[GRASS-SVN] r49291 - grass/trunk/temporal/t.list
svn_grass at osgeo.org
Fri Nov 18 06:14:54 EST 2011
Author: huhabla
Date: 2011-11-18 03:14:54 -0800 (Fri, 18 Nov 2011)
New Revision: 49291
grass/trunk/temporal/t.list/t.list.py
Wrong order - where positioning in the sql string
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2011-11-18 08:02:57 UTC (rev 49290)
+++ grass/trunk/temporal/t.list/t.list.py 2011-11-18 11:14:54 UTC (rev 49291)
@@ -24,7 +24,7 @@
#%option
#% key: type
#% type: string
-#% description: Type of the space time dataset, default is strds
+#% description: Type of the space time dataset or map, default is strds
#% required: no
#% options: strds, str3ds, stvds, rast, rast3d, vect
#% answer: strds
@@ -36,17 +36,17 @@
#% description: Sort the space time dataset by category. Columns number_of_maps and granularity only available fpr space time datasets
#% required: no
#% multiple: yes
-#% options: id, name, creator, mapset, number_of_maps, creation_time, modification_time, start_time, end_time, interval, north, south, west, east, granularity
+#% options: id, name, creator, mapset, number_of_maps, creation_time, start_time, end_time, interval, north, south, west, east, granularity
#% answer: id
#%end
#%option
#% key: columns
#% type: string
-#% description: Which columns should be printed to stdout. Columns number_of_maps and granularity only available fpr space time datasets
+#% description: Which columns should be printed to stdout. Columns number_of_maps and granularity only available for space time datasets
#% required: no
#% multiple: yes
-#% options: id, name, creator, mapset, number_of_maps, creation_time, modification_time, revision, start_time, end_time, north, south, west, east, granularity, all
+#% options: id, name, creator, mapset, number_of_maps, creation_time, start_time, end_time, north, south, west, east, granularity, all
#% answer: id
#%end
@@ -116,11 +116,12 @@
else:
sql = "SELECT * FROM " + table
+ if where:
+ sql += " WHERE " + where
if order:
sql += " ORDER BY " + order
- if where:
- sql += " WHERE " + where
dbif.cursor.execute(sql)
rows = dbif.cursor.fetchall()
