[GRASS-SVN] r48583 - grass-addons/grass7/raster/r.regression.series
svn_grass at osgeo.org
Sat Oct 1 11:21:30 EDT 2011
Author: mmetz
Date: 2011-10-01 08:21:30 -0700 (Sat, 01 Oct 2011)
New Revision: 48583
Added:
grass-addons/grass7/raster/r.regression.series/r.regression.series.html
Removed:
grass-addons/grass7/raster/r.regression.series/r.series.html
grass-addons/grass7/raster/r.regression.series/Makefile
grass-addons/grass7/raster/r.regression.series/main.c
r.regression.series
Modified: grass-addons/grass7/raster/r.regression.series/Makefile
--- grass-addons/grass7/raster/r.regression.series/Makefile 2011-10-01 15:19:02 UTC (rev 48582)
+++ grass-addons/grass7/raster/r.regression.series/Makefile 2011-10-01 15:21:30 UTC (rev 48583)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = r.series
+PGM = r.regression.series
LIBES = $(STATSLIB) $(RASTERLIB) $(GISLIB)
DEPENDENCIES = $(STATSDEP) $(RASTERDEP) $(GISDEP)
Modified: grass-addons/grass7/raster/r.regression.series/main.c
--- grass-addons/grass7/raster/r.regression.series/main.c 2011-10-01 15:19:02 UTC (rev 48582)
+++ grass-addons/grass7/raster/r.regression.series/main.c 2011-10-01 15:21:30 UTC (rev 48583)
@@ -2,11 +2,16 @@
* MODULE: r.series
- * AUTHOR(S): Glynn Clements <glynn gclements.plus.com> (original contributor)
+ * AUTHOR(S): Markus Metz
+ * based on r.series by
+ * Glynn Clements <glynn gclements.plus.com> (original contributor)
* Hamish Bowman <hamish_b yahoo.com>, Jachym Cepicky <jachym les-ejk.cz>,
* Martin Wegmann <wegmann biozentrum.uni-wuerzburg.de>
- * PURPOSE:
- * COPYRIGHT: (C) 2002-2008 by the GRASS Development Team
+ * PURPOSE: regression between two time series
+ * COPYRIGHT: (C) 2011 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -16,42 +21,134 @@
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
+#include <math.h>
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/glocale.h>
-#include <grass/stats.h>
+#define REGRESSION_SLOPE 0
+#define REGRESSION_OFFSET 1
+#define REGRESSION_COEFF_DET 2
+#define REGRESSION_COEFF_DET_ADJ 3
+#define REGRESSION_F_VALUE 4
+#define REGRESSION_T_VALUE 5
+static void reg(DCELL *result, DCELL (*values)[2], int n, int which)
+ DCELL sumX, sumY, sumsqX, sumsqY, sumXY;
+ DCELL meanX, meanY;
+ DCELL A, B, R, F, T;
+ int count;
+ int i;
+ sumX = sumY = sumsqX = sumsqY = sumXY = 0.0;
+ meanX = meanY = 0.0;
+ count = 0;
+ for (i = 0; i < n; i++) {
+ if (Rast_is_d_null_value(&values[i][0]) ||
+ Rast_is_d_null_value(&values[i][1]))
+ continue;
+ sumX += values[i][0];
+ sumY += values[i][1];
+ sumsqX += values[i][0] * values[i][0];
+ sumsqY += values[i][1] * values[i][1];
+ sumXY += values[i][0] * values[i][1];
+ count++;
+ if (count < 2) {
+ Rast_set_d_null_value(result, 1);
+ return;
+ B = (sumXY - sumX * sumY / count) / (sumsqX - sumX * sumX / count);
+ R = (sumXY - sumX * sumY / count) /
+ sqrt((sumsqX - sumX * sumX / count) * (sumsqY - sumY * sumY / count));
+ meanX = sumX / count;
+ meanY = sumY / count;
+ switch (which) {
+ case REGRESSION_SLOPE:
+ *result = B;
+ break;
+ case REGRESSION_OFFSET:
+ A = meanY - B * meanX;
+ *result = A;
+ break;
+ case REGRESSION_COEFF_DET:
+ *result = R;
+ break;
+ case REGRESSION_COEFF_DET_ADJ:
+ *result = 1 - (1 - R) * ((count - 1) / (count - 2 - 1));
+ break;
+ case REGRESSION_F_VALUE:
+ F = R * R / (1 - R * R / count - 2);
+ *result = F;
+ break;
+ case REGRESSION_T_VALUE:
+ T = sqrt(R) * sqrt((count - 2) / (1 - R));
+ *result = T;
+ break;
+ default:
+ break;
+ /* Check for NaN */
+ if (*result != *result)
+void reg_m(DCELL * result, DCELL (*values)[2], int n)
+ reg(result, values, n, REGRESSION_SLOPE);
+void reg_c(DCELL * result, DCELL (*values)[2], int n)
+ reg(result, values, n, REGRESSION_OFFSET);
+void reg_r2(DCELL * result, DCELL (*values)[2], int n)
+ reg(result, values, n, REGRESSION_COEFF_DET);
+void reg_r2_adj(DCELL * result, DCELL (*values)[2], int n)
+void reg_f(DCELL * result, DCELL (*values)[2], int n)
+ reg(result, values, n, REGRESSION_F_VALUE);
+void reg_t(DCELL * result, DCELL (*values)[2], int n)
+ reg(result, values, n, REGRESSION_T_VALUE);
+typedef void stat_func(DCELL *, DCELL (*)[2], int);
struct menu
stat_func *method; /* routine to compute new value */
- int is_int; /* result is an integer */
char *name; /* method name */
char *text; /* menu display - full description */
} menu[] = {
- {c_ave, 0, "average", "average value"},
- {c_count, 1, "count", "count of non-NULL cells"},
- {c_median, 0, "median", "median value"},
- {c_mode, 0, "mode", "most frequently occuring value"},
- {c_min, 0, "minimum", "lowest value"},
- {c_minx, 1, "min_raster", "raster with lowest value"},
- {c_max, 0, "maximum", "highest value"},
- {c_maxx, 1, "max_raster", "raster with highest value"},
- {c_stddev, 0, "stddev", "standard deviation"},
- {c_range, 0, "range", "range of values"},
- {c_sum, 0, "sum", "sum of values"},
- {c_var, 0, "variance", "statistical variance"},
- {c_divr, 1, "diversity", "number of different values"},
- {c_reg_m, 0, "slope", "linear regression slope"},
- {c_reg_c, 0, "offset", "linear regression offset"},
- {c_reg_r2, 0, "detcoeff", "linear regression coefficient of determination"},
- {c_quart1, 0, "quart1", "first quartile"},
- {c_quart3, 0, "quart3", "third quartile"},
- {c_perc90, 0, "perc90", "ninetieth percentile"},
- {c_quant, 0, "quantile", "arbitrary quantile"},
- {c_skew, 0, "skewness", "skewness"},
- {c_kurt, 0, "kurtosis", "kurtosis"},
- {NULL, 0, NULL, NULL}
+ {reg_m, "slope", "linear regression slope"},
+ {reg_c, "offset", "linear regression offset"},
+ {reg_r2, "detcoeff", "linear regression coefficient of determination"},
+ {reg_r2_adj, "adjdetcoeff", "adjusted coefficient of determination"},
+ {reg_f, "f", "F statistic"},
+ {reg_t, "t", "T statistic"},
+ {NULL, NULL, NULL}
struct input
@@ -67,7 +164,6 @@
int fd;
DCELL *buf;
stat_func *method_fn;
- double quantile;
static char *build_method_list(void)
@@ -107,7 +203,7 @@
struct GModule *module;
struct
- struct Option *input, *output, *method, *quantile, *range;
+ struct Option *xinput, *yinput, *output, *method;
} parm;
struct
@@ -115,14 +211,13 @@
} flag;
int i;
int num_inputs;
- struct input *inputs;
+ struct input *xinputs, *yinputs;
int num_outputs;
struct output *outputs;
struct History history;
- DCELL *values, *values_tmp;
+ DCELL (*values)[2], (*values_tmp)[2];
int nrows, ncols;
int row, col;
- double lo, hi;
G_gisinit(argv[0]);
@@ -134,8 +229,12 @@
"function of the values assigned to the corresponding cells "
"in the input raster map layers.");
- parm.input = G_define_standard_option(G_OPT_R_INPUTS);
+ parm.xinput = G_define_standard_option(G_OPT_R_INPUTS);
+ parm.xinput->key = "xseries";
+ parm.yinput = G_define_standard_option(G_OPT_R_INPUTS);
+ parm.yinput->key = "yseries";
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
parm.output->multiple = YES;
@@ -144,23 +243,9 @@
parm.method->type = TYPE_STRING;
parm.method->required = YES;
parm.method->options = build_method_list();
- parm.method->description = _("Aggregate operation");
+ parm.method->description = _("Regression parameters");
parm.method->multiple = YES;
- parm.quantile = G_define_option();
- parm.quantile->key = "quantile";
- parm.quantile->type = TYPE_DOUBLE;
- parm.quantile->required = NO;
- parm.quantile->description = _("Quantile to calculate for method=quantile");
- parm.quantile->options = "0.0-1.0";
- parm.quantile->multiple = YES;
- parm.range = G_define_option();
- parm.range->key = "range";
- parm.range->type = TYPE_DOUBLE;
- parm.range->key_desc = "lo,hi";
- parm.range->description = _("Ignore values outside this range");
flag.nulls = G_define_flag();
flag.nulls->key = 'n';
flag.nulls->description = _("Propagate NULLs");
@@ -168,28 +253,39 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (parm.range->answer) {
- lo = atof(parm.range->answers[0]);
- hi = atof(parm.range->answers[1]);
/* process the input maps */
- for (i = 0; parm.input->answers[i]; i++)
+ for (i = 0; parm.xinput->answers[i]; i++)
num_inputs = i;
- if (num_inputs < 1)
- G_fatal_error(_("Raster map not found"));
+ for (i = 0; parm.yinput->answers[i]; i++)
+ if (num_inputs != i)
+ G_fatal_error(_("The number of '%s' and '%s' maps must be identical"),
+ parm.xinput->key, parm.yinput->key);
- inputs = G_malloc(num_inputs * sizeof(struct input));
+ if (num_inputs < 3)
+ G_fatal_error(_("Regression parameters can not be calculated for less than 3 maps per series"));
+ if (num_inputs < 7)
+ G_warning(_("Regression parameters are dubious for less than 7 maps per series"));
+ xinputs = G_malloc(num_inputs * sizeof(struct input));
+ yinputs = G_malloc(num_inputs * sizeof(struct input));
for (i = 0; i < num_inputs; i++) {
- struct input *p = &inputs[i];
+ struct input *px = &xinputs[i];
+ struct input *py = &yinputs[i];
- p->name = parm.input->answers[i];
- G_message(_("Reading raster map <%s>..."), p->name);
- p->fd = Rast_open_old(p->name, "");
- p->buf = Rast_allocate_d_buf();
+ px->name = parm.xinput->answers[i];
+ G_message(_("Reading raster map <%s>..."), px->name);
+ px->fd = Rast_open_old(px->name, "");
+ px->buf = Rast_allocate_d_buf();
+ py->name = parm.yinput->answers[i];
+ G_message(_("Reading raster map <%s>..."), py->name);
+ py->fd = Rast_open_old(py->name, "");
+ py->buf = Rast_allocate_d_buf();
/* process the output maps */
@@ -212,17 +308,13 @@
out->name = output_name;
out->method_fn = menu[method].method;
- out->quantile = (parm.quantile->answer && parm.quantile->answers[i])
- ? atof(parm.quantile->answers[i])
- : 0;
out->buf = Rast_allocate_d_buf();
- out->fd = Rast_open_new(output_name,
- menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
+ out->fd = Rast_open_new(output_name, DCELL_TYPE);
/* initialise variables */
- values = G_malloc(num_inputs * sizeof(DCELL));
- values_tmp = G_malloc(num_inputs * sizeof(DCELL));
+ values = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
+ values_tmp = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
nrows = Rast_window_rows();
ncols = Rast_window_cols();
@@ -233,23 +325,23 @@
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
- for (i = 0; i < num_inputs; i++)
- Rast_get_d_row(inputs[i].fd, inputs[i].buf, row);
+ for (i = 0; i < num_inputs; i++) {
+ Rast_get_d_row(xinputs[i].fd, xinputs[i].buf, row);
+ Rast_get_d_row(yinputs[i].fd, yinputs[i].buf, row);
for (col = 0; col < ncols; col++) {
int null = 0;
- DCELL v = inputs[i].buf[col];
+ DCELL x = xinputs[i].buf[col];
+ DCELL y = yinputs[i].buf[col];
- if (Rast_is_d_null_value(&v))
+ if (Rast_is_d_null_value(&x) || Rast_is_d_null_value(&y))
null = 1;
- else if (parm.range->answer && (v < lo || v > hi)) {
- Rast_set_d_null_value(&v, 1);
- null = 1;
- values[i] = v;
+ values[i][0] = x;
+ values[i][1] = y;
for (i = 0; i < num_outputs; i++) {
@@ -258,8 +350,8 @@
if (null && flag.nulls->answer)
Rast_set_d_null_value(&out->buf[col], 1);
else {
- memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
- (*out->method_fn)(&out->buf[col], values_tmp, num_inputs, &out->quantile);
+ memcpy(values_tmp, values, num_inputs * 2 * sizeof(DCELL));
+ (*out->method_fn)(&out->buf[col], values_tmp, num_inputs);
@@ -281,8 +373,10 @@
Rast_write_history(out->name, &history);
- Rast_close(inputs[i].fd);
+ Rast_close(xinputs[i].fd);
+ Rast_close(yinputs[i].fd);
exit(EXIT_SUCCESS);
Copied: grass-addons/grass7/raster/r.regression.series/r.regression.series.html (from rev 48582, grass-addons/grass7/raster/r.regression.series/r.series.html)
--- grass-addons/grass7/raster/r.regression.series/r.regression.series.html (rev 0)
+++ grass-addons/grass7/raster/r.regression.series/r.regression.series.html 2011-10-01 15:21:30 UTC (rev 48583)
@@ -0,0 +1,105 @@
+<h2>DESCRIPTION</h2>
+<em>r.regression.series</em> makes each output cell value a function of the values
+assigned to the corresponding cells in the two input raster map series.
+Following methods are available:
+<ul>
+ <li>offset: linear regression offset
+ <li>slope: linear regression slope
+ <li>detcoeff: linear regression coefficient of determination
+ <li>adjdetcoeff: adjusted coefficient of determination
+ <li>f: F statistic
+ <li>t: T statistic
+ </ul>
+The module assumes a simple linear regression of the form
+<div class="code"><pre>
+ y = a + b * x
+</pre></div>
+<p>
+<em>offset</em> is equivalent to <em>a</em> in the above equation, also
+referred to as constant or intercept.
+<p>
+<em>slope</em> is equivalent to <em>b</em> in the above equation.
+<p>
+<em>detcoff</em> is the coefficient of determination, equivalent to
+the squared correlation coefficient R<sup>2</sup>.
+<p>
+<em>adjdetcoff</em> is the coefficient of determination adjusted for the
+number of samples, i.e. number of input maps per series.
+<p>
+<em>f</em> is the value of the F statistic.
+<p>
+<em>t</em> is the value of the T statistic.
+<h2>NOTES</h2>
+The number of maps in <em>xseries</em> and <em>yseries</em> must be
+identical.
+<p>
+With <em>-n</em> flag, any cell for which any of the corresponding input cells are
+NULL is automatically set to NULL (NULL propagation). The aggregate function is not
+called, so all methods behave this way with respect to the <em>-n</em> flag.
+<p>
+Without <em>-n</em> flag, the complete list of inputs for each cell
+(including NULLs) is passed to the function. Individual functions can
+handle data as they choose. Mostly, they just compute the parameter
+over the non-NULL values, producing a NULL result only if all inputs
+are NULL.
+<p>
+Linear regression (slope, offset, coefficient of determination) requires
+an equal number of <em>xseries</em> and <em>yseries</em> maps.
+If the different time series have irregular time intervals, NULL raster
+maps can be inserted into time series to make time intervals equal (see example).
+<p>
+The maximum number of raster maps to be processed is limited by the
+operating system. For example, both the hard and soft limits are
+typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
+1500</tt> (UNIX-based operating systems) but not higher than the hard
+limit. If it is too low, you can as superuser add an entry in
+/etc/security/limits.conf
+# <domain> <type> <item> <value>
+your_username hard nofile 1500
+</pre></div>
+This would raise the hard limit to 1500 file. Be warned that more
+files open need more RAM.
+<h2>EXAMPLES</h2>
+Using <em>r.regression.series</em> with wildcards:
+<br>
+r.regression.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
+ output=insitu_data.det method=detcoeff
+</pre></div>
+<p>
+Note the <em>g.mlist</em> module also supports regular expressions for
+selecting map names.
+<p>
+Example for multiple parameters to be computed in one run (3 resulting
+parameters from 8 input maps, 4 maps per time series):
+r.regression.series x=xone,xtwo,xthree,xfour y=yone,ytwo,ythree,yfour \
+ out=res_offset,res_slope,res_det meth=offset,slope,adjdetcoeff
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="r.series.html">r.series</a></em>,
+<em><a href="r.regression.line.html">r.regression.line</a></em>,
+<em><a href="g.mlist.html">g.mlist</a></em>,
+<em><a href="g.region.html">g.region</a></em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster/r.regression.series/r.series.html
--- grass-addons/grass7/raster/r.regression.series/r.series.html 2011-10-01 15:19:02 UTC (rev 48582)
+++ grass-addons/grass7/raster/r.regression.series/r.series.html 2011-10-01 15:21:30 UTC (rev 48583)
@@ -1,107 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.series</em> makes each output cell value a function of the values
-assigned to the corresponding cells in the input raster map layers.
-Following methods are available:
-<ul>
- <li>average: average value
- <li>count: count of non-NULL cells
- <li>median: median value
- <li>mode: most frequently occuring value
- <li>minimum: lowest value
- <li>maximum: highest value
- <li>range: range of values (max - min)
- <li>stddev: standard deviation
- <li>sum: sum of values
- <li>variance: statistical variance
- <li>diversity: number of different values
- <li>slope: linear regression slope
- <li>offset: linear regression offset
- <li>detcoeff: linear regression coefficient of determination
- <li>min_raster: raster map number with the minimum time-series value
- <li>max_raster: raster map number with the maximum time-series value
- </ul>
-<h2>NOTES</h2>
-With <em>-n</em> flag, any cell for which any of the corresponding input cells are
-NULL is automatically set to NULL (NULL propagation). The aggregate function is not
-called, so all methods behave this way with respect to the <em>-n</em> flag.
-<p>
-Without <em>-n</em> flag, the complete list of inputs for each cell (including
-NULLs) is passed to the aggregate function. Individual aggregates can
-handle data as they choose. Mostly, they just compute the aggregate
-over the non-NULL values, producing a NULL result only if all inputs
-are NULL.
-<p>
-The <em>min_raster</em> and <em>max_raster</em> methods generate a map with the
-number of the raster map that holds the minimum/maximum value of the
-time-series. The numbering starts at <em>0</em> up to <em>n</em> for the
-first and the last raster listed in <em>input=</em>, respectively.
-<p>
-If the <em>range=</em> option is given, any values which fall outside
-that range will be treated as if they were NULL.
-The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
-values outside of this range are treated as NULL (i.e., they will be
-ignored by most aggregates, or will cause the result to be NULL if -n is given).
-The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
-<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
-negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
-<p>
-Linear regression (slope, offset, coefficient of determination) assumes equal time intervals.
-If the data have irregular time intervals, NULL raster maps can be inserted into time series
-to make time intervals equal (see example).
-<p>
-Number of raster maps to be processed is given by the limit of the
-operating system. For example, both the hard and soft limits are
-typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
-1500</tt> (UNIX-based operating systems) but not higher than the hard
-limit. If it is too low, you can as superuser add an entry in
-<div class="code"><pre>
-/etc/security/limits.conf
-# <domain> <type> <item> <value>
-your_username hard nofile 1500
-</pre></div>
-This would raise the hard limit to 1500 file. Be warned that more
-files open need more RAM.
-<h2>EXAMPLES</h2>
-Using <em>r.series</em> with wildcards:
-<br>
-r.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
- output=insitu_data.stddev method=stddev
-</pre></div>
-<p>
-Note the <em>g.mlist</em> script also supports regular expressions for
-selecting map names.
-<p>
-Using <em>r.series</em> with NULL raster maps:
-<br>
-r.mapcalc "dummy = null()"
-r.series in=map2001,map2002,dummy,dummy,map2005,map2006,dummy,map2008 \
- out=res_slope,res_offset,res_coeff meth=slope,offset,detcoeff
-</pre></div>
-<p>
-Example for multiple aggregates to be computed in one run (3 resulting aggregates from two input maps):
-r.series in=one,two out=result_avg,res_slope,result_count meth=sum,slope,count
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="g.mlist.html">g.mlist</a></em>,
-<em><a href="g.region.html">g.region</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements
-<p><i>Last changed: $Date$</i>
