[GRASS-SVN] r48666 - grass/trunk/raster/r.gwflow
svn_grass at osgeo.org
Fri Oct 7 03:29:32 EDT 2011
Author: martinl
Date: 2011-10-07 00:29:32 -0700 (Fri, 07 Oct 2011)
New Revision: 48666
grass/trunk/raster/r.gwflow/main.c
r.gwflow: remove extra newlines from option description + description standardization
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c 2011-10-06 21:13:16 UTC (rev 48665)
+++ grass/trunk/raster/r.gwflow/main.c 2011-10-07 07:29:32 UTC (rev 48666)
@@ -54,31 +54,31 @@
param.phead = G_define_standard_option(G_OPT_R_INPUT);
param.phead->key = "phead";
- param.phead->description = _("Input raster map with initial piezometric head in [m]");
+ param.phead->description = _("Name of input raster map with initial piezometric head in [m]");
param.status = G_define_standard_option(G_OPT_R_INPUT);
param.status->key = "status";
param.status->description =
- _("Input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet");
+ _("Name of input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet");
param.hc_x =G_define_standard_option(G_OPT_R_INPUT);
param.hc_x->key = "hc_x";
param.hc_x->description =
- _("Input raster map with x-part of the hydraulic conductivity tensor in [m/s]");
+ _("Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]");
param.hc_y = G_define_standard_option(G_OPT_R_INPUT);
param.hc_y->key = "hc_y";
param.hc_y->description =
- _("Input raster map with y-part of the hydraulic conductivity tensor in [m/s]");
+ _("Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]");
param.q = G_define_standard_option(G_OPT_R_INPUT);
param.q->key = "q";
param.q->required = NO;
- param.q->description = _("Input raster map with water sources and sinks in [m^3/s]");
+ param.q->description = _("Name of input raster map with water sources and sinks in [m^3/s]");
param.s = G_define_standard_option(G_OPT_R_INPUT);
param.s->key = "s";
- param.s->description = _("Input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] ");
+ param.s->description = _("Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] ");
param.r = G_define_standard_option(G_OPT_R_INPUT);
param.r->key = "recharge";
@@ -89,11 +89,11 @@
param.top = G_define_standard_option(G_OPT_R_INPUT);
param.top->key = "top";
- param.top->description = _("Input raster map describing the top surface of the aquifer in [m]");
+ param.top->description = _("Name of input raster map describing the top surface of the aquifer in [m]");
param.bottom = G_define_standard_option(G_OPT_R_INPUT);
param.bottom->key = "bottom";
- param.bottom->description = _("Input raster map describing the bottom surface of the aquifer in [m]");
+ param.bottom->description = _("Name of input raster map describing the bottom surface of the aquifer in [m]");
param.output = G_define_standard_option(G_OPT_R_OUTPUT);
param.output->key = "output";
@@ -103,19 +103,19 @@
param.vector_x->key = "vx";
param.vector_x->required = NO;
param.vector_x->description =
- _("Output raster map to store the groundwater filter velocity vector part in x direction [m/s]\n");
+ _("Output raster map to store the groundwater filter velocity vector part in x direction [m/s]");
param.vector_y = G_define_standard_option(G_OPT_R_OUTPUT);
param.vector_y->key = "vy";
param.vector_y->required = NO;
param.vector_y->description =
- _("Output raster map to store the groundwater filter velocity vector part in y direction [m/s]\n");
+ _("Output raster map to store the groundwater filter velocity vector part in y direction [m/s]");
param.budget = G_define_standard_option(G_OPT_R_OUTPUT);
param.budget->key = "budget";
param.budget->required = NO;
param.budget->description =
- _("Output raster map to store the groundwater budget for each cell [m^3/s]\n");
+ _("Output raster map to store the groundwater budget for each cell [m^3/s]");
param.type = G_define_option();
param.type->key = "type";
@@ -129,7 +129,7 @@
param.river_bed = G_define_standard_option(G_OPT_R_INPUT);
param.river_bed->key = "river_bed";
param.river_bed->required = NO;
- param.river_bed->description = _("Input raster map providing the height of the river bed in [m]");
+ param.river_bed->description = _("Name of input raster map providing the height of the river bed in [m]");
param.river_bed->guisection = "River";
param.river_head = G_define_standard_option(G_OPT_R_INPUT);
@@ -137,14 +137,14 @@
param.river_head->required = NO;
param.river_head->guisection = "River";
param.river_head->description =
- _("Input raster map providing the water level (head) of the river with leakage connection in [m]");
+ _("Name of input raster map providing the water level (head) of the river with leakage connection in [m]");
param.river_leak = G_define_standard_option(G_OPT_R_INPUT);
param.river_leak->key = "river_leak";
param.river_leak->required = NO;
param.river_leak->guisection = "River";
param.river_leak->description =
- _("Input raster map providing the leakage coefficient of the river bed in [1/s].");
+ _("Name of input raster map providing the leakage coefficient of the river bed in [1/s].");
param.drain_bed = G_define_standard_option(G_OPT_R_INPUT);
param.drain_bed->key = "drain_bed";
@@ -152,14 +152,14 @@
param.drain_bed->required = NO;
param.drain_bed->gisprompt = "old,raster,raster";
param.drain_bed->guisection = "Drainage";
- param.drain_bed->description = _("Input raster map providing the height of the drainage bed in [m]");
+ param.drain_bed->description = _("Name of input raster map providing the height of the drainage bed in [m]");
param.drain_leak = G_define_standard_option(G_OPT_R_INPUT);
param.drain_leak->key = "drain_leak";
param.drain_leak->required = NO;
param.drain_leak->guisection = "Drainage";
param.drain_leak->description =
- _("Input raster map providing the leakage coefficient of the drainage bed in [1/s]");
+ _("Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]");
param.dt = N_define_standard_option(N_OPT_CALC_TIME);
param.maxit = N_define_standard_option(N_OPT_MAX_ITERATIONS);
@@ -171,7 +171,7 @@
param.full_les->key = 'f';
param.full_les->guisection = "Solver";
param.full_les->description = _("Allocate a full quadratic linear equation system,"
- " default is a sparse linear equation system.");
+ " default is a sparse linear equation system.");
@@ -254,8 +254,8 @@
solver = param.solver->answer;
if (strcmp(solver, G_MATH_SOLVER_DIRECT_CHOLESKY) == 0 && !param.full_les->answer)
- G_fatal_error(_("The cholesky solver dos not work with sparse matrices.\n"
- "You may choose a full filled quadratic matrix, flag -f. "));
+ G_fatal_error(_("The cholesky solver dos not work with sparse matrices. "
+ "You may choose a full filled quadratic matrix, flag -f."));
/*get the current region */
@@ -373,7 +373,7 @@
inner_count = 0;
do {
- G_message(_("Calculation of unconfined groundwater flow loop %i\n"),
+ G_message(_("Calculation of unconfined groundwater flow loop %i"),
inner_count + 1);
/* we will allocate a new les for each loop */
