[GRASS-SVN] r48577 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Sat Oct 1 03:29:46 EDT 2011
Author: mmetz
Date: 2011-10-01 00:29:46 -0700 (Sat, 01 Oct 2011)
New Revision: 48577
grass/trunk/raster/r.in.lidar/r.in.lidar.html
r.in.lidar: update manual
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html 2011-10-01 07:29:22 UTC (rev 48576)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html 2011-10-01 07:29:46 UTC (rev 48577)
@@ -82,8 +82,6 @@
The default map <b>type</b>=<tt>FCELL</tt> is intended as compromise between
preserving data precision and limiting system resource consumption.
-If reading data from a <tt>stdin</tt> stream, the program can only run using
-a single pass.
<h3>Setting region bounds and resolution</h3>
@@ -176,33 +174,32 @@
<h2>EXAMPLE</h2>
-Import the <a href="http://www.grassbook.org/data_menu2nd.phtml">Jockey's
-Ridge, NC, LIDAR dataset</a>, and process into a clean DEM:
+This example is analogous to the example used in the GRASS wiki page for
+<a href="http://grass.osgeo.org/wiki/LIDAR#Import_LAS_as_raster_DEM">importing LAS as raster DEM</a>.
+<p>
+The sample LAS data are in the file "Serpent Mound Model LAS Data.las",
+available at
+<a href="http://www.appliedimagery.com/downloads/sampledata/Serpent%20Mound%20Model%20LAS%20Data.las">appliedimagery.com</a>
<div class="code"><pre>
- # scan and set region bounds
- r.in.xyz -s fs=, in=lidaratm2.txt out=test
- g.region n=35.969493 s=35.949693 e=-75.620999 w=-75.639999
- g.region res=0:00:00.075 -a
- # create "n" map containing count of points per cell for checking density
- r.in.xyz in=lidaratm2.txt out=lidar_n fs=, method=n zrange=-2,50
- # check point density [rho = n_sum / (rows*cols)]
- r.univar lidar_n | grep sum
- # create "min" map (elevation filtered for premature hits)
- r.in.xyz in=lidaratm2.txt out=lidar_min fs=, method=min zrange=-2,50
- # zoom to area of interest
- g.region n=35:57:56.25N s=35:57:13.575N w=75:38:23.7W e=75:37:15.675W
- # check number of non-null cells (try and keep under a few million)
- r.univar lidar_min | grep '^n:'
- # convert to points
- r.to.vect -z feature=point in=lidar_min out=lidar_min_pt
- # interpolate using a regularized spline fit
- v.surf.rst layer=0 in=lidar_min_pt elev=lidar_min.rst
- # set color scale to something interesting
- r.colors lidar_min.rst rule=bcyr -n -e
- # prepare a 1:1:1 scaled version for NVIZ visualization (for lat/lon input)
- r.mapcalc "lidar_min.rst_scaled = lidar_min.rst / (1852*60)"
- r.colors lidar_min.rst_scaled rule=bcyr -n -e
+ # using v.in.lidar to print file info and to create a new location
+ # print LAS file info
+ v.in.lidar -p input="Serpent Mound Model LAS Data.las"
+ # create location with projection information of the LAS data
+ v.in.lidar -i input="Serpent Mound Model LAS Data.las" location=Serpent_Mound
+ # quit and restart GRASS in the newly created location "Serpent_Mound"
+ # scan the extents of the LAS data
+ r.in.lidar -sg input="Serpent Mound Model LAS Data.las"
+ # set the region to the extents of the LAS data, align to resolution
+ g.region n=4323641.57 s=4320942.61 w=289020.90 e=290106.02 res=1 -ap
+ # import as raster DEM
+ r.in.lidar input="Serpent Mound Model LAS Data.las" output=Serpent_Mound_Model_LAS_Data method=mean
</pre></div>
<br>
@@ -250,6 +247,7 @@
<a href="r.to.rast3.html">r.to.rast3</a><br>
<a href="r.to.vect.html">r.to.vect</a><br>
<a href="r.univar.html">r.univar</a><br>
+<a href="v.in.lidar.html">v.in.lidar</a><br>
<a href="v.in.ascii.html">v.in.ascii</a><br>
<a href="v.surf.rst.html">v.surf.rst</a><br>
<br>
