[GRASS-SVN] r49283 - grass/trunk/lib/gis
svn_grass at osgeo.org
Thu Nov 17 07:48:32 EST 2011
Author: martinl
Date: 2011-11-17 04:48:31 -0800 (Thu, 17 Nov 2011)
New Revision: 49283
grass/trunk/lib/gis/handler.c
gislib: document error handlers
Modified: grass/trunk/lib/gis/handler.c
--- grass/trunk/lib/gis/handler.c 2011-11-16 21:56:18 UTC (rev 49282)
+++ grass/trunk/lib/gis/handler.c 2011-11-17 12:48:31 UTC (rev 49283)
@@ -1,3 +1,16 @@
+ \file lib/gis/handler.c
+ \brief GIS Library - Error handlers
+ (C) 2010-2011 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author Glynn Clements
#include <stddef.h>
#include <grass/gis.h>
@@ -2,4 +15,13 @@
+ \brief Error handler (see G_add_error_handler() for usage)
struct handler {
+ \brief Pointer to the handler routine
void (*func)(void *);
+ \brief Pointer to closure data
void *closure;
@@ -30,6 +52,21 @@
return &handlers[num_handlers++];
+ \brief Add new error handler
+ Example
+ \code
+ static void error_handler(void *p) {
+ const char *map = (const char *) p;
+ Vect_delete(map);
+ G_add_error_handler(error_handler, new->answer);
+ \endcode
+ \param func handler to add
+ \param closure pointer to closure data
void G_add_error_handler(void (*func)(void *), void *closure)
struct handler *h = alloc_handler();
@@ -38,6 +75,12 @@
h->closure = closure;
+ \brief Remove existing error hander
+ \param func handler to be remove
void G_remove_error_handler(void (*func)(void *), void *closure)
int i;
@@ -52,6 +95,9 @@
+ \brief Call available error handlers (internal use only)
void G__call_error_handlers(void)
int i;
