[GRASS-SVN] r49406 - grass/trunk/lib/gmath
svn_grass at osgeo.org
Mon Nov 28 04:52:18 EST 2011
Author: huhabla
Date: 2011-11-28 01:52:18 -0800 (Mon, 28 Nov 2011)
New Revision: 49406
grass/trunk/lib/gmath/solvers_direct_cholesky_band.c
Added OpenMP pragma to cholesky sband decomposition
Modified: grass/trunk/lib/gmath/solvers_direct_cholesky_band.c
--- grass/trunk/lib/gmath/solvers_direct_cholesky_band.c 2011-11-28 08:33:09 UTC (rev 49405)
+++ grass/trunk/lib/gmath/solvers_direct_cholesky_band.c 2011-11-28 09:52:18 UTC (rev 49406)
@@ -24,20 +24,22 @@
for (i = 0; i < rows; i++) {
G_percent(i, rows, 2);
- for (j = 0; j < bandwidth; j++) {
+ /* For j = 0 */
+ sum = A[i][0];
+ end = ((bandwidth - 0) < (i + 1) ? (bandwidth - 0) : (i + 1));
+ for (k = 1; k < end; k++)
+ sum -= T[i - k][k] * T[i - k][0 + k];
+ if (sum <= 0.0)
+ G_fatal_error(_("Decomposition failed at row %i and col %i"), i, 0);
+ T[i][0] = sqrt(sum);
+ #pragma omp parallel for schedule (static) private(j, k, end, sum) shared(A, T, i, bandwidth)
+ for (j = 1; j < bandwidth; j++) {
sum = A[i][j];
- /* start = 1 */
- /* end = bandwidth - j or i + 1 */
end = ((bandwidth - j) < (i + 1) ? (bandwidth - j) : (i + 1));
sum -= T[i - k][k] * T[i - k][j + k];
- if (j == 0) {
- if (sum <= 0.0)
- G_fatal_error(_("Decomposition failed at row %i and col %i"), i, j);
- T[i][0] = sqrt(sum);
- else
- T[i][j] = sum / T[i][0];
+ T[i][j] = sum / T[i][0];
