[GRASS-SVN] r49166 - in grass/trunk: lib/python raster/r.info
svn_grass at osgeo.org
Thu Nov 10 04:46:21 EST 2011
Author: lucadelu
Date: 2011-11-10 01:46:21 -0800 (Thu, 10 Nov 2011)
New Revision: 49166
grass/trunk/lib/python/raster.py
grass/trunk/raster/r.info/main.c
standardize r.info with -g flag for shell output and remove several other flags, like v.info
Modified: grass/trunk/lib/python/raster.py
--- grass/trunk/lib/python/raster.py 2011-11-10 08:33:22 UTC (rev 49165)
+++ grass/trunk/lib/python/raster.py 2011-11-10 09:46:21 UTC (rev 49166)
@@ -73,7 +73,7 @@
else:
return float(s)
- s = read_command('r.info', flags = 'rgstmpud', map = map)
+ s = read_command('r.info', flags = 'g', map = map)
kv = parse_key_val(s)
for k in ['min', 'max']:
kv[k] = float_or_null(kv[k])
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c 2011-11-10 08:33:22 UTC (rev 49165)
+++ grass/trunk/raster/r.info/main.c 2011-11-10 09:46:21 UTC (rev 49166)
@@ -60,9 +60,8 @@
struct Reclass reclass;
struct GModule *module;
struct Option *opt1;
- struct Flag *rflag, *sflag, *tflag, *gflag, *hflag, *mflag;
- struct Flag *uflag, *dflag, *timestampflag;
+ struct Flag *gflag, *hflag;
/* Initialize GIS Engine */
G_gisinit(argv[0]);
@@ -74,44 +73,14 @@
opt1 = G_define_standard_option(G_OPT_R_MAP);
- rflag = G_define_flag();
- rflag->key = 'r';
- rflag->description = _("Print range only");
- sflag = G_define_flag();
- sflag->key = 's';
- sflag->description =
- _("Print raster map resolution (NS-res, EW-res) only");
- tflag = G_define_flag();
- tflag->key = 't';
- tflag->description = _("Print raster map type only");
gflag = G_define_flag();
gflag->key = 'g';
- gflag->description = _("Print map region only");
+ gflag->description = _("Print basic info in shell script style");
hflag = G_define_flag();
hflag->key = 'h';
hflag->description = _("Print raster history instead of info");
- uflag = G_define_flag();
- uflag->key = 'u';
- uflag->description = _("Print raster map data units only");
- dflag = G_define_flag();
- dflag->key = 'd';
- dflag->description = _("Print raster map vertical datum only");
- mflag = G_define_flag();
- mflag->key = 'm';
- mflag->description = _("Print map title only");
- timestampflag = G_define_flag();
- timestampflag->key = 'p';
- timestampflag->description =
- _("Print raster map timestamp (day.month.year hour:minute:seconds) only");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -145,9 +114,8 @@
out = stdout;
- if (!rflag->answer && !sflag->answer && !tflag->answer &&
- !gflag->answer && !hflag->answer && !timestampflag->answer &&
- !mflag->answer && !uflag->answer && !dflag->answer) {
+ /* no flags */
+ if (!gflag->answer && !hflag->answer) {
divider('+');
compose_line(out, "Layer: %-29.29s Date: %s", name,
@@ -320,9 +288,10 @@
fprintf(out, "\n");
- else { /* r,s,t,g,h, or m flag */
+ else { /* g,h flag */
- if (rflag->answer) {
+ if (gflag->answer) {
+ /* old rflag */
if (data_type == CELL_TYPE) {
if (2 == Rast_read_range(name, "", &crange)) {
fprintf(out, "min=NULL\n");
@@ -341,10 +310,7 @@
fprintf(out, "min=%.15g\n", zmin);
fprintf(out, "max=%.15g\n", zmax);
- if (gflag->answer) {
G_format_northing(cellhd.north, tmp1, -1);
G_format_northing(cellhd.south, tmp2, -1);
fprintf(out, "north=%s\n", tmp1);
@@ -354,47 +320,46 @@
G_format_easting(cellhd.west, tmp2, -1);
fprintf(out, "east=%s\n", tmp1);
fprintf(out, "west=%s\n", tmp2);
- if (sflag->answer) {
+ /* old sflag */
G_format_resolution(cellhd.ns_res, tmp3, cellhd.proj);
fprintf(out, "nsres=%s\n", tmp3);
G_format_resolution(cellhd.ew_res, tmp3, cellhd.proj);
fprintf(out, "ewres=%s\n", tmp3);
- if (tflag->answer) {
+ /* new rows and columns parameters */
+ fprintf(out, "rows=%d\n", cellhd.rows);
+ fprintf(out, "cols=%d\n", cellhd.cols);
+ /* old tflag */
fprintf(out, "datatype=%s\n",
(data_type == CELL_TYPE ? "CELL" :
(data_type == DCELL_TYPE ? "DCELL" :
(data_type == FCELL_TYPE ? "FCELL" : "??"))));
- if (mflag->answer) {
+ /* old mflag */
fprintf(out, "title=%s (%s)\n", cats_ok ? cats.title :
"??", hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??");
- if (timestampflag->answer) {
+ /* old timestampflag */
if (time_ok && (first_time_ok || second_time_ok)) {
G_format_timestamp(&ts, timebuff);
/*Create the r.info timestamp string */
fprintf(out, "timestamp=\"%s\"\n", timebuff);
else {
fprintf(out, "timestamp=\"none\"\n");
+ /* old uflag */
+ fprintf(out, "units=%s\n", units ? units : "(none)");
+ /* old dflag */
+ fprintf(out, "vertical_datum=%s\n", vdatum ? vdatum : "(none)");
- if (uflag->answer)
- fprintf(out, "units=%s\n", units ? units : "(none)");
- if (dflag->answer)
- fprintf(out, "vertical_datum=%s\n", vdatum ? vdatum : "(none)");
if (hflag->answer) {
if (hist_ok) {
fprintf(out, "Data Source:\n");
@@ -409,8 +374,7 @@
- } /* else rflag or sflag or tflag or gflag or hflag or mflag */
return EXIT_SUCCESS;
