[GRASS-SVN] r49218 - in grass/trunk/gui/wxpython: . gui_modules
Mon Nov 14 02:58:29 EST 2011
Author: martinl
Date: 2011-11-13 23:58:29 -0800 (Sun, 13 Nov 2011)
New Revision: 49218
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/gui_modules/gselect.py
   grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI: various import-oriented fixes
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2011-11-14 07:57:15 UTC (rev 49217)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2011-11-14 07:58:29 UTC (rev 49218)
@@ -1248,7 +1248,9 @@
         list = self.FindWindowById(self.layerPage[self.layer]['data'])
         cats = map(int, list.GetSelectedItems())
-        digitToolbar = self.mapdisplay.toolbars['vdigit']
+        digitToolbar = None
+        if 'vdigit' in self.mapdisplay.toolbars:
+            digitToolbar = self.mapdisplay.toolbars['vdigit']
         if digitToolbar and digitToolbar.GetLayer() and \
                 digitToolbar.GetLayer().GetName() == self.vectorName:
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-11-14 07:57:15 UTC (rev 49217)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-11-14 07:58:29 UTC (rev 49218)
@@ -1993,7 +1993,7 @@
         if len(columns) == 3:
             width = (65, 200)
         else:
-            width = (65, 200, 90)
+            width = (65, 180, 110)
         for i in range(len(width)):
             self.SetColumnWidth(col = i, width = width[i])
@@ -2007,14 +2007,15 @@
             return
         self.DeleteAllItems()
         for item in data:
             index = self.InsertStringItem(sys.maxint, str(item[0]))
             for i in range(1, len(item)):
                 self.SetStringItem(index, i, "%s" % str(item[i]))
-            # check by default
-            ### self.CheckItem(index, True)
+        # check by default only on one item
+        if len(data) == 1:
+            self.CheckItem(index, True)
     def OnPopupMenu(self, event):
         """!Show popup menu"""
         if self.GetItemCount() < 1:
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py	2011-11-14 07:57:15 UTC (rev 49217)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py	2011-11-14 07:58:29 UTC (rev 49218)
@@ -560,14 +560,11 @@
     def _CheckDBConnection(self):
         """!Check DB connection"""
         nuldev = file(os.devnull, 'w+')
-        self.layers = grass.vector_db(map=self.map, stderr=nuldev)
+        self.layers = grass.vector_db(map = self.map, stderr = nuldev)
         nuldev.close()
-        if (len(self.layers.keys()) == 0):
-            return False
-        return True
+        return bool(len(self.layers.keys()) > 0)
     def _DescribeTables(self):
         """!Describe linked tables"""
         for layer in self.layers.keys():
@@ -1484,13 +1481,6 @@
         win.SetValue('')
         win.Show()
-        if sel in (self.sourceMap['file'],
-                   self.sourceMap['dir']):
-            if not self.ogr:
-                self.OnSetFormat(event = None, format = 'GeoTIFF')
-            else:
-                self.OnSetFormat(event = None, format = 'ESRI Shapefile')
         if sel == self.sourceMap['native']: # native
             win.Enable(False)
             self.format.Enable(False)
@@ -1506,6 +1496,13 @@
             if self.parent.GetName() == 'MultiImportDialog':
                 self.parent.list.DeleteAllItems()
+        if sel in (self.sourceMap['file'],
+                   self.sourceMap['dir']):
+            if not self.ogr:
+                self.OnSetFormat(event = None, format = 'GeoTIFF')
+            else:
+                self.OnSetFormat(event = None, format = 'ESRI Shapefile')
         if sel == self.sourceMap['dir'] and not self.dest:
             if not self.extension.IsShown():
                 self.extensionText.Show()
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox	2011-11-14 07:57:15 UTC (rev 49217)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox	2011-11-14 07:58:29 UTC (rev 49218)
@@ -1,4 +1,4 @@
-/*! \page wxpythonlib GRASS WxPython-based Graphical User Interface
+/*! \page wxpythonlib GRASS wxPython-based GUI
 The GUI (Graphical User Interface) is written in the Python
 programming language using <a
