[GRASS-SVN] r48670 - in grass/trunk/gui/wxpython: gui_modules icons
xml
svn_grass at osgeo.org
Fri Oct 7 05:49:18 EDT 2011
Author: martinl
Date: 2011-10-07 02:49:17 -0700 (Fri, 07 Oct 2011)
New Revision: 48670
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/icons/icon.py
grass/trunk/gui/wxpython/xml/menudata_modeler.xml
wxGUI/modeler: fix variable substitution
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2011-10-07 09:24:50 UTC (rev 48669)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2011-10-07 09:49:17 UTC (rev 48670)
@@ -527,8 +527,7 @@
continue
if pattern.search(par[idx]['value']):
- par[idx]['value'] = pattern.sub(par[idx]['value'], var)
+ par[idx]['value'] = pattern.sub(var, par[idx]['value'])
self.RunAction(action, { action.GetName(): {'params': par } }, log, onDone)
if params:
@@ -4689,12 +4688,12 @@
sys.exit(main())
- def _writePythonItem(self, item, ignoreBlock = True):
+ def _writePythonItem(self, item, ignoreBlock = True, variables = []):
"""!Write model object to Python file"""
if isinstance(item, ModelAction):
if ignoreBlock and item.GetBlockId(): # ignore items in loops of conditions
return
- self._writePythonAction(item)
+ self._writePythonAction(item, variables = variables)
elif isinstance(item, ModelLoop) or isinstance(item, ModelCondition):
# substitute condition
variables = self.model.GetVariables()
@@ -4712,13 +4711,13 @@
if condText[0] == '`' and condText[-1] == '`':
task = menuform.GUI(show = None).ParseCommand(cmd = utils.split(condText[1:-1]))
cond += "grass.read_command("
- cond += self._getPythonActionCmd(task, len(cond)) + ".splitlines()"
+ cond += self._getPythonActionCmd(task, len(cond), variables = [condVar]) + ".splitlines()"
else:
cond += condText
self.fd.write('%s:\n' % cond)
self.indent += 4
for action in item.GetItems():
- self._writePythonItem(action, ignoreBlock = False)
+ self._writePythonItem(action, ignoreBlock = False, variables = [condVar])
self.indent -= 4
else: # ModelCondition
self.fd.write('%sif %s:\n' % (' ' * self.indent, cond))
@@ -4734,13 +4733,13 @@
self.indent += 4
- def _writePythonAction(self, item):
+ def _writePythonAction(self, item, variables = []):
"""!Write model action to Python file"""
task = menuform.GUI(show = None).ParseCommand(cmd = item.GetLog(string = False))
strcmd = "%sgrass.run_command(" % (' ' * self.indent)
- self.fd.write(strcmd + self._getPythonActionCmd(task, len(strcmd)) + '\n')
+ self.fd.write(strcmd + self._getPythonActionCmd(task, len(strcmd), variables) + '\n')
- def _getPythonActionCmd(self, task, cmdIndent):
+ def _getPythonActionCmd(self, task, cmdIndent, variables = []):
opts = task.get_options()
ret = ''
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2011-10-07 09:24:50 UTC (rev 48669)
+++ grass/trunk/gui/wxpython/icons/icon.py 2011-10-07 09:49:17 UTC (rev 48670)
@@ -367,11 +367,11 @@
'toPython' : MetaIcon(img = iconSet.get('python-export', wx.ART_ERROR),
label = _('Export model to Python script')),
'actionAdd' : MetaIcon(img = iconSet.get('module-add', wx.ART_ERROR),
- label = _('Add action (GRASS module) to model')),
+ label = _('Add command (GRASS module) to model')),
'dataAdd' : MetaIcon(img = iconSet.get('data-add', wx.ART_ERROR),
- label = _('Add data item to model')),
+ label = _('Add data to model')),
'relation' : MetaIcon(img = iconSet.get('relation-create', wx.ART_ERROR),
- label = _('Define relation between data and action items')),
+ label = _('Manually define relation between data and commands')),
'run' : MetaIcon(img = iconSet.get('execute', wx.ART_ERROR),
label = _('Run model')),
'validate' : MetaIcon(img = iconSet.get('check', wx.ART_ERROR),
Modified: grass/trunk/gui/wxpython/xml/menudata_modeler.xml
--- grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2011-10-07 09:24:50 UTC (rev 48669)
+++ grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2011-10-07 09:49:17 UTC (rev 48670)
@@ -66,8 +66,8 @@
<label>&Model</label>
<items>
<menuitem>
- <label>Add action</label>
- <help>Add action (GRASS module) to model</help>
+ <label>Add command</label>
+ <help>Add action (GRASS command) to model</help>
<handler>OnAddAction</handler>
<shortcut>Ctrl+A</shortcut>
</menuitem>
@@ -83,8 +83,8 @@
<handler>OnDefineRelation</handler>
</menuitem>
<menuitem>
- <label>Add loop</label>
- <help>Adds loop (for) to model</help>
+ <label>Add loop / series</label>
+ <help>Adds loop (series) to model</help>
<handler>OnDefineLoop</handler>
<shortcut>Ctrl+L</shortcut>
</menuitem>
