[GRASS-SVN] r48668 - in grass-addons/grass7/raster: . r.regression.multi
Fri Oct 7 05:22:02 EDT 2011
Author: mmetz
Date: 2011-10-07 02:22:02 -0700 (Fri, 07 Oct 2011)
New Revision: 48668
Added:
   grass-addons/grass7/raster/r.regression.multi/
   grass-addons/grass7/raster/r.regression.multi/main.c
Removed:
prepare for r.regression.multi
Deleted: grass-addons/grass7/raster/r.regression.multi/main.c
--- grass/trunk/raster/r.regression.line/main.c	2011-10-03 16:00:49 UTC (rev 48607)
+++ grass-addons/grass7/raster/r.regression.multi/main.c	2011-10-07 09:22:02 UTC (rev 48668)
@@ -1,156 +0,0 @@
- * r.regression
- *   Calculates linear regression from two raster maps: y = a + b*x
- *   Copyright (C) 2010 by the GRASS Development Team
- *   Author(s): original author Dr. Agustin Lobo
- *              Markus Metz (conversion to C for speed)
- *      This program is free software under the GNU General Public
- *      License (>=v2). Read the file COPYING that comes with GRASS
- *      for details.
- *   This program is a replacement for the r.regression.line script
- *   (the C version is up to 200x faster than the script version)
-#include <stdio.h>
-#include <stdlib.h>
-#include <math.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/raster.h>
-int main(int argc, char *argv[])
-    unsigned int r, c, rows, cols;	/*  totals  */
-    int map1_fd, map2_fd;
-    double sumX, sumY, sumsqX, sumsqY, sumXY;
-    double meanX, meanY, varX, varY, sdX, sdY;
-    double A, B, R, F;
-    long count = 0;
-    DCELL *map1_buf, *map2_buf, map1_val, map2_val;
-    char *name;
-    struct Option *input_map1, *input_map2, *output_opt;
-    struct Flag *shell_style;
-    struct Cell_head region;
-    struct GModule *module;
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    G_add_keyword(_("raster"));
-    G_add_keyword(_("statistics"));
-    module->description =
-	_("Calculates linear regression from two raster maps: y = a + b*x.");
-    /* Define the different options */
-    input_map1 = G_define_standard_option(G_OPT_R_MAP);
-    input_map1->key = "map1";
-    input_map1->description = (_("Map for x coefficient"));
-    input_map2 = G_define_standard_option(G_OPT_R_MAP);
-    input_map2->key = "map2";
-    input_map2->description = (_("Map for y coefficient"));
-    output_opt = G_define_standard_option(G_OPT_F_OUTPUT);
-    output_opt->key = "output";
-    output_opt->required = NO;
-    output_opt->description =
-	(_("ASCII file for storing regression coefficients (output to screen if file not specified)."));
-    shell_style = G_define_flag();
-    shell_style->key = 'g';
-    shell_style->description = _("Print in shell script style");
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    name = output_opt->answer;
-    if (name != NULL && strcmp(name, "-") != 0) {
-	if (NULL == freopen(name, "w", stdout)) {
-	    G_fatal_error(_("Unable to open file <%s> for writing"), name);
-    G_get_window(&region);
-    rows = region.rows;
-    cols = region.cols;
-    /* open maps */
-    map1_fd = Rast_open_old(input_map1->answer, "");
-    map2_fd = Rast_open_old(input_map2->answer, "");
-    map1_buf = Rast_allocate_d_buf();
-    map2_buf = Rast_allocate_d_buf();
-    sumX = sumY = sumsqX = sumsqY = sumXY = 0.0;
-    meanX = meanY = varX = varY = sdX = sdY = 0.0;
-    for (r = 0; r < rows; r++) {
-	G_percent(r, rows, 2);
-	Rast_get_d_row(map1_fd, map1_buf, r);
-	Rast_get_d_row(map2_fd, map2_buf, r);
-	for (c = 0; c < cols; c++) {
-	    map1_val = map1_buf[c];
-	    map2_val = map2_buf[c];
-	    if (Rast_is_d_null_value(&map1_val) ||
-		Rast_is_d_null_value(&map2_val))
-		continue;
-	    sumX += map1_val;
-	    sumY += map2_val;
-	    sumsqX += map1_val * map1_val;
-	    sumsqY += map2_val * map2_val;
-	    sumXY += map1_val * map2_val;
-	    count++;
-    Rast_close(map1_fd);
-    Rast_close(map2_fd);
-    G_free(map1_buf);
-    G_free(map2_buf);
-    B = (sumXY - sumX * sumY / count) / (sumsqX - sumX * sumX / count);
-    R = (sumXY - sumX * sumY / count) /
-	sqrt((sumsqX - sumX * sumX / count) * (sumsqY - sumY * sumY / count));
-    meanX = sumX / count;
-    sumsqX = sumsqX / count;
-    varX = sumsqX - (meanX * meanX);
-    sdX = sqrt(varX);
-    meanY = sumY / count;
-    sumsqY = sumsqY / count;
-    varY = sumsqY - (meanY * meanY);
-    sdY = sqrt(varY);
-    A = meanY - B * meanX;
-    F = R * R / (1 - R * R / count - 2);
-    if (shell_style->answer) {
-	fprintf(stdout, "a=%f\n", A);
-	fprintf(stdout, "b=%f\n", B);
-	fprintf(stdout, "R=%f\n", R);
-	fprintf(stdout, "N=%ld\n", count);
-	fprintf(stdout, "F=%f\n", F);
-	fprintf(stdout, "meanX=%f\n", meanX);
-	fprintf(stdout, "sdX=%f\n", sdX);
-	fprintf(stdout, "meanY=%f\n", meanY);
-	fprintf(stdout, "sdY=%f\n", sdY);
-    else {
-	fprintf(stdout, "y = a + b*x\n");
-	fprintf(stdout, "   a (Offset): %f\n", A);
-	fprintf(stdout, "   b (Gain): %f\n", B);
-	fprintf(stdout, "   R (sumXY - sumX*sumY/N): %f\n", R);
-	fprintf(stdout, "   N (Number of elements): %ld\n", count);
-	fprintf(stdout, "   F (F-test significance): %f\n", F);
-	fprintf(stdout, "   meanX (Mean of map1): %f\n", meanX);
-	fprintf(stdout, "   sdX (Standard deviation of map1): %f\n", sdX);
-	fprintf(stdout, "   meanY (Mean of map2): %f\n", meanY);
-	fprintf(stdout, "   sdY (Standard deviation of map2): %f\n", sdY);
-    exit(EXIT_SUCCESS);
Copied: grass-addons/grass7/raster/r.regression.multi/main.c (from rev 48667, grass/trunk/raster/r.regression.line/main.c)
--- grass-addons/grass7/raster/r.regression.multi/main.c	                        (rev 0)
@@ -0,0 +1,159 @@
+ * MODULE:       r.regression.line
+ * AUTHOR(S):    Dr. Agustin Lobo
+ *               Markus Metz (conversion to C for speed)
+ * PURPOSE:      Calculates linear regression from two raster maps:
+ *               y = a + b*x
+ * COPYRIGHT:    (C) 2010 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/raster.h>
+int main(int argc, char *argv[])
+    unsigned int r, c, rows, cols;	/*  totals  */
+    int map1_fd, map2_fd;
+    double sumX, sumY, sumsqX, sumsqY, sumXY;
+    double meanX, meanY, varX, varY, sdX, sdY;
+    double A, B, R, F;
+    long count = 0;
+    DCELL *map1_buf, *map2_buf, map1_val, map2_val;
+    char *name;
+    struct Option *input_map1, *input_map2, *output_opt;
+    struct Flag *shell_style;
+    struct Cell_head region;
+    struct GModule *module;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("statistics"));
+    module->description =
+	_("Calculates linear regression from two raster maps: y = a + b*x.");
+    /* Define the different options */
+    input_map1 = G_define_standard_option(G_OPT_R_MAP);
+    input_map1->key = "map1";
+    input_map1->description = (_("Map for x coefficient"));
+    input_map2 = G_define_standard_option(G_OPT_R_MAP);
+    input_map2->key = "map2";
+    input_map2->description = (_("Map for y coefficient"));
+    output_opt = G_define_standard_option(G_OPT_F_OUTPUT);
+    output_opt->key = "output";
+    output_opt->required = NO;
+    output_opt->description =
+	(_("ASCII file for storing regression coefficients (output to screen if file not specified)."));
+    shell_style = G_define_flag();
+    shell_style->key = 'g';
+    shell_style->description = _("Print in shell script style");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    name = output_opt->answer;
+    if (name != NULL && strcmp(name, "-") != 0) {
+	if (NULL == freopen(name, "w", stdout)) {
+	    G_fatal_error(_("Unable to open file <%s> for writing"), name);
+    G_get_window(&region);
+    rows = region.rows;
+    cols = region.cols;
+    /* open maps */
+    map1_fd = Rast_open_old(input_map1->answer, "");
+    map2_fd = Rast_open_old(input_map2->answer, "");
+    map1_buf = Rast_allocate_d_buf();
+    map2_buf = Rast_allocate_d_buf();
+    sumX = sumY = sumsqX = sumsqY = sumXY = 0.0;
+    meanX = meanY = varX = varY = sdX = sdY = 0.0;
+    for (r = 0; r < rows; r++) {
+	G_percent(r, rows, 2);
+	Rast_get_d_row(map1_fd, map1_buf, r);
+	Rast_get_d_row(map2_fd, map2_buf, r);
+	for (c = 0; c < cols; c++) {
+	    map1_val = map1_buf[c];
+	    map2_val = map2_buf[c];
+	    if (Rast_is_d_null_value(&map1_val) ||
+		Rast_is_d_null_value(&map2_val))
+		continue;
+	    sumX += map1_val;
+	    sumY += map2_val;
+	    sumsqX += map1_val * map1_val;
+	    sumsqY += map2_val * map2_val;
+	    sumXY += map1_val * map2_val;
+	    count++;
+    Rast_close(map1_fd);
+    Rast_close(map2_fd);
+    G_free(map1_buf);
+    G_free(map2_buf);
+    B = (sumXY - sumX * sumY / count) / (sumsqX - sumX * sumX / count);
+    R = (sumXY - sumX * sumY / count) /
+	sqrt((sumsqX - sumX * sumX / count) * (sumsqY - sumY * sumY / count));
+    meanX = sumX / count;
+    sumsqX = sumsqX / count;
+    varX = sumsqX - (meanX * meanX);
+    sdX = sqrt(varX);
+    meanY = sumY / count;
+    sumsqY = sumsqY / count;
+    varY = sumsqY - (meanY * meanY);
+    sdY = sqrt(varY);
+    A = meanY - B * meanX;
+    F = R * R / (1 - R * R / count - 2);
+    if (shell_style->answer) {
+	fprintf(stdout, "a=%f\n", A);
+	fprintf(stdout, "b=%f\n", B);
+	fprintf(stdout, "R=%f\n", R);
+	fprintf(stdout, "N=%ld\n", count);
+	fprintf(stdout, "F=%f\n", F);
+	fprintf(stdout, "meanX=%f\n", meanX);
+	fprintf(stdout, "sdX=%f\n", sdX);
+	fprintf(stdout, "meanY=%f\n", meanY);
+	fprintf(stdout, "sdY=%f\n", sdY);
+    else {
+	fprintf(stdout, "y = a + b*x\n");
+	fprintf(stdout, "   a (Offset): %f\n", A);
+	fprintf(stdout, "   b (Gain): %f\n", B);
+	fprintf(stdout, "   R (sumXY - sumX*sumY/N): %f\n", R);
+	fprintf(stdout, "   N (Number of elements): %ld\n", count);
+	fprintf(stdout, "   F (F-test significance): %f\n", F);
+	fprintf(stdout, "   meanX (Mean of map1): %f\n", meanX);
+	fprintf(stdout, "   sdX (Standard deviation of map1): %f\n", sdX);
+	fprintf(stdout, "   meanY (Mean of map2): %f\n", meanY);
+	fprintf(stdout, "   sdY (Standard deviation of map2): %f\n", sdY);
+    exit(EXIT_SUCCESS);
