[GRASS-SVN] r49228 - grass/trunk/vector/v.what
svn_grass at osgeo.org
Mon Nov 14 03:16:13 EST 2011
Author: martinl
Date: 2011-11-14 00:16:12 -0800 (Mon, 14 Nov 2011)
New Revision: 49228
grass/trunk/vector/v.what/main.c
grass/trunk/vector/v.what/what.c
grass/trunk/vector/v.what/what.h
v.what: clean up, east_north requires '-' for standard input
Modified: grass/trunk/vector/v.what/main.c
--- grass/trunk/vector/v.what/main.c 2011-11-14 08:14:43 UTC (rev 49227)
+++ grass/trunk/vector/v.what/main.c 2011-11-14 08:16:12 UTC (rev 49228)
@@ -11,7 +11,7 @@
* the interactive component to enable its use with the new
* gis.m and future GUI.
- * COPYRIGHT: (C) 2006-2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2010, 2011 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -29,16 +29,22 @@
#include <grass/glocale.h>
#include "what.h"
-char **vect;
-int nvects;
-struct Map_info *Map;
int main(int argc, char **argv)
- struct Flag *printattributes, *topo_flag, *shell_flag;
- struct Option *map_opt, *field_opt, *coords_opt, *maxdistance;
+ struct {
+ struct Flag *print, *topo, *shell;
+ } flag;
+ struct {
+ struct Option *map, *field, *coords, *maxdist;
+ } opt;
struct Cell_head window;
struct GModule *module;
+ char **vect;
+ int nvects;
+ struct Map_info *Map;
char buf[2000];
int i, level, ret;
int *field;
@@ -56,53 +62,47 @@
G_add_keyword(_("querying"));
module->description = _("Queries a vector map at given locations.");
- map_opt = G_define_standard_option(G_OPT_V_MAPS);
+ opt.map = G_define_standard_option(G_OPT_V_MAPS);
- field_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
+ opt.field = G_define_standard_option(G_OPT_V_FIELD_ALL);
+ opt.field->multiple = YES;
- coords_opt = G_define_standard_option(G_OPT_M_EN);
- coords_opt->label = _("Coordinates for query");
- coords_opt->description = _("If not given read from standard input");
+ opt.coords = G_define_standard_option(G_OPT_M_EN);
+ opt.coords->required = YES;
+ opt.coords->label = _("Coordinates for query");
+ opt.coords->description = _("\"-\" to read from standard input");
- maxdistance = G_define_option();
- maxdistance->type = TYPE_DOUBLE;
- maxdistance->key = "distance";
- maxdistance->answer = "0";
- maxdistance->multiple = NO;
- maxdistance->description = _("Query threshold distance");
+ opt.maxdist = G_define_option();
+ opt.maxdist->type = TYPE_DOUBLE;
+ opt.maxdist->key = "distance";
+ opt.maxdist->answer = "0";
+ opt.maxdist->multiple = NO;
+ opt.maxdist->description = _("Query threshold distance");
+ opt.maxdist->guisection = _("Threshold");
+ flag.topo = G_define_flag();
+ flag.topo->key = 'd';
+ flag.topo->description = _("Print topological information (debugging)");
+ flag.topo->guisection = _("Print");
- topo_flag = G_define_flag();
- topo_flag->key = 'd';
- topo_flag->description = _("Print topological information (debugging)");
- topo_flag->guisection = _("Print");
+ flag.print = G_define_flag();
+ flag.print->key = 'a';
+ flag.print->description = _("Print attribute information");
+ flag.print->guisection = _("Print");
- printattributes = G_define_flag();
- printattributes->key = 'a';
- printattributes->description = _("Print attribute information");
- printattributes->guisection = _("Print");
+ flag.shell = G_define_flag();
+ flag.shell->key = 'g';
+ flag.shell->description = _("Print the stats in shell script style");
+ flag.shell->guisection = _("Print");
- shell_flag = G_define_flag();
- shell_flag->key = 'g';
- shell_flag->description = _("Print the stats in shell script style");
- shell_flag->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (map_opt->answers && map_opt->answers[0])
- vect = map_opt->answers;
+ if (opt.map->answers && opt.map->answers[0])
+ vect = opt.map->answers;
- maxd = atof(maxdistance->answer);
+ maxd = atof(opt.maxdist->answer);
- * fprintf(stdout, maxdistance->answer);
- * fprintf(stdout, "Maxd is %f", maxd);
- * fprintf(stdout, xcoord->answer);
- * fprintf(stdout, "xval is %f", xval);
- * fprintf(stdout, ycoord->answer);
- * fprintf(stdout, "yval is %f", yval);
if (maxd == 0.0) {
G_get_window(&window);
x = window.proj;
@@ -129,12 +129,11 @@
/* Look at maps given on command line */
if (vect) {
for (i = 0; vect[i]; i++)
nvects = i;
- for (i = 0; field_opt->answers[i]; i++)
+ for (i = 0; opt.field->answers[i]; i++)
if (nvects != i)
@@ -145,23 +144,23 @@
field = (int *) G_malloc(nvects * sizeof(int));
for (i = 0; i < nvects; i++) {
- level = Vect_open_old2(&Map[i], vect[i], "", field_opt->answers[i]);
+ level = Vect_open_old2(&Map[i], vect[i], "", opt.field->answers[i]);
if (level < 2)
G_fatal_error(_("You must build topology on vector map <%s>"),
vect[i]);
- field[i] = Vect_get_field_number(&Map[i], field_opt->answers[i]);
+ field[i] = Vect_get_field_number(&Map[i], opt.field->answers[i]);
- if (!coords_opt->answer) {
+ if (strcmp(opt.coords->answer, "-") == 0) {
/* read them from stdin */
setvbuf(stdin, NULL, _IOLBF, 0);
setvbuf(stdout, NULL, _IOLBF, 0);
while (fgets(buf, sizeof(buf), stdin) != NULL) {
ret = sscanf(buf, "%lf%c%lf", &xval, &ch, &yval);
if (ret == 3 && (ch == ',' || ch == ' ' || ch == '\t')) {
- what(xval, yval, maxd, topo_flag->answer,
- printattributes->answer, shell_flag->answer, field);
+ what(Map, nvects, vect, xval, yval, maxd, flag.topo->answer,
+ flag.print->answer, flag.shell->answer, field);
else {
G_warning(_("Unknown input format, skipping: '%s'"), buf);
@@ -171,11 +170,11 @@
else {
/* use coords given on command line */
- for (i = 0; coords_opt->answers[i] != NULL; i += 2) {
- xval = atof(coords_opt->answers[i]);
- yval = atof(coords_opt->answers[i + 1]);
+ for (i = 0; opt.coords->answers[i] != NULL; i += 2) {
+ xval = atof(opt.coords->answers[i]);
+ yval = atof(opt.coords->answers[i + 1]);
Modified: grass/trunk/vector/v.what/what.c
--- grass/trunk/vector/v.what/what.c 2011-11-14 08:14:43 UTC (rev 49227)
+++ grass/trunk/vector/v.what/what.c 2011-11-14 08:16:12 UTC (rev 49228)
@@ -16,7 +16,7 @@
const char *tblname, const char *key, int keyval,
char **form)
- int col, ncols, ctype, sqltype, more;
+ int col, ncols, sqltype, more;
char buf[5000];
const char *colname;
dbString sql, html, str;
@@ -78,7 +78,6 @@
for (col = 0; col < ncols; col++) {
column = db_get_table_column(table, col);
sqltype = db_get_column_sqltype(column);
- ctype = db_sqltype_to_Ctype(sqltype);
value = db_get_column_value(column);
db_convert_value_to_string(value, sqltype, &str);
colname = db_get_column_name(column);
@@ -102,7 +101,7 @@
db_free_string(&str);
-void what(double east, double north, double maxdist, int topo, int showextra, int script, int *field)
+void what(struct Map_info *Map, int nvects, char **vect, double east, double north, double maxdist, int topo, int showextra, int script, int *field)
int type;
char east_buf[40], north_buf[40];
Modified: grass/trunk/vector/v.what/what.h
--- grass/trunk/vector/v.what/what.h 2011-11-14 08:14:43 UTC (rev 49227)
+++ grass/trunk/vector/v.what/what.h 2011-11-14 08:16:12 UTC (rev 49228)
@@ -1,6 +1,3 @@
/* what.c */
-extern void what(double, double, double, int, int, int, int*);
-extern char **vect;
-extern int nvects;
-extern struct Map_info *Map;
+void what(struct Map_info *, int, char **,
+ double, double, double, int, int, int, int*);
