[GRASS-SVN] r49410 - in grass/trunk: gui/wxpython/core gui/wxpython/mapdisp gui/wxpython/nviz include/defs lib/ogsf
Mon Nov 28 14:10:58 EST 2011
Author: annakrat
Date: 2011-11-28 11:10:58 -0800 (Mon, 28 Nov 2011)
New Revision: 49410
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/nviz/mapwindow.py
   grass/trunk/gui/wxpython/nviz/wxnviz.py
   grass/trunk/include/defs/ogsf.h
   grass/trunk/lib/ogsf/GVL2.c
wxNviz: update 3d region when switching to 3d view
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2011-11-28 18:58:14 UTC (rev 49409)
+++ grass/trunk/gui/wxpython/core/render.py	2011-11-28 19:10:58 UTC (rev 49410)
@@ -588,7 +588,7 @@
     def GetRegion(self, rast = [], zoom = False, vect = [], regionName = None,
                   n = None, s = None, e = None, w = None, default = False,
-                  update = False):
+                  update = False, add3d = False):
         """!Get region settings (g.region -upgc)
         Optionally extent, raster or vector map layer can be given.
@@ -600,6 +600,7 @@
         @param n,s,e,w force extent
         @param default force default region settings
         @param update if True update current display region settings
+        @param add3d add 3d region settings
         @return region settings as directory, e.g. {
         'n':'4928010', 's':'4913700', 'w':'589980',...}
@@ -624,6 +625,9 @@
         if default:
             cmd['flags'] += 'd'
+        if add3d:
+            cmd['flags'] += '3'
         if regionName:
             cmd['region'] = regionName
@@ -693,7 +697,7 @@
         return self.region
-    def SetRegion(self, windres = False):
+    def SetRegion(self, windres = False, windres3 = False):
         """!Render string for GRASS_REGION env. variable, so that the
         images will be rendered from desired zoom level.
@@ -706,10 +710,16 @@
         grass_region = ""
         if windres:
-            compRegion = self.GetRegion()
+            compRegion = self.GetRegion(add3d = windres3)
             region = copy.copy(self.region)
             for key in ('nsres', 'ewres', 'cells'):
                 region[key] = compRegion[key]
+            if windres3:
+                for key in ('nsres3', 'ewres3', 'tbres', 'cells3',
+                            'cols3', 'rows3', 'depths'):
+                    if key in compRegion:
+                        region[key] = compRegion[key]
         else:
             # adjust region settings to match monitor
             region = self.AdjustRegion()
@@ -717,6 +727,7 @@
         # read values from wind file
         try:
             for key in self.wind.keys():
                 if key == 'north':
                     grass_region += "north: %s; " % \
                         (region['n'])
@@ -753,6 +764,24 @@
                     grass_region += 'rows: %d; ' % \
                         region['rows']
                     continue
+                elif key == "n-s resol3" and windres3:
+                    grass_region += "n-s resol3: %f; " % \
+                        (region['nsres3'])
+                elif key == "e-w resol3" and windres3:
+                    grass_region += "e-w resol3: %f; " % \
+                        (region['ewres3'])
+                elif key == "t-b resol" and windres3:
+                    grass_region += "t-b resol: %f; " % \
+                        (region['tbres'])
+                elif key == "cols3" and windres3:
+                    grass_region += "cols3: %d; " % \
+                        (region['cols3'])
+                elif key == "rows3" and windres3:
+                    grass_region += "rows3: %d; " % \
+                        (region['rows3'])
+                elif key == "depths" and windres3:
+                    grass_region += "depths: %d; " % \
+                        (region['depths'])
                 else:
                     grass_region += key + ": "  + self.wind[key] + "; "
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2011-11-28 18:58:14 UTC (rev 49409)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2011-11-28 19:10:58 UTC (rev 49410)
@@ -326,7 +326,7 @@
             self.MapWindow3D.UpdateView(None)
         else:
             self.MapWindow = self.MapWindow3D
-            os.environ['GRASS_REGION'] = self.Map.SetRegion(windres = True)
+            os.environ['GRASS_REGION'] = self.Map.SetRegion(windres = True, windres3 = True)
             self.MapWindow3D.GetDisplay().Init()
             del os.environ['GRASS_REGION']
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py	2011-11-28 18:58:14 UTC (rev 49409)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py	2011-11-28 19:10:58 UTC (rev 49410)
@@ -128,8 +128,8 @@
             logerr = sys.stderr
         # create nviz instance - use display region instead of computational
         self.nvizThread = NvizThread(logerr,
                                      self.parent.GetProgressBar(),
                                      logmsg)
Modified: grass/trunk/gui/wxpython/nviz/wxnviz.py
--- grass/trunk/gui/wxpython/nviz/wxnviz.py	2011-11-28 18:58:14 UTC (rev 49409)
+++ grass/trunk/gui/wxpython/nviz/wxnviz.py	2011-11-28 19:10:58 UTC (rev 49410)
@@ -124,6 +124,7 @@
         Rast__init_window()
         GS_libinit()
         GVL_libinit()
+        GVL_init_region()
     def ResizeWindow(self, width, height):
         """!GL canvas resized
Modified: grass/trunk/include/defs/ogsf.h
--- grass/trunk/include/defs/ogsf.h	2011-11-28 18:58:14 UTC (rev 49409)
+++ grass/trunk/include/defs/ogsf.h	2011-11-28 19:10:58 UTC (rev 49410)
@@ -231,6 +231,7 @@
 /* GVL2.c */
 void GVL_libinit(void);
+void GVL_init_region(void);
 int GVL_get_region(float *, float *, float *, float *, float *, float *);
 void *GVL_get_window();
 int GVL_vol_exists(int);
Modified: grass/trunk/lib/ogsf/GVL2.c
--- grass/trunk/lib/ogsf/GVL2.c	2011-11-28 18:58:14 UTC (rev 49409)
+++ grass/trunk/lib/ogsf/GVL2.c	2011-11-28 19:10:58 UTC (rev 49410)
@@ -50,6 +50,25 @@
+   \brief Initialize 3D region
+   Set region extent (N,S,W,E,T,B)
+    Rast3d_read_window(&wind3, NULL);
+    Region[0] = wind3.north;
+    Region[1] = wind3.south;
+    Region[2] = wind3.west;
+    Region[3] = wind3.east;
+    Region[4] = wind3.top;
+    Region[5] = wind3.bottom;
+    return;
    \brief Get region extent settings
    \param[out] n,s,w,e north, south, west, east
