[GRASS-SVN] r49176 - grass-addons/raster/LandDyn/r.soildepth.py
svn_grass at osgeo.org
Thu Nov 10 16:44:48 EST 2011
Author: isaacullah
Date: 2011-11-10 13:44:48 -0800 (Thu, 10 Nov 2011)
New Revision: 49176
grass-addons/raster/LandDyn/r.soildepth.py/r.soildepth.py
Updated code to use internal grass python libs. This should also have the effect of making this script useable in GRASS 7, but I have not tested to see if this is the case.
Modified: grass-addons/raster/LandDyn/r.soildepth.py/r.soildepth.py
--- grass-addons/raster/LandDyn/r.soildepth.py/r.soildepth.py 2011-11-10 18:55:27 UTC (rev 49175)
+++ grass-addons/raster/LandDyn/r.soildepth.py/r.soildepth.py 2011-11-10 21:44:48 UTC (rev 49176)
@@ -3,11 +3,11 @@
# MODULE: r.soildepth
-# AUTHOR(S): Isaac Ullah, Arizona State University
+# AUTHOR(S): Isaac Ullah and Claudine Gravel-Miguel, Arizona State University
# PURPOSE: Create soil depth map based on hillslope curvature.
# ACKNOWLEDGEMENTS: National Science Foundation Grant #BCS0410269
# Based on equations from Heimsath et al, 1997
-# COPYRIGHT: (C) 2007 by Isaac Ullah, Michael Barton, Arizona State University
+# COPYRIGHT: (C) 2011 by Isaac Ullah, Michael Barton, Claudine Gravel-Miguel Arizona State University
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
@@ -37,7 +37,7 @@
#% type: string
#% gisprompt: old,cell,raster
#% description: Output soil depths map
-#% required : no
+#% required : yes
#%END
#%option
#% key: min
@@ -66,27 +66,10 @@
import os
import subprocess
import tempfile
+grass_install_tree = os.getenv('GISBASE')
+sys.path.append(grass_install_tree + os.sep + 'etc' + os.sep + 'python')
+import grass.script as grass
-# m is a message (as a string) one wishes to have printed in the output window
-def grass_print(m):
- subprocess.Popen('g.message message="%s"' % m, shell='bash').wait()
- return
-# m is grass (or bash) command to execute (written as a string). script will wait for grass command to finish
-def grass_com(m):
- subprocess.Popen('%s' % m, shell='bash').wait()
- return
-# m is a grass/bash command that will generate some list of keyed info to stdout, n is the character that seperates the key from the data, o is a defined blank dictionary to write results to
-def out2dict(m, n, o):
- p1 = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
- p2 = p1.stdout.readlines()
- for y in p2:
- y0,y1 = y.split('%s' % n)
- o[y0] = y1.strip('\n')
-# m is a grass/bash command that will generate some info to stdout. You must invoke this command in the form of "variable to be made" = out2var('command')
-def out2var(m):
- pn = subprocess.Popen('%s' % m, stdout=subprocess.PIPE, shell='bash')
- return pn.stdout.read()
def main():
if os.getenv('GIS_OPT_soildepth') == None:
soildepth = "temp.soildepth"
@@ -101,49 +84,46 @@
tc = "temp_tc_deletable"
temprate = "temp_rate_deletable"
#let's grab the current resolution
- reg1 = {}
- out2dict('g.region -p -m -g', '=', reg1)
- res = int(float(reg1['nsres']))
+ res = grass.region()['nsres']
# make color rules for soil depth maps
sdcolors = tempfile.NamedTemporaryFile()
sdcolors.write('100% 0:249:47\n20% 78:151:211\n6% 194:84:171\n0% 227:174:217')
sdcolors.flush()
- grass_print('STEP 1, calculating profile and tangental curvatures\n')
- grass_com('r.slope.aspect --quiet --overwrite format=percent elevation=%s slope=%s pcurv=%s tcurv=%s' % (elev, slope, pc, tc))
- grass_print('STEP 2, Calculating soil depth ratios across the landscape\n')
- grass_com('r.mapcalc "' + temprate + '=eval(x = (-1*(' + pc + '+' + tc + ')), y = (if(' + slope + ' < 1, 1, ' + slope + ')), ((50*x)+50)/y)"')
+ grass.message('STEP 1, calculating profile and tangental curvatures\n')
+ grass.run_command('r.slope.aspect', quiet = "True", overwrite = "True", format='percent', elevation=elev, slope=slope, pcurv=pc, tcurv=tc)
+ grass.message('STEP 2, Calculating soil depth ratios across the landscape\n')
+ grass.mapcalc("${temprate}=eval(x = (-1.000*(${pc} + ${tc})), y = (if(${slope} < 1.000, 1.000, ${slope})), ((50.000*x)+50.000)/y)", quiet = "True", temprate = temprate, pc = pc, tc = tc, slope = slope)
# create dictionary to record max and min rate so we can rescale it according the user supplied max and min desired soil depths
- ratedict = {}
- out2dict('r.info -r map=%s' % temprate, '=', ratedict)
- grass_print('STEP 3, Calculating actual soil depths across the landscape (based on user input min and max soil depth values)\n')
+ ratedict = grass.parse_command('r.info', flags = 'r', map=temprate)
+ grass.message('STEP 3, Calculating actual soil depths across the landscape (based on user input min and max soil depth values)\n')
#creating and running a linear regression to scale the calculated landform soil depth ratios into real soil dpeths using user specified min and max soil depth values
#grass_com('r.mapcalc "' + soildepth + '=eval(x = ((' + ratedict['max'] + '-' + max +')/(' + ratedict['min'] + '-' + min + ')), y = (' + ratedict['max'] + '-(y*' + ratedict['min'] + ')), (y*' + temprate + ')+x)"') #####this is the discreet way using mapcalc, I thik the r.recode way (below) may be faster
recode = tempfile.NamedTemporaryFile()
recode.write('%s:%s:%s:%s' % (ratedict['min'] , ratedict['max'] , min, max))
recode.flush()
- grass_com('r.recode --quiet input=%s output=%s rules=%s' % (temprate, soildepth, recode.name))
+ grass.run_command('r.recode', quiet = "True", input=temprate, output=soildepth, rules=recode.name)
recode.close()
#grab some stats if asked to
if os.getenv('GIS_FLAG_s') == '1':
- depthdict = {}
- out2dict('r.univar -ge map=' + soildepth + ' percentile=90', '=', depthdict)
- grass_print('STEP 4, calculating bedrock elevation map\n')
- grass_com('r.mapcalc "' + bedrock + '=(' + elev + ' - ' + soildepth + ')"')
- grass_print('Cleaning up...')
+ depthdict = grass.parse_command('r.univar', flags = "ge", map=soildepth, percentile=90)
+ grass.message('STEP 4, calculating bedrock elevation map\n')
+ grass.mapcalc("${bedrock}=(${elev} - ${soildepth})", quiet = "True", bedrock = bedrock, elev = elev, soildepth = soildepth)
+ grass.message('Cleaning up...')
if os.getenv('GIS_FLAG_k') == '1':
- grass_com('g.remove --quiet rast=' + pc + ',' + tc)
- grass_com('g.rename --quiet rast=' + temprate + ',' + bedrock + '_rate')
+ grass.run_command('g.remove', quiet = "true", rast = [pc, tc, slope])
+ grass.run_command('g.rename', quiet = "true", rast = "%s,%s%s_rate" % (temprate, temprate, bedrock))
else:
- grass_com('g.remove --quiet rast=' + pc + ',' + tc + ',' + temprate)
+ grass.run_command('g.remove', quiet = "True", rast = [pc, tc, temprate, slope])
if os.getenv('GIS_OPT_soildepth') is None:
- grass_com('g.remove --quiet rast=' + soildepth)
+ grass.run_command('g.remove', quiet = "true", rast = soildepth)
else:
- grass_com('r.colors --quiet map=%s rules=%s' % (soildepth , sdcolors.name))
- grass_print('\nDONE!\n')
+ grass.run_command('r.colors', quiet = "True", map=soildepth, rules=sdcolors.name)
+ grass.message('\nDONE!\n')
+ # have to figure that part out!
for key in depthdict.keys():
- grass_print('%s=%s' % (key, depthdict[key]))
- grass_print('Total volume of soil is %s cubic meters' % (float(depthdict['sum'])*res))
+ grass.message('%s=%s' % (key, depthdict[key]))
+ grass.message('Total volume of soil is %s cubic meters' % (float(depthdict['sum'])*res))
return
# here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run.
