[GRASS-SVN] r49151 - in grass/trunk/temporal: . tr.to.rast3
svn_grass at osgeo.org
Tue Nov 8 18:12:40 EST 2011
Author: huhabla
Date: 2011-11-08 15:12:40 -0800 (Tue, 08 Nov 2011)
New Revision: 49151
Added:
grass/trunk/temporal/tr.to.rast3/
grass/trunk/temporal/tr.to.rast3/Makefile
grass/trunk/temporal/tr.to.rast3/test.tr.to.rast3.sh
grass/trunk/temporal/tr.to.rast3/tr.to.rast3.html
grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py
grass/trunk/temporal/Makefile
New module to convert space time raster datasets into raster3d maps
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2011-11-08 22:33:51 UTC (rev 49150)
+++ grass/trunk/temporal/Makefile 2011-11-08 23:12:40 UTC (rev 49151)
@@ -7,11 +7,13 @@
t.list \
t.info \
t.remove \
+ t.sample \
t.time.abs \
t.time.rel \
tr.aggregate \
tr.aggregate.ds \
tr.register \
+ tr.to.rast3 \
tr.list \
tv.list \
tr3.list \
Added: grass/trunk/temporal/tr.to.rast3/Makefile
--- grass/trunk/temporal/tr.to.rast3/Makefile (rev 0)
+++ grass/trunk/temporal/tr.to.rast3/Makefile 2011-11-08 23:12:40 UTC (rev 49151)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = tr.to.rast3
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/tr.to.rast3/test.tr.to.rast3.sh
--- grass/trunk/temporal/tr.to.rast3/test.tr.to.rast3.sh (rev 0)
+++ grass/trunk/temporal/tr.to.rast3/test.tr.to.rast3.sh 2011-11-08 23:12:40 UTC (rev 49151)
@@ -0,0 +1,33 @@
+# This is a test to register and unregister raster maps in
+# space time raster input.
+# The raster maps will be registered in different space time raster
+# inputs
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create two space time raster inputs
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=1 res=10 res3=1 -p3
+r.mapcalc --o expr="prec_1 = 100"
+r.mapcalc --o expr="prec_2 = 200"
+r.mapcalc --o expr="prec_3 = 300"
+r.mapcalc --o expr="prec_4 = 400"
+r.mapcalc --o expr="prec_5 = 500"
+r.mapcalc --o expr="prec_6 = 600"
+# The first @test
+# We create the space time raster inputs and register the raster maps with absolute time interval
+t.create --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
+tr.register -i input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
+tr.to.rast3 --o input=precip_abs output=prec_sum
+t.remove type=rast input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs
+r3.info prec_sum
Added: grass/trunk/temporal/tr.to.rast3/tr.to.rast3.html
Added: grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py
--- grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py (rev 0)
+++ grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py 2011-11-08 23:12:40 UTC (rev 49151)
@@ -0,0 +1,114 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: tr.to.rast3
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Convert a space time raster dataset into a rast3d map
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Convert a space time raster dataset into a rast3d map
+#% keywords: dataset
+#% keywords: spacetime
+#% keywords: raster
+#% keywords: raster3d
+#%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of a space time raster dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option G_OPT_R3_OUTPUT
+#%end
+import os
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ mapset = grass.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
+ sp = tgis.space_time_raster_dataset(id)
+ if sp.is_in_db() == False:
+ grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
+ sp.select()
+ # Compute relative granularity and set bottom, top and resolution
+ granularity = sp.get_granularity()
+ if sp.is_time_absolute():
+ start, end = sp.get_valid_time()
+ end = tgis.increment_datetime_by_string(start, granularity)
+ granularity = tgis.time_delta_to_relative_time(end - start)
+ maps = sp.get_registered_maps_as_objects_by_granularity()
+ num_maps = len(maps)
+ bottom = 0
+ top = granularity * num_maps
+ ret = grass.run_command("g.region", t=top, b=bottom, tbres=granularity)
+ if ret != 0:
+ grass.fatal(_("Unable to set 3d region"))
+ # Create a NULL map in case of granularity support
+ null_map = "temporary_null_map_%i" % os.getpid()
+ grass.mapcalc("%s = null()" % (null_map))
+ if maps:
+ count = 0
+ map_names = ""
+ for map in maps:
+ # Use the first map
+ id = map[0].get_id()
+ # None ids will be replaced by NULL maps
+ if id == None:
+ id = null_map
+ if count == 0:
+ map_names = id
+ else:
+ map_names += ",%s" % id
+ count += 1
+ ret = grass.run_command("r.to.rast3", input=map_names, output=output, overwrite=grass.overwrite())
+ if ret != 0:
+ grass.fatal(_("Unable to create raster3d map <%s>" % output))
+ grass.run_command("g.remove", rast=null_map)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py
___________________________________________________________________
Added: svn:executable
