[GRASS-SVN] r49236 - grass/trunk/raster/r.drain
svn_grass at osgeo.org
Mon Nov 14 03:54:42 EST 2011
Author: mmetz
Date: 2011-11-14 00:54:42 -0800 (Mon, 14 Nov 2011)
New Revision: 49236
grass/trunk/raster/r.drain/main.c
use standard vector library
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c 2011-11-14 08:30:42 UTC (rev 49235)
+++ grass/trunk/raster/r.drain/main.c 2011-11-14 08:54:42 UTC (rev 49236)
@@ -226,10 +226,6 @@
G_get_window(&window);
nrows = Rast_window_rows();
ncols = Rast_window_cols();
- if (opt4->answer) {
- Points = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
/* calculate true cell resolution */
m = (struct metrics *)G_malloc(nrows * sizeof(struct metrics));
@@ -258,28 +254,43 @@
have_points = 1;
- if (vpointopt->answer) {
+ if (vpointopt->answers) {
for (i = 0; vpointopt->answers[i] != NULL; i++) {
- struct Map_info *fp;
+ struct Map_info In;
+ struct bound_box box;
+ int type;
- /* struct start_pt *new_start_pt; */
- Site *site = NULL; /* pointer to Site */
- int dims, strs, dbls;
- RASTER_MAP_TYPE cat;
+ G_message(_("Reading vector map <%s> with start points..."), vpointopt->answers[i]);
- fp = G_fopen_sites_old(vpointopt->answers[i], "");
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
- if (0 != G_site_describe(fp, &dims, &cat, &strs, &dbls))
- G_fatal_error(_("Failed to guess site file format"));
+ Vect_set_open_level(1); /* topology not required */
- site = G_site_new_struct(cat, dims, strs, dbls);
+ if (1 > Vect_open_old(&In, vpointopt->answers[i], ""))
+ G_fatal_error(_("Unable to open vector map <%s>"), vpointopt->answers[i]);
- for (; (G_site_get(fp, site) != EOF);) {
- if (!G_site_in_region(site, &window))
+ Vect_rewind(&In);
+ Vect_region_box(&window, &box);
+ while (1) {
+ /* register line */
+ type = Vect_read_next_line(&In, Points, Cats);
+ /* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
+ if (type == -1) {
+ G_warning(_("Unable to read vector map"));
continue;
+ else if (type == -2) {
+ break;
+ if (!Vect_point_in_box(Points->x[0], Points->y[0], 0, &box))
+ continue;
- start_col = (int)Rast_easting_to_col(site->east, &window);
- start_row = (int)Rast_northing_to_row(site->north, &window);
+ start_col = (int)Rast_easting_to_col(Points->x[0], &window);
+ start_row = (int)Rast_northing_to_row(Points->y[0], &window);
/* effectively just a duplicate check to G_site_in_region() ??? */
if (start_row < 0 || start_row > nrows || start_col < 0 ||
@@ -293,12 +304,15 @@
G_fatal_error(_("Too many start points"));
have_points = 1;
+ Vect_close(&In);
/* only catches maps out of range until something is found, not after */
if (!have_points) {
G_warning(_("Starting vector map <%s> contains no points in the current region"),
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
if (have_points == 0)
@@ -377,14 +391,14 @@
/* only necessary for non-dir drain */
if (costmode == 0) {
- G_verbose_message(_("Calculating flow directions..."));
+ G_verbose_message(_("Calculating flow directions..."));
- /* fill one-cell pits and take a first stab at flow directions */
- filldir(fe, fd, nrows, &bnd, m);
+ /* fill one-cell pits and take a first stab at flow directions */
+ filldir(fe, fd, nrows, &bnd, m);
- /* determine flow directions for more ambiguous cases */
- resolve(fd, nrows, &bndC);
+ /* determine flow directions for more ambiguous cases */
+ resolve(fd, nrows, &bndC);
/* free the buffers already used */
G_free(bndC.b[0]);
@@ -518,6 +532,8 @@
/* Output a vector path */
if (opt4->answer) {
/* Need to modify for multiple paths */
thispoint = list;
i = 1;
