[GRASS-SVN] r49402 - grass-addons/grass7/display/d.mon2
svn_grass at osgeo.org
Sun Nov 27 22:57:31 EST 2011
Author: hamish
Date: 2011-11-27 19:57:31 -0800 (Sun, 27 Nov 2011)
New Revision: 49402
grass-addons/grass7/display/d.mon2/d.mon2.py
sync to changed d.erase color= option, don't recenter qiv windows, DOS mode todo
Modified: grass-addons/grass7/display/d.mon2/d.mon2.py
--- grass-addons/grass7/display/d.mon2/d.mon2.py 2011-11-27 20:42:06 UTC (rev 49401)
+++ grass-addons/grass7/display/d.mon2/d.mon2.py 2011-11-28 03:57:31 UTC (rev 49402)
@@ -92,22 +92,25 @@
print('GRASS_HEIGHT=%s' % options['height'])
if flags['c']:
print('GRASS_RENDER_IMMEDIATE=cairo')
- else:
- print('GRASS_RENDER_IMMEDIATE=PNG')
+ else:
+ print('GRASS_RENDER_IMMEDIATE=PNG')
print('GRASS_PNG_MAPPED=TRUE')
print('GRASS_PNG_READ=TRUE')
print('export GRASS_PNGFILE GRASS_WIDTH GRASS_HEIGHT GRASS_RENDER_IMMEDIATE GRASS_PNG_MAPPED GRASS_PNG_READ;')
- print('d.erase color=%s;' % options['color'])
+ print('d.erase bgcolor=%s;' % options['color'])
if handler == "none":
grass.message("Image file is '%s'" % img_tmp)
elif handler == "qiv":
- print('qiv -T "%s" &' % img_tmp) # add --center ?
+ print('qiv -e -T "%s" &' % img_tmp) # add --center ?
else:
print('%s image="%s" percent=%s &' % ( handler, img_tmp, options['percent']) )
sys.exit(0)
+ if flags['d']:
+ print('rem DOS export not yet implemented')
+ sys.exit(0)
## rest of this won't work, as parent can't inherit from the child..
@@ -127,10 +130,10 @@
os.environ['GRASS_PNG_READ'] = 'TRUE'
#? os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
- grass.run_command('d.erase', color = options['color'])
+ grass.run_command('d.erase', bgcolor = options['color'])
- ret = grass.call(['qiv', '-T', img_tmp])
+ ret = grass.call(['qiv', '-e', '-T', img_tmp])
else:
ret = grass.exec_command(handler, image = img_tmp, percent = options['percent'])
