[GRASS-SVN] r48645 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Oct 5 13:15:41 EDT 2011
Author: cmbarton
Date: 2011-10-05 10:15:41 -0700 (Wed, 05 Oct 2011)
New Revision: 48645
grass/trunk/gui/wxpython/gui_modules/wxplot_dialogs.py
wxgui: updated wxplot_dialog for scatterplot tool
Modified: grass/trunk/gui/wxpython/gui_modules/wxplot_dialogs.py
--- grass/trunk/gui/wxpython/gui_modules/wxplot_dialogs.py 2011-10-05 17:14:37 UTC (rev 48644)
+++ grass/trunk/gui/wxpython/gui_modules/wxplot_dialogs.py 2011-10-05 17:15:41 UTC (rev 48645)
@@ -20,6 +20,7 @@
import os
import sys
+from types import *
import wx
import wx.lib.colourselect as csel
@@ -33,7 +34,7 @@
class ProfileRasterDialog(wx.Dialog):
def __init__(self, parent, id = wx.ID_ANY,
- title = _("Select raster map or imagery group to histogram"),
+ title = _("Select raster maps to profile"),
style = wx.DEFAULT_DIALOG_STYLE, **kwargs):
"""!Dialog to select raster maps to profile.
@@ -106,6 +107,119 @@
for idx in range(0,n):
self.rasterList.append(rList[idx])
+class ScatterRasterDialog(wx.Dialog):
+ def __init__(self, parent, id = wx.ID_ANY,
+ title = _("Select pairs of raster maps for scatterplots"),
+ style = wx.DEFAULT_DIALOG_STYLE, **kwargs):
+ """!Dialog to select raster maps to profile.
+ wx.Dialog.__init__(self, parent, id, title, style = style, **kwargs)
+ self.parent = parent
+ self.rasterList = self.parent.rasterList
+ self.bins = self.parent.bins
+ self.scattertype = self.parent.scattertype
+ self.maptype = self.parent.maptype
+ self.spinbins = ''
+ self.colorList = ["blue", "red", "green", "yellow", "magenta", "cyan", \
+ "aqua", "black", "grey", "orange", "brown", "purple", "violet", \
+ "indigo"]
+ self._do_layout()
+ def _do_layout(self):
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ box = wx.GridBagSizer (hgap = 3, vgap = 3)
+ # parse raster pair tuples
+ rastText = ''
+ if len(self.rasterList) > 0:
+ for r in self.rasterList:
+ rastText += '%s,%s,' % r
+ rastText = rastText.rstrip(',')
+ # select rasters
+ txt = _("Select pairs of raster maps for bivariate scatterplots:")
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = txt)
+ box.Add(item = label,
+ flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
+ selection = Select(self, id = wx.ID_ANY,
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ type = 'cell', multiple=True)
+ selection.SetValue(rastText)
+ selection.Bind(wx.EVT_TEXT, self.OnSelection)
+ box.Add(item = selection, pos = (0, 1))
+ # Nsteps for FP maps
+ label = _("Number of bins (for FP maps)"))
+ flag = wx.ALIGN_CENTER_VERTICAL, pos = (1, 0))
+ self.spinbins = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "", pos = (30, 50),
+ size = (100,-1), style = wx.SP_ARROW_KEYS)
+ self.spinbins.SetRange(1,1000)
+ self.spinbins.SetValue(self.bins)
+ box.Add(item = self.spinbins,
+ flag = wx.ALIGN_CENTER_VERTICAL, pos = (1, 1))
+#### TODO possibly make bubble plots with marker size proportional to cell counts
+# # scatterplot type
+# label = wx.StaticText(parent = self, id = wx.ID_ANY,
+# label = _("Scatterplot type"))
+# box.Add(item = label,
+# flag = wx.ALIGN_CENTER_VERTICAL, pos = (2, 0))
+# types = ['normal', 'bubble']
+# scattertype = wx.ComboBox(parent = self, id = wx.ID_ANY, size = (250, -1),
+# choices = types, style = wx.CB_DROPDOWN)
+# scattertype.SetStringSelection(self.scattertype)
+# box.Add(item = scattertype,
+# flag = wx.ALIGN_CENTER_VERTICAL, pos = (2, 1))
+ sizer.Add(item = box, proportion = 0,
+ flag = wx.ALL, border = 10)
+ line = wx.StaticLine(parent = self, id = wx.ID_ANY, size = (20, -1), style = wx.LI_HORIZONTAL)
+ sizer.Add(item = line, proportion = 0,
+ flag = wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border = 5)
+ btnsizer = wx.StdDialogButtonSizer()
+ btn = wx.Button(self, wx.ID_OK)
+ btn.SetDefault()
+ btnsizer.AddButton(btn)
+ btn = wx.Button(self, wx.ID_CANCEL)
+ btnsizer.Realize()
+ sizer.Add(item = btnsizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ self.spinbins.Bind(wx.EVT_TEXT, self.OnSetBins)
+ self.spinbins.Bind(wx.EVT_SPINCTRL, self.OnSetBins)
+# scattertype.Bind(wx.EVT_TEXT, self.OnSetScattertypes)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ def OnSelection(self, event):
+ """!Select raster maps for scatterplot. Must select maps in pairs.
+ self.rasterList = []
+ self.rasterList = event.GetString().split(',')
+ def OnSetBins(self, event):
+ """!Bins for histogramming FP maps (=nsteps in r.stats)
+ self.bins = self.spinbins.GetValue()
+ def OnSetScattertypes(self, event):
+ self.scattertype = event.GetString()
class HistRasterDialog(wx.Dialog):
@@ -538,7 +652,7 @@
# init variables
- self.pstyledict = parent.pstyledict
+ self.linestyledict = parent.linestyledict
self.ptfilldict = parent.ptfilldict
self.plottype = plottype
@@ -571,6 +685,17 @@
caption = _("Warning"), style = wx.OK | wx.ICON_ERROR)
self._do_layout()
+ def ConvertTuples(self, tlist):
+ """!Converts tuples to strings when rasterList contains raster pairs
+ for scatterplot
+ list = []
+ for i in tlist:
+ i = str(i).strip('()')
+ list.append(i)
+ return list
"""!Do layout"""
@@ -584,73 +709,86 @@
self.wxId['pcolor'] = 0
self.wxId['pwidth'] = 0
self.wxId['pstyle'] = 0
+ self.wxId['psize'] = 0
+ self.wxId['ptype'] = 0
+ self.wxId['pfill'] = 0
self.wxId['plegend'] = 0
self.wxId['marker'] = {}
self.wxId['x-axis'] = {}
self.wxId['y-axis'] = {}
+ # plot line settings and point settings
+ if len(self.rasterList) == 0: return
+ box = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label = _("Map/image plotted"))
+ boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
+ row = 0
+ choicelist = []
+ for i in self.rasterList:
+ choicelist.append(str(i))
+ self.mapchoice = wx.Choice(parent = self, id = wx.ID_ANY, size = (300, -1),
+ choices = choicelist)
+ if not self.map:
+ self.map = self.rasterList[self.mapchoice.GetCurrentSelection()]
+ else:
+ self.mapchoice.SetStringSelection(str(self.map))
+ gridSizer.Add(item = self.mapchoice, flag = wx.ALIGN_CENTER_VERTICAL,
+ pos = (row, 0), span = (1, 2))
- # plot line settings
+ # options for line plots (profiles and histograms)
- if len(self.rasterList) > 0:
- box = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label = _("Map/image plotted"))
- boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
- row = 0
- self.mapchoice = wx.Choice(parent = self, id = wx.ID_ANY, size = (300, -1),
- choices = self.rasterList)
- if not self.map:
- self.map = self.rasterList[self.mapchoice.GetCurrentSelection()]
- else:
- self.mapchoice.SetStringSelection(self.map)
- gridSizer.Add(item = self.mapchoice, flag = wx.ALIGN_CENTER_VERTICAL,
- pos = (row, 0), span = (1, 2))
+ if self.plottype != 'scatter':
row +=1
label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Line color"))
gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
- pcolor = csel.ColourSelect(parent = self, id = wx.ID_ANY, colour = self.raster[self.map]['pcolor'])
- self.wxId['pcolor'] = pcolor.GetId()
- gridSizer.Add(item = pcolor, pos = (row, 1))
+ color = csel.ColourSelect(parent = self, id = wx.ID_ANY, colour = self.raster[self.map]['pcolor'])
+ self.wxId['pcolor'] = color.GetId()
+ gridSizer.Add(item = color, pos = (row, 1))
row += 1
label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Line width"))
- pwidth = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "",
+ width = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "",
size = (50,-1), style = wx.SP_ARROW_KEYS)
- pwidth.SetRange(1, 10)
- pwidth.SetValue(self.raster[self.map]['pwidth'])
- self.wxId['pwidth'] = pwidth.GetId()
- gridSizer.Add(item = pwidth, pos = (row, 1))
+ width.SetRange(1, 10)
+ width.SetValue(self.raster[self.map]['pwidth'])
+ self.wxId['pwidth'] = width.GetId()
+ gridSizer.Add(item = width, pos = (row, 1))
row +=1
label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Line style"))
- pstyle = wx.Choice(parent = self, id = wx.ID_ANY,
- size = (120, -1), choices = self.pstyledict.keys(), style = wx.CB_DROPDOWN)
- pstyle.SetStringSelection(self.raster[self.map]['pstyle'])
- self.wxId['pstyle'] = pstyle.GetId()
- gridSizer.Add(item = pstyle, pos = (row, 1))
+ style = wx.Choice(parent = self, id = wx.ID_ANY,
+ size = (120, -1), choices = self.linestyledict.keys(), style = wx.CB_DROPDOWN)
+ style.SetStringSelection(self.raster[self.map]['pstyle'])
+ self.wxId['pstyle'] = style.GetId()
+ gridSizer.Add(item = style, pos = (row, 1))
- row += 1
- label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Legend"))
- gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
- plegend = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (200,-1))
- plegend.SetValue(self.raster[self.map]['plegend'])
- gridSizer.Add(item = plegend, pos = (row, 1))
- self.wxId['plegend'] = plegend.GetId()
- boxSizer.Add(item = gridSizer)
- boxMainSizer.Add(item = boxSizer, flag = wx.ALL, border = 3)
+ row += 1
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Legend"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
+ legend = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (200,-1))
+ legend.SetValue(self.raster[self.map]['plegend'])
+ gridSizer.Add(item = legend, pos = (row, 1))
+ self.wxId['plegend'] = legend.GetId()
+ boxSizer.Add(item = gridSizer)
+ boxMainSizer.Add(item = boxSizer, flag = wx.ALL, border = 3)
- # segment marker settings
+ # segment marker settings for profiles only
- if self.plottype != 'histogram':
+ if self.plottype == 'profile':
label = " %s " % _("Transect segment marker settings"))
@@ -698,10 +836,61 @@
+ # point options for scatterplots
+ elif self.plottype == 'scatter':
+ label = " %s " % _("Scatterplot points"))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Color"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
+ ptcolor = csel.ColourSelect(parent = self, id = wx.ID_ANY, colour = self.raster[self.map]['pcolor'])
+ self.wxId['pcolor'] = ptcolor.GetId()
+ gridSizer.Add(item = ptcolor, pos = (0, 1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Size"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (1, 0))
+ ptsize = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "",
+ size = (50, -1), style = wx.SP_ARROW_KEYS)
+ ptsize.SetRange(1, 10)
+ ptsize.SetValue(self.raster[self.map]['psize'])
+ self.wxId['psize'] = ptsize.GetId()
+ gridSizer.Add(item = ptsize, pos = (1, 1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Style"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (2, 0))
+ ptfill = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ size = (120, -1), choices = self.ptfilldict.keys(), style = wx.CB_DROPDOWN)
+ ptfill.SetStringSelection(self.raster[self.map]['pfill'])
+ self.wxId['pfill'] = ptfill.GetId()
+ gridSizer.Add(item = ptfill, pos = (2, 1))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (3, 0))
+ ptlegend = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (200,-1))
+ ptlegend.SetValue(self.raster[self.map]['plegend'])
+ self.wxId['plegend'] = ptlegend.GetId()
+ gridSizer.Add(item = ptlegend, pos = (3, 1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Type"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (4, 0))
+ pttype = wx.ComboBox(parent = self,
+ size = (200, -1), choices = self.pttypelist, style = wx.CB_DROPDOWN)
+ pttype.SetStringSelection(self.raster[self.map]['ptype'])
+ self.wxId['ptype'] = pttype.GetId()
+ gridSizer.Add(item = pttype, pos = (4, 1))
sizer.Add(item = boxMainSizer, flag = wx.ALL | wx.EXPAND, border = 3)
- # axis options
+ # axis options for all plots
label = " %s " % _("Axis settings"))
@@ -763,7 +952,7 @@
middleSizer.Add(item = boxMainSizer, flag = wx.ALL | wx.EXPAND, border = 3)
- # grid & legend options
+ # grid & legend options for all plots
self.wxId['grid'] = {}
self.wxId['legend'] = {}
@@ -842,10 +1031,20 @@
# bindings for buttons and map plot settings controls
self.mapchoice.Bind(wx.EVT_CHOICE, self.OnSetMap)
- pcolor.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
- pwidth.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
- pstyle.Bind(wx.EVT_CHOICE, self.OnSetOpt)
- plegend.Bind(wx.EVT_TEXT, self.OnSetOpt)
+ color.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
+ width.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
+ style.Bind(wx.EVT_CHOICE, self.OnSetOpt)
+ legend.Bind(wx.EVT_TEXT, self.OnSetOpt)
+ if self.plottype != 'histogram':
+ ptcolor.Bind(csel.EVT_COLOURSELECT, self.OnSetOpt)
+ ptsize.Bind(wx.EVT_SPINCTRL, self.OnSetOpt)
+ ptfill.Bind(wx.EVT_CHOICE, self.OnSetOpt)
+ ptlegend.Bind(wx.EVT_TEXT, self.OnSetOpt)
+ pttype.Bind(wx.EVT_CHOICE, self.OnSetOpt)
btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
@@ -855,13 +1054,24 @@
def OnSetMap(self, event):
"""!Handler for changing map selection"""
- self.map = event.GetString()
+ idx = event.GetSelection()
+ self.map = self.rasterList[idx]
- # update plot settings controls for selected map
+ # update settings controls for all plots
self.FindWindowById(self.wxId['pcolor']).SetColour(self.raster[self.map]['pcolor'])
- self.FindWindowById(self.wxId['pwidth']).SetValue(self.raster[self.map]['pwidth'])
- self.FindWindowById(self.wxId['pstyle']).SetStringSelection(self.raster[self.map]['pstyle'])
self.FindWindowById(self.wxId['plegend']).SetValue(self.raster[self.map]['plegend'])
+ # update settings controls for histograms and profiles
+ self.FindWindowById(self.wxId['pwidth']).SetValue(self.raster[self.map]['pwidth'])
+ self.FindWindowById(self.wxId['pstyle']).SetStringSelection(self.raster[self.map]['pstyle'])
+ # update settings controls for scatterplots
+ self.FindWindowById(self.wxId['psize']).SetValue(self.raster[self.map]['psize'])
+ self.FindWindowById(self.wxId['ptype']).SetStringSelection(self.raster[self.map]['ptype'])
+ self.FindWindowById(self.wxId['pfill']).SetStringSelection(self.raster[self.map]['pfill'])
self.Refresh()
def OnSetOpt(self, event):
@@ -870,7 +1080,7 @@
self.UpdateSettings()
self.parent.SetGraphStyle()
if self.parent.plot:
- p = self.parent.CreatPlotList()
+ p = self.parent.CreatePlotList()
self.parent.DrawPlot(p)
def UpdateSettings(self):
@@ -878,9 +1088,16 @@
# update plot settings for selected map
self.raster[self.map]['pcolor'] = self.FindWindowById(self.wxId['pcolor']).GetColour()
- self.raster[self.map]['pwidth'] = int(self.FindWindowById(self.wxId['pwidth']).GetValue())
- self.raster[self.map]['pstyle'] = self.FindWindowById(self.wxId['pstyle']).GetStringSelection()
self.raster[self.map]['plegend'] = self.FindWindowById(self.wxId['plegend']).GetValue()
+ self.raster[self.map]['pwidth'] = int(self.FindWindowById(self.wxId['pwidth']).GetValue())
+ self.raster[self.map]['pstyle'] = self.FindWindowById(self.wxId['pstyle']).GetStringSelection()
+ self.raster[self.map]['psize'] = self.FindWindowById(self.wxId['psize']).GetValue()
+ self.raster[self.map]['ptype'] = self.FindWindowById(self.wxId['ptype']).GetValue()
+ self.raster[self.map]['pfill'] = self.FindWindowById(self.wxId['pfill']).GetValue()
# update settings for entire plot
for axis in ('x-axis', 'y-axis'):
@@ -889,7 +1106,7 @@
self.properties[axis]['prop']['max'] = float(self.FindWindowById(self.wxId[axis]['max']).GetValue())
self.properties[axis]['prop']['log'] = self.FindWindowById(self.wxId[axis]['log']).IsChecked()
self.properties['marker']['color'] = self.FindWindowById(self.wxId['marker']['color']).GetColour()
self.properties['marker']['fill'] = self.FindWindowById(self.wxId['marker']['fill']).GetStringSelection()
self.properties['marker']['size'] = self.FindWindowById(self.wxId['marker']['size']).GetValue()
