[GRASS-SVN] r48675 - in grass/trunk: lib/python/temporal
lib/temporal raster/r.colors raster/r.series
temporal/t.create temporal/t.remove temporal/tr.extract
temporal/tr.series visualization visualization/nviz2
visualization/nviz2/cmd
svn_grass at osgeo.org
Fri Oct 7 20:00:22 EDT 2011
Author: huhabla
Date: 2011-10-07 17:00:22 -0700 (Fri, 07 Oct 2011)
New Revision: 48675
Added:
grass/trunk/raster/r.series/test_3_prec_max.ref
grass/trunk/raster/r.series/test_3_prec_mean.ref
grass/trunk/raster/r.series/test_3_prec_min.ref
grass/trunk/raster/r.series/test_4_prec_max.ref
grass/trunk/raster/r.series/test_4_prec_mean.ref
grass/trunk/raster/r.series/test_4_prec_min.ref
grass/trunk/visualization/nviz2/
grass/trunk/visualization/nviz2/cmd/
grass/trunk/visualization/nviz2/cmd/OBJ.x86_64-unknown-linux-gnu/
grass/trunk/lib/python/temporal/abstract_datasets.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/metadata.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/temporal_extent.py
grass/trunk/lib/temporal/stds_tables_template.sql
grass/trunk/raster/r.colors/
grass/trunk/raster/r.series/test.r.series.sh
grass/trunk/temporal/t.create/t.create.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/tr.extract/tr.extract.py
grass/trunk/temporal/tr.series/tr.series.py
Code cleanup. The temporal map type (single point of time, time interval or mixed) is now computed and stored in space time datasets.
Modified: grass/trunk/lib/python/temporal/abstract_datasets.py
--- grass/trunk/lib/python/temporal/abstract_datasets.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/lib/python/temporal/abstract_datasets.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -7,7 +7,7 @@
Usage:
@code
-from grass.script import tgis_abstract_datasets as grass
+import grass.temporal as tgis
@endcode
@@ -496,7 +496,7 @@
return granularity, temporal_type, semantic_type, title, description
def get_temporal_relation_matrix(self, dbif=None):
- """Return the temporal relation matrix between all registered maps
+ """Return the temporal relation matrix of all registered maps as list
connect = False
@@ -593,6 +593,8 @@
dbif.cursor.execute(sql)
rows = dbif.cursor.fetchall()
except:
+ if connect == True:
+ dbif.close()
core.error(_("Unable to get map ids from register table <%s>") % (self.get_map_register()))
raise
@@ -628,6 +630,8 @@
sql = "DROP TABLE " + self.get_map_register()
except:
+ dbif.close()
core.error(_("Unable to drop table <%s>") % (self.get_map_register()))
raise
@@ -655,6 +659,7 @@
connect = True
if map.is_in_db(dbif) == False:
+ dbif.close()
core.fatal(_("Only maps with absolute or relative valid time can be registered"))
core.verbose(_("Register %s map <%s> in space time %s dataset <%s>") % (map.get_type(), map.get_id(), map.get_type(), self.get_id()))
@@ -676,6 +681,7 @@
#print "STDS register table", stds_register_table
if stds_mapset != map_mapset:
+ dbif.close()
core.fatal(_("Only maps from the same mapset can be registered"))
# Check if map is already registred
@@ -688,6 +694,8 @@
row = dbif.cursor.fetchone()
# In case of no entry make a new one
if row and row[0] == map_id:
+ dbif.close()
core.warning(_("Map <%s> is already registered.") % (map_id))
return False
@@ -710,7 +718,7 @@
sql = sql.replace("MAP_ID", map_id)
sql = sql.replace("STDS", self.get_type())
try:
- if dbmi.paramstyle == "qmark":
+ if dbmi.__name__ == "sqlite3":
dbif.cursor.executescript(sql)
else:
@@ -720,14 +728,18 @@
sql = "DROP TABLE " + map_register_table
except:
+ dbif.close()
core.error(_("Unable to drop table <%s>" % (map_register_table)))
raise
try:
dbif.cursor.executescript(sql_script)
else:
dbif.cursor.execute(sql_script)
except:
+ dbif.close()
core.error(_("Unable to create the space time %s dataset register table for <%s>") % (map.get_type(), map.get_id()))
raise
@@ -750,12 +762,12 @@
sql_script = ""
- #sql_script += "BEGIN TRANSACTION;\n"
+ sql_script += "BEGIN TRANSACTION;\n"
sql_script += sql
- #sql_script += "\n"
- #sql_script += "END TRANSACTION;"
+ sql_script += "\n"
+ sql_script += "END TRANSACTION;"
try:
else:
@@ -766,14 +778,18 @@
print sql
except:
+ dbif.close()
core.error(_("Unable to drop table <%s>" % (stds_register_table)))
raise
try:
else:
except:
+ dbif.close()
raise
@@ -844,6 +860,7 @@
connect = True
+ dbif.close()
core.fatal(_("Unable to find map <%s> in temporal database") % (map.get_id()))
core.verbose(_("Unregister %s map <%s>") % (map.get_type(), map.get_id()))
@@ -852,8 +869,6 @@
map.select(dbif)
map_id = map.base.get_id()
map_register_table = map.get_stds_register()
- # Get basic info
stds_register_table = self.get_map_register()
# Check if the map is registered in the space time raster dataset
@@ -867,6 +882,8 @@
# Break if the map is not registered
if row == None:
core.warning(_("Map <%s> is not registered in space time dataset") %(map_id, self.base.get_id()))
+ dbif.close()
return False
# Remove the space time raster dataset from the raster dataset register
@@ -915,6 +932,7 @@
dbif.connect()
connect = True
+ map_time = None
use_start_time = False
@@ -950,12 +968,11 @@
else:
# Read and validate the selected end time
self.select()
@@ -984,7 +1001,8 @@
if row != None:
+ # This seems to be a bug in sqlite3 Python driver
tstring = row[0]
# Convert the unicode string into the datetime format
if tstring.find(":") > 0:
@@ -995,10 +1013,13 @@
max_start_time = datetime.strptime(tstring, time_format)
else:
max_start_time = row[0]
if end_time < max_start_time:
+ map_time = "mixed"
use_start_time = True
+ else:
+ map_time = "interval"
# Set the maximum start time as end time
if use_start_time:
if self.is_time_absolute():
@@ -1020,10 +1041,31 @@
sql = sql.replace("SPACETIME_ID", self.base.get_id())
else:
+ if end_time == None:
+ map_time = "point"
+ # Set the map time type
+ if self.is_time_absolute():
+ self.absolute_time.select(dbif)
+ self.metadata.select(dbif)
+ if self.metadata.get_number_of_maps() > 0:
+ self.absolute_time.set_map_time(map_time)
+ else:
+ self.absolute_time.set_map_time(None)
+ self.absolute_time.update_all(dbif)
+ else:
+ self.relative_time.select(dbif)
+ self.relative_time.set_map_time(map_time)
+ else:
+ self.relative_time.set_map_time(None)
+ self.relative_time.update_all(dbif)
if connect == True:
dbif.close()
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/lib/python/temporal/base.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -12,9 +12,9 @@
Usage:
@code
-from grass.script import tgis_core as grass
-rbase = grass.raster_base(ident="soil")
+rbase = tgis.raster_base(ident="soil")
@endcode
@@ -187,11 +187,12 @@
def connect(self):
#print "Connect to", self.database
self.connection = dbmi.connect(self.database, detect_types=dbmi.PARSE_DECLTYPES|dbmi.PARSE_COLNAMES)
self.connection.row_factory = dbmi.Row
+ self.connection.isolation_level = None
self.cursor = self.connection.cursor()
- else:
+ elif dbmi.__name__ == "psycopg2":
self.connection = dbmi.connect(self.database)
self.connection.set_isolation_level(dbmi.extensions.ISOLATION_LEVEL_AUTOCOMMIT)
self.cursor = self.connection.cursor(cursor_factory=dbmi.extras.DictCursor)
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/lib/python/temporal/core.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -7,9 +7,9 @@
Usage:
@code
-grass.create_temporal_database()
+tgis.create_temporal_database()
@endcode
@@ -21,22 +21,23 @@
@author Soeren Gebbert
import os
+import copy
+from datetime import datetime, date, time, timedelta
+import grass.script.core as core
import sqlite3 as dbmi
#import psycopg2 as dbmi
# Needed for dictionary like cursors
#import psycopg2.extras
-import grass.script.core as core
-import copy
-from datetime import datetime, date, time, timedelta
def get_grass_location_db_path():
grassenv = core.gisenv()
dbpath = os.path.join(grassenv["GISDBASE"], grassenv["LOCATION_NAME"])
return os.path.join(dbpath, "grass.db")
- else:
return "dbname=grass_test user=soeren password=abcdefgh"
@@ -46,6 +47,8 @@
base_etc = os.path.join(base, "etc")
return os.path.join(base_etc, "sql")
def test_increment_datetime_by_string():
dt = datetime(2001, 9, 1, 0, 0, 0)
@@ -59,16 +62,18 @@
if delta.days != 0 or delta.seconds != 0:
core.fatal("increment computation is wrong")
def increment_datetime_by_string(mydate, increment, mult = 1):
"""Return a new datetime object incremented with the provided relative dates specified as string.
Additional a multiplier can be specified to multiply the increment bevor adding to the provided datetime object.
- @mydate A datetime object to incremented
- @increment A string providing increment information:
+ @param mydate A datetime object to incremented
+ @param increment A string providing increment information:
The string may include comma separated values of type seconds, minutes, hours, days, weeks, months and years
Example: Increment the datetime 2001-01-01 00:00:00 with "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
will result in the datetime 2003-02-18 12:05:00
- @mult A multiplier, default is 1
+ @param mult A multiplier, default is 1
if increment:
@@ -103,7 +108,8 @@
elif inc[1].find("years") >= 0:
years = mult * int(inc[0])
else:
- core.fatal(_("Wrong increment format: %s") % (increment))
+ core.error(_("Wrong increment format: %s") % (increment))
+ return None
return increment_datetime(mydate, years, months, weeks, days, hours, minutes, seconds)
@@ -160,15 +166,24 @@
database = get_grass_location_db_path()
- build_db = False
+ db_exists = False
- # Check if it already exists
+ # Check if the database already exists
# Check path of the sqlite database
- if not os.path.exists(database):
- build_db = True
- if build_db == False:
+ if os.path.exists(database):
+ db_exists = True
+ # Connect to database
+ connection = dbmi.connect(database)
+ cursor = connection.cursor()
+ # Check for raster_base table
+ cursor.execute("SELECT EXISTS(SELECT * FROM information_schema.tables WHERE table_name=%s)", ('raster_base',))
+ db_exists = cursor.fetchone()[0]
+ connection.commit()
+ cursor.close()
+ if db_exists == True:
return
# Read all SQL scripts and templates
@@ -181,7 +196,6 @@
str3ds_metadata_sql = open(os.path.join(get_sql_template_path(), "str3ds_metadata_table.sql"), 'r').read()
stvds_metadata_sql = open(os.path.join(get_sql_template_path(), "stvds_metadata_table.sql"), 'r').read()
# Create the raster, raster3d and vector tables
raster_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster")
vector_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "vector")
@@ -196,8 +210,7 @@
sqlite3_delete_trigger_sql = open(os.path.join(get_sql_template_path(), "sqlite3_delete_trigger.sql"), 'r').read()
@@ -217,7 +230,7 @@
cursor.executescript(str3ds_tables_sql)
cursor.executescript(str3ds_metadata_sql)
cursor.executescript(sqlite3_delete_trigger_sql)
- else:
# Execute the SQL statements for postgresql
# Create the global tables for the native grass datatypes
cursor.execute(raster_tables_sql)
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/lib/python/temporal/metadata.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -7,9 +7,9 @@
Usage:
@code
-from grass.script import tgis_metadata as grass
-meta = grass.raster_metadata()
+meta = tgis.raster_metadata()
@endcode
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -7,9 +7,9 @@
Usage:
@code
-from grass.script import tgis_space_time_dataset as grass
-strds = grass.space_time_raster_dataset("soils_1950_2010")
+strds = tgis.space_time_raster_dataset("soils_1950_2010")
@endcode
@@ -419,6 +419,7 @@
sp.select(dbif)
if sp.is_in_db(dbif) == False:
+ dbif.close()
core.fatal("Space time " + sp.get_new_map_instance(None).get_type() + " dataset <" + name + "> not found")
if maps.find(",") == -1:
@@ -445,6 +446,7 @@
# Break in case no valid time is provided
if start == "" or start == None:
+ dbif.close()
core.fatal("Unable to register " + map.get_type() + " map <" + map.get_id() + ">. The map has no valid time and the start time is not set.")
# Load the data from the grass file database
map.load()
@@ -458,6 +460,7 @@
else:
map.select(dbif)
if map.get_temporal_type() != sp.get_temporal_type():
+ dbif.close()
core.fatal("Unable to register " + map.get_type() + " map <" + map.get_id() + ">. The temporal types are different.")
# Set the valid time
@@ -509,6 +512,7 @@
sp = space_time_vector_dataset(id)
+ dbif.close()
# Build the list of maps
@@ -576,6 +580,8 @@
if end and increment:
+ if dbif:
+ dbif.close()
core.fatal(_("Valid end time and increment are mutual exclusive"))
# List of space time datasets to be updated
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -7,9 +7,9 @@
Usage:
@code
-from grass.script import tgis_spatial_extent as grass
-extent = grass.raster_spatial_extent()
+extent = tgis.raster_spatial_extent()
@endcode
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -7,9 +7,9 @@
Usage:
@code
-from grass.script import tgis_temporal_extent as grass
-grass.raster_temporal_extent()
+tgis.raster_temporal_extent()
@endcode
@@ -383,15 +383,28 @@
class stds_absolute_time(absolute_temporal_extent):
- def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None, timezone=None):
+ def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None, timezone=None, map_time=None):
absolute_temporal_extent.__init__(self, table, ident, start_time, end_time, timezone)
self.set_granularity(granularity)
+ self.set_map_time(map_time)
def set_granularity(self, granularity):
"""Set the granularity of the space time dataset"""
self.D["granularity"] = granularity
+ def set_map_time(self, map_time):
+ """Set the type of the map time
+ Registered maps may have different types of time:
+ Single point of time "point"
+ Time intervals "interval"
+ Or single point and interval time "mixed"
+ This variable will be set automatically when maps are registered.
+ self.D["map_time"] = map_time
def get_granularity(self):
"""Get the granularity of the space time dataset
@return None if not found"""
@@ -400,16 +413,33 @@
else:
return None
+ def get_map_time(self):
+ """Get the type of the map time
+ if self.D.has_key("map_time"):
+ return self.D["map_time"]
+ else:
+ return None
def print_info(self):
"""Print information about this class in human readable style"""
absolute_temporal_extent.print_info(self)
# 0123456789012345678901234567890
print " | Granularity:................ " + str(self.get_granularity())
+ print " | Temporal type of maps:...... " + str(self.get_map_time())
def print_shell_info(self):
"""Print information about this class in shell style"""
absolute_temporal_extent.print_shell_info(self)
print "granularity=" + str(self.get_granularity())
+ print "map_time=" + str(self.get_map_time())
@@ -427,7 +457,6 @@
class relative_temporal_extent(abstract_temporal_extent):
"""This is the relative time class for all maps and spacetime datasets
@@ -437,14 +466,12 @@
abstract_temporal_extent.__init__(self, table, ident, start_time, end_time)
print " +-------------------- Reltive time ------------------------------------------+"
abstract_temporal_extent.print_info(self)
class raster_relative_time(relative_temporal_extent):
@@ -462,15 +489,28 @@
class stds_relative_time(relative_temporal_extent):
- def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None):
+ def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None, map_time=None):
relative_temporal_extent.__init__(self, table, ident, start_time, end_time)
@@ -479,16 +519,33 @@
else:
return None
+ else:
+ return None
relative_temporal_extent.print_info(self)
relative_temporal_extent.print_shell_info(self)
@@ -503,4 +560,3 @@
class stvds_relative_time(stds_relative_time):
def __init__(self, ident=None, start_time=None, end_time=None, granularity=None):
stds_relative_time.__init__(self, "stvds_relative_time", ident, start_time, end_time, granularity)
Modified: grass/trunk/lib/temporal/stds_tables_template.sql
--- grass/trunk/lib/temporal/stds_tables_template.sql 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/lib/temporal/stds_tables_template.sql 2011-10-08 00:00:22 UTC (rev 48675)
@@ -19,7 +19,7 @@
creation_time TIMESTAMP NOT NULL, -- The time of creation of the space-time dataset
-- Uncommented due to performance issues
-- modification_time TIMESTAMP NOT NULL, -- The time of the last modification of the grass map
--- revision SMALLINT NOT NULL, -- The revision number -- The revision number
+-- revision SMALLINT NOT NULL, -- The revision number -- The revision number
PRIMARY KEY (id)
@@ -27,7 +27,8 @@
id VARCHAR NOT NULL, -- Id of the space-time dataset, this is the primary foreign key
start_time DOUBLE PRECISION, -- The relative valid start time in [days]
end_time DOUBLE PRECISION, -- The relative valid end time in [days]
- granularity DOUBLE PRECISION, -- The granularity in [days]
+ granularity DOUBLE PRECISION, -- The granularity in [days]
+ map_time VARCHAR, -- The temporal type of the registered maps, may be interval, point or mixed
PRIMARY KEY (id),
FOREIGN KEY (id) REFERENCES STDS_base (id) ON DELETE CASCADE
@@ -38,6 +39,7 @@
end_time TIMESTAMP, -- End of the valid time, can be NULL if no map is registered
granularity VARCHAR, -- The granularity "NNN seconds, NNN minutes, NNN hours, NNN days, NNN weeks, NNN months, NNN years"
timezone SMALLINT, -- The time zone number
PRIMARY KEY (id),
Property changes on: grass/trunk/raster/r.colors
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
.pgm
Modified: grass/trunk/raster/r.series/test.r.series.sh
--- grass/trunk/raster/r.series/test.r.series.sh 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/raster/r.series/test.r.series.sh 2011-10-08 00:00:22 UTC (rev 48675)
@@ -38,7 +38,6 @@
r.series --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_count method=count
r.series -z --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_range method=range
r.series --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_1_prec_sum method=sum
#r.out.ascii --o input=test_1_prec_mean output=test_1_prec_mean.ref dp=3
#r.out.ascii --o input=test_1_prec_max output=test_1_prec_max.ref dp=3
#r.out.ascii --o input=test_1_prec_min output=test_1_prec_min.ref dp=3
@@ -60,3 +59,15 @@
#r.out.ascii --o input=test_2_prec_count output=test_2_prec_count.ref dp=3
#r.out.ascii --o input=test_2_prec_range output=test_2_prec_range.ref dp=3
#r.out.ascii --o input=test_2_prec_sum output=test_2_prec_sum.ref dp=3
+# The third @test with multiple methods and outputs
+r.series --o --v input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=test_3_prec_mean,test_3_prec_max,test_3_prec_min method=average,maximum,minimum
+r.series -z --o --v file=$TMP_FILE output=test_4_prec_mean,test_4_prec_max,test_4_prec_min method=average,maximum,minimum
+#r.out.ascii --o input=test_1_prec_mean output=test_3_prec_mean.ref dp=3
+#r.out.ascii --o input=test_1_prec_max output=test_3_prec_max.ref dp=3
+#r.out.ascii --o input=test_1_prec_min output=test_3_prec_min.ref dp=3
+#r.out.ascii --o input=test_2_prec_mean output=test_4_prec_mean.ref dp=3
+#r.out.ascii --o input=test_2_prec_max output=test_4_prec_max.ref dp=3
+#r.out.ascii --o input=test_2_prec_min output=test_4_prec_min.ref dp=3
\ No newline at end of file
Added: grass/trunk/raster/r.series/test_3_prec_max.ref
--- grass/trunk/raster/r.series/test_3_prec_max.ref (rev 0)
+++ grass/trunk/raster/r.series/test_3_prec_max.ref 2011-10-08 00:00:22 UTC (rev 48675)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+600 600 600 600 600 600 600 600 600 600 600 600
Added: grass/trunk/raster/r.series/test_3_prec_mean.ref
--- grass/trunk/raster/r.series/test_3_prec_mean.ref (rev 0)
+++ grass/trunk/raster/r.series/test_3_prec_mean.ref 2011-10-08 00:00:22 UTC (rev 48675)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+350 350 350 350 350 350 350 350 350 350 350 350
Added: grass/trunk/raster/r.series/test_3_prec_min.ref
--- grass/trunk/raster/r.series/test_3_prec_min.ref (rev 0)
+++ grass/trunk/raster/r.series/test_3_prec_min.ref 2011-10-08 00:00:22 UTC (rev 48675)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
+100 100 100 100 100 100 100 100 100 100 100 100
Added: grass/trunk/raster/r.series/test_4_prec_max.ref
--- grass/trunk/raster/r.series/test_4_prec_max.ref (rev 0)
+++ grass/trunk/raster/r.series/test_4_prec_max.ref 2011-10-08 00:00:22 UTC (rev 48675)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Added: grass/trunk/raster/r.series/test_4_prec_mean.ref
--- grass/trunk/raster/r.series/test_4_prec_mean.ref (rev 0)
+++ grass/trunk/raster/r.series/test_4_prec_mean.ref 2011-10-08 00:00:22 UTC (rev 48675)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Added: grass/trunk/raster/r.series/test_4_prec_min.ref
--- grass/trunk/raster/r.series/test_4_prec_min.ref (rev 0)
+++ grass/trunk/raster/r.series/test_4_prec_min.ref 2011-10-08 00:00:22 UTC (rev 48675)
@@ -0,0 +1,14 @@
+north: 80N
+south: 0
+east: 120E
+west: 0
+rows: 8
+cols: 12
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/temporal/t.create/t.create.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -116,6 +116,7 @@
dbif.connect()
if sp.is_in_db(dbif) and grass.overwrite() == False:
+ dbif.close()
grass.fatal("Space time " + sp.get_new_map_instance(None).get_type() + " dataset <" + name + "> is already in the database. Use the overwrite flag.")
if sp.is_in_db(dbif) and grass.overwrite() == True:
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/temporal/t.remove/t.remove.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -79,6 +79,7 @@
ds = tgis.vector_dataset(id)
if ds.is_in_db(dbif) == False:
+ dbif.close()
grass.fatal(ds.get_type() + " dataset <" + name + "> not found in temporal database")
# We need to read some data from the temporal database
Modified: grass/trunk/temporal/tr.extract/tr.extract.py
--- grass/trunk/temporal/tr.extract/tr.extract.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/temporal/tr.extract/tr.extract.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -89,7 +89,7 @@
sp = tgis.space_time_raster_dataset(id)
if sp.is_in_db() == False:
- grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
+ grass.fatal(_("Space time arster dataset <%s> not found in temporal database") % (id))
if expression and not base:
grass.fatal(_("Please specify base="))
@@ -156,14 +156,11 @@
grass.verbose(_("Apply r.mapcalc expression: \"%s\"") % expr)
- if grass.overwrite() == True:
- ret = grass.run_command("r.mapcalc", expression=expr, overwrite=True, quiet=True)
- else:
- ret = grass.run_command("r.mapcalc", expression=expr, overwrite=False, quiet=True)
+ ret = grass.run_command("r.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
if ret != 0:
grass.error(_("Error while r.mapcalc computation, continue with next map"))
- continue
+ break
# Read the raster map data
new_map.load()
Modified: grass/trunk/temporal/tr.series/tr.series.py
--- grass/trunk/temporal/tr.series/tr.series.py 2011-10-07 19:53:04 UTC (rev 48674)
+++ grass/trunk/temporal/tr.series/tr.series.py 2011-10-08 00:00:22 UTC (rev 48675)
@@ -5,7 +5,7 @@
# MODULE: tr.series
# AUTHOR(S): Soeren Gebbert
-# PURPOSE: Performe different aggregation algorithms from r.series on all raster maps of a space time raster dataset
+# PURPOSE: Performe different aggregation algorithms from r.series on all or a selected subset of raster maps in a space time raster dataset
# COPYRIGHT: (C) 2011 by the GRASS Development Team
# This program is free software under the GNU General Public
@@ -15,7 +15,7 @@
#%module
-#% description: Performe different aggregation algorithms from r.series on all raster maps of a space time raster dataset
+#% description: Performe different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset
#% keywords: spacetime raster dataset
#% keywords: raster
#% keywords: extract
@@ -32,7 +32,7 @@
#%option
#% key: method
#% type: string
-#% description: Aggregate operation on all raster maps of a space time raster dataset
+#% description: Aggregate operation to be peformed on the raster maps
#% required: yes
#% multiple: no
#% options: average,count,median,mode,minimum,min_raster,maximum,max_raster,stddev,range,sum,variance,diversity,slope,offset,detcoeff,quart1,quart3,perc90,quantile,skewness,kurtosis
@@ -57,7 +57,7 @@
#%flag
#% key: t
-#% description: Assign the space time raster dataset time interval to the output map
+#% description: Assign the space time raster dataset start and end time to the output map
#%end
import grass.script as grass
@@ -87,19 +87,14 @@
+ grass.fatal(_("Space time raster dataset <%s> not found in temporal database") % (id))
sp.select()
- if add_time:
- if sp.is_time_absolute():
- start_time, end_time, tz = sp.get_absolute_time()
- else:
- start_time, end_time = sp.get_relative_time()
rows = sp.get_registered_maps(None, where, sort)
if rows:
+ # Create the r.series input file
filename = grass.tempfile(True)
file = open(filename, 'w')
@@ -109,32 +104,34 @@
file.close()
- grass.run_command("r.series", flags="z", file=filename, output=output, overwrite=True, method=method)
- else:
- grass.run_command("r.series", flags="z", file=filename, output=output, overwrite=False, method=method)
+ ret = grass.run_command("r.series", flags="z", file=filename, output=output, overwrite=grass.overwrite(), method=method)
- if add_time:
- # Create the time range for the output map
- if output.find("@") >= 0:
- id = output
- else:
- mapset = grass.gisenv()["MAPSET"]
- id = output + "@" + mapset
+ if ret == 0 and add_time:
+ if sp.is_time_absolute():
+ start_time, end_time, tz = sp.get_absolute_time()
+ else:
+ start_time, end_time = sp.get_relative_time()
+ # Create the time range for the output map
+ if output.find("@") >= 0:
+ id = output
+ else:
+ mapset = grass.gisenv()["MAPSET"]
+ id = output + "@" + mapset
- map = sp.get_new_map_instance(id)
+ map = sp.get_new_map_instance(id)
- map.load()
- map.set_absolute_time(start_time, end_time, tz)
- else:
- map.set_relative_time(start_time, end_time)
+ map.load()
+ map.set_absolute_time(start_time, end_time, tz)
+ else:
+ map.set_relative_time(start_time, end_time)
- # Register the map in the temporal database
- if map.is_in_db():
- map.update()
- else:
- map.insert()
+ # Register the map in the temporal database
+ if map.is_in_db():
+ map.update()
+ else:
+ map.insert()
if __name__ == "__main__":
options, flags = grass.parser()
