[GRASS-SVN] r49374 - in grass/branches/develbranch_6: include
lib/ogsf
svn_grass at osgeo.org
Sat Nov 26 18:48:12 EST 2011
Author: martinl
Date: 2011-11-26 15:48:12 -0800 (Sat, 26 Nov 2011)
New Revision: 49374
grass/branches/develbranch_6/include/ogsf_proto.h
grass/branches/develbranch_6/lib/ogsf/gsd_objs.c
ogsflib: add missing declaration for gsd_scalebar_v2() - see r49357
Modified: grass/branches/develbranch_6/include/ogsf_proto.h
--- grass/branches/develbranch_6/include/ogsf_proto.h 2011-11-26 23:34:24 UTC (rev 49373)
+++ grass/branches/develbranch_6/include/ogsf_proto.h 2011-11-26 23:48:12 UTC (rev 49374)
@@ -505,6 +505,7 @@
int gsd_arrow_onsurf(float *, float *, unsigned long, int, geosurf *);
void gsd_3darrow(float *, unsigned long, float, float, float *, float);
int gsd_scalebar(float *, float, GLuint, unsigned long, unsigned long);
+int gsd_scalebar_v2(float *, float, GLuint, unsigned long, unsigned long);
void primitive_cone(unsigned long);
void primitive_cylinder(unsigned long, int);
Modified: grass/branches/develbranch_6/lib/ogsf/gsd_objs.c
--- grass/branches/develbranch_6/lib/ogsf/gsd_objs.c 2011-11-26 23:34:24 UTC (rev 49373)
+++ grass/branches/develbranch_6/lib/ogsf/gsd_objs.c 2011-11-26 23:48:12 UTC (rev 49374)
@@ -1246,7 +1246,7 @@
\return 1
int gsd_scalebar_v2(float *pos, float len, GLuint fontbase,
- unsigned long bar_clr, unsigned long text_clr)
+ unsigned long bar_clr, unsigned long text_clr)
float base[6][3];
float Ntop[] = { 0.0, 0.0, 1.0 };
