[GRASS-SVN] r49435 - in grass/trunk/gui/wxpython: gcp gui_core mapdisp
Wed Nov 30 11:17:59 EST 2011
Author: martinl
Date: 2011-11-30 08:17:59 -0800 (Wed, 30 Nov 2011)
New Revision: 49435
Added:
   grass/trunk/gui/wxpython/mapdisp/main.py
   grass/trunk/gui/wxpython/gcp/mapdisplay.py
   grass/trunk/gui/wxpython/gui_core/mapdisp.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
wxGUI: added 'mapdisp.main' for standalone app
Modified: grass/trunk/gui/wxpython/gcp/mapdisplay.py
--- grass/trunk/gui/wxpython/gcp/mapdisplay.py	2011-11-30 16:04:22 UTC (rev 49434)
+++ grass/trunk/gui/wxpython/gcp/mapdisplay.py	2011-11-30 16:17:59 UTC (rev 49435)
@@ -127,8 +127,8 @@
         # initialize region values
-        self._initMap(map = self.SrcMap)
-        self._initMap(map = self.TgtMap)
+        self._initMap(Map = self.SrcMap)
+        self._initMap(Map = self.TgtMap)
         # Bind various events
Modified: grass/trunk/gui/wxpython/gui_core/mapdisp.py
--- grass/trunk/gui/wxpython/gui_core/mapdisp.py	2011-11-30 16:04:22 UTC (rev 49434)
+++ grass/trunk/gui/wxpython/gui_core/mapdisp.py	2011-11-30 16:17:59 UTC (rev 49435)
@@ -76,7 +76,7 @@
         self._mgr = wx.aui.AuiManager(self)
-    def _initMap(self, map):
+    def _initMap(self, Map):
         """!Initialize map display, set dimensions and map region
         if not grass.find_program('g.region', ['--help']):
@@ -86,8 +86,8 @@
         self.width, self.height = self.GetClientSize()
         Debug.msg(2, "MapFrame._initMap():")
-        map.ChangeMapSize(self.GetClientSize())
-        map.region = map.GetRegion() # g.region -upgc
+        Map.ChangeMapSize(self.GetClientSize())
+        Map.region = Map.GetRegion() # g.region -upgc
         # self.Map.SetRegion() # adjust region to match display window
     def SetProperty(self, name, value):
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2011-11-30 16:04:22 UTC (rev 49434)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2011-11-30 16:17:59 UTC (rev 49435)
@@ -8,11 +8,7 @@
 Classes:
  - mapdisp::MapFrame
- - mapdisp::MapApp
-Usage:
-python mapdisp.py monitor-identifier /path/to/map/file /path/to/command/file /path/to/env/file
 (C) 2006-2011 by the GRASS Development Team
 This program is free software under the GNU General Public License
@@ -62,14 +58,6 @@
 from grass.script import core as grass
-# for standalone app
-monFile = { 'cmd' : None,
-            'map' : None,
-            'env' : None,
-monName = None
-monSize = list(globalvar.MAP_WINDOW_SIZE)
 haveCtypes = False
 class MapFrame(MapFrameBase):
@@ -155,7 +143,7 @@
-        self._initMap(map = self.Map)
+        self._initMap(Map = self.Map)
@@ -1405,101 +1393,3 @@
     def GetMapToolbar(self):
         """!Returns toolbar with zooming tools"""
         return self.toolbars['map']
-class MapApp(wx.App):
-    def OnInit(self):
-        wx.InitAllImageHandlers()
-        if __name__ == "__main__":
-            self.cmdTimeStamp = os.path.getmtime(monFile['cmd'])
-            Map = Map(cmdfile = monFile['cmd'], mapfile = monFile['map'],
-                      envfile = monFile['env'], monitor = monName)
-        else:
-            Map = None
-        self.mapFrm = MapFrame(parent = None, id = wx.ID_ANY, Map = Map,
-                               size = monSize)
-        # self.SetTopWindow(Map)
-        self.mapFrm.Show()
-            self.timer = wx.PyTimer(self.watcher)
-            #check each 0.5s
-            global mtime
-            mtime = 500
-            self.timer.Start(mtime)
-        return True
-    def OnExit(self):
-            # stop the timer
-            # self.timer.Stop()
-            # terminate thread
-            for f in monFile.itervalues():
-                grass.try_remove(f)
-    def watcher(self):
-        """!Redraw, if new layer appears (check's timestamp of
-        cmdfile)
-        # todo: events
-        if os.path.getmtime(monFile['cmd']) > self.cmdTimeStamp:
-            self.timer.Stop()
-            self.mapFrm.OnDraw(None)
-            self.mapFrm.GetMap().GetLayersFromCmdFile()
-if __name__ == "__main__":
-    # set command variable
-    if len(sys.argv) < 5:
-        print __doc__
-        sys.exit(1)
-    monName = sys.argv[1]
-    monFile = { 'map' : sys.argv[2],
-                'cmd' : sys.argv[3],
-                'env' : sys.argv[4],
-    if len(sys.argv) >= 6:
-        try:
-            monSize[0] = int(sys.argv[5])
-        except ValueError:
-            pass
-    if len(sys.argv) == 7:
-        try:
-            monSize[1] = int(sys.argv[6])
-            pass
-    import gettext
-    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
-    grass.verbose(_("Starting map display <%s>...") % (monName))
-    RunCommand('g.gisenv',
-               set = 'MONITOR_%s_PID=%d' % (monName, os.getpid()))
-    gm_map = MapApp(0)
-    # set title
-    gm_map.mapFrm.SetTitle(_("GRASS GIS Map Display: " +
-                             monName +
-                             " - Location: " + grass.gisenv()["LOCATION_NAME"]))
-    gm_map.MainLoop()
-    grass.verbose(_("Stopping map display <%s>...") % (monName))
-    # clean up GRASS env variables
-    env = grass.gisenv()
-    env_name = 'MONITOR_%s' % monName
-    for key in env.keys():
-        if key.find(env_name) == 0:
-                       set = '%s=' % key)
-        if key == 'MONITOR' and env[key] == monName:
-    sys.exit(0)
Added: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2011-11-30 16:17:59 UTC (rev 49435)
@@ -0,0 +1,141 @@
+ at package mapdisp.main
+ at brief Start Map Display as standalone application
+Classes:
+ - mapdisp::MapApp
+Usage:
+python mapdisp/main.py monitor-identifier /path/to/map/file /path/to/command/file /path/to/env/file
+(C) 2006-2011 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Michael Barton
+ at author Jachym Cepicky
+ at author Martin Landa <landa.martin gmail.com>
+ at author Vaclav Petras <wenzeslaus gmail.com> (MapFrameBase)
+ at author Anna Kratochvilova <kratochanna gmail.com> (MapFrameBase)
+import os
+import sys
+import wx
+sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
+from core          import globalvar
+from core.gcmd     import RunCommand
+from core.render   import Map
+from mapdisp.frame import MapFrame
+from grass.script  import core as grass
+# for standalone app
+monFile = { 'cmd' : None,
+            'map' : None,
+            'env' : None,
+monName = None
+monSize = list(globalvar.MAP_WINDOW_SIZE)
+class MapApp(wx.App):
+    def OnInit(self):
+        wx.InitAllImageHandlers()
+        if __name__ == "__main__":
+            self.cmdTimeStamp = os.path.getmtime(monFile['cmd'])
+            self.Map = Map(cmdfile = monFile['cmd'], mapfile = monFile['map'],
+                           envfile = monFile['env'], monitor = monName)
+        else:
+            self.Map = None
+        self.mapFrm = MapFrame(parent = None, id = wx.ID_ANY, Map = self.Map,
+                               size = monSize)
+        # self.SetTopWindow(Map)
+        self.mapFrm.Show()
+            self.timer = wx.PyTimer(self.watcher)
+            #check each 0.5s
+            global mtime
+            mtime = 500
+            self.timer.Start(mtime)
+        return True
+    def OnExit(self):
+            # stop the timer
+            # self.timer.Stop()
+            # terminate thread
+            for f in monFile.itervalues():
+                grass.try_remove(f)
+    def watcher(self):
+        """!Redraw, if new layer appears (check's timestamp of
+        cmdfile)
+        # todo: events
+        if os.path.getmtime(monFile['cmd']) > self.cmdTimeStamp:
+            self.timer.Stop()
+            self.mapFrm.OnDraw(None)
+            self.mapFrm.GetMap().GetLayersFromCmdFile()
+if __name__ == "__main__":
+    # set command variable
+    if len(sys.argv) < 5:
+        print __doc__
+        sys.exit(1)
+    monName = sys.argv[1]
+    monFile = { 'map' : sys.argv[2],
+                'cmd' : sys.argv[3],
+                'env' : sys.argv[4],
+    if len(sys.argv) >= 6:
+        try:
+            monSize[0] = int(sys.argv[5])
+        except ValueError:
+            pass
+    if len(sys.argv) == 7:
+        try:
+            monSize[1] = int(sys.argv[6])
+            pass
+    import gettext
+    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+    grass.verbose(_("Starting map display <%s>...") % (monName))
+    RunCommand('g.gisenv',
+               set = 'MONITOR_%s_PID=%d' % (monName, os.getpid()))
+    gmMap = MapApp(0)
+    # set title
+    gmMap.mapFrm.SetTitle(_("GRASS GIS Map Display: " +
+                            monName +
+                            " - Location: " + grass.gisenv()["LOCATION_NAME"]))
+    gmMap.MainLoop()
+    grass.verbose(_("Stopping map display <%s>...") % (monName))
+    # clean up GRASS env variables
+    env = grass.gisenv()
+    env_name = 'MONITOR_%s' % monName
+    for key in env.keys():
+        if key.find(env_name) == 0:
+                       set = '%s=' % key)
+        if key == 'MONITOR' and env[key] == monName:
+    sys.exit(0)
Property changes on: grass/trunk/gui/wxpython/mapdisp/main.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
