[GRASS-SVN] r49271 - grass-addons/tools/addons
svn_grass at osgeo.org
Wed Nov 16 10:15:56 EST 2011
Author: martinl
Date: 2011-11-16 07:15:55 -0800 (Wed, 16 Nov 2011)
New Revision: 49271
grass-addons/tools/addons/build-xml.py
grass-addons/tools/addons/compile-xml.sh
grass-addons/tools/addons/compile.sh
addons management: updated supporting scripts
Modified: grass-addons/tools/addons/build-xml.py
--- grass-addons/tools/addons/build-xml.py 2011-11-16 15:13:44 UTC (rev 49270)
+++ grass-addons/tools/addons/build-xml.py 2011-11-16 15:15:55 UTC (rev 49271)
@@ -2,10 +2,12 @@
import os
import sys
+import glob
def get_list(addons):
- mlist = os.listdir(os.path.join(addons, 'bin')) + \
- os.listdir(os.path.join(addons, 'scripts'))
+ mlist = os.listdir(os.path.join(addons))
+ for f in ('log', 'make.log', 'modules.xml'):
+ mlist.remove(f)
mlist.sort()
return mlist
@@ -28,9 +30,6 @@
gsetup.init(gisbase,
gisdbase, location, mapset)
- os.environ['PATH'] += os.pathsep + os.path.join(sys.argv[1], 'bin') + os.pathsep + \
- os.path.join(sys.argv[1], 'scripts')
def parse_modules(fd, mlist):
indent = 4
for m in mlist:
@@ -40,18 +39,46 @@
indent += 4
fd.write('%s<description>%s</description>\n' % (' ' * indent, desc))
fd.write('%s<keywords>%s</keywords>\n' % (' ' * indent, ','.join(keyw)))
+ fd.write('%s<binary>\n' % (' ' * indent))
+ indent += 4
+ for f in get_module_files(m):
+ fd.write('%s<file>%s</file>\n' % (' ' * indent, f))
indent -= 4
+ fd.write('%s</binary>\n' % (' ' * indent))
+ indent -= 4
fd.write('%s</task>\n' % (' ' * indent))
if desc:
print " SUCCESS"
else:
print " FAILED"
+def scandirs(path):
+ flist = list()
+ for f in glob.glob(os.path.join(path, '*') ):
+ if os.path.isdir(f):
+ flist += scandirs(f)
+ else:
+ flist.append(f)
+ return flist
+def get_module_files(name):
+ os.chdir(os.path.join(sys.argv[1], name))
+ return scandirs('*')
def get_module_metadata(name):
import grass.script.task as gtask
+ path = os.environ['PATH']
+ os.environ['PATH'] += os.pathsep + os.path.join(sys.argv[1], name, 'bin') + os.pathsep + \
+ os.path.join(sys.argv[1], name, 'scripts')
try:
task = gtask.parse_interface(name)
except:
+ task = None
+ os.environ['PATH'] = path
+ if not task:
return '', ''
return task.get_description(full = True), \
@@ -61,10 +88,10 @@
import grass.script.core as grass
fd.write('<?xml version="1.0" encoding="UTF-8"?>\n')
fd.write('<!DOCTYPE task SYSTEM "grass-addons.dtd">\n') # TODO
- fd.write('<modules version=%s>\n' % grass.version()['version'])
+ fd.write('<addons version="%s">\n' % grass.version()['version'])
def footer(fd):
- fd.write('</modules>\n')
+ fd.write('</addons>\n')
def main():
if len(sys.argv) < 2:
Modified: grass-addons/tools/addons/compile-xml.sh
--- grass-addons/tools/addons/compile-xml.sh 2011-11-16 15:13:44 UTC (rev 49270)
+++ grass-addons/tools/addons/compile-xml.sh 2011-11-16 15:15:55 UTC (rev 49271)
@@ -1,7 +1,7 @@
#!/bin/sh
compile() {
- ./compile.sh $1 $2 $3
+ ./compile.sh $1 $2 $3 1
build_xml() {
Modified: grass-addons/tools/addons/compile.sh
--- grass-addons/tools/addons/compile.sh 2011-11-16 15:13:44 UTC (rev 49270)
+++ grass-addons/tools/addons/compile.sh 2011-11-16 15:15:55 UTC (rev 49271)
@@ -1,8 +1,8 @@
#!/bin/sh
if [ -z "$3" ]; then
- echo "usage: $0 svn_path topdir addons_path"
- echo "eg. $0 ~/src/grass-addons/grass7/ ~/src/grass_trunk/dist.i686-pc-linux-gnu/ ~/.grass7/addons"
+ echo "usage: $0 svn_path topdir addons_path [separate]"
+ echo "eg. $0 ~/src/grass-addons/grass7/ ~/src/grass_trunk/dist.x86_64-unknown-linux-gnu ~/.grass7/addons"
exit 1
fi
@@ -10,6 +10,12 @@
TOPDIR="$2"
ADDON_PATH="$3"
+if [ -n "$4" ] ; then
+ SEP=1 # useful for collecting files (see build-xml.py)
+else
+ SEP=0
+fi
rm -rf $ADDON_PATH
mkdir $ADDON_PATH
@@ -30,12 +36,17 @@
m="${m%%/}"
echo -n "Compiling $m..."
cd $m
+ if [ $SEP -eq 1 ] ; then
+ path=${ADDON_PATH}/$m
+ else
+ path=$ADDON_PATH
+ fi
make MODULE_TOPDIR=$TOPDIR \
- BIN=$ADDON_PATH/bin \
- HTMLDIR=$ADDON_PATH/docs/html \
- MANDIR=$ADDON_PATH/man/man1 \
- SCRIPTDIR=$ADDON_PATH/scripts \
- ETC=$ADDON_PATH/etc \
+ BIN=$path/bin \
+ HTMLDIR=$path/docs/html \
+ MANDIR=$path/man/man1 \
+ SCRIPTDIR=$path/scripts \
+ ETC=$path/etc \
MANIFEST= WINDRES= MANIFEST_OBJ= >$ADDON_PATH/log/${m}.log 2>&1
if [ `echo $?` -eq 0 ] ; then
printf "%-30s%s\n" "$c/$m" "SUCCESS" >> $ADDON_PATH/make.log
