[GRASS-SVN] r49334 - grass-addons/raster/r.pi/r.pi.corearea
svn_grass at osgeo.org
Wed Nov 23 10:56:15 EST 2011
Author: wegmann
Date: 2011-11-23 07:56:15 -0800 (Wed, 23 Nov 2011)
New Revision: 49334
grass-addons/raster/r.pi/r.pi.corearea/description_TO_BE_integrated.html
merged with main description file. and just the german description remains for later cross-check
Modified: grass-addons/raster/r.pi/r.pi.corearea/description_TO_BE_integrated.html
--- grass-addons/raster/r.pi/r.pi.corearea/description_TO_BE_integrated.html 2011-11-23 15:53:01 UTC (rev 49333)
+++ grass-addons/raster/r.pi/r.pi.corearea/description_TO_BE_integrated.html 2011-11-23 15:56:15 UTC (rev 49334)
@@ -1,62 +1,3 @@
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>r.pi.index</b></em> - is part of a patch based fragmentation analysis package (<em>r.pi</em>) providing basic patch based indices, like area, SHAPE or Nearest Neighbour distance.
-<h2>KEYWORDS</h2>
-raster, patch index, landscape ecology
-<h2>SYNOPSIS</h2>
-<b>r.pi.index</b><br>
-<b>r.pi.index help</b><br>
-<b>r.pi.index</b> [-<b>a</b>] <b>input</b>=<em>name</em> <b>output</b>=<em>name</em>
-<b>keyval</b>=<em>val</em> <b>method</b>=<em>name</em> [<b>title</b>=<em>name</em>] [--<b>overwrite</b>] [--<b>verbose</b>] [--<b>quiet</b>]
-<h3>Flags:</h3>
-<dl>
-<dt><b>-a</b></dt>
-<dd>use 8-neighbour rules (Queen-Typ) instead of 4-neighbour rule (Rook-Typ)</dd>
-<dt><b>--overwrite</b></dt>
-<dd>Allow output files to overwrite existing files</dd>
-<dt><b>--verbose</b></dt>
-<dd>Verbose module output</dd>
-<dt><b>--quiet</b></dt>
-<dd>Quiet module output</dd>
-</dl>
-<h3>Parameters:</h3>
-<dl>
-<dt><b>input</b>=<em>name</em></dt>
-<dd>Name of existing raster map containing categories</dd>
-<dt><b>output</b>=<em>name</em></dt>
-<dd>Output patch-based result raster map</dd>
-<dt><b>keyval</b>=<em>val</em></dt>
-<dd>The value of the class to analyse</dd>
-<dt><b>method</b>=<em>name</em></dt>
-<dd>The index to compute. Options: area, perimeter (perim), SHAPE, Border-Index (bor), Compactness (comp), Asymmetry (asym), area-perimeter ratio (apr), fractal dimension (fract), distance to euclidean nearest neighbour (ENN)</dd>
-<dt><b>title</b>=<em>name</em></dt>
-<dd>Optional title of output map</dd>
-</dl>
-<h2>DESCRIPTION</h2>
-<p>
-The program will be run non-interactively if the user specifies program arguments (see OPTIONS) on the command
-line. Alternately, the user can simply type <b>r.pi.index</b> on the command line, without program
-arguments. In this case, the user will be prompted for flag settings and parameter values.
> Was die propmap angeht:
> Wenn du nur 0 Werte nimmst, dann werden die Werte immer unendlich
@@ -101,100 +42,3 @@
zum Wert 0 bei d = d_max
dist_weight = 1: Keine Distanzbewertung, d.h. so wie vorher
-<dt><b>Area</b>
-<dd>The <em>Area</em> (area) computes the area of each patch.
-<dt><b>Perimeter</b>
-<dd>The <em>Perimeter (perim)</em> computes the perimeter of each patch.
-<dt><b>Area-Perimeter ratio </b>
-<dd>The <em>Area-Perimeter ratio</em> (apr) divides the patch perimeter by the area.
-<dt><b>SHAPE Index </b>
-<dd>The <em>SHAPE Index</em> (shape) divides the patch perimete by the minimum perimeter
-possible for a maximally compact patch of the corresponding patch area.
-<dt><b>Border Index </b>
-<dd>The <em>Border Index</em> (bor)....
-<dt><b>Compactness Index </b>
-<dd>The <em>Compactness Index</em> (comp)....
-<dt><b>Asymmetry Index </b>
-<dd>The <em>Border Index</em> (asym)....
-<dt><b>Fractal Dimension Index </b>
-<dd>The <em>Fractal Dimension Index</em> (fract)....
-<dt><b>Nearest Neighbour Index </b>
-<dd>The <em>Nearest Neighbour Index</em> (ENN) ....
-<!-- Bsp um Pseudo code or Bsp einzufügen -->
-<!--<div class="code"><pre>
-Input: Output:
- ELEVATION SURFACE LEAST COST PATH
-. 20| 19| 17. 16. 17. 16. 16. . . 1 . 1 . 1 . . . .
-. . |___| . . . . . . . . . . . . . . . . . . . . . . . . .
-. 18. 18. 24. 18. 15. 12. 11. . . . . . 1 . . .
-. 22. 16. 16. 18. 10. 10. 10. . . . . . 1 . . .
-. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 1 . .
-. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 1 . .
-. 17. 9 . 8 . 7 . 8 . 6 .12 . . . . . . . . .
-</pre></div>-->
-</dl>
-<h2>NOTES</h2>
-<p>
-<h2>BUGS</h2>
-<h2>SEE ALSO</h2>
-<em><a href="r.pi.ENN.html">r.pi.ENN</a></em><br>
-<em><a href="r.pi.FNN.html">r.pi.FNN</a></em><br>
-<em><a href="r.pi.dist.html">r.pi.dist</a></em><br>
-<em><a href="r.li.setup.html">r.li.setup</a></em><br>
-<h2>AUTHOR</h2>
-Programming: Elshad Shirinov<br>
-Scientific concept: Martin Wegmann <br>
-University of Wuerzburg<br>
-<p><i>Last changed: $Date$</i>
