[GRASS-SVN] r49188 - grass-addons/grass7/raster/r.agent
svn_grass at osgeo.org
Sun Nov 13 05:46:01 EST 2011
Author: mic
Date: 2011-11-13 02:46:01 -0800 (Sun, 13 Nov 2011)
New Revision: 49188
grass-addons/grass7/raster/r.agent/r.agent.aco
prepare refactoring
Modified: grass-addons/grass7/raster/r.agent/r.agent.aco
--- grass-addons/grass7/raster/r.agent/r.agent.aco 2011-11-13 09:16:33 UTC (rev 49187)
+++ grass-addons/grass7/raster/r.agent/r.agent.aco 2011-11-13 10:46:01 UTC (rev 49188)
@@ -29,9 +29,13 @@
#% key: inputmap
#% type: string
#% gisprompt: old,cell,raster
-#% description: Name of pheromone map, input raster data (e.g. from prior run)
+#% description: Name of input pheromone map, raster data (e.g. from prior run)
#% required : no
#%end
+#%flag
+#% key: overwrite
+#% description: Allow overwriting existing maps
+#%end
#%option
#% key: penaltymap
#% type: string
@@ -50,7 +54,8 @@
#% key: rounds
#% type: integer
#% gisprompt: number
-#% description: Number of rounds to run
+#% description: Number of rounds to run (iterations)
+#% answer: 999
#% options: 0-999999
#% required : yes
#%end
@@ -59,6 +64,7 @@
#% type: integer
#% description: Produce output after this number of rounds run
+#% answer: 999
#% required : no
#%end
@@ -83,6 +89,7 @@
#% type: integer
#% description: Absolute maximum of pheromone intensity a position may have
+#% answer: 999999999
#% options: <minpheromone>-<max integer on system would make sense>
#% required : no
#%end
@@ -91,6 +98,7 @@
#% type: integer
#% description: Absolute minimum of pheromone intensity to leave on playground
+#% answer: 9
#% options: 0-<maxpheromone>
#% required : no
#%end
@@ -98,7 +106,7 @@
#% key: volatilizationtime
#% type: integer
-#% description: Half-life for pheromone to volatize
+#% description: Half-life for pheromone to volatize (e.g. =rounds)
#% options: 0-<max integer on system would make sense>
#% required : no
#%end
@@ -107,6 +115,7 @@
#% type: integer
#% description: Pheromone intensity to leave on each step
+#% answer: 9
#% required : no
#%end
@@ -115,6 +124,7 @@
#% type: integer
#% description: Pheromone intensity to leave on found paths
+#% answer: 999
#% required : no
#%end
@@ -130,8 +140,8 @@
#% key: antslife
#% type: integer
-#% description: Time to live for an ant
-#% options: 0-<e.g. for times distance between points>
+#% description: Time to live for an ant (e.g. for times points distance)
+#% options: 0-<max integer on system would make sense>
#% required : no
#%end
#%option
@@ -139,6 +149,7 @@
#% type: string
#% gisprompt: algorithm
#% description: What algorithm is used for walking step
+#% answer: standard
#% options: standard,random,test
#% required : no
#%end
@@ -146,7 +157,8 @@
#% key: validposition
#% type: string
-#% description: What algorithm is used for finding and remembering paths
+#% description: What algorithm is used for finding and remembering paths
+#% answer: avoidorforgetloop
#% options: specials,avoidloop,forgetloop,avoidorforgetloop
#% required : no
#%end
@@ -163,6 +175,7 @@
#% type: integer
#% description: How is the pheromone value weighted when walking
+#% answer: 1
#% options: 0-999
#% required : no
#%end
@@ -171,6 +184,7 @@
#% type: integer
#% description: How is the random value weighted when walking
+#% answer: 1
#% options: 0-999
#% required : no
#%end
@@ -179,6 +193,7 @@
#% type: integer
#% description: How is the penalty value weighted when walking
+#% answer: 1
#% options: 0-999
#% required : no
#%end
