[GRASS-SVN] r49399 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Nov 27 15:33:57 EST 2011
Author: martinl
Date: 2011-11-27 12:33:57 -0800 (Sun, 27 Nov 2011)
New Revision: 49399
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
wxGUI/vdigit: fix bug when digitizing areas (left X right)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-11-27 17:07:27 UTC (rev 49398)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-11-27 20:33:57 UTC (rev 49399)
@@ -1538,6 +1538,9 @@
left = cleft.value
right = cright.value
+ Debug.msg(3, "IVDigit._addFeature(): area - left=%d right=%d",
+ left, right)
# check if area exists and has no centroid inside
if layer > 0 and (left > 0 or right > 0):
Vect_cat_set(self.poCats, layer, cat)
@@ -1564,7 +1567,7 @@
Vect_get_area_centroid(self.poMapInfo, right) == 0:
# if Vect_get_area_points(byref(self.poMapInfo), right, bpoints) > 0 and
# Vect_find_poly_centroid(bpoints, byref(x), byref(y)) == 0:
- if Vect_get_point_in_area(self.poMapInfo, left, byref(x), byref(y)) == 0:
+ if Vect_get_point_in_area(self.poMapInfo, right, byref(x), byref(y)) == 0:
Vect_reset_line(bpoints)
Vect_append_point(bpoints, x.value, y.value, 0.0)
newline = Vect_write_line(self.poMapInfo, GV_CENTROID,
