[GRASS-SVN] r48595 - in grass-addons/vector: . v.eqsm
svn_grass at osgeo.org
Sun Oct 2 13:18:14 EDT 2011
Author: annalisapg
Date: 2011-10-02 10:18:14 -0700 (Sun, 02 Oct 2011)
New Revision: 48595
Added:
grass-addons/vector/v.eqsm/
grass-addons/vector/v.eqsm/Makefile
grass-addons/vector/v.eqsm/description.html
grass-addons/vector/v.eqsm/v.eqsm.py
new module for vertical sorting in river dynamic
Added: grass-addons/vector/v.eqsm/Makefile
--- grass-addons/vector/v.eqsm/Makefile (rev 0)
+++ grass-addons/vector/v.eqsm/Makefile 2011-10-02 17:18:14 UTC (rev 48595)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.eqsm.py
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/vector/v.eqsm/Makefile
___________________________________________________________________
Added: svn:executable
Added: grass-addons/vector/v.eqsm/description.html
--- grass-addons/vector/v.eqsm/description.html (rev 0)
+++ grass-addons/vector/v.eqsm/description.html 2011-10-02 17:18:14 UTC (rev 48595)
@@ -0,0 +1,11 @@
+<h2>DESCRIPTION</h2>
+<em>v.eqsm</em> allows to perform a point-to-point prediction of vertical sorting of sediments by grainsize computing the variation of bed composition in depth for a river reach; the module implements the Equilibrium Sorting Model by Blom&Parker (2006).
+<h2>AUTHOR</h2>
+Annalisa Minelli, University of Perugia<br />
+<br />
+<p>
+<i>Last changed: $Date: 2009-07-14 07:52:42 +0200 (mar, 14 lug 2009) $</i>
Added: grass-addons/vector/v.eqsm/v.eqsm.py
--- grass-addons/vector/v.eqsm/v.eqsm.py (rev 0)
+++ grass-addons/vector/v.eqsm/v.eqsm.py 2011-10-02 17:18:14 UTC (rev 48595)
@@ -0,0 +1,709 @@
+#!/usr/bin/env python
+#%Module
+#% description: Implements Equilibrium Sorting Model at reach scale for a bimodal sediment mixture (Blom&Parker)
+#% keywords: eqsm
+#%end
+#%flag
+#% key: m
+#% description: Multiple point calculation
+#%end
+#%option
+#% key: dem
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Input dem of the zone
+#% required: no
+#%end
+#%option
+#% key: input_csv
+#% type: string
+#% gisprompt: old_file,file,input
+#% key_desc: name
+#% description: .csv file in output from the laser scanner - lab_mode only -
+#% required: no
+#% guisection: DEM importation
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: file type
+#% options: key,mas,snr
+#% required: no
+#%end
+#%option
+#% key: outputDEM
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: DEM interpolated
+#% required: no
+#%end
+#%option
+#% key: vector
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Input vector file of examined fluvial reach
+#% required: yes
+#%end
+#%option
+#% key: res
+#% type: double
+#% description: Resolution how to work [meters or mm for field or lab mode respectively]
+#% required: yes
+#%end
+#%option
+#% key: fiuno
+#% type: double
+#% description: Dimension of first grainsize examined [phi]
+#% required: yes
+#%end
+#%option
+#% key: fidue
+#% type: double
+#% description: Dimension of second grainsize examined [phi]
+#% required: yes
+#%end
+#%option
+#% key: dmax
+#% type: double
+#% description: Maximum depth where to perform the analysis [meters or mm for field or lab mode respectively]
+#% required: yes
+#%end
+#%option
+#% key: nstep
+#% type: double
+#% description: Number of steps (in depth) where to perform the analysis
+#% required: yes
+#%end
+#%option
+#% key: lee_out
+#% type: string
+#% gisprompt: new,vector,vector
+#% description: Vector file of lee faces in output from model
+#% required: yes
+#%end
+#%option
+#% key: point_out
+#% type: string
+#% description: Vector file of point/s reporting results of the prediction
+#% required: no
+#%end
+#%option
+#% key: ros
+#% type: double
+#% description: Bed-load material density [N/mc]
+#% required: yes
+#% guisection: Bedload info
+#%end
+#%option
+#% key: to
+#% type: double
+#% description: Averaged bed shear stress [Pa]
+#% required: yes
+#%end
+#%option
+#% key: fauno
+#% type: double
+#% description: Volume fraction of material of first grainsize in bed-load transport [%]
+#% required: yes
+#%end
+#%option
+#% key: fadue
+#% type: double
+#% description: Volume fraction of material of second grainsize in bed-load transport [%]
+#% required: yes
+#%end
+#%option
+#% key: n_iter
+#% type: integer
+#% description: Number of iterations to execute in performing Fi predictions
+#% required: yes
+#%end
+#%option
+#% key: txtout
+#% type: string
+#% description: Output text file where to store results of the prediction
+#% required: yes
+#%end
+#%option
+#% key: graphout
+#% type: string
+#% description: Prefix for output graphs of vertical sorting for each point selected (final format: prefix_point1, prefix_point2, ...)
+#% required: yes
+#%end
+import sys,os,re,math,numpy
+import grass.script as grass
+import matplotlib.pyplot as plt
+#OK FUNZIA
+def import_csv(res,input_csv,type,outputDEM):
+ """Cleans the .csv file in output from the laser scanner, imports points in GRASS GIS and interpolates bed surface using idw method"""
+ prova1=open(input_csv,"rw")
+ array=(prova1.readlines())
+ if type == 'key':
+ array2=array[20:]
+ elif type == 'mas':
+ array2=array[21:]
+ elif type == 'snr':
+ array2=array[33:]
+ i=0
+ p=open("p","w")
+ for b in array2:
+ s=re.split(",",array2[i])[5]
+ if s == 'OutOfRange\r\n' or s == 'OutOfRange' or s == 'OutOfRange\r' or s == 'OutOfRange\r\n' or s == '"OutOfRange"\r\n' or s == '"OutOfRange"' or s == '"OutOfRange"\r' or s == '"OutOfRange\r\n"':
+ i=i+1
+ continue
+ else:
+ x=float(re.split(",",array2[i])[2])
+ y=float(re.split(",",array2[i])[3])
+ z=float(re.split("\r",s)[0])
+ c=str(x)+'|'+str(y)+'|'+str(z)
+ p.write(c)
+ p.write('\n')
+ i=i+1
+ p.close()
+ grass.run_command('v.in.ascii',input='p',output='provadb')
+ grass.run_command('g.region',vect='provadb',n='n+100',e='e+100',w='w-100',s='s-100')
+ grass.run_command('g.region',flags='a',res=res)
+ grass.run_command('v.surf.idw',input='provadb',npoints='2',power='1.0',column='dbl_3',output=outputDEM)
+#OK FUNZIA
+def general_geom(vector,dem,res):
+ """Defines some general information about geometry of the reach studied"""
+ grass.run_command('g.region',vect=vector,n='n+100',s='s-100',e='e+100',w='w-100')
+ grass.run_command('v.drape',input=vector,type='line',rast=dem,output='vector_drape',method='nearest',scale='1.0',layer='1')
+ start=(grass.read_command('v.to.db',flags='p',map='vector_drape',option='start',columns='Estart,Nstart,Zstart').split('\n')[1]).split('|')[1:3]
+ end=(grass.read_command('v.to.db',flags='p',map='vector_drape',option='end',columns='Eend,Nend,Zend').split('\n')[1]).split('|')[1:3]
+ profilec=(grass.read_command('r.profile',input=dem,profile=start[0]+','+start[1]+','+end[0]+','+end[1],res=res)).split('\n')[0:-1]
+ x=[]
+ z=[]
+ for i in profilec:
+ x.append(float(i.split(' ')[0]))
+ z.append(float(i.split(' ')[1]))
+ xline=x[0],x[-1]
+ zline=z[0],z[-1]
+ length=float(((grass.read_command('v.to.db',flags='pc',map='vector_drape',type='line',layer='1',qlayer='1',option='length',units='meters')).split(' ')[-1]).split('\n')[0])
+ deltatot=float(((grass.read_command('v.info',flags='g',map='vector_drape')).split('\n')[-3]).split('=')[-1])-float(((grass.read_command('v.info',flags='g',map='vector_drape')).split('\n')[-2]).split('=')[-1])
+ rad=math.atan(deltatot/length)
+ return x,z,xline,zline,length,deltatot,rad
+#OK_FUNZIA
+def lines_sl(vector,res,dem,stoss_dradd,lee_dradd):
+ """Classifies segments of the original reach file in stoss and lee faces, in reason of the heigth of start and ending point of each one read by DEM, for calculation issues the reach is extended of an half resolution length, so the first segment (outlet of the reach) has not to be considered"""
+ grass.run_command('g.remove',vect='preso_punto,presoo,preso_ok,vector_pezzi,vector_pezzi_add,vector_pezzi_del,vector_drape_pezzi,vector_lee,vector_stoss,tratti_leep,tratti_stossp,tratti_lee_del,lee_dradd')
+ newE=float((re.split('\n',grass.read_command('v.to.db',flags='p',map=vector,option='start',column='Es,Ns'))[1]).split('|')[1])
+ newN=float((re.split('\n',grass.read_command('v.to.db',flags='p',map=vector,option='start',column='Es,Ns'))[1]).split('|')[2])
+ grass.write_command('v.in.ascii',output='preso_punto',stdin=str(newE)+'|'+str(newN))
+ grass.run_command('v.net',input=vector,points='preso_punto',output='presoo',operation='connect',thresh=res)
+ grass.run_command('v.edit',map='presoo',layer='1',type='line',tool='delete',thresh='-1,0,0',ids='1',snap='no')
+ grass.run_command('v.edit',map='presoo',layer='1',type='point',tool='delete',thresh='-1,0,0',ids='1-999',snap='no')
+ grass.run_command('v.build.polylines',input='presoo',output='preso_ok')
+ grass.run_command('v.split',input='preso_ok',output='vector_pezzi',length=0.999*float(res))
+ grass.run_command('v.category',input='vector_pezzi',output='vector_pezzi_del',option='del',type='line',cat='1',step='1')
+ grass.run_command('v.category',input='vector_pezzi_del',output='vector_pezzi_add',option='add',type='line',cat='1',step='1')
+ grass.run_command('v.drape',input='vector_pezzi_add',type='line',rast=dem,output='vector_drape_pezzi',method='nearest',scale='1.0',layer='1')
+ grass.run_command('v.db.addtable',map='vector_drape_pezzi',columns='cat integer,startE double precision,startN double precision,startZ double precision,endE double precision,endN double precision,endZ double precision')
+ grass.run_command('v.to.db',map='vector_drape_pezzi',type='line',layer='1',qlayer='1',option='start',units='meters',columns='startE,startN,startZ')
+ grass.run_command('v.to.db',map='vector_drape_pezzi',type='line',layer='1',qlayer='1',option='end',units='meters',columns='endE,endN,endZ')
+ firstcat_endZ=float((grass.read_command('db.select',flags='c',table='vector_drape_pezzi').split('\n')[0]).split('|')[-1])
+ lastcat_endZ=float((grass.read_command('db.select',flags='c',table='vector_drape_pezzi').split('\n')[-2]).split('|')[-1])
+ if lastcat_endZ < firstcat_endZ:
+ grass.run_command('v.extract',input='vector_drape_pezzi',output='vector_lee',type='line',layer='1',where="endZ<=startZ",new='-1')
+ grass.run_command('v.extract',input='vector_drape_pezzi',output='vector_stoss',type='line',layer='1',where="endZ>startZ",new='-1')
+ else:
+ grass.run_command('v.extract',input='vector_drape_pezzi',output='vector_lee',type='line',layer='1',where="endZ>=startZ",new='-1')
+ grass.run_command('v.extract',input='vector_drape_pezzi',output='vector_stoss',type='line',layer='1',where="endZ<startZ",new='-1')
+ grass.run_command('v.build.polylines',input='vector_lee',output='tratti_leep',cats='no')
+ grass.run_command('v.build.polylines',input='vector_stoss',output='tratti_stossp',cats='no')
+ grass.run_command('v.category',input='tratti_stossp',output='tratti_stoss_del',option='del',type='line',layer='1',cat='1',step='1')
+ grass.run_command('v.category',input='tratti_stoss_del',output=stoss_dradd,option='add',type='line',layer='1',cat='1',step='1')
+ grass.run_command('v.category',input='tratti_leep',output='tratti_lee_del',option='del',type='line',layer='1',cat='1',step='1')
+ grass.run_command('v.category',input='tratti_lee_del',output=lee_dradd,option='add',type='line',layer='1',cat='1',step='1')
+ return lastcat_endZ,firstcat_endZ
+#OK FUNZIA!
+def populate_lines(lee_dradd,vector_pezzi_add,firstcat_endZ,lastcat_endZ,rad,deltatot,length,stoss_dradd,lee_out,dem,point_out):
+ """Populates database of lee faces vector file with start end ending point coords, length and delta of each segment, eta and lambda are evaluated as subroutines"""
+ grass.run_command('g.remove',vect='vector_del,vector_add,take_this,point_del')
+ grass.run_command('v.db.addtable',map=lee_dradd,columns='cat integer,startE double precision,startN double precision,startZ double precision,endE double precision,endN double precision,endZ double precision')
+ grass.run_command('v.to.db',map=lee_dradd,type='line',layer='1',qlayer='1',option='start',units='meters',columns='startE,startN,startZ')
+ grass.run_command('v.to.db',map=lee_dradd,type='line',layer='1',qlayer='1',option='end',units='meters',columns='endE,endN,endZ')
+ grass.run_command('v.db.addtable',map=vector_pezzi_add,layer='1',columns='cat integer,length double precision,startE double precision,startN double precision,endE double precision,endN double precision')
+ grass.run_command('v.to.db',map=vector_pezzi_add,option='length',type='line',units='meters',columns='length')
+ grass.run_command('v.to.db',map=vector_pezzi_add,option='start',type='line',units='meters',columns='startE,startN')
+ grass.run_command('v.to.db',map=vector_pezzi_add,option='end',type='line',units='meters',columns='endE,endN')
+ grass.run_command('v.db.addcol',map=lee_dradd,column='delta double precision,etat double precision,etab double precision')
+ vector_length=re.split('\n',grass.read_command('db.select',flags='c',table=vector_pezzi_add,driver='dbf'))[:-1]
+ lee_drad=re.split('\n',grass.read_command('db.select',table=lee_dradd,driver='dbf'))[1:-1]
+ for i in lee_drad:
+ cat=str(i.split('|')[0])
+ estart=str(i.split('|')[1])
+ nstart=str(i.split('|')[2])
+ eend=str(i.split('|')[4])
+ nend=str(i.split('|')[5])
+ if lastcat_endZ<firstcat_endZ:
+ dtop=float(i.split('|')[3])
+ dbottom=float(i.split('|')[6])
+ else:
+ dtop=float(i.split('|')[6])
+ dbottom=float(i.split('|')[3])
+ d=[]
+ g=[]
+ v=[]
+ for c in vector_length:
+ d.append(str(str(c.split('|')[2])+'|'+str(c.split('|')[3])+'|'+str(c.split('|')[0])))
+ g.append(str(str(c.split('|')[4])+'|'+str(c.split('|')[5])+'|'+str(c.split('|')[0])))
+ v.append(int(c.split('|')[0]))
+ coord1=str(estart)+'|'+str(nstart)
+ coord2=str(eend)+'|'+str(nend)
+ catt=[int(f.split('|')[2]) for f in d if re.match(coord1,f)]
+ catb=[int(f.split('|')[2]) for f in g if re.match(coord2,f)]
+ min=lastcat_endZ
+ lb=(max(v)-catb[0]-1)*float(vector_length[1].split('|')[1])
+ lt=(max(v)-catt[0])*float(vector_length[1].split('|')[1])
+ else:
+ min=firstcat_endZ
+ catb=[int(f.split('|')[2]) for f in d if re.match(coord1,f)]
+ catt=[int(f.split('|')[2]) for f in g if re.match(coord2,f)]
+ lb=(catb[0]-1)*float(vector_length[1].split('|')[1])
+ lt=(catt[0])*float(vector_length[1].split('|')[1])
+ deltab=lb*deltatot/length
+ deltat=lt*deltatot/length
+ zt=dtop-min
+ zb=dbottom-min
+ etab=(zb-deltab)*float(math.cos(rad))
+ etat=(zt-deltat)*float(math.cos(rad))
+ delta=abs(etat-etab)
+ grass.run_command('v.db.update',map=lee_dradd,layer='1',column='etab',value=etab,where='cat='+str(cat))
+ grass.run_command('v.db.update',map=lee_dradd,layer='1',column='etat',value=etat,where='cat='+str(cat))
+ grass.run_command('v.db.update',map=lee_dradd,layer='1',column='delta',value=delta,where='cat='+str(cat))
+ grass.run_command('v.db.addtable',map=stoss_dradd,columns='cat integer,length double precision')
+ grass.run_command('v.to.db',map=stoss_dradd,type='line',layer='1',option='length',units='meters',columns='length')
+ stoss_lambda=re.split('\n',grass.read_command('db.select',table=stoss_dradd,driver='dbf'))[1:-1]
+ grass.run_command('v.db.addcol',map=lee_dradd,columns='length double precision,lambda double precision')
+ grass.run_command('v.to.db',map=lee_dradd,type='line',layer='1',option='length',units='meters',columns='length')
+ lee_lambda=re.split('\n',grass.read_command('db.select',table=lee_dradd,driver='dbf'))[1:-1]
+ grass.run_command('v.category',input=vector_pezzi_add,output='vector_del',option='del')
+ grass.run_command('v.category',input='vector_del',output='vector_add',option='add')
+ grass.run_command('v.drape',input='vector_add',rast=dem,output=vector_pezzi_add)
+ grass.run_command('v.extract',flags='t',input=vector_pezzi_add,output='one_add',type='line',list='1',new='-1')
+ grass.run_command('v.extract',flags='t',input=lee_dradd,output='one_lee',type='line',list='1',new='-1')
+ grass.run_command('v.select',ainput='one_add',atype='line',binput='one_lee',btype='line',output='take_this1')
+ grass.run_command('v.select',ainput='one_lee',atype='line',binput='one_add',btype='line',output='take_this2')
+ info1=int((grass.read_command('v.info',flags='t',map='take_this1').split('\n')[2]).split('=')[1])
+ info2=int((grass.read_command('v.info',flags='t',map='take_this2').split('\n')[2]).split('=')[1])
+ for i in lee_lambda:
+ l_cat=int(i.split('|')[0])
+ l_catj=l_cat+1
+ l_lee=float(i.split('|')[10])
+ if info1 != 0 or info2 !=0:
+ try:
+ l_stoss=float((stoss_lambda[l_cat-1]).split('|')[1])
+ except IndexError:
+ break
+ else:
+ try:
+ l_stoss=float(stoss_lambda[l_catj-1].split('|')[1])
+ break
+ lambd=(l_lee+l_stoss)/float(math.cos(rad))
+ grass.run_command('v.db.update',map=lee_dradd,layer='1',column='lambda',value=lambd,where='cat='+str(int(l_cat)))
+ lee_lambda=(grass.read_command('db.select',flags='c',table=lee_dradd,driver='dbf').split('\n'))[:-1]
+ grass.run_command('g.copy',vect=str(lee_dradd)+','+str(lee_out))
+ return lee_lambda
+#OK FUNZIA
+def point_selection(lee_dradd,m,nstep,point_out,dem):
+ """Allows you to select one or more sections for the prediction"""
+ grass.run_command('g.remove',vect=point_out)
+ grass.run_command('v.in.ascii',output=point_out,flags='e')
+ grass.run_command('v.db.addtable',map=point_out,columns='cat integer,lee integer,E double precision,N double precision')
+ nstep=int(nstep)
+ for j in range(nstep+1):
+ grass.run_command('v.db.addcol',map=point_out,columns='F1'+str(j+1)+' double precision,F2'+str(j+1)+' double precision')
+ id_section=[]
+ east_section=[]
+ north_section=[]
+ z_avg=[]
+ z_pt=[]
+ grass.run_command('d.vect',map=lee_dradd,color='255:0:0')
+ print "+--------------------------------------------------------------------+"
+ print " Please zoom on the zone where you want to perform the prediction"
+ grass.run_command('d.zoom')
+ if m:
+ print "+----------------------------------------------------------------+"
+ print " Please select multiple points where to perform your prediction"
+ output=(grass.read_command('d.what.vect',flags='xt',map=lee_dradd)).split('\n')
+ for i in output:
+ if re.match('category:',i):
+ id_section.append(int(i.split(': ')[1]))
+ elif re.match('.*\(E\).*',i):
+ east_section.append(float(i.split('(E) ')[0]))
+ north_section.append(float(((i.split('(E) ')[1])).split('(N')[0]))
+ else:
+ print "+------------------------------------------------------------+"
+ print " Please select the point where to perform your prediction"
+ output=(grass.read_command('d.what.vect',flags='1xt',map=lee_dradd)).split('\n')
+ id_section=[int(i.split(': ')[1]) for i in output if re.match('category:',i)]
+ east_section=[float(i.split('(E) ')[0]) for i in output if re.match('.*\(E\).*',i)]
+ north_section=[float(((i.split('(E) ')[1])).split('(N')[0]) for i in output if re.match('.*\(E\).*',i)]
+ n=0
+ for h in east_section:
+ grass.run_command('v.in.ascii',flags='e',output='out'+str(n))
+ grass.write_command('v.in.ascii',output='out'+str(n),x='1',y='2',fs='|',stdin='%s|%s' % (h,north_section[n]))
+ grass.run_command('v.db.addtable',map='out'+str(n),columns='cat integer,lee integer,E double precision,N double precision')
+ grass.run_command('v.db.addcol',map='out'+str(n),columns='F1'+str(j+1)+' double precision,F2'+str(j+1)+' double precision')
+ grass.run_command('v.patch',flags='ae',input='out'+str(n),output=point_out)
+ grass.run_command('v.category',input=point_out,option='del',output='point_del')
+ grass.run_command('v.category',input='point_del',option='add',output=point_out)
+ grass.run_command('v.db.update',map=point_out,layer='1',column='lee',value=str(id_section[n]),where='cat='+str(n+1))
+ grass.run_command('v.to.db',map=point_out,option='cat',columns='cat')
+ grass.run_command('v.to.db',map=point_out,option='coor',columns='E,N')
+ n=n+1
+ grass.run_command('v.db.update',map=point_out,layer='1',column='lee',value=str(id_section[0]),where='cat=1')
+ n=0
+ for i in id_section:
+ Z=(float(grass.read_command('db.select',flags='c',sql='select startZ from lee_dradd where cat='+str(i),table='lee_dradd'))+float(grass.read_command('db.select',flags='c',sql='select endZ from lee_dradd where cat='+str(i),table='lee_dradd')))/2
+ z_pt.append(float((grass.read_command('r.what',input=dem,east_north=str(east_section[n])+','+str(north_section[n]))).split('|')[3]))
+ z_avg.append(Z)
+ n=n+1
+ return id_section,east_section,north_section,z_avg,z_pt
+#OK FUNZIA!
+def graphics(lee_lambda,x,z,xline,zline):
+ """Draws distribution graphics for the reach profile and point/s examined"""
+ import pylab
+ delta_list=[]
+ delta_log=[]
+ etat_list=[]
+ etat_abs=[]
+ etab_list=[]
+ etab_abs=[]
+ cc=0
+ cv=0
+ me=0
+ delta_list.append(float(i.split('|')[7]))
+ delta_log.append(math.log(float(i.split('|')[7])))
+ etat_list.append(float(i.split('|')[8]))
+ etab_list.append(float(i.split('|')[9]))
+ etat_abs.append(abs(float(i.split('|')[8])))
+ etab_abs.append(abs(float(i.split('|')[9])))
+ if float(i.split('|')[8])>0 and float(i.split('|')[9])>0:
+ cv=cv+1
+ elif float(i.split('|')[8])<0 and float(i.split('|')[9])<0:
+ cc=cc+1
+ else:
+ me=me+1
+ totlee=int(lee_lambda[-1].split('|')[0])
+ pylab.plot(x,z)
+ pylab.plot(xline,zline)
+ pylab.axis([min(x),max(x),min(z)-100,max(z)+100])
+ pylab.figtext(x=0.05,y=0.95,s='The profile is concave for the '+str(cc*100/totlee)+'%, convex for the '+str(cv*100/totlee)+'%, and average for the '+str(me*100/totlee)+'%,')
+ pylab.figtext(x=0.05,y=0.92,s='respect to the mean bed level')
+ pylab.xlabel('x [mm]')
+ pylab.ylabel('z [mm]')
+ pylab.savefig('reach_profile')
+ pylab.close()
+ pylab.hist(delta_list)
+ pylab.xlabel('delta [mm]')
+ pylab.ylabel('frequency')
+ pylab.savefig('delta_raw')
+ pylab.close()
+ pylab.hist(delta_log)
+ pylab.xlabel('ln(delta)')
+ pylab.ylabel('density')
+ pylab.savefig('delta_log')
+ pylab.close()
+ pylab.hist(etat_list)
+ pylab.xlabel('etat [mm]')
+ pylab.savefig('etat_raw')
+ pylab.close()
+ pylab.hist(etab_list)
+ pylab.xlabel('etab [mm]')
+ pylab.savefig('etab_raw')
+ pylab.close()
+ rankt=numpy.array(range(len(etat_list)+1))[1:]
+ rankb=numpy.array(range(len(etab_list)+1))[1:]
+ setat=numpy.array(sorted(etat_abs))
+ setab=numpy.array(sorted(etab_abs))
+ Fetat=numpy.array(rankt-0.3)/(len(setat)+0.4)
+ Fetab=numpy.array(rankb-0.3)/(len(setab)+0.4)
+ xtweib=numpy.array(numpy.log(setat))
+ xbweib=numpy.array(numpy.log(setab))
+ ytweib=numpy.array(numpy.log(-numpy.log(1-Fetat)))
+ ybweib=numpy.array(numpy.log(-numpy.log(1-Fetab)))
+ (a,b)=pylab.polyfit(xtweib,ytweib,1)
+ pylab.plot(xtweib,ytweib,'o', xtweib,a*xtweib+b,'-')
+ pylab.xlabel('ln(F(etat))')
+ pylab.ylabel('ln(-ln(1-F(etat)))')
+ pylab.savefig('etat_weibull')
+ pylab.close()
+ (a,b)=pylab.polyfit(xbweib,ybweib,1)
+ pylab.plot(xbweib,ybweib,'o', xbweib,a*xbweib+b,'-')
+ pylab.xlabel('ln(F(etab))')
+ pylab.ylabel('ln(-ln(1-F(etab)))')
+ pylab.savefig('etab_weibull')
+ pylab.close()
+ k_etab=a
+ l_etab=numpy.exp(-b/k_etab)
+ return k_etab,l_etab,delta_list,etab_list
+#CORRETTA:
+def weibull(x,k,l):
+ return [0 if (x<0) else ((k/l) * (x/l)**(k-1) * math.e**(-(x/l)**k))]
+def integ1(x,jzeta,lambd,delta,deltauno,z_star,k,l):
+ return (((jzeta**2)/(lambd*delta))+((jzeta*deltauno*z_star)/(lambd*delta)))*(numpy.array(weibull(x,k,l)))
+def integ2(x,jzeta,lambd,delta,deltadue,z_star,k,l):
+ return (((jzeta**2)/(lambd*delta))+((jzeta*deltadue*z_star)/(lambd*delta)))*(numpy.array(weibull(x,k,l)))
+def integ3(x,jzeta,delta,lambd,k,l):
+ return (((jzeta)/(lambd*delta)))*(numpy.array(weibull(x,k,l)))
+def numeric(id_section,east_section,north_section,dmax,nstep,z_pt,z_avg,lee_lambda,delta_list,etab_list,rad,fiuno,fidue,fauno,fadue,to,ros,k,l,n_iter,point_out):
+ """Executes the Eqsm prediction on the point/s examined"""
+ import scipy.integrate as integrate
+ k=float(k)
+ l=float(l)
+ fiuno=float(fiuno)
+ fidue=float(fidue)
+ ros=float(ros)
+ to=float(to)
+ fauno=float(fauno)
+ fadue=float(fadue)
+ dmax=float(dmax)
+ nstep=int(nstep)
+ lambda_list=[]
+ lambda_list.append(float(i.split('|')[10]))
+ try:
+ step=float(dmax/nstep)
+ except ZeroDivisionError:
+ step=0.0
+ dval=[]
+ for i in range(nstep):
+ dval.append((i+1)*step)
+ dval.insert(0,0.0)
+ print dval
+ n=0
+ g=0
+ for j in dval:
+ etabi=float(lee_lambda[i-1].split('|')[9])
+ etati=float(lee_lambda[i-1].split('|')[8])
+ delta=float(lee_lambda[i-1].split('|')[7])
+ lambd=float(lee_lambda[i-1].split('|')[10])
+ est_start=float(lee_lambda[i-1].split('|')[1])
+ nord_start=float(lee_lambda[i-1].split('|')[2])
+ alfa=math.atan(delta/lambd)
+ x_coord=math.sqrt( (float(east_section[n])-est_start)**2 + ((float(north_section[n]))-nord_start)**2 )
+ z_abs=z_pt[n] - j
+ z_star=(z_abs-z_avg[n])/delta
+ if abs(z_abs-z_avg[n]) <= delta:
+ jzeta=1
+ else:
+ jzeta=0
+ print "z out of range"
+# jzeta=1
+ cosa=math.cos(rad)
+ dmedia=numpy.mean(delta_list)
+ emedia=numpy.mean(etab_list)
+ estd=numpy.std(etab_list)
+ lmedia=numpy.mean(lambda_list)
+ etabmin=numpy.min(etab_list)
+ etabmax=numpy.max(etab_list)
+ n_iter=int(n_iter)
+ for c in range(n_iter):
+ if c==0:
+ fleeuno=0.5
+ fleedue=0.5
+ fimlee=((fiuno*fleeuno)+(fidue*fleedue))
+ sigma=numpy.sqrt((fleeuno*(fiuno-fimlee)**2)+(fleedue*(fidue-fimlee)**2))
+ taustarb=(to/(((ros-999.972)*9.81*2**(-fimlee))/1000))
+ deltauno=-0.3*((fimlee-fiuno)/sigma)*taustarb**(-0.5)
+ deltadue=-0.3*((fimlee-fidue)/sigma)*taustarb**(-0.5)
+ A=1/(jzeta*(1+deltauno*z_star))
+ omega=1/A
+ Aprimo=1/(jzeta*(1+deltadue*z_star))
+ omegaprimo=1/Aprimo
+ B=fauno*(1-(deltauno/6)+((deltauno*dmedia)/(6*lmedia)))**(-1)
+ C=fadue*(1-(deltadue/6)+((deltadue*dmedia)/(6*lmedia)))**(-1)
+ E=integrate.quad(lambda x:integ1(x,jzeta,lambd,delta,deltauno,z_star,k,l),etabmin,etabmax)
+ E=float(E[0])
+ Eprimo=integrate.quad(lambda x:integ2(x,jzeta,lambd,delta,deltadue,z_star,k,l),etabmin,etabmax)
+ Eprimo=float(Eprimo[0])
+ F=integrate.quad(lambda x:integ3(x,jzeta,delta,lambd,k,l),etabmin,etabmax)
+ F=float(F[0])
+ fleeunou=A*(B/(B+C))*(E/F)
+ fleeuno=(fleeunou+fleeuno)/2
+ fleedueu=Aprimo*(C/(B+C))*(Eprimo/F)
+ fleedue=(fleedueu+fleedue)/2
+ c=c+1
+ funo=fleeunou*omega
+ fdue=fleedueu*omegaprimo
+ grass.run_command('v.db.update',map=point_out,column='F1'+str(g+1),value=str(funo),where='cat='+str(n+1))
+ grass.run_command('v.db.update',map=point_out,column='F2'+str(g+1),value=str(fdue),where='cat='+str(n+1))
+ g=g+1
+ n=n+1
+# resultPoint=(grass.read_command('db.select',flags='c',table=point_out)).split('\n')[:-2]
+ resultPoint=(grass.read_command('db.select',flags='c',table=point_out)).split('\n')[:-1]
+ resultp=[]
+ for i in resultPoint:
+ elemi=i.split('|')[1]
+ if elemi == '':
+ continue
+ else:
+ resultp.append(i)
+ return resultp,dval
+def results(fiuno,fidue,fauno,fadue,fivalues,dval,lee_lambda,txtout,graphout):
+ """Draws output graphs and a text file report for the point(s) examined"""
+ import pylab
+ fout=open(txtout,'w')
+ fout.write("~~~ Input Data Summary ~~~")
+ fout.write('\n')
+ fout.writelines("Grainsize examined:")
+ fout.write('\n')
+ fout.writelines('phi_1='+str(fiuno))
+ fout.write('\n')
+ fout.writelines('phi_2='+str(fidue))
+ fout.write('\n')
+ fout.writelines("Bedload composition:")
+ fout.write('\n')
+ fout.writelines('Fa_1='+str(fauno))
+ fout.write('\n')
+ fout.writelines('Fa_2='+str(fadue))
+ fout.write('\n')
+ fout.write('\n')
+ fout.writelines("~~~ Prediction Results ~~~")
+ fout.write('\n')
+ neg=[]
+ for i in dval:
+ neg.append(float(i*(-1)))
+ for i in fivalues:
+ f=i.split('|')[4:][::2]
+ fi=[]
+ for j in f:
+ fi.append(float(j))
+ pylab.plot(fi,neg,'o',color='b')
+ pylab.fill_betweenx(neg,fi,facecolor='orange')
+ pylab.axis([0.0,1.0,min(neg),max(neg)])
+ pylab.xlabel('F1, F2 [%]')
+ pylab.ylabel('Relative depth from the bed surface [mm]')
+ pylab.savefig(str(graphout)+'_point'+str(i[0])+'.png')
+ pylab.close()
+ east=float(i.split('|')[2])
+ north=float(i.split('|')[3])
+ cat=int(i.split('|')[1])
+ deltalee=float(lee_lambda[cat-1].split('|')[7])
+ etat=float(lee_lambda[cat-1].split('|')[8])
+ etab=float(lee_lambda[cat-1].split('|')[9])
+ fout.write('\n')
+ fout.writelines("Output for point #"+str(i.split('|')[0])+":")
+ fout.write('\n')
+ fout.writelines("E [mm or m]="+str(east))
+ fout.write('\n')
+ fout.writelines("N [mm or m]="+str(north))
+ fout.write('\n')
+ fout.writelines("Total heigth of the bedform [mm or m]="+str(deltalee))
+ fout.write('\n')
+ fout.writelines("Crest heigth of the bedform over the mean heigth of the reach [mm or m]="+str(etat))
+ fout.write('\n')
+ fout.writelines("Through heigth of the bedform over the mean heigth of the reach [mm or m]="+str(etab))
+ fout.write('\n')
+ fout.writelines("Prediction of vertical sorting of sediment over the bed surface for chosen grainsizes (phi_1,phi_2="+str(fiuno)+","+str(fidue)+"):")
+ fout.write('\n')
+ fout.writelines("(depth [m or mm], F1 [%], F2 [%])")
+ fout.write('\n')
+ f11=i.split('|')[4:][::2]
+ f22=i.split('|')[5:][::2]
+ m=0
+ for i in neg:
+ fout.writelines("("+str(i)+", "+str(float(f11[m]))+", "+str(float(f22[m]))+")")
+ fout.write('\n')
+ m=m+1
+ fout.close()
+#inizia qui lo script:
+def main():
+ m=flags["m"];
+ dem=options["dem"]
+ input_csv=options["input_csv"]
+ type=options["type"]
+ outputDEM=options["outputDEM"]
+ vector=options["vector"]
+ dmax=options["dmax"]
+ nstep=options["nstep"]
+ res=options["res"]
+ lee_out=options["lee_out"]
+ point_out=options["point_out"]
+ fiuno=options["fiuno"]
+ fidue=options["fidue"]
+ ros=options["ros"]
+ to=options["to"]
+ fauno=options["fauno"]
+ fadue=options["fadue"]
+ n_iter=options["n_iter"]
+ txtout=options["txtout"]
+ graphout=options["graphout"]
+ grass.run_command('g.gisenv',set='OVERWRITE=1')
+ if input_csv:
+ import_csv(res,input_csv,type,outputDEM)
+ dem=outputDEM
+ grass.run_command('g.remove',rast='slope',vect='lee_dradd,take_this1,take_this2,one_lee,one_add,preso_ok,preso_punto,presoo,punti_lee,punti_stoss,stoss_dradd,tratti_lee,tratti_leep,tratti_stoss,tratti_stossp,vector_drape,vector_pezzi,vector_pezzi_add,vector_punti,vector_punti_add,vector_punti_del,vector_lee')
+ grass.run_command('g.region',vect=vector,n='n+50',e='e+50',s='s-50',w='w-50')
+ general=general_geom(vector,dem,res)
+ x,z,xline,zline,length,deltatot,rad=general[0],general[1],general[2],general[3],general[4],general[5],general[6]
+ lines=lines_sl(vector,res,dem,'stoss_dradd','lee_dradd')
+ lastcat_endZ,firstcat_endZ=lines[0],lines[1]
+ lee_lambda=populate_lines('lee_dradd','vector_pezzi_add',firstcat_endZ,lastcat_endZ,rad,deltatot,length,'stoss_dradd',lee_out,dem,point_out)
+ point=point_selection('lee_dradd',m,nstep,point_out,dem)
+ id_section,east_section,north_section,z_avg,z_pt=point[0],point[1],point[2],point[3],point[4]
+ graph=graphics(lee_lambda,x,z,xline,zline)
+ k,l,delta_list,etab_list=graph[0],graph[1],graph[2],graph[3]
+ resultNum=numeric(id_section,east_section,north_section,dmax,nstep,z_pt,z_avg,lee_lambda,delta_list,etab_list,rad,fiuno,fidue,fauno,fadue,to,ros,k,l,n_iter,point_out)
+ fivalues,dval=resultNum[0],resultNum[1]
+ results(fiuno,fidue,fauno,fadue,fivalues,dval,lee_lambda,txtout,graphout)
+ grass.run_command('g.remove',vect='lee_dradd,take_this1,take_this2,one_lee,one_add,preso_ok,preso_punto,presoo,point_del,stoss_dradd,tratti_lee_del,tratti_leep,tratti_stoss_del,tratti_stossp,vector_drape,vector_add,vector_del,vector_drape_pezzi,vector_lee,vector_pezzi,vector_pezzi_add,vector_pezzi_del,vector_stoss')
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/vector/v.eqsm/v.eqsm.py
