[GRASS-SVN] r49446 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Wed Nov 30 18:14:01 EST 2011
Author: martinl
Date: 2011-11-30 15:14:01 -0800 (Wed, 30 Nov 2011)
New Revision: 49446
grass/trunk/scripts/g.extension/g.extension.py
g.extension: update for installing pre-compiled GRASS Addons on Windows
(merge r49445 from devbr6)
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-11-30 23:03:33 UTC (rev 49445)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-11-30 23:14:01 UTC (rev 49446)
@@ -96,6 +96,7 @@
import glob
import zipfile
import tempfile
+import shutil
from urllib2 import urlopen, HTTPError
@@ -373,7 +374,66 @@
if grass.find_program(options['extension'], ['--help']):
grass.warning(_("Extension <%s> already installed. Will be updated...") % options['extension'])
+ if sys.platform == "win32":
+ install_extension_win()
+ else:
+ install_extension_other()
+ # manual page: fix href
+ if os.getenv('GRASS_ADDON_PATH'):
+ html_man = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'docs', 'html', options['extension'] + '.html')
+ if os.path.exists(html_man):
+ fd = open(html_man)
+ html_str = '\n'.join(fd.readlines())
+ fd.close()
+ for rep in ('grassdocs.css', 'grass_logo.png'):
+ patt = re.compile(rep, re.IGNORECASE)
+ html_str = patt.sub(os.path.join(gisbase, 'docs', 'html', rep),
+ html_str)
+ patt = re.compile(r'(<a href=")(d|db|g|i|m|p|ps|r|r3|s|v|wxGUI)(\.)(.+)(.html">)', re.IGNORECASE)
+ while True:
+ m = patt.search(html_str)
+ if not m:
+ break
+ html_str = patt.sub(m.group(1) + os.path.join(gisbase, 'docs', 'html',
+ m.group(2) + m.group(3) + m.group(4)) + m.group(5),
+ html_str, count = 1)
+ fd = open(html_man, "w")
+ fd.write(html_str)
+ fd.close()
+ # symlink for binaries needed, see http://trac.osgeo.org/grass/changeset/49124
+ src = None
+ if sys.platform == 'win32':
+ bin_ext = '.exe'
+ sct_ext = '.py'
+ else:
+ bin_ext = sct_ext = ''
+ if os.path.exists(os.path.join(options['prefix'], 'bin',
+ options['extension'] + bin_ext)):
+ src = os.path.join(options['prefix'], 'bin', options['extension']) + bin_ext
+ dst = os.path.join(options['prefix'], options['extension']) + bin_ext
+ elif os.path.exists(os.path.join(options['prefix'], 'scripts',
+ options['extension'] + sct_ext)):
+ src = os.path.join(options['prefix'], 'scripts', options['extension']) + sct_ext
+ dst = os.path.join(options['prefix'], options['extension']) + sct_ext
+ if src and not os.path.exists(dst):
+ shutil.copyfile(src, dst)
+ else:
+ os.symlink(src, dst)
+ if not os.environ.has_key('GRASS_ADDON_PATH') or \
+ not os.environ['GRASS_ADDON_PATH']:
+ grass.warning(_('This add-on module will not function until you set the '
+ 'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
+def install_extension_other():
+ gisbase = os.getenv('GISBASE')
gui_list = list_wxgui_extensions(print_module = False)
if options['extension'] not in gui_list:
@@ -617,9 +677,6 @@
remove_tmpdir = False
if options['operation'] == 'add':
- if sys.platform == "win32":
- install_extension_win()
- else:
install_extension()
else: # remove
remove_extension()
