[GRASS-SVN] r48612 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Mon Oct 3 18:03:10 EDT 2011
Author: huhabla
Date: 2011-10-03 15:03:10 -0700 (Mon, 03 Oct 2011)
New Revision: 48612
grass/trunk/lib/python/temporal/abstract_datasets.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/spatial_extent.py
Fixed wrong end time computation for space time datasets.
Modified: grass/trunk/lib/python/temporal/abstract_datasets.py
--- grass/trunk/lib/python/temporal/abstract_datasets.py 2011-10-03 19:04:10 UTC (rev 48611)
+++ grass/trunk/lib/python/temporal/abstract_datasets.py 2011-10-03 22:03:10 UTC (rev 48612)
@@ -345,9 +345,9 @@
try:
dbif.cursor.execute(sql)
except:
- core.error("Unable to remove space time dataset register table " + self.get_stds_register())
+ core.error(_("Unable to remove space time dataset register table <%s>") % (self.get_stds_register()))
- core.verbose("Delete " + self.get_type() + " dataset <" + self.get_id() + "> from temporal database")
+ core.verbose(_("Delete %s dataset <%s> from temporal database") % (self.get_type(), self.get_id()))
# Delete yourself from the database, trigger functions will take care of dependencies
self.base.delete(dbif)
@@ -361,7 +361,7 @@
""" Remove the map entry in each space time dataset in which this map is registered
- core.verbose("Unregister " + self.get_type() + " dataset <" + self.get_id() + "> from space time datasets")
+ core.verbose(_("Unregister %s dataset <%s> from space time datasets") % (self.get_type(), self.get_id()))
connect = False
@@ -409,7 +409,7 @@
rows = dbif.cursor.fetchall()
except:
- core.error("Unable to select space time dataset register table " + self.get_stds_register())
+ core.error(_("Unable to select space time dataset register table <%s>") % (self.get_stds_register()))
if connect == True:
dbif.close()
@@ -459,7 +459,7 @@
self.set_time_to_relative()
self.relative_time.set_granularity(granularity)
else:
- core.fatal("Unknown temporal type \"" + temporal_type + "\"")
+ core.fatal(_("Unknown temporal type \"%s\"") % (temporal_type))
self.base.set_semantic_type(semantic_type)
self.metadata.set_title(title)
@@ -627,9 +627,9 @@
connect = True
if map.is_in_db(dbif) == False:
- core.fatal("Only maps with absolute or relative valid time can be registered")
+ core.fatal(_("Only maps with absolute or relative valid time can be registered"))
- core.verbose("Register " + map.get_type() + " map: " + map.get_id() + " in space time " + map.get_type() + " dataset <" + self.get_id() + ">")
+ core.verbose(_("Register %s map <%s> in space time %s dataset <%s>") % (map.get_type(), map.get_id(), map.get_type(), self.get_id()))
# First select all data from the database
map.select(dbif)
@@ -648,7 +648,7 @@
#print "STDS register table", stds_register_table
if stds_mapset != map_mapset:
- core.fatal("Only maps from the same mapset can be registered")
+ core.fatal(_("Only maps from the same mapset can be registered"))
# Check if map is already registred
if stds_register_table:
@@ -657,7 +657,7 @@
row = dbif.cursor.fetchone()
# In case of no entry make a new one
if row and row[0] == map_id:
- core.warning("Map " + map_id + "is already registered.")
+ core.warning(_("Map <%s> is already registered.") % (map_id))
return False
# Create tables
@@ -691,15 +691,14 @@
try:
dbif.cursor.executescript(sql_script)
except:
- core.error("Unable to create the space time " + map.get_type() +\
- " dataset register table for " + map.get_type() + " map <" + map.get_id())
+ core.error(_("Unable to create the space time %s dataset register table for <%s>") % (map.get_type(), map.get_id()))
raise
# Set the stds register table name and put it into the DB
map.set_stds_register(map_register_table)
map.metadata.update(dbif)
- core.verbose("Created register table <" + map_register_table + "> for " + map.get_type() + " map <" + map.get_id() + ">")
+ core.verbose(_("Created register table <%s> for %s map <%s>") % (map_register_table, map.get_type(), map.get_id()))
# We need to create the table and register it
if stds_register_table == None:
@@ -731,8 +730,7 @@
try:
except:
- core.error("Unable to create the " + map.get_type() +\
- " map register table for space time " + map.get_type() + " dataset <" + map.get_id())
raise
# Trigger have been disabled due to peformance issues while registration
@@ -755,7 +753,7 @@
self.set_map_register(stds_register_table)
self.metadata.update(dbif)
- core.verbose("Created register table <" + stds_register_table + "> for space time " + map.get_type() + " dataset <" + self.get_id() + ">")
+ core.verbose(_("Created register table <%s> for space time %s dataset <%s>") % (stds_register_table, map.get_type(), self.get_id()))
# Register the stds in the map stds register table
# Check if the entry is already there
@@ -793,9 +791,9 @@
connect = True
- core.fatal("Unable to find map <" + map.get_id() + "> in temporal database")
+ core.fatal(_("Unable to find map <%s> in temporal database") % (map.get_id()))
- core.info("Unregister " + map.get_type() + " map: " + map.get_id())
+ core.verbose(_("Unregister %s map <%s>") % (map.get_type(), map.get_id()))
map.select(dbif)
@@ -812,7 +810,7 @@
# Break if the map is not registered
if row == None:
- core.warning("Map " + map_id + " is not registered in space time dataset " + self.base.get_id())
+ core.warning(_("Map <%s> is not registered in space time dataset") %(map_id, self.base.get_id()))
return False
# Remove the space time raster dataset from the raster dataset register
@@ -833,11 +831,16 @@
type specific metadata. It should always been called after maps are registered
or unregistered/deleted from the space time dataset.
+ The update of the temporal extent checks if the end time is set correctly.
+ In case the registered maps have no valid end time (None) the maximum start time
+ will be used. If the end time is smaller than the maximum start time, it will
+ be replaced by the maximum start time.
An other solution to automate this is to use the diactivated trigger
in the SQL files. But this will result in a huge performance issue
in case many maps are registred (>1000).
- core.info("Update metadata, spatial and temporal extent from all registered maps of <" + self.get_id() + ">")
+ core.verbose(_("Update metadata, spatial and temporal extent from all registered maps of <%s>") % (self.get_id()))
connect = False
@@ -846,6 +849,8 @@
dbif.connect()
connect = True
+ use_start_time = False
# Get basic info
stds_name = self.base.get_name()
stds_mapset = self.base.get_mapset()
@@ -880,5 +885,67 @@
+ # Read and validate the selected end time
+ self.select()
+ if self.is_time_absolute():
+ start_time, end_time, tz = self.get_absolute_time()
+ else:
+ start_time, end_time = self.get_relative_time()
+ # In case no end time is set, use the maximum start time of all registered maps as end time
+ if end_time == None:
+ use_start_time = True
+ else:
+ # Check if the end time is smaller than the maximum start time
+ sql = """SELECT max(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+ (SELECT id FROM SPACETIME_NAME_GRASS_MAP_register);"""
+ sql = sql.replace("GRASS_MAP", self.get_new_map_instance(None).get_type())
+ sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset )
+ else:
+ sql = """SELECT max(start_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+ dbif.cursor.execute(sql)
+ row = dbif.cursor.fetchone()
+ if row != None:
+ tstring = row[0]
+ # Convert the unicode string into the datetime format
+ if tstring.find(":") > 0:
+ time_format = "%Y-%m-%d %H:%M:%S"
+ else:
+ time_format = "%Y-%m-%d"
+ max_start_time = datetime.strptime(tstring, time_format)
+ if end_time < max_start_time:
+ # Set the maximum start time as end time
+ if use_start_time:
+ sql = """UPDATE STDS_absolute_time SET end_time =
+ (SELECT max(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+ ) WHERE id = "SPACETIME_ID";"""
+ sql = sql.replace("SPACETIME_ID", self.base.get_id())
+ sql = sql.replace("STDS", self.get_type())
+ elif self.is_time_relative():
+ sql = """UPDATE STDS_relative_time SET end_time =
+ (SELECT max(start_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+ dbif.cursor.executescript(sql)
if connect == True:
dbif.close()
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2011-10-03 19:04:10 UTC (rev 48611)
+++ grass/trunk/lib/python/temporal/core.py 2011-10-03 22:03:10 UTC (rev 48612)
@@ -97,7 +97,7 @@
elif inc[1].find("years") >= 0:
years = mult * int(inc[0])
else:
- core.fatal("Wrong increment format: " + increment)
+ core.fatal(_("Wrong increment format: %s") % (increment))
return increment_datetime(mydate, years, months, weeks, days, hours, minutes, seconds)
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2011-10-03 19:04:10 UTC (rev 48611)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2011-10-03 22:03:10 UTC (rev 48612)
@@ -565,7 +565,7 @@
if end and increment:
- core.fatal("Valid end time and increment are mutual exclusive")
+ core.fatal(_("Valid end time and increment are mutual exclusive"))
# List of space time datasets to be updated
splist = {}
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2011-10-03 19:04:10 UTC (rev 48611)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2011-10-03 22:03:10 UTC (rev 48612)
@@ -35,7 +35,7 @@
"""Return True if the 2d extents overlap. Code is lend from wind_overlap.c in lib/gis"""
if self.get_projection() != extent.get_projection():
- core.error("Projections are different. Unable to compute overlap_2d for spatial extents")
+ core.error(_("Projections are different. Unable to compute overlap_2d for spatial extents"))
N = extent.get_north()
S = extent.get_south()
@@ -158,7 +158,7 @@
"""Compute the volume of the extent, in case z is zero (top == bottom or top - bottom = 1) the area is returned"""
if self.get_projection() == "LL":
- core.error("Volume computation is not supported for LL projections")
+ core.error(_("Volume computation is not supported for LL projections"))
area = self.get_area()
@@ -175,7 +175,7 @@
"""Compute the area of the extent, extent in z direction is ignored"""
- core.error("Area computation is not supported for LL projections")
+ core.error(_("Area computation is not supported for LL projections"))
bbox = self.get_spatial_extent()
