contained in a text file to WKT
format:<br>
cat proj4.description | g.proj -w proj4=-
</pre></div>
-<p>
-Create a new location with the co-ordinate system referred to by EPSG code
+<p>Create a new location with the co-ordinate system referred to by EPSG code
4326 (Latitude-Longitude/WGS84), without explicitly specifiying datum
transformation parameters:<br>
@@ -137,47 +133,41 @@
g.proj -c epsg=4326 location=latlong
</pre></div>
-<p>
-Create a new location with the co-ordinate system referred to by ESRI-EPSG code
+<p>Create a new location with the co-ordinate system referred to by ESRI-EPSG code
900913 (<a href="http://spatialreference.org/ref/user/6/">Google Mercator Projection</a>)<br>
g.proj -c epsg=900913 loc=google
</pre></div>
-<p>
29900 (Irish Grid), selecting datum transformation parameter set no. 2:<br>
g.proj -c epsg=29900 datumtrans=2 location=irish_grid
</pre></div>
-<p>
-Create a new location with the same co-ordinate system as the current
+<p>Create a new location with the same co-ordinate system as the current
location, but forcing a change to datum transformation parameter set no. 1:<br>
g.proj -c location=newloc -t datumtrans=1
</pre></div>
-<p>
-List the possible datum transformation parameters for the current location:<br>
+<p>List the possible datum transformation parameters for the current location:<br>
g.proj -t datumtrans=-1
</pre></div>
-<p>
-Create a new location with the co-ordinate system from a WKT definition
+<p>Create a new location with the co-ordinate system from a WKT definition
stored in a text file:<br>
g.proj -c wkt=irish_grid.prj location=irish_grid
</pre></div>
-<p>
-Reproject external raster map to current GRASS projection (does not always make sense!)
+<p>Reproject external raster map to current GRASS projection (does not always make sense!)
using the GDAL 'gdalwarp' tool. We recommend to use the ERDAS/Img format and not
to use the ESRI style of WKT:<br>
@@ -185,8 +175,7 @@
gdalwarp -of HFA -tr 30 30 -t_srs "`g.proj -wf`" aster.img aster_tmerc.img
</pre></div>
-<p>
-Reproject external vector map to current GRASS projection
+<p>Reproject external vector map to current GRASS projection
using the OGR 'ogr2ogr' tool:<br>
ogr2ogr -t_srs "`g.proj -wf`" polbnda_italy_GB_ovest.shp polbnda_italy_LL.shp
@@ -199,8 +188,7 @@
<a href="http://www.gdal.org">GDAL raster library and toolset</a><br>
<a href="http://www.gdal.org/ogr/">OGR vector library and toolset</a>
-<p>
-<b>Further reading</b>
+<p><b>Further reading</b>
<ul>
<li> <a href="http://www.asprs.org/resources/grids/">ASPRS Grids and Datum</a>
<li> <a href="http://www.mapref.org">MapRef - The Collection of Map Projections and Reference Systems for Europe</a>
Modified: grass/trunk/general/g.region/g.region.html
--- grass/trunk/general/g.region/g.region.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.region/g.region.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -27,7 +27,6 @@
"cells").
<p>
The region's boundaries are given as the northernmost,
southernmost, easternmost, and westernmost points that
define its extent (cell edges). The north and south boundaries
@@ -35,7 +34,6 @@
boundaries are called <em>eastings</em>.
<p>
The region's cell resolution defines the size of the
smallest piece of data recognized (imported, analyzed,
displayed, stored, etc.) by GRASS modules affected by the
@@ -43,8 +41,7 @@
resolutions need not be the same, thus allowing non-square
data cells to exist.
-<p>
-Typically all raster and display modules are affected by the current
+<p>Typically all raster and display modules are affected by the current
region settings, but not vector modules.
Some special modules diverge from this rule, for example raster import
modules and <em>v.in.region</em>.
@@ -96,14 +93,12 @@
north/south resolution and that the east/west distance is a
multiple of the east/west resolution.
-<p>
-With the <b>-a</b> flag all four boundaries are adjusted
+<p>With the <b>-a</b> flag all four boundaries are adjusted
to be even multiples of the resolution, aligning the region to the
resolution supplied by the user. The default is to
align the region resolution to match the region boundaries.
-<p>
-The <b>-m</b> flag will report the region resolution in meters. The
+<p>The <b>-m</b> flag will report the region resolution in meters. The
resolution is calculated by averaging the resolution at the region
boundaries. This resolution is calculated by dividing the geodesic
distance in meters at the boundary by the number of rows or columns.
@@ -119,12 +114,10 @@
-<p>
-The <b>-p</b> (or <b>-g</b>) option is recognized
+<p>The <b>-p</b> (or <b>-g</b>) option is recognized
last. This means that all changes are applied to the
region settings before printing occurs.
-<p>
-The <b>-g</b> flag prints the current region settings in shell script style.
+<p>The <b>-g</b> flag prints the current region settings in shell script style.
This format can be given back to <em>g.region</em> on its command line.
This may also be used to save region settings as shell environment variables
with the UNIX eval command, "<tt>eval `g.region -g`</tt>".
@@ -145,8 +138,7 @@
layer that fall inside the user's current region. In this
way you can tightly zoom in on isolated clumps within a
bigger map.
-<p>
-If the user also includes the <b>rast=</b><em>name</em>
+<p>If the user also includes the <b>rast=</b><em>name</em>
option on the command line, <b>zoom=</b><em>name</em> will
set the current region settings to the smallest region
encompassing all non-NULL data in the named <b>zoom</b> map
@@ -179,7 +171,6 @@
cell resolutions unchanged.
<p>
<dt><span class="code"><tt>
g.region n=51:36:05N e=10:10:05E s=51:29:55N w=9:59:55E res=0:00:01
</tt></span>
@@ -189,7 +180,6 @@
(decimal degrees and degrees with decimal minutes can also be used).
<p>
g.region -dp s=698000
</tt></span>
@@ -199,7 +189,6 @@
698000, and then print the result.
<p>
g.region n=n+1000 w=w-500
</tt></span>
@@ -214,7 +203,6 @@
decreased by 500 units.
<p>
g.region n=s+1000 e=w+1000
</tt></span>
@@ -228,7 +216,6 @@
corresponding forms s=n-<em>value</em> and
<p>
w=e-<em>value</em> may be used to set the values of the
region's southern and western boundaries, relative to the
northern and eastern boundary values.
@@ -244,7 +231,6 @@
<p>
g.region rast=soils zoom=soils
</tt></span>
@@ -261,7 +247,6 @@
<p>
g.region -up rast=soils
</tt></span>
@@ -273,7 +258,6 @@
without changing the current region settings.
<p>
g.region -up zoom=soils save=soils
</tt></span>
@@ -286,7 +270,6 @@
changed.
<p>
g.region b=0 t=3000 tbres=200 res3=100
g.region -p3
@@ -298,7 +281,6 @@
is defined.
<p>
g.region -p
</tt></span>
@@ -321,7 +303,6 @@
</pre></div>
<p>
g.region -p3
</tt></span>
@@ -353,7 +334,6 @@
</pre></div>
<p>
g.region -g
</tt></span>
@@ -373,7 +353,6 @@
</pre></div>
<p>
g.region -bg
</tt></span>
@@ -398,7 +377,6 @@
</pre></div>
<p>
g.region -l
</tt></span>
@@ -418,7 +396,6 @@
</pre></div>
<p>
g.region -pm
</tt></span>
@@ -443,8 +420,7 @@
</dl>
-<p>
-Usage example of <em>g.region</em> in a shell with external software:<br>
+<p>Usage example of <em>g.region</em> in a shell with external software:<br>
<!-- why not 'v.in.ogr spatial=' ?? -->
Extract spatial subset of external vector map 'soils.shp' to new external
vector map 'soils_cut.shp' using the OGR 'ogr2ogr' tool:<br>
@@ -457,8 +433,7 @@
This requires that the location/SHAPE file projection match.
-<p>
-Usage example of <em>g.proj</em> and <em>g.region</em> in a shell with external software:<br>
+<p>Usage example of <em>g.proj</em> and <em>g.region</em> in a shell with external software:<br>
Extract spatial subset of external raster map 'p016r035_7t20020524_z17_nn30.tif'
to new external raster map'p016r035_7t20020524_nc_spm_wake_nn30.tif using the GDAL
'gdalwarp' tool:<br>
@@ -493,5 +468,4 @@
Research Laboratory
-<p>
Modified: grass/trunk/general/g.remove/g.remove.html
--- grass/trunk/general/g.remove/g.remove.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.remove/g.remove.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -30,7 +30,6 @@
files along with the data base element file specified.
<p>
The user can only use <em>g.remove</em> to remove data
files existing under the user's <em>current mapset</em>.
Modified: grass/trunk/general/g.rename/g.rename.html
--- grass/trunk/general/g.rename/g.rename.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.rename/g.rename.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,7 +15,6 @@
<p>
Users can also simply type <em>g.rename -help</em> without
arguments on the command line, to receive a menu of
existing data base element types and files from which to
@@ -42,7 +41,6 @@
also are renamed.
<p>
If the user attempts to rename a file to itself by setting
the <em>new</em> file name equal to the <em>old</em> file
name (e.g., <b>g.rename rast=soils,soils</b>),
@@ -52,8 +50,7 @@
will allow the user to overwrite other existing files in
the current mapset by making the <em>new</em> file name
that of an already existing file.
-<p>
-For portability reasons, <em>g.rename</em> is ignoring case of
+<p>For portability reasons, <em>g.rename</em> is ignoring case of
names. To change the case of a map name, first rename the map
to a name which differs by more than case, then rename it to
the intended name.
Modified: grass/trunk/general/g.setproj/g.setproj.html
--- grass/trunk/general/g.setproj/g.setproj.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.setproj/g.setproj.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -36,7 +36,7 @@
<p>The user will be prompted for the projection name.
Most projections are supported. The
-<a href="http://proj.maptools.org/">PROJ.4</A> abbreviations for the names are
+<a href="http://proj.maptools.org/">PROJ.4</a> abbreviations for the names are
used with two exceptions, viz. 'll', for latitude / longitude geographic
co-ordinates, and 'stp', for the State Plane Co-ordinate system (used in the
USA).
@@ -56,7 +56,6 @@
the various other parameters required to define it.
<p>
The projections of aea, lcc, merc, leae, leac, and
tmerc will generate a request to the user for the prime meridian and standard
parallel for the output map.
@@ -64,14 +63,13 @@
<h2>SEE ALSO</h2>
-<em><a href="g.proj.html">g.proj</A></em>,
-<em><a href="m.proj.html">m.proj</A></em>,
-<em><a href="r.proj.html">r.proj</A></em>,
-<em><a href="v.proj.html">v.proj</A></em>,
-<em><a href="http://proj.maptools.org">PROJ.4</A></em>
+<em><a href="g.proj.html">g.proj</a></em>,
+<em><a href="m.proj.html">m.proj</a></em>,
+<em><a href="r.proj.html">r.proj</a></em>,
+<em><a href="v.proj.html">v.proj</a></em>,
+<em><a href="http://proj.maptools.org">PROJ.4</a></em>
-<p>
<ul>
<li> A guide to <a href="http://erg.usgs.gov/isb/pubs/MapProjections/projections.html">Map Projections</a> by USGS
@@ -87,8 +85,7 @@
Morten Hulden, morten at untamo.net - rewrote module and added 121 projections <br>
Andreas Lange, andreas.lange at rhein-main.de - added prelimnary map datum support
-<p>
</body>
Modified: grass/trunk/general/g.tempfile/g.tempfile.html
--- grass/trunk/general/g.tempfile/g.tempfile.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.tempfile/g.tempfile.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -9,7 +9,6 @@
by programs that failed to remove them before terminating.
<p>
<em>g.tempfile</em>
creates an unique file and prints the name. The user is required to provide
a process-id which will be used as part of the name of the file.
Modified: grass/trunk/general/g.version/g.version.html
--- grass/trunk/general/g.version/g.version.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/general/g.version/g.version.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -52,5 +52,4 @@
U.S. Army Construction Engineering
Research Laboratory
-<p>
Modified: grass/trunk/imagery/i.albedo/i.albedo.html
--- grass/trunk/imagery/i.albedo/i.albedo.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.albedo/i.albedo.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -23,5 +23,4 @@
Yann Chemin, International Rice Research Institute, The Philippines
-<p>
Modified: grass/trunk/imagery/i.aster.toar/i.aster.toar.html
--- grass/trunk/imagery/i.aster.toar/i.aster.toar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.aster.toar/i.aster.toar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -29,13 +29,12 @@
<h2>SEE ALSO</h2>
<em>
-<a href="i.landsat.toar.html">i.landsat.toar</A><br>
-<a href="r.in.aster.html">r.in.aster</A><br>
+<a href="i.landsat.toar.html">i.landsat.toar</a><br>
+<a href="r.in.aster.html">r.in.aster</a><br>
</em>
<h2>AUTHORS</h2>
Yann Chemin, CSU, Australia
-<p>
Modified: grass/trunk/imagery/i.atcorr/i.atcorr.html
--- grass/trunk/imagery/i.atcorr/i.atcorr.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.atcorr/i.atcorr.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,30 +7,25 @@
<a href="http://modis-sr.ltdri.org/">Land Surface
Reflectance Science Computing Facility website</a>.
-<p>
-<em>Important note: Current region settings are ignored!</em> The region is adjusted
+<p><em>Important note: Current region settings are ignored!</em> The region is adjusted
to cover the input raster map before the atmospheric correction is
performed. The previous settings are restored afterwards.
-<p>
-Because using a <b>elevation</b> and/or <b>visibility</b>
+<p>Because using a <b>elevation</b> and/or <b>visibility</b>
raster map makes execution time much longer, it is advised to use
the optimization flag <b>-o</b>.
This flag tells <em>i.atcorr</em> to try and speedup calculations.
However, this option will increase memory requirements.
-<p>
-If flag <b>-r</b> is used, the input raster data are treated as
+<p>If flag <b>-r</b> is used, the input raster data are treated as
<em>reflectance</em>. Otherwise, the input raster data are treated
as <em>radiance</em> values and are converted to reflectance at
the <em>i.atcorr</em> runtime. The output data are always reflectance.
-<p>
-Note that the satellite overpass time has to be specified in Greenwich
+<p>Note that the satellite overpass time has to be specified in Greenwich
Mean Time (GMT).
-<p>
-An example 6S parameters:
+<p>An example 6S parameters:
8 - geometrical conditions=Landsat ETM+
@@ -364,8 +359,7 @@
0.112 - aerosol optical depth 550 nm
</pre></div>
-<p>
-NOTE: if iaer is 0, enter -1 for visibility.
+<p>NOTE: if iaer is 0, enter -1 for visibility.
<h3>E. Target altitude (xps), sensor platform (xpp)</h3>
@@ -375,8 +369,7 @@
in [km], given as negative value
</blockquote>
-<p>
-Sensor platform (xpp, in negative [km] or -1000):
+<p>Sensor platform (xpp, in negative [km] or -1000):
<blockquote>
<br>xpp = -1000 means that the sensor is on board a satellite.
<br>xpp = 0 means that the sensor is at the ground level.
@@ -384,8 +377,7 @@
this altitude is given <b>relative to the target</b> altitude as negative value.
</blockquote>
-<p>
-For aircraft simulations only (xpp is neither equal to 0 nor equal to -1000):
+<p>For aircraft simulations only (xpp is neither equal to 0 nor equal to -1000):
<blockquote>
puw,po3 (water vapor content,ozone content between the aircraft and the surface)
<br>taerp (the aerosol optical thickness at 550nm between the aircraft and the
@@ -436,8 +428,7 @@
</tr>
</table>
-<p>
-Pre-defined satellite bands:
+<p>Pre-defined satellite bands:
<table border="1">
@@ -590,7 +581,6 @@
In this case, we have: SUN_AZIMUTH = 120.8810347, SUN_ELEVATION = 64.7730999.
<p>
If the sun position metadata are unavailable, we can also calculate
them from the overpass time as follows
(<em><a href="r.sunmask.html">r.sunmask</a></em>
@@ -601,8 +591,7 @@
</pre></div>
If the overpass time is unknown, use the <a href="http://www-air.larc.nasa.gov/tools/predict.htm">Satellite Overpass Predictor</a>.
-<p>
-Convert DN (digital number = pixel values) to Radiance at top-of-atmosphere (TOA), using the
+<p>Convert DN (digital number = pixel values) to Radiance at top-of-atmosphere (TOA), using the
formula
Lλ = ((LMAXλ - LMINλ)/(QCALMAX-QCALMIN)) * (QCAL-QCALMIN) + LMINλ
@@ -625,8 +614,7 @@
<a href="http://landsathandbook.gsfc.nasa.gov/handbook/handbook_htmls/chapter11/chapter11.html">Landsat handbook</a>),
and the maximal DN value (QCALMAX) is 255. QCAL is the DN value for every
separate pixel in the Landsat image.
-<p>
-We extract the coefficients and apply them in order to obtain the radiance map:
+<p>We extract the coefficients and apply them in order to obtain the radiance map:
CHAN=4
r.info lsat7_2002_${CHAN}0 -h | tr '\n' ' ' | sed 's+ ++g' | tr ':' '\n' | grep "LMIN_BAND${CHAN}\|LMAX_BAND${CHAN}"
@@ -676,8 +664,7 @@
to compute the initial transform. It is necessary to give a value which could
be the mean value of the elevation model. For the atmospheric correction then
the raster elevation values are used from the map.
-<p>
-Note that the process is computationally intensive.<br>
+<p>Note that the process is computationally intensive.<br>
Note also, that <em>i.atcorr</em> reports solar elevation angle above horizon rather than solar zenith angle.
<h2><font color="red">REMAINING DOCUMENTATION ISSUES</font></h2>
@@ -689,8 +676,7 @@
GRASS Wiki page about
<a href="http://grass.osgeo.org/wiki/Atmospheric_correction">Atmospheric correction</a>
-<p>
-<em>
+<p><em>
<a href="r.info.html">r.info</a>,
<a href="r.mapcalc.html">r.mapcalc</a>,
<a href="r.univar.html">r.univar</a>
@@ -738,6 +724,5 @@
<p><em>VGT1 and VGT2 sensors addition from <a href="http://6s.ltdri.org/">6SV-1.1 sources</a>, addition 07/2011:</em>
<br>Alfredo Alessandrini, Anne Ghisla
-<p>
Modified: grass/trunk/imagery/i.biomass/i.biomass.html
--- grass/trunk/imagery/i.biomass/i.biomass.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.biomass/i.biomass.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -21,7 +21,7 @@
<h2>SEE ALSO</h2>
<em>
-<a href="i.eb.evapfr">i.eb.evapfr</A><br>
+<a href="i.eb.evapfr">i.eb.evapfr</a><br>
</em>
<h2>REFERENCES</h2>
@@ -35,5 +35,4 @@
Yann Chemin, Bec de Mortagne, France
-<p>
Modified: grass/trunk/imagery/i.cca/i.cca.html
--- grass/trunk/imagery/i.cca/i.cca.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.cca/i.cca.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,9 +11,8 @@
transformation".
<p>
Typically the user will use the
-<em><a href="i.class.html">i.class</A></em>
+<em><a href="i.class.html">i.class</a></em>
program to collect a set of signatures and then pass those
signatures along with the raster band files to
<em>i.cca</em>. The raster band file names are specified
@@ -21,23 +20,22 @@
were used to collect the signatures.
<p>
The output raster map names are built by appending a ".1",
".2", etc. to the output raster map name specified on the
command line.
-<H3>Parameters:</H3>
+<h3>Parameters:</h3>
<dl>
<dt><b>group=</b><em>name</em>
-<dd>Name of the <a href="i.group.html">imagery</A> group
+<dd>Name of the <a href="i.group.html">imagery</a> group
to which the 2 to 8 raster band files used belong.
<dt><b>subgroup=</b><em>name</em>
subgroup to which the 2 to 8 raster band files used
belong.
@@ -64,12 +62,11 @@
Classification in Remote Sensing</b>, Academic Press, 1983.
<p>
+<em><a href="i.class.html">i.class</a></em><br>
+<em><a href="i.pca.html">i.pca</a></em><br>
+<em><a href="r.covar.html">r.covar</a></em><br>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>
-<em><a href="i.class.html">i.class</A></em><br>
-<em><a href="i.pca.html">i.pca</A></em><br>
-<em><a href="r.covar.html">r.covar</A></em><br>
-<em><a href="r.mapcalc.html">r.mapcalc</A></em>
<h2>AUTHORS</h2>
David Satnik, GIS Laboratory,
Modified: grass/trunk/imagery/i.class/i.class.html
--- grass/trunk/imagery/i.class/i.class.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.class/i.class.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,12 +4,11 @@
performs the first pass in the GRASS two-pass supervised image
classification process;
the GRASS program
-<em><a href="i.maxlik.html">i.maxlik</A></em> executes the second pass.
+<em><a href="i.maxlik.html">i.maxlik</a></em> executes the second pass.
Both programs must be run to generate a classified map in GRASS
raster format.
<p>
<em>i.class</em> is an interactive program that allows the user to outline
a region on the screen and calculate the spectral signature based on the
cells that are within that region. During this process the user will be
@@ -21,18 +20,16 @@
<p>
The spectral signatures that result are composed of region means and
covariance matrices. These region means and covariance matrices are used in
-the second pass (<em><a href="i.maxlik.html">i.maxlik</A></em>) to classify
+the second pass (<em><a href="i.maxlik.html">i.maxlik</a></em>) to classify
the image.
<p>
Alternatively, the spectral signatures generated by <em>i.class</em> can be
used for seed means for the clusters in the
-<em><a href="i.cluster.html">i.cluster</A></em> program.
+<em><a href="i.cluster.html">i.cluster</a></em> program.
<h2>USER INPUTS</h2>
@@ -41,7 +38,7 @@
to be displayed during the process of outlining regions.
Typically, the user will want to enter the name of a color
composite previously created by
-<em><a href="r.composite.html">r.composite</A></em>.
+<em><a href="r.composite.html">r.composite</a></em>.
However, the user can enter the name of any existing raster
map. This leaves the potential for using a raster map not
@@ -49,9 +46,8 @@
user can outline the classes of interest.
<p>
The first screen in the program <em>i.class</em> asks the user for the
-<a href="i.group.html">imagery</A> <em>group</em> and <em>subgroup</em>
+<a href="i.group.html">imagery</a> <em>group</em> and <em>subgroup</em>
to be analyzed:
@@ -69,30 +65,27 @@
</pre></div>
<p>
The <em>group</em> should contain the
imagery bands that the user wishes
to classify. The <em>subgroup</em> is a subset of this group.
The user must create a group and a subgroup by running the GRASS program
-<em><a href="i.group.html">i.group</A></em>
+<em><a href="i.group.html">i.group</a></em>
before running <em>i.class</em>. The subgroup should contain
only the image bands that the user wishes to classify.
Note that this subgroup must contain more than one band.
<p>
After the first screen, the program asks the user for the name of the
resulting signature file. The signature file is both the output file for
<em>i.class</em> and the required input file for the GRASS
-<em><a href="i.maxlik.html">i.maxlik</A></em> module.
+<em><a href="i.maxlik.html">i.maxlik</a></em> module.
It contains the region means and covariance matrices that are used to
-classify an image in <em><a href="i.maxlik.html">i.maxlik</A></em>.
+classify an image in <em><a href="i.maxlik.html">i.maxlik</a></em>.
The signature file will be saved in the
<tt>$MAPSET/group/$GROUP/subgroup/$SUBGROUP/sig/</tt> directory.
<p>
After entering the resulting signature file name, the user
is asked to enter the name of a seed signature file. This
is optional. A "seed" signature file is a previously
@@ -105,7 +98,6 @@
signature file.
<p>
At this point the <em>i.class</em> graphics screen will be
drawn on the graphics monitor and the user will be directed
to use the mouse. From this point on the user will
@@ -156,7 +148,7 @@
<A NAME="commandmenu"></a>
-<H3>The Command Menu</H3>
+<h3>The Command Menu</h3>
The Command Menu includes the following selections:
@@ -171,7 +163,6 @@
indicating what area the Zoom Display Frame shows.
<p>
To outline the rectangular region simply use any mouse button to anchor
the first corner of the border and then use any button to choose the
other corner.
@@ -181,7 +172,7 @@
<dt><em>Define region</em>
<dd>This selection takes the user to the
-<a href="#regionmenu">Region Menu</A>.
+<a href="#regionmenu">Region Menu</a>.
This menu includes the
options that allow the user to outline a region of interest
on the displayed raster map.
@@ -191,7 +182,7 @@
<dd>This selection takes the user to the Redisplay Menu.
The
-<a href="#redisplaymenu">Redisplay Menu</A>
+<a href="#redisplaymenu">Redisplay Menu</a>
allows the user to redraw map display
frames.
@@ -208,7 +199,7 @@
possible, centered around the mean, will be displayed.
After the histograms are displayed, the user will be given
the
-<a href="#signaturemenu">Signature Menu</A>.
+<a href="#signaturemenu">Signature Menu</a>.
<dt><em>Quit</em>
<dd>The user should make this selection
@@ -217,7 +208,7 @@
</dl>
<A NAME="regionmenu"></a>
-<H3>The Region Menu</H3>
+<h3>The Region Menu</h3>
The Region Menu contains the following selections:
@@ -246,16 +237,16 @@
currently being drawn. As noted above, it saves the complete
region to be restored later, if needed. Once the user has made a
complete region, it can be analyzed with the Analyze Region
-selection on the <a href="#commandmenu">Command Menu</A>.
+selection on the <a href="#commandmenu">Command Menu</a>.
<dt><em>Done</em>
<dd>Use this selection to return to the
-<a href="#commandmenu">Command Menu</A>.
+<a href="#commandmenu">Command Menu</a>.
</dl>
<A NAME="redisplaymenu"></a>
-<H3>The Redisplay Map Menu</H3>
+<h3>The Redisplay Map Menu</h3>
The Redisplay Map Menu has the following selections, which are useful
to redraw the raster maps displayed in the Map and Zoom Display Frames.
@@ -278,12 +269,12 @@
<dt><em>Cancel</em>
<dd>Use this selection if you do not want to redisplay
either of the above regions. The user will be returned to the
</dl>
<A NAME="signaturemenu"></a>
-<H3>The Analyze Region Menu</H3>
+<h3>The Analyze Region Menu</h3>
The Analyze Region Menu contains the Signature Menu, which
allows the user to set the number of standard deviations
@@ -313,7 +304,6 @@
<p>
Note that the number in parentheses on this
selection is the current number of standard deviations.
@@ -327,7 +317,6 @@
selection is made.
<p>
Note that the color in parentheses on this selection is the current
color for display.
@@ -348,7 +337,7 @@
he/she will be asked to enter a description for the
resultant signature file on the text terminal keyboard.
The saved signature file description will be used by <em>
-<a href="i.maxlik.html">i.maxlik</A></em> to name the
+<a href="i.maxlik.html">i.maxlik</a></em> to name the
category that is created from the current signature. After
either a "No" answer or the signature description is
entered, the user is returned to the Command Menu.
@@ -363,46 +352,41 @@
a MASK already exists it will be removed during the
execution of this program.
-<p>
-The cell values in the image bands cannot fall outside of
+<p>The cell values in the image bands cannot fall outside of
the range of 0 to 255. <em>i.class</em> will report an
error if they do.
-<p>
-<em>i.class</em>, like some of the other
-<a href="imagery.html">imagery</A> programs, does not use the
+<p><em>i.class</em>, like some of the other
+<a href="imagery.html">imagery</a> programs, does not use the
standard GRASS display frames. After running
<em>i.class</em>, you will need to create a display frame
(e.g., using
-<em><a href="d.frame.html">d.frame</A></em> or
+<em><a href="d.frame.html">d.frame</a></em> or
-<em><a href="d.erase.html">d.erase</A></em>)
+<em><a href="d.erase.html">d.erase</a></em>)
before you can use most of the GRASS display (d.) commands.
-<p>
+<p><em><a href="i.group.html">i.group</a></em>
must be run before <em>i.class</em> to create an
-<a href="i.group.html">imagery</A> group and a subgroup
+<a href="i.group.html">imagery</a> group and a subgroup
containing the image bands to be classified.
-<p>
-The user can perform a supervised image classification by
+<p>The user can perform a supervised image classification by
running <em>i.class</em> followed by
-<em><a href="i.maxlik.html">i.maxlik</A></em>.
+<em><a href="i.maxlik.html">i.maxlik</a></em>.
The user can perform an unsupervised classification
by running
-<em><a href="i.cluster.html">i.cluster</A></em> followed by
+<em><a href="i.cluster.html">i.cluster</a></em> followed by
-<p>
-<em>i.class</em> is interactive and requires the user to be running
-a graphics display monitor (see <em><a href="d.mon.html">d.mon</A></em>)
+<p><em>i.class</em> is interactive and requires the user to be running
+a graphics display monitor (see <em><a href="d.mon.html">d.mon</a></em>)
to run this program.
@@ -410,23 +394,21 @@
The GRASS 4 <em>
<a href="http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf">Image
-Processing manual</A></em>
+Processing manual</a></em>
-<p>
-<em><a href="d.frame.html">d.frame</A>,
-<a href="d.mon.html">d.mon</A>,
-<a href="g.region.html">g.region</A>,
-<a href="i.cca.html">i.cca</A>,
-<a href="i.cluster.html">i.cluster</A>,
-<a href="r.composite.html">r.composite</A>,
-<a href="i.group.html">i.group</A>,
-<a href="i.maxlik.html">i.maxlik</A>,
-<a href="r.mapcalc.html">r.mapcalc</A></em>
+<p><em><a href="d.frame.html">d.frame</a>,
+<a href="d.mon.html">d.mon</a>,
+<a href="g.region.html">g.region</a>,
+<a href="i.cca.html">i.cca</a>,
+<a href="i.cluster.html">i.cluster</a>,
+<a href="r.composite.html">r.composite</a>,
+<a href="i.group.html">i.group</a>,
+<a href="i.maxlik.html">i.maxlik</a>,
+<a href="r.mapcalc.html">r.mapcalc</a></em>
<h2>AUTHOR</h2>
David Satnik,
Central Washington University
-<p>
Modified: grass/trunk/imagery/i.cluster/i.cluster.html
--- grass/trunk/imagery/i.cluster/i.cluster.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.cluster/i.cluster.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,8 +7,7 @@
the second pass. Both programs must be run to complete the unsupervised
classification.
-<p>
-<em>i.cluster</em> is a clustering algorithm that reads
+<p><em>i.cluster</em> is a clustering algorithm that reads
through the (raster) imagery data and builds pixel clusters
based on the spectral reflectances of the pixels (see Figure).
The pixel clusters are imagery categories that can be related
@@ -18,8 +17,7 @@
by the user. The first parameter set by the user is the
initial number of clusters to be discriminated.
-<p>
-<center>
+<p><center>
<img src="landsat_cluster.png" border=1><br>
<table border=0 width=590>
<tr><td><center>
@@ -28,7 +26,6 @@
</table>
</center>
<p>
<em>i.cluster</em> starts by generating spectral signatures
for this number of clusters and "attempts" to end up with
this number of clusters during the clustering process. The
@@ -42,7 +39,6 @@
<p>
The cluster spectral signatures that result are composed of
cluster means and covariance matrices. These cluster means
and covariance matrices are used in the second pass
@@ -75,7 +71,7 @@
discriminated; any parameter values left unspecified are
set to their default values.
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
@@ -88,7 +84,7 @@
</dl>
<dl>
@@ -240,7 +236,6 @@
<p>
<em>
<a href="i.class.html">i.class</a>,
@@ -259,5 +254,4 @@
University of Illinois at
Urbana-Champaign,
Illinois
-<p>
Modified: grass/trunk/imagery/i.eb.eta/i.eb.eta.html
--- grass/trunk/imagery/i.eb.eta/i.eb.eta.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.eb.eta/i.eb.eta.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -21,9 +21,9 @@
<h2>SEE ALSO</h2>
<em>
-<a href="r.sun.html">r.sun</A><br>
-<a href="i.eb.evapfr.html">i.eb.evapfr</A><br>
-<a href="i.eb.netrad.html">i.eb.netrad</A><br>
+<a href="r.sun.html">r.sun</a><br>
+<a href="i.eb.evapfr.html">i.eb.evapfr</a><br>
+<a href="i.eb.netrad.html">i.eb.netrad</a><br>
</em>
<h2>REFERENCES</h2>
@@ -45,5 +45,4 @@
Yann Chemin, Asian Institute of Technology, Thailand
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html
--- grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,9 +10,9 @@
<h2>SEE ALSO</h2>
<em>
-<a href="i.eb.soilheatflux.html">i.eb.soilheatflux</A><br>
-<a href="i.eb.h_SEBAL01.html">i.eb.h_SEBAL01</A><br>
+<a href="i.eb.soilheatflux.html">i.eb.soilheatflux</a><br>
+<a href="i.eb.h_SEBAL01.html">i.eb.h_SEBAL01</a><br>
</em>
<h2>REFERENCES</h2>
@@ -33,5 +33,4 @@
-<p>
Modified: grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html
--- grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -21,9 +21,9 @@
<h2>SEE ALSO</h2>
<em>
-<a href="i.albedo.html">i.albedo</A><br>
+<a href="i.albedo.html">i.albedo</a><br>
</em>
@@ -31,5 +31,4 @@
Yann Chemin, International Rice Research Institute, The Philippines<br>
-<p>
Modified: grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
--- grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -9,11 +9,11 @@
<h2>SEE ALSO</h2>
<em>
-<a href="i.emissivity.html">i.emissivity</A><br>
+<a href="i.emissivity.html">i.emissivity</a><br>
</em>
<h2>REFERENCES</h2>
@@ -34,5 +34,4 @@
Yann Chemin, Asian Institute of Technology, Thailand<br>
-<p>
Modified: grass/trunk/imagery/i.emissivity/i.emissivity.html
--- grass/trunk/imagery/i.emissivity/i.emissivity.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.emissivity/i.emissivity.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,18 +3,16 @@
<em>i.emissivity</em> calculates the emissivity in the longwave radiation
spectrum, according to the semi-empirical equation related to NDVI by
Caselles and Colles (1997), valid in the NDVI range of 0.16 to 0.74.
-<p>
-Estimation in the 8-14 micrometers range for sparse canopy...
+<p>Estimation in the 8-14 micrometers range for sparse canopy...
<h2>SEE ALSO</h2>
<em>
</em>
<h2>AUTHORS</h2>
Yann Chemin, GRASS Development Team<br>
-<p>
Modified: grass/trunk/imagery/i.evapo.mh/i.evapo.mh.html
--- grass/trunk/imagery/i.evapo.mh/i.evapo.mh.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.evapo.mh/i.evapo.mh.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -16,18 +16,14 @@
Hargreaves GL, Hargreaves GH, Riley JP, 1985. Agricultural benefits for
Senegal River Basin. Journal of Irrigation and Drainange Engineering,
ASCE, 111(2):113-124.
-<p>
-Droogers P, Allen RG, 2002. Towards a simplified global reference
+<p>Droogers P, Allen RG, 2002. Towards a simplified global reference
evapotranspiration equation. Irrigation Science.
-<p>
-Droogers, P., and R.G. Allen. 2002. Estimating reference evapotranspiration
+<p>Droogers, P., and R.G. Allen. 2002. Estimating reference evapotranspiration
under inaccurate data conditions. Irrigation and Drainage Systems 16: 33-45.
-<p>
-Hargreaves and Samani, 1985.
+<p>Hargreaves and Samani, 1985.
<h2>AUTHORS</h2>
Yann Chemin, GRASS Development team, 2007-2011<br>
-<p>
Modified: grass/trunk/imagery/i.evapo.pm/i.evapo.pm.html
--- grass/trunk/imagery/i.evapo.pm/i.evapo.pm.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.evapo.pm/i.evapo.pm.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -60,7 +60,7 @@
<h2>REFERENCES</h2>
<p>[1] Cannata M., 2006. <a href="http://istgis.ist.supsi.ch:8001/geomatica/index.php?id=1">
- GIS embedded approach for Free & Open Source Hydrological Modelling</A>. PhD thesis, Department of Geodesy and Geomatics, Polytechnic of Milan, Italy.
+ GIS embedded approach for Free & Open Source Hydrological Modelling</a>. PhD thesis, Department of Geodesy and Geomatics, Polytechnic of Milan, Italy.
<p>[2] Allen, R.G., L.S. Pereira, D. Raes, and M. Smith. 1998.
Crop Evapotranspiration: Guidelines for computing crop water requirements.
Modified: grass/trunk/imagery/i.evapo.pt/i.evapo.pt.html
--- grass/trunk/imagery/i.evapo.pt/i.evapo.pt.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.evapo.pt/i.evapo.pt.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,8 +8,7 @@
RNETD optional output from i.evapo.potrad is giving good results as input
for net radiation in this module.
-<p>
-Alpha values:
+<p>Alpha values:
<ul>
<li> 1.32 for estimates from vegetated areas as a result of the increase in
surface roughness (Morton, 1983; Brutsaert and Stricker, 1979)
@@ -36,5 +35,4 @@
Yann Chemin, GRASS Development team, 2007-08
-<p>
Modified: grass/trunk/imagery/i.evapo.time/i.evapo.time.html
--- grass/trunk/imagery/i.evapo.time/i.evapo.time.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.evapo.time/i.evapo.time.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -64,5 +64,4 @@
<h2>AUTHORS</h2>
-<p>
Modified: grass/trunk/imagery/i.fft/i.fft.html
--- grass/trunk/imagery/i.fft/i.fft.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.fft/i.fft.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>i.fft</em> is an image processing program based on the FFT algorithm
given by Frigo et al. (1998), that processes a single input raster map layer
(<b>input_image</b>) and constructs the real and imaginary Fourier
@@ -18,7 +17,6 @@
<p>
The current geographic region and mask settings are respected when
reading the input file. The presence of nulls or a mask will make the
resulting fast Fourier transform invalid.
@@ -49,17 +47,15 @@
<li> John A. Richards, 1986. Remote Sensing Digital Image Analysis, Springer-Verlag.
</ul>
-<P>
-Personal communication, between progam author and Ali R. Vali,
-Space Research Center, <A HREF="http://www.utexas.edu">University of Texas</A>, Austin, 1990.
+<p>Personal communication, between progam author and Ali R. Vali,
+Space Research Center, <A HREF="http://www.utexas.edu">University of Texas</a>, Austin, 1990.
<p>
+<em><a href="i.cca.html">i.cca</a></em><br>
+<em><a href="i.ifft.html">i.ifft</a></em><br>
-<em><a href="i.cca.html">i.cca</A></em><br>
-<em><a href="i.ifft.html">i.ifft</A></em><br>
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.gensig/i.gensig.html
--- grass/trunk/imagery/i.gensig/i.gensig.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.gensig/i.gensig.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,14 +1,13 @@
<em>i.gensig</em>
is a non-interactive method for generating input into
It can be used as the first pass in the GRASS two-pass
classification process (instead of
or
-<em><a href="i.class.html">i.class</A></em>).
+<em><a href="i.class.html">i.class</a></em>).
It reads a raster map layer, called the training map, which
has some of the pixels or regions already classified.
@@ -16,19 +15,18 @@
from an image based on the classification of the pixels in
the training map and make these signatures available to
<p>
The user would then execute the GRASS program
to actually create the final classified map.
<h2>OPTIONS</h2>
-<H3>Parameters</H3>
+<h3>Parameters</h3>
<dl>
@@ -37,7 +35,6 @@
<dd>ground truth training map
<p>
This map must be prepared by the user in advance using vector or
raster digitizer. Of course other methods could be devised by the user
for creating this training map - <em>i.gensig</em> makes no assumption
@@ -50,25 +47,22 @@
<dd>imagery group
<p>
This is the name of the group that contains the band files
which comprise the image to be analyzed. The <em>
-<a href="i.group.html">i.group</A> </em> command is
+<a href="i.group.html">i.group</a> </em> command is
used to construct groups of raster layers which comprise an
image.
<p>
+<dt><A NAME="subgroup"></a><b>subgroup=</b><em>name</em>
-<dt><A NAME="subgroup"></A><b>subgroup=</b><em>name</em>
<dd>subgroup containing image files
<p>
This names the subgroup within the group that selects a
subset of the bands to be analyzed. The <em>
also used to prepare this subgroup. The subgroup mechanism
allows the user to select a subset of all the band files
that form an image.
@@ -79,11 +73,10 @@
<dd>resultant signature file
<p>
This is the resultant signature file (containing the means
and covariance matrices) for each class in the training map
that is associated with the band files in the subgroup
-select (see <a href="#subgroup">above</A>).
+select (see <a href="#subgroup">above</a>).
</dl>
@@ -95,7 +88,6 @@
<p>
It should be noted that interactive mode here only means
interactive prompting for maps and files.
It does not mean visualization of the signatures that
@@ -104,26 +96,23 @@
<h2>SEE ALSO</h2>
for creating groups and subgroups.
<p>
-<em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector digitizer</A></em>
+<em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector digitizer</a></em>
and
-<em><a href="r.digit.html">r.digit</A></em>
+<em><a href="r.digit.html">r.digit</a></em>
for interactively creating the training map.
<p>
for unsupervised clustering as an alternative to
<em>i.gensig</em> to create signatures.
<p>
for a graphic/interactive as an alternative to
Modified: grass/trunk/imagery/i.gensigset/i.gensigset.html
--- grass/trunk/imagery/i.gensigset/i.gensigset.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.gensigset/i.gensigset.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,10 +1,9 @@
<em>i.gensigset</em>
-<em><a href="i.smap.html">i.smap</A>.</em>
+<em><a href="i.smap.html">i.smap</a>.</em>
It is used as the first pass in the a two-pass
classification process. It reads a raster map layer,
@@ -14,18 +13,17 @@
classification of the pixels in the training map and make
<p>
The user would then execute the GRASS program <em>
-<a href="i.smap.html">i.smap</A></em> to create the
+<a href="i.smap.html">i.smap</a></em> to create the
<h2>OPTIONS</h2>
<dl>
@@ -35,7 +33,6 @@
<p>
This raster layer, supplied as input by the user, has some
of its pixels already classified, and the rest (probably
most) of the pixels unclassified. Classified means that
@@ -43,25 +40,23 @@
the pixel has a zero value.
<p>
This map must be prepared by the user in advance.
The user must use
-<em><a href="r.digit.html">r.digit</A></em>,
+<em><a href="r.digit.html">r.digit</a></em>,
a combination of
and
-<em><a href="v.to.rast.html">v.to.rast</A></em>,
+<em><a href="v.to.rast.html">v.to.rast</a></em>,
or some other import/developement process (e.g.,
-<em><a href="v.in.transects.html">v.in.transects</A>)</em>
+<em><a href="v.in.transects.html">v.in.transects</a>)</em>
to define the areas
representative
of the classes in the image.
<p>
At present, there is no fully-interactive tool specifically
designed for producing this layer.
@@ -70,28 +65,25 @@
<dd>imagery group
<p>
command is used to construct groups of raster layers which
comprise an image.
<p>
<p>
command is also used to prepare this subgroup. The
subgroup mechanism allows the user to select a subset of
@@ -103,7 +95,6 @@
<p>
@@ -111,7 +102,6 @@
<p>
<dt><b>maxsig=</b><em>value</em>
<dd>maximum number of sub-signatures in any class
@@ -121,9 +111,8 @@
default: 10
<p>
The spectral signatures which are produced by this program
-are "mixed" signatures (see <a href="#notes">NOTES</A>).
+are "mixed" signatures (see <a href="#notes">NOTES</a>).
Each signature contains one or more subsignatures
(represeting subclasses). The algorithm in this program
starts with a maximum number of subclasses and reduces this
@@ -141,7 +130,6 @@
names of these maps and files.
<p>
interactive prompting for maps and files. It does not mean
visualization of the signatures that result from the
@@ -149,9 +137,8 @@
<p>
+<A NAME="notes"></a><h2>NOTES</h2>
-<A NAME="notes"></A><h2>NOTES</h2>
The algorithm in <em>i.gensigset</em> determines the
parameters of a spectral class model known as a Gaussian
mixture distribution. The parameters are estimated using
@@ -162,7 +149,6 @@
of the multispectral image.
<p>
The Gaussian mixture class is a useful model because it can
be used to describe the behavior of an information class
which contains pixels with a variety of distinct spectral
@@ -176,7 +162,6 @@
<p>
The objective of mixture classes is to improve segmentation
performance by modeling each information class as a
probabilistic mixture with a variety of subclasses. The
@@ -190,61 +175,58 @@
<p>
This clustering algorithm estimates both the number of
distinct subclasses in each class, and the spectral mean
and covariance for each subclass. The number of subclasses
is estimated using Rissanen's minimum description length
(MDL) criteria
-[<a href="#rissanen83">1</A>].
+[<a href="#rissanen83">1</a>].
This criteria attempts to determine
the number of subclasses which "best" describe the data.
The approximate maximum likelihood estimates of the mean
and covariance of the subclasses are computed using the
expectation maximization (EM) algorithm
-[<a href="#dempster77">2</A>,<a href="#redner84">3</A>].
+[<a href="#dempster77">2</a>,<a href="#redner84">3</a>].
<h2>REFERENCES</h2>
-<OL>
+<ol>
-<LI><A NAME="rissanen83">J. Rissanen,</A>
+<li><A NAME="rissanen83">J. Rissanen,</a>
"A Universal Prior for Integers and Estimation by Minimum
Description Length,"
<em>Annals of Statistics,</em>
vol. 11, no. 2, pp. 417-431, 1983.
-<LI><A NAME="dempster77">A. Dempster, N. Laird and D. Rubin,</A>
+<li><A NAME="dempster77">A. Dempster, N. Laird and D. Rubin,</a>
"Maximum Likelihood from Incomplete Data via the EM Algorithm,"
<em>J. Roy. Statist. Soc. B,</em>
vol. 39, no. 1, pp. 1-38, 1977.
-<LI><A NAME="redner84">E. Redner and H. Walker,</A>
+<li><A NAME="redner84">E. Redner and H. Walker,</a>
"Mixture Densities, Maximum Likelihood and the EM Algorithm,"
<em>SIAM Review,</em>
vol. 26, no. 2, April 1984.
-</OL>
+</ol>
<h2>SEE ALSO</h2>
<p>
and
<p>
-<em><a href="i.smap.html">i.smap</A></em>
+<em><a href="i.smap.html">i.smap</a></em>
for creating a final classification layer from the signatures
generated by <em>i.gensigset.</em>
Modified: grass/trunk/imagery/i.group/i.group.html
--- grass/trunk/imagery/i.group/i.group.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.group/i.group.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,8 +20,7 @@
The <em>i.group</em> options are only available for
imagery map layers in the current LOCATION_NAME.
-<p>
-Subgroup names may not contain more than 12 characters.
+<p>Subgroup names may not contain more than 12 characters.
<h2>SEE ALSO</h2>
@@ -30,8 +29,7 @@
<a href="http://grass.osgeo.org/gdp/imagery/grass4_image_processing.pdf">Image
-<p>
-<em>
+<p><em>
<a href="i.points.html">i.points</a>,
@@ -48,5 +46,4 @@
<br>
Parser support: Bob Covill (Tekmap, Canada)
-<p>
Modified: grass/trunk/imagery/i.his.rgb/i.his.rgb.html
--- grass/trunk/imagery/i.his.rgb/i.his.rgb.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.his.rgb/i.his.rgb.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>i.his.rgb</em> is an image processing program that
processes three input raster map layers as hue, intensity
and saturation components and produces three output raster
@@ -17,7 +16,7 @@
<em>i.his.rgb</em> and then exactly recover the original
bands with
-<em><a href="i.rgb.his.html">i.rgb.his</A></em>.
+<em><a href="i.rgb.his.html">i.rgb.his</a></em>.
This is due to loss of precision because of integer
computations and rounding. Tests have shown that more than
@@ -28,7 +27,7 @@
<h2>SEE ALSO</h2>
-<em><a href="r.colors.html">r.colors</A></em>
+<em><a href="r.colors.html">r.colors</a></em>
<h2>AUTHOR</h2>
@@ -36,7 +35,6 @@
<p>
with acknowledgements to Ali Vali, Univ. of Texas Space Research
Center, for the core routine.
Modified: grass/trunk/imagery/i.ifft/i.ifft.html
--- grass/trunk/imagery/i.ifft/i.ifft.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.ifft/i.ifft.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,10 +1,9 @@
<em>i.ifft</em> is an image processing program based on the algorithm given
by Frigo et al. (1998), that converts real and imaginary frequency space
images (produced by
-<em><a href="i.fft.html">i.fft</A></em>) into a normal image.
+<em><a href="i.fft.html">i.fft</a></em>) into a normal image.
<h2>NOTES</h2>
@@ -18,7 +17,7 @@
specifying the DC point as circle/ring center.
When <em>i.ifft</em> is executed, it (automatically) uses the same GRASS
region definition setting that was used during the original transformation
-done with <em><a href="i.fft.html">i.fft</A></em>.
+done with <em><a href="i.fft.html">i.fft</a></em>.
<h2>SEE ALSO</h2>
@@ -28,25 +27,22 @@
dimensions, of both real and complex data, and of arbitrary input size.
<p>
<b>Remote Sensing Digital Image Analysis</b>,
by John A. Richards,
Springer-Verlag, 1986.
<p>
between program author and Ali R. Vali, Space Research Center,
University of Texas, Austin, 1990.
<p>
+<em><a href="i.cca.html">i.cca</a></em>,
+<em><a href="i.class.html">i.class</a></em>,
+<em><a href="i.fft.html">i.fft</a></em>,
+<em><a href="i.pca.html">i.pca</a></em>,
+<em><a href="r.circle.html">r.circle</a></em>
-<em><a href="i.cca.html">i.cca</A></em>,
-<em><a href="i.class.html">i.class</A></em>,
-<em><a href="i.fft.html">i.fft</A></em>,
-<em><a href="i.pca.html">i.pca</A></em>,
-<em><a href="r.circle.html">r.circle</A></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html
--- grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,8 +8,7 @@
band-6 temperature
with <em><a href="i.landsat.toar.html">i.landsat.toar</a></em>).
-<p>
-The ACCA algorithm gives good results over most of the planet with the
+<p>The ACCA algorithm gives good results over most of the planet with the
exception of ice sheets because ACCA operates on the premise that
clouds are colder than the land surface they cover. The algorithm was
designed for Landsat-7 ETM+ but because reflectance is used it is also
@@ -57,5 +56,4 @@
E. Jorge Tizado (ej.tizado unileon es), Dept. Biodiversity and Environmental Management, University of León, Spain
-<p>
Modified: grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html
--- grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.landsat.toar/i.landsat.toar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,20 +6,17 @@
TM and ETM+). Optionally, it can be used to calculate the at-surface
radiance or reflectance with atmospheric correction (DOS method).
-<p>
-Usually, to do so the production date, the acquisition date, and the
+<p>Usually, to do so the production date, the acquisition date, and the
solar elevation is needed. Moreover, for Landsat-7 ETM+ it is also
needed the gain (high or low) of the nine respective bands.
-<p>
-Optionally, the data can be read from header file (.met) for all
+<p>Optionally, the data can be read from header file (.met) for all
Landsat MSS, TM and ETM+. However, if the solar elevation or the
product creation date are given the values of the metfile are
overwriten. This is necessary when the data in the metfile is
incorrect or not accurate.
-<p>
-<b>Attention</b>: Any null value or smaller than QCALmin in the input
+<p><b>Attention</b>: Any null value or smaller than QCALmin in the input
raster is set to null in the output raster and it is not included in
the equations.
@@ -33,8 +30,7 @@
at-sensor radiance, and then to effective at-sensor temperature in
Kelvin degrees.
-<p>
-Radiometric calibration converts QCAL to <b>at-sensor radiance</b>, a
+<p>Radiometric calibration converts QCAL to <b>at-sensor radiance</b>, a
radiometric quantity measured in W/(m² * sr * µm) using the
equations:
<ul>
@@ -47,8 +43,7 @@
and <em>QCALmax</em> and <em>QCALmin</em> are the highest and the
lowest points of the range of rescaled radiance in QCAL.
-<p>
-Then, to calculate <b>at-sensor reflectance</b> the equations are:
+<p>Then, to calculate <b>at-sensor reflectance</b> the equations are:
<ul>
<li> sun_radiance = [Esun * sin(e)] / (PI * d^2)</li>
@@ -73,8 +68,7 @@
<li> reflectance = radiance / sun_radiance </li>
</ul>
-<p>
-<b>Note</b>: Other possibility to avoid negative values is set to zero
+<p><b>Note</b>: Other possibility to avoid negative values is set to zero
this values (radiance and/or reflectance), but this option is ease
with uncorrected method
and <em><a href="r.mapcalc.html">r.mapcalc</a></em>.
@@ -126,14 +120,12 @@
In verbose mode (flag <b>--verbose</b>), the program write basic
satellite data and the parameters used in the transformations.
-<p>
-In L5_MTL mode (flag <b>-t</b>), the Landsat 5TM imagery that has a
+<p>In L5_MTL mode (flag <b>-t</b>), the Landsat 5TM imagery that has a
_MTL.txt metadata file can be processed. Landsat 7 ETM+ does not need
a flag since .met and _MTL.txt are sufficient compatible for this
sensor.
-<p>
-Production date is not an exact value but it is necessary to apply
+<p>Production date is not an exact value but it is necessary to apply
correct calibration constants, which were changed in the dates:
<ul>
<li>Landsat-1 MSS: never </li>
@@ -218,5 +210,4 @@
-<p>
Modified: grass/trunk/imagery/i.latlong/i.latlong.html
--- grass/trunk/imagery/i.latlong/i.latlong.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.latlong/i.latlong.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,7 +6,7 @@
<h2>NOTES</h2>
-The PROJ.4 <a href="http://trac.osgeo.org/proj/">website</A>.
+The PROJ.4 <a href="http://trac.osgeo.org/proj/">website</a>.
<h2>TODO</h2>
Datum transform is not implemented, the same datum is taken as output.
@@ -22,5 +22,4 @@
-<p>
Modified: grass/trunk/imagery/i.maxlik/i.maxlik.html
--- grass/trunk/imagery/i.maxlik/i.maxlik.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.maxlik/i.maxlik.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
step in either an unsupervised or a supervised image
classification.
-<p>
-Either image classification methods are performed in two
+<p>Either image classification methods are performed in two
steps. The first step in an unsupervised image
classification is performed by
<em><a href="i.cluster.html">i.cluster</a></em>; the
@@ -16,8 +15,7 @@
the second step in the image classification procedure is
performed by <em>i.maxlik</em>.
-<p>
-In an unsupervised classification, the maximum-likelihood
+<p>In an unsupervised classification, the maximum-likelihood
classifier uses the cluster means and covariance matrices
from the <em><a href="i.cluster.html">i.cluster</a></em>
signature file to determine to which category (spectral
@@ -31,15 +29,13 @@
to which category each cell in the image has the highest
probability of belonging.
-<p>
-In either case, the raster map layer output by
+<p>In either case, the raster map layer output by
<em>i.maxlik</em> is a classified image in which each cell
has been assigned to a spectral class (i.e., a category).
The spectral classes (categories) can be related to
specific land cover types on the ground.
-<p>
-The program will run non-interactively if the user
+<p>The program will run non-interactively if the user
specifies the names of raster map layers, i.e., group and
subgroup names, seed signature file name, result
classification file name, and any combination of
@@ -56,7 +52,6 @@
where each flag and options have the meanings stated below.
<p>
Alternatively, the user can simply type <em>i.maxlik</em>
in the command line without program arguments. In this case
the user will be prompted for the program parameter
@@ -66,7 +61,7 @@
<h2>OPTIONS</h2>
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
@@ -76,7 +71,7 @@
</dl>
<dl>
@@ -145,8 +140,7 @@
<em>i.maxlik</em>
will reject them and display a warning message.
-<p>
-This program runs interactively if the user types
+<p>This program runs interactively if the user types
<em>i.maxlik</em> only. If the user types <em>i.maxlik</em>
along with all required options, it will overwrite the
classified raster map without prompting if this map
@@ -159,8 +153,7 @@
-<p>
-<em>
+<p><em>
<a href="i.gensig.html">i.gensig</a>,
@@ -178,5 +171,4 @@
University of Illinois at Urbana-Champaign,
Illinois
-<p>
Modified: grass/trunk/imagery/i.modis.qc/i.modis.qc.html
--- grass/trunk/imagery/i.modis.qc/i.modis.qc.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.modis.qc/i.modis.qc.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -417,5 +417,4 @@
<h2>AUTHOR</h2>
Yann Chemin
-<p>
Modified: grass/trunk/imagery/i.pca/i.pca.html
--- grass/trunk/imagery/i.pca/i.pca.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.pca/i.pca.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<h2>DESCRIPTION</h2>
<em>i.pca</em> is an image processing program based on the
algorithm provided by Vali (1990), that processes n
(n >= 2) input raster map layers and produces n output
@@ -15,7 +14,7 @@
<h2>OPTIONS</h2>
<dl>
<dt><b>input=</b><em>name,name</em>[<em>,name,name</em>,...]
<dd>Name of two or more input raster map layers.
@@ -47,8 +46,7 @@
Richards (1986) gives a good example of the application of principal
components analysis (pca) to a time series of LANDSAT images of a burned
region in Australia.
-<p>
-Eigenvalue and eigenvector information is stored in the output maps'
+<p>Eigenvalue and eigenvector information is stored in the output maps'
history files. View with <em>r.info</em>.
@@ -74,37 +72,32 @@
<p>
Vali, Ali R.,
<p>
<em>
-<a href="i.cca.html">i.cca</A><br>
-<a href="i.class.html">i.class</A><br>
-<a href="i.fft.html">i.fft</A><br>
-<a href="i.ifft.html">i.ifft</A><br>
-<a href="m.eigensystem.html">m.eigensystem</A><br>
-<a href="r.covar.html">r.covar</A><br>
+<a href="i.cca.html">i.cca</a><br>
+<a href="i.class.html">i.class</a><br>
+<a href="i.fft.html">i.fft</a><br>
+<a href="i.ifft.html">i.ifft</a><br>
+<a href="m.eigensystem.html">m.eigensystem</a><br>
+<a href="r.covar.html">r.covar</a><br>
</em>
<h2>AUTHOR</h2>
-<p>
-Major modifications for GRASS 4.1 were made by <br>
+<p>Major modifications for GRASS 4.1 were made by <br>
Olga Waupotitsch and
Michael Shapiro,
U.S.Army Construction Engineering
Research Laboratory
-<p>
-Rewritten for GRASS 6.x and major modifications by <br>
+<p>Rewritten for GRASS 6.x and major modifications by <br>
Brad Douglas
-<p>
Modified: grass/trunk/imagery/i.points/i.points.html
--- grass/trunk/imagery/i.points/i.points.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.points/i.points.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,17 +1,16 @@
<em>i.points</em> is an
-<a href="imagery.html">imagery</A> function that enables
+<a href="imagery.html">imagery</a> function that enables
the user to mark points on a (raster) image to be rectified
and then input the geographic coordinates of each point for
calculation of a coordinate transformation matrix.
<em>i.points</em> must be followed by use of the GRASS
-program <em><a href="i.rectify.html">i.rectify</A></em>, which
+program <em><a href="i.rectify.html">i.rectify</a></em>, which
rectifies the image using the transformation matrix
coefficients calculated by <em>i.points</em>.
<p>
<em>Rectification</em> is the mapping (transformation) of
an image from one coordinate system to another. The
geometry of an image extracted into a GRASS LOCATION having
@@ -29,38 +28,33 @@
transformation coefficients is the output file for
<em>i.points</em>.
-<p>
-During the process of marking points and entering map
+<p>During the process of marking points and entering map
coordinates, the user can compute the RMS (root mean
square) error for each point entered. <em>i.points</em>
does this by calculating the transformation equation (the
same one that is calculated in the GRASS program <em>
-<a href="i.rectify.html">i.rectify</A></em>), and then
+<a href="i.rectify.html">i.rectify</a></em>), and then
plugging these results into an equation for RMS error.
-<p>
-<em>i.points</em> offers a zoom option to locate precisely
+<p><em>i.points</em> offers a zoom option to locate precisely
the point to be marked on an image. This program also
offers the user the option of acquiring standard
coordinates for a marked point from a map layer in the
target data base.
-<p>
-<em><a href="i.target.html">i.target</A></em> must be
+<p><em><a href="i.target.html">i.target</a></em> must be
run before running <em>i.points</em> to enable the PLOT
RASTER option to be used and to identify a target data base
LOCATION_NAME and MAPSET for the rectified image. To run
<em>i.points</em>, a graphics monitor is required.
-<p>
-The procedure for marking points, entering coordinates, and
+<p>The procedure for marking points, entering coordinates, and
calculating RMS error is described below.
-<p>
-The first prompt in the program asks the user for the
-<a href="i.group.html">imagery group</A> to be
+<p>The first prompt in the program asks the user for the
+<a href="i.group.html">imagery group</a> to be
registered. Note that if
-<em><a href="i.target.html">i.target</A></em> is not run
+<em><a href="i.target.html">i.target</a></em> is not run
before <em>i.points</em>, the <em>i.points</em> program
will display the following error message:
@@ -126,28 +120,27 @@
Any single raster map layer in the
-<a href="i.group.html">imagery group</A> may be used on
+<a href="i.group.html">imagery group</a> may be used on
which to mark points, and the user can mark points on more
than one raster map layer in the
-<a href="i.group.html">imagery group</A> to accumulate the
+<a href="i.group.html">imagery group</a> to accumulate the
suggested minimum number of 12 points. Any raster map
-layer in the <a href="i.group.html">imagery group</A>
+layer in the <a href="i.group.html">imagery group</a>
can be rectified (using
-<em><a href="i.rectify.html">i.rectify</A></em>) based on the
+<em><a href="i.rectify.html">i.rectify</a></em>) based on the
transformation matrix computed from these points.
<p>
The imagery file chosen by
the user is displayed in the upper left quadrant of the
screen.
-<H3>ZOOM</H3>
+<h3>ZOOM</h3>
To magnify the displayed file, the user must
place the mouse cross hairs on the word ZOOM. The following menu
@@ -167,7 +160,7 @@
menu to guide the user in identifying the corner points of
the region.
-<H3>MARKING POINTS</H3>
+<h3>MARKING POINTS</h3>
To mark the points on the image that correspond to the
points on a standard coordinate system map, the user must
@@ -199,7 +192,7 @@
RETURN to return control to the mouse; the marked point
then disappears.
-<H3>PLOT RASTER</H3>
+<h3>PLOT RASTER</h3>
In addition to acquiring reference points from a standard
map, the user has the option of acquiring the reference
@@ -268,7 +261,6 @@
<p>
If the user selects the SCREEN option, then points marked
on the image will automatically be associated with the
coordinates from the corresponding points on the target
@@ -304,7 +296,7 @@
automatically saved as the coordinates corresponding to the
marked point on the image.
-<H3>ANALYZE</H3>
+<h3>ANALYZE</h3>
After a number of points have been marked (4 to 7), the
user can check the RMS error of the points marked on the
@@ -351,9 +343,8 @@
displayed in red on the graphics monitor (represented here
in italics).
-<p>
-The location of the point marked on the
-<a href="i.group.html">imagery group</A> file is given
+<p>The location of the point marked on the
+<a href="i.group.html">imagery group</a> file is given
under the heading "image" and the subheadings "east" and
"north". The location of the point in the target data base
is given under the heading "target" and the subheadings
@@ -368,7 +359,7 @@
retrieved within <em>i.points</em> at any time by double
clicking with the mouse as described above.
-<H3>QUIT</H3>
+<h3>QUIT</h3>
To end the <em>i.points</em> program place the mouse cross
hairs on the word QUIT; the marked points (including
@@ -379,39 +370,35 @@
A good rule of thumb is to mark at least 12 to 15 points
which are evenly distributed over the entire
-<a href="i.group.html">imagery group</A> file in order to
+<a href="i.group.html">imagery group</a> file in order to
obtain an accurate transformation equation for the
rectification process. The RMS error may increase with
more points added, but the transformation equation will be
more accurate.
-<p>
-An RMS error of less than or equal to approximately one
+<p>An RMS error of less than or equal to approximately one
resolution unit (pixel or cell) for the image being
rectified is generally considered acceptable.
-<p>
-In order to use a digitizer with <em>i.points</em>, at
+<p>In order to use a digitizer with <em>i.points</em>, at
least one digitizer driver besides "none" (the on-screen
digitizer) must be available in the digitcap file.
-<p>
-This program is interactive.
+<p>This program is interactive.
<h2>SEE ALSO</h2>
The GRASS 4 <em>
-<p>
-<em>
-<a href="g.mapsets.html">g.mapsets</A><br>
-<a href="i.group.html">i.group</A><br>
-<a href="i.rectify.html">i.rectify</A><br>
-<a href="i.target.html">i.target</A><br>
-<a href="i.vpoints.html">i.vpoints</A>
+<p><em>
+<a href="g.mapsets.html">g.mapsets</a><br>
+<a href="i.group.html">i.group</a><br>
+<a href="i.rectify.html">i.rectify</a><br>
+<a href="i.target.html">i.target</a><br>
+<a href="i.vpoints.html">i.vpoints</a>
</em><br>
<em><a href="gm_georect.html">gis.m: GEORECTIFY TOOL</a></em>
@@ -420,5 +407,4 @@
Michael Shapiro,
U.S.Army Construction Engineering Research Laboratory
-<p>
Modified: grass/trunk/imagery/i.rectify/i.rectify.html
--- grass/trunk/imagery/i.rectify/i.rectify.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.rectify/i.rectify.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>i.rectify</em> uses the control
points identified in
<em><a href="i.points.html">i.points</a></em>
@@ -15,7 +14,6 @@
system than before it was rectified).
<p>
or
<em><a href="i.vpoints.html">i.vpoints</a></em>
@@ -37,8 +35,7 @@
program is completed. The original unrectified files are not modified
or removed.
-<p>
-If the <b>-c</b> flag is used, <em>i.rectify</em> will only rectify that
+<p>If the <b>-c</b> flag is used, <em>i.rectify</em> will only rectify that
portion of the image or raster map that occurs within the chosen window
region in the target location, and only that portion of the cell
file will be relocated in the target database. It is
@@ -46,7 +43,6 @@
the target LOCATION if the <b>-c</b> flag is used.
<p>
If you are rectifying a file with plans to patch it to
another file using the GRASS program <em>r.patch</em>,
choose option number one, the current window in the target
@@ -63,8 +59,7 @@
window.
<h3>Coordinate transformation</h3>
-<p>
-The desired order of transformation (1, 2, or 3) is selected with the
+<p>The desired order of transformation (1, 2, or 3) is selected with the
<b>order</b> option.
The program will calculate the RMSE and check the required number of points.
@@ -85,7 +80,7 @@
images, and (2) the terrain or camera distortion effect can
be ignored.
-<H4>Polynomial Transformation Matrix (2nd, 3d order transformation)</H4>
+<h4>Polynomial Transformation Matrix (2nd, 3d order transformation)</h4>
<em>i.rectify</em> uses a first, second, or third order transformation
matrix to calculate the registration coefficients. The number
@@ -107,12 +102,10 @@
modified Gaussian elimination method.
<h3>Resampling method</h3>
-<p>
-The rectified data is resampled with one of seven different methods:
+<p>The rectified data is resampled with one of seven different methods:
<em>nearest</em>, <em>bilinear</em>, <em>cubic</em>, <em>lanczos</em>,
<em>bilinear_f</em>, <em>cubic_f</em>, or <em>lanczos_f</em>.
-<p>
-The <em>method=nearest</em> method, which performs a nearest neighbor assignment,
+<p>The <em>method=nearest</em> method, which performs a nearest neighbor assignment,
is the fastest of the resampling methods. It is primarily used for
categorical data such as a land use classification, since it will not change
the values of the data cells. The <em>method=bilinear</em> method determines the new
@@ -122,25 +115,21 @@
the input map. The <em>method=lanczos</em> method determines the new value of
the cell based on a weighted distance average of the 25 surrounding cells in
the input map.
-<p>
-The bilinear, cubic and lanczos interpolation methods are most appropriate for
+<p>The bilinear, cubic and lanczos interpolation methods are most appropriate for
continuous data and cause some smoothing. These options should not be used
with categorical data, since the cell values will be altered.
-<p>
-In the bilinear, cubic and lanczos methods, if any of the surrounding cells used to
+<p>In the bilinear, cubic and lanczos methods, if any of the surrounding cells used to
interpolate the new cell value are NULL, the resulting cell will be NULL, even if
the nearest cell is not NULL. This will cause some thinning along NULL borders,
such as the coasts of land areas in a DEM. The bilinear_f, cubic_f and lanczos_f
interpolation methods can be used if thinning along NULL edges is not desired.
These methods "fall back" to simpler interpolation methods along NULL borders.
That is, from lanczos to cubic to bilinear to nearest.
-<p>
-If nearest neighbor assignment is used, the output map has the same raster
+<p>If nearest neighbor assignment is used, the output map has the same raster
format as the input map. If any of the other interpolations is used, the
output map is written as floating point.
-<p>
+<p><!--
Note: In interactive mode it is possible to define a new file name
for the target images. This is (currently) not provided in command line
mode.
@@ -162,8 +151,7 @@
-<p>
-<em>
+<p><em>
<a href="m.transform.html">m.transform</a>,
<a href="r.proj.html">r.proj</a>,
<a href="v.proj.html">v.proj</a>,
@@ -182,13 +170,11 @@
Michigan State University,
Center for Remote Sensing
-<p>
-Modified for GRASS 5.0 by:<br>
+<p>Modified for GRASS 5.0 by:<br>
Luca Palmeri (palmeri at ux1.unipd.it)<br>
Bill Hughes<br>
Pierre de Mouveaux (pmx at audiovu.com)
<br>
CMD mode by Bob Covill
-<p>
Modified: grass/trunk/imagery/i.rgb.his/i.rgb.his.html
--- grass/trunk/imagery/i.rgb.his/i.rgb.his.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.rgb.his/i.rgb.his.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>i.rgb.his</em> is an image processing program that
processes three input raster map layers as red, green, and
blue components and produces three output raster map layers
@@ -14,7 +13,7 @@
<h2>SEE ALSO</h2>
-<em><a href="i.his.rgb.html">i.his.rgb</A></em>
+<em><a href="i.his.rgb.html">i.his.rgb</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.smap/i.smap.html
--- grass/trunk/imagery/i.smap/i.smap.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.smap/i.smap.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,26 +10,24 @@
covariance parameters.
<p>
<em>i.smap</em> has two modes of operation. The first mode
is the sequential maximum a posteriori (SMAP) mode
-[<a href="#ref1">1</A>,<a href="#ref2">2</A>]. The SMAP
+[<a href="#ref1">1</a>,<a href="#ref2">2</a>]. The SMAP
segmentation algorithm attempts to improve segmentation
accuracy by segmenting the image into regions rather than
segmenting each pixel separately
-(see <a href="#notes">NOTES</A>).
+(see <a href="#notes">NOTES</a>).
<p>
The second mode is the more conventional maximum likelihood (ML)
classification which classifies each pixel separately,
but requires somewhat less computation. This mode is selected with
-the <b>-m</b> flag (see <a href="#mflag.html">below</A>).
+the <b>-m</b> flag (see <a href="#mflag.html">below</a>).
<h2>OPTIONS</h2>
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
@@ -37,7 +35,7 @@
<dd>Use maximum likelihood estimation (instead of smap).
Normal operation is to use SMAP estimation (see
-<a href="#notes">NOTES</A>).
+<a href="#notes">NOTES</a>).
<dt><b>-q</b>
@@ -48,7 +46,7 @@
</dl>
<dl>
@@ -69,8 +67,8 @@
The signature file that contains the spectral signatures (i.e., the
statistics) for the classes to be identified in the image.
This signature file is produced by the program
-<em><a href="i.gensigset.html">i.gensigset</A></em>
+<em><a href="i.gensigset.html">i.gensigset</a></em>
<dt><b>blocksize=</b><em>value</em>
@@ -80,7 +78,6 @@
reading the image data.
<p>
This program was written to be nice about memory usage
without influencing the resultant classification. This
option allows the user to control how much memory is used.
@@ -89,7 +86,6 @@
virtual memory the program uses.
<p>
The size of the submatrix used in segmenting the image has
a principle function of controlling memory usage; however,
it also can have a subtle effect on the quality of the
@@ -103,7 +99,6 @@
image.
<p>
The submatrix size has no effect on the performance of the
ML segmentation method.
@@ -123,7 +118,7 @@
<em>i.smap</em> will interactively prompt for the names of
the maps and files.
The SMAP algorithm exploits the fact that nearby pixels in
an image are likely to have the same class. It works by
@@ -135,7 +130,6 @@
class which may be useful in some applications.
<p>
The amount of smoothing that is performed in the
segmentation is dependent of the behavior of the data in
the image. If the data suggests that the nearby pixels
@@ -144,12 +138,10 @@
excessively large regions are not formed.
<p>
The module i.smap does not support MASKed or NULL cells. Therefore
it might be necessary to create a copy of the classification results
using e.g. r.mapcalc.
-<p>
-r.mapcalc MASKed_map=classification results
+<p>r.mapcalc MASKed_map=classification results
<h2>REFERENCES</h2>
@@ -171,17 +163,15 @@
<h2>SEE ALSO</h2>
<p>
to copy classification result in order to cut out MASKed subareas
<p>
to generate the signature file required by this program
<h2>AUTHORS</h2>
Modified: grass/trunk/imagery/i.sunhours/i.sunhours.html
--- grass/trunk/imagery/i.sunhours/i.sunhours.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.sunhours/i.sunhours.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,13 +5,11 @@
as found in the AHAS manual (Parodi, 2000).
-<p>
-The day of year (1-365) raster map can be created with ...?
+<p>The day of year (1-365) raster map can be created with ...?
why isn't this just a single integer value?
-<p>
-The latitude input map can be created with the <em>i.latlong</em>
+<p>The latitude input map can be created with the <em>i.latlong</em>
module, or with <em>r.mapcalc</em>'s <tt>y()</tt> function in a
latitude-longitude location (possibly reprojected with <em>r.proj</em>.
@@ -19,8 +17,7 @@
Iqbal, M., 1983. An Introduction to Solar Radiation. Iqbal, M.,
Editorial: Academic Press. Toronto, Canada.
-<p>
-Parodi, G., 2000. AVHRR Hydrological Analysis System. Algorithms
+<p>Parodi, G., 2000. AVHRR Hydrological Analysis System. Algorithms
and Theory, Version 1.0. WRES - ITC, The Netherlands.
<h2>SEE ALSO</h2>
@@ -35,5 +32,4 @@
-<p>
Modified: grass/trunk/imagery/i.target/i.target.html
--- grass/trunk/imagery/i.target/i.target.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.target/i.target.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,15 +14,13 @@
<h2>NOTES</h2>
-<p>
-The module's first option asks for the name of the
+<p>The module's first option asks for the name of the
<a href="i.group.html">imagery group</a> that needs a target.
The imagery group must be present in the user's current mapset.
An <a href="i.group.html">imagery group</a> may be targeted to any GRASS
location.
-<p>
-If a group name is given without setting options, the currently targeted
+<p>If a group name is given without setting options, the currently targeted
group will be displayed.
@@ -32,8 +30,7 @@
-<p>
-<em>
+<p><em>
<a href="i.vpoints.html">i.vpoints</a>,
@@ -45,8 +42,6 @@
<h2>AUTHOR</h2>
Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory<p>
-Parser support: Bob Covill
+U.S. Army Construction Engineering Research Laboratory<p>Parser support: Bob Covill
-<p>
Modified: grass/trunk/imagery/i.vi/i.vi.html
--- grass/trunk/imagery/i.vi/i.vi.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.vi/i.vi.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -22,15 +22,12 @@
</ul>
<em>Warning to the new remote sensing users</em>
-<p>
-Vegetation Indices are often considered the entry point of remote sensing for Earth land monitoring. They are suffering from their success, in terms that often people tend to harvest satellite images from online sources and use them directly in this module.
+<p>Vegetation Indices are often considered the entry point of remote sensing for Earth land monitoring. They are suffering from their success, in terms that often people tend to harvest satellite images from online sources and use them directly in this module.
<em>If you are in this situation please read the following</em>
-<p>
-Satellite imagery is often stored in Digital Number (DN) for storage purpose, Landsat is stored in 8bit values (ranging from 0 to 255), other satellites maybe stored in 10 or 16 bits. Get to know about your satellite data. Once you covered this knowledge and that you are sure the data is in DN, this implies that your imagery is not corrected. What this means is that the image is what the satellite sees at its position and altitude in space. This is not the ground reality yet. We call this data at the satellite. Encoded in the 8bits (or more) is the amount of energy sensed by the sensor inside the satellite platform. This energy is called radiance-at-sensor. Generally, satellites image providers encode the radiance-at-sensor into 8bit (or more) through an affine transform equation (y=ax+b). If you are using Landsat imagery, look at the i.landsat.toar for an easy way to transform DN to radiance-at-sensor. If you are using Aster data, try i.aster.toar module.
+<p>Satellite imagery is often stored in Digital Number (DN) for storage purpose, Landsat is stored in 8bit values (ranging from 0 to 255), other satellites maybe stored in 10 or 16 bits. Get to know about your satellite data. Once you covered this knowledge and that you are sure the data is in DN, this implies that your imagery is not corrected. What this means is that the image is what the satellite sees at its position and altitude in space. This is not the ground reality yet. We call this data at the satellite. Encoded in the 8bits (or more) is the amount of energy sensed by the sensor inside the satellite platform. This energy is called radiance-at-sensor. Generally, satellites image providers encode the radiance-at-sensor into 8bit (or more) through an affine transform equation (y=ax+b). If you are using Landsat imagery, look at the i.landsat.toar for an easy way to transform DN to radiance-at-sensor. If you are using Aster data, try i.aster.toar module.
-<p>
-Finally, once you have the radiance at sensor, you still have the atmosphere between the sensor and the surface vagetation. You need to correct the atmospheric interaction with the sun energy that the vegetation reflects back into space. This can be done in two ways for landsat. The simple way is within i.landsat.toar, look for DOS correction. The more accurate way is by using i.atcorr (which works for many satellite sensors). Get to know this last one if you intend to stay around remote sensing some time. Once you have completed the use of an atmospheric correction on the energy sensed by the satellite, you can call your data by the name of surface reflectance. Surface reflectance is ranging from 0.0 to 1.0 theoretically (and absolutely). This level of data correction is the proper level of correction to use with this Vegetation Index module.
+<p>Finally, once you have the radiance at sensor, you still have the atmosphere between the sensor and the surface vagetation. You need to correct the atmospheric interaction with the sun energy that the vegetation reflects back into space. This can be done in two ways for landsat. The simple way is within i.landsat.toar, look for DOS correction. The more accurate way is by using i.atcorr (which works for many satellite sensors). Get to know this last one if you intend to stay around remote sensing some time. Once you have completed the use of an atmospheric correction on the energy sensed by the satellite, you can call your data by the name of surface reflectance. Surface reflectance is ranging from 0.0 to 1.0 theoretically (and absolutely). This level of data correction is the proper level of correction to use with this Vegetation Index module.
<div class="code"><pre>
@@ -174,12 +171,10 @@
<h2>NOTES</h2>
Originally from kepler.gps.caltech.edu
-<p>
-A FAQ on Vegetation in Remote Sensing<br>
+<p>A FAQ on Vegetation in Remote Sensing<br>
Written by Terrill W. Ray, Div. of Geological and Planetary Sciences,
California Institute of Technology, email: terrill at mars1.gps.caltech.edu
-<p>
-Snail Mail: Terrill Ray<br>
+<p>Snail Mail: Terrill Ray<br>
Division of Geological and Planetary Sciences<br>
Caltech, Mail Code 170-25<br>
Pasadena, CA 91125
@@ -198,5 +193,4 @@
Baburao Kamble, Asian Institute of Technology, Thailand<br>
-<p>
Modified: grass/trunk/imagery/i.vpoints/i.vpoints.html
--- grass/trunk/imagery/i.vpoints/i.vpoints.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.vpoints/i.vpoints.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,14 +4,13 @@
vector map or keyboard entry and corresponding points in an image to be
rectified. The map coordinate values of each point are used to calculate a
transformation matrix. The operator may then use the
-<em><a href="i.rectify.html">i.rectify</A></em> program to rectify the image using
+<em><a href="i.rectify.html">i.rectify</a></em> program to rectify the image using
the transformation matrix coefficients calculated from the control point
file created in <em>i.vpoints</em>. The
-<em> <a href="i.rectify.html">i.rectify</A></em> program performs a first, second or
+<em> <a href="i.rectify.html">i.rectify</a></em> program performs a first, second or
third order transformation of the image.
-<p>
-The first step is to display the unrectified image and
+<p>The first step is to display the unrectified image and
corresponding vector map data. The operator would then
mark corresponding control point locations on the image and
map. To identify the precise location of a point to be
@@ -35,7 +34,7 @@
transformation equation (the same one that is calculated in
the GRASS program
2). Coefficients are
computed for the equation. The coefficients are then used in the
equation along with the x,y coordinates of the marked points. The
@@ -43,15 +42,13 @@
interpretation of RMS error is described in the ANALYZE subsection.
-<p>
-The procedures for marking control points (registration
+<p>The procedures for marking control points (registration
points), displaying vector map layers, overlaying vector maps onto
the raster image, and calculating RMS error are described in the
following sections .
-<p>
-To enter the program (the <em>i.vpoints</em> program requires the use of a
+<p>To enter the program (the <em>i.vpoints</em> program requires the use of a
graphics monitor) type <em>i.vpoints</em>:
@@ -115,26 +112,22 @@
And the color graphics monitor displays the following
screen:
-<p>
- Any single file in the imagery group may be used to mark
+<p> Any single file in the imagery group may be used to mark
points, and points can be marked on more than one file in the
imagery group to accumulate the suggested minimum number of points
(3 for a 1st order transformation, 6 for a 2nd order, and 10 for a
3rd order). Any file in the imagery group can be subsequently
-rectified (using <em><a href="i.rectify.html">i.rectify</A></em>)
+rectified (using <em><a href="i.rectify.html">i.rectify</a></em>)
based on the transformation matrix computed from these points.
-<p>
- The chosen file is displayed in the upper left quadrant of the
+<p> The chosen file is displayed in the upper left quadrant of the
monitor at a default magnification based on the extent of the
current active window.
<p>
<b>RASTER IMAGE</b>
-<p>
- The raster image option on the menu at the bottom of the
+<p> The raster image option on the menu at the bottom of the
window allows the user to display any single file in the imagery
group in the upper right quadrant of the window screen. The option
provides the same file selection pick list as is presented when you
@@ -144,30 +137,24 @@
<p>
<b>VECTOR MAPS</b>
-<p>
- The vector maps option on the menu at the bottom of the screen
+<p> The vector maps option on the menu at the bottom of the screen
allows the user to display vector map data in the upper right
quadrant of the screen. After selecting the vector map layer to
display, a menu selection bar appears along the bottom on the
screen. This pick list is used to select the line color (blue,
gray, green, red, white, or yellow) for the selected vector data
layer.
-<p>
-<b>Refresh</b>
-<p>
- The refresh option on the main menu allows the user to
+<p><b>Refresh</b>
+<p> The refresh option on the main menu allows the user to
"refresh" or re-draw the displayed vector data. This function will
erase all outlines showing the limits of previously zoomed areas.
A "yes/no" roompt will appear:
<pre>
Refresh Map ? NO YES
</pre>
-<p>
-<b>Zoom</b>
-<p>
- To enlarge a raster or vector image, place the mouse cross
+<p><b>Zoom</b>
+<p> To enlarge a raster or vector image, place the mouse cross
hairs on the word zoom on the main menu and press the left button.
The following menu will be displayed at the bottom. of the screen:
<pre>
@@ -191,23 +178,17 @@
<p>
The point method for enlarging an image will display a mouse menu
to guide you in selecting the appropriate enlargement. To enlarge
or reduce the magnification factor, place the cursor on the "+" or
"-" box and press the left button on the mouse.
-<p>
-<p>
-You may zoom either the raster or the vector display.
-<p>
-Upon accepting the new region limits, the raster or vector data are
+<p><p>You may zoom either the raster or the vector display.
+<p>Upon accepting the new region limits, the raster or vector data are
redisplayed in either the lower left (raster) or lower right
(vector) windows.
-<p>
-The extent of the zoomed area is outlined on the unzoomed image in
+<p>The extent of the zoomed area is outlined on the unzoomed image in
the main window area.
-<p>
- While the main menu is displayed, you can mark
+<p> While the main menu is displayed, you can mark
corrosponding control points on the raster and vector
images or enter map coordinates from the keyboard. If you
are using coordinates taken from a reference map, circle
@@ -218,8 +199,7 @@
determined the standard coordinates (for example, UTM's) of
each circled point, you are ready to mark the points on the
displayed image.
-<p>
- To mark the points on the image, that correspond to the points
+<p> To mark the points on the image, that correspond to the points
on the standard coordinate map, place the mouse cross hairs on the
point on the image to be marked (you will probably have to ZOOM to
find the exact spot) and press the left hand button on the mouse.
@@ -234,7 +214,6 @@
</pre>
<b>Analyze</b>
<p>
After a number of points have been marked (a minimum of 4 for
a 1st order transformation, 7 for a 2nd order, and 11 for a 3rd
order), the RMS error of the points marked on the image can be
@@ -280,8 +259,7 @@
transformation matrix. However, it can be retrieved within
<em>i.vpoints</em> at any time by double clicking with the mouse as
described above.
-<p>
-The following menu appears at the bottom of the monitor:
+<p>The following menu appears at the bottom of the monitor:
<pre>
DONE PRINT FILE OVERLAY DELETE ON Transformation -
-> 1st ORDER Double click on point to be DELETED
@@ -290,10 +268,8 @@
toggle option is used to allow the user to physically remove a
control point from the POINTS file instead of just flagging it as
an non-active reference point.
-<p>
-<b>Overlay</b>
-<p>
-Overlay allows the user to overlay the vector map(s) onto the
+<p><b>Overlay</b>
+<p>Overlay allows the user to overlay the vector map(s) onto the
raster image. Overlay can be used to warp (register) and display
the selected vector map data on top of the raster image contained
in the upper left window of the color screen. An inverse
@@ -309,10 +285,8 @@
</pre>
The program will immediately recalculate the RMSE and the number of
points required.
-<p>
-<b>Quit</b>
-<p>
- To exit the <em>i.vpoints</em> program, place the mouse cross hairs on
+<p><b>Quit</b>
+<p> To exit the <em>i.vpoints</em> program, place the mouse cross hairs on
the word QUIT at the bottom of the monitor and all of the marked
points (including coordinates) will be saved.
@@ -320,15 +294,14 @@
The GRASS 4 <em>
-<p>
-<em>
-<a href="i.points.html">i.points</A><br>
+<p><em>
+<a href="i.points.html">i.points</a><br>
</em><br>
@@ -338,5 +311,4 @@
William R. Enslin, Michigan State University Center for Remote Sensing<br>
Radim Blazek (update to GRASS 5.7)<br>
Hamish Bowman (finish GRASS 6 porting)
-<p>
Modified: grass/trunk/imagery/i.zc/i.zc.html
--- grass/trunk/imagery/i.zc/i.zc.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/imagery/i.zc/i.zc.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>i.zc</em> is an image processing program used for edge
detection. The raster map produced shows the location of
"boundaries" on the input map. Boundaries tend to be found
@@ -11,7 +10,7 @@
<h2>OPTIONS</h2>
-<H3>Parameters:</H3>
+<h3>Parameters:</h3>
<dl>
@@ -52,7 +51,7 @@
cells on the output raster map layer are categorized into
(similar to the aspect raster map layer produced by the
-<em><a href="r.slope.aspect.html">r.slope.aspect</A></em>
+<em><a href="r.slope.aspect.html">r.slope.aspect</a></em>
program). For example, a value of 16 would result in
detected edges being categorized into one of 16 bins
@@ -71,26 +70,26 @@
The procedure to find the "edges" in the image is as follows:
-<OL>
-<LI> The Fourier transform of the image is taken,
-<LI> The Fourier transform of the Laplacian of a two-dimensional
+<ol>
+<li> The Fourier transform of the image is taken,
+<li> The Fourier transform of the Laplacian of a two-dimensional
Gaussian function is used to filter the transformed image,
-<LI> The result is run through an inverse Fourier transform,
-<LI> The resulting image is traversed in search of places where the image
+<li> The result is run through an inverse Fourier transform,
+<li> The resulting image is traversed in search of places where the image
changes from positive to negative or from negative to positive,
-<LI> Each cell in the map where the value crosses zero
+<li> Each cell in the map where the value crosses zero
(with a change in value greater than the threshold value)
is marked as an edge and an orientation is assigned to it.
The resulting raster map layer is output.
-</OL>
+</ol>
<h2>SEE ALSO</h2>
-<em><a href="i.ifft.html">i.ifft</A></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</A></em>,
-<em><a href="r.mfilter.html">r.mfilter</A></em>,
+<em><a href="i.ifft.html">i.ifft</a></em>,
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
+<em><a href="r.mfilter.html">r.mfilter</a></em>,
<h2>AUTHOR</h2>
Modified: grass/trunk/lib/cairodriver/cairodriver.html
--- grass/trunk/lib/cairodriver/cairodriver.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/lib/cairodriver/cairodriver.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,11 +1,11 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
-<HTML>
-<HEAD>
- <TITLE>Cairo driver</TITLE>
- <META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
+<html>
+<head>
+ <title>Cairo driver</title>
+ <meta http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</HEAD>
-<BODY bgColor=white>
+</head>
+<body bgColor=white>
<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
@@ -131,19 +131,16 @@
requires a reasonably recent version of the Cairo libraries
and a working <tt>pkg-config</tt>.
-<p>
-Antialiasing is enabled by default for bitmap formats. There is
+<p>Antialiasing is enabled by default for bitmap formats. There is
currently no way of disabling this.
-<p>
-The resolution of the output images is defined by current region
+<p>The resolution of the output images is defined by current region
extents. Use <tt>g.region -p</tt> to get the number of rows and cols
and use the environment variables to set the image size. If you would
like a larger image, multiply both rows and cols by the same whole
number to preserve the aspect ratio.
-<p>
-Cairo supports true vector format output whenever possible. However,
+<p>Cairo supports true vector format output whenever possible. However,
if the selected format doesn't support a necessary feature, Cairo may
fall back on rendering a bitmap representation of the image wrapped in
the selected vector format.
Modified: grass/trunk/lib/htmldriver/htmldriver.html
--- grass/trunk/lib/htmldriver/htmldriver.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/lib/htmldriver/htmldriver.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,11 +1,11 @@
-<HTML>
-<HEAD>
- <TITLE>HTML driver</TITLE>
+<html>
+<head>
+ <title>HTML driver</title>
-</HEAD>
+</head>
@@ -21,21 +21,18 @@
HTML driver can create both client-side image maps embedded into HTML
files, or server-side image maps used by web server software.
-<p>
-Polygons can at most have 100 vertices (this limit imposed by HTML
+<p>Polygons can at most have 100 vertices (this limit imposed by HTML
image map formats, see <b>GRASS_HTMLMAXPOINTS</b> below.) The driver
will attempt to trim polygons that have more that 100 vertices by
removing vertices with the least amount of angle to the next
vertice. Also, any polygon that is entirely bounded by another polygon
will be discarded.
-<p>
-Text written to the driver before polygons are used as the HREF tag
+<p>Text written to the driver before polygons are used as the HREF tag
for all subsequent polygons written. All polygons that exist in a
vector map will have the same HREF tag.
-<p>
-The only GRASS display commands that should be used with this driver
+<p>The only GRASS display commands that should be used with this driver
are:
<ul>
<li><em><a href="d.text.html">d.text</a></em> - pass href
@@ -181,8 +178,7 @@
</li>
</ul>
-<p>
-If you create an HTML file with two or more images and image maps, you
+<p>If you create an HTML file with two or more images and image maps, you
will need to edit the map names. The HTML driver creates its map
with the name
<tt>map</tt>. A small sed script can easily change the map name:
@@ -206,5 +202,4 @@
<a href="d.redraw.html">d.redraw</a>
</em>
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/lib/init/grass7.html
--- grass/trunk/lib/init/grass7.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/lib/init/grass7.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,7 +1,7 @@
<html>
<head>
- <TITLE>GRASS 7</TITLE>
+ <title>GRASS 7</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
@@ -25,8 +25,7 @@
-<p>
-This command is used to launch GRASS GIS. It will parse the command line
+<p>This command is used to launch GRASS GIS. It will parse the command line
arguments and then initialize GRASS for the user. Since GRASS programs
require a specific environment, this program must be called before any other
GRASS program can run. The command line arguments are optional and provide
@@ -36,14 +35,12 @@
<h2>FEATURES</h2>
-<p>
-The <em>grass70</em> startup program will remember both the desired user
+<p>The <em>grass70</em> startup program will remember both the desired user
interface and mapset. Thus, the next time the user runs GRASS, typing
<em>grass70</em> (without any options) will start GRASS with the previous
settings for the user interface and mapset selected.
-<p>
-If you specify a graphical user interface (wxPython) the <em>grass70</em>
+<p>If you specify a graphical user interface (wxPython) the <em>grass70</em>
program will try to verify that the system you specified exists and that you
can access it successfully. If any of these checks fail then <em>grass70</em>
will automatically switch back to the text user interface mode.
@@ -51,10 +48,9 @@
<h2>OPTIONS</h2>
-<p>
-All command line options are optional.
+<p>All command line options are optional.
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
@@ -75,7 +71,7 @@
</dl>
<dl>
<dt><b>GISDBASE</b>
@@ -106,8 +102,7 @@
with automation and customization. Most users will not need to bother with
these.
-<p>
-In addition to these shell environment variables GRASS maintains a number of
+<p>In addition to these shell environment variables GRASS maintains a number of
GIS environment variables in the <tt>$HOME/.grass7/rc</tt> file. User changes
to this file will be read during the next startup of GRASS. If this file
becomes corrupted the user may edit it by hand or remove it to start afresh.
@@ -116,17 +111,15 @@
The rest of this help page will only consider shell environment variables.
-<H3>User Interface Environment Variable</H3>
+<h3>User Interface Environment Variable</h3>
-<p>
-The <em>grass70</em> program will check for the existence of an environment
+<p>The <em>grass70</em> program will check for the existence of an environment
variable called GRASS_GUI which indicates the type of user interface for
GRASS to use. If this variable is not set when <em>grass70</em> is run, then
it will be created and then saved in the <tt>$HOME/.grass7/rc</tt> file for
the next time GRASS is run. It can be set to "text" or "wxpython".
-<p>
-There is an order of precedence in the way <em>grass70</em> determines the user
+<p>There is an order of precedence in the way <em>grass70</em> determines the user
interface to use. The following is the hierarchy from highest precedence to
lowest.
@@ -138,10 +131,9 @@
• Default value - wxpython
</dl>
-<H3>Python Environment Variables</H3>
+<h3>Python Environment Variables</h3>
-<p>
-If you choose to use the wxPython interface, then
+<p>If you choose to use the wxPython interface, then
the following environment variables can be used to override your
system default <tt>python</tt> command.
@@ -151,48 +143,43 @@
</dl>
-<H4>Example Use of GRASS Python Environment Variable</H4>
+<h4>Example Use of GRASS Python Environment Variable</h4>
-<p>
-Suppose your system has Python 2.4 installed and you install a personal
+<p>Suppose your system has Python 2.4 installed and you install a personal
version of the Python 2.5 binaries under <tt>$HOME/bin</tt>. You can use
the above variables to have GRASS use the Python 2.5 binaries instead.
-<H4>Example Use of the GRASS Python Environment Variable</H4>
-<p>
-<pre>
+<h4>Example Use of the GRASS Python Environment Variable</h4>
+<p><pre>
GRASS_PYTHON=python2.5
</pre>
-<H3>Addon path to extra local GRASS modules</H3>
+<h3>Addon path to extra local GRASS modules</h3>
This environment variable allows the user to extend the GRASS program search
paths to include locally developed/installed addon modules which are not
distributed with the standard GRASS release.
-<p>
-<pre>
+<p><pre>
GRASS_ADDON_PATH=/usr/mytools
GRASS_ADDON_PATH=/usr/mytools:/usr/local/othertools
</pre>
-<p>
-In this example above path(s) would be added to the standard GRASS path
+<p>In this example above path(s) would be added to the standard GRASS path
environment.
-<H3>HTML browser variable</H3>
+<h3>HTML browser variable</h3>
The GRASS_HTML_BROWSER environment variable allows the user to set the HTML
web browser to use for dispalying help pages.
-<H3>Location Environment Variables</H3>
+<h3>Location Environment Variables</h3>
-<p>
-The Synopsis and Options sections above describe options that can be used to
+<p>The Synopsis and Options sections above describe options that can be used to
set the location and mapset that GRASS will use. These values can also be set
with environment variables. However, specifying the location and mapset
variables on the command line will override these environment variables. The
@@ -218,7 +205,7 @@
</dl>
-<H3>Running non-interactive batch jobs</H3>
+<h3>Running non-interactive batch jobs</h3>
If the <tt>GRASS_BATCH_JOB</tt> environment variable is set to the <i>full</i>
path and filename of a shell script then GRASS will be launched in a
@@ -228,18 +215,16 @@
The script file must have its executable bit set.
-<H3>Note</H3>
+<h3>Note</h3>
-<p>
-Note that you will need to set these variables using the appropriate method
+<p>Note that you will need to set these variables using the appropriate method
required for the UNIX shell that you use. (e.g. in a Bash shell you must
"export" the variables for them to propogate)
<h2>EXAMPLES</h2>
-<p>
-The following are some examples of how you could start GRASS
+<p>The following are some examples of how you could start GRASS
<dl>
@@ -266,7 +251,7 @@
</dl>
-<H3>Other examples</H3>
+<h3>Other examples</h3>
There are a variety of ways in which the <i>location environment
variables</i> (see above) can be used to specify the mapset to use.
@@ -362,8 +347,7 @@
administrator must create an appropriate link to the actual <tt>python</tt>
program.
-<p>
-Furthermore, if you have more than one version of Python installed, make sure
+<p>Furthermore, if you have more than one version of Python installed, make sure
that the version you want to use with GRASS is the first version found in
your <tt>$PATH</tt> variable. GRASS searches your <tt>$PATH</tt> variable
until it finds the first version of <tt>python</tt>.
@@ -381,10 +365,8 @@
<h2>SEE ALSO</h2>
List of <a href=variables.html>implemented GRASS environment variables</a>.
-<p>
-<a href="http://grass.osgeo.org">GRASS Web site</a>
-<p>
-<a href="http://download.osgeo.org/grass/grass7_progman/">GRASS 7 Programmer's Manual</a>
+<p><a href="http://grass.osgeo.org">GRASS Web site</a>
+<p><a href="http://download.osgeo.org/grass/grass7_progman/">GRASS 7 Programmer's Manual</a>
<h2>AUTHORS (of this page)</h2>
@@ -392,11 +374,9 @@
Markus Neteler<br>
Hamish Bowman
-<p>
<HR>
-<p>
-<a href=index.html>Help Index</a>
+<p><a href=index.html>Help Index</a>
</body>
</html>
Modified: grass/trunk/lib/init/helptext.html
--- grass/trunk/lib/init/helptext.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/lib/init/helptext.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,12 +1,12 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN">
-<HTML>
-<HEAD>
- <META name="Author" content="Markus Neteler/GRASS Development Team">
- <META http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
- <TITLE>GRASS Quickstart</TITLE>
+<html>
+<head>
+ <meta name="Author" content="Markus Neteler/GRASS Development Team">
+ <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
+ <title>GRASS Quickstart</title>
-</HEAD>
-<BODY bgcolor="#ffffff">
+</head>
+<body bgcolor="#ffffff">
@@ -26,8 +26,7 @@
<h2>1. Startup of GRASS GIS</h2>
-<p>
- <IMG SRC="grass_start.png" ALT="[GRASS start screen]">
+<p> <IMG SRC="grass_start.png" ALT="[GRASS start screen]">
<h3><IMG SRC="circle_1.png" ALT="[(1)]"> Selecting the GIS Database directory</h3>
@@ -44,8 +43,7 @@
LOCATION are created automatically when GRASS is started the first
time with a new LOCATION. It is important to understand that each
projection stays in its own LOCATION.
-<p>
-See <IMG SRC="circle_4.png" ALT="[(4)]"> the "Location Wizard" to
+<p>See <IMG SRC="circle_4.png" ALT="[(4)]"> the "Location Wizard" to
easily create a new LOCATION from scratch from a geocoded file, by
defining the parameters or by selecting the corresponding EPSG projection
code.
@@ -74,12 +72,10 @@
<h2>2. Background GRASS Location structure</h2>
-<p>
- <IMG SRC="help_loc_struct.png" ALT="[GRASS Location structure]">
+<p> <IMG SRC="help_loc_struct.png" ALT="[GRASS Location structure]">
<br>
<i>Fig. 1: GRASS Location structure</i>
<p>
A LOCATION is simply a set of directories which contains the GRASS
data of a project. Within each LOCATION, a mandatory "PERMANENT"
MAPSET exists which contains projection information and some
@@ -96,8 +92,7 @@
MAPSET, each user can also read map layers in other users' MAPSETs,
but s/he can modify or remove only the map layers in his/her own
MAPSET.
-<p>
-You can learn more about mapsets and how to seamlessly access maps
+<p>You can learn more about mapsets and how to seamlessly access maps
found in another MAPSET of the same LOCATION in the
<a href="g.mapsets.html">g.mapsets</a> documentation.
@@ -123,22 +118,20 @@
To create the GRASS database:
-<OL>
-<LI> Find a place on your disk where you have write access and that
+<ol>
+<li> Find a place on your disk where you have write access and that
has enough diskspace to hold your spatial data.</LI>
-<LI> Create a subdirectory that will hold the general GRASS database
+<li> Create a subdirectory that will hold the general GRASS database
(e.g. using a file manager or with <tt>mkdir /data/grassdata</tt> or
<tt>mkdir /home/yourlogin/grassdata</tt>).</LI>
-</OL>
+</ol>
-<p>
-Sample data such as the "Spearfish" or the "North Carolina" sample datasets
+<p>Sample data such as the "Spearfish" or the "North Carolina" sample datasets
may be downloaded from
-<a href="http://grass.osgeo.org/download/data.php">http://grass.osgeo.org/download/data.php</A>
+<a href="http://grass.osgeo.org/download/data.php">http://grass.osgeo.org/download/data.php</a>
and placed in this new database directory.
<p>
<h3>A) Create New Location with wxGUI</h3>
The <a href="wxGUI.html">wxGUI</a> graphical user interface provides a
graphical "Location Wizard" instead which let's you easily create a
@@ -154,65 +147,59 @@
continue by pressing "ESC"-"RETURN" - i.e. press (NOT hold) the ESC key,
and then press the RETURN key on your keyboard.
-<p>
-Next you will need to assign parameters to the location such
+<p>Next you will need to assign parameters to the location such
as the coordinate system and datum you want to use, the project area's
boundary coordinates, and the default resolution for raster data:
<UL>
-<LI> Start by chosing between, X,Y, Latitude-Longitude, UTM, or
+<li> Start by chosing between, X,Y, Latitude-Longitude, UTM, or
"other" coordinate system. This choice depends on your data and the
use you will make of it.</LI>
-<LI> You are then prompted for a single line of text describing the
+<li> You are then prompted for a single line of text describing the
project area, for example "Topo Map of the Alps".</LI>
</UL>
-<p>
-Next you are requested for some more information about the projection.
+<p>Next you are requested for some more information about the projection.
Note that the prompts vary from projection to projection, an example follows:
<UL>
-<LI> (if you chose "D - Other Projection") "specify projection name":
+<li> (if you chose "D - Other Projection") "specify projection name":
"list" gives you the list of all available projections, examples are
"tmerc" for Transverse Mercator, "lcc" for Lambert Conformal Conic,
"moll" for Mollweide, etc.
-<LI> specify datum name: again use "list" to get a list of available
+<li> specify datum name: again use "list" to get a list of available
datums, examples are "wgs84", "nad27", "eur79", etc.
-<LI> Enter Central Parallel: 0 if you want the Equator as the
+<li> Enter Central Parallel: 0 if you want the Equator as the
central parallel
-<LI> Enter Central Meridian: 0 if you want the Greenwich meridian as
+<li> Enter Central Meridian: 0 if you want the Greenwich meridian as
central meridian
-<LI> Enter Scale Factor at the Central Meridian
-<LI> Enter plural form of map units: for example, meters
+<li> Enter Scale Factor at the Central Meridian
+<li> Enter plural form of map units: for example, meters
</UL>
-<p>
-The next step is the description of the project area's boundary coordinates
+<p>The next step is the description of the project area's boundary coordinates
and the definition of the default raster resolution:
-<p>
-The default raster resolution (GRID RESOLUTION) has to be chosen
+<p>The default raster resolution (GRID RESOLUTION) has to be chosen
according to your needs. Generally, it is advisable to work in steps of
0.25 (0.25, 0.5, 1.75, 2.00, 12.25 etc.). This resolution does not
concern vector and site data since these are stored with their exact
coordinate values. Note that every raster map may have its own
resolution. You can leave this screen with "ESC"-"RETURN" and then
if everything is correct accept the list of parameters that appears.
-<p>
-You will then be back to the startup screen to enter the mapset's
+<p>You will then be back to the startup screen to enter the mapset's
name (if not already entered). Another "ESC"-"RETURN" will finally
let you leave this screen. This mapset is created within the new
location by answering "yes" to the next question. The mapset will
use the parameters of the location (such as the region and resolution
definitions) as its default parameters.
-<p>
-Now the project area, i.e. the location including a mapset, has been
+<p>Now the project area, i.e. the location including a mapset, has been
created. You have "arrived" in the GRASS system and can start working
within this new location.
<h2>Further Reading</h2>
Please have a look at the GRASS web site for tutorials and books:
-<a href="http://grass.osgeo.org/gdp/index.php">http://grass.osgeo.org/gdp/index.php</A>.
+<a href="http://grass.osgeo.org/gdp/index.php">http://grass.osgeo.org/gdp/index.php</a>.
<h2>See also</h2>
<a href="index.html">GRASS 7 Reference Manual</a>
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/lib/init/variables.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -74,8 +74,7 @@
It looks unusual with two equals signs, but <em>g.gisenv</em> serves dual duty for
getting and setting GRASS variables.
-<p>
-If the user just specifies a variable name, it defaults to <b>get</b> mode.
+<p>If the user just specifies a variable name, it defaults to <b>get</b> mode.
For example:
g.gisenv MAPSET
@@ -452,15 +451,12 @@
<a href="g.parser.html">g.parser</a>
</em>
-<p>
<hr>
-<p>
-<p>
-© 2008-2011 <a href="http://grass.osgeo.org">GRASS Development Team</a>
+<p>© 2008-2011 <a href="http://grass.osgeo.org">GRASS Development Team</a>
</body>
</html>
Modified: grass/trunk/lib/pngdriver/pngdriver.html
--- grass/trunk/lib/pngdriver/pngdriver.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/lib/pngdriver/pngdriver.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,11 +1,11 @@
-<HTML>
-<HEAD>
- <TITLE>PNG driver</TITLE>
+<html>
+<head>
+ <title>PNG driver</title>
-</HEAD>
+</head>
@@ -92,15 +92,13 @@
<a href="http://www.zlib.net">zlib</a> home page), all which needs to
be installed for the PNG driver to work (it's worth it).
-<p>
-<p>
-Further PNG file processing (e.g. quantization to 1 bit for monochrome
+<p>Further PNG file processing (e.g. quantization to 1 bit for monochrome
images) can be done with <tt>pnmquant</tt> of
the <a href="http://netpbm.sourceforge.net/">netpbm</a> tools.
@@ -125,5 +123,4 @@
<br>
Rewritten by: Glynn Clements, 2003
-<p>
Modified: grass/trunk/lib/psdriver/psdriver.html
--- grass/trunk/lib/psdriver/psdriver.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/lib/psdriver/psdriver.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,11 +1,11 @@
-<HTML>
-<HEAD>
- <TITLE>PS driver</TITLE>
+<html>
+<head>
+ <title>PS driver</title>
-</HEAD>
+</head>
@@ -81,13 +81,11 @@
-<p>
-GRASS_TRUECOLOR requires either PostScript level 2 or level 1 plus the
+<p>GRASS_TRUECOLOR requires either PostScript level 2 or level 1 plus the
colorimage and setrgbcolor operators (this is the case for colour
printers which pre-date level 2 PostScript).
-<p>
-Masked images (<tt>d.rast</tt>, <tt>d.rgb</tt>, <tt>d.his -n</tt>)
+<p>Masked images (<tt>d.rast</tt>, <tt>d.rgb</tt>, <tt>d.his -n</tt>)
require PostScript level 3.
<h2>SEE ALSO</h2>
@@ -108,5 +106,4 @@
Glynn Clements, 2007
-<p>
Modified: grass/trunk/lib/vector/vectorascii.html
--- grass/trunk/lib/vector/vectorascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/lib/vector/vectorascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
faces, and kernels. The GRASS ASCII vector format may contain also
a <i>header</i> with various metadata (see example below).
-<p>
-The header is similar as the head file of vector binary format but
+<p>The header is similar as the head file of vector binary format but
contains bounding box also. Key words are:
@@ -26,8 +25,7 @@
MAP THRESH
</pre></div>
-<p>
-The body begins with the row:
+<p>The body begins with the row:
VERTI:
@@ -47,8 +45,7 @@
Everything above in <tt>[ ]</tt> is optional.
-<p>
-The primitive codes are as follows:
+<p>The primitive codes are as follows:
<ul>
<li>'P': point</li>
<li>'L': line</li>
@@ -65,8 +62,7 @@
for multiple layers). Below that 1 or several lines follow to
indicate the layer number and the category number (ID).
-<p>
-The order of coordinates is
+<p>The order of coordinates is
X Y [Z]
</pre></div>
@@ -77,8 +73,7 @@
Y X
</pre></div>
-<p>
-Latitude/Longitude data may be given in a number of ways.
+<p>Latitude/Longitude data may be given in a number of ways.
Decimal degrees must be positive or negative instead of using a hemisphere
letter. Mixed coordinates must use a hemisphere letter. Whole minutes and
seconds must always contain two digits (example: use <tt>167:03:04.567</tt>;
Modified: grass/trunk/misc/m.cogo/m.cogo.html
--- grass/trunk/misc/m.cogo/m.cogo.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/misc/m.cogo/m.cogo.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,8 +4,7 @@
and X,Y coordinates. Only simple bearing/distance or coordinate
pairs are handled. It assumes a cartesian coordinate system.
-<p>
-Input can be entered via standard input (default) or from the file
+<p>Input can be entered via standard input (default) or from the file
<b>input=</b><em>name</em>. Specifying the input as "-" also
specifies standard input, and is useful for using the program in
a pipeline. Output will be to standard output unless a file
@@ -13,16 +12,14 @@
closely adhere to the following format, where up to a 10 character
label is allowed but not required (see <b>-l</b> flag).
-<p>
-<b>Example COGO input:</b>
+<p><b>Example COGO input:</b>
P23 N 23:14:12 W 340
P24 S 04:18:56 E 230
</pre></div>
-<p>
-The first column may contain a label and you must use the <b>-l</b>
+<p>The first column may contain a label and you must use the <b>-l</b>
flag so the program knows. This is followed by a space, and then
either the character 'N' or 'S' to indicate whether the bearing is
relative to the north or south directions. After another space,
@@ -33,18 +30,15 @@
characters. A space separates the bearing from the distance (which should
be in appropriate linear units).
-<p>
-<b>Output of the above input:</b>
+<p><b>Output of the above input:</b>
-134.140211 312.420236 P23
-116.832837 83.072345 P24
</pre></div>
-<p>
-Unless specified with the <b>coord</b> option, calculations begin from (0,0).
+<p>Unless specified with the <b>coord</b> option, calculations begin from (0,0).
-<p>
-For those unfamiliar with the notation for bearings: Picture yourself in the
+<p>For those unfamiliar with the notation for bearings: Picture yourself in the
center of a circle. The first hemispere notation tell you whether you should
face north or south. Then you read the angle and either turn that many
degrees to the east or west, depending on the second hemisphere notation.
@@ -60,7 +54,6 @@
using the familiar GRASS parser interface.
<p>
<h2>NOTES</h2>
This program is very simplistic, and will not handle deviations
@@ -141,5 +134,4 @@
Eric G. Miller
-<p>
Modified: grass/trunk/misc/m.measure/m.measure.html
--- grass/trunk/misc/m.measure/m.measure.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/misc/m.measure/m.measure.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,5 +13,4 @@
Derived from d.measure by James Westervelt, Michael Shapiro, U.S. Army
-<p>
Modified: grass/trunk/misc/m.nviz.image/m.nviz.image.html
--- grass/trunk/misc/m.nviz.image/m.nviz.image.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/misc/m.nviz.image/m.nviz.image.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -31,5 +31,4 @@
Anna Kratochvilova, <a href="http://grass.osgeo.org/wiki/WxNviz_GSoC_2011">Google
Summer of Code 2011</a> (mentor: Martin Landa)
-<p>
Modified: grass/trunk/misc/m.nviz.script/m.nviz.script.html
--- grass/trunk/misc/m.nviz.script/m.nviz.script.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/misc/m.nviz.script/m.nviz.script.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,14 +10,13 @@
be loaded into the <em>Keyframe Animation</em> panel for fine
tuning or editing.
-<p>
-The script generated by <em>m.nviz.script</em> can be run from the NVIZ
+<p>The script generated by <em>m.nviz.script</em> can be run from the NVIZ
command line (nviz script=script_name) or after NVIZ is started by
selecting <em>Scripting->Play Script</em>.
<h2>OPTIONS</h2>
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
<dt><b>-i</b>
<dd>Intercative mode
@@ -45,7 +44,7 @@
</dl>
<dl>
<dt><b>input</b>
<dd>The name of the GRASS raster map with elevation data.
@@ -99,14 +98,11 @@
<h2>NOTES / HINTS</h2>
The user must select at least four key-frame locations (points)
otherwise an error is generated.
-<p>
-If the GRASS region is changed the <em>m.nviz.script</em> command must be re-run.
-<p>
-The current GRASS region and the user supplied parameters are included
+<p>If the GRASS region is changed the <em>m.nviz.script</em> command must be re-run.
+<p>The current GRASS region and the user supplied parameters are included
as a comment at the top of the output script. This information can be
used to easily re-create the animation.
-<p>
-The camera position is calculated backwards from the supplied
+<p>The camera position is calculated backwards from the supplied
position(s). It is possible that the camera position will lie outside
the current window, in which case a non-fatal error is generated
(Error: selected point is outside region). This error can result in
@@ -138,9 +134,9 @@
<h2>SEE ALSO</h2>
-<em><a href="nviz.html">nviz</A></em>
+<em><a href="nviz.html">nviz</a></em>
<h2>AUTHOR</h2>
-<a href="mailto:bcovill at tekmap.ns.ca">Bob Covill</A>
+<a href="mailto:bcovill at tekmap.ns.ca">Bob Covill</a>
Modified: grass/trunk/misc/m.transform/m.transform.html
--- grass/trunk/misc/m.transform/m.transform.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/misc/m.transform/m.transform.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,10 +10,8 @@
<tt>stdin</tt>, the input format is "x y" with one coordinate pair per
line.
-<p>
-The transformations are:
-<p>
-order=1:
+<p>The transformations are:
+<p>order=1:
e = [E0 E1][1].[1]
[E2 0][e] [n]
@@ -47,14 +45,13 @@
</pre></div>
["." = dot-product, (AE).N = N'EA.]
-<p>
-In other words, order=1 and order=2 are equivalent to order=3 with
+<p>In other words, order=1 and order=2 are equivalent to order=3 with
the higher coefficients equal to zero.
<h2>SEE ALSO</h2>
<h2>AUTHORS</h2>
@@ -63,5 +60,4 @@
Glynn Clements<br>
Hamish Bowman
-<p>
Modified: grass/trunk/ps/ps.map/ps.map.html
--- grass/trunk/ps/ps.map/ps.map.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/ps/ps.map/ps.map.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,30 +4,25 @@
hardcopy maps in PostScript format. Output can include a raster map, any
number of vector overlays, text labels, decorations, and other spatial data.
-<p>
-A file of mapping instructions that describes the various spatial and textual
+<p>A file of mapping instructions that describes the various spatial and textual
information to be printed must be prepared prior to running <em>ps.map</em>.
<h2>NOTES</h2>
-<p>
-The order of commands is generally unimportant but may affect how some layers
+<p>The order of commands is generally unimportant but may affect how some layers
are drawn. For example to plot <b>vpoints</b> above <b>vareas</b> list the
<b>vpoints</b> entry first. Raster maps are always drawn first, and only a
single raster map (or 3 if part of a RGB group) may be used.
-<p>
-The hash character ('<tt>#</tt>') may be used at the beginning of a line
+<p>The hash character ('<tt>#</tt>') may be used at the beginning of a line
to indicate that the line is a comment. Blank lines will also be ignored.
-<p>
-Be aware that some mapping instructions require the <i>end</i> command
+<p>Be aware that some mapping instructions require the <i>end</i> command
and some do not. Any instruction that allows subcommands will require
it, any instruction that does not allow subcommands will not.
-<p>
-The resolution and extent of raster maps plotted with <em>ps.map</em> are
+<p>The resolution and extent of raster maps plotted with <em>ps.map</em> are
controlled by the current region settings via the
<a href="g.region.html">g.region</a> module. The output filesize is largely
a function of the region resolution, so special care should be taken
@@ -39,17 +34,14 @@
output file larger, but with a consumer printer you probably won't be able
to resolve any better detail in the hardcopy.
-<p>
-The user can specify negative or greater than 100 percentage values for
+<p>The user can specify negative or greater than 100 percentage values for
positioning several map decorations and embedded EPS-files, to move them
outside the current map box region (for example to position a caption,
barscale, or legend above or below the map box).
-<p>
-One point ("pixel") is 1/72 of an inch.
+<p>One point ("pixel") is 1/72 of an inch.
-<p>
-For users wanting to use special characters (such as accented characters) it
+<p>For users wanting to use special characters (such as accented characters) it
is important to note that <em>ps.map</em> uses <tt>ISO-8859-1</tt> encoding.
This means that your instructions file will have to be encoded in this
encoding. If you normally work in a different encoding environment (such as
@@ -62,7 +54,6 @@
<p><p>
<h2>MAPPING INSTRUCTIONS</h2>
The mapping instructions allow the user to specify various spatial data
@@ -72,7 +63,6 @@
consist of the main instruction followed by a subsection of one or more
additional instructions and are terminated with an <i>end</i> instruction.
<p>
<h3>Instruction keywords:</h3>
<a href="#border">border</a> |
@@ -190,8 +180,7 @@
</dl>
-<p>
-<br>
+<p><br>
<h3>Command usage</h3>
@@ -210,13 +199,11 @@
or "none". The width is specified in points, unless followed by an "i"
in which case it is measured in inches.
The default is a black border box of width 1 point.
-<p>
-The border can be turned off completely with the
+<p>The border can be turned off completely with the
"<tt>border n</tt>" instruction. In this case
the <b>end</b> command should not be given as the
main command will be treated as a single line instruction.
<p>
This example would create a grey border 0.1" wide.
<pre>
EXAMPLE:
@@ -227,7 +214,6 @@
</pre>
<p>
<a name="colortable"></a>
<h2>colortable</h2>
@@ -253,8 +239,7 @@
the colors for each of a raster map's category values along with its
associated category label. For a floating point (FCELL or DCELL) map a
continuous gradient legend will be created.
-<p>
-If <b>raster</b> is omitted, the colortable defaults to the previously
+<p>If <b>raster</b> is omitted, the colortable defaults to the previously
registered raster layer.
The default location for the colortable is immediately below any other
@@ -263,12 +248,10 @@
Omitting the <b>colortable</b> instruction would result in
no color table.
-<p>
-If the colortable is turned off with a "<tt>colortable N</tt>"
+<p>If the colortable is turned off with a "<tt>colortable N</tt>"
instruction the <b>end</b> command should not be given as the
-<p>
-See also the <a href="#vlegend">vlegend</a> command for creating vector map
+<p>See also the <a href="#vlegend">vlegend</a> command for creating vector map
legends.
@@ -283,8 +266,7 @@
This could result in the printing of an extremely long color table!
In this situation it is useful to use the <b>discrete N</b> instruction
to force a continuous color gradient legend.
-<p>
-Be aware that the color table only includes categories which
+<p>Be aware that the color table only includes categories which
have a label. You can use the <em>r.category</em> module to add labels.
@@ -313,8 +295,7 @@
first.
<br>
-<p>
-This example would print a color table immediately below any other map legend
+<p>This example would print a color table immediately below any other map legend
information, starting at the left margin, with 4 columns:
<pre>
EXAMPLE:
@@ -325,7 +306,6 @@
</pre>
<p>
<a name="comments"></a>
<h2>comments</h2>
@@ -340,13 +320,11 @@
</pre>
The default location is immediately below the last item item printed,
starting at the left margin. The default text color is black.
-<p>
-If you wish to use parentheses spanning multiple lines you will need to
+<p>If you wish to use parentheses spanning multiple lines you will need to
quote them with a backslash to prevent the PostScript interpreter from
getting confused. e.g. '<b><tt>\(</tt></b>' and '<b><tt>\)</tt></b>'
<p>
This example prints in blue
whatever is in the file <em>veg.comments</em> starting at
1.5 inches from the left edge of the page and 7.25 inches from the top of
@@ -368,7 +346,6 @@
such as "This map was created by classifying a LANDSAT TM image".
<p>
<a name="copies"></a>
<h2>copies</h2>
@@ -377,11 +354,9 @@
USAGE: <b>copies</b> n
</pre>
Each page will be printed n times.
+<p>This instruction is identical to the <em>copies</em> command line parameter.
<p>
-This instruction is identical to the <em>copies</em> command line parameter.
-<p>
<a name="eps"></a>
<h2>eps</h2>
@@ -405,10 +380,9 @@
(default is 0)
and whether the point is to be <b>masked</b>
by the current mask.
-(See manual entry for <em><a href="r.mask.html">r.mask</A></em>
+(See manual entry for <em><a href="r.mask.html">r.mask</a></em>
for more information on the mask.)
<p>
This example would place a EPS file ./epsf/logo.eps
at the point (E456000 N7890000). This picture would be
rotated 20 degrees clockwise, 3 times bigger than
@@ -427,7 +401,6 @@
instructions.
<p>
<a name="geogrid"></a>
<h2>geogrid</h2>
@@ -455,11 +428,9 @@
black grid lines, unnumbered.
<p>
NOTE: The <b>geogrid</b> draws grid numbers on the east and south borders of the map.
<p>
This example would overlay a blue geographic grid with a spacing of 30 minutes
onto the output map. Alternate grid
lines would be numbered with yellow numbers.
@@ -472,7 +443,6 @@
</pre>
<p>
<a name="greyrast"></a>
<h2>greyrast</h2>
@@ -486,7 +456,6 @@
<em>greyrast</em> or the <em>raster</em> instruction).
<p>
<a name="grid"></a>
<h2>grid</h2>
@@ -514,7 +483,6 @@
The defaults are black grid lines, unnumbered.
<p>
This example would overlay a green grid with a spacing of 10000 meters
(for a metered database, like UTM) onto the output map. Alternate grid
lines would be numbered with red numbers.
@@ -527,7 +495,6 @@
</pre>
<p>
<a name="group"></a>
<h2>group</h2>
@@ -540,7 +507,6 @@
layers, comprising the red, green and blue bands of the image.
<p>
<a name="header"></a>
<h2>header</h2>
@@ -558,8 +524,7 @@
and the location's description.<!-- PERMANENT/MYNAME -->
The text will be centered on the page above the map.
-<p>
-If the <em>file</em> sub-instruction is given the header will consist
+<p>If the <em>file</em> sub-instruction is given the header will consist
of the text in the text file specified, with some special formatting keys:
<ul>
@@ -592,7 +557,6 @@
</pre></div>
<p>
This example prints (in red) whatever is in the file <em>soils.hdr</em> above
the map, using a 20/72 inch <tt>Courier</tt> font.
<pre>
@@ -606,24 +570,21 @@
</pre>
<p>
<a name="labels"></a>
<h2>labels</h2>
Selects a labels file for output (see manual entry for
<em>
-<a href="v.label.html">v.label</A>
+<a href="v.label.html">v.label</a>
).</em>
<pre>
USAGE: <b>labels</b> labelfile
<b>font</b> font name
<b>end</b>
</pre>
-<p>
-NOTE: ps.map can read new option 'ROTATE:' from labels file, which
+<p>NOTE: ps.map can read new option 'ROTATE:' from labels file, which
specifies counter clockwise rotation in degrees.
-<p>
-This example would paint labels from the labels file called
+<p>This example would paint labels from the labels file called
<em>town.names</em>. Presumably, these labels would indicate the names of
towns on the map.
<pre>
@@ -633,7 +594,6 @@
</pre>
<p>
<a name="line"></a>
<h2>line</h2>
@@ -652,13 +612,12 @@
The user may also specify line <b>color</b>, <b>width</b>
in points (1/72"; accepts decimal values as well as integers),
and if the line is to be <b>masked</b> by the current mask.
</em> for more information on the mask.)
The line <b>width</b> (if given) is measured in points; an <i>i</i>
directly following the number indicates that the width is given in
inches instead.
<p>
This example would draw a yellow line from the point x=10% y=80%
to the point x=30% y=70%.
This line would be 2 points wide (2/72") and would appear even if
@@ -676,7 +635,6 @@
instructions.
<p>
<a name="mapinfo"></a>
<h2>mapinfo</h2>
@@ -696,11 +654,9 @@
starting at the left edge of the map.
The default background box color is white.
-<p>
-<em>border</em> will draw a border around the legend using the specified color.
+<p><em>border</em> will draw a border around the legend using the specified color.
(see <a href="#NAMED_COLORS">NAMED COLORS</a>)
<p>
This example prints (in brown) the scale, grid and region information
immediately below the map and starting 1.5 inches from the left edge
of the page, using a 12/72 inch <tt>Courier</tt> font.
@@ -716,7 +672,6 @@
</pre>
<p>
<a name="maploc"></a>
<h2>maploc</h2>
@@ -730,7 +685,6 @@
rescaled, if necessary, to fit.
<p>
This example positions the upper left corner of the map 2.0 inches from
the left edge and 3.5 inches from the top edge of the map.
<pre>
@@ -739,7 +693,6 @@
</pre>
<p>
<a name="maskcolor"></a>
<h2>maskcolor</h2>
@@ -772,7 +725,6 @@
layer other than the one currently being painted may be placed on the map.)
<p>
This example would outline the category areas of the
<em>soils</em>
raster map layer
@@ -787,7 +739,6 @@
</pre>
<p>
<a name="paper"></a>
<h2>paper</h2>
@@ -809,14 +760,12 @@
If the plot is rotated with the <b>-r</b> command line flag, measures
are applied to the <em>rotated</em> page.
<p>
<pre>
EXAMPLE:
<b>paper</b> a3
<b>end</b>
</pre>
-<p>
-<pre>
+<p><pre>
EXAMPLE:
<b>paper</b>
<b>width</b> 10
@@ -829,7 +778,6 @@
</pre>
<p>
<a name="point"></a>
<h2>point</h2>
@@ -852,14 +800,13 @@
the <b>size</b> of symbol in points,
the rotation angle (in degrees CCW),
and whether the point is to be <b>masked</b> by the current mask.
-(See manual entry for <em> <a href="r.mask.html">r.mask</A>
+(See manual entry for <em> <a href="r.mask.html">r.mask</a>
The symbol line <b>width</b> (if given) is measured in points; an <i>i</i>
directly following the number indicates that the width is given in inches
instead. If a <b>width</b> is not given it will be set proportional to the
symbol size.
-<p>
-This example would place a purple diamond (from icon file
+<p>This example would place a purple diamond (from icon file
<em>diamond</em>) at the point (E456000 N7890000). This diamond would be the
the size of a 15 points and would not be masked by the current mask.
<pre>
@@ -877,14 +824,12 @@
instructions.
<p>
<a name="psfile"></a>
<h2>psfile</h2>
Copies a file containing PostScript commands into the output file.
<p>
<b>Note:</b>
<em>ps.map</em>
will not search for this file. The user must be in the
@@ -900,7 +845,6 @@
</pre>
<p>
<a name="raster"></a>
<h2>raster</h2>
@@ -913,16 +857,13 @@
raster map layer is requested, a completely white map will be
produced. It can be useful to select no raster map layer in
order to provide a white background for vector maps.
-<p>
-Note that an imagery group selected with the <em>group</em>
+<p>Note that an imagery group selected with the <em>group</em>
option, or a set of three raster layers selected with the
<em>rgb</em> option, count as a raster map layer for the
purposes of the preceding paragraph.
-<p>
-The PostScript file's internal title will be set to the raster map's
+<p>The PostScript file's internal title will be set to the raster map's
title, which in turn may be set with the <em>r.suppport</em> module.
-<p>
-This example would paint a map of the raster map layer <em>soils</em>.
+<p>This example would paint a map of the raster map layer <em>soils</em>.
<pre>
EXAMPLE:
@@ -930,7 +871,6 @@
</pre>
<p>
<a name="read"></a>
<h2>read</h2>
@@ -942,7 +882,6 @@
<em>ps.map.</em>
<p>
<b>Note:</b>
<em>ps.map</em>
@@ -950,7 +889,6 @@
(Note to /bin/csh users: ~ won't work with this instruction).
<p>
This example reads the UNIX file <em>pmap.roads</em> into <em>ps.map</em>.
This file may contain all the <em>ps.map</em> instructions for placing
the vector map layer <em>roads</em> onto the output map.
@@ -965,7 +903,6 @@
file with the correct instructions.
<p>
<a name="rectangle"></a>
<h2>rectangle</h2>
@@ -986,7 +923,7 @@
<b>color</b>, fill color <b>fcolor</b>, <b>width</b>
in points (accepts decimal points [floating points] as well as integers),
and if the rectangle is to be <b>masked</b> by the current mask.
The border line <b>width</b> (if given) is measured in points; an <i>i</i>
@@ -994,7 +931,6 @@
<br>
Multiple rectangles may be drawn by using multiple <em>rectangle</em> instructions.
<p>
This example would draw a yellow rectangle filled by green from the point x=10% y=80%
The border line would be 1/16" wide and would appear even if there is a mask.
@@ -1009,7 +945,6 @@
</pre>
<p>
<a name="region"></a>
<h2>region</h2>
@@ -1022,20 +957,18 @@
<b>end</b>
</pre>
Geographic region settings are created and saved using <em> the
-<a href="g.region.html">g.region</A></em> module.
+<a href="g.region.html">g.region</a></em> module.
The <em>ps.map</em> <em>region</em> option can be used to show an outline of
a smaller region which was printed on a separate run of <em>ps.map</em>
on other user-created maps.
-<p>
-The user can specify the <b>color</b>
+<p>The user can specify the <b>color</b>
and the <b>width</b> in point units (accepts decimal points
[floating points] as well as integers) of the outline.
The default is a black border of one point width (1/72").
-<p>
-This example would place a white outline, 2 points wide, of the
+<p>This example would place a white outline, 2 points wide, of the
geographic region called <em>fire.zones</em> onto the output map.
This geographic region would have been created and saved using
-<em><a href="g.region.html">g.region</A></em>.
+<em><a href="g.region.html">g.region</a></em>.
<pre>
EXAMPLE:
<b>region</b> fire.zones
@@ -1045,7 +978,6 @@
</pre>
<p>
<a name="rgb"></a>
<h2>rgb</h2>
@@ -1057,7 +989,6 @@
raster map layers instead of a single layer. The three layers
are composed to form a color image, similar to <em>d.rgb</em>.
<p>
For each layer, only one of the components of the layer's color
table is used: the red component for the red layer, and so on.
This will give the desired result if all of the layers have a
@@ -1065,7 +996,6 @@
hue appropriate to the layer.
<p>
<a name="scale"></a>
<h2>scale</h2>
@@ -1088,7 +1018,6 @@
</dd>
</dl>
<p>
This example would set the scale of the map to 1 unit = 25000
units.
<pre>
@@ -1097,7 +1026,6 @@
</pre>
<p>
<a name="scalebar"></a>
<h2>scalebar</h2>
@@ -1128,15 +1056,12 @@
numbers every n-th segment.
The <b>background</b> command can turn off the background box for the text.
-<p>
-The scalebar <b>length</b> is the only required argument. The defaults are a
+<p>The scalebar <b>length</b> is the only required argument. The defaults are a
fancy scalebar with 4 segments, each segment labeled, and a height of 0.1
inches. The default location is 2 inches from the top of the page and
halfway across.
-<p>
-NOTE: The scalebar is centered on the location given.
-<p>
-This example draws a simple scalebar 1000 meters (for a metered database,
+<p>NOTE: The scalebar is centered on the location given.
+<p>This example draws a simple scalebar 1000 meters (for a metered database,
like UTM) long, with tics every 200 meters, labeled every second tic.
The scalebar is drawn 5 inches from the top and 4 inches from the left
and is 0.25 inches high.
@@ -1177,7 +1102,6 @@
"<tt>default</tt>" (i.e. out-of-range) color may also be reassigned.
<p>
<a name="text"></a>
<h2>text</h2>
@@ -1207,60 +1131,47 @@
More than one line of text can be specified by notating the end of a line with
<b>\n</b>
(e.g. USA<b>\n</b>CERL).
-<p>
-The user can then specify various text features:
-<p>
-<b>font:</b>
+<p>The user can then specify various text features:
+<p><b>font:</b>
the PostScript font. Common possibilities are listed at the start of this
help page. The default is <tt>Helvetica</tt>.
-<p>
-<b>color</b>
+<p><b>color</b>
(see <a href="#NAMED_COLORS">NAMED COLORS</a>);
-<p>
-<b>width</b>
+<p><b>width</b>
of the lines used to draw the text to make thicker letters
(accepts decimal points [floating points] as well as integers);
-<p>
-<b>size</b> and <b>fontsize.</b>
+<p><b>size</b> and <b>fontsize.</b>
<b>size</b> gives the vertical height of the letters in meters on the
ground (text size will grow or shrink depending on the scale at which
the map is painted). Alternatively <b>fontsize</b> can set the font
size directly. If neither <b>size</b> or <b>fontsize</b> is given, a
default font size of 10 will be used;
-<p>
-the highlight color (<b>hcolor</b>) and
+<p>the highlight color (<b>hcolor</b>) and
the width of the highlight color (<b>hwidth</b>);
-<p>
-the text-enclosing-box <b>background</b> color;
+<p>the text-enclosing-box <b>background</b> color;
the text box <b>border</b> color;
-<p>
-<b>ref.</b>
+<p><b>ref.</b>
This reference point specifies the text handle - what
part of the text should be placed on the location specified by the map
coordinates. Reference points can refer to:
[lower|upper|center] [left|right|center] of the text to be printed;
The default is center center, i.e. the text is centered on the reference point.
-<p>
-<b>rotate</b>
+<p><b>rotate</b>
sets the text rotation angle, measured in degrees counter-clockwise.
-<p>
-<b>yoffset</b>,
+<p><b>yoffset</b>,
which provides finer placement of text by shifting the
text a vertical distance in points (1/72") from the specified north.
The vertical offset will shift the location to the south if positive,
north if negative;
-<p>
-<b>xoffset</b>,
+<p><b>xoffset</b>,
which shifts the text a horizontal distance in points from
the specified east The horizontal offset will shift the location east if
positive, west if negative;
-<p>
-<b>opaque</b>,
+<p><b>opaque</b>,
whether or not the text should be <b>opaque</b> to vectors. Entering <b>no</b>
to the opaque option will allow the user to see any vectors which go
through the text's background box. Otherwise, they will end at the box's edge.
-<p>
-<br>
+<p><br>
The following example would place the text <em>SPEARFISH LAND COVER</em>
at the coordinates E650000 N7365000. The text would be a total of
3 points wide (2 pixels of red text and 1 pixel black highlight), have a white
@@ -1284,7 +1195,6 @@
</pre>
<p>
<a name="vareas"></a>
<h2>vareas</h2>
@@ -1307,35 +1217,25 @@
<b>end</b>
</pre>
The user can specify:
-<p>
-<b>color</b> - color of the vector lines or area boundaries;
-<p>
-<b>fcolor</b> - the area fill color;
-<p>
-<b>rgbcolumn</b> - name of color definition column used for the area fill color;
-<p>
-<b>width</b> - width of the vectors lines or area boundaries in points
+<p><b>color</b> - color of the vector lines or area boundaries;
+<p><b>fcolor</b> - the area fill color;
+<p><b>rgbcolumn</b> - name of color definition column used for the area fill color;
+<p><b>width</b> - width of the vectors lines or area boundaries in points
-<p>
-<b>masked</b> - whether or not the raster map layer is to be masked
+<p><b>masked</b> - whether or not the raster map layer is to be masked
by the current mask;
-(see manual entry <em><a href="r.mask.html">r.mask</A></em>
+(see manual entry <em><a href="r.mask.html">r.mask</a></em>
for more information on the mask)
-<p>
-<b>cats</b> - which categories should be plotted (default is all);
-<p>
-<b>where</b> - select features using a SQL where statement.
+<p><b>cats</b> - which categories should be plotted (default is all);
+<p><b>where</b> - select features using a SQL where statement.
For example: <tt>vlastnik = 'Cimrman'</tt>;
-<p>
-<b>label</b> - for description in <a href="#vlegend">vlegend</a>.
+<p><b>label</b> - for description in <a href="#vlegend">vlegend</a>.
Default is: map(mapset);
-<p>
-<b>lpos</b> - position vector is plotted in legend. If lpos is
+<p><b>lpos</b> - position vector is plotted in legend. If lpos is
0 then this vector is omitted in legend. If more vectors used the
same lpos then their symbols in legend are merged and label for
first vector is used.
-<p>
-<b>pat</b> - full path to pattern file. The pattern file contains header and
+<p><b>pat</b> - full path to pattern file. The pattern file contains header and
simple PostScript commands. It is similar to EPS but more limited, meaning that
while each pattern file is a true EPS file, most EPS files are not useful as pattern
files because they contain restricted commands. Color <!-- and width --> of patterns
@@ -1360,13 +1260,10 @@
</pre></div>
-<p>
-<b>scale</b> - pattern scale
-<p>
-<b>pwidth</b> - pattern line width, width is used by pattern until the width is overwritten
+<p><b>scale</b> - pattern scale
+<p><b>pwidth</b> - pattern line width, width is used by pattern until the width is overwritten
in pattern file.
<p>
<pre>
EXAMPLE:
<b>vareas</b> forest
@@ -1378,7 +1275,6 @@
</pre>
<p>
<a name="vlines"></a>
<h2>vlines</h2>
@@ -1406,41 +1302,29 @@
<b>end</b>
</pre>
-<p>
-<b>type</b> - the default is lines only;
-<p>
-<p>
-<b>rgbcolumn</b> - name of color definition column used for the vector lines
+<p><b>type</b> - the default is lines only;
+<p><b>rgbcolumn</b> - name of color definition column used for the vector lines
or area boundaries;
-<p>
-<p>
-<b>cwidth</b> - width of the vectors lines. If cwidth is used then
+<p><b>cwidth</b> - width of the vectors lines. If cwidth is used then
width of line is equal to cwidth * category value and width is
used in legend;
-<p>
-<b>hcolor</b> - the highlight color for the vector lines;
-<p>
-<b>hwidth</b> - the width of the highlight color in points;
-<p>
-<b>offset</b> (experimental) - offset for the vectors lines in points (1/72")
+<p><b>hcolor</b> - the highlight color for the vector lines;
+<p><b>hwidth</b> - the width of the highlight color in points;
+<p><b>offset</b> (experimental) - offset for the vectors lines in points (1/72")
for plotting parallel lines in distance equal to offset (accepts positive or
negative decimal points). Useful to print streets with several parallel lanes;
-<p>
-<b>coffset</b> (experimental) - offset for the vectors lines. If coffset
+<p><b>coffset</b> (experimental) - offset for the vectors lines. If coffset
is used then offset of line is equal to coffset * category value and offset
is used in legend;
-<p>
-<b>ref</b> (experimental) - line justification.
-<p>
+<p><b>ref</b> (experimental) - line justification.
for more information on the mask);
-<p>
-<b>style</b> - the line style allows the vectors to be dashed in different
+<p><b>style</b> - the line style allows the vectors to be dashed in different
patterns. This is done by either typing "solid", "dashed", "dotted", or
"dashdotted", or as a series of 0's and 1's in a desired sequence or pattern.
The first block of repeated zeros or ones represents "draw", the second
@@ -1448,25 +1332,20 @@
An even number of blocks will repeat the pattern, an odd number of blocks
will alternate the pattern.
The default is "solid";
-<p>
-<b>linecap</b> - the linecap specifies the look of the ends of the line,
+<p><b>linecap</b> - the linecap specifies the look of the ends of the line,
or the end of the dashes in a dashed line. The parameters are:
'butt' for butt caps (default), 'round' for round caps and 'extended_butt'
for extended butt caps. The shape of the round and the extended butt caps
is related to the line thickness: for round butts the radius is half the
linewidth, while for extended butt the line will extend for half the linewidth.
-<p>
-<p>
-<p>
<p>
<pre>
EXAMPLE:
<b>vlines</b> streams
@@ -1481,7 +1360,6 @@
</pre>
<p>
<a name="vpoints"></a>
<h2>vpoints</h2>
@@ -1532,7 +1410,6 @@
<b>end</b>
</pre>
<p>
<a name="vlegend"></a>
<h2>vlegend</h2>
@@ -1555,30 +1432,23 @@
If the <em>where</em> instruction is present and <em>y</em> is less than or
equal to zero, the vector legend will be positioned immediately below
the map, starting <em>x</em> inches from the left edge of the page.
-<p>
-<em>width</em> is the width in inches of the color symbol (for lines)
+<p><em>width</em> is the width in inches of the color symbol (for lines)
in front of the legend text. The default is 1/24 * fontsize inches.
-<p>
-<em>cols</em> is the number of columns to split the legend into. The
+<p><em>cols</em> is the number of columns to split the legend into. The
default is one column. The maximum number of colums is 10, or equal
to the number of legend entries if there are less than 10 entries.
-<p>
-<em>span</em> is the column separation distance between the left edges of
+<p><em>span</em> is the column separation distance between the left edges of
two columns in a multicolumn legend. It is given in inches.
The default is automatic scaling based on the left margin and the right
hand side of the map box.
-<p>
-<p>
-Alternatively, the user can create a custom legend by using the
+<p>Alternatively, the user can create a custom legend by using the
<a href="#rectangle">rectangle</a>, <a href="#point">point</a>, and
<a href="#text">text</a> instructions.
-<p>
-See also the <a href="#colortable">colortable</a> command for creating
+<p>See also the <a href="#colortable">colortable</a> command for creating
raster map legends.
-<p>
-This example prints the vector legend
+<p>This example prints the vector legend
immediately below the map and starting 4.5 inches from the left edge
of the page, using a 12/72 inch Helvetica font.
@@ -1592,7 +1462,6 @@
</pre>
<p>
<a name="end"></a>
<h2>end</h2>
@@ -1604,13 +1473,11 @@
<br>
<p>
<h2>EXAMPLES</h2>
The following are examples of <em>ps.map</em> script files.
-<p>
-<h3>Simple example</h3>
+<p><h3>Simple example</h3>
The file has been named <em>spear.basic</em>:
<pre>
@@ -1713,21 +1580,19 @@
ps.map input=spear.soils output=soils.ps
</pre></div>
-<p>
-More examples can be found on the
+<p>More examples can be found on the
<a href="http://grass.osgeo.org/wiki/Ps.map_scripts">GRASS Wiki</a>
help site.
<p>
<h2>CHANGES BETWEEN VERSION 5.0.x/5.4.x and 6.0</h2>
<UL>
-<LI>Devices and ps.select do not exist any more. Paper is defined by the
+<li>Devices and ps.select do not exist any more. Paper is defined by the
<em>paper</em> instruction.</LI>
-<LI><em>vpoints</em> are used instead of <em>sites</em> (points are read from vector).</LI>
-<LI><em>vector</em> is substituted by <em>vpoints</em>, <em>vlines</em> and <em>vareas</em>.</LI>
-<LI>Symbols are used instead of icons (different format and directory).</LI>
-<LI>Map legend can be printed in columns.</LI>
+<li><em>vpoints</em> are used instead of <em>sites</em> (points are read from vector).</LI>
+<li><em>vector</em> is substituted by <em>vpoints</em>, <em>vlines</em> and <em>vareas</em>.</LI>
+<li>Symbols are used instead of icons (different format and directory).</LI>
+<li>Map legend can be printed in columns.</LI>
</UL>
@@ -1741,5 +1606,4 @@
Paul Carlson, USDA, SCS, NHQ-CGIS<br>
Modifications: Radim Blazek, Glynn Clements, Bob Covill, Hamish Bowman
-<p>
Modified: grass/trunk/raster/r.basins.fill/r.basins.fill.html
--- grass/trunk/raster/r.basins.fill/r.basins.fill.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.basins.fill/r.basins.fill.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<h2>DESCRIPTION</h2>
<em>r.basins.fill</em>
generates a raster map layer depicting subbasins, based
on input raster map layers for the coded stream network
@@ -15,7 +14,6 @@
(for example, through digitizing done in <em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector digitizer</a></em>).
<p>
The resulting output raster map layer will
code the subbasins with category values matching
those of the channel segments passing through them.
@@ -53,5 +51,4 @@
<br>
Larry Band, Dept. of Geography, University of Toronto, Canada
-<p>
Modified: grass/trunk/raster/r.bitpattern/r.bitpattern.html
--- grass/trunk/raster/r.bitpattern/r.bitpattern.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.bitpattern/r.bitpattern.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.bitpattern</em> performs bit pattern comparisons.
The module can be used to pixelwise verify a satellite image
for low quality pixels if a Quality Control Bit Index map is
Modified: grass/trunk/raster/r.buffer/r.buffer2.html
--- grass/trunk/raster/r.buffer/r.buffer2.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.buffer/r.buffer2.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -41,7 +41,6 @@
units</em> parameter: <em>meters, kilometers, feet, miles</em>, and <em>nautmiles</em>
(nautical miles).
<p>
<!-- ??? is this the real method used or some ancient option ??? -->
Distances from cells containing the user-specified category values
are calculated using the "fromcell" method. This method locates each
@@ -52,13 +51,11 @@
slowly when there are numerous cells containing the
category values of interest spread throughout the area.
<p>
<em>r.buffer</em> measures distances from center of cell to
center of cell using Euclidean distance measure for
planimetric locations (like UTM) and using ellipsoidal
geodesic distance measure for latitude/longitude locations.
<p>
<em>r.buffer</em> calculates distance zones from all cells having non-NULL
category values in the <em>input</em> map. If the user wishes to calculate
distances from only selected <em>input</em> map layer
@@ -67,11 +64,9 @@
<em>r.buffer</em>, to reclass all categories from which distance zones
are not desired to be calculated into category NULL.
<p>
The <b>-z</b> flag can be used to ignore raster values of zero instead of NULL
values in the input raster map.
<p>
<h2>EXAMPLE</h2>
In the following example, the buffer zones would be (in the default units
@@ -113,5 +108,4 @@
James Westervelt, U.S. Army Construction Engineering
Research Laboratory
-<p>
Modified: grass/trunk/raster/r.category/r.category.html
--- grass/trunk/raster/r.category/r.category.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.category/r.category.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,12 +1,10 @@
<em>r.category</em> prints the category values and labels for the raster map
layer specified by <b>map=</b><em>name</em> to standard output. You can also
use it to set category labels for a raster map.
<p>
The user can specify all needed parameters on the command line, and run the
program non-interactively. If the user does not specify any categories
(e.g., using the optional <b>cats=</b><em>range</em>[,<em>range</em>,...]
@@ -24,7 +22,6 @@
separate these fields in the output, by default.
<p>
The output is sent to standard output in the form of one category per line,
with the category value first on the line, then an ASCII TAB character (or
whatever single character or space is specified using the <b>fs</b>
@@ -34,8 +31,7 @@
<h2>NOTES</h2>
Any ASCII TAB characters which may be in the label are replaced by spaces.
-<p>
-The output from <em>r.category</em> can be redirected into a file, or piped into
+<p>The output from <em>r.category</em> can be redirected into a file, or piped into
another program.
<h3>Input from a file</h3>
@@ -71,34 +67,26 @@
or
15:30 label description
</pre>
-<p>
-In the format line
+<p>In the format line
<ul>
<li>$1 refers to the value num*5.0+1000 (ie, using the first 2 coefficients)
<li>$2 refers to the value num*5.0+1005 (ie, using the last 2 coefficients)
</ul>
$1.2 will print $1 with 2 decimal places.
-<p>
-Also, the form $?xxx$yyy$ translates into yyy if the category is 1, xxx
+<p>Also, the form $?xxx$yyy$ translates into yyy if the category is 1, xxx
otherwise. The $yyy$ is optional. Thus
-<p>
- $1 meter$?s
-<p>
-will become: 1 meter (for category 1)<br>
+<p> $1 meter$?s
+<p>will become: 1 meter (for category 1)<br>
2 meters (for category 2), etc.
-<p>
-format='Elevation: $1.2 to $2.2 feet' ## Format Statement
+<p>format='Elevation: $1.2 to $2.2 feet' ## Format Statement
coefficients="5.0,1000,5.0,1005" ## Coefficients
-<p>
-The format and coefficients above would be used to generate the
+<p>The format and coefficients above would be used to generate the
following statement in creation of the format appropriate category
string for category "num":
-<p>
- sprintf(buff,"Elevation: %.2f to %.2f feet", num*5.0+1000, num*5.0*1005)
+<p> sprintf(buff,"Elevation: %.2f to %.2f feet", num*5.0+1000, num*5.0*1005)
-<p>
-Note: while both the format and coefficent lines must be present
+<p>Note: while both the format and coefficent lines must be present
a blank line for the format string will effectively suppress
automatic label generation.
@@ -108,18 +96,15 @@
know that i-th rule maps fp range to i, thus we know for sure
that cats.labels[i] corresponds to i-th quant rule
-<p>
-To use a "<tt>$</tt>" in the label without triggering the plural test,
+<p>To use a "<tt>$</tt>" in the label without triggering the plural test,
put "<tt>$$</tt>" in the format string.
-<p>
-Use 'single quotes' when using a "<tt>$</tt>" on the command line to
+<p>Use 'single quotes' when using a "<tt>$</tt>" on the command line to
avoid unwanted shell substitution.
<h2>EXAMPLES</h2>
-<p>
-<dl>
+<p><dl>
<dt><span class="code"><tt>
r.category map=soils
</tt></span>
@@ -147,8 +132,7 @@
<dl>
<dt>Example output:
<dd>
-<p>
-<div class="code"><pre>
+<p><div class="code"><pre>
10:Dumps, mine, Cc
20:Kyle clay, KaA
</pre></div>
@@ -162,8 +146,7 @@
2:potential presence
EOF
</pre></div>
-<p>
-sets the categoy values 1 and 2 to respective text labels.
+<p>sets the categoy values 1 and 2 to respective text labels.
</dl>
<h2>TODO</h2>
@@ -175,8 +158,7 @@
UNIX Manual entries for <i>awk</i> and <i>sort</i>
-<p>
-<em><a href="r.coin.html">r.coin</a></em>,
+<p><em><a href="r.coin.html">r.coin</a></em>,
<em><a href="r.describe.html">r.describe</a></em>,
<em><a href="d.what.rast.html">d.what.rast</a></em>,
<em><a href="r.support.html">r.support</a></em>
@@ -186,5 +168,4 @@
Michael Shapiro, U.S. Army Construction Engineering Research Laboratory<br>
Hamish Bowman, University of Otago, New Zealand (label creation options)
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.circle/r.circle.html
--- grass/trunk/raster/r.circle/r.circle.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.circle/r.circle.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,12 +5,10 @@
The output cell values increase linearly from the specified center. The <em>min</em>
and <em>max</em> parameters control the inner and outer output raster map radii, respectively.
-<p>
-The <em>mult</em> parameter can be used to multiply the output raster cells by a common factor.
+<p>The <em>mult</em> parameter can be used to multiply the output raster cells by a common factor.
Note that this parameter does not affect the output raster position or size; only the z-values
are changed with this parameter.
-<p>
-Binary-output raster maps (solid circles of one value) can be created
+<p>Binary-output raster maps (solid circles of one value) can be created
with the <b>-b</b> flag. Raster maps so created can be used to create
binary filters for use in <em>i.ifft</em> (inverse Fourier transformations;
apply filter with <em>r.mask</em>).
@@ -52,5 +50,4 @@
Bill Brown, U.S. Army Construction Engineering Research Laboratory<br>
Additional flag/min/max parameter by Markus Neteler, University of Hannover
-<p>
Modified: grass/trunk/raster/r.clump/r.clump.html
--- grass/trunk/raster/r.clump/r.clump.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.clump/r.clump.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,7 +17,6 @@
The lower right-hand corner of the matrix is grouped with the cells above it,
or to the left of it (diagonal cells are not considered.)
<p>
<em>r.clump</em> works properly with raster map layers that
contain only "fat" areas (more than a single cell in
width). Linear elements (lines that are a single cell
Modified: grass/trunk/raster/r.coin/r.coin.html
--- grass/trunk/raster/r.coin/r.coin.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.coin/r.coin.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,7 +6,6 @@
region and mask settings.
<p>
<em>r.coin</em>
tabulates the coincidence of category values among the two
map layers and prepares the basic table from which the
@@ -20,7 +19,6 @@
These units are:
<p>
<dl>
<dt><em>c</em> <dd>cells
<dt><em>p</em> <dd>percent cover of region
@@ -33,7 +31,6 @@
</dl>
<p>
Note that three of these options give results as percentage
values: "p" is based on the grand total number of cells;
"x" is based on only column totals; and "y" is based on
@@ -49,7 +46,6 @@
using a different unit of measurement.
<p>
<h2>NOTES</h2>
It is <b>not</b> a good idea to run <em>r.coin</em> on a
@@ -61,7 +57,6 @@
<em>r.coin</em> on the reclassed raster map layer.
<p>
<h2>EXAMPLE</h2>
Below is a sample of tabular output produced by
@@ -82,7 +77,6 @@
to obtain this information.
<p>
The body of the report is arranged in panels. The map layer
with the most categories is arranged along the vertical
axis of the table; the other, along the horizontal axis.
@@ -97,26 +91,21 @@
of all columns for each row appears in a separate panel.
<p>
Note how the following information may be obtained from the sample report.
<p>
In the Spearfish data base, in area not owned by the Forest Service, there
are 50.63 square miles of land not used for roads. Roads make up 9.27 square
miles of land in this area.
-<p>
-Of the total 102.70 square miles in Spearfish, 42.80
+<p>Of the total 102.70 square miles in Spearfish, 42.80
square miles is owned by the Forest Service.
<br>
In total, there are 14.58 square miles of roads.
-<p>
-There are more category 2 roads outside Forest Service land
+<p>There are more category 2 roads outside Forest Service land
(2.92 mi. sq.)
than there are inside Forest land boundaries (0.72 mi. sq.).
-<p>
-Following is a sample report.
+<p>Following is a sample report.
<pre>
@@ -173,7 +162,6 @@
</pre>
<p>
<em>r.coin</em> calculates the coincidence of two raster
map layers. Although <em>r.coin</em> allows the user to
rerun the report using different units, it is not possible
@@ -200,5 +188,4 @@
Michael Shapiro, <br>
-<p>
Modified: grass/trunk/raster/r.colors/r.colors.html
--- grass/trunk/raster/r.colors/r.colors.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.colors/r.colors.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,21 +4,17 @@
table for a raster map. The raster map (specified on the command line
by <b>map</b>) must exist in the user's current mapset search path.
-<p>
-The <b>rast</b> option allows user to specify a raster map <i>name</i>
+<p>The <b>rast</b> option allows user to specify a raster map <i>name</i>
from which to copy the color map.
-<p>
-The <b>volume</b> option allows user to specify a volume (3d raster)
+<p>The <b>volume</b> option allows user to specify a volume (3d raster)
map <i>name</i> from which to copy the color map.
-<p>
-All color tables are stored in <tt>$GISBASE/etc/colors/</tt>. Further
+<p>All color tables are stored in <tt>$GISBASE/etc/colors/</tt>. Further
user-defined color tables can also be stored in this directory for
access from the <em>color</em> parameter.
-<p>
-The <b>-e</b> flag equalizes the original raster's color table. It can
+<p>The <b>-e</b> flag equalizes the original raster's color table. It can
preclude the need for <em>grey.eq</em> rule, when used as
<b>-e color=</b><em>grey</em>. Note however, that this will not yield
a color table identical to <em>color=grey.eq</em>,
@@ -29,8 +25,7 @@
used. <b>-e</b> is designed to work with any color table, both the
floating point and the integer raster maps.
-<p>
-The <b>-g</b> flag divides the raster's grey value range into 100
+<p>The <b>-g</b> flag divides the raster's grey value range into 100
logarithmically equal steps (where "step" is a rule with the
same grey level for the start and end points). It can preclude the
need for <em>grey.log</em> rule, when used as <b>-g
@@ -43,26 +38,22 @@
case when the value range includes zero, there's no realistic
solution.
-<p>
-The <b>-e</b> and <b>-g</b> flags are not mutually exclusive.
+<p>The <b>-e</b> and <b>-g</b> flags are not mutually exclusive.
-<p>
-If the user specifies the <b>-w</b> flag, the current color table file for
+<p>If the user specifies the <b>-w</b> flag, the current color table file for
the input map will not be overwritten. This means that the color table is
created only if the <i>map</i> does not already have a color table. If this
option is not specified, the color table will be created if one does not
exist, or modified if it does.
-<p>
-<p>Color table types <i>aspect, grey, grey.eq</i> (histogram-equalized
+<p><p>Color table types <i>aspect, grey, grey.eq</i> (histogram-equalized
grey scale), <i>byg</i> (blue-yellow-green), <i>byr</i>
(blue-yellow-red), <i>gyr</i> (green-yellow-red), <i>rainbow, ramp,
ryg</i> (red-yellow-green), <i>random</i>, and <i>wave</i> are
pre-defined color tables that <em>r.colors</em> knows how to create
without any further input.
-<p>
-In general, tables which associate colors with percentages (aspect, bcyr, byg,
+<p>In general, tables which associate colors with percentages (aspect, bcyr, byg,
byr, elevation, grey, gyr, rainbow, ramp, ryb, ryg and wave) can be applied to
any data, while those which use absolute values (aspectcolr, curvature, etopo2,
evi, ndvi, population, slope, srtm, and terrain) only make sense for data with
@@ -83,13 +74,11 @@
90 0:0:0
</pre></div>
-<p>
-This is designed for the slope map generated
+<p>This is designed for the slope map generated
by <em><a href="r.slope.aspect.html">r.slope.aspect</a></em>, where the
value is a slope angle between 0 and 90 degrees.
-<p>
-Similarly, the <em>aspectcolr</em> rule:
+<p>Similarly, the <em>aspectcolr</em> rule:
0 white
@@ -100,31 +89,26 @@
360 yellow
</pre></div>
-<p>
-is designed for the aspect maps produced
+<p>is designed for the aspect maps produced
value is a heading between 0 and 360 degrees.
-<p>
-The <b>rules</b> color table type will cause <i>r.colors</i> to read
+<p>The <b>rules</b> color table type will cause <i>r.colors</i> to read
color table specifications from standard input (stdin) and will build
the color table accordingly.
-<p>
-Using color table type <b>rules</b>, there are <!--three-->two ways to
+<p>Using color table type <b>rules</b>, there are <!--three-->two ways to
build a color table: <!--by color list,--> by category values and by
"percent" values.
<!-- HB: this causes an error in current code, maybe easy to enable functionality from old code??
-<p>
-Building a customized color table by color list is the simplest of the three
+<p>Building a customized color table by color list is the simplest of the three
rules methods: just list the colors you wish to appear in the color table in the
order that you wish them to appear. Use the standard GRASS color names: white,
black, red, green, blue, yellow, magenta, cyan, aqua, grey, gray, orange, brown,
purple, violet, and indigo.
-<p>
-For example, to create a color table for the raster map layer <i>elevation</i>
+<p>For example, to create a color table for the raster map layer <i>elevation</i>
that assigns greens to low map category values, browns to the next larger
map category values, and yellows to the still larger map category values,
one would type:
@@ -137,8 +121,7 @@
end
</pre></div>
-<p>
-To build a color table by category values' indices, the user should
+<p>To build a color table by category values' indices, the user should
determine the range of category values in the raster map with which
the color table will be used. Specific category values will then be
associated with specific colors. Note that a color does not have to be
@@ -155,14 +138,12 @@
end
</pre></div>
-<p>
-Each category value must be valid for the raster map, category values
+<p>Each category value must be valid for the raster map, category values
must be in ascending order and only use standard GRASS color names
(aqua, black, blue, brown, cyan, gray, green, grey, indigo, magenta,
orange, purple, red, violet, white, yellow).
-<p>
-Colors can also be specified by color numbers each in the range
+<p>Colors can also be specified by color numbers each in the range
0-255. The format of a category value color table specification using
color numbers instead of color names is as follows:
@@ -175,8 +156,7 @@
end
</pre></div>
-<p>
-Specifying a color table by "percent" values allows one to
+<p>Specifying a color table by "percent" values allows one to
treat a color table as if it were numbered from 0 to 100. The format
of a "percent" value color table specification is the same
as for a category value color specification, except that the category
@@ -192,8 +172,7 @@
end
</pre></div>
-<p>
-Using "percent" value color table specification rules,
+<p>Using "percent" value color table specification rules,
colors can also be specified by color numbers each in the range
0-255. The format of a percent value color table specification using
@@ -207,8 +186,7 @@
end
</pre></div>
-<p>
-Note that you can also mix these <!--three-->two methods of color
+<p>Note that you can also mix these <!--three-->two methods of color
table specification; for example:
@@ -221,8 +199,7 @@
end
</pre></div>
-<p>
-To set the NULL (no data) color, use the "nv" parameter:
+<p>To set the NULL (no data) color, use the "nv" parameter:
0 black
@@ -231,8 +208,7 @@
end
</pre></div>
-<p>
-To set the color to used for undefined values (beyond the range of the
+<p>To set the color to used for undefined values (beyond the range of the
color rules) use the "default" parameter:
@@ -258,8 +234,7 @@
end
</pre></div>
-<p>
-The color table can then by assigned to map <i>threecats</i> by the
+<p>The color table can then by assigned to map <i>threecats</i> by the
following GRASS commands (two ways are available):
@@ -270,8 +245,7 @@
r.colors map=threecats rules=rules.file
</pre></div>
-<p>
-To create a natural looking lookup table (LUT) for true map layer
+<p>To create a natural looking lookup table (LUT) for true map layer
<i>elevation</i>, use the following rules specification file. It will
assign light green shades to the lower elevations (first 20% of the
LUT), and then darker greens (next 15%, and next 20%) and light browns
@@ -289,8 +263,7 @@
100% 255:255:100
</pre></div>
-<p>
-To invert the current rules:
+<p>To invert the current rules:
r.colors map=current_raster -n rast=current_raster
</pre></div>
@@ -311,13 +284,11 @@
<a href="r3.colors.out.html">r3.colors.out</a>
</em>
-<p>
-See also wiki
+<p>See also wiki
page <a href="http://grass.osgeo.org/wiki/Color_tables">Color
tables</a> (from GRASS User Wiki)
-<p>
-<a href="http://colorbrewer.org">ColorBrewer</a> is an online tool designed to
+<p><a href="http://colorbrewer.org">ColorBrewer</a> is an online tool designed to
help people select good color schemes for maps and other graphics.
@@ -325,5 +296,4 @@
Michael Shapiro and David Johnson<br>
Support for 3D rasters by Soeren Gebbert
-<p>
Modified: grass/trunk/raster/r.colors/r3.colors.html
--- grass/trunk/raster/r.colors/r3.colors.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.colors/r3.colors.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,5 +20,4 @@
<br>
-<p>
Modified: grass/trunk/raster/r.colors.out/r.colors.out.html
--- grass/trunk/raster/r.colors.out/r.colors.out.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.colors.out/r.colors.out.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,5 +20,4 @@
<h2>AUTHOR</h2>
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.colors.out/r3.colors.out.html
--- grass/trunk/raster/r.colors.out/r3.colors.out.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.colors.out/r3.colors.out.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -21,5 +21,4 @@
<h2>AUTHOR</h2>
Glynn Clements
-<p>
-<i>Last changed: $Date: 2010-11-01 08:41:16 +0100 (Mo, 01. Nov 2010) $</i>
+<p><i>Last changed: $Date: 2010-11-01 08:41:16 +0100 (Mo, 01. Nov 2010) $</i>
Modified: grass/trunk/raster/r.composite/r.composite.html
--- grass/trunk/raster/r.composite/r.composite.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.composite/r.composite.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,8 +15,7 @@
resulting layer with <em><a href="d.rast.html">d.rast</a></em> will
also be significantly slower.
-<p>
-Floyd-Steinberg dithering is optionally used with the <b>-d</b> flag.
+<p>Floyd-Steinberg dithering is optionally used with the <b>-d</b> flag.
<h2>EXAMPLE</h2>
Creating a composite RGB raster using 32 color levels per layer, with dithering:
@@ -33,8 +32,7 @@
<a href="r.blend.html">r.blend</a>,
<a href="r.colors.html">r.colors</a>
</em>
-<p>
-<em>
+<p><em>
<a href="http://en.wikipedia.org/wiki/Floyd-Steinberg_dithering">Wikipedia Entry: Floyd-Steinberg dithering</a>
</em>
Modified: grass/trunk/raster/r.compress/r.compress.html
--- grass/trunk/raster/r.compress/r.compress.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.compress/r.compress.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,7 +4,6 @@
raster map layers.
<p>
During compression, this program reformats raster maps
using a run-length-encoding (RLE) algorithm. Raster map
layers which contain very little information (such as
@@ -21,14 +20,12 @@
of whichever raster data format consumes less space.
<p>
As an example, the Spearfish data base raster map layer
<em>owner</em> was originally a size of 26600 bytes. After
it was compressed, the raster map became only 1249 bytes
(25351 bytes smaller).
<p>
Raster files may be decompressed to return them to their
original format, using the <b>-u</b> flag of
<em>r.compress</em>. If <em>r.compress</em> is asked to
@@ -59,7 +56,6 @@
3 (or more) bytes per cell.
<p>
The <b>decompressed</b> raster map format matches the
conceptual format. For example, a raster map with 1 byte
cells that is 100 rows with 200 cells per row, consists of
@@ -76,7 +72,6 @@
is broken up into rows of category values.
<p>
The <b>compressed</b> format is not so simple, but is quite
elegant in its design. It not only requires less disk space
to store the raster data, but often can result in faster
@@ -93,14 +88,12 @@
the raster data as compressed.
<p>
Address array (long) - array (size of the number of rows +
1) of addresses pointing to the internal start of each row.
Because each row may be a different size, this array is
necessary to provide a mapping of the data.
<p>
Row by row, beginning at the northern edge of the data, a
series of byte groups describes the data. The number of
bytes in each group is the number of bytes per cell plus
@@ -114,11 +107,9 @@
Instead, a field in the cell header is used to indicate compressed format.
<p>
The address array is the same.
<p>
The RLE format is the same as the pre-3.0 RLE, except that
each row of data is preceded by a single byte containing
the number of bytes per cell for the row, and if
@@ -126,7 +117,6 @@
than non-run-length-encoding, then the row is not encoded.
<p>
These improvements give better compression than the pre-3.0
format in 99% of the raster data layers. The kinds of
raster data layers which get bigger are those in which each
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.cost/r.cost.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -23,8 +23,7 @@
resultant raster map of cumulative cost. The <b>outdir</b> <em>name</em> is the
name of the resultant raster map of movement directions (see <a href="#move">Movement Direction</a>).
-<p>
-<em>r.cost</em> can be run with three different methods of identifying the
+<p><em>r.cost</em> can be run with three different methods of identifying the
starting point(s). One or more points (geographic coordinate pairs) can be
provided as specified <b>coordinate</b>s on the command line, from a vector
points file, or from a raster map.
@@ -35,8 +34,7 @@
desired can be entered by the user. These starting points can also be read
from a vector points file through the <b>start_points</b> option or from a
raster map through the <b>start_rast</b> option.
-<p>
-<em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
+<p><em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
or one of the stop points given with <b>stop_coordinates</b> is reached.
Alternatively, the stop points can be read from a vector points file with the
<b>stop_points</b> option. During execution, once the cumulative cost to all
@@ -46,8 +44,7 @@
will be processed.
-<p>
-The null cells in the <b>input</b> map can be assigned a (positive floating
+<p>The null cells in the <b>input</b> map can be assigned a (positive floating
point) cost with the <b>null_cost</b> option.
<br>
When input map null cells are given a cost with the <b>null_cost</b>
@@ -55,12 +52,10 @@
cells. By using the <b>-n</b> flag, the null cells of the input map are
retained as null cells in the output map.
-<p>
-As <em>r.cost</em> can run for a very long time, it can be useful to
+<p>As <em>r.cost</em> can run for a very long time, it can be useful to
use the <b>-v</b> verbose flag to track progress.
-<p>
-The Knight's move (<b>-k</b> flag) may be used to improve the accuracy of
+<p>The Knight's move (<b>-k</b> flag) may be used to improve the accuracy of
the output. In the diagram below, the center location (<tt>O</tt>) represents a
grid cell from which cumulative distances are calculated. Those
neighbors marked with an <tt>X</tt> are always considered for cumulative cost
@@ -98,8 +93,7 @@
<p>By default null cells in the input raster map are excluded from
the algorithm, and thus retained in the output map.
-<p>
-If one wants <b>r.cost</b> to transparently cross any region of null cells,
+<p>If one wants <b>r.cost</b> to transparently cross any region of null cells,
the <b>null_cost</b>=<tt>0.0</tt> option should be used. Then null cells just
propagate the adjacent costs. These cells can be retained as null cells in the
output map by using the <b>-n</b> flag.
@@ -135,14 +129,12 @@
of selecting the lowest cumulative cost cell, computing costs to the
neighbors, putting the neighbors on the list and removing the
originating cell from the list continues until the list is empty.
-<p>
-The most time consuming aspect of this algorithm is the management of
+<p>The most time consuming aspect of this algorithm is the management of
the list of cells for which cumulative costs have been at least
initially computed. <em>r.cost</em> uses a binary tree with an linked list
at each node in the tree for efficiently holding cells with identical
cumulative costs.
-<p>
-<em>r.cost</em>, like most all GRASS raster programs, is also made to be run on
+<p><em>r.cost</em>, like most all GRASS raster programs, is also made to be run on
maps larger that can fit in available computer memory. As the
algorithm works through the dynamic list of cells it can move almost
randomly around the entire area. <em>r.cost</em> divides the entire area
@@ -193,8 +185,7 @@
</pre></div>
-<p>
-<!-- ??? are "starting" and "ending" swapped in the following text ??? -->
+<p><!-- ??? are "starting" and "ending" swapped in the following text ??? -->
The user-provided ending location in the above example is the boxed <b>3</b>
in the above input map. The costs in the output map represent the total
cost of moving from each box ("cell") to one or more (here,
@@ -233,8 +224,7 @@
<a name="move"></a>
<h2>Movement Direction</h2>
-<p>
-The movement direction surface is created to record the sequence of
+<p>The movement direction surface is created to record the sequence of
movements that created the cost accumulation surface. Without it
<em>r.drain</em> would not correctly create a path from an end point
back to the start point. The direction shown in each cell points <b>away</b>
@@ -246,8 +236,7 @@
202.5 225 270 315 337.5
247.5 292.5
</pre></div>
-<p>
-Once <em>r.cost</em> computes the cumulative cost map, <em>r.drain</em>
+<p>Once <em>r.cost</em> computes the cumulative cost map, <em>r.drain</em>
can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
and the movement direction raster map when running r.drain to ensure
the path is computed according to the proper movement directions.
Modified: grass/trunk/raster/r.covar/r.covar.html
--- grass/trunk/raster/r.covar/r.covar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.covar/r.covar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,12 +1,10 @@
<em>r.covar</em> outputs a covariance/correlation matrix for user-specified
raster map layer(s). The output can be printed, or saved by redirecting
output into a file.
<p>
The output is an N x N symmetric covariance (correlation) matrix,
where N is the number of raster map layers specified on the command line.
@@ -20,7 +18,6 @@
N real eigen values and N eigen vectors (each composed of N real numbers).
<p>
The module <em><a href="m.eigensystem.html">m.eigensystem</a></em> in
src.contrib can be compiled and used to generate the eigen values and
vectors.
Modified: grass/trunk/raster/r.cross/r.cross.html
--- grass/trunk/raster/r.cross/r.cross.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.cross/r.cross.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,7 +14,6 @@
and the name of a raster map layer to hold program <em>output</em>.
<p>
With the <b>-z</b> flag zero data values are not crossed.
This means that if a zero category value occurs in any input data layer,
the combination is assigned to category zero in the resulting map layer,
@@ -23,13 +22,11 @@
would cause 3 categories to be generated instead of 5.
<p>
If the <b>-z</b> flag is not specified, then map layer combinations
in which not all category values are zero will be assigned
a unique category value in the resulting map layer.
<p>
Category values in the new <em>output</em> map layer will be the
cross-product of the category values from these existing <em>input</em> map
layers.
@@ -105,5 +102,4 @@
-<p>
Modified: grass/trunk/raster/r.describe/r.describe.html
--- grass/trunk/raster/r.describe/r.describe.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.describe/r.describe.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,7 +4,6 @@
a user-specified raster map layer.
<p>
<em><b>r.describe</b></em> ignores the current geographic region and mask, and
reads the full extent of the input raster map. This functionality is useful if the
user intends to <em>reclassify</em> or <em>rescale</em> the data,
@@ -13,12 +12,10 @@
also ignore the current <em>geographic region</em>
and <em>mask</em>.
-<p>
-The <em><b>nv</b></em> parameter sets the string to be used to represent <tt>NULL</tt>
+<p>The <em><b>nv</b></em> parameter sets the string to be used to represent <tt>NULL</tt>
values in the module output; the default is '*'.
-<p>
-The <em><b>nsteps</b></em> parameter sets the number of quantisation steps to divide into
+<p>The <em><b>nsteps</b></em> parameter sets the number of quantisation steps to divide into
<h2>NOTES</h2>
@@ -33,30 +30,25 @@
report will generally run faster than the full list (the default output).
<p>
The <b>-d</b> flag can be used to force <em>r.describe</em> to respect the current region
extents when repoting raster map categories. The default behavior is to read the full
-<p>
-If the <b>-1</b> flag is specified, the output appears with one category value/range per line.
+<p>If the <b>-1</b> flag is specified, the output appears with one category value/range per line.
-<p>
-The <b>-n</b> flag suppresses the reporting of <tt>NULL</tt> values.
+<p>The <b>-n</b> flag suppresses the reporting of <tt>NULL</tt> values.
<h2>EXAMPLES</h2>
The following examples are from the Spearfish60 sample Location:
<p>
# Print the full list of raster map categories:
r.describe landcover.30m
* 11 21-23 31 32 41-43 51 71 81-83 85 91 92
</pre></div>
<p>
# Print the raster range only:
r.describe -r landcover.30m
@@ -70,7 +62,6 @@
</pre></div>
<p>
# Print raster map categories, one category per line:
r.describe -1 geology
@@ -87,7 +78,6 @@
9
</pre></div>
<p>
<h2>SEE ALSO</h2>
<em>
@@ -105,5 +95,4 @@
-<p>
Modified: grass/trunk/raster/r.digit/r.digit.html
--- grass/trunk/raster/r.digit/r.digit.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.digit/r.digit.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,14 +17,12 @@
instructions is generated. It is available for use as a
mask, in analyses, and for display.
-<p>
-The <b>bgcmd</b> option is intended to be used with display (d.*) commands.
+<p>The <b>bgcmd</b> option is intended to be used with display (d.*) commands.
If several display commands are to be used to render the background
they should be separated with the semi-colon ';' character.
When run from the command line, these display commands will generally
need to be "quoted" as they will contain spaces (see examples).
-<p>
-Digitizing is done in a "polygon" method. Each area is
+<p>Digitizing is done in a "polygon" method. Each area is
circumscribed completely. Two or more overlapping areas and/or lines
might define a single part of a map. Each part of the map,
however, is assigned only the LAST area or line which
@@ -37,7 +35,6 @@
d.mon x0
</pre></div>
<p>
<h4>Digitizing an area based on a existing map; creating a new raster map</h4>
r.digit out=name_of_new_raster_map bgcmd="d.rast map=name_of_raster"
@@ -59,7 +56,6 @@
<h2>SEE ALSO</h2>
<em>
<a href="d.graph.html">d.graph</a>,
Modified: grass/trunk/raster/r.distance/r.distance.html
--- grass/trunk/raster/r.distance/r.distance.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.distance/r.distance.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,7 +6,6 @@
The cell centers are considered for the distance calculation (two
adjacent grid cells have the distance between their cell centers).
<p>
The output is an ascii list, one line per pair of objects, in the following form:
cat1:cat2:distance:east1:north1:east2:north2
@@ -33,25 +32,20 @@
<b>-l</b>
The -l flag outputs the category labels of the matched raster objects at the
beginning of the line, if they exist.
-<p>
-<b>-o</b>
+<p><b>-o</b>
The -o flag reports zero distance if the input rasters are overlapping.
<p>
<h2>NOTES</h2>
The output format lends itself to filtering. For example, to "see" lines
connecting each of the category pairs in two maps, filter the output using
awk and then into <em>d.graph</em>:
<p>
<div class="code"><pre>r.distance maps=map1,map2 | \
awk -F: '{print "move",$4,$5,"\ndraw",$6,$7}' | d.graph -m</pre></div>
-<p>
-To create a vector map of all the "map1" coordinates, filter the output into
+<p>To create a vector map of all the "map1" coordinates, filter the output into
awk and then into <em>v.in.ascii</em>:
<p>
<br>awk -F: '{print $4,$5}' | v.in.ascii format=point output=name fs=space</pre></div>
Modified: grass/trunk/raster/r.drain/r.drain.html
--- grass/trunk/raster/r.drain/r.drain.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.drain/r.drain.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.drain</em> traces a flow through a least-cost path in an elevation
model. If the <b>input</b> surface (a raster map layer) is a cumulative
cost map generated by the <em><a href="r.walk.html">r.walk</a></em> or
@@ -14,8 +13,7 @@
By default, the <b>output</b> will be an integer CELL map with <tt>1</tt>
along the least cost path, and null cells elsewhere.
-<p>
-With the <b>-c</b> (<em>copy</em>) flag, the input map cell values are
+<p>With the <b>-c</b> (<em>copy</em>) flag, the input map cell values are
copied verbatim along the path. With the <b>-a</b> (<em>accumulate</em>)
flag, the accumulated cell value from the starting point up to the current
cell is written on output. With either the <b>-c</b> or the <b>-a</b> flags, the
@@ -25,15 +23,13 @@
starting point to the final point.
The <b>-c</b>, <b>-a</b>, and <b>-n</b> flags are mutually incompatible.
-<p>
-For an elevation surface, the path is calculated by choosing the steeper
+<p>For an elevation surface, the path is calculated by choosing the steeper
"slope" between adjacent cells. The slope calculation accurately acounts
for the variable scale in lat-lon projections. For a cost surface, the path
is calculated by following the movement direction surface back to the start
point given in <em>r.walk</em> or <em>r.cost</em>.
-<p>
-The <b>coordinate</b> parameter consists of map E and N grid coordinates of
+<p>The <b>coordinate</b> parameter consists of map E and N grid coordinates of
a starting point. Each x,y pair is the easting and northing (respectively) of
a starting point from which a least-cost corridor will be developed.
The <b>vector_points</b> parameter can take multiple vector maps containing
@@ -54,7 +50,6 @@
fill in subbasins prior to processing with <em>r.drain</em>.
<p>
<em>r.drain</em> will not give sane results at the region boundary. On outer rows
and columns bordering the edge of the region, the flow direction is always directly out
of the map. In this case, the user could try adjusting the region extents slightly with
@@ -83,14 +78,12 @@
</pre></div>
<p>
The user-provided starting location in the above example is
the boxed <b>19</b> in the left-hand map. The path in the output
shows the least-cost corridor for moving from the starting
box to the lowest (smallest) possible point. This is the path a raindrop
would take in this landscape.
<p>
With the <b>-c</b> <em>(copy)</em> flag, you get the following result:
@@ -114,7 +107,6 @@
</pre></div>
<p>
With the <b>-a</b> <em>(accumulate)</em> flag, you get the following result:
@@ -136,7 +128,6 @@
</pre></div>
<p>
With the <b>-n</b> <em>(number)</em> flag, you get the following result:
@@ -170,11 +161,9 @@
</pre></div>
<p>
<h2>BUGS</h2>
-<p>
-Sometimes, when the differences among integer cell category values in the
+<p>Sometimes, when the differences among integer cell category values in the
<em><a href="r.cost.html">r.cost</a></em> cumulative cost surface output are
small, this cumulative cost output cannot accurately be used as input to
<em>r.drain</em> (<em>t.drain</em> will output bad results).
@@ -202,8 +191,7 @@
<h2>AUTHOR</h2>
Completely rewritten by Roger S. Miller, 2001
-<p>
-July 2004 at WebValley 2004, error checking and vector points added by
+<p>July 2004 at WebValley 2004, error checking and vector points added by
Matteo Franchi (Liceo Leonardo Da Vinci, Trento) and
Roberto Flor (ITC-irst, Trento, Italy)
Modified: grass/trunk/raster/r.external/r.external.html
--- grass/trunk/raster/r.external/r.external.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.external/r.external.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -30,5 +30,4 @@
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.external.out/r.external.out.html
--- grass/trunk/raster/r.external.out/r.external.out.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.external.out/r.external.out.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -39,5 +39,4 @@
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.fill.dir/r.fill.dir.html
--- grass/trunk/raster/r.fill.dir/r.fill.dir.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.fill.dir/r.fill.dir.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.fill.dir</em> filters and generates a depressionless
elevation map and a flow direction map from a given raster elevation map.
@@ -14,13 +13,11 @@
at 45 degree increments. The <i>grass</i> format gives the same category
values as the <em><a href="r.slope.aspect.html">r.slope.aspect</a></em>
program.<p>
The method adopted to filter the elevation map and rectify it is
based on the paper titled "Software Tools to Extract Structure from Digital
Elevation Data for Geographic Information System Analysis" by S.K. Jenson
and J.O. Domingue (1988).
<p>
The procedure takes an elevation layer as input and initially fills all the
depressions with one pass across the layer. Next, the flow direction
algorithm tries to find a unique direction for each cell. If the watershed
@@ -29,7 +26,6 @@
technique used by the flow direction routine. The final output will be a
depressionless elevation layer and a unique flow direction layer.
<p>
This (D8) flow algorithm performs as follows: At each raster cell the code
determines the slope to each of the 8 surrounding cells and assigns the flow
direction to the highest slope out of the cell. If there is more than one
@@ -40,14 +36,12 @@
effectively propagating flow directions from areas where the directions are
known into the area where the flow direction can't otherwise be resolved.
-<p>
-The flow direction map can be encoded in either ANSWERS (Beasley et.al,
+<p>The flow direction map can be encoded in either ANSWERS (Beasley et.al,
1982) or AGNPS (Young et.al, 1985) form, so that it can be readily used as
input to these hydrologic models. The resulting depressionless elevation
layer can further be manipulated for deriving slopes and other attributes
required by the hydrologic models.
<p>
In case of local problems, those unfilled areas can be stored optionally.
Each unfilled area in this maps is numbered. The <b>-f</b> flag
instructs the program to fill single-cell pits but otherwise to just find
@@ -59,13 +53,11 @@
partially-fixed elevation map, identify the remaining problems and fix the
problems appropriately.
<p>
<em>r.fill.dir</em> is sensitive to the current window setting. Thus
the program can be used to generate a flow direction map for any
sub-area within the full map layer. Also, <em>r.fill.dir</em> is
sensitive to any <em>mask</em> in effect.
<p>
In some cases it may be necessary to run r.fill.dir repeatedly (using output
from one run as input to the next run) before all of problem areas are
filled.
@@ -76,8 +68,7 @@
r.fill.dir input=ansi.elev elevation=ansi.fill.elev direction=ansi.asp
</pre></div>
-<p>
-will create a depressionless (sinkless) elevation map ansi.fill.elev and a flow
+<p>will create a depressionless (sinkless) elevation map ansi.fill.elev and a flow
direction map ansi.asp for the type "grass".
<h2>SEE ALSO</h2>
@@ -86,16 +77,12 @@
<a href="r.fillnulls.html">r.fillnulls</a>,
-<p>
-Beasley, D.B. and L.F. Huggins. 1982. ANSWERS (areal nonpoint source watershed environmental response simulation): User's manual. U.S. EPA-905/9-82-001, Chicago, IL, 54 p.
-<p>
-Jenson, S.K., and J.O. Domingue. 1988. Extracting topographic structure from
+<p>Beasley, D.B. and L.F. Huggins. 1982. ANSWERS (areal nonpoint source watershed environmental response simulation): User's manual. U.S. EPA-905/9-82-001, Chicago, IL, 54 p.
+<p>Jenson, S.K., and J.O. Domingue. 1988. Extracting topographic structure from
digital elevation model data for geographic information system analysis. Photogram. Engr. and Remote Sens. 54: 1593-1600.
-<p>
-Young, R.A., C.A. Onstad, D.D. Bosch and W.P. Anderson. 1985. Agricultural nonpoint surface pollution models (AGNPS) I and II model documentation. St. Paul: Minn. Pollution control Agency and Washington D.C., USDA-Agricultural Research
+<p>Young, R.A., C.A. Onstad, D.D. Bosch and W.P. Anderson. 1985. Agricultural nonpoint surface pollution models (AGNPS) I and II model documentation. St. Paul: Minn. Pollution control Agency and Washington D.C., USDA-Agricultural Research
Service.
<p>
<h2>AUTHOR</h2>
Fortran version:
Raghavan Srinivasan, Agricultural Engineering Department, Purdue
Modified: grass/trunk/raster/r.flow/r.flow.html
--- grass/trunk/raster/r.flow/r.flow.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.flow/r.flow.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,12 +12,10 @@
densities (which are equal upslope contributed areas per unit width, when
multiplied by resolution).
<p>
Aspect used for input must follow the same rules as aspect computed
in other GRASS programs (see <a href="v.surf.rst.html">v.surf.rst</a>
or <a href="r.slope.aspect.html">r.slope.aspect</a>).
<p>
Flowline output is given in a vector map <b>flowline</b>, (flowlines generated
downhill). The line segments of flowline vectors have endpoints on edges
of a grid formed by drawing imaginary lines through the centers of the
@@ -31,7 +29,6 @@
A high <b>skip</b> usually speeds up processing time and often improves
the readability of a visualization of <b>flowline</b>.
<p>
Flowpath length output is given in a raster map <b>flowlength</b>. The value
in each grid cell is the sum of the planar lengths of all segments of the
flowline generated from that cell. If the flag <b>-3</b> is given, elevation
@@ -115,7 +112,6 @@
<h3><b>Differences between <em>r.flow</em> and <em>r.flowmd</em></b></h3>
<p>
<ol>
<li> <em>r.flow</em> has an option to compute slope and aspect internally thus making
Modified: grass/trunk/raster/r.grow/r.grow.html
--- grass/trunk/raster/r.grow/r.grow.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.grow/r.grow.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.grow</em> adds cells around the perimeters of all areas
in a user-specified raster map layer and stores the output in
a new raster map layer. The user can use it to grow by one or
@@ -17,7 +16,6 @@
<i>Maximum</i>.
<p>
The <i>Euclidean distance</i> or <i>Euclidean metric</i> is the "ordinary" distance
between two points that one would measure with a ruler, which can be
proven by repeated application of the Pythagorean theorem.
@@ -28,8 +26,7 @@
Cells grown using this metric would form isolines of distance that are
circular from a given point, with the distance given by the <b>radius</b>.
-<p>
-The <i>Manhattan metric</i>, or <i>Taxicab geometry</i>, is a form of geometry in
+<p>The <i>Manhattan metric</i>, or <i>Taxicab geometry</i>, is a form of geometry in
which the usual metric of Euclidean geometry is replaced by a new
metric in which the distance between two points is the sum of the (absolute)
differences of their coordinates. The name alludes to the grid layout of
@@ -43,15 +40,13 @@
where cells grown using this metric would form isolines of distance that are
rhombus-shaped from a given point.
-<p>
-The <i>Maximum metric</i> is given by the formula
+<p>The <i>Maximum metric</i> is given by the formula
<div class="code"><pre>d(dx,dy) = max(abs(dx),abs(dy))</pre></div>
where the isolines of distance from a point are squares.
-<p>
-If there are two cells which are equal candidates to grow into an empty space,
+<p>If there are two cells which are equal candidates to grow into an empty space,
<em>r.grow</em> will choose the northernmost candidate; if there are multiple
candidates with the same northing, the westernmost is chosen.
@@ -80,8 +75,7 @@
<a href="r.patch.html">r.patch</a>
</em>
-<p>
-<em><a href="http://en.wikipedia.org/wiki/Euclidean_metric">Wikipedia Entry: Euclidean Metric</a></em><br>
+<p><em><a href="http://en.wikipedia.org/wiki/Euclidean_metric">Wikipedia Entry: Euclidean Metric</a></em><br>
<em><a href="http://en.wikipedia.org/wiki/Manhattan_metric">Wikipedia Entry: Manhattan Metric</a></em>
@@ -89,8 +83,6 @@
Marjorie Larson,
-<p>
-Glynn Clements
+<p>Glynn Clements
-<p>
Modified: grass/trunk/raster/r.grow.distance/r.grow.distance.html
--- grass/trunk/raster/r.grow.distance/r.grow.distance.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.grow.distance/r.grow.distance.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.grow.distance</em> generates raster maps representing the
distance to the nearest non-null cell in the input map and/or the
value of the nearest non-null cell.
@@ -12,7 +11,6 @@
<i>Manhattan</i>, and <i>Maximum</i>.
<p>
@@ -23,13 +21,11 @@
-<p>
-The <i>Squared</i> metric is the <i>Euclidean</i> distance squared,
+<p>The <i>Squared</i> metric is the <i>Euclidean</i> distance squared,
i.e. it simply omits the square-root calculation. This may be faster,
and is sufficient if only relative values are required.
<p>
@@ -45,7 +41,6 @@
<p>
@@ -71,7 +66,6 @@
</em>
<p>
<em>
Euclidean Metric</a><br>
@@ -84,5 +78,4 @@
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.gwflow/r.gwflow.html
--- grass/trunk/raster/r.gwflow/r.gwflow.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.gwflow/r.gwflow.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,11 +4,9 @@
raster maps and the current region settings.
All initial and boundary conditions must be provided as
raster maps. The unit in the location must be meters.
-<p>
-This module is sensitive to mask settings. All cells which are outside the mask
+<p>This module is sensitive to mask settings. All cells which are outside the mask
are ignored and handled as no flow boundaries.
-<p>
-<center>
+<p><center>
<img src=r_gwflow_concept.png border=0><br>
<table border=0 width=700>
<tr><td><center>
@@ -17,7 +15,6 @@
</table>
</center>
<p>
<em>r.gwflow</em> calculates the piezometric head and optionally
the water budget and the filter velocity field,
based on the hydraulic conductivity and the piezometric head.
@@ -42,12 +39,9 @@
linear equation system in form of <i>Ax = b</i>, which must be solved. The groundwater flow partial
differential equation is of the following form:
-<p>
-(dh/dt)*S = div (K grad h) + q
-<p>
-In detail for 2 dimensions:
-<p>
-(dh/dt)*S = Kxx * (d^2h/dx^2) + Kyy * (d^2h/dy^2) + q
+<p>(dh/dt)*S = div (K grad h) + q
+<p>In detail for 2 dimensions:
+<p>(dh/dt)*S = Kxx * (d^2h/dx^2) + Kyy * (d^2h/dy^2) + q
<ul>
<li>h -- the piezometric head im [m]</li>
@@ -58,14 +52,11 @@
<li>q - inner source/sink in meter per second [1/s]</li>
</ul>
-<p>
-Confined and unconfined groundwater flow is supported. Be aware that the storativity input parameter
+<p>Confined and unconfined groundwater flow is supported. Be aware that the storativity input parameter
is handled differently in case of unconfined flow. Instead of the storativity, the effective porosity is expected.
-<p>
-To compute unconfined groundwater flow, a simple Picard based linearization scheme is used to
+<p>To compute unconfined groundwater flow, a simple Picard based linearization scheme is used to
solve the resulting non-linear equation system.
-<p>
-Two different boundary conditions are implemented,
+<p>Two different boundary conditions are implemented,
the Dirichlet and Neumann conditions. By default the calculation area is surrounded by homogeneous Neumann boundary conditions.
The calculation and boundary status of single cells must be set with a status map,
the following states are supportet:
@@ -153,8 +144,7 @@
<h2>AUTHOR</h2>
Sören Gebbert
-<p>
-This work is based on the Diploma Thesis of Sören Gebbert available
+<p>This work is based on the Diploma Thesis of Sören Gebbert available
<a href="http://www.hydrogeologie.tu-berlin.de/fileadmin/fg66/_hydro/Diplomarbeiten/2007_Diplomarbeit_Soeren_Gebbert.pdf">here</a>
at Technical University Berlin in Germany.
Modified: grass/trunk/raster/r.his/r.his.html
--- grass/trunk/raster/r.his/r.his.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.his/r.his.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,7 +7,6 @@
user-specified raster map layers.
<p>
The human brain automatically interprets the vast amount of
visual information available according to basic rules.
Color, or <i>hue</i>, is used to categorize objects.
@@ -21,7 +20,6 @@
<i>hue</i>, <i>intensity</i>, and <i>saturation</i>.
<p>
While any raster map layer can be used to represent the hue
information, map layers with a few very distinct colors
work best. Only raster map layers representing
@@ -30,7 +28,6 @@
intensity and saturation information.
<p>
For example, a visually pleasing image can be made by using
a watershed map for the <i>hue</i> factor, an aspect map
for the <i>intensity</i> factor, and an elevation map for
@@ -74,7 +71,6 @@
</pre>
<p>
Either (but not both) of the intensity or the saturation
map layers may be omitted. This means that it is possible
to produce output images that represent combinations of
Modified: grass/trunk/raster/r.horizon/r.horizon.html
--- grass/trunk/raster/r.horizon/r.horizon.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.horizon/r.horizon.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,8 +13,7 @@
height in a specific direction. One raster is created for each direction.
</ul>
-<p>
-The directions are given as azimuthal angles (in degrees), with
+<p>The directions are given as azimuthal angles (in degrees), with
the angle starting with 0 towards East and moving counterclockwise
(North is 90, etc.). The calculation takes into account the actual
projection, so the angles are corrected for direction distortions
@@ -27,14 +26,14 @@
not applied.
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
<dt><b>-d</b>
<dd>Output horizon height in degrees (the default is radians)</dd>
</dl>
-<H3>Input parameters:</H3>
+<h3>Input parameters:</h3>
<p>The <I>elevin</I> parameter is an input elevation raster map. If
the buffer options are used (see below), this raster should extend
over the area that accommodate the presently defined region plus
@@ -91,8 +90,7 @@
in the single point mode this option will be ignored.
-<p>
-At the moment the elevation and maximum distance must be measured in meters,
+<p>At the moment the elevation and maximum distance must be measured in meters,
even if you use geographical coordinates (longitude/latitude). If your
projection is based on distance (easting and northing), these too must
be in meters. The buffer parameters must be in the same units as the
@@ -138,9 +136,9 @@
<h2>SEE ALSO</h2>
<em>
-<a href="r.sun.html">r.sun</A>,
-<a href="r.sunmask.html">r.sunmask</A>,
-<a href="r.los.html">r.los</A></em>
+<a href="r.sun.html">r.sun</a>,
+<a href="r.sunmask.html">r.sunmask</a>,
+<a href="r.los.html">r.los</a></em>
<h2>REFERENCES</h2>
@@ -153,39 +151,34 @@
<a href="http://www.isess.org/papers.asp?year=2007">International Symposium on
Environmental Software Systems</a>, Prague, 2007
<p>Neteler M., Mitasova H., 2004. Open Source GIS: A GRASS GIS
-Approach, <a href="http://www.springer.com/geography/gis+cartography/book/978-0-387-35767-6">Springer</A>, New York.
+Approach, <a href="http://www.springer.com/geography/gis+cartography/book/978-0-387-35767-6">Springer</a>, New York.
ISBN: 1-4020-8064-6, 2nd Edition 2004 (reprinted 2005), 424 pages
-<p>Project <a href="http://re.jrc.ec.europa.eu/pvgis/">PVGIS</A>, European
+<p>Project <a href="http://re.jrc.ec.europa.eu/pvgis/">PVGIS</a>, European
Commission, DG Joint Research Centre 2001-2007
<p>Suri M., Hofierka J., 2004.
A New GIS-based Solar Radiation Model and Its Application for
Photovoltaic Assessments. <a href="http://www.blackwellpublishing.com/toc.asp?ref=1361-1682">Transactions
-in GIS</A>, 8(2), 175-190
+in GIS</a>, 8(2), 175-190
<h2>AUTHORS</h2>
-<p>
-Thomas Huld, Joint Research Centre of
+<p>Thomas Huld, Joint Research Centre of
the European Commission, Ispra, Italy
<br>
-<p>
-Tomas Cebecauer, Joint Research Centre
+<p>Tomas Cebecauer, Joint Research Centre
of the European Commission, Ispra, Italy
<br>
-<p>
-Jaroslav Hofierka, GeoModel s.r.o.,
+<p>Jaroslav Hofierka, GeoModel s.r.o.,
Bratislava, Slovakia <br>Marcel Suri, Joint Research Centre of the
-<p>
-© 2007, Thomas Huld, Tomas Cebecauer, Jaroslav Hofierka, Marcel Suri
+<p>© 2007, Thomas Huld, Tomas Cebecauer, Jaroslav Hofierka, Marcel Suri
-<ADDRESS STYLE="margin-bottom: 0.2in"><a href="mailto:Thomas.Huld at jrc.it">Thomas.Huld at jrc.it</A>
-<a href="mailto:Tomas.Cebecauer at jrc.it">Tomas.Cebecauer at jrc.it</A>
-<a href="mailto:hofi at geomodel.sk">hofierka at geomodel.sk</A>
-<a href="mailto:Marcel.Suri at jrc.it">Marcel.Suri at jrc.it</A>
+<ADDRESS STYLE="margin-bottom: 0.2in"><a href="mailto:Thomas.Huld at jrc.it">Thomas.Huld at jrc.it</a>
+<a href="mailto:Tomas.Cebecauer at jrc.it">Tomas.Cebecauer at jrc.it</a>
+<a href="mailto:hofi at geomodel.sk">hofierka at geomodel.sk</a>
+<a href="mailto:Marcel.Suri at jrc.it">Marcel.Suri at jrc.it</a>
</ADDRESS>
-<p>
-<I>Last changed: $Date$</I>
+<p><I>Last changed: $Date$</I>
Modified: grass/trunk/raster/r.in.arc/r.in.arc.html
--- grass/trunk/raster/r.in.arc/r.in.arc.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.arc/r.in.arc.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,7 +4,6 @@
from an ESRI ARC/INFO ascii GRID file with (optional) title.
<p>
The ARC/INFO ascii GRID file header has 6 lines (last line optional):
ncols:
Modified: grass/trunk/raster/r.in.ascii/r.in.ascii.html
--- grass/trunk/raster/r.in.ascii/r.in.ascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.ascii/r.in.ascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,12 +4,10 @@
layer from an ASCII raster input file with (optional) TITLE.
<p>
The GRASS ASCII <b>input</b> file has a header section which describes
the location and size of the data, followed by the data itself.
<p>
The header has 6 lines:
@@ -28,7 +26,6 @@
The data which follows is <em>r</em> rows of <em>c</em> integers.
<p>
Optionally the following parameters can be defined in the header section:
@@ -38,7 +35,6 @@
</pre></div>
<p>
"null" defines a string or number to be converted to NULL value (no
data).<br>
"type" defines the data type (int, float double) and is not required.<br>
@@ -55,25 +51,21 @@
SW value occurs at the beginning of the last line of data.
<p>
The data (which follows the header section) must contain
<tt>r</tt> <em>x</em> <tt>c</tt> values, but it is not necessary
that all the data for a row be on one line. A row may be
split over many lines.
<p>
<em>r.in.ascii</em> may import <i>integer</i>, <i>floating point</i>, or <i>double</i> cell
types using the <b>-i</b>, <b>-f</b>, and <b>-d</b> flags, respectively.
<p>
The header information in ESRI Raster ASCII files differs from GRASS.
To convert an Arc/Info (ArcView) ASCII grid file into GRASS, see
<em><a href="r.in.arc.html">r.in.arc</a></em>.
<p>
SURFER (Golden Software) ASCII files may be imported by passing the <b>-s</b> flag.
<h2>EXAMPLE</h2>
@@ -118,5 +110,4 @@
Surfer support by Roger Miller
-<p>
Modified: grass/trunk/raster/r.in.bin/r.in.bin.html
--- grass/trunk/raster/r.in.bin/r.in.bin.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.bin/r.in.bin.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,17 +1,13 @@
<em>r.in.bin</em> allows a user to create a (binary) GRASS raster map layer
from a variety of binary raster data formats.
-<p>
-The <b> -s</b> flag is used for importing two's-complement signed data.
-<p>
-The <b> -h</b> flag is used to read region information from a Generic
+<p>The <b> -s</b> flag is used for importing two's-complement signed data.
+<p>The <b> -h</b> flag is used to read region information from a Generic
Mapping Tools (GMT) type binary header. It is compatible with GMT binary
grid types 1 and 2.
-<p>
-The north, south, east, and west field values entered
+<p>The north, south, east, and west field values entered
are the coordinates of the edges of the geographic region.
The rows and cols field values entered describe the dimensions
of the matrix of data to follow. If input is a
@@ -20,11 +16,9 @@
If the bytes field is entered incorrectly an error will be generated
suggesting a closer bytes value.
-<p>
-<em>r.in.bin</em> can be used to import numerous binary arrays including:
+<p><em>r.in.bin</em> can be used to import numerous binary arrays including:
ETOPO30, ETOPO-5, ETOPO-2, Globe DEM, BIL, AVHRR and GMT binary arrays (ID 1 & 2)
<p>
<h2>NOTES</h2>
If optional parameters are not supplied, <b>r.in.bin</b> attempts
@@ -35,14 +29,12 @@
east, and west parameters are not entered, <b>r.in.bin</b> assigns
them from the rows and columns parameters. In the above AVHRR example,
the raster would be assigned a north=128, south=0, east=128, west=0.
-<p>
-The geographic coordinates north, south, east, and west
+<p>The geographic coordinates north, south, east, and west
describe the outer edges of the geographic region. They
run along the edges of the cells at the edge of the
geographic region and <em>not</em> through the center of the cells
at the edges.
-<p>
-Eastern limit of geographic region (in projected coordinates must be east
+<p>Eastern limit of geographic region (in projected coordinates must be east
of the west parameter value, but in geographical coordinates will wrap
around the globe; user errors can be detected by comparing the <em>ewres</em> and
<em>nsres</em> values of the imported map layer carefully).
@@ -51,13 +43,10 @@
of the east parameter value, but in geographical coordinates will wrap
-<p>
-Notes on (non)signed data:<p>
-If you use the -s flag the highest bit is the sign bit. If this is 1 the
+<p>Notes on (non)signed data:<p>If you use the -s flag the highest bit is the sign bit. If this is 1 the
data is negative, and the data interval is half of the unsigned (not
exactly).
-<p>
-This flag is only used if <b>bytes=</b> 1. If <b>bytes=</b> is greater
+<p>This flag is only used if <b>bytes=</b> 1. If <b>bytes=</b> is greater
than 1 the flag is ignored.
<h2>EXAMPLES</h2>
@@ -66,24 +55,20 @@
The following is a sample call of <em>r.in.bin</em> to import
<a href="http://edcdaac.usgs.gov/gtopo30/gtopo30.asp">GTOPO30 DEM</a>
data:
-<p>
r.in.bin -sb input=E020N90.DEM output=gtopo30 bytes=2 north=90 south=40
east=60 west=20 r=6000 c=4800
</pre></div>
-<p>
-(you can add "anull=-9999" if you want sea level to have a NULL value)
+<p>(you can add "anull=-9999" if you want sea level to have a NULL value)
<h3>GMT</h3>
The following is a sample call of <em>r.in.bin</em> to import a GMT
type 1 (float) binary array:
-<p>
r.in.bin -hf input=sample.grd output=sample.grass
</pre></div>
-<p>
-(-b could be used to swap bytes if required)
+<p>(-b could be used to swap bytes if required)
<h3>AVHRR</h3>
The following is a sample call of <em>r.in.bin</em> to import an AVHRR image:
@@ -96,8 +81,7 @@
<h3>ETOPO2</h3>
<a href="http://www.ngdc.noaa.gov/mgg/image/2minrelief.html">ETOPO2 DEM</a> data (here full data set):
-<p>
r.in.bin ETOPO2.dos.bin out=ETOPO2min r=5400 c=10800 n=90 s=-90 w=-180 e=180 bytes=2
r.colors ETOPO2min rules=terrain
</pre></div>
@@ -105,8 +89,7 @@
<h3>TOPEX/SRTM30 PLUS</h3>
<a href="http://topex.ucsd.edu/WWW_html/srtm30_plus.html">SRTM30 PLUS</a> data:
-<p>
r.in.bin -sb input=e020n40.Bathmetry.srtm output=e020n40_topex \
bytes=2 north=40 south=-10 east=60 west=20 r=6000 c=4800
r.colors e020n40_topex rules=etopo2
Modified: grass/trunk/raster/r.in.gdal/r.in.gdal.html
--- grass/trunk/raster/r.in.gdal/r.in.gdal.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.gdal/r.in.gdal.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,9 +20,7 @@
<h3>GDAL supported raster formats</h3>
Full details on GDAL supported formats are available at:<p>
<a href="http://www.gdal.org/formats_list.html">http://www.gdal.org/formats_list.html</a><p>
Selected formats of more than 80 supported formats:
@@ -88,13 +86,11 @@
match current location</tt>) and then report the PROJ_INFO parameters of
the source dataset.
-<p>
-If the user wishes to ignore the difference between the apparent coordinate
+<p>If the user wishes to ignore the difference between the apparent coordinate
system of the source data and the current location, they may pass the
<b>-o</b> flag to override the projection check.
<p>
If the user wishes to import the data with the full projection definition,
it is possible to have r.in.gdal automatically create a new location based
on the projection and extents of the file being read. This is accomplished
@@ -103,8 +99,7 @@
created (with only a PERMANENT mapset), and the raster will have been
imported with the indicated <b>output</b> name into the PERMANENT mapset.
-<p>
-Support for GCPs: In case the image contains GCPs they are written to a
+<p>Support for GCPs: In case the image contains GCPs they are written to a
POINTS file within an imagery group. They can directly be used for
<a href=i.rectify.html>i.rectify</a>. The <b>target</b> option allows to
automatically re-project the GCPs from their own projection into another
@@ -116,12 +111,10 @@
Import of large files can be significantly faster when setting <b>memory</b> to
the size of the input file.
-<p>
-The <em>r.in.gdal</em> command does support the following features, as long as
+<p>The <em>r.in.gdal</em> command does support the following features, as long as
the underlying format driver supports it:
<p>
<dl>
<dt> Color Table
@@ -169,8 +162,7 @@
</dl>
-<p>
-Planned improvements to <em>r.in.gdal</em> in the future include support for
+<p>Planned improvements to <em>r.in.gdal</em> in the future include support for
reporting everything known about a dataset if the <b>output</b> parameter is not set.
<h3>Error Messages</h3>
@@ -186,8 +178,7 @@
gdalwarp rotated.tif northup.tif
</pre></div>
-<p>
-<i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
+<p><i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
You need to create a location whose projection matches the data you
wish to import. Try using <b>location</b> parameter to create a new
@@ -195,8 +186,7 @@
you can then re-project it to another location with <em>r.proj</em>.
Alternatively you can override this error by using the <b>-o</b> flag.
-<p>
-<i>"WARNING: G_set_window(): Illegal latitude for North"</i><br>
+<p><i>"WARNING: G_set_window(): Illegal latitude for North"</i><br>
Latitude/Longitude locations in GRASS can not have regions which exceed
90° North or South. Non-georeferenced imagery will have coordinates
@@ -326,5 +316,4 @@
<a href="http://home.gdal.org/warmerda/">Frank Warmerdam</a>
(<a href="mailto:warmerdam AT pobox dot com">email</a>).
-<p>
Modified: grass/trunk/raster/r.in.gridatb/r.in.gridatb.html
--- grass/trunk/raster/r.in.gridatb/r.in.gridatb.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.gridatb/r.in.gridatb.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<h2>DESCRIPTION</h2>
<em>r.in.gridatb</em> imports GRIDATB.FOR map file (TOPMODEL) into GRASS
raster map.
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,13 +5,11 @@
methods in creating the new raster. Gridded data provided as a stream of
x,y,z points may also be imported.
<p>
<em>r.in.lidar</em> is designed for processing massive point cloud datasets,
for example raw LIDAR or sidescan sonar swath data. It has been tested with
datasets as large as tens of billion of points (705GB in a single file).
<!-- Doug Newcomb, US Fish & Wildlife Service -->
<p>
Available statistics for populating the raster are:<br>
<ul>
<li>
@@ -79,7 +77,6 @@
but for the aggregate fns it will also depend on the number of data points. (?) -->
<p>
The default map <b>type</b>=<tt>FCELL</tt> is intended as compromise between
preserving data precision and limiting system resource consumption.
@@ -106,7 +103,6 @@
</pre></div>
<p>
If you only intend to interpolate the data with <em>r.to.vect</em> and
<em>v.surf.rst</em>, then there is little point to setting the region
resolution so fine that you only catch one data point per cell -- you might
@@ -119,26 +115,22 @@
points falling <em>exactly</em> on the southern region bound.
(to capture those adjust the region with "<tt>g.region s=s-0.000001</tt>";
see <em>g.region</em>)
-<p>
-Blank lines and comment lines starting with the hash symbol (<tt>#</tt>)
+<p>Blank lines and comment lines starting with the hash symbol (<tt>#</tt>)
will be skipped.
<p>
The <b>zrange</b> parameter may be used for filtering the input data by
vertical extent. Example uses might include preparing multiple raster
sections to be combined into a 3D raster array with <em>r.to.rast3</em>, or
for filtering outliers on relatively flat terrain.
<p>
In varied terrain the user may find that <em>min</em> maps make for a good
noise filter as most LIDAR noise is from premature hits. The <em>min</em> map
may also be useful to find the underlying topography in a forested or urban
environment if the cells are over sampled.
<p>
The user can use a combination of <em>r.in.lidar</em> <b>output</b> maps to create
custom filters. e.g. use <em>r.mapcalc</em> to create a <tt>mean-(2*stddev)</tt>
map. [In this example the user may want to include a lower bound filter in
@@ -158,7 +150,6 @@
and adjust bounds and/or resolution as needed before proceeding.
<p>
Typical commands to create a DEM using a regularized spline fit:
r.univar lidar_min
@@ -176,8 +167,7 @@
This example is analogous to the example used in the GRASS wiki page for
<a href="http://grass.osgeo.org/wiki/LIDAR#Import_LAS_as_raster_DEM">importing LAS as raster DEM</a>.
-<p>
-The sample LAS data are in the file "Serpent Mound Model LAS Data.las",
+<p>The sample LAS data are in the file "Serpent Mound Model LAS Data.las",
available at
<a href="http://www.appliedimagery.com/downloads/sampledata/Serpent%20Mound%20Model%20LAS%20Data.las">appliedimagery.com</a>
@@ -257,8 +247,7 @@
<a href="v.outlier.html">v.outlier</a>,
<a href="v.surf.bspline.html">v.surf.bspline</a>
</i>
-<p>
-<i><a href="http://www.ivarch.com/programs/pv.shtml">pv</a></i>
+<p><i><a href="http://www.ivarch.com/programs/pv.shtml">pv</a></i>
- The UNIX pipe viewer utility
<br><br>
@@ -269,5 +258,4 @@
based on r.in.xyz by Hamish Bowman and Volker Wichmann<br>
<br>
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.in.mat/r.in.mat.html
--- grass/trunk/raster/r.in.mat/r.in.mat.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.mat/r.in.mat.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -121,8 +121,7 @@
<a href="r.mapcalc.html">r.mapcalc</a>,
<a href="r.null.html">r.null</a>.
</em>
-<p>
-<em>
+<p><em>
The <a href="http://www.octave.org">Octave</a> project
</em>
Modified: grass/trunk/raster/r.in.png/r.in.png.html
--- grass/trunk/raster/r.in.png/r.in.png.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.png/r.in.png.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -16,5 +16,4 @@
Alex Shevlakov
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.in.poly/r.in.poly.html
--- grass/trunk/raster/r.in.poly/r.in.poly.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.poly/r.in.poly.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,19 +1,16 @@
<em>r.in.poly</em> allows the creation of GRASS binary
raster maps from ASCII files in the current directory
containing polygon, linear, and point features.
<p>
The <b>input</b> file is an ASCII text file containing the
polygon, linear, and point feature definitions.
The format of this file is described in the
<a href="#format.html"><i>INPUT FORMAT</i></a> section below.
<p>
The number of raster <b>rows</b> to hold in memory is per default 4096.
This parameter allows users with less memory (or more) on their
system to control how much memory <em>r.in.poly</em> uses.
@@ -23,19 +20,16 @@
<h2>NOTES</h2>
<p>
The data will be imported using the current region settings to set the
new raster map's bounds and resolution. Any features falling outside
the current region will be cropped. The region settings are contolled
with the <em>g.region</em> module.
<p>
The format is a simplified version of the standard GRASS vector ASCII
format used by <em>v.in.ascii</em>.
<p>
Polygons are filled, i.e. they define an area.
<A NAME="format.html"></a>
@@ -113,5 +107,4 @@
Michael Shapiro, U.S.Army Construction Engineering Research Laboratory
-<p>
Modified: grass/trunk/raster/r.in.xyz/r.in.xyz.html
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,13 +5,11 @@
<p>
<em>r.in.xyz</em> is designed for processing massive point cloud datasets,
<p>
<ul>
<li>
@@ -79,7 +77,6 @@
<p>
If reading data from a <tt>stdin</tt> stream, the program can only run using
@@ -108,7 +105,6 @@
</pre></div>
<p>
@@ -121,26 +117,22 @@
-<p>
will be skipped.
<p>
<p>
<p>
The user can use a combination of <em>r.in.xyz</em> <b>output</b> maps to create
@@ -166,7 +158,6 @@
<p>
r.univar lidar_min
@@ -260,8 +251,7 @@
</i>
-<p>
<br><br>
@@ -277,5 +267,4 @@
<i>median, percentile, skewness</i> and <i>trimmed mean</i>.
<br>
-<p>
Modified: grass/trunk/raster/r.info/r.info.html
--- grass/trunk/raster/r.info/r.info.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.info/r.info.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,7 +12,6 @@
stored.
<p>
The user can save the tabular output to a file
by using the UNIX redirection mechanism (>); for example, the user
might save a report on the <em>soils</em> map layer in a file called
@@ -28,14 +27,12 @@
with an accurate number. This is only cosmetic.
<p>
Some standards (ISO-C90) and compilers do not support the 'long long' type
as a 64-bit type. In the case that GRASS was built with such a compiler,
an accuracy message may be displayed in the output of <em>r.info</em>
after Total Cells:
<p>
<h2>EXAMPLES</h2>
Below is a full report produced by <em>r.info</em> for the raster map
Modified: grass/trunk/raster/r.kappa/r.kappa.html
--- grass/trunk/raster/r.kappa/r.kappa.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.kappa/r.kappa.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,13 +1,11 @@
<em>r.kappa</em> tabulates the error matrix of classification result by
crossing classified map layer with respect to reference map layer. Both
overall <em>kappa</em> (accompanied by its <em>variance</em>) and
conditional <em>kappa</em> values are calculated. This analysis program
respects the current geographic region and mask settings.
-<p>
-<em>r.kappa</em> calculates the error matrix of the
+<p><em>r.kappa</em> calculates the error matrix of the
two map layers and prepares the table from which the report
is to be created. <em>kappa</em> values for overall and
each classes are computed along with their variances. Also
@@ -16,14 +14,12 @@
counts and percentage of overall correctly classified
pixels are tabulated.
-<p>
-The report will be write to an output file which is in
+<p>The report will be write to an output file which is in
plain text format and named by user at prompt of running
the program.
-<p>
-The body of the report is arranged in panels. The
+<p>The body of the report is arranged in panels. The
classified result map layer categories is arranged along
the vertical axis of the table, while the reference map
layer categories along the horizontal axis. Each panel has
@@ -45,7 +41,6 @@
information for each and every category.
<p>
<em>NA</em>'s in output file mean non-applicable in case
<em>MASK</em> exists.
Modified: grass/trunk/raster/r.lake/r.lake.html
--- grass/trunk/raster/r.lake/r.lake.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.lake/r.lake.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -18,8 +18,7 @@
<p>The water level must be in DEM units.
<h2>NOTES</h2>
-<p>
-The seed (starting) point can be a raster map with at least one
+<p>The seed (starting) point can be a raster map with at least one
cell value greater than zero, or a seed point can be specified as an E,
N coordinate pair. If the seed is specified as a coordinate pair, an additional
check is done to make sure that the target water level is above the level of
@@ -29,7 +28,6 @@
as a seed map for a new run to simulate rising water levels.
<p>
The module will create a new map (<b>lake=foo</b>) or can be set to replace
the input (<b>seed=bar</b>) map if the <b>-o</b> flag is used. The user can use
<b>-o</b> flag to create animations of rising water level without
@@ -38,7 +36,6 @@
water levels maps (i.e., a single file serves for both input and output).
<p>
Negative output (the <b>-n</b> flag) is useful for visualisations in NVIZ.
It equals the mapcalc's expression <em>"negative = 0 - positive"</em>.
@@ -63,8 +60,7 @@
if(isnull(${seedmap}[-1,-1]),0, ${seedmap}[-1,-1]>0 && ${wlevel}>${dem}),\
${wlevel}-${dem}, null() )))
</pre></div>
-<p>
-The ${seedmap} variable is replaced by seed map names, ${dem} with DEM map name, and
+<p>The ${seedmap} variable is replaced by seed map names, ${dem} with DEM map name, and
${wlevel} with target water level. To get single water level, this code block is
called with same level numerous times (in a loop) as the lake grows by single cells
during single run.
Modified: grass/trunk/raster/r.li/r.li.html
--- grass/trunk/raster/r.li/r.li.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.li/r.li.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -21,8 +21,7 @@
It aims at replacing the <em>r.le</em> suite of modules through a client-server,
multiprocess implementation. External software for quantitative measures of landscape
structure is for example FRAGSTATS (McGarigal and Marks 1995).
-<p>
-The <em>r.li</em> suite offers a set of patch and diversity indices.
+<p>The <em>r.li</em> suite offers a set of patch and diversity indices.
It supports analysis of landscapes composed of a mosaic of
patches, but, more generally, the modules work with any two-dimensional
raster map whose cell values are integer (e.g., 1, 2) or floating point
@@ -35,15 +34,13 @@
at a variety of spatial scales simultaneously. Sampling areas may be
distributed across the landscape in a random, systematic, or
stratified-random manner, or as a moving window.
-<p>
-The <em>r.li</em> modules can calculate a number of measures that produce
+<p>The <em>r.li</em> modules can calculate a number of measures that produce
single values as output (e.g. mean patch size in the sampling area),
as well as measures that produce a distribution of values as output
(e.g. frequency distribution of patch sizes in the sampling area). The
results are stored as raster maps.
-<p>
-The general procedure to calculate an index from a raster map is two-fold:
+<p>The general procedure to calculate an index from a raster map is two-fold:
<ol>
<li>run <em>r.li.setup</em>: create a configuration file selecting the parts of
@@ -181,11 +178,9 @@
University of Pisa (Italy). <br>
Commission from Faunalia Pontedera (PI)<br>
-<p>
<hr>
-<p>
-<a href="index.html">Main index</a> - <a href="raster.html">raster index</a>
+<p><a href="index.html">Main index</a> - <a href="raster.html">raster index</a>
- <a href="full_index.html">Full index</a>
</body>
</html>
Modified: grass/trunk/raster/r.los/r.los.html
--- grass/trunk/raster/r.los/r.los.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.los/r.los.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.los</em> generates a raster output map in which the cells that are
visible from a user-specified observer position are marked with the
vertical angle (in degrees) required to see those cells (viewshed).
@@ -9,15 +8,13 @@
The angle to the cell containing the viewing position is undefined
and set to 180.
-<p>
-To run <em>r.los</em>, the user must specify at least
+<p>To run <em>r.los</em>, the user must specify at least
an <b>input</b> map name, <b>output</b> map name, and the geographic
<b>coordinate</b>s of the user's viewing location;
any remaining parameters whose values are unspecified
will be set to their default values (see below).
-<p>
-The <b>patt_map</b> is the name of a binary (1/0) raster map layer in which
+<p>The <b>patt_map</b> is the name of a binary (1/0) raster map layer in which
cells within the areas of interest are assigned the category value '1', and
all other cells are assigned the category value '0' or NULL. If this parameter is
omitted, the analysis will be performed for the whole area within a certain
@@ -26,11 +23,9 @@
Default: assign all cells that are within the <b>max_dist</b> and within
the user's current geographic region boundaries a value of 1.
-<p>
-The <b>obs_elev</b> parameter defines the height of the observer (in
+<p>The <b>obs_elev</b> parameter defines the height of the observer (in
meters) above the viewing point's elevation.
<p>
The <b>max_dist</b> parameter is the maximum distance (in meters) from the
viewing point inside of which the line of sight analysis will be performed.
The cells outside this distance range are assigned a NULL value.
@@ -42,18 +37,15 @@
geographic region set equal to the resolution of the data
(see <em><a href="g.region.html">g.region</a></em>).
-<p>
-The time to complete the calculation increases dramatically with the region size.
+<p>The time to complete the calculation increases dramatically with the region size.
Try to keep the columns and rows under 1000.
-<p>
-It is advisable to use a 'pattern layer' which identifies
+<p>It is advisable to use a 'pattern layer' which identifies
the areas of interest in which the line of sight analysis
is required. Such a measure will reduce the time taken by
the program to run.
-<p>
-The curvature of the Earth is not taken into account for these calculations.
+<p>The curvature of the Earth is not taken into account for these calculations.
However, for interest's sake, a handy calculation for distance to the true horizon
is approximated by <i>d = sqrt(13*h)</i> where <i>h</i> is the height of the observer
in meters (above sea level) and <i>d</i> is the distance to the horizon in km.
@@ -94,5 +86,4 @@
Kewan Q. Khawaja, Intelligent Engineering Systems Laboratory, M.I.T.
-<p>
Modified: grass/trunk/raster/r.mapcalc/r.mapcalc.html
--- grass/trunk/raster/r.mapcalc/r.mapcalc.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.mapcalc/r.mapcalc.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,10 +7,8 @@
<h3>PROGRAM USE</h3>
<em>r.mapcalc</em> expects its input to have the form:
-<p>
-<b>result =</b><em> expression</em>
-<p>
-where <em>result</em> is the name of a raster map layer
+<p><b>result =</b><em> expression</em>
+<p>where <em>result</em> is the name of a raster map layer
to contain the result of the calculation and
<em>expression</em> is any legal arithmetic expression involving existing
raster map layers, integer or floating point constants,
@@ -18,7 +16,6 @@
Parentheses are allowed in the expression and may be nested to any depth.
<em>result</em> will be created in the user's current mapset.
<p>
As <em>expression=</em> is the first option, it is the default. This
means that passing an expression on the command line is possible
as long as the expression is quoted and a space is included before the
@@ -66,17 +63,14 @@
EOF
</pre></div>
-<p>
-The formula entered to <em>r.mapcalc</em> by the user is recorded both in the
+<p>The formula entered to <em>r.mapcalc</em> by the user is recorded both in the
<em>result</em> map title (which appears in the category file for <em>result</em>)
and in the history file for <em>result</em>.
-<p>
-Some characters have special meaning to the command shell. If the user
+<p>Some characters have special meaning to the command shell. If the user
is entering input to <em>r.mapcalc</em> on the command line, expressions
should be enclosed within single quotes. See NOTES, below.
<p>
<h3>OPERATORS AND ORDER OF PRECEDENCE</h3>
The following operators are supported:
@@ -109,88 +103,66 @@
?: conditional Logical 1
</pre></div>
(modulus is the remainder upon division)
-<p>
-[1] The &&& and ||| operators handle null values differently to other
+<p>[1] The &&& and ||| operators handle null values differently to other
operators. See the section entitled <b>NULL support</b> below for more
details.
-<p>
-The operators are applied from left to right, with those of higher precedence
+<p>The operators are applied from left to right, with those of higher precedence
applied before those with lower precedence.
Division by 0 and modulus by 0 are acceptable and give a NULL result.
The logical operators give a 1 result if the comparison is true, 0 otherwise.
-<p>
-<p>
+<p><p>
<h3>RASTER MAP LAYER NAMES</h3>
Anything in the expression which is not a number, operator, or function name
is taken to be a raster map layer name.
Examples:
-<p>
-<div class="code"><pre>
+<p><div class="code"><pre>
elevation
x3
3d.his
</pre></div>
-<p>
-Most GRASS raster map layers meet this naming convention.
+<p>Most GRASS raster map layers meet this naming convention.
However, if a raster map layer has a name which conflicts with the
above rule, it should be quoted. For example, the expression
-<p>
x = a-b
</pre></div>
-<p>
-would be interpreted as: x equals a minus b, whereas
-<p>
+<p>would be interpreted as: x equals a minus b, whereas
x = "a-b"
</pre></div>
-<p>
-would be interpreted as: x equals the raster map layer named <em>a-b</em>
-<p>
-Also
-<p>
+<p>would be interpreted as: x equals the raster map layer named <em>a-b</em>
+<p>Also
x = 3107
</pre></div>
-<p>
-would create <em>x</em> filled with the number 3107, while
-<p>
+<p>would create <em>x</em> filled with the number 3107, while
x = "3107"
</pre></div>
-<p>
-would copy the raster map layer <em>3107</em> to the raster map layer <em>x</em>.
+<p>would copy the raster map layer <em>3107</em> to the raster map layer <em>x</em>.
-<p>
-Quotes are not required unless the raster map layer names
+<p>Quotes are not required unless the raster map layer names
look like numbers or contain operators, OR unless the program
is run non-interactively. Examples given here assume the
program is run interactively. See NOTES, below.
-<p>
-<em>r.mapcalc</em> will look for the raster map layers according to the
+<p><em>r.mapcalc</em> will look for the raster map layers according to the
user's current mapset search path.
It is possible to override the search path and specify the mapset
from which to select the raster map layer.
This is done by specifying the raster map layer name in the form:
-<p>
name at mapset
</pre></div>
-<p>
-For example, the following is a legal expression:
-<p>
+<p>For example, the following is a legal expression:
result = x at PERMANENT / y at SOILS
</pre></div>
-<p>
-The mapset specified does not have to be in the mapset search path.
+<p>The mapset specified does not have to be in the mapset search path.
(This method of overriding the mapset search path is common to all
GRASS commands, not just <em>r.mapcalc</em>.)
<p>
<h3>THE NEIGHBORHOOD MODIFIER</h3>
Maps and images are data base files stored in raster format, i.e.,
two-dimensional matrices of integer values.
@@ -205,18 +177,15 @@
map or across multiple maps.
<p>
<h3>RASTER MAP LAYER VALUES FROM THE CATEGORY FILE</h3>
Sometimes it is desirable to use a value associated with a category's
<em>label</em> instead of the category value itself. If a raster
map layer name is preceded by the <b>@</b>
operator, then the labels in the category file for the raster map layer
are used in the expression instead of the category value.
-<p>
-For example, suppose that the raster map layer <em>soil.ph</em>
+<p>For example, suppose that the raster map layer <em>soil.ph</em>
(representing soil pH values) has a category file with labels as follows:
-<p>
cat label
0 no data
@@ -228,17 +197,13 @@
6 8.8
7 9.4
</pre></div>
-<p>
-Then the expression:
-<p>
+<p>Then the expression:
result = @soils.ph
</pre></div>
-<p>
-would produce a result with category values
+<p>would produce a result with category values
0, 1.4, 2.4, 3.5, 5.8, 7.2, 8.8 and 9.4.
-<p>
-Note that this operator may only be applied to raster map layers
+<p>Note that this operator may only be applied to raster map layers
and produces a floating point value in the expression.
Therefore, the category label must start with a valid number.
If the category label is integer, it will be represented by
@@ -253,49 +218,36 @@
(as with imagery data), or when the map category values represent real
quantities (as when category values reflect true elevation values).
Map color manipulation can also aid visual recognition, and map printing.
-<p>
-The # operator can be used to either convert map category values to their
+<p>The # operator can be used to either convert map category values to their
grey scale equivalents or to extract the red, green, or blue components
of a raster map layer into separate raster map layers.
-<p>
result = #map
</pre></div>
-<p>
-converts each category value in <em>map</em> to a value in the range 0-255 which
+<p>converts each category value in <em>map</em> to a value in the range 0-255 which
represents the grey scale level implied by the color for the category.
If the map has a grey scale color table, then the grey level is what
#map evaluates to. Otherwise, it is computed as:
-<p>
0.10 * red + 0.81 * green + 0.01 * blue
</pre></div>
-<p>
-Alternatively, you can use:
-<p>
+<p>Alternatively, you can use:
result = y#map
</pre></div>
-<p>
-to use the NTSC weightings:
-<p>
+<p>to use the NTSC weightings:
0.30 * red + 0.59 * green + 0.11 * blue
</pre></div>
-<p>
-Or, you can use:
-<p>
+<p>Or, you can use:
result = i#map
</pre></div>
-<p>
-to use equal weightings:
-<p>
+<p>to use equal weightings:
0.33 * red + 0.33 * green + 0.33 * blue
</pre></div>
-<p>
-The # operator has three other forms: r#map, g#map, b#map.
+<p>The # operator has three other forms: r#map, g#map, b#map.
These extract the red, green, or blue components in the named raster map,
respectively. The GRASS shell script <em><a href="r.blend.html">r.blend</a></em> extracts each of these
components from two raster map layers, and combines them by a user-specified
@@ -304,29 +256,23 @@
extract the red component from <em>map</em>
and store it in the new 0-255 map layer <em>red</em>,
the user could type:
-<p>
red = r#map
</pre></div>
-<p>
-To assign this map grey colors type:
-<p>
+<p>To assign this map grey colors type:
<a href="r.colors.html">r.colors</a> map=red color=rules
black
white
</pre></div>
-<p>
-To assign this map red colors type:
-<p>
+<p>To assign this map red colors type:
black
red
</pre></div>
<p>
<h3>FUNCTIONS</h3>
The functions currently supported are listed in the table below.
The type of the result is indicated in the last column.
@@ -337,8 +283,7 @@
<em>*</em>
indicates that the result is float if any of the arguments to the function
are floating point values and integer if all arguments are integer.
-<p>
function description type
abs(x) return absolute value of x *
@@ -401,12 +346,10 @@
(truncated) integer, while division of floats results in an accurate
floating point value. With functions of type * (see table above),
the result is float if any argument is float, integer otherwise.
-<p>
-Note: If you calculate with integer numbers, the resulting map will
+<p>Note: If you calculate with integer numbers, the resulting map will
be integer. If you want to get a float result, add the decimal point
to integer number(s).
-<p>
-If you want floating point division, at least one of the arguments has
+<p>If you want floating point division, at least one of the arguments has
to be a floating point value. Multiplying one of them by 1.0 will
produce a floating-point result, as will using float():
@@ -453,42 +396,34 @@
pow(a,b) where a is negative and b is not an integer
</pre></div>
</ul>
-<p>
-NULL support: Please note that any math performed with NULL cells always
+<p>NULL support: Please note that any math performed with NULL cells always
results in a NULL value for these cells. If you want to replace a NULL cell
on-the-fly, use the isnull() test function in a if-statement.
-<p>
-Example: The users wants the NULL-valued cells to be treated like zeros. To
+<p>Example: The users wants the NULL-valued cells to be treated like zeros. To
add maps A and B (where B contains NULLs) to get a map C the user can use a
-construction like:<p>
+construction like:<p><div class="code"><pre>
C = A + if(isnull(B),0,B)
</pre></div>
-<p>
-<b>NULL and conditions:</b>
-<p>
-For the one argument form:
+<p><b>NULL and conditions:</b>
+<p>For the one argument form:
if(x) = NULL if x is NULL
if(x) = 0 if x = 0
if(x) = 1 otherwise (i.e. x is neither NULL nor 0).
</pre></div>
-<p>
-For the two argument form:
+<p>For the two argument form:
if(x,a) = NULL if x is NULL
if(x,a) = 0 if x = 0
if(x,a) = a otherwise (i.e. x is neither NULL nor 0).
</pre></div>
-<p>
-For the three argument form:
+<p>For the three argument form:
if(x,a,b) = NULL if x is NULL
if(x,a,b) = b if x = 0
if(x,a,b) = a otherwise (i.e. x is neither NULL nor 0).
</pre></div>
-<p>
-For the four argument form:
+<p>For the four argument form:
if(x,a,b,c) = NULL if x is NULL
if(x,a,b,c) = a if x > 0
@@ -503,8 +438,7 @@
The function isnull() returns 1 if its argument is NULL and 0 otherwise.
If the user wants the opposite, the ! operator, e.g. "!isnull(x)" must be
used.
-<p>
-All forms of if() return NULL if the first argument is NULL. The 2, 3
+<p>All forms of if() return NULL if the first argument is NULL. The 2, 3
and 4 argument forms of if() return NULL if the "selected" argument is
NULL, e.g.:
@@ -513,8 +447,7 @@
</pre></div>
eval() always returns its last argument, so it only returns NULL if
the last argument is NULL.
-<p>
-<b>Note</b>: The user cannot test for NULL using the == operator, as that
+<p><b>Note</b>: The user cannot test for NULL using the == operator, as that
returns NULL if either or both arguments are NULL, i.e. if x and y are
both NULL, then "x == y" and "x != y" are both NULL rather than 1 and
0 respectively.
@@ -528,17 +461,14 @@
Extra care must be taken if the expression is given on the command line.
Some characters have special meaning to the UNIX shell.
These include, among others:
-<p>
-<p>
-It is advisable to put single quotes around the expression; e.g.:
+<p>* ( ) > & |
+<p>It is advisable to put single quotes around the expression; e.g.:
'result = elevation * 2'
</pre></div>
Without the quotes, the *, which has special meaning to the UNIX shell,
would be altered and <em>r.mapcalc</em> would see something other than the *.
<p>
In general, it's preferable to do as much as possible in each
r.mapcalc command. E.g. rather than:
@@ -546,8 +476,7 @@
r.mapcalc "$GIS_OPT_OUTPUT.g = g#$GIS_OPT_FIRST * .$GIS_OPT_PERCENT + (1.0 - .$GIS_OPT_PERCENT) * g#$GIS_OPT_SECOND"
r.mapcalc "$GIS_OPT_OUTPUT.b = b#$GIS_OPT_FIRST * .$GIS_OPT_PERCENT + (1.0 - .$GIS_OPT_PERCENT) * b#$GIS_OPT_SECOND"
</pre></div>
-<p>
-use:
+<p>use:
r.mapcalc <<EOF
$GIS_OPT_OUTPUT.r = r#$GIS_OPT_FIRST * .$GIS_OPT_PERCENT + (1.0 - .$GIS_OPT_PERCENT) * r#$GIS_OPT_SECOND
@@ -555,26 +484,21 @@
EOF
</pre></div>
-<p>
-as the latter will read each input map only once.
-<p>
-For formulas that the user enters from standard input
+<p>as the latter will read each input map only once.
+<p>For formulas that the user enters from standard input
(rather than from the command line), a line continuation feature now exists.
If the user adds a backslash to the end of an input line, <em>r.mapcalc</em> assumes that
the formula being entered by the user continues on to the next input line.
There is no limit to the possible number of input lines
or to the length of a formula.
-<p>
-If the <em>r.mapcalc</em> formula entered by the user is very long,
+<p>If the <em>r.mapcalc</em> formula entered by the user is very long,
the map title will contain only some of it, but most (if not all) of
the formula will be placed into the history file for the <em>result</em> map.
-<p>
-When the user enters input to <em>r.mapcalc</em> non-interactively on
+<p>When the user enters input to <em>r.mapcalc</em> non-interactively on
the command line, the program will not warn the user not to overwrite
existing map layers. Users should therefore take care to assign program
outputs raster map names that do not yet exist in their current mapsets.
-<p>
-The environment variable GRASS_RND_SEED is read to initialise the
+<p>The environment variable GRASS_RND_SEED is read to initialise the
random number generator.
<h2>EXAMPLES</h2>
@@ -640,18 +564,15 @@
continuation lines, the error messages produced by <em>r.mapcalc</em> will
be meaningless and the equation will not work as the user intended.
This is important for the eval() function.
-<p>
-<!-- STILL TRUE ??-->
+<p><!-- STILL TRUE ??-->
Currently, there is no comment mechanism in <em>r.mapcalc</em>.
Perhaps adding a capability that would cause the entire line to be
ignored when the user inserted a # at the start of a line
as if it were not present, would do the trick.
-<p>
-The function should require the user to type "end" or "exit" instead
+<p>The function should require the user to type "end" or "exit" instead
of simply a blank line. This would make separation of multiple scripts
separable by white space.
-<p>
-r.mapcalc does not print a warning in case of operations on NULL cells.
+<p>r.mapcalc does not print a warning in case of operations on NULL cells.
It is left to the user to utilize the isnull() function.
@@ -664,12 +585,10 @@
r.mapcalc Program Tutorial</a></b>, by Marji Larson, Michael Shapiro and Scott
Tweddale, U.S. Army Construction Engineering Research Laboratory (December
1991)
-<p>
-Grey scale conversion is based on the C.I.E. x,y,z system where y represents
+<p>Grey scale conversion is based on the C.I.E. x,y,z system where y represents
luminance. See "Fundamentals of Digital Image Processing,"
by Anil K. Jain (Prentice Hall, NJ, 1989; p 67).
-<p>
-<em>
+<p><em>
<a href="g.region.html">g.region</a>,
<a href="r.bitpattern.html">r.bitpattern</a>,
<a href="r.blend.html">r.blend</a>,
@@ -681,8 +600,6 @@
<h2>AUTHORS</h2>
Research Laboratory
-<p>
-Glynn Clements
+<p>Glynn Clements
-<p>
Modified: grass/trunk/raster/r.mapcalc/r3.mapcalc.html
--- grass/trunk/raster/r.mapcalc/r3.mapcalc.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.mapcalc/r3.mapcalc.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,10 +7,8 @@
<h2>PROGRAM USE</h2>
<em>r3.mapcalc</em> expects its input to have the form:
-<p>
-<p>
@@ -18,7 +16,6 @@
<p>
@@ -66,17 +63,14 @@
EOF
</pre></div>
-<p>
-The formula entered to <em>r3.mapcalc</em> by the user is recorded both in the
+<p>The formula entered to <em>r3.mapcalc</em> by the user is recorded both in the
-<p>
is entering input to <em>r3.mapcalc</em> on the command line, expressions
<p>
<h2>OPERATORS AND ORDER OF PRECEDENCE</h2>
@@ -109,85 +103,63 @@
</pre></div>
-<p>
details.
-<p>
-<p>
-<p>
+<p><p>
<h2>3D GRID NAMES</h2>
name is taken to be a 3D grid name. Examples:
-<p>
volume
x3
3d.his
</pre></div>
-<p>
-Most GRASS raster map layers and 3D grids meet this naming convention.
+<p>Most GRASS raster map layers and 3D grids meet this naming convention.
However, if a 3D grid has a name which conflicts with the above rule, it
-<p>
x = a-b
</pre></div>
-<p>
-<p>
x = "a-b"
</pre></div>
-<p>
-would be interpreted as: x equals the 3D grid named <em>a-b</em>
-<p>
-Also
-<p>
+<p>would be interpreted as: x equals the 3D grid named <em>a-b</em>
+<p>Also
x = 3107
</pre></div>
-<p>
-<p>
x = "3107"
</pre></div>
-<p>
-would copy the 3D grid <em>3107</em> to the 3D grid <em>x</em>.
+<p>would copy the 3D grid <em>3107</em> to the 3D grid <em>x</em>.
-<p>
-Quotes are not required unless the 3D grid names look like numbers or
+<p>Quotes are not required unless the 3D grid names look like numbers or
contain operators, OR unless the program is run non-interactively. Examples
given here assume the program is run interactively. See NOTES, below.
-<p>
-<em>r3.mapcalc</em> will look for the 3D grids according to the user's
+<p><em>r3.mapcalc</em> will look for the 3D grids according to the user's
current mapset search path. It is possible to override the search path
and specify the mapset from which to select the 3D grid. This is done by
specifying the 3D grid name in the form:
-<p>
name at mapset
</pre></div>
-<p>
-<p>
</pre></div>
-<p>
-The mapset specified does not have to be in the mapset search path. (This
+<p>The mapset specified does not have to be in the mapset search path. (This
method of overriding the mapset search path is common to all GRASS commands,
not just <em>r3.mapcalc</em>.)
<p>
<h2>THE NEIGHBORHOOD MODIFIER</h2>
3D grids are data base files stored in voxel format, i.e., three-dimensional
matrices of float/double values. In <em>r3.mapcalc</em>, 3D grids may be
@@ -205,7 +177,6 @@
<p>
<h2>FUNCTIONS</h2>
@@ -216,8 +187,7 @@
<em>*</em>
-<p>
@@ -283,12 +253,10 @@
-<p>
-<p>
@@ -335,42 +303,34 @@
</pre></div>
</ul>
-<p>
-<p>
C=A + if(isnull(B),0,B)
</pre></div>
-<p>
-<p>
if(x) = 0 if x = 0
</pre></div>
-<p>
</pre></div>
-<p>
</pre></div>
-<p>
@@ -385,8 +345,7 @@
used.
-<p>
NULL, e.g.:
@@ -395,8 +354,7 @@
</pre></div>
-<p>
0 respectively.
@@ -465,28 +423,23 @@
-<p>
-<p>
+<p>* ( ) > & |
</pre></div>
would be altered and <em>r3.mapcalc</em> would see something other than the *.
-<p>
-For formulas that the user enters from standard input (rather than from
+<p>For formulas that the user enters from standard input (rather than from
the command line), a line continuation feature now exists. If the user
adds \e to the end of an input line, <em>r3.mapcalc</em> assumes that the
There is no limit to the possible number of input lines or to the length
of a formula.
-<p>
-If the <em>r3.mapcalc</em> formula entered by the user is very long, the
+<p>If the <em>r3.mapcalc</em> formula entered by the user is very long, the
map title will contain only some of it, but most (if not all) of the formula
-<p>
@@ -496,18 +449,15 @@
continuation lines, the error messages produced by <em>r3.mapcalc</em> will
-<p>
Currently, there is no comment mechanism in <em>r3.mapcalc</em>. Perhaps
adding a capability that would cause the entire line to be ignored when
the user inserted a # at the start of a line as if it were not present,
would do the trick.
-<p>
-<p>
-r3.mapcalc does not print a warning in case of operations on NULL cells.
+<p>r3.mapcalc does not print a warning in case of operations on NULL cells.
@@ -520,8 +470,7 @@
1991)
-<p>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>
+<p><em><a href="r.mapcalc.html">r.mapcalc</a></em>
<h2>AUTHORS</h2>
@@ -529,5 +478,4 @@
<br><a href="mailto:tpaudits at mailbox.sk">tpaudits at mailbox.sk</a>,
<a href="MAILTO:hofierka at geomodel.sk">hofierka at geomodel.sk</a>
-<p>
Modified: grass/trunk/raster/r.mfilter/r.mfilter.html
--- grass/trunk/raster/r.mfilter/r.mfilter.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.mfilter/r.mfilter.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.mfilter.fp</em> filters the raster <em>input</em> to produce the
raster <em>output</em> according to the matrix <em>filter</em> designed
by the user (see <em>FILTERS</em> below).
@@ -15,13 +14,11 @@
the first filter will be changed. In most cases this will NOT be the
desired result. Hence -z should be used only with single step filters.
<p>
The <b>filter</b> parameter defines the name of an existing, user-created
UNIX ASCII file whose contents is a matrix defining the way in which the
<em>input</em> file will be filtered. The format of this file is described
below, under FILTERS.
<p>
The <b>repeat</b> parameter defines the number of times the <em>filter</em>
is to be applied to the <em>input</em> data.
@@ -68,20 +65,17 @@
<p>
Sequential filtering happens in place. As the filter is applied to the
raster map layer, the category values that were changed in neighboring
cells affect the resulting category value of the current
cell being filtered.
-<p>
-Parallel filtering happens in such a way that the original raster
+<p>Parallel filtering happens in such a way that the original raster
map layer category values are used to produce the new category value.
-<p>
-More than one filter may be specified in the filter file.
+<p>More than one filter may be specified in the filter file.
The additional filter(s) are described just like the first.
For example, the following describes two filters:
@@ -123,7 +117,6 @@
<p>
If more than one filter step is specified, either because the
repeat value was greater than one or because the filter file
contained more than one matrix, these steps are performed
@@ -153,5 +146,4 @@
Based upon r.mfilter, by Michael Shapiro,
-<p>
Modified: grass/trunk/raster/r.mode/r.mode.html
--- grass/trunk/raster/r.mode/r.mode.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.mode/r.mode.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,18 +5,15 @@
the same category value in the user-specified <em>base</em> raster map
layer. These modes are stored in the new <em>output</em> map layer.
-<p>
-The <em>output</em> map is actually a <em>reclass</em> of the <em>base</em>
+<p>The <em>output</em> map is actually a <em>reclass</em> of the <em>base</em>
map.
-<p>
-The <b>base</b> parameter defines an existing raster map layer in the user's
+<p>The <b>base</b> parameter defines an existing raster map layer in the user's
current mapset search path. For each group of cells assigned the same
category value in the <em>base</em> map, the mode of the values assigned
these cells in the <em>cover</em> map will be computed.
-<p>
-The <b>cover</b> parameter defines an existing raster map layer containing
+<p>The <b>cover</b> parameter defines an existing raster map layer containing
the values to be used to compute the mode within each category of the
<em>base</em> map.
@@ -29,8 +26,7 @@
map layer is only valid if the geographic region and mask settings are
the same as they were at the time that the result map was created.
-<p>
-Results are affected by the current region settings and mask.
+<p>Results are affected by the current region settings and mask.
<h2>EXAMPLE</h2>
Modified: grass/trunk/raster/r.neighbors/r.neighbors.html
--- grass/trunk/raster/r.neighbors/r.neighbors.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.neighbors/r.neighbors.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,7 +13,6 @@
<p>
The program will be run non-interactively if the user
specifies program arguments (see OPTIONS) on the command
line. Alternately, the user can simply type
@@ -28,15 +27,13 @@
<b>method</b> used to analyze neighborhood
values (i.e., the neighborhood function or operation to be
performed), and the <b>size</b> of the neighborhood.
-<p>
-The user can optionally
+<p>The user can optionally
specify a <b>selection</b> map, to compute new values only where the raster
cells of the selection map are not NULL. In case of a NULL cells,
the values from the input map are copied into the output map.
This may useful to smooth only parts of an elevation map (pits, peaks, ...).
-<p>
-<em>Example how to use a selection map with method=average:</em><br>
+<p><em>Example how to use a selection map with method=average:</em><br>
input map:
<pre>
1 1 1 1 1
@@ -70,15 +67,13 @@
1 1 1 1 1
</pre>
-<p>
-Optionally, the user can also specify the <b>TITLE</b> to
+<p>Optionally, the user can also specify the <b>TITLE</b> to
be assigned to the raster map layer <b>output</b>, elect
to not align the resolution of the output with that of the
input (the <b>-a</b> option), and run <em><b>r.neighbors</b></em>
with a custom matrix weights with the <em>weight</em> option.
These options are described further below.
<p>
<em>Neighborhood Operation Methods:</em>
The <b>neighborhood</b> operators determine what new
value a center cell in a neighborhood will have after examining
@@ -87,8 +82,7 @@
as the neighborhood window moves from cell to cell throughout the map layer.
<em><b>r.neighbors</b></em> can perform the following operations:
-<p>
-<dl>
+<p><dl>
<dt><b>average</b>
@@ -169,8 +163,7 @@
The result is rounded to the nearest integer (in this case 64).
</dl>
-<p>
-<br>
+<p><br>
<em>Neighborhood Size:</em>
The neighborhood <b>size</b> specifies which cells surrounding any given
@@ -185,7 +178,6 @@
</pre>
<p>
<em>Matrix weights:</em>
A custom matrix can be used if none of the neighborhood operation
methods are desirable by using the <b>weight</b>. This option must
@@ -216,7 +208,6 @@
</pre>
<p>
<h3>FLAGS</h3>
<dl>
<dt><b>-a</b>
@@ -229,14 +220,12 @@
By default, if unspecified,
<em><b>r.neighbors</b></em> will align these geographic region settings.
<p>
<dt><b>-c</b>
<dd>
This flag will use a circular neighborhood for the moving analysis window,
centered on the current cell.
-<p>
-The exact masks for the first few neighborhood sizes are as follows:
+<p>The exact masks for the first few neighborhood sizes are as follows:
3x3 . X . 5x5 . . X . . 7x7 . . . X . . .
X O X . X X X . . X X X X X .
@@ -271,11 +260,9 @@
original input and output resolutions which are not aligned by specifying
this (e.g., using the <b>-a</b> option).
<p>
<em><b>r.neighbors</b></em> doesn't propagate NULLs, but computes the
aggregate over the non-NULL cells in the neighborhood.
<p>
The <b>-c</b> flag and the <b>weights</b> parameter are mutually exclusive. Any
use of the two together will produce an error. Differently-shaped neighborhood
analysis windows may be achieved by using the <b>weight=</b> parameter to
@@ -284,13 +271,11 @@
that lies inside the neighborhood circle, effectively anti-aliasing the analysis
mask.
<p>
For aggregates where a weighted calculation isn't meaningful
(specifically: minimum, maximum, diversity and interspersion), the
weights are used to create a binary mask, where zero causes the cell
to be ignored and any non-zero value causes the cell to be used.
<p>
<em><b>r.neighbors</b></em> copies the GRASS <em>color</em> files associated with
the input raster map layer for those output map layers that are based
on the neighborhood average, median, mode, minimum, and maximum.
@@ -318,5 +303,4 @@
Michael Shapiro,
-<p>
Modified: grass/trunk/raster/r.null/r.null.html
--- grass/trunk/raster/r.null/r.null.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.null/r.null.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,17 +6,14 @@
converted to NULL). The module does not work with reclassified maps.
<p>
The design is flexible. Ranges of values can be set to NULL and/or the NULL
value can be eliminated and replace with a specified value.
<p>
The <b>setnull</b> parameter is used to specify values in the ranges to
be set to NULL. A range is either a single value (e.g., 5.3), or a pair of
values (e.g., 4.76-34.56). Existing NULL-values are left NULL, unless the
null argument is requested.
<p>
The <b>null</b> parameter eliminates the NULL value and replaces it with
value. This argument is applied only to existing NULL values, and not to the
NULLs created by the setnull argument.
@@ -36,8 +33,7 @@
<h2>NOTES</h2>
Note that value is restricted to integer if the map is an integer map.
-<p>
-<em>r.null</em> and reclassified maps:<br>
+<p><em>r.null</em> and reclassified maps:<br>
The problem is, if r.null was run on the reclass raster it would alter the
original and any other reclass rasters of the original. Therefore r.null
doesn't allow to recode reclassified maps (products of r.reclass).
Modified: grass/trunk/raster/r.out.arc/r.out.arc.html
--- grass/trunk/raster/r.out.arc/r.out.arc.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.arc/r.out.arc.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.out.arc</em> converts a user-specified raster map layer
(<b>input=</b><em>name</em>) into an ESRI ARC-GRID ascii file
(<b>output=</b><em>name</em>) suitable for export to other computer systems.
@@ -13,7 +12,6 @@
<p>
The GRASS program <em><a href="r.in.arc.html">r.in.arc</a></em> can be used
to perform the reverse function, converting an ESRI ARC-GRID ascii file in
suitable format to GRASS raster map format. The order of cell values in
@@ -36,14 +34,11 @@
Use the "Import to Raster" -> "ASCII to Grid" tool to create a binary grid
which can be selected using ArcCatalog. The spatial analyst extension may
need to be installed and activated within Arc.
-<p>
-In ArcGIS 9.0 the import tool can be found at:<br>
+<p>In ArcGIS 9.0 the import tool can be found at:<br>
ArcMap -> Toolbox -> Conversion Tools -> To Raster -> ASCII to Raster
-<p>
-A GeoTIFF created with <em><a href="r.out.gdal.html">r.out.gdal</a></em> is
+<p>A GeoTIFF created with <em><a href="r.out.gdal.html">r.out.gdal</a></em> is
sometimes a better solution for transferring raster maps to other GIS software.
-<p>
-<h2>SEE ALSO</h2>
+<p><h2>SEE ALSO</h2>
<em><a href="r.in.arc.html">r.in.arc</a></em><br>
<em><a href="r.out.gdal.html">r.out.gdal</a></em><br>
Modified: grass/trunk/raster/r.out.ascii/r.out.ascii.html
--- grass/trunk/raster/r.out.ascii/r.out.ascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.ascii/r.out.ascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,19 +6,15 @@
<p>
The GRASS program <em><a href="r.in.ascii.html">r.in.ascii</a></em> can be
used to perform the reverse function, converting an ASCII file in suitable
-<p>
-<!--With <b>-s</b> flag SURFER .grd ASCII GRID instead of GRASS ASCII GRID is
+<p><!--With <b>-s</b> flag SURFER .grd ASCII GRID instead of GRASS ASCII GRID is
written (with reverted row order, different header).
-<p>
-With <b>-m</b> flag MODFLOW (USGS) free-format array instead of GRASS ASCII
+<p>With <b>-m</b> flag MODFLOW (USGS) free-format array instead of GRASS ASCII
GRID is written.-->
-<p>
-To write a SURFER .grd ASCII GRID file (with reverted row order and different
+<p>To write a SURFER .grd ASCII GRID file (with reverted row order and different
header) use the <em>-s</em> flag:
@@ -39,8 +35,7 @@
The output file out.file can then be printed or copied onto a CDROM
or floppy disk for export purposes.
-<p>
-To export the raster values as x,y,z values of cell centers (one per line)
+<p>To export the raster values as x,y,z values of cell centers (one per line)
use the <em><a href="r.out.xyz.html">r.out.xyz</a></em> module.
<h2>SEE ALSO</h2>
@@ -56,8 +51,6 @@
<h2>AUTHOR</h2>
Michael Shapiro,
-<p>
-Surfer support by Markus Neteler
+<p>Surfer support by Markus Neteler
-<p>
Modified: grass/trunk/raster/r.out.bin/r.out.bin.html
--- grass/trunk/raster/r.out.bin/r.out.bin.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.bin/r.out.bin.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,8 +17,7 @@
grdinfo new.grd=1 (if float)
</pre></div>
-<p>
-Exported data can be piped directly into the GMT program xyz2grd.
+<p>Exported data can be piped directly into the GMT program xyz2grd.
r.out.bin input=grass.raster output=- | xyz2grd -R.... -ZTLf -
</pre></div>
Modified: grass/trunk/raster/r.out.gdal/r.out.gdal.html
--- grass/trunk/raster/r.out.gdal/r.out.gdal.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.gdal/r.out.gdal.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,23 +5,19 @@
exported for a particular application, the application's native format
would be preferrable. GeoTIFF is supported by a wide range of
applications (see also <b>NOTES</b> on GeoTIFF below).
-<p>
-To specify multiple creation options use a comma separated list
+<p>To specify multiple creation options use a comma separated list
(<em>createopt="TFW=YES,COMPRESS=DEFLATE"</em>).
-<p>
-For possible <em>createopt</em> and <em>metaopt</em> parameters please
+<p>For possible <em>createopt</em> and <em>metaopt</em> parameters please
consult the individual
<a href="http://www.gdal.org/formats_list.html">supported formats</a>
pages on the GDAL website.
The <em>createopt</em> parameter may be used to create TFW or World files
("TFW=YES","WORLDFILE=ON").
-<p>
-<em>r.out.gdal</em> also supports the export of multiband rasters as
+<p><em>r.out.gdal</em> also supports the export of multiband rasters as
a group, when the imagery group's name is entered as input.
(created imagery groups with the <em><a href="i.group.html">i.group</a></em>
module)
-<p>
-As with most GRASS raster modules, the current region extents and region
+<p>As with most GRASS raster modules, the current region extents and region
resolution are used, and a MASK is respected if present.
Use <em><a href="g.region.html">g.region</a></em>'s "align=", or "rast="
options if you need to realign the region settings to match the original
@@ -33,7 +29,6 @@
The set of <a href="http://www.gdal.org/formats_list.html">supported
raster formats</a> written by <em>r.out.gdal</em> depends on the
local GDAL installation. Available may be (incomplete list):<p>
<pre>
AAIGrid: Arc/Info ASCII Grid
BMP: MS Windows Device Independent Bitmap
@@ -63,8 +58,7 @@
<h2>NOTES</h2>
-<p>
-Out of the GDAL data types, the closest match for GRASS CELL, FCELL and
+<p>Out of the GDAL data types, the closest match for GRASS CELL, FCELL and
DCELL rasters are respectively Int32, Float32 and Float64. These are not
exact equivalents, but they will preserve the maximum possible data range
and number of decimal places for each respective GRASS raster data type.
@@ -93,26 +87,22 @@
Float64, CFloat64 -1.79E308 1.79E308
</pre>
-<p>
-If there is a need to keep file sizes small, use the simplest data type
+<p>If there is a need to keep file sizes small, use the simplest data type
covering the data range of the raster(s) to be exported, e.g., if suitable
use Byte rather than UInt16; use Int16 rather than Int32; or use Float32
rather than Float64. In addition, the COMPRESS <b>createopt</b> used can
have a very large impact on the size of the output file.
-<p>
-Some software may not recognize all of the compression methods
+<p>Some software may not recognize all of the compression methods
available for a given file format, and certain compression methods may
only be supported for certain data types (depends on vendor and version).
<!-- e.g. data destined for ESRI software should use COMPRESS=LZW/PACKBITS/DEFLATE ??? -->
-<p>
-If the export settings are set such that data loss would occur in the output
+<p>If the export settings are set such that data loss would occur in the output
file (i.e, due to the particular choice of data type and/or file type), the
normal behaviour of <em>r.out.gdal</em> in this case would be to issue an error
message describing the problem and exit without exporting. The <b>-f</b> flag
allows raster export even if some of the data loss tests are not passed, and
warnings are issued instead of errors.
-<p>
-<em>r.out.gdal</em> exports may appear all black or gray on initial
+<p><em>r.out.gdal</em> exports may appear all black or gray on initial
display in other GIS software. This is not a bug of <em>r.out.gdal</em>,
but often caused by the default color table assigned by that software.
The default color table may be grayscale covering the whole range of
@@ -128,15 +118,13 @@
properly read with GIS software only. Although GeoTIFF files usually
have a .tif extension, these files are not necessarily images but
first of all spatial raster datasets, e.g. SRTM DEM version 4.
-<p>
-When writing out multi-band GeoTIFF images for users of ESRI software or
+<p>When writing out multi-band GeoTIFF images for users of ESRI software or
ImageMagick, the interleaving mode should be set to "pixel" using
<em>createopt="INTERLEAVE=PIXEL"</em>. BAND interleaving is slightly more
efficient, but not supported by some applications.
<!-- GDAL switched default from BAND to PIXEL interleave on 08/01/07 (r11823) -->
This issue only arises when writing out multi-band imagery groups.
<p>
<h3>Improving GeoTIFF compatibility</h3>
To create a GeoTIFF that is highly compatible with various other GIS
@@ -145,8 +133,7 @@
software is compatible with, as this varies widely between vendors and
versions. Long term, the less metadata you have to remove the more
self-documenting (and useful) the dataset will be.
-<p>
-Here are some things to try:
+<p>Here are some things to try:
<ul>
<li>Create a World file with <tt>createopt="TFW=YES"</tt>.
@@ -180,20 +167,17 @@
r.out.gdal input=roads output=roads.tif type=UInt16
</pre></div>
<p>
<h3>Export a DCELL raster map in GeoTIFF format suitable for ESRI software:</h3>
r.out.gdal in=elevation.10m out=ned_elev10m.tif type=Float64 createopt="PROFILE=GeoTIFF,TFW=YES"
</pre></div>
<p>
<h3>Export R,G,B imagery bands in GeoTIFF format suitable for ESRI software:</h3>
i.group group=nc_landsat_rgb input=lsat7_2002_30,lsat7_2002_20,lsat7_2002_10
r.out.gdal in=nc_landsat_rgb out=nc_landsat_rgb.tif type=Byte createopt="PROFILE=GeoTIFF,INTERLEAVE=PIXEL,TFW=YES"
</pre></div>
<p>
<h3>Export the floating point raster elevation map to ERDAS/IMG format:</h3>
r.out.gdal input=elevation.10m output=elev_dem10.img format=HFA type=Float32
@@ -254,5 +238,4 @@
Vytautas Vebra (oliver4grass at gmail.com)<br>
Markus Metz (improved nodata logic)
-<p>
Modified: grass/trunk/raster/r.out.gridatb/r.out.gridatb.html
--- grass/trunk/raster/r.out.gridatb/r.out.gridatb.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.gridatb/r.out.gridatb.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.out.gridatb</em> exports a GRASS raster map to GRIDATB.FOR map file
(TOPMODEL)
Modified: grass/trunk/raster/r.out.mpeg/r.out.mpeg.html
--- grass/trunk/raster/r.out.mpeg/r.out.mpeg.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.mpeg/r.out.mpeg.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,8 +8,7 @@
viewing program.
MPEG-2 and MPEG-4 provide much better quality animations.
-<p>
-The user may define up to four "views", or sub-windows, to animate
+<p>The user may define up to four "views", or sub-windows, to animate
simultaneously. e.g., View 1 could be rainfall, View 2 flooded areas, View
3 damage to bridges or levees, View 4 other economic damage, all animated as
a time series. A black border 2 pixels wide is drawn around each view. There
@@ -18,8 +17,7 @@
tmp space could also limit the number of frames you are able to convert.
<!-- flag to keep these to feed into another more modern encoder? -->
-<p>
-The environment variable GMPEG_SIZE is checked for a value to use as the
+<p>The environment variable GMPEG_SIZE is checked for a value to use as the
dimension, in pixels, of the longest dimension of the animation image. If
GMPEG_SIZE is not set, the animation size defaults to the rows & columns
in the current GRASS region, scaling if necessary to a default minimum size
@@ -29,8 +27,7 @@
compressed data "on-the-fly", therefore smaller dimensioned animations will
provide higher frame rates and smoother animations.
-<p>
-UNIX - style wild cards may be used with the command line version in place
+<p>UNIX - style wild cards may be used with the command line version in place
of a raster map name, but wild cards must be quoted.
<h2>Example:</h2>
@@ -38,20 +35,17 @@
r.out.mpeg view1="rain[1-9]","rain1[0-2]" view2="temp*"
</pre></div>
-<p>
-If the number of files differs for each view, the view with the fewest files
+<p>If the number of files differs for each view, the view with the fewest files
will determine the number of frames in the animation.
-<p>
-With <b>-c</b> flag the module converts "on the fly", uses less disk space
+<p>With <b>-c</b> flag the module converts "on the fly", uses less disk space
by using <em>r.out.ppm</em> with stdout option to convert frames as needed
instead of converting all frames to ppm before encoding. Only use when
encoding a single view. Use of this option also overrides any size
defaults, using the <b>CURRENTLY DEFINED GRASS REGION for the output size</b>.
So be careful to set region to a reasonable size prior to encoding.
-<p>
-A quality value of <em>qual=1</em> will yield higher quality images, but
+<p>A quality value of <em>qual=1</em> will yield higher quality images, but
with less compression (larger MPEG file size). Compression ratios will vary
depending on the number of frames in the animation, but an MPEG produced
using <em>qual=5</em> will usually be about 60% the size of the MPEG
@@ -67,28 +61,23 @@
<h2>NOTES</h2>
This program requires the program <em>mpeg_encode</em> (aka <em>ppmtompeg</em>):
-<p>
-MPEG-1 Video Software Encoder<br>
+<p>MPEG-1 Video Software Encoder<br>
(Version 1.3; March 14, 1994)
-<p>
-Lawrence A. Rowe, Kevin Gong, Ketan Patel, and Dan Wallach Computer Science
+<p>Lawrence A. Rowe, Kevin Gong, Ketan Patel, and Dan Wallach Computer Science
Division-EECS, Univ. of Calif. at Berkeley
-<p>
-Available from Berkeley:
+<p>Available from Berkeley:
<a href="http://bmrc.berkeley.edu/frame/research/mpeg/mpeg_encode.html">http://bmrc.berkeley.edu/frame/research/mpeg/mpeg_encode.html</a>
<br>or as part of the netpbm package (<em>ppmtompeg</em>):
<a href="http://netpbm.sourceforge.net">http://netpbm.sourceforge.net</a>
-<p>
-Playback may be done with many viewers; <em>mpeg_encode</em>'s official companion
+<p>Playback may be done with many viewers; <em>mpeg_encode</em>'s official companion
is <em>mpeg_play</em> available from Berkeley at
<a href="ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/play/">ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/play/</a>
or a precompiled Debian package from
<a href="http://packages.debian.org/ucbmpeg-play">http://packages.debian.org/ucbmpeg-play</a>
(includes maintained source code).
-<p>
-Use of the <em>-c</em> flag requires the <em>r.out.ppm</em> GRASS module
+<p>Use of the <em>-c</em> flag requires the <em>r.out.ppm</em> GRASS module
with the <em>stdout</em> option.
Modified: grass/trunk/raster/r.out.png/r.out.png.html
--- grass/trunk/raster/r.out.png/r.out.png.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.png/r.out.png.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>r.out.png</em> exports a GRASS raster map in non-georeferenced PNG image
format, respecting the current region resolution and bounds.
-<p>
-Optionally the user can choose to export a World File to provide basic
+<p>Optionally the user can choose to export a World File to provide basic
georeferencing support. When used with the transparency flag this can
create images useful for KML, TMS, or WMS overlays. (e.g. for use in
Google Earth or as OpenLayers tiles) If output is to stdout, the world
@@ -26,5 +25,4 @@
Alex Shevlakov<br>
Hamish Bowman
-<p>
Modified: grass/trunk/raster/r.out.pov/r.out.pov.html
--- grass/trunk/raster/r.out.pov/r.out.pov.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.pov/r.out.pov.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -16,8 +16,7 @@
<h2>EXAMPLE</h2>
An example Povray script file may look like this:
-<p>
#include "shapes.inc"
#include "colors.inc"
#include "textures.inc"
Modified: grass/trunk/raster/r.out.ppm/r.out.ppm.html
--- grass/trunk/raster/r.out.ppm/r.out.ppm.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.ppm/r.out.ppm.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,26 +3,21 @@
<em>r.out.ppm</em> converts a GRASS raster map into a PPM image
at the pixel resolution of the CURRENTLY DEFINED REGION.
To get the resolution and region settings of the raster map, run:<p>
g.region -p rast=[mapname]
</pre></div>
<p>
before running <em>r.out.ppm</em>.<p>
By default the PPM file created is 24-bit color, rawbits storage.
You can use the <b>-g</b> flag to force <em>r.out.ppm</em> to
output an 8-bit greyscale instead.
The greyscale conversion uses the NTSC conversion:<p>
Y = .30*Red + .59*Green + .11*Blue
</pre></div>
-<p>
-One pixel is written for each cell value, so if <tt>ew_res</tt> and
+<p>One pixel is written for each cell value, so if <tt>ew_res</tt> and
<tt>ns_res</tt> differ, the aspect ratio of the resulting image will be off.
Modified: grass/trunk/raster/r.out.ppm3/r.out.ppm3.html
--- grass/trunk/raster/r.out.ppm3/r.out.ppm3.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.ppm3/r.out.ppm3.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,12 +3,10 @@
<b>r.out.ppm3</b> converts 3 GRASS raster layers (R,G,B) to a PPM
image file, using the current region.
-<p>
-This program converts a GRASS raster map to a PPM image file
+<p>This program converts a GRASS raster map to a PPM image file
using the the current region settings.
-<p>
-To get the full area and resolutin of the raster map, run:
+<p>To get the full area and resolutin of the raster map, run:
g.region rast=[mapname]
Modified: grass/trunk/raster/r.out.tiff/r.out.tiff.html
--- grass/trunk/raster/r.out.tiff/r.out.tiff.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.tiff/r.out.tiff.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,30 +4,25 @@
be 8 or 24 bit (TrueColor). Optionally, a TIFF World file compatible with
ESRI's and other's products may be output.
-<p>
-The program prompts the user for the name of a GRASS raster map, an output
+<p>The program prompts the user for the name of a GRASS raster map, an output
TIFF file, whether an 8 or 24 bit format is desired, and whether or not to
create a TIFF world file. Currently only uncompressed, packpit, or deflate
TIFF files are written. These output formats are known to be compatible
with r.in.tiff.
-<p>
-The output filename will always have the suffix <code>.tif</code>, and the Tiff World
+<p>The output filename will always have the suffix <code>.tif</code>, and the Tiff World
file (if requested) <code>.tfw</code>. Any <code>.tif</code> or
<code>.tiff</code> suffix (case insensitive) specified in the output filename
will be discarded.
-<p>
-When writing with "-l" option, tiles are written at 128x128 pixels. For
+<p>When writing with "-l" option, tiles are written at 128x128 pixels. For
programs that can utilize tiles, it can help speed up some drawing
operations.
-<p>
-The user may adjust region and resolution before export using
+<p>The user may adjust region and resolution before export using
<a href="g.region.html">g.region</a>.
-<p>
-A better choice to export GRASS raster data might be
+<p>A better choice to export GRASS raster data might be
<a href="r.out.gdal.html">r.out.gdal</a>.
<h2>SEE ALSO</h2>
@@ -39,7 +34,6 @@
<h2>AUTHOR</h2>
Michael Shapiro,
-<p>
-GRASS 5.0 team
+<p>GRASS 5.0 team
Modified: grass/trunk/raster/r.out.vrml/r.out.vrml.html
--- grass/trunk/raster/r.out.vrml/r.out.vrml.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.out.vrml/r.out.vrml.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,8 +2,7 @@
This module exports a GRASS raster map to the Virtual Reality Modeling
Language (VRML) format for 3D visualization.
-<p>
-This version only outputs raster maps in VRML 1.0 format.
+<p>This version only outputs raster maps in VRML 1.0 format.
The newer VRML 2.0 format will be more efficient for geographic
applications, as it introduces an "ElevationGrid" node so that
only the elevation points will have to be written instead
@@ -24,12 +23,10 @@
is ascii text, gzip works very well to significantly compress file
size.<p>
<h2>NOTE</h2>
This is a preliminary release of "<em>r.out.vrml</em>".
-For further information about VRML and available viewers for various platforms, see:<p>
-<a href="http://www.w3.org/MarkUp/VRML/">VRML Virtual Reality Modeling Language</a>
+For further information about VRML and available viewers for various platforms, see:<p><a href="http://www.w3.org/MarkUp/VRML/">VRML Virtual Reality Modeling Language</a>
<h2>BUGS:</h2>
@@ -47,13 +44,11 @@
<a href="http://www.web3d.org">X3D format</a>.
See also the <a href="http://www.xj3d.org">Xj3D project</a>.
-<p>
-Future plans for this module are to allow draping of sites objects and
+<p>Future plans for this module are to allow draping of sites objects and
vector maps and using the new sites format available in floating
point GRASS to embed WWW links into site objects. It will also be
upgraded to support VRML 2.0 and will allow entering multiple preset
"views" using the existing GRASS 3d_view file format.<p>
Other possible additions:
<ul>
<li> Allow animation of elevation, color, or sites based on
@@ -65,5 +60,4 @@
<h2>AUTHOR</h2>
Bill Brown, US Army Construction Engineering Research Laboratory
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.param.scale/r.param.scale.html
--- grass/trunk/raster/r.param.scale/r.param.scale.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.param.scale/r.param.scale.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,8 +4,7 @@
multi-scale approach by fitting a bivariate quadratic polynomial to a given
window size using least squares.
-<p>
-The module calculates the following parameters (terminology is from Wood,
+<p>The module calculates the following parameters (terminology is from Wood,
1996 with related terminology used in other GRASS modules listed in
brackets):
<ul>
@@ -83,8 +82,7 @@
r.param.scale in=elevation.10m output=morphology param=feature size=9
</pre></div>
-<p>
-<center>
+<p><center>
<img src="r_param_scale_morph.jpg" alt="r.param.scale generated geomorphological map"><br>
<i>Geomorphological map of a subregion in the Spearfish (SD) area</i>
</center>
Modified: grass/trunk/raster/r.patch/r.patch.html
--- grass/trunk/raster/r.patch/r.patch.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.patch/r.patch.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,8 +14,7 @@
digital elevation data), or for updating an older map layer with more recent
data. The current geographic region definition and mask settings are
respected.
-<p>
-The first <em>name</em> listed in the string
+<p>The first <em>name</em> listed in the string
<b>input=</b><em>name</em>,<em>name</em>,<em>name</em>, ... is the name of
the first map whose data values will be used to fill in "no data" cells
in the current region. The second through last input <em>name</em>
@@ -56,8 +55,7 @@
<em><a href="v.mkgrid.html">v.mkgrid</a></em> can be used to make adjacent
maps align neatly.
-<p>
-The user should check the current geographic region settings before running
+<p>The user should check the current geographic region settings before running
<em>r.patch</em>, to ensure that the region boundaries encompass all
of the data desired to be included in the composite map and to ensure that the
region resolution is the resolution of the desired data. To set the
@@ -69,7 +67,6 @@
</pre></div>
<p>
Use of <em>r.patch</em> is generally followed by use of the GRASS programs
<em><a href="g.remove.html">g.remove</a></em> and
<em><a href="g.rename.html">g.rename</a></em>;
@@ -78,8 +75,7 @@
composite (patched) raster map layer the name of the original raster map
layer.
-<p>
-<em>r.patch</em> creates support files for the patched, composite output map.
+<p><em>r.patch</em> creates support files for the patched, composite output map.
<h2>EXAMPLE</h2>
Modified: grass/trunk/raster/r.profile/r.profile.html
--- grass/trunk/raster/r.profile/r.profile.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.profile/r.profile.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -9,22 +9,18 @@
<b>-i</b> flag. The profile resolution, or distance between profile
points, is obtained from the current region resolution, or can be manually
set with the <b>res</b> argument.
-<p>
-The <b>-i</b> flag allows the user for selecting the profile from the GRASS
+<p>The <b>-i</b> flag allows the user for selecting the profile from the GRASS
monitor by clicking the left mouse button along the profile; clicking the
right mouse button ends the profile.
-<p>
-The <b>profile</b> parameter can be set to comma separated geographic
+<p>The <b>profile</b> parameter can be set to comma separated geographic
coordinates for profile line endpoints. The interactive flag (<b>-i</b>)
overrides this option. Alternatively the coordinate pairs can be piped
from stdin, one comma separated pair per line.
-<p>
-The <b>res</b> parameter sets the distance between each profile point
+<p>The <b>res</b> parameter sets the distance between each profile point
(resolution). The resolution must be provided in GRASS database units (i.e.
decimal degrees for Lat Long databases and meters for UTM). By default
<em>r.profile</em> uses the resolution of the current GRASS region.
-<p>
-The <b>null</b> parameter can optionally be set to change the character
+<p>The <b>null</b> parameter can optionally be set to change the character
string representing null values.
<h2>OUTPUT FORMAT</h2>
@@ -40,8 +36,7 @@
</pre></div>
The 2 column output is compatible with most plotting programs.
-<p>
-The optional RGB output provides the associated GRASS colour value for
+<p>The optional RGB output provides the associated GRASS colour value for
each profile point.
<h2>EXAMPLES</h2>
@@ -71,8 +66,7 @@
<b>Example 3</b><br>
Extract a profile with coordinates provided from standard input or an external file:
-<p>
-First create a points file with <em><a href="d.where.html">d.where</a></em>
+<p>First create a points file with <em><a href="d.where.html">d.where</a></em>
d.where > saved.points
@@ -86,11 +80,9 @@
The advantage of this method is that the same profile points can be piped into
different GRASS rasters by changing the input parameter.
-<p>
-With this method the coordinates must be given as space or tab separated easting
+<p>With this method the coordinates must be given as space or tab separated easting
and northing. Labels after these values are ignored.
-<p>
-Another example using d.where:
+<p>Another example using d.where:
d.where | r.profile elevation.dem
@@ -122,8 +114,7 @@
exact multiple of the profile resolution and will therefore not always match
the end point coordinates entered for the segmanet.
-<p>
-To extract the numbers in scripts, following parameters can be used:
+<p>To extract the numbers in scripts, following parameters can be used:
r.profile input=dgm12.5 profile=3570631,5763556 2>/dev/null
</pre></div>
@@ -142,5 +133,4 @@
<h2>AUTHOR</h2>
<a href="mailto:bcovill at tekmap.ns.ca">Bob Covill</a>
-<p>
Modified: grass/trunk/raster/r.proj/r.proj.html
--- grass/trunk/raster/r.proj/r.proj.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.proj/r.proj.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,8 +17,7 @@
including cylindrical and pseudo-cylindrical, conic and pseudo-conic,
and azimuthal methods, each of which may be conformal, equal-area, or
neither.
-<p>
-The particular projection chosen depends on the purpose of the
+<p>The particular projection chosen depends on the purpose of the
project, and the size, shape and location of the area of interest.
For example, normal cylindrical projections are good for maps which
are of greater extent east-west than north-south and in equatorial
@@ -30,8 +29,7 @@
better preserve arc-length, while equal-area projections are more
appropriate for statistical studies and work in which the amount of
material is important.
-<p>
-Projections are defined by precise mathematical relations, so the
+<p>Projections are defined by precise mathematical relations, so the
method of projecting coordinates from a geographic reference frame
(latitude-longitude) into a projected cartesian reference frame (eg
metres) is governed by these equations. Inverse projections can also
@@ -40,16 +38,14 @@
manual contains a detailed description of over 100 useful projections.
This also includes a programmers library of the projection methods to
support other software development.
-<p>
-Thus, converting a vector map - in which objects are located with
+<p>Thus, converting a vector map - in which objects are located with
arbitrary spatial precision - from one projection into another is
usually accomplished by a simple two-step process: first the location
of all the points in the map are converted from the source through an
inverse projection into latitude-longitude, and then through a forward
projection into the target. (Of course the procedure will be one-step
if either the source or target is in geographic coordinates.)
-<p>
-Converting a raster map, or image, between different projections,
+<p>Converting a raster map, or image, between different projections,
however, involves additional considerations. A raster may be
considered to represent a sampling of a process at a regular, ordered
set of locations. The set of locations that lie at the intersections
@@ -64,8 +60,7 @@
GIS data capture, import and transfer often requires a projection
step, since the source or client will frequently be in a different
projection to the working projection.
-<p>
-In some cases it is convenient to do the conversion outside the
+<p>In some cases it is convenient to do the conversion outside the
package, prior to import or after export, using software such
as <i>PROJ.4</i>'s
<em><a href="http://proj.maptools.org/">cs2cs</a></em> [1]. This is an easy
@@ -74,8 +69,7 @@
process simple lists using a one-line command. The <em>m.proj</em> module
provides a handy front end to <tt>cs2cs</tt>.
-<p>
-Vector maps is generally more complex, as parts of the data stored in
+<p>Vector maps is generally more complex, as parts of the data stored in
the files will describe topology, and not just coordinates. In GRASS
GIS the
<em><a href="v.proj.html">v.proj</a></em> module is provided to reproject
@@ -90,14 +84,12 @@
raster is resampling the source grid at locations corresponding to the
intersections of a grid in the target projection. The basic procedure
for accomplishing this, therefore, is as follows:
-<p>
-<em>r.proj</em> converts a map to a new geographic projection. It
+<p><em>r.proj</em> converts a map to a new geographic projection. It
reads a map from a different location, projects it and write it out to
the current location. The projected data is resampled with one of four
different methods: nearest neighbor, bilinear, cubic convolution or
lanczos.
-<p>
-The <b>method=nearest</b> method, which performs a nearest neighbor
+<p>The <b>method=nearest</b> method, which performs a nearest neighbor
assignment, is the fastest of the three resampling methods. It is
primarily used for categorical data such as a land use classification,
since it will not change the values of the data
@@ -111,14 +103,12 @@
cubic, lanczos puts a higher weight on cells close to the center and a
lower weight on cells away from the center, resulting in slightly
better contrast.
-<p>
-The bilinear, cubic and lanczos interpolation methods are most
+<p>The bilinear, cubic and lanczos interpolation methods are most
appropriate for continuous data and cause some smoothing. The amount
of smoothing decreases from bilinear to cubic to lanczos. These
options should not be used with categorical data, since the cell
values will be altered.
-<p>
-In the bilinear, cubic and lanczos methods, if any of the surrounding
+<p>In the bilinear, cubic and lanczos methods, if any of the surrounding
cells used to interpolate the new cell value are null, the resulting
cell will be null, even if the nearest cell is not null. This will
cause some thinning along null borders, such as the coasts of land
@@ -127,12 +117,10 @@
These methods "fall back" to simpler interpolation methods
along null borders. That is, from lanczos to cubic to bilinear to
nearest.
-<p>
-If nearest neighbor assignment is used, the output map has the same
+<p>If nearest neighbor assignment is used, the output map has the same
raster format as the input map. If any of the interpolations is used,
the output map is written as floating point.
-<p>
-Note that, following normal GRASS conventions, the coverage and
+<p>Note that, following normal GRASS conventions, the coverage and
resolution of the resulting grid is set by the current region
settings, which may be adjusted
using <em><a href="g.region.html">g.region</a></em>. The target raster
@@ -144,8 +132,7 @@
different for categorical versus numerical data. Note that three
methods for the local interpolation step are provided.
-<p>
-<em>r.proj</em> supports general datum transformations, making use of
+<p><em>r.proj</em> supports general datum transformations, making use of
the <em>PROJ.4</em> co-ordinate system translation library.
<h2>NOTES</h2>
@@ -154,8 +141,7 @@
and resolution of the target location should be set appropriately
beforehand.
-<p>
-A simple way to do this is to check the projected bounds of the input
+<p>A simple way to do this is to check the projected bounds of the input
map in the current location's projection using the <b>-p</b>
flag. The <b>-g</b> flag reports the same thing, but in a form which
can be directly cut and pasted into
@@ -166,8 +152,7 @@
flag. E.g.
<tt>g.region -a res=5 -p</tt>. Note that this is just a rough guide.
-<p>
-A more involved, but more accurate, way to do this is to generate a
+<p>A more involved, but more accurate, way to do this is to generate a
vector "box" map of the region in the source location using
<em><a href="v.in.region.html">v.in.region</a></em>.
This "box" map is then reprojected into the target location with
@@ -179,8 +164,7 @@
pixel).
<em>r.proj</em> is then run for the raster map the user wants to
reproject. In this case a little preparation goes a long way.
-<p>
-When reprojecting whole-world maps the user should disable
+<p>When reprojecting whole-world maps the user should disable
map-trimming with the <b>-n</b> flag. Trimming is not useful here
because the module has the whole map in memory anyway. Besides that,
world "edges" are hard (or impossible) to find in projections other
@@ -283,12 +267,10 @@
Springer-Verlag, Berlin, 2nd edition.
</ol>
-<p>
-<a href="http://proj.osgeo.org">PROJ.4</a>: Projection/datum support
+<p><a href="http://proj.osgeo.org">PROJ.4</a>: Projection/datum support
library.
-<p>
- <b>Further reading</b>
+<p> <b>Further reading</b>
<ul>
<li> <a href="http://www.asprs.org/resources/grids/">ASPRS Grids and Datum</a>
<li> <a href="http://www.remotesensing.org/geotiff/proj_list/">Projections Transform List</a> (PROJ.4)
@@ -310,8 +292,7 @@
<a href="v.proj.html">v.proj</a>,
</em>
-<p>
-The 'gdalwarp' and 'gdal_translate' utilities are available from the
+<p>The 'gdalwarp' and 'gdal_translate' utilities are available from the
<a href="http://www.gdal.org">GDAL</a> project.
<h2>AUTHORS</h2>
@@ -321,5 +302,4 @@
Updated by <a href="mailto:morten at untamo.net">Morten Hulden</a><br>
Datum tranformation support and cleanup by Paul Kelly
-<p>
Modified: grass/trunk/raster/r.quant/r.quant.html
--- grass/trunk/raster/r.quant/r.quant.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.quant/r.quant.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,7 +2,6 @@
<em>r.quant</em> produces the quantization file for a floating-point map.
<p>
The <em>map</em> parameter defines the map for which the rules are to be
created. If more than one map is specified, then this implies that the
floating-point range is the miniumum and maximum of all the maps together,
@@ -11,11 +10,8 @@
<h3> Quant rules </h3>
The quant rules have to be entered interactively.
-<p>
-If rules is specified, the input has the form: <p>
+<p>If rules is specified, the input has the form: <p>
value1:value2:cat1:[cat2] <p>
where value1 and value2 are floating point values and cat1 cand cat2 are
integers. If cat2 is missing, it is taken to be equal to cat1. All values
can be "*" which means infinity.
Modified: grass/trunk/raster/r.quantile/r.quantile.html
--- grass/trunk/raster/r.quantile/r.quantile.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.quantile/r.quantile.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -22,5 +22,4 @@
<h2>AUTHOR</h2>
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.random/r.random.html
--- grass/trunk/raster/r.random/r.random.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.random/r.random.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<h2>DESCRIPTION</h2>
-<p>
-The program <em>r.random</em> allows the user to create a
+<p>The program <em>r.random</em> allows the user to create a
raster map layer and/or a vector points map containing
coordinates of points whose locations have been randomly
determined. The program locates these randomly generated
@@ -10,8 +9,7 @@
<b>-z</b> flag, points will be randomly generated across all
cells (even those with NULL values).
-<p>
-The category values and
+<p>The category values and
corresponding category names already associated with the
random point locations in the <em>input</em> map layer are
assigned to these points in the <em>raster_output</em> map
@@ -21,13 +19,11 @@
<em>input</em> raster and is given a medium gray color.
<h2>NOTES</h2>
-<p>
-If a <em>cover</em> raster map is specified and the <em>cover</em> map
+<p>If a <em>cover</em> raster map is specified and the <em>cover</em> map
contains NULL (no data) values, these points are suppressed in the
resulting <em>vector_output</em> or <em>raster_output</em> map.
-<p>
-The <em>vector_output</em> file created by <em>r.random</em>
+<p>The <em>vector_output</em> file created by <em>r.random</em>
contains vector points that represent the <em>center points</em> of the
randomly generated cells. A <em>value</em> attribute contains the cell value
of the <em>input</em> raster (or the assigned value
@@ -36,13 +32,11 @@
column <em>covervalue</em> is populated with raster values from
the <em>cover</em> map.
-<p>
-If the user sets the <b>-b</b> flag, vector points are written without
+<p>If the user sets the <b>-b</b> flag, vector points are written without
topology to minimize the required resources. This is suitable input
to <em>v.surf.rst</em> and other vector modules.
-<p>
-The user may specify the quantity of random locations to be
+<p>The user may specify the quantity of random locations to be
generated either as a <em>positive integer</em> (e.g., 10),
or as a <em>percentage of the raster map layer's cells</em>
(e.g., 10%, or 3.05%). The number of cells considered for
@@ -50,8 +44,7 @@
was given. Options are 0-100; percentages less than
one percent may be stated as decimals.
-<p>
-Flag <b>-i</b> prints the raster map's name and location,
+<p>Flag <b>-i</b> prints the raster map's name and location,
the total number of cells under the current region settings, and
the number of NULL valued cells under the current region settings.
Then module exits without doing anything. Useful for deciding on the number
@@ -65,8 +58,7 @@
r.report map=inputmap units=c null=* nsteps=1
</pre></div>
-<p>
-To create random vector point locations within some, but not all,
+<p>To create random vector point locations within some, but not all,
non-zero categories of the input raster map layer,
the user must first create a reclassified raster map layer
of the original raster map layer (e.g., using the GRASS
@@ -75,8 +67,7 @@
and then use the reclassed raster map layer as input to <em>r.random</em>.
<h2>EXAMPLES</h2>
-<p>
-Random vector elevation points sampled from elevation map in the
+<p>Random vector elevation points sampled from elevation map in the
Spearfish region, result stored in 2D vector map:
@@ -87,8 +78,7 @@
</pre></div>
-<p>
Spearfish region with collocated values sampled from landuse map,
result stored in 3D vector map:
@@ -126,10 +116,7 @@
Dr. James Hinthorne,
GIS Laboratory,
Central Washington University
-<p>
-Modified for GRASS 5.0 by Eric G. Miller
-<p>
-Cover map support by Markus Neteler, 2007
+<p>Modified for GRASS 5.0 by Eric G. Miller
+<p>Cover map support by Markus Neteler, 2007
-<p>
Modified: grass/trunk/raster/r.random.cells/r.random.cells.html
--- grass/trunk/raster/r.random.cells/r.random.cells.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.random.cells/r.random.cells.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -41,8 +41,7 @@
<h2>REFERENCES</h2>
Random Field Software for GRASS by Chuck Ehlschlaeger
-<p>
- As part of my dissertation, I put together several programs that help
+<p> As part of my dissertation, I put together several programs that help
GRASS (4.1 and beyond) develop uncertainty models of spatial data. I hope
you find it useful and dependable. The following papers might clarify their
use:
@@ -87,5 +86,4 @@
Charles Ehlschlaeger; National Center for Geographic Information and
Analysis, University of California, Santa Barbara.
-<p>
Modified: grass/trunk/raster/r.random.surface/r.random.surface.html
--- grass/trunk/raster/r.random.surface/r.random.surface.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.random.surface/r.random.surface.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,16 +13,14 @@
large map is 0.0 and a variance of 1.0. Description of the algorithm is in
the <b>NOTES</b> section.
-<p>
-The random surface generated are composed of floating point numbers, and
+<p>The random surface generated are composed of floating point numbers, and
saved in the category description files of the output map(s). Cell values
are uniformly or normally distributed between 1 and high values inclusive
(determined by whether the <b>-u</b> flag is used). The category names
indicate the average floating point value and the range of floating point
values that each cell value represents.
-<p>
-<em>r.random.surface's</em> original goal is to generate random fields for
+<p><em>r.random.surface's</em> original goal is to generate random fields for
spatial error modeling. A procedure to use <em>r.random.surface</em> in
spatial error modeling is given in the <b>NOTES</b> section.
@@ -96,8 +94,7 @@
While most literature uses the term random field instead of random surface,
this algorithm always generates a surface. Thus, its use of random surface.
-<p>
-<em>r.random.surface</em> builds the random surface using a filter algorithm
+<p><em>r.random.surface</em> builds the random surface using a filter algorithm
smoothing a map of independent random deviates. The size of the filter is
determined by the largest distance of spatial dependence. The shape of the
filter is determined by the distance decay exponent(s), and the various
@@ -107,16 +104,14 @@
reduction of degrees of freedom. The map of independent random deviates will
ignore the current mask for the same reason.
-<p>
-One of the most important uses for <em>r.random.surface</em> is to determine
+<p>One of the most important uses for <em>r.random.surface</em> is to determine
how the error inherent in raster maps might effect the analyses done with
those maps.
<h2>REFERENCES</h2>
-<p>
use:
@@ -159,5 +154,4 @@
for Geographic Information and Analysis, University of California, Santa
Barbara.
-<p>
Modified: grass/trunk/raster/r.reclass/r.reclass.html
--- grass/trunk/raster/r.reclass/r.reclass.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.reclass/r.reclass.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,13 +8,11 @@
treated. A <em>TITLE</em> for the output map layer may be
(optionally) specified by the user.
-<p>
-The reclass rules are read from standard input (i.e., from
+<p>The reclass rules are read from standard input (i.e., from
the keyboard, redirected from a file, or piped through
another program).
-<p>
-Before using <em>r.reclass</em> the user must know the following:
+<p>Before using <em>r.reclass</em> the user must know the following:
<ol>
<li>The new categories desired; and, which old categories fit into
@@ -31,14 +29,12 @@
is requested. As far as the user (and programmer) is concerned, that
raster map has been created.
-<p>
-<em>r.reclass</em> only works on an <i>integer</i> input raster map; if the
+<p><em>r.reclass</em> only works on an <i>integer</i> input raster map; if the
input map is instead floating point data, you must multiply the input data by some
factor to acheive whole number input data, otherwise <em>r.reclass</em> will round
the raster values down to the next integer.
-<p>
-Also note that although the user can generate a <em>r.reclass</em> map
+<p>Also note that although the user can generate a <em>r.reclass</em> map
which is based on another <em>r.reclass</em> map,
the new <em>r.reclass</em> map map will be stored in GRASS as a reclass
of the <em>original</em> raster map on which the first reclassed map was
@@ -48,15 +44,13 @@
(i.e., <em>reclass table</em>) will ever be <em>stored</em>
as a <em>r.reclass</em> of a <em>r.reclass</em>.
-<p>
-To convert a reclass map to a regular raster map layer, set your
+<p>To convert a reclass map to a regular raster map layer, set your
geographic region settings to match the settings in the header for the
reclass map (with "<tt>g.region rast=reclass_map</tt>", or
viewable by running <em><a href="r.info.html">r.info</a></em>)
and then run <em><a href="r.resample.html">r.resample</a></em>.
-<p>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em> can be used to convert
+<p><em><a href="r.mapcalc.html">r.mapcalc</a></em> can be used to convert
a reclass map to a regular raster map layer as well:
<div class="code"><pre>
@@ -64,25 +58,21 @@
</pre></div>
-<p>
-where <em>raster_map</em> is the name to be given to the new raster map,
+<p>where <em>raster_map</em> is the name to be given to the new raster map,
and <em>reclass_map</em> is an existing reclass map.
-<p>
-Because <em>r.reclass</em> generates a table referencing some original
+<p>Because <em>r.reclass</em> generates a table referencing some original
raster map layer rather than creating a reclassed raster map layer,
a <em>r.reclass</em> map layer will no longer be accessible if
the original raster map layer upon which it was based is later removed.
-<p>
-A <em>r.reclass</em> map is not a true raster map layer.
+<p>A <em>r.reclass</em> map is not a true raster map layer.
Rather, it is a table of reclassification values which reference the
input raster map layer. Therefore, users who wish to retain reclassified
map layers must also save the original input raster map layers
from which they were generated. Alternatively r.recode can be used.
-<p>
-Category values which are not explicitly reclassified to a new value
+<p>Category values which are not explicitly reclassified to a new value
by the user will be reclassified to NULL.
@@ -94,8 +84,7 @@
<dd><b>input_categories=</b><em>output_category </em>[<em>label</em>]
</dl>
-<p>
-where each line of input specifies the category values in the
+<p>where each line of input specifies the category values in the
input raster map layer to be reclassified to the new
<em>output_category</em> category value. Specification of
a <em>label</em> to be associated with the new output map
@@ -105,17 +94,14 @@
may consist of single category values or a range of such
values in the format "<em>low</em> thru <em>high</em>." The
word "thru" must be present.
-<p>
-To include all (remaining) values the asterix "*" can be used. This
+<p>To include all (remaining) values the asterix "*" can be used. This
rule has to be set as last rule. No further rules are accepted after
setting this rule. The special rule "<tt>* = *</tt>" specifies
that all categories not expicitly set by one of the above rules
should be passed through unaltered instead of being set to NULL.
-<p>
-Categories to become no data are specified by setting the output
+<p>Categories to become no data are specified by setting the output
category value to "<tt>NULL</tt>".
<p>
A line containing only the word <b>end</b> terminates the
input.
@@ -123,8 +109,7 @@
<h2>EXAMPLES</h2>
The following examples may help clarify the reclass rules.
-<p>
-<dl>
+<p><dl>
<dt>
<dd>1. This example reclassifies categories 1, 2 and 3 in the input raster
map layer "roads" to category 1 with category label "good quality" in the output map
@@ -137,8 +122,7 @@
</pre>
-<p>
-<dd>2. This example reclassifies categories 1, 3 and 5 in the input raster
+<p><dd>2. This example reclassifies categories 1, 3 and 5 in the input raster
map layer to category 1 with category label "poor quality" in the output
map layer, and reclassifies input raster map layer categories 2, 4, and 6
to category 2 with the label "good quality" in the output map layer.
@@ -149,8 +133,7 @@
* = NULL
</pre>
-<p>
-<dd>3. This example reclassifies input raster map layer categories 1 thru 10 to output
+<p><dd>3. This example reclassifies input raster map layer categories 1 thru 10 to output
map layer category 1, input map layer categories 11 thru 20 to output map layer
category 2, and input map layer categories 21 thru 30 to output map layer
category 3, all without labels. The range from 30 to 40 is reclassified as
@@ -162,8 +145,7 @@
30 thru 40 = NULL
</pre>
-<p>
-<dd>4. Subsequent rules override previous rules. Therefore, the below example
+<p><dd>4. Subsequent rules override previous rules. Therefore, the below example
reclassifies input raster map layer categories 1 thru 19 and 51 thru 100
to category 1 in the output map layer,
input raster map layer categories 20 thru 24 and 26 thru 50 to
@@ -175,8 +157,7 @@
25 = 3 good quality
</pre>
-<p>
-<dd>5. The previous example could also have been entered as:
+<p><dd>5. The previous example could also have been entered as:
<pre>
1 thru 19 51 thru 100 = 1 poor quality
20 thru 24 26 thru 50 = 2 medium quality
@@ -193,7 +174,6 @@
</dd>
</dl>
<p>
The final example was given to show how the labels are handled. If a new
category value appears in more than one rule (as is the case with new
category values 1 and 2),
@@ -214,5 +194,4 @@
Michael Shapiro<br>
U.S.Army Construction Engineering Research Laboratory
-<p>
Modified: grass/trunk/raster/r.recode/r.recode.html
--- grass/trunk/raster/r.recode/r.recode.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.recode/r.recode.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,13 +4,11 @@
raster map based on recode <b>rules</b>. A <b>title</b> for the output
raster map may be (optionally) specified by the user.
-<p>
-The recode rules can be read from standard input (i.e., from the
+<p>The recode rules can be read from standard input (i.e., from the
keyboard, redirected from a file, or piped through another program) by
entering <b>rules=-</b>.
-<p>
-Rules are defined in one of these formats:
+<p>Rules are defined in one of these formats:
old_low:old_high:new_low:new_high
@@ -19,16 +17,14 @@
old_val:*:new_val (interval [old_val, inf])
</pre></div>
-<p>
-<em>r.recode</em> is loosely based
+<p><em>r.recode</em> is loosely based
on <em><a href="r.reclass.html">r.reclass</a></em> and uses the GRASS
Reclass Library to convert the rasters. It has routines for converting
to every possible combination of raster (eg. CELL to DCELL, DCELL to
FCELL, etc). Standard floating point raster precision is float
(FCELL), with <b>-d</b> double precision (DCELL) will be written.
-<p>
-There are four basic routines that it accepts:
+<p>There are four basic routines that it accepts:
<ol>
<li>old-low to old-high is reclassed to new-low to new high , where the
@@ -81,5 +77,4 @@
CERL
-<p>
Modified: grass/trunk/raster/r.region/r.region.html
--- grass/trunk/raster/r.region/r.region.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.region/r.region.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,7 +6,6 @@
<kbd>windows</kbd> directory in the user's current mapset), a raster
or vector map, or a 3dview file.
<p>
The <b>align</b> parameter allows to set the current resolution equal to
that of the named raster map, and align the boundaries to a row and column
edge in the named map. Alignment only moves the existing boundaries outward
@@ -21,8 +20,7 @@
settings are recomputed from the boundaries and the number of rows and
columns in the raster map.
-<p>
-The n=<em>value</em> may also be specified as a
+<p>The n=<em>value</em> may also be specified as a
function of its current value: n=n+<em>value</em>
increases the current northing, while n=n-<em>value</em>
decreases it. This is also true for s=<em>value</em>,
@@ -55,5 +53,4 @@
<br>
Based upon <em>g.region</em>
-<p>
Modified: grass/trunk/raster/r.regression.line/r.regression.line.html
--- grass/trunk/raster/r.regression.line/r.regression.line.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.regression.line/r.regression.line.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -21,7 +21,6 @@
r.regression.line map1=elevation.dem map2=elevation.10m
</pre></div>
<p>
Using the script style flag AND <em>eval</em> to make results
available in the shell:
Modified: grass/trunk/raster/r.report/r.report.html
--- grass/trunk/raster/r.report/r.report.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.report/r.report.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,28 +8,23 @@
user is given the option of printing out each report and/or saving output to
a file.
-<p>
-The report itself consists of two parts, a header section and the main body
+<p>The report itself consists of two parts, a header section and the main body
of the report.
-<p>
-The header section of the report identifies the raster map layer(s) (by map
+<p>The header section of the report identifies the raster map layer(s) (by map
layer name and TITLE), location, mapset, report date, and the region of
interest. The area of interest is described in two parts: the user's current
geographic region is presented, and the mask is presented (if any is used).
-<p>
-The main body of the report consists of from one to three tables which
+<p>The main body of the report consists of from one to three tables which
present the statistics for each category and the totals for each unit
column.
-<p>
-Note that, unlike <em><a href="r.stats.html">r.stats</a></em>,
+<p>Note that, unlike <em><a href="r.stats.html">r.stats</a></em>,
<em>r.report</em> allows the user to select the specific units of measure in
which statistics will be reported.
-<p>
-Following is the result of a <em>r.report</em> run on the raster map layer
+<p>Following is the result of a <em>r.report</em> run on the raster map layer
<em>geology</em> (located in the Spearfish, SD sample data base), with the
units expressed in square miles and acres. Here, <em>r.report</em> output is
directed into the file <em>report.file</em>.
@@ -76,8 +71,7 @@
in a file, this file will be placed into the user's current working
directory.
-<p>
-If the user runs <em>r.report</em> non-interactively, report output can be
+<p>If the user runs <em>r.report</em> non-interactively, report output can be
saved by redirecting it to a file or a printer using the UNIX redirection
mechanism.
Modified: grass/trunk/raster/r.resamp.bspline/r.resamp.bspline.html
--- grass/trunk/raster/r.resamp.bspline/r.resamp.bspline.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.resamp.bspline/r.resamp.bspline.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,28 +5,24 @@
input NULL cells are interpolated, useful to fill NULL cells, an alternative
to <a href="r.fillnulls.html">r.fillnulls</a>. Using the -n flag to only
interpolate NULL cells will considerably speed up the module.
-<p>
-The input raster map is read at its native resolution, the output raster
+<p>The input raster map is read at its native resolution, the output raster
map will be produced for the current computational region set with
<a href="g.region.html">g.region</a>. Any MASK will be respected, masked
values will be treated as NULL cells in both the input and the output map.
-<p>
-Spline step values <b><i>se</i></b> for the east-west direction and
+<p>Spline step values <b><i>se</i></b> for the east-west direction and
<b><i>sn</i></b> for the north-south direction should not be smaller than
the east-west and north-south resolutions of the input map. For a raster
map without NULL cells, 1 * resolution can be used, but check for
undershoots and overshoots. For very large areas with missing values
(NULL cells), larger spline step values may be required, but most of the
time the defaults (1.5 x resolution) should be fine.
-<p>
-The Tykhonov regularization parameter ("<b><i>lambda</i></b>") acts to
+<p>The Tykhonov regularization parameter ("<b><i>lambda</i></b>") acts to
smooth the interpolation. With a small <b><i>lambda</i></b>, the
interpolated surface closely follows observation points; a larger value
will produce a smoother interpolation. Reasonable values are 0.0001,
0.001, 0.005, 0.01, 0.02, 0.05, 0.1 (needs more testing). For seamless
NULL cell interpolation, a small value is required and default is set to 0.005.
-<p>
-From a theoretical perspective, the interpolating procedure takes place in two
+<p>From a theoretical perspective, the interpolating procedure takes place in two
parts: the first is an estimate of the linear coefficients of a spline function;
these are derived from the observation points using a least squares regression; the
second is the computation of the interpolated surface (or interpolated vector
@@ -41,8 +37,7 @@
Regularization avoids the need to have one one observation and one coefficient
for each spline (in order to avoid instability).
-<p>
-A cross validation "leave-one-out" analysis is available to help to determine
+<p>A cross validation "leave-one-out" analysis is available to help to determine
the optimal <b><i>lambda</i></b> value that produces an interpolation that
best fits the original observation data. The more points used for
cross-validation, the longer the time needed for computation. Empirical testing
@@ -108,17 +103,14 @@
Brovelli M. A., Cannata M., and Longoni U.M., 2004, LIDAR Data
Filtering and DTM Interpolation Within GRASS, Transactions in GIS,
April 2004, vol. 8, iss. 2, pp. 155-174(20), Blackwell Publishing Ltd
-<p>
-Brovelli M. A. and Cannata M., 2004, Digital Terrain model
+<p>Brovelli M. A. and Cannata M., 2004, Digital Terrain model
reconstruction in urban areas from airborne laser scanning data: the
method and an example for Pavia (Northern Italy). Computers and
Geosciences 30, pp.325-331
-<p>
-Brovelli M. A e Longoni U.M., 2003, Software per il filtraggio di
+<p>Brovelli M. A e Longoni U.M., 2003, Software per il filtraggio di
dati LIDAR, Rivista dell'Agenzia del Territorio, n. 3-2003, pp. 11-22
(ISSN 1593-2192)
-<p>
-Antolin R. and Brovelli M.A., 2007, LiDAR data Filtering with GRASS GIS for the
+<p>Antolin R. and Brovelli M.A., 2007, LiDAR data Filtering with GRASS GIS for the
Determination of Digital Terrain Models. Proceedings of Jornadas de SIG Libre,
Girona, España. CD ISBN: 978-84-690-3886-9 <br>
Modified: grass/trunk/raster/r.resamp.filter/r.resamp.filter.html
--- grass/trunk/raster/r.resamp.filter/r.resamp.filter.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.resamp.filter/r.resamp.filter.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,37 +1,31 @@
-<p>
-<em>r.resamp.filter</em> resamples an input raster, filtering the
+<p><em>r.resamp.filter</em> resamples an input raster, filtering the
input with an analytic kernel.
-<p>
-All of the kernels specified by the filter= option are multiplied
+<p>All of the kernels specified by the filter= option are multiplied
together. Typical usage will use either a single kernel or an infinite
kernel along with a finite window.
<h2>NOTES</h2>
-<p>
-Resampling modules (<em>r.resample, r.resamp.stats, r.resamp.interp,
+<p>Resampling modules (<em>r.resample, r.resamp.stats, r.resamp.interp,
r.resamp.rst, r.resamp.filter</em>) resample the map to match the
-<p>
-When using a kernel which can have negative values (sinc, Lanczos),
+<p>When using a kernel which can have negative values (sinc, Lanczos),
the <em>-n</em> flag should be used. Otherwise, extreme values can
arise due to the total weight being close (or even equal) to zero.
-<p>
-Kernels with infinite extent (Gauss, normal, sinc, Hann, Hamming,
+<p>Kernels with infinite extent (Gauss, normal, sinc, Hann, Hamming,
Blackman) must be used in conjunction with a finite windowing function
(box, Bartlett, Hermite, Lanczos)
-<p>
-For longitude-latitude locations, the interpolation algorithm is based on
+<p>For longitude-latitude locations, the interpolation algorithm is based on
degree fractions, not on the absolute distances between cell centers. Any
attempt to implement the latter would violate the integrity of the
interpolation method.
@@ -49,5 +43,4 @@
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.resamp.interp/r.resamp.interp.html
--- grass/trunk/raster/r.resamp.interp/r.resamp.interp.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.resamp.interp/r.resamp.interp.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,8 +14,7 @@
<li>lanczos (25 cells)</li>
</ul>
-<p>
-This module is intended for reinterpolation of continuous data
+<p>This module is intended for reinterpolation of continuous data
to a different resolution rather than for interpolation from scattered data
(use the <em>v.surf.*</em> modules for that purpose).
@@ -23,20 +22,17 @@
<h2>NOTES</h2>
-<p>
r.resamp.rst</em>) resample the map to match the current region settings.
-<p>
-Note that for bilinear, bicubic and lanczos interpolation,
+<p>Note that for bilinear, bicubic and lanczos interpolation,
cells of the output raster that cannot be bounded by the appropriate number
of input cell centers are set to NULL (NULL propagation). This could occur
due to the input cells being outside the current region, being NULL or MASKed.
-<p>
@@ -65,5 +61,4 @@
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.resamp.rst/r.resamp.rst.html
--- grass/trunk/raster/r.resamp.rst/r.resamp.rst.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.resamp.rst/r.resamp.rst.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,49 +8,39 @@
Reinterpolation (resampling) is done to higher, same or lower resolution
specified by the <i>ew_res</i> and <i>ns_res</i> parameters.
-<p>
-All resulting raster maps are created using the settings of the current
+<p>All resulting raster maps are created using the settings of the current
region (which may be different from that of the <i>input</i> raster map).
-<p>
-Optionally, and simultaneously with interpolation, topographic parameters
+<p>Optionally, and simultaneously with interpolation, topographic parameters
are computed from an input raster map containing z-values of elevation/depth: slope,
aspect, profile curvature (measured in the direction of steepest
slope), tangential curvature (measured in the direction of a tangent to
contour line) and/or mean curvature are computed from and saved as raster maps
as specified by the options <i>slope, aspect, pcurv, tcurv, mcurv</i> respectively.
-<p>
-If the <i>-d</i> flag is set the program outputs partial derivatives fx, fy,
+<p>If the <i>-d</i> flag is set the program outputs partial derivatives fx, fy,
fxx, fxy, and fyy instead of slope, aspect and curvatures.
-<p>
-For noisy data it is possible to define spatially variable smoothing
+<p>For noisy data it is possible to define spatially variable smoothing
by providing a raster map named by the <i>smooth</i> option containing
smoothing parameters.
With the smoothing parameter set to zero (<i>smooth</i> is not given or
contains zero data), the resulting surface passes exactly through the data
points.
-<p>
-The user can also define a raster map (named with <i>maskmap</i>) which will
+<p>The user can also define a raster map (named with <i>maskmap</i>) which will
be used as a mask. The interpolation is skipped for cells which have zero
or NULL value in the mask.
-<p>
-Zero values will be assigned to these cells in all output raster maps.
+<p>Zero values will be assigned to these cells in all output raster maps.
<!-- is this still true???? -->
-<p>
-The <i>zmult</i> parameter allows the user to rescale the z-values which may
+<p>The <i>zmult</i> parameter allows the user to rescale the z-values which may
be useful, e.g., for transformation of elevations given in feet to meters,
so that the proper values of slopes and curvatures can be computed.
The default value is 1.
-<p>
-A regularized spline with tension method is used for the interpolation.
+<p>A regularized spline with tension method is used for the interpolation.
The <i>tension</i> parameter tunes the character of the resulting surface
from thin plate to membrane. Higher values of tension parameter reduce the
overshoots that can appear in surfaces with rapid change of gradient.
-<p>
-The <i>-t</i> flag can be set to use "dnorm independent tension".
+<p>The <i>-t</i> flag can be set to use "dnorm independent tension".
<!-- but what is "dnorm independent tension" ??? -->
-<p>
-The interpolation is performed for overlapping rectangular segments.
+<p>The interpolation is performed for overlapping rectangular segments.
The user can define the width of overlap (in number of cells) with
the <i>overlap</i> option. The default value is 3.
<br>
@@ -60,16 +50,13 @@
<i>r.resamp.rst</i> uses regularized spline with tension for interpolation
(as described in Mitasova and Mitas, 1993).
-<p>
-The region is temporarily changed while writing output files with desired
+<p>The region is temporarily changed while writing output files with desired
resolution. Topographic parameters are computed in the same way as in
the <i>v.surf.rst</i> module. (See also Mitasova and Hofierka, 1993)
-<p>
-The raster map used with the <i>smooth</i> option should contain variable
+<p>The raster map used with the <i>smooth</i> option should contain variable
smoothing parameters. These can be derived from errors, slope, etc. using
the <i>r.mapcalc</i> module.
-<p>
-The program gives warning when significant overshoots appear and higher
+<p>The program gives warning when significant overshoots appear and higher
tension should be used. However, with tension set too high the resulting surface
changes its behavior to a membrane (rubber sheet stretched over the data
points resulting in a peak or pit in each given point and everywhere else
@@ -77,8 +64,7 @@
the overshoots. When overshoots occur the resulting <i>elev</i> file will
have white color in the locations of overshoots since the color table for
the output file is the same as colortable for raster input file.
-<p>
-The program checks the numerical stability of the algorithm by computation
+<p>The program checks the numerical stability of the algorithm by computation
of values at given points, and prints the maximum difference found into the
history file of raster map <i>elev</i> (view with <i>r.info</i>).
An increase in tension is suggested if the difference is unacceptable.
@@ -87,8 +73,7 @@
the data points exactly, and the higher the parameter the closer the surface
will be to the trend.
-<p>
-The program writes the values of parameters used in computation into
+<p>The program writes the values of parameters used in computation into
the comment part of the <i>elev</i> map history file. Additionally the
following values are also written to assist in the evaluation of results
and choosing of suitable parameters:
@@ -100,12 +85,10 @@
<li>rescaling parameter used for normalization (dnorm), which influences the
tension.</li>
</ul>
-<p>
-The program gives a warning when the user wants to interpolate outside
+<p>The program gives a warning when the user wants to interpolate outside
the region given by the <i>input</i> raster map's header data. Zooming into the
area where the points are is suggested in this case.
-<p>
-When a mask is used, the program uses all points in the given region for
+<p>When a mask is used, the program uses all points in the given region for
interpolation, including those in the area which is masked out, to ensure
proper interpolation along the border of the mask. It therefore does not
mask out the data points; if this is desirable, it must be done outside
Modified: grass/trunk/raster/r.resamp.stats/r.resamp.stats.html
--- grass/trunk/raster/r.resamp.stats/r.resamp.stats.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.resamp.stats/r.resamp.stats.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,16 +1,13 @@
-<p>
-<em>r.resamp.stats</em> fills a grid cell (raster) matrix with
+<p><em>r.resamp.stats</em> fills a grid cell (raster) matrix with
aggregated values generated from a set of input layer data points.
-<p>
-Without the <em>-w</em> switch, the aggregate is computed over all of
+<p>Without the <em>-w</em> switch, the aggregate is computed over all of
the input cells whose centers lie within the output cell.
-<p>
-With the <em>-w</em> switch, the aggregate uses the values from all
+<p>With the <em>-w</em> switch, the aggregate uses the values from all
input cells which intersect the output cell, weighted according to the
proportion of the source cell which lies inside the output cell. This
is slower, but produces a more accurate result.
@@ -19,12 +16,10 @@
<h2>NOTES</h2>
-<p>
-<p>
-The notion of weighting doesn't make any sense for the min and max
+<p>The notion of weighting doesn't make any sense for the min and max
aggregates. However, the <em>-w</em> flag still has significance in
that, when multiple destination cells overlap a source cell, the
source cell is included in the calculation of all of the destination
@@ -32,8 +27,7 @@
<h2>EXAMPLE</h2>
-<p>
-Resample elevation raster map to a lower resolution (from 6m to 20m;
+<p>Resample elevation raster map to a lower resolution (from 6m to 20m;
North Carolina sample dataset):
@@ -55,5 +49,4 @@
Glynn Clements
-<p>
Modified: grass/trunk/raster/r.resample/r.resample.html
--- grass/trunk/raster/r.resample/r.resample.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.resample/r.resample.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,8 +20,7 @@
resolution as the resolution of the current geographic region
(set using <em><a href="g.region.html">g.region</a></em>).
-<p>
-The resulting raster map layer may be identical to the original raster
+<p>The resulting raster map layer may be identical to the original raster
map layer. The <em>r.resample</em> program will copy the color table
and history file associated with the original raster map
layer for the resulting raster map layer and will create a modified
@@ -29,7 +28,6 @@
which appear in resampled file.
<p>
When the user resamples a GRASS <em>reclass</em> file, a true raster map
is created by <em>r.resample</em>.
Modified: grass/trunk/raster/r.ros/r.ros.html
--- grass/trunk/raster/r.ros/r.ros.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.ros/r.ros.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -160,5 +160,4 @@
Jianping Xu, Center for Remote Sensing and Spatial Analysis, Rutgers University.
-<p>
Modified: grass/trunk/raster/r.series/r.series.html
--- grass/trunk/raster/r.series/r.series.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.series/r.series.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.series</em> makes each output cell value a function of the values
assigned to the corresponding cells in the input raster map layers.
Following methods are available:
@@ -29,19 +28,16 @@
With <em>-n</em> flag, any cell for which any of the corresponding input cells are
NULL is automatically set to NULL (NULL propagation). The aggregate function is not
called, so all methods behave this way with respect to the <em>-n</em> flag.
-<p>
-Without <em>-n</em> flag, the complete list of inputs for each cell (including
+<p>Without <em>-n</em> flag, the complete list of inputs for each cell (including
NULLs) is passed to the aggregate function. Individual aggregates can
handle data as they choose. Mostly, they just compute the aggregate
over the non-NULL values, producing a NULL result only if all inputs
are NULL.
-<p>
-The <em>min_raster</em> and <em>max_raster</em> methods generate a map with the
+<p>The <em>min_raster</em> and <em>max_raster</em> methods generate a map with the
number of the raster map that holds the minimum/maximum value of the
time-series. The numbering starts at <em>0</em> up to <em>n</em> for the
first and the last raster listed in <em>input=</em>, respectively.
-<p>
-If the <em>range=</em> option is given, any values which fall outside
+<p>If the <em>range=</em> option is given, any values which fall outside
that range will be treated as if they were NULL.
The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
values outside of this range are treated as NULL (i.e., they will be
@@ -49,12 +45,10 @@
The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
-<p>
-Linear regression (slope, offset, coefficient of determination) assumes equal time intervals.
+<p>Linear regression (slope, offset, coefficient of determination) assumes equal time intervals.
If the data have irregular time intervals, NULL raster maps can be inserted into time series
to make time intervals equal (see example).
-<p>
-Number of raster maps to be processed is given by the limit of the
+<p>Number of raster maps to be processed is given by the limit of the
operating system. For example, both the hard and soft limits are
typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
1500</tt> (UNIX-based operating systems) but not higher than the hard
@@ -69,8 +63,7 @@
This would raise the hard limit to 1500 file. Be warned that more
files open need more RAM.
-<p>
-Use the <em>file</em> option to analyze large amount of raster maps without
+<p>Use the <em>file</em> option to analyze large amount of raster maps without
hitting open files limit and the size limit of command line arguments.
The computation is slower than the <em>input</em> option method.
For every sinlge row in the output map(s)
@@ -86,11 +79,9 @@
r.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
output=insitu_data.stddev method=stddev
</pre></div>
-<p>
-Note the <em>g.mlist</em> script also supports regular expressions for
+<p>Note the <em>g.mlist</em> script also supports regular expressions for
selecting map names.
-<p>
-Using <em>r.series</em> with NULL raster maps:
+<p>Using <em>r.series</em> with NULL raster maps:
<br>
r.mapcalc "dummy = null()"
@@ -98,14 +89,12 @@
out=res_slope,res_offset,res_coeff meth=slope,offset,detcoeff
</pre></div>
-<p>
-Example for multiple aggregates to be computed in one run (3 resulting aggregates from two input maps):
+<p>Example for multiple aggregates to be computed in one run (3 resulting aggregates from two input maps):
r.series in=one,two out=result_avg,res_slope,result_count meth=sum,slope,count
</pre></div>
-<p>
-Example to use the file option of r.series:
+<p>Example to use the file option of r.series:
cat > input.txt << EOF
map1
@@ -125,4 +114,4 @@
Glynn Clements
-<p><i>Last changed: $Date$</i>
\ No newline at end of file
Modified: grass/trunk/raster/r.slope.aspect/r.slope.aspect.html
--- grass/trunk/raster/r.slope.aspect/r.slope.aspect.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.slope.aspect/r.slope.aspect.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,39 +7,33 @@
<i>format</i> for slope (degrees, percent; default=degrees), and the
<i>zfactor</i>: multiplicative factor to convert elevation units to meters;
(default 1.0).
-<p>
-The <i>elevation</i> input raster map specified by the user must contain true
+<p>The <i>elevation</i> input raster map specified by the user must contain true
elevation values, <b>not</b> rescaled or categorized data. If the elevation
values are in feet or other units than meters (with a conversion factor
<i>meters:</i>, defined in PROJ_UNITS), they must be converted to meters using
the parameter <i>zfactor</i>.
-<p>
-The <i>aspect</i> output raster map indicates the direction that slopes are
+<p>The <i>aspect</i> output raster map indicates the direction that slopes are
facing. The aspect categories represent the number degrees of east. Category
and color table files are also generated for the aspect map layer. The aspect
categories represent the number degrees of east and they increase
counterclockwise: 90deg is North, 180 is West, 270 is South 360 is East. The
aspect value 0 is used to indicate undefined aspect in flat areas with slope=0.
-<p>
-The <i>slope</i> output raster map contains slope values, stated in degrees of
+<p>The <i>slope</i> output raster map contains slope values, stated in degrees of
inclination from the horizontal if <i>format</i>=degrees option (the default)
is chosen, and in percent rise if <i>format</i>=percent option is chosen.
Category and color table files are generated.
-<p>
-Profile and tangential curvatures are the curvatures in the direction of
+<p>Profile and tangential curvatures are the curvatures in the direction of
steepest slope and in the direction of the contour tangent respectively. The
curvatures are expressed as 1/metres, e.g. a curvature of 0.05 corresponds to a
radius of curvature of 20m. Convex form values are positive and concave form values
are negative.
-<p>
-<table width="100%" border="0">
+<p><table width="100%" border="0">
<tr valign="baseline">
<td>
<center>
<img src="dem.png" border="1">
- <p>
- Example DEM
+ <p> Example DEM
<br><br>
</center>
</td>
@@ -51,16 +45,14 @@
<td>
<center>
<img src="slope.png" border="1">
- <p>
- Slope (degree) from example DEM
+ <p> Slope (degree) from example DEM
<br><br>
</center>
</td>
<td>
<center>
<img src="aspect.png" border="1">
- <p>
- Aspect (degree) from example DEM
+ <p> Aspect (degree) from example DEM
<br><br>
</center>
</td>
@@ -70,16 +62,14 @@
<td>
<center>
<img src="tcurv.png" border="1">
- <p>
- Tangential curvature (m<sup>-1</sup>) from example DEM
+ <p> Tangential curvature (m<sup>-1</sup>) from example DEM
<br><br>
</center>
</td>
<td>
<center>
<img src="pcurv.png" border="1">
- <p>
- Profile curvature (m<sup>-1</sup>) from example DEM
+ <p> Profile curvature (m<sup>-1</sup>) from example DEM
<br><br>
</center>
</td>
@@ -88,8 +78,7 @@
</tr>
</table>
-<p>
-For some applications, the user will wish to use a reclassified raster map
+<p>For some applications, the user will wish to use a reclassified raster map
of slope that groups slope values into ranges of slope. This can be done using
<i><a href="r.reclass.html">r.reclass</a></i>. An example of a useful
reclassification is given below:
@@ -128,27 +117,22 @@
cells in the elevation map. If the user really wants the elevation map
resampled to the current region resolution, the -a flag should be specified.
-<p>
-The current mask is ignored.
+<p>The current mask is ignored.
-<p>
-The algorithm used to determine slope and aspect uses a 3x3 neighborhood
+<p>The algorithm used to determine slope and aspect uses a 3x3 neighborhood
around each cell in the elevation file. Thus, it is not possible to determine
slope and aspect for the cells adjacent to the edges in the elevation map
layer. These cells are assigned a "zero slope" value (category 0) in both
the slope and aspect raster map layers.
-<p>
-Horn's formula is used to find the first order derivatives in x and y directions.
+<p>Horn's formula is used to find the first order derivatives in x and y directions.
-<p>
-Only when using integer elevation models, the aspect is biased in 0,
+<p>Only when using integer elevation models, the aspect is biased in 0,
45, 90, 180, 225, 270, 315, and 360 directions; i.e., the distribution
of aspect categories is very uneven, with peaks at 0, 45,..., 360 categories.
When working with floating point elevation models, no such aspect bias occurs.
-<p>
-Because most cells with a very small slope end up having category 0,
+<p>Because most cells with a very small slope end up having category 0,
45, ..., 360, it is sometimes possible to reduce the bias in these directions
by filtering out the aspect in areas where the terrain is almost flat. A new
option <i>min_slp_allowed</i> was added to specify the minimum slope for which
@@ -179,5 +163,4 @@
Michael Shapiro, U.S.Army Construction Engineering Research Laboratory<br>
Olga Waupotitsch, U.S.Army Construction Engineering Research Laboratory
-<p>
Modified: grass/trunk/raster/r.solute.transport/r.solute.transport.html
--- grass/trunk/raster/r.solute.transport/r.solute.transport.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.solute.transport/r.solute.transport.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,8 +4,7 @@
raster maps and the current region settings. All initial- and boundary-conditions must be provided as
raster maps. The unit in the location must be meters.
<br>
-<p>
-This module is sensitive to mask settings. All cells which are outside the mask
+<p>This module is sensitive to mask settings. All cells which are outside the mask
are ignored and handled as no flow boundaries.
<br>
This module calculates the concentration of the solution and optional the
@@ -15,7 +14,7 @@
with r.out.vtk.
<br>
<br>
-Use <a href="r.gwflow.html">r.gwflow</A> to compute the piezometric heights
+Use <a href="r.gwflow.html">r.gwflow</a> to compute the piezometric heights
of the aquifer. The piezometric heights and the hydraulic conductivity
are used to compute the flow direction and the mean velocity of the groundwater.
This is the base of the solute transport computation.
@@ -39,8 +38,7 @@
which must be solved. The solute transport partial
differential equation is of the following form:
-<p>
-(dc/dt)*R = div ( D grad c - uc) + cs -q/nf(c - c_in)
+<p>(dc/dt)*R = div ( D grad c - uc) + cs -q/nf(c - c_in)
<ul>
<li>c -- the concentration [kg/m^3]</li>
@@ -147,14 +145,13 @@
<h2>SEE ALSO</h2>
-<em><a href="r.gwflow.html">r.gwflow</A></em><br>
-<em><a href="r3.gwflow.html">r3.gwflow</A></em><br>
-<em><a href="r.out.vtk.html">r.out.vtk</A></em><br>
+<em><a href="r.gwflow.html">r.gwflow</a></em><br>
+<em><a href="r3.gwflow.html">r3.gwflow</a></em><br>
+<em><a href="r.out.vtk.html">r.out.vtk</a></em><br>
<h2>AUTHOR</h2>
Sören Gebbert
-<p>
-This work is based on the Diploma Thesis of Sören Gebbert available
+<p>This work is based on the Diploma Thesis of Sören Gebbert available
<a href="http://www.hydrogeologie.tu-berlin.de/fileadmin/fg66/_hydro/Diplomarbeiten/2007_Diplomarbeit_Soeren_Gebbert.pdf">here</a>
at Technical University Berlin in Germany.
Modified: grass/trunk/raster/r.spread/r.spread.html
--- grass/trunk/raster/r.spread/r.spread.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.spread/r.spread.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -32,8 +32,8 @@
GRASS raster program r.spreadpath.
<p>Part of the spotting function in r.spread is based on Chase (1984)
-and Rothermel (1983). More information on <I>r.spread</I>, <I><a href="r.ros.html">r.ros</A></I>
-and <I><a href="r.spreadpath.html">r.spreadpath</A></I> can be found in
+and Rothermel (1983). More information on <I>r.spread</I>, <I><a href="r.ros.html">r.ros</a></I>
+and <I><a href="r.spreadpath.html">r.spreadpath</a></I> can be found in
Xu (1994).
<h2>Flags:</h2>
@@ -193,11 +193,11 @@
<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</A></em>,
-<em><a href="r.cost.html">r.cost</A></em>,
-<!-- <em><a href="r.mask.html">r.mask</A></em>, -->
-<em><a href="r.spreadpath.html">r.spreadpath</A></em>,
-<em><a href="r.ros.html">r.ros</A></em>
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="r.cost.html">r.cost</a></em>,
+<!-- <em><a href="r.mask.html">r.mask</a></em>, -->
+<em><a href="r.spreadpath.html">r.spreadpath</a></em>,
+<em><a href="r.ros.html">r.ros</a></em>
<h2>REFERENCES</h2>
Chase, Carolyn, H., 1984, Spotting distance from wind-driven surface fires
Modified: grass/trunk/raster/r.spreadpath/r.spreadpath.html
--- grass/trunk/raster/r.spreadpath/r.spreadpath.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.spreadpath/r.spreadpath.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,7 +7,6 @@
x_input) coordinates from which the cell's cumulative cost was determined.
<p>
The backlink inputs can be generated from another GRASS raster program
<em>r.spread</em>. One of the major applications of <em>r.spreadpath</em>
along with <em>r.spread</em> is to accurately find the least cost corridors
@@ -32,8 +31,8 @@
</dl>
<h2>SEE ALSO</h2>
-<em><a href="r.spread.html">r.spread</A></em>,
+<em><a href="r.spread.html">r.spread</a></em>,
<h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.statistics/r.statistics.html
--- grass/trunk/raster/r.statistics/r.statistics.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.statistics/r.statistics.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -28,14 +28,12 @@
The calculations will be performed on each area of data of the
cover layers which fall within each unique value, or category, of the base layer.
-<p>
-Setting the <em>-c</em> flag the category lables of the covering raster
+<p>Setting the <em>-c</em> flag the category lables of the covering raster
layer will be used. This is nice to avoid the GRASS limitation to interger
in raster maps because using category values floating point numbers can be
stored.
-<p>
-All calculations create an output layer. The output
+<p>All calculations create an output layer. The output
layer is a reclassified version of the base layer with identical
category values, but modified category labels - the results of the calculations
are stored in the category labels of the output layer.
Modified: grass/trunk/raster/r.statistics3/r.statistics3.html
--- grass/trunk/raster/r.statistics3/r.statistics3.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.statistics3/r.statistics3.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,5 +15,4 @@
<h2>AUTHOR</h2>
Glynn Clements
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.stats/r.stats.html
--- grass/trunk/raster/r.stats/r.stats.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.stats/r.stats.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,8 +13,7 @@
layers are specified on the command line, a cross-tabulation table of areas
for each combination of categories in the map layers will be printed.
-<p>
-For example, if one raster map layer were specified, the output would look like:
+<p>For example, if one raster map layer were specified, the output would look like:
<pre>
1:1350000.00
2:4940000.00
@@ -48,15 +47,12 @@
<h2>NOTES</h2>
<em>r.stats</em> works in the current geographic region with the current mask.
-<p>
-If a nicely formatted output is desired, pipe the output into a command
+<p>If a nicely formatted output is desired, pipe the output into a command
which can create columnar output. For example, the command:
-<p>
- <b>r.stats input=</b>a,b,c | pr -3 | cat -s
+<p> <b>r.stats input=</b>a,b,c | pr -3 | cat -s
-<p>
-will create a three-column output
+<p>will create a three-column output
<pre>
1:4:4:10000.00 2:1:5:290000.00 2:4:5:2090000.00
1:4:5:1340000.00 2:2:5:350000.00 3:1:2:450000.00
@@ -66,8 +62,7 @@
The output from <em>r.stats</em> on more than one map layer is sorted.
-<p>
-Note that the user has only the option of printing out cell statistics in
+<p>Note that the user has only the option of printing out cell statistics in
terms of cell counts and/or area totals. Users wishing to use different
units than are available here should use the GRASS program
<em><a href="r.report.html">r.report</a></em>.
Modified: grass/trunk/raster/r.sun/r.sun.html
--- grass/trunk/raster/r.sun/r.sun.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.sun/r.sun.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,8 +10,7 @@
the shadowing effect directly from the digital elevation model or using rasters
of the horizon height which is much faster. The horizon rasters can be
constructed using <a href="r.horizon.html">r.horizon</a>.
-<p>
-For latitude-longitude coordinates it requires that the elevation map is in meters.
+<p>For latitude-longitude coordinates it requires that the elevation map is in meters.
The rules are:
<ul>
<li> lat/lon coordinates: elevation in meters;
@@ -44,8 +43,7 @@
parameters are saved in the resultant maps' history files, which may be viewed
with the <a href="r.info.html">r.info</a> command.
-<p>
-The solar incidence angle raster map <i>incidout</i> is computed specifying
+<p>The solar incidence angle raster map <i>incidout</i> is computed specifying
elevation raster map <i>elevin</i>, aspect raster map <i>aspin</i>, slope
steepness raster map <i>slopin,</i> given the day <i>day</i> and local time
<i>time</i>. There is no need to define latitude for locations with known
@@ -63,8 +61,7 @@
where January 1 is day no.1 and December 31 is 365. Time <i>time</i> must
be a local (solar) time (i.e. NOT a zone time, e.g. GMT, CET) in decimal system,
e.g. 7.5 (= 7h 30m A.M.), 16.1 = 4h 6m P.M..
-<p>
-Setting the solar declination <i>declin</i> by user is an option to override
+<p>Setting the solar declination <i>declin</i> by user is an option to override
the value computed by the internal routine for the day of the year. The value
of geographical latitude can be set as a constant for the whole computed
region or, as an option, a grid representing spatially distributed values
@@ -72,15 +69,13 @@
with positive values for northern hemisphere and negative for southern one.
In similar principle the Linke turbidity factor (<i>linkein</i>, <i>lin</i>
) and ground albedo (<i>albedo</i>, <i>alb</i>) can be set.
-<p>
-Besides clear-sky radiations, the user can compute a real-sky radiation (beam,
+<p>Besides clear-sky radiations, the user can compute a real-sky radiation (beam,
diffuse) using <i>coefbh</i> and <i>coefdh </i>input raster maps defining
the fraction of the respective clear-sky radiations reduced by atmospheric
factors (e.g. cloudiness). The value is between 0-1. Usually these
coefficients can be obtained from a long-terms meteorological measurements
provided as raster maps with spatial distribution of these coefficients separately
-for beam and diffuse radiation (see Suri and Hofierka, 2004, section 3.2).<p>
-The solar irradiation or irradiance raster maps <i>beam_rad</i>, <i>diff_rad</i>,
+for beam and diffuse radiation (see Suri and Hofierka, 2004, section 3.2).<p>The solar irradiation or irradiance raster maps <i>beam_rad</i>, <i>diff_rad</i>,
<i>refl_rad</i> are computed for a given day <i>day,</i> latitude <i>latin</i>,
elevation <i>elevin</i>, slope <i>slopein</i> and aspect <i>aspin</i> raster maps.
For convenience, the output raster given as <i>glob_rad</i>
@@ -91,8 +86,7 @@
factor for an absolutely clear atmosphere is <i>lin</i>=1.0. See notes below
to learn more about this factor. The incidence solar angle is the angle between
horizon and solar beam vector.
-<p>
-The solar radiation maps for a given day are computed by integrating the
+<p>The solar radiation maps for a given day are computed by integrating the
relevant irradiance between sunrise and sunset times for that day. The
user can set a finer or coarser time step used for all-day radiation
calculations with the <i>step</i> option. The default value of <i>step</i> is
@@ -104,8 +98,7 @@
<i>step</i> to 4 minutes or less. <i>step</i><tt>=0.05</tt> is equivalent
to every 3 minutes. Of course setting the time step to be very fine
proportionally increases the module's running time.
-<p>
-The output units are in Wh per squared meter per given
+<p>The output units are in Wh per squared meter per given
day [Wh/(m*m)/day]. The incidence angle and irradiance/irradiation maps can
be computed without shadowing influence of relief by default or they can
be computed with this influence using the flag <i>-s</i>. In mountainous areas
@@ -161,8 +154,7 @@
sensing. Solar rays incidence angle maps can be effectively used in radiometric
and topographic corrections in mountainous and hilly terrain where very accurate
investigations should be performed.
-<p>
-The clear-sky solar radiation model applied in the r.sun is based on the
+<p>The clear-sky solar radiation model applied in the r.sun is based on the
work undertaken for development of European Solar Radiation Atlas (Scharmer
and Greif 2000, Page et al. 2001, Rigollier 2001). The clear sky model estimates
the global radiation from the sum of its beam, diffuse and reflected components.
@@ -172,13 +164,11 @@
consideration the existing models and their limitation the European Solar
Radiation Atlas team selected the Muneer (1990) model as it has a sound theoretical
basis and thus more potential for later improvement.
-<p>
-Details of underlying equations used in this program can be found in the
+<p>Details of underlying equations used in this program can be found in the
reference literature cited below or book published by Neteler and Mitasova:
Open Source GIS: A GRASS GIS Approach (published in Kluwer Academic Publishers
in 2002).
-<p>
-Average monthly values of the Linke turbidity coefficient for a mild climate
+<p>Average monthly values of the Linke turbidity coefficient for a mild climate
in the northern hemisphere (see reference literature for your study area):
<table border="1">
@@ -189,8 +179,7 @@
<tr><td>industrial</td><td>4.1</td><td>4.3</td><td>4.7</td><td>5.3</td><td>5.5</td><td>5.7</td><td>5.8</td><td>5.7</td><td>5.3</td><td>4.9</td><td>4.5</td><td>4.2</td><td>5.00</td></tr>
</table>
-<p>
-Planned improvements include the use of the SOLPOS algorithm for solar
+<p>Planned improvements include the use of the SOLPOS algorithm for solar
geometry calculations and internal computation of aspect and slope.
<h3>Shadow maps</h3>
@@ -257,50 +246,37 @@
Hofierka, J., Suri, M. (2002): The solar radiation model for Open source
GIS: implementation and applications. Manuscript submitted to the International
GRASS users conference in Trento, Italy, September 2002.
-<p>
-Hofierka, J. (1997). Direct solar radiation modelling within an open GIS
+<p>Hofierka, J. (1997). Direct solar radiation modelling within an open GIS
environment. Proceedings of JEC-GI'97 conference in Vienna, Austria, IOS
Press Amsterdam, 575-584.
-<p>
-Jenco, M. (1992). Distribution of direct solar radiation on georelief and
+<p>Jenco, M. (1992). Distribution of direct solar radiation on georelief and
its modelling by means of complex digital model of terrain (in Slovak). Geograficky
casopis, 44, 342-355.
-<p>
-Kasten, F. (1996). The Linke turbidity factor based on improved values of
+<p>Kasten, F. (1996). The Linke turbidity factor based on improved values of
the integral Rayleigh optical thickness. Solar Energy, 56 (3), 239-244.
-<p>
-Kasten, F., Young, A. T. (1989). Revised optical air mass tables and approximation
+<p>Kasten, F., Young, A. T. (1989). Revised optical air mass tables and approximation
formula. Applied Optics, 28, 4735-4738.
-<p>
-Kittler, R., Mikler, J. (1986): Basis of the utilization of solar radiation
+<p>Kittler, R., Mikler, J. (1986): Basis of the utilization of solar radiation
(in Slovak). VEDA, Bratislava, p. 150.
-<p>
-Krcho, J. (1990). Morfometrická analza a digitálne modely georeliéfu
+<p>Krcho, J. (1990). Morfometrická analza a digitálne modely georeliéfu
(Morphometric analysis and digital models of georelief). VEDA,
Bratislava (in Slovak).
-<p>
-Muneer, T. (1990). Solar radiation model for Europe. Building services engineering
+<p>Muneer, T. (1990). Solar radiation model for Europe. Building services engineering
research and technology, 11, 4, 153-163.
-<p>
-Neteler, M., Mitasova, H. (2002): Open Source GIS: A GRASS GIS Approach, Kluwer
+<p>Neteler, M., Mitasova, H. (2002): Open Source GIS: A GRASS GIS Approach, Kluwer
Academic Publishers/Springer.
-<p>
-Page, J. ed. (1986). Prediction of solar radiation on inclined surfaces. Solar
+<p>Page, J. ed. (1986). Prediction of solar radiation on inclined surfaces. Solar
energy R&D in the European Community, series F -- Solar radiation data,
Dordrecht (D. Reidel), 3, 71, 81-83.
-<p>
-Page, J., Albuisson, M., Wald, L. (2001). The European solar radiation atlas:
+<p>Page, J., Albuisson, M., Wald, L. (2001). The European solar radiation atlas:
a valuable digital tool. Solar Energy, 71, 81-83.
-<p>
-Rigollier, Ch., Bauer, O., Wald, L. (2000). On the clear sky model of the
+<p>Rigollier, Ch., Bauer, O., Wald, L. (2000). On the clear sky model of the
ESRA - European Solar radiation Atlas - with respect to the Heliosat method.
Solar energy, 68, 33-48.
-<p>
-Scharmer, K., Greif, J., eds., (2000). The European solar radiation atlas,
+<p>Scharmer, K., Greif, J., eds., (2000). The European solar radiation atlas,
Vol. 2: Database and exploitation software. Paris (Les Presses de l'Ãcole
des Mines).
-<p>
-Suri, M., Hofierka, J. (2004): A new GIS-based solar radiation model and its
+<p>Suri, M., Hofierka, J. (2004): A new GIS-based solar radiation model and its
application to photovoltaic assessments. Transactions in GIS 8, pp. 175-190.
<p>Joint Research Centre: <a href="http://re.jrc.ec.europa.eu/pvgis/">GIS solar radiation database for Europe</a> and
Modified: grass/trunk/raster/r.sunmask/r.sunmask.html
--- grass/trunk/raster/r.sunmask/r.sunmask.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.sunmask/r.sunmask.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,8 +10,7 @@
to specify date/time for sun position calculation by r.sunmask itself have
to be used.
-<p>
-The module performs sunset/sunrise checks and refraction correction for sun
+<p>The module performs sunset/sunrise checks and refraction correction for sun
position calculation. Local coordinate systems are internally transformed to
latitude/longitude for the SOLPOS algorithm. The elevation is not considered
in the sunset/sunrise calculations.
@@ -25,14 +24,12 @@
(different for winter and summer), he/she would have to change the Time Zone
parameter seasonally in r.sunmask (timezone parameter).
<p>
Note: In latitude/longitude locations the position coordinates pair
(east/west) has to be specified in decimal degree (not D:M:S). If
not specified, the map center's coordinates will be used.
Also <em>g.region -l</em> displays the map center's coordinates.
-<p>
-Note for module usage with <em>-g</em> flag and calculations
+<p>Note for module usage with <em>-g</em> flag and calculations
close to sunset/sunrise:
<pre>
Modified: grass/trunk/raster/r.support/r.support.html
--- grass/trunk/raster/r.support/r.support.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.support/r.support.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,8 +11,7 @@
module will run non-interactively. If only the map name is given
<em>r.support</em> will run interactively within a terminal shell and the
user with be prompted for input.
-<p>
-Freeform metadata information is stored in a "<tt>hist</tt>" file which may be
+<p>Freeform metadata information is stored in a "<tt>hist</tt>" file which may be
appended to by using the <b>history</b> option. Currently this is limited to
50 lines of text with a maximum line length of 78 characters. Any input
larger than this will be wrapped to the next line.
@@ -37,6 +36,5 @@
M. Hamish Bowman: command line enhancements<br>
Markus Neteler: category copy from other map
-<p>
Modified: grass/trunk/raster/r.surf.area/r.surf.area.html
--- grass/trunk/raster/r.surf.area/r.surf.area.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.surf.area/r.surf.area.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -16,13 +16,11 @@
edges. The module does not [currently] attempt to correct for the
error introduced by this <em>edge effect</em>.
-<p>
-This version actually calculates area twice for each triangle pair,
+<p>This version actually calculates area twice for each triangle pair,
keeping a running minimum and maximum area depending on the direction
of the diagonal used.
-<p>
-Reported totals are:
+<p>Reported totals are:
<ol>
<li>"Plan" area of <tt>NULL</tt> values within the current GRASS
region</li>
@@ -35,8 +33,7 @@
<li>Scaling of calculated area to current region</li>
</ol>
-<p>
-<em>r.surf.area</em> works best when the surface being evaluated
+<p><em>r.surf.area</em> works best when the surface being evaluated
extends to the edges of the current region and the cell resolution is
small. Surfaces which are especially long and thin and have highly
irregular boudaries will tend to have underestimated surface areas.
@@ -79,5 +76,4 @@
Updated for GRASS 7, and units option by Martin Landa, Czech Technical
University in Prague, Czech Republic (October 2011)
-<p>
Modified: grass/trunk/raster/r.surf.contour/r.surf.contour.html
--- grass/trunk/raster/r.surf.contour/r.surf.contour.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.surf.contour/r.surf.contour.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<h2>DESCRIPTION</h2>
<em>r.surf.contour</em> creates a raster elevation map from a rasterized
contour map. Elevation values are determined using procedures similar
to a manual methods.
@@ -10,7 +9,6 @@
<p>
<em>r.surf.contour</em> works in a similar way. Initially, a vector map of
the contour lines is made with the elevation of each line as an attribute.
When the program <em><a href="v.to.rast.html">v.to.rast</a></em>
@@ -43,8 +41,7 @@
the known category values in the input raster map layer.
</dl>
-<p>
-An existing MASK raster map is respected for both reading <em>input</em>
+<p>An existing MASK raster map is respected for both reading <em>input</em>
and writing <em>output</em>.
<h2>NOTES</h2>
@@ -61,8 +58,7 @@
</em> on <em>r.surf.contour</em> results to locate potential anomalies.
-<p>
-The running of <em>r.surf.contour</em> is very sensitive to the resolution of
+<p>The running of <em>r.surf.contour</em> is very sensitive to the resolution of
rasterized vector map. If multiple contour lines go through the same raster,
slight anomalies may occur. The speed of <em>r.surf.contour</em> is dependent
on how far "apart" the contour lines are from each other (as measured in
@@ -86,5 +82,4 @@
Chuck Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory
-<p>
Modified: grass/trunk/raster/r.surf.fractal/r.surf.fractal.html
--- grass/trunk/raster/r.surf.fractal/r.surf.fractal.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.surf.fractal/r.surf.fractal.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
showing the build up of different spectral coefficients (see Saupe,
pp.106-107 for an example of this).
-<p>
-Use this module to generate naturally looking synthetical elevation models
+<p>Use this module to generate naturally looking synthetical elevation models
(DEM).
@@ -37,5 +36,4 @@
Midlands Regional Research Laboratory (ASSIST),
University of Leicester
-<p>
Modified: grass/trunk/raster/r.surf.gauss/r.surf.gauss.html
--- grass/trunk/raster/r.surf.gauss/r.surf.gauss.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.surf.gauss/r.surf.gauss.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
random number generator. It is essentialy the same as <em>r.surf.random</em>,
but uses a Gaussian random number generator instead.
-<p>
-<center>
+<p><center>
<img src="r_surf_gauss_hist.png" alt="r.surf.gauss map histogram"><br>
<i>Histogram of map generated with r.surf.gauss (mean=0, sigma=10)</i>
</center>
Modified: grass/trunk/raster/r.surf.idw/r.surf.idw.html
--- grass/trunk/raster/r.surf.idw/r.surf.idw.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.surf.idw/r.surf.idw.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,6 +1,5 @@
<em>r.surf.idw</em> fills a grid cell (raster) matrix with
interpolated values generated from a set of input layer
data points. It uses a numerical approximation technique
@@ -10,7 +9,6 @@
specified by the user (default: 12 nearest data points).
<p>
If there is a current working mask, it applies to the output
raster map. Only those cells falling within the mask will be
assigned interpolated values. The search procedure for the
@@ -20,8 +18,7 @@
The <b>-e</b> flag is the error analysis option that interpolates values
only for those cells of the input raster map which have non-zero values and
outputs the difference (see <a href="#minuse.html">NOTES</a> below).
-<p>
-The <b>npoints</b> parameter defines the number of nearest data points used
+<p>The <b>npoints</b> parameter defines the number of nearest data points used
to determine the interpolated value of an output raster cell.
<A NAME="notes.html"></a>
@@ -39,7 +36,6 @@
geodesic.
<p>
Unlike <em><a href="r.surf.idw2.html">r.surf.idw2</a></em>, which processes
all input data points in each interpolation cycle, <em>r.surf.idw</em>
attempts to minimize the number of input data for which distances must be
@@ -47,7 +43,6 @@
and does not increase appreciably with the number of input data points.
<p>
<em>r.surf.idw</em> will generally outperform
<em><a href="r.surf.idw2.html">r.surf.idw2</a></em> except when the input data
layer contains few non-zero data, i.e. when the cost of the search exceeds
@@ -57,7 +52,6 @@
and floating point operations on a particular platform.
<p>
Worst case search performance by <em>r.surf.idw</em> occurs
when the interpolated cell is located outside of the region
in which input data are distributed. It therefore behooves
@@ -66,7 +60,6 @@
data.
<p>
The degree of smoothing produced by the interpolation will
increase relative to the number of nearest data points
considered. The utility may be used with regularly or
@@ -75,7 +68,6 @@
the surface pattern.
<p>
The <A NAME="minuse.html"><b>-e</b></a> flag option provides a standard
surface-generation error analysis facility. It produces an output raster map
of the difference of interpolated values minus input values for those cells
@@ -106,5 +98,4 @@
200 S.W. 35th Street, JSB <br>
Corvallis, OR 97333
-<p>
Modified: grass/trunk/raster/r.surf.idw2/r.surf.idw2.html
--- grass/trunk/raster/r.surf.idw2/r.surf.idw2.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.surf.idw2/r.surf.idw2.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -29,14 +29,12 @@
points.
<p>
If the user has a mask set, then interpolation is only done
for those cells that fall within the mask. However, all
non-zero data points in the input layer are used even if
they fall outside the mask.
<p>
This program does not work with latitude/longitude data
bases. Another surface generation program, named
<em><a href="r.surf.idw.html">r.surf.idw</a></em>,
@@ -44,7 +42,6 @@
<p>
The user should refer to the manual entries for <br>
<em><a href="r.surf.idw.html">r.surf.idw</a></em><br>
<em><a href="r.surf.contour.html">r.surf.contour</a></em><br>
Modified: grass/trunk/raster/r.surf.random/r.surf.random.html
--- grass/trunk/raster/r.surf.random/r.surf.random.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.surf.random/r.surf.random.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
It uses the random number generator drand48() or rand()<!-- cite? -->,
depending on the user's platform.
-<p>
-<center>
+<p><center>
<img src="r_surf_random_hist.png" alt="r.surf.random map histogram"><br>
<i>Histogram of map generated with r.surf.random</i>
</center>
@@ -37,5 +36,4 @@
<br><a href="http://www.geog.le.ac.uk/assist/index.html">ASSIST's home</a>
-<p>
Modified: grass/trunk/raster/r.terraflow/r.terraflow.html
--- grass/trunk/raster/r.terraflow/r.terraflow.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.terraflow/r.terraflow.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -25,8 +25,7 @@
neighbor. The MFD method assigns multiple flow directions towards all
downslope neighbors.
-<p>
-<table width="80%" align=center>
+<p><table width="80%" align=center>
<tr>
<th><img src="rterraflow_dir2.png" alt="[SFD]" border=0></th>
<th><img src="rterraflow_dir3.png" alt="[MFD]" border=0></th>
@@ -53,8 +52,7 @@
</ul>
-<p>
-In order to flood the terrain, <em>r.terraflow</em> identifies all
+<p>In order to flood the terrain, <em>r.terraflow</em> identifies all
sinks and partitions the terrain into sink-watersheds (a
sink-watershed contains all the cells that flow into that sink),
builds a graph representing the adjacency information of the
@@ -65,14 +63,12 @@
leading outside the terrain and therefore every cell in the terrain
can be assigned SFD/MFD flow directions as above.
-<p>
-Once flow directions are computed for every cell in the terrain,
+<p>Once flow directions are computed for every cell in the terrain,
<em>r.terraflow</em> computes flow accumulation by routing water using
the flow directions and keeping track of how much water flows through
each cell.
-<p>
-If flow accumulation of a cell is larger than the value given by the
+<p>If flow accumulation of a cell is larger than the value given by the
<b>d8cut</b> option, then
the flow of this cell is routed to its neighbors using the SFD (D8)
model. This option affects only the flow accumulation raster and is
@@ -80,13 +76,11 @@
this option is used for SFD flow it is ignored. The default value of
<b>d8cut</b> is <i>infinity</i>.
-<p>
-<em>r.terraflow</em> also computes the tci raster (topographic convergence
+<p><em>r.terraflow</em> also computes the tci raster (topographic convergence
index, defined as the logarithm of the ratio of flow accumulation and
local slope).
-<p>
-For more details on the algorithms see [1,2,3] below.
+<p>For more details on the algorithms see [1,2,3] below.
@@ -102,29 +96,25 @@
columns) in the elevation raster (more precisely, 80K bytes, where K
is the number of valid (not no-data) cells in the input elevation
raster).
-<p>
-All these intermediate temporary files are stored in the path specified
+<p>All these intermediate temporary files are stored in the path specified
by the <b>STREAM_DIR</b> option. Note: <b>STREAM_DIR</b> must contain
enough free disk space in order to store up to 2 x 80N bytes.
-<p>
-The <b>memory</b> option can be used to set the maximum amount of main
+<p>The <b>memory</b> option can be used to set the maximum amount of main
memory (RAM) the module will use during processing. In practice its
<i>value</i> should be an underestimate of the amount of available
(free) main memory on the machine. <em>r.terraflow</em> will use at
all times at most this much memory, and the virtual memory system
(swap space) will never be used. The default value is 300 MB.
-<p>
-The internal type used by <em>r.terraflow</em> to store elevations
+<p>The internal type used by <em>r.terraflow</em> to store elevations
can be defined at compile-time. By default, <em>r.terraflow</em> is
compiled to store elevations internally as floats.
A version which is compiled to store elevations internally as
shorts is available as <em>r.terraflow.short</em>. Other versions can
be created by the user if needed.
-<p>
-<em>r.terraflow.short</em> uses less space (up to 60B per cell, up
+<p><em>r.terraflow.short</em> uses less space (up to 60B per cell, up
to 60N intermediate file) and therefore is more space and time
efficient. <em>r.terraflow</em> is intended for use with floating
point raster data (FCELL), and <em>r.terraflow.short</em> with integer
@@ -132,8 +122,7 @@
value of a short SHRT_MAX=32767 (this is not a constraint for any
terrain data of the Earth, if elevation is stored in meters).
-<p>
-Both <em>r.terraflow</em> and <em>r.terraflow.short</em> work with
+<p>Both <em>r.terraflow</em> and <em>r.terraflow.short</em> work with
input elevation rasters which can be either integer, floating point or
double (CELL, FCELL, DCELL). If the input raster contains a value that
exceeds the allowed internal range (short for
@@ -144,8 +133,7 @@
<em>r.terraflow.short</em>, float for <em>r.terraflow</em>). In this
case precision may be lost and artificial flat areas may be created.
-<p>
-For instance, if <em>r.terraflow.short</em> is used with floating
+<p>For instance, if <em>r.terraflow.short</em> is used with floating
point raster data (FCELL or DCELL), the values of the elevation will
be truncated as shorts. This may create artificial flat areas, and the
output of <em>r.terraflow.short</em> may be less realistic than those
@@ -154,8 +142,7 @@
The outputs of <em>r.terraflow.short</em> and <em>r.terraflow</em> are
identical for integer raster data (CELL maps).
-<p>
-The <b>stats</b> option defines the name of the file that contains the
+<p>The <b>stats</b> option defines the name of the file that contains the
statistics (stats) of the run. The default name is <tt>stats.out</tt>
(in the current directory).
@@ -248,5 +235,4 @@
</ol>
-<p>
Modified: grass/trunk/raster/r.texture/r.texture.html
--- grass/trunk/raster/r.texture/r.texture.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.texture/r.texture.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,15 +4,12 @@
user-specified raster map layer. The module calculates textural features
based on spatial dependence matrices at 0, 45, 90, and 135
degrees for a <em>distance</em> (default = 1).
-<p>
-<em>r.texture</em> assumes grey levels ranging from 0 to 255 as input.
+<p><em>r.texture</em> assumes grey levels ranging from 0 to 255 as input.
The input is rescaled to 0 to 255 if needed.
-<p>
-In general, several variables constitute texture: differences in grey level values,
+<p>In general, several variables constitute texture: differences in grey level values,
coarseness as scale of grey level differences, presence or lack of directionality
and regular patterns.
-<p>
-<em>r.texture</em> reads a GRASS raster map as input and calculates textural
+<p><em>r.texture</em> reads a GRASS raster map as input and calculates textural
features based on spatial
dependence matrices for north-south, east-west, northwest, and southwest
directions using a side by side neighborhood (i.e., a distance of 1). The user
@@ -21,17 +18,14 @@
The output consists into four images for each textural feature, one for every
direction.
-<p>
-A commonly used texture model is based on the so-called grey level co-occurrence
+<p>A commonly used texture model is based on the so-called grey level co-occurrence
matrix. This matrix is a two-dimensional histogram of grey levels
for a pair of pixels which are separated by a fixed spatial relationship.
The matrix approximates the joint probability distribution of a pair of pixels.
Several texture measures are directly computed from the grey level co-occurrence
matrix.
-<p>
-The following are brief explanations of texture measures:
-<p>
-<ul>
+<p>The following are brief explanations of texture measures:
+<p><ul>
<li> Angular Second Moment (ASM, also called Uniformity):
This is a measure of local homogeneity and the opposite of Entropy.
High values of ASM occur when the pixels in the moving window are
@@ -107,8 +101,7 @@
The algorithm was implemented after Haralick et al., 1973.
-<p>
-The code was taken by permission from <em>pgmtexture</em>, part of
+<p>The code was taken by permission from <em>pgmtexture</em>, part of
PBMPLUS (Copyright 1991, Jef Poskanser and Texas Agricultural Experiment
Station, employer for hire of James Darrell McCauley). <br>
Manual page of <a href="http://netpbm.sourceforge.net/doc/pgmtexture.html">pgmtexture</a>
Modified: grass/trunk/raster/r.thin/r.thin.html
--- grass/trunk/raster/r.thin/r.thin.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.thin/r.thin.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,7 +5,6 @@
into linear features having a single cell width.
<p>
<em>r.thin</em> will thin only the non-zero cells of the
named <em>input</em> raster map layer within the current
geographic region settings. The cell width of the thinned
@@ -15,7 +14,6 @@
cell.
<p>
<em>r.thin</em> will create a new <em>output</em> raster
data file containing the thinned linear features.
<em>r.thin</em> assumes that linear features are encoded
@@ -29,14 +27,12 @@
on the resultant raster map to create a vector
(<em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector digitizer</a></em>) map layer.
-<p>
-<em>r.thin</em> may create small spurs or "dangling lines"
+<p><em>r.thin</em> may create small spurs or "dangling lines"
during the thinning process. These spurs may be removed
(after creating a vector map layer) by
<em><a href="v.clean.html">v.clean</a></em>.
<p>
<em>r.thin</em> creates a 0/1 output map.
<h2>NOTE</h2>
@@ -51,8 +47,7 @@
object while retaining any pixels whose removal would alter
the connectivity or shorten the legs of the sceleton."
-<p>
-The sceleton is finally thinned when the thinning process
+<p>The sceleton is finally thinned when the thinning process
converges; i.e., "no further pixels can be removed without
altering the connectivity or shortening the sceleton legs"
(p. 541). The authors prove that the thinning process
@@ -77,8 +72,7 @@
-<p>
-The code for finding the bounding box as well as input/output code
+<p>The code for finding the bounding box as well as input/output code
was written by Mike Baba (DBA Systems, 1990) and Jean Ezell (USACERL, 1988).
Modified: grass/trunk/raster/r.timestamp/r.timestamp.html
--- grass/trunk/raster/r.timestamp/r.timestamp.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.timestamp/r.timestamp.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -18,8 +18,7 @@
description of the format. For convience, the formats are reproduced
here:
-<p>
-There are two types of datetime values:
+<p>There are two types of datetime values:
<ul>
<li><em>absolute</em> and
@@ -132,5 +131,4 @@
-<p>
Modified: grass/trunk/raster/r.to.vect/r.to.vect.html
--- grass/trunk/raster/r.to.vect/r.to.vect.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.to.vect/r.to.vect.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,7 +14,6 @@
using <em><a href="r.thin.html">r.thin</a></em>.
<p>
<em>r.to.vect</em> extracts vectors (aka, "arcs") from a
raster map. These arcs may represent linear features
(like roads or streams), or may represent area edge
@@ -22,7 +21,6 @@
units).
<p>
<em><a href="r.thin.html">r.thin</a></em> and <em>r.to.vect</em>
may create excessive nodes at every junction, and may create small spurs
or "dangling lines" during the thinning and vectorization process.
@@ -39,7 +37,6 @@
resultant vector area edge data.
<p>
A true vector tracing of the area edges might appear
blocky, since the vectors outline the edges of raster data
that are stored in rectangular cells. To produce a
@@ -57,7 +54,6 @@
error introduced by smoothing.
<p>
<em>r.to.vect</em> extracts only area edges from the named raster input file.
If the raster map contains other data (i.e., line edges, or point data) the
output may be wrong.
@@ -88,8 +84,7 @@
Research Laboratory
-<p>
-<em>Modified</em> program for smoothed lines:
+<p><em>Modified</em> program for smoothed lines:
<br>
David Satnik,
Central Washington University
Modified: grass/trunk/raster/r.topidx/r.topidx.html
--- grass/trunk/raster/r.topidx/r.topidx.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.topidx/r.topidx.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,22 +2,18 @@
<em>r.topidx</em> creates topographic index (wetness index), ln(a/tan(beta)), map from
elevation map
-<p>
-where
+<p>where
<dl>
<dd>a: the area of the hillslope per unit contour length that drains through any point,
-<p>
-<dd>tan(beta): the local surface topographic slope (delta vertical) / (delta horizontal).
+<p><dd>tan(beta): the local surface topographic slope (delta vertical) / (delta horizontal).
</dl>
-<p>
-Input maps may have NULL values. For example, if you have a MASK for
+<p>Input maps may have NULL values. For example, if you have a MASK for
a watershed (basin map from <em>r.water.outlet</em>), the
following command will create a masked elevation map (belev):
<div class="code"><pre>
r.mapcalc "belev = if(isnull(basin), basin, elev)"
</pre></div>
<p>
<em>r.stats -Anc</em> prints out averaged statistics for topographic index.
<h2>SEE ALSO</h2>
@@ -35,8 +31,7 @@
Main algorithm sources are rewritten from GRIDATB.FOR.
<br>
Thanks to Keith Beven.
-<p>
-GRASS port by <a href="mailto:grass4u at gmail com">Huidae Cho</a><br>
+<p>GRASS port by <a href="mailto:grass4u at gmail com">Huidae Cho</a><br>
Hydro Laboratory, Kyungpook National University, South Korea
Modified: grass/trunk/raster/r.topmodel/r.topmodel.html
--- grass/trunk/raster/r.topmodel/r.topmodel.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.topmodel/r.topmodel.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,17 +2,14 @@
<b><em>r.topmodel</em></b> simulates TOPMODEL which is a physically based
hydrologic model.
-<p>
-Note: (i) means input; (o) means output; (o/i) means input or output
-<p>
-The <b>-i</b> flag indicates that input data are given for (o/i). Without this
+<p>Note: (i) means input; (o) means output; (o/i) means input or output
+<p>The <b>-i</b> flag indicates that input data are given for (o/i). Without this
flag, all inputs (i) and intermediate outputs (o/i) should be given. For
example, [belevation] map will be created from [elevation] and [basin] in every
run. However, given the same [elevation] and [basin], [belevation] output will
be the same all the time, so r.topmodel can directly take [belevation] as an
input with this flag to save time.
<p>
<h3>Selected Parameters:</h3>
<dl>
@@ -45,8 +42,7 @@
K. Beven, R. Lamb, P. Quinn, R. Romanowicz, and J. Freer.
TOPMODEL, in V.P. Singh (Ed.). Computer Models of Watershed Hydrology.
Water Resources Publications, 1995.
-<p>
-S.C. Liaw, Streamflow simulation using a physically based hydrologic
+<p>S.C. Liaw, Streamflow simulation using a physically based hydrologic
model in humid forested watersheds (Dissertation).
Colorado State University, CO. p163, 1988.
@@ -65,9 +61,7 @@
Main algorithm sources are rewritten in C based on TMOD9502.FOR.
<br>
-<p>
-<p>
Modified: grass/trunk/raster/r.transect/r.transect.html
--- grass/trunk/raster/r.transect/r.transect.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.transect/r.transect.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,18 +10,15 @@
each transect, may be the values at each of the cells, or a
single aggregate value (e.g., average or median value). -->
<p>
The <b>line</b> parameter is a definition of (each) transect line,
specified by the geographic coordinates of its starting point (<em>easting,
northing</em>), the angle and direction of its travel (<em>azimuth</em>),
and its distance (<em>distance</em>).
-<p>
-The <em>azimuth</em> is an angle, in degrees, measured to
+<p>The <em>azimuth</em> is an angle, in degrees, measured to
the east of north. The <em>distance</em> is in map units
(meters for a metered database, like UTM).
-<p>
-The <b>null</b> parameter can optionally be set to change the character
+<p>The <b>null</b> parameter can optionally be set to change the character
string representing null values.
<h2>NOTES</h2>
Modified: grass/trunk/raster/r.univar/r.univar.html
--- grass/trunk/raster/r.univar/r.univar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.univar/r.univar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -19,13 +19,11 @@
As with most GRASS raster modules, <em>r.univar</em> operates on the cell
array defined by the current region settings, not the original extent and
resolution of the input map. See <em><a href="g.region.html">g.region</a></em>.
-<p>
-This module can use large amounts of system memory when the <b>-e</b>
+<p>This module can use large amounts of system memory when the <b>-e</b>
extended statistics flag is used with a very large region setting. If the
region is too large the module should exit gracefully with a memory allocation
error. Basic statistics can be calculated using any size input region.
-<p>
-Without a <b>zones</b> input raster, the <em>r.quantile</em> module will
+<p>Without a <b>zones</b> input raster, the <em>r.quantile</em> module will
be significantly more efficient for calculating percentiles with large maps.
<h2>EXAMPLE</h2>
@@ -129,5 +127,4 @@
Extended statistics by Martin Landa<br>
Zonal loop by Markus Metz
-<p>
Modified: grass/trunk/raster/r.univar/r3.univar.html
--- grass/trunk/raster/r.univar/r3.univar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.univar/r3.univar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -19,15 +19,13 @@
As with most GRASS raster3d modules, <em>r3.univar</em> operates on the cell
array defined by the current 3d region settings, not the original extent and
-<p>
<!-- no rast3D support?
-<p>
-The <em>r.quantile</em> module will be significantly more efficient for
+<p>The <em>r.quantile</em> module will be significantly more efficient for
@@ -63,5 +61,4 @@
-<p>
Modified: grass/trunk/raster/r.uslek/r.uslek.html
--- grass/trunk/raster/r.uslek/r.uslek.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.uslek/r.uslek.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -18,8 +18,8 @@
<h2>SEE ALSO</h2>
<em>
-<a href="r.usler.html">r.usler</A><br>
-<a href="r.watershed.html">r.watershed</A><br>
+<a href="r.usler.html">r.usler</a><br>
+<a href="r.watershed.html">r.watershed</a><br>
</em>
@@ -28,5 +28,4 @@
Yann Chemin, SIC-ISDC, Turkmenistan<br>
-<p>
Modified: grass/trunk/raster/r.usler/r.usler.html
--- grass/trunk/raster/r.usler/r.usler.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.usler/r.usler.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,5 +20,4 @@
Natialia Medvedeva, SIC-ISDC, Ashgabat, Turkmenistan<br>
Yann Chemin, SIC-ISDC, Ashgabat, Turkmenistan
-<p>
Modified: grass/trunk/raster/r.volume/r.volume.html
--- grass/trunk/raster/r.volume/r.volume.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.volume/r.volume.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,8 +2,7 @@
<em>r.volume</em> is a tool for summing cell values within clumps
and calculating volumes and centroids of patches or clumps.
-<p>
-<em>r.volume</em> generates a table containing the sum of all cells from
+<p><em>r.volume</em> generates a table containing the sum of all cells from
a data_map layer sorted by category on a clump map, and optionally
generates a vector points map of the centroids for each clump. If a
clump map is not specified, the current MASK is used.
@@ -21,22 +20,17 @@
<h2>NOTES</h2>
-<p>
-If a clump map is not given and a MASK not set, the program exits
+<p>If a clump map is not given and a MASK not set, the program exits
with an error message.
+<p><em>r.volume</em> works in the current region and respects the current MASK.
<p>
-<em>r.volume</em> works in the current region and respects the current MASK.
-<p>
<h2>EXAMPLE</h2>
The following report was generated by the command:
(spearfish data base; fields.only is the fields layer without the
National Forest category)
+<p>r.volume data=elevation clump=fields.only centroids=field.centers
<p>
-r.volume data=elevation clump=fields.only centroids=field.centers
-<p>
<pre><tt>
Volume report on data from elevation using clumps on fields.only map
@@ -63,7 +57,6 @@
the units on the volume may be difficult if the units of cell
values on the data_map layer and the resolution units differ.
<p>
<h3>CENTROIDS</h3>
The centroid coordinates are the same as those stored in the sites
file (if one was requested). They are guaranteed to fall on a cell
@@ -82,11 +75,9 @@
sum,
count
</tt>
-<p>
-This can be converted directly to a raster map with each point
+<p>This can be converted directly to a raster map with each point
a separate category using <em>v.to.rast</em>.
<p>
<!-- As far as I can tell, no attributes are written to a table in Grass 6.3
(Jan 2008), as this program hasn't been updated to use the Grass 6 vector library. - EP
Modified: grass/trunk/raster/r.walk/r.walk.html
--- grass/trunk/raster/r.walk/r.walk.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.walk/r.walk.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,15 +12,12 @@
friction map, it considers an anisotropic travel time due to the
different walking speed associated with downhill and uphill movements.
<p>
The formula from Aitken 1977/Langmuir 1984 (based on Naismith's rule
for walking times) has been used to estimate the cost parameters of
specific slope intervals:
-<p>
-T= [(a)*(Delta S)] + [(b)*(Delta H uphill)] + [(c)*(Delta H moderate downhill)] + [(d)*(Delta H steep downhill)]
-<p>
-where:<br>
+<p>T= [(a)*(Delta S)] + [(b)*(Delta H uphill)] + [(c)*(Delta H moderate downhill)] + [(d)*(Delta H steep downhill)]
+<p>where:<br>
T is time of movement in seconds,<br>
Delta S is the distance covered in meters,<br>
Delta H is the altitude difference in meter.
@@ -44,14 +41,12 @@
default values for a, b, c, d are those proposed by Langmuir (0.72, 6.0,
1.9998, -1.9998), based on man walking effort in standard
conditions.<p>
The lambda parameter of the linear equation combining movement and
friction costs:<br>
total cost = movement time cost + (lambda) * friction costs<br>
must be set in the option section of <em>r.walk</em>.
<p>
For a more accurate result, the "knight's move" option can be used
(although it is more time consuming). In the diagram below, the center
location (O) represents a grid cell from which cumulative distances
@@ -67,14 +62,12 @@
K K
</pre></div>
-<p>
-The minimum cumulative costs are computed using Dijkstra's
+<p>The minimum cumulative costs are computed using Dijkstra's
algorithm, that find an optimum solution (for more details see
<em>r.cost</em>, that uses the same algorithm).
<a name="move"></a>
<h2>Movement Direction</h2>
-<p>
-The movement direction surface is created to record the sequence of
+<p>The movement direction surface is created to record the sequence of
movements that created the cost accumulation surface. Without it
<em>r.drain</em> would not correctly create a path from an end point
back to the start point. The direction shown in each cell points <b>away</b>
@@ -86,8 +79,7 @@
202.5 225 270 315 337.5
247.5 292.5
</pre></div>
-<p>
-Once <em>r.walk</em> computes the cumulative cost map as a linear
+<p>Once <em>r.walk</em> computes the cumulative cost map as a linear
combination of friction cost (from friction map) and the altitude and
distance covered (from the digital elevation model), <em>r.drain</em>
can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
@@ -120,8 +112,7 @@
<h2>AUTHORS</h2>
<b>Based on r.cost written by :</b>
-<p>
-Antony Awaida,<br>
+<p>Antony Awaida,<br>
Intelligent Engineering<br>
Systems Laboratory,<br>
M.I.T.<br>
@@ -132,21 +123,15 @@
<p>Updated for Grass 5<br>
Pierre de Mouveaux (pmx at audiovu.com)
-<p>
-<b>Initial version of r.walk:</b>
-<p>
-Steno Fontanari, 2002
+<p><b>Initial version of r.walk:</b>
+<p>Steno Fontanari, 2002
-<p>
-<b>Current version of r.walk:</b>
-<p>
-Franceschetti Simone, Sorrentino Diego, Mussi Fabiano and Pasolli Mattia<br>
+<p><b>Current version of r.walk:</b>
+<p>Franceschetti Simone, Sorrentino Diego, Mussi Fabiano and Pasolli Mattia<br>
Correction by: Fontanari Steno, Napolitano Maurizio and Flor Roberto<br>
In collaboration with: Franchi Matteo, Vaglia Beatrice, Bartucca Luisa, Fava Valentina and Tolotti Mathias, 2004
-<p>
-<b>Updated for Grass 6.1</b>
-<p>
-Roberto Flor and Markus Neteler
+<p><b>Updated for Grass 6.1</b>
+<p>Roberto Flor and Markus Neteler
Modified: grass/trunk/raster/r.water.outlet/r.water.outlet.html
--- grass/trunk/raster/r.water.outlet/r.water.outlet.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.water.outlet/r.water.outlet.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -63,8 +63,7 @@
d.his h=accum_5K i=basin_A30
</pre></div>
-<p>
-<center>
+<p><center>
<img src="r_water_outlet.png" border=0><br>
<i>Watershed draped over flow accumulation</i>
</center>
Modified: grass/trunk/raster/r.what/r.what.html
--- grass/trunk/raster/r.what/r.what.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.what/r.what.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,20 +6,16 @@
eastings and northings); the user can also (optionally) associate a label
with each location.
-<p>
-The input coordinates can be entered directly on the command line, or
+<p>The input coordinates can be entered directly on the command line, or
redirected via <tt>stdin</tt> from an input text file, script, or piped from
another program (like <em><a href="d.where.html">d.where</a></em>).
-<p>
-If none of the above input methods are used and the module is run from the
+<p>If none of the above input methods are used and the module is run from the
terminal prompt, the program will interactively query the user for point
locations and labels.
-<p>
-Each line of the input consists of an easting, a northing, and an optional
+<p>Each line of the input consists of an easting, a northing, and an optional
label, which are separated by spaces. In interactive mode, the word
"<tt>end</tt>" must be typed after the last pair of input coordinates.
-<p>
-<em>r.what</em> output consists of the input geographic location and label,
+<p><em>r.what</em> output consists of the input geographic location and label,
and, for each user-named raster map layer, the category value, and (if
the <b>-f</b> label flag is specified) the category label associated with
the cell(s) at this geographic location.
@@ -141,5 +137,4 @@
Michael Shapiro,
-<p>
Modified: grass/trunk/raster/r.what.color/r.what.color.html
--- grass/trunk/raster/r.what.color/r.what.color.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster/r.what.color/r.what.color.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,12 +2,10 @@
<em>r.what.color</em> outputs the color associated with user-specified
category values in a raster input map.
-<p>
-Values may be specified either using the <b>values=</b> option, or by
+<p>Values may be specified either using the <b>values=</b> option, or by
specifying the <b>-i</b> flag and passing the values on
<tt>stdin</tt>, one per line.
-<p>
-For each value which is specified, a line of output will be generated
+<p>For each value which is specified, a line of output will be generated
consisting of the category value followed by the color, e.g.:
@@ -15,13 +13,11 @@
1500: 223:127:31
</pre></div>
-<p>
-If the input map is an integer (CELL) map, the category will be
+<p>If the input map is an integer (CELL) map, the category will be
written as an integer (no decimal point), otherwise it will be written
in floating point format (<i>printf("%.15g")</i> format).
-<p>
-If the lookup fails for a value, the color will be output as an
+<p>If the lookup fails for a value, the color will be output as an
asterisk, e.g.:
@@ -29,8 +25,7 @@
9999: *
</pre></div>
-<p>
-If a value cannot be parsed, both the value and the color will be
+<p>If a value cannot be parsed, both the value and the color will be
output as an asterisk, e.g.:
@@ -38,8 +33,7 @@
</pre></div>
-<p>
-The format can be changed using the <b>format=</b> option. The value
+<p>The format can be changed using the <b>format=</b> option. The value
should be a <i>printf()</i>-style format string containing three
conversion specifiers for the red, green and blue values respectively,
e.g.:
@@ -49,8 +43,7 @@
1500: df:7f:1f
</pre></div>
-<p>
-If your system supports the <i>%m$</i> syntax, you can change the
+<p>If your system supports the <i>%m$</i> syntax, you can change the
ordering of the components, e.g.:
@@ -58,8 +51,7 @@
1500: 1f:7f:df
</pre></div>
-<p>
-Common formats:<br>
+<p>Common formats:<br>
<ul>
<li>Tcl/Tk: <tt>format="#%02x%02x%02x"</tt>
<li>WxPython: <tt>format='"#%02x%02x%02x"'</tt> or <tt>format='"(%d,%d,%d)"'</tt>
Modified: grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html
--- grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,8 +15,7 @@
</table>
</center>
-<p>
-If the 2D and 3D region settings are different,
+<p>If the 2D and 3D region settings are different,
the 2D resolution will be adjust to the 3D resolution.
<h2>NOTES</h2>
Modified: grass/trunk/raster3d/r3.gwflow/r3.gwflow.html
--- grass/trunk/raster3d/r3.gwflow/r3.gwflow.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.gwflow/r3.gwflow.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,17 +5,14 @@
and the current 3D region settings.
All initial- and boundary-conditions must be provided as volume maps.
-<p>
the mask are ignored and handled as no flow boundaries.
-<p>
-The module calculates the piezometric head and optionally the water
+<p>The module calculates the piezometric head and optionally the water
balance for each cell and the groundwater velocity field in 3 dimensions.
The vector components can be visualized with ParaView if they are exported
with <em>r3.out.vtk</em>.
-<p>
-The groundwater flow will always be calculated transient.
+<p>The groundwater flow will always be calculated transient.
For steady state computation the user should set the timestep
to a large number (billions of seconds) or set the
specific yield raster map to zero.
@@ -28,12 +25,9 @@
<i>Ax = b</i>, which must be solved. The groundwater flow partial
-<p>
-(dh/dt)*S = div (K grad h) + q
-<p>
-In detail for 3 dimensions:
-<p>
-(dh/dt)*S = Kxx * (d^2h/dx^2) + Kyy * (d^2h/dy^2) + Kzz * (d^2h/dz^2) + q
+<p>(dh/dt)*S = div (K grad h) + q
+<p>In detail for 3 dimensions:
+<p>(dh/dt)*S = Kxx * (d^2h/dx^2) + Kyy * (d^2h/dy^2) + Kzz * (d^2h/dz^2) + q
<ul>
<li>h -- the piezometric head im meters [m]</li>
@@ -46,8 +40,7 @@
<li>q - inner source/sinc in [1/s]</li>
</ul>
-<p>
-Two different boundary conditions are implemented, the Dirichlet and
+<p>Two different boundary conditions are implemented, the Dirichlet and
Neumann conditions. By default the calculation area is surrounded by
homogeneous Neumann boundary conditions. The calculation and boundary
status of single cells can be set with the status map, the following
@@ -62,13 +55,11 @@
head value which do not change over time </li>
</ul>
-<p>
-Note that all required raster maps are read into main memory. Additionally
+<p>Note that all required raster maps are read into main memory. Additionally
the linear equation system will be allocated, so the memory consumption of
this module rapidely grow with the size of the input maps.
-<p>
-The resulting linear equation system <i>Ax = b</i> can be solved with
+<p>The resulting linear equation system <i>Ax = b</i> can be solved with
several solvers. An iterative solvers with sparse and quadratic matrices
support is implemented.
The conjugate gradients method with (pcg) and without (cg) precondition.
@@ -142,8 +133,7 @@
<h2>AUTHOR</h2>
Sören Gebbert
-<p>
<a href="http://www.hydrogeologie.tu-berlin.de/fileadmin/fg66/_hydro/Diplomarbeiten/2007_Diplomarbeit_Sören_Gebbert.pdf">here</a>
at Technical University Berlin, Germany.
Modified: grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html
--- grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,18 +3,15 @@
<em>r3.in.ascii</em> allows a user to create a (binary) GRASS 3D raster map
layer from a 3D ASCII raster input file with (optional) TITLE.
-<p>
-Note that for compression the <em>none</em> option only specifies
+<p>Note that for compression the <em>none</em> option only specifies
that neither LZW nor RLE is used for compression. It
does not turn off the compression all together. 3D raster maps do
not support non-compressed files.
-<p>
-The <em>tiledimension</em> parameter defines the dimension of the tiles
+<p>The <em>tiledimension</em> parameter defines the dimension of the tiles
used in the output file. The format is: XxYxZ
-<p>
-The <em>nv</em> parameter specifies which value to convert to NULL-value.
+<p>The <em>nv</em> parameter specifies which value to convert to NULL-value.
If the specified value is <em>none</em>, no conversion is performed.
Default is <em>none</em>.
@@ -53,11 +50,9 @@
<em>north -> south, west -> east, bottom -> top</em> order.
So dependent on the order information the data is automatically imported
into the correct internal coordinate system.
-<p>
-The version and order options are not mandatory. In case no version and
+<p>The version and order options are not mandatory. In case no version and
order option is specified, the default GRASS 6 ASCII format is assumed.
-<p>
-This header is followed by the cell values in <em>floating point</em> format
+<p>This header is followed by the cell values in <em>floating point</em> format
organized in rows with constant <em>col</em> and <em>level</em> coordinate.
The rows are organized by constant <em>level</em> coordinate. Individual cell
values are separated by <em>space</em> or <em>CR</em>.
@@ -104,5 +99,4 @@
<a href="v.to.rast3.html">v.to.rast3</a>
</em>
-<p>
Modified: grass/trunk/raster3d/r3.in.v5d/r3.in.v5d.html
--- grass/trunk/raster3d/r3.in.v5d/r3.in.v5d.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.in.v5d/r3.in.v5d.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,8 +4,7 @@
one variable and one time step). Otherwise, only first variable and
timestep from 4/5D V5D file will be imported.
-<p>
-<a href="http://www.ssec.wisc.edu/~billh/vis5d.html">Vis5D</a> is a system
+<p><a href="http://www.ssec.wisc.edu/~billh/vis5d.html">Vis5D</a> is a system
for interactive visualization of large 5D gridded data sets such as those
produced by numerical weather models. The user can make isosurfaces, contour
line slices, colored slices, volume renderings, etc. of data in a 3D raster map,
Modified: grass/trunk/raster3d/r3.mask/r3.mask.html
--- grass/trunk/raster3d/r3.mask/r3.mask.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.mask/r3.mask.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
File <em>map</em> is used as reference file.
Cells in the mask are marked as "mask out" if the corresponding cell in
<em>map</em> contains a value in the range specified with <em>maskvalues</em>.
-<p>
-Before a new 3D-mask can be created the exisitng mask has to be removed
+<p>Before a new 3D-mask can be created the exisitng mask has to be removed
with <em>g.remove</em>.
<h2>SEE ALSO</h2>
Modified: grass/trunk/raster3d/r3.mkdspf/r3.mkdspf.html
--- grass/trunk/raster3d/r3.mkdspf/r3.mkdspf.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.mkdspf/r3.mkdspf.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,7 +8,7 @@
to specify a sub-range of the data. The <I>step</I>
parameter is given precedence over <I>tnum</I>.
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
<dt><b>-q</b>
<dd>Suppress progress report & min/max information
@@ -17,7 +17,7 @@
<dd>Use flat shading rather than gradient
</dl>
-<H3>Parameters:</H3>
+<h3>Parameters:</h3>
<dl>
<dt><b>grid3</b>
<dd>Name of an existing 3D raster map
@@ -62,7 +62,7 @@
<h2>AUTHOR</h2>
<p>Bill Brown,
-<a href="mailto:brown at gis.uiuc.edu">bbrown at gis.uiuc.edu</A>
+<a href="mailto:brown at gis.uiuc.edu">bbrown at gis.uiuc.edu</a>
Modified: grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html
--- grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,12 +4,10 @@
a valid 3D raster map in the current mapset search path. The <em>output</em>
parameter is the name of an ASCII file which will be written in the
current working directory.
-<p>
-If <em>output</em> is not specified then standard output (stdout) is used.
+<p>If <em>output</em> is not specified then standard output (stdout) is used.
The <em>-h</em> flag may be used to suppress header information. The
module is sensitive to region settings (set with <em>g.region</em>).
-<p>
-The <em>-c</em> flag will create GRASS 6 <em>r3.in.ascii</em> compatible
+<p>The <em>-c</em> flag will create GRASS 6 <em>r3.in.ascii</em> compatible
output.
<h2>NOTES</h2>
@@ -18,8 +16,7 @@
<em>r3.out.ascii</em> with header information may be converted back to
3D raster maps with <em>r3.in.ascii</em>.
-<p>
-The format of the ASCII file is:
+<p>The format of the ASCII file is:
version: <i>"grass7"</i>
order: <i>"nsbt" or "nstb" or "snbt" or "sntb"</i>
@@ -38,8 +35,7 @@
The <b>order</b> option describes the order of rows and depths in the output.
It is possible to create output of different row order using the <em>-r</em> flag
and output of different depths order using the <em>-d</em> flag. The default order is:
-<p>
-<div class="code"><pre>
+<p><div class="code"><pre>
west -> east for columns
north -> south for rows
bottom -> top for depths
@@ -80,8 +76,7 @@
The data starts with the upper left corner (NW) at the bottom of the data set.
-<p>
-One level maps can be imported with <em>r.in.ascii</em> (2D raster) using
+<p>One level maps can be imported with <em>r.in.ascii</em> (2D raster) using
the default <b>nsbt</b> order and removing the header lines "version",
"order", "top", "bottom" and "levels".
Modified: grass/trunk/raster3d/r3.out.v5d/r3.out.v5d.html
--- grass/trunk/raster3d/r3.out.v5d/r3.out.v5d.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.out.v5d/r3.out.v5d.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
parameter is the name of a V5D file which will be written in the current
working directory.
-<p>
Modified: grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html
--- grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -25,36 +25,30 @@
ParaView can be used to visualize the valid data. Just filter all data which is
greater/lesser than the chosen null value in the VTK-ASCII file.
-<p>
-The top and bottom region values are expected in meters.
+<p>The top and bottom region values are expected in meters.
If a Latitude-Longitude (LL) coordinates are used, the elevation value for each
voxel will be converted into degrees.
-<p>
-The <em>input</em>, <em>rgbmaps</em> and <em>vectormaps</em> parameters are
+<p>The <em>input</em>, <em>rgbmaps</em> and <em>vectormaps</em> parameters are
optional, so only the geometry can be exported.
-<p>
-If the user defines <em>top</em> and <em>bottom</em> and the 2D and 3D region
+<p>If the user defines <em>top</em> and <em>bottom</em> and the 2D and 3D region
values differ, the 2D resolution will be adjusted to the 3D resolution. The
elevation maps are expected in meters. If Lat/Long coordinates are used, the
elevation will automatically converted into degree.
If the surface and bottom maps are in a different unit than meters, use the
scale parameter to convert them into meters.
-<p>
-The RGB voxel data can be created from 2D raster maps (Landsat TM images)
+<p>The RGB voxel data can be created from 2D raster maps (Landsat TM images)
with <em><a href="r.to.rast3.html">r.to.rast3</a></em>. The values of the RGB maps
must be within 0 and 255. If not, the values are automatically set
to 0 and warnings will be printed to stderr.
-<p>
-The vector data is created from three 3D raster maps. Each map represents a vector component.
+<p>The vector data is created from three 3D raster maps. Each map represents a vector component.
So x, y and z components are required in this order. This data can be visualized with Glyph3d or
StreamTracer filters within Paraview.
-<p>
-If the <em>-c</em> flag is used and the data should be visualised together with
+<p>If the <em>-c</em> flag is used and the data should be visualised together with
other data exported via <em>*.out.vtk</em> modules, be sure the <em>-c</em> flag
was also set in these modules. But this will only work with data from the SAME
location (the reference point for the coordinates transformation is based on the
Modified: grass/trunk/raster3d/r3.showdspf/r3.showdspf.html
--- grass/trunk/raster3d/r3.showdspf/r3.showdspf.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.showdspf/r3.showdspf.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,15 +6,13 @@
dspf file to draw isosurfaces and 3D raster map to draw planes and everything
related (boxes, etc).
-<p>
-Upon initialization of the program, two graphics windows are
+<p>Upon initialization of the program, two graphics windows are
opened, one for the color table and the other for data display. The
display window initially contains a red bounding box. Command options
are then printed to the terminal and user is prompted for drawing
instructions:
-<p>
-<pre>
+<p><pre>
THE INTERACTIVE OPTIONS ARE:
?, (l #), L, (t #), (T # #), I, +, -
@@ -68,7 +66,6 @@
</pre>
<p>
<h3>Hints:</h3>
<ul>
<li>To navigate around the data, use the <em>r</em> command, then place
@@ -90,35 +87,29 @@
After generating a "dspf" control file with <em>r3.mkdspf</em> start
<em>r3.showdspf</em>. Display/add the layers using <em>+</em>.
-<p>
-List available thresholds with <em>?</em>. Use <em>l</em> to select isosurfaces (available
+<p>List available thresholds with <em>?</em>. Use <em>l</em> to select isosurfaces (available
number can be adjusted with <em>r3.mkdspf</em>) and <em>L</em> to display:
<br>
<tt>l 1 2 3 4 5<br> L </tt>
-<p>
-To select and display a single threshold (here: 2), use:<br>
+<p>To select and display a single threshold (here: 2), use:<br>
<tt>t 2</tt>
-<p>
-To select and display a range of thresholds (here: 3-5), use:<br>
+<p>To select and display a range of thresholds (here: 3-5), use:<br>
<tt>T 3 5<br>
D</tt>
-<p>
-To draw a box, enter<br>
+<p>To draw a box, enter<br>
<tt>p</tt><br>
the p# to plot a selected wall (here top wall):<br>
<tt>p1</tt>
-<p>
-Tp draw a cut-off box, define it's position<br>
+<p>Tp draw a cut-off box, define it's position<br>
<tt>Ex20</tt><br>
<tt>p</tt><br>
Here Ex20 defines the x coordinate of the end of the box.
-<p>
-In general - <em>p</em> draws a side of a box, <em>E</em>, <em>B</em>, define where that box starts or
+<p>In general - <em>p</em> draws a side of a box, <em>E</em>, <em>B</em>, define where that box starts or
ends, so to make a fence diagram, the user draws sides of a series of boxes
which have their starting (or ending) side shifting by a given interval.
(this way the user can draw even more complex fence diagrams which have
@@ -126,8 +117,7 @@
<em>B</em> depending whether fence are drawn by using the end side or front side of a
box).
-<p>
-To draw a fence, a sequence like this would be needed<br>
+<p>To draw a fence, a sequence like this would be needed<br>
<tt>Ex10<br>
p5<br>
Ex15<br>
@@ -146,8 +136,7 @@
Bx20<br>
p6</tt>
-<p>
-The <em>p</em> is needed for the fence diagram, solids and boxes.
+<p>The <em>p</em> is needed for the fence diagram, solids and boxes.
<h2>SEE ALSO</h2>
<em><a href="r3.mkdspf.html">r3.mkdspf</a></em>
Modified: grass/trunk/raster3d/r3.showdspf/r3.showdspf_opengl_mods.html
--- grass/trunk/raster3d/r3.showdspf/r3.showdspf_opengl_mods.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.showdspf/r3.showdspf_opengl_mods.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,12 +8,10 @@
<body bgcolor="#ffffff">
-<p>
-<font size="4"><b>Description of modifications made to r3.showdspf directory during conversion of code from
+<p><font size="4"><b>Description of modifications made to r3.showdspf directory during conversion of code from
IrisGL (running only on SGI workstations) to OpenGL (running on any OpenGL-capable UNIX workstation)</b>
-<p>
-The following files were changed (and perhaps renamed during conversion)<br>
+<p>The following files were changed (and perhaps renamed during conversion)<br>
</font><tt>do_color.c -> do_color_ogl.c<br>
draw_cap.c -> draw_cap_ogl.c<br>
draw_polys.c -> draw_polys_ogl.c<br>
Modified: grass/trunk/raster3d/r3.stats/r3.stats.html
--- grass/trunk/raster3d/r3.stats/r3.stats.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.stats/r3.stats.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,8 +12,7 @@
As with most GRASS 3D raster map modules, <em>r3.stats</em> operates on the cell
array defined by the current 3D region settings, not the original extent and
resolution of the input map. See <em>g.region</em>.
-<p>
-The region setting will not effect the memory consumption of this module.
+<p>The region setting will not effect the memory consumption of this module.
The number of subranges in case of value range calculation or the number of
equal value groups effect the memory consumption and the calculation time.
The user can expect a huge time consumption to calculate the equal value
@@ -29,8 +28,7 @@
equal values into single volumes.
<em>r3.stats geology -e</em> will produce the following output:
-<p>
num | value | volume | perc | count
1 1.000000 300822000.000 50.13700 50137
2 2.000000 101400000.000 16.90000 16900
@@ -100,5 +98,4 @@
<h2>AUTHOR</h2>
Sören Gebbert
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster3d/r3.timestamp/r3.timestamp.html
--- grass/trunk/raster3d/r3.timestamp/r3.timestamp.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/raster3d/r3.timestamp/r3.timestamp.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,20 +14,16 @@
there is a timestamp, one or two lines are printed,
depending on if the timestamp for the map consists of a
single date or two dates (ie start and end dates).
-<p>
-<b>r3.timestamp map=soils date='15 sep 1987'</b><br>
+<p><b>r3.timestamp map=soils date='15 sep 1987'</b><br>
Sets the timestamp for "soils" to the single date<br>
"15 sep 1987"
-<p>
-<b>r3.timestamp map=soils date='15 sep 1987/20 feb 1988'</b><br>
+<p><b>r3.timestamp map=soils date='15 sep 1987/20 feb 1988'</b><br>
Sets the timestamp for "soils" to have the start date<br>
"15 sep 1987" and the end date "20 feb 1988"
-<p>
-<b>r3.timestamp map=soils date='18 feb 2005 10:30:00/20 jul 2007 20:30:00'</b><br>
+<p><b>r3.timestamp map=soils date='18 feb 2005 10:30:00/20 jul 2007 20:30:00'</b><br>
"18 aug 2005 10:30:00" and the end date "20 jul 2007 20:30:00"
<p>
<b>r3.timestamp map=soils date=none</b><br>
Removes the timestamp for the "soils" 3D raster map
@@ -36,14 +32,11 @@
GRASS datetime library. The source tree for this library
should have a description of the format. For convience, the
formats as of Feb, 1996 are reproduced here:
-<p>
- There are two types of datetime values: absolute and
+<p> There are two types of datetime values: absolute and
relative. Absolute values specify exact dates and/or times.
Relative values specify a span of time. Some examples will
help clarify:
-<p>
-<b>Absolute</b><p>
- The general format for absolute values is
+<p><b>Absolute</b><p> The general format for absolute values is
<p><tt>
day month year [bc] hour:minute:seconds timezone
<br>
@@ -72,11 +65,9 @@
<p><tt>
[-] # years # months<br>
[-] # days # hours # minutes # seconds
-</tt><p>
- The words years, months, days, hours, minutes, seconds
+</tt><p> The words years, months, days, hours, minutes, seconds
are literal words, and the # are the numeric values.<br>
- Examples:<p>
-<tt>
+ Examples:<p><tt>
2 years<br>
5 months<br>
2 years 5 months<br>
@@ -84,11 +75,9 @@
15 hours 25 minutes 35.34 seconds<br>
100 days 25 minutes<br>
1000 hours 35.34 seconds
-</tt><p>
- The following are <i>illegal</i> because it mixes year-month
+</tt><p> The following are <i>illegal</i> because it mixes year-month
and day-second (because the number of days in a month
- or in a year vary):<p>
-<tt>
+ or in a year vary):<p><tt>
3 months 15 days<br>
3 years 10 days
</tt>
Modified: grass/trunk/scripts/d.correlate/d.correlate.html
--- grass/trunk/scripts/d.correlate/d.correlate.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/d.correlate/d.correlate.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
highlights the correlation (or lack of it) among data
layers (scattergram).
-<p>
-The results are displayed in the active display frame on
+<p>The results are displayed in the active display frame on
the user's graphics monitor. <em>d.correlate</em> erases
the active frame before displaying results.
@@ -18,8 +17,7 @@
<h2>EXAMPLE</h2>
Scatterplot of two LANDSAT TM7 channels (North Carolina sample dataset):
-<p>
g.region rast=lsat7_2002_30 -p
d.correlate map=lsat7_2002_30,lsat7_2002_40
</pre></div>
@@ -38,7 +36,6 @@
Michael Shapiro,
<a href="http://www.cecer.army.mil/">U.S.Army Construction Engineering Research Laboratory</a>
-<p>
-Rewritten to GRASS 6 (from csh to sh) by Markus Neteler; from sh to Python by Glynn Clements
+<p>Rewritten to GRASS 6 (from csh to sh) by Markus Neteler; from sh to Python by Glynn Clements
Modified: grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html
--- grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,24 +5,20 @@
image and updates the GpsDrive image list with the appropriate geo-referencing
information.
-<p>
-<b><em>Use at your own risk. Do not use as a primary means of navigation.
+<p><b><em>Use at your own risk. Do not use as a primary means of navigation.
This software comes with absolutely no warranty.</em></b>
-<p>
-<h2>NOTES</h2>
+<p><h2>NOTES</h2>
Maps are saved in the user's <tt>~/.gpsdrive/maps/</tt> directory.
Geo-referencing information is added to the user's
<tt>~/.gpsdrive/maps/map_koord.txt</tt> file.
-<p>
-JPEG output requires the <tt>pngtopnm</tt> and <tt>pnmtojpeg</tt> programs
+<p>JPEG output requires the <tt>pngtopnm</tt> and <tt>pnmtojpeg</tt> programs
from the <a href="http://netpbm.sourceforge.net">NetPBM tools</a>.
-<p>
-GpsDrive assumes northings are not rotated compared to true-geographic north.
+<p>GpsDrive assumes northings are not rotated compared to true-geographic north.
If you are using a projection with significant curvature away from the central
meridian, or a map datum with a significant rotational component, then you will
likely end up with a distorted or inexact background map!
@@ -31,16 +27,13 @@
centered directly on the center of your map. You can check the local
convergence angle (difference between grid north and true north) with
"<tt>g.region -n</tt>".
-<p>
-To avoid distortion, anything more global than 1:150k to 1:500k
+<p>To avoid distortion, anything more global than 1:150k to 1:500k
should come from a lat/lon location. Anything more local than that
will look better coming from a projected system such as UTM.
-<p>
-The extent of a map given a target scale can be calculated with
+<p>The extent of a map given a target scale can be calculated with
<tt>x_ext=scale*(1280/2817.95)</tt>. e.g. 1:50,000 translates to approx
a 22.7km x 18.2km image window in the GIS.
-<p>
-For your convenience (calculations are rough, but nominal):
+<p>For your convenience (calculations are rough, but nominal):
1:50,000 uses a region 22.7km x 18.2km.
1:75,000 uses a region 34.1km x 27.3km.
@@ -54,13 +47,11 @@
Maps exported from locations of other projections will be given a
"<tt>map_</tt>" prefix. This is done so GpsDrive knows how to scale the
image correctly.
-<p>
-GpsDrive requires backdrop images to be 1280x1024 pixels in size. While this
+<p>GpsDrive requires backdrop images to be 1280x1024 pixels in size. While this
script takes care of that automatically, to avoid annoying bands on the sides
of your image you may want to set up your display monitor at half-scale (same
aspect ratio) and use d.zoom to select the full frame. For example:
-<p>
export GRASS_WIDTH=640
export GRASS_HEIGHT=512
d.mon wx0
@@ -76,8 +67,7 @@
It may be desirable to create a series of image tiles covering a large area.
An easy way to do this is to run <em>d.out.gpsdrive</em> in a shell loop.
Here is an example Bash script contributed by Manuel Morales:
-<p>
#!/bin/bash
# map scale is determined by "panels" by dividing the N-S
@@ -124,15 +114,15 @@
<br><br>
<h2>SEE ALSO</h2>
-<em><a href="d.info.html">d.info</A></em>,
-<em><a href="d.grid.html">d.grid</A></em>,
-<em><a href="d.out.file.html">d.out.file</A></em>,
-<em><a href="d.out.png.html">d.out.png</A></em>,
-<em><a href="d.save.html">d.save</A></em>,
-<em><a href="g.region.html">g.region</A></em>,
-<em><a href="v.in.garmin.html">v.in.garmin</A></em>
+<em><a href="d.info.html">d.info</a></em>,
+<em><a href="d.grid.html">d.grid</a></em>,
+<em><a href="d.out.file.html">d.out.file</a></em>,
+<em><a href="d.out.png.html">d.out.png</a></em>,
+<em><a href="d.save.html">d.save</a></em>,
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="v.in.garmin.html">v.in.garmin</a></em>
<br><br>
-The GRASS <a href="pngdriver.html">PNG driver</A><br>
+The GRASS <a href="pngdriver.html">PNG driver</a><br>
The <a href="http://www.gpsdrive.de">GpsDrive</a> project<br>
The <a href="http://gpsd.berlios.de">gpsd</a> personal GPS server project
@@ -145,5 +135,4 @@
New Zealand</i><br>
<br>
-<p>
Modified: grass/trunk/scripts/d.polar/d.polar.html
--- grass/trunk/scripts/d.polar/d.polar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/d.polar/d.polar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,17 +5,14 @@
The input angle map orientation must be counter-clockwise (CCW)
from east, and the angle map units must be degrees. This refers
to the standard orientation of GRASS (e.g., see <em>r.slope.aspect</em>).
-<p>
-The radius of the outer circle is defined by the total number
+<p>The radius of the outer circle is defined by the total number
of pixels in the map. If the polar diagram does not reach the
outer circle, no data (NULL) pixels were found in the map.
-<p>
-The vector in the diagram indicates a prevailing direction, its length
+<p>The vector in the diagram indicates a prevailing direction, its length
the strength of such direction. In case all angle vectors are oriented
along the same direction, the length for the vector is maximal (in fact
it is equal to length of the most populated bin of the underlying histogram).
-<p>
-As a side effect, the quality of the angle map can be derived from
+<p>As a side effect, the quality of the angle map can be derived from
the diagram. Strong spikes may indicate an over-representation of
the related angle(s) which happens in particular if integer maps
are used.
@@ -26,13 +23,11 @@
as EPS file. If the <b>-x</b> flag is used <em>xgraph</em> is lauched.
Otherwise <em>d.polar</em> will use <em>d.graph</em> to draw the plot
in the current display frame.
-<p>
-If <em>d.polar</em> is used on an aspect map generated by
+<p>If <em>d.polar</em> is used on an aspect map generated by
<em>r.slope.aspect</em>, the <b>undef</b> parameter should be
set to 0 to distinguish NO DATA (NULL) areas from areas where
aspect is undefined (i.e. flat areas).
<p>
<center>
<img src="d_polar_aspect.png" alt="Polar diagram of aspect map">
<br>
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.html
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,40 +11,37 @@
program. Parts of it may be out of date or wrong.</I></b>
-<H3>Overview window</H3>
+<h3>Overview window</h3>
An overview window shows the entire map with a box showing the current
editing region. The edit window shows the cells within the selected area.
Click on a new spot on the overview window to move the editing area.
Moving the editing view can take a while.
-<H3>Mouse and menus</H3>
+<h3>Mouse and menus</h3>
Cell editing is done using a mouse cursor to choose menu selections
and indicate areas on the displayed raster map that are to be edited.
-<p>
-Selections available at the top of the edit window are <b>Save</b> and
+<p>Selections available at the top of the edit window are <b>Save</b> and
<b>Exit</b>.
<p>
As the mouse travels over the cells in the edit window you are shown the
current coordinates and current cell values under the cursor.
-<p>
-To change the value of a cell put the new value to use in the "New value"
+<p>To change the value of a cell put the new value to use in the "New value"
box at the bottom left of the edit window under the coordinate information
bar. A value of "*" indicates a NULL value should be used.
-<H3>Arrows</H3>
+<h3>Arrows</h3>
This function is available for users editing aspect maps. The
-<em><a href="d.rast.arrow.html">d.rast.arrow</A></em> program is
+<em><a href="d.rast.arrow.html">d.rast.arrow</a></em> program is
called, which draws arrows over the displayed
cells to indicate the downslope direction of the cell.
You can set the aspect map to use on the command line.
Aspect maps are expected to be in regular "GRASS" format, as produced by
-<em><a href="r.slope.aspect.html">r.slope.aspect</A></em>; i.e. degrees
+<em><a href="r.slope.aspect.html">r.slope.aspect</a></em>; i.e. degrees
counter-clockwise from east.
@@ -52,18 +49,16 @@
There is no "undo" command or way to exit edit mode without saving
changes.
-<p>
-Any MASK in place will be respected when writing the new raster map layer,
+<p>Any MASK in place will be respected when writing the new raster map layer,
including any edits to the MASKed areas.
-<H3>Geographic Region Concerns</H3>
+<h3>Geographic Region Concerns</h3>
<em>d.rast.edit</em> reads the region definition for the raster map layer
being edited from its internal cell header file. The new, edited copy of
the raster layer will be created with the same resolution and region
dimensions.
-<p>
-The primary bane of the <em>d.rast.edit</em> program involves large map
+<p>The primary bane of the <em>d.rast.edit</em> program involves large map
layers with lots of rows and columns) and/or slow computers,
since the program must read and write raster map layers row by row for
the full size of the map layer as dictated by its region size and resolution.
@@ -78,11 +73,10 @@
<!-- not true, but it would be nice
<em>d.rast.edit</em> will not create a new raster map layer if
the user makes no cell edits while running the program.
-<p>
+<p>-->
It would be nice to incorporate a scrollable version of <em>
-<a href="d.legend.html">d.legend</A>
+<a href="d.legend.html">d.legend</a>
</em>
(such that one could see a label legend for files with many categories on
a standard size sub-frame). It would be even nicer to be able
@@ -90,15 +84,13 @@
cell values (thereby saving a trip to the text frame to type in the
new value).
-<p>
-Perhaps method(s) for multiple or mass cell edits would be useful.
+<p>Perhaps method(s) for multiple or mass cell edits would be useful.
This could be done by providing modes in which the user may:<br>
1) edit a block of cells to a given value by drawing a box;<br>
2) be able to choose a given value which is automatically used as
the new value on each cell chosen until a different value is desired.
-<p>
-There is no interrupt handling. <!-- ?? --> This could leave files in .tmp
+<p>There is no interrupt handling. <!-- ?? --> This could leave files in .tmp
or (rarely) result in half-baked raster maps. The original file
would survive unscathed by an interrupt at most any point in execution.
Beware of exiting the program
@@ -120,5 +112,4 @@
Agricultural Engineering,
Purdue University
-<p>
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.html
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -9,21 +9,17 @@
<h2>NOTES</h2>
The legend may be flipped with the <b>-f</b> flag.
-<p>
-If the <b>num_of_lines</b> parameter is not given then the legend frame will
+<p>If the <b>num_of_lines</b> parameter is not given then the legend frame will
display as many lines as number of categories in the map, otherwise, it
will display the first <b>num_of_lines</b> minus 1 categories with the
rest being truncated.
-<p>
-The user may adjust the <b>num_of_lines</b> parameter or
+<p>The user may adjust the <b>num_of_lines</b> parameter or
the size of graphics window to get an appropriate result.
-<p>
-The user may specify a second raster map with the <b>rast</b> parameter from
+<p>The user may specify a second raster map with the <b>rast</b> parameter from
which the legend is generated. This is useful to visualize (time) series of
raster maps with a common static legend instead of the default dynamic legend.
-<p>
-To remove all frames when clearing the display, use
+<p>To remove all frames when clearing the display, use
"<em><tt>d.erase -f</tt></em>".
<h2>EXAMPLE</h2>
Modified: grass/trunk/scripts/d.redraw/d.redraw.html
--- grass/trunk/scripts/d.redraw/d.redraw.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/d.redraw/d.redraw.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,5 +17,4 @@
Martin Landa, Czech Republic
-<p>
Modified: grass/trunk/scripts/d.shadedmap/d.shadedmap.html
--- grass/trunk/scripts/d.shadedmap/d.shadedmap.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/d.shadedmap/d.shadedmap.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -31,5 +31,4 @@
Unknown; updated to GRASS 5.7 by Michael Barton
-<p>
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -45,16 +45,14 @@
d.vect.thematic -l recent_earthquakes column=magnitude type=point
</pre></div>
-<p>
-Earthquake points with different sizes:
+<p>Earthquake points with different sizes:
d.vect.thematic -l recent_earthquakes column=magnitude type=point \
themetype=graduated_points maxsize=15
</pre></div>
-<p>
-Spearfish: differences between 'elevation.10m' and 'elevation.dem':
+<p>Spearfish: differences between 'elevation.10m' and 'elevation.dem':
# random sampling of elevation points:
@@ -74,8 +72,7 @@
d.vect.thematic -l elev_sample column=diff type=point
</pre></div>
-<p>
-North Carolina data set example:
+<p>North Carolina data set example:
g.region vect=nc_state
d.vect.thematic -l precip_30ynormals column=annual type=point
Modified: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,8 +13,7 @@
<h2>EXAMPLE</h2>
Dropping a column (North Carolina sample dataset):
-<p>
# work on own copy
g.copy vect=roadsmajor,myroads
db.describe -c myroads
Modified: grass/trunk/scripts/db.droptable/db.droptable.html
--- grass/trunk/scripts/db.droptable/db.droptable.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/db.droptable/db.droptable.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,8 +13,7 @@
<h2>EXAMPLE</h2>
Removing an attribute table:
-<p>
# show available tables
db.tables -p
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.html
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,32 +14,25 @@
Limited type recognition can be done for Integer, Real, String, Date, Time and DateTime
columns through a descriptive file with same name as the CSV file, but .csvt extension
(see details <a href="http://www.gdal.org/ogr/drv_csv.html">here</a>).
-<p>
# NOTE: create koeppen_gridcode.csvt first for type recognition
db.in.ogr dsn=koeppen_gridcode.csv output=koeppen_gridcode
db.select koeppen_gridcode
</pre></div>
-<p>
-Import of a DBF table with additional unique key column (e.g., needed for <em>v.in.db</em>):
-<p>
+<p>Import of a DBF table with additional unique key column (e.g., needed for <em>v.in.db</em>):
db.in.ogr dsn=$HOME/mydata.dbf output=census_raleigh key=myid
db.describe -c census_raleigh
</pre></div>
-<p>
-Import of a SQLite table:
-<p>
+<p>Import of a SQLite table:
db.in.ogr dsn=$HOME/sqlite/sqlite.db db_table=census_raleigh output=census_raleigh
</pre></div>
-<p>
-Import of a PostgreSQL table:
-<p>
+<p>Import of a PostgreSQL table:
db.in.ogr dsn="PG:host=localhost dbname=ecad user=neteler" \
db_table=ecad_verona_tmean output=ecad_verona_tmean
db.select ecad_verona_tmean
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.html
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,22 +7,17 @@
<h2>EXAMPLES</h2>
Export of GRASS table to a DBF table (default format):
-<p>
db.out.ogr precip_30ynormals dsn=/tmp/precip_30ynormals.dbf
</pre></div>
-<p>
-Export of GRASS table to a CSV table file:<br>
-<p>
+<p>Export of GRASS table to a CSV table file:<br>
db.out.ogr precip_30ynormals dsn=precip_30ynormals.csv format=CSV
</pre></div>
-<p>
-Export of GRASS table into a PostgreSQL table:
-<p>
+<p>Export of GRASS table into a PostgreSQL table:
db.out.ogr precip_30ynormals dsn="PG:host=localhost dbname=meteo user=neteler" \
format=PostgreSQL
echo "SELECT * FROM precip_30ynormals" | psql meteo
Modified: grass/trunk/scripts/db.test/db.test.html
--- grass/trunk/scripts/db.test/db.test.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/db.test/db.test.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,8 +7,7 @@
<h2>EXAMPLE</h2>
Test current SQL backend driver:
-<p>
db.connect -p
db.test test=test1
</pre></div>
Modified: grass/trunk/scripts/g.extension/g.extension.html
--- grass/trunk/scripts/g.extension/g.extension.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/g.extension/g.extension.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,8 +4,7 @@
extensions from GRASS Addons SVN repository into the local GRASS
installation.
-<p>
-Re-running the script on an installed GRASS Addons re-installs
+<p>Re-running the script on an installed GRASS Addons re-installs
the requested extension which may include updates.
<h2>EXAMPLES</h2>
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.html
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -46,8 +46,7 @@
Results:
-<p>
-<center>
+<p><center>
<table border=1>
<tr>
<td align=center>
@@ -76,10 +75,10 @@
<h2>SEE ALSO</h2>
<em>
-<a href="i.his.rgb.html">i.his.rgb</A>,
-<a href="i.rgb.his.html">i.rgb.his</A>,
-<a href="d.rgb.html">d.rgb</A>,
-<a href="r.composite.html">r.composite</A>
+<a href="i.his.rgb.html">i.his.rgb</a>,
+<a href="i.rgb.his.html">i.rgb.his</a>,
+<a href="d.rgb.html">d.rgb</a>,
+<a href="r.composite.html">r.composite</a>
</em>
@@ -107,5 +106,4 @@
<h2>AUTHOR</h2>
Markus Neteler, ITC-irst, Italy
-<p>
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.html
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,8 +4,7 @@
After import the digital numbers (DN) are remapped to VEGETATION NDVI
values and the NDVI color table is applied. The imported DN map is
removed after remapping.
-<p>
-Apparently missing raster cells due to bad pixel quality are reconstructed
+<p>Apparently missing raster cells due to bad pixel quality are reconstructed
by the SPOT operating team in the NDVI file. The differences between the
filtered (-a flag) and raw NDVI map should be compared.
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,12 +3,10 @@
<em>i.landsat.rgb</em> auto-balances and enhances the color channels of a
LANDSAT RGB image to provide a more natural color mixture. Only the color
table of each image band is modified, the base data remains untouched.
-<p>
-The module works by calculating a histogram for each color channel and
+<p>The module works by calculating a histogram for each color channel and
removing an adjustable amount of outliers from either end before recalibrating
the color scale with <em>r.colors</em>.
-<p>
-It will work with any 8-bit RGB imagery set and the script is easily modified
+<p>It will work with any 8-bit RGB imagery set and the script is easily modified
to work with other datasets of greater band-depth.
<h2>NOTES</h2>
@@ -17,13 +15,11 @@
flag to preserve the relative color scaling. You will have to experiment
with the different options to find a setting that works best for your
particular imagery.
-<p>
-The <b>strength</b> option should generally be set in the 90-99 range. The
+<p>The <b>strength</b> option should generally be set in the 90-99 range. The
lower the number, the more saturated the image becomes. It represents the
percentage cut-off for the top end of the color histogram curve. The lower
end is fixed at 2% of the area under the curve.
-<p>
-For quicker execution of this module on large images you can achieve largely
+<p>For quicker execution of this module on large images you can achieve largely
similar results by switching to a coarser resolution before the running of
the module (using <em>g.region</em>) and then back to the original resolution
afterwards.
Modified: grass/trunk/scripts/i.oif/i.oif.html
--- grass/trunk/scripts/i.oif/i.oif.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/i.oif/i.oif.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,13 +1,11 @@
<h2>DESCRIPTION</h2>
<em>i.oif</em> calculates the Optimum Index Factor for LANDSAT TM bands 1,2,3,4,5 and 7.
-<p>
-The Optimum Index Factor is calculated to determine the band combination which
+<p>The Optimum Index Factor is calculated to determine the band combination which
shows the maximum information when combined into a composite image. The bands
comprising the highest scoring combination from <em>i.oif</em> are used as the
three color channels required for <em>d.rgb</em> or <em>r.composite</em>.
-<p>
-The analysis is saved to a file in the current directory called "i.oif.result".
+<p>The analysis is saved to a file in the current directory called "i.oif.result".
<h2>NOTES</h2>
@@ -66,5 +64,4 @@
Markus Neteler, ITC-Irst, Trento, Italy<br>
Updated to GRASS 5.7 by Michael Barton, Arizona State University
-<p>
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.html
--- grass/trunk/scripts/i.tasscap/i.tasscap.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -29,8 +29,7 @@
Results:
-<p>
-<center>
+<p><center>
<table border=1>
<tr>
<td align=center>
@@ -90,5 +89,4 @@
<h2>AUTHOR</h2>
-<p>
Modified: grass/trunk/scripts/m.proj/m.proj.html
--- grass/trunk/scripts/m.proj/m.proj.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/m.proj/m.proj.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,8 +10,7 @@
<em>cs2cs</em> utility. The <b>-i</b> or <b>-o</b> flags make the task
especially easy for the common problem of converting to or from lat/long
WGS84.
-<p>
-<i>Note</i>: This program does not transform GRASS maps, it is designed to determine
+<p><i>Note</i>: This program does not transform GRASS maps, it is designed to determine
the equivalent coordinate values of an individual position or list of
positions. Use <em>v.proj</em> or <em>r.proj</em> to reproject GRASS maps.
@@ -22,48 +21,40 @@
with latitude-longitude data be sure to send the <tt>x</tt> value first,
i.e., "<tt>longitude latitude</tt>". Output data will be exported using
the same convention.
-<p>
-<em>cs2cs</em> will treat a third data column as a <tt>z</tt> value (elevation)
+<p><em>cs2cs</em> will treat a third data column as a <tt>z</tt> value (elevation)
and will modify the value accordingly. This usually translates into small but
real differences in that data column.
-<p>
-<em>cs2cs</em> does not expect the input stream to contain column headings,
+<p><em>cs2cs</em> does not expect the input stream to contain column headings,
only numbers. If your data file has lines you wish to have passed through
without being processed, they must start with the '<tt>#</tt>' character.
-<p>
-If sending <em>m.proj</em> data from <tt>stdin</tt>, be aware that the data is
+<p>If sending <em>m.proj</em> data from <tt>stdin</tt>, be aware that the data is
first stored to a temporary file before being processed with <em>cs2cs</em>.
It is therefore not advisable to send <em>m.proj</em> data from an open data
stream. The module will stop listening for incoming data after 2 seconds of
inactivity. You may use the projection parameters gleaned from <em>m.proj</em>'s
verbose mode (<b>-v</b>) with <em>cs2cs</em> directly in this case.
-<p>
-Custom projection parameters can be used via the <b>proj_in</b> and
+<p>Custom projection parameters can be used via the <b>proj_in</b> and
<b>proj_out</b> options. Full documentation of the projection parameter
format may be found on the <tt><a href="http://proj.maptools.org">PROJ.4</a></tt>
website. Using these options will fully override the default parameters the
module would normally use.
-<p>
-By using the <b>-v</b> verbose flag, the user can see exactly what projection
+<p>By using the <b>-v</b> verbose flag, the user can see exactly what projection
parameters will be used in the conversion as well as some other informative
messages.
-<p>
-If output is to lat/long, it will be formatted using <tt>PROJ.4</tt>'s
+<p>If output is to lat/long, it will be formatted using <tt>PROJ.4</tt>'s
Degree:Minute:Second (DMS) convention of <tt>DDDdMM'SSS.SS"H</tt>. This can be handy
if you wish to quickly convert lat/long decimal degree data into its DMS
equivalent.<br>
Alternatively, to have <em>m.proj</em> output data in decimal degrees, use the
<b>-d</b> flag. This flag can also be used with non-lat/long data to force a
higher number of decimal places (the <em>cs2cs</em> default is 2).
-<p>
-Lat/long output can be converted to GRASS's DMS convention (<tt>DDD:MM:SSS.SSSH</tt>)
+<p>Lat/long output can be converted to GRASS's DMS convention (<tt>DDD:MM:SSS.SSSH</tt>)
by piping the results of <em>m.proj</em> through the <em>sed</em> stream
editor as follows.
m.proj -o | sed -e 's/d/:/g' -e "s/'/:/g" -e 's/"//g'
</pre></div>
-<p>
-The <em>m.proj</em> module is designed to work seamlessly with point data
+<p>The <em>m.proj</em> module is designed to work seamlessly with point data
exported from the GIS with <em>v.out.ascii</em>, as the following example
shows.
@@ -108,8 +99,7 @@
+x_0=3500000.0" <b>input</b>=utm.coord.txt <b>output</b>=new.gk.coord.txt
</pre></div>
-<p>
-Projection parameters provided in the above case: "<tt>+proj</tt>" (projection
+<p>Projection parameters provided in the above case: "<tt>+proj</tt>" (projection
type), "<tt>+name</tt>" (projection name), "<tt>+a</tt>" (ellipsoid: equatorial
radius), "<tt>+es</tt>" (ellipsoid: eccentricity squared), "<tt>+zone</tt>"
(zone for the area), "<tt>+unfact</tt>" (conversion factor from meters to other
@@ -126,11 +116,9 @@
"<tt>+datum</tt>" setings are specified on <b>both</b> the input <b>and</b> output
projections on the command line. The "<tt>+towgs84</tt>" parameter can be used to
define either 3 or 7 term datum transform coefficients, satisfying this requirement.
-<p>
-If a datum is specified there is no need for the '<tt>+ellps=</tt>' or underlying
+<p>If a datum is specified there is no need for the '<tt>+ellps=</tt>' or underlying
parameters, '<tt>+a=</tt>', '<tt>+es=</tt>', etc.
-<p>
-<h3>Another custom parameter usage example:</h3>
+<p><h3>Another custom parameter usage example:</h3>
m.proj <b>proj_in</b>="+proj=tmerc +datum=ire65 +lat_0=53.5 +lon_0=-8 +x_0=200000 \
@@ -144,15 +132,13 @@
+y_0=250000 +k=1.000035" <b>proj_out</b>="+proj=ll +datum=wgs84" <b>input</b>=wpt.txt
</pre></div>
-<p>
-In this example no datum transformation will take place as a datum was not
+<p>In this example no datum transformation will take place as a datum was not
specified for the input projection. The datum specified for the output
projection will thus be silently ignored and may be left out; all that is
achieved a simple conversion from projected to geodetic co-ordinates,
keeping the same datum (and thus also the same ellipsoid).
-<p>
-For more usage examples, see the documentation for the
+<p>For more usage examples, see the documentation for the
<tt><a href="http://proj.maptools.org">PROJ.4</a></tt> <em>cs2cs</em> program.
@@ -161,21 +147,20 @@
[1] Evenden, G.I. (1990) <a href="http://proj.maptools.org/">Cartographic projection procedures for
the UNIX environment - a user's manual.</a> USGS Open-File Report 90-284 (OF90-284.pdf)
See also there: Interim Report and 2nd Interim Report on Release 4, Evenden 1994).
-<p>
-[2] <tt><a href="http://proj.maptools.org">PROJ.4</a></tt> Cartographic Projection Library
+<p>[2] <tt><a href="http://proj.maptools.org">PROJ.4</a></tt> Cartographic Projection Library
<h2>SEE ALSO</h2>
<em>
-<a href="v.proj.html">v.proj</A>,
-<a href="r.proj.html">r.proj</A>,
-<a href="g.proj.html">g.proj</A>,
-<a href="g.setproj.html">g.setproj</A>,
-<a href="i.rectify.html">i.rectify</A>,
-<!-- <a href="i.rectify3.html">i.rectify3</A> -->
-<a href="v.in.ascii.html">v.in.ascii</A>,
-<a href="v.out.ascii.html">v.out.ascii</A>
+<a href="v.proj.html">v.proj</a>,
+<a href="r.proj.html">r.proj</a>,
+<a href="g.proj.html">g.proj</a>,
+<a href="g.setproj.html">g.setproj</a>,
+<a href="i.rectify.html">i.rectify</a>,
+<!-- <a href="i.rectify3.html">i.rectify3</a> -->
+<a href="v.in.ascii.html">v.in.ascii</a>,
+<a href="v.out.ascii.html">v.out.ascii</a>
</em>
Modified: grass/trunk/scripts/r.blend/r.blend.html
--- grass/trunk/scripts/r.blend/r.blend.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.blend/r.blend.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,8 +7,7 @@
Blending the aspect map with the elevation map for a shaded map
-<p>
g.region rast=aspect -p
r.blend first=aspect second=elevation output_prefix=elev_shade_blend
d.mon wx0
@@ -29,5 +28,4 @@
Unknown: probably CERL<br>
-<p>
Modified: grass/trunk/scripts/r.buffer/r.buffer.html
--- grass/trunk/scripts/r.buffer/r.buffer.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.buffer/r.buffer.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -41,7 +41,6 @@
units</em> parameter: <em>meters, kilometers, feet, miles</em>, and <em>nautmiles</em>
(nautical miles).
<p>
<!-- ??? is this the real method used or some ancient option ??? -->
Distances from cells containing the user-specified category values
are calculated using the "fromcell" method. This method locates each
@@ -52,13 +51,11 @@
slowly when there are numerous cells containing the
category values of interest spread throughout the area.
<p>
<em>r.buffer</em> measures distances from center of cell to
center of cell using Euclidean distance measure for
planimetric locations (like UTM) and using ellipsoidal
geodesic distance measure for latitude/longitude locations.
<p>
<em>r.buffer</em> calculates distance zones from all cells having non-NULL
category values in the <em>input</em> map. If the user wishes to calculate
distances from only selected <em>input</em> map layer
@@ -67,11 +64,9 @@
<em>r.buffer</em>, to reclass all categories from which distance zones
are not desired to be calculated into category NULL.
<p>
The <b>-z</b> flag can be used to ignore raster values of zero instead of NULL
values in the input raster map.
<p>
<h2>EXAMPLE</h2>
In the following example, the buffer zones would be (in the default units
@@ -113,5 +108,4 @@
James Westervelt, U.S. Army Construction Engineering
Research Laboratory
-<p>
Modified: grass/trunk/scripts/r.colors.stddev/r.colors.stddev.html
--- grass/trunk/scripts/r.colors.stddev/r.colors.stddev.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.colors.stddev/r.colors.stddev.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,12 +4,10 @@
deviations from a map's mean value, either as a continuous color gradient
or in color bands per standard deviation (S.D.) from the mean.
-<p>
-With the color band option values less that 1 S.D. from the mean are
+<p>With the color band option values less that 1 S.D. from the mean are
colored green, within 1-2 S.D. are colored yellow, within 2-3 S.D. are
colored red, and beyond 3 S.D. are colored black.
-<p>
-For a differences map there is an option to lock the center of the color
+<p>For a differences map there is an option to lock the center of the color
table at zero. Values more than two S.D. below the mean will be colored blue;
values below the mean but less than 2 S.D. away will transition to white,
and above the mean the colors will simularly transition to full red at +2 S.D.
@@ -37,5 +35,4 @@
Hamish Bowman, <i>Dunedin, New Zealand</i>
-<p>
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.html
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,15 +11,12 @@
three points around the edge. This way the algorithm interpolates into the hole with
a trained slope and curvature at the edges, in order to avoid that such a flat plane
is generated in a hole.
-<p>
-During the interpolation following warning may occur:<p>
+<p>During the interpolation following warning may occur:<p>
<tt>
Warning: strip exists with insufficient data<br>
Warning: taking too long to find points for interpolation--please change
the region to area where your points are</tt>
<p>
This warning is generated if large data holes exist within the surface.
As the idea of <em>r.fillnulls</em> is to fill such holes, the user may
ignore the warning. The interpolation will be continued. However, the user
@@ -94,8 +91,7 @@
<i>Mathematical Geology</i> 25, 657-667.
<h2>AUTHORS</h2>
-r.fillnulls: Markus Neteler, University of Hannover<p>
-and authors of v.surf.rst<br>
+r.fillnulls: Markus Neteler, University of Hannover<p>and authors of v.surf.rst<br>
Improvement by Hamish Bowman, NZ
Modified: grass/trunk/scripts/r.grow/r.grow.html
--- grass/trunk/scripts/r.grow/r.grow.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.grow/r.grow.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,8 +14,7 @@
the <b>metric</b> parameter): <i>Euclidean</i>, <i>Manhattan</i>, and
<i>Maximum</i>.
-<p>
-The <i>Euclidean distance</i> or <i>Euclidean metric</i> is the "ordinary" distance
+<p>The <i>Euclidean distance</i> or <i>Euclidean metric</i> is the "ordinary" distance
between two points that one would measure with a ruler, which can be
proven by repeated application of the Pythagorean theorem.
The formula is given by:
@@ -25,8 +24,7 @@
Cells grown using this metric would form isolines of distance that are
circular from a given point, with the distance given by the <b>radius</b>.
-<p>
-The <i>Manhattan metric</i>, or <i>Taxicab geometry</i>, is a form of geometry in
+<p>The <i>Manhattan metric</i>, or <i>Taxicab geometry</i>, is a form of geometry in
which the usual metric of Euclidean geometry is replaced by a new
metric in which the distance between two points is the sum of the (absolute)
differences of their coordinates. The name alludes to the grid layout of
@@ -40,15 +38,13 @@
where cells grown using this metric would form isolines of distance that are
rhombus-shaped from a given point.
-<p>
-The <i>Maximum metric</i> is given by the formula
+<p>The <i>Maximum metric</i> is given by the formula
<div class="code"><pre>d(dx,dy) = max(abs(dx),abs(dy))</pre></div>
where the isolines of distance from a point are squares.
-<p>
-If there are two cells which are equal candidates to grow into an empty space,
+<p>If there are two cells which are equal candidates to grow into an empty space,
<em>r.grow</em> will choose the northernmost candidate; if there are multiple
candidates with the same northing, the westernmost is chosen.
@@ -69,15 +65,13 @@
<a href="r.patch.html">r.patch</a>
</em>
-<p>
-<em><a href="http://en.wikipedia.org/wiki/Euclidean_metric">Wikipedia Entry: Euclidean Metric</a></em><br>
+<p><em><a href="http://en.wikipedia.org/wiki/Euclidean_metric">Wikipedia Entry: Euclidean Metric</a></em><br>
<em><a href="http://en.wikipedia.org/wiki/Manhattan_metric">Wikipedia Entry: Manhattan Metric</a></em>
<h2>AUTHORS</h2>
Marjorie Larson,
U.S. Army Construction Engineering Research Laboratory
-<p>
-Glynn Clements
+<p>Glynn Clements
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.html
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -24,8 +24,7 @@
<em>
<a href="r.in.bin.html">r.in.bin</a>
</em>
-<p>
-The <a href="http://www2.jpl.nasa.gov/srtm/">Shuttle Radar Topography Mission</a>
+<p>The <a href="http://www2.jpl.nasa.gov/srtm/">Shuttle Radar Topography Mission</a>
homepage at NASA's JPL.
<br>
The <a href="http://pub7.bravenet.com/forum/537683448/">SRTM Web Forum</a>
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.html
--- grass/trunk/scripts/r.in.wms/r.in.wms.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,15 +12,13 @@
By default data is downloaded to <tt>$GISDBASE/wms_download</tt>. This can be changed
by setting the <b>folder</b> option when using <em>r.in.wms</em>.
-<p>
-To understand the data you are getting it is necessary to look at the
+<p>To understand the data you are getting it is necessary to look at the
capabilities of the WMS server. This should be available via a capabilities
request. This is an
<a href="http://wms.jpl.nasa.gov/wms.cgi?request=GetCapabilities">example
capabilities request to NASA's OnEarth server</a>.
-<p>
+<p><!--
Some brain-dead servers will only talk to certain web browsers. You can
fool these by adding <tt>- -user-agent=MSIE5.5</tt> to <b>wgetoptions</b>
or for curl adding <tt>-A "MSIE5.5"</tt> to <b>curloptions</b>.
@@ -136,5 +134,4 @@
Soeren Gebbert, Jachym Cepicky, and Cedric Shock<br>
Updated for GRASS 7 by Martin Landa, CTU in Prague, Czech Republic (05/2009)
-<p>
Modified: grass/trunk/scripts/r.mapcalculator/r.mapcalculator.html
--- grass/trunk/scripts/r.mapcalculator/r.mapcalculator.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.mapcalculator/r.mapcalculator.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,14 +7,12 @@
Enter an <em>r.mapcalc</em> expression in the formula field using the
format: A+C or exp(A+C)+(B-2)*7 where A, B, C are raster maps entered
in the A field, B field, and C field.
-<p>
-Do not enter output file in the formula field: correct: A+B; incorrect: newfile = A+B. Use no spaces or blanks.
-<p>
-Expert mode runs <em>r.mapcalc</em> for more complex expressions.
+<p>Do not enter output file in the formula field: correct: A+B; incorrect: newfile = A+B. Use no spaces or blanks.
+<p>Expert mode runs <em>r.mapcalc</em> for more complex expressions.
<h2>SEE ALSO</h2>
-<em><a href="r.mapcalc.html">r.mapcalc</A></em>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/scripts/r.mask/r.mask.html
--- grass/trunk/scripts/r.mask/r.mask.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.mask/r.mask.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,28 +3,24 @@
<em><b>r.mask</b></em> - Facilitates creation of a raster "MASK" map to
control raster operations.
-<p>
-The MASK is only applied when <em>reading</em> an existing GRASS raster map,
+<p>The MASK is only applied when <em>reading</em> an existing GRASS raster map,
for example when used in a module as an input map.
The MASK will block out certain areas of a raster map from analysis and/or
display, by "hiding" them from sight of other GRASS modules. Data falling
within the bounaries of the MASK can be modified and operated upon by other
GRASS raster modules; data falling outside the MASK is treated as if it were NULL.
-<p>
-Because the MASK is actually only a reclass map named "MASK", it can be
+<p>Because the MASK is actually only a reclass map named "MASK", it can be
copied, renamed, removed, and used in analyses, just like other GRASS
raster map layers. The user should be aware that a MASK remains in
place until a user renames it to something other than "MASK", or removes
it using "<tt>r.mask -r</tt>" or <em>g.remove</em>.
-<p>
-Grid cells in the MASK map containing <tt>0</tt> or <tt>NULL</tt>
+<p>Grid cells in the MASK map containing <tt>0</tt> or <tt>NULL</tt>
will replace data with NULL, while cells containing other values will allow
data to pass through unaltered.
-<p>
-To restore raster operations to normal (i.e., all cells of the current region),
+<p>To restore raster operations to normal (i.e., all cells of the current region),
remove the MASK file by setting the <b>-r</b> remove MASK flag. In this case, a
dummy value must also be given for the input parameter.
A MASK also can be removed by using <em>g.remove</em>
@@ -38,13 +34,11 @@
areas outside the MASK will be ignored until the MASK file
is removed.
<p>
The mask is read as an integer map. If MASK is actually a
floating-point map, the values will be converted to integers using the
map's quantisation rules (this defaults to round-to-nearest, but can
be changed with r.quant).
<p>
<em>r.mask</em> uses <em>r.reclass</em> to create a reclassification of an
existing raster map and name it MASK. A reclass map takes up less space, but
is affected by any changes to the underlying map from which it was created.
@@ -53,7 +47,6 @@
command line, the category values listed in <em>maskcats</em> must be quoted
(see example below).
<p>
Somewhat similar program functions to those performed by
<em>r.mask</em> can be done using <em>r.mapcalc</em>,
<em>g.region</em>, and other commands.
@@ -97,5 +90,4 @@
-<p>
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.html
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,19 +3,15 @@
The <em>r.out.xyz</em> module exports a raster map as a list of x,y,z
values into an ASCII text file.
<p>
<h2>NOTES</h2>
This module will not export x,y coordinates for raster cells containing
a NULL value. This includes cells masked by a raster MASK.
-<p>
-This module, as all GRASS raster modules, will export cells based on the
+<p>This module, as all GRASS raster modules, will export cells based on the
current region settings. See the <em>g.region</em> module for details.
-<p>
-The <em>r.out.ascii</em> module should be used to export an array (of
+<p>The <em>r.out.ascii</em> module should be used to export an array (of
size row x column) containing z values.
-<p>
-<em>r.out.xyz</em> is simply a front-end to "<tt>r.stats -1gn</tt>".
+<p><em>r.out.xyz</em> is simply a front-end to "<tt>r.stats -1gn</tt>".
<h2>EXAMPLE</h2>
@@ -47,5 +43,4 @@
<i>Dept. Marine Science<br>
Otago University, New Zealand</i>
-<p>
Modified: grass/trunk/scripts/r.pack/r.pack.html
--- grass/trunk/scripts/r.pack/r.pack.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.pack/r.pack.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -39,5 +39,4 @@
<br>
Converted to Python and updated for GRASS 7 by Martin Landa, CTU in Prague, Czech Republic
-<p>
Modified: grass/trunk/scripts/r.plane/r.plane.html
--- grass/trunk/scripts/r.plane/r.plane.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.plane/r.plane.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
point on the plane.<br>
The angle orientations of the <em>azimuth</em> parameter increase counter-clockwise,
i.e., 0 degree = N, 45 degree = NW, 90 degree = W etc.
-<p>
-Increasing values of the <em>dip</em> parameter progressively lower (or dip) the northern
+<p>Increasing values of the <em>dip</em> parameter progressively lower (or dip) the northern
half of the plane, and incline the southern half, assuming the <em>azimuth</em> parameter
is held constant at 0 degrees.
@@ -14,8 +13,7 @@
<h2>NOTES</h2>
<tt>g.region -c</tt> provides the easting and northing coordinates for
the center of the current region.
-<p>
-<em>int</em> maps take less disk space than <em>float</em>s, which in turn
+<p><em>int</em> maps take less disk space than <em>float</em>s, which in turn
take up less space than <em>double</em>s (but can be less exact).
Modified: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.html
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.shaded.relief/r.shaded.relief.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
relief map is named <em><input_map>.shade</em>.
The map is assigned a grey-scale color table.
-<p>
-The module then prompts the user to enter values for:
+<p>The module then prompts the user to enter values for:
<ol>
<li>The <b>altitude</b> of the sun in degrees above the horizon
(a value between 0 and 90 degrees), and
@@ -42,8 +41,7 @@
of the filtering syntax shown in the above expression.
See, for example, the section on "The Neighborhood Modifier".
-<p>
-<em>r.shaded.relief</em> then runs <em>r.colors</em>
+<p><em>r.shaded.relief</em> then runs <em>r.colors</em>
to assign a grey-scale color table to the new shaded relief map.
<h2>NOTES</h2>
@@ -63,8 +61,7 @@
r.shaded.relief input=elevation output=elevation.shaded
</pre></div>
-<p>
-In Latitude-Longitude locations (or other non-metric locations), the
+<p>In Latitude-Longitude locations (or other non-metric locations), the
<em>scale</em> factor has to be used:
@@ -78,9 +75,8 @@
and Jim Westervelt, U.S. Army Construction Engineering Research Laboratory
(March/1991) (available from the GRASS web site).
-<p>
-<!-- RGB version not ported to GRASS 6:
- <em><a href="shade.clr.sh.html">shade.clr.sh</A></em><br>
+<p><!-- RGB version not ported to GRASS 6:
+ <em><a href="shade.clr.sh.html">shade.clr.sh</a></em><br>
<em>
<a href="d.his.html">d.his</a>,
Modified: grass/trunk/scripts/r.tileset/r.tileset.html
--- grass/trunk/scripts/r.tileset/r.tileset.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.tileset/r.tileset.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,8 +15,7 @@
twice the necessary information. Furthermore, generating a tiling near
a divergant point of a source projection, such as the poles of a
cylindrical source projections, results in divergence of the tile set.
-<p>
-Not generating "optimal" tilings may have another consequence; the
+<p>Not generating "optimal" tilings may have another consequence; the
aspect ratio of cells in the destination region will not necessarily
carry over to the source region and generated tiles may have cells of
strange aspect ratios. This might be a problem for some map request
@@ -63,16 +62,14 @@
Generates tiles in latitude longitude that cover the current
region, each tile will be less than 1024 cells high and 2048 cells
across. The bounds and sizes of tiles in the output are separated by | (pipe):
-<p>
r.tileset sourceproj=+init=epsg:4326 maxrows=1024 maxcols=2048
</pre></div>
Generates tiles in latitude longitude projection that cover the
named region "ne-rio". The tiles will have 2 cells of overlap. The
output format will be strings like the bbox requests for WMS servers:
-<p>
r.tileset sourceproj=+init=epsg:4326 overlap=2 -w region=ne-rio
</pre></div>
@@ -82,8 +79,7 @@
is in a format where each line is in shell script style. The
substitution <code>`g.proj -j location=IrishGrid`</code> will only
work in a unix style shell:
-<p>
r.tileset sourceproj=`g.proj -j location=IrishGrid` maxrows=400 maxcols=300 overlap=3 -g
</pre></div>
@@ -99,5 +95,4 @@
Cedric Shock<br>
-<p>
Modified: grass/trunk/scripts/r.unpack/r.unpack.html
--- grass/trunk/scripts/r.unpack/r.unpack.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r.unpack/r.unpack.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -36,5 +36,4 @@
<br>
-<p>
Modified: grass/trunk/scripts/r3.mapcalculator/r3.mapcalculator.html
--- grass/trunk/scripts/r3.mapcalculator/r3.mapcalculator.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/r3.mapcalculator/r3.mapcalculator.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,14 +7,12 @@
Enter an <em>r3.mapcalc</em> expression in the formula field using the
format: A+C or exp(A+C)+(B-2)*7 where A, B, C are 3D raster volumes entered
-<p>
-<p>
-Expert mode runs <em>r3.mapcalc</em> for more complex expressions.
+<p>Expert mode runs <em>r3.mapcalc</em> for more complex expressions.
<h2>SEE ALSO</h2>
-<em><a href="r3.mapcalc.html">r3.mapcalc</A></em>
+<em><a href="r3.mapcalc.html">r3.mapcalc</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/scripts/v.build.all/v.build.all.html
--- grass/trunk/scripts/v.build.all/v.build.all.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.build.all/v.build.all.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,5 +6,4 @@
<h2>AUTHOR</h2>
Radim Blazek
-<p>
Modified: grass/trunk/scripts/v.centroids/v.centroids.html
--- grass/trunk/scripts/v.centroids/v.centroids.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.centroids/v.centroids.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,13 +6,11 @@
adds centroids to closed boundaries in the <b>input</b> file and assigns a
category number to them. The starting value as well as the increment size
may be set using optional parameters.
-<p>
-Multiple attributes may be linked to a single vector entity through
+<p>Multiple attributes may be linked to a single vector entity through
numbered fields referred to as layers. Refer to <em>v.category</em>
for more details, as <em>v.centroids</em> is simply a frontend to that
module.
-<p>
-The boundary itself is often stored without any category reference as it
+<p>The boundary itself is often stored without any category reference as it
can mark the border between two adjacent areas. Thus it would be ambiguous
as to which feature the attribute would belong. In some cases it may, for
example, represent a road between two parcels of land. In this case it
@@ -30,5 +28,4 @@
<br>
help page: Trevor Wiens
-<p>
Modified: grass/trunk/scripts/v.convert.all/v.convert.all.html
--- grass/trunk/scripts/v.convert.all/v.convert.all.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.convert.all/v.convert.all.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -9,14 +9,11 @@
directories, so the same names can be kept. Old vector maps can be listed with
<em>g.list oldvect</em>.
-<p>
-To convert back from 7 to 6 vector format, use <em>v.build</em> in GRASS 6.
-<p>
-To convert back from 6.0 into the 5.0/5.3/5.4 vector format,
+<p>To convert back from 7 to 6 vector format, use <em>v.build</em> in GRASS 6.
+<p>To convert back from 6.0 into the 5.0/5.3/5.4 vector format,
use <em>v.out.ogr</em> (to SHAPE format) and then <em>v.in.shape</em>
in the old GRASS program.
<p>
As this GRASS version uses SQL for attribute management, there are
some <a href=sql.html>SQL restrictings concerning the file names</a>.
This script changes dots (e.g. "foo.bar") in old vector map names into
@@ -25,8 +22,7 @@
<h2>EXAMPLE</h2>
To convert all old vector maps in the current mapset to the new vector format:
-<p>
-<div class="code"><pre>
+<p><div class="code"><pre>
v.convert.all
</pre></div>
@@ -44,5 +40,4 @@
-<p>
Modified: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.html
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,8 +10,7 @@
The supported types of columns depend on the database backend. However, all
backends should support VARCHAR, INT, DOUBLE PRECISION and DATE.
-<p>
-The existing database connection(s) can be verified with <em>v.db.connect</em>.
+<p>The existing database connection(s) can be verified with <em>v.db.connect</em>.
<h2>EXAMPLES</h2>
@@ -22,8 +21,7 @@
v.info -c myroads
</pre></div>
-<p>
-Adding two columns:<br>
+<p>Adding two columns:<br>
v.db.addcolumn myroads columns="slope double precision,myname varchar(15)"
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.html
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -21,8 +21,7 @@
-<p>
<h2>EXAMPLE</h2>
@@ -34,8 +33,7 @@
v.info -c myroads
</pre></div>
-<p>
-Adding a new attribute table with two columns to layer 2:<br>
+<p>Adding a new attribute table with two columns to layer 2:<br>
v.db.addtable myroads columns="slope double precision, roadname varchar(15)" layer=2
@@ -63,5 +61,4 @@
Markus Neteler
-<p>
Modified: grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.html
--- grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,8 +8,7 @@
<h2>NOTES</h2>
<em>v.db.dropcolumn</em> is a front-end to <em>db.execute</em> to allow easier usage.
-<p>
<h2>EXAMPLES</h2>
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.html
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,8 +7,7 @@
<h2>NOTES</h2>
<em>v.db.droptable</em> is a front-end to <em>db.execute</em> to allow easier usage.
-<p>
<h2>EXAMPLE</h2>
Modified: grass/trunk/scripts/v.db.join/v.db.join.html
--- grass/trunk/scripts/v.db.join/v.db.join.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.join/v.db.join.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,8 +10,7 @@
The vector attribute table must be stored in a SQL database (SQLite, PostgreSQL,
MySQL, ODBC, ...). The DBF backend is not supported. Tables can be
imported with <em>db.in.ogr</em>.
-<p>
-The vector map-database connection(s) can be verified with <em>v.db.connect</em>.
+<p>The vector map-database connection(s) can be verified with <em>v.db.connect</em>.
<h2>EXAMPLE</h2>
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,5 +14,4 @@
<h2>AUTHOR</h2>
Radim Blazek
-<p>
Modified: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.html
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,8 +13,7 @@
this the renamed column is found as last column of the table, it's original position
cannot be maintained.
-<p>
-The SQLite driver will exit with an error if the column rename involves only a change of
+<p>The SQLite driver will exit with an error if the column rename involves only a change of
case, i.e., upper-to-lowercase, or lower-to-uppercase. The SQLite protocol considers "NAME"
and "name" to be identical column names. In cases like these, the user should rename the original
column to an intermediary name, then rename the intermediary to the final name.
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.html
--- grass/trunk/scripts/v.db.univar/v.db.univar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -36,8 +36,6 @@
<h2>AUTHOR</h2>
-<p>
-and authors of <em>r.univar.sh</em>
+<p>and authors of <em>r.univar.sh</em>
-<p>
Modified: grass/trunk/scripts/v.db.update/v.db.update.html
--- grass/trunk/scripts/v.db.update/v.db.update.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.db.update/v.db.update.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,8 +8,7 @@
<em>v.db.update</em> is just a front-end to <em>db.execute</em> to
allow easier usage.
-<p>
-For complex SQL UPDATE statements, <em>db.execute</em> should be used.
+<p>For complex SQL UPDATE statements, <em>db.execute</em> should be used.
<h2>EXAMPLES</h2>
@@ -71,5 +70,4 @@
Moritz Lennert (mlennert at club.worldonline.be)
-<p>
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.html
--- grass/trunk/scripts/v.dissolve/v.dissolve.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,13 +15,11 @@
category number
(see <em>v.centroids</em>), this number is linked to area attributes and
database links.
-<p>
numbered fields referred to as layers. Refer to <em>v.category</em> for
more details.
-<p>
-Merging of areas can also be accomplished using
+<p>Merging of areas can also be accomplished using
<tt>v.extract -d</tt> which provides some additional options.
In fact, <em>v.dissolve</em> is simply a
front-end to that module. The use of the <em>column</em> parameter
@@ -78,5 +76,4 @@
Markus Neteler for column support<br>
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.html
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,8 +11,7 @@
<h2>NOTES</h2>
The current DB connection is used to write the database table.
-<p>
-If importing into a DBF database, the original column names longer that 10 characters
+<p>If importing into a DBF database, the original column names longer that 10 characters
are shortened to 10 characters to meet the DBF column name restrictions. If this is a
problem consider choosing another database driver with <em>db.connect</em>.
@@ -57,5 +56,4 @@
<a href="http://www.grassbook.org/">Markus Neteler</a>
-<p>
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.html
--- grass/trunk/scripts/v.in.gns/v.in.gns.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,12 +10,10 @@
<h2>NOTES</h2>
-<p>
-Generally, column names longer that 10 characters are shortened to
+<p>Generally, column names longer that 10 characters are shortened to
-<p>
-To filter outliers (points outside of a country), the <em>v.select</em>
+<p>To filter outliers (points outside of a country), the <em>v.select</em>
module can be used to perform point-in-polygon tests. <em>v.select</em>
saves only the GNS points falling into a country polygon into the new
points map.
@@ -36,5 +34,4 @@
Markus Neteler, MPBA Group, ITC-irst, Trento, Italy
-<p>
Modified: grass/trunk/scripts/v.in.gps/v.in.gps.html
--- grass/trunk/scripts/v.in.gps/v.in.gps.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.in.gps/v.in.gps.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
GPS data of many common formats. Translation is done via the
<em><a href="http://www.gpsbabel.org">GPSBabel</a></em> program.
-<p>
-This software is not intended as a primary means of navigation.
+<p>This software is not intended as a primary means of navigation.
<h2>NOTES</h2>
@@ -23,8 +22,7 @@
The automatic transform may be skipped by using the <b>-k</b> flag in which
case the data will be imported unprojected, as it appears in the <b>input</b>.
-<p>
-Route and Track data may be uploaded as a series of points by using the <b>-p</b>
+<p>Route and Track data may be uploaded as a series of points by using the <b>-p</b>
flag, otherwise they will be imported as lines. You can run <em>v.in.gps</em>
multiple times and merge the line and point vectors with the <em>v.patch</em>
command if you want, but take care when merging dissimilar attribute tables.
@@ -97,5 +95,4 @@
from <i>garmin</i> to <i>xcsv</i> ...
-<p>
Modified: grass/trunk/scripts/v.in.lines/v.in.lines.html
--- grass/trunk/scripts/v.in.lines/v.in.lines.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.in.lines/v.in.lines.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,11 +8,9 @@
Input ASCII coordinates are simply a series of "x y" data points.
Lines are separated by a row containing "<tt>NaN NaN</tt>".
<!-- TODO:? Line categories start at 1 and increase sequentially. -->
-<p>
-The user can import 3D lines by providing 3 columns of data in the input
+<p>The user can import 3D lines by providing 3 columns of data in the input
stream and using the <b>-z</b> flag.
-<p>
-This script is a simple wrapper around the <em>v.in.mapgen</em> module.
+<p>This script is a simple wrapper around the <em>v.in.mapgen</em> module.
<h2>EXAMPLE</h2>
@@ -53,5 +51,4 @@
Hamish Bowman<br>
-<p>
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.html
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,11 +6,9 @@
<h2>NOTES</h2>
This module only imports data into vector lines.
-<p>
-The user can get coastline data in Mapgen or Matlab format from NOAA's Coastline
+<p>The user can get coastline data in Mapgen or Matlab format from NOAA's Coastline
Extractor at <a href="http://www.ngdc.noaa.gov/mgg/shorelines/shorelines.html">http://www.ngdc.noaa.gov/mgg/shorelines/shorelines.html</a>.
-<p>
-Matlab vector line maps are simply a series of "x y" data points. Lines
+<p>Matlab vector line maps are simply a series of "x y" data points. Lines
are separated by a row containing <tt>NaN NaN</tt>.
Output from Matlab with this command:
@@ -18,8 +16,7 @@
save filename.txt arrayname -ASCII
</pre></div>
-<p>
-The user can import 3D lines from Matlab by exporting a 3 column array and
+<p>The user can import 3D lines from Matlab by exporting a 3 column array and
@@ -30,5 +27,4 @@
Based on <em>v.in.mapgen.sh</em> for GRASS 5.0 by Andreas Lange
<br>Rewritten for GRASS 6 by Hamish Bowman
-<p>
Modified: grass/trunk/scripts/v.in.sites.all/v.in.sites.all.html
--- grass/trunk/scripts/v.in.sites.all/v.in.sites.all.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.in.sites.all/v.in.sites.all.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -35,5 +35,4 @@
-<p>
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.html
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
<h2>EXAMPLES</h2>
Import of GRASS user map:
-<p>
# run in LatLong location:
v.in.wfs \
url="http://mapserver.gdf-hannover.de/cgi-bin/grassuserwfs?REQUEST=GetFeature&SERVICE=WFS&VERSION=1.0.0" out=grass_users
Modified: grass/trunk/scripts/v.krige/v.krige.html
--- grass/trunk/scripts/v.krige/v.krige.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.krige/v.krige.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -9,8 +9,7 @@
<em>v.krige</em> is just a front-end to R. The options and parameters
are the same offered by packages <i>automap</i> and <i>gstat</i>.
-<p>
-Kriging, like other interpolation methods, is fully dependent on input
+<p>Kriging, like other interpolation methods, is fully dependent on input
data features. Exploratory analysis of data is encouraged to find out
outliers, trends, anisotropies, uneven distributions and consequently
choose the kriging algorithm that will give the most acceptable
@@ -82,8 +81,7 @@
Kriging example based on elevation map (Spearfish data set).
-<p>
-<b>Part 1: random sampling</b> of 2000 vector points from known
+<p><b>Part 1: random sampling</b> of 2000 vector points from known
elevation map. Each point will receive the elevation value from the
elevation raster, as if it came from a point survey.
@@ -188,5 +186,4 @@
Anne Ghisla, Google Summer of Code 2009
-<p>
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.html
--- grass/trunk/scripts/v.out.gps/v.out.gps.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
many common GPS data formats. Translation is done via the
-<p>
-Do not use as a primary means of navigation.
+<p>Do not use as a primary means of navigation.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
@@ -16,18 +15,15 @@
<em>v.out.gps</em> automatically reprojects data from the
projection settings of the current location to Lat/Lon WGS84.
-<p>
-GPX format is used for data interchange between GRASS and GpsBabel.
+<p>GPX format is used for data interchange between GRASS and GpsBabel.
If the requested output is GPX, then <tt>gpsbabel</tt> is never run.
-<p>
-OGR's GPX driver knows a number of standard field names. If an attribute
+<p>OGR's GPX driver knows a number of standard field names. If an attribute
column matches the name it will be used in that field. Otherwise the
attribute will be placed within the <tt><extensions></tt> metadata
section of the record. Not all fields names are used with all feature
types (e.g. DOP fix error is not meaningful for route lines). You can
use the <em>v.db.renamecolumn</em> module to rename columns.
-<p>
-These are the standard GPX data fields known to OGR:
+<p>These are the standard GPX data fields known to OGR:
ageofdgpsdata
cmt: Comment
@@ -82,13 +78,13 @@
<h2>SEE ALSO</h2>
<em>
-<a href="m.proj.html">m.proj</A><br>
-<a href="v.in.ascii.html">v.in.ascii</A><br>
-<a href="v.out.ascii.html">v.out.ascii</A><br>
-<a href="v.in.garmin.html">v.in.garmin</A><br>
-<a href="v.in.gpsbabel.html">v.in.gpsbabel</A><br>
-<a href="v.db.renamecolumn.html">v.db.renamecolumn</A><br>
-<a href="v.extract.html">v.extract</A>
+<a href="m.proj.html">m.proj</a><br>
+<a href="v.in.ascii.html">v.in.ascii</a><br>
+<a href="v.out.ascii.html">v.out.ascii</a><br>
+<a href="v.in.garmin.html">v.in.garmin</a><br>
+<a href="v.in.gpsbabel.html">v.in.gpsbabel</a><br>
+<a href="v.db.renamecolumn.html">v.db.renamecolumn</a><br>
+<a href="v.extract.html">v.extract</a>
</em>
<br>
<br>
@@ -101,5 +97,4 @@
<h2>AUTHOR</h2>
Hamish Bowman, Dunedin New Zealand
-<p>
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.html
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
Then univariate statistics are calculated per vector category (cat) from
the raster map and the results uploaded to the vector map attribute table.
New columns are generated in the attribute table if not already present.
-<p>
-Nine columns are generated (n, min, max, range, mean, stddev, variance,
+<p>Nine columns are generated (n, min, max, range, mean, stddev, variance,
coeff_var, sum) according to the output of <em>r.univar</em>.
If the <b>-e</b> extended statistics flag is given the 1st quartile,
median, 3rd quartile, and given percentile are also calculated.
@@ -18,22 +17,18 @@
The module may take a long time to run if the raster region contains a large
number of cells. In this case the <b>--verbose</b> flag may be used to track
progress.
-<p>
-The script stops if a (prefixed) upload column is already present in the
+<p>The script stops if a (prefixed) upload column is already present in the
vector map attribute table, unless otherwise instructed with the <b>-c</b>
continue flag. The column prefix will be separated from the statistic name
with an underscore. For example with a prefix of "<tt>elev</tt>" the sum
column will be named <tt>elev_sum</tt>.
-<p>
-If a DBF database is being used, note that column names are restricted by the
+<p>If a DBF database is being used, note that column names are restricted by the
DBF specification to 10 characters. Therefore it is advised to be economical
in the use of the column prefix when using DBF as any additional characters
will be chopped off.
-<p>
-If a MASK is present, it will be restored after the script finished.
+<p>If a MASK is present, it will be restored after the script finished.
The script changes temporarily to the resolution of the given raster map.
-<p>
-<!-- r.univar limitation -->
+<p><!-- r.univar limitation -->
Large amounts of system memory can be used when the <b>-e</b> extended
statistics flag is used with a very large region setting. If the region
is too large the module should display memory allocation errors.
@@ -71,5 +66,4 @@
Markus Neteler, CEA (for the <a href="http://www.eden-fp6project.net/">EDEN EU/FP6 Project</a>)
-<p>
Modified: grass/trunk/scripts/v.report/v.report.html
--- grass/trunk/scripts/v.report/v.report.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.report/v.report.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,16 +2,13 @@
<em>v.report</em> generates a table showing the area present in
each of the categories of a user-selected data layer.
-<p>
-Area is given in hectares, square meters, and square kilometers.
+<p>Area is given in hectares, square meters, and square kilometers.
If the units option is used, area is given in acres, square feet,
and square miles.
-<p>
-Feet and acre units are always reported in their common versions
+<p>Feet and acre units are always reported in their common versions
(i.e. the International Foot, exactly 5280 feet in a mile), even
when the location's standard map unit is the US Survey foot.
-<p>
-<em>v.report</em> works on the full map data; therefore, the current
+<p><em>v.report</em> works on the full map data; therefore, the current
region is ignored. If you wish to spatially limit the statistics,
a map subset must be created with <em>v.in.region</em> and
<em>v.overlay</em>, and then run <em>v.report</em> on the new map.
@@ -39,5 +36,4 @@
Markus Neteler, GDF Hannover
-<p>
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.html
--- grass/trunk/scripts/v.what.vect/v.what.vect.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,16 +8,13 @@
The upload <b>column</b>, into which the query results are stored, must be
present in the <b>vector</b> map. Use <em>v.db.addcolumn</em> to add one if needed.
-<p>
-Use dmax parameter to control query distance tolerance (how far points/centroids
+<p>Use dmax parameter to control query distance tolerance (how far points/centroids
can be from <b>qvector</b> features). For more options, use
<em>v.distance</em> instead.
-<p>
-In case of a multipoint input <b>vector</b> map, with several points having the
+<p>In case of a multipoint input <b>vector</b> map, with several points having the
same category number, it can happen, that the query result is NULL, if the same
category number falls into different <b>qvector</b> polygons.
-<p>
-When transferring attributes from a point map to a polygon map, usually <b>dmax</b>
+<p>When transferring attributes from a point map to a polygon map, usually <b>dmax</b>
has to be larger than zero (determined by distance between query points and
polygon centroids).
@@ -36,7 +33,6 @@
v.db.select myhospitals
</pre></div>
<p>
In this example, city names, population data and more from
<a href="http://download.geonames.org/export/dump/">Geonames.org country files</a> are
transferred to selected EU CORINE landuse/landcover classes
@@ -71,5 +67,4 @@
Markus Neteler
-<p>
Modified: grass/trunk/scripts/wxpyimgview/wxpyimgview.html
--- grass/trunk/scripts/wxpyimgview/wxpyimgview.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/scripts/wxpyimgview/wxpyimgview.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -22,5 +22,4 @@
<h2>AUTHOR</h2>
Glynn Clements
-<p>
Modified: grass/trunk/sites/s.in.ascii/s.in.ascii.html
--- grass/trunk/sites/s.in.ascii/s.in.ascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/sites/s.in.ascii/s.in.ascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,11 +1,9 @@
<em>s.in.ascii</em> converts an ASCII listing of site
locations and category labels into GRASS vector format.
<p>
Input can be entered via standard input or from the file
<b>input=</b><em>name</em>. Each line of input should
contain the easting, northing, and either the category value
@@ -18,14 +16,13 @@
stored in the vector map <b>output=</b><em>name</em>.
<p>
The GRASS program <em><a href="s.out.ascii.html">s.out.ascii</a></em>
can be used to perform the reverse function, converting a file in GRASS
vector sites format into an ASCII listing of eastings, northings, and
category labels associated with site locations.
-<H3>Parameters:</H3>
+<h3>Parameters:</h3>
<dl>
<dt><b>output=</b><em>name</em>
@@ -45,7 +42,6 @@
</dl>
<p>
<em>s.in.ascii</em> can be run either non-interactively or
interactively. The program will be run non-interactively
if the user specifies a name to be assigned to the
@@ -54,7 +50,6 @@
separator <b>fs</b> appearing in the <b>input</b> file.
<p>
Alternately, the user can simply type <b>s.in.ascii</b> on
the command line, without program arguments. In this case,
the user will be prompted for parameter values using the
@@ -68,14 +63,12 @@
further) column in the <b>input</b> file will be treated as an attribute.
<p>To define a <b>date</b> (timestamp), several date strings are accepted.
-Please see <em><a href="r.timestamp.html">r.timestamp</A></em> for details.
+Please see <em><a href="r.timestamp.html">r.timestamp</a></em> for details.
-<p>
-<h2>NOTES</h2>
+<p><h2>NOTES</h2>
<b>Importing from other GRASS programs</b>
-<p>
-Other GRASS programs can be used to produce output in a
+<p>Other GRASS programs can be used to produce output in a
format suitable for input to <em>s.in.ascii</em>. For
example, the user might pipe output produced by
<em><a href="d.where.html">d.where</a></em> into
@@ -87,20 +80,15 @@
separates the easting and northing values with spaces, and
spaces are the default field separator assumed by
-<p>
-<dl>
+<p><dl>
<dd><b>d.where</b> | <b>s.in.ascii output=</b>my.sites
</dl>
-<p>
-<b>Importing from a spreadsheet</b>
-<p>
-Data may be imported from many spreadsheet programs by saving the spreadsheet
+<p><b>Importing from a spreadsheet</b>
+<p>Data may be imported from many spreadsheet programs by saving the spreadsheet
as a comma separated variable (.csv) text file, and then using
the "<b>fs=</b><em>,</em>" command line parameter with <em>s.in.ascii</em>.
-<p>
-<b>Importing latitude/longitude data</b>
-<p>
-Latitude/longitude data may be imported either in decimal degree format:<br>
+<p><b>Importing latitude/longitude data</b>
+<p>Latitude/longitude data may be imported either in decimal degree format:<br>
<pre>
8.314824 54.921730 site1
@@ -116,10 +104,8 @@
9:32:57.7356E 54:50:02.688N site3
</pre>
+<p><b>Time as String Attributes</b>
<p>
-<b>Time as String Attributes</b>
-<p>
In this example, we will work with the following site list:
<pre>
@@ -133,11 +119,11 @@
<h2>SEE ALSO</h2>
-<em><a href="d.vect.html">d.sites</A></em>,
-<em><a href="d.what.vect.html">d.what.vect</A></em>,
-<em><a href="d.where.html">d.where</A></em>,
-<em><a href="r.timestamp.html">r.timestamp</A></em>,
-<em><a href="s.out.ascii.html">s.out.ascii</A></em>
+<em><a href="d.vect.html">d.sites</a></em>,
+<em><a href="d.what.vect.html">d.what.vect</a></em>,
+<em><a href="d.where.html">d.where</a></em>,
+<em><a href="r.timestamp.html">r.timestamp</a></em>,
+<em><a href="s.out.ascii.html">s.out.ascii</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/sites/s.out.ascii/s.out.ascii.html
--- grass/trunk/sites/s.out.ascii/s.out.ascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/sites/s.out.ascii/s.out.ascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,7 +6,6 @@
format suitable for input to other program).
<p>
Each line of output consists of the easting, northing, and
category label for a site listed in the named <b>vector points</b> (sites)
file. The <b>fs=</b><em>name</em> option (where
@@ -17,7 +16,6 @@
<em>sed</em>.
<p>
The GRASS program <em>s.in.ascii</em> can be used to
perform the reverse function, converting a UNIX file
containing eastings, northings, and category labels
@@ -26,7 +24,7 @@
<h2>OPTIONS</h2>
-<H3>Flags:</H3>
+<h3>Flags:</h3>
<dl>
<dt><b>-a</b>
@@ -42,7 +40,7 @@
</dl>
<dl>
@@ -66,8 +64,7 @@
if the user specifies the name of an existing site list
file and (optionally) a value for <b>fs</b>, using the form
-<p>
-<dl>
+<p><dl>
<dd>
<b>s.out.ascii</b>
[<b>-adi</b>]
@@ -85,21 +82,19 @@
output.
<p>
Alternately, the user can simply type <b>s.out.ascii</b> on
standard GRASS
-<a href="parser.html">parser</A>
+<a href="parser.html">parser</a>
interface.
<h2>NOTES</h2>
To output GRASS data in x,y,z ASCII style, the s.out.ascii may be used:
-<p>
-<dl>
+<p><dl>
<dd>
<b>s.out.ascii -d input=</b>sitesmap
</dl>
@@ -117,12 +112,10 @@
converted to sites format using <em>r.to.sites</em> and <em>s.out.ascii</em>
subsequently as described above.
-<p>
-The output from <em>s.out.ascii</em> may be placed into a
+<p>The output from <em>s.out.ascii</em> may be placed into a
file by using the UNIX redirection mechanism; e.g.:
-<p>
-<dl>
+<p><dl>
<dd>
<b>s.out.ascii input=</b>archsites > out.file
</dl>
@@ -130,18 +123,17 @@
<em>s.out.ascii</em> output may also be redirected into
other programs; e.g.:
-<p>
-<dl>
+<p><dl>
<dd>
<b>s.out.ascii input=</b>archsites | d.points <b>color=</b>red <b>size=</b>10 <b>type=</b>diamond
</dl>
<h2>SEE ALSO</h2>
-<em><a href="d.points.html">d.points</A></em><br>
-<em><a href="d.vect.html">d.vect</A></em><br>
-<em><a href="s.in.ascii.html">s.in.ascii</A></em><br>
-<em><a href="r.to.vect.html">r.to.vect</A></em>
+<em><a href="d.points.html">d.points</a></em><br>
+<em><a href="d.vect.html">d.vect</a></em><br>
+<em><a href="s.in.ascii.html">s.in.ascii</a></em><br>
+<em><a href="r.to.vect.html">r.to.vect</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.buffer/v.buffer.html
--- grass/trunk/vector/v.buffer/v.buffer.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.buffer/v.buffer.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -58,5 +58,4 @@
Radim Blazek<br>
Rewritten by Rosen Matev (with support through the
Google Summer of Code program 2008)
-<p>
Modified: grass/trunk/vector/v.build/v.build.html
--- grass/trunk/vector/v.build/v.build.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.build/v.build.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,11 +4,9 @@
GRASS vector data files. These support files supply
topology and category information that are needed by other
GRASS modules.
-<p>
-GRASS is generating these support files automatically,
+<p>GRASS is generating these support files automatically,
only in rare cases the user has to (re)build them.
-<p>
-Refer to
+<p>Refer to
<em><a href="vectorintro.html">Vector data processing in GRASS GIS</a></em>
for more information on GRASS GIS vector data model.
@@ -18,13 +16,11 @@
vector maps located in the user's current mapset. If vector map
is located in another mapset, you need to specify this:
-<p>
v.build map=geology at PERMANENT
</pre></div>
-<p>
-In case of errors, the user can optionally generate an <em>error</em>
+<p>In case of errors, the user can optionally generate an <em>error</em>
vector map containing the erroneous vectors for later inspection.
<h2>SEE ALSO</h2>
Modified: grass/trunk/vector/v.build.polylines/v.build.polylines.html
--- grass/trunk/vector/v.build.polylines/v.build.polylines.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.build.polylines/v.build.polylines.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,14 +3,12 @@
<em>v.build.polylines</em> builds polylines from the lines or
boundaries in a vector map.
-<p>
-A line is defined by one start node, one end node and any number of
+<p>A line is defined by one start node, one end node and any number of
vertices between the start and end node. The shortest possible line
consists of only two vertices where the coordinates of the start and end
node are identical to those of the two vertices.
-<p>
-<em>v.build.polyline</em> picks a line and from its start node, walks
+<p><em>v.build.polyline</em> picks a line and from its start node, walks
back as long as exactly one other line of the same type is connected to
this node. Line directions are reversed as required, i.e. it does not
matter if the next line is connected to the current node by its start or
@@ -25,8 +23,7 @@
the <em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector
digitizer</a></em>.
-<p>
-Polylines provide the most appropriate representation of curved lines when it
+<p>Polylines provide the most appropriate representation of curved lines when it
is important that nodes serve to define topology rather than geometry. Curved
lines are usually digitized as polylines, but these are sometimes broken into
their constituent straight line segments during conversion from one data
@@ -38,8 +35,7 @@
<em>v.build.polylines</em> combines only lines oif the same type to
a new polyline, i.e. lines and boundaries are kept separate.
-<p>
-Category number(s) are assigned to a polyline based on <b>cats</b> parameter.
+<p>Category number(s) are assigned to a polyline based on <b>cats</b> parameter.
<ul>
<li><b>cats=no</b> - No category number is assigned to a
@@ -84,5 +80,4 @@
Category mode added by Martin Landa, FBK-irst, Trento, Italy, October 2007<br>
Support for different line types by Markus Metz
-<p>
Modified: grass/trunk/vector/v.category/v.category.html
--- grass/trunk/vector/v.category/v.category.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.category/v.category.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,29 +10,24 @@
Use <em><a href="v.to.db.html">v.to.db</a></em> to upload related categories
to a linked attribute table.
-<p>
-The <b>type</b> parameter specifies the type of geometry objects to which
+<p>The <b>type</b> parameter specifies the type of geometry objects to which
the category is added; it is similar to an input filter - only the
geometry specified in 'type' is processed.
-<p>
-If the <b>type</b> parameter is set to <b>centroid</b> and
+<p>If the <b>type</b> parameter is set to <b>centroid</b> and
the <b>option</b> parameter set to <b>add</b>, new categories will be
added to existing centroids. Note however, that new centroids cannot
be created this way. To do so, they must be added manually
using <em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector
digitizer</a></em> or by running <em>v.category</em> with the type
parameter set to area.
-<p>
-Areas are a special case because it is impossible to attach a cat to
+<p>Areas are a special case because it is impossible to attach a cat to
an area without a centroid; in this case, the module places new
centroids in areas automatically.
-<p>
-The <b>cat</b> parameter is only used with <b>option</b>=<i>add</i> and
+<p>The <b>cat</b> parameter is only used with <b>option</b>=<i>add</i> and
<b>option</b>=<i>sum</i>.
-<p>
-The <b>ids</b> parameter specifies the list of feature IDs to which the
+<p>The <b>ids</b> parameter specifies the list of feature IDs to which the
operation is performed; by default, all vector feature ids are processed.
The <i>feature ID</i> is an internal (unique) geometry ID that all vector
primitives possess, and is separate from any category the feature may
@@ -117,5 +112,4 @@
Modified (the id parameter) by Martin Landa,
FBK-irst (formerly ITC-irst), Trento, Italy, 2008/02
-<p>
Modified: grass/trunk/vector/v.class/v.class.html
--- grass/trunk/vector/v.class/v.class.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.class/v.class.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -40,8 +40,8 @@
<h2>SEE ALSO</h2>
-<em><a href="v.univar.html">v.univar</A></em>
-<em><a href="d.thematic.area.html">d.area.thematic</A></em>
+<em><a href="v.univar.html">v.univar</a></em>
+<em><a href="d.thematic.area.html">d.area.thematic</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.clean/v.clean.html
--- grass/trunk/vector/v.clean/v.clean.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.clean/v.clean.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,68 +5,55 @@
<h3>Break lines/boundaries</h3>
<em>tool=break</em>
-<p>
-Threshold does not apply, use dummy value if <em>v.clean</em> is
+<p>Threshold does not apply, use dummy value if <em>v.clean</em> is
run with several tools.
-<p>
-The <em>break</em> tool breaks lines/boundaries at intersections and also
+<p>The <em>break</em> tool breaks lines/boundaries at intersections and also
breaks lines/boundaries forming a collapsed loop, for example 0.0;1.0;0.0
is broken at 1.0.
-<p>
-Breaking lines should be followed by removing duplicates, e.g.
+<p>Breaking lines should be followed by removing duplicates, e.g.
<em>v.clean tool=break,rmdupl</em>. If the <em>-c</em> flag is used with
<em>v.clean tool=break</em>, duplicates are automatically removed.
<h3>Remove duplicate geometry features</h3>
<em>tool=rmdupl</em>
-<p>
-<p>
-The <em>rmdupl</em> tool removes geometry features with identical
+<p>The <em>rmdupl</em> tool removes geometry features with identical
coordinates. Categories are merged. If a point and a centroid have
identical coordinates, one of them will be removed if both points and
centroids are selected with <em>v.clean type=point,centroid</em>. The
same applies for lines and boundaries.
-<p>
-The <em>rmdupl</em> tool should be used after breaking lines and
+<p>The <em>rmdupl</em> tool should be used after breaking lines and
breaking polygons.
<h3>Remove dangles or change boundary dangles to type line</h3>
<em>tool=rmdangle</em> and <em>tool=chdangle</em>
-<p>
-Threshold gives maximum line/boundary length in map units, degrees for
+<p>Threshold gives maximum line/boundary length in map units, degrees for
latlon. Dangles shorter than <em>thresh</em> are removed sequentially.
All dangles will be removed if <em>thresh</em> < 0.
-<p>
-A line/boundary is considered to be a dangle if no other line of given
+<p>A line/boundary is considered to be a dangle if no other line of given
<em>type</em> is on at least one end node. If a dangle is formed by
several lines, such a string of lines is taken as one dangle and line
lengths are summarized. The <em>rmdangle</em> tool deletes a dangle if
the (combined) length is shorter than <em>thres</em> or <em>thres</em>
< 0. If the combined length is larger than <em>thresh</em>, nothing
is deleted.
-<p>
-With <em>thresh</em> < 0, only closed loops and lines connecting
+<p>With <em>thresh</em> < 0, only closed loops and lines connecting
loops will remain. This is useful to remove all incorrect boundaries
after other cleaning operations with <em>thres</em> is < 0. Areas can
then be successfully built.
-<p>
-To preferentially remove shortest dangles first, a first pass with a
+<p>To preferentially remove shortest dangles first, a first pass with a
small <em>thresh</em> value can be followed by subsequent passes with
increasing <em>thresh</em> values.
-<p>
-The <em>chdangle</em> tool is similar to the <em>rmdangle</em> tool, but
+<p>The <em>chdangle</em> tool is similar to the <em>rmdangle</em> tool, but
works only on boundaries and changes dangling boundaries to lines
instead of removing dangles.
<h3>Remove or change bridges connecting an area and an island or two islands</h3>
<em>tool=rmbridge</em> and <em>tool=chbridge</em>
-<p>
-<p>
-A bridge is an area type connection of an island (polygon in a polygon)
+<p>A bridge is an area type connection of an island (polygon in a polygon)
to the outer polygon. This is topologically incorrect (but OGC Simple
Features allow it). The <em>rmbridge</em> tool removes bridges and the
<em>chbridge</em> tool changes bridges to type line:
@@ -83,24 +70,20 @@
</pre></div>
-<p>
-Islands and areas must be already clean, i.e. without dangles or small
+<p>Islands and areas must be already clean, i.e. without dangles or small
angles, e.g. <em>v.clean type=boundary tool=rmdangle,rmsa,break,rmdupl,rmbridge
thresh=-1,0,0,0,0</em>.
<h3>Snap lines to vertex in threshold</h3>
<em>tool=snap</em>
-<p>
-Threshold gives maximum distance to another vertex in map units,
+<p>Threshold gives maximum distance to another vertex in map units,
degrees for latlon.
-<p>
-The <em>snap</em> tool snaps vertices to another vertex not farther away
+<p>The <em>snap</em> tool snaps vertices to another vertex not farther away
than <em>thresh</em>. If there is no other vertex within <em>thresh</em>,
no snapping will be done. The <em>type</em> option can have a strong
influence on the result. A too large threshold and <em>type=boundary</em>
can severely damage area topology, beyond repair.
-<p>
-Snapped boundaries may need to be cleaned with <em>break,rmdupl,rmsa</em>.
+<p>Snapped boundaries may need to be cleaned with <em>break,rmdupl,rmsa</em>.
If the <em>-c</em> flag is used with <em>v.clean tool=snap</em>, the
sequence of <em>break,rmdupl,rmsa</em> is automatically repeated after
snapping until no more small angles a left. Additional cleaning with e.g.
@@ -108,35 +91,29 @@
<h3>Remove duplicate area centroids</h3>
<em>tool=rmdac</em>
-<p>
-<p>
-The <em>rmdac</em> tool removes duplicate area centroids that can result
+<p>The <em>rmdac</em> tool removes duplicate area centroids that can result
from deleting boundaries.
<h3>Break (topologically clean) areas (imported from a non topological
format like ShapeFile)</h3>
<em>tool=bpol</em>
-<p>
-<p>
-The <em>bpol</em> tool breaks boundaries on each point shared between 2
+<p>The <em>bpol</em> tool breaks boundaries on each point shared between 2
and more areas where angles of boundary segments are different and on
all boundary nodes (start and end points of each boundary). The
<em>bpol</em> tool behaves similar to <em>break</em> for boundaries, but
does not break collapsed loops. The <em>bpol</em> tool is faster than
the <em>break</em> tool but needs more memory.
-<p>
-The <em>bpol</em> tool should be followed by <em>rmdupl</em>. If the
+<p>The <em>bpol</em> tool should be followed by <em>rmdupl</em>. If the
<em>-c</em> flag is used with <em>v.clean tool=bpol</em>, duplicates are
<h3>Remove vertices in threshold from lines and boundaries</h3>
<em>tool=prune</em>
-<p>
-The <em>prune</em> tool simplifies lines and boundaries by removing
+<p>The <em>prune</em> tool simplifies lines and boundaries by removing
vertices according to threshold. This tool preserves area topology,
areas are never deleted and centroid attachment is never changed.
<em><a href=v.generalize.html>v.generalize</a></em> offers much more
@@ -145,43 +122,35 @@
<h3>Remove small areas</h3>
<em>tool=rmarea</em>
-<p>
-Threshold gives area size in map units, square meters for latlon.
-<p>
-The <em>rmarea</em> tool removes all areas <= <em>thresh</em>. The
+<p>Threshold gives area size in map units, square meters for latlon.
+<p>The <em>rmarea</em> tool removes all areas <= <em>thresh</em>. The
longest boundary with an adjacent area is removed or all boundaries if
there is no adjacent area. Area categories are not combined when a small
area is merged with a larger area.
<h3>Remove all lines or boundaries of zero length</h3>
<em>tool=rmline</em>
-<p>
-<p>
-The <em>rmline</em> tool removes all lines or boundaries of zero length
+<p>The <em>rmline</em> tool removes all lines or boundaries of zero length
that may have resulted from other cleaning operations. Zero length
boundaries are redundant and do not influence area topology.
<h3>Remove small angles between lines at nodes</h3>
<em>tool=rmsa</em>
-<p>
-<p>
-The <em>rmsa</em> tool only concerns angles which are so small that the
+<p>The <em>rmsa</em> tool only concerns angles which are so small that the
calculated angle is 0. The following figure should help demonstrate what
the tool does.
-<p>
-<table><tr><td>
+<p><table><tr><td>
<img src="v_clean_rmsa.png" border=1>
</td></tr>
<tr><td align=center>
<font size=-1><em>tool=rmsa</em></font>
</td></tr>
</table>
-<p>
-The <em>rmsa</em> tool should be followed by <em>break,rmdupl</em>. The
+<p>The <em>rmsa</em> tool should be followed by <em>break,rmdupl</em>. The
<em>rmsa</em> tool followed by <em>break,rmdupl</em> may need to be run
more than once to remove all small angles. If the <em>-c</em> flag is
used with <em>v.clean tool=rmsa</em>, the sequence of
Modified: grass/trunk/vector/v.colors/v.colors.html
--- grass/trunk/vector/v.colors/v.colors.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.colors/v.colors.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,29 +3,24 @@
<em>v.colors</em> allows the user to create and/or modify the color
table for a vector map. The vector map (specified on the command line
by <b>map</b>) must exist in the user's current mapset search path.
-<p>
-As input a vector map with a numeric data column is required which is
+<p>As input a vector map with a numeric data column is required which is
used to apply the color rules. The color values are stored in a string
column (default name "GRASSRGB", varchar(11)) by saving the RRR:GGG:BBB
values suitable for use with '<tt>d.vect -a</tt>'. If this RGB column
is not found in the attribute table, it is automatically created.
-<p>
-The <b>rast</b> option allows user to specify a raster map <i>name</i>
+<p>The <b>rast</b> option allows user to specify a raster map <i>name</i>
from which to copy the color map.
-<p>
-The <b>volume</b> option allows user to specify a volume (3D raster)
+<p>The <b>volume</b> option allows user to specify a volume (3D raster)
map <i>name</i> from which to copy the color map.
-<p>
-If the user specifies the <b>-w</b> flag, the current color table file
+<p>If the user specifies the <b>-w</b> flag, the current color table file
for the input map will not be overwritten. This means that the color
table is created only if the <i>map</i> does not already have a color
table. If this option is not specified, the color table will be
created if one does not exist, or modified if it does.
-<p>
-In general, tables which associate colors with percentages (aspect,
+<p>In general, tables which associate colors with percentages (aspect,
bcyr, byg, byr, elevation, grey, gyr, rainbow, ramp, ryb, ryg and
wave) can be applied to any data, while those which use absolute
values (aspectcolr, curvature, etopo2, evi, ndvi, population, slope,
@@ -42,13 +37,11 @@
100% green
</pre></div>
-<p>
-The <b>rules</b> color table type will cause <em>r.colors</em> to read
+<p>The <b>rules</b> color table type will cause <em>r.colors</em> to read
color table specifications from standard input and will build
the color table accordingly.
-<p>
-For details see <em><a href="r.colors.html">r.colors</a></em> manual page.
+<p>For details see <em><a href="r.colors.html">r.colors</a></em> manual page.
<h2>EXAMPLES</h2>
@@ -92,18 +85,15 @@
<a href="r3.colors.out.html">r3.colors.out</a>,
</em>
-<p>
-See also wiki
+<p>See also wiki
page <a href="http://grass.osgeo.org/wiki/Color_tables">Color
tables</a> (from GRASS User Wiki)
-<p>
-<a href="http://colorbrewer.org">ColorBrewer</a> is an online tool designed to
+<p><a href="http://colorbrewer.org">ColorBrewer</a> is an online tool designed to
help people select good color schemes for maps and other graphics.
<h2>AUTHORS</h2>
Martin Landa, Czech Technical University in Prague, Czech Republic
-<p>
Modified: grass/trunk/vector/v.colors.out/v.colors.out.html
--- grass/trunk/vector/v.colors.out/v.colors.out.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.colors.out/v.colors.out.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -25,5 +25,4 @@
-<p>
Modified: grass/trunk/vector/v.convert/v.convert.html
--- grass/trunk/vector/v.convert/v.convert.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.convert/v.convert.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,16 +7,13 @@
Vector maps from 5.0/5.3/5.4 and 5.7/6.x do not interfere. They are stored in different
directories, so you can use the same names. Old vector maps can be listed with
-<p>
-If you need to convert back from 5.7/6.x into the 5.0/5.3/5.4 vector format,
+<p>If you need to convert back from 5.7/6.x into the 5.0/5.3/5.4 vector format,
Alternatively use "<em>v.out.ascii -o</em>" and <em>v.in.ascii</em>.
-<p>
-As this GRASS version uses SQL for attribute management, there are
+<p>As this GRASS version uses SQL for attribute management, there are
-<p>
-Missing centroids can be added with <em>v.category</em>.
+<p>Missing centroids can be added with <em>v.category</em>.
<h2>EXAMPLE</h2>
@@ -25,12 +22,12 @@
<h2>SEE ALSO</h2>
-<a href="g.list.html">g.list</A>,
-<a href="v.category.html">v.category</A>,
-<a href="v.convert.all.html">v.convert.all</A>,
-<a href="v.out.ascii.html">v.out.ascii</A>,
-<a href="v.in.ascii.html">v.in.ascii</A>,
-<a href="v.out.ogr.html">v.out.ogr</A>
+<a href="g.list.html">g.list</a>,
+<a href="v.category.html">v.category</a>,
+<a href="v.convert.all.html">v.convert.all</a>,
+<a href="v.out.ascii.html">v.out.ascii</a>,
+<a href="v.in.ascii.html">v.in.ascii</a>,
+<a href="v.out.ogr.html">v.out.ogr</a>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.db.connect/v.db.connect.html
--- grass/trunk/vector/v.db.connect/v.db.connect.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.db.connect/v.db.connect.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,13 +10,11 @@
<a href="db.connect.html">db.connect</a>, they are taken as default values and
do not need to be spcified each time.
-<p>
-When printing database connection (<em>p</em> or <em>g</em> flag) the parameter
+<p>When printing database connection (<em>p</em> or <em>g</em> flag) the parameter
<em>layer</em> is ignored, i.e. <b>all</b> connections are printed to the
output.
-<p>
-<b>Attention:</b> Removing a vector map will also delete all tables
+<p><b>Attention:</b> Removing a vector map will also delete all tables
linked to it! If you use <a href="db.connect.html">v.db.connect </a>to
link further tables to your map, it is advisable to make a copy from
those tables first and connect the copied tables to the vector map
@@ -32,8 +30,7 @@
v.db.connect -p map=roads
</pre></div>
-<p>
-Print column types and names of table linked to vector map.
+<p>Print column types and names of table linked to vector map.
v.db.connect -c map=roads
@@ -43,28 +40,24 @@
Connect vector map to DBF table without or with variables.<br>
-<p>
-Using default DB connection:
+<p>Using default DB connection:
v.db.connect map=vectormap table=table
</pre></div>
-<p>
-Using hardcoded path to DBF directory (not recommended):<br>
+<p>Using hardcoded path to DBF directory (not recommended):<br>
v.db.connect map=vectormap table=table \
database=/home/user/grassdata/spearfish60/PERMANENT/dbf
</pre></div>
-<p>
-Using variable as DBF directory definition, single quotes must be used:<br>
+<p>Using variable as DBF directory definition, single quotes must be used:<br>
database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
</pre></div>
-<p>
-Connect vector map layer 2 and key ID to database with variables
+<p>Connect vector map layer 2 and key ID to database with variables
(note: if needed, single quotes must be used for the <em>database</em>
parameter):
@@ -112,7 +105,7 @@
table=mytable key=id
</pre></div>
-<H3>Store geometry in GRASS but attributes in PostgreSQL</H3>
+<h3>Store geometry in GRASS but attributes in PostgreSQL</h3>
This example illustrated a mixed data storage with possibility
top update attributes in external PostgreSQL database:
@@ -152,7 +145,7 @@
is very large.
-<H3>Store geometry in GRASS but attributes in PostGIS</H3>
+<h3>Store geometry in GRASS but attributes in PostGIS</h3>
top update attributes in external PostGIS database:
Modified: grass/trunk/vector/v.db.select/v.db.select.html
--- grass/trunk/vector/v.db.select/v.db.select.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.db.select/v.db.select.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -50,5 +50,4 @@
Minimal region extent added by Martin Landa,
FBK-irst (formerly ITC-irst), Trento, Italy (2008/08)
-<p>
Modified: grass/trunk/vector/v.delaunay/v.delaunay.html
--- grass/trunk/vector/v.delaunay/v.delaunay.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.delaunay/v.delaunay.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,7 +3,6 @@
<em>v.delaunay</em> uses an existing vector points map (<b>input</b>)
to create a Delaunay triangulation vector map (<b>output</b>).
<p>
<br>
Delaunay triangulation and Voronoi diagram example:
<center>
@@ -54,8 +53,8 @@
<h2>SEE ALSO</h2>
<em>
-<a href="v.voronoi.html">v.voronoi</A>,
-<a href="v.hull.html">v.hull</A>
+<a href="v.voronoi.html">v.voronoi</a>,
+<a href="v.hull.html">v.hull</a>
</em>
@@ -65,5 +64,4 @@
Based on "dct" by Geoff Leach, Department of Computer Science, RMIT.<br>
-<p>
Modified: grass/trunk/vector/v.distance/v.distance.html
--- grass/trunk/vector/v.distance/v.distance.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.distance/v.distance.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,16 +14,14 @@
that if a point is in an island (area WITHOUT category), <em>v.distance</em>
does not search for the nearest area WITH category; the island is identified
as the nearest and category updated to null.
-<p>
-The upload <em>column</em>(s) must already exist. Create one with <em>v.db.addcolumn</em>.
-<p>
-In lat-long locations <em>v.distance</em> gives distances (<em>dist</em>
+<p>The upload <em>column</em>(s) must already exist. Create one with <em>v.db.addcolumn</em>.
+<p>In lat-long locations <em>v.distance</em> gives distances (<em>dist</em>
and <em>to_along</em>) in meters not in degrees calculated as geodesic
distances on a sphere.
<h2>EXAMPLES</h2>
-<H3>Find nearest lines</H3>
+<h3>Find nearest lines</h3>
Find <em>nearest lines</em> in vector map <b>ln</b> for points from
vector map <b>pnt</b> within the given threshold and write related
@@ -34,7 +32,7 @@
v.distance from=pnt to=ln upload=cat column=linecat
</pre></div>
-<H3>Find nearest area</H3>
+<h3>Find nearest area</h3>
For each point from vector map <b>pnt</b>, find the <em>nearest area</em>
from map <b>ar</b> within the given threshold and write the related
@@ -46,7 +44,7 @@
v.distance from=pnt to=ar upload=cat column=areacat
</pre></div>
-<H3>Create a new vector map</H3>
+<h3>Create a new vector map</h3>
Create a new vector map which contains <em>lines connecting nearest
features</em> of maps <b>pnt</b> and map <b>ln</b>. The resulting
@@ -57,13 +55,12 @@
v.distance -p from=pnt to=ln out=connections upload=dist column=dist
</pre></div>
-<H3>Query information</H3>
+<h3>Query information</h3>
Query information from selected point(s). <em>v.distance</em> takes
points from a vector map as input instead of stdin. A new vector map
with query points has to be created before the map can be analysed.
<p>
Create query map (if not present):
@@ -76,7 +73,7 @@
v.distance from=pnt to=map_to_query upload=cat col=somecol -p
</pre></div>
-<H3>Point-in-polygon</H3>
+<h3>Point-in-polygon</h3>
The option <em>dmax=0</em> is here important because otherwise for
points not falling into any area, the category of the nearest area is
@@ -91,7 +88,7 @@
v.distance from=pnt to=ar dmax=0 upload=cat column=areacat
</pre></div>
-<H3>Univariate statistics on results</H3>
+<h3>Univariate statistics on results</h3>
Create a vector map containing connecting lines and investigate mean
distance to targets. An alternative solution is to use
@@ -122,7 +119,7 @@
v.univar vdistance_vectors column=length
</pre></div>
-<H3>Print distance matrix</H3>
+<h3>Print distance matrix</h3>
v.distance -pa from=archsites to=archsites upload=dist col=dist
Modified: grass/trunk/vector/v.drape/v.drape.html
--- grass/trunk/vector/v.drape/v.drape.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.drape/v.drape.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,12 +11,10 @@
can not be determined from raster map.
<h2>NOTES</h2>
-<p>
-Additional vertices can be added to the input 2D vector map
+<p>Additional vertices can be added to the input 2D vector map
with <a href="v.split.html">v.split</a>.
-<p>
-The module can be used in conjunction
+<p>The module can be used in conjunction
with <a href="v.out.pov.html">v.out.pov</a> and
<a href="r.out.pov.html">r.out.pov</a> to export a complete set of
vector and raster data for display in POVRAY.
Modified: grass/trunk/vector/v.edit/v.edit.html
--- grass/trunk/vector/v.edit/v.edit.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.edit/v.edit.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,17 +3,14 @@
The module <em>v.edit</em> allows the user to edit a vector map
via command line interface.
-<p>
-<em>v.edit</em> supports only "simple" vector features: points,
+<p><em>v.edit</em> supports only "simple" vector features: points,
centroids, lines and boundaries. Currently, only 2D vector features
(except of tool <b>zbulk</b>) are supported.
-<p>
-Provides editing features' geometry. Attribute data connected to the
+<p>Provides editing features' geometry. Attribute data connected to the
vector map are not modified at all.
-<p>
-Vector features can be selected either by internal <b>id</b>, category
+<p>Vector features can be selected either by internal <b>id</b>, category
number <b>cats</b>, coordinates <b>coords</b>, bounding
box <b>bbox</b>, <b>polygon</b>, <b>where</b> statement (attribute
data) or by <b>query</b>. Selecting features by coordinates is
@@ -192,7 +189,6 @@
format</a>.
<p>
Add new features read from standard input:
@@ -426,8 +422,7 @@
<a href="v.extrude.html">v.extrude</a>
</em>
-<p>
-See also <em><a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a></em>.
+<p>See also <em><a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a></em>.
<h2>AUTHOR</h2>
@@ -435,5 +430,4 @@
Initial updates: Jachym Cepicky, Mendel University of Agriculture and Forestry in Brno, Czech Republic<br>
Major update by Martin Landa, FBK-irst (formerly ITC-irst), Trento, Italy
-<p>
Modified: grass/trunk/vector/v.external/v.external.html
--- grass/trunk/vector/v.external/v.external.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.external/v.external.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -61,8 +61,7 @@
modules working correctly with GRASS native data, can produce wrong
results with input layers created by <em>v.external</em>.
-<p>
-See <em><a href="v.db.connect.html">v.db.connect</a></em> for an example of
+<p>See <em><a href="v.db.connect.html">v.db.connect</a></em> for an example of
maintaining attributes in external DBMS in also writeable mode.
<h2>REFERENCES</h2>
@@ -87,5 +86,4 @@
Radim Blazek, ITC-Irst, Trento, Italy
-<p>
Modified: grass/trunk/vector/v.external.out/v.external.out.html
--- grass/trunk/vector/v.external.out/v.external.out.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.external.out/v.external.out.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -37,5 +37,4 @@
Martin Landa, CTU in Prague, Czech Republic (based on r.external.out code)
-<p>
Modified: grass/trunk/vector/v.extract/v.extract.html
--- grass/trunk/vector/v.extract/v.extract.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.extract/v.extract.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -7,8 +7,7 @@
Dissolving (optional) is based on the output categories. If 2 adjacent
areas have the same output category, the boundary is removed.
-<p>
-If <b>list</b>, <b>file</b>, <b>random</b> or <b>where</b> options are not
+<p>If <b>list</b>, <b>file</b>, <b>random</b> or <b>where</b> options are not
specified, all features of given type and layer are
extracted. Categories are not changed in that case.
@@ -26,8 +25,7 @@
v.extract -d list=1,2,3,4 input=soils output=soil_groupa type=area new=0
</pre></div>
-<p>
-produces a new vector <b>soil_groupa</b>, containing those areas from vector
+<p>produces a new vector <b>soil_groupa</b>, containing those areas from vector
<b>soils</b> which have category numbers <b>1 thru 4</b>; any common boundaries are
dissolved, and all areas in the new map will be assigned category number 0.
@@ -35,8 +33,7 @@
v.extract -d list=1-4 input=soils output=soil_groupa type=area new=-1
</pre></div>
-<p>
-produces a new vector map <b>soil_groupa</b> containing the areas from vector
+<p>produces a new vector map <b>soil_groupa</b> containing the areas from vector
<b>soils</b> which have categories <b>1 thru 4</b>. Any common boundaries are
dissolved, all areas in the new map will retain their original category
numbers 1 thru 4, since <b>new</b> was set to -1.
@@ -46,7 +43,6 @@
v.extract input=soils output=soil_groupa type=area new=1
</pre></div>
<p>
produces a new vector map <b>soil_groupa</b> containing all areas from
<b>soils</b>. No common boundaries are dissolved, all areas of the new
map will be assigned category number 1.
@@ -56,7 +52,6 @@
v.extract input=markveggy.shp output=markveggy.1 new=13 where="(VEGTYPE = 'Wi') or (VEGTYPE = 'PS') or (PRIME_TYPE='Wi')"
</pre></div>
<p>
produces a new vector map with category number 13 if the SQL statement is
fulfilled.
@@ -100,7 +95,6 @@
v.extract -d polbnda_italy_recl_nam out=pol_italy_regions
</pre></div>
<p>
produces a new vector map with common boundaries dissolved where the reclassed
attributes of adjacent (left/right) areas are identical.
@@ -112,8 +106,7 @@
</pre></div>
<h3>Extract 3 random areas from geology map</h3>
-<p>
v.extract input=geology output=random_geology type=area random=3
</pre></div>
will create new map with three random categories matching areas.
@@ -133,5 +126,4 @@
R.L. Glenn, USDA, SCS, NHQ-CGIS<br>
GRASS 6 port by Radim Blazek
-<p>
Modified: grass/trunk/vector/v.extrude/v.extrude.html
--- grass/trunk/vector/v.extrude/v.extrude.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.extrude/v.extrude.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,13 +1,11 @@
<h2>DESCRIPTION</h2>
-<p>
-<em>v.extrude</em> creates faces, kernels, volumes or 3D lines based
+<p><em>v.extrude</em> creates faces, kernels, volumes or 3D lines based
on 2D vector objects, i.e. points become 3D vertical lines, lines to
3D lines, boundaries to faces and areas to volumes (composition of
faces and kernel).
-<p>
-If the flag <b>-t</b> is used then 3D vector objects follow the
+<p>If the flag <b>-t</b> is used then 3D vector objects follow the
elevation model by using individual elevation values for the vertices
and nodes. This can be useful for models of large objects (forest
stands).
@@ -42,5 +40,4 @@
Jachym Cepicky,<br>
Updated by Martin Landa, FBK-irst, Italy
-<p>
Modified: grass/trunk/vector/v.generalize/v.generalize.html
--- grass/trunk/vector/v.generalize/v.generalize.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.generalize/v.generalize.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
network generalization and displacement (new methods may be added later).
For more examples and nice pictures, see
<em><a href="http://users.ox.ac.uk/~orie1848/tutorial.html">tutorial</a><br></em>
-<p>
-If <em>type=area</em> is selected, boundaries of selected areas will be
+<p>If <em>type=area</em> is selected, boundaries of selected areas will be
generalized, and the options <em>cats</em>, <em>where</em>, and
<em>layer</em> will be used to select areas.
@@ -17,15 +16,13 @@
fewer vertices, that still approximate the original line. Most of the
algorithms described below select a subset of points on the original line.
-<p>
-(Line) smoothing is a "reverse" process which takes as input a line and
+<p>(Line) smoothing is a "reverse" process which takes as input a line and
produces a smoother approximate of the original. In some cases, this is
achieved by inserting new vertices into the original line, and can total
up to 4000% of the number of vertices in the original. In such an instance,
it is always a good idea to simplify the line after smoothing.
-<p>
-Smoothing and simplification algorithms implemented in this module work
+<p>Smoothing and simplification algorithms implemented in this module work
line by line, i.e. simplification/smoothing of one line does not affect
the other lines; they are treated separately. Also, the first and the
last point of each line is never translated and/or deleted.
@@ -150,8 +147,7 @@
through these points. In some sense, this algorithm outputs a line which
"circumscribes" the input line.
-<p>
-On the other hand, <i>Chaiken's Algorithm</i> outputs a line which
+<p>On the other hand, <i>Chaiken's Algorithm</i> outputs a line which
"inscribes" a given line. The output line always touches/intersects the
centre of the input line segment between two consecutive points. For
more iterations, the property above does not hold, but the computed
@@ -161,19 +157,16 @@
simplification algorithm. To achieve this, it is necessary to set
<i>angle_thresh</i> to higher values (15 or so).
-<p>
-One restriction on both McMasters' Algorithms is that <i>look_ahead</i>
+<p>One restriction on both McMasters' Algorithms is that <i>look_ahead</i>
parameter must be odd. Also note that these algorithms have no effect if
<i>look_ahead = 1</i>.
-<p>
-Note that <i>Boyle's</i>, <i>McMasters'</i> and <i>Snakes</i> algorithm
+<p>Note that <i>Boyle's</i>, <i>McMasters'</i> and <i>Snakes</i> algorithm
are sometimes used in the signal processing to smooth the signals.
More importantly, these algorithms never change the number of points on
the lines; they only translate the points, and do not insert any new points.
-<p>
-<i>Snakes</i> Algorithm is (asymptotically) the slowest among the
+<p><i>Snakes</i> Algorithm is (asymptotically) the slowest among the
algorithms presented above. Also, it requires quite a lot of memory.
This means that it is not very efficient for maps with the lines
consisting of many segments.
@@ -185,13 +178,11 @@
move the conflicting features apart so that they do not interact and can
be distinguished.
-<p>
-This module implements an algorithm for displacement of linear features
+<p>This module implements an algorithm for displacement of linear features
based on the <i>Snakes</i> approach. This method generally yields very
good results; however, it requires a lot of memory and is not very efficient.
-<p>
-Displacement is selected by <b>method=displacement</b>. It uses the
+<p>Displacement is selected by <b>method=displacement</b>. It uses the
following parameters:
<ul>
@@ -259,8 +250,7 @@
All three parameters above can be presented at the same time. In that
case, the algorithm selects only the lines which meet each criterion.
-<p>
-Also, the outputed network may not be connected if the value of
+<p>Also, the outputed network may not be connected if the value of
<b>betweeness_thresh</b> is too large.
<!-- TODO: example(s) -->
@@ -281,5 +271,4 @@
<!-- TODO: references -->
-<p>
Modified: grass/trunk/vector/v.hull/v.hull.html
--- grass/trunk/vector/v.hull/v.hull.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.hull/v.hull.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
convex set containing the given objects. This module creates a vector
polygon containing all vector points or lines of the input map.
-<p>
-In the case of 3D input points, the hull will be a 3D hull as well,
+<p>In the case of 3D input points, the hull will be a 3D hull as well,
unless the user specifies the <b>-f</b> flag. The 3D hull will be
composed of triangular faces.
@@ -56,5 +55,4 @@
Benjamin Ducke, CAU Kiel (3D hull support)<br>
Martin Landa, CTU in Prague, Czech Republic (vector lines support)
-<p>
Modified: grass/trunk/vector/v.in.ascii/v.in.ascii.html
--- grass/trunk/vector/v.in.ascii/v.in.ascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.in.ascii/v.in.ascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,8 +12,7 @@
and category values.</li>
</ul>
-<p>
-<em><a href="v.out.ascii.html">v.out.ascii</a></em> performs the
+<p><em><a href="v.out.ascii.html">v.out.ascii</a></em> performs the
function of <em>v.in.ascii</em> in reverse; i.e., it converts vector
maps in binary format to GRASS ASCII vector format. These two companion programs
are useful both for importing and exporting vector maps between GRASS
@@ -24,23 +23,19 @@
The input is read from the file specified by the <b>input</b> option or
from standard input.
-<p>
-The field separator may be a character, the word '<tt>tab</tt>'
+<p>The field separator may be a character, the word '<tt>tab</tt>'
(or '<tt>\t</tt>') for tab, '<tt>space</tt>' (or ' ') for a blank,
or '<tt>comma</tt>' (or ',') for a comma.
-<p>
-An attribute table is only created if it is needed, i.e. when at
+<p>An attribute table is only created if it is needed, i.e. when at
least one attribute column is present in the input file besides
geometry columns. The attribute column will be auto-scanned for type, but
may be explicitly declared along with the geometry columns using the
<b>columns</b> parameter.
-<p>
-Use the <b>-z</b> flag to convert ASCII data into a 3D vector map.
+<p>Use the <b>-z</b> flag to convert ASCII data into a 3D vector map.
-<p>
-In special cases of data import, such as the import of large LIDAR
+<p>In special cases of data import, such as the import of large LIDAR
datasets (millions of data points), it may be necessary to disable
topology support (vector level 1) due to memory constraints. This is
done with the <b>-b</b> flag. As only very few vector modules support
@@ -50,8 +45,7 @@
within a subregion (the <b>-r</b> flag) before resorting the to
disabling of topology.
-<p>
-If old version is requested, the <b>output</b> files
+<p>If old version is requested, the <b>output</b> files
from <em><a href="v.out.ascii.html">v.out.ascii</a></em> is placed in
the <tt>$LOCATION/$MAPSET/dig_ascii/</tt>
and <tt>$LOCATION/$MAPSET/dig_att</tt> directory.
@@ -75,8 +69,7 @@
be written to the map's history file for later reference (read with
<tt>v.info -h</tt>). The skip option only works in <b>points</b> mode.
-<p>
-Any line starting with the hash character ('<tt>#</tt>') will be treated as
+<p>Any line starting with the hash character ('<tt>#</tt>') will be treated as
a comment and skipped completely if located in the main data file. If located
in the header, as defined by the <b>skip</b> parameter, it will be treated as
a header line and written to the history file.
@@ -111,8 +104,7 @@
<h3>Example 1a) - standard format mode</h3>
Sample ASCII polygon vector map for 'standard' format mode.
The two areas will be assigned categories 20 and 21.
-<p>
-<div class="code"><pre>
+<p><div class="code"><pre>
echo "ORGANIZATION: GRASS Development Team
DIGIT DATE: 1/9/2005
DIGIT NAME: -
@@ -174,8 +166,7 @@
1663709|5102614
</pre></div>
-<p>
-Import into GRASS:
+<p>Import into GRASS:
v.in.ascii input=coords.txt output=mymap
</pre></div>
@@ -193,15 +184,13 @@
5|1663709|5102614|mineralni pramen
</pre></div>
-<p>
-Import into GRASS:
cat points.dat | v.in.ascii out=mypoints x=2 y=3 cat=1 \
columns='cat int, x double precision, y double precision, label varchar(20)'
</pre></div>
-<p>
-The module is reading from standard input, using the default '|' (pipe) delimiter.
+<p>The module is reading from standard input, using the default '|' (pipe) delimiter.
<h3>Example 4 - point format mode</h3>
@@ -226,8 +215,7 @@
593549.3|4925500.7|442.6|mineralni pramen|mineral spring
600375.7|4925235.6|342.2|kozi stezka|goat path
</pre></div>
-<p>
-Import into GRASS:
#As the 'cat' option is set to 0 by default, an extra column 'cat'
#containing the IDs will be auto-generated (no need to define that):
@@ -295,5 +283,4 @@
Research Laboratory<br>
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/vector/v.in.db/v.in.db.html
--- grass/trunk/vector/v.in.db/v.in.db.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.in.db/v.in.db.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,8 +11,7 @@
v.in.db driver=pg database="host=myserver.itc.it,dbname=mydb" \
table=pat_stazioni x=east y=north z=quota key=id output=pat_stazioni
</pre></div>
-<p>
-If an ID column is not not present in the PostgreSQL table,
+<p>If an ID column is not not present in the PostgreSQL table,
a new column should be added. See <a href="grass-pg.html">pg</a> driver
page for detail.
@@ -23,8 +22,7 @@
table=station x="x(geom)" y="y(geom)" z="z(geom)" key=id out=meteostations
</pre></div>
-<p>
page for detail.
@@ -40,8 +38,7 @@
v.info dtmpoints
v.info -c dtmpoints
</pre></div>
-<p>
-If an ID column is missing in the DBF file, it has to be added beforehand, e.g. with OpenOffice.
+<p>If an ID column is missing in the DBF file, it has to be added beforehand, e.g. with OpenOffice.
Alternatively, import the table with <em>db.in.ogr</em> into GRASS and then with <em>v.in.db</em>
from the imported table (<em>db.in.ogr</em> optionally adds an unique ID column).
@@ -57,16 +54,13 @@
v.info dtmpoints
v.info -c dtmpoints
</pre></div>
-<p>
-If an ID column is missing in the table, it has to be added beforehand with 'sqlite3' or
+<p>If an ID column is missing in the table, it has to be added beforehand with 'sqlite3' or
<em>db.execute</em>.
<h3>5) Import of a points table (x, y, z) from DBF file to vector points map for selected points only:</h3>
-<p>
-The user can import only selected vector points from a table using the <em>where</em> parameter
-(see above for general DBF handling):<p>
+<p>The user can import only selected vector points from a table using the <em>where</em> parameter
+(see above for general DBF handling):<p><div class="code"><pre>
v.in.db driver=dbf database=/home/user/tables/ table=pointsfile x=x y=y z=z \
key=idcol out=dtmpoints where="x NOT NULL and z > 100"
</pre></div>
Modified: grass/trunk/vector/v.in.dwg/v.in.dwg.html
--- grass/trunk/vector/v.in.dwg/v.in.dwg.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.in.dwg/v.in.dwg.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,8 +11,7 @@
v.in.dwg requires OpenDWG toolkit. To get this toolkit you must become at
least "Associate Member" of OpenDWG Alliance (http://www.opendesign.com/).
-<p>
-The toolkit, for example <tt>ad27linx.tar</tt>, unpack in a directory
+<p>The toolkit, for example <tt>ad27linx.tar</tt>, unpack in a directory
(e.g. /home/usr1/opendwg27) and use the related <tt>configure</tt> options
to tell GRASS about it:
@@ -25,8 +24,7 @@
</pre></div>
Then you can compile this module.
-<p>
-Not all entity types are supported (warning printed).
+<p>Not all entity types are supported (warning printed).
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.in.dxf/v.in.dxf.html
--- grass/trunk/vector/v.in.dxf/v.in.dxf.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.in.dxf/v.in.dxf.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -31,13 +31,11 @@
SQL usage (lowercase table/column names avoid the need to quote them
if the attribute table is stored in a SQL DBMS such as PostgreSQL).
-<p>
-The "layer" column will contain the name(s) of the DXF input
+<p>The "layer" column will contain the name(s) of the DXF input
layer(s). The DXF entity type string will be stored in the "entity"
column as uppercase.
-<p>
-The "handle" column can be used to store small bits of data associated
+<p>The "handle" column can be used to store small bits of data associated
with any entity in the DXF file (i.e., entity handle or unique object
identifiers in the layer). The entity handle is a "text string of up
to 16 hexadecimal digits", which is a 64-bit integer (currently not
@@ -58,8 +56,7 @@
</em>
-<p>
-<em>
+<p><em>
<a href="http://grass.osgeo.org/wiki/Import_DXF">How-to import DXF files in wxGUI</a> (from GRASS User Wiki)
</em>
@@ -69,9 +66,7 @@
Revised by Dave Gerdes, 12/1989<br>
US Army Construction Engineering Research Lab
-<p>
-Updated for GRASS 6 and 3D support. Huidae Cho, 3/2006<br>
+<p>Updated for GRASS 6 and 3D support. Huidae Cho, 3/2006<br>
With minor additions by Benjamin Ducke (Oxford Archaeology), 4/2009
-<p>
Modified: grass/trunk/vector/v.in.lidar/v.in.lidar.html
--- grass/trunk/vector/v.in.lidar/v.in.lidar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.in.lidar/v.in.lidar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,17 +3,14 @@
<em>v.in.lidar</em> converts LiDAR point clouds in LAS format to a GRASS
vector, using the <a href="http://www.liblas.org">libLAS</a> library.
The created vector is true 3D with x, y, z coordinates.
-<p>
-The typical file extensions for the LAS format are .las and .laz (compressed).
+<p>The typical file extensions for the LAS format are .las and .laz (compressed).
The compressed LAS format can be imported only if libLAS has been compiled
with laszip support. It is also recommended to compile libLAS with GDAL,
needed to text for matching projections.
-<P>
-For larger datasets, it is recommended to not build topology (-b flag).
+<p>For larger datasets, it is recommended to not build topology (-b flag).
Also, creating a table with attributes can take some time for larger datasets.
-<p>
-The optional <b>spatial</b> parameter defines spatial query extents.
+<p>The optional <b>spatial</b> parameter defines spatial query extents.
This parameter allows the user to restrict the region to a spatial subset
while importing the data. All LiDAR points falling into this rectangle
subregion are imported. The <b>-r</b> current region flag is identical,
@@ -30,13 +27,11 @@
match current location</tt>") and then report the PROJ_INFO parameters of
the source dataset.
-<p>
-If the user wishes to ignore the difference between the apparent coordinate
+<p>If the user wishes to ignore the difference between the apparent coordinate
system of the source data and the current location, they may pass the
<b>-o</b> flag to override the projection check.
-<p>
-If the user wishes to import the data with the full projection definition,
+<p>If the user wishes to import the data with the full projection definition,
it is possible to have <em>v.in.lidar</em> automatically create a new location based
on the projection and extents of the file being read. This is accomplished
by passing the name to be used for the new location via the <b>location</b>
@@ -48,8 +43,7 @@
This example is analogous to the example used in the GRASS wiki page for
<a href="http://grass.osgeo.org/wiki/LIDAR#Import_LAS_as_vector_points">importing LAS as vector points</a>.
-<p>
-The sample LAS data are in the file "Serpent Mound Model LAS Data.las",
+<p>The sample LAS data are in the file "Serpent Mound Model LAS Data.las",
available at
<a href="http://www.appliedimagery.com/downloads/sampledata/Serpent%20Mound%20Model%20LAS%20Data.las">appliedimagery.com</a>
@@ -80,5 +74,4 @@
<br>
based on v.in.ogr
-<p>
Modified: grass/trunk/vector/v.in.ogr/v.in.ogr.html
--- grass/trunk/vector/v.in.ogr/v.in.ogr.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.in.ogr/v.in.ogr.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,23 +5,19 @@
OGR (Simple Features Library) is part of the
<a href="http://www.gdal.org">GDAL</a> library, so you need to
install GDAL to use <em>v.in.ogr</em>.
-<p>
-If the <b>layer</b> parameter is not given, all available layers
+<p>If the <b>layer</b> parameter is not given, all available layers
are imported as separate GRASS layers into one GRASS vector map. If
several OGR layer names are given, all these layers are imported as
-<p>
while importing the data. All vector features completely or partially
falling into this rectangle subregion are imported.
The <b>-r</b> current region flag is identical, but uses the current region
settings as the spatial bounds (see <em><a href="g.region.html">g.region</a></em>).
-<p>
-Topology cleaning on areas is automatically performed, but may fail in
+<p>Topology cleaning on areas is automatically performed, but may fail in
special cases (then use <a href="v.clean.html">v.clean</a>).
-<p>
-The <b>min_area</b> threshold value is being specified as area size
+<p>The <b>min_area</b> threshold value is being specified as area size
in map units with the exception of latitude-longitude locations in which
it is being specified solely in square meters.
@@ -31,8 +27,7 @@
Shapefile</a><br>
<a href="http://www.gdal.org/ogr/drv_mitab.html">Mapinfo File</a>
-<p>
-Further available drivers such as UK .NTF, SDTS, TIGER, IHO S-57 (ENC),
+<p>Further available drivers such as UK .NTF, SDTS, TIGER, IHO S-57 (ENC),
DGN, GML, AVCBin, REC, Memory, OGDI, and PostgreSQL depend on the local
installation (OGR library), for details see
<a href="http://www.gdal.org/ogr/ogr_formats.html">OGR web site</a>.
@@ -48,13 +43,11 @@
the source dataset.
-<p>
-<p>
it is possible to have <em>v.in.ogr</em> automatically create a new location based
@@ -133,12 +126,10 @@
<h3>Support of database schema:</h3>
-<p>
-For schema support, first set a default schema with
+<p>For schema support, first set a default schema with
<em><a href="db.connect.html">db.connect</a></em>. If schema support is
used the schema name must be specified whenever a db.* module is called.
-<p>
-Example:
+<p>Example:
db.connect driver=pg database=test schema=user1 group=group1
db.login driver=pg database=test user=user1 password=pwd1
@@ -171,8 +162,7 @@
The <b>cnames</b> parameter is used to define new column names during import.
-<p>
-The DBF database specification limits column names to 10 characters.
+<p>The DBF database specification limits column names to 10 characters.
If the default DB is set to DBF and the input data contains longer
column/field names, they will be truncated. If this results in multiple
columns with the same name then <em>v.in.ogr</em> will produce an error.
@@ -199,8 +189,7 @@
A different column name should be used. The <em>cnames</em> parameter can be used
to assign different column names on the fly.
-<p>
-<i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
+<p><i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
You need to create a location whose projection matches the data you
wish to import. Try using <em>location</em> parameter to create a new location based
@@ -234,5 +223,4 @@
<br>
Location and spatial extent support by Markus Neteler and Paul Kelly
-<p>
Modified: grass/trunk/vector/v.info/v.info.html
--- grass/trunk/vector/v.info/v.info.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.info/v.info.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>v.info</em> reports some basic information (metadata) about a
user-specified vector map and its topology status.
-<p>
-If topology info is not available (i.e., vector map cannot be open on
+<p>If topology info is not available (i.e., vector map cannot be open on
level 2), vector map extends and number of features need to be counted
on the fly which may take some time.
@@ -153,5 +152,4 @@
Level 1 support by Markus Metz<br>
Updated to GRASS 7 by Martin Landa, CTU in Prague, Czech Republic
-<p>
Modified: grass/trunk/vector/v.kcv/v.kcv.html
--- grass/trunk/vector/v.kcv/v.kcv.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.kcv/v.kcv.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -22,10 +22,8 @@
<!-- BUG: missing text -->
only be as random as the original points. This program
simply divides points up in a random manner.<p>
Be warned that random number generation occurs over the
intervals defined by the region of the map.<p>
This program may not work properly with Lat-long data.
<h2>SEE ALSO</h2>
@@ -35,14 +33,13 @@
<h2>AUTHOR</h2>
-<a href="http://mccauley-usa.com/">James Darrell McCauley</A>
-<a href="mailto:darrell at mccauley-usa.com"><darrell at mccauley-usa.com></A>,
+<a href="http://mccauley-usa.com/">James Darrell McCauley</a>
+<a href="mailto:darrell at mccauley-usa.com"><darrell at mccauley-usa.com></a>,
<br>when he was at:
<a href="http://ABE.www.ecn.purdue.edu/ABE/">Agricultural
-Engineering</A>
-<a href="http://www.purdue.edu/">Purdue University</A>
+Engineering</a>
+<a href="http://www.purdue.edu/">Purdue University</a>
-<p>
-Update to 5.7 Radim Blazek 10 / 2004
+<p>Update to 5.7 Radim Blazek 10 / 2004
Modified: grass/trunk/vector/v.kernel/v.kernel.html
--- grass/trunk/vector/v.kernel/v.kernel.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.kernel/v.kernel.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -4,8 +4,7 @@
a moving kernel. Available <a href="http://en.wikipedia.org/wiki/Kernel_(statistics)#Kernel_functions_in_common_use">kernel density functions</a> are <em>uniform,
triangular, epanechnikov, quartic, triweight, gaussian, cosine</em>,
default is <em>gaussian</em>.
-<p>
-The module can also generate a vector density map on a vector network.
+<p>The module can also generate a vector density map on a vector network.
Conventional kernel functions produce biased estimates by overestimating
the densities around network nodes, whereas the equal split method of
Okabe et al. (2009) produces unbiased density estimates. The equal split
@@ -17,8 +16,7 @@
The <em>mult</em> option is needed to overcome the limitation that
the resulting density in case of a vector map output is stored as category
(Integer). The density result stored as category may be multiplied by this number.
-<p>
-With the <em>-o</em> flag (experimental) the command tries to calculate an
+<p>With the <em>-o</em> flag (experimental) the command tries to calculate an
optimal standard deviation. The value of <em>stddeviation</em> is taken
as maximum value. Standard deviation is calculated using ALL points,
not just those in the current region.
@@ -29,7 +27,7 @@
(yet) any attribute values.
<h2>SEE ALSO</h2>
-<a href="v.surf.rst.html">v.surf.rst</A>
+<a href="v.surf.rst.html">v.surf.rst</a>
<h2>REFERENCES</h2>
Okabe, A., Satoh, T., Sugihara, K. (2009). <i>A kernel density estimation
Modified: grass/trunk/vector/v.label/v.label.html
--- grass/trunk/vector/v.label/v.label.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.label/v.label.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,7 +12,6 @@
otherwise the <em>space</em> option should be set roughly the same
as the <em>size</em> option.
<p>
<br>
A description of the labels file follows.<p>
The file is located in <tt>$MAPSET/paint/labels/</tt>.
@@ -20,8 +19,7 @@
<br>
<h4>Caution: The following information may be incomplete, out of date,
and wrong!</h4>
-<p>
-The label information that must be provided in the <em>labels</em> file is:
+<p>The label information that must be provided in the <em>labels</em> file is:
<dl>
<dt><b>TEXT</b>:
@@ -78,22 +76,18 @@
<dt><b>FONT</b>:
<dd>This specifies the font to use.
-<p>
-The following fonts are available for use with
+<p>The following fonts are available for use with
<a href="d.labels.html"><i>d.labels</i></a>:
<p><pre>
cyrilc gothgbt gothgrt gothitt greekc greekcs greekp greeks
italicc italiccs italict romanc romancs romand romans romant
scriptc scripts
</pre>
-<p>
-Alternatively the path to a FreeType (.ttf) font may be given.
+<p>Alternatively the path to a FreeType (.ttf) font may be given.
(for <em>d.labels</em> only)
-<p>
-The word <em>standard</em> can be used to specify the default font
+<p>The word <em>standard</em> can be used to specify the default font
(which is <em>romans</em>).
-<p>
-Note <a href="ps.map.html"><em>ps.map</em></a> can override this setting
+<p>Note <a href="ps.map.html"><em>ps.map</em></a> can override this setting
to use other fonts. Its default font is Helvetica.
@@ -106,37 +100,37 @@
Alternatively <em>fontsize</em> can set the font size in normal font points.
-<dt><A NAME="textcolor"><b>TEXT COLOR</b></A>:
+<dt><A NAME="textcolor"><b>TEXT COLOR</b></a>:
<dd>This selects the text color. If unspecified, the
label's text is drawn in <em>black</em>, by default. The
text color can be specified in one of several ways:
-<OL>
-<LI>By color name:
+<ol>
+<li>By color name:
<br>
<tt>aqua black blue brown cyan gray green grey indigo
magenta orange purple red violet white yellow</tt>
-<LI>As red, green, blue component values. (0-255)<br>
+<li>As red, green, blue component values. (0-255)<br>
for example: <tt>128:100:200</tt>
<!-- eh?
-<LI>As red, green, blue percentages.
+<li>As red, green, blue percentages.
for example: .5 .4 .7
<br>
(This form is not supported by
-<em><a href="d.labels.html">d.labels</A></em>.)
+<em><a href="d.labels.html">d.labels</a></em>.)
-<LI>By printer color number to get the exact printer color.
+<li>By printer color number to get the exact printer color.
<br>
-<LI>Specify "<tt>none</tt>" to suppress the lettering.
-</OL>
+<li>Specify "<tt>none</tt>" to suppress the lettering.
+</ol>
<dt><b>WIDTH</b>:
@@ -153,7 +147,7 @@
("<tt>none</tt>") is used by default, if unspecified by the
user. To specify use of no highlight color, specify
"<tt>none</tt>".
-(See <a href="#textcolor">TEXT COLOR</A>
+(See <a href="#textcolor">TEXT COLOR</a>
above for a list of permissible color names.)
@@ -170,7 +164,7 @@
<dd>Text may be boxed in a solid color by specifying a background color.
Specify "<tt>none</tt>" for no background. The default background color
setting, if unspecified by the user, is <em>white</em>.
@@ -179,7 +173,7 @@
<dd>Select a color for the border around the background.
Specify "<tt>none</tt>" to suppress the border.
The default border color used, if unspecified, is <em>black</em>.
@@ -221,8 +215,8 @@
<h2>SEE ALSO</h2>
<em>
-<a href="d.labels.html">d.labels</A><br>
-<a href="ps.map.html">ps.map</A>
+<a href="d.labels.html">d.labels</a><br>
+<a href="ps.map.html">ps.map</a>
</em>
<br>
@@ -233,5 +227,4 @@
Radim Blazek (GRASS 6 port)<br>
Hamish Bowman (enhancements)<br>
-<p>
Modified: grass/trunk/vector/v.label.sa/v.label.sa.html
--- grass/trunk/vector/v.label.sa/v.label.sa.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.label.sa/v.label.sa.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,14 +3,13 @@
<em>v.label.sa</em> makes a label-file from a GRASS vector map
with labels created from attributes in the attached table. The labels are
placed in as optimal place as possible. The label file has the same syntax
-as the one created by <a href="v.label.html">v.label</A>
+as the one created by <a href="v.label.html">v.label</a>
<h2>EXAMPLE</h2>
North Carolina example:
-<p>
# get font names:
d.font -L
@@ -26,8 +25,7 @@
d.labels roads_labels
</pre></div>
-<p>
-<center>
+<p><center>
<img src="v_label_sa.jpg" alt="Road labeling with v.label.sa"><br>
<i>Road labeling with v.label.sa (Raleigh, North Carolina, USA, area)</i>
</center>
@@ -40,10 +38,10 @@
<h2>SEE ALSO</h2>
<em>
-<a href="v.labels.html">d.label</A><br>
-<a href="http://en.wikipedia.org/wiki/Simulated_Annealing">Wikipedia article on simulated annealing</A>
+<a href="v.labels.html">d.label</a><br>
+<a href="http://en.wikipedia.org/wiki/Simulated_Annealing">Wikipedia article on simulated annealing</a>
</em><br>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.lidar.edgedetection/v.lidar.edgedetection.html
--- grass/trunk/vector/v.lidar.edgedetection/v.lidar.edgedetection.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.lidar.edgedetection/v.lidar.edgedetection.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -117,5 +117,4 @@
report by Sithole, G. and Vosselman, G., 2003.
<br>
-<p>
Modified: grass/trunk/vector/v.lrs/lrs.html
--- grass/trunk/vector/v.lrs/lrs.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.lrs/lrs.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -22,7 +22,6 @@
composed from more features in the input map. Events can be either
points or lines (segments).
<p>
LRS is created from input lines and points in vector map.
Points - MP (mileposts) must have attached attributes specifying
line and distance.
@@ -30,8 +29,7 @@
are specified by MP+offset.
Typically, MP is in kilometers and offset in meters.
-<p>
-The implementation of LRS in GRASS has some particularities.
+<p>The implementation of LRS in GRASS has some particularities.
<h3>Double referenced system</h3>
This feature gives a possibility to continue to use most of
@@ -94,20 +92,17 @@
</pre></div>
Because each MP can keep 2 values (start, end) it is called 'double' referenced LRS.
-<p>
-To avoid potential confusion, MP values are limited to integers only.
+<p>To avoid potential confusion, MP values are limited to integers only.
It would be ambiguous to have for example segments 3.500 - 3.500+200
and 3.600 - 3.600+200. The position 3+650 would fall into 2 segments,
correct would be 3.600+50.
That means, that MP must be the beginning of antonomous segment
and all parts which becomes longer then before must be referenced
from the last not changed MP.
-<p>
-The MP <em>start_mp</em> and <em>end_mp</em> columns must be decimal, but
+<p>The MP <em>start_mp</em> and <em>end_mp</em> columns must be decimal, but
<em>v.lrs.create</em> takes only the decimal part, and adds its value to
offset and prints a warning.
-<p>
-It is highly recommended to work with polylines instead of segmented vector
+<p>It is highly recommended to work with polylines instead of segmented vector
lines. The command <em>v.build.polylines</em> creates this map structure.
<h3>LRS table structure</h3>
@@ -151,8 +146,7 @@
In this case, the module gives error because the position
results in 2 points.
-<p>
-It can be also intended, for example a part of the road is shared
+<p>It can be also intended, for example a part of the road is shared
with another one, but MP are used only for one:
+ road1/km15 + road1/km22
@@ -181,8 +175,7 @@
<em>R. Blazek, 2004, <a href="http://gisws.media.osaka-cu.ac.jp/grass04/viewpaper.php?id=50">Introducing the Linear Reference System in GRASS</a>, Bangkok, GRASS User Conf. Proc.</em><br>
<em>R. Blazek, 2005, <a href="http://www.j-geoinfo.net/Content/fulmar05/IJG_095-100.pdf">Introducing the Linear Reference System in GRASS</a>, International Journal of Geoinformatics, Vol. 1(3), pp. 95-100</em><br>
-<p>
-<em><a href="v.build.polylines.html">v.build.polylines</a></em>,
+<p><em><a href="v.build.polylines.html">v.build.polylines</a></em>,
<em><a href="v.lrs.create.html">v.lrs.create</a></em>,
<em><a href="v.lrs.segment.html">v.lrs.segment</a></em>,
<em><a href="v.lrs.where.html">v.lrs.where</a></em>,
Modified: grass/trunk/vector/v.mkgrid/v.mkgrid.html
--- grass/trunk/vector/v.mkgrid/v.mkgrid.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.mkgrid/v.mkgrid.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,8 +8,7 @@
Grid points created with the <b>-p</b> flag will be placed at the
<i>center</i> of each grid cell, not at the grid line nodes.
-<p>
-This is NOT to be used to generate a vector map of USGS quadrangles,
+<p>This is NOT to be used to generate a vector map of USGS quadrangles,
because USGS quads are not exact rectangles.
@@ -21,8 +20,7 @@
</pre></div>
<br>
-<p>
-Make a 10x12 lat/lon grid, cells 2 arc-min a side, with lower left corner
+<p>Make a 10x12 lat/lon grid, cells 2 arc-min a side, with lower left corner
at 167deg 52min east, 47deg 6min south. For use with e.g. QGIS you can then
pull this grid into a projected location with <em>v.proj</em> before
exporting as a Shapefile with <em>v.out.ogr</em> (within GRASS you could
@@ -34,8 +32,8 @@
<h2>SEE ALSO</h2>
-<a href="v.patch.html">v.patch</A>,
-<a href="d.grid.html">d.grid</A>
+<a href="v.patch.html">v.patch</a>,
+<a href="d.grid.html">d.grid</a>
<h2>AUTHOR</h2>
@@ -43,8 +41,6 @@
Michael Higgins,
U.S.Army Construction Engineering
Research Laboratory
-<p>
-Update for new vectors Radim Blazek 10/2004
+<p>Update for new vectors Radim Blazek 10/2004
-<p>
Modified: grass/trunk/vector/v.neighbors/v.neighbors.html
--- grass/trunk/vector/v.neighbors/v.neighbors.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.neighbors/v.neighbors.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,7 +6,7 @@
<h2>SEE ALSO</h2>
-<a href="r.neighbors.html">r.neighbors</A>
+<a href="r.neighbors.html">r.neighbors</a>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.net/v.net.html
--- grass/trunk/vector/v.net/v.net.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net/v.net.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
nodes to the network within a given distance threshold.
It can also report the current network graph status.
-<p>
-In terms of network analysis, a network consists of nodes connected by
+<p>In terms of network analysis, a network consists of nodes connected by
arcs. In a vector map prepared for network analysis, nodes are represented
by the grass-internal geometry type <em>node</em> and arcs by the geometry
type <em>line</em>. If a <em>line</em> consists of several vertices and
@@ -15,8 +14,7 @@
nodes for e.g. a least costly path search or subnetwork allocation are
represented by the geometry type point.
-<p>
-In general, network analysis will find the least costly (shortest or
+<p>In general, network analysis will find the least costly (shortest or
fastest) path from point A to point B by follwing the existing lines.
This implies that these points must lie at the start or end point of a
line with is part of the network. If no line is starting or ending at a
@@ -36,8 +34,7 @@
<a href="http://www.grassbook.org/data_menu3rd.php">NC dataset</a> based examples.
-<p>
-Create nodes globally for all line ends and intersections:
+<p>Create nodes globally for all line ends and intersections:
v.net input=streams output=streams_node operation=nodes
@@ -81,5 +78,4 @@
Martin Landa, FBK-irst (formerly ITC-irst), Trento, Italy and CTU in
Prague, Czech Republic (operation 'connect' and 'arcs')
-<p>
Modified: grass/trunk/vector/v.net.alloc/v.net.alloc.html
--- grass/trunk/vector/v.net.alloc/v.net.alloc.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.alloc/v.net.alloc.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>v.net.alloc</em> allocates subnets for nearest centers (direction from
center). center nodes must be opened (costs >= 0). Costs of center nodes are
used in the calculation.
-<p>
-Costs may be either line lengths, or attributes saved in a database
+<p>Costs may be either line lengths, or attributes saved in a database
table. These attribute values are taken as costs of whole segments, not
as costs to traverse a length unit (e.g. meter) of the segment.
For example, if the speed limit is 100 km / h, the cost to traverse a
@@ -13,32 +12,25 @@
Supported are cost assignments for both arcs and nodes,
and also different costs for both directions of a vector line.
For areas, costs will be calculated along boundary lines.
-<p>
-The input vector needs to be prepared with <em>v.net operation=connect</em>
+<p>The input vector needs to be prepared with <em>v.net operation=connect</em>
in order to connect points representing center nodes to the network.
<h2>NOTES</h2>
Nodes and arcs can be closed using cost = -1.
-<p>
-Center nodes can also be assigned to vector nodes using
+<p>Center nodes can also be assigned to vector nodes using
<em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector digitizer</a></em>.
<h2>EXAMPLES</h2>
-<p>
-1. Subnetwork allocation using distance:
-<p>
-<img src="v_net_alloc.png" alt="v.net.alloc example using distance" border="1">
+<p>1. Subnetwork allocation using distance:
+<p><img src="v_net_alloc.png" alt="v.net.alloc example using distance" border="1">
<br>
-<p>
-2. Subnetwork allocation using traveling time:
-<p>
-<img src="v_net_alloc_time.png" alt="v.net.alloc example using time" border="1">
+<p>2. Subnetwork allocation using traveling time:
+<p><img src="v_net_alloc_time.png" alt="v.net.alloc example using time" border="1">
<br>
-<p>
-Example 1: <em>Calculating subnets for 3 center nodes using distances</em>
+<p>Example 1: <em>Calculating subnets for 3 center nodes using distances</em>
# Spearfish
@@ -76,8 +68,7 @@
d.vect myroads_net col=red icon=basic/triangle fcol=green size=12 layer=2
</pre></div>
-<p>
-Example 2: <em>Calculating subnets for 3 center nodes using traveling time</em><br>
+<p>Example 2: <em>Calculating subnets for 3 center nodes using traveling time</em><br>
# Spearfish
Modified: grass/trunk/vector/v.net.allpairs/v.net.allpairs.html
--- grass/trunk/vector/v.net.allpairs/v.net.allpairs.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.allpairs/v.net.allpairs.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -32,7 +32,6 @@
</pre></div>
<p>
<h2>SEE ALSO</h2>
<em>
@@ -46,5 +45,4 @@
Daniel Bundala, Google Summer of Code 2009, Student<br>
Wolf Bergenheim, Mentor
-<p>
Modified: grass/trunk/vector/v.net.bridge/v.net.bridge.html
--- grass/trunk/vector/v.net.bridge/v.net.bridge.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.bridge/v.net.bridge.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -27,7 +27,6 @@
</pre></div>
<p>
</pre></div>
@@ -43,5 +42,4 @@
-<p>
Modified: grass/trunk/vector/v.net.centrality/v.net.centrality.html
--- grass/trunk/vector/v.net.centrality/v.net.centrality.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.centrality/v.net.centrality.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -30,7 +30,6 @@
v.net.centrality input=roads output=roads_cent closeness=close betweenness=betw -a
</pre></div>
<p>
</pre></div>
@@ -46,5 +45,4 @@
-<p>
Modified: grass/trunk/vector/v.net.components/v.net.components.html
--- grass/trunk/vector/v.net.components/v.net.components.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.components/v.net.components.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -27,7 +27,6 @@
v.net.components input=roads output=roads_components method=strong
</pre></div>
<p>
</pre></div>
@@ -43,5 +42,4 @@
-<p>
Modified: grass/trunk/vector/v.net.connectivity/v.net.connectivity.html
--- grass/trunk/vector/v.net.connectivity/v.net.connectivity.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.connectivity/v.net.connectivity.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,7 +20,6 @@
v.net.connectivity input=roads output=roads_conn set1_where="bank=left" set2_where="bank=right"
</pre></div>
<p>
v.net.connectivity input=airtraffic output=connectivity set1_where="name=JFK" set2_where="name=Heathrow" ncolumn=capacity
</pre></div>
@@ -38,5 +37,4 @@
-<p>
Modified: grass/trunk/vector/v.net.distance/v.net.distance.html
--- grass/trunk/vector/v.net.distance/v.net.distance.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.distance/v.net.distance.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -32,7 +32,6 @@
d.vect nearest cats=1
</pre></div>
<p>
<h2>SEE ALSO</h2>
<em>
@@ -47,5 +46,4 @@
-<p>
Modified: grass/trunk/vector/v.net.flow/v.net.flow.html
--- grass/trunk/vector/v.net.flow/v.net.flow.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.flow/v.net.flow.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -31,7 +31,6 @@
v.net.flow input=roads output=roads_flow cut=roads_cut afcolumn=SPEED source_where="type=factory" sink_where="type=store"
</pre></div>
<p>
If all the capacties are one then the minimum cut corresponds to the
minimum number of edges separating sources from sinks.
@@ -51,5 +50,4 @@
-<p>
Modified: grass/trunk/vector/v.net.iso/v.net.iso.html
--- grass/trunk/vector/v.net.iso/v.net.iso.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.iso/v.net.iso.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>v.net.iso</em> splits a network into bands between cost isolines
(distance from center). Center nodes must be opened (costs >= 0). The
costs of center nodes are used in the calculation.
-<p>
@@ -13,15 +12,13 @@
-<p>
<h2>NOTES</h2>
-<p>
-Nodes must be on the isolines.
+<p>Nodes must be on the isolines.
<h2>EXAMPLES</h2>
@@ -29,18 +26,13 @@
The map must contain at least one center (point) on the vector network
which can be patched into with <a href="v.net.html">v.net</a>.
-<p>
-Isonetwork using distance:
-<p>
-<img src="vnetiso.png" alt="v.net.iso example with distance" border="1">
+<p>Isonetwork using distance:
+<p><img src="vnetiso.png" alt="v.net.iso example with distance" border="1">
-<p>
-Isonetwork using time:
-<p>
-<img src="vnetisotime.png" alt="v.net.iso example with traveling time" border="1">
+<p>Isonetwork using time:
+<p><img src="vnetisotime.png" alt="v.net.iso example with traveling time" border="1">
-<p>
-<h4>Subdivision of a network using distance:</h4>
+<p><h4>Subdivision of a network using distance:</h4>
# Spearfish
Modified: grass/trunk/vector/v.net.path/v.net.path.html
--- grass/trunk/vector/v.net.path/v.net.path.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.path/v.net.path.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>v.net.path</em> determines least costly, e.g. shortest or fastest
path(s) on a vector network.
-<p>
@@ -13,17 +12,13 @@
-<p>
-<p>
-Nodes and arcs can be closed using cost = -1.
-<p>
-Least cost paths are written to the output vector map with an
+<p>Nodes and arcs can be closed using cost = -1.
+<p>Least cost paths are written to the output vector map with an
attached attribute table.
-<p>
-Nodes can be piped into the program from file or from stdin. The
+<p>Nodes can be piped into the program from file or from stdin. The
syntax is as follows:
id start_point_category end_point_category
@@ -35,15 +30,12 @@
id start_point_x start_point_y end_point_x end_point_y
</pre></div>
-<p>
-Points specified by category must be exactly on network nodes, and the
+<p>Points specified by category must be exactly on network nodes, and the
input vector map needs to be prepared with <em>v.net operation=connect</em>.
-<p>
-When specifying coordinates, the next network node to a given coordinate
+<p>When specifying coordinates, the next network node to a given coordinate
pair is used.
-<p>
-The attribute table will contain the following attributes:
+<p>The attribute table will contain the following attributes:
<ul>
<li>cat - path unique category assigned by module</li>
@@ -63,12 +55,10 @@
<h2>NOTES</h2>
-<p>
-If the cost columns 'afcol', 'abcol' and 'ncol' are not
+<p>If the cost columns 'afcol', 'abcol' and 'ncol' are not
specified, the length of network segments is measured and
zero costs are assumed for nodes.
-<p>
-When using attributes, the length of segments is not used. To get
+<p>When using attributes, the length of segments is not used. To get
accurate results, the line length must be taken into account when
assigning costs as attributes. For example, to get the <b>fastest path</b>,
the columns 'max_speed' and 'length' are required. The correct fastest
@@ -80,11 +70,9 @@
Shortest (red) and fastest (blue) path between two digitized nodes (Spearfish):
-<p>
-<img src="vnetpath.png" alt="v.net.path example" border="1">
+<p><img src="vnetpath.png" alt="v.net.path example" border="1">
-<p>
# Spearfish
echo "1|601955.1|4916944.9|start
Modified: grass/trunk/vector/v.net.salesman/v.net.salesman.html
--- grass/trunk/vector/v.net.salesman/v.net.salesman.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.salesman/v.net.salesman.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>v.net.salesman</em> calculates the optimal route to visit nodes on a
vector network.
-<p>
@@ -13,12 +12,10 @@
Supported are cost assignments for arcs,
-<p>
-<p>
<h2>NOTES</h2>
@@ -28,18 +25,13 @@
Traveling salesman for 6 digitized nodes (Spearfish):
-<p>
-Shortest path, along unimproved roads:
-<p>
-<img src="vnetsalesman.png" alt="v.net.salesman example using distance" border="1">
+<p>Shortest path, along unimproved roads:
+<p><img src="vnetsalesman.png" alt="v.net.salesman example using distance" border="1">
-<p>
-Fastest path, along highways:
-<p>
-<img src="vnetsalesmantime.png" alt="v.net.salesman example using time" border="1">
+<p>Fastest path, along highways:
+<p><img src="vnetsalesmantime.png" alt="v.net.salesman example using time" border="1">
-<p>
-Searching for the shortest path using distance and the fastest path using
+<p>Searching for the shortest path using distance and the fastest path using
traveling time according to the speed limits of different road types:
Modified: grass/trunk/vector/v.net.spanningtree/v.net.spanningtree.html
--- grass/trunk/vector/v.net.spanningtree/v.net.spanningtree.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.spanningtree/v.net.spanningtree.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,7 +20,6 @@
v.net.spanningtree input=projected_pipelines output=spanningtree accol=cost
</pre></div>
<p>
<h2>SEE ALSO</h2>
<em>
@@ -32,5 +31,4 @@
-<p>
Modified: grass/trunk/vector/v.net.steiner/v.net.steiner.html
--- grass/trunk/vector/v.net.steiner/v.net.steiner.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.steiner/v.net.steiner.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,15 +3,13 @@
<em>v.net.steiner</em> calculates the optimal connection of nodes on a
vector network.
-<p>
-A Steiner tree is used to calculate the minimum-cost vector network
+<p>A Steiner tree is used to calculate the minimum-cost vector network
connecting some number of end nodes in a network framework.
For example it could be used to find the path following a road system
which will minimize the amount of fibre optic cable needed to connect
a series of satellite offices.
-<p>
@@ -20,23 +18,18 @@
Supported are cost assignments for both arcs and nodes.
-<p>
-Points representing nodes must be exactly on network nodes, and the
+<p>Points representing nodes must be exactly on network nodes, and the
<h2>EXAMPLE</h2>
Steiner tree for 6 digitized nodes (Spearfish):
-<p>
-<p>
-<img src="vnetsteiner.png" alt="v.net.steiner example using distance" border="1">
+<p><img src="vnetsteiner.png" alt="v.net.steiner example using distance" border="1">
-<p>
-<p>
-<img src="vnetsteinertime.png" alt="v.net.steiner example using time" border="1">
+<p><img src="vnetsteinertime.png" alt="v.net.steiner example using time" border="1">
Modified: grass/trunk/vector/v.net.timetable/v.net.timetable.html
--- grass/trunk/vector/v.net.timetable/v.net.timetable.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.timetable/v.net.timetable.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -141,5 +141,4 @@
-<p>
Modified: grass/trunk/vector/v.net.visibility/v.net.visibility.html
--- grass/trunk/vector/v.net.visibility/v.net.visibility.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.net.visibility/v.net.visibility.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,8 +15,7 @@
<b>IMPORTANT : the algorithm doesn't work well with intersecting lines
(that includes overlapping)</b>
-<p>
-If you compute a shortest path after computing the visibility graph you
+<p>If you compute a shortest path after computing the visibility graph you
will notice that this path might go through a vertix of a line. If this
is not wanted you might to run the map through <em>v.buffer</em> first
whith a small value. Example:
@@ -25,8 +24,7 @@
v.buffer input=map output=bufferedmap buffer=1 type=point,line,area,boundary
</pre></div>
-<p>
-The first argument is the input map. It supports lines, boudaries (so areas)
+<p>The first argument is the input map. It supports lines, boudaries (so areas)
and points. For the algorithm to work lines and boundaries must not be
intersecting (that includes overlapping).
The result map containing the visibility graph is given in the output map.
Modified: grass/trunk/vector/v.normal/v.normal.html
--- grass/trunk/vector/v.normal/v.normal.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.normal/v.normal.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,24 +8,24 @@
below. The tests that are performed are specified by
giving an index, ranges of indices, or multiple thereof.
-<OL>
-<LI> Sample skewness and kurtosis
-<LI> Geary's a-statistic and an approximate normal transformation
-<LI> Extreme normal deviates
-<LI> D'Agostino's D-statistic
-<LI> Modified Kuiper V-statistic
-<LI> Modified Watson U^2-statistic
-<LI> Durbin's Exact Test (modified Kolmogorov)
-<LI> Modified Anderson-Darling statistic
-<LI> Modified Cramer-Von Mises W^2-statistic
-<LI> Kolmogorov-Smirnov D-statistic (modified for normality testing)
-<LI> Chi-Square test statistic (equal probability classes) and
+<ol>
+<li> Sample skewness and kurtosis
+<li> Geary's a-statistic and an approximate normal transformation
+<li> Extreme normal deviates
+<li> D'Agostino's D-statistic
+<li> Modified Kuiper V-statistic
+<li> Modified Watson U^2-statistic
+<li> Durbin's Exact Test (modified Kolmogorov)
+<li> Modified Anderson-Darling statistic
+<li> Modified Cramer-Von Mises W^2-statistic
+<li> Kolmogorov-Smirnov D-statistic (modified for normality testing)
+<li> Chi-Square test statistic (equal probability classes) and
the number of degrees of freedom
-<LI> Shapiro-Wilk W Test
-<LI> Weisberg-Binghams W'' (similar to Shapiro-Francia's W')
-<LI> Royston's extension of W for large samples
-<LI> Kotz Separate-Families Test for Lognormality vs. Normality
-</OL>
+<li> Shapiro-Wilk W Test
+<li> Weisberg-Binghams W'' (similar to Shapiro-Francia's W')
+<li> Royston's extension of W for large samples
+<li> Kotz Separate-Families Test for Lognormality vs. Normality
+</ol>
<h2>EXAMPLE</h2>
@@ -47,14 +47,14 @@
<h2>SEE ALSO</h2>
-<a href="v.univar.html">v.univar</A>
+<a href="v.univar.html">v.univar</a>
<h2>AUTHOR</h2>
<br>when he was at:
-Engineering</A>
+Engineering</a>
Modified: grass/trunk/vector/v.out.ascii/v.out.ascii.html
--- grass/trunk/vector/v.out.ascii/v.out.ascii.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.out.ascii/v.out.ascii.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
flag <b>-o</b> <em>v.out.ascii</em> output will be in old (version 4)
ASCII format.
-<p>
-If the <b>output</b> parameter is not given then the coordinates of any
+<p>If the <b>output</b> parameter is not given then the coordinates of any
<em>point</em> data within the vector map is sent to stdout.
<h2>NOTES</h2>
@@ -18,24 +17,20 @@
maps between GRASS and other software, and for transferring data
between machines.
-<p>
-If old version is requested, the <b>output</b> files from <em>v.out.ascii</em> is placed
+<p>If old version is requested, the <b>output</b> files from <em>v.out.ascii</em> is placed
in the <tt>$LOCATION/$MAPSET/dig_ascii/</tt> and <tt>$LOCATION/$MAPSET/dig_att</tt> directory.
-<p>
-Only features with a category number will be
+<p>Only features with a category number will be
exported. Use <em><a href="v.category.html">v.category</a></em> to add
them if needed.
-<p>
-<em>v.out.ascii</em> does not copy the <tt>dig_cats</tt> file
+<p><em>v.out.ascii</em> does not copy the <tt>dig_cats</tt> file
associated with the binary vector <b>input</b> map to the
new <b>output</b> file name. The user must copy the <tt>dig_cats</tt>
file to the new <b>output</b> name if this is desired (e.g. using the
UNIX <em>cp</em> command).
-<p>
-It is possible to output the coordinates of vertices in a non-points vector
+<p>It is possible to output the coordinates of vertices in a non-points vector
feature by first converting the vector feature to a points map with
<em><a href="v.to.points.html">v.to.points</a></em> and then exporting
with <em>v.out.ascii</em> in
@@ -45,8 +40,7 @@
<h3>Standard mode</h3>
-<p>
v.out.ascii input=quads format=standard
ORGANIZATION: US Army Const. Eng. Rsch. Lab
@@ -139,5 +133,4 @@
Attribute selection added by Martin Landa, Czech Technical University
in Prague, Czech Republic (2008/12)
-<p>
Modified: grass/trunk/vector/v.out.dxf/v.out.dxf.html
--- grass/trunk/vector/v.out.dxf/v.out.dxf.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.out.dxf/v.out.dxf.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,7 +15,7 @@
<h2>SEE ALSO</h2>
-<em><a href="v.in.dxf.html">v.in.dxf</A></em>,
+<em><a href="v.in.dxf.html">v.in.dxf</a></em>,
<em><a href="vectorintro.html">Introduction to GRASS vector map processing</a></em>
<h2>AUTHOR</h2>
@@ -23,8 +23,7 @@
Charles Ehlschlaeger, U.S. Army Construction Engineering
Research Laboratory,<br>
wrote original <em>v.out.dxf</em> program in 4/89.
-<p>
-Update to GRASS 5.7 Radim Blazek, 10/2004
+<p>Update to GRASS 5.7 Radim Blazek, 10/2004
Modified: grass/trunk/vector/v.out.ogr/v.out.ogr.html
--- grass/trunk/vector/v.out.ogr/v.out.ogr.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.out.ogr/v.out.ogr.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,7 +17,6 @@
<a href="http://www.gdal.org/ogr/drv_tiger.html">TIGER</a>
<p>
For further available drivers go
<a href="http://www.gdal.org/ogr/ogr_formats.html">here</a>.
@@ -26,8 +25,7 @@
By default, islands will appear as holes inside surrounding areas.
To export areas with holes into, e.g., a Shapefile, and make the
holes appear as filled areas, the flag <em>-c</em> has to be used.
-<p>
-The "-z" flag can be used to automatically export a 3D map to a 3D Shapefile, instead
+<p>The "-z" flag can be used to automatically export a 3D map to a 3D Shapefile, instead
of setting the correct <em>lco=</em> option manually.
<h2>EXAMPLES</h2>
@@ -38,29 +36,24 @@
v.out.ogr input=lines type=line dsn=lines.shp
</pre></div>
-<p>
-Export areas from GRASS vector map to Shapefile format, converting
+<p>Export areas from GRASS vector map to Shapefile format, converting
islands (holes) to filled areas (generates /tmp/testogr.shp and related files):
v.out.ogr -c input=areas_islands type=area dsn=areas_islands.shp
</pre></div>
-<p>
-Export 3D lines from GRASS vector map to Shapefile format:
+<p>Export 3D lines from GRASS vector map to Shapefile format:
v.out.ogr input=lines_3d type=line dsn=lines_3d.shp lco="SHPT=ARCZ"
</pre></div>
-<p>
-Export 3D points (e.g., Lidar points) from GRASS vector map to Shapefile format
+<p>Export 3D points (e.g., Lidar points) from GRASS vector map to Shapefile format
v.out.ogr points_3d type=point dsn=points_3d.shp lco="SHPT=POINTZ"
</pre></div>
-<p>
-Export 3D faces from GRASS vector map to Shapefile format:
+<p>Export 3D faces from GRASS vector map to Shapefile format:
v.out.ogr input=objects_3d type=face dsn=faces_3d.shp lco="SHPT=POLYGONZ"
</pre></div>
-<p>
-Export 3D faces from GRASS vector map to Shapefile format, automatic 3D setting:
+<p>Export 3D faces from GRASS vector map to Shapefile format, automatic 3D setting:
v.out.ogr input=objects_3d type=face dsn=faces_3d.shp -z"
</pre></div>
@@ -91,8 +84,7 @@
format=KML type=face
</pre></div>
-<p>
-<b>Example 2 (Latitude-Longitude location):</b><br>
+<p><b>Example 2 (Latitude-Longitude location):</b><br>
Generate and export GRASS vector "asteroid" map (faces, 3D vectors) to
KML format for Google Earth:
@@ -128,8 +120,8 @@
<h2>SEE ALSO</h2>
<em>
-<a href="db.out.ogr.html">db.out.ogr</A>,
-<a href="v.external.html">v.external</A>,
+<a href="db.out.ogr.html">db.out.ogr</a>,
+<a href="v.external.html">v.external</a>,
<a href="v.in.ogr.html">v.in.ogr</a>
</em>
@@ -137,6 +129,5 @@
Radim Blazek, ITC-Irst, Trento, Italy<br>
Some contributions: Markus Neteler, Martin Landa
-<p>
Modified: grass/trunk/vector/v.out.svg/v.out.svg.html
--- grass/trunk/vector/v.out.svg/v.out.svg.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.out.svg/v.out.svg.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -14,21 +14,18 @@
<h2>EXAMPLE</h2>
-<p>
-Export <b>polygons</b> from GRASS vector map soils (Spearfish sample data) to SVG format:
+<p>Export <b>polygons</b> from GRASS vector map soils (Spearfish sample data) to SVG format:
v.out.svg input=soils output=/tmp/output.svg type=poly
</pre></div>
-<p>
-Export <b>lines</b> from GRASS vector map t_hydro (Spearfish sample
+<p>Export <b>lines</b> from GRASS vector map t_hydro (Spearfish sample
data) to SVG format, set coordinate precision to 0:
v.out.svg input=t_hydro output=/tmp/output.svg type=line precision=0
</pre></div>
-<p>
-Export <b>points</b> from GRASS vector map archsites (Spearfish sample
+<p>Export <b>points</b> from GRASS vector map archsites (Spearfish sample
data) to SVG format, include attribute <b>str1</b> (name):
v.out.svg input=archsites output=/tmp/output.svg type=point precision=0 attrib=str1
@@ -43,7 +40,7 @@
<h2>SEE ALSO</h2>
-<em><a href="v.out.ogr.html">v.out.ogr</A></em>
+<em><a href="v.out.ogr.html">v.out.ogr</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.out.vtk/v.out.vtk.html
--- grass/trunk/vector/v.out.vtk/v.out.vtk.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.out.vtk/v.out.vtk.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>v.out.vtk</em>
converts a GRASS vector map in binary format to the VTK ASCII
output.
-<p>
-If the <b>output</b> parameter is not given, the output will be send to stdout.
+<p>If the <b>output</b> parameter is not given, the output will be send to stdout.
<h2>NOTES</h2>
@@ -49,23 +48,20 @@
<li><i>vtk lines</i> -- representing lines and boundaries </li>
<li><i>vtk polygons</i> -- representing areas and faces </li>
</ul>
-<p>
-The VTK file can be visualized with
-<em><a href="http://www.vtk.org">VTK Toolkit</A></em>,
-<em><a href="http://www.paraview.org">Paraview</A></em> and
-<em><a href="http://mayavi.sourceforge.net">MayaVi</A></em>.
+<p>The VTK file can be visualized with
+<em><a href="http://www.vtk.org">VTK Toolkit</a></em>,
+<em><a href="http://www.paraview.org">Paraview</a></em> and
+<em><a href="http://mayavi.sourceforge.net">MayaVi</a></em>.
<h3>Attention</h3>
-<p>
-If areas or faces are exported, the data have to be triangulated within Paraview or
+<p>If areas or faces are exported, the data have to be triangulated within Paraview or
MayaVi.
<h2>EXAMPLE</h2>
Spearfish example:
-<p>
-Export the soils with cats in layer 1:
+<p>Export the soils with cats in layer 1:
v.out.vtk input=soils type=area layer=1 output=/tmp/soils.vtk
</pre></div>
Modified: grass/trunk/vector/v.outlier/v.outlier.html
--- grass/trunk/vector/v.outlier/v.outlier.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.outlier/v.outlier.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -58,5 +58,4 @@
<br>
Roberto Antolin
-<p>
Modified: grass/trunk/vector/v.overlay/v.overlay.html
--- grass/trunk/vector/v.overlay/v.overlay.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.overlay/v.overlay.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -22,20 +22,17 @@
The operator defines what kind of operation will be done. Features are written to output,
if the result of an operation 'ainput operator binput' is true.
-<p>
-Attributes of the tables from ainput and binput are joined into a new table
+<p>Attributes of the tables from ainput and binput are joined into a new table
linked to the output maps new cat-column.
<!-- This is outdated
-<p>
v.db.connect map=outputmap table=ainput.dbf field=2
v.db.connect map=outputmap table=binput.dbf field=3
</pre></div>
-<p>
-<b>Attention:</b> Removing the output map will also delete all tables linked to
+<p><b>Attention:</b> Removing the output map will also delete all tables linked to
it! Therefore it is advisable to copy tables from ainput and binput first and
connect the copied tables to the output map.-->
Modified: grass/trunk/vector/v.parallel/v.parallel.html
--- grass/trunk/vector/v.parallel/v.parallel.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.parallel/v.parallel.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,7 +6,7 @@
<h2>SEE ALSO</h2>
<em>
-<a href="v.buffer.html">v.buffer</A>
+<a href="v.buffer.html">v.buffer</a>
</em>
<h2>AUTHORS</h2>
@@ -14,5 +14,4 @@
Radim Blazek<br>
Rewritten by Rosen Matev (with support through the Google Summer of Code program 2008)
-<p>
Modified: grass/trunk/vector/v.patch/v.patch.html
--- grass/trunk/vector/v.patch/v.patch.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.patch/v.patch.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,19 +12,16 @@
edited or removed after <em>v.patch</em> is run. Such
editing can be done automatically using
<em><a href="v.clean.html">v.clean</a></em>.
-<p>
-Lines may need to be
+<p>Lines may need to be
snapped with <em><a href="v.clean.html">v.clean</a>
tool=snap,break,rmdupl</em>.
-<p>
-Boundaries may need to be cleaned with
+<p>Boundaries may need to be cleaned with
<em><a href="v.clean.html">v.clean</a> tool=break,rmdupl,rmsa</em>
repeatedly until the <em>rmsa</em> tool (Remove small angles at nodes)
no longer modifies any boundaries. If vector topology is still not
clean, boundaries may also need to be snapped with
<em><a href="v.clean.html">v.clean</a> tool=snap,break,rmdupl</em>.
-<p>
-When using the <em>-a</em> flag, the user has to make sure that the
+<p>When using the <em>-a</em> flag, the user has to make sure that the
features in the different maps added to the output map do not have
overlapping category numbers, unless identical category numbers
reflect identical attributes, otherwise the attributes of the added
@@ -62,5 +59,4 @@
<br>
-<p>
Modified: grass/trunk/vector/v.perturb/v.perturb.html
--- grass/trunk/vector/v.perturb/v.perturb.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.perturb/v.perturb.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -15,31 +15,28 @@
center, the <em>minimum</em> parameter can be used.
<p>
Usually, the mean (first parameter) of the normal
distribution is zero (i.e., the distribution is centered at
zero). The standard deviation (second parameter) is
naturally constrained to be positive.
<p>
Output vector points are not guaranteed to be contained within the
current geographic region.
<h2>SEE ALSO</h2>
-<em><a href="v.random.html">v.random</A></em><br>
-<em><a href="v.univar.html">v.univar</A></em><br>
+<em><a href="v.random.html">v.random</a></em><br>
+<em><a href="v.univar.html">v.univar</a></em><br>
<h2>AUTHOR</h2>
<br>when he was at:
-<a href="http://ABE.www.ecn.purdue.edu/ABE/">Agricultural Engineering</A>
-<p>
-Random number generators originally written in FORTRAN by Wes Peterson and
+<a href="http://ABE.www.ecn.purdue.edu/ABE/">Agricultural Engineering</a>
+<p>Random number generators originally written in FORTRAN by Wes Peterson and
translated to C using <i>f2c</i>.
Modified: grass/trunk/vector/v.proj/v.proj.html
--- grass/trunk/vector/v.proj/v.proj.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.proj/v.proj.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -20,8 +20,7 @@
If <b>set</b> is not specified, its name is assumed to be the same as the current
mapset's name.
-<p>
-<em>v.proj</em> supports general datum transformations, making use of the
+<p><em>v.proj</em> supports general datum transformations, making use of the
<em>PROJ.4</em> co-ordinate system translation library.
@@ -35,8 +34,7 @@
<a href="http://proj.maptools.org/">PROJ 4</a>: Projection/datum support library.
-<p>
-<b>Further reading</b>
+<p><b>Further reading</b>
<ul>
<li> <a href="http://www.asprs.org/resources/grids/">ASPRS Grids and Datum</a>
<li> <a href="http://www.mapref.org">MapRef - The Collection of Map Projections and Reference Systems for Europe</a>
@@ -46,14 +44,14 @@
<h2>SEE ALSO</h2>
<em>
-<a href="r.proj.html">r.proj</A>,
-<a href="g.proj.html">g.proj</A>,
-<a href="g.setproj.html">g.setproj</A>,
-<a href="i.rectify.html">i.rectify</A>,
-<a href="r.stats.html">r.stats</A>,
-<a href="v.sample.html">v.sample</A>,
-<a href="v.surf.idw.html">v.surf.idw</A>,
+<a href="r.proj.html">r.proj</a>,
+<a href="g.proj.html">g.proj</a>,
+<a href="g.setproj.html">g.setproj</a>,
+<a href="i.rectify.html">i.rectify</a>,
+<a href="r.stats.html">r.stats</a>,
+<a href="v.sample.html">v.sample</a>,
+<a href="v.surf.idw.html">v.surf.idw</a>,
</em>
<h2>AUTHORS</h2>
Modified: grass/trunk/vector/v.qcount/v.qcount.html
--- grass/trunk/vector/v.qcount/v.qcount.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.qcount/v.qcount.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -17,13 +17,11 @@
-<p>
-<em>Complete Spatial Randomness and Quadrat Methods</em> -
+<p><em>Complete Spatial Randomness and Quadrat Methods</em> -
GRASS Tutorial on <em>v.qcount</em>
(only available as older file s.qcount-tutorial.ps),
-<p>
-General references include:
+<p>General references include:
<br>
Noel A. C. Cressie.
@@ -36,8 +34,7 @@
<em>Spatial Statistics</em>.
John Wiley \& Sons, New York, NY, 1981.
-<p>
-References to the indices include:
+<p>References to the indices include:
<br>
F. N. David and P. G. Moore.
Notes on contagious distributions in plant populations.
@@ -65,10 +62,8 @@
Biology</em>, 2:215-235, 1959.
<h2>BUGS</h2>
-<p>
-Timestamp not working for header part of counts output. (2000-10-28)
-<p>
-Please send all bug fixes and comments to the author
+<p>Timestamp not working for header part of counts output. (2000-10-28)
+<p>Please send all bug fixes and comments to the author
or the GRASS development team. <br>
<a href="http://grass.osgeo.org"><tt>http://grass.osgeo.org</tt></a>.
@@ -80,8 +75,7 @@
-<p>
-Modified for GRASS 5.0 by Eric G. Miller (2000-10-28)
+<p>Modified for GRASS 5.0 by Eric G. Miller (2000-10-28)
<br>
Modified for GRASS 5.7 by R. Blazek (2004-10-14)
Modified: grass/trunk/vector/v.random/v.random.html
--- grass/trunk/vector/v.random/v.random.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.random/v.random.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -12,8 +12,7 @@
<b>DOUBLE PRECISION</b> for floating point numbers. Integer values are
calculated by rounding random floating point number.
-<p>
-To produce repeatable results a random seed can be set using the option <em>seed</em>>.
+<p>To produce repeatable results a random seed can be set using the option <em>seed</em>>.
<h2>EXAMPLES</h2>
Generate 20 random points with binary attribute (only 0 or 1):
@@ -43,12 +42,11 @@
<h2>SEE ALSO</h2>
UNIX man pages for <em>rand(3)</em> and <em>drand48(3)</em>.
-<p>
-<em>
+<p><em>
<a href="g.region.html">g.region</a>,
<a href="r.random.html">r.random</a>,
-<a href="v.perturb.html">v.perturb</A>,
+<a href="v.perturb.html">v.perturb</a>,
<a href="v.what.rast.html">v.what.rast</a>
<a href="v.what.vect.html">v.what.vect</a>
</em>
@@ -56,16 +54,16 @@
<h2>BUGS</h2>
The RNG used by
-<em><a href="v.perturb.html">v.perturb</A></em>
+<em><a href="v.perturb.html">v.perturb</a></em>
should probably be added to this program.<br>
<h2>AUTHOR</h2>
<br>when he was at:
-Engineering</A>
+Engineering</a>
Modified: grass/trunk/vector/v.reclass/v.reclass.html
--- grass/trunk/vector/v.reclass/v.reclass.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.reclass/v.reclass.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
to change the <i>key column</i> away from the default of "<b>cat</b>" with
the <b>column</b> option.
-<p>
-Rules file may contain on each row either pair:
+<p>Rules file may contain on each row either pair:
keyword value
</pre></div>
@@ -27,8 +26,7 @@
column containing the unique string column values, sorted in alphabetical
order.
-<p>
-For dissolving common boundaries, see
+<p>For dissolving common boundaries, see
<em><a href="v.dissolve.html">v.dissolve</a></em>.
@@ -36,7 +34,7 @@
<h2>EXAMPLES</h2>
-<H3>Example 1: Reclass by rules</H3>
+<h3>Example 1: Reclass by rules</h3>
v.reclass input=land output=land_u type=boundary rules=land.rcl
@@ -64,7 +62,7 @@
<tt>select id from tland where use = 'E14'</tt> changed to category 2.
-<H3>Example 2: Reclass by attribute column</H3>
+<h3>Example 2: Reclass by attribute column</h3>
(North Carolina sample dataset)<br>
@@ -87,10 +85,9 @@
<em>
<a href="v.dissolve.html">v.dissolve</a>,
-<a href="v.extract.html">v.extract</A>
+<a href="v.extract.html">v.extract</a>
</em>
-<p>
-<em><a href="sql.html">GRASS SQL interface</a></em>
+<p><em><a href="sql.html">GRASS SQL interface</a></em>
<h2>AUTHOR</h2>
@@ -99,5 +96,4 @@
from v.reclass to v.db.reclass and later to v.reclass in 5.7 rewritten
by Radim Blazek
-<p>
Modified: grass/trunk/vector/v.sample/v.sample.html
--- grass/trunk/vector/v.sample/v.sample.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.sample/v.sample.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
interpolation, bilinear interpolation, or nearest neighbor
sampling (default).
-<p>
-This program may be especially useful when sampling for
+<p>This program may be especially useful when sampling for
cross validation of interpolations whose output is a raster
map.
@@ -16,17 +15,14 @@
The input category value is used. The input attribute, raster value
and difference is written to output.
-<p>
-When NULL values are encountered for a cell, zero value is used
+<p>When NULL values are encountered for a cell, zero value is used
instead. In these cases, more acurrate results may be obtained
by using the default nearest neighbor comparisons.
-<p>
-This program may not work properly with lat-long data when
+<p>This program may not work properly with lat-long data when
the <b>-BC</b> flags are used.
-<p>
-When interpolation is done (i.e., the <b>-BC</b> flags are
+<p>When interpolation is done (i.e., the <b>-BC</b> flags are
used), values are assumed to be located at the centroid of
grid cells. Therefore, current resolution settings are
important.
@@ -76,8 +72,7 @@
<br>when he was at:
-<p>
-Updated for GRASS 5.0 by Eric G. Miller
+<p>Updated for GRASS 5.0 by Eric G. Miller
<br>
Updated for GRASS 5.7 by Radim Blazek
Modified: grass/trunk/vector/v.segment/v.segment.html
--- grass/trunk/vector/v.segment/v.segment.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.segment/v.segment.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>v.segment</em> generates segments or points from input lines and from
positions read from a text file or '<tt>stdin</tt>'.
-<p>
-The format is:
+<p>The format is:
P <point id> <line cat> <offset> [<side offset>]
L <segment id> <line cat> <start offset> <end offset> [<side offset>]
@@ -24,20 +23,16 @@
<h2>NOTES</h2>
A segment is only created for the first line found of the specified category.
-<p>
-Points are generated along the lines at the given distance(s) from the
+<p>Points are generated along the lines at the given distance(s) from the
beginning of the vector line.
-<p>
-The side offset is the orthogonal distance from the line. Positive side
+<p>The side offset is the orthogonal distance from the line. Positive side
offsets are to the right side of the line going forward, negative offsets
are to the left (<em>d.vect</em> with <em>display=shape,dir</em> shows
the direction of vector lines). As the segment distance is measured along the
original line, side-offset lines will be longer than the start-end segment distance
for outside corners of curving lines, and shorter for inside corners.
-<p>
-All offsets are measured in map units (see "<em>g.proj -p</em>").
-<p>
-To place a point in the middle of a line, the <em>v.to.db</em> module may be
+<p>All offsets are measured in map units (see "<em>g.proj -p</em>").
+<p>To place a point in the middle of a line, the <em>v.to.db</em> module may be
used to find the line's length. Then half of that distance can be used as the
along-line offset.
@@ -127,5 +122,4 @@
-<p>
-<i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/vector/v.select/v.select.html
--- grass/trunk/vector/v.select/v.select.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.select/v.select.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -3,8 +3,7 @@
<em>v.select</em> allows the user to select features from a vector
map by features from another one.
-<p>
-Supported operators (without GEOS):
+<p>Supported operators (without GEOS):
<ul>
<li><tt>overlap</tt> - features partially or completely overlap
</ul>
@@ -30,8 +29,7 @@
as an area's attributes are inherited from the centroid. Typically
points, lines, and centroids will always want to have a cat number.
-<p>
-E.g. take a road which separates two farms. It is ambiguous as to which
+<p>E.g. take a road which separates two farms. It is ambiguous as to which
farm an attribute that is attached to the road belongs to. The boundary
only needs a cat number if it will hold its own attributes, such as road
name or pavement form. A centroid in each paddock holds the information
@@ -65,8 +63,7 @@
<a href="v.overlay.html">v.overlay</a>
</em>
-<p>
-<em>
+<p><em>
</em>
@@ -77,5 +74,4 @@
Updated by Martin Landa, CTU in Prague, Czech Republic (GEOS support)
-<p>
Modified: grass/trunk/vector/v.support/v.support.html
--- grass/trunk/vector/v.support/v.support.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.support/v.support.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -16,8 +16,8 @@
<h2>SEE ALSO</h2>
<em>
- <a href="v.build.html">v.build</A>,
- <a href="v.info.html">v.info</A>
+ <a href="v.build.html">v.build</a>,
+ <a href="v.info.html">v.info</a>
</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.surf.bspline/v.surf.bspline.html
--- grass/trunk/vector/v.surf.bspline/v.surf.bspline.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.surf.bspline/v.surf.bspline.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
attribue column in a 2D or 3D map. Output can be a raster or vector map.
Optionally, a "sparse point" vector map can be input which indicates the
location of <b><i>output</i></b> vector points.
-<p>
-From a theoretical perspective, the interpolating procedure takes place in two
+<p>From a theoretical perspective, the interpolating procedure takes place in two
parts: the first is an estimate of the linear coefficients of a spline function
is derived from the observation points using a least squares regression; the
second is the computation of the interpolated surface (or interpolated vector
@@ -21,8 +20,7 @@
Regularization, avoids the need to have one one observation and one coefficient
for each spline (in order to avoid instability).
-<p>
-With regularly distributed data points, a spline step corresponding to the
+<p>With regularly distributed data points, a spline step corresponding to the
maximum distance between two points in both the east and north directions is
sufficient. But often data points are not regularly distributed and require
statistial regularization or estimation. In such cases, v.surf.bspline will
@@ -35,8 +33,7 @@
step lengths--especially spline step lengths that are less than the distance
between observation points--can greatly increase processing time.
-<p>
-Moreover, the maximum number of splines for each direction at each time is
+<p>Moreover, the maximum number of splines for each direction at each time is
fixed, regardless of the spline step length. As the total number of splines used
increases (i.e., with small spline step lengths), the region is automatically
into subregions for interpolation. Each subregion can contain no more than
@@ -44,23 +41,19 @@
partially overlap each other. A weighted mean of observations, based on point
locations, is calculated within each subregion.
-<p>
-The Tykhonov regularization parameter ("<b><i>lambda_i</i></b>") acts to smooth
+<p>The Tykhonov regularization parameter ("<b><i>lambda_i</i></b>") acts to smooth
the interpolation. With a small <b><i>lambda_i</i></b>, the interpolated surface
closely follows observation points; a larger value will produce a smoother
interpolation.
-<p>
-The input can be a 2D pr 3D vector points map. If "<b><i>layer =</i></b>" 0 the
+<p>The input can be a 2D pr 3D vector points map. If "<b><i>layer =</i></b>" 0 the
z-value of a 3D map is used for interpolation. If layer > 0, the user must
specify an attribute column to used for interpolation using the
"<b><i>column=</i></b>" argument (2D or 3D map).
-<p>
-v.surf.bspline can produce a raster OR a vector output (NOT simultaneously).
+<p>v.surf.bspline can produce a raster OR a vector output (NOT simultaneously).
-<p>
-If output is a vector points map and a "<b><i>sparse=</i></b>" vector points map
+<p>If output is a vector points map and a "<b><i>sparse=</i></b>" vector points map
is not specified, the output vector map will contain points at the same
locations as observation points in the input map, but the values of the output
points are interpolated values. If instead a "<b><i>sparse=</i></b>" vector points
@@ -68,8 +61,7 @@
the sparse vector map points, and values will be those of the interpolated
raster surface at those points.
-<p>
-A cross validation "leave-one-out" analysis is available to help to determine
+<p>A cross validation "leave-one-out" analysis is available to help to determine
the optimal <b><i>lambda_i</i></b> value that produces an interpolation that
best fits the original observation data. The more points used for
cross-validation, the longer the time needed for computation. Empirical testing
@@ -130,8 +122,7 @@
<h2>BUGS</h2>
Known issues:
-<p>
-In order to avoid RAM memory problems, an auxiliary table is needed for
+<p>In order to avoid RAM memory problems, an auxiliary table is needed for
recording some intermediate calculations. This requires the "<b>GROUP BY</b>"
SQL function is used, which is not supported by the "<b>dbf</b>" driver. For
this reason, vector map output "<b><i>output=</i></b>" is not permitted with the
@@ -150,8 +141,7 @@
Original version in GRASS 5.4: (s.bspline.reg)
<br>
Maria Antonia Brovelli, Massimiliano Cannata, Ulisse Longoni, Mirko Reguzzoni
-<p>
-Update for GRASS 6.X and improvements:
+<p>Update for GRASS 6.X and improvements:
<br>
Roberto Antolin
@@ -160,17 +150,14 @@
Brovelli M. A., Cannata M., and Longoni U.M., 2004, LIDAR Data
Filtering and DTM Interpolation Within GRASS, Transactions in GIS,
April 2004, vol. 8, iss. 2, pp. 155-174(20), Blackwell Publishing Ltd
-<p>
-Brovelli M. A. and Cannata M., 2004, Digital Terrain model
+<p>Brovelli M. A. and Cannata M., 2004, Digital Terrain model
reconstruction in urban areas from airborne laser scanning data: the
method and an example for Pavia (Northern Italy). Computers and
Geosciences 30, pp.325-331
-<p>
-Brovelli M. A e Longoni U.M., 2003, Software per il filtraggio di
+<p>Brovelli M. A e Longoni U.M., 2003, Software per il filtraggio di
dati LIDAR, Rivista dell'Agenzia del Territorio, n. 3-2003, pp. 11-22
(ISSN 1593-2192)
-<p>
-Antolin R. and Brovelli M.A., 2007, LiDAR data Filtering with GRASS GIS for the
+<p>Antolin R. and Brovelli M.A., 2007, LiDAR data Filtering with GRASS GIS for the
Determination of Digital Terrain Models. Proceedings of Jornadas de SIG Libre,
Girona, España. CD ISBN: 978-84-690-3886-9 <br>
Modified: grass/trunk/vector/v.surf.idw/v.surf.idw.html
--- grass/trunk/vector/v.surf.idw/v.surf.idw.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.surf.idw/v.surf.idw.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -1,7 +1,6 @@
<h2>DESCRIPTION</h2>
-<p>
-<em>v.surf.idw</em> fills a raster matrix with interpolated
+<p><em>v.surf.idw</em> fills a raster matrix with interpolated
values generated from a set of irregularly spaced data
points using numerical approximation (weighted averaging)
techniques. The interpolated value of a cell is determined
@@ -13,15 +12,13 @@
and generates the interpolated surface from the data
points.
-<p>
-This program allows the user to use a GRASS vector point map file,
+<p>This program allows the user to use a GRASS vector point map file,
rather than a raster map layer, as input.
<h2>NOTES</h2>
-<p>
-The amount of memory used by this program is related to the number
+<p>The amount of memory used by this program is related to the number
of vector points in the current region. If the vector point map is
very dense (i.e., contains many data points), the program may
not be able to get all the memory it needs from the
@@ -29,13 +26,11 @@
resolution of the current region, after an initial delay
determined by the time taken to read the input vector points map.
-<p>
-To read and interpolate from the elevation co-ordinates as 3rd dimension
+<p>To read and interpolate from the elevation co-ordinates as 3rd dimension
of the vector geometry, use the <em>-z</em> flag. In this case no <em>column</em>
parameter has to be specified.
-<p>
-If the user has a mask set, then interpolation is only done
+<p>If the user has a mask set, then interpolation is only done
for those cells that fall within the mask. However, all
vector points in the current region are used even
if they fall outside the mask. Vector points outside the current
@@ -45,28 +40,26 @@
interpolation. The <em>-n</em> flag may also be used to
achieve a similar result.
-<p>
-If more than <em>count</em> points fall into one target raster cell,
+<p>If more than <em>count</em> points fall into one target raster cell,
the mean of all the site values will determine the cell value (unless
the -n flag is specified, in which case only the <em>count</em>
points closest to the centre of the cell will be interpolated).
-<p>
-By setting <em>npoints=1</em>, the module can be used
+<p>By setting <em>npoints=1</em>, the module can be used
to calculate raster Voronoi diagrams (Thiessen polygons).
<h2>SEE ALSO</h2>
-<em><a href="d.vect.html">d.vect</A></em><br>
-<em><a href="g.region.html">g.region</A></em><br>
-<em><a href="r.surf.contour.html">r.surf.contour</A></em><br>
-<em><a href="r.surf.idw.html">r.surf.idw</A></em><br>
-<em><a href="r.surf.idw2.html">r.surf.idw2</A></em><br>
-<em><a href="r.surf.gauss.html">r.surf.gauss</A></em><br>
-<em><a href="r.surf.fractal.html">r.surf.fractal</A></em><br>
-<em><a href="r.surf.random.html">r.surf.random</A></em><br>
-<em><a href="v.surf.rst.html">v.surf.rst</A></em>
+<em><a href="d.vect.html">d.vect</a></em><br>
+<em><a href="g.region.html">g.region</a></em><br>
+<em><a href="r.surf.contour.html">r.surf.contour</a></em><br>
+<em><a href="r.surf.idw.html">r.surf.idw</a></em><br>
+<em><a href="r.surf.idw2.html">r.surf.idw2</a></em><br>
+<em><a href="r.surf.gauss.html">r.surf.gauss</a></em><br>
+<em><a href="r.surf.fractal.html">r.surf.fractal</a></em><br>
+<em><a href="r.surf.random.html">r.surf.random</a></em><br>
+<em><a href="v.surf.rst.html">v.surf.rst</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.surf.rst/v.surf.rst.html
--- grass/trunk/vector/v.surf.rst/v.surf.rst.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.surf.rst/v.surf.rst.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -16,8 +16,7 @@
If the input data have time stamp, the program creates time stamp for all
output files.
-<p>
-User can define a raster map named <em>maskmap</em>, which will be used
+<p>User can define a raster map named <em>maskmap</em>, which will be used
as a mask. The approximation is skipped for cells which have zero or NULL
value in mask. NULL values will be assigned to these cells in all output
raster maps. Data points are checked for identical points and points that
@@ -31,7 +30,6 @@
and curvatures can be computed).
<p>
Regularized spline with tension is used for the approximation. The
<em>tension</em>
parameter tunes the character of the resulting surface from thin plate
@@ -46,7 +44,6 @@
of the resulting surface from the given data.
<p>
If the number of given points is greater than <em>segmax</em>, segmented
processing is used . The region is split into quadtree-based rectangular segments, each
having less than <em>segmax</em> points and approximation is performed on
@@ -60,7 +57,6 @@
from which additional points for approximation on each segment were taken.
<p>
Predictive error of surface approximation for given parameters can be computed using the
<b>-c</b> flag. A crossvalidation procedure is then performed using the data given in the vector map
<em>input</em> and the estimated predictive errors are stored in the vector point file
@@ -73,7 +69,6 @@
<b><em>elev</em></b>.
<p>
<h2>NOTES</h2>
<em>v.surf.rst </em>uses regularized spline with tension for approximation
@@ -201,8 +196,7 @@
Using the <em>where</em> parameter, the interpolation can be limited to use
only a subset of the input vectors.
-<p>
-Spearfish example (we simulate randomly distributed elevation measures):
+<p>Spearfish example (we simulate randomly distributed elevation measures):
<div class="code"><pre>
g.region rast=elevation.10m -p
@@ -226,8 +220,7 @@
<h3>Cross validation procedure</h3>
-<p>
-The "optimal" approximation parameters for given data can be found using
+<p>The "optimal" approximation parameters for given data can be found using
a cross-validation (CV) procedure (<b>-c </b>flag).
The CV procedure is based on removing one input data point at a time,
performing the approximation for the location of the removed point using
@@ -302,47 +295,39 @@
<h2> REFERENCES</h2>
-<p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/IEEEGRSL2005.pdf">
+<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/IEEEGRSL2005.pdf">
Mitasova, H., Mitas, L. and Harmon, R.S., 2005,</a>
Simultaneous spline approximation and topographic analysis for
lidar elevation data in open source GIS, IEEE GRSL 2 (4), 375- 379.
-<p>
-Hofierka, J., 2005, Interpolation of Radioactivity Data Using Regularized Spline with Tension. Applied GIS, Vol. 1, No. 2,
+<p>Hofierka, J., 2005, Interpolation of Radioactivity Data Using Regularized Spline with Tension. Applied GIS, Vol. 1, No. 2,
pp. 16-01 to 16-13. DOI: 10.2104/ag050016
-<p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/TGIS2002_Hofierka_et_al.pdf">
+<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/TGIS2002_Hofierka_et_al.pdf">
Hofierka J., Parajka J., Mitasova H., Mitas L., 2002,</a>
Multivariate Interpolation of Precipitation Using Regularized Spline with Tension.
Transactions in GIS 6(2), pp. 135-150.
-<p>
-H. Mitasova, L. Mitas, B.M. Brown, D.P. Gerdes, I. Kosinovsky, 1995, Modeling
+<p>H. Mitasova, L. Mitas, B.M. Brown, D.P. Gerdes, I. Kosinovsky, 1995, Modeling
spatially and temporally distributed phenomena: New methods and tools for
GRASS GIS. International Journal of GIS, 9 (4), special issue on Integrating
GIS and Environmental modeling, 433-446.
-<p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/MG-I-93.pdf">
+<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/MG-I-93.pdf">
Mitasova, H. and Mitas, L., 1993</a>:
Interpolation by Regularized Spline with Tension:
I. Theory and Implementation, Mathematical Geology ,25, 641-655.
-<p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/MG-II-93.pdf">
+<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/MG-II-93.pdf">
Mitasova, H. and Hofierka, J., 1993</a>: Interpolation
by Regularized Spline with Tension: II. Application to Terrain Modeling
and Surface Geometry Analysis, Mathematical Geology 25, 657-667.
-<p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/CMA1988.pdf">
+<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/CMA1988.pdf">
Mitas, L., and Mitasova H., 1988, </a> General variational approach to the approximation
problem, Computers and Mathematics with Applications, v.16, p. 983-992.
-<p>
-<a href="http://www.grassbook.org">
+<p><a href="http://www.grassbook.org">
Neteler, M. and Mitasova, H., 2008, Open Source GIS: A GRASS GIS Approach, 3rd Edition, </a>
Springer, New York, 406 pages.
Modified: grass/trunk/vector/v.to.3d/description.html
--- grass/trunk/vector/v.to.3d/description.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.to.3d/description.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
by <b>height</b> parameter as fixed value or by <b>column</b>
parameter.
-<p>
-Flag <b>-r</b> enables to perform reverse transformation, i.e.,
+<p>Flag <b>-r</b> enables to perform reverse transformation, i.e.,
transform 3D vector to 2D by omitting z-coordinate.
<h2> NOTES</h2>
@@ -46,5 +45,4 @@
-<p>
Modified: grass/trunk/vector/v.to.3d/v.to.3d.html
--- grass/trunk/vector/v.to.3d/v.to.3d.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.to.3d/v.to.3d.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -5,8 +5,7 @@
parameter.
-<p>
<h2> NOTES</h2>
@@ -46,5 +45,4 @@
-<p>
Modified: grass/trunk/vector/v.to.db/v.to.db.html
--- grass/trunk/vector/v.to.db/v.to.db.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.to.db/v.to.db.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,35 +10,28 @@
<h2>NOTES</h2>
The units <em>miles</em>, <em>feet</em>, <em>meters</em> and
<em>kilometers</em> are square for <em>option=area</em>.
-<p>
-Feet and acre units are always reported in their common versions
+<p>Feet and acre units are always reported in their common versions
(i.e. the International Foot, exactly 5280 feet in a mile), even
when the location's standard map unit is the US Survey foot.
-<p>
-When calculating perimeters in Latitude-Longitude locations, the geodesic
+<p>When calculating perimeters in Latitude-Longitude locations, the geodesic
distance between the vertices is used.
-<p>
-When using <em>option=coor</em> on a vector area map,
+<p>When using <em>option=coor</em> on a vector area map,
only coordinates of centroids with unique category will be reported.
-<p>
-Line azimuth is calculated as angle from the North direction to the line endnode
+<p>Line azimuth is calculated as angle from the North direction to the line endnode
direction at the line statnode. By default it's reported in decimal degrees (0-360, CW) but
it also may be repored in radians with <em>unit=radians</em>. Azimuth value
<b>-1</b> is used to report closed line with it's startnode and endnode being in
same place. Azimuth values make sense only if every vector line has only one
entry in database (unique CAT value).
-<p>
-If the module is apparently slow <em>and</em> the map attributes are
+<p>If the module is apparently slow <em>and</em> the map attributes are
stored in an external DBMS such as PostgreSQL, it is highly recommended
to create an index on the key (category) column.
-<p>
-Uploading the vector map attributes to a database requires a table attached to
+<p>Uploading the vector map attributes to a database requires a table attached to
a given input vector <em>layer</em>. The <b>print only</b> (<b>-p</b>) mode
doesn't require a table. Use <em><a href="db.execute.html">db.execute</a></em>
or <em><a href="v.db.addtable.html">v.db.addtable</a></em> to create a table if
needed.
-<p>
-Updating the table has to be done column-wise. The <em>column</em> must be
+<p>Updating the table has to be done column-wise. The <em>column</em> must be
present in the table, except when using the <b>print only</b> (<b>-p</b>)
mode. Use <em><a href="db.execute.html">db.execute</a></em> or
<em><a href="v.db.addcolumn.html">v.db.addcolumn</a></em> to add new columns if
@@ -53,41 +46,35 @@
v.to.db map=soils type=centroid option=cat
</pre></div>
-<p>
-Upload polygon areas to corresponding centroid record in the attribute table:<br>
+<p>Upload polygon areas to corresponding centroid record in the attribute table:<br>
v.to.db map=soils type=centroid option=area col=area_size unit=h
</pre></div>
-<p>
-Upload line lengths (in meters) of each vector line to attribute table
+<p>Upload line lengths (in meters) of each vector line to attribute table
(use <em>v.category</em> in case of missing categories):<br>
v.to.db map=roads option=length type=line col=linelength units=me
</pre></div>
-<p>
-Upload x and y coordinates from vector geometry to attribute table:<br>
+<p>Upload x and y coordinates from vector geometry to attribute table:<br>
v.to.db map=pointsmap option=coor col=x,y
</pre></div>
-<p>
-Upload x, y and z coordinates from vector geometry to attribute table:<br>
+<p>Upload x, y and z coordinates from vector geometry to attribute table:<br>
v.to.db map=pointsmap option=coor col=x,y,z
</pre></div>
-<p>
-Transfer attributes from a character column (with numeric contents) to a new
+<p>Transfer attributes from a character column (with numeric contents) to a new
integer column:<br>
v.db.addcolumn usa_income_employment2002 col="FIPS_NUM integer"
v.to.db usa_income_employment2002 option=query col=FIPS_NUM qcol=STATE_FIPS
</pre></div>
-<p>
-Upload category numbers of left and right area, to an attribute table of
+<p>Upload category numbers of left and right area, to an attribute table of
boundaries common for the areas:<br>
# add categories for boundaries of the input vector map, in layer 2:
@@ -101,8 +88,7 @@
v.db.select mysoils layer=2
</pre></div>
-<p>
-Compute D<sub>L</sub>, the Fractal Dimension (Mandelbrot, 1982), of the boundary defining a polygon based on the formula:
+<p>Compute D<sub>L</sub>, the Fractal Dimension (Mandelbrot, 1982), of the boundary defining a polygon based on the formula:
<br><tt>
D = 2 * (log perimeter) / (log area):<br>
</tt>
@@ -132,21 +118,18 @@
v.to.db -p soils option=area type=boundary units=h
</pre></div>
-<p>
-Report all area sizes of the input vector map, in hectares, sorted by category
+<p>Report all area sizes of the input vector map, in hectares, sorted by category
number (requires GNU <em>sort</em> utility installed):<br>
v.to.db -p soils option=area type=boundary units=h | sort -n
</pre></div>
-<p>
-Report all line lengths of the input vector map, in kilometers:<br>
+<p>Report all line lengths of the input vector map, in kilometers:<br>
v.to.db -p roads option=length type=line units=k
</pre></div>
-<p>
-Report number of features for each category in the input vector map:<br>
+<p>Report number of features for each category in the input vector map:<br>
v.to.db -p roads option=count type=line
</pre></div>
@@ -181,5 +164,4 @@
Radim Blazek, ITC-irst, Trento, Italy<br>
Line sinuousity implemented by Wolf Bergenheim
-<p>
Modified: grass/trunk/vector/v.to.points/v.to.points.html
--- grass/trunk/vector/v.to.points/v.to.points.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.to.points/v.to.points.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,8 +13,7 @@
of the vector line the user should use
<a href="v.segment.html">v.segment</a>.
-<p>
-The <em>type</em> parameter is used to control which input vector
+<p>The <em>type</em> parameter is used to control which input vector
geometry types to convert into points.
Some caveats to consider about this parameter:
@@ -46,18 +45,14 @@
The -v flag is used to digitize points that fall on the line's vertices <em>only</em>.
<em>dmax</em> is ignored in this case.
-<p>
-If the -i flag is used in conjunction with the -v flag,
+<p>If the -i flag is used in conjunction with the -v flag,
<em>v.to.points</em> will digitize points on the line vertices, as
well as interpolate points between line vertices using <em>dmax</em>
as the maximum allowable spacing.
-<p>
-To get points created for the beginning, middle and end only, use
+<p>To get points created for the beginning, middle and end only, use
the -i switch and set <em>dmax</em> so that:
-<p>
- (length of input line / 2) <= <em>dmax</em> <= length of input line
-<p>
-So if <em>dmax</em> is between 0.5x and 1.0x the line length, you
+<p> (length of input line / 2) <= <em>dmax</em> <= length of input line
+<p>So if <em>dmax</em> is between 0.5x and 1.0x the line length, you
will always get points created at exactly the beginning, middle and
end of the input line.
Modified: grass/trunk/vector/v.to.rast/v.to.rast.html
--- grass/trunk/vector/v.to.rast/v.to.rast.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.to.rast/v.to.rast.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,53 +13,44 @@
therefore ensure that the current geographic region is
correctly set and that the region resolution is at the
desired level.
-<p>
-Either the <em><b>column</b></em> parameter or the <em><b>value</b></em>
+<p>Either the <em><b>column</b></em> parameter or the <em><b>value</b></em>
parameter must be specified. The <em><b>use</b></em> option may be
specified alone when using the <em>dir</em> option.
-<p>
-<em><b>use</b></em> options are:
+<p><em><b>use</b></em> options are:
<ul>
-<LI>
+<li>
<em>attr</em> - read values from attribute table (default)
-<LI>
+<li>
<em>cat</em> - read values from category
-<LI>
+<li>
<em>val</em> - use value specified by <em><b>value</b></em> option
-<LI>
+<li>
<em>z</em> - use z coordinate (points or contours only)
-<LI>
+<li>
<em>dir</em> - output as flow direction in degrees (lines only)
</ul>
-<p>
-The <em><b>column</b></em> parameter uses an existing column from the vector map
+<p>The <em><b>column</b></em> parameter uses an existing column from the vector map
database table as the category value in the output raster map. Existing table
columns can be shown by using <em><a href="db.describe.html">db.describe</a></em>.
-<p>
-An empty raster map layer will be created if the vector map layer has not
+<p>An empty raster map layer will be created if the vector map layer has not
been assigned category/attribute labels (e.g., through use of
<a href="v.category.html">v.category option=add</a>).
-<p>
-Otherwise:
+<p>Otherwise:
<ul>
-<LI>
+<li>
Labeled areas and/or centroids will produce filled raster coverages with edges
that straddle the original area boundary <b>as long as the boundary is NOT
labeled</b>.
<br>(Use <tt>v.category option=del type=boundary</tt> to remove.)
-<LI>
+<li>
Labeled lines and boundaries will produce lines of raster cells which touch the
original vector line. This tends to be more aggressive than area-only conversions.
-<LI>
+<li>
Points and orphaned centroids will be converted into single cells on the
resultant raster map.
</ul>
-<p>
-<p>
-<b>Flow directions</b> are given in degrees counterclockwise from east.
-<p>
-<p>
-Raster category labels are supported for all of <em>use=</em> except <em>use=z</em>.
+<p><p><b>Flow directions</b> are given in degrees counterclockwise from east.
+<p><p>Raster category labels are supported for all of <em>use=</em> except <em>use=z</em>.
<h2>EXAMPLES</h2>
@@ -77,16 +68,12 @@
v.to.rast in=vect_map out=raster_map col=SPEED
</pre></div>
-<p>
-<p>
-<em>2. Calculate stream directions from a river vector map (Spearfish)</em><br>
+<p><p><em>2. Calculate stream directions from a river vector map (Spearfish)</em><br>
v.to.rast in=streams out=streamsdir use=dir
</pre></div>
-<p>
-<p>
-<em>3. Convert a vector polygon map to raster including descriptive labels (Spearfish)</em><br>
+<p><p><em>3. Convert a vector polygon map to raster including descriptive labels (Spearfish)</em><br>
v.to.rast in=fields out=myfields use=attr col=cat labelcol=label
r.category myfields
@@ -108,8 +95,6 @@
Stream directions: Jaro Hofierka and Helena Mitasova
<br>
GRASS 6.3 code cleanup and label support: Brad Douglas
-<p>
-<p>
+<p><p><i>Last changed: $Date$</i>
Modified: grass/trunk/vector/v.to.rast3/v.to.rast3.html
--- grass/trunk/vector/v.to.rast3/v.to.rast3.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.to.rast3/v.to.rast3.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -23,7 +23,7 @@
<h2>SEE ALSO</h2>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.transform/v.transform.html
--- grass/trunk/vector/v.transform/v.transform.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.transform/v.transform.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -11,8 +11,7 @@
When using an ASCII table containing source and target coordinate pairs,
in each row four coordinate values separated by white space have to be specified.
Comments are permitted and have to be indicated by a '#' character.
-<p>
-Example for a points file of a linear transformation from XY to UTM coordinates
+<p>Example for a points file of a linear transformation from XY to UTM coordinates
(L: left, R: right, U: upper, L: lower, N, S, W, E):
@@ -36,7 +35,6 @@
map. In this case vector objects can be transformed with different
parameters based on their category number. If the parameter cannot be
fetched from the table, default value is used instead.<p>
<h3>Affine Transformation Matrix</h3>
The affine transfomation matrix can optionally be printed with the '-m'
flag. The format of the matrix is:
Modified: grass/trunk/vector/v.type/v.type.html
--- grass/trunk/vector/v.type/v.type.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.type/v.type.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -10,7 +10,7 @@
</pre></div>
<h2>SEE ALSO</h2>
-<em><a href="v.to.points.html">v.to.points</A></em>
+<em><a href="v.to.points.html">v.to.points</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.univar/v.univar.html
--- grass/trunk/vector/v.univar/v.univar.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.univar/v.univar.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
Variance and standard deviation is calculated only for points if
<tt>type=point</tt> is defined.
-<p>
-Extended statistics adds median, 1st and 3rd quartiles, and 90th
+<p>Extended statistics adds median, 1st and 3rd quartiles, and 90th
percentile.
<h2>EXAMPLE</h2>
@@ -25,7 +24,7 @@
<h2>SEE ALSO</h2>
-<em><a href="v.neighbors.html">v.neighbors</A></em>
+<em><a href="v.neighbors.html">v.neighbors</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/vector/v.vect.stats/v.vect.stats.html
--- grass/trunk/vector/v.vect.stats/v.vect.stats.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.vect.stats/v.vect.stats.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -13,8 +13,7 @@
a new value is detmined with the selected method.
<em>v.vect.stats</em> can perform the following operations:
-<p>
-<dl>
+<p><dl>
<dt><b>sum</b>
@@ -74,8 +73,7 @@
(no centroid attached or centroid without category) are ignored.
If no points are falling into a given area, the point count is set to 0
(zero) and the statistics result to "null".
-<p>
-The columns <em>count_column</em> and <em>stats_column</em> are created if not
+<p>The columns <em>count_column</em> and <em>stats_column</em> are created if not
existing. If they do already exist, the <em>count_column</em> must be of
type integer and the <em>stats_column</em> of type double.
Modified: grass/trunk/vector/v.vol.rst/v.vol.rst.html
--- grass/trunk/vector/v.vol.rst/v.vol.rst.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.vol.rst/v.vol.rst.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -138,11 +138,9 @@
very long time, so it might be worth to use just a sample data
representing the whole dataset.
-<p>
-<i>Example
+<p><i>Example
(based on <a href="http://www.grassbook.org/data_menu2nd.phtml">Slovakia3d dataset</a>):</i>
-<p>
-<div class="code"><pre>
+<p><div class="code"><pre>
v.info -c precip3d
v.vol.rst -c input=precip3d wcolumn=precip zmult=50 segmax=700 cvdev=cvdevmap tension=10
v.db.select cvdevmap
@@ -152,15 +150,13 @@
Based on these results, the parameters will have to be optimized. It is
recommended to plot the CV error as curve while modifying
the parameters.
-<p>
-The best approach is to start with <b>tension</b>, <b>smooth</b>
+<p>The best approach is to start with <b>tension</b>, <b>smooth</b>
and <b>zmult</b> with rough steps, or to set <b>zmult</b> to a
constant somewhere between 30-60. This helps to find minimal RMSE
values while then finer steps can be used in all parameters. The
reasonable range is <b>tension</b>=10...100,
<b>smooth</b>=0.1...1.0, <b>zmult</b>=10...100.
-<p>
-In <em>v.vol.rst</em> the tension parameter is much more sensitive to
+<p>In <em>v.vol.rst</em> the tension parameter is much more sensitive to
changes than in <em>v.surf.rst</em>,
therefore the user should always check the
result by visual inspection. Minimizing CV does not always provide the best
Modified: grass/trunk/vector/v.voronoi/v.voronoi.html
--- grass/trunk/vector/v.voronoi/v.voronoi.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.voronoi/v.voronoi.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -2,11 +2,9 @@
<em>v.voronoi</em> uses an existing vector points map (<b>input</b>) to create
a Voronoi diagram (Thiessen polygons) in a new vector map (<b>output</b>).
-<p>
-The bounds of the output map are limited by the current region.
+<p>The bounds of the output map are limited by the current region.
(see <em>g.region</em>)
<p>
<br>
Voronoi diagram and Delaunay triangulation example:
<center>
@@ -24,9 +22,9 @@
Voronoi diagrams may be used for nearest-neighbor flood filling.
Give the centroids attributes (start with
-<em><a href="v.db.addcolumn.html">v.db.addcolumn</A></em>),
+<em><a href="v.db.addcolumn.html">v.db.addcolumn</a></em>),
then optionally convert to a raster map with
-<em><a href="v.to.rast.html">v.to.rast</A></em>.
+<em><a href="v.to.rast.html">v.to.rast</a></em>.
<h2>EXAMPLE</h2>
@@ -66,9 +64,9 @@
<h2>SEE ALSO</h2>
<em>
-<a href="g.region.html">g.region</A>,
-<a href="v.delaunay.html">v.delaunay</A>,
-<a href="v.hull.html">v.hull</A>
+<a href="g.region.html">g.region</a>,
+<a href="v.delaunay.html">v.delaunay</a>,
+<a href="v.hull.html">v.hull</a>
</em>
@@ -77,5 +75,4 @@
GRASS 5 update, improvements: <a href="mailto:aaime at libero.it">Andrea Aime</a>, Modena, Italy<br>
GRASS 5.7 update: Radim Blazek
-<p>
Modified: grass/trunk/vector/v.what/v.what.html
--- grass/trunk/vector/v.what/v.what.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.what/v.what.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -6,8 +6,7 @@
<em>d.what.vect</em> module by removing all interactive code and
modification of the output for easy parsing. Using the <em>-g</em> flag permits to
generate script style output which is easily parsable.
-<p>
-This module always reports standard acres, even when the location uses
+<p>This module always reports standard acres, even when the location uses
US Survey feet as the map unit.
@@ -29,5 +28,4 @@
Trevor Wiens<br>
Edmonton, Alberta, Canada
-<p>
Modified: grass/trunk/vector/v.what.rast/v.what.rast.html
--- grass/trunk/vector/v.what.rast/v.what.rast.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/vector/v.what.rast/v.what.rast.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -21,8 +21,7 @@
v.what.rast vect=pnts rast=elevation col=heights
</pre></div>
-<p>
-B) In case of a vector map without attached attribute table, first add
+<p>B) In case of a vector map without attached attribute table, first add
a new attribute table. This table is then populated with values
queried from the raster map:
<br>
@@ -57,5 +56,4 @@
<h2>AUTHOR</h2>
Radim Blazek
-<p>
Modified: grass/trunk/visualization/wximgview/wximgview.html
--- grass/trunk/visualization/wximgview/wximgview.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/visualization/wximgview/wximgview.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -42,5 +42,4 @@
<h2>AUTHOR</h2>
Glynn Clements
-<p>
Modified: grass/trunk/visualization/xganim/xganim.html
--- grass/trunk/visualization/xganim/xganim.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/visualization/xganim/xganim.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -8,15 +8,13 @@
left of the controls. Each raster map is read into memory, then the
animation is played once beginning to end. The user may then replay
the series or play continuous animation by using the buttons.
-<p>
-The user may define up to four "views", or sub-windows, to animate
+<p>The user may define up to four "views", or sub-windows, to animate
simultaneously. e.g., View 1 could be rainfall, View 2 flooded areas,
View 3 damage to bridges or levees, View 4 other economic damage, all
animated as a time series. There is an arbitrary limit of 400 files
per view (400 animation frames), but the practical limit may be less
depending on the window size and amount of available RAM.
-<p>
-The environment variable XGANIM_SIZE is checked for a value to use as
+<p>The environment variable XGANIM_SIZE is checked for a value to use as
the dimension, in pixels, of the longest dimension of the animation
window. If XGANIM_SIZE is not set, the animation size defaults to the
rows & columns in the current GRASS region, scaling if necessary
@@ -24,11 +22,9 @@
the current GRASS region is maintained, independent of window size.
Resizing the window after the program is running will have no effect
on the animation size.
-<p>
-UNIX - style wild cards may be used with the command line version in
+<p>UNIX - style wild cards may be used with the command line version in
place of a raster map name, but it must be quoted.
-<p>
-If the number of files differs for each view, the view with the fewest
+<p>If the number of files differs for each view, the view with the fewest
files will determine the number of frames in the animation.
<h2>EXAMPLE</h2>
Modified: grass/trunk/visualization/ximgview/ximgview.html
--- grass/trunk/visualization/ximgview/ximgview.html 2011-11-08 13:58:55 UTC (rev 49147)
+++ grass/trunk/visualization/ximgview/ximgview.html 2011-11-08 21:24:20 UTC (rev 49148)
@@ -42,5 +42,4 @@
<h2>AUTHOR</h2>
Glynn Clements
-<p>
