[GRASS-SVN] r49155 - grass/branches/develbranch_6/gui/wxpython
svn_grass at osgeo.org
Wed Nov 9 10:47:39 EST 2011
Author: martinl
Date: 2011-11-09 07:47:39 -0800 (Wed, 09 Nov 2011)
New Revision: 49155
Removed:
grass/branches/develbranch_6/gui/wxpython/build_ext.py
wxGUI: remove unused file
Deleted: grass/branches/develbranch_6/gui/wxpython/build_ext.py
--- grass/branches/develbranch_6/gui/wxpython/build_ext.py 2011-11-09 15:41:41 UTC (rev 49154)
+++ grass/branches/develbranch_6/gui/wxpython/build_ext.py 2011-11-09 15:47:39 UTC (rev 49155)
@@ -1,62 +0,0 @@
-# Build wxGUI extensions (vdigit and nviz)
-import os
-import sys
-def __read_variables(file, dict={}):
- """!Read variables from file (e.g. Platform.make)
- @param file file descriptor
- @param dict dictionary to store (variable, value)
- for line in file.readlines():
- if len(line) < 1:
- continue # skip empty lines
- if line[0] == '#':
- continue # skip comments
- try:
- var, val = line.split('=', 1)
- except ValueError:
- continue
- dict[var.strip()] = val.strip()
-def update_opts(flag, macros, inc_dirs, lib_dirs, libs, extras):
- """!Update Extension options"""
- global variables
- line = variables[flag]
- fw_next = False
- for val in line.split(' '):
- key = val[:2]
- if fw_next:
- extras.append(val)
- fw_next = False
- elif key == '-I': # includes
- inc_dirs.append(val[2:])
- elif key == '-D': # macros
- if '=' in val[2:]:
- macros.append(tuple(val[2:].split('=')))
- else:
- macros.append((val[2:], None))
- elif key == '-L': # libs dir
- lib_dirs.append(val[2:])
- elif key == '-l':
- libs.append(val[2:])
- elif key == '-F': # frameworks dir
- elif val == '-framework':
- fw_next = True
-try:
- Platform_make = open(os.path.join('..', '..', '..',
- 'include', 'Make', 'Platform.make'))
- Grass_make = open(os.path.join('..', '..', '..',
- 'include', 'Make', 'Grass.make'))
-except IOError, e:
- print 'Unable to compile wxGUI vdigit extension.\n\n', e
- sys.exit(1)
-variables = {}
-__read_variables(Platform_make, variables)
-__read_variables(Grass_make, variables)
