[GRASS-SVN] r49361 - in grass/trunk/gui/wxpython: . core gcp
gmodeler gui_core psmap
svn_grass at osgeo.org
Fri Nov 25 16:09:24 EST 2011
Author: martinl
Date: 2011-11-25 13:09:24 -0800 (Fri, 25 Nov 2011)
New Revision: 49361
Added:
grass/trunk/gui/wxpython/gcp/mapdisplay.py
Removed:
grass/trunk/gui/wxpython/gcp/mapdisp.py
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/gcp/manager.py
grass/trunk/gui/wxpython/gmodeler/dialogs.py
grass/trunk/gui/wxpython/gmodeler/frame.py
grass/trunk/gui/wxpython/gmodeler/model.py
grass/trunk/gui/wxpython/gui_core/dialogs.py
grass/trunk/gui/wxpython/psmap/frame.py
grass/trunk/gui/wxpython/psmap/menudata.py
grass/trunk/gui/wxpython/psmap/toolbars.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI major code reorganization (more fixes)
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/core/utils.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -50,8 +50,6 @@
@return Path to file name (string) or None
- from core import cmd as gcmd
ret = RunCommand('g.tempfile',
read = True,
pid = os.getpid())
Modified: grass/trunk/gui/wxpython/gcp/manager.py
--- grass/trunk/gui/wxpython/gcp/manager.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/gcp/manager.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -39,11 +39,10 @@
from core import utils
from core.render import Map
from gui_core.gselect import Select, LocationSelect, MapsetSelect
-from gui_core.gdialogs import GroupDialog
+from gui_core.dialogs import GroupDialog
from core.gcmd import RunCommand, GMessage, GError, GWarning
from core.settings import UserSettings
-from gcp.mapdisp import MapFrame
-from mapdisp.window import BufferedWindow
+from gcp.mapdisplay import MapFrame
from location_wizard.wizard import TitledPage as TitledPage
Deleted: grass/trunk/gui/wxpython/gcp/mapdisp.py
--- grass/trunk/gui/wxpython/gcp/mapdisp.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/gcp/mapdisp.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -1,629 +0,0 @@
- at package gcp.mapdisp
- at brief Display to manage ground control points with two toolbars, one
-for various display management functions, one for manipulating GCPs.
-Classes:
-- MapFrame
-(C) 2006-2011 by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
- at author Markus Metz
-import os
-import math
-import platform
-from core import globalvar
-import wx
-import wx.aui
-from core.render import EVT_UPDATE_PRGBAR
-from mapdisp.toolbars import MapToolbar
-from gcp.toolbars import GCPDisplayToolbar, GCPManToolbar
-from mapdisp.gprint import PrintOptions
-from core.gcmd import GMessage
-from gui_core.dialogs import GetImageHandlers, ImageSizeDialog
-from gui_core.mapdisp import MapFrameBase
-from core.settings import UserSettings
-import mapdisp.statusbar as sb
-# for standalone app
-cmdfilename = None
-class MapFrame(MapFrameBase):
- """!Main frame for map display window. Drawing takes place in
- child double buffered drawing window.
- def __init__(self, parent=None, title=_("GRASS GIS Manage Ground Control Points"),
- toolbars=["gcpdisp"], tree=None, notebook=None, lmgr=None,
- page=None, Map=None, auimgr=None, name = 'GCPMapWindow', **kwargs):
- """!Main map display window with toolbars, statusbar and
- DrawWindow
- @param toolbars array of activated toolbars, e.g. ['map', 'digit']
- @param tree reference to layer tree
- @param notebook control book ID in Layer Manager
- @param lmgr Layer Manager
- @param page notebook page with layer tree
- @param Map instance of render.Map
- @param auimgs AUI manager
- @param kwargs wx.Frame attribures
- MapFrameBase.__init__(self, parent = parent, title = title, toolbars = toolbars,
- Map = Map, auimgr = auimgr, name = name, **kwargs)
- self._layerManager = lmgr # Layer Manager object
- self.tree = tree # Layer Manager layer tree object
- self.page = page # Notebook page holding the layer tree
- self.layerbook = notebook # Layer Manager layer tree notebook
- # Add toolbars
- for toolb in toolbars:
- self.AddToolbar(toolb)
- self.activemap = self.toolbars['gcpdisp'].togglemap
- self.activemap.SetSelection(0)
- self.SrcMap = self.grwiz.SrcMap # instance of render.Map
- self.TgtMap = self.grwiz.TgtMap # instance of render.Map
- self._mgr.SetDockSizeConstraint(0.5, 0.5)
- # Add statusbar
- # items for choice
- self.statusbarItems = [sb.SbCoordinates,
- sb.SbRegionExtent,
- sb.SbCompRegionExtent,
- sb.SbShowRegion,
- sb.SbResolution,
- sb.SbDisplayGeometry,
- sb.SbMapScale,
- sb.SbProjection,
- sb.SbGoToGCP,
- sb.SbRMSError]
- # create statusbar and its manager
- statusbar = self.CreateStatusBar(number = 4, style = 0)
- statusbar.SetStatusWidths([-5, -2, -1, -1])
- self.statusbarManager = sb.SbManager(mapframe = self, statusbar = statusbar)
- # fill statusbar manager
- self.statusbarManager.AddStatusbarItemsByClass(self.statusbarItems, mapframe = self, statusbar = statusbar)
- self.statusbarManager.AddStatusbarItem(sb.SbMask(self, statusbar = statusbar, position = 2))
- self.statusbarManager.AddStatusbarItem(sb.SbRender(self, statusbar = statusbar, position = 3))
- self.statusbarManager.SetMode(8) # goto GCP
- self.statusbarManager.Update()
- # Init map display (buffered DC & set default cursor)
- self.grwiz.SwitchEnv('source')
- self.SrcMapWindow = BufferedWindow(self, id=wx.ID_ANY,
- Map=self.SrcMap, tree=self.tree, lmgr=self._layerManager)
- self.grwiz.SwitchEnv('target')
- self.TgtMapWindow = BufferedWindow(self, id=wx.ID_ANY,
- Map=self.TgtMap, tree=self.tree, lmgr=self._layerManager)
- self.MapWindow = self.SrcMapWindow
- self.Map = self.SrcMap
- self.SrcMapWindow.SetCursor(self.cursors["cross"])
- self.TgtMapWindow.SetCursor(self.cursors["cross"])
- # initialize region values
- self._initMap(map = self.SrcMap)
- self._initMap(map = self.TgtMap)
- # Bind various events
- self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
- self.Bind(EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
- self.Bind(wx.EVT_SIZE, self.OnDispResize)
- self.activemap.Bind(wx.EVT_CHOICE, self.OnUpdateActive)
- # Update fancy gui style
- # AuiManager wants a CentrePane, workaround to get two equally sized windows
- self.list = self.CreateGCPList()
- #self.SrcMapWindow.SetSize((300, 300))
- #self.TgtMapWindow.SetSize((300, 300))
- self.list.SetSize((100, 150))
- self._mgr.AddPane(self.list, wx.aui.AuiPaneInfo().
- Name("gcplist").Caption(_("GCP List")).LeftDockable(False).
- RightDockable(False).PinButton().FloatingSize((600,200)).
- CloseButton(False).DestroyOnClose(True).
- Top().Layer(1).MinSize((200,100)))
- self._mgr.AddPane(self.SrcMapWindow, wx.aui.AuiPaneInfo().
- Name("source").Caption(_("Source Display")).Dockable(False).
- CloseButton(False).DestroyOnClose(True).Floatable(False).
- Centre())
- self._mgr.AddPane(self.TgtMapWindow, wx.aui.AuiPaneInfo().
- Name("target").Caption(_("Target Display")).Dockable(False).
- Right().Layer(0))
- srcwidth, srcheight = self.SrcMapWindow.GetSize()
- tgtwidth, tgtheight = self.TgtMapWindow.GetSize()
- srcwidth = (srcwidth + tgtwidth) / 2
- self._mgr.GetPane("target").Hide()
- self._mgr.Update()
- self._mgr.GetPane("source").BestSize((srcwidth, srcheight))
- self._mgr.GetPane("target").BestSize((srcwidth, srcheight))
- if self.show_target:
- self._mgr.GetPane("target").Show()
- else:
- self.activemap.Enable(False)
- # needed by Mac OS, does not harm on Linux, breaks display on Windows
- if platform.system() != 'Windows':
- # Init print module and classes
- self.printopt = PrintOptions(self, self.MapWindow)
- # Initialization of digitization tool
- self.digit = None
- # set active map
- # do not init zoom history here, that happens when zooming to map(s)
- # Re-use dialogs
- self.dialogs = {}
- self.dialogs['attributes'] = None
- self.dialogs['category'] = None
- self.dialogs['barscale'] = None
- self.dialogs['legend'] = None
- self.decorationDialog = None # decoration/overlays
- def AddToolbar(self, name):
- """!Add defined toolbar to the window
- Currently known toolbars are:
- - 'map' - basic map toolbar
- - 'vdigit' - vector digitizer
- - 'gcpdisp' - GCP Manager, Display
- - 'gcpman' - GCP Manager, points management
- - 'nviz' - 3D view mode
- # default toolbar
- if name == "map":
- self.toolbars['map'] = MapToolbar(self, self.Map)
- self._mgr.AddPane(self.toolbars['map'],
- wx.aui.AuiPaneInfo().
- Name("maptoolbar").Caption(_("Map Toolbar")).
- ToolbarPane().Top().
- LeftDockable(False).RightDockable(False).
- BottomDockable(False).TopDockable(True).
- CloseButton(False).Layer(2).
- BestSize((self.toolbars['map'].GetSize())))
- # GCP display
- elif name == "gcpdisp":
- self.toolbars['gcpdisp'] = GCPDisplayToolbar(self)
- self._mgr.AddPane(self.toolbars['gcpdisp'],
- Name("gcpdisplaytoolbar").Caption(_("GCP Display toolbar")).
- CloseButton(False).Layer(2))
- if self.show_target == False:
- self.toolbars['gcpdisp'].Enable('zoommenu', enable = False)
- self.toolbars['gcpman'] = GCPManToolbar(self)
- self._mgr.AddPane(self.toolbars['gcpman'],
- Name("gcpmanagertoolbar").Caption(_("GCP Manager toolbar")).
- ToolbarPane().Top().Row(1).
- def OnUpdateProgress(self, event):
- Update progress bar info
- self.GetProgressBar().SetValue(event.value)
- event.Skip()
- def OnFocus(self, event):
- Change choicebook page to match display.
- Or set display for georectifying
- if self._layerManager and \
- self._layerManager.gcpmanagement:
- # in GCP Management, set focus to current MapWindow for mouse actions
- self.OnPointer(event)
- self.MapWindow.SetFocus()
- else:
- # change bookcontrol page to page associated with display
- # GCP Manager: use bookcontrol?
- if self.page:
- pgnum = self.layerbook.GetPageIndex(self.page)
- if pgnum > -1:
- self.layerbook.SetSelection(pgnum)
- event.Skip()
- def OnDraw(self, event):
- """!Re-display current map composition
- self.MapWindow.UpdateMap(render = False)
- def OnRender(self, event):
- """!Re-render map composition (each map layer)
- # delete tmp map layers (queries)
- qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
- for layer in qlayer:
- self.Map.DeleteLayer(layer)
- self.SrcMapWindow.UpdateMap(render=True)
- self.TgtMapWindow.UpdateMap(render=True)
- # update statusbar
- self.StatusbarUpdate()
- def OnPointer(self, event):
- """!Pointer button clicked
- # change the cursor
- self.SrcMapWindow.mouse['use'] = "pointer"
- self.SrcMapWindow.mouse['box'] = "point"
- self.TgtMapWindow.mouse['use'] = "pointer"
- self.TgtMapWindow.mouse['box'] = "point"
- def OnZoomIn(self, event):
- Zoom in the map.
- Set mouse cursor, zoombox attributes, and zoom direction
- if self.GetToolbar('map'):
- self.toolbars['map'].OnTool(event)
- self.toolbars['map'].action['desc'] = ''
- self.MapWindow.mouse['use'] = "zoom"
- self.MapWindow.mouse['box'] = "box"
- self.MapWindow.zoomtype = 1
- self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
- self.MapWindow.SetCursor(self.cursors["cross"])
- if self.MapWindow == self.SrcMapWindow:
- win = self.TgtMapWindow
- elif self.MapWindow == self.TgtMapWindow:
- win = self.SrcMapWindow
- win.mouse['use'] = "zoom"
- win.mouse['box'] = "box"
- win.zoomtype = 1
- win.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
- win.SetCursor(self.cursors["cross"])
- def OnZoomOut(self, event):
- Zoom out the map.
- self.MapWindow.zoomtype = -1
- win.zoomtype = -1
- def OnPan(self, event):
- Panning, set mouse to drag
- self.MapWindow.mouse['use'] = "pan"
- self.MapWindow.mouse['box'] = "pan"
- self.MapWindow.zoomtype = 0
- self.MapWindow.SetCursor(self.cursors["hand"])
- win.mouse['use'] = "pan"
- win.mouse['box'] = "pan"
- win.zoomtype = 0
- win.SetCursor(self.cursors["hand"])
- def OnErase(self, event):
- Erase the canvas
- self.MapWindow.EraseMap()
- win.EraseMap()
- def OnZoomRegion(self, event):
- Zoom to region
- self.Map.getRegion()
- self.Map.getResolution()
- self.UpdateMap()
- # event.Skip()
- def OnAlignRegion(self, event):
- Align region
- if not self.Map.alignRegion:
- self.Map.alignRegion = True
- else:
- self.Map.alignRegion = False
- # event.Skip()
- def SaveToFile(self, event):
- """!Save map to image
- img = self.MapWindow.img
- if not img:
- GMessage(parent = self,
- message = _("Nothing to render (empty map). Operation canceled."))
- return
- filetype, ltype = GetImageHandlers(img)
- # get size
- dlg = ImageSizeDialog(self)
- dlg.CentreOnParent()
- if dlg.ShowModal() != wx.ID_OK:
- dlg.Destroy()
- return
- width, height = dlg.GetValues()
- dlg.Destroy()
- # get filename
- dlg = wx.FileDialog(parent = self,
- message = _("Choose a file name to save the image "
- "(no need to add extension)"),
- wildcard = filetype,
- style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
- if dlg.ShowModal() == wx.ID_OK:
- path = dlg.GetPath()
- if not path:
- dlg.Destroy()
- return
- base, ext = os.path.splitext(path)
- fileType = ltype[dlg.GetFilterIndex()]['type']
- extType = ltype[dlg.GetFilterIndex()]['ext']
- if ext != extType:
- path = base + '.' + extType
- self.MapWindow.SaveToFile(path, fileType,
- width, height)
- dlg.Destroy()
- def PrintMenu(self, event):
- Print options and output menu for map display
- point = wx.GetMousePosition()
- printmenu = wx.Menu()
- # Add items to the menu
- setup = wx.MenuItem(printmenu, wx.ID_ANY, _('Page setup'))
- printmenu.AppendItem(setup)
- self.Bind(wx.EVT_MENU, self.printopt.OnPageSetup, setup)
- preview = wx.MenuItem(printmenu, wx.ID_ANY, _('Print preview'))
- printmenu.AppendItem(preview)
- self.Bind(wx.EVT_MENU, self.printopt.OnPrintPreview, preview)
- doprint = wx.MenuItem(printmenu, wx.ID_ANY, _('Print display'))
- printmenu.AppendItem(doprint)
- self.Bind(wx.EVT_MENU, self.printopt.OnDoPrint, doprint)
- # Popup the menu. If an item is selected then its handler
- # will be called before PopupMenu returns.
- self.PopupMenu(printmenu)
- printmenu.Destroy()
- def FormatDist(self, dist):
- """!Format length numbers and units in a nice way,
- as a function of length. From code by Hamish Bowman
- Grass Development Team 2006"""
- mapunits = self.Map.projinfo['units']
- if mapunits == 'metres': mapunits = 'meters'
- outunits = mapunits
- dist = float(dist)
- divisor = 1.0
- # figure out which units to use
- if mapunits == 'meters':
- if dist > 2500.0:
- outunits = 'km'
- divisor = 1000.0
- else: outunits = 'm'
- elif mapunits == 'feet':
- # nano-bug: we match any "feet", but US Survey feet is really
- # 5279.9894 per statute mile, or 10.6' per 1000 miles. As >1000
- # miles the tick markers are rounded to the nearest 10th of a
- # mile (528'), the difference in foot flavours is ignored.
- if dist > 5280.0:
- outunits = 'miles'
- divisor = 5280.0
- else:
- outunits = 'ft'
- elif 'degree' in mapunits:
- if dist < 1:
- outunits = 'min'
- divisor = (1/60.0)
- else:
- outunits = 'deg'
- # format numbers in a nice way
- if (dist/divisor) >= 2500.0:
- outdist = round(dist/divisor)
- elif (dist/divisor) >= 1000.0:
- outdist = round(dist/divisor,1)
- elif (dist/divisor) > 0.0:
- outdist = round(dist/divisor,int(math.ceil(3-math.log10(dist/divisor))))
- else:
- outdist = float(dist/divisor)
- return (outdist, outunits)
- def OnZoomToRaster(self, event):
- Set display extents to match selected raster map (ignore NULLs)
- self.MapWindow.ZoomToMap(ignoreNulls = True)
- def OnZoomToSaved(self, event):
- """!Set display geometry to match extents in
- saved region file
- self.MapWindow.ZoomToSaved()
- def OnDisplayToWind(self, event):
- """!Set computational region (WIND file) to match display
- extents
- self.MapWindow.DisplayToWind()
- def SaveDisplayRegion(self, event):
- """!Save display extents to named region file.
- self.MapWindow.SaveDisplayRegion()
- def OnZoomMenu(self, event):
- """!Popup Zoom menu
- zoommenu = wx.Menu()
- zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
- zoommenu.AppendItem(zoomwind)
- self.Bind(wx.EVT_MENU, self.OnZoomToWind, zoomwind)
- zoomdefault = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to default region'))
- zoommenu.AppendItem(zoomdefault)
- self.Bind(wx.EVT_MENU, self.OnZoomToDefault, zoomdefault)
- zoomsaved = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to saved region'))
- zoommenu.AppendItem(zoomsaved)
- self.Bind(wx.EVT_MENU, self.OnZoomToSaved, zoomsaved)
- savewind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Set computational region from display'))
- zoommenu.AppendItem(savewind)
- self.Bind(wx.EVT_MENU, self.OnDisplayToWind, savewind)
- savezoom = wx.MenuItem(zoommenu, wx.ID_ANY, _('Save display geometry to named region'))
- zoommenu.AppendItem(savezoom)
- self.Bind(wx.EVT_MENU, self.SaveDisplayRegion, savezoom)
- self.PopupMenu(zoommenu)
- zoommenu.Destroy()
- def IsStandalone(self):
- """!Check if Map display is standalone"""
- if self._layerManager:
- return False
- return True
- def GetLayerManager(self):
- """!Get reference to Layer Manager
- @return window reference
- @return None (if standalone)
- return self._layerManager
- def GetSrcWindow(self):
- return self.SrcMapWindow
- def GetTgtWindow(self):
- return self.TgtMapWindow
- def GetShowTarget(self):
- return self.show_target
- def GetMapToolbar(self):
- """!Returns toolbar with zooming tools"""
- return self.toolbars['gcpdisp']
Copied: grass/trunk/gui/wxpython/gcp/mapdisplay.py (from rev 49357, grass/trunk/gui/wxpython/gcp/mapdisp.py)
--- grass/trunk/gui/wxpython/gcp/mapdisplay.py (rev 0)
+++ grass/trunk/gui/wxpython/gcp/mapdisplay.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -0,0 +1,629 @@
+ at package gcp.mapdisp
+ at brief Display to manage ground control points with two toolbars, one
+for various display management functions, one for manipulating GCPs.
+Classes:
+- MapFrame
+(C) 2006-2011 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Markus Metz
+import os
+import math
+import platform
+from core import globalvar
+import wx
+import wx.aui
+from core.render import EVT_UPDATE_PRGBAR
+from mapdisp.toolbars import MapToolbar
+from gcp.toolbars import GCPDisplayToolbar, GCPManToolbar
+from mapdisp.gprint import PrintOptions
+from core.gcmd import GMessage
+from gui_core.dialogs import GetImageHandlers, ImageSizeDialog
+from gui_core.mapdisp import MapFrameBase
+from core.settings import UserSettings
+from mapdisp.mapwindow import BufferedWindow
+import mapdisp.statusbar as sb
+# for standalone app
+cmdfilename = None
+class MapFrame(MapFrameBase):
+ """!Main frame for map display window. Drawing takes place in
+ child double buffered drawing window.
+ def __init__(self, parent=None, title=_("GRASS GIS Manage Ground Control Points"),
+ toolbars=["gcpdisp"], tree=None, notebook=None, lmgr=None,
+ page=None, Map=None, auimgr=None, name = 'GCPMapWindow', **kwargs):
+ """!Main map display window with toolbars, statusbar and
+ DrawWindow
+ @param toolbars array of activated toolbars, e.g. ['map', 'digit']
+ @param tree reference to layer tree
+ @param notebook control book ID in Layer Manager
+ @param lmgr Layer Manager
+ @param page notebook page with layer tree
+ @param Map instance of render.Map
+ @param auimgs AUI manager
+ @param kwargs wx.Frame attribures
+ MapFrameBase.__init__(self, parent = parent, title = title, toolbars = toolbars,
+ Map = Map, auimgr = auimgr, name = name, **kwargs)
+ self._layerManager = lmgr # Layer Manager object
+ self.tree = tree # Layer Manager layer tree object
+ self.page = page # Notebook page holding the layer tree
+ self.layerbook = notebook # Layer Manager layer tree notebook
+ # Add toolbars
+ for toolb in toolbars:
+ self.AddToolbar(toolb)
+ self.activemap = self.toolbars['gcpdisp'].togglemap
+ self.activemap.SetSelection(0)
+ self.SrcMap = self.grwiz.SrcMap # instance of render.Map
+ self.TgtMap = self.grwiz.TgtMap # instance of render.Map
+ self._mgr.SetDockSizeConstraint(0.5, 0.5)
+ # Add statusbar
+ # items for choice
+ self.statusbarItems = [sb.SbCoordinates,
+ sb.SbRegionExtent,
+ sb.SbCompRegionExtent,
+ sb.SbShowRegion,
+ sb.SbResolution,
+ sb.SbDisplayGeometry,
+ sb.SbMapScale,
+ sb.SbProjection,
+ sb.SbGoToGCP,
+ sb.SbRMSError]
+ # create statusbar and its manager
+ statusbar = self.CreateStatusBar(number = 4, style = 0)
+ statusbar.SetStatusWidths([-5, -2, -1, -1])
+ self.statusbarManager = sb.SbManager(mapframe = self, statusbar = statusbar)
+ # fill statusbar manager
+ self.statusbarManager.AddStatusbarItemsByClass(self.statusbarItems, mapframe = self, statusbar = statusbar)
+ self.statusbarManager.AddStatusbarItem(sb.SbMask(self, statusbar = statusbar, position = 2))
+ self.statusbarManager.AddStatusbarItem(sb.SbRender(self, statusbar = statusbar, position = 3))
+ self.statusbarManager.SetMode(8) # goto GCP
+ self.statusbarManager.Update()
+ # Init map display (buffered DC & set default cursor)
+ self.grwiz.SwitchEnv('source')
+ self.SrcMapWindow = BufferedWindow(self, id=wx.ID_ANY,
+ Map=self.SrcMap, tree=self.tree, lmgr=self._layerManager)
+ self.grwiz.SwitchEnv('target')
+ self.TgtMapWindow = BufferedWindow(self, id=wx.ID_ANY,
+ Map=self.TgtMap, tree=self.tree, lmgr=self._layerManager)
+ self.MapWindow = self.SrcMapWindow
+ self.Map = self.SrcMap
+ self.SrcMapWindow.SetCursor(self.cursors["cross"])
+ self.TgtMapWindow.SetCursor(self.cursors["cross"])
+ # initialize region values
+ self._initMap(map = self.SrcMap)
+ self._initMap(map = self.TgtMap)
+ # Bind various events
+ self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
+ self.Bind(EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
+ self.Bind(wx.EVT_SIZE, self.OnDispResize)
+ self.activemap.Bind(wx.EVT_CHOICE, self.OnUpdateActive)
+ # Update fancy gui style
+ # AuiManager wants a CentrePane, workaround to get two equally sized windows
+ self.list = self.CreateGCPList()
+ #self.SrcMapWindow.SetSize((300, 300))
+ #self.TgtMapWindow.SetSize((300, 300))
+ self.list.SetSize((100, 150))
+ self._mgr.AddPane(self.list, wx.aui.AuiPaneInfo().
+ Name("gcplist").Caption(_("GCP List")).LeftDockable(False).
+ RightDockable(False).PinButton().FloatingSize((600,200)).
+ CloseButton(False).DestroyOnClose(True).
+ Top().Layer(1).MinSize((200,100)))
+ self._mgr.AddPane(self.SrcMapWindow, wx.aui.AuiPaneInfo().
+ Name("source").Caption(_("Source Display")).Dockable(False).
+ CloseButton(False).DestroyOnClose(True).Floatable(False).
+ Centre())
+ self._mgr.AddPane(self.TgtMapWindow, wx.aui.AuiPaneInfo().
+ Name("target").Caption(_("Target Display")).Dockable(False).
+ Right().Layer(0))
+ srcwidth, srcheight = self.SrcMapWindow.GetSize()
+ tgtwidth, tgtheight = self.TgtMapWindow.GetSize()
+ srcwidth = (srcwidth + tgtwidth) / 2
+ self._mgr.GetPane("target").Hide()
+ self._mgr.Update()
+ self._mgr.GetPane("source").BestSize((srcwidth, srcheight))
+ self._mgr.GetPane("target").BestSize((srcwidth, srcheight))
+ if self.show_target:
+ self._mgr.GetPane("target").Show()
+ else:
+ self.activemap.Enable(False)
+ # needed by Mac OS, does not harm on Linux, breaks display on Windows
+ if platform.system() != 'Windows':
+ # Init print module and classes
+ self.printopt = PrintOptions(self, self.MapWindow)
+ # Initialization of digitization tool
+ self.digit = None
+ # set active map
+ # do not init zoom history here, that happens when zooming to map(s)
+ # Re-use dialogs
+ self.dialogs = {}
+ self.dialogs['attributes'] = None
+ self.dialogs['category'] = None
+ self.dialogs['barscale'] = None
+ self.dialogs['legend'] = None
+ self.decorationDialog = None # decoration/overlays
+ def AddToolbar(self, name):
+ """!Add defined toolbar to the window
+ Currently known toolbars are:
+ - 'map' - basic map toolbar
+ - 'vdigit' - vector digitizer
+ - 'gcpdisp' - GCP Manager, Display
+ - 'gcpman' - GCP Manager, points management
+ - 'nviz' - 3D view mode
+ # default toolbar
+ if name == "map":
+ self.toolbars['map'] = MapToolbar(self, self.Map)
+ self._mgr.AddPane(self.toolbars['map'],
+ wx.aui.AuiPaneInfo().
+ Name("maptoolbar").Caption(_("Map Toolbar")).
+ ToolbarPane().Top().
+ LeftDockable(False).RightDockable(False).
+ BottomDockable(False).TopDockable(True).
+ CloseButton(False).Layer(2).
+ BestSize((self.toolbars['map'].GetSize())))
+ # GCP display
+ elif name == "gcpdisp":
+ self.toolbars['gcpdisp'] = GCPDisplayToolbar(self)
+ self._mgr.AddPane(self.toolbars['gcpdisp'],
+ Name("gcpdisplaytoolbar").Caption(_("GCP Display toolbar")).
+ CloseButton(False).Layer(2))
+ if self.show_target == False:
+ self.toolbars['gcpdisp'].Enable('zoommenu', enable = False)
+ self.toolbars['gcpman'] = GCPManToolbar(self)
+ self._mgr.AddPane(self.toolbars['gcpman'],
+ Name("gcpmanagertoolbar").Caption(_("GCP Manager toolbar")).
+ ToolbarPane().Top().Row(1).
+ def OnUpdateProgress(self, event):
+ Update progress bar info
+ self.GetProgressBar().SetValue(event.value)
+ event.Skip()
+ def OnFocus(self, event):
+ Change choicebook page to match display.
+ Or set display for georectifying
+ if self._layerManager and \
+ self._layerManager.gcpmanagement:
+ # in GCP Management, set focus to current MapWindow for mouse actions
+ self.OnPointer(event)
+ self.MapWindow.SetFocus()
+ else:
+ # change bookcontrol page to page associated with display
+ # GCP Manager: use bookcontrol?
+ if self.page:
+ pgnum = self.layerbook.GetPageIndex(self.page)
+ if pgnum > -1:
+ self.layerbook.SetSelection(pgnum)
+ event.Skip()
+ def OnDraw(self, event):
+ """!Re-display current map composition
+ self.MapWindow.UpdateMap(render = False)
+ def OnRender(self, event):
+ """!Re-render map composition (each map layer)
+ # delete tmp map layers (queries)
+ qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
+ for layer in qlayer:
+ self.Map.DeleteLayer(layer)
+ self.SrcMapWindow.UpdateMap(render=True)
+ self.TgtMapWindow.UpdateMap(render=True)
+ # update statusbar
+ self.StatusbarUpdate()
+ def OnPointer(self, event):
+ """!Pointer button clicked
+ # change the cursor
+ self.SrcMapWindow.mouse['use'] = "pointer"
+ self.SrcMapWindow.mouse['box'] = "point"
+ self.TgtMapWindow.mouse['use'] = "pointer"
+ self.TgtMapWindow.mouse['box'] = "point"
+ def OnZoomIn(self, event):
+ Zoom in the map.
+ Set mouse cursor, zoombox attributes, and zoom direction
+ if self.GetToolbar('map'):
+ self.toolbars['map'].OnTool(event)
+ self.toolbars['map'].action['desc'] = ''
+ self.MapWindow.mouse['use'] = "zoom"
+ self.MapWindow.mouse['box'] = "box"
+ self.MapWindow.zoomtype = 1
+ self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+ self.MapWindow.SetCursor(self.cursors["cross"])
+ if self.MapWindow == self.SrcMapWindow:
+ win = self.TgtMapWindow
+ elif self.MapWindow == self.TgtMapWindow:
+ win = self.SrcMapWindow
+ win.mouse['use'] = "zoom"
+ win.mouse['box'] = "box"
+ win.zoomtype = 1
+ win.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+ win.SetCursor(self.cursors["cross"])
+ def OnZoomOut(self, event):
+ Zoom out the map.
+ self.MapWindow.zoomtype = -1
+ win.zoomtype = -1
+ def OnPan(self, event):
+ Panning, set mouse to drag
+ self.MapWindow.mouse['use'] = "pan"
+ self.MapWindow.mouse['box'] = "pan"
+ self.MapWindow.zoomtype = 0
+ self.MapWindow.SetCursor(self.cursors["hand"])
+ win.mouse['use'] = "pan"
+ win.mouse['box'] = "pan"
+ win.zoomtype = 0
+ win.SetCursor(self.cursors["hand"])
+ def OnErase(self, event):
+ Erase the canvas
+ self.MapWindow.EraseMap()
+ win.EraseMap()
+ def OnZoomRegion(self, event):
+ Zoom to region
+ self.Map.getRegion()
+ self.Map.getResolution()
+ self.UpdateMap()
+ # event.Skip()
+ def OnAlignRegion(self, event):
+ Align region
+ if not self.Map.alignRegion:
+ self.Map.alignRegion = True
+ else:
+ self.Map.alignRegion = False
+ # event.Skip()
+ def SaveToFile(self, event):
+ """!Save map to image
+ img = self.MapWindow.img
+ if not img:
+ GMessage(parent = self,
+ message = _("Nothing to render (empty map). Operation canceled."))
+ return
+ filetype, ltype = GetImageHandlers(img)
+ # get size
+ dlg = ImageSizeDialog(self)
+ dlg.CentreOnParent()
+ if dlg.ShowModal() != wx.ID_OK:
+ dlg.Destroy()
+ return
+ width, height = dlg.GetValues()
+ dlg.Destroy()
+ # get filename
+ dlg = wx.FileDialog(parent = self,
+ message = _("Choose a file name to save the image "
+ "(no need to add extension)"),
+ wildcard = filetype,
+ style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
+ if dlg.ShowModal() == wx.ID_OK:
+ path = dlg.GetPath()
+ if not path:
+ dlg.Destroy()
+ return
+ base, ext = os.path.splitext(path)
+ fileType = ltype[dlg.GetFilterIndex()]['type']
+ extType = ltype[dlg.GetFilterIndex()]['ext']
+ if ext != extType:
+ path = base + '.' + extType
+ self.MapWindow.SaveToFile(path, fileType,
+ width, height)
+ dlg.Destroy()
+ def PrintMenu(self, event):
+ Print options and output menu for map display
+ point = wx.GetMousePosition()
+ printmenu = wx.Menu()
+ # Add items to the menu
+ setup = wx.MenuItem(printmenu, wx.ID_ANY, _('Page setup'))
+ printmenu.AppendItem(setup)
+ self.Bind(wx.EVT_MENU, self.printopt.OnPageSetup, setup)
+ preview = wx.MenuItem(printmenu, wx.ID_ANY, _('Print preview'))
+ printmenu.AppendItem(preview)
+ self.Bind(wx.EVT_MENU, self.printopt.OnPrintPreview, preview)
+ doprint = wx.MenuItem(printmenu, wx.ID_ANY, _('Print display'))
+ printmenu.AppendItem(doprint)
+ self.Bind(wx.EVT_MENU, self.printopt.OnDoPrint, doprint)
+ # Popup the menu. If an item is selected then its handler
+ # will be called before PopupMenu returns.
+ self.PopupMenu(printmenu)
+ printmenu.Destroy()
+ def FormatDist(self, dist):
+ """!Format length numbers and units in a nice way,
+ as a function of length. From code by Hamish Bowman
+ Grass Development Team 2006"""
+ mapunits = self.Map.projinfo['units']
+ if mapunits == 'metres': mapunits = 'meters'
+ outunits = mapunits
+ dist = float(dist)
+ divisor = 1.0
+ # figure out which units to use
+ if mapunits == 'meters':
+ if dist > 2500.0:
+ outunits = 'km'
+ divisor = 1000.0
+ else: outunits = 'm'
+ elif mapunits == 'feet':
+ # nano-bug: we match any "feet", but US Survey feet is really
+ # 5279.9894 per statute mile, or 10.6' per 1000 miles. As >1000
+ # miles the tick markers are rounded to the nearest 10th of a
+ # mile (528'), the difference in foot flavours is ignored.
+ if dist > 5280.0:
+ outunits = 'miles'
+ divisor = 5280.0
+ else:
+ outunits = 'ft'
+ elif 'degree' in mapunits:
+ if dist < 1:
+ outunits = 'min'
+ divisor = (1/60.0)
+ else:
+ outunits = 'deg'
+ # format numbers in a nice way
+ if (dist/divisor) >= 2500.0:
+ outdist = round(dist/divisor)
+ elif (dist/divisor) >= 1000.0:
+ outdist = round(dist/divisor,1)
+ elif (dist/divisor) > 0.0:
+ outdist = round(dist/divisor,int(math.ceil(3-math.log10(dist/divisor))))
+ else:
+ outdist = float(dist/divisor)
+ return (outdist, outunits)
+ def OnZoomToRaster(self, event):
+ Set display extents to match selected raster map (ignore NULLs)
+ self.MapWindow.ZoomToMap(ignoreNulls = True)
+ def OnZoomToSaved(self, event):
+ """!Set display geometry to match extents in
+ saved region file
+ self.MapWindow.ZoomToSaved()
+ def OnDisplayToWind(self, event):
+ """!Set computational region (WIND file) to match display
+ extents
+ self.MapWindow.DisplayToWind()
+ def SaveDisplayRegion(self, event):
+ """!Save display extents to named region file.
+ self.MapWindow.SaveDisplayRegion()
+ def OnZoomMenu(self, event):
+ """!Popup Zoom menu
+ zoommenu = wx.Menu()
+ zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
+ zoommenu.AppendItem(zoomwind)
+ self.Bind(wx.EVT_MENU, self.OnZoomToWind, zoomwind)
+ zoomdefault = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to default region'))
+ zoommenu.AppendItem(zoomdefault)
+ self.Bind(wx.EVT_MENU, self.OnZoomToDefault, zoomdefault)
+ zoomsaved = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to saved region'))
+ zoommenu.AppendItem(zoomsaved)
+ self.Bind(wx.EVT_MENU, self.OnZoomToSaved, zoomsaved)
+ savewind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Set computational region from display'))
+ zoommenu.AppendItem(savewind)
+ self.Bind(wx.EVT_MENU, self.OnDisplayToWind, savewind)
+ savezoom = wx.MenuItem(zoommenu, wx.ID_ANY, _('Save display geometry to named region'))
+ zoommenu.AppendItem(savezoom)
+ self.Bind(wx.EVT_MENU, self.SaveDisplayRegion, savezoom)
+ self.PopupMenu(zoommenu)
+ zoommenu.Destroy()
+ def IsStandalone(self):
+ """!Check if Map display is standalone"""
+ if self._layerManager:
+ return False
+ return True
+ def GetLayerManager(self):
+ """!Get reference to Layer Manager
+ @return window reference
+ @return None (if standalone)
+ return self._layerManager
+ def GetSrcWindow(self):
+ return self.SrcMapWindow
+ def GetTgtWindow(self):
+ return self.TgtMapWindow
+ def GetShowTarget(self):
+ return self.show_target
+ def GetMapToolbar(self):
+ """!Returns toolbar with zooming tools"""
+ return self.toolbars['gcpdisp']
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -24,10 +24,12 @@
import wx
+from core import utils
from gui_core.widgets import GNotebook
from core.gcmd import GError, EncodeString
from gui_core.dialogs import ElementDialog, MapLayersDialog
from gui_core.ghelp import SearchModuleWindow
+from gui_core.prompt import GPromptSTC
from grass.script import task as gtask
@@ -124,7 +126,7 @@
self.cmdBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label=" %s " % _("Command"))
- self.cmd_prompt = prompt.GPromptSTC(parent = self)
+ self.cmd_prompt = GPromptSTC(parent = self)
self.search = SearchModuleWindow(parent = self.panel, cmdPrompt = self.cmd_prompt, showTip = True)
wx.CallAfter(self.cmd_prompt.SetFocus)
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -7,20 +7,13 @@
- ModelToolbar
- ModelFrame
- ModelCanvas
- - ModelObject
- - ModelAction
- - ModelData
- ModelEvtHandler
- - ModelRelation
- ModelListCtrl
- VariablePanel
- ValiableListCtrl
- - ModelItem
- - ModelLoop
- ItemPanel
- ItemListCtrl
- ItemCheckListCtrl
- - ModelCondition
(C) 2010-2011 by the GRASS Development Team
@@ -39,7 +32,7 @@
import re
import wx
-import wx.lib.ogl as ogl
+from wx.lib import ogl
import wx.lib.flatnotebook as FN
import wx.lib.mixins.listctrl as listmix
@@ -53,7 +46,14 @@
from core.menudata import MenuData
from gui_core.toolbars import BaseToolbar
+from gui_core.menu import Menu
+from gmodeler.menudata import ModelerData
+from icons.icon import Icons
+from gui_core.forms import GUI
+from gmodeler.model import *
+from gmodeler.dialogs import *
from grass.script import core as grass
class ModelToolbar(BaseToolbar):
@@ -1073,497 +1073,7 @@
item.Update()
self.Refresh()
-class ModelObject:
- def __init__(self, id = -1):
- self.id = id
- self.rels = list() # list of ModelRelations
- self.isEnabled = True
- self.inBlock = list() # list of related loops/conditions
- def __del__(self):
- pass
- def GetId(self):
- """!Get id"""
- return self.id
- def AddRelation(self, rel):
- """!Record new relation
- self.rels.append(rel)
- def GetRelations(self, fdir = None):
- """!Get list of relations
- @param fdir True for 'from'
- if fdir is None:
- return self.rels
- result = list()
- for rel in self.rels:
- if fdir == 'from':
- if rel.GetFrom() == self:
- result.append(rel)
- else:
- if rel.GetTo() == self:
- return result
- def IsEnabled(self):
- """!Get True if action is enabled, otherwise False"""
- return self.isEnabled
- def Enable(self, enabled = True):
- """!Enable/disable action"""
- self.isEnabled = enabled
- self.Update()
- def Update(self):
- pass
- def SetBlock(self, item):
- """!Add object to the block (loop/condition)
- @param item reference to ModelLoop or ModelCondition which
- defines loops/condition
- if item not in self.inBlock:
- self.inBlock.append(item)
- def UnSetBlock(self, item):
- """!Remove object from the block (loop/consition)
- defines loops/codition
- if item in self.inBlock:
- self.inBlock.remove(item)
- def GetBlock(self):
- """!Get list of related ModelObject(s) which defines block
- (loop/condition)
- @return list of ModelObjects
- return self.inBlock
- def GetBlockId(self):
- """!Get list of related ids which defines block
- @return list of ids
- ret = list()
- for mo in self.inBlock:
- ret.append(mo.GetId())
- return ret
-class ModelAction(ModelObject, ogl.RectangleShape):
- """!Action class (GRASS module)"""
- def __init__(self, parent, x, y, id = -1, cmd = None, task = None, width = None, height = None):
- ModelObject.__init__(self, id)
- self.parent = parent
- self.task = task
- if not width:
- width = UserSettings.Get(group='modeler', key='action', subkey=('size', 'width'))
- if not height:
- height = UserSettings.Get(group='modeler', key='action', subkey=('size', 'height'))
- if cmd:
- self.task = GUI(show = None).ParseCommand(cmd = cmd)
- else:
- if task:
- self.task = task
- else:
- self.task = None
- self.propWin = None
- self.data = list() # list of connected data items
- self.isValid = False
- self.isParameterized = False
- if self.parent.GetCanvas():
- ogl.RectangleShape.__init__(self, width, height)
- self.SetCanvas(self.parent)
- self.SetX(x)
- self.SetY(y)
- self.SetPen(wx.BLACK_PEN)
- self._setPen()
- self._setBrush()
- self.SetId(id)
- if self.task:
- self.SetValid(self.task.get_options())
- def _setBrush(self, running = False):
- """!Set brush"""
- if running:
- color = UserSettings.Get(group='modeler', key='action',
- subkey=('color', 'running'))
- elif not self.isEnabled:
- color = UserSettings.Get(group='modeler', key='disabled',
- subkey='color')
- elif self.isValid:
- subkey=('color', 'valid'))
- else:
- subkey=('color', 'invalid'))
- wxColor = wx.Color(color[0], color[1], color[2])
- self.SetBrush(wx.Brush(wxColor))
- def _setPen(self):
- """!Set pen"""
- if self.isParameterized:
- width = int(UserSettings.Get(group='modeler', key='action',
- subkey=('width', 'parameterized')))
- else:
- subkey=('width', 'default')))
- pen = self.GetPen()
- pen.SetWidth(width)
- self.SetPen(pen)
- def SetId(self, id):
- """!Set id"""
- self.id = id
- cmd = self.task.get_cmd(ignoreErrors = True)
- if cmd and len(cmd) > 0:
- self.ClearText()
- self.AddText('(%d) %s' % (self.id, cmd[0]))
- else:
- self.AddText('(%d) <<%s>>' % (self.id, _("unknown")))
- def SetProperties(self, params, propwin):
- """!Record properties dialog"""
- self.task.params = params['params']
- self.task.flags = params['flags']
- self.propWin = propwin
- def GetPropDialog(self):
- """!Get properties dialog"""
- return self.propWin
- def GetLog(self, string = True, substitute = None):
- """!Get logging info
- @param string True to get cmd as a string otherwise a list
- @param substitute dictionary of parameter to substitute or None
- cmd = self.task.get_cmd(ignoreErrors = True, ignoreRequired = True,
- ignoreDefault = False)
- # substitute variables
- if substitute:
- variables = []
- if 'variables' in substitute:
- for p in substitute['variables']['params']:
- variables.append(p.get('name', ''))
- else:
- variables = self.parent.GetVariables()
- for variable in variables:
- pattern= re.compile('%' + variable)
- value = ''
- if substitute and 'variables' in substitute:
- if variable == p.get('name', ''):
- if p.get('type', 'string') == 'string':
- value = p.get('value', '')
- else:
- value = str(p.get('value', ''))
- break
- if not value:
- value = variables[variable].get('value', '')
- if not value:
- continue
- for idx in range(len(cmd)):
- if pattern.search(cmd[idx]):
- cmd[idx] = pattern.sub(value, cmd[idx])
- break
- idx += 1
- if string:
- if cmd is None:
- return ''
- else:
- return ' '.join(cmd)
- return cmd
- def GetName(self):
- """!Get name"""
- return cmd[0]
- return _('unknown')
- def GetParams(self, dcopy = False):
- """!Get dictionary of parameters"""
- if dcopy:
- return copy.deepcopy(self.task.get_options())
- return self.task.get_options()
- def GetTask(self):
- """!Get grassTask instance"""
- return self.task
- def SetParams(self, params):
- """!Set dictionary of parameters"""
- def MergeParams(self, params):
- """!Merge dictionary of parameters"""
- if 'flags' in params:
- for f in params['flags']:
- self.task.set_flag(f['name'],
- f.get('value', False))
- if 'params' in params:
- for p in params['params']:
- self.task.set_param(p['name'],
- p.get('value', ''))
- def SetValid(self, options):
- """!Set validity for action
- @param options dictionary with flags and params (gtask)
- self.isValid = True
- for f in options['flags']:
- if f.get('parameterized', False):
- self.IsParameterized = True
- break
- for p in options['params']:
- if self.isValid and p.get('required', False) and \
- p.get('value', '') == '' and \
- p.get('default', '') == '':
- if not self.isParameterized and p.get('parameterized', False):
- self.isParameterized = True
- self._setBrush()
- self._setPen()
- def IsValid(self):
- """!Check validity (all required parameters set)"""
- return self.isValid
- def IsParameterized(self):
- """!Check if action is parameterized"""
- return self.isParameterized
- def FindData(self, name):
- """!Find data item by name"""
- for rel in self.GetRelations():
- data = rel.GetData()
- if name == rel.GetName() and name in data.GetName():
- return data
- return None
- def Update(self, running = False):
- """!Update action"""
- if running:
- self._setBrush(running = True)
- else:
- self._setBrush()
- self._setPen()
- def OnDraw(self, dc):
- """!Draw action in canvas"""
- self._setBrush()
- self._setPen()
- ogl.RectangleShape.OnDraw(self, dc)
-class ModelData(ModelObject, ogl.EllipseShape):
- def __init__(self, parent, x, y, value = '', prompt = '', width = None, height = None):
- """Data item class
- @param parent window parent
- @param x, y position of the shape
- @param fname, tname list of parameter names from / to
- @param value value
- @param prompt type of GIS element
- @param width,height dimension of the shape
- ModelObject.__init__(self)
- self.value = value
- self.prompt = prompt
- self.intermediate = False
- if not width:
- width = UserSettings.Get(group='modeler', key='data', subkey=('size', 'width'))
- if not height:
- height = UserSettings.Get(group='modeler', key='data', subkey=('size', 'height'))
- ogl.EllipseShape.__init__(self, width, height)
- self.SetX(x)
- self.SetY(y)
- self._setBrush()
- self._setText()
- def IsIntermediate(self):
- """!Checks if data item is intermediate"""
- return self.intermediate
- def SetIntermediate(self, im):
- """!Set intermediate flag"""
- self.intermediate = im
- pen.SetWidth(1)
- if self.intermediate:
- pen.SetStyle(wx.SHORT_DASH)
- else:
- pen.SetStyle(wx.SOLID)
- self.SetPen(pen)
- ogl.EllipseShape.OnDraw(self, dc)
- def GetLog(self, string = True):
- """!Get logging info"""
- name = list()
- name.append(rel.GetName())
- if name:
- return '/'.join(name) + '=' + self.value + ' (' + self.prompt + ')'
- else:
- return self.value + ' (' + self.prompt + ')'
- """!Get list of names"""
- name = list()
- return name
- def GetPrompt(self):
- """!Get prompt"""
- return self.prompt
- def SetPrompt(self, prompt):
- """!Set prompt
- @param prompt
- def GetValue(self):
- """!Get value"""
- return self.value
- def SetValue(self, value):
- """!Set value
- @param value
- self._setText()
- for direction in ('from', 'to'):
- for rel in self.GetRelations(direction):
- if direction == 'from':
- action = rel.GetTo()
- else:
- action = rel.GetFrom()
- task = GUI(show = None).ParseCommand(cmd = action.GetLog(string = False))
- task.set_param(rel.GetName(), self.value)
- action.SetParams(params = task.get_options())
- def SetPropDialog(self, win):
- self.propWin = win
- def _setBrush(self):
- """!Set brush"""
- if self.prompt == 'raster':
- color = UserSettings.Get(group = 'modeler', key = 'data',
- subkey = ('color', 'raster'))
- elif self.prompt == 'raster3d':
- subkey = ('color', 'raster3d'))
- elif self.prompt == 'vector':
- subkey = ('color', 'vector'))
- else:
- color = UserSettings.Get(group = 'modeler', key = 'action',
- subkey = ('color', 'invalid'))
- """!Set pen"""
- isParameterized = False
- for rel in self.GetRelations('from'):
- if rel.GetTo().IsParameterized():
- isParameterized = True
- break
- if not isParameterized:
- for rel in self.GetRelations('to'):
- if rel.GetFrom().IsParameterized():
- break
- if isParameterized:
- width = int(UserSettings.Get(group = 'modeler', key = 'action',
- subkey = ('width', 'parameterized')))
- else:
- subkey = ('width', 'default')))
- self.SetPen(pen)
- def _setText(self):
- """!Update text"""
- self.ClearText()
- name = []
- self.AddText('/'.join(name))
- if self.value:
- self.AddText(self.value)
- else:
- self.AddText(_('<not defined>'))
- def Update(self):
- self._setBrush()
- self._setPen()
- self._setText()
class ModelEvtHandler(ogl.ShapeEvtHandler):
"""!Model event handler class"""
def __init__(self, log, frame):
@@ -1815,80 +1325,7 @@
self.frame.GetCanvas().RemoveSelected()
self.frame.itemPanel.Update()
-class ModelRelation(ogl.LineShape):
- """!Data - action relation"""
- def __init__(self, parent, fromShape, toShape, param = ''):
- self.fromShape = fromShape
- self.toShape = toShape
- self.param = param
- self._points = None
- ogl.LineShape.__init__(self)
- if self in self.fromShape.rels:
- self.fromShape.rels.remove(self)
- if self in self.toShape.rels:
- self.toShape.rels.remove(self)
- def GetFrom(self):
- """!Get id of 'from' shape"""
- return self.fromShape
- def GetTo(self):
- """!Get id of 'to' shape"""
- return self.toShape
- def GetData(self):
- """!Get related ModelData instance
- @return ModelData instance
- @return None if not found
- if isinstance(self.fromShape, ModelData):
- elif isinstance(self.toShape, ModelData):
- return None
- """!Get parameter name"""
- return self.param
- def ResetShapes(self):
- """!Reset related objects"""
- self.fromShape.ResetControlPoints()
- self.toShape.ResetControlPoints()
- self.ResetControlPoints()
- def SetControlPoints(self, points):
- """!Set control points"""
- self._points = points
- def GetControlPoints(self):
- """!Get list of control points"""
- return self._points
- """!Set pen"""
- pen.SetWidth(1)
- self.SetPen(pen)
- """!Draw relation"""
- self._setPen()
- ogl.LineShape.OnDraw(self, dc)
- def SetName(self, param):
class ModelListCtrl(wx.ListCtrl,
listmix.ListCtrlAutoWidthMixin,
listmix.TextEditMixin,
@@ -2209,105 +1646,7 @@
self.PopupMenu(menu)
menu.Destroy()
-class ModelItem(ModelObject):
- def __init__(self, parent, x, y, id = -1, width = None, height = None, text = '', items = []):
- """!Abstract class for loops and conditions"""
- self.text = text
- self.items = items # list of items in the loop
- def GetText(self):
- """!Get loop text"""
- return self.text
- def GetItems(self):
- """!Get items (id)"""
- return self.items
- """!Set loop id"""
- self.id = id
- def SetText(self, cond):
- """!Set loop text (condition)"""
- self.text = cond
- self.ClearText()
- self.AddText('(' + str(self.id) + ') ' + self.text)
- def GetLog(self):
- """!Get log info"""
- if self.text:
- return _("Condition: ") + self.text
- else:
- return _("Condition: not defined")
- """!Record relation"""
- def Clear(self):
- """!Clear object, remove rels"""
-class ModelLoop(ModelItem, ogl.RectangleShape):
- """!Defines a loop"""
- ModelItem.__init__(self, parent, x, y, id, width, height, text, items)
- if not width:
- width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
- if not height:
- height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
- self.SetX(x)
- self.SetY(y)
- self.SetCornerRadius(100)
- if text:
- self.AddText('(' + str(self.id) + ') ' + text)
- else:
- self.AddText('(' + str(self.id) + ')')
- self._setBrush()
- """!Set brush"""
- if not self.isEnabled:
- subkey='color')
- else:
- color = UserSettings.Get(group='modeler', key='loop',
- for item in self.items:
- if not isinstance(item, ModelAction):
- continue
- item.Enable(enabled)
- ModelObject.Enable(self, enabled)
- def Update(self):
- self._setBrush()
- """!Get name"""
- return _("loop")
- def SetItems(self, items):
- """!Set items (id)"""
class ItemPanel(wx.Panel):
def __init__(self, parent, id = wx.ID_ANY,
**kwargs):
@@ -2575,60 +1914,6 @@
self.CheckItem(i, flag)
break
-class ModelCondition(ModelItem, ogl.PolygonShape):
- items = { 'if' : [], 'else' : [] }):
- """!Defines a if-else condition"""
- if not width:
- self.width = UserSettings.Get(group='modeler', key='if-else', subkey=('size', 'width'))
- else:
- self.width = width
- if not height:
- self.height = UserSettings.Get(group='modeler', key='if-else', subkey=('size', 'height'))
- else:
- self.height = height
- ogl.PolygonShape.__init__(self)
- points = [(0, - self.height / 2),
- (self.width / 2, 0),
- (0, self.height / 2),
- (- self.width / 2, 0)]
- self.Create(points)
- self.SetX(x)
- self.SetY(y)
- if text:
- else:
- """!Get name"""
- return _("if-else")
- def GetWidth(self):
- """!Get object width"""
- return self.width
- def GetHeight(self):
- """!Get object height"""
- return self.height
- def SetItems(self, items, branch = 'if'):
- @param items list of items
- @param branch 'if' / 'else'
- if branch in ['if', 'else']:
- self.items[branch] = items
def main():
import gettext
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -5,6 +5,13 @@
Classes:
- Model
+ - ModelObject
+ - ModelAction
+ - ModelData
+ - ModelRelation
+ - ModelItem
+ - ModelLoop
+ - ModelCondition
@@ -23,9 +30,11 @@
import elementtree.ElementTree as etree # Python <= 2.4
import wx
-from core.globalvar import ETCWXDIR
-from core.gcmd import GMessage, GException, GError, RunCommand
+from core.globalvar import ETCWXDIR
+from core.gcmd import GMessage, GException, GError, RunCommand
+from gmodeler.dialogs import ModelParamDialog
@@ -729,3 +738,718 @@
self.variablesParams = result # record parameters
return result
+class ModelObject:
+ def __init__(self, id = -1):
+ self.id = id
+ self.rels = list() # list of ModelRelations
+ self.isEnabled = True
+ self.inBlock = list() # list of related loops/conditions
+ def __del__(self):
+ pass
+ def GetId(self):
+ """!Get id"""
+ return self.id
+ def AddRelation(self, rel):
+ """!Record new relation
+ self.rels.append(rel)
+ def GetRelations(self, fdir = None):
+ """!Get list of relations
+ @param fdir True for 'from'
+ if fdir is None:
+ return self.rels
+ result = list()
+ for rel in self.rels:
+ if fdir == 'from':
+ if rel.GetFrom() == self:
+ result.append(rel)
+ else:
+ if rel.GetTo() == self:
+ return result
+ def IsEnabled(self):
+ """!Get True if action is enabled, otherwise False"""
+ return self.isEnabled
+ def Enable(self, enabled = True):
+ """!Enable/disable action"""
+ self.isEnabled = enabled
+ self.Update()
+ def Update(self):
+ pass
+ def SetBlock(self, item):
+ """!Add object to the block (loop/condition)
+ @param item reference to ModelLoop or ModelCondition which
+ defines loops/condition
+ if item not in self.inBlock:
+ self.inBlock.append(item)
+ def UnSetBlock(self, item):
+ """!Remove object from the block (loop/consition)
+ defines loops/codition
+ if item in self.inBlock:
+ self.inBlock.remove(item)
+ def GetBlock(self):
+ """!Get list of related ModelObject(s) which defines block
+ (loop/condition)
+ @return list of ModelObjects
+ return self.inBlock
+ def GetBlockId(self):
+ """!Get list of related ids which defines block
+ @return list of ids
+ ret = list()
+ for mo in self.inBlock:
+ ret.append(mo.GetId())
+ return ret
+class ModelAction(ModelObject, ogl.RectangleShape):
+ """!Action class (GRASS module)"""
+ def __init__(self, parent, x, y, id = -1, cmd = None, task = None, width = None, height = None):
+ ModelObject.__init__(self, id)
+ self.parent = parent
+ self.task = task
+ if not width:
+ width = UserSettings.Get(group='modeler', key='action', subkey=('size', 'width'))
+ if not height:
+ height = UserSettings.Get(group='modeler', key='action', subkey=('size', 'height'))
+ if cmd:
+ self.task = GUI(show = None).ParseCommand(cmd = cmd)
+ else:
+ if task:
+ self.task = task
+ else:
+ self.task = None
+ self.propWin = None
+ self.data = list() # list of connected data items
+ self.isValid = False
+ self.isParameterized = False
+ if self.parent.GetCanvas():
+ ogl.RectangleShape.__init__(self, width, height)
+ self.SetCanvas(self.parent)
+ self.SetX(x)
+ self.SetY(y)
+ self.SetPen(wx.BLACK_PEN)
+ self._setPen()
+ self._setBrush()
+ self.SetId(id)
+ if self.task:
+ self.SetValid(self.task.get_options())
+ def _setBrush(self, running = False):
+ """!Set brush"""
+ if running:
+ color = UserSettings.Get(group='modeler', key='action',
+ subkey=('color', 'running'))
+ elif not self.isEnabled:
+ color = UserSettings.Get(group='modeler', key='disabled',
+ subkey='color')
+ elif self.isValid:
+ subkey=('color', 'valid'))
+ else:
+ subkey=('color', 'invalid'))
+ wxColor = wx.Color(color[0], color[1], color[2])
+ self.SetBrush(wx.Brush(wxColor))
+ def _setPen(self):
+ """!Set pen"""
+ if self.isParameterized:
+ width = int(UserSettings.Get(group='modeler', key='action',
+ subkey=('width', 'parameterized')))
+ else:
+ subkey=('width', 'default')))
+ pen = self.GetPen()
+ pen.SetWidth(width)
+ self.SetPen(pen)
+ def SetId(self, id):
+ """!Set id"""
+ self.id = id
+ cmd = self.task.get_cmd(ignoreErrors = True)
+ if cmd and len(cmd) > 0:
+ self.ClearText()
+ self.AddText('(%d) %s' % (self.id, cmd[0]))
+ else:
+ self.AddText('(%d) <<%s>>' % (self.id, _("unknown")))
+ def SetProperties(self, params, propwin):
+ """!Record properties dialog"""
+ self.task.params = params['params']
+ self.task.flags = params['flags']
+ self.propWin = propwin
+ def GetPropDialog(self):
+ """!Get properties dialog"""
+ return self.propWin
+ def GetLog(self, string = True, substitute = None):
+ """!Get logging info
+ @param string True to get cmd as a string otherwise a list
+ @param substitute dictionary of parameter to substitute or None
+ cmd = self.task.get_cmd(ignoreErrors = True, ignoreRequired = True,
+ ignoreDefault = False)
+ # substitute variables
+ if substitute:
+ variables = []
+ if 'variables' in substitute:
+ for p in substitute['variables']['params']:
+ variables.append(p.get('name', ''))
+ else:
+ variables = self.parent.GetVariables()
+ for variable in variables:
+ pattern= re.compile('%' + variable)
+ value = ''
+ if substitute and 'variables' in substitute:
+ if variable == p.get('name', ''):
+ if p.get('type', 'string') == 'string':
+ value = p.get('value', '')
+ else:
+ value = str(p.get('value', ''))
+ break
+ if not value:
+ value = variables[variable].get('value', '')
+ if not value:
+ continue
+ for idx in range(len(cmd)):
+ if pattern.search(cmd[idx]):
+ cmd[idx] = pattern.sub(value, cmd[idx])
+ break
+ idx += 1
+ if string:
+ if cmd is None:
+ return ''
+ else:
+ return ' '.join(cmd)
+ return cmd
+ def GetName(self):
+ """!Get name"""
+ return cmd[0]
+ return _('unknown')
+ def GetParams(self, dcopy = False):
+ """!Get dictionary of parameters"""
+ if dcopy:
+ return copy.deepcopy(self.task.get_options())
+ return self.task.get_options()
+ def GetTask(self):
+ """!Get grassTask instance"""
+ return self.task
+ def SetParams(self, params):
+ """!Set dictionary of parameters"""
+ def MergeParams(self, params):
+ """!Merge dictionary of parameters"""
+ if 'flags' in params:
+ for f in params['flags']:
+ self.task.set_flag(f['name'],
+ f.get('value', False))
+ if 'params' in params:
+ for p in params['params']:
+ self.task.set_param(p['name'],
+ p.get('value', ''))
+ def SetValid(self, options):
+ """!Set validity for action
+ @param options dictionary with flags and params (gtask)
+ self.isValid = True
+ for f in options['flags']:
+ if f.get('parameterized', False):
+ self.IsParameterized = True
+ break
+ for p in options['params']:
+ if self.isValid and p.get('required', False) and \
+ p.get('value', '') == '' and \
+ p.get('default', '') == '':
+ if not self.isParameterized and p.get('parameterized', False):
+ self.isParameterized = True
+ self._setBrush()
+ self._setPen()
+ def IsValid(self):
+ """!Check validity (all required parameters set)"""
+ return self.isValid
+ def IsParameterized(self):
+ """!Check if action is parameterized"""
+ return self.isParameterized
+ def FindData(self, name):
+ """!Find data item by name"""
+ for rel in self.GetRelations():
+ data = rel.GetData()
+ if name == rel.GetName() and name in data.GetName():
+ return data
+ return None
+ def Update(self, running = False):
+ """!Update action"""
+ if running:
+ self._setBrush(running = True)
+ else:
+ self._setBrush()
+ self._setPen()
+ def OnDraw(self, dc):
+ """!Draw action in canvas"""
+ self._setBrush()
+ self._setPen()
+ ogl.RectangleShape.OnDraw(self, dc)
+class ModelData(ModelObject, ogl.EllipseShape):
+ def __init__(self, parent, x, y, value = '', prompt = '', width = None, height = None):
+ """Data item class
+ @param parent window parent
+ @param x, y position of the shape
+ @param fname, tname list of parameter names from / to
+ @param value value
+ @param prompt type of GIS element
+ @param width,height dimension of the shape
+ ModelObject.__init__(self)
+ self.value = value
+ self.prompt = prompt
+ self.intermediate = False
+ if not width:
+ width = UserSettings.Get(group='modeler', key='data', subkey=('size', 'width'))
+ if not height:
+ height = UserSettings.Get(group='modeler', key='data', subkey=('size', 'height'))
+ ogl.EllipseShape.__init__(self, width, height)
+ self.SetX(x)
+ self.SetY(y)
+ self._setBrush()
+ self._setText()
+ def IsIntermediate(self):
+ """!Checks if data item is intermediate"""
+ return self.intermediate
+ def SetIntermediate(self, im):
+ """!Set intermediate flag"""
+ self.intermediate = im
+ pen.SetWidth(1)
+ if self.intermediate:
+ pen.SetStyle(wx.SHORT_DASH)
+ else:
+ pen.SetStyle(wx.SOLID)
+ self.SetPen(pen)
+ ogl.EllipseShape.OnDraw(self, dc)
+ def GetLog(self, string = True):
+ """!Get logging info"""
+ name = list()
+ name.append(rel.GetName())
+ if name:
+ return '/'.join(name) + '=' + self.value + ' (' + self.prompt + ')'
+ else:
+ return self.value + ' (' + self.prompt + ')'
+ """!Get list of names"""
+ name = list()
+ return name
+ def GetPrompt(self):
+ """!Get prompt"""
+ return self.prompt
+ def SetPrompt(self, prompt):
+ """!Set prompt
+ @param prompt
+ def GetValue(self):
+ """!Get value"""
+ return self.value
+ def SetValue(self, value):
+ """!Set value
+ @param value
+ self._setText()
+ for direction in ('from', 'to'):
+ for rel in self.GetRelations(direction):
+ if direction == 'from':
+ action = rel.GetTo()
+ else:
+ action = rel.GetFrom()
+ task = GUI(show = None).ParseCommand(cmd = action.GetLog(string = False))
+ task.set_param(rel.GetName(), self.value)
+ action.SetParams(params = task.get_options())
+ def SetPropDialog(self, win):
+ self.propWin = win
+ def _setBrush(self):
+ """!Set brush"""
+ if self.prompt == 'raster':
+ color = UserSettings.Get(group = 'modeler', key = 'data',
+ subkey = ('color', 'raster'))
+ elif self.prompt == 'raster3d':
+ subkey = ('color', 'raster3d'))
+ elif self.prompt == 'vector':
+ subkey = ('color', 'vector'))
+ else:
+ color = UserSettings.Get(group = 'modeler', key = 'action',
+ subkey = ('color', 'invalid'))
+ """!Set pen"""
+ isParameterized = False
+ for rel in self.GetRelations('from'):
+ if rel.GetTo().IsParameterized():
+ isParameterized = True
+ break
+ if not isParameterized:
+ for rel in self.GetRelations('to'):
+ if rel.GetFrom().IsParameterized():
+ break
+ if isParameterized:
+ width = int(UserSettings.Get(group = 'modeler', key = 'action',
+ subkey = ('width', 'parameterized')))
+ else:
+ subkey = ('width', 'default')))
+ self.SetPen(pen)
+ def _setText(self):
+ """!Update text"""
+ self.ClearText()
+ name = []
+ self.AddText('/'.join(name))
+ if self.value:
+ self.AddText(self.value)
+ else:
+ self.AddText(_('<not defined>'))
+ def Update(self):
+ self._setBrush()
+ self._setPen()
+ self._setText()
+class ModelRelation(ogl.LineShape):
+ """!Data - action relation"""
+ def __init__(self, parent, fromShape, toShape, param = ''):
+ self.fromShape = fromShape
+ self.toShape = toShape
+ self.param = param
+ self._points = None
+ ogl.LineShape.__init__(self)
+ if self in self.fromShape.rels:
+ self.fromShape.rels.remove(self)
+ if self in self.toShape.rels:
+ self.toShape.rels.remove(self)
+ def GetFrom(self):
+ """!Get id of 'from' shape"""
+ return self.fromShape
+ def GetTo(self):
+ """!Get id of 'to' shape"""
+ return self.toShape
+ def GetData(self):
+ """!Get related ModelData instance
+ @return ModelData instance
+ @return None if not found
+ if isinstance(self.fromShape, ModelData):
+ elif isinstance(self.toShape, ModelData):
+ return None
+ """!Get parameter name"""
+ return self.param
+ def ResetShapes(self):
+ """!Reset related objects"""
+ self.fromShape.ResetControlPoints()
+ self.toShape.ResetControlPoints()
+ self.ResetControlPoints()
+ def SetControlPoints(self, points):
+ """!Set control points"""
+ self._points = points
+ def GetControlPoints(self):
+ """!Get list of control points"""
+ return self._points
+ """!Set pen"""
+ pen.SetWidth(1)
+ self.SetPen(pen)
+ """!Draw relation"""
+ self._setPen()
+ ogl.LineShape.OnDraw(self, dc)
+ def SetName(self, param):
+class ModelItem(ModelObject):
+ def __init__(self, parent, x, y, id = -1, width = None, height = None, text = '', items = []):
+ """!Abstract class for loops and conditions"""
+ self.text = text
+ self.items = items # list of items in the loop
+ def GetText(self):
+ """!Get loop text"""
+ return self.text
+ def GetItems(self):
+ """!Get items (id)"""
+ return self.items
+ """!Set loop id"""
+ self.id = id
+ def SetText(self, cond):
+ """!Set loop text (condition)"""
+ self.text = cond
+ self.ClearText()
+ self.AddText('(' + str(self.id) + ') ' + self.text)
+ def GetLog(self):
+ """!Get log info"""
+ if self.text:
+ return _("Condition: ") + self.text
+ else:
+ return _("Condition: not defined")
+ """!Record relation"""
+ def Clear(self):
+ """!Clear object, remove rels"""
+class ModelLoop(ModelItem, ogl.RectangleShape):
+ """!Defines a loop"""
+ ModelItem.__init__(self, parent, x, y, id, width, height, text, items)
+ if not width:
+ width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
+ if not height:
+ height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
+ self.SetX(x)
+ self.SetY(y)
+ self.SetCornerRadius(100)
+ if text:
+ self.AddText('(' + str(self.id) + ') ' + text)
+ else:
+ self.AddText('(' + str(self.id) + ')')
+ self._setBrush()
+ """!Set brush"""
+ if not self.isEnabled:
+ subkey='color')
+ else:
+ color = UserSettings.Get(group='modeler', key='loop',
+ for item in self.items:
+ if not isinstance(item, ModelAction):
+ continue
+ item.Enable(enabled)
+ ModelObject.Enable(self, enabled)
+ def Update(self):
+ self._setBrush()
+ """!Get name"""
+ return _("loop")
+ def SetItems(self, items):
+ """!Set items (id)"""
+class ModelCondition(ModelItem, ogl.PolygonShape):
+ items = { 'if' : [], 'else' : [] }):
+ """!Defines a if-else condition"""
+ if not width:
+ self.width = UserSettings.Get(group='modeler', key='if-else', subkey=('size', 'width'))
+ else:
+ self.width = width
+ if not height:
+ self.height = UserSettings.Get(group='modeler', key='if-else', subkey=('size', 'height'))
+ else:
+ self.height = height
+ ogl.PolygonShape.__init__(self)
+ points = [(0, - self.height / 2),
+ (self.width / 2, 0),
+ (0, self.height / 2),
+ (- self.width / 2, 0)]
+ self.Create(points)
+ self.SetX(x)
+ self.SetY(y)
+ if text:
+ else:
+ """!Get name"""
+ return _("if-else")
+ def GetWidth(self):
+ """!Get object width"""
+ return self.width
+ def GetHeight(self):
+ """!Get object height"""
+ return self.height
+ def SetItems(self, items, branch = 'if'):
+ @param items list of items
+ @param branch 'if' / 'else'
+ if branch in ['if', 'else']:
+ self.items[branch] = items
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -1,5 +1,5 @@
- at package gui_core.gdialogs
+ at package gui_core.dialogs
@brief Various dialogs used in wxGUI.
Modified: grass/trunk/gui/wxpython/psmap/frame.py
--- grass/trunk/gui/wxpython/psmap/frame.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/psmap/frame.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -42,6 +42,8 @@
from icon import Icons, MetaIcon, iconSet
from core.gcmd import RunCommand, GError, GMessage
+from psmap.menudata import PsMapData
from psmap.dialogs import *
class PsMapFrame(wx.Frame):
Modified: grass/trunk/gui/wxpython/psmap/menudata.py
--- grass/trunk/gui/wxpython/psmap/menudata.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/psmap/menudata.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -1,39 +1,30 @@
- at package core.menudata
+ at package ps.menudata
- at brief Complex list for menu entries for wxGUI
+ at brief wxPsMap - menu entries
Classes:
- - MenuData
+ - PsMapData
-Usage:
- at code
-python menudata.py [action] [manager|modeler]
- at endcode
-where <i>action</i>:
- - strings (default)
- - tree
- - commands
- - dump
-(C) 2007-2011 by the GRASS Development Team
+(C) 2011 by the GRASS Development Team
- at author Michael Barton (Arizona State University)
- at author Yann Chemin <yann.chemin gmail.com>
- at author Martin Landa <landa.martin gmail.com>
- at author Glynn Clements
@author Anna Kratochvilova <kratochanna gmail.com>
import os
-import sys
-import pprint
-try:
- import xml.etree.ElementTree as etree
-except ImportError:
- import elementtree.ElementTree as etree # Python <= 2.4
-import wx
+from core.menudata import MenuData
+class PsMapData(MenuData):
+ def __init__(self, path = None):
+ """!Menu for Cartographic Composer (psmap.py)
+ @path path to XML to be read (None for menudata_psmap.xml)
+ if not path:
+ path = os.path.join(globalvar.ETCWXDIR, 'xml', 'menudata_psmap.xml')
+ MenuData.__init__(self, path)
Modified: grass/trunk/gui/wxpython/psmap/toolbars.py
--- grass/trunk/gui/wxpython/psmap/toolbars.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/psmap/toolbars.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -30,7 +30,7 @@
@param parent parent window
- AbstractToolbar.__init__(self, parent)
+ BaseToolbar.__init__(self, parent)
self.InitToolbar(self._toolbarData())
@@ -41,7 +41,7 @@
'bind' : self.parent.OnPointer }
self.OnTool(None)
- from psmap import havePILImage
+ from psmap.frame import havePILImage
if not havePILImage:
self.EnableTool(self.preview, False)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-11-25 20:19:06 UTC (rev 49360)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-11-25 21:09:24 UTC (rev 49361)
@@ -351,7 +351,7 @@
def OnGModeler(self, event):
"""!Launch Graphical Modeler"""
- win = gmodeler.ModelFrame(parent = self)
+ win = ModelFrame(parent = self)
win.CentreOnScreen()
win.Show()
