[GRASS-SVN] r49348 - in grass/trunk/gui/wxpython: . core gmodeler gui_core lmgr mapdisp modules nviz psmap
Thu Nov 24 08:56:12 EST 2011
Author: martinl
Date: 2011-11-24 05:56:11 -0800 (Thu, 24 Nov 2011)
New Revision: 49348
Added:
   grass/trunk/gui/wxpython/gmodeler/menudata.py
   grass/trunk/gui/wxpython/gui_core/task.py
   grass/trunk/gui/wxpython/modules/extensions.py
   grass/trunk/gui/wxpython/core/menudata.py
   grass/trunk/gui/wxpython/gis_set.py
   grass/trunk/gui/wxpython/gmodeler/frame.py
   grass/trunk/gui/wxpython/gmodeler/model_file.py
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/gui_core/ghelp.py
   grass/trunk/gui/wxpython/gui_core/goutput.py
   grass/trunk/gui/wxpython/gui_core/widgets.py
   grass/trunk/gui/wxpython/lmgr/layertree.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/modules/colorrules.py
   grass/trunk/gui/wxpython/modules/histogram.py
   grass/trunk/gui/wxpython/modules/mcalc_builder.py
   grass/trunk/gui/wxpython/nviz/mapwindow.py
   grass/trunk/gui/wxpython/psmap/frame.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI major code reorganization (part 2)
Modified: grass/trunk/gui/wxpython/core/menudata.py
--- grass/trunk/gui/wxpython/core/menudata.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/core/menudata.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -35,7 +35,7 @@
 except ImportError:
     import elementtree.ElementTree as etree # Python <= 2.4
-from wx import ID_ANY
+import wx
 if not os.getenv("GISBASE"):
     sys.exit("GRASS is not running. Exiting...")
@@ -75,7 +75,7 @@
             if wxId != None:
                 wxId = eval('wx.' + wxId.text)
             else:
-                wxId = ID_ANY
+                wxId = wx.ID_ANY
 	    return (label, help, handler, gcmd, keywords, shortcut, wxId)
 	elif mi.tag == 'menu':
 	    return self._getMenu(mi)
@@ -212,11 +212,12 @@
             menu = arg
     sys.path.append(os.path.join(os.getenv("GISBASE"), "etc", "gui", "wxpython"))
     if menu == 'manager':
-        from lmgr.menudata import ManagerData
+        from lmgr.menudata     import ManagerData
         data = ManagerData()
     else:
-        from gmodeler.frame import ModelerData
+        from gmodeler.menudata import ModelerData
         data = ModelerData()
     if action == 'strings':
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/gis_set.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -22,7 +22,6 @@
 import os
 import sys
-import glob
 import shutil
 import copy
 import platform
@@ -32,17 +31,13 @@
 import gettext
 gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
-from gui_modules import globalvar
+from core import globalvar
 import wx
-import wx.html
-import wx.lib.rcsizer as rcs
-import wx.lib.filebrowsebutton as filebrowse
 import wx.lib.mixins.listctrl as listmix
 import wx.lib.scrolledpanel as scrolled
-from gui_modules import goutput
-from gui_modules.ghelp import HelpFrame
-from gui_modules.gcmd  import GMessage, GError
+from gui_core.ghelp import HelpFrame
+from core.gcmd      import GMessage, GError
 sys.stderr = codecs.getwriter('utf8')(sys.stderr)
@@ -369,7 +364,7 @@
                 rc = open(gisrc, "r")
                 for line in rc.readlines():
                     key, val = line.split(":", 1)
-                    grassrc[key.strip()] = utils.DecodeString(val.strip())
+                    grassrc[key.strip()] = DecodeString(val.strip())
             finally:
                 rc.close()
@@ -385,9 +380,9 @@
     def OnWizard(self, event):
         """!Location wizard started"""
-        from gui_modules import location_wizard
-        gWizard = location_wizard.LocationWizard(parent = self,
-                                                 grassdatabase = self.tgisdbase.GetValue())
+        from location_wizard.wizard import LocationWizard
+        gWizard = LocationWizard(parent = self,
+                                 grassdatabase = self.tgisdbase.GetValue())
         if gWizard.location !=  None:
             self.OnSetDatabase(event)
             self.UpdateMapsets(os.path.join(self.gisdbase, gWizard.location))
@@ -544,7 +539,7 @@
     def UpdateLocations(self, dbase):
         """!Update list of locations"""
         try:
-            self.listOfLocations = utils.GetListOfLocations(dbase)
+            self.listOfLocations = GetListOfLocations(dbase)
         except UnicodeEncodeError:
             wx.MessageBox(parent = self, caption = _("Error"),
                           message = _("Unable to set GRASS database. "
@@ -566,29 +561,29 @@
         self.FormerMapsetSelection = wx.NOT_FOUND # for non-selectable item
         self.listOfMapsetsSelectable = list()
-        self.listOfMapsets = utils.GetListOfMapsets(self.gisdbase, location)
+        self.listOfMapsets = GetListOfMapsets(self.gisdbase, location)
         self.lbmapsets.Clear()
         # disable mapset with denied permission
         locationName = os.path.basename(location)
-        ret = gcmd.RunCommand('g.mapset',
-                              read = True,
-                              flags = 'l',
-                              location = locationName,
-                              gisdbase = self.gisdbase)
+        ret = RunCommand('g.mapset',
+                         read = True,
+                         flags = 'l',
+                         location = locationName,
+                         gisdbase = self.gisdbase)
         if ret:
             for line in ret.splitlines():
                 self.listOfMapsetsSelectable += line.split(' ')
         else:
-            gcmd.RunCommand("g.gisenv",
-                            set = "GISDBASE=%s" % self.gisdbase)
-                            set = "LOCATION_NAME=%s" % locationName)
-                            set = "MAPSET=PERMANENT")
+            RunCommand("g.gisenv",
+                       set = "GISDBASE=%s" % self.gisdbase)
+                       set = "LOCATION_NAME=%s" % locationName)
+                       set = "MAPSET=PERMANENT")
             # first run only
             self.listOfMapsetsSelectable = copy.copy(self.listOfMapsets)
@@ -772,12 +767,12 @@
             else:
                 return
-                        set = "GISDBASE=%s" % dbase)
-                        set = "LOCATION_NAME=%s" % location)
-                        set = "MAPSET=%s" % mapset)
+                   set = "GISDBASE=%s" % dbase)
+                   set = "LOCATION_NAME=%s" % location)
+                   set = "MAPSET=%s" % mapset)
         self.Destroy()
         sys.exit(0)
@@ -885,8 +880,8 @@
         import gettext
-        import gui_modules.gcmd as gcmd
-        import gui_modules.utils as utils
+        from core.gcmd  import RunCommand, DecodeString
+        from core.utils import GetListOfMapsets, GetListOfLocations
         GRASSStartUp = StartUp(0)
         GRASSStartUp.MainLoop()
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -4,7 +4,6 @@
 @brief wxGUI Graphical Modeler for creating, editing, and managing models
 Classes:
- - ModelerData
  - ModelToolbar
  - ModelFrame
  - ModelCanvas
@@ -57,15 +56,6 @@
 from grass.script import core as grass
-class ModelerData(MenuData):
-    def __init__(self, filename = None):
-        if not filename:
-            gisbase = os.getenv('GISBASE')
-            global etcwxdir
-	    filename = os.path.join(globalvar.ETCWXDIR, 'xml', 'menudata_modeler.xml')
-        MenuData.__init__(self, filename)
 class ModelToolbar(BaseToolbar):
     """!Graphical modeler toolbaro (see gmodeler.py)
Added: grass/trunk/gui/wxpython/gmodeler/menudata.py
--- grass/trunk/gui/wxpython/gmodeler/menudata.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gmodeler/menudata.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -0,0 +1,28 @@
+ at package gmodeler.menudata
+ at brief wxGUI Graphical Modeler - menu data
+Classes:
+ - ModelerData
+(C) 2010-2011 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Martin Landa <landa.martin gmail.com>
+import os
+from core.menudata        import MenuData
+class ModelerData(MenuData):
+    def __init__(self, filename = None):
+        if not filename:
+            gisbase = os.getenv('GISBASE')
+	    filename = os.path.join(globalvar.ETCWXDIR, 'xml', 'menudata_modeler.xml')
+        MenuData.__init__(self, filename)
Property changes on: grass/trunk/gui/wxpython/gmodeler/menudata.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
Modified: grass/trunk/gui/wxpython/gmodeler/model_file.py
--- grass/trunk/gui/wxpython/gmodeler/model_file.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/gmodeler/model_file.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -19,7 +19,7 @@
 import time
 import re
-from gui_core.forms import GUI
+from gui_core.task  import GUI
 from core.gcmd      import GWarning, EncodeString
 class ProcessModelFile:
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -48,7 +48,7 @@
 from core.gcmd        import GError, RunCommand, GMessage
 from gui_core.gselect import ElementSelect, LocationSelect, MapsetSelect, Select, OgrTypeSelect, GdalSelect
-from core.forms       import GUI
 from core.utils       import GetListOfMapsets, GetLayerNameFromCmd, GetValidLayerName
 from core.settings    import UserSettings
 from core.debug       import Debug
@@ -2224,37 +2224,6 @@
     return filetype, ltype
-class StaticWrapText(wx.StaticText):
-    """!A Static Text field that wraps its text to fit its width,
-    enlarging its height if necessary.
-    def __init__(self, parent, id = wx.ID_ANY, label = '', *args, **kwds):
-        self.parent        = parent
-        self.originalLabel = label
-        wx.StaticText.__init__(self, parent, id, label = '', *args, **kwds)
-        self.SetLabel(label)
-        self.Bind(wx.EVT_SIZE, self.OnResize)
-    def SetLabel(self, label):
-        self.wrappedSize = None
-        self.OnResize(None)
-    def OnResize(self, event):
-        if not getattr(self, "resizing", False):
-            self.resizing = True
-            newSize = wx.Size(self.parent.GetSize().width - 50,
-                              self.GetSize().height)
-            if self.wrappedSize != newSize:
-                wx.StaticText.SetLabel(self, self.originalLabel)
-                self.Wrap(newSize.width)
-                self.wrappedSize = newSize
-                self.SetSize(self.wrappedSize)
-            del self.resizing
 class ImageSizeDialog(wx.Dialog):
     """!Set size for saved graphic file"""
     def __init__(self, parent, id = wx.ID_ANY, title = _("Set image size"),
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -11,7 +11,6 @@
  - GrassGUIApp
  - GUI
  - FloatValidator
- - GNotebook
 This program is just a coarse approach to automatically build a GUI
 from a xml-based GRASS user interface description.
@@ -46,13 +45,11 @@
 import sys
-import re
 import string
 import textwrap
 import os
 import time
 import copy
-import locale
 from threading import Thread
 import Queue
@@ -65,17 +62,8 @@
 import wx.lib.colourselect     as csel
-from wx.lib.expando  import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
 from wx.lib.newevent import NewEvent
-try:
-    import xml.etree.ElementTree as etree
-except ImportError:
-    import elementtree.ElementTree as etree # Python <= 2.4
-from gui_core.dialogs import StaticWrapText
-from gui_core.ghelp   import HelpPanel
 gisbase = os.getenv("GISBASE")
 if gisbase is None:
     print >>sys.stderr, "We don't seem to be properly installed, or we are being run outside GRASS. Expect glitches."
@@ -89,15 +77,15 @@
 from grass.script import task as gtask
-from gui_core import gselect
-from core import cmd as gcmd
-from gui_core import goutput
-from core import utils
-from core.settings import UserSettings
-try:
-    import subprocess
-except:
-    from compat import subprocess
+from gui_core.widgets import StaticWrapText
+from gui_core.ghelp   import HelpPanel
+from gui_core         import gselect
+from core             import gcmd
+from core             import utils
+from gui_core.goutput import GMConsole
+from core.settings    import UserSettings
+from gui_core.widgets import FloatValidator
 wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
@@ -834,7 +822,7 @@
         # are we running from command line?
         ### add 'command output' tab regardless standalone dialog
         if self.parent.GetName() ==  "MainFrame" and self.parent.get_dcmd is None:
-            self.goutput = goutput.GMConsole(parent = self, margin = False)
+            self.goutput = GMConsole(parent = self, margin = False)
             self.outpage = self.notebook.AddPage(page = self.goutput, text = _("Command output"), name = 'output')
         else:
             self.goutput = None
@@ -1943,223 +1931,6 @@
         return True
-class GUI:
-    def __init__(self, parent = None, show = True, modal = False,
-                 centreOnParent = False, checkError = False):
-        """!Parses GRASS commands when module is imported and used from
-        Layer Manager.
-        self.show   = show
-        self.modal  = modal
-        self.centreOnParent = centreOnParent
-        self.checkError     = checkError
-        self.grass_task = None
-        self.cmd = list()
-        global _blackList
-        if self.parent:
-            _blackList['enabled'] = True
-        else:
-            _blackList['enabled'] = False
-    def GetCmd(self):
-        """!Get validated command"""
-        return self.cmd
-    def ParseCommand(self, cmd, gmpath = None, completed = None):
-        """!Parse command
-        Note: cmd is given as list
-        If command is given with options, return validated cmd list:
-         - add key name for first parameter if not given
-         - change mapname to mapname at mapset
-        start = time.time()
-        dcmd_params = {}
-        if completed == None:
-            get_dcmd = None
-            layer = None
-            dcmd_params = None
-        else:
-            get_dcmd = completed[0]
-            layer = completed[1]
-            if completed[2]:
-                dcmd_params.update(completed[2])
-        # parse the interface decription
-        try:
-            global _blackList
-            self.grass_task = gtask.parse_interface(cmd[0],
-                                                    blackList = _blackList)
-        except ValueError, e: #grass.ScriptError, e:
-            gcmd.GError(e.value)
-            return
-        # if layer parameters previously set, re-insert them into dialog
-        if completed is not None:
-            if 'params' in dcmd_params:
-                self.grass_task.params = dcmd_params['params']
-            if 'flags' in dcmd_params:
-                self.grass_task.flags = dcmd_params['flags']
-        err = list()
-        # update parameters if needed && validate command
-        if len(cmd) > 1:
-            i = 0
-            cmd_validated = [cmd[0]]
-            for option in cmd[1:]:
-                if option[0] ==  '-': # flag
-                    if option[1] ==  '-':
-                        self.grass_task.set_flag(option[2:], True)
-                    else:
-                        self.grass_task.set_flag(option[1], True)
-                    cmd_validated.append(option)
-                else: # parameter
-                    try:
-                        key, value = option.split('=', 1)
-                    except:
-                        if self.grass_task.firstParam:
-                            if i == 0: # add key name of first parameter if not given
-                                key = self.grass_task.firstParam
-                                value = option
-                            else:
-                                raise gcmd.GException, _("Unable to parse command '%s'") % ' '.join(cmd)
-                        else:
-                            continue
-                    element = self.grass_task.get_param(key, raiseError = False)
-                    if not element:
-                        err.append(_("%(cmd)s: parameter '%(key)s' not available") % \
-                                       { 'cmd' : cmd[0],
-                                         'key' : key })
-                        continue
-                    element = element['element']
-                    if element in ['cell', 'vector']:
-                        # mapname -> mapname at mapset
-                        try:
-                            name, mapset = value.split('@')
-                        except ValueError:
-                            mapset = grass.find_file(value, element)['mapset']
-                            curr_mapset = grass.gisenv()['MAPSET']
-                            if mapset and mapset !=  curr_mapset:
-                                value = value + '@' + mapset
-                    self.grass_task.set_param(key, value)
-                    cmd_validated.append(key + '=' + value)
-                    i += 1
-            # update original command list
-            cmd = cmd_validated
-        if self.show is not None:
-            self.mf = mainFrame(parent = self.parent, ID = wx.ID_ANY,
-                                task_description = self.grass_task,
-                                get_dcmd = get_dcmd, layer = layer)
-        else:
-            self.mf = None
-        if get_dcmd is not None:
-            # update only propwin reference
-            get_dcmd(dcmd = None, layer = layer, params = None,
-                     propwin = self.mf)
-            self.mf.notebookpanel.OnUpdateSelection(None)
-            if self.show is True:
-                if self.parent and self.centreOnParent:
-                    self.mf.CentreOnParent()
-                else:
-                    self.mf.CenterOnScreen()
-                self.mf.Show(self.show)
-                self.mf.MakeModal(self.modal)
-            else:
-                self.mf.OnApply(None)
-        self.cmd = cmd
-        if self.checkError:
-            return self.grass_task, err
-        else:
-    def GetCommandInputMapParamKey(self, cmd):
-        """!Get parameter key for input raster/vector map
-        @param cmd module name
-        @return parameter key
-        @return None on failure
-        if not self.grass_task:
-            enc = locale.getdefaultlocale()[1]
-            if enc and enc.lower() == "cp932":
-                p = re.compile('encoding="' + enc + '"', re.IGNORECASE)
-                tree = etree.fromstring(p.sub('encoding="utf-8"',
-                                              gtask.get_interface_description(cmd).decode(enc).encode('utf-8')))
-            else:
-                tree = etree.fromstring(gtask.get_interface_description(cmd))
-            self.grass_task = gtask.processTask(tree).get_task()
-            for p in self.grass_task.params:
-                if p.get('name', '') in ('input', 'map'):
-                    age = p.get('age', '')
-                    prompt = p.get('prompt', '')
-                    element = p.get('element', '')
-                    if age ==  'old' and \
-                            element in ('cell', 'grid3', 'vector') and \
-                            prompt in ('raster', '3d-raster', 'vector'):
-                        return p.get('name', None)
-        return None
-class FloatValidator(wx.PyValidator):
-    """!Validator for floating-point input"""
-    def __init__(self):
-        wx.PyValidator.__init__(self)
-        self.Bind(wx.EVT_TEXT, self.OnText)
-    def Clone(self):
-        """!Clone validator"""
-        return FloatValidator()
-    def Validate(self):
-        """Validate input"""
-        textCtrl = self.GetWindow()
-        text = textCtrl.GetValue()
-        if text:
-            try:
-                float(text)
-                textCtrl.SetBackgroundColour("grey")
-                textCtrl.SetFocus()
-                textCtrl.Refresh()
-                return False
-        sysColor = wx.SystemSettings_GetColour(wx.SYS_COLOUR_WINDOW)
-        textCtrl.SetBackgroundColour(sysColor)
-        return True
-    def OnText(self, event):
-        """!Do validation"""
-        self.Validate()
-        event.Skip()
-    def TransferToWindow(self):
-        return True # Prevent wxDialog from complaining.
-    def TransferFromWindow(self):
 if __name__ ==  "__main__":
     import gettext
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -5,12 +5,9 @@
 Classes:
  - SearchModuleWindow
- - ItemTree
  - MenuTreeWindow
  - MenuTree
  - AboutWindow
- - InstallExtensionWindow
- - ExtensionTree
  - HelpFrame
  - HelpWindow
  - HelpPanel
@@ -26,6 +23,7 @@
 import codecs
 import wx
+from wx.html import HtmlWindow
 try:
     import wx.lib.agw.customtreectrl as CT
     from wx.lib.agw.hyperlink import HyperLinkCtrl
@@ -33,18 +31,15 @@
     import wx.lib.customtreectrl as CT
     from wx.lib.hyperlink import HyperLinkCtrl
 import wx.lib.flatnotebook as FN
-import  wx.lib.scrolledpanel as scrolled
+import wx.lib.scrolledpanel as scrolled
 import grass.script as grass
-from grass.script import task as gtask
-from core.gcmd        import GError, RunCommand, DecodeString
-from gui_core.widgets import GNotebook
+from core.gcmd        import GError, DecodeString
+from gui_core.widgets import GNotebook, StaticWrapText, ItemTree
 class HelpFrame(wx.Frame):
     """!GRASS Quickstart help window"""
@@ -350,85 +345,6 @@
         event.Skip()
-class ItemTree(CT.CustomTreeCtrl):
-                 ctstyle = CT.TR_HIDE_ROOT | CT.TR_FULL_ROW_HIGHLIGHT | CT.TR_HAS_BUTTONS |
-                 CT.TR_LINES_AT_ROOT | CT.TR_SINGLE, **kwargs):
-        if globalvar.hasAgw:
-            super(ItemTree, self).__init__(parent, id, agwStyle = ctstyle, **kwargs)
-        else:
-            super(ItemTree, self).__init__(parent, id, style = ctstyle, **kwargs)
-        self.root = self.AddRoot(_("Menu tree"))
-        self.itemsMarked = [] # list of marked items
-        self.itemSelected = None
-    def SearchItems(self, element, value):
-        """!Search item
-        @param element element index (see self.searchBy)
-        @param value
-        @return list of found tree items
-        items = list()
-        if not value:
-            return items
-        item = self.GetFirstChild(self.root)[0]
-        self._processItem(item, element, value, items)
-        self.itemsMarked  = items
-        return items
-    def _processItem(self, item, element, value, listOfItems):
-        """!Search items (used by SearchItems)
-        @param item reference item
-        @param listOfItems list of found items
-        while item and item.IsOk():
-            subItem = self.GetFirstChild(item)[0]
-            if subItem:
-                self._processItem(subItem, element, value, listOfItems)
-            data = self.GetPyData(item)
-            if data and element in data and \
-                    value.lower() in data[element].lower():
-                listOfItems.append(item)
-            item = self.GetNextSibling(item)
-    def GetSelected(self):
-        """!Get selected item"""
-        return self.itemSelected
-    def OnShowItem(self, event):
-        """!Highlight first found item in menu tree"""
-        if len(self.itemsMarked) > 0:
-            if self.GetSelected():
-                self.ToggleItemSelection(self.GetSelected())
-                idx = self.itemsMarked.index(self.GetSelected()) + 1
-            else:
-                idx = 0
-            try:
-                self.ToggleItemSelection(self.itemsMarked[idx])
-                self.itemSelected = self.itemsMarked[idx]
-                self.EnsureVisible(self.itemsMarked[idx])
-            except IndexError:
-                self.ToggleItemSelection(self.itemsMarked[0]) # reselect first item
-                self.EnsureVisible(self.itemsMarked[0])
-                self.itemSelected = self.itemsMarked[0]
-        else:
-            for item in self.root.GetChildren():
-                self.Collapse(item)
-            itemSelected = self.GetSelection()
-            if itemSelected:
-                self.ToggleItemSelection(itemSelected)
 class MenuTree(ItemTree):
     """!Menu tree class"""
     def __init__(self, parent, data, **kwargs):
@@ -686,7 +602,7 @@
                 GError(parent = self,
                        message = _("Error when reading file '%s'.") % contribfile + \
                            "\n\n" + _("Lines:") + " %s" % \
-                           os.linesep.join(map(utils.DecodeString, errLines)))
+                           os.linesep.join(map(DecodeString, errLines)))
         else:
             contribs = None
@@ -746,7 +662,7 @@
                        message = _("Error when reading file '%s'.") % translatorsfile + \
         else:
             translators = None
@@ -793,335 +709,7 @@
         """!Close window"""
         self.Close()
-class InstallExtensionWindow(wx.Frame):
-                 title = _("Fetch & install extension from GRASS Addons"), **kwargs):
-        self.options = dict() # list of options
-        wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
-        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
-        self.repoBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
-                                    label = " %s " % _("Repository"))
-        self.treeBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
-                                    label = " %s " % _("List of extensions"))
-        self.repo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
-        self.fullDesc = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
-                                    label = _("Fetch full info including description and keywords (takes time)"))
-        self.fullDesc.SetValue(True)
-        self.search = SearchModuleWindow(parent = self.panel)
-        self.search.SetSelection(0)
-        self.tree   = ExtensionTree(parent = self.panel, log = parent.GetLogWindow())
-        self.optionBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
-                                      label = " %s " % _("Options"))
-        task = gtask.parse_interface('g.extension')
-        for f in task.get_options()['flags']:
-            name = f.get('name', '')
-            desc = f.get('label', '')
-            if not desc:
-                desc = f.get('description', '')
-            if not name and not desc:
-                continue
-            if name in ('l', 'c', 'g', 'quiet', 'verbose'):
-                continue
-            self.options[name] = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
-                                             label = desc)
-        self.repo.SetValue(task.get_param(value = 'svnurl').get('default',
-        'http://svn.osgeo.org/grass/grass-addons/grass7'))
-        self.statusbar = self.CreateStatusBar(number = 1)
-        self.btnFetch = wx.Button(parent = self.panel, id = wx.ID_ANY,
-                                  label = _("&Fetch"))
-        self.btnFetch.SetToolTipString(_("Fetch list of available modules from GRASS Addons SVN repository"))
-        self.btnClose = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
-        self.btnInstall = wx.Button(parent = self.panel, id = wx.ID_ANY,
-                                    label = _("&Install"))
-        self.btnInstall.SetToolTipString(_("Install selected add-ons GRASS module"))
-        self.btnInstall.Enable(False)
-        self.btnCmd = wx.Button(parent = self.panel, id = wx.ID_ANY,
-                                label = _("Command dialog"))
-        self.btnCmd.SetToolTipString(_('Open %s dialog') % 'g.extension')
-        self.btnClose.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
-        self.btnFetch.Bind(wx.EVT_BUTTON, self.OnFetch)
-        self.btnInstall.Bind(wx.EVT_BUTTON, self.OnInstall)
-        self.btnCmd.Bind(wx.EVT_BUTTON, self.OnCmdDialog)
-        self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
-        self.tree.Bind(wx.EVT_TREE_SEL_CHANGED,    self.OnItemSelected)
-        self.search.Bind(wx.EVT_TEXT_ENTER,        self.OnShowItem)
-        self.search.Bind(wx.EVT_TEXT,              self.OnUpdateStatusBar)
-        self._layout()
-    def _layout(self):
-        """!Do layout"""
-        sizer = wx.BoxSizer(wx.VERTICAL)
-        repoSizer = wx.StaticBoxSizer(self.repoBox, wx.VERTICAL)
-        repo1Sizer = wx.BoxSizer(wx.HORIZONTAL)
-        repo1Sizer.Add(item = self.repo, proportion = 1,
-                      flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL, border = 1)
-        repo1Sizer.Add(item = self.btnFetch, proportion = 0,
-        repoSizer.Add(item = repo1Sizer,
-                      flag = wx.EXPAND)
-        repoSizer.Add(item = self.fullDesc)
-        findSizer = wx.BoxSizer(wx.HORIZONTAL)
-        findSizer.Add(item = self.search, proportion = 1)
-        treeSizer = wx.StaticBoxSizer(self.treeBox, wx.HORIZONTAL)
-        treeSizer.Add(item = self.tree, proportion = 1,
-                      flag = wx.ALL | wx.EXPAND, border = 1)
-        # options
-        optionSizer = wx.StaticBoxSizer(self.optionBox, wx.VERTICAL)
-        for key in self.options.keys():
-            optionSizer.Add(item = self.options[key], proportion = 0)
-        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
-        btnSizer.Add(item = self.btnCmd, proportion = 0,
-                     flag = wx.RIGHT, border = 5)
-        btnSizer.AddSpacer(10)
-        btnSizer.Add(item = self.btnClose, proportion = 0,
-        btnSizer.Add(item = self.btnInstall, proportion = 0)
-        sizer.Add(item = repoSizer, proportion = 0,
-                  flag = wx.ALL | wx.EXPAND, border = 3)
-        sizer.Add(item = findSizer, proportion = 0,
-                  flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 3)
-        sizer.Add(item = treeSizer, proportion = 1,
-        sizer.Add(item = optionSizer, proportion = 0,
-        sizer.Add(item = btnSizer, proportion = 0,
-                  flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
-        self.panel.SetSizer(sizer)
-        sizer.Fit(self.panel)
-        self.Layout()
-    def _getCmd(self):
-        item = self.tree.GetSelected()
-        if not item or not item.IsOk():
-            return ['g.extension']
-        name = self.tree.GetItemText(item)
-        if not name:
-            GError(_("Extension not defined"), parent = self)
-            return
-        flags = list()
-            if self.options[key].IsChecked():
-                flags.append('-%s' % key)
-        return ['g.extension'] + flags + ['extension=' + name,
-                                          'svnurl=' + self.repo.GetValue().strip()]
-    def OnUpdateStatusBar(self, event):
-        """!Update statusbar text"""
-        element = self.search.GetSelection()
-        if not self.tree.IsLoaded():
-            self.SetStatusText(_("Fetch list of available extensions by clicking on 'Fetch' button"), 0)
-            return
-        self.tree.SearchItems(element = element,
-                              value = event.GetString())
-        nItems = len(self.tree.itemsMarked)
-        if event.GetString():
-            self.SetStatusText(_("%d items match") % nItems, 0)
-        else:
-            self.SetStatusText("", 0)
-        event.Skip()
-    def OnCloseWindow(self, event):
-        """!Close window"""
-        self.Destroy()
-    def OnFetch(self, event):
-        """!Fetch list of available extensions"""
-        wx.BeginBusyCursor()
-        self.SetStatusText(_("Fetching list of modules from GRASS-Addons SVN (be patient)..."), 0)
-        self.tree.Load(url = self.repo.GetValue().strip(), full = self.fullDesc.IsChecked())
-        wx.EndBusyCursor()
-    def OnItemActivated(self, event):
-        item = event.GetItem()
-        data = self.tree.GetPyData(item)
-        if data and 'command' in data:
-            self.OnInstall(event = None)
-    def OnInstall(self, event):
-        """!Install selected extension"""
-        log = self.parent.GetLogWindow()
-        log.RunCmd(self._getCmd(), onDone = self.OnDone)
-    def OnDone(self, cmd, returncode):
-        if not item or not item.IsOk() or \
-                returncode != 0 or \
-                not os.getenv('GRASS_ADDON_PATH'):
-            return
-        globalvar.grassCmd['all'].append(name)
-    def OnItemSelected(self, event):
-        """!Item selected"""
-        self.tree.itemSelected = item
-        if not data:
-            self.SetStatusText('', 0)
-        else:
-            self.SetStatusText(data.get('description', ''), 0)
-            self.btnInstall.Enable(True)
-        """!Show selected item"""
-        self.tree.OnShowItem(event)
-        if self.tree.GetSelected():
-            self.btnInstall.Enable()
-        else:
-    def OnCmdDialog(self, event):
-        """!Shows command dialog"""
-        GUI(parent = self).ParseCommand(cmd = self._getCmd())
-class ExtensionTree(ItemTree):
-    """!List of available extensions"""
-    def __init__(self, parent, log, id = wx.ID_ANY,
-                 **kwargs):
-        self.parent = parent # GMFrame
-        self.log    = log
-        super(ExtensionTree, self).__init__(parent, id, ctstyle = ctstyle, **kwargs)
-        self._initTree()
-    def _initTree(self):
-        for prefix in ('display', 'database',
-                       'general', 'imagery',
-                       'misc', 'postscript', 'paint',
-                       'raster', 'raster3D', 'sites', 'vector', 'wxGUI', 'other'):
-            self.AppendItem(parentId = self.root,
-                            text = prefix)
-        self._loaded = False
-    def _expandPrefix(self, c):
-        name = { 'd'  : 'display',
-                 'db' : 'database',
-                 'g'  : 'general',
-                 'i'  : 'imagery',
-                 'm'  : 'misc',
-                 'ps' : 'postscript',
-                 'p'  : 'paint',
-                 'r'  : 'raster',
-                 'r3' : 'raster3D',
-                 's'  : 'sites',
-                 'v'  : 'vector',
-                 'wx' : 'wxGUI',
-                 'u'  : 'other' }
-        if c in name:
-            return name[c]
-        return c
-    def _findItem(self, text):
-        """!Find item"""
-            if text == self.GetItemText(item):
-                return item
-        return None
-    def Load(self, url, full = False):
-        """!Load list of extensions"""
-        self.DeleteAllItems()
-        self._initTree()
-        if full:
-            flags = 'g'
-        else:
-            flags = 'l'
-        ret = RunCommand('g.extension', read = True,
-                         svnurl = url,
-                         flags = flags, quiet = True)
-        if not ret:
-            return
-        mdict = dict()
-        for line in ret.splitlines():
-            if full:
-                key, value = line.split('=', 1)
-                if key == 'name':
-                    try:
-                        prefix, name = value.split('.', 1)
-                        prefix = 'u'
-                        name = value
-                    if prefix not in mdict:
-                        mdict[prefix] = dict()
-                    mdict[prefix][name] = dict()
-                else:
-                    mdict[prefix][name][key] = value
-            else:
-                try:
-                    prefix, name = line.strip().split('.', 1)
-                except:
-                    prefix = 'unknown'
-                    name = line.strip()
-                if self._expandPrefix(prefix) == prefix:
-                mdict[prefix][name] = { 'command' : prefix + '.' + name }
-        for prefix in mdict.keys():
-            prefixName = self._expandPrefix(prefix)
-            item = self._findItem(prefixName)
-            names = mdict[prefix].keys()
-            names.sort()
-            for name in names:
-                new = self.AppendItem(parentId = item,
-                                      text = prefix + '.' + name)
-                data = dict()
-                for key in mdict[prefix][name].keys():
-                    data[key] = mdict[prefix][name][key]
-                self.SetPyData(new, data)
-        self._loaded = True
-    def IsLoaded(self):
-        """Check if items are loaded"""
-        return self._loaded
-class HelpWindow(wx.html.HtmlWindow):
+class HelpWindow(HtmlWindow):
     """!This panel holds the text from GRASS docs.
     GISBASE must be set in the environment to find the html docs dir.
@@ -1143,7 +731,7 @@
         wx.InitAllImageHandlers()
-        wx.html.HtmlWindow.__init__(self, parent = parent, **kwargs)
+        HtmlWindow.__init__(self, parent = parent, **kwargs)
         self.loaded = False
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -39,7 +39,7 @@
 from core.gcmd       import CommandThread, GMessage, GError, GException, EncodeString
 from gui_core.prompt import GPromptSTC
 from core.settings   import UserSettings, Settings
Added: grass/trunk/gui/wxpython/gui_core/task.py
--- grass/trunk/gui/wxpython/gui_core/task.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_core/task.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -0,0 +1,210 @@
+ at package gui_core.task
+ at brief Construct simple wxPython GUI from a GRASS command interface
+description.
+Classes:
+ - GUI
+(C) 2000-2011 by the GRASS Development Team
+This program is free software under the GPL(>=v2) Read the file
+COPYING coming with GRASS for details.
+ at author Jan-Oliver Wagner <jan at intevation.de>
+ at author Bernhard Reiter <bernhard at intevation.de>
+ at author Michael Barton, Arizona State University
+ at author Daniel Calvelo <dca.gis at gmail.com>
+ at author Martin Landa <landa.martin at gmail.com>
+ at author Luca Delucchi <lucadeluge at gmail.com>
+import sys
+import re
+import os
+import time
+import locale
+try:
+    import xml.etree.ElementTree as etree
+except ImportError:
+    import elementtree.ElementTree as etree # Python <= 2.4
+import wx
+from grass.script import core as grass
+from grass.script import task as gtask
+from core.gcmd    import GException, GError
+class GUI:
+    def __init__(self, parent = None, show = True, modal = False,
+                 centreOnParent = False, checkError = False):
+        """!Parses GRASS commands when module is imported and used from
+        Layer Manager.
+        self.parent = parent
+        self.show   = show
+        self.modal  = modal
+        self.centreOnParent = centreOnParent
+        self.checkError     = checkError
+        self.grass_task = None
+        self.cmd = list()
+        global _blackList
+        if self.parent:
+            _blackList['enabled'] = True
+        else:
+            _blackList['enabled'] = False
+    def GetCmd(self):
+        """!Get validated command"""
+        return self.cmd
+    def ParseCommand(self, cmd, gmpath = None, completed = None):
+        """!Parse command
+        Note: cmd is given as list
+        If command is given with options, return validated cmd list:
+         - add key name for first parameter if not given
+         - change mapname to mapname at mapset
+        start = time.time()
+        dcmd_params = {}
+        if completed == None:
+            get_dcmd = None
+            layer = None
+            dcmd_params = None
+        else:
+            get_dcmd = completed[0]
+            layer = completed[1]
+            if completed[2]:
+                dcmd_params.update(completed[2])
+        # parse the interface decription
+        try:
+            global _blackList
+            self.grass_task = gtask.parse_interface(cmd[0],
+                                                    blackList = _blackList)
+        except ValueError, e: #grass.ScriptError, e:
+            GError(e.value)
+            return
+        # if layer parameters previously set, re-insert them into dialog
+        if completed is not None:
+            if 'params' in dcmd_params:
+                self.grass_task.params = dcmd_params['params']
+            if 'flags' in dcmd_params:
+                self.grass_task.flags = dcmd_params['flags']
+        err = list()
+        # update parameters if needed && validate command
+        if len(cmd) > 1:
+            i = 0
+            cmd_validated = [cmd[0]]
+            for option in cmd[1:]:
+                if option[0] ==  '-': # flag
+                    if option[1] ==  '-':
+                        self.grass_task.set_flag(option[2:], True)
+                    else:
+                        self.grass_task.set_flag(option[1], True)
+                    cmd_validated.append(option)
+                else: # parameter
+                    try:
+                        key, value = option.split('=', 1)
+                    except:
+                        if self.grass_task.firstParam:
+                            if i == 0: # add key name of first parameter if not given
+                                key = self.grass_task.firstParam
+                                value = option
+                            else:
+                                raise GException, _("Unable to parse command '%s'") % ' '.join(cmd)
+                        else:
+                            continue
+                    element = self.grass_task.get_param(key, raiseError = False)
+                    if not element:
+                        err.append(_("%(cmd)s: parameter '%(key)s' not available") % \
+                                       { 'cmd' : cmd[0],
+                                         'key' : key })
+                        continue
+                    element = element['element']
+                    if element in ['cell', 'vector']:
+                        # mapname -> mapname at mapset
+                        try:
+                            name, mapset = value.split('@')
+                        except ValueError:
+                            mapset = grass.find_file(value, element)['mapset']
+                            curr_mapset = grass.gisenv()['MAPSET']
+                            if mapset and mapset !=  curr_mapset:
+                                value = value + '@' + mapset
+                    self.grass_task.set_param(key, value)
+                    cmd_validated.append(key + '=' + value)
+                    i += 1
+            # update original command list
+            cmd = cmd_validated
+        if self.show is not None:
+            self.mf = mainFrame(parent = self.parent, ID = wx.ID_ANY,
+                                task_description = self.grass_task,
+                                get_dcmd = get_dcmd, layer = layer)
+        else:
+            self.mf = None
+        if get_dcmd is not None:
+            # update only propwin reference
+            get_dcmd(dcmd = None, layer = layer, params = None,
+                     propwin = self.mf)
+            self.mf.notebookpanel.OnUpdateSelection(None)
+            if self.show is True:
+                if self.parent and self.centreOnParent:
+                    self.mf.CentreOnParent()
+                else:
+                    self.mf.CenterOnScreen()
+                self.mf.Show(self.show)
+                self.mf.MakeModal(self.modal)
+            else:
+                self.mf.OnApply(None)
+        self.cmd = cmd
+        if self.checkError:
+            return self.grass_task, err
+        else:
+    def GetCommandInputMapParamKey(self, cmd):
+        """!Get parameter key for input raster/vector map
+        @param cmd module name
+        @return parameter key
+        @return None on failure
+        if not self.grass_task:
+            enc = locale.getdefaultlocale()[1]
+            if enc and enc.lower() == "cp932":
+                p = re.compile('encoding="' + enc + '"', re.IGNORECASE)
+                tree = etree.fromstring(p.sub('encoding="utf-8"',
+                                              gtask.get_interface_description(cmd).decode(enc).encode('utf-8')))
+            else:
+                tree = etree.fromstring(gtask.get_interface_description(cmd))
+            self.grass_task = gtask.processTask(tree).get_task()
+            for p in self.grass_task.params:
+                if p.get('name', '') in ('input', 'map'):
+                    age = p.get('age', '')
+                    prompt = p.get('prompt', '')
+                    element = p.get('element', '')
+                    if age ==  'old' and \
+                            element in ('cell', 'grid3', 'vector') and \
+                            prompt in ('raster', '3d-raster', 'vector'):
+                        return p.get('name', None)
+        return None
Property changes on: grass/trunk/gui/wxpython/gui_core/task.py
   + text/x-python
   + native
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -9,6 +9,9 @@
  - NumTextCtrl
  - FloatSlider
  - SymbolButton
+ - StaticWrapText
+ - FloatValidator
+ - ItemTree
 (C) 2008-2011 by the GRASS Development Team
@@ -31,6 +34,10 @@
     from wx.lib.buttons import ThemedGenBitmapTextButton as BitmapTextButton
 except ImportError: # not sure about TGBTButton version
     from wx.lib.buttons import GenBitmapTextButton as BitmapTextButton
+try:
+    import wx.lib.agw.customtreectrl as CT
+    import wx.lib.customtreectrl as CT
@@ -229,3 +236,157 @@
         dc.SetBrush(wx.Brush(wx.Color(50, 50, 50)))
         dc.DrawRectangle(0, 0, 2 * size[0] / 5, size[1])
         dc.DrawRectangle(3 * size[0] / 5, 0, 2 * size[0] / 5, size[1])
+class StaticWrapText(wx.StaticText):
+    """!A Static Text field that wraps its text to fit its width,
+    enlarging its height if necessary.
+    def __init__(self, parent, id = wx.ID_ANY, label = '', *args, **kwds):
+        self.originalLabel = label
+        wx.StaticText.__init__(self, parent, id, label = '', *args, **kwds)
+        self.SetLabel(label)
+        self.Bind(wx.EVT_SIZE, self.OnResize)
+    def SetLabel(self, label):
+        self.wrappedSize = None
+        self.OnResize(None)
+    def OnResize(self, event):
+        if not getattr(self, "resizing", False):
+            self.resizing = True
+            newSize = wx.Size(self.parent.GetSize().width - 50,
+                              self.GetSize().height)
+            if self.wrappedSize != newSize:
+                wx.StaticText.SetLabel(self, self.originalLabel)
+                self.Wrap(newSize.width)
+                self.wrappedSize = newSize
+                self.SetSize(self.wrappedSize)
+            del self.resizing
+class FloatValidator(wx.PyValidator):
+    """!Validator for floating-point input"""
+    def __init__(self):
+        wx.PyValidator.__init__(self)
+        self.Bind(wx.EVT_TEXT, self.OnText)
+    def Clone(self):
+        """!Clone validator"""
+        return FloatValidator()
+    def Validate(self):
+        """Validate input"""
+        textCtrl = self.GetWindow()
+        text = textCtrl.GetValue()
+        if text:
+            try:
+                float(text)
+                textCtrl.SetBackgroundColour("grey")
+                textCtrl.SetFocus()
+                textCtrl.Refresh()
+                return False
+        sysColor = wx.SystemSettings_GetColour(wx.SYS_COLOUR_WINDOW)
+        textCtrl.SetBackgroundColour(sysColor)
+        return True
+    def OnText(self, event):
+        """!Do validation"""
+        self.Validate()
+        event.Skip()
+    def TransferToWindow(self):
+        return True # Prevent wxDialog from complaining.
+    def TransferFromWindow(self):
+class ItemTree(CT.CustomTreeCtrl):
+                 ctstyle = CT.TR_HIDE_ROOT | CT.TR_FULL_ROW_HIGHLIGHT | CT.TR_HAS_BUTTONS |
+                 CT.TR_LINES_AT_ROOT | CT.TR_SINGLE, **kwargs):
+        if globalvar.hasAgw:
+            super(ItemTree, self).__init__(parent, id, agwStyle = ctstyle, **kwargs)
+        else:
+            super(ItemTree, self).__init__(parent, id, style = ctstyle, **kwargs)
+        self.root = self.AddRoot(_("Menu tree"))
+        self.itemsMarked = [] # list of marked items
+        self.itemSelected = None
+    def SearchItems(self, element, value):
+        """!Search item
+        @param element element index (see self.searchBy)
+        @param value
+        @return list of found tree items
+        items = list()
+        if not value:
+            return items
+        item = self.GetFirstChild(self.root)[0]
+        self._processItem(item, element, value, items)
+        self.itemsMarked  = items
+        return items
+    def _processItem(self, item, element, value, listOfItems):
+        """!Search items (used by SearchItems)
+        @param item reference item
+        @param listOfItems list of found items
+        while item and item.IsOk():
+            subItem = self.GetFirstChild(item)[0]
+            if subItem:
+                self._processItem(subItem, element, value, listOfItems)
+            data = self.GetPyData(item)
+            if data and element in data and \
+                    value.lower() in data[element].lower():
+                listOfItems.append(item)
+            item = self.GetNextSibling(item)
+    def GetSelected(self):
+        """!Get selected item"""
+        return self.itemSelected
+    def OnShowItem(self, event):
+        """!Highlight first found item in menu tree"""
+        if len(self.itemsMarked) > 0:
+            if self.GetSelected():
+                self.ToggleItemSelection(self.GetSelected())
+                idx = self.itemsMarked.index(self.GetSelected()) + 1
+            else:
+                idx = 0
+            try:
+                self.ToggleItemSelection(self.itemsMarked[idx])
+                self.itemSelected = self.itemsMarked[idx]
+                self.EnsureVisible(self.itemsMarked[idx])
+            except IndexError:
+                self.ToggleItemSelection(self.itemsMarked[0]) # reselect first item
+                self.EnsureVisible(self.itemsMarked[0])
+                self.itemSelected = self.itemsMarked[0]
+        else:
+            for item in self.root.GetChildren():
+                self.Collapse(item)
+            itemSelected = self.GetSelection()
+            if itemSelected:
+                self.ToggleItemSelection(itemSelected)
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -30,7 +30,7 @@
 from gui_core.dialogs    import SqlQueryFrame, SetOpacityDialog
 from mapdisp.frame       import MapFrame
 from core.render         import Map
 from modules.histogram   import HistogramFrame
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -50,9 +50,9 @@
 from icon               import Icons
 from gui_core.mapdisp   import MapFrameBase
-from mapdisp.window     import BufferedWindow
-from modules.histogram  import HistFrame
-from wxplot.histogram   import HistFrame as HistFramePyPlot
+from mapdisp.mapwindow  import BufferedWindow
+from modules.histogram  import HistogramFrame
+from wxplot.histogram   import Histogram2Frame
 from wxplot.profile     import ProfileFrame
 from wxplot.scatter     import ScatterFrame
@@ -1105,10 +1105,10 @@
                 continue
             raster.append(self.tree.GetPyData(layer)[0]['maplayer'].GetName())
-        self.histogramPyPlot = HistFramePyPlot(self, id = wx.ID_ANY,
-                                                pos = wx.DefaultPosition, size = (700,300),
-                                                style = wx.DEFAULT_FRAME_STYLE,
-                                                rasterList = raster)
+        self.histogramPyPlot = Histogram2Frame(self, id = wx.ID_ANY,
+                                               pos = wx.DefaultPosition, size = (700,300),
+                                               style = wx.DEFAULT_FRAME_STYLE,
+                                               rasterList = raster)
         self.histogramPyPlot.Show()
         # Open raster select dialog to make sure that a raster (and the desired raster)
         # is selected to be histogrammed
Modified: grass/trunk/gui/wxpython/modules/colorrules.py
--- grass/trunk/gui/wxpython/modules/colorrules.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/modules/colorrules.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -38,7 +38,7 @@
 from core.gcmd        import GMessage, RunCommand
 from gui_core.gselect import Select, LayerSelect, ColumnSelect, VectorDBInfo
 from core.debug       import Debug as Debug
 from nviz.mapwindow   import wxUpdateProperties
Added: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/modules/extensions.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -0,0 +1,360 @@
+ at package modules.extensions
+ at brief GRASS Addons extensions management classes
+Classes:
+ - InstallExtensionWindow
+ - ExtensionTree
+(C) 2008-2011 by the GRASS Development Team
+import os
+import wx
+try:
+import wx.lib.flatnotebook as FN
+import grass.script as grass
+from core.gcmd        import GError, RunCommand
+from gui_core.widgets import ItemTree
+class InstallExtensionWindow(wx.Frame):
+                 title = _("Fetch & install extension from GRASS Addons"), **kwargs):
+        self.options = dict() # list of options
+        wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
+        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.repoBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+                                    label = " %s " % _("Repository"))
+        self.treeBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+                                    label = " %s " % _("List of extensions"))
+        self.repo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY)
+        self.fullDesc = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
+                                    label = _("Fetch full info including description and keywords (takes time)"))
+        self.fullDesc.SetValue(True)
+        self.search = SearchModuleWindow(parent = self.panel)
+        self.search.SetSelection(0)
+        self.tree   = ExtensionTree(parent = self.panel, log = parent.GetLogWindow())
+        self.optionBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+                                      label = " %s " % _("Options"))
+        task = gtask.parse_interface('g.extension')
+        for f in task.get_options()['flags']:
+            name = f.get('name', '')
+            desc = f.get('label', '')
+            if not desc:
+                desc = f.get('description', '')
+            if not name and not desc:
+                continue
+            if name in ('l', 'c', 'g', 'quiet', 'verbose'):
+                continue
+            self.options[name] = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
+                                             label = desc)
+        self.repo.SetValue(task.get_param(value = 'svnurl').get('default',
+        'http://svn.osgeo.org/grass/grass-addons/grass7'))
+        self.statusbar = self.CreateStatusBar(number = 1)
+        self.btnFetch = wx.Button(parent = self.panel, id = wx.ID_ANY,
+                                  label = _("&Fetch"))
+        self.btnFetch.SetToolTipString(_("Fetch list of available modules from GRASS Addons SVN repository"))
+        self.btnClose = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
+        self.btnInstall = wx.Button(parent = self.panel, id = wx.ID_ANY,
+                                    label = _("&Install"))
+        self.btnInstall.SetToolTipString(_("Install selected add-ons GRASS module"))
+        self.btnInstall.Enable(False)
+        self.btnCmd = wx.Button(parent = self.panel, id = wx.ID_ANY,
+                                label = _("Command dialog"))
+        self.btnCmd.SetToolTipString(_('Open %s dialog') % 'g.extension')
+        self.btnClose.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
+        self.btnFetch.Bind(wx.EVT_BUTTON, self.OnFetch)
+        self.btnInstall.Bind(wx.EVT_BUTTON, self.OnInstall)
+        self.btnCmd.Bind(wx.EVT_BUTTON, self.OnCmdDialog)
+        self.tree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnItemActivated)
+        self.tree.Bind(wx.EVT_TREE_SEL_CHANGED,    self.OnItemSelected)
+        self.search.Bind(wx.EVT_TEXT_ENTER,        self.OnShowItem)
+        self.search.Bind(wx.EVT_TEXT,              self.OnUpdateStatusBar)
+        self._layout()
+    def _layout(self):
+        """!Do layout"""
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        repoSizer = wx.StaticBoxSizer(self.repoBox, wx.VERTICAL)
+        repo1Sizer = wx.BoxSizer(wx.HORIZONTAL)
+        repo1Sizer.Add(item = self.repo, proportion = 1,
+                      flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL, border = 1)
+        repo1Sizer.Add(item = self.btnFetch, proportion = 0,
+        repoSizer.Add(item = repo1Sizer,
+                      flag = wx.EXPAND)
+        repoSizer.Add(item = self.fullDesc)
+        findSizer = wx.BoxSizer(wx.HORIZONTAL)
+        findSizer.Add(item = self.search, proportion = 1)
+        treeSizer = wx.StaticBoxSizer(self.treeBox, wx.HORIZONTAL)
+        treeSizer.Add(item = self.tree, proportion = 1,
+                      flag = wx.ALL | wx.EXPAND, border = 1)
+        # options
+        optionSizer = wx.StaticBoxSizer(self.optionBox, wx.VERTICAL)
+        for key in self.options.keys():
+            optionSizer.Add(item = self.options[key], proportion = 0)
+        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+        btnSizer.Add(item = self.btnCmd, proportion = 0,
+                     flag = wx.RIGHT, border = 5)
+        btnSizer.AddSpacer(10)
+        btnSizer.Add(item = self.btnClose, proportion = 0,
+        btnSizer.Add(item = self.btnInstall, proportion = 0)
+        sizer.Add(item = repoSizer, proportion = 0,
+                  flag = wx.ALL | wx.EXPAND, border = 3)
+        sizer.Add(item = findSizer, proportion = 0,
+                  flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 3)
+        sizer.Add(item = treeSizer, proportion = 1,
+        sizer.Add(item = optionSizer, proportion = 0,
+        sizer.Add(item = btnSizer, proportion = 0,
+                  flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+        self.panel.SetSizer(sizer)
+        sizer.Fit(self.panel)
+        self.Layout()
+    def _getCmd(self):
+        item = self.tree.GetSelected()
+        if not item or not item.IsOk():
+            return ['g.extension']
+        name = self.tree.GetItemText(item)
+        if not name:
+            GError(_("Extension not defined"), parent = self)
+            return
+        flags = list()
+            if self.options[key].IsChecked():
+                flags.append('-%s' % key)
+        return ['g.extension'] + flags + ['extension=' + name,
+                                          'svnurl=' + self.repo.GetValue().strip()]
+    def OnUpdateStatusBar(self, event):
+        """!Update statusbar text"""
+        element = self.search.GetSelection()
+        if not self.tree.IsLoaded():
+            self.SetStatusText(_("Fetch list of available extensions by clicking on 'Fetch' button"), 0)
+            return
+        self.tree.SearchItems(element = element,
+                              value = event.GetString())
+        nItems = len(self.tree.itemsMarked)
+        if event.GetString():
+            self.SetStatusText(_("%d items match") % nItems, 0)
+        else:
+            self.SetStatusText("", 0)
+        event.Skip()
+    def OnCloseWindow(self, event):
+        """!Close window"""
+        self.Destroy()
+    def OnFetch(self, event):
+        """!Fetch list of available extensions"""
+        wx.BeginBusyCursor()
+        self.SetStatusText(_("Fetching list of modules from GRASS-Addons SVN (be patient)..."), 0)
+        self.tree.Load(url = self.repo.GetValue().strip(), full = self.fullDesc.IsChecked())
+        wx.EndBusyCursor()
+    def OnItemActivated(self, event):
+        item = event.GetItem()
+        data = self.tree.GetPyData(item)
+        if data and 'command' in data:
+            self.OnInstall(event = None)
+    def OnInstall(self, event):
+        """!Install selected extension"""
+        log = self.parent.GetLogWindow()
+        log.RunCmd(self._getCmd(), onDone = self.OnDone)
+    def OnDone(self, cmd, returncode):
+        if not item or not item.IsOk() or \
+                returncode != 0 or \
+                not os.getenv('GRASS_ADDON_PATH'):
+            return
+        globalvar.grassCmd['all'].append(name)
+    def OnItemSelected(self, event):
+        """!Item selected"""
+        self.tree.itemSelected = item
+        if not data:
+            self.SetStatusText('', 0)
+        else:
+            self.SetStatusText(data.get('description', ''), 0)
+            self.btnInstall.Enable(True)
+        """!Show selected item"""
+        self.tree.OnShowItem(event)
+        if self.tree.GetSelected():
+            self.btnInstall.Enable()
+        else:
+    def OnCmdDialog(self, event):
+        """!Shows command dialog"""
+        GUI(parent = self).ParseCommand(cmd = self._getCmd())
+class ExtensionTree(ItemTree):
+    """!List of available extensions"""
+    def __init__(self, parent, log, id = wx.ID_ANY,
+                 **kwargs):
+        self.parent = parent # GMFrame
+        self.log    = log
+        super(ExtensionTree, self).__init__(parent, id, ctstyle = ctstyle, **kwargs)
+        self._initTree()
+    def _initTree(self):
+        for prefix in ('display', 'database',
+                       'general', 'imagery',
+                       'misc', 'postscript', 'paint',
+                       'raster', 'raster3D', 'sites', 'vector', 'wxGUI', 'other'):
+            self.AppendItem(parentId = self.root,
+                            text = prefix)
+        self._loaded = False
+    def _expandPrefix(self, c):
+        name = { 'd'  : 'display',
+                 'db' : 'database',
+                 'g'  : 'general',
+                 'i'  : 'imagery',
+                 'm'  : 'misc',
+                 'ps' : 'postscript',
+                 'p'  : 'paint',
+                 'r'  : 'raster',
+                 'r3' : 'raster3D',
+                 's'  : 'sites',
+                 'v'  : 'vector',
+                 'wx' : 'wxGUI',
+                 'u'  : 'other' }
+        if c in name:
+            return name[c]
+        return c
+    def _findItem(self, text):
+        """!Find item"""
+            if text == self.GetItemText(item):
+                return item
+        return None
+    def Load(self, url, full = False):
+        """!Load list of extensions"""
+        self.DeleteAllItems()
+        self._initTree()
+        if full:
+            flags = 'g'
+        else:
+            flags = 'l'
+        ret = RunCommand('g.extension', read = True,
+                         svnurl = url,
+                         flags = flags, quiet = True)
+        if not ret:
+            return
+        mdict = dict()
+        for line in ret.splitlines():
+            if full:
+                key, value = line.split('=', 1)
+                if key == 'name':
+                    try:
+                        prefix, name = value.split('.', 1)
+                        prefix = 'u'
+                        name = value
+                    if prefix not in mdict:
+                        mdict[prefix] = dict()
+                    mdict[prefix][name] = dict()
+                else:
+                    mdict[prefix][name][key] = value
+            else:
+                try:
+                    prefix, name = line.strip().split('.', 1)
+                except:
+                    prefix = 'unknown'
+                    name = line.strip()
+                if self._expandPrefix(prefix) == prefix:
+                mdict[prefix][name] = { 'command' : prefix + '.' + name }
+        for prefix in mdict.keys():
+            prefixName = self._expandPrefix(prefix)
+            item = self._findItem(prefixName)
+            names = mdict[prefix].keys()
+            names.sort()
+            for name in names:
+                new = self.AppendItem(parentId = item,
+                                      text = prefix + '.' + name)
+                data = dict()
+                for key in mdict[prefix][name].keys():
+                    data[key] = mdict[prefix][name][key]
+                self.SetPyData(new, data)
+        self._loaded = True
+    def IsLoaded(self):
+        """Check if items are loaded"""
+        return self._loaded
Property changes on: grass/trunk/gui/wxpython/modules/extensions.py
   + text/x-python
   + native
Modified: grass/trunk/gui/wxpython/modules/histogram.py
--- grass/trunk/gui/wxpython/modules/histogram.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/modules/histogram.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -22,7 +22,7 @@
 from mapdisp.gprint       import PrintOptions
 from core.utils           import GetLayerNameFromCmd
 from gui_core.dialogs     import GetImageHandlers, ImageSizeDialog
@@ -258,7 +258,7 @@
         self.Draw(self.pdc, pdctype = 'clear')
-class HistFrame(wx.Frame):
+class HistogramFrame(wx.Frame):
     """!Main frame for hisgram display window. Uses d.histogram
     rendered onto canvas
Modified: grass/trunk/gui/wxpython/modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/modules/mcalc_builder.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/modules/mcalc_builder.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -24,7 +24,7 @@
 class MapCalcFrame(wx.Frame):
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -34,16 +34,15 @@
-from core.gcmd        import GMessage, GException, GError
-from core.debug       import Debug
-from mapdisp.window   import MapWindow
-from gui_core.goutput import wxCmdOutput
-from nviz.workspace   import NvizSettings
-from nviz.animation   import Animation
+from core.gcmd          import GMessage, GException, GError
+from core.debug         import Debug
+from gui_core.mapwindow import MapWindow
+from gui_core.goutput   import wxCmdOutput
+from nviz.workspace     import NvizSettings
+from nviz.animation     import Animation
+from nviz               import wxnviz
-import nviz.wxcore as wxnviz
 wxUpdateProperties, EVT_UPDATE_PROP  = NewEvent()
 wxUpdateView,       EVT_UPDATE_VIEW  = NewEvent()
 wxUpdateLight,      EVT_UPDATE_LIGHT = NewEvent()
Modified: grass/trunk/gui/wxpython/psmap/frame.py
--- grass/trunk/gui/wxpython/psmap/frame.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/psmap/frame.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -41,7 +41,7 @@
 from psmap.toolbars   import PsMapToolbar
 from icon             import Icons, MetaIcon, iconSet
 from core.gcmd        import RunCommand, GError, GMessage
 from psmap.dialogs    import *
 class PsMapFrame(wx.Frame):
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2011-11-24 11:46:55 UTC (rev 49347)
+++ grass/trunk/gui/wxpython/wxgui.py	2011-11-24 13:56:11 UTC (rev 49348)
@@ -53,7 +53,7 @@
 from lmgr.layertree        import LayerTree
 from modules.mcalc_builder import MapCalcFrame
 from dbm.manager           import AttributeManager
 from core.workspace        import ProcessWorkspaceFile, ProcessGrcFile, WriteWorkspaceFile
@@ -69,7 +69,8 @@
 from nviz.tools            import NvizToolWindow
 from psmap.frame           import PsMapFrame
-from gui_core.ghelp        import MenuTreeWindow, AboutWindow, InstallExtensionWindow
+from gui_core.ghelp        import MenuTreeWindow, AboutWindow
+from modules.extensions    import InstallExtensionWindow
 from lmgr.toolbars         import LMWorkspaceToolbar, LMDataToolbar, LMToolsToolbar
 from lmgr.toolbars         import LMMiscToolbar, LMVectorToolbar, LMNvizToolbar
 from lmgr.pyshell          import PyShellWindow
