[GRASS-SVN] r49370 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Nov 26 17:46:19 EST 2011
Author: annakrat
Date: 2011-11-26 14:46:19 -0800 (Sat, 26 Nov 2011)
New Revision: 49370
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
wxNviz: miscellaneous bug fixes (merge from trunk 49369)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2011-11-26 22:35:04 UTC (rev 49369)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2011-11-26 22:46:19 UTC (rev 49370)
@@ -1432,7 +1432,7 @@
mapWin.LoadVector(layer)
# reset view when first layer loaded
- nlayers = len(mapWin.Map.GetListOfLayers(l_type = ('raster', 'vector'),
+ nlayers = len(mapWin.Map.GetListOfLayers(l_type = ('raster', '3d-raster', 'vector'),
l_active = True))
if nlayers < 2:
mapWin.ResetView()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-11-26 22:35:04 UTC (rev 49369)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-11-26 22:46:19 UTC (rev 49370)
@@ -1296,7 +1296,6 @@
except gcmd.GException, e:
GError(parent = self,
message = e.value)
- self.init = False
stop = time.time()
@@ -1984,7 +1983,7 @@
sliceId += 1
# position
- if 'update' in data['position']:
+ if 'update' in data['position'] and 'x' in data['position']:
x = data['position']['x']
y = data['position']['y']
z = data['position']['z']
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py 2011-11-26 22:35:04 UTC (rev 49369)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py 2011-11-26 22:46:19 UTC (rev 49370)
@@ -4759,7 +4759,8 @@
level = iso['topo']['value']
isosurfaces.append("%s %s" % (_("Level"), level))
box.Set(isosurfaces)
- box.SetChecked(range(len(isosurfaces)))
+ for i in range(len(isosurfaces)):
+ box.Check(i)
if data['isosurface']:
box.SetSelection(0)
self.UpdateVolumeIsosurfPage(data['isosurface'][0])
@@ -4771,7 +4772,8 @@
axis = ("X", "Y", "Z")[slice['position']['axis']]
slices.append("%s %s" % (_("Slice parallel to"), axis))
box.Set(slices)
- box.SetChecked(range(len(slices)))
+ for i in range(len(slices)):
+ box.Check(i)
if data['slice']:
box.SetSelection(0)
self.UpdateVolumeSlicePage(data['slice'][0])
