[GRASS-SVN] r49268 - in grass/branches/develbranch_6/gui: scripts
wxpython/gui_modules
svn_grass at osgeo.org
Wed Nov 16 08:06:48 EST 2011
Author: martinl
Date: 2011-11-16 05:06:48 -0800 (Wed, 16 Nov 2011)
New Revision: 49268
grass/branches/develbranch_6/gui/scripts/g.extension.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
wxGUI: use g.extension.py instead of g.extension
sync g.extension.py with trunk
Modified: grass/branches/develbranch_6/gui/scripts/g.extension.py
--- grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-11-16 12:47:42 UTC (rev 49267)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-11-16 13:06:48 UTC (rev 49268)
@@ -20,7 +20,9 @@
#%module
#% label: Tool to maintain the extensions in local GRASS installation.
#% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
-#% keywords: general, installation, extensions
+#% keywords: general
+#% keywords: installation
+#% keywords: extensions
#%end
#%option
@@ -28,7 +30,6 @@
#% type: string
#% key_desc: name
#% description: Name of extension to install/remove
-#% required: no
#%end
#%option
#% key: operation
@@ -44,7 +45,7 @@
#% key_desc: url
#% description: SVN Addons repository URL
#% required: yes
-#% answer: https://svn.osgeo.org/grass/grass-addons
+#% answer: http://svn.osgeo.org/grass/grass-addons
#%end
#%option
#% key: prefix
@@ -61,8 +62,8 @@
#% guisection: Print
#%end
#%flag
-#% key: f
-#% description: List available modules in the GRASS Addons SVN repository including modules description
+#% key: c
+#% description: List available modules in the GRASS Addons SVN repository including complete module description
#%end
#%flag
@@ -82,14 +83,25 @@
#% key: i
#% description: Don't install new extension, just compile it
#%end
+#%flag
+#% key: f
+#% description: Force removal (required for actual deletion of files)
+#%end
import os
import sys
import re
import atexit
+import shutil
+import glob
-import urllib
+from urllib2 import urlopen, HTTPError
+try:
+ import xml.etree.ElementTree as etree
+except ImportError:
+ import elementtree.ElementTree as etree # Python <= 2.4
from grass.script import core as grass
# temp dir
@@ -109,7 +121,7 @@
'ps' : 'postscript',
'p' : 'paint',
'r' : 'raster',
- 'r3' : 'raster3D',
+ 'r3' : 'raster3d',
's' : 'sites',
'v' : 'vector',
'gui' : 'gui/wxpython' }
@@ -121,6 +133,37 @@
def list_available_modules():
mlist = list()
+ # try to download XML metadata file first
+ url = "http://grass.osgeo.org/addons/grass%s.xml" % grass.version()['version'].split('.')[0]
+ try:
+ f = urlopen(url)
+ tree = etree.fromstring(f.read())
+ for mnode in tree.findall('task'):
+ name = mnode.get('name')
+ if flags['c'] or flags['g']:
+ desc = mnode.find('description').text
+ if not desc:
+ desc = ''
+ keyw = mnode.find('keywords').text
+ if not keyw:
+ keyw = ''
+ if flags['g']:
+ print 'name=' + name
+ print 'description=' + desc
+ print 'keywords=' + keyw
+ elif flags['c']:
+ print name + ' - ' + desc
+ else:
+ print name
+ except HTTPError:
+ return list_available_modules_svn()
+ return mlist
+def list_available_modules_svn():
+ mlist = list()
grass.message(_('Fetching list of modules from GRASS-Addons SVN (be patient)...'))
pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
i = 0
@@ -137,9 +180,10 @@
url = '%s/%s' % (options['svnurl'], modclass)
grass.debug("url = %s" % url, debug = 2)
- f = urllib.urlopen(url)
- if not f:
- grass.warning(_("Unable to fetch '%s'") % url)
+ try:
+ f = urlopen(url)
+ except HTTPError:
+ grass.debug(_("Unable to fetch '%s'") % url, debug = 1)
continue
for line in f.readlines():
@@ -167,7 +211,7 @@
url = '%s/%s' % (options['svnurl'], 'gui/wxpython')
+ f = urlopen(url)
if not f:
return
@@ -186,7 +230,7 @@
return mlist
def print_module_desc(name, url):
- if not flags['f'] and not flags['g']:
+ if not flags['c'] and not flags['g']:
print name
return
@@ -199,7 +243,7 @@
desc = get_module_desc(url + '/' + name + '/main.c', script = False)
if not desc:
if not flags['g']:
- print name + '-'
return
if flags['g']:
@@ -210,7 +254,11 @@
def get_module_desc(url, script = True):
grass.debug('url=%s' % url)
+ try:
+ f = urlopen(url)
+ except HTTPError:
+ return {}
if script:
ret = get_module_script(f)
else:
@@ -283,8 +331,35 @@
if remove_tmpdir:
grass.try_rmdir(tmpdir)
else:
- grass.info(_("Path to the source code: '%s'") % os.path.join(tmpdir, options['extension']))
+ grass.message(_("Path to the source code:"))
+ sys.stderr.write('%s\n' % os.path.join(tmpdir, options['extension']))
+def install_extension_win():
+ ### TODO: do not use hardcoded url
+ version = grass.version()['version'].split('.')
+ url = "http://wingrass.fsv.cvut.cz/grass%s%s/addons" % (version[0], version[1])
+ success = False
+ grass.message(_("Downloading precompiled GRASS Addons <%s>...") % options['extension'])
+ for comp, ext in [(('bin', ), 'exe'),
+ (('docs', 'html'), 'html'),
+ (('man', 'man1'), None),
+ (('scripts', ), 'py')]:
+ name = options['extension']
+ if ext:
+ name += '.' + ext
+ try:
+ f = urlopen(url + '/' + '/'.join(comp) + '/' + name)
+ fo = open(os.path.join(options['prefix'], os.path.sep.join(comp), name), 'wb')
+ fo.write(f.read())
+ fo.close()
+ if comp[0] in ('bin', 'scripts'):
+ success = True
+ except HTTPError:
+ pass
+ if not success:
+ grass.fatal(_("GRASS Addons <%s> not found") % options['extension'])
def install_extension():
gisbase = os.getenv('GISBASE')
if not gisbase:
@@ -314,7 +389,7 @@
if grass.call(['svn', 'checkout',
url], stdout = outdev) != 0:
- grass.fatal(_("GRASS Addons '%s' not found in repository") % options['extension'])
dirs = { 'bin' : os.path.join(tmpdir, options['extension'], 'bin'),
'docs' : os.path.join(tmpdir, options['extension'], 'docs'),
@@ -331,7 +406,7 @@
'HTMLDIR=%s' % dirs['html'],
'MANDIR=%s' % dirs['man1'],
'SCRIPTDIR=%s' % dirs['scripts'],
- 'ETC=%s' % dirs['etc']
+ 'ETC=%s' % os.path.join(dirs['etc'],options['extension'])
installCmd = ['make',
@@ -342,7 +417,9 @@
if flags['d']:
+ grass.message(_("To compile run:"))
sys.stderr.write(' '.join(makeCmd) + '\n')
+ grass.message(_("To install run:\n\n"))
sys.stderr.write(' '.join(installCmd) + '\n')
return
@@ -350,10 +427,6 @@
grass.message(_("Compiling '%s'...") % options['extension'])
if options['extension'] not in gui_list:
- for d in dirs.itervalues():
- if not os.path.exists(d):
- os.makedirs(d)
ret = grass.call(makeCmd,
stdout = outdev)
else:
@@ -363,7 +436,7 @@
if ret != 0:
grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
if flags['i'] or options['extension'] in gui_list:
return
@@ -376,24 +449,66 @@
grass.warning(_('Installation failed, sorry. Please check above error messages.'))
else:
grass.message(_("Installation of '%s' successfully finished.") % options['extension'])
+ # manual page: fix href
+ if os.getenv('GRASS_ADDON_PATH'):
+ html_man = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'docs', 'html', options['extension'] + '.html')
+ if os.path.exists(html_man):
+ fd = open(html_man)
+ html_str = '\n'.join(fd.readlines())
+ fd.close()
+ for rep in ('grassdocs.css', 'grass_logo.png'):
+ patt = re.compile(rep, re.IGNORECASE)
+ html_str = patt.sub(os.path.join(gisbase, 'docs', 'html', rep),
+ html_str)
+ patt = re.compile(r'(<a href=")(d|db|g|i|m|p|ps|r|r3|s|v|wxGUI)(\.)(.+)(.html">)', re.IGNORECASE)
+ while True:
+ m = patt.search(html_str)
+ if not m:
+ break
+ html_str = patt.sub(m.group(1) + os.path.join(gisbase, 'docs', 'html',
+ m.group(2) + m.group(3) + m.group(4)) + m.group(5),
+ html_str, count = 1)
+ fd = open(html_man, "w")
+ fd.write(html_str)
+ fd.close()
if not os.environ.has_key('GRASS_ADDON_PATH') or \
not os.environ['GRASS_ADDON_PATH']:
grass.warning(_('This add-on module will not function until you set the '
'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
-def remove_extension():
- # is module available?
- if not os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
- grass.fatal(_("Module '%s' not found") % options['extension'])
- for file in [os.path.join(options['prefix'], 'bin', options['extension']),
- os.path.join(options['prefix'], 'scripts', options['extension']),
- os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html')]:
- if os.path.isfile(file):
- os.remove(file)
- grass.message(_("'%s' successfully uninstalled.") % options['extension'])
+def remove_extension(flags):
+ #is module available?
+ bin_dir = os.path.join(options['prefix'], 'bin')
+ scr_dir = os.path.join(options['prefix'], 'scripts')
+ #add glob because if install a module with several submodule like r.modis
+ #or r.pi.* or r.stream.* it was not possible to remove all the module
+ #but the user has to remove the single command
+ if glob.glob1(bin_dir,options['extension'] + "*"):
+ modules = glob.glob1(bin_dir,options['extension'] + "*")
+ elif glob.glob1(scr_dir,options['extension'] + "*"):
+ modules = glob.glob1(scr_dir,options['extension'] + "*")
+ else:
+ grass.fatal(_("No module <%s> found") % options['extension'])
+ #the user want really remove the scripts
+ if flags['f']:
+ #for each module remove script and documentation files
+ for mod in modules:
+ for f in [os.path.join(bin_dir, mod), os.path.join(scr_dir, mod),
+ os.path.join(options['prefix'], 'docs', 'html', mod + '.html'),
+ os.path.join(options['prefix'], 'man', 'man1', mod + '.1')]:
+ grass.try_remove(f)
+ #add etc for the internal library of a module
+ grass.try_rmdir(os.path.join(options['prefix'], 'etc', options['extension']))
+ grass.message(_("Module <%s> successfully uninstalled") % options['extension'])
+ #print modules that you are going to remove with -f option
+ else:
+ grass.message(mod)
+ grass.message(_("You must use the force flag (-%s) to actually remove them. Exiting") % "f")
def create_dir(path):
if os.path.isdir(path):
@@ -405,19 +520,37 @@
grass.fatal(_("Unable to create '%s': %s") % (path, e))
grass.debug("'%s' created" % path)
+def check_style_files(fil):
+ #check the links to grassdocs.css/grass_logo.png to a correct manual page of addons
+ dist_file = os.path.join(os.getenv('GISBASE'),'docs','html',fil)
+ addons_file = os.path.join(options['prefix'],'docs','html',fil)
+ #check if file already exists in the grass addons docs html path
+ if os.path.isfile(addons_file):
+ return
+ #otherwise copy the file from $GISBASE/docs/html, it doesn't use link
+ #because os.symlink it work only in Linux
+ else:
+ try:
+ shutil.copyfile(dist_file,addons_file)
+ except OSError, e:
+ grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
def check_dirs():
create_dir(os.path.join(options['prefix'], 'bin'))
create_dir(os.path.join(options['prefix'], 'docs', 'html'))
+ check_style_files('grass_logo.png')
+ check_style_files('grassdocs.css')
create_dir(os.path.join(options['prefix'], 'man', 'man1'))
create_dir(os.path.join(options['prefix'], 'scripts'))
def main():
# check dependecies
- check()
+ if sys.platform != "win32":
+ check()
# list available modules
- if flags['l'] or flags['f'] or flags['g']:
+ if flags['l'] or flags['c'] or flags['g']:
return 0
else:
@@ -453,9 +586,12 @@
remove_tmpdir = False
if options['operation'] == 'add':
- install_extension()
+ if sys.platform == "win32":
+ install_extension_win()
+ else:
+ install_extension()
else: # remove
- remove_extension()
+ remove_extension(flags)
return 0
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py 2011-11-16 12:47:42 UTC (rev 49267)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py 2011-11-16 13:06:48 UTC (rev 49268)
@@ -810,7 +810,7 @@
self.repo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
self.fullDesc = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
label = _("Fetch full info including description and keywords (takes time)"))
- self.fullDesc.SetValue(False)
+ self.fullDesc.SetValue(True)
self.search = SearchModuleWindow(parent = self.panel)
self.search.SetSelection(2)
@@ -820,7 +820,7 @@
self.optionBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label = " %s " % _("Options"))
- task = gtask.parse_interface('g.extension')
+ task = gtask.parse_interface('g.extension.py')
for f in task.get_options()['flags']:
name = f.get('name', '')
@@ -834,7 +834,7 @@
self.options[name] = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
label = desc)
self.repo.SetValue(task.get_param(value = 'svnurl').get('default',
- 'https://svn.osgeo.org/grass/grass-addons'))
+ 'http://svn.osgeo.org/grass/grass-addons'))
self.statusbar = self.CreateStatusBar(number = 1)
@@ -848,7 +848,7 @@
self.btnInstall.Enable(False)
self.btnCmd = wx.Button(parent = self.panel, id = wx.ID_ANY,
label = _("Command dialog"))
- self.btnCmd.SetToolTipString(_('Open %s dialog') % 'g.extension')
+ self.btnCmd.SetToolTipString(_('Open %s dialog') % 'g.extension.py')
self.btnClose.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
self.btnFetch.Bind(wx.EVT_BUTTON, self.OnFetch)
@@ -913,7 +913,7 @@
def _getCmd(self):
item = self.tree.GetSelected()
if not item or not item.IsOk():
- return ['g.extension']
+ return ['g.extension.py']
name = self.tree.GetItemText(item)
if not name:
@@ -924,8 +924,8 @@
if self.options[key].IsChecked():
flags.append('-%s' % key)
- return ['g.extension'] + flags + ['extension=' + name,
- 'svnurl=' + self.repo.GetValue().strip()]
+ return ['g.extension.py'] + flags + ['extension=' + name,
+ 'svnurl=' + self.repo.GetValue().strip()]
def OnUpdateStatusBar(self, event):
"""!Update statusbar text"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2011-11-16 12:47:42 UTC (rev 49267)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2011-11-16 13:06:48 UTC (rev 49268)
@@ -153,8 +153,8 @@
os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'gui', 'scripts')
os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'wxpython', 'scripts')
for script in os.listdir(os.path.join(gisbase, 'etc', 'gui', 'scripts')):
- patt = "_wrapper"
- if script[-len(patt):] != patt: # ignore wrappers
+ patt = "_wrapper" # ignore wrappers
+ if script[-len(patt):] != patt:
cmd.append(script)
if addons and os.getenv('GRASS_ADDON_PATH'):
