[GRASS-SVN] r48638 - in grass/trunk: lib/python/temporal
raster/r.series temporal/tr.register temporal/tr.series
svn_grass at osgeo.org
Wed Oct 5 05:57:33 EDT 2011
Author: huhabla
Date: 2011-10-05 02:57:33 -0700 (Wed, 05 Oct 2011)
New Revision: 48638
Added:
grass/trunk/raster/r.series/test.r.series.sh
grass/trunk/raster/r.series/test_1_prec_count.ref
grass/trunk/raster/r.series/test_1_prec_max.ref
grass/trunk/raster/r.series/test_1_prec_mean.ref
grass/trunk/raster/r.series/test_1_prec_min.ref
grass/trunk/raster/r.series/test_1_prec_range.ref
grass/trunk/raster/r.series/test_1_prec_sum.ref
grass/trunk/raster/r.series/test_2_prec_count.ref
grass/trunk/raster/r.series/test_2_prec_max.ref
grass/trunk/raster/r.series/test_2_prec_mean.ref
grass/trunk/raster/r.series/test_2_prec_min.ref
grass/trunk/raster/r.series/test_2_prec_range.ref
grass/trunk/raster/r.series/test_2_prec_sum.ref
grass/trunk/lib/python/temporal/abstract_datasets.py
grass/trunk/raster/r.series/main.c
grass/trunk/raster/r.series/r.series.html
grass/trunk/temporal/tr.register/register_ECAD_maps_temp_mean_1995_2010.py
grass/trunk/temporal/tr.series/test.tr.series.sh
grass/trunk/temporal/tr.series/tr.series.py
Implemented input file with newline separated map names support in r.series. r.series now supports two input methods, file and input. Using option file is slower but avoids the open file descriptor limit. Temporal module tr.series is now ready to analyze ten-thousends of maps using r.series. Implemented tests for r.series and tr.series.
Modified: grass/trunk/lib/python/temporal/abstract_datasets.py
--- grass/trunk/lib/python/temporal/abstract_datasets.py 2011-10-05 09:01:49 UTC (rev 48637)
+++ grass/trunk/lib/python/temporal/abstract_datasets.py 2011-10-05 09:57:33 UTC (rev 48638)
@@ -107,7 +107,9 @@
self.metadata.insert(dbif)
def update(self, dbif=None):
- """Update temporal dataset entry of database from the internal structure"""
+ """Update temporal dataset entry of database from the internal structure
+ excluding None variables
self.base.update(dbif)
if self.is_time_absolute():
self.absolute_time.update(dbif)
@@ -116,6 +118,18 @@
self.spatial_extent.update(dbif)
self.metadata.update(dbif)
+ def update_all(self, dbif=None):
+ and include None varuables.
+ self.base.update_all(dbif)
+ if self.is_time_absolute():
+ self.absolute_time.update_all(dbif)
+ if self.is_time_relative():
+ self.relative_time.update_all(dbif)
+ self.spatial_extent.update_all(dbif)
+ self.metadata.update_all(dbif)
def print_self(self):
"""Print the content of the internal structure to stdout"""
self.base.print_self()
Modified: grass/trunk/raster/r.series/main.c
--- grass/trunk/raster/r.series/main.c 2011-10-05 09:01:49 UTC (rev 48637)
+++ grass/trunk/raster/r.series/main.c 2011-10-05 09:57:33 UTC (rev 48638)
@@ -107,22 +107,25 @@
struct GModule *module;
struct
- struct Option *input, *output, *method, *quantile, *range;
+ struct Option *input, *file, *output, *method, *quantile, *range;
} parm;
struct
struct Flag *nulls;
} flag;
+ FILE *in = NULL;
int i;
int num_inputs;
+ int num_lines;
struct input *inputs;
int num_outputs;
struct output *outputs;
struct History history;
DCELL *values, *values_tmp;
int nrows, ncols;
- int row, col;
+ int row, col, count;
double lo, hi;
+ char buf[GNAME_MAX];
G_gisinit(argv[0]);
@@ -135,7 +138,13 @@
"in the input raster map layers.");
parm.input = G_define_standard_option(G_OPT_R_INPUTS);
+ parm.input->required = NO;
+ parm.file = G_define_standard_option(G_OPT_F_INPUT);
+ parm.file->key = "file";
+ parm.file->description = _("Input file with raster map names, separated by new lines");
+ parm.file->required = NO;
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
parm.output->multiple = YES;
@@ -172,24 +181,94 @@
lo = atof(parm.range->answers[0]);
hi = atof(parm.range->answers[1]);
+ if (parm.input->answer && parm.file->answer)
+ G_fatal_error("The parameter <input> and <file> are mutual exclusive");
+ if (!parm.input->answer && !parm.file->answer)
+ G_fatal_error("You need to specify input or file option");
- /* process the input maps */
- for (i = 0; parm.input->answers[i]; i++)
- num_inputs = i;
- if (num_inputs < 1)
- G_fatal_error(_("Raster map not found"));
+ /* process the input maps from the file */
+ if (parm.file->answer) {
+ /* Open the input file with raster map names and count the lines */
+ in = fopen(parm.file->answer, "r");
+ if(in == NULL)
+ G_fatal_error(_("Unable to open input file <%s>"), parm.file->answer);
+ num_inputs = 0;
+ num_lines = 0;
+ /* Count lines in file and check the input */
+ while (fgets(buf, sizeof buf, in)) {
+ num_lines++;
+ /* Jump over invlaid files and empty new lines */
+ if (strlen(buf) < 2 || G_check_input_output_name(G_chop(buf),
+ parm.output->answer, GR_FATAL_RETURN)) {
+ G_warning(_("Raster map <%s> is not valid"), G_chop(buf));
+ continue;
+ /* Count number of valid input names */
+ num_inputs++;
- inputs = G_malloc(num_inputs * sizeof(struct input));
+ fclose(in);
- for (i = 0; i < num_inputs; i++) {
- struct input *p = &inputs[i];
+ if (num_inputs < 1)
+ G_fatal_error(_("No raster map found in input file"));
- p->name = parm.input->answers[i];
- G_message(_("Reading raster map <%s>..."), p->name);
- p->fd = Rast_open_old(p->name, "");
- p->buf = Rast_allocate_d_buf();
+ inputs = G_malloc(num_inputs * sizeof(struct input));
+ /* Reopen the input file and read the map names */
+ count = 0;
+ for (i = 0; i < num_lines; i++) {
+ fgets(buf, sizeof buf, in);
+ char *name = G_calloc(strlen(buf) + 1, sizeof(char));
+ G_snprintf(name, strlen(buf), "%s", buf);
+ G_free(name);
+ continue;
+ struct input *p = &inputs[count];
+ p->name = G_chop(name);
+ G_message(_("Reading raster map <%s>..."), p->name);
+ p->buf = Rast_allocate_d_buf();
+ count++;
+ if(count != num_inputs)
+ G_fatal_error(_("An internal error occured"));
+ fclose(in);
+ } else {
+ for (i = 0; parm.input->answers[i]; i++)
+ num_inputs = i;
+ G_fatal_error(_("Raster map not found"));
+ for (i = 0; i < num_inputs; i++) {
+ struct input *p = &inputs[i];
+ p->name = parm.input->answers[i];
+ p->fd = Rast_open_old(p->name, "");
/* process the output maps */
@@ -233,8 +312,17 @@
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
- Rast_get_d_row(inputs[i].fd, inputs[i].buf, row);
+ /* Open the files only on run time */
+ inputs[i].fd = Rast_open_old(inputs[i].name, "");
+ Rast_get_d_row(inputs[i].fd, inputs[i].buf, row);
+ Rast_close(inputs[i].fd);
+ } else {
for (col = 0; col < ncols; col++) {
int null = 0;
@@ -270,7 +358,7 @@
- /* close maps */
+ /* close output maps */
for (i = 0; i < num_outputs; i++) {
struct output *out = &outputs[i];
@@ -281,8 +369,11 @@
Rast_write_history(out->name, &history);
- Rast_close(inputs[i].fd);
+ /* Close input maps */
+ if (!parm.file->answer) {
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.series/r.series.html
--- grass/trunk/raster/r.series/r.series.html 2011-10-05 09:01:49 UTC (rev 48637)
+++ grass/trunk/raster/r.series/r.series.html 2011-10-05 09:57:33 UTC (rev 48638)
@@ -69,6 +69,15 @@
This would raise the hard limit to 1500 file. Be warned that more
files open need more RAM.
+<p>
+Use the <em>file</em> option to analyze large amount of raster maps without
+hitting open files limit and the size limit of command line arguments.
+The computation is slower than the <em>input</em> option method.
+For every sinlge row in the output map(s)
+all input maps are opened and closed. The amount of RAM will rise linear
+with the number of specified input maps. The input and file options are mutual exclusive.
+Input is a text file with a new line separatetd list of raster map names.
<h2>EXAMPLES</h2>
Using <em>r.series</em> with wildcards:
@@ -95,6 +104,18 @@
r.series in=one,two out=result_avg,res_slope,result_count meth=sum,slope,count
</pre></div>
+<p>
+Example to use the file option of r.series:
+<div class="code"><pre>
+cat > input.txt << EOF
+map1
+map2
+map3
+EOF
+r.series2 file=input.txt out=result_sum meth=sum
+</pre></div>
<h2>SEE ALSO</h2>
<em><a href="g.mlist.html">g.mlist</a></em>,
@@ -104,4 +125,4 @@
Glynn Clements
-<p><i>Last changed: $Date$</i>
+<p><i>Last changed: $Date$</i>
\ No newline at end of file
Added: grass/trunk/raster/r.series/test.r.series.sh
--- grass/trunk/raster/r.series/test.r.series.sh (rev 0)
+++ grass/trunk/raster/r.series/test.r.series.sh 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,61 @@
+# Test r.series basic aggregation functions with map and file inputs
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = 100"
+r.mapcalc --o expr="prec_2 = 200"
+r.mapcalc --o expr="prec_3 = 300"
+r.mapcalc --o expr="prec_4 = 400"
+r.mapcalc --o expr="prec_5 = 500"
+r.mapcalc --o expr="prec_6 = 600"
+TMP_FILE=`g.tempfile pid=1`
+# We create an input file containing errors. However, r.series should process the
+# valid raster maps listed in this file.
+cat > $TMP_FILE << EOF
+prec_1
+prec_2
+prec_3
+invalid_name
+prec_4
+prec_5
+prec_6
+EOF
+# The first @test with map input and @precision=3
+r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_mean method=average
+r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_max method=maximum
+r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_min method=minimum
+r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_count method=count
+r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_range method=range
+r.series --o input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_sum method=sum
+#r.out.ascii --o input=test_1_prec_mean output=test_1_prec_mean.ref dp=3
+#r.out.ascii --o input=test_1_prec_max output=test_1_prec_max.ref dp=3
+#r.out.ascii --o input=test_1_prec_min output=test_1_prec_min.ref dp=3
+#r.out.ascii --o input=test_1_prec_count output=test_1_prec_count.ref dp=3
+#r.out.ascii --o input=test_1_prec_range output=test_1_prec_range.ref dp=3
+#r.out.ascii --o input=test_1_prec_sum output=test_1_prec_sum.ref dp=3
+# The second @test with file input and @precision=3
+r.series --o file=$TMP_FILE output=test_2_prec_mean method=average
+r.series --o file=$TMP_FILE output=test_2_prec_max method=maximum
+r.series --o file=$TMP_FILE output=test_2_prec_min method=minimum
+r.series --o file=$TMP_FILE output=test_2_prec_count method=count
+r.series --o file=$TMP_FILE output=test_2_prec_range method=range
+r.series --o file=$TMP_FILE output=test_2_prec_sum method=sum
+#r.out.ascii --o input=test_2_prec_mean output=test_2_prec_mean.ref dp=3
+#r.out.ascii --o input=test_2_prec_max output=test_2_prec_max.ref dp=3
+#r.out.ascii --o input=test_2_prec_min output=test_2_prec_min.ref dp=3
+#r.out.ascii --o input=test_2_prec_count output=test_2_prec_count.ref dp=3
+#r.out.ascii --o input=test_2_prec_range output=test_2_prec_range.ref dp=3
+#r.out.ascii --o input=test_2_prec_sum output=test_2_prec_sum.ref dp=3
Added: grass/trunk/raster/r.series/test_1_prec_count.ref
--- grass/trunk/raster/r.series/test_1_prec_count.ref (rev 0)
+++ grass/trunk/raster/r.series/test_1_prec_count.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+6 6 6 6 6 6 6 6 6 6 6 6
Added: grass/trunk/raster/r.series/test_1_prec_max.ref
--- grass/trunk/raster/r.series/test_1_prec_max.ref (rev 0)
+++ grass/trunk/raster/r.series/test_1_prec_max.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+600 600 600 600 600 600 600 600 600 600 600 600
Added: grass/trunk/raster/r.series/test_1_prec_mean.ref
--- grass/trunk/raster/r.series/test_1_prec_mean.ref (rev 0)
+++ grass/trunk/raster/r.series/test_1_prec_mean.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+350 350 350 350 350 350 350 350 350 350 350 350
Added: grass/trunk/raster/r.series/test_1_prec_min.ref
--- grass/trunk/raster/r.series/test_1_prec_min.ref (rev 0)
+++ grass/trunk/raster/r.series/test_1_prec_min.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+100 100 100 100 100 100 100 100 100 100 100 100
Added: grass/trunk/raster/r.series/test_1_prec_range.ref
--- grass/trunk/raster/r.series/test_1_prec_range.ref (rev 0)
+++ grass/trunk/raster/r.series/test_1_prec_range.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+500 500 500 500 500 500 500 500 500 500 500 500
Added: grass/trunk/raster/r.series/test_1_prec_sum.ref
--- grass/trunk/raster/r.series/test_1_prec_sum.ref (rev 0)
+++ grass/trunk/raster/r.series/test_1_prec_sum.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+2100 2100 2100 2100 2100 2100 2100 2100 2100 2100 2100 2100
Added: grass/trunk/raster/r.series/test_2_prec_count.ref
--- grass/trunk/raster/r.series/test_2_prec_count.ref (rev 0)
+++ grass/trunk/raster/r.series/test_2_prec_count.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Added: grass/trunk/raster/r.series/test_2_prec_max.ref
--- grass/trunk/raster/r.series/test_2_prec_max.ref (rev 0)
+++ grass/trunk/raster/r.series/test_2_prec_max.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Added: grass/trunk/raster/r.series/test_2_prec_mean.ref
--- grass/trunk/raster/r.series/test_2_prec_mean.ref (rev 0)
+++ grass/trunk/raster/r.series/test_2_prec_mean.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Added: grass/trunk/raster/r.series/test_2_prec_min.ref
--- grass/trunk/raster/r.series/test_2_prec_min.ref (rev 0)
+++ grass/trunk/raster/r.series/test_2_prec_min.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Added: grass/trunk/raster/r.series/test_2_prec_range.ref
--- grass/trunk/raster/r.series/test_2_prec_range.ref (rev 0)
+++ grass/trunk/raster/r.series/test_2_prec_range.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Added: grass/trunk/raster/r.series/test_2_prec_sum.ref
--- grass/trunk/raster/r.series/test_2_prec_sum.ref (rev 0)
+++ grass/trunk/raster/r.series/test_2_prec_sum.ref 2011-10-05 09:57:33 UTC (rev 48638)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Modified: grass/trunk/temporal/tr.register/register_ECAD_maps_temp_mean_1995_2010.py
--- grass/trunk/temporal/tr.register/register_ECAD_maps_temp_mean_1995_2010.py 2011-10-05 09:01:49 UTC (rev 48637)
+++ grass/trunk/temporal/tr.register/register_ECAD_maps_temp_mean_1995_2010.py 2011-10-05 09:57:33 UTC (rev 48638)
@@ -11,7 +11,7 @@
name = "temp_mean."
maps=""
#for i in range(6025):
-for i in range(365):
+for i in range(5844):
inc = i + 1
map_name = name + str(inc)
if i == 0:
@@ -20,4 +20,4 @@
maps += "," + map_name
# Register all maps at once
-grass.run_command("tr.register", dataset=dataset, maps=maps, start="1995-01-01", increment="1 days")
+grass.run_command("tr.register", flags="i", dataset=dataset, maps=maps, start="1995-01-01", increment="1 days")
Modified: grass/trunk/temporal/tr.series/test.tr.series.sh
--- grass/trunk/temporal/tr.series/test.tr.series.sh 2011-10-05 09:01:49 UTC (rev 48637)
+++ grass/trunk/temporal/tr.series/test.tr.series.sh 2011-10-05 09:57:33 UTC (rev 48638)
@@ -10,12 +10,12 @@
-r.mapcalc --o expr="prec_1 = rand(0, 550)"
-r.mapcalc --o expr="prec_2 = rand(0, 450)"
-r.mapcalc --o expr="prec_3 = rand(0, 320)"
-r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
-r.mapcalc --o expr="prec_6 = rand(0, 650)"
# The first @test
# We create the space time raster datasets and register the raster maps with absolute time interval
@@ -25,13 +25,12 @@
tr.register --v dataset=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
tr.series --o input=precip_abs method=average output=prec_average where='start_time > "2001-03-01"'
-tr.series --o input=precip_abs method=maximum output=prec_max sort=north
-tr.series --o input=precip_abs method=sum output=prec_sum
-#tr.series --o input=precip_abs method=quantile output=prec_quant quantile=0.9
+tr.series --o -t input=precip_abs method=maximum output=prec_max sort=start_time
+tr.series --o -t input=precip_abs method=sum output=prec_sum
t.remove --v type=raster dataset=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.remove --v type=strds dataset=precip_abs
r.info prec_average
-r.info prec_max
-r.info prec_sum
+t.info type=raster dataset=prec_max
+t.info type=raster dataset=prec_sum
Modified: grass/trunk/temporal/tr.series/tr.series.py
--- grass/trunk/temporal/tr.series/tr.series.py 2011-10-05 09:01:49 UTC (rev 48637)
+++ grass/trunk/temporal/tr.series/tr.series.py 2011-10-05 09:57:33 UTC (rev 48638)
@@ -55,6 +55,11 @@
#%option G_OPT_R_OUTPUT
#%end
+#%flag
+#% key: t
+#% description: Assign the space time raster dataset time interval to the output map
+#%end
import grass.script as grass
import grass.temporal as tgis
@@ -68,6 +73,7 @@
method = options["method"]
sort = options["sort"]
where = options["where"]
+ add_time = flags["t"]
# Make sure the temporal database exists
tgis.create_temporal_database()
@@ -84,28 +90,52 @@
grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
sp.select()
+ if add_time:
+ if sp.is_time_absolute():
+ start_time, end_time, tz = sp.get_absolute_time()
+ else:
+ start_time, end_time = sp.get_relative_time()
rows = sp.get_registered_maps(None, where, sort)
if rows:
- inputs = ""
+ filename = grass.tempfile(True)
+ file = open(filename, 'w')
- count = 0
for row in rows:
- if count == 0:
- inputs += row["id"]
- else:
- inputs += "," + row["id"]
- count += 1
+ string = "%s\n" % (row["id"])
+ file.write(string)
+ file.close()
- print inputs
if grass.overwrite() == True:
- grass.run_command("r.series", input=inputs, output=output, overwrite=True, method=method)
+ grass.run_command("r.series", file=filename, output=output, overwrite=True, method=method)
else:
- grass.run_command("r.series", input=inputs, output=output, overwrite=False, method=method)
+ grass.run_command("r.series", file=filename, output=output, overwrite=False, method=method)
+ if add_time:
+ # Create the time range for the output map
+ if output.find("@") >= 0:
+ id = output
+ else:
+ mapset = grass.gisenv()["MAPSET"]
+ id = output + "@" + mapset
+ map = sp.get_new_map_instance(id)
+ map.load()
+ map.set_absolute_time(start_time, end_time, tz)
+ else:
+ map.set_relative_time(start_time, end_time)
+ # Register the map in the temporal database
+ if map.is_in_db():
+ map.update()
+ else:
+ map.insert()
if __name__ == "__main__":
options, flags = grass.parser()
main()
