[GRASS-SVN] r48579 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Sat Oct 1 03:31:11 EDT 2011
Author: mmetz
Date: 2011-10-01 00:31:11 -0700 (Sat, 01 Oct 2011)
New Revision: 48579
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: improve no import handling
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2011-10-01 07:30:09 UTC (rev 48578)
+++ grass/trunk/vector/v.in.lidar/main.c 2011-10-01 07:31:11 UTC (rev 48579)
@@ -217,6 +217,7 @@
no_import_flag->description =
_("Create the location specified by the \"location\" parameter and exit."
" Do not import the vector file.");
+ no_import_flag->suppress_required = YES;
notopo_flag = G_define_flag();
notopo_flag->key = 'b';
@@ -266,17 +267,6 @@
exit(EXIT_SUCCESS);
- if (!outloc_opt->answer) { /* Check if the map exists */
- if (G_find_vector2(out_opt->answer, G_mapset())) {
- if (overwrite)
- G_warning(_("Vector map <%s> already exists and will be overwritten"),
- out_opt->answer);
- else
- G_fatal_error(_("Vector map <%s> already exists"),
- out_opt->answer);
return_filter = LAS_ALL;
if (filter_opt->answer) {
if (strcmp(filter_opt->answer, "first") == 0)
@@ -478,6 +468,17 @@
db_init_string(&sql);
db_init_string(&strval);
+ if (!outloc_opt->answer) { /* Check if the map exists */
+ if (G_find_vector2(out_opt->answer, G_mapset())) {
+ if (overwrite)
+ G_warning(_("Vector map <%s> already exists and will be overwritten"),
+ out_opt->answer);
+ else
+ G_fatal_error(_("Vector map <%s> already exists"),
+ out_opt->answer);
/* open output vector */
sprintf(buf, "%s", out_opt->answer);
/* strip any @mapset from vector output name */
