[GRASS-SVN] r49339 - in grass-addons/raster/r.pi: r.pi.export r.pi.graph
Wed Nov 23 11:12:25 EST 2011
Author: wegmann
Date: 2011-11-23 08:12:25 -0800 (Wed, 23 Nov 2011)
New Revision: 49339
   grass-addons/raster/r.pi/r.pi.export/description.html
   grass-addons/raster/r.pi/r.pi.graph/description.html
all remaining html flags in examples removed, examples will be extended in the next days
Modified: grass-addons/raster/r.pi/r.pi.export/description.html
--- grass-addons/raster/r.pi/r.pi.export/description.html	2011-11-23 16:08:37 UTC (rev 49338)
+++ grass-addons/raster/r.pi/r.pi.export/description.html	2011-11-23 16:12:25 UTC (rev 49339)
@@ -12,12 +12,12 @@
 generating a patch index map for later export:
 <div class="code"><pre>
-<b> r.pi.index input=</b>landclass96 <b>output=</b>landclass96_forestclass5_area <b>keyval=</b>5 <b>method=</b>area
+r.pi.index input=landclass96 output=landclass96_forestclass5_area keyval=5 method=area
 </pre></div>
 export this resulting map:
-<b>r.pi.export input=</b>landclass96_forestclass5_area <b>output=</b>patch_area_out <b>values=</b>patch_area_values <b>id_raster=</b>forestclass5_ID <b>stats=</b>average,variance,min
+r.pi.export input=landclass96_forestclass5_area output=patch_area_out values=patch_area_values id_raster=forestclass5_ID stats=average,variance,min
 </pre></div>
 various resulting files are generated:<br>
Modified: grass-addons/raster/r.pi/r.pi.graph/description.html
--- grass-addons/raster/r.pi/r.pi.graph/description.html	2011-11-23 16:08:37 UTC (rev 49338)
+++ grass-addons/raster/r.pi/r.pi.graph/description.html	2011-11-23 16:12:25 UTC (rev 49339)
@@ -12,7 +12,7 @@
 Computing a graph of all patches (4 neighbourhood rule) using a maximum distance of 10 pixel, the Gabriel method and as resulting index the <em> largest patch diameter</em>:
-<b>r.pi.graph input=</b>landclass96 <b>output=</b>landclass96_graph <b>keyval=</b>5 <b>distance=</b>10 <b>neighborhood=</b>gabriel <b>index=</b>largest_patch_diameter
+r.pi.graph input=landclass96 output=landclass96_graph keyval=5 distance=10 neighborhood=gabriel index=largest_patch_diameter
 </pre></div>
 the results are 2 files:
