[GRASS-SVN] r49279 - in grass-addons/grass7/raster/r.agent: .
libagent
svn_grass at osgeo.org
Wed Nov 16 15:32:18 EST 2011
Author: mic
Date: 2011-11-16 12:32:18 -0800 (Wed, 16 Nov 2011)
New Revision: 49279
Added:
grass-addons/grass7/raster/r.agent/r.agent.tests.py
Removed:
grass-addons/grass7/raster/r.agent/tests.py
grass-addons/grass7/raster/r.agent/libagent/playground.py
interfacing with grass
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py 2011-11-16 20:29:07 UTC (rev 49278)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py 2011-11-16 20:32:18 UTC (rev 49279)
@@ -12,19 +12,21 @@
+import grass.script as grass
class Playground(object):
- """A Playground is a major component of a World,
- defining and organizing space."""
+ """A Playground is a major component of a World, defining
+ and organizing space, and the interface to GRASS."""
def __init__(self):
self.layers = dict()
- self.offset = [None,None]
- self.limit = [None,None]
- self.steps = []
- def setbounds(self, north=None, south=None, east=None, west=None,
- rows=None, cols=None):
- pass
- def getbounds(self):
- return []
+ self.region = grass.region()
+ if self.region['ewres'] != self.region['nsres']:
+ raise error.DataError("r.agent::libagent.playground.Playground()",
+ "Only square raster cells make sense.")
+ def getregion(self):
+ return self.region
+ def getbound(self, bound):
+ return self.region[bound]
def setlayer(self, layername, layer, force=False):
pass
def createlayer(self, layername, grassmap=False):
Copied: grass-addons/grass7/raster/r.agent/r.agent.tests.py (from rev 49276, grass-addons/grass7/raster/r.agent/tests.py)
--- grass-addons/grass7/raster/r.agent/r.agent.tests.py (rev 0)
+++ grass-addons/grass7/raster/r.agent/r.agent.tests.py 2011-11-16 20:32:18 UTC (rev 49279)
@@ -0,0 +1,103 @@
+#!/usr/bin/env python
+# MODULE: r.agent.aco
+# AUTHOR(S): michael lustenberger inofix.ch
+# PURPOSE: r.agent.aco is used to organize ant-like agents in a raster
+# based playground. As decribed by the Ant Colony Optimization
+# algorithm, the ants wander around looking for attractors,
+# marking their paths if they find any.
+# COPYRIGHT: (C) 2011 by Michael Lustenberger and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+def dotest(function, argv):
+ """Global wrapper for the individual test suits."""
+ while True:
+ n = function.func_doc
+ o = str(argv)
+ if not n:
+ n = str(function)
+ t = str(raw_input("execute this now: '"+n+" - "+o+"'? [y/n/abort] "))
+ if t == "y":
+ if argv != None:
+ function(*argv)
+ else:
+ function()
+ break
+ elif t == "n":
+ break
+ elif t == "abort":
+ exit()
+def testError(expr, msg):
+ """Test suite for Class: Error"""
+ try:
+ raise error.DataError(expr, msg)
+ except error.DataError:
+ print "catched! all fine."
+def testPlayground():
+ """Test suite for Class: Playground"""
+ pg = playground.Playground()
+ print(pg.region)
+def testWorld():
+ """Test suite for Class: World"""
+ w = world.World()
+def testACO():
+ """Test suite for World-Class: ACO"""
+ w = aco.ACO()
+def testAgent(ttl):
+ """Test suite for Class: Agent"""
+ w = world.World()
+ w = agent.Agent(ttl, w)
+def testAnt(ttl, position):
+ """Test suite for Agent-Class: Ant"""
+ w = world.World()
+ w = ant.Ant(ttl, w, position)
+if __name__ == "__main__":
+ """Main method for testing when run as a script."""
+ import sys
+ import os
+ from libagent import error
+ if os.environ.get("GISBASE") == None:
+ raise error.EnvError("r.agent::TestSuite", "Please run inside GRASS.")
+ from libagent import playground
+ from libagent import world
+ from libagent import aco
+ from libagent import agent
+ from libagent import ant
+ alltests = {"error":[testError, ["Error Test Suite",
+ "(this error is good)"]],
+ "playground":[testPlayground, []],
+ "world":[testWorld, []],
+ "aco":[testACO, []],
+ "Agent":[testAgent, [1]],
+ "Ant":[testAnt, [1, []]]}
+ if len(sys.argv) == 1:
+ for test,details in alltests.iteritems():
+ dotest(details[0], details[1])
+ else:
+ sys.argv.pop(0)
+ for t in sys.argv:
+ if t in alltests:
+ dotest(*alltests[t])
+ else:
+ print("Test does not exist: ", t)
Deleted: grass-addons/grass7/raster/r.agent/tests.py
--- grass-addons/grass7/raster/r.agent/tests.py 2011-11-16 20:29:07 UTC (rev 49278)
+++ grass-addons/grass7/raster/r.agent/tests.py 2011-11-16 20:32:18 UTC (rev 49279)
@@ -1,95 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r.agent.aco
-# AUTHOR(S): michael lustenberger inofix.ch
-# PURPOSE: r.agent.aco is used to organize ant-like agents in a raster
-# based playground. As decribed by the Ant Colony Optimization
-# algorithm, the ants wander around looking for attractors,
-# marking their paths if they find any.
-# COPYRIGHT: (C) 2011 by Michael Lustenberger and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-def dotest(function, argv):
- """Global wrapper for the individual test suits."""
- while True:
- n = function.func_doc
- o = str(argv)
- if not n:
- n = str(function)
- t = str(raw_input("execute this now: '"+n+" - "+o+"'? [y/n/abort] "))
- if t == "y":
- if argv != None:
- function(*argv)
- else:
- function()
- break
- elif t == "n":
- break
- elif t == "abort":
- exit()
-def testError(expr, msg):
- """Test suite for Class: Error"""
- try:
- raise error.DataError(expr, msg)
- except error.DataError:
- print "catched! all fine."
-def testPlayground():
- """Test suite for Class: Playground"""
- pg = playground.Playground()
-def testWorld():
- """Test suite for Class: World"""
- w = world.World()
-def testACO():
- """Test suite for World-Class: ACO"""
- w = aco.ACO()
-def testAgent(ttl):
- """Test suite for Class: Agent"""
- w = world.World()
- w = agent.Agent(ttl, w)
-def testAnt(ttl, position):
- """Test suite for Agent-Class: Ant"""
- w = world.World()
- w = ant.Ant(ttl, w, position)
-if __name__ == "__main__":
- """Main method for testing when run as a script."""
- import sys
- from libagent import error
- from libagent import playground
- from libagent import world
- from libagent import aco
- from libagent import agent
- from libagent import ant
- alltests = {"error":[testError, ["Error Test Suite", "(this error is good)"]],
- "playground":[testPlayground, []],
- "world":[testWorld, []],
- "aco":[testACO, []],
- "Agent":[testAgent, [1]],
- "Ant":[testAnt, [1, []]]}
- if len(sys.argv) == 1:
- for test,details in alltests.iteritems():
- dotest(details[0], details[1])
- else:
- sys.argv.pop(0)
- for t in sys.argv:
- if t in alltests:
- dotest(*alltests[t])
- else:
- print("Test does not exist: ", t)
