[GRASS-SVN] r48658 - in grass/trunk/gui/wxpython: . gui_modules
Thu Oct 6 06:57:43 EDT 2011
Author: martinl
Date: 2011-10-06 03:57:43 -0700 (Thu, 06 Oct 2011)
New Revision: 48658
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/gui_modules/gmodeler.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI/modeler: implement series
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-10-06 07:16:37 UTC (rev 48657)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-10-06 10:57:43 UTC (rev 48658)
@@ -11,7 +11,7 @@
  - SavedRegion
  - DecorationDialog
  - TextLayerDialog
- - AddMapLayersDialog
+ - MapLayersDialog
  - ImportDialog
  - GdalImportDialog
  - GdalOutputDialog
@@ -903,32 +903,28 @@
                  'coords' : self.currCoords,
                  'active' : self.chkbox.IsChecked() }
-class AddMapLayersDialog(wx.Dialog):
-    """!Add selected map layers (raster, vector) into layer tree"""
-    def __init__(self, parent, title, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
-        wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title, style = style)
-        self.parent = parent # GMFrame
+class MapLayersDialog(wx.Dialog):
+    def __init__(self, parent, title,
+                 style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
+        """!Dialog for selecting map layers (raster, vector)"""
+        wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title,
+                           style = style, **kwargs)
+        self.parent = parent # GMFrame or ?
         # dialog body
-        self.bodySizer = self.__createDialogBody()
+        self.bodySizer = self._createDialogBody()
         # update list of layer to be loaded
         self.map_layers = [] # list of map layers (full list type/mapset)
         self.LoadMapLayers(self.layerType.GetStringSelection()[:4],
                            self.mapset.GetStringSelection())
         # buttons
         btnCancel = wx.Button(parent = self, id = wx.ID_CANCEL)
-        btnOk = wx.Button(parent = self, id = wx.ID_OK, label = _("&Add"))
+        btnOk = wx.Button(parent = self, id = wx.ID_OK)
         btnOk.SetDefault()
-        btnOk.SetToolTipString(_("Add selected map layers to current display"))
         # sizers & do layout
         btnSizer = wx.StdDialogButtonSizer()
         btnSizer.AddButton(btnCancel)
         btnSizer.AddButton(btnOk)
@@ -946,7 +942,7 @@
         # set dialog min size
         self.SetMinSize(self.GetSize())
-    def __createDialogBody(self):
+    def _createDialogBody(self):
         bodySizer = wx.GridBagSizer(vgap = 3, hgap = 3)
         bodySizer.AddGrowableCol(1)
         bodySizer.AddGrowableRow(3)
@@ -955,13 +951,13 @@
         bodySizer.Add(item = wx.StaticText(parent = self, label = _("Map layer type:")),
                       flag = wx.ALIGN_CENTER_VERTICAL,
                       pos = (0,0))
         self.layerType = wx.Choice(parent = self, id = wx.ID_ANY,
                                    choices = ['raster', 'vector'], size = (100,-1))
         self.layerType.SetSelection(0)
         bodySizer.Add(item = self.layerType,
                       pos = (0,1))
         # select toggle
         self.toggle = wx.CheckBox(parent = self, id = wx.ID_ANY,
                                   label = _("Select toggle"))
@@ -974,24 +970,24 @@
         bodySizer.Add(item = wx.StaticText(parent = self, label = _("Mapset:")),
                       pos = (1,0))
         self.mapset = gselect.MapsetSelect(parent = self)
         self.mapset.SetStringSelection(grass.gisenv()['MAPSET'])
         bodySizer.Add(item = self.mapset,
                       pos = (1,1), span = (1, 2))
         # map name filter
         bodySizer.Add(item = wx.StaticText(parent = self, label = _("Filter:")),
                       pos = (2,0))
         self.filter = wx.TextCtrl(parent = self, id = wx.ID_ANY,
                                   value = "",
                                   size = (250,-1))
         bodySizer.Add(item = self.filter,
                       flag = wx.EXPAND,
                       pos = (2,1), span = (1, 2))
         # layer list
         bodySizer.Add(item = wx.StaticText(parent = self, label = _("List of maps:")),
                       flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_TOP,
@@ -1002,7 +998,7 @@
         bodySizer.Add(item = self.layers,
                       flag = wx.EXPAND,
                       pos = (3,1), span = (1, 2))
         # bindings
         self.layerType.Bind(wx.EVT_CHOICE, self.OnChangeParams)
         self.mapset.Bind(wx.EVT_COMBOBOX, self.OnChangeParams)
@@ -1023,15 +1019,15 @@
         # check all items by default
         for item in range(self.layers.GetCount()):
             self.layers.Check(item)
     def OnChangeParams(self, event):
         """!Filter parameters changed by user"""
         event.Skip()
     def OnMenu(self, event):
         """!Table description area, context menu"""
         if not hasattr(self, "popupID1"):
@@ -1042,21 +1038,21 @@
             self.Bind(wx.EVT_MENU, self.OnSelectAll,    id = self.popupDataID1)
             self.Bind(wx.EVT_MENU, self.OnSelectInvert, id = self.popupDataID2)
             self.Bind(wx.EVT_MENU, self.OnDeselectAll,  id = self.popupDataID3)
         # generate popup-menu
         menu = wx.Menu()
         menu.Append(self.popupDataID1, _("Select all"))
         menu.Append(self.popupDataID2, _("Invert selection"))
         menu.Append(self.popupDataID3, _("Deselect all"))
         self.PopupMenu(menu)
         menu.Destroy()
     def OnSelectAll(self, event):
         """!Select all map layer from list"""
             self.layers.Check(item, True)
     def OnSelectInvert(self, event):
         """!Invert current selection"""
@@ -1069,13 +1065,13 @@
             self.layers.Check(item, False)
     def OnFilter(self, event):
         """!Apply filter for map names"""
         if len(event.GetString()) == 0:
            self.layers.Set(self.map_layers)
            return
         list = []
         for layer in self.map_layers:
             try:
@@ -1083,18 +1079,18 @@
                     list.append(layer)
             except:
                 pass
         self.layers.Set(list)
         self.OnSelectAll(None)
         event.Skip()
     def OnToggle(self, event):
         """!Select toggle (check or uncheck all layers)"""
         check = event.Checked()
             self.layers.Check(item, check)
         event.Skip()
     def GetMapLayers(self):
@@ -1103,14 +1099,14 @@
         for indx in self.layers.GetSelections():
             # layers.append(self.layers.GetStringSelec(indx))
             pass
         # return fully qualified map names
         mapset = self.mapset.GetStringSelection()
             if not self.layers.IsChecked(item):
                 continue
             layerNames.append(self.layers.GetString(item) + '@' + mapset)
         return layerNames
     def GetLayerType(self):
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2011-10-06 07:16:37 UTC (rev 48657)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py	2011-10-06 10:57:43 UTC (rev 48658)
@@ -73,7 +73,7 @@
 import gselect
 from debug        import Debug
 from gcmd         import GMessage, GException, GWarning, GError, RunCommand
-from gdialogs     import ElementDialog, GetImageHandlers
+from gdialogs     import ElementDialog, GetImageHandlers, MapLayersDialog
 from preferences  import PreferencesBaseDialog, globalSettings as UserSettings
 from ghelp        import SearchModuleWindow
@@ -500,13 +500,36 @@
                         if vtype == 'string':
                             value = '"' + value + '"'
                         cond = pattern.sub(value, cond)
                 # split condition
-                condVar, condText = re.split('\s*in\s*', cond)
+                condVar, condText = map(lambda x: x.strip(), re.split('\s*in\s*', cond))
+                pattern = re.compile('%' + condVar)
+                ### for vars()[condVar] in eval(condText): ?
+                if condText[0] == '`' and condText[-1] == '`':
+                    # run command
+                    cmd, dcmd = utils.CmdToTuple(condText[1:-1].split(' '))
+                    ret = RunCommand(cmd,
+                                     read = True,
+                                     **dcmd)
+                    if ret:
+                        vlist = ret.splitlines()
+                else:
+                    vlist = eval(condText)
-                for action in item.GetItems():
-                    for vars()[condVar] in eval(condText):
-                        if isinstance(action, ModelAction):
-                            self.RunAction(action, params, log, onDone)
+                for var in vlist:
+                    for action in item.GetItems():
+                        if not isinstance(action, ModelAction):
+                            continue
+                        par = action.GetParams(dcopy = True)['params']
+                        for idx in range(len(par)):
+                            if not par[idx].get('value', None):
+                                continue
+                            if pattern.search(par[idx]['value']):
+                                par[idx]['value'] = pattern.sub(par[idx]['value'], var)
+                        self.RunAction(action, { action.GetName(): {'params': par } }, log, onDone)
         if params:
             dlg.Destroy()
@@ -2226,6 +2249,7 @@
                         alist.append(action)
                 shape.SetItems(alist)
                 self.frame.DefineLoop(shape)
+                self.frame.SetStatusText(shape.GetLog(), 0)
             self.frame.GetCanvas().Refresh()
             dlg.Destroy()
@@ -4124,6 +4148,11 @@
         self.listBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
                                     label=" %s " % _("List of items in loop"))
+        self.btnSeries = wx.Button(parent = self.panel, id = wx.ID_ANY,
+                                   label = _("Series"))
+        self.btnSeries.SetToolTipString(_("Define map series as condition for the loop"))
+        self.btnSeries.Bind(wx.EVT_BUTTON, self.OnSeries)
         self._layout()
         self.SetSize((500, 400))
@@ -4132,13 +4161,15 @@
         """!Do layout"""
         sizer = wx.BoxSizer(wx.VERTICAL)
-        condSizer = wx.StaticBoxSizer(self.condBox, wx.VERTICAL)
+        condSizer = wx.StaticBoxSizer(self.condBox, wx.HORIZONTAL)
         condSizer.Add(item = self.condText, proportion = 1,
+                      flag = wx.ALL, border = 3)
+        condSizer.Add(item = self.btnSeries, proportion = 0,
                       flag = wx.EXPAND)
         listSizer = wx.StaticBoxSizer(self.listBox, wx.VERTICAL)
         listSizer.Add(item = self.itemList, proportion = 1,
-                      flag = wx.EXPAND)
+                      flag = wx.EXPAND | wx.ALL, border = 3)
         btnSizer.AddButton(self.btnCancel)
@@ -4161,6 +4192,17 @@
         """!Get list of selected actions"""
         return self.itemList.GetItems()
+    def OnSeries(self, event):
+        """!Define map series as condition"""
+        dialog = MapLayersDialog(parent = self, title = _("Define series of maps"))
+        if dialog.ShowModal() != wx.ID_OK:
+            dialog.Destroy()
+            return
+        self.condText.SetValue('map in %s' % map(lambda x: str(x), dialog.GetMapLayers()))
+        dialog.Destroy()
 class ItemPanel(wx.Panel):
     def __init__(self, parent, id = wx.ID_ANY,
                  **kwargs):
@@ -4227,11 +4269,13 @@
                 shapeItems = map(lambda x: x.GetId(), self.shape.GetItems())
         else:
             shapeItems = list()
         i = 0
         if len(self.columns) == 3: # ItemCheckList
             checked = list()
         for action in data:
-            if isinstance(action, ModelData):
+            if isinstance(action, ModelData) or \
+                    action == self.shape:
                 continue
@@ -4663,7 +4707,15 @@
             if isinstance(item, ModelLoop):
-                self.fd.write('%sfor %s:\n' % (' ' * self.indent, cond))
+                cond = "%sfor %s in " % (' ' * self.indent, condVar)
+                    task = menuform.GUI(show = None).ParseCommand(cmd = utils.split(condText[1:-1]))
+                    cond += "grass.read_command("
+                    cond += self._getPythonActionCmd(task, len(cond)) + ".splitlines()"
+                else:
+                    cond += condText
+                self.fd.write('%s:\n' % cond)
                 self.indent += 4
                     self._writePythonItem(action, ignoreBlock = False)
@@ -4685,13 +4737,18 @@
     def _writePythonAction(self, item):
         """!Write model action to Python file"""
         task = menuform.GUI(show = None).ParseCommand(cmd = item.GetLog(string = False))
+        strcmd = "%sgrass.run_command(" % (' ' * self.indent)
+        self.fd.write(strcmd + self._getPythonActionCmd(task, len(strcmd)) + '\n')
+    def _getPythonActionCmd(self, task, cmdIndent):
         opts = task.get_options()
+        ret = ''
         flags = ''
         params = list()
-        strcmd = "%sgrass.run_command(" % (' ' * self.indent)
-        cmdIndent = len(strcmd)
         for f in opts['flags']:
-            if f.get('value', False) == True:
+            if f.get('value', False):
                 name = f.get('name', '')
                 if len(name) > 1:
                     params.append('%s = True' % name)
@@ -4703,23 +4760,26 @@
             value = p.get('value', None)
             if name and value:
                 ptype = p.get('type', 'string')
-                if ptype == 'string':
+                if value[0] == '%':
+                    params.append("%s = %s" % (name, value[1:]))
+                elif ptype == 'string':
                     params.append('%s = "%s"' % (name, value))
                 else:
                     params.append("%s = %s" % (name, value))
-        self.fd.write(strcmd + '"%s"' % task.get_name())
+        ret += '"%s"' % task.get_name()
         if flags:
-            self.fd.write(",\n%sflags = '%s'" % (' ' * cmdIndent, flags))
+            ret += ",\n%sflags = '%s'" % (' ' * cmdIndent, flags)
         if len(params) > 0:
-            self.fd.write(",\n")
+            ret += ",\n"
             for opt in params[:-1]:
-                self.fd.write("%s%s,\n" % (' ' * cmdIndent, opt))
-            self.fd.write("%s%s)\n" % (' ' * cmdIndent, params[-1]))
+                ret += "%s%s,\n" % (' ' * cmdIndent, opt)
+            ret += "%s%s)" % (' ' * cmdIndent, params[-1])
         else:
-            self.fd.write(")\n")
+            ret += ")"
+        return ret
 def main():
     import gettext
     gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2011-10-06 07:16:37 UTC (rev 48657)
+++ grass/trunk/gui/wxpython/wxgui.py	2011-10-06 10:57:43 UTC (rev 48658)
@@ -1346,32 +1346,31 @@
     def OnAddMaps(self, event = None):
         """!Add selected map layers into layer tree"""
-        dialog = gdialogs.AddMapLayersDialog(parent = self, title = _("Add selected map layers into layer tree"))
+        dialog = gdialogs.MapLayersDialog(parent = self, title = _("Add selected map layers into layer tree"))
+            dialog.Destroy()
+            return
-        if dialog.ShowModal() == wx.ID_OK:
-            # start new map display if no display is available
-            if not self.curr_page:
-                self.NewDisplay()
-            maptree = self.curr_page.maptree
-            busy = wx.BusyInfo(message = _("Please wait, loading workspace..."),
-                               parent = self)
-            wx.Yield()
+        # start new map display if no display is available
+        if not self.curr_page:
+            self.NewDisplay()
-            for layerName in dialog.GetMapLayers():
-                if dialog.GetLayerType() == 'raster':
-                    cmd = ['d.rast', 'map=%s' % layerName]
-                elif dialog.GetLayerType() == 'vector':
-                    cmd = ['d.vect', 'map=%s' % layerName]
-                newItem = maptree.AddLayer(ltype = dialog.GetLayerType(),
-                                           lname = layerName,
-                                           lchecked = False,
-                                           lopacity = 1.0,
-                                           lcmd = cmd,
-                                           lgroup = None)
-            busy.Destroy()
+        maptree = self.curr_page.maptree
+        for layerName in dialog.GetMapLayers():
+            if dialog.GetLayerType() == 'raster':
+                cmd = ['d.rast', 'map=%s' % layerName]
+            elif dialog.GetLayerType() == 'vector':
+                cmd = ['d.vect', 'map=%s' % layerName]
+            newItem = maptree.AddLayer(ltype = dialog.GetLayerType(),
+                                       lname = layerName,
+                                       lchecked = False,
+                                       lopacity = 1.0,
+                                       lcmd = cmd,
+                                       lgroup = None)
+        dialog.Destroy()
     def OnAddRaster(self, event):
         """!Add raster map layer"""
