[GRASS-SVN] r49328 -
grass/branches/develbranch_6/scripts/v.db.update
svn_grass at osgeo.org
Tue Nov 22 17:30:03 EST 2011
Author: neteler
Date: 2011-11-22 14:30:02 -0800 (Tue, 22 Nov 2011)
New Revision: 49328
grass/branches/develbranch_6/scripts/v.db.update/description.html
HTML fix
Modified: grass/branches/develbranch_6/scripts/v.db.update/description.html
--- grass/branches/develbranch_6/scripts/v.db.update/description.html 2011-11-22 22:29:56 UTC (rev 49327)
+++ grass/branches/develbranch_6/scripts/v.db.update/description.html 2011-11-22 22:30:02 UTC (rev 49328)
@@ -32,6 +32,7 @@
v.db.update mylakes col=FTYPE value=WETLAND \
where="FTYPE IS NULL"
v.db.select mylakes
+</pre></div>
<p>
Spearfish example: adding new column, copying values from other table column with
on the fly calculation:
