[GRASS-SVN] r48683 - grass/trunk/locale/po
svn_grass at osgeo.org
Sat Oct 8 17:36:48 EDT 2011
Author: neteler
Date: 2011-10-08 14:36:48 -0700 (Sat, 08 Oct 2011)
New Revision: 48683
grass/trunk/locale/po/grasslibs_de.po
grass/trunk/locale/po/grassmods_de.po
Robert Nuske: cont'ed
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po 2011-10-08 21:36:17 UTC (rev 48682)
+++ grass/trunk/locale/po/grasslibs_de.po 2011-10-08 21:36:48 UTC (rev 48683)
@@ -6,7 +6,7 @@
# Stephan Holl <holl gdf-hannover.de>, 2004, 2005, 2006.
# Stephan Holl <stephan.holl intevation.de>, 2007.
# Markus Neteler <neteler osgeo.org>, 2008.
-# Robert Nuske <rnuske gwdg.de>, 2009, 2010, 2011.
+# Robert Nuske <rnuske gwdg.de>, 2009, 2010.
# Robert Nuske <robert.nuske nw-fva.de>, 2011.
# Helmut Kudrnovsky <hellik web.de>, 2011.
msgid ""
@@ -14,8 +14,8 @@
"Project-Id-Version: grasslibs_de\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2011-10-05 23:30+0200\n"
-"PO-Revision-Date: 2011-09-26 21:41+0200\n"
-"Last-Translator: Robert Nuske <rnuske nw-fva.de>\n"
+"PO-Revision-Date: 2011-10-08 19:11+0200\n"
+"Last-Translator: Robert Nuske <robert.nuske nw-fva.de>\n"
"Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=ISO-8859-15\n"
@@ -314,8 +314,7 @@
#: ../lib/raster3d/history.c:43
#, c-format
msgid "can't get history information for [%s] in mapset [%s]"
-msgstr ""
-"Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
+msgstr "Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
#: ../lib/raster/sample.c:70
msgid "Unknown interpolation type"
@@ -351,12 +350,8 @@
#: ../lib/raster/set_window.c:131
#, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
-msgstr ""
-"G_set_window(): Projektion/Zone unterscheidet sich von den gerade geöffneten "
-"Rasterdateien."
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): Projektion/Zone unterscheidet sich von den gerade geöffneten Rasterdateien."
#: ../lib/raster/set_window.c:158
msgid "Input window changed while maps are open for read"
@@ -458,8 +453,7 @@
#: ../lib/raster/put_row.c:690
#, fuzzy, c-format
msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-msgstr ""
-"%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
+msgstr "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
#: ../lib/raster/put_row.c:697
#, fuzzy
@@ -521,9 +515,7 @@
#: ../lib/raster/get_row.c:37 ../lib/raster/get_row.c:882
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist außerhalb der "
-"Region."
+msgstr "Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist außerhalb der Region."
#: ../lib/raster/get_row.c:96 ../lib/raster/get_row.c:101
#: ../lib/raster/get_row.c:134 ../lib/raster/get_row.c:140
@@ -615,9 +607,7 @@
#: ../lib/raster/reclass.c:171
#, fuzzy, c-format
msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr ""
-"Ungültiges Reklassifizierungs-Format in der Header-Datei für Karte [%s in %"
-"s]."
+msgstr "Ungültiges Reklassifizierungs-Format in der Header-Datei für Karte [%s in %s]."
#: ../lib/raster/reclass.c:273
msgid "Illegal reclass request"
@@ -638,21 +628,15 @@
msgstr "Kann Abhängigkeitsdatei in [%s in %s] nicht erstellen."
#: ../lib/raster/window.c:18
-msgid ""
-"Internal error: Rast_get_window() called with split window.Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window.Use Rast_get_input_window() or Rast_get_output_window() instead."
msgstr ""
#: ../lib/raster/window.c:77
-msgid ""
-"Internal error: Rast_window_rows() called with split window.Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window.Use Rast_input_window_rows() or Rast_output_window_rows() instead."
msgstr ""
#: ../lib/raster/window.c:112
-msgid ""
-"Internal error: Rast_window_cols() called with split window.Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window.Use Rast_input_window_cols() or Rast_output_window_cols() instead."
msgstr ""
#: ../lib/raster/gdal.c:88
@@ -686,9 +670,7 @@
#: ../lib/raster/gdal.c:492
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
msgstr ""
#: ../lib/raster/gdal.c:498
@@ -795,12 +777,8 @@
#: ../lib/raster/open.c:185
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%"
-"s> which does not exist"
-msgstr ""
-"Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung "
-"der Rasterkarte <%s@%s> ist, welche nicht existiert."
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung der Rasterkarte <%s@%s> ist, welche nicht existiert."
#: ../lib/raster/open.c:190
#, fuzzy, c-format
@@ -819,9 +797,7 @@
#: ../lib/raster/open.c:214
#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
msgstr "Raster Karte Raster Karte."
#: ../lib/raster/open.c:221
@@ -836,8 +812,7 @@
#: ../lib/raster/open.c:252
#, fuzzy, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr "Karte"
#: ../lib/raster/open.c:261
@@ -911,8 +886,7 @@
#: ../lib/raster/open.c:927
#, fuzzy
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
msgstr "Raster"
#: ../lib/raster/put_title.c:28
@@ -941,9 +915,7 @@
#: ../lib/raster/init.c:62
#, fuzzy
msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-"Fehler. System ist nicht initialisiert. Der Programmierer hat vergessen, "
-"G_gisinit() aufzurufen.\n"
+msgstr "Fehler. System ist nicht initialisiert. Der Programmierer hat vergessen, G_gisinit() aufzurufen.\n"
#: ../lib/raster/format.c:154
#, c-format
@@ -1008,9 +980,7 @@
#: ../lib/raster/get_cellhd.c:66
#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
-"map <%s@%s> %s"
+msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
msgstr "Raster Karte Raster Karte"
#: ../lib/raster/get_cellhd.c:70
@@ -1190,10 +1160,8 @@
#: ../lib/symbol/read.c:260
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
#: ../lib/symbol/read.c:284
#, c-format
@@ -1340,8 +1308,7 @@
#: ../lib/cairodriver/read_ppm.c:56
#, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
#: ../lib/proj/get_proj.c:148
@@ -1440,17 +1407,13 @@
#: ../lib/proj/convert.c:130
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR "
-"Fehler-Code %d)."
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR Fehler-Code %d)."
#: ../lib/proj/convert.c:137
#, c-format
msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
+msgstr "OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
#: ../lib/proj/convert.c:397
msgid "No projection name! Projection parameters likely to be meaningless."
@@ -1463,21 +1426,13 @@
#: ../lib/proj/convert.c:449
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. "
-"Sie sollten dies genauer untersuchen."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. Sie sollten dies genauer untersuchen."
#: ../lib/proj/convert.c:453
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. "
-"Datumstransformationsparameter bleiben unbestimmt."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. Datumstransformationsparameter bleiben unbestimmt."
#: ../lib/gis/find_file.c:80
#, c-format
@@ -1507,17 +1462,12 @@
#: ../lib/gis/view.c:545
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-" Das in \"%s\" abgespeicherte Fenster ist komplett außerhalb des derzeitigen "
-"GRASS Fensters."
+msgstr " Das in \"%s\" abgespeicherte Fenster ist komplett außerhalb des derzeitigen GRASS Fensters."
#: ../lib/gis/view.c:549
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem "
-"derzeitigen GRASS-Fenster."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem derzeitigen GRASS-Fenster."
#: ../lib/gis/mapset_msc.c:61
#, c-format
@@ -1639,15 +1589,11 @@
#: ../lib/gis/parser.c:484
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --"
-"verbose."
+msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --verbose."
#: ../lib/gis/parser.c:498
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"quiet."
+msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --quiet."
#: ../lib/gis/parser.c:529
#, c-format
@@ -1894,8 +1840,7 @@
msgstr "Datenbank"
#: ../lib/gis/parser_standard_options.c:148
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
msgstr ""
#: ../lib/gis/parser_standard_options.c:157
@@ -1994,9 +1939,7 @@
msgstr "Datentyp verwendet in Ausgabedatei"
#: ../lib/gis/parser_standard_options.c:335
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
msgstr ""
#: ../lib/gis/parser_standard_options.c:345
@@ -2006,9 +1949,7 @@
#: ../lib/gis/parser_standard_options.c:355
#, fuzzy
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
msgstr "Dimension der Kacheln, die für die Ausgabe verwerndet werden soll."
#: ../lib/gis/parser_standard_options.c:365
@@ -2055,12 +1996,8 @@
#: ../lib/gis/parser_standard_options.c:429
#: ../lib/gis/parser_standard_options.c:441
#, fuzzy
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. Layer name for direct OGR access."
-msgstr ""
-"Eine Vektorkarte kann mit mehreren Attributdatenquellen verbunden werden."
-"Diese Zahl gibt Auskunft über die zu benutzende Tabelle."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for direct OGR access."
+msgstr "Eine Vektorkarte kann mit mehreren Attributdatenquellen verbunden werden.Diese Zahl gibt Auskunft über die zu benutzende Tabelle."
#: ../lib/gis/parser_standard_options.c:439
#, fuzzy
@@ -2267,9 +2204,7 @@
#: ../lib/gis/distance.c:154
#, fuzzy, c-format
msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-msgstr ""
-"G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) "
-"S=(%f,%f)(%f,%f)"
+msgstr "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
msgid "Unable to seek"
@@ -2655,12 +2590,8 @@
msgstr "%s komplett. %s"
#: ../lib/gis/gisinit.c:50 ../lib/gis/gisinit.c:82
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut "
-"bauen oder verschiedene Installationen entwirren."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut bauen oder verschiedene Installationen entwirren."
#: ../lib/gis/gisinit.c:60
#, c-format
@@ -2674,9 +2605,7 @@
#: ../lib/gis/gisinit.c:96
msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() "
-"aufzurufen."
+msgstr "System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() aufzurufen."
#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
#: ../lib/vector/Vlib/ascii.c:199 ../lib/vector/Vlib/line.c:48
@@ -2701,9 +2630,7 @@
#: ../lib/driver/parse_ftcap.c:84
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die "
-"Standardeinstellung."
+msgstr "%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die Standardeinstellung."
#: ../lib/driver/parse_ftcap.c:90
#, c-format
@@ -2742,28 +2669,22 @@
#: ../lib/vector/diglib/test.c:75
#, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:89
#, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
msgstr ""
#: ../lib/vector/diglib/test.c:104
#, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:119
#, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
msgstr ""
#: ../lib/vector/diglib/test.c:134
@@ -2773,8 +2694,7 @@
#: ../lib/vector/diglib/test.c:150
#, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
msgstr ""
#: ../lib/vector/diglib/test.c:165
@@ -2784,12 +2704,8 @@
#: ../lib/vector/diglib/plus_node.c:217
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu "
-"lesen: Knoten %d, Linie %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu lesen: Knoten %d, Linie %d"
#: ../lib/vector/diglib/plus.c:275
msgid "Unable read topology for nodes"
@@ -2874,8 +2790,7 @@
#: ../lib/vector/diglib/plus_area.c:400
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
+msgstr "Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
#: ../lib/vector/diglib/plus_area.c:425
#, c-format
@@ -2889,23 +2804,17 @@
#: ../lib/vector/diglib/plus_struct.c:520
#, fuzzy, c-format
-msgid ""
-"Topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
+msgid "Topology format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
msgstr "Vektor."
#: ../lib/vector/diglib/plus_struct.c:526
#, fuzzy, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr "Vektor."
#: ../lib/vector/diglib/plus_struct.c:536
#, fuzzy, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology."
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
msgstr "Vektor."
#: ../lib/vector/diglib/plus_struct.c:560 ../lib/vector/diglib/portable.c:210
@@ -2915,8 +2824,7 @@
#: ../lib/vector/diglib/file.c:159
msgid "Writing to file loaded to memory not supported"
-msgstr ""
-"Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
+msgstr "Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
#: ../lib/vector/diglib/file.c:203
msgid "Unable to load file to memory, file not open"
@@ -2928,23 +2836,17 @@
#: ../lib/vector/diglib/spindex_rw.c:277
#, fuzzy, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Try to "
+msgid "Spatial index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
msgstr "Vektor."
#: ../lib/vector/diglib/spindex_rw.c:284
#, fuzzy, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
msgstr "Vektor."
#: ../lib/vector/diglib/spindex_rw.c:293
#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
msgstr ""
#: ../lib/vector/diglib/spindex_rw.c:824
@@ -3001,14 +2903,12 @@
#: ../lib/vector/Vlib/legal_vname.c:43
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
#: ../lib/vector/Vlib/legal_vname.c:50
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
#: ../lib/vector/Vlib/legal_vname.c:58
#, c-format
@@ -3017,11 +2917,8 @@
#: ../lib/vector/Vlib/legal_vname.c:65
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als "
-"Vektorkartenname benutzt werden."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als Vektorkartenname benutzt werden."
#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
#, c-format
@@ -3070,9 +2967,7 @@
#: ../lib/vector/Vlib/cats.c:403
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine "
-"Kategoriespanne konvertieren."
+msgstr "Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine Kategoriespanne konvertieren."
#: ../lib/vector/Vlib/break_polygons.c:102
msgid "Break polygons: Bug in binary tree!"
@@ -3114,17 +3009,14 @@
#: ../lib/vector/Vlib/intersect.c:446
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
+msgstr "Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
#: ../lib/vector/Vlib/intersect.c:1099 ../lib/vector/Vlib/intersect.c:1105
#: ../lib/vector/Vlib/intersect.c:1107 ../lib/vector/Vlib/intersect.c:1155
#: ../lib/vector/Vlib/intersect.c:1164 ../lib/vector/Vlib/intersect.c:1185
#: ../lib/vector/Vlib/intersect.c:1202
msgid "Error while adding point to array. Out of memory"
-msgstr ""
-"Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend "
-"Arbeitsspeicher."
+msgstr "Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend Arbeitsspeicher."
#: ../lib/vector/Vlib/level.c:34
msgid "Map structure was never initialized"
@@ -3174,8 +3066,7 @@
#: ../lib/vector/Vlib/array.c:292
#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-"Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
+msgstr "Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
#: ../lib/vector/Vlib/box.c:261
#, fuzzy, c-format
@@ -3193,12 +3084,8 @@
#: ../lib/vector/Vlib/geos.c:55
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
-"Vektorkarte <%s>: %d)."
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
#: ../lib/vector/Vlib/geos.c:60
msgid "only native format supported"
@@ -3217,8 +3104,7 @@
#: ../lib/vector/Vlib/geos.c:104
#, c-format
msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
+msgstr "Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
#: ../lib/vector/Vlib/geos.c:202
#, c-format
@@ -3386,9 +3272,7 @@
#: ../lib/vector/Vlib/build.c:429
#, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
msgstr "Vektor Karte"
#: ../lib/vector/Vlib/build.c:451
@@ -3477,12 +3361,8 @@
msgstr "Kann den OGR DBMI-Treiber nicht öffnen."
#: ../lib/vector/Vlib/field.c:639
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' "
-"sind in der OGR DB Tabelle vorhanden."
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' sind in der OGR DB Tabelle vorhanden."
#: ../lib/vector/Vlib/field.c:695
#, c-format
@@ -3501,8 +3381,7 @@
#: ../lib/vector/Vlib/field.c:906
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
+msgstr "Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
#: ../lib/vector/Vlib/area.c:47
msgid "Attempt to read points of nonexistent area"
@@ -3546,22 +3425,16 @@
#: ../lib/vector/Vlib/read.c:111
#, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
#: ../lib/vector/Vlib/build_nat.c:100
msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
-"Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
+msgstr "Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
#: ../lib/vector/Vlib/build_nat.c:109
msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
-"Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
+msgstr "Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
#: ../lib/vector/Vlib/build_nat.c:119
msgid "Area of size = 0.0 ignored"
@@ -3632,17 +3505,13 @@
#: ../lib/vector/Vlib/buffer2.c:589
#, fuzzy
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
-msgstr ""
-"Nächste Kante besucht, aber sie ist nicht die Erste !!! Beende Schleife."
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgstr "Nächste Kante besucht, aber sie ist nicht die Erste !!! Beende Schleife."
#: ../lib/vector/Vlib/buffer2.c:600
#, fuzzy
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
-msgstr ""
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
#: ../lib/vector/Vlib/buffer2.c:648
msgid "side != 0 feature not implemented"
@@ -3766,20 +3635,13 @@
#: ../lib/vector/Vlib/open_nat.c:152
#, fuzzy, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-"Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte "
-"Überschuss)."
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte Überschuss)."
#: ../lib/vector/Vlib/open_nat.c:156
#, fuzzy, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
-msgstr ""
-"Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte "
-"Fehlend)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte Fehlend)."
#: ../lib/vector/Vlib/dangles.c:148
msgid "Changed"
@@ -3829,8 +3691,7 @@
#: ../lib/vector/Vlib/net.c:362
#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
+msgstr "Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
#: ../lib/vector/Vlib/net.c:221
msgid "Registering arcs..."
@@ -3838,21 +3699,13 @@
#: ../lib/vector/Vlib/net.c:250
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht "
-"gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
#: ../lib/vector/Vlib/net.c:269
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
-msgstr ""
-"Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden "
-"(Richtung der Linie übersprungen)."
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden (Richtung der Linie übersprungen)."
#: ../lib/vector/Vlib/net.c:318
msgid "Cannot add network arc"
@@ -3865,9 +3718,7 @@
#: ../lib/vector/Vlib/net.c:398
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 "
-"gesetzt)."
+msgstr "Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 gesetzt)."
#: ../lib/vector/Vlib/net.c:425
msgid "Flattening the graph..."
@@ -3939,19 +3790,13 @@
#: ../lib/vector/Vlib/write.c:236
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem "
-"Level geöffnet."
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
#: ../lib/vector/Vlib/write.c:242
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus "
-"geöffnet."
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
#: ../lib/vector/Vlib/write.c:256
#, fuzzy, c-format
@@ -3960,19 +3805,13 @@
#: ../lib/vector/Vlib/write.c:282
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf "
-"topologischem Level geöffnet."
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
#: ../lib/vector/Vlib/write.c:288
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im "
-"Schreibmodus geöffnet."
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
#: ../lib/vector/Vlib/write.c:302
#, c-format
@@ -3995,11 +3834,8 @@
msgstr "Programmierer fordert unbekanntes open_level %d an"
#: ../lib/vector/Vlib/open.c:229
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum "
-"Aktualisierung geöffnet werden."
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum Aktualisierung geöffnet werden."
#: ../lib/vector/Vlib/open.c:256 ../lib/ogsf/Gv3.c:66 ../lib/ogsf/Gv3.c:330
#: ../lib/ogsf/Gp3.c:62 ../lib/ogsf/Gp3.c:194
@@ -4010,12 +3846,8 @@
#: ../lib/vector/Vlib/open.c:272 ../lib/vector/Vlib/open.c:362
#: ../lib/vector/Vlib/open.c:383
#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die "
-"Topologie mit v.build neu anzulegen."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die Topologie mit v.build neu anzulegen."
#: ../lib/vector/Vlib/open.c:275
#, fuzzy, c-format
@@ -4084,9 +3916,7 @@
#: ../lib/vector/Vlib/open.c:975
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"Größe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei "
-"gespeicherten Wert."
+msgstr "Größe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei gespeicherten Wert."
#: ../lib/vector/Vlib/open.c:986 ../lib/vector/Vlib/open.c:1080
#, c-format
@@ -4119,22 +3949,13 @@
#: ../lib/vector/Vlib/open_ogr.c:168
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-msgstr ""
-"Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. "
-"Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
#: ../lib/vector/Vlib/open_ogr.c:173
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-msgstr ""
-"Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d.%"
-"d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu "
-"aktualisieren."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d.%d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
#: ../lib/vector/Vlib/open_ogr.c:240
#, fuzzy, c-format
@@ -4357,8 +4178,7 @@
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:371
-msgid ""
-"Random read is not supported by OGR for this layer, unable to build topology"
+msgid "Random read is not supported by OGR for this layer, unable to build topology"
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:376
@@ -4442,9 +4262,7 @@
msgstr "Kann die Tabelle <%s> nicht anlegen."
#: ../lib/vector/Vlib/dgraph.c:430
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
msgstr ""
#: ../lib/vector/Vlib/line.c:178 ../lib/vector/Vlib/line.c:211
@@ -4902,9 +4720,7 @@
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-"Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht "
-"möglich."
+msgstr "Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht möglich."
#: ../lib/init/lock.c:60
#, c-format
@@ -5076,8 +4892,7 @@
#: ../lib/init/grass.py:566
msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
+"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
"Switching to text mode now.\n"
"\n"
"Hit RETURN to continue..."
@@ -5113,9 +4928,7 @@
#: ../lib/init/grass.py:613
#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
msgstr ""
#: ../lib/init/grass.py:617
@@ -5138,8 +4951,7 @@
#: ../lib/init/grass.py:670
#, python-format
msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
"\n"
"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
@@ -5228,8 +5040,7 @@
"Unable to start GRASS. You can:\n"
" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
msgstr ""
#: ../lib/init/grass.py:1049
@@ -5252,22 +5063,13 @@
msgstr "Ändern Sie zunächst die Spaltenanzahl zu nsizc %d %d."
#: ../lib/rst/interp_float/segmen2d.c:111
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie "
-"die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der "
-"Berechnung fort..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der Berechnung fort..."
#: ../lib/rst/interp_float/interp2d.c:214
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-"
-"value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-value %f, zmin %f, zmax %f."
#: ../lib/rst/interp_float/resout2d.c:77
msgid "Temporarily changing the region to desired resolution..."
@@ -5341,8 +5143,7 @@
#: ../lib/rst/interp_float/vinput2d.c:249
#, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"Es gibt Punkte außerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
+msgstr "Es gibt Punkte außerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
#: ../lib/rst/interp_float/vinput2d.c:252
#, c-format
@@ -5351,12 +5152,8 @@
#: ../lib/rst/interp_float/vinput2d.c:256
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN=%"
-"d"
-msgstr ""
-"%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die "
-"angegebenen NPMIN=%d."
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die angegebenen NPMIN=%d."
#: ../lib/rst/interp_float/vinput2d.c:261
msgid "Zero points in the given region"
@@ -5364,22 +5161,13 @@
#: ../lib/rst/interp_float/vinput2d.c:266
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum "
-"glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
#: ../lib/rst/interp_float/vinput2d.c:272
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung "
-"notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = %"
-"d (siehe Handbuch)."
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = %d (siehe Handbuch)."
#: ../lib/rst/interp_float/vinput2d.c:276
#, c-format
@@ -5402,7 +5190,7 @@
#: ../lib/rst/interp_float/vinput2d.c:318
msgid "Unable to allocate memory"
-msgstr "Kann keinen Speicher allokieren."
+msgstr "Kann keinen Speicher reservieren."
#: ../lib/rst/interp_float/vinput2d.c:326
#, c-format
@@ -5432,12 +5220,8 @@
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Klassengrenzen außerhalb der min-max Spanne. Anzahl der Klassen auf %i "
-"reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Klassengrenzen außerhalb der min-max Spanne. Anzahl der Klassen auf %i reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
#: ../lib/ogsf/GVL2.c:248
#, c-format
@@ -5490,9 +5274,7 @@
#: ../lib/ogsf/gsd_surf.c:1742
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-"Schnittflächenpunkte der Oberflächen passen nicht zusammen. Überprüfen Sie "
-"die Auflösung(en)."
+msgstr "Schnittflächenpunkte der Oberflächen passen nicht zusammen. Überprüfen Sie die Auflösung(en)."
#: ../lib/ogsf/gvl_file.c:104
msgid "Maximum number of datafiles exceeded"
@@ -5510,12 +5292,8 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. "
-"Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/gsd_img_ppm.c:53
#: ../lib/ogsf/gsd_img_ppm.c:96 ../lib/ogsf/GK2.c:219
@@ -5536,8 +5314,7 @@
#: ../lib/ogsf/Gs3.c:597
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
+msgstr "Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
#: ../lib/ogsf/Gs3.c:659 ../lib/ogsf/Gs3.c:731
#, c-format
@@ -5546,9 +5323,7 @@
#: ../lib/ogsf/Gs3.c:968
msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-"View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen "
-"auftreten."
+msgstr "View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen auftreten."
#: ../lib/ogsf/gsds.c:109
msgid "Maximum number of datasets exceeded"
@@ -5561,8 +5336,7 @@
#: ../lib/ogsf/Gv3.c:261
#, c-format
msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-"Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr "Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
#: ../lib/ogsf/Gv3.c:266
#, c-format
@@ -5601,15 +5375,13 @@
#: ../lib/ogsf/GS2.c:1656
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
+msgstr "Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
#: ../lib/ogsf/GS2.c:1734 ../lib/ogsf/GS2.c:1740 ../lib/ogsf/GS2.c:1748
#: ../lib/ogsf/GS2.c:1757 ../lib/ogsf/GS2.c:1765 ../lib/ogsf/GS2.c:1775
#: ../lib/ogsf/GS2.c:1823
msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
-"GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
+msgstr "GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
#: ../lib/ogsf/GS2.c:1851
msgid "Loading failed"
@@ -5626,8 +5398,7 @@
#: ../lib/ogsf/Gp3.c:146
#, c-format
msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-"Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr "Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
#: ../lib/ogsf/Gp3.c:151
#, c-format
@@ -5649,7 +5420,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:63
msgid "Unable to allocate stream"
-msgstr "Kann keinen Speicher für den Stream belegen."
+msgstr "Kann keinen Speicher für den Stream reservieren."
#: ../lib/ogsf/gsd_img_mpeg.c:156
msgid "Video codec not found"
@@ -5661,11 +5432,11 @@
#: ../lib/ogsf/gsd_img_mpeg.c:181
msgid "Unable to allocate picture"
-msgstr "Kann keinen Speicher für das Bild belegen."
+msgstr "Kann keinen Speicher für das Bild reservieren."
#: ../lib/ogsf/gsd_img_mpeg.c:192
msgid "Unable to allocate temporary picture"
-msgstr "Kann keinen Speicher für temporäres Bild belegen."
+msgstr "Kann keinen Speicher für temporäres Bild reservieren."
#: ../lib/ogsf/gsd_img_mpeg.c:252
msgid "Error while writing video frame"
@@ -5678,9 +5449,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:306
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Kann nicht von der Dateiendung auf das Ausgabeformat schließen: verwende "
-"MPEG."
+msgstr "Kann nicht von der Dateiendung auf das Ausgabeformat schließen: verwende MPEG."
#: ../lib/ogsf/gsd_img_mpeg.c:310
msgid "Unable to find suitable output format"
@@ -5849,13 +5618,11 @@
#: ../lib/python/temporal/abstract_datasets.py:873
#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:38
-msgid ""
-"Projections are different. Unable to compute overlap_2d for spatial extents"
+msgid "Projections are different. Unable to compute overlap_2d for spatial extents"
msgstr ""
#: ../lib/python/temporal/spatial_extent.py:161
@@ -5929,12 +5696,8 @@
#: ../lib/python/raster.py:46
#, fuzzy, python-format
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-msgstr ""
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
#: ../lib/python/raster.py:101
msgid "An error occurred while running r.mapcalc"
@@ -5965,8 +5728,7 @@
#: ../lib/db/dbmi_base/legal_dbname.c:38
#, fuzzy, c-format
msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Ungültiger Tabellenname <%s>. Er darf '.' oder 'NULL' nicht enthalten.\n"
+msgstr "Ungültiger Tabellenname <%s>. Er darf '.' oder 'NULL' nicht enthalten.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:45
#, fuzzy, c-format
@@ -5976,8 +5738,7 @@
#: ../lib/db/dbmi_base/legal_dbname.c:54
#, fuzzy, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr ""
-"Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
+msgstr "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
#: ../lib/db/dbmi_base/error.c:72
#, fuzzy
@@ -6181,12 +5942,8 @@
msgstr "Speicherfehler beim Allokieren des Zeitstempel."
#: ../lib/sites/sites.c:296 ../lib/sites/sites.c:426
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul "
-"sollte für die GRASS 6 Vector Library aktualisiert werden)."
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul sollte für die GRASS 6 Vector Library aktualisiert werden)."
#: ../lib/sites/sites.c:345
msgid "Cannot fetch row"
@@ -6497,7 +6254,7 @@
#: ../lib/gmath/la.c:158
msgid "Unable to allocate space for matrix copy"
-msgstr "Kann keinen Speicher für Kopie der Matrix belegen."
+msgstr "Kann keinen Speicher für Kopie der Matrix reservieren."
#: ../lib/gmath/la.c:247
msgid "First scalar multiplier must be non-zero"
@@ -6513,11 +6270,11 @@
#: ../lib/gmath/la.c:272
msgid "Unable to allocate space for matrix sum"
-msgstr "Kann keinen Speicher für Summe der Matrizen belegen."
+msgstr "Kann keinen Speicher für Summe der Matrizen reservieren."
#: ../lib/gmath/la.c:336
msgid "Unable to allocate space for matrix product"
-msgstr "Kann keinen Speicher für Produkt der Matrizen belegen."
+msgstr "Kann keinen Speicher für Produkt der Matrizen reservieren."
#: ../lib/gmath/la.c:448
msgid "Input: one or both data matrices uninitialised"
@@ -6533,11 +6290,11 @@
#: ../lib/gmath/la.c:464
msgid "Could not allocate space for solution matrix"
-msgstr "Konnte keinen Platz für die Lösungsmatrix belegen."
+msgstr "Konnte keinen Speicher für die Lösungsmatrix reservieren."
#: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
msgid "Could not allocate space for working matrix"
-msgstr "Konnte keinen Platz für die Arbeitsmatrix belegen."
+msgstr "Konnte keinen Platz für die Arbeitsmatrix reservieren."
#: ../lib/gmath/la.c:531
msgid "Matrix (or submatrix is singular). Solution undetermined"
@@ -6557,7 +6314,7 @@
#: ../lib/gmath/la.c:581
msgid "Unable to allocate space for matrix"
-msgstr "Kann keinen Speicher für die Matrix belegen."
+msgstr "Kann keinen Speicher für die Matrix reservieren."
#: ../lib/gmath/la.c:598
msgid "Matrix is singular"
@@ -6569,7 +6326,7 @@
#: ../lib/gmath/la.c:691
msgid "Element array has not been allocated"
-msgstr "Es wurde kein Speicher für das Element-Array belegt."
+msgstr "Es wurde kein Speicher für das Element-Array reserviert."
#: ../lib/gmath/la.c:696
msgid "Specified element is outside array bounds"
@@ -6586,7 +6343,7 @@
#: ../lib/gmath/la.c:760 ../lib/gmath/la.c:801
msgid "Could not allocate space for vector structure"
-msgstr "Konnte keinen Platz für die Vektorstruktur belegen."
+msgstr "Konnte keinen Platz für die Vektorstruktur reservieren."
#: ../lib/gmath/la.c:791
msgid "Specified matrix row index is outside range"
@@ -6709,23 +6466,17 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht "
-"erstellen."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht erstellen."
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"öffnen."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht öffnen."
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"finden."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht finden."
#: ../lib/imagery/list_gp.c:34
#, c-format
@@ -6750,20 +6501,19 @@
#: ../lib/imagery/list_subgp.c:48
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
+msgstr "Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
#, fuzzy
-#~ msgid "None"
-#~ msgstr "nichts"
+msgid "None"
+msgstr "nichts"
#, fuzzy
-#~ msgid "Unknown"
-#~ msgstr "nicht bekannt"
+msgid "Unknown"
+msgstr "nicht bekannt"
#, fuzzy
-#~ msgid "Uknown column <%s>"
-#~ msgstr "Unbekannter Spaltentyp (Spalte <%s>)"
+msgid "Uknown column <%s>"
+msgstr "Unbekannter Spaltentyp (Spalte <%s>)"
#~ msgid "projection field missing"
#~ msgstr "Projektionsfeld fehlt."
@@ -6823,13 +6573,13 @@
#~ msgstr "Genauigkeit für die Ausgabedatei (default, max, oder 0 bis 52)."
#~ msgid "Unable to allocate memory for a null buffer"
-#~ msgstr "Kann keinen Speicher belegen für einen NULL-Buffer."
+#~ msgstr "Kann keinen Speicher reservieren für einen NULL-Buffer."
#~ msgid "ERROR %s from graphics driver.\n"
#~ msgstr "FEHLER %s vom Grafiktreiber.\n"
#~ msgid "Unable to allocate memory\n"
-#~ msgstr "Kann keinen Speicher allokieren.\n"
+#~ msgstr "Kann keinen Speicher reservieren.\n"
#~ msgid "ERROR - eof from graphics monitor.\n"
#~ msgstr "FEHLER - EOF vom Grafikfenster.\n"
@@ -6862,8 +6612,7 @@
#~ msgstr "Verwenden Sie d.mon, um ein Grafikfenster zu selektieren."
#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "Versuche eine Verbindung zu etwas herzustellen, was kein Socket ist."
+#~ msgstr "Versuche eine Verbindung zu etwas herzustellen, was kein Socket ist."
#~ msgid "Probably program error."
#~ msgstr "Wahrscheinlich ein Programmfehler."
@@ -6945,12 +6694,8 @@
#~ msgid "Cannot write quant rules: map %s is integer"
#~ msgstr "Kann quant-Regeln nicht schreiben: Karte %s ist eine Integerkarte."
-#~ msgid ""
-#~ "G_set_window(): projection/zone differs from that of currently open "
-#~ "raster maps"
-#~ msgstr ""
-#~ "G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten "
-#~ "Rasterkarten."
+#~ msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+#~ msgstr "G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten Rasterkarten."
#~ msgid "The floating data range for %s@%s is empty"
#~ msgstr "Der Fließkomma-Wertebereich von %s@%s ist leer."
@@ -6962,23 +6707,16 @@
#~ msgstr "Quantisierungsdatei [%s] in Mapset [%s] %s."
#~ msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-#~ msgstr ""
-#~ "G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/d]"
-#~ "_raster_row()!"
+#~ msgstr "G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/d]_raster_row()!"
#~ msgid "%s: map [%s] not open for write - request ignored"
-#~ msgstr ""
-#~ "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
+#~ msgstr "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
#~ msgid "%s: map [%s] not open for random write - request ignored"
-#~ msgstr ""
-#~ "%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird "
-#~ "ignoriert."
+#~ msgstr "%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird ignoriert."
#~ msgid "%s: map [%s] not open for sequential write - request ignored"
-#~ msgstr ""
-#~ "%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage "
-#~ "wird ignoriert."
+#~ msgstr "%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage wird ignoriert."
#~ msgid "%s: unopened file descriptor - request ignored"
#~ msgstr "%s: Ungeöffneter Dateideskriptor - Anfrage ignoriert."
@@ -7056,12 +6794,8 @@
#~ msgid "Layer number"
#~ msgstr "Layer-Nummer"
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use."
-#~ msgstr ""
-#~ "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
-#~ "sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
#~ msgid "Sorry <%s> is not a valid option\n"
#~ msgstr "Tut mir leid, <%s> ist keine gültige Option\n"
@@ -7228,8 +6962,7 @@
#~ msgstr "Ungültiger Zeitstempel für %s Karte %s in Mapset %s angegeben."
#~ msgid "Can't open timestamp file for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "Kann die Zeitstempel-Datei für %s Karte %s in Mapset %s nicht öffnen."
+#~ msgstr "Kann die Zeitstempel-Datei für %s Karte %s in Mapset %s nicht öffnen."
#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
#~ msgstr "Ungültige Zeitstempel-Datei für %s Karte %s in Mapset %s."
@@ -7314,9 +7047,7 @@
#~ msgstr "Geben Sie %s Dateinamen ein."
#~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr ""
-#~ "Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien "
-#~ "ein.\n"
+#~ msgstr "Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien ein.\n"
#~ msgid "Enter 'list -f' for "
#~ msgstr "Geben Sie 'list -f' für "
@@ -7378,8 +7109,7 @@
#~ msgstr "Zu viele reklassifizierte Kategorien für [%s in %s]."
#~ msgid "Illegal reclass format in header file for [%s in %s]"
-#~ msgstr ""
-#~ "Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
+#~ msgstr "Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
#~ msgid "Unable to create header file for [%s in %s]"
#~ msgstr "Kann Header-Datei für [%s in %s] nicht anlegen."
@@ -7413,21 +7143,17 @@
#~ msgid "Unable to get GIS_LOCK enviroment variable value"
#~ msgstr "Kann den Inhalt der Umgebungsvariable GIS_LOCK nicht lesen."
-#~ msgid ""
-#~ "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%"
-#~ "f,%f)(%f,%f)"
-#~ msgstr ""
-#~ "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%"
-#~ "f) S=(%f,%f)(%f,%f)"
+#~ msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+#~ msgstr "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
#~ msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_malloc: Kann nicht %lu Byte auf %s:%d allokieren."
+#~ msgstr "G_malloc: Kann nicht %lu Byte auf %s:%d reservieren."
#~ msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
-#~ msgstr "G_calloc: Kann nicht %lu * %lu Byte auf %s:%d allokieren."
+#~ msgstr "G_calloc: Kann nicht %lu * %lu Byte auf %s:%d reservieren."
#~ msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_realloc: Kann nicht %lu Byte auf %s:%d allokieren."
+#~ msgstr "G_realloc: Kann nicht %lu Byte auf %s:%d reservieren."
#~ msgid "Unable to open raster map <%s@%s>"
#~ msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen."
@@ -7435,27 +7161,17 @@
#~ msgid "Unable to find <%s@%s>"
#~ msgstr "Kann <%s@%s> nicht finden."
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different projection than current region. Found "
-#~ "raster map <%s@%s>, should be <%s>."
-#~ msgstr ""
-#~ "Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle "
-#~ "Region. Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
+#~ msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+#~ msgstr "Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle Region. Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-#~ msgstr ""
-#~ "Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle "
-#~ "Region (%d)."
+#~ msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgstr "Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle Region (%d)."
#~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
#~ msgstr "Rasterkarte <%s@%s>: Bytes pro Zelle (%d) zu groß."
-#~ msgid ""
-#~ "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-#~ msgstr ""
-#~ "Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-"
-#~ "Unterstützung kompiliert."
+#~ msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#~ msgstr "Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-Unterstützung kompiliert."
#~ msgid "<%s>: bad mapset"
#~ msgstr "<%s>: schlechtes Mapset"
@@ -7463,16 +7179,11 @@
#~ msgid "G__open_raster_new(): no temp files available"
#~ msgstr "G__open_raster_new(): keine temp-Datei vorhanden."
-#~ msgid ""
-#~ "Unable to write embedded null values for raster map open for random access"
-#~ msgstr ""
-#~ "Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet "
-#~ "für den direkten Zugriff."
+#~ msgid "Unable to write embedded null values for raster map open for random access"
+#~ msgstr "Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet für den direkten Zugriff."
#~ msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-#~ msgstr ""
-#~ "G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen "
-#~ "werden."
+#~ msgstr "G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen werden."
#~ msgid "Unable to find '%s' in '%s'"
#~ msgstr "Kann '%s' in '%s' nicht finden."
@@ -7480,11 +7191,8 @@
#~ msgid "Unable to open '%s'"
#~ msgstr "Kann '%s' nicht öffnen."
-#~ msgid ""
-#~ "G_set_quant_rules() can be called only for raster maps opened for reading"
-#~ msgstr ""
-#~ "G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten "
-#~ "aufgerufen werden."
+#~ msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+#~ msgstr "G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten aufgerufen werden."
#~ msgid ""
#~ "\n"
@@ -7537,9 +7245,7 @@
#~ msgstr " Es ist eine Reklassifikation der Rasterkarte <%s@%s> "
#~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-#~ msgstr ""
-#~ " Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei "
-#~ "ungültig ist."
+#~ msgstr " Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei ungültig ist."
#~ msgid " Invalid format."
#~ msgstr " Ungültiges Format."
@@ -7548,13 +7254,10 @@
#~ msgstr "Kann die History-Informationen der Karte [%s] nicht schreiben."
#~ msgid "Not enough room in history file to record command line."
-#~ msgstr ""
-#~ "Nicht genügend Platz in der History-Datei, um die Kommandozeile zu "
-#~ "speichern."
+#~ msgstr "Nicht genügend Platz in der History-Datei, um die Kommandozeile zu speichern."
#~ msgid "Not enough room in history file for command line (truncated)."
-#~ msgstr ""
-#~ "Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
+#~ msgstr "Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
#~ msgid "Graphics driver [%s] started"
#~ msgstr "Grafiktreiber [%s] gestartet."
@@ -7568,20 +7271,14 @@
#~ msgid "not implemented"
#~ msgstr "nicht implementiert"
-#~ msgid ""
-#~ "Unable to build spatial index from topology, vector map is not opened at "
-#~ "topo level 2"
-#~ msgstr ""
-#~ "Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist "
-#~ "nicht auf dem topo level 2 geöffnet."
+#~ msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+#~ msgstr "Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist nicht auf dem topo level 2 geöffnet."
#~ msgid "%d errors in category string."
#~ msgstr "%d Fehler in Kategorie-Zeichenkette."
#~ msgid "Unable to add database link, map is not opened in WRITE mode"
-#~ msgstr ""
-#~ "Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im "
-#~ "Schreibmodus geöffnet."
+#~ msgstr "Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im Schreibmodus geöffnet."
#~ msgid "Unable to add database link"
#~ msgstr "Kann Datenbankverknüpfung nicht hinzufügen."
@@ -7593,22 +7290,13 @@
#~ msgstr "Unbekanntes Schlüsselwort %s in Vektor Header."
#~ msgid "Next edge was visited but it is not the first one !!! breaking loop"
-#~ msgstr ""
-#~ "Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
+#~ msgstr "Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
-#~ msgid ""
-#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-#~ "excess)"
-#~ msgstr ""
-#~ "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld "
-#~ "Byte zuviel)."
+#~ msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+#~ msgstr "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte zuviel)."
-#~ msgid ""
-#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-#~ "missing)."
-#~ msgstr ""
-#~ "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld "
-#~ "Byte fehlen)."
+#~ msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+#~ msgstr "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte fehlen)."
#~ msgid "Intersections: %5d"
#~ msgstr "Überschneidungen: %5d"
@@ -7631,11 +7319,8 @@
#~ msgid "Unable to open category index file for vector map <%s@%s>"
#~ msgstr "Kann die Kategorieindex-Datei der Vektorkarte <%s@%s> nicht öffnen."
-#~ msgid ""
-#~ "Random read is not supported by OGR for this layer, cannot build support"
-#~ msgstr ""
-#~ "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann "
-#~ "Support nicht erzeugen."
+#~ msgid "Random read is not supported by OGR for this layer, cannot build support"
+#~ msgstr "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support nicht erzeugen."
#~ msgid "Feature: "
#~ msgstr "Objekt: "
@@ -7653,9 +7338,7 @@
#~ msgstr "Kann die Rasterzeile %i nicht schreiben."
#~ msgid "The gauss elimination solver does not work with sparse matrices"
-#~ msgstr ""
-#~ "Der Gaußsche Eliminierungslöser kann keine dünnbesetzten Matrizen "
-#~ "verarbeiten."
+#~ msgstr "Der Gaußsche Eliminierungslöser kann keine dünnbesetzten Matrizen verarbeiten."
#~ msgid "The linear equation system is not quadratic"
#~ msgstr "Das lineare Gleichungssystem ist nicht quadratisch."
@@ -7669,45 +7352,32 @@
#~ msgid "Matrix is not symmetric!"
#~ msgstr "Matrix ist nicht symmetrisch!"
-#~ msgid ""
-#~ "The type of solver which should solve the symmetric linear equation system"
-#~ msgstr ""
-#~ "Der Solver, der das symmetrische lineare Gleichungssystem lösen soll"
+#~ msgid "The type of solver which should solve the symmetric linear equation system"
+#~ msgstr "Der Solver, der das symmetrische lineare Gleichungssystem lösen soll"
#~ msgid "The type of solver which should solve the linear equation system"
#~ msgstr "Der Solver, der das lineare Gleichungssysteme lösen soll"
-#~ msgid ""
-#~ "Maximum number of iteration used to solver the linear equation system"
-#~ msgstr ""
-#~ "Maximale Anzahl Iterationen, zum Lösen des linearen Gleichungssystems"
+#~ msgid "Maximum number of iteration used to solver the linear equation system"
+#~ msgstr "Maximale Anzahl Iterationen, zum Lösen des linearen Gleichungssystems"
-#~ msgid ""
-#~ "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-#~ msgstr ""
-#~ "Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
+#~ msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+#~ msgstr "Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
-#~ msgid ""
-#~ "The relaxation parameter used by the jacobi and sor solver for speedup or "
-#~ "stabilizing"
-#~ msgstr ""
-#~ "Entspannungsparameter (relaxation parameter) zur Beschleunigung oder "
-#~ "Stabilisierung der Jacobi und SOR Löser"
+#~ msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+#~ msgstr "Entspannungsparameter (relaxation parameter) zur Beschleunigung oder Stabilisierung der Jacobi und SOR Löser"
#~ msgid "test, gpde"
#~ msgstr "Test, gpde"
#~ msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-#~ msgstr ""
-#~ "Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
+#~ msgstr "Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
#~ msgid "Illegal table map name <%s>. Must start with a letter.\n"
-#~ msgstr ""
-#~ "Ungültiger Tabellenname <%s>. Er muss mit einem Buchstaben beginnen.\n"
+#~ msgstr "Ungültiger Tabellenname <%s>. Er muss mit einem Buchstaben beginnen.\n"
#~ msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-#~ msgstr ""
-#~ "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
+#~ msgstr "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
#~ msgid "Unable to feature %d from vector map <%s>"
#~ msgstr "Unable to feature %d from vector map <%s>"
@@ -7719,14 +7389,10 @@
#~ msgstr "Vektor ist nicht 3D."
#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr ""
-#~ "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. "
-#~ "mit v.info)."
+#~ msgstr "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. mit v.info)."
#~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double "
-#~ "sein)."
+#~ msgstr "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double sein)."
#~ msgid "Cannot read column type of smooth column"
#~ msgstr "Kann den Spaltentyp der Smooth-Spalte nicht lesen."
@@ -7735,9 +7401,7 @@
#~ msgstr "Spaltentyp der Smooth-Spalte (datetime) wird nicht unterstützt."
#~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double "
-#~ "sein)."
+#~ msgstr "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double sein)."
#~ msgid "Unknown Location"
#~ msgstr "Unbekannte Location"
@@ -7866,8 +7530,7 @@
#~ msgstr "G3d_openCellOld: Fehler in G3d_readHeader"
#~ msgid "G3d_openCellOld: projection does not match window projection"
-#~ msgstr ""
-#~ "G3d_openCellOld: Projektion passt nicht zu der Projektion des Fensters"
+#~ msgstr "G3d_openCellOld: Projektion passt nicht zu der Projektion des Fensters"
#~ msgid "G3d_openCellOld: zone does not match window zone"
#~ msgstr "G3d_openCellOld: Zone passt nicht zu der Zone des Fensters"
@@ -7898,3 +7561,15 @@
#~ msgid "G3d_openCellNew: error in G3d_fillHeader"
#~ msgstr "G3d_openCellNew: Fehler in G3d_fillHeader"
+#~ msgid "Cannot write quant rules for map %s"
+#~ msgstr "Kann keine quant-Regeln für Karte %s schreiben."
+#~ msgid "Option <%s> does not accept multiple answers\n"
+#~ msgstr "Option <%s> akzeptiert nicht mehrere Antworten.\n"
+#~ msgid " format: %s\n"
+#~ msgstr " Format: %s\n"
+#~ msgid "Unable to create raster map <%s>"
+#~ msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2011-10-08 21:36:17 UTC (rev 48682)
+++ grass/trunk/locale/po/grassmods_de.po 2011-10-08 21:36:48 UTC (rev 48683)
@@ -4,14 +4,14 @@
# Markus Neteler <neteler itc.it>, 2004.
# Stephan Holl <holl gdf-hannover.de>, 2004, 2005, 2006.
-# Robert Nuske <rnuske gwdg.de>, 2006, 2007, 2008, 2009, 2010, 2011.
+# Robert Nuske <rnuske gwdg.de>, 2006, 2007, 2008, 2009, 2010.
# Robert Nuske <robert.nuske nw-fva.de>, 2011.
msgid ""
msgstr ""
"Project-Id-Version: grassmods_de\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2011-10-05 23:30+0200\n"
-"PO-Revision-Date: 2011-09-27 18:19+0200\n"
+"PO-Revision-Date: 2011-10-08 19:43+0200\n"
"Last-Translator: Robert Nuske <robert.nuske nw-fva.de>\n"
"Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -149,9 +149,7 @@
#: ../raster3d/r3.info/r3.info.main.c:82
msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-"Gibt Basisinformationen über eine durch den Benutzer angegebene 3D "
-"Rasterkarte aus."
+msgstr "Gibt Basisinformationen über eine durch den Benutzer angegebene 3D Rasterkarte aus."
#: ../raster3d/r3.info/r3.info.main.c:89
msgid "Name of input 3D raster map"
@@ -184,9 +182,7 @@
#: ../raster3d/r3.info/r3.info.main.c:119
msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Geb nur 3D-Rasterkarten-Datumsstempel (Tag.Monat.Jahr Stunde:Minute:Sekunde) "
-"aus."
+msgstr "Geb nur 3D-Rasterkarten-Datumsstempel (Tag.Monat.Jahr Stunde:Minute:Sekunde) aus."
#: ../raster3d/r3.info/r3.info.main.c:127
#, c-format
@@ -233,7 +229,7 @@
#: ../raster3d/r3.info/r3.info.main.c:390 ../raster/r.info/main.c:307
#: ../raster/r.info/main.c:433
msgid "Cannot allocate memory for string"
-msgstr "Kann kein Speicherplatz für Zeichenkette bekommen."
+msgstr "Kann keinen Speicher für Zeichenkette reservieren."
#: ../raster3d/r3.info/r3.info.main.c:343
#: ../raster3d/r3.info/r3.info.main.c:405
@@ -257,9 +253,7 @@
#: ../raster3d/r3.in.ascii/main.c:98
msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn keiner "
-"existiert)"
+msgstr "Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn keiner existiert)"
#: ../raster3d/r3.in.ascii/main.c:188
#, fuzzy, c-format
@@ -282,11 +276,8 @@
#: ../raster3d/r3.in.ascii/main.c:293
#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
-"Nach vollständigem Import der erwarteten Daten befinden sie sich in der "
-"Input-Datei. [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr "Nach vollständigem Import der erwarteten Daten befinden sie sich in der Input-Datei. [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:327 ../raster/r.in.poly/main.c:30
#: ../raster/r.in.gdal/main.c:82 ../raster/r.in.bin/main.c:236
@@ -319,8 +310,7 @@
#: ../raster3d/r3.in.ascii/main.c:329
#, fuzzy
msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr ""
-"Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
+msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
#: ../raster3d/r3.in.ascii/main.c:357 ../raster3d/r3.in.v5d/main.c:215
msgid "Unable to open 3D raster map"
@@ -482,20 +472,12 @@
#: ../raster3d/r3.cross.rast/main.c:232
#, fuzzy
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
-msgstr ""
-"Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
-"Rasterkarte basierend auf 2D-Höhenkarte."
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
+msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
#: ../raster3d/r3.cross.rast/main.c:258
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"Die 2D und 3D Regions Parameter sind unterschiedlich. Verwende die G3D "
-"Parameter verwenden, um die 2D Region anzupassen."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Verwende die G3D Parameter verwenden, um die 2D Region anzupassen."
#: ../raster3d/r3.cross.rast/main.c:301
msgid "Output map already exists. Will be overwritten!"
@@ -586,8 +568,7 @@
msgid "Cannot create mask file: RASTER3D_MASK already exists"
msgstr ""
"Kann keine Maskendatei erzeugen: RASTER3D_MASK existiert bereits.\n"
-"Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu "
-"löschen."
+"Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu löschen."
#: ../raster3d/r3.null/main.c:54
msgid "3d raster map for which to modify null values"
@@ -639,12 +620,8 @@
#: ../raster3d/r3.to.rast/main.c:96
#, fuzzy
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
-msgstr ""
-"Verwende dieselbe Auflösung wie die RASTER3D-Eingabekarte für die 2D-"
-"Ausgabekarten. Dies ist unabhängig von der Auflösung der aktuellen Region. "
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
+msgstr "Verwende dieselbe Auflösung wie die RASTER3D-Eingabekarte für die 2D-Ausgabekarten. Dies ist unabhängig von der Auflösung der aktuellen Region. "
#: ../raster3d/r3.to.rast/main.c:209
msgid "Converts 3D raster maps to 2D raster maps"
@@ -661,12 +638,8 @@
msgstr "Fehler beim Öffnen der 3D-Rasterkarte <%s>."
#: ../raster3d/r3.to.rast/main.c:270 ../raster3d/r3.out.vtk/main.c:450
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"Die 2D und 3D Regions Parameter sind unterschiedlich. Verwende die 2D-"
-"Parameter, um den 2D-Teil der 3D-Region anzupassen."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Verwende die 2D-Parameter, um den 2D-Teil der 3D-Region anzupassen."
#: ../raster3d/r3.to.rast/main.c:294 ../raster/r.gwflow/main.c:366
#: ../raster/r.li/r.li.daemon/list.c:49 ../raster/r.to.rast3/main.c:244
@@ -713,10 +686,8 @@
#: ../raster3d/r3.to.rast/main.c:307
#, fuzzy, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr ""
-"Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
#: ../raster3d/r3.out.vtk/main.c:117
msgid "Specify top and bottom map"
@@ -752,12 +723,8 @@
#: ../raster3d/r3.out.vtk/main.c:175
#, fuzzy
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
-msgstr ""
-"Keine RASTER3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur "
-"die Geometrien schreiben."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
+msgstr "Keine RASTER3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die Geometrien schreiben."
#: ../raster3d/r3.out.vtk/main.c:209
msgid "No RGB Data will be created."
@@ -781,9 +748,7 @@
#: ../raster3d/r3.out.vtk/main.c:541
msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"Fehler beim Schließen der 3D-Rasterkarte. Die VTK-Datei könnte unvollständig "
-"sein."
+msgstr "Fehler beim Schließen der 3D-Rasterkarte. Die VTK-Datei könnte unvollständig sein."
#: ../raster3d/r3.out.vtk/main.c:556
msgid "Unable to close VTK-ASCII file"
@@ -799,8 +764,7 @@
#: ../raster3d/r3.out.vtk/writeVTKHead.c:118
msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
-msgstr ""
-"write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
+msgstr "write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
#: ../raster3d/r3.out.vtk/errorHandling.c:105
msgid "Unable to close input raster maps"
@@ -820,8 +784,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:47
msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-"Erzeugt VTK Punktedaten anstelle von VTK Zelldaten (Standaed ist Zelldaten)."
+msgstr "Erzeugt VTK Punktedaten anstelle von VTK Zelldaten (Standaed ist Zelldaten)."
#: ../raster3d/r3.out.vtk/parameters.c:56
msgid "top surface 2D raster map"
@@ -832,25 +795,16 @@
msgstr "2D Rasterkarte für den Boden."
#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"Erzeugt 3D Höhenausgabe mit einer Ober- und einer Unterfläche. Beide "
-"Rasterkarten werden benötigt."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
+msgstr "Erzeugt 3D Höhenausgabe mit einer Ober- und einer Unterfläche. Beide Rasterkarten werden benötigt."
#: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-"Drei (R,G,B) 3D-Rasterkarten, um RGB-Werte zu erzeugen [RoteKarte,GrüneKarte,"
-"BlaueKarte]."
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr "Drei (R,G,B) 3D-Rasterkarten, um RGB-Werte zu erzeugen [RoteKarte,GrüneKarte,BlaueKarte]."
#: ../raster3d/r3.out.vtk/parameters.c:92
msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"Drei (x,y,z) 3D-Rasterkarten zum Erzeugen von Vektorwerten [X-Karte,Y-Karte,"
-"Z-Karte]."
+msgstr "Drei (x,y,z) 3D-Rasterkarten zum Erzeugen von Vektorwerten [X-Karte,Y-Karte,Z-Karte]."
#: ../raster3d/r3.out.vtk/parameters.c:99 ../raster/r.out.vtk/parameters.c:96
#: ../vector/v.out.vtk/main.c:77
@@ -886,18 +840,12 @@
#: ../raster3d/r3.out.vtk/writeVTKData.c:335
#, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
-msgstr ""
-"write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer "
-"Tiefe von %i in eine VTK-ASCII-Datei."
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+msgstr "write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer Tiefe von %i in eine VTK-ASCII-Datei."
#: ../raster3d/r3.out.vtk/writeVTKData.c:441
msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Falsche Werte in der 3D-Rasterkarte! Werte sollten zwischen 0 und 255 "
-"liegen!\n"
+msgstr "Falsche Werte in der 3D-Rasterkarte! Werte sollten zwischen 0 und 255 liegen!\n"
#: ../raster3d/r3.gwflow/main.c:54
msgid "Input 3D raster map with initial piezometric heads in [m]"
@@ -905,30 +853,22 @@
#: ../raster3d/r3.gwflow/main.c:60
#, fuzzy
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
#: ../raster3d/r3.gwflow/main.c:65
#, fuzzy
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der X-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster3d/r3.gwflow/main.c:70
#, fuzzy
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der Y-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster3d/r3.gwflow/main.c:75
#, fuzzy
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der Z-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster3d/r3.gwflow/main.c:80
@@ -948,44 +888,33 @@
#: ../raster3d/r3.gwflow/main.c:93
#, fuzzy
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
-msgstr ""
-"Das resultierende piezometrisches Niveau der numerischen Berechnung wird in "
-"diese Karte geschrieben."
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
+msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
#: ../raster3d/r3.gwflow/main.c:99
#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
msgstr ""
"Berechne das Vektorfeld der Grundwasserfiltrationgeschwindigkeiten [m/s]\n"
"und schreibe die x- und y-Komponenten in Karten mit den Namen name_[xy]."
#: ../raster3d/r3.gwflow/main.c:105
#, fuzzy
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:111
#, fuzzy
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:117
#, fuzzy
-msgid ""
-"Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
+msgid "Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
msgstr ""
@@ -995,9 +924,7 @@
msgstr "Benutzte RASTER3D Maske (falls existent)."
#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
msgstr ""
#: ../raster3d/r3.gwflow/main.c:161 ../raster/r.basins.fill/main.c:55
@@ -1028,20 +955,15 @@
msgstr "Punkt Klassifikation."
#: ../raster3d/r3.gwflow/main.c:165
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions"
-msgstr ""
-"Programm zur Berechnung des transienten, beschränkten Grundwasserflusses in "
-"drei Dimensionen."
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
+msgstr "Programm zur Berechnung des transienten, beschränkten Grundwasserflusses in drei Dimensionen."
#: ../raster3d/r3.gwflow/main.c:182
#, fuzzy
msgid ""
"The cholesky solver does not work with sparse matrices.\n"
"Consider to choose a full filled quadratic matrix with flag -f "
-msgstr ""
-"Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
#: ../raster3d/r3.gwflow/main.c:281 ../raster/r.gwflow/main.c:542
msgid "Unable to create and solve the linear equation system"
@@ -1057,12 +979,8 @@
msgstr "Fehler beim Schließen der G3D-Datei."
#: ../raster3d/r3.mkdspf/main.c:82
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Erzeugt eine Datei aus einer existierenden grid3-Datei basierend auf einem "
-"gegebenen Threshold."
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Erzeugt eine Datei aus einer existierenden grid3-Datei basierend auf einem gegebenen Threshold."
#: ../raster3d/r3.mkdspf/main.c:90
msgid "Name of an existing 3d raster map"
@@ -1133,8 +1051,7 @@
#: ../raster3d/r3.in.v5d/main.c:195
#, fuzzy
msgid "Import 3-dimensional Vis5D files."
-msgstr ""
-"Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
+msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
#: ../raster3d/r3.stats/main.c:569 ../raster/r.stats/main.c:103
#: ../raster/r.quant/main.c:49 ../raster/r.mfilter/main.c:58
@@ -1211,8 +1128,7 @@
#: ../raster3d/r3.out.v5d/main.c:290
msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr ""
#: ../raster3d/r3.out.v5d/main.c:297
msgid "Use map coordinates instead of xyz coordinates"
@@ -1516,12 +1432,8 @@
msgstr ""
#: ../raster/r.his/main.c:67
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Erzeugt rot, grün und blaue Rasterkarten durch Kombination des Farbtons, der "
-"Intensität und Sättigung (HIS) aus Eingabe-Rasterkarten."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Erzeugt rot, grün und blaue Rasterkarten durch Kombination des Farbtons, der Intensität und Sättigung (HIS) aus Eingabe-Rasterkarten."
#: ../raster/r.his/main.c:76 ../display/d.his/main.c:76
msgid "Name of layer to be used for HUE"
@@ -1529,13 +1441,11 @@
#: ../raster/r.his/main.c:83 ../display/d.his/main.c:83
msgid "Name of layer to be used for INTENSITY"
-msgstr ""
-"Name der Karte, die für die Intensität (INTENSITY) verwendet werden soll."
+msgstr "Name der Karte, die für die Intensität (INTENSITY) verwendet werden soll."
#: ../raster/r.his/main.c:90 ../display/d.his/main.c:90
msgid "Name of layer to be used for SATURATION"
-msgstr ""
-"Name der Karte, die für die Sättigung (SATURATION) verwendet werden soll"
+msgstr "Name der Karte, die für die Sättigung (SATURATION) verwendet werden soll"
#: ../raster/r.his/main.c:97
msgid "Name of output layer to be used for RED"
@@ -1805,8 +1715,7 @@
#: ../raster/r.contour/main.c:90
msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
+msgstr "Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
#: ../raster/r.contour/main.c:101
msgid "List of contour levels"
@@ -1992,8 +1901,7 @@
#: ../raster/r.out.pov/main.c:180
#, c-format
msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-"Die Rasterkarte ist zu groß! Sie hat mehr als %d Spalten oder %d Zeilen."
+msgstr "Die Rasterkarte ist zu groß! Sie hat mehr als %d Spalten oder %d Zeilen."
#: ../raster/r.out.pov/main.c:201
msgid "Negative elevation values in input"
@@ -2085,26 +1993,16 @@
msgstr "Lese %s..."
#: ../raster/r.le/r.le.trace/main.c:58
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
-msgstr ""
-"Zeigt die Grenzen aller r.le-Patches und wie die Grenze verfolgt wird. Zeigt "
-"außerdem die Attribute, Größe, Umfang und Form Indices jedes Patches und "
-"speichert die Daten in eine Ausgabedatei."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
+msgstr "Zeigt die Grenzen aller r.le-Patches und wie die Grenze verfolgt wird. Zeigt außerdem die Attribute, Größe, Umfang und Form Indices jedes Patches und speichert die Daten in eine Ausgabedatei."
#: ../raster/r.le/r.le.setup/sample.c:1049
msgid "Cannot read vector"
msgstr "Kann Vektor nicht lesen."
#: ../raster/r.le/r.le.setup/main.c:59
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
-msgstr ""
-"Interaktives Werkzeug zur Erzeugung eine Stichproben- und Analyse-Rahmens, "
-"der von den anderen r.le-Progammen verwendet wird. "
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgstr "Interaktives Werkzeug zur Erzeugung eine Stichproben- und Analyse-Rahmens, der von den anderen r.le-Progammen verwendet wird. "
#: ../raster/r.le/r.le.setup/main.c:63
msgid "Raster map to use to setup sampling"
@@ -2115,20 +2013,12 @@
msgstr "Einzublendende Vektorkarte."
#: ../raster/r.le/r.le.patch/main.c:50
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"Berechnet Attribute, Patch-Größe, Kerngebiets-Größe, Form, Fraktale "
-"Dimension und Umfang für ein Satz von Patches in einer Landschaft."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "Berechnet Attribute, Patch-Größe, Kerngebiets-Größe, Form, Fraktale Dimension und Umfang für ein Satz von Patches in einer Landschaft."
#: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-"Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, "
-"Nebeneinanderstellung und Kanten"
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
+msgstr "Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, Nebeneinanderstellung und Kanten"
#: ../raster/r.out.ascii/main.c:62
#, fuzzy
@@ -2144,17 +2034,12 @@
msgstr "Name der Ausgabe ASCII-Grid Datei (verwende out=- für stdout)."
#: ../raster/r.out.ascii/main.c:93
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
-msgstr ""
-"Anzahl der ausgegebenen Werte, bevor ein Zeilenumbruch eingefügt wird (nur "
-"beim SURFER oder MODFLOW-Format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
+msgstr "Anzahl der ausgegebenen Werte, bevor ein Zeilenumbruch eingefügt wird (nur beim SURFER oder MODFLOW-Format)"
#: ../raster/r.out.ascii/main.c:101
msgid "String to represent null cell (GRASS grid only)"
-msgstr ""
-"Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
+msgstr "Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
#: ../raster/r.out.ascii/main.c:109
msgid "Write SURFER (Golden Software) ASCII grid"
@@ -2224,15 +2109,8 @@
msgstr "From"
#: ../raster/r.surf.gauss/main.c:42
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
-msgstr ""
-"GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen "
-"Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer "
-"angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird "
-"verwendet."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+msgstr "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird verwendet."
#: ../raster/r.surf.gauss/main.c:48
msgid "Name of the output random surface"
@@ -2261,8 +2139,7 @@
#: ../raster/r.out.png/main.c:131
msgid "(0 = none, 1 = fastest, 9 = best)"
-msgstr ""
-"(0 = keine Kompression, 1 = schnellste Kompression, 9 = beste Kompression)"
+msgstr "(0 = keine Kompression, 1 = schnellste Kompression, 9 = beste Kompression)"
#: ../raster/r.out.png/main.c:138
msgid "Make NULL cells transparent"
@@ -2318,16 +2195,8 @@
msgstr "Optionales kumulatives Kostenmaximum."
#: ../raster/r.walk/main.c:183
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die "
-"beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. "
-"Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte "
-"mit Reibungs-Kosten kombiniert."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
#: ../raster/r.walk/main.c:193
msgid "Name of elevation input raster map"
@@ -2377,9 +2246,7 @@
#: ../raster/r.walk/main.c:266 ../raster/r.cost/main.c:220
msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Kosten werden NULL-Zellen zugewiesen. Standardmäßig werden NULL-Zellen "
-"ignoriert."
+msgstr "Kosten werden NULL-Zellen zugewiesen. Standardmäßig werden NULL-Zellen ignoriert."
#: ../raster/r.walk/main.c:274 ../raster/r.cost/main.c:229
#: ../raster/r.in.lidar/main.c:211 ../raster/r.in.xyz/main.c:238
@@ -2388,24 +2255,19 @@
#: ../raster/r.walk/main.c:284
msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
-"Koeffizienten für die Formel zum Berechnen der Geh-Energie: a, b, c, d."
+msgstr "Koeffizienten für die Formel zum Berechnen der Geh-Energie: a, b, c, d."
#: ../raster/r.walk/main.c:293
msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-"Lambda Koeffizient zur Kombination der Geh-Energie und den Reibungskosten."
+msgstr "Lambda Koeffizient zur Kombination der Geh-Energie und den Reibungskosten."
#: ../raster/r.walk/main.c:302
msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"Hangneigungsfaktor, der die Reiseenergiekosten pro Höhenstufe ermittelt."
+msgstr "Hangneigungsfaktor, der die Reiseenergiekosten pro Höhenstufe ermittelt."
#: ../raster/r.walk/main.c:307 ../raster/r.cost/main.c:234
msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr ""
-"Gehe wie ein Pferd im Schach (Knight's move); ist etwas langsamer, aber "
-"genauer."
+msgstr "Gehe wie ein Pferd im Schach (Knight's move); ist etwas langsamer, aber genauer."
#: ../raster/r.walk/main.c:311
msgid "Keep null values in output map"
@@ -2421,9 +2283,7 @@
#: ../raster/r.walk/main.c:368 ../raster/r.cost/main.c:302
msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-"Es muss exakt entweder start_points, start_rast oder coordinate angegeben "
-"werden."
+msgstr "Es muss exakt entweder start_points, start_rast oder coordinate angegeben werden."
#: ../raster/r.walk/main.c:373 ../raster/r.cost/main.c:307
#: ../raster/r.cost/main.c:720
@@ -2487,9 +2347,7 @@
#: ../raster/r.walk/main.c:427
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden "
-"ausgeschlossen."
+msgstr "Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
#: ../raster/r.walk/main.c:447 ../raster/r.walk/main.c:452
#: ../raster/r.walk/main.c:817 ../raster/r.cost/main.c:356
@@ -2571,7 +2429,7 @@
#: ../raster/r.walk/main.c:824 ../raster/r.cost/main.c:681
#: ../raster/r.texture/h_measure.c:594 ../imagery/i.smap/interp.c:66
-msgstr "Kann den Speicher nicht belegen."
#: ../raster/r.walk/main.c:826
#, c-format
@@ -2645,9 +2503,7 @@
#: ../raster/r.in.gdal/main.c:111
msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Name der Location, von der Projektionsinformationen für eine GCP-"
-"Transformation gelesen werden soll."
+msgstr "Name der Location, von der Projektionsinformationen für eine GCP-Transformation gelesen werden soll."
#: ../raster/r.in.gdal/main.c:120 ../raster/r.in.gdal/main.c:128
#: ../raster/r.external/main.c:90 ../imagery/i.landsat.toar/main.c:90
@@ -2658,9 +2514,7 @@
msgstr "Metadaten"
#: ../raster/r.in.gdal/main.c:127
-msgid ""
-"The offset will be added to the band number while output raster map name "
-"creation"
+msgid "The offset will be added to the band number while output raster map name creation"
msgstr ""
#: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:198
@@ -2687,16 +2541,12 @@
msgstr "Verwende die Nummern der Kanäle anstatt der Farbbezeichnungen."
#: ../raster/r.in.gdal/main.c:165
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the raster file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
msgstr ""
#: ../raster/r.in.gdal/main.c:190
msgid "You have to specify a target location different from output location"
-msgstr ""
-"Sie müssen eine Ziel-Location angeben, die verschieden ist von der Ausgabe-"
-"Location."
+msgstr "Sie müssen eine Ziel-Location angeben, die verschieden ist von der Ausgabe-Location."
#: ../raster/r.in.gdal/main.c:194
#, fuzzy
@@ -2722,42 +2572,21 @@
msgstr "Die Rasterkarte <%s> existiert bereits."
#: ../raster/r.in.gdal/main.c:258
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
-msgstr ""
-"Die polynomiale Rektifikation die von i.rectify verwendet wird funktioniert "
-"nicht gut für NOAA/AVHRR Daten. Versuchen Sie stattdessen gdalwarp mit der "
-"'thin plate spline rectification' (-tps)."
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
+msgstr "Die polynomiale Rektifikation die von i.rectify verwendet wird funktioniert nicht gut für NOAA/AVHRR Daten. Versuchen Sie stattdessen gdalwarp mit der 'thin plate spline rectification' (-tps)."
#: ../raster/r.in.gdal/main.c:274
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
-msgstr ""
-"Die Eingabe-Rasterkarte wurde rotiert und kann daher nicht eingelesen "
-"werden. Sie können 'gdalwarp' verwenden, um die Karte zu transformieren, so "
-"dass Norden oben ist."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Die Eingabe-Rasterkarte wurde rotiert und kann daher nicht eingelesen werden. Sie können 'gdalwarp' verwenden, um die Karte zu transformieren, so dass Norden oben ist."
#: ../raster/r.in.gdal/main.c:315
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
-msgstr ""
-"Die Begrenzung ist an geographische Koordinaten gebunden. Eine Überprüfung "
-"der Begrenzung und Auflösung mit r.info und eine Anpassung mit r.region "
-"dieser Parameter ist für die weitere Berechnung empfehlenswert."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
+msgstr "Die Begrenzung ist an geographische Koordinaten gebunden. Eine Überprüfung der Begrenzung und Auflösung mit r.info und eine Anpassung mit r.region dieser Parameter ist für die weitere Berechnung empfehlenswert."
#: ../raster/r.in.gdal/main.c:335 ../vector/v.in.ogr/main.c:515
#: ../vector/v.in.lidar/main.c:341
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
-"erstelle daher keine neue Location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; erstelle daher keine neue Location."
#: ../raster/r.in.gdal/main.c:341 ../general/g.proj/create.c:15
#: ../vector/v.in.ogr/main.c:521 ../vector/v.in.lidar/main.c:347
@@ -2766,12 +2595,8 @@
msgstr "Location <%s> erstellt."
#: ../raster/r.in.gdal/main.c:354 ../raster/r.external/proj.c:18
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-"Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format "
-"konvertieren, zwecks Überprüfung."
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
+msgstr "Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format konvertieren, zwecks Überprüfung."
#: ../raster/r.in.gdal/main.c:370 ../raster/r.in.lidar/main.c:297
#: ../raster/r.external/proj.c:34 ../vector/v.in.ogr/main.c:551
@@ -2786,8 +2611,7 @@
"Projection of dataset does not appear to match current location.\n"
"\n"
msgstr ""
-"Die Projektion des Datensatzes scheint nicht mit der aktuellen Location "
-"übereinzustimmen.\n"
+"Die Projektion des Datensatzes scheint nicht mit der aktuellen Location übereinzustimmen.\n"
"\n"
#: ../raster/r.in.gdal/main.c:386 ../raster/r.external/proj.c:47
@@ -2808,30 +2632,20 @@
#: ../raster/r.in.gdal/main.c:446
msgid ""
"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
-"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der "
-"Projektion zu übersteuern und die Projektionsinformation der Location für "
-"diesen Datensatz zu verwenden.\n"
+"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der Projektion zu übersteuern und die Projektionsinformation der Location für diesen Datensatz zu verwenden.\n"
#: ../raster/r.in.gdal/main.c:449 ../raster/r.external/proj.c:110
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Bedenken Sie, dass es besser sein könnte eine neue Location mit den Werten "
-"des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu "
-"erzeugen.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "Bedenken Sie, dass es besser sein könnte eine neue Location mit den Werten des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu erzeugen.\n"
#: ../raster/r.in.gdal/main.c:454 ../raster/r.in.lidar/main.c:380
#: ../raster/r.external/proj.c:115 ../vector/v.in.ogr/main.c:634
#: ../vector/v.in.lidar/main.c:463
msgid "Projection of input dataset and current location appear to match"
-msgstr ""
-"Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
-"Location scheinen übereinzustimmen."
+msgstr "Die Projektionsinformationen des Eingabedatensatzes und der aktuellen Location scheinen übereinzustimmen."
#: ../raster/r.in.gdal/main.c:460 ../raster/r.external/main.c:180
msgid "Proceeding with import..."
@@ -3066,9 +2880,7 @@
#: ../raster/r.in.bin/main.c:428
msgid "Either all or none of north=, south=, east= and west= must be given"
-msgstr ""
-"Entweder alle oder keine Angabe von north=, south=, east= and west= müssen "
-"angegeben sein"
+msgstr "Entweder alle oder keine Angabe von north=, south=, east= and west= müssen angegeben sein"
#: ../raster/r.in.bin/main.c:435 ../display/d.grid/main.c:224
#, c-format
@@ -3097,12 +2909,8 @@
#: ../raster/r.in.bin/main.c:466
#, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
-msgstr ""
-"Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich "
-"wesentlich. Haben Sie east= and west= korrekt gesetzt?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
+msgstr "Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich wesentlich. Haben Sie east= and west= korrekt gesetzt?"
#: ../raster/r.in.bin/main.c:489
msgid "File Size %"
@@ -3118,11 +2926,8 @@
msgstr "Neuskalieren"
#: ../raster/r.rescale.eq/main.c:54
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Reskaliert mit Histogrammnormalisierung die Kategoriewerte einer Rasterkarte."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Reskaliert mit Histogrammnormalisierung die Kategoriewerte einer Rasterkarte."
#: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:60
msgid "The name of the raster map to be rescaled"
@@ -3130,9 +2935,7 @@
#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:68
msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-"Wertespanne der Eingangsdaten, die reskaliert werden soll (Standard: volle "
-"Spanne der Eingabekarte)"
+msgstr "Wertespanne der Eingangsdaten, die reskaliert werden soll (Standard: volle Spanne der Eingabekarte)"
#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:75
msgid "The resulting raster map name"
@@ -3176,8 +2979,7 @@
#: ../raster/r.resamp.bspline/main.c:86 ../vector/v.surf.bspline/main.c:95
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-"Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
+msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
#: ../raster/r.resamp.bspline/main.c:94
#, fuzzy
@@ -3195,15 +2997,12 @@
#: ../raster/r.resamp.bspline/main.c:108
#, fuzzy
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
msgstr "Spline-Interpolations-Schrittweite in Ost-West-Richtung."
#: ../raster/r.resamp.bspline/main.c:116
#, fuzzy
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
msgstr "Spline-Interpolations-Schrittweite in Nord-Süd-Richtung"
#: ../raster/r.resamp.bspline/main.c:123 ../vector/v.surf.bspline/main.c:156
@@ -3220,18 +3019,13 @@
msgstr "Behalte NULL-Werte in Ausgabekarte."
#: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:100
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
-msgstr ""
-"Finde die beste Tykhonov Regularisierung mittels der \"leave-one-out\" "
-"Kreuzvalidierung."
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
+msgstr "Finde die beste Tykhonov Regularisierung mittels der \"leave-one-out\" Kreuzvalidierung."
#: ../raster/r.resamp.bspline/main.c:151
#, fuzzy
msgid "Maximum memory to be used (in MB)"
-msgstr ""
-"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
#: ../raster/r.resamp.bspline/main.c:186
#, fuzzy
@@ -3354,9 +3148,7 @@
#: ../raster/r.resamp.bspline/main.c:719
#, fuzzy
msgid "No data within this subregion. Consider increasing the spline step."
-msgstr ""
-"Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
-"ändern."
+msgstr "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu ändern."
#: ../raster/r.resamp.bspline/main.c:735 ../vector/v.surf.bspline/main.c:843
msgid "Writing output..."
@@ -3364,9 +3156,7 @@
#: ../raster/r.resamp.bspline/crosscorr.c:160
#, fuzzy, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
msgstr "%d sind zu viele Punkte. Die Kreuzvalidierung würde zu lange dauern."
#: ../raster/r.resamp.bspline/crosscorr.c:169
@@ -3382,11 +3172,8 @@
#: ../raster/r.resamp.bspline/crosscorr.c:193
#: ../vector/v.surf.bspline/crosscorr.c:146
#, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
-msgstr ""
-"Zu viele Splines (%d x %d). Erwägen Sie die Splineschrittweite (\"sie=\" "
-"\"sin=\") zu ändern."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgstr "Zu viele Splines (%d x %d). Erwägen Sie die Splineschrittweite (\"sie=\" \"sin=\") zu ändern."
#: ../raster/r.resamp.bspline/crosscorr.c:211
#: ../vector/v.surf.bspline/crosscorr.c:164
@@ -3408,20 +3195,14 @@
#: ../raster/r.resamp.bspline/crosscorr.c:313
#: ../vector/v.surf.bspline/crosscorr.c:301
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
-msgstr ""
-"Eine unterschiedliche Anzahl von Splines und lambda_i-Werten wurde für die "
-"Kreuzvalidierung angegeben."
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
+msgstr "Eine unterschiedliche Anzahl von Splines und lambda_i-Werten wurde für die Kreuzvalidierung angegeben."
#: ../raster/r.resamp.bspline/crosscorr.c:315
#: ../vector/v.surf.bspline/crosscorr.c:303
#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr ""
-"Der Minimalwert für den Test (rms=%lf) wurde erreicht mit: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr "Der Minimalwert für den Test (rms=%lf) wurde erreicht mit: lambda_i = %.3f"
#: ../raster/r.resamp.bspline/crosscorr.c:323
#: ../vector/v.surf.bspline/crosscorr.c:311
@@ -3453,12 +3234,8 @@
msgstr "Name der Bewegungsrichtungskarte verbunden mit der Kostenkarte."
#: ../raster/r.drain/main.c:131
-msgid ""
-"Output drain vector map (recommended for cost surface made using knight's "
-"move)"
-msgstr ""
-"Ausgabe Abflußvektorkarte (empfohlen für Kostenkarten erstellt mittels "
-"Rösselsprung)."
+msgid "Output drain vector map (recommended for cost surface made using knight's move)"
+msgstr "Ausgabe Abflußvektorkarte (empfohlen für Kostenkarten erstellt mittels Rösselsprung)."
#: ../raster/r.drain/main.c:139
msgid "Map coordinates of starting point(s) (E,N)"
@@ -3487,12 +3264,8 @@
msgstr "Zähle Zellenanzahl entlang des Pfades."
#: ../raster/r.drain/main.c:163
-msgid ""
-"The input surface is a cost surface (if checked, a direction surface must "
-"also be specified"
-msgstr ""
-"Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muß auch eine "
-"Richtungskarte angegeben werden)."
+msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
+msgstr "Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muß auch eine Richtungskarte angegeben werden)."
#: ../raster/r.drain/main.c:175
msgid "Directional drain selected... checking for direction raster"
@@ -3503,19 +3276,13 @@
msgstr "Oberflächen-/Hydrologischer-Abfluß ausgewählt"
#: ../raster/r.drain/main.c:184
-msgid ""
-"Direction raster not specified, if direction flag is on, a direction raster "
-"must be given"
-msgstr ""
-"Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, "
-"muß eine Richtungskarte angegeben werden."
+msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
+msgstr "Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, muß eine Richtungskarte angegeben werden."
#: ../raster/r.drain/main.c:192
#, c-format
msgid "Direction map <%s> should not be specified for Surface/Hydrology drains"
-msgstr ""
-"Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluß nicht "
-"angegeben werden."
+msgstr "Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluß nicht angegeben werden."
#: ../raster/r.drain/main.c:198
msgid "Outputting a vector path"
@@ -3549,8 +3316,7 @@
#: ../raster/r.drain/main.c:299
#, c-format
msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
-"Start-Vektorkarte <%s> beinhaltet keine Punkte in der aktuellen Region."
+msgstr "Start-Vektorkarte <%s> beinhaltet keine Punkte in der aktuellen Region."
#: ../raster/r.drain/main.c:305
msgid "No start/stop point(s) specified"
@@ -3575,9 +3341,7 @@
#: ../raster/r.support/main.c:57
msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-"
-"Dateien."
+msgstr "Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-Dateien."
#: ../raster/r.support/main.c:67
msgid "Text to use for map title"
@@ -3622,8 +3386,7 @@
#: ../raster/r.support/main.c:130
#, fuzzy
msgid "Update statistics (histogram, range)"
-msgstr ""
-"Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
+msgstr "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
#: ../raster/r.support/main.c:134
#, fuzzy
@@ -3722,20 +3485,15 @@
#: ../raster/r.lake/main.c:188
msgid "Overwrite seed map with result (lake) map"
-msgstr ""
-"Überschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
+msgstr "Überschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
#: ../raster/r.lake/main.c:194
msgid "Both seed map and coordinates cannot be specified"
-msgstr ""
-"Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig "
-"verwendet werden."
+msgstr "Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig verwendet werden."
#: ../raster/r.lake/main.c:197
msgid "Seed map or seed coordinates must be set!"
-msgstr ""
-"Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben "
-"werden."
+msgstr "Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben werden."
# Einige Daten können u.U. verloren sein.er/r.lake/main.c:212
#: ../raster/r.lake/main.c:200
@@ -3744,15 +3502,11 @@
#: ../raster/r.lake/main.c:203
msgid "Both lake and overwrite cannot be specified"
-msgstr ""
-"Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet "
-"werden."
+msgstr "Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet werden."
#: ../raster/r.lake/main.c:206
msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
-"Entweder eine Ausgabe-Seekarte oder das Überschreiben-'flag' muss angegeben "
-"werden."
+msgstr "Entweder eine Ausgabe-Seekarte oder das Überschreiben-'flag' muss angegeben werden."
#: ../raster/r.lake/main.c:233
msgid "Seed point outside the current region"
@@ -3763,13 +3517,8 @@
msgstr "G_malloc: Kein Speicher mehr da."
#: ../raster/r.lake/main.c:269
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
-msgstr ""
-"Der angegebene Wasserstand am Startpunkt befindet sich unter der "
-"Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den "
-"Startpunkt."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
+msgstr "Der angegebene Wasserstand am Startpunkt befindet sich unter der Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den Startpunkt."
#: ../raster/r.lake/main.c:348
#, c-format
@@ -3788,9 +3537,7 @@
#: ../raster/r.lake/main.c:351
msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr ""
-"Das Volumen ist nur korrekt, wenn die Seetiefe (Terrain-Rasterkarte) in "
-"Metern angegeben wurde."
+msgstr "Das Volumen ist nur korrekt, wenn die Seetiefe (Terrain-Rasterkarte) in Metern angegeben wurde."
#: ../raster/r.surf.idw/main.c:106 ../raster/r.surf.idw2/main.c:64
#: ../vector/v.surf.idw/main.c:88
@@ -3883,9 +3630,7 @@
#: ../db/db.select/main.c:238
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr ""
-"Name der Ausgabekarte (wenn keiner oder \"-\" angegeben wurdeerfolgt die "
-"Ausgabe nach stdout)."
+msgstr "Name der Ausgabekarte (wenn keiner oder \"-\" angegeben wurdeerfolgt die Ausgabe nach stdout)."
#: ../raster/r.stats/main.c:119 ../raster/r.category/main.c:74
#: ../raster/r.distance/parse.c:47 ../vector/v.db.select/main.c:65
@@ -3896,8 +3641,7 @@
#: ../raster/r.stats/main.c:136 ../raster/r.report/parse.c:95
msgid "Number of fp subranges to collect stats from"
-msgstr ""
-"Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
+msgstr "Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
#: ../raster/r.stats/main.c:142
msgid "One cell (range) per line"
@@ -3917,8 +3661,7 @@
#: ../raster/r.stats/main.c:162
msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
-"Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
+msgstr "Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
#: ../raster/r.stats/main.c:167
msgid "Print category labels"
@@ -3946,9 +3689,7 @@
#: ../raster/r.stats/main.c:200 ../raster/r.report/parse.c:129
msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-"Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der "
-"Karte)."
+msgstr "Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der Karte)."
#: ../raster/r.stats/main.c:208 ../raster/r.univar/r.univar_main.c:110
#: ../raster/r.univar/r3.univar_main.c:123
@@ -3969,30 +3710,18 @@
#: ../raster/r.stats/main.c:279
#, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die "
-"Option '%s' werden ignoriert."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die Option '%s' werden ignoriert."
#: ../raster/r.stats/main.c:295
#, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-"Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten "
-"Beschriftungen. Verwende %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten Beschriftungen. Verwende %s=%d."
#: ../raster/r.stats/main.c:301
#, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
-msgstr ""
-"Der Schalter '-%c' wurde gesetzt. Verwende die fp-Kategoriespanne der "
-"Rasterkarte <%s> und ignoriere die Option '%s'."
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr "Der Schalter '-%c' wurde gesetzt. Verwende die fp-Kategoriespanne der Rasterkarte <%s> und ignoriere die Option '%s'."
#: ../raster/r.stats/main.c:334 ../raster/r.recode/read_rules.c:35
#, c-format
@@ -4030,16 +3759,12 @@
#: ../raster/r.compress/main.c:110
#, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr ""
-"[%s] ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht "
-"dekomprimieren."
+msgstr "[%s] ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht dekomprimieren."
#: ../raster/r.compress/main.c:112
#, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr ""
-"<%s> ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht "
-"komprimieren."
+msgstr "<%s> ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht komprimieren."
#: ../raster/r.compress/main.c:155
#, c-format
@@ -4101,9 +3826,7 @@
#: ../raster/r.circle/main.c:54
msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen "
-"Punkt ziehen."
+msgstr "Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen Punkt ziehen."
#: ../raster/r.circle/main.c:64
msgid "The coordinate of the center (east,north)"
@@ -4131,9 +3854,7 @@
#: ../raster/r.circle/main.c:117
msgid "Please specify min and/or max radius when using the binary flag"
-msgstr ""
-"Bitte geben Sie einen min und/oder max Radius an, wenn Sie den Binären "
-"Schalter verwenden."
+msgstr "Bitte geben Sie einen min und/oder max Radius an, wenn Sie den Binären Schalter verwenden."
#: ../raster/r.sun/main.c:230
msgid "sun energy"
@@ -4144,23 +3865,8 @@
msgstr "Modell der Sonnen-Strahlungsdichte und -Strahlungssumme."
#: ../raster/r.sun/main.c:233
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-"Berechnet direkte (beam), diffuse und reflektierte Sonneneinstrahlung für "
-"einen angegebenen Tag, geographische Breite, Oberfläche und atmosphärische "
-"Kondition. Parameter (z.B. Sonnenauf- und -untergangszeiten, Sonnenwinkel, "
-"extraterrestrische Strahlung und Tageslänge) werden in der History-Datei der "
-"Rasterkarte abgespeichert. Alternativ kann die lokale Zeit angegeben werden, "
-"daraus wird der Einfallswinkel der Strahlung und/oder die "
-"Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann "
-"eingebunden werden."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Berechnet direkte (beam), diffuse und reflektierte Sonneneinstrahlung für einen angegebenen Tag, geographische Breite, Oberfläche und atmosphärische Kondition. Parameter (z.B. Sonnenauf- und -untergangszeiten, Sonnenwinkel, extraterrestrische Strahlung und Tageslänge) werden in der History-Datei der Rasterkarte abgespeichert. Alternativ kann die lokale Zeit angegeben werden, daraus wird der Einfallswinkel der Strahlung und/oder die Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann eingebunden werden."
#: ../raster/r.sun/main.c:247 ../raster/r.horizon/main.c:196
msgid "Name of the input elevation raster map [meters]"
@@ -4183,34 +3889,24 @@
msgstr "Eingabe Optionen"
#: ../raster/r.sun/main.c:256
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-"Name der Eingabe-Expositionskarte (Geländeexposition oder Azimuth des "
-"Sonnenstandes) [in Dezimalgrad]."
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr "Name der Eingabe-Expositionskarte (Geländeexposition oder Azimuth des Sonnenstandes) [in Dezimalgrad]."
#: ../raster/r.sun/main.c:265
msgid "A single value of the orientation (aspect), 270 is south"
msgstr "Ein einzelner Wert für die Orientierung (aspect), 270 ist Süden."
#: ../raster/r.sun/main.c:274
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-"Eingabe-Rasterkarte der Hangneigung (Geländeneigung oder "
-"Sonnenstandsinklination) [in Grad]."
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr "Eingabe-Rasterkarte der Hangneigung (Geländeneigung oder Sonnenstandsinklination) [in Grad]."
#: ../raster/r.sun/main.c:282
msgid "A single value of inclination (slope)"
msgstr "Ein einzelner Wert für die Inklination (slope)."
#: ../raster/r.sun/main.c:291
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-"Eingabe-Rasterkarte des Linke-Trübungskoeffizienten der Atmosphäre [-]."
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr "Eingabe-Rasterkarte des Linke-Trübungskoeffizienten der Atmosphäre [-]."
#: ../raster/r.sun/main.c:301
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -4234,15 +3930,11 @@
#: ../raster/r.sun/main.c:349
msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-msgstr ""
-"Eingabe-Rasterkarte mit dem Koeffizient der direkten 'real-sky' "
-"Sonneneinstrahlung [-]."
+msgstr "Eingabe-Rasterkarte mit dem Koeffizient der direkten 'real-sky' Sonneneinstrahlung [-]."
#: ../raster/r.sun/main.c:358
msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-msgstr ""
-"Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' "
+msgstr "Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' Sonneneinstrahlung [-]."
#: ../raster/r.sun/main.c:366
msgid "The horizon information input map prefix"
@@ -4270,40 +3962,24 @@
msgstr "Ausgabe Optionen"
#: ../raster/r.sun/main.c:392
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Ausgabe der gerichteten [W.m-2] (Modus 1) Strahlung oder der Abstrahlung [Wh."
-"m-2.day-1] (Modus 2)."
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe der gerichteten [W.m-2] (Modus 1) Strahlung oder der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
#: ../raster/r.sun/main.c:401
msgid "Output insolation time raster map [h] (mode 2 only)"
msgstr "Ausgabe-Rasterkarte der Sonneneinstrahlungszeit [in h] (nur Modus 2)."
#: ../raster/r.sun/main.c:410
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Ausgabe-Rasterkarte der diffusen Sonneneinstrahlung [W.m-2] (Modus 1) oder "
-"der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe-Rasterkarte der diffusen Sonneneinstrahlung [W.m-2] (Modus 1) oder der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
#: ../raster/r.sun/main.c:419
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Ausgabekarte der Grund-Ausstrahlung [W.m-2] (Modus 1) oder Intensität [Wh.m-"
-"2.day1] (Modus 2)."
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabekarte der Grund-Ausstrahlung [W.m-2] (Modus 1) oder Intensität [Wh.m-2.day1] (Modus 2)."
#: ../raster/r.sun/main.c:428
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Ausgabe der globalen (Gesamt-) Strahlungsintensität/-summe [W.m-2] (Modus 1) "
-"oder Rasterkarten der Strahlungsintensität/-summe [Wh.m-2.day-1] (Modus 2)."
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe der globalen (Gesamt-) Strahlungsintensität/-summe [W.m-2] (Modus 1) oder Rasterkarten der Strahlungsintensität/-summe [Wh.m-2.day-1] (Modus 2)."
#: ../raster/r.sun/main.c:435
msgid "No. of day of the year (1-365)"
@@ -4311,20 +3987,15 @@
#: ../raster/r.sun/main.c:444
msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-"Zeitschritt für die Berechnung der ganztägigen Strahlung [in Dezimal-"
-"Stunden]."
+msgstr "Zeitschritt für die Berechnung der ganztägigen Strahlung [in Dezimal-Stunden]."
#: ../raster/r.sun/main.c:451
msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-"Deklinationswert (überschreibt den intern berechneten Wert) [Bogenmaß]."
+msgstr "Deklinationswert (überschreibt den intern berechneten Wert) [Bogenmaß]."
#: ../raster/r.sun/main.c:459
msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-"Lokale (Sonnen-)Zeit (muss nur für Modus 1 angegeben werden) [Dezimal-"
-"Stunden]"
+msgstr "Lokale (Sonnen-)Zeit (muss nur für Modus 1 angegeben werden) [Dezimal-Stunden]"
#: ../raster/r.sun/main.c:482 ../raster/r.horizon/main.c:288
msgid "Sampling distance step coefficient (0.5-1.5)"
@@ -4336,9 +4007,7 @@
#: ../raster/r.sun/main.c:497
msgid "Civil time zone value, if none, the time will be local solar time"
-msgstr ""
-"Wert der zivilen Zeitzone. Wennnicht angegeben wird die lokale Sonnenzeit "
-"verwendet."
+msgstr "Wert der zivilen Zeitzone. Wennnicht angegeben wird die lokale Sonnenzeit verwendet."
#: ../raster/r.sun/main.c:503
msgid "Incorporate the shadowing effect of terrain"
@@ -4350,9 +4019,7 @@
#: ../raster/r.sun/main.c:555
msgid "You must give the longitude raster if you use civil time"
-msgstr ""
-"Sie müssen eine Rasterkarte mit Breitengraden angeben, wenn Sie zivile Zeit "
-"verwenden."
+msgstr "Sie müssen eine Rasterkarte mit Breitengraden angeben, wenn Sie zivile Zeit verwenden."
#: ../raster/r.sun/main.c:558
msgid "Error reading civil time zone value"
@@ -4383,23 +4050,16 @@
msgstr "Die Horizont-Schrittgröße muss größer sein als 0."
#: ../raster/r.sun/main.c:604
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-"Wenn Sie die Option 'horizon' verwenden, müssen Sie auch den 'horizonstep'-"
-"Parameter angeben."
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr "Wenn Sie die Option 'horizon' verwenden, müssen Sie auch den 'horizonstep'-Parameter angeben."
#: ../raster/r.sun/main.c:610
msgid "Time and insol_time are incompatible options"
msgstr "Time und insol_time sind nicht kompatible Optionen."
#: ../raster/r.sun/main.c:612
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
-msgstr ""
-"Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei "
-"bekannter lokaler Zeit"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
#: ../raster/r.sun/main.c:617
msgid "incidout requires time parameter to be set"
@@ -4411,24 +4071,17 @@
#: ../raster/r.sun/main.c:665
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr ""
-"Wenn sie -s und keine Horizont-Rasterkarte verwenden, muss numpartitions=1 "
-"sein."
+msgstr "Wenn sie -s und keine Horizont-Rasterkarte verwenden, muss numpartitions=1 sein."
#: ../raster/r.sun/main.c:678
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-"Wenn Sie Speicher sparen und Schatten verwenden wollen, müssen Sie einen "
-"vorher berechneten Horizont verwenden."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr "Wenn Sie Speicher sparen und Schatten verwenden wollen, müssen Sie einen vorher berechneten Horizont verwenden."
#: ../raster/r.sun/main.c:723 ../general/g.region/printwindow.c:247
#: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:622
#: ../display/d.where/main.c:106 ../imagery/i.latlong/main.c:102
msgid "Can't get projection info of current location"
-msgstr ""
-"Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
+msgstr "Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
#: ../raster/r.sun/main.c:727 ../raster/r.horizon/main.c:475
#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
@@ -4454,15 +4107,11 @@
#: ../raster/r.sun/main.c:745
msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
-msgstr ""
-"Die Rasterkarten latin und longin haben kein Effekt in einer Lat/Lon "
-"Location."
+msgstr "Die Rasterkarten latin und longin haben kein Effekt in einer Lat/Lon Location."
#: ../raster/r.sun/main.c:750
msgid "Both latin and longin raster maps must be given, or neither"
-msgstr ""
-"Entweder müssen die beiden Rasterkarten latin und longin oder keine von "
-"beiden angegeben werden."
+msgstr "Entweder müssen die beiden Rasterkarten latin und longin oder keine von beiden angegeben werden."
#: ../raster/r.out.vtk/main.c:61
#, fuzzy
@@ -4470,9 +4119,7 @@
msgstr "Konvertiert eine Rasterkarte in das VTK-ASCII-Format."
#: ../raster/r.out.vtk/main.c:72
-msgid ""
-"No input maps specified. You need to specify at least one input map or three "
-"vector maps or three rgb maps."
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
msgstr ""
#: ../raster/r.out.vtk/main.c:130 ../raster/r.out.vtk/main.c:190
@@ -4487,20 +4134,15 @@
#: ../raster/r.out.vtk/main.c:231
msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-"Falsche RGB Karten. Karten sollten den selben Typ haben! RGB Ausgabe wurde "
-"nicht hinzugefügt!"
+msgstr "Falsche RGB Karten. Karten sollten den selben Typ haben! RGB Ausgabe wurde nicht hinzugefügt!"
#: ../raster/r.out.vtk/main.c:260
msgid "Writing VTK Vector Data\n"
msgstr "Schreibe VTK Vektordaten.\n"
#: ../raster/r.out.vtk/main.c:270
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-"FalscheVektorkarten. Karten sollten den selben Typ haben! Vektor-Ausgabe "
-"wurde nicht hinzugefügt!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr "FalscheVektorkarten. Karten sollten den selben Typ haben! Vektor-Ausgabe wurde nicht hinzugefügt!"
#: ../raster/r.out.vtk/main.c:282
msgid "Error closing VTK-ASCII file"
@@ -4524,23 +4166,16 @@
msgstr "Höhe (wenn keine Rasterkarte mit Höhenwerten bestimmt wurde)."
#: ../raster/r.out.vtk/parameters.c:69
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-"Erzeuge VTK Punktdaten anstelle von VTK Cell-Daten (wenn keine Höhenkarte "
-"angegeben wurde)."
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr "Erzeuge VTK Punktdaten anstelle von VTK Cell-Daten (wenn keine Höhenkarte angegeben wurde)."
#: ../raster/r.out.vtk/parameters.c:79
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-"Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,"
-"blaue Karte]."
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr "Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,blaue Karte]."
#: ../raster/r.out.vtk/parameters.c:89
msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
+msgstr "Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
#: ../raster/r.out.vtk/parameters.c:114
msgid "Use structured grid for elevation (not recommended)"
@@ -4551,17 +4186,12 @@
msgstr "Benutze Polydata-Dreiecksstreifen für die Erzeugung des Höhengitters."
#: ../raster/r.out.vtk/parameters.c:126
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
-"Benutze Polydata-Stützpunkte für die Höhenmodellerstellung (für "
-"vtkDelauny2D)."
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr "Benutze Polydata-Stützpunkte für die Höhenmodellerstellung (für vtkDelauny2D)."
#: ../raster/r.out.vtk/parameters.c:132
msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr ""
-"Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben "
-"wurde)."
+msgstr "Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben wurde)."
#: ../raster/r.out.vtk/writeascii.c:75
msgid "write_vtk_normal_header: Writing VTK-Header"
@@ -4752,12 +4382,8 @@
msgstr "Gelände"
#: ../raster/r.slope.aspect/main.c:154
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
-"Ableitungen aus einer Rasterkarte mit Höheninformationen."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen."
#: ../raster/r.slope.aspect/main.c:156
msgid "Aspect is calculated counterclockwise from east."
@@ -4807,18 +4433,12 @@
msgstr "Name der Ausgabe-Rasterkarte mit horizontaler Wölbung."
#: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West "
-"Hangneigung)."
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr "Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
#: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd "
-"Hangneigung)."
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr "Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
#: ../raster/r.slope.aspect/main.c:223
msgid "Name for output second order partial derivative dxx raster map"
@@ -4838,15 +4458,11 @@
#: ../raster/r.slope.aspect/main.c:252
msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr ""
-"Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet "
-"werden soll."
+msgstr "Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet werden soll."
#: ../raster/r.slope.aspect/main.c:261
msgid "Do not align the current region to the elevation layer"
-msgstr ""
-"Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen "
-"anpassen."
+msgstr "Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen anpassen."
#: ../raster/r.slope.aspect/main.c:313
#, c-format
@@ -4860,12 +4476,8 @@
#: ../raster/r.slope.aspect/main.c:334
#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%"
-"s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-"Sie müssen mindestens einen der Parameter wählen: <%s>, <%s>, <%s>, <%s>, <%"
-"s>, <%s>, <%s>, <%s> oder <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "Sie müssen mindestens einen der Parameter wählen: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> oder <%s>"
#: ../raster/r.slope.aspect/main.c:358
#, c-format
@@ -4900,8 +4512,7 @@
#: ../raster/r.slope.aspect/main.c:1108
#, c-format
msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr ""
-"minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
+msgstr "minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
#: ../raster/r.slope.aspect/main.c:1161
#, c-format
@@ -4944,19 +4555,12 @@
msgstr "Dxy Rasterkarte <%s> komplett."
#: ../raster/r.cost/main.c:143
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen "
-"zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die "
-"Kategoriewerte der Eingabekarte repräsentieren die Kosten."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die Kategoriewerte der Eingabekarte repräsentieren die Kosten."
#: ../raster/r.cost/main.c:150
msgid "Name of raster map containing grid cell cost information"
-msgstr ""
-"Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
+msgstr "Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
#: ../raster/r.cost/main.c:158
#, fuzzy
@@ -4997,8 +4601,7 @@
#: ../raster/r.cost/main.c:336
msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
+msgstr "Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
#: ../raster/r.cost/main.c:458
#, fuzzy, c-format
@@ -5213,13 +4816,8 @@
msgstr "Erstelle neue Cats-Datei..."
#: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Erstellt eine Komposit-Karte, indem bekannte Kategorie-Werte einer (oder "
-"mehrerer) Rasterkarte(n) in \"NO DATA\"-Bereiche einer anderen Rasterkarte "
-"gefüllt werden."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Erstellt eine Komposit-Karte, indem bekannte Kategorie-Werte einer (oder mehrerer) Rasterkarte(n) in \"NO DATA\"-Bereiche einer anderen Rasterkarte gefüllt werden."
#: ../raster/r.patch/main.c:62
msgid "Name of raster maps to be patched together"
@@ -5258,12 +4856,8 @@
msgstr "Position"
#: ../raster/simwe/r.sim.sediment/main.c:118
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der "
-"\"path sampling\" Methode (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der \"path sampling\" Methode (SIMWE)."
#: ../raster/simwe/r.sim.sediment/main.c:125
#, fuzzy
@@ -5338,9 +4932,7 @@
msgstr "Name der Eingabe-Vektorkarte mit Startpunkten."
#: ../raster/simwe/r.sim.sediment/main.c:182
-msgid ""
-"Name of the sampling points output text file. For each observation vector "
-"point the time series of sediment transport is stored."
+msgid "Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored."
msgstr ""
#: ../raster/simwe/r.sim.sediment/main.c:183
@@ -5371,8 +4963,7 @@
#: ../raster/simwe/r.sim.sediment/main.c:195
#, fuzzy
msgid "Name for output transp.limited erosion-deposition raster map [kg/m2s]"
-msgstr ""
-"Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
+msgstr "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
#: ../raster/simwe/r.sim.sediment/main.c:202
#, fuzzy
@@ -5468,15 +5059,12 @@
#: ../raster/simwe/r.sim.water/main.c:114
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-"Hydrologische Simulation des Oberflächenabfluß mittels der \"path sampling\" "
-"Methode (SIMWE)."
+msgstr "Hydrologische Simulation des Oberflächenabfluß mittels der \"path sampling\" Methode (SIMWE)."
#: ../raster/simwe/r.sim.water/main.c:131
#, fuzzy
msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
-msgstr ""
-"Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
+msgstr "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
#: ../raster/simwe/r.sim.water/main.c:140
msgid "Rainfall excess rate unique value [mm/hr]"
@@ -5501,9 +5089,7 @@
msgstr "Name Rasterkarte, die den Fluß kontrolliert (Permeabilität: 0-1)."
#: ../raster/simwe/r.sim.water/main.c:191
-msgid ""
-"point the time series of water depth is stored."
+msgid "Name of the sampling points output text file. For each observation vector point the time series of water depth is stored."
msgstr ""
#: ../raster/simwe/r.sim.water/main.c:197
@@ -5532,9 +5118,7 @@
#: ../raster/simwe/r.sim.water/main.c:269
#, fuzzy
msgid "Diffusion increases after this water depth is reached"
-msgstr ""
-"Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe "
-"erreicht wurde)."
+msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
#: ../raster/simwe/r.sim.water/main.c:277
msgid "Diffusion increase constant"
@@ -5554,12 +5138,8 @@
#: ../raster/simwe/simlib/input.c:58
#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
-msgstr ""
-"Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, "
-"welche prozessiert werden dürfen."
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
+msgstr "Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, welche prozessiert werden dürfen."
#: ../raster/simwe/simlib/input.c:171
msgid "Zero value in Mannings n"
@@ -5567,8 +5147,7 @@
#: ../raster/simwe/simlib/input.c:222
msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
-"Die Infiltration übersteigt den Niederschlag überall! Kein Oberflächenabfluß."
+msgstr "Die Infiltration übersteigt den Niederschlag überall! Kein Oberflächenabfluß."
#: ../raster/simwe/simlib/input.c:246
#, c-format
@@ -5582,9 +5161,7 @@
#: ../raster/simwe/simlib/input.c:248
#, c-format
msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
-msgstr ""
-"Mittlere Quellgeschwindigkeit (Regenüberschuss oder Sediment) \t= %f m/s or "
-"kg/m2s \n"
+msgstr "Mittlere Quellgeschwindigkeit (Regenüberschuss oder Sediment) \t= %f m/s or kg/m2s \n"
#: ../raster/simwe/simlib/input.c:250
#, c-format
@@ -5650,8 +5227,7 @@
#: ../raster/r.to.rast3elev/main.c:99
msgid "The number of input and elevation maps is not equal"
-msgstr ""
-"Die Anzahl der Eingabe-Karten ist nicht gleich der Anzahl der Höhen-Karten."
+msgstr "Die Anzahl der Eingabe-Karten ist nicht gleich der Anzahl der Höhen-Karten."
#: ../raster/r.to.rast3elev/main.c:136 ../raster/r.to.rast3/main.c:59
msgid "Could not close the map"
@@ -5663,8 +5239,7 @@
#: ../raster/r.to.rast3elev/main.c:172
msgid "The value to fill the lower cells, default is null"
-msgstr ""
-"Der Wert mit dem die unteren Zellen gefüllt werden (Standrad ist null)."
+msgstr "Der Wert mit dem die unteren Zellen gefüllt werden (Standrad ist null)."
#: ../raster/r.to.rast3elev/main.c:175 ../raster/r.to.rast3/main.c:84
msgid "The maximum tile size in kilo bytes. Default is 32KB."
@@ -5697,9 +5272,7 @@
#: ../raster/r.to.rast3elev/main.c:366
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren "
-"Rasterkarten."
+msgstr "Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren Rasterkarten."
#: ../raster/r.to.rast3elev/main.c:400
msgid "The upper value is not valid"
@@ -5710,12 +5283,8 @@
msgstr "Der untere Wert ist nicht gültig."
#: ../raster/r.to.rast3elev/main.c:427 ../raster/r.to.rast3/main.c:230
-msgid ""
-"The 2d and 3d region settings are different. I will use the g3d settings to "
-"adjust the 2d region."
-msgstr ""
-"Die 2D und 3D Regions Parameter sind unterschiedlich. Ich werde die G3D "
-"Parameter verwenden, um die 2D Region anzupassen."
+msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
+msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Ich werde die G3D Parameter verwenden, um die 2D Region anzupassen."
#: ../raster/r.to.rast3elev/main.c:443 ../raster/r.colors/stats.c:71
#: ../raster/r.to.rast3/main.c:291
@@ -5826,9 +5395,7 @@
#: ../raster/r.out.ppm3/main.c:58
#, fuzzy
msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-"Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung "
-"der DERZEITIG EINGESTELLTEN REGION."
+msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
#: ../raster/r.out.ppm3/main.c:63 ../raster/r.composite/main.c:89
#, c-format
@@ -5858,11 +5425,8 @@
msgstr "Vektor, extrahieren"
#: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den "
-"Benutzer festgelegten Linie(n) liegen."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den Benutzer festgelegten Linie(n) liegen."
#: ../raster/r.transect/main.c:110
msgid "Raster map to be queried"
@@ -5877,12 +5441,8 @@
msgstr "Gebe Nord- und Ost-Koordinaten zuerst in 2 von 4 Spalten aus."
#: ../raster/r.random/main.c:55
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete "
-"Punkte enthalten."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete Punkte enthalten."
#: ../raster/r.random/main.c:64
msgid "Name of cover raster map"
@@ -6031,8 +5591,7 @@
#: ../raster/r.los/main.c:162
msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr ""
-"Lat/Long-Unterstützung ist für dieses Modul (noch) nicht implementiert."
+msgstr "Lat/Long-Unterstützung ist für dieses Modul (noch) nicht implementiert."
#: ../raster/r.los/main.c:167
msgid "Specified observer coordinate is outside current region bounds."
@@ -6043,11 +5602,8 @@
msgstr "Musterkarte sollte eine binäre 0/1 Rasterkarte sein."
#: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-"Habe ein Problem die Parameter des aktuellen Ellipsoids zu ermitteln, "
-"verwende Kugel (6370997.0)."
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "Habe ein Problem die Parameter des aktuellen Ellipsoids zu ermitteln, verwende Kugel (6370997.0)."
#: ../raster/r.los/main.c:250
#, c-format
@@ -6061,21 +5617,17 @@
#: ../raster/r.gwflow/main.c:62
#, fuzzy
-msgid ""
-"Input raster map providing Boundary condition status: 0-inactive, 1-active, "
-"2-dirichlet"
+msgid "Input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet"
msgstr "Status der Randbedingungen, 0-inaktive, 1-aktive, 2-dirichlet."
#: ../raster/r.gwflow/main.c:67
#, fuzzy
-msgid ""
-"Input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
+msgid "Input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der X-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster/r.gwflow/main.c:72
#, fuzzy
-msgid ""
-"Input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
+msgid "Input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
msgstr "Der Y-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
#: ../raster/r.gwflow/main.c:77
@@ -6114,25 +5666,20 @@
#: ../raster/r.gwflow/main.c:106
#, fuzzy
-msgid ""
-"Output raster map storing the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+msgid "Output raster map storing the groundwater filter velocity vector part in x direction [m/s]\n"
msgstr ""
"Berechne das Vektorfeld der Grundwasserfiltrationgeschwindigkeiten [m/s]\n"
"und schreibe die x- und y-Komponenten in Karten mit den Namen name_[xy]."
#: ../raster/r.gwflow/main.c:112
#, fuzzy
-msgid ""
-"Output raster map storing the groundwater filter velocity vector part in y "
+msgid "Output raster map storing the groundwater filter velocity vector part in y direction [m/s]\n"
msgstr ""
#: ../raster/r.gwflow/main.c:118
-msgid ""
-"Output raster map storing the groundwater budget for each cell [m^3/s]\n"
+msgid "Output raster map storing the groundwater budget for each cell [m^3/s]\n"
msgstr ""
#: ../raster/r.gwflow/main.c:126
@@ -6146,15 +5693,12 @@
#: ../raster/r.gwflow/main.c:140
#, fuzzy
-msgid ""
-"Input raster map providing the water level (head) of the river with leakage "
-"connection in [m]"
+msgid "Input raster map providing the water level (head) of the river with leakage connection in [m]"
msgstr "Wasserstand des Flusses (head) mit Sicker-Verbindung [m]."
#: ../raster/r.gwflow/main.c:147
#, fuzzy
-msgid ""
-"Input raster map providing the leakage coefficient of the river bed in [1/s]."
+msgid "Input raster map providing the leakage coefficient of the river bed in [1/s]."
msgstr "Sicker-Koeffizient des Flussbettes [1/s]."
#: ../raster/r.gwflow/main.c:155
@@ -6164,15 +5708,11 @@
#: ../raster/r.gwflow/main.c:162
#, fuzzy
-msgid ""
-"Input raster map providing the leakage coefficient of the drainage bed in [1/"
-"s]"
+msgid "Input raster map providing the leakage coefficient of the drainage bed in [1/s]"
msgstr "Sicker-Koeffizient der Drainage [1/s]."
#: ../raster/r.gwflow/main.c:173
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear "
-"equation system."
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
msgstr ""
#: ../raster/r.gwflow/main.c:206
@@ -6181,20 +5721,14 @@
msgstr "Art des Grundwasserflusses "
#: ../raster/r.gwflow/main.c:208
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-"Programm zur numerischen Berechnung von transienten, beschränkten und "
-"unbeschränkten Grundwasserfluss in zwei Dimensionen."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgstr "Programm zur numerischen Berechnung von transienten, beschränkten und unbeschränkten Grundwasserfluss in zwei Dimensionen."
#: ../raster/r.gwflow/main.c:218 ../raster/r.solute.transport/main.c:244
#: ../raster/r.topidx/main.c:53
#, c-format
msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr ""
-"Lat/Long Location wird nicht unterstützt von %s. Bitte, projezieren Sie die "
-"Karte zuerst."
+msgstr "Lat/Long Location wird nicht unterstützt von %s. Bitte, projezieren Sie die Karte zuerst."
#: ../raster/r.gwflow/main.c:233
msgid "Please provide river_head, river_leak and river_bed maps"
@@ -6209,8 +5743,7 @@
msgid ""
"The cholesky solver dos not work with sparse matrices.\n"
"You may choose a full filled quadratic matrix, flag -f. "
-msgstr ""
-"Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
#: ../raster/r.gwflow/main.c:287
#, fuzzy, c-format
@@ -6229,9 +5762,7 @@
#: ../raster/r.statistics2/main.c:104
#, fuzzy
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
msgstr "Berechnet kategorie- oder objektorientierte Statistik."
#: ../raster/r.statistics2/main.c:114 ../raster/r.statistics/main.c:76
@@ -6308,9 +5839,7 @@
#: ../raster/r.profile/main.c:53
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) "
-"benutzerdefinierter Linien liegt."
+msgstr "Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) benutzerdefinierter Linien liegt."
#: ../raster/r.profile/main.c:64
msgid "Name of file for output (use output=- for stdout)"
@@ -6349,8 +5878,7 @@
#: ../raster/r.profile/main.c:156
#, c-format
msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
-msgstr ""
-"[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
+msgstr "[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
#: ../raster/r.profile/main.c:158
#, c-format
@@ -6382,12 +5910,8 @@
msgstr "Raster, Buffer"
#: ../raster/r.buffer/main.c:69
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte "
-"haben."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte haben."
#: ../raster/r.buffer/main.c:81
#: ../locale/scriptstrings/r.buffer_to_translate.c:5
@@ -6443,12 +5967,8 @@
msgstr "Sites"
#: ../raster/r.series/main.c:136
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
-"korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
#: ../raster/r.series/main.c:145
msgid "Input file with raster map names, separated by new lines"
@@ -6519,9 +6039,7 @@
msgstr "Name der Höhenkarte"
#: ../raster/r.usler/main.c:70
-msgid ""
-"roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-"
-"Swaify (1985)"
+msgid "roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-Swaify (1985)"
msgstr ""
#: ../raster/r.spread/main.c:103 ../raster/r.spreadpath/main.c:90
@@ -6531,23 +6049,12 @@
msgstr "Linie"
#: ../raster/r.spread/main.c:105
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und "
-"erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
-"Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung "
-"und der Ursprung."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung und der Ursprung."
#: ../raster/r.spread/main.c:110
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
-msgstr ""
-"Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um "
-"Ausbreitungspfade nachzuzeichnen."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
+msgstr "Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um Ausbreitungspfade nachzuzeichnen."
#: ../raster/r.spread/main.c:118 ../raster/r.spread/main.c:127
#: ../raster/r.spread/main.c:136 ../raster/r.spread/main.c:145
@@ -6558,56 +6065,39 @@
#: ../raster/r.spread/main.c:120
msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr ""
-"Name der Rasterkarte mit den maximalen Ausbreitungsgeschwindigkeiten [cm/"
-"min]."
+msgstr "Name der Rasterkarte mit den maximalen Ausbreitungsgeschwindigkeiten [cm/min]."
#: ../raster/r.spread/main.c:129
msgid "Name of raster map containing DIRections of max ROS (degree)"
-msgstr ""
-"Name der Rasterkarte mit den Richtungen der Maximalen "
-"Ausbreitungsgeschwindigkeit [Grad]."
+msgstr "Name der Rasterkarte mit den Richtungen der Maximalen Ausbreitungsgeschwindigkeit [Grad]."
#: ../raster/r.spread/main.c:138
msgid "Name of raster map containing BASE ROS (cm/min)"
-msgstr ""
-"Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
+msgstr "Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
#: ../raster/r.spread/main.c:147
msgid "Name of raster map containing STARTing sources"
msgstr "Name der Rasterkarte mit Startpunkten."
#: ../raster/r.spread/main.c:155
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] "
-"(gefordert von dem Schalter -s)."
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr "Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] (gefordert von dem Schalter -s)."
#: ../raster/r.spread/main.c:163
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/"
-"min] (gefordert von dem Schalter -s)."
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min] (gefordert von dem Schalter -s)."
#: ../raster/r.spread/main.c:171
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer "
-"Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
+msgstr "Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
#: ../raster/r.spread/main.c:179
msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-msgstr ""
-"Stichprobenrahmengröße, die für eine bestimmte Genauigkeit benötigt wird (3)."
+msgstr "Stichprobenrahmengröße, die für eine bestimmte Genauigkeit benötigt wird (3)."
#: ../raster/r.spread/main.c:186
msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-"Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
+msgstr "Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
#: ../raster/r.spread/main.c:193
msgid "INITial TIME for current simulation (0) (min)"
@@ -6619,9 +6109,7 @@
#: ../raster/r.spread/main.c:207
msgid "Name of raster map as a display backdrop"
-msgstr ""
-"Name der Rasterkarte, die als Hintergrundkarte im Grafikfenster benutzt "
-"werden soll."
+msgstr "Name der Rasterkarte, die als Hintergrundkarte im Grafikfenster benutzt werden soll."
#: ../raster/r.spread/main.c:214 ../raster/r.spread/main.c:222
#: ../raster/r.spread/main.c:230
@@ -6650,9 +6138,7 @@
#: ../raster/r.spread/main.c:244
msgid "For wildfires: consider SPOTTING effect"
-msgstr ""
-"Bei nicht zu kontrollierenden Bränden (wildfire): beachte den Effekt der "
-"Entdeckung (Spotting-Effect)."
+msgstr "Bei nicht zu kontrollierenden Bränden (wildfire): beachte den Effekt der Entdeckung (Spotting-Effect)."
#: ../raster/r.spread/main.c:256
#, fuzzy
@@ -6673,11 +6159,8 @@
msgstr "Programm zur Erzeugung von Oberflächen."
#: ../raster/r.surf.idw2/main.c:84
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Lat/Long-Datenbank wird nicht von r.surf.idw2 unterstützt. Verwenden Sie "
-"stattdessen r.surf.idw."
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Lat/Long-Datenbank wird nicht von r.surf.idw2 unterstützt. Verwenden Sie stattdessen r.surf.idw."
#: ../raster/r.surf.idw2/main.c:88
#, c-format
@@ -6769,9 +6252,7 @@
#: ../raster/r.watershed/front/main.c:81
msgid "All non-NULL and non-zero cells are considered as real depressions"
-msgstr ""
-"Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte "
-"Bodensenke aufgefasst."
+msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Bodensenke aufgefasst."
#: ../raster/r.watershed/front/main.c:87
#, fuzzy
@@ -6791,16 +6272,12 @@
#: ../raster/r.watershed/front/main.c:101
#, fuzzy
msgid "IName of input raster map blocking overland surface flow"
-msgstr ""
-"Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
#: ../raster/r.watershed/front/main.c:103
#, fuzzy
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
-msgstr ""
-"Hindernis aufgefasst."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
#: ../raster/r.watershed/front/main.c:110
#, fuzzy
@@ -6810,9 +6287,7 @@
#: ../raster/r.watershed/front/main.c:118
#, fuzzy
msgid "Maximum length of surface flow in map units"
-msgstr ""
-"Eingabewert: Maximale Länge des Oberflächenabflusses in Karteneinheiten für "
-"USLE."
+msgstr "Eingabewert: Maximale Länge des Oberflächenabflusses in Karteneinheiten für USLE."
#: ../raster/r.watershed/front/main.c:127
#, fuzzy
@@ -6880,14 +6355,11 @@
#: ../raster/r.watershed/front/main.c:183
msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr ""
-"1 = der am meisten divergierende Fluss, 10 = der am meisten konvergierende "
-"Fluss. Empfohlen: 5."
+msgstr "1 = der am meisten divergierende Fluss, 10 = der am meisten konvergierende Fluss. Empfohlen: 5."
#: ../raster/r.watershed/front/main.c:190
msgid "Maximum memory to be used with -m flag (in MB)"
-msgstr ""
#: ../raster/r.watershed/front/main.c:194
msgid "SFD (D8) flow (default is MFD)"
@@ -6906,25 +6378,16 @@
msgstr "Schalte Auslagerung auf Festplatte an: Operation ist langsam."
#: ../raster/r.watershed/front/main.c:208
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
-"Nur benötigt wenn die Speicheranforderungen den vorhandenen Arbeitsspeicher "
-"überschreiten. Schlagen Sie im Handbuch nach wie die Speicheranforderungen "
-"berechnet werden."
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr "Nur benötigt wenn die Speicheranforderungen den vorhandenen Arbeitsspeicher überschreiten. Schlagen Sie im Handbuch nach wie die Speicheranforderungen berechnet werden."
#: ../raster/r.watershed/front/main.c:213
msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-"Verwende positive Flussakkumulation, auch für vorraussichtliche "
-"Unterschätzungen."
+msgstr "Verwende positive Flussakkumulation, auch für vorraussichtliche Unterschätzungen."
#: ../raster/r.watershed/front/main.c:215
msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-"Siehe Handbuch für detaillierte Beschreibung der Ausgabe der "
-"Flussakkumulation."
+msgstr "Siehe Handbuch für detaillierte Beschreibung der Ausgabe der Flussakkumulation."
#: ../raster/r.watershed/front/main.c:220
msgid "Beautify flat areas"
@@ -6993,50 +6456,27 @@
#: ../raster/r.watershed/seg/do_cum.c:410
#, c-format
msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr ""
-"MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d "
-"Zellen"
+msgstr "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d Zellen"
#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
#, fuzzy, c-format
msgid ""
"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold "
-"[flow=overland_flow_map] [drainage=drain_direction_map] "
-"[depression=depression_map] [accumulation=accumulation_map] "
-"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
"\n"
"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold "
-"[drainage=drain_direction_map] [depression=depression_map] "
-"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
-"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
-"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
-"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
-"creation:\n"
-"[basin=watershed_basin_map] [stream=stream_segment_map] "
-"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
"\n"
msgstr ""
"VERWENDUNG für Einzugsgebietskartierung:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
"\n"
"VERWENDUNG für ARMSED-Datei Erzeugung:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-"ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
"\n"
"VERWENDUNG für Hanglängenberechnung:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-"[de=depression_map] [ac=accumulation_map] [di=display_map] "
-"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
#: ../raster/r.watershed/ram/do_astar.c:27
#: ../raster/r.watershed/seg/do_astar.c:33
@@ -7175,9 +6615,7 @@
#: ../raster/r.watershed/seg/init_vars.c:158
#, fuzzy
msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
-msgstr ""
-"Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den "
-"Standardwert 300 MB."
+msgstr "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den Standardwert 300 MB."
#: ../raster/r.watershed/seg/init_vars.c:218
#, c-format
@@ -7236,36 +6674,27 @@
#: ../raster/r.watershed/shed/com_line.c:28
#, c-format
msgid "in its fast mode or its slow mode. If you run %s"
-msgstr ""
-"im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
+msgstr "im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
#: ../raster/r.watershed/shed/com_line.c:30
msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-"im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig "
-"sein "
+msgstr "im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig sein "
#: ../raster/r.watershed/shed/com_line.c:31
msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-"als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
+msgstr "als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
#: ../raster/r.watershed/shed/com_line.c:32
msgid "at the same time. The fast mode also places all of the data into"
-msgstr ""
-"zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausßerdem alle "
-"Daten"
+msgstr "zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausßerdem alle Daten"
#: ../raster/r.watershed/shed/com_line.c:33
msgid "RAM, which limits the size of window that can be run. The slow"
-msgstr ""
-"in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
+msgstr "in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
#: ../raster/r.watershed/shed/com_line.c:34
msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-"Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS "
-"befindet. "
+msgstr "Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS befindet. "
#: ../raster/r.watershed/shed/com_line.c:35
msgid "stored. Thus, if the program does not work in the slow mode, you will"
@@ -7273,14 +6702,12 @@
#: ../raster/r.watershed/shed/com_line.c:36
msgid "need to remove unnecessary files from that partition. The slow mode"
-msgstr ""
-"das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
+msgstr "das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
#: ../raster/r.watershed/shed/com_line.c:37
#, c-format
msgid "will allow other processes to run concurrently with %s.\n"
-msgstr ""
-"gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
+msgstr "gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
#: ../raster/r.watershed/shed/com_line.c:69
#: ../raster/r.watershed/shed/com_line.c:182
@@ -7306,38 +6733,28 @@
"Eine der Optionen für %s ist eine `Senkungskarte'. Eine "
#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
msgstr "Senkungskarte zeigt alle Orte im aktuellen Fenster an wo "
#: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
msgstr "sich Wasser sammelt und nicht am Kartenrand austritt. Seen ohne "
#: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'. If you wish to"
-msgstr ""
-"Auslassströmungen und Senklöcher sind Beispiele von 'Bodensenken'. Wenn Sie "
-"eine "
+msgid "outlet streams and sinkholes are examples of `depressions'. If you wish to"
+msgstr "Auslassströmungen und Senklöcher sind Beispiele von 'Bodensenken'. Wenn Sie eine "
#: ../raster/r.watershed/shed/com_line.c:86
msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-"Karte der Bodensenken wünschen, müssen Sie eine Karte vorbereiten, in der "
-"die Nicht-Null Zellen "
+msgstr "Karte der Bodensenken wünschen, müssen Sie eine Karte vorbereiten, in der die Nicht-Null Zellen "
#: ../raster/r.watershed/shed/com_line.c:87
msgid "locations where depressions occur.\n"
msgstr "Orte anzeigen an denen Senken vorkommen.\n"
#: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-"Drücke <return> für die nächste Frage, wenn es keine Karte der Bodensenken "
-"gibt."
+msgid "Hit <return> by itself for the next question if there is no depression map."
+msgstr "Drücke <return> für die nächste Frage, wenn es keine Karte der Bodensenken gibt."
#: ../raster/r.watershed/shed/com_line.c:99
#, c-format
@@ -7349,79 +6766,50 @@
"Das %s Programm wird die Höhenkarte in ein Anzahl von "
#: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins. The number of watershed basins is indirectly determined"
-msgstr ""
-"Einzugsgebiete unterteilen. Die Anzahl von Einzugsgebieten wird indirekt "
+msgid "watershed basins. The number of watershed basins is indirectly determined"
+msgstr "Einzugsgebiete unterteilen. Die Anzahl von Einzugsgebieten wird indirekt "
#: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value. The basin threshold is the area necessary "
-"for"
-msgstr ""
-"vom 'basin threshold' Wert festgelegt. Der 'basin threshold' ist die "
-"notwendige Fläche für "
+msgid "by the `basin threshold' value. The basin threshold is the area necessary for"
+msgstr "vom 'basin threshold' Wert festgelegt. Der 'basin threshold' ist die notwendige Fläche für "
#: ../raster/r.watershed/shed/com_line.c:103
#, c-format
msgid "%s to define a unique watershed basin. This area only applies to"
-msgstr ""
-"%s um einzelne Einzugsgebiete zu definieren. Diese Fläche gilt nur für "
+msgstr "%s um einzelne Einzugsgebiete zu definieren. Diese Fläche gilt nur für "
#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'. An exterior drainage basin does not have any"
-msgstr ""
-"außenliegende Einzugsgebiete. Ein außenliegendes Einzugsgebiet hat keine "
-"anderen "
+msgid "`exterior drainage basins'. An exterior drainage basin does not have any"
+msgstr "außenliegende Einzugsgebiete. Ein außenliegendes Einzugsgebiet hat keine anderen "
#: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it. Interior drainage basin size is determined"
-msgstr ""
-"Einzugsgebiete die mit einfließen. Die Größe von Binneneinzugsgebieten ist "
-"festgelegt "
+msgid "drainage basins flowing into it. Interior drainage basin size is determined"
+msgstr "Einzugsgebiete die mit einfließen. Die Größe von Binneneinzugsgebieten ist festgelegt "
#: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-"durch den Oberflächenabfluss, der in Flussabschnitten zwischen "
-"Stromunterbrechungen fließt. "
+msgid "by the surface flow going into stream segments between stream interceptions."
+msgstr "durch den Oberflächenabfluss, der in Flussabschnitten zwischen Stromunterbrechungen fließt. "
#: ../raster/r.watershed/shed/com_line.c:108
#, c-format
msgid "Thus interior drainage basins can be of any size. The %s program"
-msgstr ""
-"Daher können Binneneinzugsgebiete eine beliebige Größe haben. Das Programm %"
-"s "
+msgstr "Daher können Binneneinzugsgebiete eine beliebige Größe haben. Das Programm %s "
#: ../raster/r.watershed/shed/com_line.c:110
msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-"ermöglicht es dem Benutzer sogar die Behältergröße in Beziehung zum "
-"Oberflächenabfluss zu setzen "
+msgstr "ermöglicht es dem Benutzer sogar die Behältergröße in Beziehung zum Oberflächenabfluss zu setzen "
#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-"(z.B. Flächen mit niedriger Infiltrationskapazität brauchen kleinere Flächen "
-"um "
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr "(z.B. Flächen mit niedriger Infiltrationskapazität brauchen kleinere Flächen um "
#: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
-msgstr ""
-"Strömungskanäle zu entwickeln als benachbarte Flächen mit hohen "
-"Infiltrationsraten). "
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
+msgstr "Strömungskanäle zu entwickeln als benachbarte Flächen mit hohen Infiltrationsraten). "
#: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
-msgstr ""
-"Der Benutzer kann eine Karte mit potentiellen Oerflächenabflusswerten "
-"generieren, und "
+msgid "The user can create a map layer with potential overland flow values, and"
+msgstr "Der Benutzer kann eine Karte mit potentiellen Oerflächenabflusswerten generieren, und "
#: ../raster/r.watershed/shed/com_line.c:114
#, c-format
@@ -7451,8 +6839,7 @@
"How large an area (or how many overland flow units) must a drainage basin"
msgstr ""
"\n"
-"Welche Fläche (oder wie viele Oberflächenabfluss-Einheiten) muss ein "
-"Einzugsgebiet "
+"Welche Fläche (oder wie viele Oberflächenabfluss-Einheiten) muss ein Einzugsgebiet "
#: ../raster/r.watershed/shed/com_line.c:132
#, c-format
@@ -7533,9 +6920,7 @@
#: ../raster/r.watershed/shed/com_line.c:292
#, c-format
msgid "%s to function (stream channels, overland flow aspect, and"
-msgstr ""
-"%s nicht unbedingt funktionieren müssen (Strömungskanäle, Oberflächenabfluss-"
-"Aspekt und "
+msgstr "%s nicht unbedingt funktionieren müssen (Strömungskanäle, Oberflächenabfluss-Aspekt und "
#: ../raster/r.watershed/shed/com_line.c:294
#, c-format
@@ -7543,11 +6928,8 @@
msgstr "Bildschirmversion der Akkumulationskarte). %s hat auch die "
#: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
-msgstr ""
-"Möglichkeit in der verbesserten allgemeinen Bodenverlust Formel (Revised "
-"Universal Soil Loss Equation; Rusle) "
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
+msgstr "Möglichkeit in der verbesserten allgemeinen Bodenverlust Formel (Revised Universal Soil Loss Equation; Rusle) "
#: ../raster/r.watershed/shed/com_line.c:297
msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
@@ -7564,17 +6946,11 @@
#: ../raster/r.watershed/shed/com_line.c:349
#, c-format
msgid "disturbed land. %s reflects this with an optional map layer or value"
-msgstr ""
-"gestörtem Boden. %s reflektiert das mit einer optionalen Karte oder einem "
-"Wert "
+msgstr "gestörtem Boden. %s reflektiert das mit einer optionalen Karte oder einem Wert "
#: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
-msgstr ""
-"wobei der Wert den Prozentanteil von gestörtem (unfruchtbarem) Boden in der "
-"Zelle angibt. "
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+msgstr "wobei der Wert den Prozentanteil von gestörtem (unfruchtbarem) Boden in der Zelle angibt. "
#: ../raster/r.watershed/shed/com_line.c:352
msgid "Type <return> if you do not have a disturbed land map layer."
@@ -7586,8 +6962,7 @@
"Type the value indicating the percent of disturbed land. This value will"
msgstr ""
"\n"
-"Geben Sie den Wert der den Prozentansatz von gestörtem Boden indiziert ein. "
-"Dieser Wert "
+"Geben Sie den Wert der den Prozentansatz von gestörtem Boden indiziert ein. Dieser Wert "
#: ../raster/r.watershed/shed/com_line.c:365
msgid "be used for every cell in the current region."
@@ -7608,8 +6983,7 @@
"Overland surface flow only occurs for a set distance before swales form."
msgstr ""
"\n"
-"Oberflächenabfluss tritt nur für eine bestimmte Distanz auf bevor eine Senke "
-"entsteht. "
+"Oberflächenabfluss tritt nur für eine bestimmte Distanz auf bevor eine Senke entsteht. "
#: ../raster/r.watershed/shed/com_line.c:380
#, c-format
@@ -7619,12 +6993,10 @@
#: ../raster/r.watershed/shed/com_line.c:382
#, c-format
msgid "these swales. %s allows for an input (warning: kludge factor)"
-msgstr ""
-"Senken nicht aufnehmen. %s erlaubt eine Eingabe (Warnung: Kludge Faktor) "
+msgstr "Senken nicht aufnehmen. %s erlaubt eine Eingabe (Warnung: Kludge Faktor) "
#: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long. Normally,"
+msgid "that prevents the surface flow distance from getting too long. Normally,"
msgstr "das verhindert dass die Distanz des Oberflächenabfluss zu lang wird. "
#: ../raster/r.watershed/shed/com_line.c:385
@@ -7640,8 +7012,7 @@
"Straßen, Gräben, Änderung in der Oberflächenabdeckung und andere Faktoren "
#: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length. You may input a raster map indicating the locations of these"
+msgid "slope length. You may input a raster map indicating the locations of these"
msgstr "begrenzen die Hanglänge. Eine Rasterkarte mit den Standorten dieser "
#: ../raster/r.watershed/shed/com_line.c:402
@@ -7649,11 +7020,8 @@
msgstr "blockierenden Faktoren sollte angegeben werden.\n"
#: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-"Drücke <return> für die nächste Frage wenn es keine Karte der Blockierungen "
-"gibt. "
+msgid "Hit <return> by itself for the next question if there is no blocking map."
+msgstr "Drücke <return> für die nächste Frage wenn es keine Karte der Blockierungen gibt. "
#: ../raster/r.watershed/shed/basin_maps.c:12
msgid ""
@@ -7663,8 +7031,7 @@
msgstr ""
"\n"
"\n"
-"Bitte geben Sie an welche Karten verwendet werden sollen in dem "
-"konzentrierten "
+"Bitte geben Sie an welche Karten verwendet werden sollen in dem konzentrierten "
#: ../raster/r.watershed/shed/basin_maps.c:13
msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
@@ -7703,15 +7070,11 @@
#: ../raster/r.watershed/shed/basin_maps.c:39
msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-"1) es werden nur die Daten beigefügt die nur das Gebiet selbst betreffen, "
-"oder 2) "
+msgstr "1) es werden nur die Daten beigefügt die nur das Gebiet selbst betreffen, oder 2) "
#: ../raster/r.watershed/shed/basin_maps.c:40
msgid "data from the basin, and all basins upstream of it."
-msgstr ""
-"es werden die Daten zum jeweiligen Gebiet und allen stromaufwärts gelegenen "
-"verwendet. "
+msgstr "es werden die Daten zum jeweiligen Gebiet und allen stromaufwärts gelegenen verwendet. "
#: ../raster/r.watershed/shed/basin_maps.c:43
msgid ""
@@ -7761,8 +7124,7 @@
#: ../raster/r.watershed/shed/intro.c:8
#, c-format
msgid "%s provides a text-based user-interface to the %s program."
-msgstr ""
-"%s erstellt eine textbasierte Benutzerschnittstelle für das %s Programm. "
+msgstr "%s erstellt eine textbasierte Benutzerschnittstelle für das %s Programm. "
#: ../raster/r.watershed/shed/intro.c:10
#, c-format
@@ -7787,9 +7149,7 @@
#: ../raster/r.watershed/shed/intro.c:18
#, c-format
msgid "divided by basin. %s will then run %s and create the report."
-msgstr ""
-"von Behältern getrennt werden. %s wird dann %s starten und einen Bericht "
-"erstellen. "
+msgstr "von Behältern getrennt werden. %s wird dann %s starten und einen Bericht erstellen. "
#: ../raster/r.info/main.c:73
msgid "Output basic information about a raster map layer."
@@ -7825,8 +7185,7 @@
#: ../raster/r.info/main.c:113
msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
+msgstr "Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
#: ../raster/r.info/main.c:143
msgid "Unable to read range file"
@@ -7896,8 +7255,7 @@
#: ../raster/r.surf.fractal/main.c:42
msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
-"Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
+msgstr "Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
#: ../raster/r.surf.fractal/main.c:48
msgid "Fractal dimension of surface (2 < D < 3)"
@@ -7914,9 +7272,7 @@
#: ../raster/r.surf.fractal/process.c:54
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr ""
-"Kann keinen Speicherplatz allokieren. Überprüfen Sie die aktuelle Region mit "
-"g.region."
+msgstr "Kann keinen Speicher für Datenbuffer reservieren. Überprüfen Sie die aktuelle Region mit g.region."
#: ../raster/r.surf.fractal/spec_syn.c:61
msgid "Preliminary surface calculations..."
@@ -7928,12 +7284,8 @@
msgstr "Berechne die Oberfläche %d (von %d)..."
#: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
-msgstr ""
-"Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert "
-"Rasterkarte(n) aus."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert Rasterkarte(n) aus."
#: ../raster/r.covar/main.c:61
msgid "Print correlation matrix"
@@ -8024,9 +7376,7 @@
#: ../raster/r.statistics3/main.c:469
#, fuzzy, c-format
msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr ""
-"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
-"Spalten (%d) in der Eingabe überein."
+msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
#: ../raster/r.statistics3/main.c:486
#, fuzzy, c-format
@@ -8062,9 +7412,7 @@
#: ../raster/r.solute.transport/main.c:79
#, fuzzy
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
#: ../raster/r.solute.transport/main.c:85
@@ -8091,14 +7439,11 @@
msgstr "Wasserquellen und -senken [m^3/s]."
#: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
msgstr ""
#: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
msgstr ""
#: ../raster/r.solute.transport/main.c:117
@@ -8119,27 +7464,19 @@
#: ../raster/r.solute.transport/main.c:132
#, fuzzy
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
-msgstr ""
-"Das resultierende piezometrisches Niveau der numerischen Berechnung wird in "
-"diese Karte geschrieben."
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
+msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
#: ../raster/r.solute.transport/main.c:140
#, fuzzy
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
msgstr ""
#: ../raster/r.solute.transport/main.c:147
#, fuzzy
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
msgstr ""
@@ -8153,9 +7490,7 @@
msgstr ""
#: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
msgstr ""
#: ../raster/r.solute.transport/main.c:187
@@ -8173,12 +7508,8 @@
#: ../raster/r.solute.transport/main.c:233
#, fuzzy
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
-msgstr ""
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
#: ../raster/r.solute.transport/main.c:258
msgid "The direct LU solver do not work with sparse matrices"
@@ -8186,8 +7517,7 @@
#: ../raster/r.solute.transport/main.c:260
msgid "The direct Gauss solver do not work with sparse matrices"
-msgstr ""
-"Der direkte Gauss'sche Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr "Der direkte Gauss'sche Löser funktioniert nicht mit dünnbesetzten Matrizen."
#: ../raster/r.solute.transport/main.c:370
#, c-format
@@ -8211,8 +7541,7 @@
#: ../raster/r.solute.transport/main.c:385
#, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
msgstr ""
#: ../raster/r.solute.transport/main.c:397
@@ -8235,9 +7564,7 @@
#: ../raster/r.in.lidar/main.c:165
#, fuzzy
msgid "Create a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
-"univariater Statistik."
+msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
#: ../raster/r.in.lidar/main.c:169
#, fuzzy
@@ -8272,24 +7599,17 @@
msgstr "Perzentil der Werte"
#: ../raster/r.in.lidar/main.c:229 ../raster/r.in.xyz/main.c:256
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-"Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten "
-"Beobachtungen."
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
+msgstr "Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten Beobachtungen."
#: ../raster/r.in.lidar/main.c:235 ../vector/v.in.ogr/main.c:249
#: ../vector/v.in.lidar/main.c:203
msgid "Override dataset projection (use location's projection)"
-msgstr ""
-"Übersteuere die Projektion des Datensatzes (verwende Projektion der "
-"Location)."
+msgstr "Übersteuere die Projektion des Datensatzes (verwende Projektion der Location)."
#: ../raster/r.in.lidar/main.c:239 ../raster/r.in.xyz/main.c:261
msgid "Scan data file for extent then exit"
-msgstr ""
-"Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
+msgstr "Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
#: ../raster/r.in.lidar/main.c:245 ../raster/r.in.xyz/main.c:266
msgid "In scan mode, print using shell script style"
@@ -8302,12 +7622,8 @@
#: ../raster/r.in.lidar/main.c:282 ../vector/v.in.ogr/main.c:536
#: ../vector/v.in.lidar/main.c:362
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-"Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format "
-"konvertieren, zwecks Überprüfung."
+msgid "Unable to convert input map projection information to GRASS format for checking"
+msgstr "Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format konvertieren, zwecks Überprüfung."
#: ../raster/r.in.lidar/main.c:312 ../vector/v.in.ogr/main.c:566
#: ../vector/v.in.lidar/main.c:395
@@ -8322,17 +7638,12 @@
"You can use the -o flag to %s to override this projection check.\n"
msgstr ""
"\n"
-"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu "
-"übersteuern.\n"
+"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu übersteuern.\n"
#: ../raster/r.in.lidar/main.c:375 ../vector/v.in.ogr/main.c:629
#: ../vector/v.in.lidar/main.c:458
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der "
-"Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr "Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
#: ../raster/r.in.lidar/main.c:392 ../raster/r.in.xyz/main.c:307
msgid "Invalid zrange"
@@ -8395,8 +7706,7 @@
#: ../raster/r.proj/main.c:150
#, fuzzy
msgid "Re-projects a raster map from given location to the current location."
-msgstr ""
-"Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
#: ../raster/r.proj/main.c:153
msgid "Name of input raster map to re-project"
@@ -8457,16 +7767,11 @@
#: ../raster/r.proj/main.c:220
msgid "Print input map's bounds in the current projection and exit"
-msgstr ""
-"Gibt die Grenzen der Eingabekarte in der aktuellen Projektion aus und "
-"beendet sich."
+msgstr "Gibt die Grenzen der Eingabekarte in der aktuellen Projektion aus und beendet sich."
#: ../raster/r.proj/main.c:226
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-"Gibt die Grenzen der Eingabekarte in der aktuellen Projektion im Shellskript-"
-"Format aus und beendet sich."
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr "Gibt die Grenzen der Eingabekarte in der aktuellen Projektion im Shellskript-Format aus und beendet sich."
#: ../raster/r.proj/main.c:251 ../vector/v.proj/main.c:134
#: ../vector/v.external/main.c:87
@@ -8484,8 +7789,7 @@
#: ../raster/r.proj/main.c:269
msgid "Unable to get projection info of output raster map"
-msgstr ""
-"Kann die Projektionsinformation der Ausgabe-Rasterkarte nicht ermitteln."
+msgstr "Kann die Projektionsinformation der Ausgabe-Rasterkarte nicht ermitteln."
#: ../raster/r.proj/main.c:272
msgid "Unable to get projection units of output raster map"
@@ -8493,8 +7797,7 @@
#: ../raster/r.proj/main.c:275
msgid "Unable to get projection key values of output raster map"
-msgstr ""
-"Kann die Kennzahlen der Projektion der Ausgabe-Rasterkarte nicht ermitteln."
+msgstr "Kann die Kennzahlen der Projektion der Ausgabe-Rasterkarte nicht ermitteln."
#: ../raster/r.proj/main.c:284
#, c-format
@@ -8693,12 +7996,8 @@
msgstr "Kann die temporäre Datei nicht schreiben."
#: ../raster/r.fill.dir/main.c:88
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtert und generiert ein depressionsloses Höhenmodell und eine "
-"Fließrichtungskarte auf Basis eines gegebenen Höhenmodells."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtert und generiert ein depressionsloses Höhenmodell und eine Fließrichtungskarte auf Basis eines gegebenen Höhenmodells."
#: ../raster/r.fill.dir/main.c:95 ../raster/r.topmodel/main.c:82
#, fuzzy
@@ -8707,8 +8006,7 @@
#: ../raster/r.fill.dir/main.c:99 ../raster/r.topmodel/main.c:89
#, fuzzy
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+msgid "Name for output flow direction map for depressionless elevation raster map"
msgstr "(o) Richtungskarte für abflusslose Höhenkarte."
#: ../raster/r.fill.dir/main.c:104
@@ -8772,8 +8070,7 @@
#: ../raster/r.resamp.interp/main.c:79
msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr ""
-"Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
+msgstr "Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
#: ../raster/r.resamp.interp/main.c:88 ../vector/v.sample/main.c:102
msgid "Interpolation method"
@@ -8793,8 +8090,7 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr ""
-"zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
+msgstr "zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
#: ../raster/r.univar/r.univar_main.c:54
#: ../raster/r.univar/r3.univar_main.c:55
@@ -8819,29 +8115,20 @@
msgstr "Tabellenausgabeformat anstatt Standardausgabeformat"
#: ../raster/r.univar/r.univar_main.c:99
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
#: ../raster/r.univar/r3.univar_main.c:37
msgid "3D Raster map used for zoning, must be of type CELL"
msgstr "3D Rasterkarte für Zonenbildung, muss vom Typ CELL sein"
#: ../raster/r.univar/r3.univar_main.c:102
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-"
-"Rasterkarte."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgstr "Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-Rasterkarte."
#: ../raster/r.cross/main.c:76
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
#: ../raster/r.cross/main.c:85
#, c-format
@@ -8882,14 +8169,8 @@
msgstr "%s: Schritt 3 ... "
#: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Reinterpoliert und berechnet ggf. topographische Analysen basierend auf "
-"einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von "
-"regularized splines with tension and smoothing (RST)."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Reinterpoliert und berechnet ggf. topographische Analysen basierend auf einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von regularized splines with tension and smoothing (RST)."
#: ../raster/r.resamp.rst/main.c:162
msgid "Desired east-west resolution"
@@ -8961,8 +8242,7 @@
#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:165
msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-"Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
+msgstr "Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
#: ../raster/r.resamp.rst/main.c:313
#, fuzzy
@@ -9009,9 +8289,7 @@
#: ../raster/r.resamp.rst/main.c:389
msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-"Auflösung der Eingabekarte unterscheidet sich von der aktuellen "
-"Regionsauflösung!"
+msgstr "Auflösung der Eingabekarte unterscheidet sich von der aktuellen Regionsauflösung!"
#: ../raster/r.resamp.rst/main.c:407
msgid "Processing all selected output files will require"
@@ -9066,8 +8344,7 @@
#: ../raster/r.resamp.rst/main.c:526
#, fuzzy
msgid "Unable to write raster maps -- try increasing cell size"
-msgstr ""
-"Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
+msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
#: ../raster/r.resamp.rst/main.c:553 ../raster/r.in.ascii/main.c:131
#: ../raster/r.in.ascii/main.c:158 ../raster/r.in.arc/main.c:115
@@ -9090,9 +8367,7 @@
msgstr "Kein Punkte mit Kategorie [%d]."
#: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
msgstr "Verwaltet die Kategoriewerte und Label von Rasterkarten."
#: ../raster/r.category/main.c:68
@@ -9105,13 +8380,11 @@
#: ../raster/r.category/main.c:86
msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+msgstr "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
#: ../raster/r.category/main.c:93
msgid "Default label or format string for dynamic labeling"
-msgstr ""
-"Standard-Beschriftung oder eine Formatanweisung für dynamische Beschriftung."
+msgstr "Standard-Beschriftung oder eine Formatanweisung für dynamische Beschriftung."
#: ../raster/r.category/main.c:95
msgid "Used when no explicit label exists for the category"
@@ -9144,9 +8417,7 @@
#: ../raster/r.category/main.c:265
msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"Die Karte ist eine Fließkommazahl-Karte. Ignoriere Kategorieliste, nehme "
-"stattdessen Vals-Liste."
+msgstr "Die Karte ist eine Fließkommazahl-Karte. Ignoriere Kategorieliste, nehme stattdessen Vals-Liste."
#: ../raster/r.category/main.c:282
msgid "vals argument is required for floating point map!"
@@ -9163,12 +8434,8 @@
msgstr "1 Klasse gefunden."
#: ../raster/r.clump/main.c:50
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch "
-"diskreter Areale zu eindeutigen Kategorie gruppiert werden."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch diskreter Areale zu eindeutigen Kategorie gruppiert werden."
#: ../raster/r.clump/main.c:61
#, fuzzy
@@ -9212,19 +8479,12 @@
#: ../raster/r.out.tiff/main.c:176
#, fuzzy, c-format
-msgid ""
-"Raster map <%s>> is a floating point map. Fractional values will be rounded "
-"to integer"
-msgstr ""
-"Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. "
-"Nachkommastellen werden auf ganze Zahlen gerundet!"
+msgid "Raster map <%s>> is a floating point map. Fractional values will be rounded to integer"
+msgstr "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. Nachkommastellen werden auf ganze Zahlen gerundet!"
#: ../raster/r.out.tiff/main.c:182
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
-msgstr ""
-"Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
+msgid "Color map for palette must have less than 256 colors for the available range of data"
+msgstr "Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
#: ../raster/r.out.tiff/main.c:196
#, c-format
@@ -9240,12 +8500,8 @@
msgstr "Kann das TIFF-Worldfile nicht zum Schreiben öffnen."
#: ../raster/r.in.xyz/main.c:164
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
#: ../raster/r.in.xyz/main.c:168
msgid "ASCII file containing input data (or \"-\" to read from stdin)"
@@ -9253,8 +8509,7 @@
#: ../raster/r.in.xyz/main.c:199
msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-"Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
+msgstr "Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
#: ../raster/r.in.xyz/main.c:207
msgid "Column number of y coordinates in input file"
@@ -9273,22 +8528,17 @@
msgstr "Bitte geben Sie eine sinnvolle Spaltenummer an."
#: ../raster/r.in.xyz/main.c:482
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-"Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang "
-"ausgeführt werden."
+msgid "If input is not from a file it is only possible to perform a single pass."
+msgstr "Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang ausgeführt werden."
#: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
#: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
#, c-format
msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
"[%s]"
msgstr ""
-"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe "
-"die folgenden Zeichen in Zeile %lu gefunden:\n"
+"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe die folgenden Zeichen in Zeile %lu gefunden:\n"
"[%s]"
#: ../raster/r.in.xyz/main.c:606 ../raster/r.in.xyz/main.c:1105
@@ -9386,20 +8636,12 @@
#: ../raster/r.texture/h_measure.c:123
#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-"Zu viele Kategorien (gefunden %i, Max: %i). Versuchen Sie die Karte zu "
-"reklassifizieren oder zu reskalieren."
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+msgstr "Zu viele Kategorien (gefunden %i, Max: %i). Versuchen Sie die Karte zu reklassifizieren oder zu reskalieren."
#: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren "
-"Spanne vom Benutzer angegeben werden kann."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren Spanne vom Benutzer angegeben werden kann."
#: ../raster/r.surf.random/main.c:47
msgid "Minimum random value"
@@ -9436,15 +8678,12 @@
#: ../raster/r.out.arc/main.c:94
msgid "Use cell center reference in header instead of cell corner"
-msgstr ""
-"Verwende als Referenz im Header den Zellmittelpunkt anstelle der Zellecke."
+msgstr "Verwende als Referenz im Header den Zellmittelpunkt anstelle der Zellecke."
#: ../raster/r.surf.contour/main.c:64
#, fuzzy
msgid "Generates surface raster map from rasterized contours."
-msgstr ""
-"Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit "
-"Höheninformationen."
+msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit Höheninformationen."
#: ../raster/r.surf.contour/main.c:67
#, fuzzy
@@ -9454,8 +8693,7 @@
#: ../raster/r.colors/rules.c:40
#, c-format
msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr ""
-"Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
+msgstr "Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
#: ../raster/r.colors/rules.c:49
#, c-format
@@ -9473,8 +8711,7 @@
"Your color rules do not cover the whole range of data!\n"
" (rules %f to %f but data %f to %f)"
msgstr ""
-"Die ausgewählten Farbregeln erstrecken sich nicht über den gesamten "
-"Wertebereich!\n"
+"Die ausgewählten Farbregeln erstrecken sich nicht über den gesamten Wertebereich!\n"
"(Regelsatz: %f - %f aber Daten: %f - %f)"
#: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
@@ -9524,9 +8761,7 @@
#: ../raster/r.colors/stats.c:84
msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr ""
-"Kann keine logarithmische Skala verwenden, wenn der Wertebereich Null "
-"enthält."
+msgstr "Kann keine logarithmische Skala verwenden, wenn der Wertebereich Null enthält."
#: ../raster/r.colors/stats.c:112
#, fuzzy, c-format
@@ -9621,9 +8856,7 @@
#: ../raster/r.colors/edit_colors.c:159 ../vector/v.colors/main.c:172
#, fuzzy, c-format
msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr ""
-"Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder "
-"\"rules\" muss angegeben werden!"
+msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
#: ../raster/r.colors/edit_colors.c:164
#, fuzzy, c-format
@@ -9767,24 +9000,15 @@
#: ../raster/r.li/r.li.mpa/mpa.c:38
msgid "Calculates mean pixel attribute index on a raster map"
-msgstr ""
-"Berechnet den Mittelwert der Attribute (Rasterwerte) -Index einer "
-"Rasterkarte."
+msgstr "Berechnet den Mittelwert der Attribute (Rasterwerte) -Index einer Rasterkarte."
#: ../raster/r.li/r.li.patchnum/main.c:35
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-"
-"Nachbarn-Algorithmus."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
#: ../raster/r.li/r.li.mps/mps.c:39
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-"Berechnet mittleren Patch-Größen-Index einer Rasterkarte, unter Verwendung "
-"eines 4-Nachbarn-Algorithmus."
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet mittleren Patch-Größen-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
#: ../raster/r.li/r.li.pielou/pielou.c:57
msgid "Calculates Pielou's diversity index on a raster map"
@@ -9800,11 +9024,8 @@
msgstr "Zeige den Index."
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Berechnet Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
#: ../raster/r.li/r.li.cwed/cwed.c:45
msgid "Calculates contrast weighted edge density index on a raster map"
@@ -9828,11 +9049,8 @@
msgstr "Berechnet den Form-Index einer Rasterkarte."
#: ../raster/r.li/r.li.patchdensity/main.c:34
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
#: ../raster/r.li/r.li.simpson/simpson.c:38
msgid "Calculates Simpson's diversity index on a raster map"
@@ -9884,8 +9102,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:363
#, c-format
msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-msgstr ""
-"Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
+msgstr "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
#: ../raster/r.li/r.li.daemon/daemon.c:370
msgid "Illegal configuration file (sample area)"
@@ -9973,9 +9190,7 @@
#: ../raster/r.out.gdal/main.c:159
#, fuzzy
msgid "Raster data format to write (case sensitive, see also -l flag)"
-msgstr ""
-"GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung "
-"beachten, siehe auch den Schalter -l)."
+msgstr "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung beachten, siehe auch den Schalter -l)."
#: ../raster/r.out.gdal/main.c:180
#, fuzzy
@@ -9995,12 +9210,8 @@
msgstr "Metadaten Schlüsselwort(e) und Wert(e), die eingefügt werden sollen."
#: ../raster/r.out.gdal/main.c:202
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
-msgstr ""
-"Im Format \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. "
-"Wird nicht von allen Treibern unterstützt."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
+msgstr "Im Format \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. Wird nicht von allen Treibern unterstützt."
#: ../raster/r.out.gdal/main.c:212
msgid "Assign a specified nodata value to output bands"
@@ -10023,12 +9234,8 @@
#: ../raster/r.out.gdal/main.c:266
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
-"Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-"
-"Treiber für einen Zwischendatensatz."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgstr "Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-Treiber für einen Zwischendatensatz."
#: ../raster/r.out.gdal/main.c:271
msgid "Unable to get in-memory raster driver"
@@ -10051,36 +9258,22 @@
#: ../raster/r.out.gdal/main.c:423
msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
-"Rasterexport würde kompletten Datenverlust bedeuten, breche die Aktion ab."
+msgstr "Rasterexport würde kompletten Datenverlust bedeuten, breche die Aktion ab."
#: ../raster/r.out.gdal/main.c:434
#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
-msgstr ""
-"Präzisionsverlust: Rasterkarte <%s> vom Typ %s soll als %s exportiert "
-"werden. Dies kann verhindert werden mit %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
+msgstr "Präzisionsverlust: Rasterkarte <%s> vom Typ %s soll als %s exportiert werden. Dies kann verhindert werden mit %s."
#: ../raster/r.out.gdal/main.c:445
#, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
-"Präzisionsverlust: Der Wertebereich von <%s> kann nicht korrekt erhalten "
-"werden mit dem GDAL Datentyp Float32. Dies kann verhindert werden durch "
-"Export nach Int32 oder Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr "Präzisionsverlust: Der Wertebereich von <%s> kann nicht korrekt erhalten werden mit dem GDAL Datentyp Float32. Dies kann verhindert werden durch Export nach Int32 oder Float64."
#: ../raster/r.out.gdal/main.c:453
#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
-msgstr ""
-"Präzisionsverlust: Float32 kann die Präzision der DCELL Rasterkarte <%s> "
-"nicht erhalten. Dies kann verhindert werden mit Float64."
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
+msgstr "Präzisionsverlust: Float32 kann die Präzision der DCELL Rasterkarte <%s> nicht erhalten. Dies kann verhindert werden mit Float64."
#: ../raster/r.out.gdal/main.c:462 ../raster/r.out.gdal/main.c:505
msgid "Forcing raster export."
@@ -10183,10 +9376,7 @@
#: ../raster/r.out.gdal/main.c:743 ../raster/r.out.gdal/main.c:756
#: ../raster/r.out.gdal/main.c:771
#, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
msgstr ""
#: ../raster/r.out.gdal/main.c:719 ../raster/r.out.gdal/main.c:746
@@ -10202,14 +9392,8 @@
#: ../raster/r.out.gdal/main.c:785
#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
-msgstr ""
-"NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten "
-"Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %g wird von "
-"dem gewählten GDAL-Datentyp nach %g konvertiert."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
+msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %g wird von dem gewählten GDAL-Datentyp nach %g konvertiert."
#: ../raster/r.out.gdal/main.c:788
#, c-format
@@ -10219,49 +9403,27 @@
#: ../raster/r.out.gdal/export_band.c:63
#: ../raster/r.out.gdal/export_band.c:354
msgid "Unable to allocate buffer for reading raster map"
-msgstr "Kann keinen Speicherplatz zum Lesen der Rasterkarte belegen."
+msgstr "Kann keinen Speicher zum Lesen der Rasterkarte reservieren."
#: ../raster/r.out.gdal/export_band.c:171
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
-msgstr ""
-"Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
-"%d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie "
-"können NoData-Wert mit dem Parameter %s bestimmen."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie können NoData-Wert mit dem Parameter %s bestimmen."
#: ../raster/r.out.gdal/export_band.c:176
#, fuzzy, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
-msgstr ""
-"Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
-"%d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie "
-"können Nodata-Wert mit dem Parameter %s bestimmen."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
#: ../raster/r.out.gdal/export_band.c:186
#, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
-"Der Standard-NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
-"Datenverlust führen. Bitte geben Sie einen eignen NoData-Wert mit dem "
-"Parameter %s an."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
+msgstr "Der Standard-NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen eignen NoData-Wert mit dem Parameter %s an."
#: ../raster/r.out.gdal/export_band.c:193
#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
-"Der gewählte NoData-Wert %g ist im Rasterkanal <%s> vorhanden und würde zu "
-"Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
-"Parameter %s an."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
+msgstr "Der gewählte NoData-Wert %g ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem Parameter %s an."
#: ../raster/r.out.gdal/export_band.c:235
msgid "Unable to get raster band"
@@ -10300,9 +9462,8 @@
#: ../raster/r.null/main.c:73 ../raster/r.null/main.c:81
#: ../general/g.proj/main.c:178
-#, fuzzy
msgid "Modify"
-msgstr "Verschiedenes"
+msgstr "Modifizieren"
#: ../raster/r.null/main.c:85
msgid "Only do the work if the map is floating-point"
@@ -10311,7 +9472,7 @@
#: ../raster/r.null/main.c:86 ../raster/r.null/main.c:91
#: ../raster/r.null/main.c:97
msgid "Check"
-msgstr ""
+msgstr "Prüfen"
#: ../raster/r.null/main.c:90
msgid "Only do the work if the map is integer"
@@ -10319,15 +9480,11 @@
#: ../raster/r.null/main.c:96
msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr ""
-"Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei "
-"existiert."
+msgstr "Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei existiert."
#: ../raster/r.null/main.c:102
msgid "Create NULL-value bitmap file validating all data cells"
-msgstr ""
-"Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig "
-"erklärt."
+msgstr "Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig erklärt."
#: ../raster/r.null/main.c:106
msgid "Remove NULL-value bitmap file"
@@ -10335,13 +9492,8 @@
#: ../raster/r.null/main.c:125
#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
-msgstr ""
-"Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. "
-"Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu "
-"erzeugen. Beende mich."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
+msgstr "Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu erzeugen. Beende mich."
#: ../raster/r.null/main.c:131
#, c-format
@@ -10405,9 +9557,7 @@
#: ../raster/r.grow/main.c:124 ../locale/scriptstrings/r.grow_to_translate.c:1
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen "
-"Flächen."
+msgstr "Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen Flächen."
#: ../raster/r.grow/main.c:135 ../locale/scriptstrings/r.grow_to_translate.c:4
msgid "Radius of buffer in raster cells"
@@ -10420,9 +9570,7 @@
#: ../raster/r.grow/main.c:151 ../locale/scriptstrings/r.grow_to_translate.c:6
msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr ""
-"Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben "
-"werden."
+msgstr "Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben werden."
#: ../raster/r.grow/main.c:157 ../locale/scriptstrings/r.grow_to_translate.c:7
msgid "Value to write for \"grown\" cells"
@@ -10450,8 +9598,7 @@
#: ../raster/r.out.vrml/main.c:51
#, fuzzy
msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-"Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
+msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
#: ../raster/r.out.vrml/main.c:58
msgid "Name of elevation map"
@@ -10472,16 +9619,12 @@
#: ../raster/r.out.vrml/main.c:98
#, fuzzy, c-format
msgid "Range info for [%s] not available (run r.support)"
-msgstr ""
-"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
-"aus)."
+msgstr "Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support aus)."
#: ../raster/r.out.vrml/main.c:107
#, fuzzy, c-format
msgid "Range info for <%s> not available (run r.support)"
-msgstr ""
-"aus)."
#: ../raster/r.out.vrml/main.c:139
#, c-format
@@ -10714,8 +9857,7 @@
#: ../raster/r.grow.distance/main.c:152
#, fuzzy
msgid "Generates a raster map of distance to features in input raster map."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
+msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
#: ../raster/r.grow.distance/main.c:159
msgid "Name for distance output map"
@@ -10755,8 +9897,7 @@
#: ../raster/r.topmodel/main.c:65
msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr ""
-"Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
+msgstr "Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
#: ../raster/r.topmodel/main.c:75
#, fuzzy
@@ -10827,18 +9968,12 @@
msgstr "Volumen Position"
#: ../raster/r.sunmask/main.c:118
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
-msgstr ""
-"Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
+msgstr "Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
#: ../raster/r.sunmask/main.c:119
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-"Entweder wird die exakte Sonnenposition (A) oder Datum/Uhrzeit zur "
-"Berechnung der Sonnenposition durch r.sunmask (B) angegeben."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr "Entweder wird die exakte Sonnenposition (A) oder Datum/Uhrzeit zur Berechnung der Sonnenposition durch r.sunmask (B) angegeben."
#: ../raster/r.sunmask/main.c:133
msgid "Altitude of the sun above horizon, degrees (A)"
@@ -10890,9 +10025,7 @@
#: ../raster/r.sunmask/main.c:199
msgid "East positive, offset from GMT, also use to adjust daylight savings"
-msgstr ""
-"Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit "
-"genutzt"
+msgstr "Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit genutzt"
#: ../raster/r.sunmask/main.c:208
msgid "Easting coordinate (point of interest)"
@@ -10936,12 +10069,8 @@
msgstr "Definiere Sie entweder die Sonnenposition oder Ort/Datum/Zeit."
#: ../raster/r.sunmask/main.c:279
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
-msgstr ""
-"Weder die Sonnenposition noch Ost/Nord, Datum/Uhrzeit/Zeitzone sind "
-"vollständig angegeben."
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+msgstr "Weder die Sonnenposition noch Ost/Nord, Datum/Uhrzeit/Zeitzone sind vollständig angegeben."
#: ../raster/r.sunmask/main.c:283
#, c-format
@@ -10949,12 +10078,8 @@
msgstr "Berechne Sonnenposition... (verwende solpos (V. %s) vom NREL)"
#: ../raster/r.sunmask/main.c:288
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
-msgstr ""
-"Verwende benutzerdefinierten Sonnenazimuth und Höhe (ignoriere eventuell "
-"anderen Werte)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
+msgstr "Verwende benutzerdefinierten Sonnenazimuth und Höhe (ignoriere eventuell anderen Werte)"
#: ../raster/r.sunmask/main.c:396
msgid "Please correct settings"
@@ -10996,8 +10121,7 @@
#: ../raster/r.sunmask/main.c:453
#, c-format
msgid "Unable to open range file for raster map <%s>"
-msgstr ""
-"Kann die Datei mit dem Wertebereich für die Rasterkarte <%s> nicht lesen."
+msgstr "Kann die Datei mit dem Wertebereich für die Rasterkarte <%s> nicht lesen."
#: ../raster/r.sunmask/main.c:469
msgid "Calculating shadows from DEM..."
@@ -11091,40 +10215,28 @@
#: ../raster/r.sunmask/solpos00.c:993
#, c-format
msgid "S_decode ==> Please fix the shadowband sky factor: %f"
-msgstr ""
-"S_decode ==> Bitte berichtigen Sie den 'sky factor' des Schattenbandes: %f"
+msgstr "S_decode ==> Bitte berichtigen Sie den 'sky factor' des Schattenbandes: %f"
#: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
-msgstr ""
-"Die Sonnenposition kann in unprojezierten Locations nicht berechnet werden. "
-"Sonnenposition muss direkt eingegeben werden."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgstr "Die Sonnenposition kann in unprojezierten Locations nicht berechnet werden. Sonnenposition muss direkt eingegeben werden."
#: ../raster/r.sunmask/g_solposition.c:88
#, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
-msgstr ""
-"Angegebener Punkt %f, %f ist außerhalb der aktuellen Gebietsausdehnung, ist "
-"dies beabsichtigt? Trotzdem, die Einstellungen werden verwendet."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgstr "Angegebener Punkt %f, %f ist außerhalb der aktuellen Gebietsausdehnung, ist dies beabsichtigt? Trotzdem, die Einstellungen werden verwendet."
#: ../raster/r.sunmask/g_solposition.c:98
msgid "Unable to get projection info of current location"
-msgstr ""
-"Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
+msgstr "Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
#: ../raster/r.sunmask/g_solposition.c:101
msgid "Unable to get projection units of current location"
-msgstr ""
-"Kann die Einheiten der Projektion der aktuellen Location nicht ermitteln."
+msgstr "Kann die Einheiten der Projektion der aktuellen Location nicht ermitteln."
#: ../raster/r.sunmask/g_solposition.c:104
msgid "Unable to get projection key values of current location"
-msgstr ""
-"Kann die Kennzahlen der Projektion der aktuellen Location nicht ermitteln."
+msgstr "Kann die Kennzahlen der Projektion der aktuellen Location nicht ermitteln."
#: ../raster/r.random.surface/main.c:61
msgid "Generates random surface(s) with spatial dependence."
@@ -11149,8 +10261,7 @@
#: ../raster/r.random.surface/main.c:102
#, fuzzy
msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
-msgstr ""
-"Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
+msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
#: ../raster/r.random.surface/main.c:108
msgid "Maximum cell value of distribution"
@@ -11223,9 +10334,7 @@
#: ../raster/r.thin/main.c:59
msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr ""
-"Dünnt Zellen, die nicht null sind und linienhafte Strukturen in einer "
-"Rasterkarte abbilden."
+msgstr "Dünnt Zellen, die nicht null sind und linienhafte Strukturen in einer Rasterkarte abbilden."
#: ../raster/r.thin/main.c:71
msgid "Maximal number of iterations"
@@ -11287,9 +10396,7 @@
#: ../raster/r.thin/thin_lines.c:175
msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-"Ausdünnung nicht vollständig. Es könnte sinnvoll sein den Wert des Parameter "
-"'iterations' zu erhöhen."
+msgstr "Ausdünnung nicht vollständig. Es könnte sinnvoll sein den Wert des Parameter 'iterations' zu erhöhen."
#: ../raster/r.reclass/main.c:51
#, fuzzy
@@ -11303,12 +10410,8 @@
#: ../raster/r.reclass/main.c:54
#, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der "
-"Kategorien einer existierenden Rasterkarte basieren."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
#: ../raster/r.reclass/main.c:59
#, fuzzy
@@ -11339,8 +10442,7 @@
#: ../raster/r.reclass/main.c:103
#, c-format
msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
#: ../raster/r.reclass/main.c:105
#, fuzzy, c-format
@@ -11427,8 +10529,7 @@
#: ../raster/r.timestamp/main.c:38
msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
-"Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
+msgstr "Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
#: ../raster/r.timestamp/main.c:47
msgid "Datetime, datetime1/datetime2, or 'none' to remove"
@@ -11471,9 +10572,7 @@
#: ../raster/r.to.vect/main.c:98
msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"Benutze Rasterzellenwerte als Kategoriewerte anstelle von eindeutigen "
-"Sequenzen (nur bei CELL-Karten)."
+msgstr "Benutze Rasterzellenwerte als Kategoriewerte anstelle von eindeutigen Sequenzen (nur bei CELL-Karten)."
#: ../raster/r.to.vect/main.c:99 ../raster/r.to.vect/main.c:106
#: ../vector/v.in.ogr/main.c:209 ../vector/v.in.ogr/main.c:244
@@ -11492,9 +10591,7 @@
#: ../raster/r.to.vect/main.c:104
#, fuzzy
msgid "Table is not created. Currently supported only for points."
-msgstr ""
-"Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. "
-"Derzeit werden nur Punkte unterstützt."
+msgstr "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. Derzeit werden nur Punkte unterstützt."
#: ../raster/r.to.vect/main.c:110
#, fuzzy
@@ -11504,21 +10601,15 @@
#: ../raster/r.to.vect/main.c:111
#, fuzzy
msgid "Recommended for massive point conversion"
-msgstr ""
-"Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von "
-"extrem großen Punktmengen)."
+msgstr "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von extrem großen Punktmengen)."
#: ../raster/r.to.vect/main.c:121
msgid "z flag is supported only for points"
msgstr "Der Schalter '-z' wird nur für Punkte unterstützt."
#: ../raster/r.to.vect/main.c:131
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
-msgstr ""
-"Die Rasterkarte hat nicht den Typ integer (CELL) daher wird der Schalter '-"
-"v' ignoriert. Rasterwerte werden in die Tabelle geschrieben."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
+msgstr "Die Rasterkarte hat nicht den Typ integer (CELL) daher wird der Schalter '-v' ignoriert. Rasterwerte werden in die Tabelle geschrieben."
#: ../raster/r.to.vect/main.c:209 ../vector/v.in.sites/main.c:172
#: ../vector/v.random/main.c:195 ../vector/v.in.dxf/write_vect.c:232
@@ -11604,12 +10695,8 @@
msgstr "extend_lines: q back pointer not NULL!"
#: ../raster/r.kappa/main.c:71
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung "
-"(accuracy assessment) der Klassifikationsergebnisse."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
#: ../raster/r.kappa/main.c:77
msgid "Name of raster map containing classification result"
@@ -11647,9 +10734,7 @@
#: ../raster/r.kappa/calc_kappa.c:32
#, c-format
msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr ""
-"Kann die Datei <%s> nicht öffnen, um die Kappawerte und relevante Parameter "
-"zu schreiben."
+msgstr "Kann die Datei <%s> nicht öffnen, um die Kappawerte und relevante Parameter zu schreiben."
#: ../raster/r.kappa/prt_label.c:17
#, c-format
@@ -11659,21 +10744,15 @@
#: ../raster/r.kappa/prt_mat.c:39
#, c-format
msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr ""
-"Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) "
-"zu schreiben."
+msgstr "Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) zu schreiben."
#: ../raster/r.kappa/stats.c:14 ../raster/r.report/stats.c:123
msgid "Problem reading r.stats output"
msgstr "Problem beim Lesen der 'r.stats'-Ausgabe."
#: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei "
-"Rasterkarten."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei Rasterkarten."
#: ../raster/r.coin/main.c:77
msgid "Name of first raster map"
@@ -11688,13 +10767,8 @@
msgstr "Maßeinheit"
#: ../raster/r.coin/main.c:92
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-"c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der "
-"Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-"
-"Meilen)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr "c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-Meilen)"
#: ../raster/r.coin/main.c:99
msgid "Wide report, 132 columns (default: 80)"
@@ -11727,18 +10801,12 @@
msgstr "Erstelle den Bericht ..."
#: ../raster/r.digit/main.c:46
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der "
-"Maus zeichnet und als Rasterkarte speichert."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der Maus zeichnet und als Rasterkarte speichert."
#: ../raster/r.digit/main.c:55
msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
-"Display-Befehle die für den Hintergrund verwendet werden sollen (getrennt "
-"durch ';')."
+msgstr "Display-Befehle die für den Hintergrund verwendet werden sollen (getrennt durch ';')."
#: ../raster/r.digit/main.c:78
msgid "No graphics device selected!"
@@ -11834,76 +10902,39 @@
#: ../raster/r.horizon/main.c:180
msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
-"Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
+msgstr "Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
#: ../raster/r.horizon/main.c:182
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
-msgstr ""
-"Berechnet Horizontwinkelhöhe auf Grundlage eines digitalen Höhenmodells. "
-"Dies Modul hat zwei verschiedende Betriebsarten: 1. Berechnet den gesamten "
-"Horizont um einen Punkt, dessen Koordinaten mit der Option 'coord' angegeben "
-"wurden. Die Horizonthöhe wird im Bogenmaß ausgegeben. 2. Berechnet eine "
-"oder mehr Rasterkarten der Horizonthöhe in einer Richtung. Eingabe dafür ist "
-"der Winkel [Grad] gemessen gegen den Uhrzeigersinn mit Osten=0, Norden=90 "
-"etc. Die Ausgabe ist die Horizonthöhe im Bogenmaß. "
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgstr "Berechnet Horizontwinkelhöhe auf Grundlage eines digitalen Höhenmodells. Dies Modul hat zwei verschiedende Betriebsarten: 1. Berechnet den gesamten Horizont um einen Punkt, dessen Koordinaten mit der Option 'coord' angegeben wurden. Die Horizonthöhe wird im Bogenmaß ausgegeben. 2. Berechnet eine oder mehr Rasterkarten der Horizonthöhe in einer Richtung. Eingabe dafür ist der Winkel [Grad] gemessen gegen den Uhrzeigersinn mit Osten=0, Norden=90 etc. Die Ausgabe ist die Horizonthöhe im Bogenmaß. "
#: ../raster/r.horizon/main.c:205
msgid "Direction in which you want to know the horizon height"
msgstr "Richtung in der die Horizonthöhe berechnet werden soll."
#: ../raster/r.horizon/main.c:221
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich um die "
-"aktuelle Region herum ein."
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich um die aktuelle Region herum ein."
#: ../raster/r.horizon/main.c:229
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich östlich "
-"der aktuellen Region ein."
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich östlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:237
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich westlich "
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich westlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:245
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich nördlich "
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich nördlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:253
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereichsüdlich der "
-"aktuellen Region ein."
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereichsüdlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:261
msgid "The maximum distance to consider when finding the horizon height"
-msgstr ""
-"Die maximale bei der Suche nach der Horizonthöhe zu berücksichtigende "
-"Distanz."
+msgstr "Die maximale bei der Suche nach der Horizonthöhe zu berücksichtigende Distanz."
#: ../raster/r.horizon/main.c:270
msgid "Prefix of the horizon raster output maps"
@@ -11924,8 +10955,7 @@
#: ../raster/r.horizon/main.c:361
msgid "You didn't specify a direction value or step size. Aborting."
-msgstr ""
-"Sie haben keine Wert für die Richtung oder Schrittgröße angegeben. Breche ab."
+msgstr "Sie haben keine Wert für die Richtung oder Schrittgröße angegeben. Breche ab."
#: ../raster/r.horizon/main.c:366
msgid "You didn't specify a horizon raster name. Aborting."
@@ -11970,12 +11000,8 @@
msgstr "Konnte die maximale Distanz nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:471
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
-msgstr ""
-"Kann die Projektionsinformationen der aktuellen Location nicht finden: Bitte "
-"setzen Sie geog. Länge via 'lat' oder 'latin'!"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "Kann die Projektionsinformationen der aktuellen Location nicht finden: Bitte setzen Sie geog. Länge via 'lat' oder 'latin'!"
#: ../raster/r.horizon/main.c:594 ../raster/r.in.ascii/main.c:195
#: ../raster/r.in.arc/main.c:135
@@ -12133,12 +11159,10 @@
#: ../raster/r.external/proj.c:107
msgid ""
"\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
-"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern "
-"und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
+"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
#: ../raster/r.external/list.c:22
#, fuzzy
@@ -12146,13 +11170,8 @@
msgstr "Unterstützte Formate:\n"
#: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie "
-"können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden "
-"nach oben zeigt."
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden nach oben zeigt."
#: ../raster/r.external/window.c:26
msgid "Applying horizontal flip"
@@ -12208,8 +11227,7 @@
#: ../raster/r.recode/read_rules.c:30
#, fuzzy, c-format
msgid "Data range of %s is %s to %s (entire map)"
-msgstr ""
-"Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
+msgstr "Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
#: ../raster/r.recode/read_rules.c:39
#, fuzzy, c-format
@@ -12256,18 +11274,12 @@
msgstr "Volumen"
#: ../raster/r.volume/main.c:61
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-"
-"Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
#: ../raster/r.volume/main.c:67
msgid "Existing raster map representing data that will be summed within clumps"
-msgstr ""
-"Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen "
-"aufsummiert werden."
+msgstr "Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen aufsummiert werden."
#: ../raster/r.volume/main.c:73
msgid "Existing raster map, preferably the output of r.clump"
@@ -12324,23 +11336,16 @@
msgstr "Verarbeite Zeilen... "
#: ../raster/r.carve/enforce_ds.c:174
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-"Vect läuft aus der Region und kommt wieder hinein. Diese Situation ist "
-"leider noch nicht implementiert!"
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr "Vect läuft aus der Region und kommt wieder hinein. Diese Situation ist leider noch nicht implementiert!"
#: ../raster/r.carve/main.c:76
msgid "Generates stream channels."
msgstr ""
#: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat "
-"und subtrahiert die Tiefe vom Ausgabe-DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat und subtrahiert die Tiefe vom Ausgabe-DEM."
#: ../raster/r.carve/main.c:82
msgid "Name of input raster elevation map"
@@ -12389,16 +11394,11 @@
#: ../raster/r.carve/lobf.c:74
msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-"Versuche durch 0 zu teilen... Keine eindeutige Lösung...Übergehe das..."
+msgstr "Versuche durch 0 zu teilen... Keine eindeutige Lösung...Übergehe das..."
#: ../raster/r.mode/main.c:58
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Findet den Modalwert der Werte einer Bedeckungskarte innerhalb der Flächen "
-"mit gleichen Werten in einer benutzerdefinierten Basiskarte."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Findet den Modalwert der Werte einer Bedeckungskarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
#: ../raster/r.mode/main.c:64
msgid "Base map to be reclassified"
@@ -12435,9 +11435,7 @@
msgstr "Einheiten"
#: ../raster/r.report/parse.c:47
-msgid ""
-"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
-"cover"
+msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
msgstr "mi;Meilen;me;Meter;k;Kilometer;a;Acres;h;Hektar;c;Zellanzahl;p;Prozent"
#: ../raster/r.report/parse.c:50 ../raster/r.report/parse.c:86
@@ -12535,11 +11533,8 @@
msgstr "vollständig"
#: ../raster/r.composite/main.c:75
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten "
-"Rasterkarte."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten Rasterkarte."
#: ../raster/r.composite/main.c:101
msgid "Number of levels to be used for each component"
@@ -12572,22 +11567,16 @@
msgstr "Erstelle Farbtabelle für Ausgabe-Rasterkarte..."
#: ../raster/r.spreadpath/main.c:93
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von "
-"denen der kumulative Weg bestimmt wurde."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von denen der kumulative Weg bestimmt wurde."
#: ../raster/r.spreadpath/main.c:102
msgid "Name of raster map containing back-path easting information"
-msgstr ""
-"Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
+msgstr "Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
#: ../raster/r.spreadpath/main.c:110
msgid "Name of raster map containing back-path northing information"
-msgstr ""
-"Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
+msgstr "Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
#: ../raster/r.spreadpath/main.c:118
msgid "The map E and N grid coordinates of starting points"
@@ -12611,8 +11600,7 @@
#: ../raster/r.to.rast3/main.c:201
msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-"Konvertiert Schnitte von 2D Rasterkarten in eine 3D-Rastervolumenkarte."
+msgstr "Konvertiert Schnitte von 2D Rasterkarten in eine 3D-Rastervolumenkarte."
#: ../raster/r.to.rast3/main.c:213
msgid "No output map"
@@ -12625,8 +11613,7 @@
#: ../raster/r.to.rast3/main.c:275
msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-"Eingabekarten müssen vom gleichen Datentyp sein. CELL FCELL oder DCELL!"
+msgstr "Eingabekarten müssen vom gleichen Datentyp sein. CELL FCELL oder DCELL!"
#: ../raster/r.flow/main.c:316
msgid "Calculating maps ..."
@@ -12639,12 +11626,8 @@
#: ../raster/r.flow/main.c:425
#, fuzzy
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
-msgstr ""
-"Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) "
-"aus einem angegebenen digitalen Höhenmodell (DEM)."
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
+msgstr "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
#: ../raster/r.flow/main.c:434
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
@@ -12695,17 +11678,11 @@
#: ../raster/r.flow/main.c:534
msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-"Es müssen eine oder mehrere Ausgabekarten ausgewählt werden (flout, lgout, "
-"dsout)."
+msgstr "Es müssen eine oder mehrere Ausgabekarten ausgewählt werden (flout, lgout, dsout)."
#: ../raster/r.flow/main.c:550
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
-"Lat/Long Projection wird von r.flow nicht unterstützt. Bitte verwenden Sie "
-"'r.watershed' für die Berechnung der Fussakkumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
+msgstr "Lat/Long Projection wird von r.flow nicht unterstützt. Bitte verwenden Sie 'r.watershed' für die Berechnung der Fussakkumulation."
#: ../raster/r.flow/io.c:85
msgid "Reading input files: elevation"
@@ -12713,9 +11690,7 @@
#: ../raster/r.flow/io.c:89
msgid "Elevation file's resolution differs from current region resolution"
-msgstr ""
-"Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen "
-"Region."
+msgstr "Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen Region."
#: ../raster/r.flow/io.c:101
msgid "Reading input files: aspect"
@@ -12723,9 +11698,7 @@
#: ../raster/r.flow/io.c:104
msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-"Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der "
-"aktuellen Region"
+msgstr "Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der aktuellen Region"
#: ../raster/r.flow/io.c:118
msgid "Reading input files: barrier"
@@ -12798,9 +11771,7 @@
#: ../raster/r.flow/precomp.c:116
#, c-format
msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
-"Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die "
-"Eingabekarte."
+msgstr "Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die Eingabekarte."
#: ../raster/r.what.color/main.c:89 ../raster/r.what/main.c:93
#: ../display/d.where/main.c:45 ../display/d.what.rast/main.c:51
@@ -12840,11 +11811,8 @@
msgstr "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
#: ../raster/r.in.ascii/main.c:77
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
-msgstr ""
-"ASCII-Datei, die importiert werden soll. Wenn nichts angegeben ist, wird von "
-"der Standardeingabe gelesen."
+msgid "ASCII raster file to be imported. If not given reads from standard input"
+msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben ist, wird von der Standardeingabe gelesen."
#: ../raster/r.in.ascii/main.c:95 ../raster/r.in.arc/main.c:95
msgid "Multiplier for ASCII data"
@@ -12927,9 +11895,7 @@
#: ../raster/r.in.ascii/gethead.c:169
msgid "ignoring type filed in header, type is set on command line"
-msgstr ""
-"Ignoriere Feldtypen des Headers, da der Typ auf der Kommandozeile gesetzt "
-"wurde."
+msgstr "Ignoriere Feldtypen des Headers, da der Typ auf der Kommandozeile gesetzt wurde."
#: ../raster/r.in.ascii/gethead.c:176
msgid "illegal multiplier field: using 1.0"
@@ -12937,15 +11903,11 @@
#: ../raster/r.in.ascii/gethead.c:181
msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-"Ignoriere Multiplikator-Feld im Header, da der Multiplikator auf der "
-"Kommandozeile gesetzt wurde."
+msgstr "Ignoriere Multiplikator-Feld im Header, da der Multiplikator auf der Kommandozeile gesetzt wurde."
#: ../raster/r.in.ascii/gethead.c:189
msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-"Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile "
-"gesetzt wurde."
+msgstr "Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile gesetzt wurde."
#: ../raster/r.in.ascii/gethead.c:218
msgid "error in ascii data format"
@@ -13044,8 +12006,7 @@
#: ../raster/r.random.cells/main.c:66
msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
-msgstr ""
#: ../raster/r.random.cells/random.c:50
#, c-format
@@ -13062,16 +12023,8 @@
msgstr "Erzeugt Flächenstatistiken für Rasterkarten."
#: ../raster/r.ros/main.c:215
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der "
-"(rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) "
-"Geschwindigkeit, 3) die Richtung der größten Ausbreitungsgeschwindigkeit und "
-"optional 4) die maximale Entdeckungsentfernung."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der (rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) Geschwindigkeit, 3) die Richtung der größten Ausbreitungsgeschwindigkeit und optional 4) die maximale Entdeckungsentfernung."
#: ../raster/r.ros/main.c:222
msgid "Name of raster map containing fuel MODELs"
@@ -13079,29 +12032,23 @@
#: ../raster/r.ros/main.c:228
msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
#: ../raster/r.ros/main.c:234
msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
#: ../raster/r.ros/main.c:240
msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
#: ../raster/r.ros/main.c:245
msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den aktuellen Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den aktuellen Brennmaterialfeuchtigkeiten [%]."
#: ../raster/r.ros/main.c:251
msgid "Name of raster map containing midflame wind VELOCITYs (ft/min)"
-msgstr ""
-"Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/"
-"min]."
+msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min]."
#: ../raster/r.ros/main.c:257
msgid "Name of raster map containing wind DIRECTIONs (degree)"
@@ -13113,15 +12060,11 @@
#: ../raster/r.ros/main.c:269
msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr ""
-"Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom "
-"Osten]."
+msgstr "Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom Osten]."
#: ../raster/r.ros/main.c:274
msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem "
-"Schalter -s)."
+msgstr "Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem Schalter -s)."
#: ../raster/r.ros/main.c:277
#, fuzzy
@@ -13133,23 +12076,17 @@
msgstr "Auch die maximale Entdeckungsentfernung berechnen."
#: ../raster/r.ros/main.c:296
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
msgstr ""
#: ../raster/r.ros/main.c:320
#, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
msgstr ""
#: ../raster/r.ros/main.c:325
#, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
msgstr ""
#: ../raster/r.ros/main.c:339
@@ -13179,9 +12116,7 @@
#: ../raster/r.topidx/main.c:42
msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis eines "
-"digitalen Höhenmodells."
+msgstr "Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis eines digitalen Höhenmodells."
#: ../raster/r.topidx/topidx.c:42 ../imagery/i.landsat.toar/main.c:468
#, fuzzy
@@ -13195,14 +12130,8 @@
#: ../raster/r.topidx/file_io.c:30
#, c-format
-msgid ""
-"Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx"
-"%.2f]! Needs to be at least identical or the current region resolution lower "
-"than the input map resolution"
-msgstr ""
-"Die Auflösung der aktuellen Region [%.2fx%.2f] ist feiner als die Auflösung "
-"der Eingabekarte [%.2fx%.2f]! Die Auflösungen der aktuellen Region muss "
-"mindestnes identisch oder feiner sein als die der Eingabekarte."
+msgid "Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"
+msgstr "Die Auflösung der aktuellen Region [%.2fx%.2f] ist feiner als die Auflösung der Eingabekarte [%.2fx%.2f]! Die Auflösungen der aktuellen Region muss mindestnes identisch oder feiner sein als die der Eingabekarte."
#: ../raster/r.topidx/file_io.c:78
msgid "Writing topographic index map..."
@@ -13221,12 +12150,8 @@
msgstr "Karte mit Werten für Y-Koeffizienten."
#: ../raster/r.regression.line/main.c:61
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen "
-"(wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr "ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen (wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
#: ../raster/r.regression.line/main.c:65 ../general/g.region/main.c:141
#: ../locale/scriptstrings/i.oif_to_translate.c:11
@@ -13428,9 +12353,7 @@
#: ../raster/r.param.scale/process.c:74
msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr ""
-"Zellengröße in Ost-West- und Nord-Süd-Richtung ist unterschiedlich. Verwende "
-"den Mittelwert."
+msgstr "Zellengröße in Ost-West- und Nord-Süd-Richtung ist unterschiedlich. Verwende den Mittelwert."
#: ../raster/r.param.scale/interface.c:55
#, fuzzy
@@ -13442,12 +12365,8 @@
msgstr "Extrahiert Terrainparameter aus einem DGM."
#: ../raster/r.param.scale/interface.c:57
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"Verwendet einen multi-skalaren Ansatz, in dem quadratische Parameter auf "
-"jede Fenstergröße angepasst werden (über die Methode der kleinsten Quadrate)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "Verwendet einen multi-skalaren Ansatz, in dem quadratische Parameter auf jede Fenstergröße angepasst werden (über die Methode der kleinsten Quadrate)."
#: ../raster/r.param.scale/interface.c:75
msgid "Output raster layer containing morphometric parameter"
@@ -13455,8 +12374,7 @@
#: ../raster/r.param.scale/interface.c:79
msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr ""
-"Hangneigungstoleranz, die eine 'flache' Oberfläche definiert (in Grad)."
+msgstr "Hangneigungstoleranz, die eine 'flache' Oberfläche definiert (in Grad)."
#: ../raster/r.param.scale/interface.c:86
msgid "Curvature tolerance that defines 'planar' surface"
@@ -13469,9 +12387,7 @@
#: ../raster/r.param.scale/interface.c:101
msgid "Morphometric parameter in 'size' window to calculate"
-msgstr ""
-"Morphometrische Parameter, die innerhalb der Fenstergröße berechnet werden "
-"sollen."
+msgstr "Morphometrische Parameter, die innerhalb der Fenstergröße berechnet werden sollen."
#: ../raster/r.param.scale/interface.c:109
msgid "Exponent for distance weighting (0.0-4.0)"
@@ -13491,11 +12407,8 @@
#: ../raster/r.in.arc/main.c:63
#, fuzzy
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-msgstr ""
-"Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) "
-"GRASS Rasterkarte."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) GRASS Rasterkarte."
#: ../raster/r.in.arc/main.c:70
msgid "ARC/INFO ASCII raster file (GRID) to be imported"
@@ -13538,19 +12451,12 @@
msgstr "Aktualisiere die Anzahl der Kategorien für [%s]..."
#: ../raster/r.neighbors/main.c:121
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
-"Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue "
-"Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
#: ../raster/r.neighbors/main.c:131
#, fuzzy
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Name of an input raster map to select the cells which should be processed"
msgstr "Name der Rasterkarte für die Statistiken berechnet werden sollen."
#: ../raster/r.neighbors/main.c:149 ../vector/v.neighbors/main.c:69
@@ -13649,8 +12555,7 @@
#: ../raster/r.quantile/main.c:285
msgid "Generate recode rules based on quantile-defined intervals."
-msgstr ""
-"Erzeuge Rekodierungs-Regeln auf Grundlage quantildefinierter Intervalle."
+msgstr "Erzeuge Rekodierungs-Regeln auf Grundlage quantildefinierter Intervalle."
#: ../general/g.version/main.c:43 ../general/g.access/main.c:37
#: ../general/g.proj/main.c:62 ../general/g.dirseps/main.c:34
@@ -13720,14 +12625,11 @@
#: ../general/g.access/main.c:64
msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-"Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht "
-"unterstützt."
+msgstr "Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht unterstützt."
#: ../general/g.access/main.c:72
msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-"Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
+msgstr "Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
#: ../general/g.access/main.c:76
msgid "Unable to determine mapset permissions"
@@ -13814,13 +12716,8 @@
#: ../general/g.proj/input.c:259
#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"Einlesen der Datei %s war erfolgreich, aber die Datei enthielt keine "
-"Projektionsinformationen. Location-Definition 'XY (unprojiziert)' wird "
-"benutzt."
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "Einlesen der Datei %s war erfolgreich, aber die Datei enthielt keine Projektionsinformationen. Location-Definition 'XY (unprojiziert)' wird benutzt."
#: ../general/g.proj/main.c:64
#, fuzzy
@@ -13829,9 +12726,7 @@
#: ../general/g.proj/main.c:67
#, fuzzy
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
msgstr "Gebe die GRASS 'Build'-Informationen aus."
#: ../general/g.proj/main.c:70
@@ -13847,8 +12742,7 @@
#: ../general/g.proj/main.c:80
#, fuzzy
msgid "Print projection information in conventional GRASS format"
-msgstr ""
-"Gebe die Projektionsinformationen (im konventionellen GRASS-Format) aus."
+msgstr "Gebe die Projektionsinformationen (im konventionellen GRASS-Format) aus."
#: ../general/g.proj/main.c:86
#, fuzzy
@@ -13857,16 +12751,14 @@
#: ../general/g.proj/main.c:92
msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Überprüfe Datum-Informationen und gebe die Transformationsparameter aus."
+msgstr "Überprüfe Datum-Informationen und gebe die Transformationsparameter aus."
#: ../general/g.proj/main.c:98
msgid "Print projection information in PROJ.4 format"
msgstr "Gebe die Projektionsinformationen im PROJ.4-Format aus."
#: ../general/g.proj/main.c:104
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
msgstr "Ausgabe ohne Zeilenumbrüche (nur bei WKT- und PROJ.4-Ausgaben)"
#: ../general/g.proj/main.c:114
@@ -13891,9 +12783,7 @@
#: ../general/g.proj/main.c:137
#, fuzzy
msgid "Name of ASCII file containing a WKT projection description"
-msgstr ""
-"ASCII-Datei die eine einzige Zeile mit WKT Projektionsinformationen enthält. "
-"(- für stdin)."
+msgstr "ASCII-Datei die eine einzige Zeile mit WKT Projektionsinformationen enthält. (- für stdin)."
#: ../general/g.proj/main.c:139 ../general/g.proj/main.c:148
#: ../vector/v.segment/main.c:69
@@ -13920,17 +12810,11 @@
#: ../general/g.proj/main.c:167
msgid "\"0\" for unspecified or \"-1\" to list and exit"
-msgstr ""
-"\"0\" für nicht spezifiziert oder \"-1\" um alle aufzulisten und sich zu "
-"beenden"
+msgstr "\"0\" für nicht spezifiziert oder \"-1\" um alle aufzulisten und sich zu beenden"
#: ../general/g.proj/main.c:173
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
-msgstr ""
-"Erzwinge das Übersteuern der Datumtransformationsinformation des Eingabe "
-"Koordinatensystems."
+msgid "Force override of datum transformation information in input co-ordinate system"
+msgstr "Erzwinge das Übersteuern der Datumtransformationsinformation des Eingabe Koordinatensystems."
#: ../general/g.proj/main.c:179
#, fuzzy
@@ -13950,8 +12834,7 @@
#: ../general/g.proj/main.c:204
#, c-format
msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-"Nur eine der Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
+msgstr "Nur eine der Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
#: ../general/g.proj/main.c:233
msgid "Projection files missing"
@@ -13960,8 +12843,7 @@
#: ../general/g.proj/main.c:249
#, fuzzy, c-format
msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr ""
#: ../general/g.proj/main.c:275
#, c-format
@@ -13991,24 +12873,13 @@
#: ../general/g.proj/create.c:36
#, fuzzy, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
-msgstr ""
-"Das PERMANENT-Mapset muss anstelle des aktuellen Mapsets (%s) ausgewählt "
-"werden, bevor Sie die Projektionsinformationen der Location aktualisieren "
-"können."
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
+msgstr "Das PERMANENT-Mapset muss anstelle des aktuellen Mapsets (%s) ausgewählt werden, bevor Sie die Projektionsinformationen der Location aktualisieren können."
#: ../general/g.proj/create.c:62
#, fuzzy
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
-msgstr ""
-"N.B. Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn "
-"Sie aber mehrere Mapsets haben g.region -d sollte in jedem ausgeführt "
-"werden, um die Regionseinstellungen von der Standardregion zu übernehmen."
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
+msgstr "N.B. Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie aber mehrere Mapsets haben g.region -d sollte in jedem ausgeführt werden, um die Regionseinstellungen von der Standardregion zu übernehmen."
#: ../general/g.proj/create.c:66
#, fuzzy
@@ -14116,15 +12987,12 @@
msgstr "PostScript"
#: ../general/g.message/main.c:36
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
msgstr "Gibt eine Nachricht, Warnung oder fatalen Fehler im GRASS-Stil aus."
#: ../general/g.message/main.c:38
msgid "This module should be used in scripts for messages served to user."
-msgstr ""
-"Dieses Modul sollte in Skripten verwendet werden um Nachrichten an den "
-"Benutzer auszugeben."
+msgstr "Dieses Modul sollte in Skripten verwendet werden um Nachrichten an den Benutzer auszugeben."
#: ../general/g.message/main.c:42 ../general/g.message/main.c:47
#: ../general/g.message/main.c:52 ../general/g.message/main.c:57
@@ -14242,8 +13110,7 @@
#: ../general/g.setproj/main.c:88
msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr ""
-"Sie müssen sich in dem Mapset PERMANENT befinden um g.setproj auszuführen."
+msgstr "Sie müssen sich in dem Mapset PERMANENT befinden um g.setproj auszuführen."
#: ../general/g.setproj/main.c:101
msgid "PERMANENT: permission denied"
@@ -14348,14 +13215,8 @@
msgstr "Die Information zu der UTM Zone wurde nicht aktualisiert."
#: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
-msgstr ""
-"Wenn Sie aber die Zone ändern, werden alle existierenden Daten von der "
-"Projektionssoftware interpretiert. GRASS wird die Daten nicht automatisch "
-"umprojezieren oder die Header existierender Karten ändern."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
+msgstr "Wenn Sie aber die Zone ändern, werden alle existierenden Daten von der Projektionssoftware interpretiert. GRASS wird die Daten nicht automatisch umprojezieren oder die Header existierender Karten ändern."
#: ../general/g.setproj/main.c:461
msgid "Would you still like to change the UTM zone?"
@@ -14411,8 +13272,7 @@
#: ../general/g.setproj/get_stp.c:43
msgid "This should not happen see your system admin"
-msgstr ""
-"Dies sollte nicht passieren, suchen Sie ihren System-Administrator auf."
+msgstr "Dies sollte nicht passieren, suchen Sie ihren System-Administrator auf."
#: ../general/g.setproj/get_stp.c:99
msgid "Unable to open FIPS code file"
@@ -14456,9 +13316,7 @@
#: ../general/g.list/main.c:48
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
-"Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten "
-"Datentyps."
+msgstr "Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten Datentyps."
#: ../general/g.list/main.c:59 ../general/g.mlist/main.c:128
msgid "Verbose listing (also list map titles)"
@@ -14476,11 +13334,8 @@
msgstr "Ändere aktuelles Mapset."
#: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
-msgstr ""
-"Erzeuge optional ein neues Mapset oder liste die verfügbaren Mapsets in der "
-"Location auf."
+msgid "Optionally create new mapset or list available mapsets in given location."
+msgstr "Erzeuge optional ein neues Mapset oder liste die verfügbaren Mapsets in der Location auf."
#: ../general/g.mapset/main.c:56
msgid "Name of mapset where to switch"
@@ -14497,9 +13352,7 @@
#: ../general/g.mapset/main.c:76
#, fuzzy
msgid "Full path to the directory where the new location is"
-msgstr ""
-"Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue "
-"L0cation befindet)."
+msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue L0cation befindet)."
#: ../general/g.mapset/main.c:81
msgid "Create mapset if it doesn't exist"
@@ -14526,8 +13379,7 @@
#: ../general/g.mapset/main.c:167
msgid "The mapset does not exist. Use -c flag to create it."
-msgstr ""
-"Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
+msgstr "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
#: ../general/g.mapset/main.c:176
msgid "Unable to read GIS_LOCK environment variable"
@@ -14535,12 +13387,8 @@
#: ../general/g.mapset/main.c:190
#, fuzzy, c-format
-msgid ""
-"<%s> is currently running GRASS in selected mapset or lock file cannot be "
-"checked"
-msgstr ""
-"%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann "
-"nicht überprüft werden."
+msgid "<%s> is currently running GRASS in selected mapset or lock file cannot be checked"
+msgstr "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann nicht überprüft werden."
#: ../general/g.mapset/main.c:196
msgid "Cleaning up temporary files..."
@@ -14582,12 +13430,8 @@
msgstr "Ändere den aktuellen Mapset-Suchpfad aus."
#: ../general/g.mapsets/main.c:63
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-"Beeinflusst beeinflusst den Zugriff des Benutzers auf Daten in anderen "
-"Mapsets in der aktuellen Location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
+msgstr "Beeinflusst beeinflusst den Zugriff des Benutzers auf Daten in anderen Mapsets in der aktuellen Location."
#: ../general/g.mapsets/main.c:71
msgid "Name(s) of existing mapset(s)"
@@ -14600,13 +13444,11 @@
#: ../general/g.mapsets/main.c:80
msgid "Name(s) of existing mapset(s) to add to search path"
-msgstr ""
-"Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden sollen."
+msgstr "Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden sollen."
#: ../general/g.mapsets/main.c:89
msgid "Name(s) of existing mapset(s) to remove from search path"
-msgstr ""
-"Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
#: ../general/g.mapsets/main.c:97
msgid "List all available mapsets in alphabetical order"
@@ -14654,9 +13496,7 @@
#: ../general/g.copy/main.c:45
#, fuzzy
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
msgstr "Kopiert die vorhandenen Daten in die aktuelle Mapset/Location."
#: ../general/g.copy/main.c:52
@@ -14693,9 +13533,7 @@
#: ../general/g.mremove/main.c:66
#, fuzzy
-msgid ""
-"Removes data base element files from the user's current mapset using regular "
-"expressions."
+msgid "Removes data base element files from the user's current mapset using regular expressions."
msgstr "Löscht Karten aus dem aktuellen Mapset."
#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:102
@@ -14746,9 +13584,7 @@
#: ../general/g.mremove/main.c:153
#, fuzzy, c-format
msgid "You must use the force flag (-%c) to actually remove them. Exiting."
-msgstr ""
-"Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende "
-"mich."
+msgstr "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende mich."
#: ../general/g.mremove/check_reclass.c:18 ../general/g.remove/main.c:38
#, fuzzy, c-format
@@ -14758,16 +13594,13 @@
#: ../general/g.mremove/check_reclass.c:22
#, fuzzy, c-format
msgid "Raster map <%s@%s> is a base map. Remove reclassed map first: %s"
-msgstr ""
-"[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
+msgstr "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
#: ../general/g.mremove/check_reclass.c:45
#: ../general/g.mremove/check_reclass.c:59
#, c-format
msgid "Removing information about reclassed map from [%s@%s] failed"
-msgstr ""
-"Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist "
-"fehlgeschlagen."
+msgstr "Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist fehlgeschlagen."
#: ../general/g.parser/main.c:63
msgid "Usage"
@@ -14979,12 +13812,8 @@
msgstr "Name des Mapsets (Standard: das aktuelle)"
#: ../general/g.mlist/main.c:66
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Datentyps und verwende optional ein Suchmuster."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten Datentyps und verwende optional ein Suchmuster."
#: ../general/g.mlist/main.c:81
msgid "Map name search pattern (default: all)"
@@ -15041,9 +13870,7 @@
#: ../general/g.region/main.c:87
msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen "
-"Ellipsoid/Datum aus."
+msgstr "Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen Ellipsoid/Datum aus."
#: ../general/g.region/main.c:93
msgid "Print the current region extent"
@@ -15070,12 +13897,8 @@
msgstr "Gebe den Konvergenzwinkel aus (Grad CCW)."
#: ../general/g.region/main.c:124
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
-msgstr ""
-"Die Differenz zwischen dem Gitternord der Projektion und der wahren "
-"Nordrichtung gemessen im Zentrum der aktuellen Region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
+msgstr "Die Differenz zwischen dem Gitternord der Projektion und der wahren Nordrichtung gemessen im Zentrum der aktuellen Region."
#: ../general/g.region/main.c:130
msgid "Print also 3D settings"
@@ -15086,12 +13909,8 @@
msgstr "Gebe die maximale Bounding-Box in Lat/Long Koordinaten in WGS84 aus."
#: ../general/g.region/main.c:147
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Passe Region an die Auflösung an (Standard = passe an die Grenzen an; "
-"funktioniert nur für 2D-Auflösung)."
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Passe Region an die Auflösung an (Standard = passe an die Grenzen an; funktioniert nur für 2D-Auflösung)."
#: ../general/g.region/main.c:153
msgid "Do not update the current region"
@@ -15109,9 +13928,7 @@
#: ../general/g.region/main.c:180
msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-"Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D als auch 3D-"
-"Werte)."
+msgstr "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D als auch 3D-Werte)."
#: ../general/g.region/main.c:243
msgid "Value for the top edge"
@@ -15158,9 +13975,7 @@
#: ../general/g.region/main.c:327
msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr ""
-"Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser "
-"Rasterkarte stösst."
+msgstr "Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser Rasterkarte stösst."
#: ../general/g.region/main.c:338
msgid "Adjust region cells to cleanly align with this raster map"
@@ -15168,9 +13983,7 @@
#: ../general/g.region/main.c:349
msgid "Save current region settings in named region file"
-msgstr ""
-"Speichere die Einstellungen der aktuellen Region in eine benannte Regions-"
-"Datei."
+msgstr "Speichere die Einstellungen der aktuellen Region in eine benannte Regions-Datei."
#: ../general/g.region/main.c:408
#, c-format
@@ -15218,9 +14031,7 @@
#: ../general/g.region/main.c:819
msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-"Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht "
-"<PERMANENT>."
+msgstr "Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht <PERMANENT>."
#: ../general/g.region/main.c:836
#, c-format
@@ -15234,24 +14045,15 @@
#: ../general/g.region/printwindow.c:410
msgid "You are already in Lat/Long. Use the -p flag instead."
-msgstr ""
-"Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
+msgstr "Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
#: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
-msgstr ""
-"Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon "
-"ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
+msgstr "Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
#: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"WGS84 Ausgabe nicht möglich, da diese Location keine "
-"Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "WGS84 Ausgabe nicht möglich, da diese Location keine Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
#: ../general/g.region/printwindow.c:783
msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -15327,9 +14129,7 @@
msgstr "output= und method= müssen die selbe Anzahl von Werten haben."
#: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts"
+msgid "Generates the font configuration file by scanning various directories for fonts"
msgstr ""
#: ../general/g.mkfontcap/main.c:79
@@ -15337,26 +14137,20 @@
msgstr ""
#: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
msgstr ""
#: ../general/g.mkfontcap/main.c:92
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
msgstr ""
#: ../general/g.mkfontcap/main.c:109
#, fuzzy, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
msgstr "Die Datei '%s' existiert bereits und wird überschrieben."
#: ../general/g.mkfontcap/main.c:121
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
msgstr ""
#: ../general/g.mkfontcap/main.c:148
@@ -15391,9 +14185,7 @@
#: ../general/g.gui/main.c:62
msgid "Do not launch GUI after updating the default GUI setting"
-msgstr ""
-"Starten Sie das GUI nicht nachdem Sie die standard GUI-Einstellungen "
-"geändert haben."
+msgstr "Starten Sie das GUI nicht nachdem Sie die standard GUI-Einstellungen geändert haben."
#: ../general/g.gui/main.c:90
#, c-format
@@ -15408,15 +14200,12 @@
#: ../general/g.remove/main.c:41
#, fuzzy, c-format
msgid "Raster <%s@%s> is a base map. Remove reclassed map <%s> first."
-msgstr ""
#: ../general/g.remove/main.c:63 ../general/g.remove/main.c:76
#, fuzzy, c-format
msgid "Removing information about reclassed map from <%s@%s> failed"
-msgstr ""
-"fehlgeschlagen."
#: ../general/g.remove/main.c:105
msgid "Removes data base element files from the user's current mapset."
@@ -15461,12 +14250,8 @@
#: ../general/g.findfile/main.c:97
#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%"
-"s> does not correspond"
-msgstr ""
-"Der Parameter 'file' enthält einen Verweis auf das Mapset <%s>, aber der "
-"Parameter Mapset <%s> stimmt damit nicht überein."
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
+msgstr "Der Parameter 'file' enthält einen Verweis auf das Mapset <%s>, aber der Parameter Mapset <%s> stimmt damit nicht überein."
#: ../general/g.findfile/element.c:7
#, fuzzy
@@ -15553,12 +14338,8 @@
msgstr ""
#: ../display/d.font/main.c:49
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt "
-"wird."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt wird."
#: ../display/d.font/main.c:57
msgid "Choose new current font"
@@ -15592,19 +14373,12 @@
#: ../display/d.font/main.c:128
#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr ""
-"Der Name des Fonts <%s> ist nicht gültig. Überprüfe Sie den Namen oder "
-"überlegen Sie 'g.mkfontcap' auszuführen."
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgstr "Der Name des Fonts <%s> ist nicht gültig. Überprüfe Sie den Namen oder überlegen Sie 'g.mkfontcap' auszuführen."
#: ../display/d.rast.arrow/main.c:98
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
-"Zeichnet Pfeile, die die Exposition der Zellen repräsentieren, basierend auf "
-"einer Rasterkarte mit Expositionsdaten."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+msgstr "Zeichnet Pfeile, die die Exposition der Zellen repräsentieren, basierend auf einer Rasterkarte mit Expositionsdaten."
#: ../display/d.rast.arrow/main.c:102
msgid "Name of raster aspect map to be displayed"
@@ -15673,8 +14447,7 @@
#: ../display/d.rast.arrow/main.c:214
msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr ""
-"Magnitude wird nur für GRASS sowie Kompass-Expositionskarten unterstützt."
+msgstr "Magnitude wird nur für GRASS sowie Kompass-Expositionskarten unterstützt."
#: ../display/d.rast.arrow/main.c:219
msgid "Scale option requires magnitude_map"
@@ -15694,21 +14467,16 @@
msgstr "Darstellung, Kartographie"
#: ../display/d.grid/main.c:54
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
msgstr "Überlagert ein benutzerdefiniertes Gitter im aktiven Grafikfenster."
#: ../display/d.grid/main.c:62
-msgid ""
-"Size of grid to be drawn (0: north-south resolution of the current region)"
+msgid "Size of grid to be drawn (0: north-south resolution of the current region)"
msgstr ""
#: ../display/d.grid/main.c:63
msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
-msgstr ""
-"In Karteneinheiten oder im DDD:MM:SS Format. Beispiel: \"1000\" oder \"0:10"
+msgstr "In Karteneinheiten oder im DDD:MM:SS Format. Beispiel: \"1000\" oder \"0:10\""
#: ../display/d.grid/main.c:72
msgid "Lines of the grid pass through this coordinate"
@@ -15825,8 +14593,7 @@
"datum transformation parameters. Try running g.setproj."
msgstr ""
"Ausgabe in WGS84 ist unmöglich, da diese Location keine Datums-\n"
-"Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu "
-"benutzen."
+"Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu benutzen."
#: ../display/d.grid/plot.c:528
msgid "Error in pj_do_proj1"
@@ -15870,25 +14637,16 @@
#: ../display/d.erase/main.c:34
#, fuzzy
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
-msgstr ""
-"Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten "
-"Farbe."
+msgid "Erases the contents of the active graphics display frame with user defined color."
+msgstr "Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten Farbe."
#: ../display/d.erase/main.c:40
msgid "Remove all frames and erase the screen"
msgstr "Entferne alle Frames und lösche den Inhalt des Grafikfensters."
#: ../display/d.geodesic/main.c:46
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
-msgstr ""
-"Stellt eine geodätische Linie, die kürzeste Distanz zwischen zwei "
-"geographischen Punkten auf dem Großkreis, in einem longitude/latitude "
-"Datensatz dar"
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
+msgstr "Stellt eine geodätische Linie, die kürzeste Distanz zwischen zwei geographischen Punkten auf dem Großkreis, in einem longitude/latitude Datensatz dar"
#: ../display/d.geodesic/main.c:55 ../display/d.path/main.c:65
#: ../display/d.rhumbline/main.c:53
@@ -16071,13 +14829,10 @@
#: ../display/d.info/main.c:56
msgid "Display geographic coordinates and resolution of entire screen"
-msgstr ""
-"Zeigt geographische Koordinaten und die Auflösung des gesamten Bildschirms."
+msgstr "Zeigt geographische Koordinaten und die Auflösung des gesamten Bildschirms."
#: ../display/d.legend/main.c:87
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
msgstr "Zeichnet eine Legende für eine Rasterkarte im aktiven Grafikfenster."
#: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:76
@@ -16102,10 +14857,8 @@
#: ../display/d.legend/main.c:133
#, fuzzy
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr ""
-"Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)."
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgstr "Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)."
#: ../display/d.legend/main.c:143
msgid "List of discrete category numbers/values for legend"
@@ -16113,8 +14866,7 @@
#: ../display/d.legend/main.c:153
msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
-"Benutze einen Teilausschnitt der Wertespanne für eine Legende (min,max)."
+msgstr "Benutze einen Teilausschnitt der Wertespanne für eine Legende (min,max)."
#: ../display/d.legend/main.c:160 ../display/d.text/main.c:219
#: ../display/d.vect/main.c:250 ../vector/v.label/main.c:122
@@ -16167,21 +14919,16 @@
#: ../display/d.legend/main.c:342
msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-"Legende liegt außerhalb des Rahmens. Text könnte nicht richtig dargestellt "
-"werden."
+msgstr "Legende liegt außerhalb des Rahmens. Text könnte nicht richtig dargestellt werden."
#: ../display/d.legend/main.c:346
msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
-"Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
+msgstr "Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
#: ../display/d.legend/main.c:357
#, c-format
msgid "Range information for <%s> not available (run r.support)"
-msgstr ""
-"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
-"aus)."
+msgstr "Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support aus)."
#: ../display/d.legend/main.c:362
msgid "Input map contains no data"
@@ -16202,14 +14949,11 @@
#: ../display/d.legend/main.c:481
msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
-"Nichts zu zeichnen! (Keine Kategorien mit Labeln? Außerhalb der Spanne?"
+msgstr "Nichts zu zeichnen! (Keine Kategorien mit Labeln? Außerhalb der Spanne?"
#: ../display/d.legend/main.c:491
msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-"Erzwinge eine geglättete Legende: Zu viele Kategorien für die Höhe des "
-"aktuellen Fensters."
+msgstr "Erzwinge eine geglättete Legende: Zu viele Kategorien für die Höhe des aktuellen Fensters."
#: ../display/d.legend/main.c:521 ../display/d.histogram/main.c:180
#, c-format
@@ -16226,8 +14970,7 @@
msgstr "Nichts zu zeichnen! Evtl. keine Kategorien mit Labeln?"
#: ../display/d.vect.chart/main.c:66
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
msgstr "Stellt Diagramme von Vektordaten im aktiven Grafikfenster dar."
#: ../display/d.vect.chart/main.c:83
@@ -16251,9 +14994,7 @@
#: ../display/d.vect.chart/main.c:105
msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-"Größe des Diagramms (Durchmesser für Tortendiagramm, Gesamtbreite für "
-"Balkendiagrramm)."
+msgstr "Größe des Diagramms (Durchmesser für Tortendiagramm, Gesamtbreite für Balkendiagrramm)."
#: ../display/d.vect.chart/main.c:112
msgid "Scale for size (to get size in pixels)"
@@ -16300,12 +15041,8 @@
msgstr "Kann den Select-Cursor '%s' nicht öffnen."
#: ../display/d.rgb/main.c:57
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
-"Stellt drei Rasterkarten als rot, grün und blau Überlagerung im aktuellen "
-"Kartenfenster dar."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
+msgstr "Stellt drei Rasterkarten als rot, grün und blau Überlagerung im aktuellen Kartenfenster dar."
#: ../display/d.rgb/main.c:62 ../display/d.rast/main.c:80
msgid "Make null cells opaque"
@@ -16318,12 +15055,8 @@
#: ../display/d.where/main.c:47
#, fuzzy
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
-msgstr ""
-"Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-"
-"Fenster."
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
+msgstr "Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-Fenster."
#: ../display/d.where/main.c:57
#, fuzzy
@@ -16333,8 +15066,7 @@
#: ../display/d.where/main.c:62
#, fuzzy
msgid "File from which to read coordinates (\"-\" to read from stdin)"
-msgstr ""
-"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+msgstr "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
#: ../display/d.where/main.c:66
msgid "Output lat/long in decimal degree"
@@ -16345,13 +15077,8 @@
msgstr "Ausgabe auf den aktuellen Ellipsoid referenziert."
#: ../display/d.where/main.c:76
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
-"Gibt Lat/long Ausgabe auf einen WGS84-Ellipsoiden mit den definierten "
-"Datumstransformationsparametern der aktuellen Location (sofern vorhanden) "
-"aus."
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgstr "Gibt Lat/long Ausgabe auf einen WGS84-Ellipsoiden mit den definierten Datumstransformationsparametern der aktuellen Location (sofern vorhanden) aus."
#: ../display/d.where/main.c:82
msgid "Output frame coordinates of current display monitor (percentage)"
@@ -16363,17 +15090,13 @@
#: ../display/d.where/main.c:93
msgid "Please specify a lat/long ellipsoid with -l or -w"
-msgstr ""
-"Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
+msgstr "Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
#: ../display/d.where/main.c:135
msgid ""
"WGS84 output not possible as this location does not contain\n"
-msgstr ""
-"Ausgabe in WGS84A ist unmöglich, da diese Location keine Datums-"
-"benutzen."
+msgstr "Ausgabe in WGS84A ist unmöglich, da diese Location keine Datums-Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu benutzen."
#: ../display/d.where/where.c:29
#, fuzzy, c-format
@@ -16410,12 +15133,8 @@
#: ../display/d.barscale/main.c:92
#, fuzzy
-msgid ""
-"The screen coordinates for top-left corner of label ([0,0] is lower-left of "
-"frame)"
-msgstr ""
-"Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist "
-"oben links)."
+msgid "The screen coordinates for top-left corner of label ([0,0] is lower-left of frame)"
+msgstr "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist oben links)."
#: ../display/d.barscale/main.c:100
#, fuzzy
@@ -16432,12 +15151,8 @@
msgstr "Wähle entweder den Schalter -n oder -s."
#: ../display/d.measure/main.c:49
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
-msgstr ""
-"Misst die Länge und Fläche von Features, gezeichnet vom Benutzer, im aktiven "
-"Grafikfenster."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
+msgstr "Misst die Länge und Fläche von Features, gezeichnet vom Benutzer, im aktiven Grafikfenster."
#: ../display/d.measure/main.c:55
msgid "Line color 1"
@@ -16468,25 +15183,16 @@
msgstr "Keine Graphik-Ausgabe ausgewählt."
#: ../display/d.his/main.c:67
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
-msgstr ""
-"Zeigt das Ergebnis der Kombination Kombination von Farbwert-, Intensitäts- "
-"und Sättigungswerten (HIS) aus vom Benutzer gewählten Rasterkarten."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
+msgstr "Zeigt das Ergebnis der Kombination Kombination von Farbwert-, Intensitäts- und Sättigungswerten (HIS) aus vom Benutzer gewählten Rasterkarten."
#: ../display/d.his/main.c:95
msgid "Percent to brighten intensity channel"
msgstr "Prozent, die der Intensitätskanal aufgehellt wird."
#: ../display/d.what.rast/main.c:53
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
-msgstr ""
-"Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an "
-"einem angeklickten Punkt in der aktuellen Region abzufragen."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
+msgstr "Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an einem angeklickten Punkt in der aktuellen Region abzufragen."
#: ../display/d.what.rast/main.c:74
msgid "Field separator (terse mode only)"
@@ -16502,18 +15208,14 @@
#: ../display/d.what.rast/main.c:88
msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
-"Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der "
-"Region aus."
+msgstr "Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der Region aus."
#: ../display/d.what.rast/what.c:56
msgid "You are clicking outside the map"
msgstr "Sie klicken außerhalb der Karte."
#: ../display/d.thematic.area/main.c:79
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
msgstr "Stellt eine thematische Vektorkarte im aktiven Grafikfenster dar."
#: ../display/d.thematic.area/main.c:89
@@ -16529,12 +15231,8 @@
msgstr "Algorithmus, der zur Klassifikation verwendet werden sollen."
#: ../display/d.thematic.area/main.c:105 ../vector/v.class/main.c:67
-msgid ""
-"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
-"(normal distribution);"
-msgstr ""
-"int;einfache Intervalle;std;Standardabweichungen;qua;Quantile;equ;"
-"gleichwahrscheinlich(Normalverteilung);"
+msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
+msgstr "int;einfache Intervalle;std;Standardabweichungen;qua;Quantile;equ;gleichwahrscheinlich(Normalverteilung);"
#: ../display/d.thematic.area/main.c:116 ../vector/v.class/main.c:78
msgid "Number of classes to define"
@@ -16597,17 +15295,11 @@
#: ../display/d.thematic.area/main.c:153
msgid "File in which to save d.graph instructions for legend display"
-msgstr ""
-"Datei in der die d.grap-Anweisungen für die Darstellung der Legende "
-"gespeichert werden."
+msgstr "Datei in der die d.grap-Anweisungen für die Darstellung der Legende gespeichert werden."
#: ../display/d.thematic.area/main.c:164
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
-msgstr ""
-"Beim ausgeben der Legenden-Info auch die erweiterte Statistik des "
-"Klassifikationsalgorithmus ausgeben."
+msgid "When printing legend info , include extended statistical info from classification algorithm"
+msgstr "Beim ausgeben der Legenden-Info auch die erweiterte Statistik des Klassifikationsalgorithmus ausgeben."
#: ../display/d.thematic.area/main.c:168
msgid "Do not draw map, only output the legend"
@@ -16616,9 +15308,7 @@
#: ../display/d.thematic.area/main.c:187
#, c-format
msgid "%s: You must build topology on vector map. Run v.build."
-msgstr ""
-"%s: Sie müssen die Topologie für die Vektorkarte erstellen. Führen Sie v."
-"build aus."
+msgstr "%s: Sie müssen die Topologie für die Vektorkarte erstellen. Führen Sie v.build aus."
#: ../display/d.thematic.area/main.c:194
msgid "'layer' must be > 0"
@@ -16669,19 +15359,12 @@
msgstr "Unbekannte Farbe: [%s]."
#: ../display/d.thematic.area/main.c:298
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
-msgstr ""
-"Sie haben manuelle Klassengrenzen und ein Klassifikationsalgorithmus/"
-"Klassenanzahl angegeben. Die manuellen Klassengrenzen haben Vorrang und "
-"werden daher verwendet."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
+msgstr "Sie haben manuelle Klassengrenzen und ein Klassifikationsalgorithmus/Klassenanzahl angegeben. Die manuellen Klassengrenzen haben Vorrang und werden daher verwendet."
#: ../display/d.thematic.area/main.c:335
msgid "You must either give classbreaks or a classification algorithm"
-msgstr ""
-"Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus "
-"angeben."
+msgstr "Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus angeben."
#: ../display/d.thematic.area/main.c:348
#, c-format
@@ -16702,11 +15385,8 @@
msgstr "Zeichne..."
#: ../display/d.thematic.area/main.c:379
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-"Die BoundingBox der Karte liegt außerhalb der derzeitigen Region, es wird "
-"nichts gezeichnet."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
+msgstr "Die BoundingBox der Karte liegt außerhalb der derzeitigen Region, es wird nichts gezeichnet."
#: ../display/d.thematic.area/main.c:429
#, c-format
@@ -16748,13 +15428,8 @@
#: ../display/d.thematic.area/plot1.c:129 ../display/d.vect/shape.c:58
#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
-msgstr ""
-"Farbdefinitionsspalte (%s) ist keine Zeichenkette. Die Spalte muss die "
-"folgende Form haben: RRR:GGG:BBB. Die RGB-Werte müssen zwischen 0 und 255 "
-"liegen."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
+msgstr "Farbdefinitionsspalte (%s) ist keine Zeichenkette. Die Spalte muss die folgende Form haben: RRR:GGG:BBB. Die RGB-Werte müssen zwischen 0 und 255 liegen."
#: ../display/d.thematic.area/plot1.c:147
msgid "Line width column not specified."
@@ -16776,12 +15451,8 @@
#: ../display/d.thematic.area/plot1.c:278
#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring [%"
-"s]"
-msgstr ""
-"Fehler in der Farbdefinitionsspalte (%s), Element %d mit Kategorie %d: "
-"Farbwert [%s]."
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+msgstr "Fehler in der Farbdefinitionsspalte (%s), Element %d mit Kategorie %d: Farbwert [%s]."
#: ../display/d.thematic.area/plot1.c:285
#, c-format
@@ -16790,11 +15461,8 @@
#: ../display/d.thematic.area/plot1.c:353
#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-"Fehler in der Spalte mit den Linienbreiten (%s), Element %d mit cat %d: "
-"Linienbreite [%d]."
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr "Fehler in der Spalte mit den Linienbreiten (%s), Element %d mit cat %d: Linienbreite [%d]."
#: ../display/d.colortable/main.c:63
msgid "Displays the color table associated with a raster map layer."
@@ -16822,14 +15490,12 @@
#: ../display/d.colortable/main.c:114
#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:128
#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
msgstr ""
#: ../display/d.colortable/main.c:139
@@ -16839,9 +15505,7 @@
#: ../display/d.extract/main.c:52
msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-"Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine "
-"neue Karte."
+msgstr "Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine neue Karte."
#: ../display/d.extract/main.c:117
msgid "Copying tables..."
@@ -16849,9 +15513,7 @@
#: ../display/d.extract/main.c:125
msgid "Cannot get db link info -> cannot copy table."
-msgstr ""
-"Kann die Informationen zu Datenbankverbindung nicht lesen -> Kann Tabelle "
-"nicht kopieren."
+msgstr "Kann die Informationen zu Datenbankverbindung nicht lesen -> Kann Tabelle nicht kopieren."
#: ../display/d.extract/extract.c:43
msgid "Select vector(s) with mouse"
@@ -16863,14 +15525,11 @@
#: ../display/d.extract/extract.c:45
msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-"- M: Zeichne Boxe mit der mittleren Maustaste, die von der Darstellung "
-"entfernt werden soll."
+msgstr "- M: Zeichne Boxe mit der mittleren Maustaste, die von der Darstellung entfernt werden soll."
#: ../display/d.extract/extract.c:46
msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-" - R: Beende und speichere die ausgewählten Vektoren in eine neuen Karte.\n"
+msgstr " - R: Beende und speichere die ausgewählten Vektoren in eine neuen Karte.\n"
#: ../display/d.extract/extract.c:48
msgid "L: add M: remove R: quit and save\n"
@@ -16882,12 +15541,8 @@
msgstr "Berechne Histogramm"
#: ../display/d.histogram/main.c:88
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-"Stellt ein Histogramm in Torten- oder Balkenform für eine angegebene "
-"Rasterkarte dar."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+msgstr "Stellt ein Histogramm in Torten- oder Balkenform für eine angegebene Rasterkarte dar."
#: ../display/d.histogram/main.c:92
msgid "Raster map for which histogram will be displayed"
@@ -16903,14 +15558,11 @@
#: ../display/d.histogram/main.c:113
msgid "Indicate if cell counts or map areas should be displayed"
-msgstr ""
-"Gibt an, ob die Zellenanzahl oder Karteneinheiten angezeigt werden sollen."
+msgstr "Gibt an, ob die Zellenanzahl oder Karteneinheiten angezeigt werden sollen."
#: ../display/d.histogram/main.c:123
msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr ""
-"Anzahl der Klassen, in die die Datenspanne aufgeteilt werden soll (nur bei "
-"Fließkommakarten)."
+msgstr "Anzahl der Klassen, in die die Datenspanne aufgeteilt werden soll (nur bei Fließkommakarten)."
#: ../display/d.histogram/main.c:130
msgid "Display information for null cells"
@@ -16934,11 +15586,8 @@
msgstr "Wenn der Schalter -C gesetzt ist, wird das Argument nsteps ignoriert."
#: ../display/d.linegraph/main.c:122
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
-msgstr ""
-"Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
+msgstr "Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
#: ../display/d.linegraph/main.c:126
msgid "Name of data file for X axis of graph"
@@ -17002,11 +15651,8 @@
msgstr "Problem beim Lesen von <%s> Datei in der Zeile %d."
#: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
-msgstr ""
-"Erzeugt einen Titel für eine Rasterkarte in einer geeigneten Form für die "
-"Darstellung mit d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
+msgstr "Erzeugt einen Titel für eine Rasterkarte in einer geeigneten Form für die Darstellung mit d.text."
#: ../display/d.title/main.c:63
msgid "Sets the text color"
@@ -17037,24 +15683,16 @@
msgstr "Keine Karte angegeben."
#: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
-msgstr ""
-"Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
+msgid "Program for generating and displaying simple graphics on the display monitor."
+msgstr "Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
#: ../display/d.graph/main.c:68
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
-msgstr ""
-"Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird "
-"von der Standardeingabe gelesen."
+msgid "Name of file containing graphics commands, if not given reads from standard input"
+msgstr "Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird von der Standardeingabe gelesen."
#: ../display/d.graph/main.c:76
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Farbe zum Zeichnen, entweder eine GRASS Standard-Farbe oder eine R:G:B-"
-"Tripel."
+msgstr "Farbe zum Zeichnen, entweder eine GRASS Standard-Farbe oder eine R:G:B-Tripel."
#: ../display/d.graph/main.c:83
msgid "Coordinates are given in map units"
@@ -17087,9 +15725,7 @@
msgstr "Kann Symbol nicht lesen; stelle daher die Punkte nicht dar."
#: ../display/d.mon/main.c:41
-msgid ""
-"Controls graphics display monitors which can be controlled from the command "
-"line."
+msgid "Controls graphics display monitors which can be controlled from the command line."
msgstr ""
#: ../display/d.mon/main.c:46
@@ -17249,12 +15885,8 @@
msgstr "Grafikfenster <%s> freigegeben."
#: ../display/d.what.vect/main.c:61
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
-msgstr ""
-"Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der "
-"aktuellen Region."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
+msgstr "Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der aktuellen Region."
#: ../display/d.what.vect/main.c:77
msgid "Name of existing vector map"
@@ -17417,9 +16049,7 @@
msgstr "Warnung: Vektorkarte '%s' wurde nicht gefunden.\n"
#: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
msgstr "Zeichnet Text im aktiven Graphik-Fenster mit der aktuellen Schrift."
#: ../display/d.text/main.c:148
@@ -17436,21 +16066,15 @@
#: ../display/d.text/main.c:173
msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Texthintergrundfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B "
-"Tripel."
+msgstr "Texthintergrundfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B Tripel."
#: ../display/d.text/main.c:182
msgid "The screen line number on which text will begin to be drawn"
msgstr "Die Zeile des Grafikfensters, in der der Text beginnt."
#: ../display/d.text/main.c:190
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
-msgstr ""
-"Bildschirmposition, an der der Text angefangen wird, zu zeichnen (in "
-"Prozent, [0,0] ist die untere linke Ecke)."
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+msgstr "Bildschirmposition, an der der Text angefangen wird, zu zeichnen (in Prozent, [0,0] ist die untere linke Ecke)."
#: ../display/d.text/main.c:198
msgid "Text alignment"
@@ -17504,8 +16128,7 @@
"Please enter text instructions. Enter EOF (ctrl-d) on last line to quit\n"
msgstr ""
"\n"
-"Bitte geben Sie Anweisungen ein. Um dies zu beenden geben Sie in der "
-"letzten Zeile EOF (Strg-d) ein.\n"
+"Bitte geben Sie Anweisungen ein. Um dies zu beenden geben Sie in der letzten Zeile EOF (Strg-d) ein.\n"
#: ../display/d.text/main.c:567
#, c-format
@@ -17519,9 +16142,7 @@
msgstr "Vektor, Zeichen Label"
#: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
msgstr "Zeigt Text-Label (mit v.label erstellt) im aktiven Grafikfenster."
#: ../display/d.labels/main.c:52
@@ -17547,13 +16168,11 @@
#: ../display/d.labels/main.c:97
msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-"Region-Größe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
+msgstr "Region-Größe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
#: ../display/d.labels/main.c:105
msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-"Region-Größe ist größer als die Maximal-Region; es wird nichts angezeigt."
+msgstr "Region-Größe ist größer als die Maximal-Region; es wird nichts angezeigt."
#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:300
#, c-format
@@ -17606,12 +16225,8 @@
msgstr "%s: ungültiger Wert."
#: ../display/d.rast.num/main.c:74
-msgid ""
-"Overlays cell category values on a raster map layer displayed to the "
-msgstr ""
-"Überlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-"
-"Fenster."
+msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+msgstr "Überlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-Fenster."
#: ../display/d.rast.num/main.c:86
msgid "Color for drawing grid, or \"none\""
@@ -17642,12 +16257,10 @@
#: ../display/d.rast.num/main.c:181
msgid ""
"\n"
-"Your current window setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current window setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
msgstr ""
"\n"
-"Ihre aktuelle Fenstereinstellung könnte zu groß sein. Um die "
-"Kategorienummern lesen zu können, sollten sie weiter hereinzoomen."
+"Ihre aktuelle Fenstereinstellung könnte zu groß sein. Um die Kategorienummern lesen zu können, sollten sie weiter hereinzoomen."
#: ../display/d.rast.num/main.c:187
msgid "Aborting."
@@ -17658,12 +16271,8 @@
msgstr ""
#: ../display/d.zoom/main.c:64
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
-msgstr ""
-"Erlaubt dem Benutzer die altuelle geographische Region interaktiv mit der "
-"Maus zu ändern."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
+msgstr "Erlaubt dem Benutzer die altuelle geographische Region interaktiv mit der Maus zu ändern."
#: ../display/d.zoom/main.c:84
msgid "Name of vector map"
@@ -17748,9 +16357,7 @@
#: ../display/d.zoom/zoom.c:41
#, c-format
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue "
-"Region einzustellen.\n"
+msgstr "Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue Region einzustellen.\n"
#: ../display/d.zoom/pan.c:17
#, c-format
@@ -17776,11 +16383,7 @@
msgstr "Darstellung"
#: ../display/d.vect/main.c:87
-msgid ""
-"shape;Display geometry of features;cat;Display category numbers of features;"
-"topo;Display topology information (nodes, edges);dir;Display direction of "
-"linear features;attr;Display selected attribute based on 'attrcolumn';zcoor;"
-"Display z-coordinate of features (only for 3D vector maps)"
+msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcolumn';zcoor;Display z-coordinate of features (only for 3D vector maps)"
msgstr ""
#: ../display/d.vect/main.c:112
@@ -17822,8 +16425,7 @@
#: ../display/d.vect/main.c:152
#, fuzzy
msgid "These values will be scaled by width_scale"
-msgstr ""
-"Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
+msgstr "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
#: ../display/d.vect/main.c:159
#, fuzzy
@@ -17846,9 +16448,7 @@
#: ../display/d.vect/main.c:180
msgid "When used with the size_column option this becomes the scale factor"
-msgstr ""
-"Dies wird der Skalierungsfaktor, wenn es zusammen mit der Option size_column "
-"verwendet wird."
+msgstr "Dies wird der Skalierungsfaktor, wenn es zusammen mit der Option size_column verwendet wird."
#: ../display/d.vect/main.c:186
msgid "Name of numeric column containing symbol size"
@@ -17872,9 +16472,7 @@
#: ../display/d.vect/main.c:202
msgid "Layer number for labels (default: the given layer number)"
-msgstr ""
-"Layernummer für die Beschriftungen (Standard: die bereits gegebene "
-"Layernummer)."
+msgstr "Layernummer für die Beschriftungen (Standard: die bereits gegebene Layernummer)."
#: ../display/d.vect/main.c:208
msgid "Name of column to be displayed"
@@ -17910,18 +16508,12 @@
msgstr "Vertikale Labelausrichtung"
#: ../display/d.vect/main.c:279
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
-msgstr ""
-"Minimale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen "
-"der Karte."
+msgid "Minimum region size (average from height and width) when map is displayed"
+msgstr "Minimale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen der Karte."
#: ../display/d.vect/main.c:287
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
-msgstr ""
-"Maximale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen "
-"der Karte."
+msgid "Maximum region size (average from height and width) when map is displayed"
+msgstr "Maximale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen der Karte."
#: ../display/d.vect/main.c:295
#, fuzzy
@@ -17929,12 +16521,8 @@
msgstr "Hole die Farbe aus der Tabellenspalte (RRR:GGG:BBB)."
#: ../display/d.vect/main.c:301
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
-msgstr ""
-"Füllt die Flächen mit zufälligen Farben entsprechend den Kategorienummern "
-"(oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+msgstr "Füllt die Flächen mit zufälligen Farben entsprechend den Kategorienummern (oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
#: ../display/d.vect/main.c:308
msgid "Use values from 'cats' option as feature id"
@@ -17949,30 +16537,22 @@
msgstr ""
#: ../display/d.vect/main.c:319
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
msgstr ""
#: ../display/d.vect/main.c:339
#, fuzzy
msgid "Region size is lower than minreg, nothing displayed"
-msgstr ""
#: ../display/d.vect/main.c:347
#, fuzzy
msgid "Region size is greater than maxreg, nothing displayed"
-msgstr ""
#: ../display/d.vect/main.c:361
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
-msgstr ""
-"Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der "
-"Schalter '-c' wird ignoriert!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
+msgstr "Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der Schalter '-c' wird ignoriert!"
#: ../display/d.vect/main.c:383 ../display/d.vect/main.c:389
#: ../vector/v.out.ascii/args.c:130
@@ -17992,11 +16572,8 @@
#: ../display/d.vect/main.c:417
#, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
-msgstr ""
+msgid "The bounding box of the map is outside the current region, nothing drawn"
#: ../display/d.vect/main.c:480
#, fuzzy
@@ -18010,9 +16587,7 @@
#: ../display/d.vect/area.c:37
#, fuzzy
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
msgstr "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
#: ../display/d.vect/lines.c:107 ../display/d.vect/lines.c:373
@@ -18022,12 +16597,8 @@
#: ../display/d.vect/lines.c:121
#, fuzzy
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
-msgstr ""
-"Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht "
-"vorhanden ist."
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
+msgstr "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht vorhanden ist."
#: ../display/d.vect/lines.c:213
#, fuzzy, c-format
@@ -18091,8 +16662,7 @@
msgstr "Spalte für die Symbolrotation (%s) is nicht numerisch."
#: ../display/d.vect/shape.c:173
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
msgstr ""
#: ../display/d.vect/shape.c:244 ../display/d.vect/shape.c:249
@@ -18111,9 +16681,7 @@
msgstr "Unbekannte Farbe: '%s'."
#: ../display/d.vect/topo.c:17
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
msgstr ""
#: ../display/d.vect/attr.c:28
@@ -18137,8 +16705,7 @@
#: ../vector/v.sample/main.c:89
#, fuzzy
msgid "Name of attribute column to use for comparison"
-msgstr ""
-"Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
+msgstr "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
#: ../vector/v.sample/main.c:92
#, fuzzy
@@ -18158,9 +16725,7 @@
#: ../vector/v.sample/main.c:114
#, fuzzy
msgid "Sampled values will be multiplied by this factor"
-msgstr ""
-"Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit "
-"diesem Faktor multipliziert."
+msgstr "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit diesem Faktor multipliziert."
#: ../vector/v.sample/main.c:140 ../vector/v.reclass/main.c:125
#: ../vector/v.surf.idw/read_sites.c:36 ../misc/m.nviz.image/vector.c:247
@@ -18171,8 +16736,7 @@
#: ../vector/v.sample/main.c:154
#, c-format
msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr ""
-"Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
+msgstr "Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
#: ../vector/v.sample/main.c:158 ../vector/v.to.rast3/main.c:92
#: ../vector/v.surf.bspline/main.c:375 ../vector/v.class/main.c:121
@@ -18293,11 +16857,8 @@
msgstr "NULL-Wert-Indikator"
#: ../vector/v.db.select/main.c:90
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
-msgstr ""
-"Gebe anstelle der Attribute die minimale Ausdehnung der Region der "
-"selektierten Vektorfeatures aus."
+msgid "Print minimal region extent of selected vector features instead of attributes"
+msgstr "Gebe anstelle der Attribute die minimale Ausdehnung der Region der selektierten Vektorfeatures aus."
#: ../vector/v.db.select/main.c:94 ../db/db.select/main.c:242
msgid "Do not include column names in output"
@@ -18309,12 +16870,8 @@
#: ../vector/v.db.select/main.c:135
#, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
-msgstr ""
-"Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' "
-"benötigt aber den topologischen Modus."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
+msgstr "Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' benötigt aber den topologischen Modus."
#: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:78
#: ../vector/v.extract/main.c:251 ../vector/v.extract/main.c:358
@@ -18369,12 +16926,8 @@
#: ../vector/v.net.alloc/main.c:66
#, fuzzy
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
-msgstr ""
-"Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen "
-"Knoten gehen im die Berechnung mit ein."
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
#: ../vector/v.net.alloc/main.c:93 ../vector/v.net.iso/main.c:100
#: ../vector/v.net.salesman/main.c:135 ../vector/v.net.distance/main.c:119
@@ -18404,12 +16957,8 @@
#: ../vector/v.net.alloc/main.c:111
#, fuzzy
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
-msgstr ""
-"Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen "
-"wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegebn."
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgstr "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegebn."
#: ../vector/v.net.alloc/main.c:163 ../vector/v.net.iso/main.c:198
#: ../vector/v.net.salesman/main.c:208 ../vector/v.net.steiner/main.c:441
@@ -18425,8 +16974,7 @@
#: ../vector/v.net.alloc/main.c:192
#, fuzzy
msgid "Not enough centers for selected nlayer. Nothing will be allocated."
-msgstr ""
-"Nicht genügend Zentren für den gewählten nlayer. Nichts wird zugewiesen."
+msgstr "Nicht genügend Zentren für den gewählten nlayer. Nichts wird zugewiesen."
#: ../vector/v.net.alloc/main.c:203
#, fuzzy
@@ -18436,8 +16984,7 @@
#: ../vector/v.net.alloc/main.c:343 ../vector/v.net.alloc/main.c:354
#: ../vector/v.net.iso/main.c:508
msgid "Cannot get line segment, segment out of line"
-msgstr ""
-"Kann das Liniensegment nicht bekommen, Segment ist außerhalb der Linie."
+msgstr "Kann das Liniensegment nicht bekommen, Segment ist außerhalb der Linie."
#: ../vector/v.net/main.c:47
#, fuzzy
@@ -18484,9 +17031,7 @@
#: ../vector/v.net/args.c:13
#, fuzzy
msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
-msgstr ""
-"Erforderlich für die Operation 'connect'. Verbindet Punkte innerhalb des "
-"gegebenen Schwellenwertes."
+msgstr "Erforderlich für die Operation 'connect'. Verbindet Punkte innerhalb des gegebenen Schwellenwertes."
#: ../vector/v.net/args.c:15 ../vector/v.net/args.c:56
msgid "Arcs"
@@ -18514,25 +17059,12 @@
#: ../vector/v.net/args.c:36
#, fuzzy
-msgid ""
-"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
-"connect still unconnected points to vector network by inserting new line(s);"
-"arcs;new line is created from start point to end point;report;print to "
-"standard output {line_category start_point_category end_point_category};"
-"nreport;print to standard output {point_category line_category[,"
-"line_category...]}"
-msgstr ""
-"nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn "
-"sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks "
-"durch einfügen neuer Linien;report;Gebe auf der Standardausgabe "
-"{line_category start_point_category end_point_category} aus;nreport;Gebe auf "
-"der Standardausgabe {point_category line_category [line_category...]}aus"
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);arcs;new line is created from start point to end point;report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
+msgstr "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe {line_category start_point_category end_point_category} aus;nreport;Gebe auf der Standardausgabe {point_category line_category [line_category...]}aus"
#: ../vector/v.net/args.c:72
msgid "Required for operation 'connect'. Connect points in given threshold."
-msgstr ""
#: ../vector/v.net/args.c:78
#, fuzzy
@@ -18722,9 +17254,7 @@
#: ../vector/v.to.db/update.c:32 ../vector/v.to.db/query.c:83
#, c-format
msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"Datenbankverbindung für Layer %d nicht definiert. Verwenden Sie zuerst v.db."
-"connect."
+msgstr "Datenbankverbindung für Layer %d nicht definiert. Verwenden Sie zuerst v.db.connect."
#: ../vector/v.to.db/update.c:82
msgid "Updating database..."
@@ -18757,8 +17287,7 @@
#: ../vector/v.to.db/parse.c:41
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Für coor sind Punkt/Zentroid erlaubt; für length sind Linie/Grenze erlaubt."
+msgstr "Für coor sind Punkt/Zentroid erlaubt; für length sind Linie/Grenze erlaubt."
#: ../vector/v.to.db/parse.c:46
#, fuzzy
@@ -18793,8 +17322,7 @@
#: ../vector/v.to.db/parse.c:104
msgid "In print mode prints totals for options: length,area,count"
-msgstr ""
-"Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
+msgstr "Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
#: ../vector/v.to.db/parse.c:139
msgid "This option requires one column"
@@ -18840,19 +17368,13 @@
#: ../vector/v.to.db/query.c:108
#, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many (%"
-"d) query categories. All later reported values for cat 0 are not valid."
-msgstr ""
-"Abfrage für Kategorie '0' (keine Kategorie) wurde nicht ausgeführt, weil zu "
-"viele (%d) Kategorien in der Abfrage sind. Alle im Folgenden berichteten "
-"Werte für cat 0 sind nicht korrekt. "
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
+msgstr "Abfrage für Kategorie '0' (keine Kategorie) wurde nicht ausgeführt, weil zu viele (%d) Kategorien in der Abfrage sind. Alle im Folgenden berichteten Werte für cat 0 sind nicht korrekt. "
#: ../vector/v.to.db/query.c:145
#, c-format
msgid "Multiple query results, output value set to NULL (category [%d])"
-msgstr ""
-"Mehrere Abfrage-Ergebnisse, Ausgabewert auf NULL gesetzt (Kategorie [%d])."
+msgstr "Mehrere Abfrage-Ergebnisse, Ausgabewert auf NULL gesetzt (Kategorie [%d])."
#: ../vector/v.to.db/query.c:152
msgid "Unable to fetch record"
@@ -18871,16 +17393,12 @@
#: ../vector/v.to.db/report.c:194
#, c-format
msgid "%d categories read from vector map exist in selection from table"
-msgstr ""
-"%d Kategorien gelesen von der Vektorkarte existieren in der Selektion der "
-"Tabelle."
+msgstr "%d Kategorien gelesen von der Vektorkarte existieren in der Selektion der Tabelle."
#: ../vector/v.to.db/report.c:197
#, c-format
msgid "%d categories read from vector map don't exist in selection from table"
-msgstr ""
-"%d Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion "
-"der Tabelle."
+msgstr "%d Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion der Tabelle."
#: ../vector/v.to.db/report.c:199
#, c-format
@@ -18960,27 +17478,8 @@
msgstr "Vektorbasierte Generalisierung."
#: ../vector/v.generalize/main.c:103
-msgid ""
-"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
-"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
-"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
-"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
-"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
-"smoothing;network;Network generalization;displacement;Displacement of lines "
-"close to each other;"
-msgstr ""
-"douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker "
-"Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;"
-"reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht "
-"beieinander liegen;reumann;Reumann-Witkam Algorithmus;boyle;Boyle's "
-"vorausschauender Algorithmus;sliding_averaging;McMaster's gleitender "
-"Mittelwert-Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-"
-"Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit "
-"kubischen Hermite-Splines;snakes;Snake-Methoden zum Glätten von Linien;"
-"network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die "
-"dicht beieinander liegen;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
+msgstr "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht beieinander liegen;reumann;Reumann-Witkam Algorithmus;boyle;Boyle's vorausschauender Algorithmus;sliding_averaging;McMaster's gleitender Mittelwert-Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit kubischen Hermite-Splines;snakes;Snake-Methoden zum Glätten von Linien;network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die dicht beieinander liegen;"
#: ../vector/v.generalize/main.c:117
msgid "Generalization algorithm"
@@ -18996,20 +17495,15 @@
#: ../vector/v.generalize/main.c:140
msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
-msgstr ""
-"Prozentsatz der Punkte im Ergebnis des 'douglas_reduction' Algorithmus."
+msgstr "Prozentsatz der Punkte im Ergebnis des 'douglas_reduction' Algorithmus."
#: ../vector/v.generalize/main.c:149
msgid "Slide of computed point toward the original point"
-msgstr ""
-"Verschieben von berechneten Punkten in Richtung seiner ursprünglichen "
-"Position."
+msgstr "Verschieben von berechneten Punkten in Richtung seiner ursprünglichen Position."
#: ../vector/v.generalize/main.c:158
msgid "Minimum angle between two consecutive segments in Hermite method"
-msgstr ""
-"Minimaler Winkel zwischen zwei aufeinanderfolgenden Segmenten in der Hermite-"
-"Methode."
+msgstr "Minimaler Winkel zwischen zwei aufeinanderfolgenden Segmenten in der Hermite-Methode."
#: ../vector/v.generalize/main.c:166
msgid "Degree threshold in network generalization"
@@ -19017,8 +17511,7 @@
#: ../vector/v.generalize/main.c:175
msgid "Closeness threshold in network generalization"
-msgstr ""
-"Geschlossenheits(closeness)-Schwellenwert für die Netzwerk Generalisierung."
+msgstr "Geschlossenheits(closeness)-Schwellenwert für die Netzwerk Generalisierung."
#: ../vector/v.generalize/main.c:183
msgid "Betweeness threshold in network generalization"
@@ -19073,17 +17566,13 @@
#: ../vector/v.generalize/main.c:492
#, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
-msgstr ""
-"%d Grenzen wurden nicht geändert, weil Änderungen die Topologie beschädigen "
-"würden."
+msgid "%d boundaries were not modified because modification would damage topology"
+msgstr "%d Grenzen wurden nicht geändert, weil Änderungen die Topologie beschädigen würden."
#: ../vector/v.generalize/main.c:495
#, c-format
msgid "%d lines/boundaries were not modified due to over-simplification"
-msgstr ""
-"%d Linien/Grenzen wurden nicht geändert wegen übertriebener Vereinfachung."
+msgstr "%d Linien/Grenzen wurden nicht geändert wegen übertriebener Vereinfachung."
#: ../vector/v.generalize/main.c:510
#, c-format
@@ -19141,24 +17630,15 @@
#: ../vector/v.build/main.c:46
msgid "Name for vector map where erroneous vector features are written to"
-msgstr ""
-"Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben werden "
-"sollen."
+msgstr "Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben werden sollen."
#: ../vector/v.build/main.c:57
msgid "Build topology or dump topology or spatial index to stdout"
-msgstr ""
-"Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach "
-"stdout."
+msgstr "Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach stdout."
#: ../vector/v.build/main.c:59
-msgid ""
-"build;build topology;dump;write topology to stdout;sdump;write spatial index "
-"to stdout;cdump;write category index to stdout"
-msgstr ""
-"build;Erzeuge Topologie;dump;Schreibe Topologie nach stdout;sdump;Schreibe "
-"den räumlichen Index nach stdout;cdump;Schreibe den Kategorie-Index nach "
-"stdout"
+msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
+msgstr "build;Erzeuge Topologie;dump;Schreibe Topologie nach stdout;sdump;Schreibe den räumlichen Index nach stdout;cdump;Schreibe den Kategorie-Index nach stdout"
#: ../vector/v.build/main.c:88
#, fuzzy, c-format
@@ -19191,9 +17671,7 @@
#: ../vector/v.in.ogr/main.c:140
msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-"Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer "
-"importiert."
+msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer importiert."
#: ../vector/v.in.ogr/main.c:142
msgid ""
@@ -19219,21 +17697,15 @@
#: ../vector/v.in.ogr/main.c:172
msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-"Kleinere Flächen und Inseln werden ignoriert. Sollte größer sein als snap^2."
+msgstr "Kleinere Flächen und Inseln werden ignoriert. Sollte größer sein als snap^2."
#: ../vector/v.in.ogr/main.c:178
msgid "Optionally change default input type"
msgstr "Optionalerweise: Ändere den Standard Input-Typ."
#: ../vector/v.in.ogr/main.c:180
-msgid ""
-"point;import area centroids as points;line;import area boundaries as lines;"
-"boundary;import lines as area boundaries;centroid;import points as centroids"
-msgstr ""
-"point;Importiere Zentroide als Punkte;line;Importiere Grenzen als Linien;"
-"boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als "
-"Zentroide"
+msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
+msgstr "point;Importiere Zentroide als Punkte;line;Importiere Grenzen als Linien;boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als Zentroide"
#: ../vector/v.in.ogr/main.c:191
msgid "Snapping threshold for boundaries"
@@ -19244,12 +17716,8 @@
msgstr "'-1' für kein snapping"
#: ../vector/v.in.ogr/main.c:207
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
-msgstr ""
-"Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der "
-"Erste entspricht der Kategoriespalte."
+msgid "List of column names to be used instead of original names, first is used for category column"
+msgstr "Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der Erste entspricht der Kategoriespalte."
#: ../vector/v.in.ogr/main.c:213 ../vector/v.external/args.c:47
#, fuzzy
@@ -19258,8 +17726,7 @@
#: ../vector/v.in.ogr/main.c:219
#, fuzzy
-msgid ""
-"List available OGR layers including feature types in data source and exit"
+msgid "List available OGR layers including feature types in data source and exit"
msgstr "Zeigt die vorhandenen Layer in der Datenquelle und beendet sich."
#: ../vector/v.in.ogr/main.c:233
@@ -19285,9 +17752,7 @@
msgstr "Ändere Spaltenname zu Kleinbuchstaben"
#: ../vector/v.in.ogr/main.c:270
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector data."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
msgstr ""
#: ../vector/v.in.ogr/main.c:289
@@ -19327,9 +17792,7 @@
#: ../vector/v.in.ogr/main.c:411 ../vector/v.in.lidar/main.c:284
msgid "Select either the current region flag or the spatial option, not both"
-msgstr ""
-"Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option "
-"'spatial' aber nicht beide."
+msgstr "Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option 'spatial' aber nicht beide."
#: ../vector/v.in.ogr/main.c:439 ../vector/v.in.lidar/main.c:312
msgid "4 parameters required for 'spatial' parameter"
@@ -19358,25 +17821,17 @@
#: ../vector/v.in.ogr/main.c:812
#, c-format
msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-"Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas "
-"abgeschnitten worden sein). "
+msgstr "Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas abgeschnitten worden sein). "
#: ../vector/v.in.ogr/main.c:835
#, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-"Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR "
-"bestimmt). Einige Texte können abgeschnitten worden sein!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr "Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR bestimmt). Einige Texte können abgeschnitten worden sein!"
#: ../vector/v.in.ogr/main.c:847
#, c-format
msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
-"Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas "
+msgstr "Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas abgeschnitten worden sein). "
#: ../vector/v.in.ogr/main.c:851
#, c-format
@@ -19466,15 +17921,8 @@
#: ../vector/v.in.ogr/main.c:1191
#, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
-msgstr ""
-"%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem "
-"Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in "
-"der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist "
-"als Kategoriewert im Layer %d abgelegt."
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr "%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist als Kategoriewert im Layer %d abgelegt."
#: ../vector/v.in.ogr/main.c:1201
#, c-format
@@ -19518,12 +17966,8 @@
#: ../vector/v.in.ogr/main.c:1262
#, fuzzy
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, use -z flag to "
-"import 3D vector."
-msgstr ""
-"Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur "
-"2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
+msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector."
+msgstr "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur 2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
#: ../vector/v.in.ogr/geom.c:193 ../vector/v.in.ogr/geom.c:214
#, fuzzy
@@ -19566,8 +18010,7 @@
#: ../vector/v.to.rast3/main.c:51
#, fuzzy
msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr ""
-"Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
+msgstr "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
#: ../vector/v.to.rast3/main.c:62
#, fuzzy
@@ -19597,12 +18040,8 @@
#: ../vector/v.extract/main.c:81
#, fuzzy
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector "
-"map containing only the selected features."
-msgstr ""
-"Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
-"neue Karte nur mit den selektierten Objekten."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
+msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
#: ../vector/v.extract/main.c:86
msgid "Dissolve common boundaries (default is no)"
@@ -19611,8 +18050,7 @@
#: ../vector/v.extract/main.c:90
#, fuzzy
msgid "Do not copy attributes (see also 'new' parameter)"
-msgstr ""
-"Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
+msgstr "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
#: ../vector/v.extract/main.c:95 ../vector/v.select/args.c:87
#: ../vector/v.edit/args.c:181
@@ -19625,9 +18063,7 @@
#: ../vector/v.extract/main.c:121
msgid "Input text file with category numbers/number ranges to be extracted"
-msgstr ""
-"Eingabe-Textdatei mit Kategorienummern/-wertebereichen, die extrahiert "
-"werden sollen."
+msgstr "Eingabe-Textdatei mit Kategorienummern/-wertebereichen, die extrahiert werden sollen."
#: ../vector/v.extract/main.c:122
msgid "If '-' given reads from standard input"
@@ -19635,14 +18071,11 @@
#: ../vector/v.extract/main.c:130
msgid "Number of random categories matching vector objects to extract"
-msgstr ""
-"Zahl der zu zufälligen Kategorien passenden Vektorobjekten, die extrahiert "
-"werden."
+msgstr "Zahl der zu zufälligen Kategorien passenden Vektorobjekten, die extrahiert werden."
#: ../vector/v.extract/main.c:132
msgid "Number must be smaller than unique cat count in layer"
-msgstr ""
-"Zahl muss kleiner sein als die Anzahl der eindeutigen cat in dem Layer."
+msgstr "Zahl muss kleiner sein als die Anzahl der eindeutigen cat in dem Layer."
#: ../vector/v.extract/main.c:140
msgid "Desired new category value (enter -1 to keep original categories)"
@@ -19655,12 +18088,8 @@
#: ../vector/v.extract/main.c:159
#, fuzzy, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
-"one of them."
-msgstr ""
-"Die Optionen list, file, where und random schließen sich gegenseitig aus. "
-"Bitte geben Sie nur eine von diesen an."
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
+msgstr "Die Optionen list, file, where und random schließen sich gegenseitig aus. Bitte geben Sie nur eine von diesen an."
#: ../vector/v.extract/main.c:204
#, c-format
@@ -19698,12 +18127,8 @@
msgstr "%d Kategorien aus der Tabelle geladen."
#: ../vector/v.extract/main.c:280
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
-msgstr ""
-"Diese Karte hat keine Kategorien beigefügt. Verwenden Sie v.category, um "
-"dieser Karte Kategorien zuzuordnen."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
+msgstr "Diese Karte hat keine Kategorien beigefügt. Verwenden Sie v.category, um dieser Karte Kategorien zuzuordnen."
#: ../vector/v.extract/main.c:287
msgid "Please specify random number larger than 0"
@@ -19711,26 +18136,16 @@
#: ../vector/v.extract/main.c:291
#, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
-msgstr ""
-"Die Zahl der zufälligen Kategorien muss kleiner sein, als die Zahl der "
-"Feature. Es gibt nur %d Feature des Typs: %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
+msgstr "Die Zahl der zufälligen Kategorien muss kleiner sein, als die Zahl der Feature. Es gibt nur %d Feature des Typs: %s"
#: ../vector/v.extract/main.c:314
#, fuzzy, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count "
-"%d"
-msgstr ""
-"Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der "
-"eindeutigen \"%s\" Feature Kategorien %d."
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
+msgstr "Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der eindeutigen \"%s\" Feature Kategorien %d."
#: ../vector/v.extract/main.c:319
-msgid ""
-"There are more categories than random number generator can reach. Report "
-"this as a GRASS bug."
+msgid "There are more categories than random number generator can reach. Report this as a GRASS bug."
msgstr ""
#: ../vector/v.extract/main.c:350
@@ -19772,11 +18187,8 @@
msgstr "Punkt"
#: ../vector/v.in.db/main.c:57
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
-"Koordinaten beinhaltet."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die Koordinaten beinhaltet."
#: ../vector/v.in.db/main.c:61
msgid "Input table name"
@@ -19811,11 +18223,8 @@
#: ../vector/v.in.db/main.c:133
#, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr ""
-"Ausgabe-Vektorkarte, Tabelle <%s> (Treiber: <%s>, Datenbank: <%s>) existiert "
-"bereits."
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr "Ausgabe-Vektorkarte, Tabelle <%s> (Treiber: <%s>, Datenbank: <%s>) existiert bereits."
#: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:95
#: ../vector/v.db.connect/main.c:287
@@ -19858,22 +18267,12 @@
msgstr "Linie"
#: ../vector/v.net.iso/main.c:76
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
-msgstr ""
-"Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). "
-"Knotens gehen in die Berechnung ein."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
+msgstr "Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knotens gehen in die Berechnung ein."
#: ../vector/v.net.iso/main.c:114
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
-msgstr ""
-"Kategorie der Zentren (Punkte auf Knoten) denen das Netz zugeteilt wird. "
-"Layer für diese Kategorien wird mit der Option nlayer angegeben. "
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
+msgstr "Kategorie der Zentren (Punkte auf Knoten), denen das Netz zugeteilt wird. Layer für diese Kategorien wird mit der Option nlayer angegeben. "
#: ../vector/v.net.iso/main.c:123
msgid "Costs for isolines"
@@ -19896,8 +18295,7 @@
#: ../vector/v.net.iso/main.c:172
msgid "Not enough costs, everything reachable falls to first band"
-msgstr ""
-"Kosten sind nicht hoch genug. Alles in Reichweit fällt in das erste Band."
+msgstr "Kosten sind nicht hoch genug. Alles in Reichweit fällt in das erste Band."
#: ../vector/v.net.iso/main.c:206
msgid "Centre at closed node (costs = -1) ignored"
@@ -19910,8 +18308,7 @@
#: ../vector/v.net.iso/main.c:227
msgid "Not enough centres for selected nlayer. Nothing will be allocated."
-msgstr ""
#: ../vector/v.net.iso/main.c:247
#, c-format
@@ -19924,17 +18321,11 @@
#: ../vector/v.net.salesman/main.c:108
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Erzeugt einen Ring der die gegebenen Knoten verbindet (Handelsreisenden-"
-"Problem)."
+msgstr "Erzeugt einen Ring der die gegebenen Knoten verbindet (Handelsreisenden-Problem)."
#: ../vector/v.net.salesman/main.c:110
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
-msgstr ""
-"Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt "
-"ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgstr "Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
#: ../vector/v.net.salesman/main.c:128
msgid "Node layer (used for cities)"
@@ -19947,9 +18338,7 @@
#: ../vector/v.net.salesman/main.c:146
msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr ""
-"Kategorien der Punkte ('Städte') auf den Knoten (Layer wird mit nlayer "
-"bestimmt)."
+msgstr "Kategorien der Punkte ('Städte') auf den Knoten (Layer wird mit nlayer bestimmt)."
#: ../vector/v.net.salesman/main.c:220
#, c-format
@@ -19995,14 +18384,8 @@
#: ../vector/v.perturb/main.c:87
#, fuzzy
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
-msgstr ""
-"Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird "
-"nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind "
-"zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
#: ../vector/v.perturb/main.c:97
msgid "Minimum deviation in map units"
@@ -20050,22 +18433,13 @@
msgstr ""
#: ../vector/v.net.distance/main.c:64
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
-msgstr ""
-"Berechne die kürzeste Distanz zwischen einer Auswahl an Objekten über das "
-"Netzwerk."
+msgid "Computes shortest distance via the network between the given sets of features."
+msgstr "Berechne die kürzeste Distanz zwischen einer Auswahl an Objekten über das Netzwerk."
#: ../vector/v.net.distance/main.c:67
#, fuzzy
-msgid ""
-"Finds the shortest paths from a feature 'to' to every feature 'from' and "
-"various information about this relation are uploaded to the attribute table."
-msgstr ""
-"Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und "
-"zahlreiche Informationen über diese Beziehung wird in der Attributtabelle "
-"abgespeichert"
+msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this relation are uploaded to the attribute table."
+msgstr "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und zahlreiche Informationen über diese Beziehung wird in der Attributtabelle abgespeichert"
#: ../vector/v.net.distance/main.c:78 ../vector/v.net.distance/main.c:84
#: ../vector/v.net.distance/main.c:120 ../vector/v.net.distance/main.c:126
@@ -20107,8 +18481,7 @@
#: ../vector/v.net.distance/main.c:94
msgid "From WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"From WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "From WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.distance/main.c:99
msgid "To category values"
@@ -20123,8 +18496,7 @@
#: ../vector/v.net.distance/main.c:105
msgid "To WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Ziel-WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Ziel-WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.distance/main.c:112
msgid "To feature type"
@@ -20139,12 +18511,8 @@
msgstr "Kann keine Rechte für die Tabelle <%s> setzen."
#: ../vector/v.distance/main.c:122
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
-"Vektorkarte 'from'. "
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der Vektorkarte 'from'. "
#: ../vector/v.distance/main.c:126
msgid "Name of existing vector map (from)"
@@ -20174,9 +18542,7 @@
#: ../vector/v.distance/main.c:161
msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr ""
-"Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen "
-"Elementen."
+msgstr "Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen Elementen."
#: ../vector/v.distance/main.c:169
msgid "Maximum distance or -1 for no limit"
@@ -20188,37 +18554,15 @@
#: ../vector/v.distance/main.c:185
msgid "Values describing the relation between two nearest features"
-msgstr ""
-"Werte, die die Verbindung zwischen zwei nächstgelegenen Featuren "
-"beschreiben. "
+msgstr "Werte, die die Verbindung zwischen zwei nächstgelegenen Featuren beschreiben. "
#: ../vector/v.distance/main.c:187
-msgid ""
-"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
-"to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
-"the nearest point on 'to' feature;to_along;distance between points/centroids "
-"in 'from' map and the linear feature's start point in 'to' map, along this "
-"linear feature;to_angle;angle between the linear feature in 'to' map and the "
-"positive x axis, at the location of point/centroid in 'from' map, "
-"counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;"
-"attribute of nearest feature given by to_column option"
-msgstr ""
-"cat;Kategorie des nächsten Features;dist;Minimumdistanz zum nächsten Feature;"
-"to_x;X Koordinate des nächsten Features von 'to' Feature;to_y;Y Koordinate "
-"des nächsten Features von 'to' Feature;to_along;Distanz zwischen Punkten/"
-"Zentroiden der 'from' Karte und des Startpunktes des linearen Features der "
-"'to' Karte, entlang diese linearen Features;to_angle;Winkel zwischen dem "
-"linearen Feature der 'to' Karte und der positiven X-Achse, an der Position "
-"des Punktes/Zentroids der 'from' Karte, gegen den Uhrzeigersinn, im Bogenmaß "
-"(zwischen -PI und PI);to_attr;Attribut des nächsten Features gegeben durch "
-"die Option to_column"
+msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of the nearest point on 'to' feature;to_along;distance between points/centroids in 'from' map and the linear feature's start point in 'to' map, along this linear feature;to_angle;angle between the linear feature in 'to' map and the positive x axis, at the location of point/centroid in 'from' map, counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;attribute of nearest feature given by to_column option"
+msgstr "cat;Kategorie des nächsten Features;dist;Minimumdistanz zum nächsten Feature;to_x;X Koordinate des nächsten Features von 'to' Feature;to_y;Y Koordinate des nächsten Features von 'to' Feature;to_along;Distanz zwischen Punkten/Zentroiden der 'from' Karte und des Startpunktes des linearen Features der 'to' Karte, entlang diese linearen Features;to_angle;Winkel zwischen dem linearen Feature der 'to' Karte und der positiven X-Achse, an der Position des Punktes/Zentroids der 'from' Karte, gegen den Uhrzeigersinn, im Bogenmaß (zwischen -PI und PI);to_attr;Attribut des nächsten Features gegeben durch die Option to_column"
#: ../vector/v.distance/main.c:205
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
-msgstr ""
-"Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte "
-"gespeichert werden."
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
+msgstr "Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte gespeichert werden."
#: ../vector/v.distance/main.c:206
msgid "From_map"
@@ -20226,38 +18570,27 @@
#: ../vector/v.distance/main.c:211
msgid "Column name of nearest feature (used with upload=to_attr)"
-msgstr ""
-"Spaltenname der nächstgelegenen Feature (verwendet mit upload=to_attr)."
+msgstr "Spaltenname der nächstgelegenen Feature (verwendet mit upload=to_attr)."
#: ../vector/v.distance/main.c:217
msgid "Name of table created for output when the distance to all flag is used"
-msgstr ""
-"Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' "
-"gesetzt wurde."
+msgstr "Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' gesetzt wurde."
#: ../vector/v.distance/main.c:222
msgid "Print output to stdout, don't update attribute table"
-msgstr ""
-"Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
+msgstr "Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
#: ../vector/v.distance/main.c:224
msgid "First column is always category of 'from' feature called from_cat"
-msgstr ""
-"Die erste Spalte ist immer die Kategorie der 'from'-Feature und 'from_cat' "
-"benannt."
+msgstr "Die erste Spalte ist immer die Kategorie der 'from'-Feature und 'from_cat' benannt."
#: ../vector/v.distance/main.c:229
msgid "Calculate distances to all features within the threshold"
msgstr "Berechne Distanzen zu allen Features innerhalb des Schwellwertes."
#: ../vector/v.distance/main.c:230
-msgid ""
-"The output is written to stdout but may be uploaded to a new table created "
-"by this module. From categories are may be multiple."
-msgstr ""
-"Die Ausgabe wird nach stdout geschrieben und kann ebenfalls in eine neue "
-"Tabelle geschrieben werden, die von diesem Modul erzeugt wird. Es kann "
-"mehrere 'from' Kategorien geben."
+msgid "The output is written to stdout but may be uploaded to a new table created by this module. From categories are may be multiple."
+msgstr "Die Ausgabe wird nach stdout geschrieben und kann ebenfalls in eine neue Tabelle geschrieben werden, die von diesem Modul erzeugt wird. Es kann mehrere 'from' Kategorien geben."
#: ../vector/v.distance/main.c:288
msgid "to_column option missing"
@@ -20309,9 +18642,7 @@
#: ../vector/v.distance/main.c:1018
msgid "DATETIME type not yet supported, no attributes will be uploaded"
-msgstr ""
-"Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute "
-"geschrieben."
+msgstr "Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute geschrieben."
#: ../vector/v.distance/main.c:1274
#, c-format
@@ -20351,8 +18682,7 @@
#: ../vector/v.distance/main.c:1297
#, c-format
msgid "%d categories read from the map exist in the table"
-msgstr ""
-"%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
+msgstr "%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
#: ../vector/v.distance/main.c:1300
#, c-format
@@ -20397,7 +18727,7 @@
#: ../vector/v.in.sites/main.c:94
msgid "Failed to allocate site structure"
-msgstr "Belegen von Speicherplatz für die Site-Struktur fehlgeschlagen."
+msgstr "Reservieren von Speicher für Site-Struktur fehlgeschlagen."
#: ../vector/v.in.sites/main.c:96
#, c-format
@@ -20406,15 +18736,11 @@
#: ../vector/v.in.sites/main.c:100
msgid "Floating point category values, using sequential integer for category"
-msgstr ""
-"Fließkomma Kategoriewerte -> verwende einen fortlaufenden Integer für die "
-"Kategorien."
+msgstr "Fließkomma Kategoriewerte -> verwende einen fortlaufenden Integer für die Kategorien."
#: ../vector/v.in.sites/main.c:103
msgid "No category values, using sequential integer for category"
-msgstr ""
-"Keine Kategoriewerte -> verwende einen fortlaufenden Integer für die "
-"Kategorien."
+msgstr "Keine Kategoriewerte -> verwende einen fortlaufenden Integer für die Kategorien."
#: ../vector/v.in.sites/main.c:185
msgid "Transferring sites to vector point map..."
@@ -20455,9 +18781,7 @@
msgstr "Maximale z-Höhe (benötigt den Schalter '-z' oder Spaltenname)."
#: ../vector/v.random/main.c:121
-msgid ""
-"The seed to initialize the random generator. If not set the process id is "
-"used."
+msgid "The seed to initialize the random generator. If not set the process id is used."
msgstr ""
#: ../vector/v.random/main.c:124
@@ -20495,12 +18819,8 @@
msgstr "Tabelle sollte nur zwei Spalten haben."
#: ../vector/v.random/main.c:236
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
-msgstr ""
-"Sie haben nicht unterstützte Spaltentypen erzeugt. Dieses Modul unterstützt "
-"nur die Spaltentypen INTEGER und DOUBLE PRECISION."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
+msgstr "Sie haben nicht unterstützte Spaltentypen erzeugt. Dieses Modul unterstützt nur die Spaltentypen INTEGER und DOUBLE PRECISION."
#: ../vector/v.random/main.c:272
msgid "Generating points..."
@@ -20536,11 +18856,8 @@
msgstr "writeVTKHeader: Schreibe VTK-Header"
#: ../vector/v.out.vtk/writeVTK.c:186
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
-msgstr ""
-"Keine Koordinaten um Ausgabe zu erzeugen. Vielleicht wurde ein leerer Vektor-"
-"Typ ausgewählt."
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr "Keine Koordinaten um Ausgabe zu erzeugen. Vielleicht wurde ein leerer Vektor-Typ ausgewählt."
#: ../vector/v.out.ascii/main.c:47
msgid "ascii"
@@ -20549,8 +18866,7 @@
#: ../vector/v.out.ascii/main.c:49
#, fuzzy
msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr ""
-"Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
+msgstr "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
#: ../vector/v.out.ascii/main.c:56
#, fuzzy
@@ -20567,9 +18883,7 @@
#: ../vector/v.out.ascii/main.c:80
#, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Only points, lines can be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Only points, lines can be processed."
msgstr "Kann die Vektorkarte <%s> auf dem Topologischen Level %d nicht öffnen."
#: ../vector/v.out.ascii/main.c:115
@@ -20599,9 +18913,7 @@
#: ../vector/v.out.ascii/args.c:25
#, fuzzy
msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
-msgstr ""
-"Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der "
-"Schalter '-o' angegeben ist."
+msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
#: ../vector/v.out.ascii/args.c:27
#, fuzzy
@@ -20610,17 +18922,14 @@
#: ../vector/v.out.ascii/args.c:32
msgid "Name of attribute column(s) to be exported (point mode)"
-msgstr ""
-"Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
+msgstr "Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
#: ../vector/v.out.ascii/args.c:48 ../misc/m.transform/main.c:351
msgid "Output format"
msgstr "Ausgabeformat."
#: ../vector/v.out.ascii/args.c:49
-msgid ""
-"point;Simple point format (point per row);standard;GRASS ASCII vector format;"
-"wkt;OGC well-known text;"
+msgid "point;Simple point format (point per row);standard;GRASS ASCII vector format;wkt;OGC well-known text;"
msgstr ""
#: ../vector/v.out.ascii/args.c:54
@@ -20638,9 +18947,7 @@
#: ../vector/v.out.ascii/args.c:79
msgid "Only export points falling within current 3D region (points mode)"
-msgstr ""
-"Exportiere nur Punkte, die sich in der aktuellen 3D Region befinden (Punkt-"
-"Modus)."
+msgstr "Exportiere nur Punkte, die sich in der aktuellen 3D Region befinden (Punkt-Modus)."
#: ../vector/v.net.allpairs/main.c:60
msgid "Computes the shortest path between all pairs of nodes in the network."
@@ -20692,12 +18999,8 @@
#: ../vector/v.outlier/main.c:76 ../vector/v.surf.bspline/main.c:106
#: ../vector/v.lidar.edgedetection/main.c:82
#: ../vector/v.lidar.correction/main.c:77
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
-msgstr ""
-"Schätze die Punktedichte und Distanz der Eingabe-Vektorkarte innerhalb der "
-"aktuellen Region und beende mich."
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
+msgstr "Schätze die Punktedichte und Distanz der Eingabe-Vektorkarte innerhalb der aktuellen Region und beende mich."
#: ../vector/v.outlier/main.c:88
msgid "Name of output outlier vector map"
@@ -20747,9 +19050,7 @@
#: ../vector/v.lidar.correction/main.c:225
#, c-format
msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr ""
-"Keine Datenbankverbindung für Treiber <%s> definiert. Bitte db.connect "
-"benutzen"
+msgstr "Keine Datenbankverbindung für Treiber <%s> definiert. Bitte db.connect benutzen"
#: ../vector/v.outlier/main.c:170 ../vector/v.surf.bspline/main.c:236
#: ../vector/v.lidar.edgedetection/main.c:192
@@ -20793,9 +19094,7 @@
#: ../vector/v.outlier/main.c:419 ../vector/v.lidar.edgedetection/main.c:456
#: ../vector/v.lidar.correction/main.c:425
msgid "No data within this subregion. Consider changing the spline step."
-msgstr ""
-"Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
-"ändern."
+msgstr "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu ändern."
#: ../vector/v.outlier/main.c:429 ../vector/v.surf.bspline/main.c:890
#: ../vector/v.lidar.edgedetection/main.c:466
@@ -20846,9 +19145,7 @@
#: ../vector/v.label.sa/main.c:135 ../vector/v.label/main.c:200
msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr ""
-"Undurchsichtig für Vektoren (nur relevant, wenn eine Hintergrundfarbe "
-"ausgewählt wurde)."
+msgstr "Undurchsichtig für Vektoren (nur relevant, wenn eine Hintergrundfarbe ausgewählt wurde)."
#: ../vector/v.label.sa/main.c:154
msgid "Border width (only for ps.map output)"
@@ -20857,7 +19154,7 @@
#: ../vector/v.label.sa/labels.c:67
#, c-format
msgid "Cannot allocate %d bytes of memory"
-msgstr "Kann nicht %d Byte Speicher belegen."
+msgstr "Kann nicht %d Byte Speicher reservieren."
#: ../vector/v.label.sa/labels.c:74 ../vector/v.vol.rst/user1.c:95
#: ../vector/v.class/main.c:100 ../vector/v.label/main.c:273
@@ -20894,7 +19191,7 @@
#: ../vector/v.label.sa/labels.c:126
msgid "Cannot allocate more memory"
-msgstr "Kann nicht mehr Speicher belegen."
+msgstr "Kann nicht mehr Speicher reservieren."
#: ../vector/v.label.sa/labels.c:160 ../vector/v.overlay/main.c:302
#: ../vector/v.label/main.c:318
@@ -20957,8 +19254,7 @@
#: ../vector/v.in.dxf/main.c:95
#, fuzzy
msgid "Invert selection by DXF layers (don't import layers in list)"
-msgstr ""
-"Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
+msgstr "Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
#: ../vector/v.in.dxf/main.c:100
msgid "Import all objects into one layer"
@@ -21037,12 +19333,8 @@
#: ../vector/v.qcount/main.c:71
#, fuzzy
-msgid ""
-"Name for output quadrant centres map (number of points is written as "
-"category)"
-msgstr ""
-"Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie "
-"ausgegeben."
+msgid "Name for output quadrant centres map (number of points is written as category)"
+msgstr "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie ausgegeben."
#: ../vector/v.qcount/main.c:77
msgid "Number of quadrats"
@@ -21068,8 +19360,7 @@
#: ../vector/v.mkgrid/main.c:67
#, fuzzy
msgid "Creates a vector map of a user-defined grid."
-msgstr ""
-"Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
#: ../vector/v.mkgrid/main.c:78
msgid "Number of rows and columns in grid"
@@ -21141,12 +19432,8 @@
msgstr "Vektor, Transformation"
#: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit "
-"Punkten oder Zentroiden."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit Punkten oder Zentroiden."
#: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:97
msgid "Use only points in current region"
@@ -21154,9 +19441,7 @@
#: ../vector/v.delaunay/main.c:103
msgid "Output triangulation as a graph (lines), not areas"
-msgstr ""
-"Gebe das Ergebnis der Triangulation als Graph (Linien) und nicht als Flächen "
-"aus."
+msgstr "Gebe das Ergebnis der Triangulation als Graph (Linien) und nicht als Flächen aus."
#: ../vector/v.delaunay/main.c:146
msgid "no points to triangulate"
@@ -21184,7 +19469,7 @@
#: ../vector/v.delaunay/memory.c:124
msgid "All allocated edges have been used."
-msgstr "Alle allokierten Kanten wurden verwendet."
+msgstr "Alle gesammelten Kanten wurden verwendet."
#: ../vector/v.delaunay/in_out.c:93
msgid "Writing edges..."
@@ -21203,12 +19488,8 @@
msgstr ""
#: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte "
-"einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr "Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
#: ../vector/v.lrs/v.lrs.where/main.c:66
#: ../vector/v.lrs/v.lrs.create/main.c:128
@@ -21296,8 +19577,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:133
msgid "Output vector map where oriented lines are written"
-msgstr ""
-"Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
+msgstr "Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
#: ../vector/v.lrs/v.lrs.create/main.c:138
msgid "Output vector map of errors"
@@ -21317,28 +19597,19 @@
#: ../vector/v.lrs/v.lrs.create/main.c:173
msgid "Column containing milepost position for the beginning of next segment"
-msgstr ""
-"Spalte mit den Meilensteinpositionen, die den Beginn des nächsten Segmentes "
-"kennzeichnen."
+msgstr "Spalte mit den Meilensteinpositionen, die den Beginn des nächsten Segmentes kennzeichnen."
#: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
-msgstr ""
-"Spalte mit dem Versatz vom Meilenstein, um den Beginn des nächsten Segmentes "
-"zu kennzeichnen."
+msgid "Column containing offset from milepost for the beginning of next segment"
+msgstr "Spalte mit dem Versatz vom Meilenstein, um den Beginn des nächsten Segmentes zu kennzeichnen."
#: ../vector/v.lrs/v.lrs.create/main.c:191
msgid "Column containing milepost position for the end of previous segment"
-msgstr ""
-"Spalte mit den Meilensteinpositionen, die das Ende des vorherigen Segmentes "
-"kennzeichnen."
+msgstr "Spalte mit den Meilensteinpositionen, die das Ende des vorherigen Segmentes kennzeichnen."
#: ../vector/v.lrs/v.lrs.create/main.c:200
msgid "Column containing offset from milepost for the end of previous segment"
-msgstr ""
-"Spalte mit dem Versatz vom Meilenstein, um das Ende des vorherigen Segmentes "
-"zu kennzeichnen."
+msgstr "Spalte mit dem Versatz vom Meilenstein, um das Ende des vorherigen Segmentes zu kennzeichnen."
#: ../vector/v.lrs/v.lrs.create/main.c:223
msgid "Name of table where the reference system will be written"
@@ -21397,8 +19668,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:479
#, c-format
msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
-msgstr ""
-"Meilenstein (Start) %f+%f verwendet als %f+%f (ändere MP nach Integer)."
+msgstr "Meilenstein (Start) %f+%f verwendet als %f+%f (ändere MP nach Integer)."
#: ../vector/v.lrs/v.lrs.create/main.c:501
#, c-format
@@ -21432,21 +19702,17 @@
#: ../vector/v.lrs/v.lrs.create/main.c:750
#, c-format
msgid "Distance along line identical for points' cats [%d], [%d]"
-msgstr ""
-"Distanz entlang der Linie ist identisch für die Punkte der cats [%d], [%d]."
+msgstr "Distanz entlang der Linie ist identisch für die Punkte der cats [%d], [%d]."
#: ../vector/v.lrs/v.lrs.create/main.c:764
#, c-format
msgid "Not enough points (%d) attached to the line (cat %d), line skip."
-msgstr ""
-"Nicht genügend Punkte (%d) der Linie (cat %d) zugeordnet, überspringe die "
-"Linie."
+msgstr "Nicht genügend Punkte (%d) der Linie (cat %d) zugeordnet, überspringe die Linie."
#: ../vector/v.lrs/v.lrs.create/main.c:769
#, c-format
msgid "Unable to guess direction for the line (cat %d), line skip."
-msgstr ""
-"Kann die Richtung der Linie (cat %d) nicht erraten, überspringe die Linie."
+msgstr "Kann die Richtung der Linie (cat %d) nicht erraten, überspringe die Linie."
#: ../vector/v.lrs/v.lrs.create/main.c:773
#, c-format
@@ -21468,8 +19734,7 @@
#: ../vector/v.lrs/v.lrs.label/main.c:105
msgid "Create stationing from input lines, and linear reference system"
-msgstr ""
-"Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
+msgstr "Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
#: ../vector/v.lrs/v.lrs.label/main.c:113
msgid "Output vector map where stationing will be written"
@@ -21531,12 +19796,8 @@
msgstr "Mehr als ein Datensatz in der LR-Tabelle."
#: ../vector/v.lrs/v.lrs.segment/main.c:74
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des "
-"Linearenreferenzsystems und Positionen von stdin oder einer Datei."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des Linearenreferenzsystems und Positionen von stdin oder einer Datei."
#: ../vector/v.lrs/v.lrs.segment/main.c:82
msgid "Output vector map where segments will be written"
@@ -21544,9 +19805,7 @@
#: ../vector/v.lrs/v.lrs.segment/main.c:113
msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr ""
-"Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von "
-"stdin gelesen."
+msgstr "Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von stdin gelesen."
#: ../vector/v.lrs/v.lrs.segment/main.c:180
#: ../vector/v.lrs/v.lrs.segment/main.c:234
@@ -21576,8 +19835,7 @@
"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
"%s"
msgstr ""
-"Kann den Punkt auf der Linie nicht bekommen: cat = [%d] Distanz = [%f] "
-"(Linienlänge = %f)\n"
+"Kann den Punkt auf der Linie nicht bekommen: cat = [%d] Distanz = [%f] (Linienlänge = %f)\n"
"%s"
#: ../vector/v.lrs/v.lrs.segment/main.c:249
@@ -21604,8 +19862,7 @@
"Requested offset for the 1. point not found, using nearest found:\n"
" %s"
msgstr ""
-"Angeforderten Versatz für den 1. Punkt nicht gefunden, verwende den "
-"Nächsten:\n"
+"Angeforderten Versatz für den 1. Punkt nicht gefunden, verwende den Nächsten:\n"
" %s"
#: ../vector/v.lrs/v.lrs.segment/main.c:269
@@ -21623,8 +19880,7 @@
"Requested offset for the 2. point not found, using nearest found:\n"
" %s"
msgstr ""
-"Angeforderten Versatz für den 2. Punkt nicht gefunden, verwende den "
-"Nächsten:\n"
+"Angeforderten Versatz für den 2. Punkt nicht gefunden, verwende den Nächsten:\n"
" %s"
#: ../vector/v.lrs/v.lrs.segment/main.c:278
@@ -21651,8 +19907,7 @@
"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
"%s"
msgstr ""
-"Kann das Linien-Segment nicht erzeugen: cat = %d : %f - %f (Länge der Linie "
-"= %f)\n"
+"Kann das Linien-Segment nicht erzeugen: cat = %d : %f - %f (Länge der Linie = %f)\n"
"%s"
#: ../vector/v.lrs/v.lrs.segment/main.c:332 ../vector/v.segment/main.c:217
@@ -21681,23 +19936,16 @@
msgstr "Attribute"
#: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Ändert die Kategorien einer existierenden Vektorkarte entsprechend den "
-"Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Ändert die Kategorien einer existierenden Vektorkarte entsprechend den Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
#: ../vector/v.reclass/main.c:88
msgid "The name of the column whose values are to be used as new categories"
-msgstr ""
-"Name der Spalte, deren Werte als neue Kategorien verwendet werden sollen."
+msgstr "Name der Spalte, deren Werte als neue Kategorien verwendet werden sollen."
#: ../vector/v.reclass/main.c:89
msgid "The source for the new key column must be type integer or string"
-msgstr ""
-"Die Quelle für die neue Schlüsselspalte muss vom Typ integer oder string "
-"sein."
+msgstr "Die Quelle für die neue Schlüsselspalte muss vom Typ integer oder string sein."
#: ../vector/v.reclass/main.c:94
msgid "Full path to the reclass rule file"
@@ -21786,13 +20034,8 @@
msgstr "Vektor, Kerndichte"
#: ../vector/v.kernel/main.c:109
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
-msgstr ""
-"Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines "
-"gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem "
-"Vektornetzwerk erstellt werden."
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+msgstr "Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem Vektornetzwerk erstellt werden."
#: ../vector/v.kernel/main.c:113
msgid "Input vector with training points"
@@ -21831,45 +20074,28 @@
msgstr "Knoten Methode"
#: ../vector/v.kernel/main.c:169
-msgid ""
-"none;No method applied at nodes with more than 2 arcs;split;Equal split "
-"(Okabe 2009) applied at nodes;"
-msgstr ""
-"nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;"
-"Equal split (Okabe 2009) angewendet bei Knoten;"
+msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
+msgstr "nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;Equal split (Okabe 2009) angewendet bei Knoten;"
#: ../vector/v.kernel/main.c:176
msgid "Kernel function"
msgstr "Kernel Funktion"
#: ../vector/v.kernel/main.c:184
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Versuche eine optimale Standardabweichung mit 'stddeviation' als Maximum zu "
-"berechnen (experimentell)."
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Versuche eine optimale Standardabweichung mit 'stddeviation' als Maximum zu berechnen (experimentell)."
#: ../vector/v.kernel/main.c:189
msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Berechnet nur die optimale Standardabweichung und beendet sich (keine Karte "
-"wird geschrieben)."
+msgstr "Berechnet nur die optimale Standardabweichung und beendet sich (keine Karte wird geschrieben)."
#: ../vector/v.kernel/main.c:194
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
-"Im Netzwerk-Modus: normalisiere Werte durch die Summe der Dichte "
-"multipliziert mit der Länge der Segmente. Integral über die Ausgabekarte "
-"ergibt 1.0 * mult."
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
+msgstr "Im Netzwerk-Modus: normalisiere Werte durch die Summe der Dichte multipliziert mit der Länge der Segmente. Integral über die Ausgabekarte ergibt 1.0 * mult."
#: ../vector/v.kernel/main.c:199
msgid "In network mode, multiply the result by number of input points."
-msgstr ""
-"Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-"
-"Punkte."
+msgstr "Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-Punkte."
#: ../vector/v.kernel/main.c:216
msgid "Unknown node method"
@@ -21880,20 +20106,12 @@
msgstr "Unbekannte Kernelfunktion"
#: ../vector/v.kernel/main.c:240
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
-msgstr ""
-"Optimale Berechnung der Standardabweichung wird nur durch die Knoten-Methode "
-"'none' und die Kernelfunktion 'gaussian' unterstützt."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
+msgstr "Optimale Berechnung der Standardabweichung wird nur durch die Knoten-Methode 'none' und die Kernelfunktion 'gaussian' unterstützt."
#: ../vector/v.kernel/main.c:244
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
-msgstr ""
-"Optimale Berechnung der Standardabweichung wird nur durch die Kernel-"
-"Funktion 'gaussian' unterstützt."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
+msgstr "Optimale Berechnung der Standardabweichung wird nur durch die Kernel-Funktion 'gaussian' unterstützt."
#: ../vector/v.kernel/main.c:301
#, c-format
@@ -21902,12 +20120,8 @@
#: ../vector/v.kernel/main.c:323
#, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"Automatisches Auswählen der Glättungsparameter (Standardabweichung). Der "
-"Maximalwert der möglichen Werte der Standardabweichung ist auf %f gesetzt"
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "Automatisches Auswählen der Glättungsparameter (Standardabweichung). Der Maximalwert der möglichen Werte der Standardabweichung ist auf %f gesetzt"
#: ../vector/v.kernel/main.c:330
#, c-format
@@ -21926,12 +20140,8 @@
#: ../vector/v.kernel/main.c:348
#, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"Entfernungen zwischen allen Punkten liegt über %e (4 * Standardabweichung), "
-"daher kann kein optimaler Wert berechnet werden."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "Entfernungen zwischen allen Punkten liegt über %e (4 * Standardabweichung), daher kann kein optimaler Wert berechnet werden."
#: ../vector/v.kernel/main.c:359
#, c-format
@@ -21994,8 +20204,7 @@
#: ../vector/v.out.ogr/main.c:220
msgid "The combination of types is not supported by all formats."
-msgstr ""
-"Die Die Kombination von Typen wird nicht von allen Formaten unterstützt."
+msgstr "Die Die Kombination von Typen wird nicht von allen Formaten unterstützt."
#: ../vector/v.out.ogr/main.c:249
#, c-format
@@ -22003,135 +20212,83 @@
msgstr ""
#: ../vector/v.out.ogr/main.c:264
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
msgstr ""
#: ../vector/v.out.ogr/main.c:270
#, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Punkt(e) gefunden, die allerdings nicht zum Export angegeben wurden. "
-"Überprüfen Sie bitte den 'type'-Parameter."
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Punkt(e) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:275
#, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Linie(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Linie(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:281
#, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Grenzlinie(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Grenzlinie(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:287
#, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Zentroid(e) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Zentroid(e) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:292
#, fuzzy, c-format
-msgid ""
-"%d area(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "%d area(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:296
#, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d 3D-Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d 3D-Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:301
#, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Volumen gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Volumen gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:307
#, fuzzy
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d Punkt(e) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No points found, but requested to be exported. Will skip this feature type."
+msgstr "%d Punkt(e) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:316
#, fuzzy
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d Linie(n) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No lines found, but requested to be exported. Will skip this feature type."
+msgstr "%d Linie(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:326
#, fuzzy
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-"%d Grenzlinie(n) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
+msgstr "%d Grenzlinie(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:335
#, fuzzy
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No areas found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:345
#, fuzzy
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-"%d Zentroid(e) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
+msgstr "%d Zentroid(e) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:354
#, fuzzy
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
-msgstr ""
-"%d 3D-Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. "
+msgid "No faces found, but requested to be exported. Will skip this feature type."
+msgstr "%d 3D-Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
#: ../vector/v.out.ogr/main.c:363
#, fuzzy
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:372
#, fuzzy
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
-msgstr ""
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
#: ../vector/v.out.ogr/main.c:383
msgid "Nothing to export"
@@ -22144,9 +20301,7 @@
#: ../vector/v.out.ogr/main.c:407
#, c-format
-msgid ""
-"Append existing layer requires opening data source in update mode, forcing '-"
-"%c' flag"
+msgid "Append existing layer requires opening data source in update mode, forcing '-%c' flag"
msgstr ""
#: ../vector/v.out.ogr/main.c:425
@@ -22175,33 +20330,18 @@
#: ../vector/v.out.ogr/main.c:492
#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-msgstr ""
-"Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische "
-"Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) "
-"zu exportieren."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) zu exportieren."
#: ../vector/v.out.ogr/main.c:504
#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
-msgstr ""
-"zu exportieren."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
#: ../vector/v.out.ogr/main.c:511
#, fuzzy, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') to export in 3D rather than 2D (default)."
-msgstr ""
-"zu exportieren."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)."
#: ../vector/v.out.ogr/main.c:528 ../db/drivers/ogr/execute.c:58
#, fuzzy, c-format
@@ -22214,9 +20354,7 @@
#: ../vector/v.out.ogr/main.c:542
msgid "No attribute table found -> using only category numbers as attributes"
-msgstr ""
-"Keine Attributtabelle gefunden -> benutze nur Kategorienummern als "
-"Attributes."
+msgstr "Keine Attributtabelle gefunden -> benutze nur Kategorienummern als Attributes."
#: ../vector/v.out.ogr/main.c:546
msgid "Exporting 'cat' anyway, as it is the only attribute table field"
@@ -22287,11 +20425,8 @@
#: ../vector/v.out.ogr/args.c:17
#, fuzzy
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
-msgstr ""
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
#: ../vector/v.out.ogr/args.c:28
msgid "OGR output datasource name"
@@ -22299,13 +20434,11 @@
#: ../vector/v.out.ogr/args.c:30
msgid "For example: ESRI Shapefile: filename or directory for storage"
-msgstr ""
-"Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
+msgstr "Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
#: ../vector/v.out.ogr/args.c:37
msgid "OGR layer name. If not specified, input name is used."
-msgstr ""
-"Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
+msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
#: ../vector/v.out.ogr/args.c:39
msgid "For example: ESRI Shapefile: shapefile name"
@@ -22318,8 +20451,7 @@
#: ../vector/v.out.ogr/args.c:58
msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr ""
-"Optionen zum Erzeugen des OGR-Datensatzes (formatspezifisch, NAME=WERT)."
+msgstr "Optionen zum Erzeugen des OGR-Datensatzes (formatspezifisch, NAME=WERT)."
#: ../vector/v.out.ogr/args.c:68
msgid "OGR layer creation option (format specific, NAME=VALUE)"
@@ -22339,22 +20471,16 @@
#: ../vector/v.out.ogr/args.c:88
#, fuzzy
-msgid ""
-"Also export features without category (not labeled). Otherwise only features "
-"with category are exported."
-msgstr ""
-"Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden "
-"alle Objekte exportiert."
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
+msgstr "Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
#: ../vector/v.out.ogr/args.c:94
msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Verwende .prj-Dateiformat im ESRI-Stil (nur bei Ausgabe von Shapefiles)."
+msgstr "Verwende .prj-Dateiformat im ESRI-Stil (nur bei Ausgabe von Shapefiles)."
#: ../vector/v.out.ogr/args.c:100
msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
-"Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
+msgstr "Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
#: ../vector/v.out.ogr/args.c:106
msgid "Export lines as polygons"
@@ -22362,12 +20488,8 @@
#: ../vector/v.out.ogr/args.c:112
#, fuzzy
-msgid ""
-"Create a new empty OGR layer in defined OGR datasource and exit. Nothing is "
-"read from input."
-msgstr ""
-"Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird "
-"eingelesen."
+msgid "Create a new empty OGR layer in defined OGR datasource and exit. Nothing is read from input."
+msgstr "Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird eingelesen."
#: ../vector/v.out.ogr/attrb.c:41
#, c-format
@@ -22377,9 +20499,7 @@
#: ../vector/v.out.ogr/attrb.c:58
#, c-format
msgid "No database record for cat = %d and export of 'cat' disabled"
-msgstr ""
-"Kein Datenbankeintrag für cat = %d und der Export von 'cat' wurde "
-"deaktiviert."
+msgstr "Kein Datenbankeintrag für cat = %d und der Export von 'cat' wurde deaktiviert."
#: ../vector/v.out.ogr/create.c:20
#, fuzzy, c-format
@@ -22400,9 +20520,7 @@
#: ../vector/v.surf.rst/main.c:170
#, fuzzy
msgid "Use z coordinates for approximation (3D vector maps only)"
-msgstr ""
-"Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden "
-"sollen."
+msgstr "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden sollen."
#: ../vector/v.surf.bspline/main.c:119
msgid "Name of input vector map of sparse points"
@@ -22429,14 +20547,11 @@
#: ../vector/v.surf.bspline/main.c:185
#, fuzzy
msgid "Maximum memory to be used for raster output (in MB)"
-msgstr ""
-"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
#: ../vector/v.surf.bspline/main.c:197
msgid "Choose either vector or raster output, not both"
-msgstr ""
-"Wählen Sie entweder die Ausgabe im Raster- oder Vektor-Format, aber nicht "
-"beides."
+msgstr "Wählen Sie entweder die Ausgabe im Raster- oder Vektor-Format, aber nicht beides."
#: ../vector/v.surf.bspline/main.c:200
msgid "No raster or vector or cross-validation output"
@@ -22464,12 +20579,8 @@
#: ../vector/v.surf.bspline/main.c:314
#, c-format
-msgid ""
-"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
-"a raster output or other driver."
-msgstr ""
-"Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul "
-"erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
+msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
+msgstr "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
#: ../vector/v.surf.bspline/main.c:336
#, fuzzy, c-format
@@ -22493,9 +20604,7 @@
#: ../vector/v.surf.bspline/main.c:396
#, c-format
msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-msgstr ""
-"Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu "
-"erstellen."
+msgstr "Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu erstellen."
#: ../vector/v.surf.bspline/main.c:464
#, fuzzy
@@ -22510,9 +20619,7 @@
#: ../vector/v.surf.bspline/main.c:837
#, fuzzy
msgid "No data within this subregion. Consider increasing spline step values."
-msgstr ""
-"ändern."
#: ../vector/v.surf.bspline/crosscorr.c:72
#, c-format
@@ -22520,12 +20627,8 @@
msgstr "%d sind zu viele Punkte. Die Kreuzvalidierung würde zu lange dauern."
#: ../vector/v.surf.bspline/crosscorr.c:85
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
-msgstr ""
-"Vielleicht dauert es zu lange. Es hängt davon ab wieviel Punkte Sie erwägen "
-"zu verwenden."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
+msgstr "Vielleicht dauert es zu lange. Es hängt davon ab wieviel Punkte Sie erwägen zu verwenden."
#: ../vector/v.surf.bspline/crosscorr.c:114
#, c-format
@@ -22545,8 +20648,7 @@
#: ../vector/v.proj/main.c:66
msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Reprojiziert eine Vektorkarte von einer Location in die aktuelle Location."
+msgstr "Reprojiziert eine Vektorkarte von einer Location in die aktuelle Location."
#: ../vector/v.proj/main.c:78
msgid "Location containing input vector map"
@@ -22570,9 +20672,7 @@
#: ../vector/v.proj/main.c:113
msgid "Assume z co-ordinate is ellipsoidal height and transform if possible"
-msgstr ""
-"Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und "
-"transformiere, wenn möglich."
+msgstr "Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und transformiere, wenn möglich."
#: ../vector/v.proj/main.c:190
#, c-format
@@ -22612,9 +20712,7 @@
#: ../vector/v.hull/main.c:69
msgid "Create a 'flat' 2D hull even if the input is 3D points"
-msgstr ""
-"Erzeuge eine 'flache' 2D Hülle, selbst wenn die Eingabe aus 3D Punkten "
-"besteht."
+msgstr "Erzeuge eine 'flache' 2D Hülle, selbst wenn die Eingabe aus 3D Punkten besteht."
#: ../vector/v.hull/main.c:88
#, c-format
@@ -22649,8 +20747,7 @@
#: ../vector/v.in.dwg/main.c:102
msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
#: ../vector/v.in.dwg/main.c:106 ../vector/v.in.ascii/main.c:140
msgid "Create 3D vector map"
@@ -22699,12 +20796,8 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:245
-msgid ""
-"Interpolates point data to a RASTER3D grid volume using regularized spline "
-"with tension (RST) algorithm."
-msgstr ""
-"Interpoliert Punkte zu einem RASTER3D Grid Volumen unter Verwendung des "
-"regularized spline with tension (RST) Algorithmus."
+msgid "Interpolates point data to a RASTER3D grid volume using regularized spline with tension (RST) algorithm."
+msgstr "Interpoliert Punkte zu einem RASTER3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
#: ../vector/v.vol.rst/main.c:253
msgid "Name of the vector map with input x,y,z,w"
@@ -22760,8 +20853,7 @@
#: ../vector/v.vol.rst/main.c:351 ../vector/v.surf.rst/main.c:303
msgid "Minimum distance between points (to remove almost identical points)"
-msgstr ""
-"Minimale Distanz zwischen Punkten (um fast identische Punkte zu entfernen)"
+msgstr "Minimale Distanz zwischen Punkten (um fast identische Punkte zu entfernen)"
#: ../vector/v.vol.rst/main.c:360
msgid "Conversion factor for w-values used for interpolation"
@@ -22830,15 +20922,11 @@
#: ../vector/v.vol.rst/user1.c:109
msgid "Column type of wcolumn is not supported (must be integer or double)"
-msgstr ""
-"Spaltentyp der wcolumn wird nicht unterstützt (muss integer oder double sein)"
+msgstr "Spaltentyp der wcolumn wird nicht unterstützt (muss integer oder double sein)"
#: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
-msgstr ""
-"Spaltentyp der 'smooth'-Spalte wird nicht unterstützt (muss integer oder "
-"double sein)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
+msgstr "Spaltentyp der 'smooth'-Spalte wird nicht unterstützt (muss integer oder double sein)"
#: ../vector/v.external.out/link.c:44
#, fuzzy
@@ -22954,9 +21042,7 @@
#: ../vector/v.lidar.edgedetection/main.c:259
#, c-format
msgid "It was impossible to create <%s> interpolation table in database."
-msgstr ""
-"Es war nicht möglich die <%s> Interpolations-Tabelle in der Datenbank zu "
-"erstellen."
+msgstr "Es war nicht möglich die <%s> Interpolations-Tabelle in der Datenbank zu erstellen."
#: ../vector/v.lidar.edgedetection/main.c:392
msgid "Allocating memory for bilinear interpolation"
@@ -23074,19 +21160,12 @@
msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten."
#: ../vector/v.patch/main.c:81
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
-msgstr ""
-"Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten "
-"geschrieben werden"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
+msgstr "Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten geschrieben werden"
#: ../vector/v.patch/main.c:85
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
-msgstr ""
-"Hänge Dateien an eine existierende Datei an. Das Überschreiben von "
-"existierenden Dateien muss aktiviert sein"
+msgid "Append files to existing file (overwriting existing files must be activated)"
+msgstr "Hänge Dateien an eine existierende Datei an. Das Überschreiben von existierenden Dateien muss aktiviert sein"
#: ../vector/v.patch/main.c:90
msgid "Copy also attribute table"
@@ -23141,9 +21220,7 @@
#: ../vector/v.patch/main.c:329
#, c-format
msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-"Fehler beim Lesen der Vektorkarte <%s> - Einige Daten könnten nicht korrekt "
-"sein"
+msgstr "Fehler beim Lesen der Vektorkarte <%s> - Einige Daten könnten nicht korrekt sein"
#: ../vector/v.patch/main.c:372
#, c-format
@@ -23192,8 +21269,7 @@
#: ../vector/v.net.connectivity/main.c:57
msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-"Berechnet Vertex connectivity zwischen zwei Gruppen von Knoten im Netzwerk."
+msgstr "Berechnet Vertex connectivity zwischen zwei Gruppen von Knoten im Netzwerk."
#: ../vector/v.net.connectivity/main.c:97
msgid "Set1 category values"
@@ -23206,8 +21282,7 @@
#: ../vector/v.net.connectivity/main.c:103
msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Set1 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Set1 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.connectivity/main.c:108
msgid "Set2 category values"
@@ -23220,8 +21295,7 @@
#: ../vector/v.net.connectivity/main.c:114
msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Set2 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Set2 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.connectivity/main.c:148
#: ../vector/v.net.connectivity/main.c:153 ../vector/v.net.flow/main.c:198
@@ -23282,8 +21356,7 @@
#: ../vector/v.support/main.c:61
msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
-msgstr ""
-"Datum, an dem die Vektorkarte digitalisiert wurde (z.B., \"15 Mar 2007\")."
+msgstr "Datum, an dem die Vektorkarte digitalisiert wurde (z.B., \"15 Mar 2007\")."
#: ../vector/v.support/main.c:68
msgid "Person who created vector map"
@@ -23314,11 +21387,8 @@
msgstr "Text, der an den Kommentar Metadatendatei der Karte angehängt wird"
#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
-msgstr ""
-"Kommentarzeile die in der History-Datei der Vektorkarte gespeichert wird "
-"(verwendet für Vektor-Skripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
+msgstr "Kommentarzeile die in der History-Datei der Vektorkarte gespeichert wird (verwendet für Vektor-Skripts)"
#: ../vector/v.support/main.c:122
msgid "Replace comment instead of appending it"
@@ -23334,11 +21404,8 @@
msgstr ""
#: ../vector/v.select/main.c:49
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Selektiert Feature der Vektorkarte (A) durch Feature von eine anderen "
-"Vektorkarte (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Selektiert Feature der Vektorkarte (A) durch Feature von eine anderen Vektorkarte (B)."
#: ../vector/v.select/main.c:82
#, fuzzy, c-format
@@ -23388,38 +21455,16 @@
msgstr "Operator bestimmt das erforderte Verhältnis zwischen den Features"
#: ../vector/v.select/args.c:47
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
-msgstr ""
-"Ein Feature wird in die Ausgabe geschrieben, wenn das Ergebnis der Operation "
-"'ainput operator binput' wahr ist. Ein Eingabe-Feature wird als wahr "
-"aufgefasst, wenn die Kategorie des gegebenen Layers definiert ist."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
+msgstr "Ein Feature wird in die Ausgabe geschrieben, wenn das Ergebnis der Operation 'ainput operator binput' wahr ist. Ein Eingabe-Feature wird als wahr aufgefasst, wenn die Kategorie des gegebenen Layers definiert ist."
#: ../vector/v.select/args.c:52
msgid "overlap;features partially or completely overlap"
msgstr "Überlappung; Feature überlappen sich teilweise oder vollständig"
#: ../vector/v.select/args.c:57
-msgid ""
-"overlap;features partially or completely overlap;equals;features are "
-"spatially equals (using GEOS);disjoint;features do not spatially intersect "
-"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
-"features spatially touches (using GEOS);crosses;features spatially crosses "
-"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
-"contains;feature B is completely inside feature A (using GEOS);overlaps;"
-"features spatially overlap (using GEOS);relate;feature A is spatially "
-"related to feature B (using GEOS, requires 'relate' option);"
-msgstr ""
-"overlap;Objekte überlappen sich ganz oder teilweise;equals;Objekte sind im "
-"Raum gleich (mit GEOS);disjoint;Objekte überschneiden sich räumlich nicht "
-"(mit GEOS);intersects;Objekte überschneiden sich räumlich (mit GEOS);touches;"
-"Objekte berühren sich räumlich (mit GEOS);crosses;Objekte kreuzen sich "
-"räumlich (mit GEOS);within;Objekt A ist komplett innerhalb von Objekt B (mit "
-"GEOS);contains;Objekt B ist komplett innerhalb von Objekt A (mit GEOS);"
-"overlaps;Objekte überlappen sich räumlich (mit GEOS);relate;Objekt A besitzt "
-"einen räumlichen Bezug zu Objekt B (mit GEOS, Option 'relate' erforderlich);"
+msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
+msgstr "overlap;Objekte überlappen sich ganz oder teilweise;equals;Objekte sind im Raum gleich (mit GEOS);disjoint;Objekte überschneiden sich räumlich nicht (mit GEOS);intersects;Objekte überschneiden sich räumlich (mit GEOS);touches;Objekte berühren sich räumlich (mit GEOS);crosses;Objekte kreuzen sich räumlich (mit GEOS);within;Objekt A ist komplett innerhalb von Objekt B (mit GEOS);contains;Objekt B ist komplett innerhalb von Objekt A (mit GEOS);overlaps;Objekte überlappen sich räumlich (mit GEOS);relate;Objekt A besitzt einen räumlichen Bezug zu Objekt B (mit GEOS, Option 'relate' erforderlich);"
#: ../vector/v.select/args.c:74
msgid "Intersection Matrix Pattern used for 'relate' operator"
@@ -23462,12 +21507,8 @@
msgstr "Kann die Tabelle <%s> nicht kopieren."
#: ../vector/v.voronoi/main.c:121
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder "
-"Zentroiden."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
#: ../vector/v.voronoi/main.c:136
msgid "Output tessellation as a graph (lines), not areas"
@@ -23495,20 +21536,15 @@
#: ../vector/v.voronoi/main.c:410
msgid "Output needs topological cleaning"
-msgstr ""
+msgstr "Die Topologie der Ausgabe muss aufgeräumt werden."
#: ../vector/v.voronoi/main.c:442
-#, fuzzy
msgid "Removing incorrect boundaries from output"
-msgstr "Entferne alle Linien und Grenzen mit der Länge null"
+msgstr "Entferne unzulässige Linien aus der Ausgabe."
#: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-"Bestimmung des Gebäude Umriss und Anwendung des 'Region Growing' Verfahrens "
-"zu Ermittelung des Gebäude Inneren."
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr "Bestimmung des Gebäude Umriss und Anwendung des 'Region Growing' Verfahrens zu Ermittelung des Gebäude Inneren."
#: ../vector/v.lidar.growing/main.c:83
msgid "Input vector (v.lidar.edgedetection output"
@@ -23572,13 +21608,8 @@
msgstr "Erzeuge 'Steiner Tree' für das Netzwerk und die gegebenen Stationen"
#: ../vector/v.net.steiner/main.c:351
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
-msgstr ""
-"Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem "
-"Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis "
-"suboptimal sein."
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
+msgstr "Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis suboptimal sein."
#: ../vector/v.net.steiner/main.c:371
msgid "Node layer (used for terminals)"
@@ -23590,8 +21621,7 @@
#: ../vector/v.net.steiner/main.c:383
msgid "Categories of points on terminals (layer is specified by nlayer)"
-msgstr ""
-"Kategorien der Punkte auf den Stationen (Layer wird mit nlayer angegebn)"
+msgstr "Kategorien der Punkte auf den Stationen (Layer wird mit nlayer angegebn)"
#: ../vector/v.net.steiner/main.c:391
msgid "Number of steiner points (-1 for all possible)"
@@ -23608,17 +21638,12 @@
#: ../vector/v.net.steiner/main.c:513
#, c-format
msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
-msgstr ""
-"Station am Knoten [%d] kann nicht mit der Station am Knoten [%d] verbunden "
-"werden"
+msgstr "Station am Knoten [%d] kann nicht mit der Station am Knoten [%d] verbunden werden"
#: ../vector/v.net.steiner/main.c:529
#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
-msgstr ""
-"[%d] (nicht erreichbare) Knoten wurden aus der Liste der Steiner-"
-"Punktkandidaten entfernt"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgstr "[%d] (nicht erreichbare) Knoten wurden aus der Liste der Steiner-Punktkandidaten entfernt"
#: ../vector/v.net.steiner/main.c:534
#, c-format
@@ -23633,9 +21658,7 @@
#: ../vector/v.net.steiner/main.c:561
#, c-format
msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr ""
-"Steiner-Punkt am Knoten [%d] wurde zu den Stationen hinzugefügt (MST Kosten "
-"= %f)."
+msgstr "Steiner-Punkt am Knoten [%d] wurde zu den Stationen hinzugefügt (MST Kosten = %f)."
#: ../vector/v.net.steiner/main.c:573
msgid "No Steiner point found -> leaving cycle"
@@ -23662,9 +21685,7 @@
#: ../vector/v.what/main.c:141
#, fuzzy, c-format
msgid "Number of given vector maps (%d) differs from number of layers (%d)"
-msgstr ""
-"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
-"Spalten (%d) in der Eingabe überein."
+msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
#: ../vector/v.what/main.c:150
#, c-format
@@ -23819,12 +21840,8 @@
msgstr "Lese Koordinaten aus Datei."
#: ../vector/v.transform/main.c:85
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Führt eine affine Transformation (schieben, skalieren und rotieren oder "
-"GPCs) von Vektorkarten durch."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
#: ../vector/v.transform/main.c:90
msgid "Shift all z values to bottom=0"
@@ -23851,12 +21868,8 @@
msgstr "ASCII-Datei mit den Transformationskoordinaten"
#: ../vector/v.transform/main.c:113
-msgid ""
-"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
-"yscale, zscale, zrot) are used instead"
-msgstr ""
-"Wenn nicht gegeben, verwende verwende stattdessen Transformationsparameter "
-"(xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
+msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
+msgstr "Wenn nicht gegeben, verwende verwende stattdessen Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
#: ../vector/v.transform/main.c:121
msgid "Shifting value for x coordinates"
@@ -23901,17 +21914,11 @@
#: ../vector/v.transform/main.c:201
#, c-format
msgid "Table name is not defined. Please use '%s' parameter."
-msgstr ""
-"Der Name der Tabelle wurde nicht angegeben. Bitte verwenden Sie den "
-"Parameter '%s'."
+msgstr "Der Name der Tabelle wurde nicht angegeben. Bitte verwenden Sie den Parameter '%s'."
#: ../vector/v.transform/main.c:206
-msgid ""
-"Name of table and name for output vector map must be different. Otherwise "
-"the table is overwritten."
-msgstr ""
-"Name der Tabelle und Name der Ausgabe-Vektorkarte müssenunterschiedlich "
-"sein. Sonst wird die Tabelle überschrieben."
+msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
+msgstr "Name der Tabelle und Name der Ausgabe-Vektorkarte müssenunterschiedlich sein. Sonst wird die Tabelle überschrieben."
#: ../vector/v.transform/main.c:220
#, c-format
@@ -23957,13 +21964,8 @@
#: ../vector/v.transform/trans_digit.c:106
#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
-msgstr ""
-"Kann den Wert der Kategorie %d aus der Tabelle <%s>, Spalte <%s> nicht "
-"selektieren. Verwende für die Kategorie %d den "
-"Standardtransformationsparameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
+msgstr "Kann den Wert der Kategorie %d aus der Tabelle <%s>, Spalte <%s> nicht selektieren. Verwende für die Kategorie %d den Standardtransformationsparameter %.3f."
#: ../vector/v.transform/trans_digit.c:117
msgid "No category number defined. Using default transformation parameters."
@@ -24007,31 +22009,15 @@
#: ../vector/v.overlay/main.c:96
msgid "Operator defines features written to output vector map"
-msgstr ""
-"Operator bestimmt, welche Feature in die Ausgabe-Vektorkarte geschrieben "
-"werden."
+msgstr "Operator bestimmt, welche Feature in die Ausgabe-Vektorkarte geschrieben werden."
#: ../vector/v.overlay/main.c:99
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-msgstr ""
-"Ein Feature wird in die Ausgabekarte geschrieben, wenn das Ergebnis der "
-"Operation 'ainput operator binput' wahr ist. Ein Eingabe-Feature wird als "
-"wahr erachtet, wenn die Kategorie des gegebenen Layers definiert ist."
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
+msgstr "Ein Feature wird in die Ausgabekarte geschrieben, wenn das Ergebnis der Operation 'ainput operator binput' wahr ist. Ein Eingabe-Feature wird als wahr erachtet, wenn die Kategorie des gegebenen Layers definiert ist."
#: ../vector/v.overlay/main.c:104
-msgid ""
-"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-"(only for atype=area);not;features from ainput not overlayed by features "
-"from binput;xor;features from either ainput or binput but not those from "
-"ainput overlayed by binput (only for atype=area)"
-msgstr ""
-"and;auch als 'intersection' im GIS bekannt;or;auch als 'union' im GIS "
-"bekannt (nur für atype=area);not;Feature von ainput nicht überlagert von "
-"Featuren von binput;xor;Feature von ainput oder binput, aber nicht solche "
-"von ainput die von binput überlagert werden(nur für atype=area)"
+msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
+msgstr "and;auch als 'intersection' im GIS bekannt;or;auch als 'union' im GIS bekannt (nur für atype=area);not;Feature von ainput nicht überlagert von Featuren von binput;xor;Feature von ainput oder binput, aber nicht solche von ainput die von binput überlagert werden(nur für atype=area)"
#: ../vector/v.overlay/main.c:117
msgid "Output layer for new category, ainput and binput"
@@ -24124,14 +22110,8 @@
msgstr "Kann Daten der Tabelle nicht selektieren."
#: ../vector/v.class/main.c:161
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
-msgstr ""
-"Der Diskontinuitätsalgorithmus weist daraufhin, dass einige Klassengrenzen "
-"nicht statistisch signifikant (alpha = 0.05) sind. Es wird Ihnen geraten, "
-"die Anzahl der Klassen zu reduzieren."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
+msgstr "Der Diskontinuitätsalgorithmus weist daraufhin, dass einige Klassengrenzen nicht statistisch signifikant (alpha = 0.05) sind. Es wird Ihnen geraten, die Anzahl der Klassen zu reduzieren."
#: ../vector/v.class/main.c:190
#, c-format
@@ -24176,13 +22156,8 @@
msgstr "Kategorienummer-Modus"
#: ../vector/v.build.polylines/main.c:126
-msgid ""
-"no;Do not assign any category number to polyline;first;Assign category "
-"number of first line to polyline;multi;Assign multiple category numbers to "
-"polyline"
-msgstr ""
-"no;Weise Polyline keine Kategorie zu;first;Weise der Polyline die Kategorie "
-"der ersten Linie zu;multi;Weise der Polylinie mehrere Kategorien zu"
+msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
+msgstr "no;Weise Polyline keine Kategorie zu;first;Weise der Polyline die Kategorie der ersten Linie zu;multi;Weise der Polylinie mehrere Kategorien zu"
#: ../vector/v.build.polylines/main.c:217
#, c-format
@@ -24231,9 +22206,7 @@
#: ../vector/v.convert/old2new.c:89
#, c-format
msgid "Failed to attach an attribute (category %d) to a line."
-msgstr ""
-"Das Anfügen von einem Attribut (Kategorie %d) an eine Linie ist "
-"fehlgeschlagen."
+msgstr "Das Anfügen von einem Attribut (Kategorie %d) an eine Linie ist fehlgeschlagen."
#: ../vector/v.convert/old2new.c:94
#, c-format
@@ -24256,8 +22229,7 @@
#: ../vector/v.convert/att.c:37
msgid "No category labels (dig_cats) found, no table created"
-msgstr ""
-"Keine Kategoriebeschriftungen (dig_cats) gefunden; keine Tabelle erstellt."
+msgstr "Keine Kategoriebeschriftungen (dig_cats) gefunden; keine Tabelle erstellt."
#: ../vector/v.convert/att.c:42
msgid "Unable to open dig_cats file"
@@ -24285,13 +22257,8 @@
msgstr "Eingabedatei ist portabel."
#: ../vector/v.convert/read.c:99
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
-msgstr ""
-"Eingabedatei ist nicht portabel. Wir versuchen sie trotzdem zu konvertieren; "
-"dies kann aber schiefgehen. Bitte lesen Sie die Hilfeseiten für weitere "
-"Informationen."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
+msgstr "Eingabedatei ist nicht portabel. Wir versuchen sie trotzdem zu konvertieren; dies kann aber schiefgehen. Bitte lesen Sie die Hilfeseiten für weitere Informationen."
#: ../vector/v.convert/read.c:185
#, c-format
@@ -24316,8 +22283,7 @@
#: ../vector/v.convert/read.c:192
#, c-format
msgid "[%d] area boundaries read and written to output"
-msgstr ""
-"[%d] Grenzen (boundaries) wurden gelesen und in die Ausgabe geschrieben"
+msgstr "[%d] Grenzen (boundaries) wurden gelesen und in die Ausgabe geschrieben"
#: ../vector/v.convert/read.c:193
#, c-format
@@ -24431,9 +22397,7 @@
msgstr "Gebe Rasterhistorie anstelle der Info aus."
#: ../vector/v.in.lidar/main.c:218
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector file."
msgstr ""
#: ../vector/v.in.lidar/main.c:279
@@ -24477,8 +22441,7 @@
#: ../vector/v.net.flow/main.c:62
msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr ""
-"Berechnet den maximalen Fluss zwischen zwei Auswahlen von Knoten im Netzwerk."
+msgstr "Berechnet den maximalen Fluss zwischen zwei Auswahlen von Knoten im Netzwerk."
#: ../vector/v.net.flow/main.c:84
msgid "Name for output vector map containing a minimum cut"
@@ -24490,8 +22453,7 @@
#: ../vector/v.net.flow/main.c:113
msgid "Source WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Source WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Source WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.flow/main.c:118
msgid "Sink category values"
@@ -24503,8 +22465,7 @@
#: ../vector/v.net.flow/main.c:124
msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Sink WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Sink WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
#: ../vector/v.net.flow/main.c:211
msgid "No sources"
@@ -24548,8 +22509,7 @@
"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
"%s"
msgstr ""
-"Kann den Punkt auf der Linie nicht bekommen: cat = %d offset = %f (Länge der "
-"Linie = %.15g)\n"
+"Kann den Punkt auf der Linie nicht bekommen: cat = %d offset = %f (Länge der Linie = %.15g)\n"
"%s"
#: ../vector/v.segment/main.c:189
@@ -24562,8 +22522,7 @@
"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
"%s"
msgstr ""
-"Kann das Liniensegment nicht machen: cat = %d : %f - %f (Länge der Linie = "
-"%.15g)\n"
+"Kann das Liniensegment nicht machen: cat = %d : %f - %f (Länge der Linie = %.15g)\n"
"%s"
#: ../vector/v.segment/main.c:224
@@ -24729,32 +22688,20 @@
msgstr "Findet den kürzesten Weg in einem Vektor-Netzwerk."
#: ../vector/v.net.path/main.c:66
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
-"Name der Datei mit Start- und Endpunkten. Falls nicht angegeben, wird von "
-"stdin gelesen."
+msgid "Name of file containing start and end points. If not given, read from stdin"
+msgstr "Name der Datei mit Start- und Endpunkten. Falls nicht angegeben, wird von stdin gelesen."
#: ../vector/v.net.path/main.c:93
msgid "Maximum distance to the network"
msgstr "Maximale Distanz zum Netzwerk."
#: ../vector/v.net.path/main.c:94
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
-msgstr ""
-"Wenn der Start-/Endpunkt als Koordinaten angegeben wurden. Wenn der Start-/"
-"Endpunkt außerhalb des Schwellwertes sind, wird der kürzeste Weg nicht "
-"gefunden und eine Fehlermeldung ausgegeben. Um die Verarbeitung zu "
-"beschleunigen, wählen Sie den Wert so gering wie möglich."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
+msgstr "Wenn der Start-/Endpunkt als Koordinaten angegeben wurden. Wenn der Start-/Endpunkt außerhalb des Schwellwertes sind, wird der kürzeste Weg nicht gefunden und eine Fehlermeldung ausgegeben. Um die Verarbeitung zu beschleunigen, wählen Sie den Wert so gering wie möglich."
#: ../vector/v.net.path/main.c:107
msgid "Write output as original input segments, not each path as one line."
-msgstr ""
-"Schreibe die Ausgabe in Form der originalen Eingabesegmente und nicht jeden "
-"Weg als eine Linie."
+msgstr "Schreibe die Ausgabe in Form der originalen Eingabesegmente und nicht jeden Weg als eine Linie."
#: ../vector/v.net.path/path.c:82
#, c-format
@@ -24769,9 +22716,7 @@
#: ../vector/v.net.path/path.c:209
#, c-format
msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-"Punkt mit der Kategorie [%d] ist nicht erreichbar von dem Punkt mit der "
-"Kategorie [%d]."
+msgstr "Punkt mit der Kategorie [%d] ist nicht erreichbar von dem Punkt mit der Kategorie [%d]."
#: ../vector/v.net.path/path.c:266
#, c-format
@@ -24791,9 +22736,7 @@
#: ../vector/v.net.path/path.c:335
#, c-format
msgid "%d destination(s) unreachable (including points out of threshold)"
-msgstr ""
-"%d Ziele sind unerreichbar (inklusive der Punkte außerhalb des "
-"Schwellwertes)."
+msgstr "%d Ziele sind unerreichbar (inklusive der Punkte außerhalb des Schwellwertes)."
#: ../vector/v.univar/main.c:66
#, fuzzy
@@ -24802,24 +22745,16 @@
#: ../vector/v.univar/main.c:67
#, fuzzy
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
-msgstr ""
-"Berechnet univariate Statistiken für die Attribute. Die Varianz und "
-"Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+msgid "Variance and standard deviation is calculated only for points if specified."
+msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
#: ../vector/v.univar/main.c:122
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-"Inkompatible Vektortypen angeben. Es kann nur die Anzahl der Feature, das "
-"Minimum, das Maximum und die Spanne berechnet werden."
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr "Inkompatible Vektortypen angeben. Es kann nur die Anzahl der Feature, das Minimum, das Maximum und die Spanne berechnet werden."
#: ../vector/v.univar/main.c:127
msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-"Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
+msgstr "Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
#: ../vector/v.univar/main.c:134
#, fuzzy, c-format
@@ -24876,9 +22811,7 @@
msgstr "Spaltennamen oder Ausdruck"
#: ../vector/v.vect.stats/main.c:189
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not "
-"existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
msgstr ""
#: ../vector/v.vect.stats/main.c:196
@@ -24887,30 +22820,23 @@
#: ../vector/v.vect.stats/main.c:198
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
msgstr ""
#: ../vector/v.vect.stats/main.c:208
#, fuzzy
msgid "Print output to stdout, do not update attribute table"
-msgstr ""
-"Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
+msgstr "Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
#: ../vector/v.vect.stats/main.c:209
#, fuzzy
msgid "First column is always area category"
-msgstr ""
-"Die erste Spalte ist immer die Kategorie der 'from'-Feature und 'from_cat' "
-"benannt."
+msgstr "Die erste Spalte ist immer die Kategorie der 'from'-Feature und 'from_cat' benannt."
#: ../vector/v.vect.stats/main.c:263
#, c-format
msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr ""
-"Vektorkarte <%s> ist nicht im Mapset des Benutzers und kann nicht "
-"aktualisiert werden."
+msgstr "Vektorkarte <%s> ist nicht im Mapset des Benutzers und kann nicht aktualisiert werden."
#: ../vector/v.vect.stats/main.c:310 ../vector/v.vect.stats/main.c:386
#, fuzzy, c-format
@@ -25035,8 +22961,7 @@
#: ../vector/v.label/main.c:137
msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Zwischenraum zwischen den Buchstaben für gewellte Label (in Karteneinheiten)."
+msgstr "Zwischenraum zwischen den Buchstaben für gewellte Label (in Karteneinheiten)."
#: ../vector/v.label/main.c:144
msgid "Label size (in points)"
@@ -25051,11 +22976,8 @@
msgstr "Breite der Grenze"
#: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"Größen- und Abstandsoptionen differieren signifikant, was zu einer komischen "
-"Ausgabe führen kann."
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "Größen- und Abstandsoptionen differieren signifikant, was zu einer komischen Ausgabe führen kann."
#: ../vector/v.label/main.c:259
msgid "Too many parameters for <reference>"
@@ -25080,20 +23002,12 @@
msgstr "Quelle der Rasterwerte"
#: ../vector/v.to.rast/main.c:64
-msgid ""
-"attr;read values from attribute table;cat;use category values;val;use value "
-"specified by value option;z;use z coordinate (points or contours only);dir;"
-"output as flow direction (lines only)"
-msgstr ""
-"attr;Lese Werte aus der Attributtabelle;cat;Verwende Kategoriewerte;val;"
-"Verwende Werte angegeben durch die Option 'value';z;Verwende die Z-"
-"Koordinate (nur Punkte oder Konturen);dir;Ausgabe als Flussrichtung (nur "
-"Linien)"
+msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
+msgstr "attr;Lese Werte aus der Attributtabelle;cat;Verwende Kategoriewerte;val;Verwende Werte angegeben durch die Option 'value';z;Verwende die Z-Koordinate (nur Punkte oder Konturen);dir;Ausgabe als Flussrichtung (nur Linien)"
#: ../vector/v.to.rast/main.c:73
msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr ""
-"Name der Spalte für den Parameter 'attr' (Datentyp muss numerisch sein)."
+msgstr "Name der Spalte für den Parameter 'attr' (Datentyp muss numerisch sein)."
#: ../vector/v.to.rast/main.c:79
msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -25113,21 +23027,15 @@
#: ../vector/v.to.rast/main.c:119
msgid "Column parameter cannot be combined with use of category values option"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung des Kategoriewertes "
-"kombiniert werden."
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung des Kategoriewertes kombiniert werden."
#: ../vector/v.to.rast/main.c:124
msgid "Column parameter cannot be combined with use of value option"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung der Wert-Option kombiniert "
-"werden."
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung der Wert-Option kombiniert werden."
#: ../vector/v.to.rast/main.c:129
msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung von Z-Koordinaten "
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung von Z-Koordinaten kombiniert werden."
#: ../vector/v.to.rast/main.c:135
#, c-format
@@ -25141,8 +23049,7 @@
#: ../vector/v.to.rast/do_lines.c:125
#, c-format
msgid "%d lines with varying height were not written to raster"
-msgstr ""
-"%d Linien mit wechselnden Höhen wurden nicht in das Raster geschrieben."
+msgstr "%d Linien mit wechselnden Höhen wurden nicht in das Raster geschrieben."
#: ../vector/v.to.rast/vect2rast.c:35
msgid "Loading data..."
@@ -25191,14 +23098,12 @@
#: ../vector/v.to.rast/vect2rast.c:157
#, c-format
msgid "Problem processing areas from vector map <%s>, continuing..."
-msgstr ""
-"Probleme beim Verarbeiten der Flächen der Vektorkarte <%s>, mache weiter..."
+msgstr "Probleme beim Verarbeiten der Flächen der Vektorkarte <%s>, mache weiter..."
#: ../vector/v.to.rast/vect2rast.c:168
#, c-format
msgid "Problem processing lines from vector map <%s>, continuing..."
-msgstr ""
-"Probleme beim Verarbeiten der Linien der Vektorkarte <%s>, mache weiter..."
+msgstr "Probleme beim Verarbeiten der Linien der Vektorkarte <%s>, mache weiter..."
#: ../vector/v.to.rast/vect2rast.c:192
msgid "Creating support files for raster map..."
@@ -25230,8 +23135,7 @@
#: ../vector/v.to.rast/support.c:173
#, c-format
msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-"Fehler in der Spalte mit den Farbwerten (%s),mit cat %d: Farbstring [%s]."
+msgstr "Fehler in der Spalte mit den Farbwerten (%s),mit cat %d: Farbstring [%s]."
#: ../vector/v.to.rast/support.c:176
msgid "Color set to [200:200:200]"
@@ -25244,9 +23148,7 @@
#: ../vector/v.to.rast/support.c:306
msgid "Label column was not specified, no labels will be written"
-msgstr ""
-"Spalte mit Beschriftungen wurde nicht angegeben. Es werden keine "
-"Beschriftungen ausgegeben."
+msgstr "Spalte mit Beschriftungen wurde nicht angegeben. Es werden keine Beschriftungen ausgegeben."
#: ../vector/v.to.rast/support.c:349
#, c-format
@@ -25275,9 +23177,7 @@
#: ../vector/v.to.points/main.c:175
#, fuzzy
msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr ""
-"Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
-"Layern."
+msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
#: ../vector/v.to.points/main.c:178
#, fuzzy
@@ -25340,8 +23240,7 @@
#: ../vector/v.in.ascii/main.c:51
#, fuzzy
msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr ""
-"Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
+msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
#: ../vector/v.in.ascii/main.c:55
#, fuzzy
@@ -25363,21 +23262,15 @@
#: ../vector/v.in.ascii/main.c:82
msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-"Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden "
-"soll (Punktmodus)."
+msgstr "Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden soll (Punktmodus)."
#: ../vector/v.in.ascii/main.c:91
msgid "Column definition in SQL style (points mode)"
msgstr "Spaltendefinition im SQL-Stil (Punkt-Modus)."
#: ../vector/v.in.ascii/main.c:92
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
-msgstr ""
-"Zum Beispiel: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
+msgstr "Zum Beispiel: 'x double precision, y double precision, cat int, name varchar(10)'"
#: ../vector/v.in.ascii/main.c:104 ../vector/v.in.ascii/main.c:114
msgid "First column is 1"
@@ -25393,26 +23286,19 @@
#: ../vector/v.in.ascii/main.c:124
msgid "First column is 1. If 0, z coordinate is not used"
-msgstr ""
-"Erste Spalte ist 1. Wenn 0, dann wird die Z-Koordinate nicht verwendet."
+msgstr "Erste Spalte ist 1. Wenn 0, dann wird die Z-Koordinate nicht verwendet."
#: ../vector/v.in.ascii/main.c:134
msgid "Number of column used as category (points mode)"
msgstr "Nummer der Spalte, die als Kategorie genutzt wird (Punkt-Modus)."
#: ../vector/v.in.ascii/main.c:136
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
-msgstr ""
-"Erste Spalte ist 1. Wenn 0, dann wird jeder Zeile eine eindeutige Kategorie "
-"zugeweisen und in die neue Spalte 'cat' geschrieben."
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "Erste Spalte ist 1. Wenn 0, dann wird jeder Zeile eine eindeutige Kategorie zugeweisen und in die neue Spalte 'cat' geschrieben."
#: ../vector/v.in.ascii/main.c:145
msgid "Create a new empty vector map and exit. Nothing is read from input."
-msgstr ""
-"eingelesen."
#: ../vector/v.in.ascii/main.c:150
msgid "Don't expect a header when reading in standard format"
@@ -25424,14 +23310,11 @@
#: ../vector/v.in.ascii/main.c:166
msgid "Only import points falling within current region (points mode)"
-msgstr ""
-"Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
+msgstr "Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
#: ../vector/v.in.ascii/main.c:180
msgid "Please specify reasonable number of lines to skip"
-msgstr ""
-"Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden "
-"sollen."
+msgstr "Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden sollen."
#: ../vector/v.in.ascii/main.c:183
msgid "Please specify z column"
@@ -25482,15 +23365,13 @@
"(falsches Trennzeichen?)"
#: ../vector/v.in.ascii/main.c:270
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
msgstr ""
"Z-Spaltennummer > letzte Spaltennummer\n"
#: ../vector/v.in.ascii/main.c:275
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
msgstr "cat-Spaltennummer > letzte Spaltennummer (falsches Trennzeichen?)"
#: ../vector/v.in.ascii/main.c:281
@@ -25515,73 +23396,56 @@
#: ../vector/v.in.ascii/main.c:416
#, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr ""
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
#: ../vector/v.in.ascii/main.c:444
#, c-format
msgid "Column number %d <%s> defined as double has only integer values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als double definiert und hat nur Integer-Werte."
+msgstr "Spalte Nummer %d <%s> ist als double definiert und hat nur Integer-Werte."
#: ../vector/v.in.ascii/main.c:449
#, c-format
msgid "Column number %d <%s> defined as string has only integer values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als string definiert und hat nur Integer-Werte."
+msgstr "Spalte Nummer %d <%s> ist als string definiert und hat nur Integer-Werte."
#: ../vector/v.in.ascii/main.c:457
#, c-format
msgid "Column number %d <%s> defined as integer has double values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als integer definiert und hat nur Double-Werte."
+msgstr "Spalte Nummer %d <%s> ist als integer definiert und hat nur Double-Werte."
#: ../vector/v.in.ascii/main.c:462
#, c-format
msgid "Column number %d <%s> defined as string has double values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als string definiert und hat nur Double-Werte."
+msgstr "Spalte Nummer %d <%s> ist als string definiert und hat nur Double-Werte."
#: ../vector/v.in.ascii/main.c:470
#, c-format
msgid "Column number %d <%s> defined as integer has string values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als integer definiert und hat nur String-Werte."
+msgstr "Spalte Nummer %d <%s> ist als integer definiert und hat nur String-Werte."
#: ../vector/v.in.ascii/main.c:476
#, c-format
msgid "Column number %d <%s> defined as double has string values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als double definiert und hat nur String-Werte."
+msgstr "Spalte Nummer %d <%s> ist als double definiert und hat nur String-Werte."
#: ../vector/v.in.ascii/main.c:482
#, c-format
msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-"Länge der Spalte %d <%s> (%d) ist geringer als die maximale Länge der Werte "
-"(%d)."
+msgstr "Länge der Spalte %d <%s> (%d) ist geringer als die maximale Länge der Werte (%d)."
#: ../vector/v.in.ascii/main.c:522
msgid "Populating table..."
msgstr "Fülle Tabelle..."
#: ../vector/v.in.ascii/main.c:528
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
-msgstr ""
-"Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat nicht alle "
-"Attribute akzeptiert."
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
+msgstr "Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat nicht alle Attribute akzeptiert."
#: ../vector/v.external/main.c:52
#, fuzzy
msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr ""
-"Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu "
-"einem OGR-Layer."
+msgstr "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu einem OGR-Layer."
#: ../vector/v.external/main.c:102
#, fuzzy, c-format
@@ -25639,8 +23503,7 @@
#: ../vector/v.external/args.c:53
#, fuzzy
-msgid ""
-"List available OGR layers including feature types in datatsource and exit"
+msgid "List available OGR layers including feature types in datatsource and exit"
msgstr "Zeigt die vorhandenen Layer in der Datenquelle und beendet sich."
#: ../vector/v.external/list.c:13
@@ -25679,9 +23542,7 @@
msgstr ""
#: ../vector/v.clean/main.c:90
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
msgstr ""
#: ../vector/v.clean/main.c:92
@@ -25689,9 +23550,7 @@
msgstr ""
#: ../vector/v.clean/main.c:93
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
msgstr ""
#: ../vector/v.clean/main.c:95
@@ -25705,13 +23564,7 @@
msgstr "Entferne doppelte Zentroide"
#: ../vector/v.clean/main.c:97
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different;prune;remove vertices "
-"in threshold from lines and boundaries, boundary is pruned only if topology "
-"is not damaged (new intersection, changed attachement of centroid), first "
-"and last segment of the boundary is never changed"
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed"
msgstr ""
#: ../vector/v.clean/main.c:104
@@ -25731,9 +23584,7 @@
#: ../vector/v.clean/main.c:114
#, fuzzy
msgid "Threshold in map units, one value for each tool"
-msgstr ""
-"Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: "
-"0.0[,0.0,...])."
+msgstr "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: 0.0[,0.0,...])."
#: ../vector/v.clean/main.c:115
msgid "Default: 0.0[,0.0,...])"
@@ -25896,19 +23747,15 @@
#: ../vector/v.clean/prune.c:215
#, fuzzy, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
msgstr ""
"\n"
-"%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z."
-"B. %.2f %%"
+"%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z.B. %.2f %%"
#: ../vector/v.clean/prune.c:219
#, c-format
msgid "%d boundaries not pruned because pruning would damage topology"
-msgstr ""
-"%d Grenzen wurden nicht geputzt, weil das Putzen die Topologie beschädigt "
-"hätte."
+msgstr "%d Grenzen wurden nicht geputzt, weil das Putzen die Topologie beschädigt hätte."
#: ../vector/v.clean/rmline.c:64
#, c-format
@@ -25916,12 +23763,8 @@
msgstr "Linien / Grenzen entfernt: %d"
#: ../vector/v.surf.idw/main.c:90
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
-"Squared Weighting."
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance Squared Weighting."
#: ../vector/v.surf.idw/main.c:99
#, fuzzy
@@ -25937,12 +23780,8 @@
msgstr "Indiziere die Punkte nicht mittels der Rasterzellen."
#: ../vector/v.surf.idw/main.c:116
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-"Langsamer, aber braucht weniger Speicher und integriert auch Punkte "
-"außerhalb der Region in die Interpolation."
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr "Langsamer, aber braucht weniger Speicher und integriert auch Punkte außerhalb der Region in die Interpolation."
#: ../vector/v.surf.idw/main.c:131
#, fuzzy
@@ -25984,12 +23823,8 @@
msgstr "Seite"
#: ../vector/v.parallel/main.c:91
-msgid ""
-"left;Parallel line is on the left;right;Parallel line is on the right;both;"
-"Parallel lines on both sides"
-msgstr ""
-"left;Parallele Linie ist links;right;Parallele Linie ist rechts;both;"
-"Parallele Linien auf beiden Seiten"
+msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
+msgstr "left;Parallele Linie ist links;right;Parallele Linie ist rechts;both;Parallele Linien auf beiden Seiten"
#: ../vector/v.parallel/main.c:101
msgid "Tolerance of arc polylines in map units"
@@ -26006,9 +23841,7 @@
#: ../vector/v.buffer/main.c:214
#, fuzzy
msgid "Creates a buffer around vector features of given type."
-msgstr ""
-"Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen "
-"Zentroide enthalten)."
+msgstr "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
#: ../vector/v.buffer/main.c:233
msgid "Buffer distance along major axis in map units"
@@ -26033,12 +23866,8 @@
msgstr "Skalierfaktor für die Werte der Attributspalte"
#: ../vector/v.buffer/main.c:272
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
-msgstr ""
-"Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als "
-"Vielfaches des Buffers"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
+msgstr "Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als Vielfaches des Buffers"
#: ../vector/v.buffer/main.c:277
msgid "Make outside corners straight"
@@ -26050,20 +23879,11 @@
#: ../vector/v.buffer/main.c:292
msgid "Select a buffer distance/minordistance/angle or column, but not both."
-msgstr ""
-"Wählen Sie entweder die Buffer distance/minordistance/angle oder eine "
-"Spalte, aber nicht beides"
+msgstr "Wählen Sie entweder die Buffer distance/minordistance/angle oder eine Spalte, aber nicht beides"
#: ../vector/v.buffer/main.c:296
-msgid ""
-"The bufcol option may contain bugs during the cleaning step. If you "
-"encounter problems, use the debug option or clean manually with v.clean "
-"tool=break; v.category step=0; v.extract -d type=area"
-msgstr ""
-"Die Option 'bufcol' kann Fehler enthalten während des Säuberungsschrittes. "
-"Wenn Sie auf Probleme stoßen, verwenden Sie die die Option 'debug' oder "
-"säubern Sie manuell mit v.clean tool=break; v.category step=0; v.extract -d "
-"type=area."
+msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
+msgstr "Die Option 'bufcol' kann Fehler enthalten während des Säuberungsschrittes. Wenn Sie auf Probleme stoßen, verwenden Sie die die Option 'debug' oder säubern Sie manuell mit v.clean tool=break; v.category step=0; v.extract -d type=area."
#: ../vector/v.buffer/main.c:307
msgid "The bufcol option requires a valid layer."
@@ -26089,12 +23909,8 @@
msgstr "Kann keine Daten der Tabelle <%s> selektieren"
#: ../vector/v.buffer/main.c:422
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
-msgstr ""
-"Keine Objekte zum Buffern vorhanden. Überprüfen Sie die Option type und die "
-"Objekte in der Eingabe-Vektorkarte."
+msgid "No features available for buffering. Check type option and features available in the input vector."
+msgstr "Keine Objekte zum Buffern vorhanden. Überprüfen Sie die Option type und die Objekte in der Eingabe-Vektorkarte."
#: ../vector/v.buffer/main.c:437
msgid "Buffering lines..."
@@ -26149,12 +23965,8 @@
msgstr "Einstellungen"
#: ../vector/v.edit/main.c:58
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern "
-"ausgewählter Vektor Feature."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern ausgewählter Vektor Feature."
#: ../vector/v.edit/main.c:67
#, c-format
@@ -26168,12 +23980,8 @@
#: ../vector/v.edit/main.c:145
#, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
-msgstr ""
-"Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu "
-"editierende Karte ausgewählte wurde."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+msgstr "Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu editierende Karte ausgewählte wurde."
#: ../vector/v.edit/main.c:156
#, c-format
@@ -26194,13 +24002,8 @@
#: ../vector/v.edit/main.c:219
#, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
-msgstr ""
-"Die Vektorkarte <%s> ist nicht 3D. Das Werkzeug '%s' benötigt eine 3D-"
-"Vektorkarte. Bitte konvertieren Sie die Vektorkarte nach 3D z.B. mit Hilfe "
-"von %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
+msgstr "Die Vektorkarte <%s> ist nicht 3D. Das Werkzeug '%s' benötigt eine 3D-Vektorkarte. Bitte konvertieren Sie die Vektorkarte nach 3D z.B. mit Hilfe von %s."
#: ../vector/v.edit/main.c:255
#, c-format
@@ -26266,12 +24069,8 @@
#: ../vector/v.edit/main.c:345
#, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
-msgstr ""
-"Mehrere Hintergrundkarten wurden angegeben. Selektierte Feature werden nur "
-"von der Vektorkarte <%s> kopiert."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
+msgstr "Mehrere Hintergrundkarten wurden angegeben. Selektierte Feature werden nur von der Vektorkarte <%s> kopiert."
#: ../vector/v.edit/main.c:355
#, c-format
@@ -26310,35 +24109,8 @@
msgstr "Werkzeug"
#: ../vector/v.edit/args.c:35
-msgid ""
-"create;Create new (empty) vector map;add;Add new features to existing vector "
-"map;delete;Delete selected features from vector map;move;Move selected "
-"features in vector map;vertexmove;Move vertex of selected vector lines;"
-"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
-"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
-"vector lines;select;Select lines and print their ID's;catadd;Set new "
-"categories to selected vector features for defined layer;catdel;Delete "
-"categories from selected vector features for defined layer;copy;Copy "
-"selected features;snap;Snap vector features in given threshold;flip;Flip "
-"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
-"labeling (automated assignment of z coordinate to vector lines);chtype;"
-"Change feature type (point<->centroid, line<->boundary)"
-msgstr ""
-"create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Feature zu einer "
-"existierenden Vektorkarte hinzu;delete;Entfernt selektierte Feature von "
-"einer Vektorkarte;move;Verschiebt selektierte Feature in einer Vektorkarte;"
-"vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;vertexdel;"
-"Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;Fügt einen "
-"neuen Vertex zu selektierten Vektorlinien hinzu;merge;Vereinigt selektierte "
-"Vektorlinien;break;Teilt Vektorlinien;select;Selektiert Linien und gibt ihre "
-"ID aus;catadd;Vergiebt neue Kategorien für selektierte Vektorfeature eines "
-"bestimmten Layers;catdel;Löscht Kategorien von selektierten Vektorfeatures "
-"eines bestimmten Layers;copy;Kopiert selektierte Feature;snap;Snap "
-"Vektorfeature innerhalb des angegebenen Schwellwertes;flip;Drehe die "
-"Richtung selektierter Vektorlinien um;connect;Verbinde zwei Linien;zbulk;Z-"
-"Massen-Beschriftung (automatisierte Zuweisung der Z Koordinate zu "
-"Vektorlinien);chtype;Ändere den Typ des Features(Punkt<->Zentroid, Linie<-"
-">Grenze)"
+msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
+msgstr "create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Feature zu einer existierenden Vektorkarte hinzu;delete;Entfernt selektierte Feature von einer Vektorkarte;move;Verschiebt selektierte Feature in einer Vektorkarte;vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;vertexdel;Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;Fügt einen neuen Vertex zu selektierten Vektorlinien hinzu;merge;Vereinigt selektierte Vektorlinien;break;Teilt Vektorlinien;select;Selektiert Linien und gibt ihre ID aus;catadd;Vergiebt neue Kategorien für selektierte Vektorfeature eines bestimmten Layers;catdel;Löscht Kategorien von selektierten Vektorfeatures eines bestimmten Layers;copy;Kopiert selektierte Feature;snap;Snap Vektorfeature innerhalb des angegebenen Schwellwertes;flip;Drehe die Richtung selektierter Vektorlinien um;connect;Verbinde zwei Linien;zbulk;Z-Massen-Beschriftung (automatisierte Zuweisung der Z Koordinate zu Vektorlinien);chtype;Ändere den Typ
des Features(Punkt<->Zentroid, Linie<->Grenze)"
#: ../vector/v.edit/args.c:80
#, fuzzy
@@ -26353,8 +24125,7 @@
#: ../vector/v.edit/args.c:92
#, fuzzy
msgid "Difference in x,y,z direction for moving feature or vertex"
-msgstr ""
-"Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
+msgstr "Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
#: ../vector/v.edit/args.c:99
msgid "Threshold distance (coords,snap,query)"
@@ -26362,8 +24133,7 @@
#: ../vector/v.edit/args.c:101
msgid "'-1' for threshold based on the current resolution settings"
-msgstr ""
-"'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
+msgstr "'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
#: ../vector/v.edit/args.c:117
msgid "List of point coordinates"
@@ -26383,38 +24153,23 @@
#: ../vector/v.edit/args.c:147
msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
-msgstr ""
-"Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte "
-"für 'Längere'."
+msgstr "Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte für 'Längere'."
#: ../vector/v.edit/args.c:150
-msgid ""
-"length;Select only lines or boundaries shorter/longer than threshold "
-"distance;dangle;Select dangles shorter/longer than threshold distance"
-msgstr ""
-"length; Selektiere nur Linien oder Grenzen kürzer/länger als der "
-"Schwellwert; dangle; Selektiere Überstände (dangles) kürzer/länger als der "
-"Schwellwert"
+msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
+msgstr "length; Selektiere nur Linien oder Grenzen kürzer/länger als der Schwellwert; dangle; Selektiere Überstände (dangles) kürzer/länger als der Schwellwert"
#: ../vector/v.edit/args.c:158
msgid "Name of background vector map(s)"
msgstr "Name der Hintergrund-Vektorkarte(n)."
#: ../vector/v.edit/args.c:165
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
-msgstr ""
-"Snap hinzugefügte oder veränderte Features innerhalb des angegebenen "
-"Schwellwertes auf das nächste existierende Feature."
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
+msgstr "Snap hinzugefügte oder veränderte Features innerhalb des angegebenen Schwellwertes auf das nächste existierende Feature."
#: ../vector/v.edit/args.c:167
-msgid ""
-"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
-"vertex"
-msgstr ""
-"no; Kein Snapping; node; Snap nur auf Nodes; vertex; Erlaube auch ein Snap "
-"auf Vertices"
+msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
+msgstr "no; Kein Snapping; node; Snap nur auf Nodes; vertex; Erlaube auch ein Snap auf Vertices"
#: ../vector/v.edit/args.c:175
msgid "Starting value and step for z bulk-labeling"
@@ -26426,8 +24181,7 @@
#: ../vector/v.edit/args.c:187
msgid "Close added boundaries (using threshold distance)"
-msgstr ""
-"Schließe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
+msgstr "Schließe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
#: ../vector/v.edit/args.c:191
msgid "Do not expect header of input data"
@@ -26508,11 +24262,8 @@
#: ../vector/v.info/parse.c:30
#, fuzzy
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
-msgstr ""
-"Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
+msgid "Print types/names of table columns for specified layer instead of info and exit"
+msgstr "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
#: ../vector/v.info/parse.c:35
#, fuzzy
@@ -26532,9 +24283,7 @@
#: ../vector/v.info/print.c:130
#, c-format
msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-"
-"Datei."
+msgstr "Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-Datei."
#: ../vector/v.info/print.c:134
#, fuzzy, c-format
@@ -26762,8 +24511,7 @@
#: ../vector/v.category/main.c:74
#, fuzzy
msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr ""
-"Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
#: ../vector/v.category/main.c:86
msgid "Feature ids (by default all features are processed)"
@@ -26775,20 +24523,8 @@
#: ../vector/v.category/main.c:99
#, fuzzy
-msgid ""
-"add;add a new category;del;delete category (-1 to delete all categories of "
-"given layer);chlayer;change layer number (e.g. layer=3,1 changes layer 3 to "
-"layer 1);sum;add the value specified by cat option to the current category "
-"value;report;print report (statistics), in shell style: layer type count min "
-"max;print;print category values, more cats in the same layer are separated "
-"by '/'"
-msgstr ""
-"add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines "
-"gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert von "
-"Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option 'cat' "
-"zu dem aktuellen Kategoriewert;report;Gebe einen Bericht (Statistiken ) im "
-"Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, "
-"mehere cats im selben Layer werden durch '/' getrennt"
+msgid "add;add a new category;del;delete category (-1 to delete all categories of given layer);chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
+msgstr "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert von Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option 'cat' zu dem aktuellen Kategoriewert;report;Gebe einen Bericht (Statistiken ) im Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, mehere cats im selben Layer werden durch '/' getrennt"
#: ../vector/v.category/main.c:115
#: ../locale/scriptstrings/v.centroids_to_translate.c:7
@@ -26804,19 +24540,12 @@
msgstr "Format: Layer Typ Anzahl Min Max"
#: ../vector/v.category/main.c:138
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
-msgstr ""
-"Die Datenbankverbindung und die Attributtabellen der betroffenen Layer "
-"werden nicht geändert."
+msgid "Database connection and attribute tables for concerned layers are not changed"
+msgstr "Die Datenbankverbindung und die Attributtabellen der betroffenen Layer werden nicht geändert."
#: ../vector/v.category/main.c:156
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
-msgstr ""
-"Ungültige Kategorie (muss größer oder gleich 0 sein). Normalerweise beginnen "
-"die Kategorien bei 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
+msgstr "Ungültige Kategorie (muss größer oder gleich 0 sein). Normalerweise beginnen die Kategorien bei 1."
#: ../vector/v.category/main.c:165
#, c-format
@@ -26900,15 +24629,8 @@
msgstr "%d Feature verändert."
#: ../vector/v.surf.rst/main.c:147
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Räumliche Approximation und topographische Analyse auf Basis gegebener "
-"Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten "
-"Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-"
-"Rasterkarte geschrieben."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Räumliche Approximation und topographische Analyse auf Basis gegebener Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-Rasterkarte geschrieben."
#: ../vector/v.surf.rst/main.c:154
msgid "Perform cross-validation procedure without raster approximation"
@@ -26921,9 +24643,7 @@
#: ../vector/v.surf.rst/main.c:183
#, fuzzy
msgid "Name of the attribute column with values to be used for approximation"
-msgstr ""
-"Name der Attributspalte mit Werten, die für die Approximation verwendet "
-"werden (wen der Layer >0)."
+msgstr "Name der Attributspalte mit Werten, die für die Approximation verwendet werden (wen der Layer >0)."
#: ../vector/v.surf.rst/main.c:192
#, fuzzy
@@ -26965,17 +24685,12 @@
msgstr "Name der Attributspalte mit Glättungsparametern (smoothing)."
#: ../vector/v.surf.rst/main.c:311
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
-"Maximale Distanz zwischen den Punkten auf einer Isolinie (zum Einfügen "
-"weiterer Punkte)."
+msgid "Maximum distance between points on isoline (to insert additional points)"
+msgstr "Maximale Distanz zwischen den Punkten auf einer Isolinie (zum Einfügen weiterer Punkte)."
#: ../vector/v.surf.rst/main.c:320
msgid "Conversion factor for values used for approximation"
-msgstr ""
-"Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden "
-"sollen."
+msgstr "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden sollen."
#: ../vector/v.surf.rst/main.c:328
msgid "Anisotropy angle (in degrees counterclockwise from East)"
@@ -26989,30 +24704,19 @@
#: ../vector/v.surf.rst/main.c:419
msgid "You are not outputting any raster or vector maps"
-msgstr ""
-"Sie haben weder die Ausgabe von Vektor- noch von Rasterkarten veranlasst."
+msgstr "Sie haben weder die Ausgabe von Vektor- noch von Rasterkarten veranlasst."
#: ../vector/v.surf.rst/main.c:428
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-"Beide Kreuzvalidierungsoptionen (Schalter '-c' und die 'cvdev'-Vektorkarte) "
-"müssen angegeben werden."
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr "Beide Kreuzvalidierungsoptionen (Schalter '-c' und die 'cvdev'-Vektorkarte) müssen angegeben werden."
#: ../vector/v.surf.rst/main.c:431
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
-msgstr ""
-"Die Kreuzvalidierung kann nicht gleichzeitig mit Ausgabe-Rasterkarten oder "
-"der 'devi'-Datei berechnet werden."
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr "Die Kreuzvalidierung kann nicht gleichzeitig mit Ausgabe-Rasterkarten oder der 'devi'-Datei berechnet werden."
#: ../vector/v.surf.rst/main.c:449
msgid "Using anisotropy - both theta and scalex have to be specified"
-msgstr ""
-"Benutze Anisotropie - beide Parameter theta und scalex müssen angegeben "
-"werden."
+msgstr "Benutze Anisotropie - beide Parameter theta und scalex müssen angegeben werden."
#: ../vector/v.surf.rst/main.c:457
msgid "Both smatt and smooth options specified - using constant"
@@ -27020,8 +24724,7 @@
#: ../vector/v.surf.rst/main.c:467
msgid "The computation will last too long - lower npmin is suggested"
-msgstr ""
-"Die Berechnung dauert zu lange - es wird vorgeschlagen, npmin zu reduzieren."
+msgstr "Die Berechnung dauert zu lange - es wird vorgeschlagen, npmin zu reduzieren."
#: ../vector/v.surf.rst/main.c:485
msgid "Not enough memory for az"
@@ -27065,9 +24768,7 @@
#: ../vector/v.surf.rst/main.c:648
#, fuzzy, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for "
-"temp files"
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
msgstr ""
"Bearbeite alle ausgewählten Ausgabedateien.\n"
"Werde %d Byte Plattenspeicher für temp-Dateien benötigen."
@@ -27084,8 +24785,7 @@
#: ../vector/v.surf.rst/main.c:692
#, fuzzy
msgid "Unable to write raster maps - try to increase resolution"
-msgstr ""
-"Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
+msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
#: ../vector/v.mapcalc/number.c:159
msgid "Can't call bad num-function"
@@ -27154,17 +24854,12 @@
msgstr "Keine Funktion definiert, um \"Karte %c Karte\" auszuführen."
#: ../vector/v.lidar.correction/main.c:71
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
-msgstr ""
-"Korrektur der v.lidar.growing Ausgabe. Das ist der letzte von 3 Algorithmen "
-"um LIDAR zu filtern."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr "Korrektur der v.lidar.growing Ausgabe. Das ist der letzte von 3 Algorithmen um LIDAR zu filtern."
#: ../vector/v.lidar.correction/main.c:81
msgid "Input observation vector map name (v.lidar.growing output)"
-msgstr ""
-"Eingabeüberwachung des Vektorkarten-Namens (Ausgabe von v.lidar.growing)"
+msgstr "Eingabeüberwachung des Vektorkarten-Namens (Ausgabe von v.lidar.growing)"
#: ../vector/v.lidar.correction/main.c:84
msgid "Output classified vector map name"
@@ -27223,12 +24918,8 @@
msgstr "Berechne Zentralitätsmaße..."
#: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-"Berechnet Degree, Centrality, Betweeness, Closeness and Eigenvektor "
-"centrality Werte im Netzwerk."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr "Berechnet Degree, Centrality, Betweeness, Closeness and Eigenvektor centrality Werte im Netzwerk."
#: ../vector/v.net.centrality/main.c:148
msgid "Name of degree centrality column"
@@ -27253,8 +24944,7 @@
#: ../vector/v.net.centrality/main.c:175
msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr ""
-"Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
+msgstr "Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
#: ../vector/v.net.centrality/main.c:183
msgid "Cummulative error tolerance for eigenvector centrality"
@@ -27278,15 +24968,12 @@
#: ../vector/v.db.connect/main.c:55
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer "
-"Attributtabelle."
+msgstr "Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer Attributtabelle."
#: ../vector/v.db.connect/main.c:77
#, fuzzy
msgid "Format: layer number[/layer name]"
-msgstr ""
-"Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
+msgstr "Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
#: ../vector/v.db.connect/main.c:81
msgid "Field separator for shell script style output"
@@ -27299,19 +24986,15 @@
#: ../vector/v.db.connect/main.c:91
#, fuzzy
msgid "Print all map connection parameters in shell script style and exit"
-msgstr ""
-"Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
+msgstr "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
#: ../vector/v.db.connect/main.c:93
msgid "Format: layer[/layer name] table key database driver"
-msgstr ""
#: ../vector/v.db.connect/main.c:99
msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und "
-"beendet sich. "
+msgstr "Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und beendet sich. "
#: ../vector/v.db.connect/main.c:106
msgid "Overwrite connection parameter for certain layer"
@@ -27341,26 +25024,18 @@
#: ../vector/v.db.connect/main.c:195
#, fuzzy, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-"Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der "
-"Schlüsselspalte <%s>\n"
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr "Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der Schlüsselspalte <%s>\n"
#: ../vector/v.db.connect/main.c:201
#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
#: ../vector/v.db.connect/main.c:264
#, c-format
msgid "Use -o to overwrite existing link for layer <%d>"
-msgstr ""
-"Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu "
-"überschreiben."
+msgstr "Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu überschreiben."
#: ../vector/v.db.connect/main.c:272 ../vector/v.db.connect/main.c:312
#, c-format
@@ -27369,12 +25044,8 @@
#: ../vector/v.db.connect/main.c:300 ../vector/v.db.connect/main.c:318
#, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS "
-"Modulen gelöscht und überschrieben werden."
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS Modulen gelöscht und überschrieben werden."
#: ../vector/v.db.connect/main.c:339
#, c-format
@@ -27386,12 +25057,8 @@
msgstr "Select-Privilegien wurden für die Tabelle gewährt."
#: ../vector/v.db.connect/main.c:349
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Um eine neue Verbindung zu definieren müssen Sie die folgenden Parameter "
-"angeben: Treiber, Datenbank, Tabelle [, Schlüsselspalte [, Layer]]."
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Um eine neue Verbindung zu definieren müssen Sie die folgenden Parameter angeben: Treiber, Datenbank, Tabelle [, Schlüsselspalte [, Layer]]."
#: ../vector/v.out.pov/main.c:49
msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
@@ -27416,9 +25083,7 @@
msgstr "Verschiebewert für Z-Koordinate."
#: ../vector/v.out.pov/main.c:76
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', '*10"
-"+100', '*exaggeration'"
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
msgstr ""
#: ../vector/v.out.pov/main.c:84
@@ -27463,9 +25128,7 @@
#: ../vector/v.drape/main.c:146
msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
-"Höheninformationen."
+msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
#: ../vector/v.drape/main.c:157
msgid "Elevation raster map for height extraction"
@@ -27485,9 +25148,7 @@
#: ../vector/v.drape/main.c:186
msgid "Will set Z to this value, if value from raster map can not be read"
-msgstr ""
-"Werde Z auf diesen Wert setzen, wenn der Wert der Rasterkarte nicht gelesen "
-"werden kann."
+msgstr "Werde Z auf diesen Wert setzen, wenn der Wert der Rasterkarte nicht gelesen werden kann."
#: ../vector/v.drape/main.c:262
msgid "No features match Your query"
@@ -27495,17 +25156,12 @@
#: ../vector/v.drape/main.c:363 ../vector/v.drape/main.c:373
msgid "Due to error attribute data to new map are not transferred"
-msgstr ""
-"Auf Grund eines Fehlers werden die Attributdaten nicht in die neue Karte "
-"übetragen."
+msgstr "Auf Grund eines Fehlers werden die Attributdaten nicht in die neue Karte übetragen."
#: ../vector/v.drape/main.c:384
#, fuzzy
-msgid ""
-"No features drapped. Check your computational region and input vector map."
-msgstr ""
-"Keine Feature wurden drapiert. Überprüfen Sie die aktuelle Region und die "
-"Eingabe-Rasterkarte."
+msgid "No features drapped. Check your computational region and input vector map."
+msgstr "Keine Feature wurden drapiert. Überprüfen Sie die aktuelle Region und die Eingabe-Rasterkarte."
#: ../vector/v.neighbors/main.c:51
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
@@ -27520,14 +25176,8 @@
#: ../vector/v.neighbors/main.c:53
#, fuzzy
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
-msgstr ""
-"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
-"Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue "
-"Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
+msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
#: ../vector/v.neighbors/main.c:75
#, fuzzy
@@ -27705,20 +25355,16 @@
#, fuzzy, c-format
msgid "Unable to make line segment: %f - %f (line length = %f)"
msgstr ""
-"%.15g)\n"
"%s"
#: ../vector/v.what.rast/main.c:86
msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
-"Attributtabelle."
+msgstr "Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die Attributtabelle."
#: ../vector/v.what.rast/main.c:91
msgid "Name of input vector points map for which to edit attribute table"
-msgstr ""
-"Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+msgstr "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
#: ../vector/v.what.rast/main.c:95
msgid "Name of existing raster map to be queried"
@@ -27734,9 +25380,7 @@
#: ../vector/v.what.rast/main.c:161
msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Rastertyp ist Fließkomma und der Spaltentyp ist Integer. Etwas "
-"Informationsgehalt der Daten geht verloren!!"
+msgstr "Rastertyp ist Fließkomma und der Spaltentyp ist Integer. Etwas Informationsgehalt der Daten geht verloren!!"
#: ../vector/v.what.rast/main.c:241
#, c-format
@@ -27833,9 +25477,7 @@
#: ../vector/v.to.3d/args.c:32
msgid "Can be used for reverse transformation, to store height of points"
-msgstr ""
-"Kann verwendet werden, um, bei umgekehrter Transformation, die Höhen der "
-"Punkte zu speichern. "
+msgstr "Kann verwendet werden, um, bei umgekehrter Transformation, die Höhen der Punkte zu speichern. "
#: ../vector/v.to.3d/args.c:33 ../vector/v.to.3d/args.c:41
msgid "Height"
@@ -27957,25 +25599,18 @@
msgstr "Erzeugt eine 3D Darstellung aus GIS Daten."
#: ../misc/m.nviz.image/main.c:55
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-"Darstellung von Oberflächen (Rasterdaten), 2D/3D Vektordaten und Volumen (3D "
-"Rasterdaten) in 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "Darstellung von Oberflächen (Rasterdaten), 2D/3D Vektordaten und Volumen (3D Rasterdaten) in 3D."
#: ../misc/m.nviz.image/main.c:138
#, c-format
msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-"Vertikale Überhöhung wurde nicht spezifiziert, verwende den berechneten Wert "
-"%.0f."
+msgstr "Vertikale Überhöhung wurde nicht spezifiziert, verwende den berechneten Wert %.0f."
#: ../misc/m.nviz.image/main.c:150
#, c-format
msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-"Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
+msgstr "Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
#: ../misc/m.nviz.image/main.c:232
msgid "Unsupported output format"
@@ -28211,9 +25846,7 @@
#: ../misc/m.nviz.image/args.c:561
#, fuzzy
msgid "Focus to point on surface (from SW corner in map units)"
-msgstr ""
-"Eingabewert: Maximale Länge des Oberflächenabflusses in Karteneinheiten für "
-"USLE."
+msgstr "Eingabewert: Maximale Länge des Oberflächenabflusses in Karteneinheiten für USLE."
#: ../misc/m.nviz.image/args.c:571 ../misc/m.nviz.image/args.c:606
#: ../misc/m.nviz.image/args.c:618 ../misc/m.nviz.image/args.c:628
@@ -28339,11 +25972,8 @@
msgstr ""
#: ../misc/m.nviz.image/args.c:822
-msgid ""
-"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
-msgstr ""
-"nw;Nord-West Begrenzung;ne;Nord-Ost-Begrenzung;sw;Süd-West-Begrenzung;se;Süd-"
-"Ost-Begrenzung"
+msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr "nw;Nord-West Begrenzung;ne;Nord-Ost-Begrenzung;sw;Süd-West-Begrenzung;se;Süd-Ost-Begrenzung"
#: ../misc/m.nviz.image/args.c:826
msgid "Fringe edges"
@@ -28363,9 +25993,7 @@
msgstr "Höhe der Randzone"
#: ../misc/m.nviz.image/args.c:854
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
msgstr ""
#: ../misc/m.nviz.image/args.c:856 ../misc/m.nviz.image/args.c:865
@@ -28587,8 +26215,7 @@
#: ../misc/m.nviz.script/main.c:147
msgid "Either -i flag and/or route parameter must be used"
-msgstr ""
-"Entweder der Parameter '-i' und/oder Routen-Parameter muss gesetzt werden."
+msgstr "Entweder der Parameter '-i' und/oder Routen-Parameter muss gesetzt werden."
#: ../misc/m.nviz.script/main.c:171
msgid "Off-screen only available with full render mode"
@@ -28605,21 +26232,12 @@
msgstr "Habe NVIZ-Skript <%s> erzeugt."
#: ../misc/m.nviz.script/main.c:439
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-"Lasse diesen Punkt aus, der selektierte Punkt liegt außerhalb der Region. "
-"Vielleicht ist der Kameraabstand zu weit, sodass der Punkt hinter die Kante "
-"gerutscht ist?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr "Lasse diesen Punkt aus, der selektierte Punkt liegt außerhalb der Region. Vielleicht ist der Kameraabstand zu weit, sodass der Punkt hinter die Kante gerutscht ist?"
#: ../misc/m.cogo/main.c:227
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Ein einfaches Hilfsprogramm, dass Kurs- und Distanzwert in Koordinaten "
-"umrechnet und umgekehrt."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Ein einfaches Hilfsprogramm, dass Kurs- und Distanzwert in Koordinaten umrechnet und umgekehrt."
#: ../misc/m.cogo/main.c:229
msgid "It assumes a cartesian coordinate system"
@@ -28697,24 +26315,15 @@
#: ../misc/m.transform/main.c:324
msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-"Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
+msgstr "Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
#: ../misc/m.transform/main.c:333
msgid "Rectification polynomial order"
msgstr "Polynomgrad der Entzerrung."
#: ../misc/m.transform/main.c:341
-msgid ""
-"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-"forward coordinates difference (destination);rxy;reverse coordinates "
-"difference (source);fd;forward error (destination);rd;reverse error (source)"
-msgstr ""
-"idx;Punkt Index;src;Quell-Koordinaten;dst;Ziel-Koordinaten;fwd;Vorwärts-"
-"Koordinaten (Ziel);rev;Rückwärts-Koordinaten (Quelle);fxy;Vorwärts-"
-"Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);fd;"
-"Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
+msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgstr "idx;Punkt Index;src;Quell-Koordinaten;dst;Ziel-Koordinaten;fwd;Vorwärts-Koordinaten (Ziel);rev;Rückwärts-Koordinaten (Quelle);fxy;Vorwärts-Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);fd;Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
#: ../misc/m.transform/main.c:355
msgid "Display summary information"
@@ -28722,9 +26331,7 @@
#: ../misc/m.transform/main.c:361
msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr ""
-"Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu "
-"lesen)."
+msgstr "Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu lesen)."
#: ../misc/m.transform/main.c:362
msgid "Local x,y coordinates to target east,north"
@@ -28777,8 +26384,7 @@
#: ../visualization/nviz/src/nvizMain.c:128
msgid "Exit after completing script launched from the command line"
-msgstr ""
-"Beendet sich nachdem das, von der Kommandozeile gestartete, Skript fertig ist"
+msgstr "Beendet sich nachdem das, von der Kommandozeile gestartete, Skript fertig ist"
#: ../visualization/nviz/src/nvizMain.c:133
msgid "Start in Demo mode (skip the \"please wait\" message)"
@@ -28798,9 +26404,7 @@
#: ../visualization/nviz/src/nviz_init.c:148
msgid "Number of elevation files does not match number of colors files"
-msgstr ""
-"Die Anzahl der Dateien mit Höheninformationen stimmt nicht mit denen der "
-"Farbinformationen überein."
+msgstr "Die Anzahl der Dateien mit Höheninformationen stimmt nicht mit denen der Farbinformationen überein."
#: ../visualization/nviz/src/nviz_init.c:159
msgid "Loading data failed"
@@ -28941,9 +26545,7 @@
#: ../ps/ps.map/main.c:106
#, fuzzy
msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-"Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten"
-"(Rand) )."
+msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
#: ../ps/ps.map/main.c:108 ../ps/ps.map/main.c:121
#, fuzzy
@@ -28955,12 +26557,8 @@
msgstr "Erzeugt EPS (Encapsulated PostScript) anstatt PostScript-Dateien."
#: ../ps/ps.map/main.c:119
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
-msgstr ""
-"Beschreibe die Position der Kartenrechtecks auf dem Papier und beendet sich "
-"(Inch von der linken-oberen Ecke). "
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
+msgstr "Beschreibe die Position der Kartenrechtecks auf dem Papier und beendet sich (Inch von der linken-oberen Ecke). "
#: ../ps/ps.map/main.c:124
#, fuzzy
@@ -29043,12 +26641,8 @@
#: ../ps/ps.map/r_vpoints.c:245
#, c-format
-msgid ""
-"The mapping instruction <%s> will be renamed to <%s> in future versions of "
-"GRASS. Please use <%s> instead."
-msgstr ""
-"Die Kartierungsanweisung <%s> wird umbenannt in <%s> in zukünftigen "
-"Versionen von GRASS. Bitte verwenden Sie sattdessen <%s>."
+msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
+msgstr "Die Kartierungsanweisung <%s> wird umbenannt in <%s> in zukünftigen Versionen von GRASS. Bitte verwenden Sie sattdessen <%s>."
#: ../ps/ps.map/r_header.c:65 ../ps/ps.map/getgrid.c:61
#: ../ps/ps.map/getgrid.c:85 ../ps/ps.map/getgrid.c:171
@@ -29099,16 +26693,12 @@
#: ../ps/ps.map/ps_fclrtbl.c:92 ../ps/ps.map/ps_fclrtbl.c:97
#: ../ps/ps.map/ps_clrtbl.c:69
msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Die Y-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere "
-"dies."
+msgstr "Die Y-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere dies."
#: ../ps/ps.map/ps_fclrtbl.c:103 ../ps/ps.map/ps_fclrtbl.c:108
#: ../ps/ps.map/ps_clrtbl.c:75
msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Die X-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere "
-"dies."
+msgstr "Die X-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere dies."
#: ../ps/ps.map/catval.c:64
msgid "Column type not supported (must be string)"
@@ -29132,15 +26722,8 @@
msgstr "Lese Rasterkarte der Gruppe <%s> ..."
#: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
-msgstr ""
-"Ihre cats/-Datei ist ungültig. Eine cats/-Datei mit Kategorien und Labeln "
-"ist für 'colortable' notwendig für eine kategorische Legende. Werfen Sie "
-"einen Blick in die Handbuchseite von r.category. Die Erzeugung der Farbteile "
-"wurde nicht ausgeführt."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
+msgstr "Ihre cats/-Datei ist ungültig. Eine cats/-Datei mit Kategorien und Labeln ist für 'colortable' notwendig für eine kategorische Legende. Werfen Sie einen Blick in die Handbuchseite von r.category. Die Erzeugung der Farbteile wurde nicht ausgeführt."
#: ../ps/ps.map/scale.c:136
msgid "PSmap: do_scale(): shouldn't happen"
@@ -29400,9 +26983,7 @@
#: ../db/db.connect/main.c:49
#, fuzzy
msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
-"Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
-"beendet sich."
+msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
#: ../db/db.connect/main.c:53
msgid "Print current connection parameters and exit"
@@ -29410,9 +26991,7 @@
#: ../db/db.connect/main.c:59
msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr ""
-"Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet "
-"sich."
+msgstr "Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet sich."
#: ../db/db.connect/main.c:64
#, fuzzy
@@ -29457,10 +27036,8 @@
#: ../db/drivers/postgres/describe.c:102
#, fuzzy, c-format
-msgid ""
-"PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be converted"
-msgstr ""
-"PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht konvertiert."
+msgid "PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be converted"
+msgstr "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht konvertiert."
#: ../db/drivers/postgres/describe.c:109
#, fuzzy, c-format
@@ -29469,30 +27046,18 @@
#: ../db/drivers/postgres/describe.c:116
#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"Spalte '%s' : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. "
-"Einige Datensätze könnten beschädigt sein."
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "Spalte '%s' : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. Einige Datensätze könnten beschädigt sein."
#: ../db/drivers/postgres/describe.c:120
#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"Spalte '%s' : Typ 'character' wird als Typ varchar(250) abgespeichert. "
-"Einige Daten könnten verloren gehen."
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "Spalte '%s' : Typ 'character' wird als Typ varchar(250) abgespeichert. Einige Daten könnten verloren gehen."
#: ../db/drivers/postgres/describe.c:126
#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"Spalte '%s' : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 "
-"(falsch), 1 (wahr) abgespeichert."
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "Spalte '%s' : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 (falsch), 1 (wahr) abgespeichert."
#: ../db/drivers/postgres/execute.c:44
#, fuzzy
@@ -29511,15 +27076,11 @@
#: ../db/drivers/postgres/parse.c:55 ../db/drivers/mysql/parse.c:71
msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-"'user' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' "
-"verwenden."
+msgstr "'user' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' verwenden."
#: ../db/drivers/postgres/parse.c:59 ../db/drivers/mysql/parse.c:75
msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'Password' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db."
-"login' verwenden."
+msgstr "'Password' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' verwenden."
#: ../db/drivers/postgres/parse.c:63
msgid "Unknown option in database definition for PostgreSQL: "
@@ -29556,7 +27117,7 @@
#: ../db/drivers/mysql/cursor.c:46
msgid "Cannot allocate cursor."
-msgstr "Kann den Cursor nicht belegen."
+msgstr "Kann keinen Speicher für Cursor reservieren."
#: ../db/drivers/mysql/cursor.c:55
msgid "Cannot ad new token."
@@ -29569,12 +27130,8 @@
#: ../db/drivers/mysql/describe.c:126
#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"Spalte '%s' : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige "
-"Datensätze könnten beschädigt sein."
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "Spalte '%s' : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige Datensätze könnten beschädigt sein."
#: ../db/drivers/mysql/parse.c:60
msgid "Wrong port number in MySQL database definition: "
@@ -29653,12 +27210,8 @@
#: ../db/drivers/ogr/describe.c:192
#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"Spalte '%s', Typ 'string': unbekannte Breite -> als Datentyp varchar(250) "
-"abgespeichert. Einige Daten könnten verloren gehen."
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "Spalte '%s', Typ 'string': unbekannte Breite -> als Datentyp varchar(250) abgespeichert. Einige Daten könnten verloren gehen."
#: ../db/drivers/ogr/db.c:54
#, fuzzy
@@ -29695,9 +27248,8 @@
msgstr "Kann Datenbank nicht öffnen:"
#: ../db/drivers/sqlite/db.c:110
-#, fuzzy
msgid "SQLite database connection is still busy"
-msgstr "Datenbank, Verbindungseinstellungen"
+msgstr "Die SQLite Datenbankverbindung ist noch beschäftigt."
#: ../db/db.execute/main.c:56
#, fuzzy, c-format
@@ -29815,9 +27367,7 @@
#: ../db/db.select/main.c:265
msgid "Selects data from attribute table (performs SQL query statement(s))."
-msgstr ""
-"Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) "
-"aus)."
+msgstr "Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) aus)."
#: ../db/db.databases/main.c:56
msgid "Unable to list databases"
@@ -29869,13 +27419,8 @@
msgstr "Kopiere eine Tabelle."
#: ../db/db.copy/main.c:41
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Es kann entweder die Option 'from_table' (auch mit 'WHERE') oder die "
-"'select'-Option verwendet werden, aber nicht 'from_table' und 'select' "
-"können zur selben Zeit."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Es kann entweder die Option 'from_table' (auch mit 'WHERE') oder die 'select'-Option verwendet werden, aber nicht 'from_table' und 'select' können zur selben Zeit."
#: ../db/db.copy/main.c:47
msgid "Input driver name"
@@ -29887,8 +27432,7 @@
#: ../db/db.copy/main.c:60
msgid "Input table name (only, if 'select' is not used)"
-msgstr ""
-"Name der Eingabe-Tabelle (nur wenn 'SELECT'-Statement nicht benutzt wird)."
+msgstr "Name der Eingabe-Tabelle (nur wenn 'SELECT'-Statement nicht benutzt wird)."
#: ../db/db.copy/main.c:66
msgid "Output driver name"
@@ -29904,9 +27448,7 @@
#: ../db/db.copy/main.c:88
msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-"Vollständiger Select-Ausdruck (nur wenn 'from_table' und 'where' nicht "
-"verwendet werden)."
+msgstr "Vollständiger Select-Ausdruck (nur wenn 'from_table' und 'where' nicht verwendet werden)."
#: ../db/db.copy/main.c:89
msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
@@ -29933,11 +27475,8 @@
msgstr "Entfernt eine Datenbank."
#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe "
-"oder in Bilderen."
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe oder in Bilderen."
#: ../locale/scriptstrings/i.spectral_to_translate.c:2
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
@@ -29987,21 +27526,13 @@
msgstr "Darzustellender Text"
#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"Konvertiert alle alten GRASS Vektorkarten im aktuellen Mapset in das "
-"aktuelle Format."
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Konvertiert alle alten GRASS Vektorkarten im aktuellen Mapset in das aktuelle Format."
#: ../locale/scriptstrings/r.buffer_to_translate.c:1
#, fuzzy
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte "
-"haben."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte haben."
#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
#, fuzzy
@@ -30051,12 +27582,8 @@
msgstr "Eingabe-Rasterkarten"
#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung "
-"(inclination), Ausrichtung (azimuth) und einem Punkt."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung (inclination), Ausrichtung (azimuth) und einem Punkt."
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
@@ -30102,24 +27629,17 @@
msgstr "Name einer existierenden Rasterkarte."
#: ../locale/scriptstrings/tr.register_to_translate.c:5
-msgid ""
-"Name(s) of existing raster map(s), multiple maps must be provided in "
-"temporal order in case datetime should be attached"
+msgid "Name(s) of existing raster map(s), multiple maps must be provided in temporal order in case datetime should be attached"
msgstr ""
#: ../locale/scriptstrings/tr.register_to_translate.c:6
-msgid ""
-"The valid start date and time of the first raster map, in case the map has "
-"no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0)"
+msgid "The valid start date and time of the first raster map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0)"
msgstr ""
#: ../locale/scriptstrings/tr.register_to_translate.c:7
#: ../locale/scriptstrings/tr3.register_to_translate.c:7
#: ../locale/scriptstrings/tv.register_to_translate.c:7
-msgid ""
-"Time increment between maps for valid time interval creation (format "
-"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
-"relative: 1.0)"
+msgid "Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)"
msgstr ""
#: ../locale/scriptstrings/tr.register_to_translate.c:8
@@ -30127,16 +27647,13 @@
#: ../locale/scriptstrings/tv.register_to_translate.c:8
#: ../locale/scriptstrings/t.time.abs_to_translate.c:11
#: ../locale/scriptstrings/t.time.rel_to_translate.c:11
-msgid ""
-"Create an interval (start and end time) in case an increment is provided"
+msgid "Create an interval (start and end time) in case an increment is provided"
msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:1
#, fuzzy
msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs "
-"Frontend)."
+msgstr "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs Frontend)."
#: ../locale/scriptstrings/m.proj_to_translate.c:4
#, fuzzy
@@ -30155,9 +27672,7 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:6
#, fuzzy
msgid "Name for output coordinate file (omit to send to stdout)"
-msgstr ""
-"Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
-"soll)."
+msgstr "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden soll)."
#: ../locale/scriptstrings/m.proj_to_translate.c:8
#, fuzzy
@@ -30185,21 +27700,15 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:15
msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-"
-"Projektion."
+msgstr "Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-Projektion."
#: ../locale/scriptstrings/m.proj_to_translate.c:17
msgid "Use current location as input and LL WGS84 as output projection"
msgstr "Verwende LL WGS84 als Eingabe-Projektion und Ausgabe-Projektion."
#: ../locale/scriptstrings/m.proj_to_translate.c:19
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
-msgstr ""
-"Gebe long/lat in Dezimalgrad oder anderen Projektionen mit vielen "
-"Dezimalstellen aus"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgstr "Gebe long/lat in Dezimalgrad oder anderen Projektionen mit vielen Dezimalstellen aus"
#: ../locale/scriptstrings/m.proj_to_translate.c:21
#, fuzzy
@@ -30313,8 +27822,7 @@
msgstr "Name der neuen Datenbank."
#: ../locale/scriptstrings/t.create_to_translate.c:6
-msgid ""
-"The granularity of the new space time dataset (NNN day, NNN week, NNN month)"
+msgid "The granularity of the new space time dataset (NNN day, NNN week, NNN month)"
msgstr ""
#: ../locale/scriptstrings/t.create_to_translate.c:7
@@ -30342,21 +27850,15 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db."
-"connect verbunden sein."
+msgstr "Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db.connect verbunden sein."
#: ../locale/scriptstrings/db.test_to_translate.c:4
msgid "Test name"
msgstr "Testname"
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region "
-"und -Projektion."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region und -Projektion."
#: ../locale/scriptstrings/r.tileset_to_translate.c:3
#, fuzzy
@@ -30372,11 +27874,8 @@
msgstr "Erzeugt ein Web Map Server Query-String."
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Name der Region die anstelle der aktuellen Region für die Ausdehnung "
-"(bounding box) und Auflösung verwendet werden soll."
+msgid "Name of region to use instead of current region for bounds and resolution"
+msgstr "Name der Region die anstelle der aktuellen Region für die Ausdehnung (bounding box) und Auflösung verwendet werden soll."
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
msgid "Source projection"
@@ -30404,11 +27903,8 @@
msgstr "Anzahl Zellen, die die Kacheln in alle Richtungen überlappen sollen."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
-"panchromatischer Kanäle."
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
msgid "fusion"
@@ -30466,13 +27962,8 @@
msgstr ""
#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
-msgstr ""
-"Download und Installation von Erweiterungen aus dem 'GRASS Addons SVN "
-"Repository' in der lokalen GRASS Installation oder Entfernt installierte "
-"Erweiterungen. "
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
+msgstr "Download und Installation von Erweiterungen aus dem 'GRASS Addons SVN Repository' in der lokalen GRASS Installation oder Entfernt installierte Erweiterungen. "
#: ../locale/scriptstrings/g.extension_to_translate.c:4
#, fuzzy
@@ -30503,22 +27994,17 @@
#: ../locale/scriptstrings/g.extension_to_translate.c:12
#, fuzzy
-msgid ""
-"List available modules in the GRASS Addons SVN repository including modules "
-"description"
+msgid "List available modules in the GRASS Addons SVN repository including modules description"
msgstr "Zeigt die vorhandenen Regelsätze und Schluß."
#: ../locale/scriptstrings/g.extension_to_translate.c:14
#, fuzzy
-msgid ""
-"List available modules in the GRASS Addons SVN repository (shell script "
-"style)"
+msgid "List available modules in the GRASS Addons SVN repository (shell script style)"
#: ../locale/scriptstrings/g.extension_to_translate.c:16
msgid "Install system-wide (may need system administrator rights)"
-msgstr ""
-"Systemweite Installation (eventuell Systemadministratorrechte erforderlich)."
+msgstr "Systemweite Installation (eventuell Systemadministratorrechte erforderlich)."
#: ../locale/scriptstrings/g.extension_to_translate.c:17
msgid "Download source code and exit"
@@ -30538,15 +28024,11 @@
#: ../locale/scriptstrings/tr3.register_to_translate.c:5
-msgid ""
-"Name(s) of existing raster3d map(s), multiple maps must be provided in "
+msgid "Name(s) of existing raster3d map(s), multiple maps must be provided in temporal order in case datetime should be attached"
msgstr ""
#: ../locale/scriptstrings/tr3.register_to_translate.c:6
-msgid ""
-"The valid start date and time of the first raster3d map, in case the map has "
+msgid "The valid start date and time of the first raster3d map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0)"
msgstr ""
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
@@ -30568,9 +28050,7 @@
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
#, fuzzy
msgid "Mosaics several images and extends colormap."
-msgstr ""
-"Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-"
-"Karten."
+msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
msgid "mosaicking"
@@ -30578,8 +28058,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:1
msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mischt die Farbkomponenten zweier Rasterkarten im angegebenen Verhältnis."
+msgstr "Mischt die Farbkomponenten zweier Rasterkarten im angegebenen Verhältnis."
#: ../locale/scriptstrings/r.blend_to_translate.c:3
msgid "Name of first raster map for blending"
@@ -30592,20 +28071,15 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:5
#, fuzzy
msgid "Prefix for red, green and blue output raster maps containing"
-msgstr ""
-"Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
+msgstr "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
#: ../locale/scriptstrings/r.blend_to_translate.c:6
msgid "Percentage weight of first map for color blending"
msgstr "Anteil der ersten Karte in der Mischung in Prozent."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reklassifiziert eine Rasterkarte mit Flächen größer oder kleiner als eine "
-"benutzerspezifizierte Fläche (in Hektar)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reklassifiziert eine Rasterkarte mit Flächen größer oder kleiner als eine benutzerspezifizierte Fläche (in Hektar)."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
msgid "Lesser value option that sets the <= area size limit [hectares]"
@@ -30675,8 +28149,7 @@
msgstr "Zu berechnender Wert."
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
+msgid "Allows to update a column in the attribute table connected to a vector map."
msgstr "Aktualisiert eine Spalte einer Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
@@ -30686,11 +28159,8 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
#, fuzzy
-msgid ""
-"Value to update the column with, can be (combination of) other column(s)"
-msgstr ""
-"Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in "
-"einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
+msgid "Value to update the column with, can be (combination of) other column(s)"
+msgstr "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
#, fuzzy
@@ -30735,23 +28205,17 @@
msgstr "Name einer existierenden Vektorkarte."
#: ../locale/scriptstrings/tv.register_to_translate.c:5
-msgid ""
-"Name(s) of existing vector map(s), multiple maps must be provided in "
+msgid "Name(s) of existing vector map(s), multiple maps must be provided in temporal order in case datetime should be attached"
msgstr ""
#: ../locale/scriptstrings/tv.register_to_translate.c:6
-msgid ""
-"The valid start date and time of the first vector map, in case the map has "
+msgid "The valid start date and time of the first vector map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0)"
msgstr ""
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
#, fuzzy
msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr ""
-"Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
-"numerischen Spalte der Attributtabelle."
+msgstr "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
#: ../locale/scriptstrings/g.manual_to_translate.c:1
#, fuzzy
@@ -30780,9 +28244,7 @@
msgstr "Handbuchseite die gezeigt werden soll."
#: ../locale/scriptstrings/tr.series_to_translate.c:1
-msgid ""
-"Performe different aggregation algorithms from r.series on all raster maps "
-"of a space time raster dataset"
+msgid "Performe different aggregation algorithms from r.series on all raster maps of a space time raster dataset"
msgstr ""
#: ../locale/scriptstrings/tr.series_to_translate.c:6
@@ -30798,11 +28260,8 @@
msgstr ""
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu "
-"Vektorkarten."
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr "Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu Vektorkarten."
#: ../locale/scriptstrings/r.mask_to_translate.c:1
msgid "Creates a MASK for limiting raster operation."
@@ -30821,8 +28280,7 @@
#: ../locale/scriptstrings/r.mask_to_translate.c:5
#, fuzzy
msgid "Category values to use for mask (format: 1 2 3 thru 7 *)"
-msgstr ""
-"Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
+msgstr "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
#: ../locale/scriptstrings/r.mask_to_translate.c:7
msgid "Create inverse mask from specified 'maskcats' list"
@@ -30837,26 +28295,19 @@
msgstr ""
#: ../locale/scriptstrings/t.list_to_translate.c:6
-msgid ""
-"Sort the space time dataset by category. Columns number_of_maps and "
-"granularity only available fpr space time datasets"
+msgid "Sort the space time dataset by category. Columns number_of_maps and granularity only available fpr space time datasets"
msgstr ""
#: ../locale/scriptstrings/t.list_to_translate.c:7
-msgid ""
-"Which columns should be printed to stdout. Columns number_of_maps and "
+msgid "Which columns should be printed to stdout. Columns number_of_maps and granularity only available fpr space time datasets"
msgstr ""
#: ../locale/scriptstrings/t.list_to_translate.c:8
-msgid ""
-"A where statement for selected listing e.g: start_time < \"2001-01-01\" and "
-"end_time > \"2001-01-01\""
+msgid "A where statement for selected listing e.g: start_time < \"2001-01-01\" and end_time > \"2001-01-01\""
msgstr ""
#: ../locale/scriptstrings/t.list_to_translate.c:10
-msgid ""
-"The field separator character between the columns, default is tabular \"\t\""
+msgid "The field separator character between the columns, default is tabular \"\t\""
msgstr ""
#: ../locale/scriptstrings/t.list_to_translate.c:11
@@ -30887,12 +28338,8 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
#, fuzzy
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-"Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative "
-"DGMs mit Hilfe von gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
#, fuzzy
@@ -30905,25 +28352,17 @@
#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
#, fuzzy
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
-msgstr ""
-"L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein "
-"einzelnen Kanal umrechnen."
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
+msgstr "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein einzelnen Kanal umrechnen."
#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
#, fuzzy
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Base name for output raster map (band number will be appended to base name)"
msgstr "Name der Ausgabe-Rasterkarte (Sättigung, saturation)."
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten "
-"Vektorkarte um."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten Vektorkarte um."
#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
msgid "Old and new name of the column (old,new)"
@@ -30960,9 +28399,7 @@
msgstr "Name der Eingabe-Datei (oder \"-\" um von stdin zu lesen)."
-msgid ""
-"Set the absolute valid time interval for maps of type raster, vector and "
-"raster3d"
+msgid "Set the absolute valid time interval for maps of type raster, vector and raster3d"
msgstr ""
#: ../locale/scriptstrings/t.time.abs_to_translate.c:2
@@ -30984,31 +28421,21 @@
msgstr "Name existierender Rasterkarte(n)"
#: ../locale/scriptstrings/t.time.abs_to_translate.c:8
-msgid ""
-"The valid start date and time of the first raster map. Time format is \"yyyy-"
-"mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\""
+msgid "The valid start date and time of the first raster map. Time format is \"yyyy-mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\""
msgstr ""
#: ../locale/scriptstrings/t.time.abs_to_translate.c:9
-msgid ""
-"The valid end date and time of the first raster map. Time format is \"yyyy-"
-"mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\". End time and increment are mutual "
-"exclusive."
+msgid "The valid end date and time of the first raster map. Time format is \"yyyy-mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\". End time and increment are mutual exclusive."
msgstr ""
#: ../locale/scriptstrings/t.time.abs_to_translate.c:10
-msgid ""
-"Time increment between maps for valid time interval creation. Interval "
-"format: NNN seconds, minutes, hours, days, weeks, months, years"
+msgid "Time increment between maps for valid time interval creation. Interval format: NNN seconds, minutes, hours, days, weeks, months, years"
msgstr ""
#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
#, fuzzy
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr ""
-"Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das "
-"von GpsBabel unterstützt wird."
+msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgstr "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das von GpsBabel unterstützt wird."
#: ../locale/scriptstrings/v.out.gps_to_translate.c:4
msgid "GPS"
@@ -31060,9 +28487,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Name der Attribut-Spalte, die für die thematische Darstellung (muß umerisch "
-"sein)."
+msgstr "Name der Attribut-Spalte, die für die thematische Darstellung (muß umerisch sein)."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
msgid "Type of thematic display"
@@ -31099,15 +28524,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:17
msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-"Kleinste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/"
-"Linien."
+msgstr "Kleinste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/Linien."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
-"Größste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/"
-"Linien."
+msgstr "Größste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/Linien."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
msgid "Number of classes for interval theme (integer)"
@@ -31127,8 +28548,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
-"GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
+msgstr "GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
msgid "Color for graduated lines or point/area outlines"
@@ -31136,8 +28556,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
msgid "Beginning color for custom color gradient"
@@ -31171,15 +28590,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-"Speichere die Befehle zur Erstellung der thematischen Karte in die group-"
-"Datei für den GIS-Manager."
+msgstr "Speichere die Befehle zur Erstellung der thematischen Karte in die group-Datei für den GIS-Manager."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-"Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im "
-"aktuellen Verzeichnis gespeichert."
+msgstr "Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im aktuellen Verzeichnis gespeichert."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
msgid "If not set, no psmap instruction files will be created)"
@@ -31187,9 +28602,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-"Name der group-Datei, in der die Befehle zur Erstellung der thematischen "
-"Karte gespeichert werden."
+msgstr "Name der group-Datei, in der die Befehle zur Erstellung der thematischen Karte gespeichert werden."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
msgid "Create graphic legend in x11 display monitor"
@@ -31205,9 +28618,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:55
msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr ""
-"Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in "
-"Skripten)."
+msgstr "Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in Skripten)."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:57
msgid "Use math notation brackets in legend"
@@ -31256,12 +28667,8 @@
msgstr "Radius des Buffers in Rasterzellen."
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importiert LÄnderdateien vom US-NGA GEOnet Names Server (GNS) in eine "
-"Vektorpunktkarte."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importiert LÄnderdateien vom US-NGA GEOnet Names Server (GNS) in eine Vektorpunktkarte."
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -31275,12 +28682,8 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
#, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygon "
-"map and uploads statistics to new attribute columns."
-msgstr ""
-"Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
-"und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+msgid "Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns."
+msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
msgid "Continue if upload column(s) already exist"
@@ -31312,22 +28715,16 @@
#: ../locale/scriptstrings/t.remove_to_translate.c:5
#, fuzzy
-msgid ""
-"Name(s) of the space time or map dataset to be removed from the temporal "
-"database"
-msgstr ""
-"Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+msgid "Name(s) of the space time or map dataset to be removed from the temporal database"
+msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
#, fuzzy
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
msgstr "."
#: ../locale/scriptstrings/tr3.unregister_to_translate.c:1
-msgid ""
-"Unregister raster3d map(s) from a specific or from all space time raster3d "
-"dataset in which it is registered"
+msgid "Unregister raster3d map(s) from a specific or from all space time raster3d dataset in which it is registered"
msgstr ""
#: ../locale/scriptstrings/tr3.unregister_to_translate.c:2
@@ -31336,10 +28733,7 @@
msgstr "Aktualisiere die Statistik der Rasterkarte."
#: ../locale/scriptstrings/tr3.unregister_to_translate.c:4
-msgid ""
-"Name of an existing space time raster3d dataset. If no name is provided the "
-"raster3d map(s) are unregistered from all space time datasets in which they "
-"are registered."
+msgid "Name of an existing space time raster3d dataset. If no name is provided the raster3d map(s) are unregistered from all space time datasets in which they are registered."
msgstr ""
#: ../locale/scriptstrings/tr3.unregister_to_translate.c:5
@@ -31365,8 +28759,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
+msgstr "Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
msgid "Rebuilds topology on all vector maps in the current mapset."
@@ -31415,9 +28808,7 @@
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
#, fuzzy
msgid "Drapes a color raster over a shaded relief map."
-msgstr ""
-"Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter "
-"Verwendung von d.his."
+msgstr "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter Verwendung von d.his."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
#, fuzzy
@@ -31434,11 +28825,8 @@
msgstr "Prozentuale Aufhellung."
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
msgid "Layer number where to add column(s)"
@@ -31449,24 +28837,15 @@
msgstr "Name and Typ der neuen Spalten ('name type [,name type, ...]')"
#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
-msgstr ""
-"Datentyp hängt von der verwendeten Datenbank ab, aber alle unterstützen "
-"VARCHAR(), INT, DOUBLE PRECISION und DATE."
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgstr "Datentyp hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION und DATE."
#: ../locale/scriptstrings/tr.unregister_to_translate.c:1
-msgid ""
-"Unregister raster map(s) from a specific or from all space time raster "
+msgid "Unregister raster map(s) from a specific or from all space time raster dataset in which it is registered"
msgstr ""
#: ../locale/scriptstrings/tr.unregister_to_translate.c:4
-msgid ""
-"Name of an existing space time raster dataset. If no name is provided the "
-"raster map(s) are unregistered from all space time datasets in which they "
-"are registered."
+msgid "Name of an existing space time raster dataset. If no name is provided the raster map(s) are unregistered from all space time datasets in which they are registered."
msgstr ""
#: ../locale/scriptstrings/tr.unregister_to_translate.c:5
@@ -31606,9 +28985,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"Benannte Region, für die Daten angefragt werden sollen. Wenn nicht angegeben "
-"wird die aktuelle Region verwendet."
+msgstr "Benannte Region, für die Daten angefragt werden sollen. Wenn nicht angegeben wird die aktuelle Region verwendet."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:42
#, fuzzy
@@ -31643,9 +29020,7 @@
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
#, fuzzy
msgid "Fills no-data areas in raster maps using splines interpolation."
-msgstr ""
-"Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-"
-"Interpolation"
+msgstr "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-Interpolation"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
msgid "Spline tension parameter"
@@ -31656,12 +29031,8 @@
msgstr "Spline-Glättungs-(smooth) Parameter"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder "
-"gleichem Attributwert auf."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder gleichem Attributwert auf."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
msgid "dissolve"
@@ -31675,9 +29046,7 @@
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
#, fuzzy
msgid "Name of attribute column used to dissolve common boundaries"
-msgstr ""
-"Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden "
-"soll."
+msgstr "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden soll."
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
msgid "Adds missing centroids to closed boundaries."
@@ -31692,16 +29061,11 @@
msgstr "Startwert der Kategorienummern.goriewerte."
#: ../locale/scriptstrings/tv.unregister_to_translate.c:1
-msgid ""
-"Unregister vector map(s) from a specific or from all space time vector "
-"datasets in which it is registered"
+msgid "Unregister vector map(s) from a specific or from all space time vector datasets in which it is registered"
msgstr ""
#: ../locale/scriptstrings/tv.unregister_to_translate.c:4
-msgid ""
-"Name of an existing space time vector dataset. If no name is provided the "
-"vector map(s) are unregistered from all space time datasets in which they "
-"are registered."
+msgid "Name of an existing space time vector dataset. If no name is provided the vector map(s) are unregistered from all space time datasets in which they are registered."
msgstr ""
#: ../locale/scriptstrings/tv.unregister_to_translate.c:5
@@ -31715,8 +29079,7 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
msgid "Force removal (required for actual deletion of table)"
-msgstr ""
-"Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
+msgstr "Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
#, fuzzy
@@ -31725,9 +29088,7 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"Ermöglicht es eine Tabelle an eine Attributtabelle einer Vektorkarte zu "
-"joinen."
+msgstr "Ermöglicht es eine Tabelle an eine Attributtabelle einer Vektorkarte zu joinen."
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
msgid "Vector map to which to join other table"
@@ -31764,8 +29125,7 @@
msgstr ""
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
msgstr "Löscht eine Spalte der Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -31789,8 +29149,7 @@
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
#, fuzzy
-msgid ""
-"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
@@ -31839,12 +29198,8 @@
msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 7)."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Erzeugt eine neue Attributtabelle und sie zu einem Layer einer existierenden "
-"Vektorkarte."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Erzeugt eine neue Attributtabelle und sie zu einem Layer einer existierenden Vektorkarte."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
msgid "Name of new attribute table (default: vector map name)"
@@ -31870,12 +29225,8 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
#, fuzzy
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: \"label varchar(250), type integer\""
-msgstr ""
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: \"label varchar(250), type integer\""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
#, fuzzy
@@ -31914,9 +29265,7 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu "
-"Höheneinheiten"
+msgstr "Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu Höheneinheiten"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:11
@@ -31925,16 +29274,12 @@
msgstr "Shading"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:10
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-"Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: "
-"scale=1)."
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgstr "Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: scale=1)."
#: ../locale/scriptstrings/i.oif_to_translate.c:1
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
+msgstr "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
#: ../locale/scriptstrings/i.oif_to_translate.c:5
msgid "LANDSAT TM band 1."
@@ -31971,9 +29316,7 @@
msgstr "Namen der Eingabedateien."
-msgid ""
-"Set the relative valid time interval for maps of type raster, vector and "
-"raster3d"
+msgid "Set the relative valid time interval for maps of type raster, vector and raster3d"
msgstr ""
#: ../locale/scriptstrings/t.time.rel_to_translate.c:3
@@ -32045,9 +29388,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen "
-"oder Fließrichtungen."
+msgstr "Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen oder Fließrichtungen."
#: ../locale/scriptstrings/d.polar_to_translate.c:4
msgid "Name of raster angle map"
@@ -32055,9 +29396,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:5
msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr ""
-"Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von "
-"NULL)."
+msgstr "Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von NULL)."
#: ../locale/scriptstrings/d.polar_to_translate.c:6
#, fuzzy
@@ -32069,11 +29408,8 @@
msgstr "Verwende Xgraph zum Zeichnen."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr "Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
msgid "Extended statistics (quartiles and 90th percentile)"
@@ -32086,10 +29422,8 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
#, fuzzy
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr ""
-"Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
+msgstr "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
#, fuzzy
@@ -32098,9 +29432,7 @@
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-"
-"Karte."
+msgstr "Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-Karte."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
#, fuzzy
@@ -32124,12 +29456,8 @@
msgstr ""
#: ../imagery/i.smap/main.c:43
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des "
-"'sequential maximum a posteriori (SMAP)' Ansatzes durch."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des 'sequential maximum a posteriori (SMAP)' Ansatzes durch."
#: ../imagery/i.smap/interp.c:225
msgid "Invalid parameter values"
@@ -32288,9 +29616,7 @@
msgstr ""
#: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
msgstr ""
#: ../imagery/i.albedo/main.c:127
@@ -32354,14 +29680,12 @@
#: ../imagery/i.pca/main.c:214
msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr ""
-"Die Länge des Skalierungsbereichs sollte > 0 sein. Verwende Standardwerte: "
-"0,255. "
+msgstr "Die Länge des Skalierungsbereichs sollte > 0 sein. Verwende Standardwerte: 0,255. "
#: ../imagery/i.pca/main.c:251 ../imagery/i.pca/main.c:299
#: ../imagery/i.pca/main.c:426
msgid "Unable allocate memory for row buffer"
-msgstr "Kann keinen Speicherplatz für Zeilenbuffer belegen."
+msgstr "Kann keinen Speicher für Zeilenbuffer reservieren."
#: ../imagery/i.pca/main.c:253
#, c-format
@@ -32375,11 +29699,11 @@
#: ../imagery/i.pca/main.c:317
msgid "Unable to allocate memory for row buffer"
#: ../imagery/i.pca/main.c:378
msgid "Unable to allocate memory for raster row"
-msgstr "Kann keinen Speicher allokieren für Rasterzeile."
+msgstr "Kann keinen Speicher für Rasterzeilen reservieren."
#: ../imagery/i.pca/main.c:387
#, c-format
@@ -32402,9 +29726,7 @@
msgstr "Vektor, Transformation"
#: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
msgstr ""
#: ../imagery/i.evapo.pm/main.c:65
@@ -32466,8 +29788,7 @@
msgstr ""
#: ../imagery/i.vi/main.c:82
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
msgstr ""
#: ../imagery/i.vi/main.c:87
@@ -32481,16 +29802,7 @@
msgstr "Name der Höhenkarte"
#: ../imagery/i.vi/main.c:91
-msgid ""
-"arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation "
-"Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green "
-"atmospherically resistant vegetation index;gemi;Global Environmental "
-"Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified "
-"Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted "
-"Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;"
-"Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple "
-"Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference "
-"Vegetation Index;"
+msgid "arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green atmospherically resistant vegetation index;gemi;Global Environmental Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference Vegetation Index;"
msgstr ""
#: ../imagery/i.vi/main.c:110
@@ -32628,12 +29940,7 @@
msgstr "Name der Eingabekarte."
#: ../imagery/i.modis.qc/main.c:132
-msgid ""
-"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
-"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
-"LST 1Km 8-days (Day/Night);mod13A2;VI 1Km 16-days;mcd43B2;Brdf-Albedo "
-"Quality (Ancillary SDS) 1Km 8-days;mcd43B2q;Brdf-Albedo Quality (BRDF SDS) "
-"1Km 8-days;"
+msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);mod13A2;VI 1Km 16-days;mcd43B2;Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days;mcd43B2q;Brdf-Albedo Quality (BRDF SDS) 1Km 8-days;"
msgstr ""
#: ../imagery/i.modis.qc/main.c:147
@@ -32642,37 +29949,7 @@
msgstr "Name der zu erstellenden Ebene (Rasterkarte)."
#: ../imagery/i.modis.qc/main.c:148
-msgid ""
-"adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
-"cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
-"diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
-"modland_qa;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;"
-"mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;"
-"mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average "
-"Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;"
-"data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;"
-"mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS "
-"Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error "
-"Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow "
-"Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow "
-"Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;"
-"mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: StateQA Internal "
-"Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow "
-"Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow "
-"Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;"
-"mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA "
-"Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
-"Maskmodland_qa;mod13A2: MODIS Land General Quality Assessmentvi_usefulness;"
-"mod13A2: Quality estimation of the pixelaerosol_quantity;mod13A2: Quantity "
-"range of Aerosolpixel_adjacent_to_cloud;mod13A2: if pixel is a cloud "
-"neighbourbrdf_correction_performed;mod13A2: if BRDF correction "
-"performedmixed_clouds;mod13A2: if pixel mixed with cloudsland_water;mod13A2: "
-"separate land from various water objectspossible_snow_ice;mod13A2: if snow/"
-"ice present in pixelpossible_shadow;mod13A2: if shadow is present in "
-"pixelplatform;mcd43B2: Quality of BRDF correction performedland_water;"
-"mcd43B2: Quality of BRDF correction performedsun_z_angle_at_local_noon;"
-"mcd43B2: Quality of BRDF correction performedbrdf_correction_performed;"
-"mcd43B2q: Quality of BRDF correction performed"
+msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: Stat
eQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Maskmodland_qa;mod13A2: MODIS Land General Quality Assessmentvi_usefulness;mod13A2: Quality estimation of the pixelaerosol_quantity;mod13A2: Quantity range of Aerosolpixel_adjacent_to_cloud;mod13A2: if pixel is a cloud neighbourbrdf_correction_performed;mod13A2: if BRDF correction performedmixed_clouds;mod13A2: if pixel mixed with cloudsland_water;mod13A2: separate land from various water objectspossible_snow_ice;mod13A2: if snow/ice present in pixelpossible_shadow;mod13A2: if shadow is present in pixelplatform;mcd43B2: Quality of BRDF correction performedland_water;mcd43B2: Quality of BRDF correction performedsun_z_angle_at_loca
l_noon;mcd43B2: Quality of BRDF correction performedbrdf_correction_performed;mcd43B2q: Quality of BRDF correction performed"
msgstr ""
#: ../imagery/i.modis.qc/main.c:191
@@ -32681,14 +29958,11 @@
msgstr "Name Referenzsystemtabelle."
#: ../imagery/i.modis.qc/main.c:199
-msgid ""
-"Band number of Modis product mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7]"
+msgid "Band number of Modis product mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7]"
msgstr ""
#: ../imagery/i.modis.qc/main.c:200
-msgid ""
-"1;Band 1: Red;2;Band 2: NIR;3;Band 3: Blue;4;Band 4: Green;5;Band 5: SWIR "
-"1;6;Band 6: SWIR 2;7;Band 7: SWIR 3;"
+msgid "1;Band 1: Red;2;Band 2: NIR;3;Band 3: Blue;4;Band 4: Green;5;Band 5: SWIR 1;6;Band 6: SWIR 2;7;Band 7: SWIR 3;"
msgstr ""
#: ../imagery/i.modis.qc/main.c:211
@@ -32780,12 +30054,8 @@
msgstr "Bildverarbeitung, Rektifikation"
#: ../imagery/i.rectify/main.c:98
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel "
-"des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
#: ../imagery/i.rectify/main.c:112
msgid "Output raster map(s) suffix"
@@ -32804,11 +30074,8 @@
msgstr "Verwendete Speichergröße in MB"
#: ../imagery/i.rectify/main.c:147
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
-msgstr ""
-"Verwende die Einstellungen der aktuelle Region für die Ziellocation "
-"(Standard: Berechne den kleinsten Bereich)."
+msgid "Use current region settings in target location (def.=calculate smallest area)"
+msgstr "Verwende die Einstellungen der aktuelle Region für die Ziellocation (Standard: Berechne den kleinsten Bereich)."
#: ../imagery/i.rectify/main.c:151
msgid "Rectify all raster maps in group"
@@ -32897,9 +30164,7 @@
#: ../imagery/i.rectify/cp.c:21
#, c-format
msgid "Not enough active control points for current order, %d are required."
-msgstr ""
-"Nicht genügend aktive Kontrollpunkte für den momentanen Grad, %d werden "
-"benötigt."
+msgstr "Nicht genügend aktive Kontrollpunkte für den momentanen Grad, %d werden benötigt."
#: ../imagery/i.rectify/cp.c:25
msgid "Poorly placed control points."
@@ -32968,8 +30233,7 @@
#: ../imagery/i.rectify/rectify.c:106
#, c-format
msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr ""
-"Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
+msgstr "Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
#: ../imagery/i.rectify/rectify.c:112
#, c-format
@@ -32977,9 +30241,7 @@
msgstr "Rasterkarte <%s@%s>: Zone passt nicht zu den aktuellen Einstellungen."
#: ../imagery/i.landsat.toar/main.c:65
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
msgstr ""
#: ../imagery/i.landsat.toar/main.c:67 ../imagery/i.landsat.acca/main.c:106
@@ -33023,9 +30285,7 @@
msgstr ""
#: ../imagery/i.landsat.toar/main.c:99
-msgid ""
-"mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;"
-"tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
+msgid "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
msgstr ""
#: ../imagery/i.landsat.toar/main.c:113
@@ -33140,12 +30400,8 @@
msgstr ""
#: ../imagery/i.vpoints/main.c:97
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
-msgstr ""
-"Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder "
-"durch Koordinateneingaben über die Tastatur."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
+msgstr "Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder durch Koordinateneingaben über die Tastatur."
#: ../imagery/i.vpoints/main.c:105 ../imagery/i.points/main.c:106
msgid "Name of imagery group to be registered"
@@ -33342,9 +30598,7 @@
msgstr "Features"
#: ../imagery/i.eb.netrad/main.c:89
-msgid ""
-"Name of the difference of temperature from surface skin to about 2 m height "
-"[K]"
+msgid "Name of the difference of temperature from surface skin to about 2 m height [K]"
msgstr ""
#: ../imagery/i.eb.netrad/main.c:90
@@ -33403,9 +30657,7 @@
msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
#: ../imagery/i.eb.evapfr/main.c:53
-msgid ""
-"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
-"moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
msgstr ""
#: ../imagery/i.eb.evapfr/main.c:59 ../imagery/i.eb.soilheatflux/main.c:71
@@ -33438,9 +30690,7 @@
msgstr ""
#: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
msgstr ""
#: ../imagery/i.evapo.time/main.c:86
@@ -33544,9 +30794,7 @@
msgstr ""
#: ../imagery/i.aster.toar/main.c:104
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN.\n"
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n"
msgstr ""
#: ../imagery/i.aster.toar/main.c:108
@@ -33596,12 +30844,8 @@
msgstr ""
#: ../imagery/i.rgb.his/main.c:51
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-"Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS "
-"(Hue-Intensity-Saturation) Farbraum."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr "Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS (Hue-Intensity-Saturation) Farbraum."
#: ../imagery/i.rgb.his/main.c:57
msgid "Name of input raster map (red)"
@@ -33628,12 +30872,8 @@
#: ../imagery/i.his.rgb/main.c:51
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-"Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum "
-"in den RGB (Rot-Grün-Blau) Farbraum."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr "Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum in den RGB (Rot-Grün-Blau) Farbraum."
#: ../imagery/i.his.rgb/main.c:57
msgid "Name of input raster map (hue)"
@@ -33700,16 +30940,12 @@
#: ../imagery/i.gensigset/subcluster.c:548
msgid "Unreliable clustering. Try a smaller initial number of clusters"
-msgstr ""
-"Unzuverlässiger Clusterprozess. Versuchen Sie es mit einer kleineren Anzahl "
-"von Anfangsclustern."
+msgstr "Unzuverlässiger Clusterprozess. Versuchen Sie es mit einer kleineren Anzahl von Anfangsclustern."
#: ../imagery/i.gensigset/subcluster.c:557
#, c-format
msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr ""
-"Habe eine singuläre Unter-Signatur mit der Nummer %d entfernt (%d "
-"verbleiben)."
+msgstr "Habe eine singuläre Unter-Signatur mit der Nummer %d entfernt (%d verbleiben)."
#: ../imagery/i.gensigset/get_train.c:35 ../imagery/i.gensig/get_train.c:32
msgid "Finding training classes..."
@@ -33842,8 +31078,7 @@
#: ../imagery/i.cca/main.c:88
msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
-"Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
+msgstr "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
#: ../imagery/i.cca/main.c:95 ../imagery/i.class/main.c:111
msgid "Name of input imagery subgroup"
@@ -33884,7 +31119,7 @@
#: ../imagery/i.cca/transform.c:24
msgid "Unable to allocate cell buffers."
-msgstr "Kann den Zellbuffer nicht belegen."
+msgstr "Kann keinen Speicher für Zellbuffer reservieren."
#: ../imagery/i.cca/transform.c:58
msgid "Transform completed.\n"
@@ -33910,9 +31145,7 @@
#: ../imagery/i.landsat.acca/main.c:70
#, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
msgstr ""
#: ../imagery/i.landsat.acca/main.c:104
@@ -33960,8 +31193,7 @@
msgstr ""
#: ../imagery/i.landsat.acca/main.c:159
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
msgstr ""
#: ../imagery/i.landsat.acca/main.c:164
@@ -34139,9 +31371,7 @@
#: ../imagery/i.fft/main.c:106
msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-"Raster Maske (MASK) gefunden, denken Sie über das Löschen nach (siehe MAN "
-"Seiten). Fahre trotzdem fort..."
+msgstr "Raster Maske (MASK) gefunden, denken Sie über das Löschen nach (siehe MAN Seiten). Fahre trotzdem fort..."
#: ../imagery/i.fft/main.c:129
#, c-format
@@ -34161,9 +31391,7 @@
msgstr " "
#: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Prestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
msgstr ""
#: ../imagery/i.evapo.pt/main.c:75
@@ -34307,20 +31535,12 @@
msgstr "Sites"
#: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
-msgstr ""
-"Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels "
-"eines Clusteralgorithmus."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
+msgstr "Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels eines Clusteralgorithmus."
#: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-"Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um "
-"eine unüberwachte Bildklassifikation zu erzeugen."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr "Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um eine unüberwachte Bildklassifikation zu erzeugen."
#: ../imagery/i.cluster/main.c:101
msgid "Initial number of classes"
@@ -34505,9 +31725,7 @@
#: ../imagery/i.cluster/main.c:286
msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr ""
-"Speicher voll! Bitte wiederholen Sie den Lauf mit einer kleineren "
-"Stichprobengröße."
+msgstr "Speicher voll! Bitte wiederholen Sie den Lauf mit einer kleineren Stichprobengröße."
#: ../imagery/i.cluster/main.c:292
#, c-format
@@ -34515,18 +31733,12 @@
msgstr "Stichprobengröße: %d Punkte\n"
#: ../imagery/i.cluster/main.c:295
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-"Nicht genügend Stichprobenpunkte. Bitte wiederholen Sie den Lauf mit einer "
-"größeren Stichprobe."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr "Nicht genügend Stichprobenpunkte. Bitte wiederholen Sie den Lauf mit einer größeren Stichprobe."
#: ../imagery/i.cluster/main.c:299
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-"Nicht genug nicht-null Stichprobenpunkte. Bitte überprüfen Sie die aktuelle "
-"Region (und Maske)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr "Nicht genug nicht-null Stichprobenpunkte. Bitte überprüfen Sie die aktuelle Region (und Maske)."
#: ../imagery/i.cluster/main.c:312
#, c-format
@@ -34545,9 +31757,7 @@
#: ../imagery/i.cluster/main.c:324
#, c-format
msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr ""
-"Kann die Signaturdatei <%s> für die Gruppe <%s> Untergruppe <%s> nicht "
-"erzeugen."
+msgstr "Kann die Signaturdatei <%s> für die Gruppe <%s> Untergruppe <%s> nicht erzeugen."
#: ../imagery/i.cluster/main.c:329
#, c-format
@@ -34852,9 +32062,7 @@
" Geben Sie Variablen manuell ein."
#: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
msgstr ""
#: ../imagery/i.evapo.mh/main.c:78
@@ -34901,16 +32109,11 @@
#: ../imagery/i.maxlik/main.c:65
msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
-"Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
+msgstr "Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
#: ../imagery/i.maxlik/main.c:67
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
-msgstr ""
-"Die Klassifikation basiert auf der Information der spektralen Signatur "
-"erzeugt von .cluster, i.class, oder i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
+msgstr "Die Klassifikation basiert auf der Information der spektralen Signatur erzeugt von .cluster, i.class, oder i.gensig."
#: ../imagery/i.maxlik/main.c:80
msgid "Generated by either i.cluster, i.class, or i.gensig"
@@ -34922,26 +32125,17 @@
#: ../imagery/i.maxlik/main.c:91
msgid "Name for raster map holding reject threshold results"
-msgstr ""
-"Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
+msgstr "Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
#: ../imagery/i.maxlik/open.c:27
#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> beinhaltet keine Rasterkarten. Die "
-"Untergruppe muss mindestens 2 Rasterkarten haben."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
+msgstr "Untergruppe <%s> der Gruppe <%s> beinhaltet keine Rasterkarten. Die Untergruppe muss mindestens 2 Rasterkarten haben."
#: ../imagery/i.maxlik/open.c:30
#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> hat nur eine Rasterkarte. Die Untergruppe "
-"muss mindestens 2 Rasterkarten haben."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
+msgstr "Untergruppe <%s> der Gruppe <%s> hat nur eine Rasterkarte. Die Untergruppe muss mindestens 2 Rasterkarten haben."
#: ../imagery/i.maxlik/open.c:47
#, c-format
@@ -34959,20 +32153,12 @@
msgstr "Signatur %d ist nicht gültig (singulär) - ignoriert."
#: ../imagery/i.class/main.c:94
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
-msgstr ""
-"Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt "
-"Trainingsgebiete zu markieren."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
+msgstr "Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt Trainingsgebiete zu markieren."
#: ../imagery/i.class/main.c:97
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
-msgstr ""
-"Die resultierende Signatur-Datei kann als Eingabe für i.maxlik oder als "
-"Start-Signatur für i.cluster verwendet werden."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
+msgstr "Die resultierende Signatur-Datei kann als Eingabe für i.maxlik oder als Start-Signatur für i.cluster verwendet werden."
#: ../imagery/i.class/main.c:116
msgid "File to contain result signatures"
@@ -34984,15 +32170,12 @@
#: ../imagery/i.class/main.c:133
msgid "You have a mask set. Unset mask and run again"
-msgstr ""
-"Es ist eine Maske gesetzt. Beseitigen Sie die Maske und versuchen Sie es "
-"erneut"
+msgstr "Es ist eine Maske gesetzt. Beseitigen Sie die Maske und versuchen Sie es erneut"
#: ../imagery/i.class/main.c:251
#, c-format
msgid "** The following raster maps in subgroup [%s] do not exist:"
-msgstr ""
-"** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
+msgstr "** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
#: ../imagery/i.class/main.c:260
#, c-format
@@ -35046,7 +32229,7 @@
#: ../imagery/i.class/signature.c:50 ../imagery/i.class/signature.c:55
msgid "Unable to allocate space for signature statistics."
-msgstr "Kann keinen Speicherplatz für die Signatur-Statistik belegen."
+msgstr "Kann keinen Speicher für Signatur-Statistik reservieren."
#: ../imagery/i.class/signature.c:82
msgid "prepare_signature: outline has odd number of points."
@@ -35140,326 +32323,263 @@
#: ../imagery/i.class/add_point.c:22
#, c-format
msgid "Can't mark another point. Only %d points allowed. Sorry."
-msgstr ""
-"Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
+msgstr "Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
-#~ msgid "Surface area estimation for rasters."
-#~ msgstr "Abschätzung der Größe der Rasteroberflächen."
+msgid "Raster map for which to edit null file"
+msgstr "Rasterkarte, bei der die NULL-Datei editiert werden soll."
-#~ msgid "Raster file for surface"
-#~ msgstr "Rasterkarte für die Oberfläche."
-#~ msgid "Raster map for which to edit null file"
-#~ msgstr "Rasterkarte, bei der die NULL-Datei editiert werden soll."
-#~ msgid "Writting buffers..."
-#~ msgstr "Schreibe Buffer..."
-#~ msgid "ASCII file to be converted to binary vector map"
-#~ msgstr "ASCII-Datei, die in eine Vektorkarte konvertiert werden soll."
-#~ msgid "If not given (or \"-\") reads from standard input"
-#~ msgstr "Lese von der Standardeingabe, wenn nicht angegeben (oder \"-\")."
#, fuzzy
-#~ msgid "Display the HTML man pages of GRASS GIS"
-#~ msgstr "Zeige die HTML-Handbuchseite von GRASS."
+msgid "Display the HTML man pages of GRASS GIS"
+msgstr "Zeige die HTML-Handbuchseite von GRASS."
#, fuzzy
-#~ msgid "Join column in table"
-#~ msgstr ""
-#~ "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
+msgid "Join column in table"
+msgstr "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
-#~ msgid "Join column in other table"
-#~ msgstr ""
-#~ "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
#, fuzzy
-#~ msgid ""
-#~ "Path to resulting ASCII file ('-' for standard output) or ASCII vector "
-#~ "name if '-o' is defined"
-#~ msgstr ""
-#~ "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der "
-#~ "Schalter '-o' angegeben ist."
+msgid "Path to resulting ASCII file ('-' for standard output) or ASCII vector name if '-o' is defined"
+msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
#, fuzzy
-#~ msgid "Unable to parse '%s'\n"
-#~ msgstr "Kann <%s> nicht lesen."
+msgid "Unable to parse '%s'\n"
+msgstr "Kann <%s> nicht lesen."
#, fuzzy
-#~ msgid "Driver <%s> doesn't support creating new fields"
-#~ msgstr "Der Treiber <%s> unterstützt die Erzeugung von Rasterdaten nicht."
+msgid "Driver <%s> doesn't support creating new fields"
+msgstr "Der Treiber <%s> unterstützt die Erzeugung von Rasterdaten nicht."
#, fuzzy
-#~ msgid "Unable to add new field <%s>"
-#~ msgstr "Kann 3Dview-Datei <%s> in <%s> nicht lesen."
+msgid "Unable to add new field <%s>"
+msgstr "Kann 3Dview-Datei <%s> in <%s> nicht lesen."
#, fuzzy
-#~ msgid ""
-#~ "Sets color rules for features in a vector map using a numeric attribute "
-#~ "column."
-#~ msgstr ""
-#~ "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
-#~ "numerischen Spalte der Attributtabelle."
+msgid "Sets color rules for features in a vector map using a numeric attribute column."
#, fuzzy
-#~ msgid "Name of raster map from which to copy color table"
-#~ msgstr "Rasterkarte, von der die Farbtabelle kopiert werden soll."
+msgid "Name of raster map from which to copy color table"
+msgstr "Rasterkarte, von der die Farbtabelle kopiert werden soll."
#, fuzzy
-#~ msgid "Name of file containing rules"
-#~ msgstr "Name der Datei mit den Signaturen."
+msgid "Name of file containing rules"
+msgstr "Name der Datei mit den Signaturen."
#, fuzzy
-#~ msgid "Creating support files for <%s>"
-#~ msgstr "Erstelle Support-Dateien für <%s>."
+msgid "Creating support files for <%s>"
+msgstr "Erstelle Support-Dateien für <%s>."
#, fuzzy
-#~ msgid "Title for new raster file."
-#~ msgstr "Titel für die neue Rasterkarte."
+msgid "Title for new raster file."
+msgstr "Titel für die neue Rasterkarte."
#, fuzzy
-#~ msgid "Unable it load G3d range"
-#~ msgstr "Kann die Ausdehnungs-Datei nicht lesen."
+msgid "Unable it load G3d range"
+msgstr "Kann die Ausdehnungs-Datei nicht lesen."
#, fuzzy
-#~ msgid "\raster\" and \"volume\" options are mutually exclusive"
-#~ msgstr ""
-#~ "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich "
-#~ "gegenseitig aus."
+msgid "\raster\" and \"volume\" options are mutually exclusive"
+msgstr "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig aus."
#, fuzzy
-#~ msgid "Raster3d map <%s> not found"
-#~ msgstr "Rasterkarte <%s> konnte nicht gefunden werden."
+msgid "Raster3d map <%s> not found"
+msgstr "Rasterkarte <%s> konnte nicht gefunden werden."
#, fuzzy
-#~ msgid "Calculating measure #%d <%s> (56 measures available)"
-#~ msgstr "Habe die Kenngröße #%d <%s> berechnet (56 Kenngrößen verfügbar)."
+msgid "Calculating measure #%d <%s> (56 measures available)"
+msgstr "Habe die Kenngröße #%d <%s> berechnet (56 Kenngrößen verfügbar)."
#, fuzzy
-#~ msgid "Exports the color table associated with a raster3d map layer."
-#~ msgstr "Exportiert die Farbtabelle einer Rasterkarte."
+msgid "Exports the color table associated with a raster3d map layer."
+msgstr "Exportiert die Farbtabelle einer Rasterkarte."
-#~ msgid "Could not close RASTER3D map"
-#~ msgstr "Konnte RASTER3D Karte nicht schließen"
+msgid "Could not close RASTER3D map"
+msgstr "Konnte RASTER3D Karte nicht schließen"
-#~ msgid "Could not close RASTER3D map <%s>"
-#~ msgstr "Konnte RASTER3D Karte <%s> nicht schließen."
+msgid "Could not close RASTER3D map <%s>"
+msgstr "Konnte RASTER3D Karte <%s> nicht schließen."
-#~ msgid "Name for v5d output file"
-#~ msgstr "Name der v5d Ausgabedatei."
+msgid "Name for v5d output file"
+msgstr "Name der v5d Ausgabedatei."
#, fuzzy
-#~ msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
-#~ msgstr ""
-#~ "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
+msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
+msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
#, fuzzy
-#~ msgid "Name for output flowline density raster map"
-#~ msgstr "Ausgabe-Rasterkarte der Fließdichte."
+msgid "Name for output flowline density raster map"
+msgstr "Ausgabe-Rasterkarte der Fließdichte."
#, fuzzy
-#~ msgid "Lists available GIS elements of the user-specified data type."
-#~ msgstr "Gibt die Daten des angegeben Typs auf die Standardausgabe."
+msgid "Lists available GIS elements of the user-specified data type."
+msgstr "Gibt die Daten des angegeben Typs auf die Standardausgabe."
#, fuzzy
-#~ msgid "Remove dangles:"
-#~ msgstr "Entferne Überstände (dangles)"
+msgid "Remove dangles:"
+msgstr "Entferne Überstände (dangles)"
#, fuzzy
-#~ msgid "Unable to create 3D vector and attribute table at same time"
-#~ msgstr ""
-#~ "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit "
-#~ "erstellen."
+msgid "Unable to create 3D vector and attribute table at same time"
+msgstr "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit erstellen."
#, fuzzy
-#~ msgid "Coordinates"
-#~ msgstr "Präzision der Koordinaten"
+msgid "Coordinates"
+msgstr "Präzision der Koordinaten"
#, fuzzy
-#~ msgid "vector, interpolation, kriging"
-#~ msgstr "Vektor, Interpolation"
+msgid "vector, interpolation, kriging"
+msgstr "Vektor, Interpolation"
#, fuzzy
-#~ msgid "maps for mosaic."
-#~ msgstr "2. Bild für das Mosaik."
+msgid "maps for mosaic."
+msgstr "2. Bild für das Mosaik."
#, fuzzy
-#~ msgid "reclass raster output map"
-#~ msgstr "Vektor-Ausgabekarte"
+msgid "reclass raster output map"
+msgstr "Vektor-Ausgabekarte"
#, fuzzy
-#~ msgid "Data source for OGR access"
-#~ msgstr "Datenquelle enthält %d Layer:"
+msgid "Data source for OGR access"
+msgstr "Datenquelle enthält %d Layer:"
#, fuzzy
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use. Layer name for OGR access."
-#~ msgstr ""
-#~ "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
-#~ "sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for OGR access."
+msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
#, fuzzy
-#~ msgid "Vector map for which to drop vector objects"
-#~ msgstr ""
-#~ "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
+msgid "Vector map for which to drop vector objects"
+msgstr "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
#, fuzzy
-#~ msgid "Layer of attribute table to use for selection"
-#~ msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
+msgid "Layer of attribute table to use for selection"
+msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
#, fuzzy
-#~ msgid ""
-#~ "WHERE conditions for vector delete, without 'where' keyword (e.g. "
-#~ "\"elevation IS NULL\")"
-#~ msgstr ""
-#~ "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z."
-#~ "B. cat=1 or col1/col2>1)."
+msgid "WHERE conditions for vector delete, without 'where' keyword (e.g. \"elevation IS NULL\")"
+msgstr "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. cat=1 or col1/col2>1)."
#, fuzzy
-#~ msgid "Raster map to use as mask"
-#~ msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
+msgid "Raster map to use as mask"
+msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
#, fuzzy
-#~ msgid "Overwrite existing file"
-#~ msgstr "Überschreibe existierende Maske (MASK)."
+msgid "Overwrite existing file"
+msgstr "Überschreibe existierende Maske (MASK)."
#, fuzzy
-#~ msgid "Name of input vector polygon map"
-#~ msgstr "Name der Vektorkarte (Polygone)."
+msgid "Name of input vector polygon map"
+msgstr "Name der Vektorkarte (Polygone)."
#, fuzzy
-#~ msgid "Name of MODIS product"
-#~ msgstr "Name der Eingabekarte."
+msgid "Name of MODIS product"
+msgstr "Name der Eingabekarte."
#, fuzzy
-#~ msgid "The names of tile/s to download"
-#~ msgstr "Die Zahl der Punkte, die verteilt werden sollen."
+msgid "The names of tile/s to download"
+msgstr "Die Zahl der Punkte, die verteilt werden sollen."
#, fuzzy
-#~ msgid "raster, import, copying"
-#~ msgstr "Raster, Import, Konvertierung"
+msgid "raster, import, copying"
+msgstr "Raster, Import, Konvertierung"
#, fuzzy
-#~ msgid "raster, export, copying"
-#~ msgstr "Raster, Export"
+msgid "raster, export, copying"
+msgstr "Raster, Export"
#, fuzzy
-#~ msgid "Name of input elevation map"
-#~ msgstr "Eingabe-Rasterkarte, die Höhenwerte enthält."
+msgid "Name of input elevation map"
+msgstr "Eingabe-Rasterkarte, die Höhenwerte enthält."
#, fuzzy
-#~ msgid "Name for output shaded relief map"
-#~ msgstr "Name der Ausgabe-Rasterkarte."
+msgid "Name for output shaded relief map"
+msgstr "Name der Ausgabe-Rasterkarte."
#, fuzzy
-#~ msgid "Existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-#~ msgstr "Existierende SPOT VGT NDVI HDF Datei (z.B. 0001_NDV.HDF)."
+msgid "Existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
+msgstr "Existierende SPOT VGT NDVI HDF Datei (z.B. 0001_NDV.HDF)."
#, fuzzy
-#~ msgid "zenith"
-#~ msgstr "Länge: %f\n"
+msgid "zenith"
+msgstr "Länge: %f\n"
#, fuzzy
-#~ msgid "topographic correction method"
-#~ msgstr "Name der Ausgabe-Rasterkarte, der Fließrichtungen."
+msgid "topographic correction method"
+msgstr "Name der Ausgabe-Rasterkarte, der Fließrichtungen."
#, fuzzy
-#~ msgid "Elevation file of unknown type"
-#~ msgstr "Höhe eines Punktes der Ebene."
+msgid "Elevation file of unknown type"
+msgstr "Höhe eines Punktes der Ebene."
#, fuzzy
-#~ msgid ""
-#~ "Cannot allocate memory for auxiliar matrix.Consider changing region "
-#~ "(resolution)"
-#~ msgstr ""
-#~ "Speicher für Hilfmatrix kann nicht bereitgestellt werden. Erwägen Sie die "
-#~ "Auflösung der Region zu ändern."
+msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
+msgstr "Speicher für Hilfmatrix kann nicht bereitgestellt werden. Erwägen Sie die Auflösung der Region zu ändern."
-#~ msgid "Converts a 3D raster map layer into an ASCII text file"
-#~ msgstr "Konvertiert eine 3D-Rasterkarte in eine ASCII-Datei"
+msgid "Converts a 3D raster map layer into an ASCII text file"
+msgstr "Konvertiert eine 3D-Rasterkarte in eine ASCII-Datei"
-#~ msgid ""
-#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-#~ msgstr ""
-#~ "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-"
-#~ "Rasterkarte. "
+msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
-#~ msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
-#~ msgstr "Konvertiert eine 3D-Rasterkarte (RASTER3D) in das VTK-ASCII-Format."
+msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
+msgstr "Konvertiert eine 3D-Rasterkarte (RASTER3D) in das VTK-ASCII-Format."
-#~ msgid "unable to close top raster map"
-#~ msgstr "Kann die obere Rasterkarte nicht schließen."
+msgid "unable to close top raster map"
+msgstr "Kann die obere Rasterkarte nicht schließen."
-#~ msgid "unable to close bottom raster map"
-#~ msgstr "Kann die untere Rasterkarte nicht schließen."
+msgid "unable to close bottom raster map"
+msgstr "Kann die untere Rasterkarte nicht schließen."
-#~ msgid ""
-#~ "Calculate the groundwater distance velocity vector field and write the x, "
-#~ "y, and z components to maps named name_[xyz]. Name is basename for the "
-#~ "new raster3d maps"
-#~ msgstr ""
-#~ "Berechne das Vektorfeld der Grundwassergeschwindigkeit und schreibe die "
-#~ "X, Y und Z Komponenten in die Karten name_[xyz]. Name ist der gemeinsame "
-#~ "Bestandteil der neuen raster3d Karten."
+msgid "Calculate the groundwater distance velocity vector field and write the x, y, and z components to maps named name_[xyz]. Name is basename for the new raster3d maps"
+msgstr "Berechne das Vektorfeld der Grundwassergeschwindigkeit und schreibe die X, Y und Z Komponenten in die Karten name_[xyz]. Name ist der gemeinsame Bestandteil der neuen raster3d Karten."
-#~ msgid ""
-#~ "Cannot create mask file: RASTER3D_MASK already exists!\n"
-#~ " Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
-#~ msgstr ""
-#~ "Kann keine Maskendatei erzeugen: RASTER3D_MASK existiert bereits.\n"
-#~ "Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu "
-#~ "löschen."
+msgid ""
+"Cannot create mask file: RASTER3D_MASK already exists!\n"
+" Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
+msgstr ""
+"Kann keine Maskendatei erzeugen: RASTER3D_MASK existiert bereits.\n"
+"Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu löschen."
-#~ msgid "Checking GDAl data type and nodata value"
-#~ msgstr "Prüfe GDAL Datentyp und NoData-Wert."
+msgid "Checking GDAl data type and nodata value"
+msgstr "Prüfe GDAL Datentyp und NoData-Wert."
-#~ msgid ""
-#~ "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-#~ "Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-#~ "reduction;Vertex Reduction Algorithm eliminates points close to each "
-#~ "other;reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter "
-#~ "than threshold and areas of area less than threshold;boyle;Boyle's "
-#~ "Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging "
-#~ "Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;"
-#~ "chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite "
-#~ "Splines;snakes;Snakes method for line smoothing;network;Network "
-#~ "generalization;displacement;Displacement of lines close to each other;"
-#~ msgstr ""
-#~ "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker "
-#~ "Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;"
-#~ "reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht "
-#~ "beieinander liegen;reumann;Reumann-Witkam Algorithmus;remove_small;"
-#~ "Entfernt Linien, die kürzer als der Schwellwert sind und Flächen, die "
-#~ "kleiner als der Schwellwert sind;boyle;Boyle's Vorausschauender-"
-#~ "Algorithmus;sliding_averaging;McMaster's Gleitender Mittelwert- "
-#~ "Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-"
-#~ "Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit "
-#~ "kubischen Hermite-Splines;snakes;Snake-Methoden zum glätten von Linien;"
-#~ "network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die "
-#~ "dicht beieinander liegen;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter than threshold and areas of area less than threshold;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
+msgstr "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht beieinander liegen;reumann;Reumann-Witkam Algorithmus;remove_small;Entfernt Linien, die kürzer als der Schwellwert sind und Flächen, die kleiner als der Schwellwert sind;boyle;Boyle's Vorausschauender-Algorithmus;sliding_averaging;McMaster's Gleitender Mittelwert- Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit kubischen Hermite-Splines;snakes;Snake-Methoden zum glätten von Linien;network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die dicht beieinander liegen;"
-#~ msgid "Number of vertices was reduced from %d to %d [%d%%]"
-#~ msgstr "Anzahl der Vertices wurden von %d auf %d [%d%%] reduziert."
+msgid "Number of vertices was reduced from %d to %d [%d%%]"
+msgstr "Anzahl der Vertices wurden von %d auf %d [%d%%] reduziert."
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ " (%s).\n"
-#~ msgstr ""
-#~ "\n"
-#~ "FEHLER: Benötigter Parameter <%s> wurde nicht angegeben:\n"
-#~ " (%s).\n"
+msgid ""
+"\n"
+"ERROR: Required parameter <%s> not set:\n"
+" (%s).\n"
+msgstr ""
+"\n"
+"FEHLER: Benötigter Parameter <%s> wurde nicht angegeben:\n"
+" (%s).\n"
-#~ msgid "also import quality map (SM status map layer) and filter NDVI map"
-#~ msgstr ""
-#~ "Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-"
-#~ "Karte."
+msgid "also import quality map (SM status map layer) and filter NDVI map"
-#~ msgid "Band to select"
-#~ msgstr "Zu selektierender Kanal"
+msgid "Band to select"
+msgstr "Zu selektierender Kanal"
+#~ msgid "Surface area estimation for rasters."
+#~ msgstr "Abschätzung der Größe der Rasteroberflächen."
+#~ msgid "Raster file for surface"
+#~ msgstr "Rasterkarte für die Oberfläche."
+#~ msgid "Writting buffers..."
+#~ msgstr "Schreibe Buffer..."
+#~ msgid "ASCII file to be converted to binary vector map"
+#~ msgstr "ASCII-Datei, die in eine Vektorkarte konvertiert werden soll."
+#~ msgid "If not given (or \"-\") reads from standard input"
+#~ msgstr "Lese von der Standardeingabe, wenn nicht angegeben (oder \"-\")."
+#~ msgid "Join column in other table"
+#~ msgstr "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
#~ msgid "Name of arc forward/both direction(s) cost column"
#~ msgstr "Kostenspalte für vorwärts/beide Richtungen der Kanten"
@@ -35490,11 +32610,8 @@
#~ msgid "Name of Arc cost column"
#~ msgstr "Spaltenname mit den Arc-Kosten"
-#~ msgid ""
-#~ "Enter -1 to keep original categories or the desired NEW category value"
-#~ msgstr ""
-#~ "Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der "
-#~ "erwünschte NEUE Kategoriewert."
+#~ msgid "Enter -1 to keep original categories or the desired NEW category value"
+#~ msgstr "Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der erwünschte NEUE Kategoriewert."
#~ msgid "Key column name"
#~ msgstr "Name der Schlüsselspalte."
@@ -35523,22 +32640,14 @@
#~ msgid "Line width column (%s) is not numeric."
#~ msgstr "Spalte mit der Linienbreite (%s) ist nicht numerisch."
-#~ msgid ""
-#~ "Error in color definition column '%s', feature id %d with cat %d: "
-#~ "colorstring '%s'"
-#~ msgstr ""
-#~ "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d: "
-#~ "Farbwert '%s'."
+#~ msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
+#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d: Farbwert '%s'."
#~ msgid "Error in color definition column '%s', feature id %d with cat %d"
-#~ msgstr ""
-#~ "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d"
+#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', Feature ID %d mit cat %d"
-#~ msgid ""
-#~ "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-#~ msgstr ""
-#~ "Fehler in der Symbolgrößen-Spalte (%s), Element %d mit cat %d: "
-#~ "Symbolgröße [%f]."
+#~ msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+#~ msgstr "Fehler in der Symbolgrößen-Spalte (%s), Element %d mit cat %d: Symbolgröße [%f]."
#~ msgid "Error in color definition column '%s': %d features affected"
#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', %d Feature betroffen."
@@ -35547,8 +32656,7 @@
#~ msgstr "Färbe die Polygone gemäß ihrer Z-Höhe."
#~ msgid "'layer' must be > 0 for 'where'."
-#~ msgstr ""
-#~ "Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
+#~ msgstr "Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
#~ msgid "'layer' must be > 0 for 'cats'."
#~ msgstr "'Layer' muss > 0 sein für den Parameter 'cats'."
@@ -35559,12 +32667,8 @@
#~ msgid "Color definition column not specified."
#~ msgstr "Farbspalte nicht angegeben."
-#~ msgid ""
-#~ "Error in color definition column (%s), area %d with cat %d: colorstring [%"
-#~ "s]"
-#~ msgstr ""
-#~ "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: "
-#~ "Farbwert [%s]."
+#~ msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+#~ msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: Farbwert [%s]."
#~ msgid "pg driver: column '%s', type %d is not supported"
#~ msgstr "PG-Treiber: Spalte '%s', Typ %d wird nicht unterstützt."
@@ -35575,12 +32679,8 @@
#~ msgid "Save placeholder raster map for use with d.legend"
#~ msgstr "Speichere Platzhalter Rasterkarte für Verwendung in d.legend."
-#~ msgid ""
-#~ "Name and type of the new column(s) (types depend on database backend, but "
-#~ "all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-#~ msgstr ""
-#~ "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank "
-#~ "ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
+#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+#~ msgstr "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
#~ msgid "Name for input source not specified"
#~ msgstr "Name der Eingabe-Qulle nicht angegeben."
@@ -35595,20 +32695,13 @@
#~ msgstr "Fehler beim Öffnen der G3D-Rasterkarte <%s>."
#~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr ""
+#~ msgstr "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig aus."
#~ msgid "-g and -a flags are mutually exclusive"
#~ msgstr "-g und -a schließen sich gegenseitig aus."
-#~ msgid ""
-#~ "Negative or no data pixel found. This module is not yet able to process "
-#~ "no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr ""
-#~ "Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in "
-#~ "Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit "
-#~ "dem Modul r.fillnulls oder anderen Füllalgorithmen."
+#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
+#~ msgstr "Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit dem Modul r.fillnulls oder anderen Füllalgorithmen."
#~ msgid "Too many iterations to required to find %s - giving up"
#~ msgstr "Zu viele Iterationen werden benötigt um %s zu finden - gebe auf."
@@ -35712,12 +32805,8 @@
#~ msgid "Error closing g3d vector map."
#~ msgstr "Fehler beim Schließen der G3D-Vektorkarte."
-#~ msgid ""
-#~ "The 2d and 3d region settings are different. The g3d settings are used to "
-#~ "adjust the 2d region."
-#~ msgstr ""
-#~ "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter "
-#~ "werden verwendet, um die 2D Region anzupassen."
+#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
+#~ msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter werden verwendet, um die 2D Region anzupassen."
#~ msgid "unable to close input 3d raster map"
#~ msgstr "Kann die Eingabe-3D-Rasterkarte nicht schließen."
@@ -35740,24 +32829,14 @@
#~ msgid "Error while writing grid. Disk full?"
#~ msgstr "Ein Fehler trat während des Lesens der Karte auf. Festplatte voll?"
-#~ msgid ""
-#~ "Converts co-ordinate system descriptions (i.e. projection information) "
-#~ "between various formats (including GRASS format)."
-#~ msgstr ""
-#~ "Konvertiert Beschreibungen von Koordinatensystemen (z.B. "
-#~ "Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-"
-#~ "Formats)."
+#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+#~ msgstr "Konvertiert Beschreibungen von Koordinatensystemen (z.B. Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-Formats)."
#~ msgid "Create/Edit"
#~ msgstr "Erzeuge/Editiere"
-#~ msgid ""
-#~ "Create new projection files (modifies current location unless 'location' "
-#~ "option specified)"
-#~ msgstr ""
-#~ "Erzeuge neue Projektionsdateien. Dies modifiziert die "
-#~ "Projektionsinformationen der aktuellen Location, solange nicht der "
-#~ "Parameter 'location' angegeben ist."
+#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
+#~ msgstr "Erzeuge neue Projektionsdateien. Dies modifiziert die Projektionsinformationen der aktuellen Location, solange nicht der Parameter 'location' angegeben ist."
#~ msgid "Location %s created!"
#~ msgstr "Location '%s' erstellt!"
@@ -35768,12 +32847,8 @@
#~ msgid "Force remove"
#~ msgstr "Erzwinge das Löschen"
-#~ msgid ""
-#~ "Color to erase with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-"
-#~ "Tripel (Semicolon als Trennzeichen)."
+#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+#~ msgstr "Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-Tripel (Semicolon als Trennzeichen)."
#~ msgid "Min-area & snap"
#~ msgstr "Min-Fläche & snap"
@@ -35877,12 +32952,8 @@
#~ msgid "Column to query"
#~ msgstr "Spalte, die abgefragt werden soll"
-#~ msgid ""
-#~ "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-#~ "col2>1)"
-#~ msgstr ""
+#~ msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
+#~ msgstr "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. cat=1 or col1/col2>1)."
#~ msgid "Old schema"
#~ msgstr "Altes Schema"
@@ -35908,12 +32979,8 @@
#~ msgid "Field separator"
#~ msgstr "Feld-Trennzeichen"
-#~ msgid ""
-#~ "number determines which table to use."
-#~ msgstr ""
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
#~ msgid "WHERE conditions of SQL statement without 'where' keyword"
#~ msgstr "WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'."
@@ -35936,26 +33003,20 @@
#~ msgid "Raster map in which to fill nulls"
#~ msgstr "Rasterkarte, in der die NULL-Zellen gefüllt werden sollen"
-#~ msgid ""
-#~ "Output raster map with nulls filled by interpolation from surrounding "
-#~ "values"
-#~ msgstr ""
-#~ "Gibt eine Rasterkarte aus, in der NULL-Gebiete durch Interpolation der "
-#~ "umgebenden Werte gefüllt wurden"
+#~ msgid "Output raster map with nulls filled by interpolation from surrounding values"
+#~ msgstr "Gibt eine Rasterkarte aus, in der NULL-Gebiete durch Interpolation der umgebenden Werte gefüllt wurden"
#~ msgid "Vector map from which to remove attribute table"
#~ msgstr "Vektorkarte, von der die Attributtabelle gelöscht werden soll."
#~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr ""
-#~ "Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
+#~ msgstr "Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
#~ msgid "Layer from which to drop linked attribute table"
#~ msgstr "Layer aus dem die Attributtabelle gelöscht werden soll."
#~ msgid "Vector map for which to drop attribute column"
-#~ msgstr ""
+#~ msgstr "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
#~ msgid "Layer where to drop column"
#~ msgstr "Layer, in dem eine Spalte gelöscht werden soll."
@@ -35964,8 +33025,7 @@
#~ msgstr "Präfix für Ausgabe TC-Rasterkarten"
#~ msgid "Vector map for which to add new attribute table"
-#~ msgstr ""
-#~ "Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
+#~ msgstr "Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
#~ msgid "vector, import, wfs"
#~ msgstr "Vektor, Import, WFS"
@@ -36005,12 +33065,8 @@
#~ msgid "Topographic correction method"
#~ msgstr "Methode der topographischen Korrektion"
-#~ msgid ""
-#~ "resolution"
-#~ msgstr ""
+#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
+#~ msgstr "Kann keinen Speicher für Hilfsmatrix reservieren. Erwägen Sie die Auflösung der Region zu ändern."
#~ msgid "raster3d, voxel, export"
#~ msgstr "3D-Raster, Voxel, Export"
@@ -36075,22 +33131,14 @@
#~ msgid "Recharge raster map in m^3/s"
#~ msgstr "Grundwasserneubildungskarte in m^3/s"
-#~ msgid ""
-#~ "The piezometric head result of the numerical calculation will be written "
-#~ "to this map"
-#~ msgstr ""
-#~ "Das resultierende piezometrisches Niveau der numerischen Berechnung wird "
-#~ "in diese Karte geschrieben."
+#~ msgid "The piezometric head result of the numerical calculation will be written to this map"
+#~ msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
-#~ msgid ""
-#~ "Use a sparse linear equation system, only available with iterative solvers"
-#~ msgstr ""
-#~ "Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative "
-#~ "Lösungsverfahren verfügbar."
+#~ msgid "Use a sparse linear equation system, only available with iterative solvers"
+#~ msgstr "Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative Lösungsverfahren verfügbar."
#~ msgid "The direct cholesky solver do not work with sparse matrices"
-#~ msgstr ""
-#~ "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+#~ msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
#~ msgid "raster3d, voxel, statistics"
#~ msgstr "3D-Raster, Voxel, Statistik"
@@ -36116,12 +33164,8 @@
#~ msgid "raster, statistics"
#~ msgstr "Raster, Statistik"
-#~ msgid ""
-#~ "Finds the median of values in a cover map within areas assigned the same "
-#~ "category value in a user-specified base map."
-#~ msgstr ""
-#~ "Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit "
-#~ "gleichen Werten in einer benutzerdefinierten Basiskarte."
+#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
+#~ msgstr "Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
#~ msgid "Base raster map <%s> not found"
#~ msgstr "Basis-Rasterkarte <%s> nicht gefunden."
@@ -36144,12 +33188,8 @@
#~ msgid "Error reading 'saturation' map"
#~ msgstr "Fehler beim Lesen der Datei 'Sättigung' (saturation)."
-#~ msgid ""
-#~ "The '-v' flag is superseded and will be removed in future. Please use '--"
-#~ "verbose' instead."
-#~ msgstr ""
-#~ "Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden "
-#~ "Sie stattdessen '--verbose'."
+#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+#~ msgstr "Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden Sie stattdessen '--verbose'."
#~ msgid "raster, import"
#~ msgstr "Raster, Import"
@@ -36166,13 +33206,8 @@
#~ msgid "Suppress single crossing error messages"
#~ msgstr "Unterdrücke Fehlermeldungen für 'single crossing'."
-#~ msgid ""
-#~ "The '-q' and '-n' flag is superseded and will be removed in future. "
-#~ "Please use '--quiet' instead."
-#~ msgstr ""
-#~ "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der "
-#~ "kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen "
-#~ "'--quiet'."
+#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
#~ msgstr "Exportiert eine Rasterkarte in eine Höhenfeld-Datei für POVRAY."
@@ -36183,12 +33218,8 @@
#~ msgid "raster, metadata"
#~ msgstr "Raster, Metadaten"
-#~ msgid ""
-#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
-#~ "quiet' instead."
-#~ msgstr ""
-#~ "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
-#~ "ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
#~ msgid "%s: [%s] not found"
#~ msgstr "%s: [%s] nicht gefunden."
@@ -36205,12 +33236,8 @@
#~ msgid "Name of filter file"
#~ msgstr "Name der Filterdatei"
-#~ msgid ""
-#~ "quiet' instead"
-#~ msgstr ""
-#~ "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft "
-#~ "entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
+#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
+#~ msgstr "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
#~ msgid "Cannot read raster row %d"
#~ msgstr "Kann die Zeile %d des Rasters nicht lesen."
@@ -36300,16 +33327,13 @@
#~ msgstr "Initialisiere die Ausgabe ."
#~ msgid "Unable to allocate memory for segment fbuff == NULL"
-#~ msgstr "Kann den Speicher für das Segment fbuff == NULL nicht allokieren."
+#~ msgstr "Kann keinen Speicher für Segment fbuff == NULL reservieren."
#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr ""
-#~ "Ausgabe-Rasterkarte <%s> nicht gefunden (keine Start-Punkte angegeben)."
+#~ msgstr "Ausgabe-Rasterkarte <%s> nicht gefunden (keine Start-Punkte angegeben)."
#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr ""
-#~ "Fehler beim allozieren von Speicher während des Lesens der Startpunktes "
-#~ "der Rasterkarte %s."
+#~ msgstr "Fehler beim allozieren von Speicher während des Lesens der Startpunktes der Rasterkarte %s."
#~ msgid "End of map!"
#~ msgstr "Ende der Karte!"
@@ -36357,9 +33381,7 @@
#~ msgstr "Horizont-datei Nr. %d <%s> nicht gefunden."
#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr ""
-#~ "Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS "
-#~ "Rasterkarte."
+#~ msgstr "Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS Rasterkarte."
#~ msgid "Required"
#~ msgstr "Benötigt"
@@ -36378,8 +33400,7 @@
#~ "Drücken Sie RETURN um fortzufahren -->"
#~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr ""
-#~ "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
+#~ msgstr "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
#~ msgid "Not enough room in history file"
#~ msgstr "Nicht genug Platz in der History-Datei."
@@ -36419,12 +33440,10 @@
#~ msgid ""
#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell "
-#~ "values are considered valid data? "
+#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
#~ msgstr ""
#~ "\n"
-#~ "Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen "
-#~ "mit NULL-Werten als gültige Daten angesehen werden?"
+#~ "Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen mit NULL-Werten als gültige Daten angesehen werden?"
#~ msgid "Error writing null row [%d]."
#~ msgstr "Fehler beim Schreiben der NULL-Zeile [%d]."
@@ -36454,9 +33473,7 @@
#~ msgstr " Fließkomma-Karte"
#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr ""
-#~ "Zeilen * Spalten * Bytes* pro Zelle musse genauso groß sein wie die Datei "
-#~ "(%lu)."
+#~ msgstr "Zeilen * Spalten * Bytes* pro Zelle musse genauso groß sein wie die Datei (%lu)."
#~ msgid "If you need help figuring them out, just hit ESC"
#~ msgstr "Für Hilfe beim Herausfinden bitte ESC drücken."
@@ -36477,14 +33494,10 @@
#~ msgstr "Für welchen Layer soll die Header-Datei editiert werden?"
#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr ""
-#~ "[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht "
-#~ "editieren! Führen Sie support für [%s] aus."
+#~ msgstr "[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht editieren! Führen Sie support für [%s] aus."
#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr ""
-#~ "[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header "
-#~ "nicht editieren!"
+#~ msgstr "[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht editieren!"
#~ msgid "Cannot open raster map [%s]!"
#~ msgstr "Kann die Rasterkarte [%s] nicht öffnen!"
@@ -36523,9 +33536,7 @@
#~ msgstr "Die Datei scheint komprimiert zu sein.\n"
#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr ""
-#~ "Höhstwahrscheinlich ist die Information aus dem Header falsch, aber ich "
-#~ "möchte, dass Sie entscheiden.\n"
+#~ msgstr "Höhstwahrscheinlich ist die Information aus dem Header falsch, aber ich möchte, dass Sie entscheiden.\n"
#~ msgid "The header for [%s] says the file is compressed. "
#~ msgstr "Der Header von [%s] sagt, dass die Datei komprimiert ist."
@@ -36533,12 +33544,8 @@
#~ msgid "The file does NOT appear to be compressed.\n"
#~ msgstr "Die Datei scheint NICHT komprimiert zu sein.\n"
-#~ msgid ""
-#~ "Header indicates %d row%s in the raster map, but the actual file format "
-#~ "indicates %d row%s"
-#~ msgstr ""
-#~ "Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber "
-#~ "die aktuelle Datei hat %d Zeile%s."
+#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
+#~ msgstr "Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber die aktuelle Datei hat %d Zeile%s."
#~ msgid "Unable to write header for [%s]."
#~ msgstr "Kann den Header für [%s] nicht schreiben."
@@ -36611,24 +33618,16 @@
#~ msgstr "Raster, Geometrie"
#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr ""
-#~ "Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung "
+#~ msgstr "Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung [-]."
#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr ""
-#~ "Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung "
+#~ msgstr "Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung [-]."
#~ msgid "time and insol_time are incompatible options"
#~ msgstr "time und insol_time sind nicht kompatible Optionen."
-#~ msgid ""
-#~ "Mode 1: instantaneous solar incidence angle & irradiance given a set "
-#~ "local time"
-#~ msgstr ""
-#~ "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei "
-#~ "bekannter lokaler Zeit"
+#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
+#~ msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
#~ msgid "elevin raster map <%s> not found"
#~ msgstr "elevin Rasterkarte <%s> nicht gefunden."
@@ -36664,16 +33663,13 @@
#~ msgstr "RGB Rasterkarte <%s> nicht gefunden"
#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr ""
-#~ "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur "
-#~ "Verfügung [r,g,b]"
+#~ msgstr "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur Verfügung [r,g,b]"
#~ msgid "Vector cell map <%s> not found"
#~ msgstr "Vektor-Zellen-Karte <%s> nicht gefunden."
#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr ""
-#~ "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
+#~ msgstr "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
#~ msgid "Converts raster maps into the VTK-Ascii format"
#~ msgstr "Konvertiert eine Rasterkarte in das VTK-ASCII-Format."
@@ -36685,8 +33681,7 @@
#~ msgstr "Raster, Quantisierung"
#~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
-#~ msgstr ""
-#~ "Setze Quantisierungsregeln für Eingabekarte(n) auf (%f %f) -> (%d,%d)"
+#~ msgstr "Setze Quantisierungsregeln für Eingabekarte(n) auf (%f %f) -> (%d,%d)"
#~ msgid "Quant table not changed for %s"
#~ msgstr "Quantisierungstabelle für <%s> wurde nicht geändert."
@@ -36730,17 +33725,11 @@
#~ msgid "Bilinear interpolation utility for raster map layers."
#~ msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr ""
-#~ "Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und "
-#~ "Breitengrad-Gittern zugewiesen wird."
+#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
+#~ msgstr "Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und Breitengrad-Gittern zugewiesen wird."
#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr ""
-#~ "Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp."
-#~ "interp'."
+#~ msgstr "Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp.interp'."
#~ msgid "Apply filter only to zero data values"
#~ msgstr "Filter nur auf 0-Werte anwenden."
@@ -36782,8 +33771,7 @@
#~ msgstr "Ausgabe-Rasterkarte der Transportkapazität [kg/ms]."
#~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#~ msgstr ""
-#~ "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
+#~ msgstr "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
#~ msgid "Output sediment concentration raster map [particle/m3]"
#~ msgstr "Ausgabe-Rasterkarte der Sedimentkonzentration [Partikel/m3]"
@@ -36798,9 +33786,7 @@
#~ msgstr "Raster, Abfluss, Hydrologie"
#~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr ""
-#~ "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/"
-#~ "hr]."
+#~ msgstr "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
#~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
#~ msgstr "Name der Rasterkarte der Abflußinfiltrationsrate [mm/hr]."
@@ -36817,12 +33803,8 @@
#~ msgid "Output simulation error raster map [m]"
#~ msgstr "Ausgabe-Rasterkarte des Simulationsfehlers [m]."
-#~ msgid ""
-#~ "Threshold water depth [m] (diffusion increases after this water depth is "
-#~ "reached)"
-#~ msgstr ""
-#~ "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese "
-#~ "Wassertiefe erreicht wurde)."
+#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
+#~ msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
#~ msgid "Unable to close input map"
#~ msgstr "Kann die Eingabekarte nicht schließen."
@@ -36836,19 +33818,11 @@
#~ msgid "raster, raster3d, voxel, conversion"
#~ msgstr "Raster, 3D-Raster, Voxel, Konvertieren"
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the currently defined region."
-#~ msgstr ""
-#~ "Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der "
-#~ "Auflösung der aktuellen Region."
+#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+#~ msgstr "Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der Auflösung der aktuellen Region."
-#~ msgid ""
-#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-#~ "resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr ""
-#~ "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-"
-#~ "Auflösung der DERZEITIG EINGESTELLTEN REGION."
+#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
#~ msgid "raster, transect"
#~ msgstr "Raster, Transekt"
@@ -36884,9 +33858,7 @@
#~ msgstr "Ausführliche Ausgabe."
#~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr ""
-#~ "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen "
-#~ "anderen Namen."
+#~ msgstr "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen anderen Namen."
#~ msgid "Name of raster map to contain results (several new layers)"
#~ msgstr "Name der Rasterkarten mit den Ergebnissen (mehrere Karten möglich)."
@@ -36910,8 +33882,7 @@
#~ msgstr "Spezifischer Ertrag [1/m]."
#~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#~ msgstr ""
-#~ "Anreicherungskarte (recharge map) z.B.: 6*10^-9 pro Zelle [m^3/s*m^2]."
+#~ msgstr "Anreicherungskarte (recharge map) z.B.: 6*10^-9 pro Zelle [m^3/s*m^2]."
#~ msgid "The map storing the numerical result [m]"
#~ msgstr "Karte der numerischen Ergebnisse [m]."
@@ -36939,9 +33910,7 @@
#~ msgstr "Sicker-Koeffizient der Drainage [1/s]."
#~ msgid "Use a sparse matrix, only available with iterative solvers"
-#~ msgstr ""
-#~ "Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren "
-#~ "verfügbar."
+#~ msgstr "Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren verfügbar."
#~ msgid "raster, profile"
#~ msgstr "Raster, Profil"
@@ -36987,12 +33956,8 @@
#~ msgid "Unable to open raster map <%s> in mapset <%s>"
#~ msgstr "Kann die Rasterkarte <%s> in Mapset <%s> nicht öffnen."
-#~ msgid ""
-#~ "Finds the average of values in a cover map within areas assigned the same "
-#~ msgstr ""
-#~ "Findet den Durchschnitt der Werte in einer Überlagerungskarte innerhalb "
-#~ "gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
+#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+#~ msgstr "Findet den Durchschnitt der Werte in einer Überlagerungskarte innerhalb gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
#~ msgid "%s: ERROR running %s command"
#~ msgstr "%s: Fehler beim Ausführen des Kommandos %s."
@@ -37007,9 +33972,7 @@
#~ msgstr "Modul zur Analyse von Wassereinzugsgebieten."
#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr ""
-#~ "Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten "
-#~ "Analyse ist."
+#~ msgstr "Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten Analyse ist."
#~ msgid "Input map: locations of real depressions"
#~ msgstr "Eingabekarte mit Orten realer Senken im Gebiet."
@@ -37018,12 +33981,10 @@
#~ msgstr "Eingabekarte mit der Größe des Oberflächenabfluss pro Zelle."
#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr ""
-#~ "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
+#~ msgstr "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr ""
-#~ "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+#~ msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
#~ msgid "Output map: number of cells that drain through each cell"
#~ msgstr "Ausgabekarte mit Anzahl der Zellen, die durch jede Zelle abfließt."
@@ -37041,8 +34002,7 @@
#~ msgstr "Ausgabekarte mit Einzugsgebietshälften mit eindeutigen Wert."
#~ msgid "Output map: useful for visual display of results"
-#~ msgstr ""
-#~ "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
+#~ msgstr "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
#~ msgstr "Ausgabekarte der Hanglängen und -Neigungsfaktoren (LS) für USLE."
@@ -37088,40 +34048,22 @@
#~ msgid ""
#~ "USAGE for basin delineation:\n"
-#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
#~ "\n"
#~ "USAGE for ARMSED FILE creation:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-#~ "ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
#~ "\n"
#~ "USAGE for slope length determination:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
-#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
-#~ "map]"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
#~ msgstr ""
#~ "VERWENDUNG für Einzugsgebietskartierung:\n"
#~ "\n"
#~ "VERWENDUNG für ARMSED-Datei Erzeugung:\n"
#~ "\n"
#~ "VERWENDUNG für Hanglängenberechnung:\n"
-#~ "map]"
#~ msgid "SECTION 2: A * Search."
#~ msgstr "ABSCHNITT 2: A * Suche."
@@ -37144,11 +34086,8 @@
#~ msgid "unable to open flow accumulation map layer"
#~ msgstr "Kann neue Fluss-Akkumulations-Karte nicht öffnen."
-#~ msgid ""
-#~ "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-#~ msgstr ""
-#~ "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den "
-#~ "Standardwert 300 MB."
+#~ msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+#~ msgstr "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den Standardwert 300 MB."
#~ msgid "unable to open accum file in valid_basins()"
#~ msgstr "Kann die accum-Datei in valid_basins() nicht öffnen."
@@ -37169,8 +34108,7 @@
#~ msgstr "Raster, Projektion, Transformation"
#~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr ""
-#~ "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+#~ msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
#~ msgid "Resolution of output map"
#~ msgstr "Auflösung der Ausgabe-Karte"
@@ -37231,9 +34169,7 @@
#~ msgstr "Nicht genügend Speicher für zero_array_cell."
#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr ""
-#~ "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
-#~ "schreiben."
+#~ msgstr "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht schreiben."
#~ msgid "raster, statistics, reclass"
#~ msgstr "Raster, Statistik, Reklassifizieren"
@@ -37247,12 +34183,8 @@
#~ msgid "Failed writing raster map row %d"
#~ msgstr "Schreiben der Zeile %d der Rasterkarte fehlgeschlagen."
-#~ msgid ""
-#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-#~ "resolution of the currently defined region."
-#~ msgstr ""
-#~ "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die "
-#~ "Pixelauflösung wird aus der aktuellen Region-Einstellung übernommen."
+#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+#~ msgstr "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung wird aus der aktuellen Region-Einstellung übernommen."
#~ msgid "Unable to read header of raster map <%s>"
#~ msgstr "Kann den Header der Rasterkarte <%s> nicht lesen."
@@ -37260,12 +34192,8 @@
#~ msgid "Can't set window"
#~ msgstr "Kann das Fenster nicht setzen."
-#~ msgid ""
-#~ "Raster map <%s> in mapset <%s> is a floating point map. Decimal values "
-#~ "will be rounded to integer!"
-#~ msgstr ""
-#~ "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. "
-#~ "Nachkommastellen werden auf ganze Zahlen gerundet!"
+#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
+#~ msgstr "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. Nachkommastellen werden auf ganze Zahlen gerundet!"
#~ msgid "raster, import, LIDAR"
#~ msgstr "Raster, Import, LIDAR"
@@ -37274,9 +34202,7 @@
#~ msgstr "Schreibe Karte, Zeile %d."
#~ msgid "Surface generation program from rasterized contours."
-#~ msgstr ""
-#~ "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit "
-#~ "Höheninformationen."
+#~ msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit Höheninformationen."
#~ msgid "Name of existing raster map containing contours"
#~ msgstr "Name der existierenden Rasterkarte, die Konturlinien enthält."
@@ -37284,18 +34210,11 @@
#~ msgid "Output elevation raster map"
#~ msgstr "Name der Ausgabe-Rasterkarte, die Höheninformationen enthält."
-#~ msgid ""
-#~ "Unused; retained for compatibility purposes, will be removed in future"
-#~ msgstr ""
-#~ "Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Diese Feature "
-#~ "wird in der Zukunft entfernt."
+#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
+#~ msgstr "Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Diese Feature wird in der Zukunft entfernt."
-#~ msgid ""
-#~ "Invoke slow, but memory frugal operation (generally not needed, will be "
-#~ "removed in future)"
-#~ msgstr ""
-#~ "Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht "
-#~ "benötigt, wird in Zukunft entfernt)."
+#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
+#~ msgstr "Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht benötigt, wird in Zukunft entfernt)."
#~ msgid "raster, color table"
#~ msgstr "Raster, Farbtabellen"
@@ -37312,24 +34231,14 @@
#~ msgid "Enter rules interactively"
#~ msgstr "Gebe Regeln interaktive ein"
-#~ msgid ""
-#~ "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must "
-#~ "be specified!"
-#~ msgstr ""
-#~ "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" "
-#~ "oder \"rules\" muss angegeben werden!"
+#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+#~ msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
-#~ msgid ""
-#~ "Interactive mode is incompatible with \"color\", \"rules\", and \"raster"
-#~ "\" options"
-#~ msgstr ""
-#~ "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules"
-#~ "\" und \"raster\"."
+#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
+#~ msgstr "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules\" und \"raster\"."
#~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr ""
-#~ "Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' "
-#~ "gewählt wurde)."
+#~ msgstr "Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' gewählt wurde)."
#~ msgid "Output map <%s> ignored"
#~ msgstr "Ausgabekarte <%s> ignoriert."
@@ -37338,8 +34247,7 @@
#~ msgstr "Noch nicht implementiert."
#~ msgid "An output raster map needs to be defined with method '%s'"
-#~ msgstr ""
-#~ "Eine Ausgabe-Rasterkarte muss mit der Methode '%s' definiert werden."
+#~ msgstr "Eine Ausgabe-Rasterkarte muss mit der Methode '%s' definiert werden."
#~ msgid "%s: running %s command"
#~ msgstr "%s: verarbeite %s Anweisung"
@@ -37468,9 +34376,7 @@
#~ msgstr "Kann Header der Rasterkarte nicht lesen."
#~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr ""
-#~ "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung "
-#~ "beachten, siehe auch den Schalter -l)."
+#~ msgstr "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung beachten, siehe auch den Schalter -l)."
#~ msgid "File type"
#~ msgstr "Dateityp"
@@ -37484,23 +34390,11 @@
#~ msgid "Range to be exported: %f - %f"
#~ msgstr "Zu exportierender Wertebereich: %f - %f"
-#~ msgid ""
-#~ "Mismatch between metadata nodata value and actual nodata value in "
-#~ "exported raster: specified nodata value %f gets converted to %d by "
-#~ "selected GDAL datatype."
-#~ msgstr ""
-#~ "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten "
-#~ "Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von "
-#~ "dem gewählten GDAL-Datentyp nach %d konvertiert."
+#~ msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
+#~ msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von dem gewählten GDAL-Datentyp nach %d konvertiert."
-#~ msgid ""
-#~ "Input raster map contains cells with NULL-value (no-data). The value %f "
-#~ "will be used to represent no-data values in the input map. You can "
-#~ "specify a nodata value with the %s option."
-#~ msgstr ""
-#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
-#~ "Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu "
-#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
#~ msgid "raster, null data"
#~ msgstr "Raster, NULL-Werte"
@@ -37512,9 +34406,7 @@
#~ msgstr "Raster, Export, VRML"
#~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-#~ msgstr ""
-#~ "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language "
-#~ "(VRML)."
+#~ msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
#~ msgid "Rowio_setup failed"
#~ msgstr "Rowio_setup fehlgeschlagen"
@@ -37529,8 +34421,7 @@
#~ msgstr "Schreiben der Zeile der Rasterkarte fehlgeschlagen."
#~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr ""
-#~ "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
+#~ msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
#~ msgid "Unable to create distance map <%s>"
#~ msgstr "Kann die Distanz-Karte <%s> nicht erzeugen."
@@ -37554,9 +34445,7 @@
#~ msgstr "(o/i) Höhenkarte des Einzugsgebiets (mit angewandter Maske (MASK))."
#~ msgid "(o) Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr ""
-#~ "(o) Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske "
-#~ "(MASK))."
+#~ msgstr "(o) Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske (MASK))."
#~ msgid "(i) Number of topographic index classes"
#~ msgstr "(i) Anzahl der Klassen des Topgraphischen Indexes."
@@ -37580,9 +34469,7 @@
#~ msgstr "(i) OPTIONAL: Ausgabe für einen angegebenen Zeitabschnitt."
#~ msgid "(i) OPTIONAL Output for given topographic index class"
-#~ msgstr ""
-#~ "(i) OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen "
-#~ "Index."
+#~ msgstr "(i) OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen Index."
#~ msgid "raster, sun position"
#~ msgstr "Raster, Sonnenposition"
@@ -37597,8 +34484,7 @@
#~ msgstr "Kann die Farbtabelle der Rasterkarte <%s> nicht schreiben."
#~ msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default: random)"
-#~ msgstr ""
-#~ "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
+#~ msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
#~ msgid "No (quiet) description during run"
#~ msgstr "Keine Beschreibung während der Bearbeitung."
@@ -37610,19 +34496,13 @@
#~ msgstr "Raster, Ausdünnung"
#~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr ""
-#~ "Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer "
-#~ "Rasterkarte abbilden."
+#~ msgstr "Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer Rasterkarte abbilden."
#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
#~ msgstr "%s: Fehler beim Lesen der Rasterkarte <%s> im Mapset <%s>."
-#~ msgid ""
-#~ "Creates a new map layer whose category values are based upon a "
-#~ "reclassification of the categories in an existing raster map layer."
-#~ msgstr ""
-#~ "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation "
-#~ "der Kategorien einer existierenden Rasterkarte basieren."
+#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+#~ msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
#~ msgid "Raster map to be reclassified"
#~ msgstr "Rasterkarte, die neu klassifiziert werden soll."
@@ -37642,11 +34522,8 @@
#~ msgid "Converts a raster map into a vector map layer."
#~ msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
-#~ msgid ""
-#~ "Do not build vector topology (use with care for massive point export)"
-#~ msgstr ""
-#~ "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von "
-#~ "extrem großen Punktmengen)."
+#~ msgid "Do not build vector topology (use with care for massive point export)"
+#~ msgstr "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von extrem großen Punktmengen)."
#~ msgid "Quiet - Do not show progress"
#~ msgstr "Schweigsam - keinen Fortschritt anzeigen."
@@ -37669,19 +34546,14 @@
#~ msgid "GIS Coincidence Tabulation Facility\n"
#~ msgstr "GIS Koinzidenz-Tabellierungsanlage\n"
-#~ msgid ""
-#~ "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr ""
-#~ "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu "
-#~ "vergleichen\n"
+#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
+#~ msgstr "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu vergleichen\n"
#~ msgid "The report can be made in one of 8 units."
#~ msgstr "DerBericht kann in einer von 8 Einheiten erstellt werden."
#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr ""
-#~ "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden "
-#~ "Buchstaben:"
+#~ msgstr "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden Buchstaben:"
#~ msgid " 'c': cells"
#~ msgstr " 'c': Zellen"
@@ -37723,11 +34595,8 @@
#~ msgid "'%s' being saved\n"
#~ msgstr "'%s' wird gespeichert\n"
-#~ msgid ""
-#~ "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr ""
-#~ "Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) "
-#~ "[n] "
+#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+#~ msgstr "Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) [n] "
#~ msgid ""
#~ "Do you wish it printed in 80 or 132 columns?\n"
@@ -37736,9 +34605,7 @@
#~ "Möchten Sie die Ausgabe in 80 oder 132 Spalten?\n"
-#~ msgid ""
-#~ "Do you wish to run this report with a different unit of measure? (y/n) "
-#~ "[y] "
+#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
#~ msgstr "Möchten Sie diesen Bericht mit einer anderen Maßeinheit? (y/n) [y] "
#~ msgid "Watershed basin creation program."
@@ -37793,8 +34660,7 @@
#~ msgstr "Wertebereich der Rasterkarte <%s> ist leer."
#~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr ""
-#~ "Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
+#~ msgstr "Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
#~ msgid "Integer data range of raster map <%s> is empty"
#~ msgstr "Integer Wertebereich der Rasterkarte <%s> ist leer."
@@ -37809,9 +34675,7 @@
#~ msgstr "Raster, Volumen"
#~ msgid "No clump map specified and MASK not set."
-#~ msgstr ""
-#~ "Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht "
-#~ "gesetzt."
+#~ msgstr "Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht gesetzt."
#~ msgid "Unable to find data map"
#~ msgstr "Kann die Rasterkarte nicht finden."
@@ -37858,12 +34722,8 @@
#~ msgid "Unable to get current region"
#~ msgstr "Kann die aktuelle Region nicht bekommen."
-#~ msgid ""
-#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
-#~ "densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr ""
-#~ "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope "
-#~ "areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
+#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+#~ msgstr "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
#~ msgid "Input elevation raster map"
#~ msgstr "Eingabe-Rasterkarte, mit Höheninformationen"
@@ -37899,8 +34759,7 @@
#~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr ""
-#~ "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
+#~ msgstr "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
#~ msgid "%s: can only do up to %d raster maps, sorry\n"
#~ msgstr "%s: Kann nur bis zu %d Rasterkarten abfragen, sorry\n"
@@ -37950,12 +34809,8 @@
#~ msgid "raster, geomorphology"
#~ msgstr "Raster, Geomorphologie"
-#~ msgid ""
-#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-#~ "map layer."
-#~ msgstr ""
-#~ "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) "
-#~ "GRASS Rasterkarte."
+#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+#~ msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) GRASS Rasterkarte."
#~ msgid "File containing weights"
#~ msgstr "Datei die Gewichte enthält."
@@ -37969,10 +34824,7 @@
#~ msgid "general, map management"
#~ msgstr "Allgemein, Kartenverwaltung"
-#~ msgid ""
-#~ "Copies available data files in the user's current mapset search path and "
-#~ "location to the appropriate element directories under the user's current "
-#~ "mapset."
+#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
#~ msgstr "Kopiert die vorhandenen Daten in die aktuelle Mapset/Location."
#~ msgid "%s file(s) to be copied"
@@ -37982,9 +34834,7 @@
#~ msgstr "[%s@%s] ist die Ausgangskarte für [%s]. Löschen wurde erzwungen."
#~ msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-#~ msgstr ""
-#~ "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: "
-#~ "%s"
+#~ msgstr "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
#~ msgid "%s file(s) to be removed"
#~ msgstr "%s Datei(en), die entfernt werden sollen."
@@ -37999,9 +34849,7 @@
#~ msgstr "Allgemein, Projektionen"
#~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr ""
-#~ "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der "
-#~ "Befehlszeile)."
+#~ msgstr "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der Befehlszeile)."
#~ msgid ""
#~ "\n"
@@ -38010,13 +34858,10 @@
#~ msgstr ""
#~ "\n"
#~ "\n"
-#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert "
-#~ "bereits!\n"
+#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert bereits!\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr ""
-#~ "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
+#~ msgid "Would you still like to overwrite the current projection information "
+#~ msgstr "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
#~ msgid "Error writing PROJ_INFO"
#~ msgstr "Fehler beim Schreiben der Datei PROJ_INFO."
@@ -38039,11 +34884,8 @@
#~ msgid "general, settings"
#~ msgstr "Allgemein, Einstellungen"
-#~ msgid ""
-#~ "GIS data directory (full path to the directory where the new location is)"
-#~ msgstr ""
-#~ "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die "
-#~ "neue Location befindet)."
+#~ msgid "GIS data directory (full path to the directory where the new location is)"
+#~ msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue Location befindet)."
#~ msgid "Erasing monitors..."
#~ msgstr "Lösche Monitore... "
@@ -38058,9 +34900,7 @@
#~ msgstr "Allgemein, Einstellungen, Suchpfad"
#~ msgid "Special characters: newline, space, comma, tab"
-#~ msgstr ""
-#~ "Trennzeichen für die Ausgabe: Zeilenumbruch, Komma, Leerzeichen oder "
-#~ "Tabulator."
+#~ msgstr "Trennzeichen für die Ausgabe: Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
#~ msgid "** no mapsets **\n"
#~ msgstr "** keine Mapsets **\n"
@@ -38099,9 +34939,7 @@
#~ msgstr "-s und -n schließen sich gegenseitig aus."
#~ msgid "One-character output separator, newline, comma, space, or tab"
-#~ msgstr ""
-#~ "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder "
-#~ "Tabulator."
+#~ msgstr "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
#~ msgid "Raster map <%s@%s>: %s"
#~ msgstr "Rasterkarte <%s@%s>: %s"
@@ -38121,14 +34959,8 @@
#~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
#~ msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten wxpython"
-#~ msgid ""
-#~ "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
-#~ "(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;"
-#~ "command line interface only"
-#~ msgstr ""
-#~ "wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS "
-#~ "Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d."
-#~ "m);text;Nur Kommandozeile"
+#~ msgid "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
+#~ msgstr "wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d.m);text;Nur Kommandozeile"
#~ msgid "Name of workspace file"
#~ msgstr "Name der Workspace-Datei."
@@ -38143,8 +34975,7 @@
#~ msgstr "Darstellung, Raster, Profil"
#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr ""
-#~ "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
+#~ msgstr "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
#~ msgid "Optional display raster"
#~ msgstr "optionale Ansichts-Rasterkarte"
@@ -38153,8 +34984,7 @@
#~ msgstr "Gebe Profildaten in Datei(en) mit dem Prefix 'name'."
#~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr ""
-#~ "Zu zeigendes Rasterkarte [%s] nicht gefunden. Verwende Profilraster."
+#~ msgstr "Zu zeigendes Rasterkarte [%s] nicht gefunden. Verwende Profilraster."
#~ msgid ""
#~ "\n"
@@ -38166,8 +34996,7 @@
#~ "Verwenden Sie die Maus, um eine Aktion auszuwählen."
#~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr ""
-#~ "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
+#~ msgstr "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
#~ msgid "Error opening cell-file"
#~ msgstr "Fehler beim Öffnen der Zell-Datei."
@@ -38275,8 +35104,7 @@
#~ msgstr "unten,oben,links,rechts"
#~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr ""
-#~ "Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
+#~ msgstr "Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
#~ msgid "Error choosing frame [%s]\n"
#~ msgstr "Fehler beim Wählen des Fensters [%s].\n"
@@ -38309,11 +35137,8 @@
#~ msgid "display, menu"
#~ msgstr "Darstellung, Menue"
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr ""
-#~ "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
+#~ msgid "Creates and displays a menu within the active frame on the graphics monitor."
+#~ msgstr "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
#~ msgid "Sets the color of the menu background"
#~ msgstr "Bestimmt die Farbe des Menü Hintergrunds."
@@ -38363,12 +35188,8 @@
#~ msgid "display, map management"
#~ msgstr "Darstellung, Kartenverwaltung"
-#~ msgid ""
-#~ "Prompts the user to select a GRASS data base file from among files "
-#~ "displayed in a menu on the graphics monitor."
-#~ msgstr ""
-#~ "Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü "
-#~ "präsentierten Dateien im Grafikfenster auszuwählen."
+#~ msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
+#~ msgstr "Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü präsentierten Dateien im Grafikfenster auszuwählen."
#~ msgid "Database element, one word description"
#~ msgstr "Datenbankelement, ein Wort Beschreibung"
@@ -38421,9 +35242,7 @@
#~ msgstr "Stelle die Anzahl der Farben dar."
#~ msgid "Placement as percentage of screen coordinates (0,0 is lower left)"
-#~ msgstr ""
-#~ "Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links "
-#~ "unten)."
+#~ msgstr "Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)."
#~ msgid "Use mouse to size & place legend"
#~ msgstr "Benutze Maus zum Plazieren und zur Größeneinstellung der Legende."
@@ -38440,63 +35259,35 @@
#~ msgid "display, position, querying"
#~ msgstr "Darstellung, Position, Abfrage"
-#~ msgid ""
-#~ "Identifies the geographic coordinates associated with point locations in "
-#~ "the active frame on the graphics monitor."
-#~ msgstr ""
-#~ "Identifiziert geographische Koordinaten an einem gegebenen Punkt im "
-#~ "Grafik-Fenster."
+#~ msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
+#~ msgstr "Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-Fenster."
#~ msgid "One mouse click only"
#~ msgstr "Nur ein Mausklick."
-#~ msgid ""
-#~ "Displays the rhumbline joining two user-specified points, in the active "
-#~ "frame on the user's graphics monitor."
-#~ msgstr ""
-#~ "Stellt im aktiven Grafikfenster eine Linie dar, die zwei vom Benutzer "
-#~ "angegebene Punkte verbindet."
+#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
+#~ msgstr "Stellt im aktiven Grafikfenster eine Linie dar, die zwei vom Benutzer angegebene Punkte verbindet."
-#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
-#~ msgstr ""
-#~ "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster "
-#~ "dar."
+#~ msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
+#~ msgstr "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster dar."
-#~ msgid ""
-#~ "Unix file containg graphing instructions, if not given reads from "
-#~ "standard input"
-#~ msgstr ""
-#~ "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht "
-#~ "angegeben ist, wird von der Standardeingabe gelesen."
+#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
+#~ msgstr "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht angegeben ist, wird von der Standardeingabe gelesen."
-#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ msgstr ""
-#~ "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B "
-#~ "Tripel (durch Doppelpunkte getrennt)."
+#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+#~ msgstr "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B Tripel (durch Doppelpunkte getrennt)."
#~ msgid "Use mouse to interactively place scale"
#~ msgstr "Benutze die Maus zum Interaktiven Plazieren des Maßstabs."
-#~ msgid ""
-#~ "The screen coordinates for top-left corner of label ([0,0] is top-left of "
-#~ "frame)"
-#~ msgstr ""
-#~ "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist "
-#~ "oben links)."
+#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
+#~ msgstr "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist oben links)."
#~ msgid "display, geometry"
#~ msgstr "Darstellung, Geometrie"
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr ""
-#~ "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-"
-#~ "Fensters zu zeichnen."
+#~ msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
+#~ msgstr "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-Fensters zu zeichnen."
#~ msgid "Screen position (percentage, [0,0] is bottom left)"
#~ msgstr "Koordinaten (in Prozent, [0,0] ist unten links)."
@@ -38541,8 +35332,7 @@
#~ msgstr "%s: Kann diese Schrift nicht lesen."
#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr ""
-#~ "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
+#~ msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
#~ msgid "%s: No FreeType definition file"
#~ msgstr "%s: Keine FreeType Definitionsdatei gefunden."
@@ -38580,41 +35370,23 @@
#~ msgid "Rendering method for filled polygons"
#~ msgstr "Render-Methode für gefüllte Polygone."
-#~ msgid ""
-#~ "d;use the display library basic functions (features: polylines);c;use the "
-#~ "display library clipping functions (features: clipping);l;use the display "
-#~ "library culling functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "d;Verwende grundlegende Funktion der Displaybibliothek (Feature: "
-#~ "Polylinien);c;Verwende die Clipping-Funkton der Displaybibliothek "
-#~ "(Feature: abschneiden);l;Verwende die Culling-Funkton der "
-#~ "Displaybibliothek (Feature: Beschneiden, Polylinien)"
+#~ msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
+#~ msgstr "d;Verwende grundlegende Funktion der Displaybibliothek (Feature: Polylinien);c;Verwende die Clipping-Funkton der Displaybibliothek (Feature: abschneiden);l;Verwende die Culling-Funkton der Displaybibliothek (Feature: Beschneiden, Polylinien)"
#~ msgid "Invalid rendering method <%s>"
#~ msgstr "Ungültige Render-Methode <%s>."
#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr ""
-#~ "Erstelle eine Liste von Kommandos zum Wiederherstellen der "
-#~ "Bildschirmgrafik."
+#~ msgstr "Erstelle eine Liste von Kommandos zum Wiederherstellen der Bildschirmgrafik."
#~ msgid "Name of frame(s) to save"
#~ msgstr "Name der Rahmen zum speichern."
-#~ msgid ""
-#~ "List of object numbers to remove which are displayed after \"#\". -1 for "
-#~ "the last object."
-#~ msgstr ""
-#~ "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" "
-#~ "angezeigt werden. -1 steht für das letzte Objekt."
+#~ msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
+#~ msgstr "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" angezeigt werden. -1 steht für das letzte Objekt."
-#~ msgid ""
-#~ "List of object numbers to move (\"from\" to \"to\"). remove= option will "
-#~ "be done first, if any."
-#~ msgstr ""
-#~ "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach"
-#~ "\"). Falls eine Option angegeben wurde, wird remove= als erstes "
-#~ "ausgeführt."
+#~ msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
+#~ msgstr "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach\"). Falls eine Option angegeben wurde, wird remove= als erstes ausgeführt."
#~ msgid "Save current frame"
#~ msgstr "Speichere aktuellen Rahmen."
@@ -38628,19 +35400,11 @@
#~ msgid "Unknown item type in pad: %s"
#~ msgstr "Unbekannter Typ in pad: %s"
-#~ msgid ""
-#~ "<%s> is a floating point map. Ignoring [lines] and drawing continuous "
-#~ "color ramp"
-#~ msgstr ""
-#~ "<%s> ist eine Fließkommakarte. Ignoriere [lines] und zeichne einen "
-#~ "kontinuierlichen Farbverlauf."
+#~ msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
+#~ msgstr "<%s> ist eine Fließkommakarte. Ignoriere [lines] und zeichne einen kontinuierlichen Farbverlauf."
-#~ msgid ""
-#~ "<%s> is a floating point map. Ignoring [cols] and drawing continuous "
-#~ "color ramp"
-#~ msgstr ""
-#~ "<%s> ist eine Fließkommakarte. Ignoriere [cols] und zeichne einen "
+#~ msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
+#~ msgstr "<%s> ist eine Fließkommakarte. Ignoriere [cols] und zeichne einen kontinuierlichen Farbverlauf."
#~ msgid "R_color file for [%s] not available"
#~ msgstr "Farbdatei für [%s] nicht vorhanden."
@@ -38670,8 +35434,7 @@
#~ msgstr "Es gibt das Grafikfenster <%s> nicht."
#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr ""
-#~ "Fehler - Grafikfenster '%s' wird von einem anderen Benutzer verwendet."
+#~ msgstr "Fehler - Grafikfenster '%s' wird von einem anderen Benutzer verwendet."
#~ msgid "Error - Locking mechanism failed"
#~ msgstr "Fehler - Sperrvorrichtung ist fehlgeschlagen."
@@ -38704,9 +35467,7 @@
#~ msgstr "Aufleuchten anschalten (ist langsamer)."
#~ msgid " Middle: toggle flash color\n"
-#~ msgstr ""
-#~ " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten "
-#~ "sollen.\n"
+#~ msgstr " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten sollen.\n"
#~ msgid "value [%.0f,%.0f] out of range [0-100]"
#~ msgstr "Wert [%.0f,%.0f] außerhalb der Spanne [0-100]"
@@ -38721,18 +35482,13 @@
#~ msgstr "Invertiere Kategorieliste."
#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr ""
-#~ "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
+#~ msgstr "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
#~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr ""
-#~ "Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen "
-#~ "Sie 'val=')."
+#~ msgstr "Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen Sie 'val=')."
#~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr ""
-#~ "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie "
-#~ "'cat=')."
+#~ msgstr "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie 'cat=')."
#~ msgid "No raster map exists in current window"
#~ msgstr "Es existiert keine Rasterkarte im aktuellen Fenster."
@@ -38764,51 +35520,23 @@
#~ msgid "No map is displayed in GRASS monitor"
#~ msgstr "Im Grafikfenster ist keine Karte dargestellt."
-#~ msgid ""
-#~ "shape;Display geometry of features;cat;Display category numbers of "
-#~ "features;topo;Display topology information (nodes, edges);dir;Display "
-#~ "direction of linear features;attr;Display selected attribute based on "
-#~ "'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
-#~ msgstr ""
-#~ "shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern "
-#~ "der Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;"
-#~ "Anzeige der Richtung von linearen Objekten;attr;Anzeige der ausgewählten "
-#~ "Attribute basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der "
-#~ "Objekte (nur für 3D Vektorkarten)"
+#~ msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
+#~ msgstr "shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern der Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;Anzeige der Richtung von linearen Objekten;attr;Anzeige der ausgewählten Attribute basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der Objekte (nur für 3D Vektorkarten)"
#~ msgid "Layer number (if -1, all layers are displayed)"
#~ msgstr "Layernummer (wenn -1, alle Layer werden dargestellt)."
-#~ msgid ""
-#~ "g;use the libgis render functions (features: clipping);r;use the raster "
-#~ "graphics library functions (features: polylines);d;use the display "
-#~ "library basic functions (features: polylines);c;use the display library "
-#~ "clipping functions (features: clipping);l;use the display library culling "
-#~ "functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "g;Verwende die Render-Funktion von libgis (Feature: abschneiden);r;"
-#~ "verwende dir Render-Funktion der Rastergrafikbibliothek (Feature: "
-#~ "Polylinien);d;Verwende die grundlegenden Funktionen der Displaybibliothek "
-#~ "(Feature: Polylinien);c;Verwende die Clipping-Funktion der "
-#~ "Displaybibliothek (Feature: abschneiden);l;Verwende die Culling-Funktion "
-#~ "der der Displaybibliothek (Feature: Beschneiden, Polylinien)"
+#~ msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
+#~ msgstr "g;Verwende die Render-Funktion von libgis (Feature: abschneiden);r;verwende dir Render-Funktion der Rastergrafikbibliothek (Feature: Polylinien);d;Verwende die grundlegenden Funktionen der Displaybibliothek (Feature: Polylinien);c;Verwende die Clipping-Funktion der Displaybibliothek (Feature: abschneiden);l;Verwende die Culling-Funktion der der Displaybibliothek (Feature: Beschneiden, Polylinien)"
-#~ msgid ""
-#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
-#~ "if the monitor is refreshed)"
-#~ msgstr ""
-#~ "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen "
-#~ "(Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster "
-#~ "aktualisiert wird)."
+#~ msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
+#~ msgstr "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen (Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster aktualisiert wird)."
#~ msgid "Unable to display areas, topology not available"
-#~ msgstr ""
-#~ "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
+#~ msgstr "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
#~ msgid "Unable to display lines by id, topology not available"
-#~ msgstr ""
-#~ "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht "
-#~ "vorhanden ist."
+#~ msgstr "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht vorhanden ist."
#~ msgid "Unable to display topology, not available"
#~ msgstr "Kann die Topologie nicht darstellen, da sie nicht vorhanden ist."
@@ -38820,8 +35548,7 @@
#~ msgstr "Vektordatei die Beispielpunkte enthält."
#~ msgid "Vector map attribute column to use for comparison"
-#~ msgstr ""
-#~ "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
+#~ msgstr "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
#~ msgid "Vector map to store differences"
#~ msgstr "Vektorkarte, die die Unterschiede beinhalten soll."
@@ -38829,24 +35556,17 @@
#~ msgid "Raster map to be sampled"
#~ msgstr "Rasterkarte, die abgefragt wird."
-#~ msgid ""
-#~ "Option scaling factor for values read from raster map. Sampled values "
-#~ "will be multiplied by this factor"
-#~ msgstr ""
-#~ "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit "
-#~ "diesem Faktor multipliziert."
+#~ msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
+#~ msgstr "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit diesem Faktor multipliziert."
#~ msgid "Bilinear interpolation (default is nearest neighbor)"
#~ msgstr "Bilineare Interpolation (Standard: Nächster Nachbar)."
#~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#~ msgstr ""
-#~ "Interpolation mittels kubischer Faltung (Standard: Nächster Nachbar)."
+#~ msgstr "Interpolation mittels kubischer Faltung (Standard: Nächster Nachbar)."
#~ msgid "Flags -b & -c are mutually exclusive. Choose only one."
-#~ msgstr ""
-#~ "Die Schalter -b und -c schließen sich gegenseitig aus. Bitte wählen Sie "
-#~ "nur Einen."
+#~ msgstr "Die Schalter -b und -c schließen sich gegenseitig aus. Bitte wählen Sie nur Einen."
#~ msgid "Checking vector points..."
#~ msgstr "Prüfe Vektorpunkte..."
@@ -38866,19 +35586,8 @@
#~ msgid "Required for operation 'connect'"
#~ msgstr "Benötigt für die Operation 'connect'."
-#~ msgid ""
-#~ "nodes;new point is placed on each node (line end) if doesn't exist;"
-#~ "connect;connect still unconnected points to vector network by inserting "
-#~ "new line(s);report;print to standard output {line_category "
-#~ "start_point_category end_point_category};nreport;print to standard output "
-#~ "{point_category line_category[,line_category...]}"
-#~ msgstr ""
-#~ "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, "
-#~ "wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des "
-#~ "Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe "
-#~ "{line_category start_point_category end_point_category} aus;nreport;Gebe "
-#~ "auf der Standardausgabe {point_category line_category [line_category...]}"
-#~ "aus"
+#~ msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
+#~ msgstr "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe {line_category start_point_category end_point_category} aus;nreport;Gebe auf der Standardausgabe {point_category line_category [line_category...]}aus"
#~ msgid "Output vector map must be specified"
#~ msgstr "Ausgabe-Vektorkarte muss angegeben werden."
@@ -38913,11 +35622,8 @@
#~ msgid "Query layer number (read from)"
#~ msgstr "Abfragelayernummer (lesen)"
-#~ msgid ""
-#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d"
-#~ "(egrees)"
-#~ msgstr ""
-#~ "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar),r(adians),d(egrees)"
+#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+#~ msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar),r(adians),d(egrees)"
#~ msgid "vector, statistics"
#~ msgstr "Vektor, Statistik"
@@ -38929,23 +35635,16 @@
#~ msgstr "Wenn 0, dann wird die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
#~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr ""
-#~ "Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn "
-#~ "layer > 0)."
+#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn layer > 0)."
#~ msgid "Need either 3D vector or layer and column with z values"
-#~ msgstr ""
-#~ "Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
+#~ msgstr "Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
#~ msgid "Layer but not column with z values given"
#~ msgstr "Ein Layer aber keine Spalte mit Z-Werten erhalten."
-#~ msgid ""
-#~ "No vector map of sparse points to interpolate was specified. "
-#~ "Interpolation will be done with <%s> vector map"
-#~ msgstr ""
-#~ "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die "
-#~ "Interpolation erfolgt mit der <%s> Vektorkarte"
+#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
+#~ msgstr "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die Interpolation erfolgt mit der <%s> Vektorkarte"
#~ msgid "vector, LIDAR, edges"
#~ msgstr "Vektor, LIDAR, Kanten"
@@ -38962,12 +35661,8 @@
#~ msgid "vector, LIDAR"
#~ msgstr "Vektor, LIDAR"
-#~ msgid ""
-#~ "vector, generalization, simplification, smoothing, displacement, network "
-#~ "generalization"
-#~ msgstr ""
-#~ "Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-"
-#~ "Generalisierung"
+#~ msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
+#~ msgstr "Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-Generalisierung"
#~ msgid "Vector based generalization."
#~ msgstr "Vektorbasierte Generalisierung."
@@ -38982,16 +35677,10 @@
#~ msgstr "Kann keinen Zentroid für die Fläche %d berechnen."
#~ msgid "New centroids were calculated, attribute attachment may be changed"
-#~ msgstr ""
-#~ "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert "
-#~ "haben."
+#~ msgstr "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert haben."
-#~ msgid ""
-#~ "Areas may have disappeared and/or area attribute attachment may have "
-#~ "changed"
-#~ msgstr ""
-#~ "Flächen können verschwunden sein und/oder die Zuordnung der Attribute "
-#~ "kann sich geändert haben."
+#~ msgid "Areas may have disappeared and/or area attribute attachment may have changed"
+#~ msgstr "Flächen können verschwunden sein und/oder die Zuordnung der Attribute kann sich geändert haben."
#~ msgid "Try v.clean tool=prune thresh=%f"
#~ msgstr "Versuchen Sie v.clean tool=prune thresh=%f"
@@ -39005,12 +35694,8 @@
#~ msgid "Convert OGR vector layers to GRASS vector map."
#~ msgstr "Konvertiere OGR Vektorlayer in das GRASS Vektorkarten."
-#~ msgid ""
-#~ "Unable to convert input map projection to GRASS format; cannot create new "
-#~ "location"
-#~ msgstr ""
-#~ "Kann die Projektion der Eingabekarte nicht in das GRASS-Format "
-#~ "konvertieren; kann daher keine neue Location erstellen."
+#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
+#~ msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; kann daher keine neue Location erstellen."
#~ msgid "Change dangles to lines:"
#~ msgstr "Ändere Überstände zu Linien:"
@@ -39018,11 +35703,8 @@
#~ msgid "vector, volume, conversion"
#~ msgstr "Vektor, Volumen, Konvertierung"
-#~ msgid ""
-#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-#~ "raster map layer."
-#~ msgstr ""
-#~ "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
+#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+#~ msgstr "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
#~ msgid "Column name (type must be numeric)"
#~ msgstr "Spaltenname (Spaltentyp muss numerisch sein)."
@@ -39030,12 +35712,8 @@
#~ msgid "vector, extract"
#~ msgstr "Vektor, extrahieren"
-#~ msgid ""
-#~ "Layer number (if -1, all features in all layers of given type are "
-#~ "extracted)"
-#~ msgstr ""
-#~ "Layernummer (wenn -1, dann werden alle Feature in allen Layern des "
-#~ "angegebenen Typs extrahiert)."
+#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
+#~ msgstr "Layernummer (wenn -1, dann werden alle Feature in allen Layern des angegebenen Typs extrahiert)."
#~ msgid "Layer 0 not supported"
#~ msgstr "Layer 0 wird nicht unterstützt."
@@ -39058,14 +35736,8 @@
#~ msgid "Vector points to be spatially perturbed"
#~ msgstr "Vektorpunkte die räumlich gestört werden sollen."
-#~ msgid ""
-#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
-#~ "parameter, the maximum, is needed. For a normal distribution, two "
-#~ "parameters, the mean and standard deviation, are required."
-#~ msgstr ""
-#~ "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird "
-#~ "nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind "
-#~ "zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
+#~ msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+#~ msgstr "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
#~ msgid "vector, geometry"
#~ msgstr "Vektor, Geometrie"
@@ -39091,17 +35763,11 @@
#~ msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
#~ msgstr "Spaltenname und -typ (z.B. INTEGER, DOUBLE PRECISION) für z Werte."
-#~ msgid ""
-#~ "If type is not given then DOUBLE PRECISION is used. Writes Z data to "
-#~ "column instead of 3D vector."
-#~ msgstr ""
-#~ "Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe "
-#~ "Z Werte in eine Spalte an Stelle einer 3D Vektorkarte."
+#~ msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
+#~ msgstr "Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe Z Werte in eine Spalte an Stelle einer 3D Vektorkarte."
#~ msgid "v.random can't create 3D vector and attribute table at same time"
-#~ msgstr ""
-#~ "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit "
-#~ "erstellen."
+#~ msgstr "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit erstellen."
#~ msgid "Using 'double precision' for column <%s>"
#~ msgstr "Verwende 'double precision' für die Spalte <%s>"
@@ -39110,13 +35776,10 @@
#~ msgstr "Konvertieren eine GRASS Vektorkarte zu einer VTK ASCII-Datei."
#~ msgid "Export numeric attribute table fields as VTK scalar variables"
-#~ msgstr ""
-#~ "Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
+#~ msgstr "Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
#~ msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-#~ msgstr ""
-#~ "Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. "
-#~ "Überspringe den Export."
+#~ msgstr "Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. Überspringe den Export."
#~ msgid "No numerical attributes found. Skipping export"
#~ msgstr "Keine numerischen Attribute gefunden. Überspringe den Export."
@@ -39125,8 +35788,7 @@
#~ msgstr "Fehler beim Lesen des Wertes des Attributes '%s'."
#~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr ""
-#~ "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
+#~ msgstr "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
#~ msgid "Parameter '%s' ignored in standard mode"
#~ msgstr "Parameter '%s' wird im Standard-Modus ignoriert."
@@ -39135,13 +35797,10 @@
#~ msgstr "habe Typ '%d' erhalten."
#~ msgid "Feature has more categories. Only first category (%d) is exported."
-#~ msgstr ""
-#~ "Feature hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde "
-#~ "exportiert."
+#~ msgstr "Feature hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde exportiert."
#~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr ""
-#~ "Kann Daten nicht aus der Tabelle selektieren<%s> (key %s, column %s)."
+#~ msgstr "Kann Daten nicht aus der Tabelle selektieren<%s> (key %s, column %s)."
#~ msgid "Column <%s>: unsupported data type"
#~ msgstr "Spalte <%s>: nicht unterstützter Datentyp."
@@ -39149,20 +35808,11 @@
#~ msgid "vector, paint labels"
#~ msgstr "Vektor, Zeichen Label"
-#~ msgid ""
-#~ "Numeric column to give precedence in case of overlapping labels. The "
-#~ "label with a smaller weight is hidden."
-#~ msgstr ""
-#~ "Numerische Spalte mit Werten, um den Vorrang bei überlappenden "
-#~ "Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird "
-#~ "verdeckt."
+#~ msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
+#~ msgstr "Numerische Spalte mit Werten, um den Vorrang bei überlappenden Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird verdeckt."
-#~ msgid ""
-#~ "Cannot load overlap weights. Column %s is not of numeric type in table <%"
-#~ "s>"
-#~ msgstr ""
-#~ "Kann die Überlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <%"
-#~ "s> ist nicht numerisch."
+#~ msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+#~ msgstr "Kann die Überlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <%s> ist nicht numerisch."
#~ msgid "%s: Unable to read font definition file; use the default"
#~ msgstr "%s: Kann die Font Definitionsdatei nicht lesen; nehme den Standard."
@@ -39207,16 +35857,13 @@
#~ msgstr "Vektorkarte mit Stichprobenpunkten."
#~ msgid "Output quadrant centres, number of points is written as category"
-#~ msgstr ""
-#~ "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie "
-#~ "ausgegeben."
+#~ msgstr "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie ausgegeben."
#~ msgid "Counting sites in quadrats..."
#~ msgstr "Zähle Sites in den Quadraten..."
#~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr ""
-#~ "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+#~ msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
#~ msgid "Quiet; No chatter"
#~ msgstr "Ruhe; Kein Geschwätz!"
@@ -39239,27 +35886,17 @@
#~ msgid "Unable to read MASK"
#~ msgstr "Kann die Maske (MASK) nicht lesen."
-#~ msgid ""
-#~ "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr ""
-#~ "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
+#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgstr "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
-#~ msgid ""
-#~ "Feature type(s). Combinations not supported by all output formats. "
-#~ "Default: first type found in input."
-#~ msgstr ""
-#~ "Feature-Typ(en): Kombinationen der Typen wird nicht von allen Formaten "
-#~ "unterstützt. Standard: der erste in der Eingabe gefundene Typ."
+#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
+#~ msgstr "Feature-Typ(en): Kombinationen der Typen wird nicht von allen Formaten unterstützt. Standard: der erste in der Eingabe gefundene Typ."
#~ msgid "OGR format"
#~ msgstr "OGR-Format."
-#~ msgid ""
-#~ "Export features with category (labeled) only. Otherwise all features are "
-#~ "exported"
-#~ msgstr ""
-#~ "Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten "
-#~ "werden alle Objekte exportiert."
+#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
+#~ msgstr "Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
#~ msgid "Skipping all boundaries that are not part of an area."
#~ msgstr "Überspringe alle Grenzen, die nicht zu einer Fläche gehören."
@@ -39270,97 +35907,44 @@
#~ msgid "Could not determine input map's feature type(s)."
#~ msgstr "Der Objekttyp der Eingabekarte konnte nicht bestimmt werden."
-#~ msgid ""
-#~ "The map contains islands. To preserve them in the output map, use the -c "
-#~ "flag"
-#~ msgstr ""
-#~ "Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der "
-#~ "Ausgabe-Karte zu erhalten."
+#~ msgid "The map contains islands. To preserve them in the output map, use the -c flag"
+#~ msgstr "Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der Ausgabe-Karte zu erhalten."
-#~ msgid ""
-#~ "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr ""
-#~ "%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
-#~ "Überprüfen Sie bitte den 'type'-Parameter."
+#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
+#~ msgstr "%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
-#~ msgid ""
-#~ "%d kernel(s) found, but not requested to be exported. Verify 'type' "
-#~ "parameter."
-#~ msgstr ""
-#~ "%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. "
-#~ "Überprüfen Sie den Parameter 'type'."
+#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
+#~ msgstr "%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie den Parameter 'type'."
-#~ msgid ""
-#~ "No points found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Punkte gefunden, die allerdings exportiert werden sollen. "
-#~ "Überspringe diesen Geometrie-Typ."
+#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Punkte gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometrie-Typ."
-#~ msgid ""
-#~ "No lines found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Linien gefunden, die allerdings exportiert werden sollen. "
-#~ "Überspringe diesen Geometry-Typ."
+#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Linien gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No boundaries found, but requested to be exported. Will skip this "
-#~ "geometry type."
-#~ msgstr ""
-#~ "Keine Grenzen gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Grenzen gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No areas found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Flächen gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Flächen gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No centroids found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Zentroide gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Zentroide gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No faces found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Faces gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Faces gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No kernels found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Kerne gefunden, die allerdings exportiert werden sollen. "
+#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Kerne gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "No volumes found, but requested to be exported. Will skip this geometry "
-#~ "type."
-#~ msgstr ""
-#~ "Keine Volumen gefunden, obwohl sie exportiert werden sollen. Überspringe "
-#~ "diesen Geometry-Typ."
+#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
+#~ msgstr "Keine Volumen gefunden, obwohl sie exportiert werden sollen. Überspringe diesen Geometry-Typ."
-#~ msgid ""
-#~ "Vector map <%s> is 3D. Use format specific layer creation options "
-#~ "(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-#~ msgstr ""
-#~ "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische "
-#~ "Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und "
-#~ "nicht 2D (Standard) zu exportieren"
+#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+#~ msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und nicht 2D (Standard) zu exportieren"
-#~ msgid ""
-#~ "(parameter 'lco') to export in 3D rather than 2D (default)"
-#~ msgstr ""
-#~ "Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D "
-#~ "(Standard) zu exportieren."
+#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
+#~ msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) zu exportieren."
#~ msgid "Key column '%s' not found"
#~ msgstr "Schlüsselspalte '%s' nicht gefunden."
@@ -39378,9 +35962,7 @@
#~ msgstr "Liest die Vertices einer Vektorlinie"
#~ msgid "Convex hull calculation requires at least three points. Exiting."
-#~ msgstr ""
-#~ "Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. "
-#~ "Beende mich."
+#~ msgstr "Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. Beende mich."
#~ msgid "Cannot open %s"
#~ msgstr "Kann %s nicht öffnen."
@@ -39389,8 +35971,7 @@
#~ msgstr "Vektor, Netzwerk, articulation points"
#~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr ""
-#~ "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten"
+#~ msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten"
#~ msgid "Patching vector map <%s@%s>..."
#~ msgstr "Kombiniere Vektorkarte <%s@%s>..."
@@ -39410,36 +35991,23 @@
#~ msgid "vector, buffer"
#~ msgstr "Vektor, Buffer"
-#~ msgid ""
-#~ "Creates a buffer around features of given type (areas must contain "
-#~ "centroid)."
-#~ msgstr ""
-#~ "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen "
-#~ "Zentroide enthalten)."
+#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
+#~ msgstr "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
#~ msgid "Unused"
#~ msgstr "Nicht genutzt"
#~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr ""
-#~ "Dies tut nichts. Es wurde nur für die Rückwärtskompatibilität erhalten"
+#~ msgstr "Dies tut nichts. Es wurde nur für die Rückwärtskompatibilität erhalten"
-#~ msgid ""
-#~ "This is an alias to the distance option. It is retained for backwards "
-#~ "compatibility"
-#~ msgstr ""
-#~ "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts "
-#~ "Kompatibilität erhalten"
+#~ msgid "This is an alias to the distance option. It is retained for backwards compatibility"
+#~ msgstr "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts Kompatibilität erhalten"
#~ msgid "Buffer distance in map units"
#~ msgstr "Bufferdistanz in Karteneinheiten"
-#~ msgid ""
-#~ "The buffer option has been replaced by the distance option and will be "
-#~ "removed in future."
-#~ msgstr ""
-#~ "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in "
-#~ "Zukunft entfernt."
+#~ msgid "The buffer option has been replaced by the distance option and will be removed in future."
+#~ msgstr "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in Zukunft entfernt."
#~ msgid "Use the distance option instead of the buffer option."
#~ msgstr "Verwende die Distanz-Option anstelle der Buffer-Option."
@@ -39468,27 +36036,14 @@
#~ msgid "Suppress display of residuals or other information"
#~ msgstr "Unterdrücke die Darstellung der Residuen oder anderer Informationen"
-#~ msgid ""
-#~ "Instead of points use transformation parameters (xshift, yshift, zshift, "
-#~ "xscale, yscale, zscale, zrot)"
-#~ msgstr ""
-#~ "Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, "
-#~ "zshift, xscale, yscale, zscale, zrot)."
+#~ msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
+#~ msgstr "Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
-#~ msgid ""
-#~ "The '%c' flag is deprecated and will be removed in future. Transformation "
-#~ "parameters are used automatically when no pointsfile is given."
-#~ msgstr ""
-#~ "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden "
-#~ "sein. Transformationsparameter werden automatisch verwendet wenn kein "
-#~ "pointsfile angegeben wurde."
+#~ msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
+#~ msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Transformationsparameter werden automatisch verwendet wenn kein pointsfile angegeben wurde."
-#~ msgid ""
-#~ "The '%c' flag is deprecated and will be removed in future. Please use '--"
-#~ "quiet' instead."
-#~ msgstr ""
-#~ "sein. Bitte verwenden Sie stattdessen '--quiet'."
+#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Bitte verwenden Sie stattdessen '--quiet'."
#~ msgid ""
#~ "\n"
@@ -39522,8 +36077,7 @@
#~ msgstr "Namde der Eingabe-Vektorkarte mit Linien."
#~ msgid "Name for output vector map where segments will be written"
-#~ msgstr ""
-#~ "Name der Ausgabe-Vektorkarte, in die die Segmente geschrieben werden."
+#~ msgstr "Name der Ausgabe-Vektorkarte, in die die Segmente geschrieben werden."
#~ msgid "Tests for normality for points."
#~ msgstr "Test auf Normalverteilung für Punkte."
@@ -39531,12 +36085,8 @@
#~ msgid "Doing log transformation"
#~ msgstr "Führe log Transformation aus."
-#~ msgid ""
-#~ "Calculates univariate statistics for attribute. Variance and standard "
-#~ "deviation is calculated only for points if specified."
-#~ msgstr ""
-#~ "Berechnet univariate Statistiken für die Attribute. Die Varianz und "
-#~ "Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+#~ msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
#~ msgid "Column name"
#~ msgstr "Spaltenname"
@@ -39554,7 +36104,7 @@
#~ msgstr "Vektor, Raster, Konvertierung"
#~ msgid "Cannot allocate memory for row buffer"
-#~ msgstr "Kann keinen Speicherplatz für Zeilenbuffer belegen."
+#~ msgstr "Kann keinen Speicher für Zeilenbuffer reservieren."
#~ msgid "Unable to write categories for raster map <%s>"
#~ msgstr "Kann die Kategorien für die Rasterkarte <%s> nicht schreiben."
@@ -39563,9 +36113,7 @@
#~ msgstr "Fläche ohne Zentroid (kann für Inseln OK sein)."
#~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr ""
-#~ "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
-#~ "Layern."
+#~ msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
#~ msgid "Output vector map where points will be written"
#~ msgstr "Ausgabe-Vektorkarte, in welche die Punkten geschrieben werden"
@@ -39608,36 +36156,26 @@
#~ msgstr "Unbekanntes Schlüsselwort <%s im Vektorheader."
#~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr ""
-#~ "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-"
-#~ "Vektordatei."
+#~ msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
#~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr ""
-#~ "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von "
-#~ "der Standardeingabe gelesen."
+#~ msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von der Standardeingabe gelesen."
#~ msgid "vector, external, import"
#~ msgstr "Vektor, External, Import"
#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr ""
-#~ "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu "
-#~ "einem OGR-Layer."
+#~ msgstr "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu einem OGR-Layer."
#~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr ""
-#~ "Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer "
-#~ "lediglichangezeigt."
+#~ msgstr "Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer lediglichangezeigt."
#~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. "
-#~ "Examples:\n"
+#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
#~ "\t\tESRI Shapefile: shapefile name\n"
#~ "\t\tMapInfo File: mapinfo file name"
#~ msgstr ""
-#~ "OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen "
-#~ "lediglich angezeigt. Beispiele:\n"
+#~ "OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen lediglich angezeigt. Beispiele:\n"
#~ "\t\tESRI Shapefile: Name des Shapefiles\n"
#~ "\t\tMapInfo File: Name der MapInfo-Datei"
@@ -39647,51 +36185,11 @@
#~ msgid "Cannot open data source"
#~ msgstr "Kann die Datenquelle nicht öffnen."
-#~ msgid ""
-#~ "break;break lines at each intersection;rmdupl;remove duplicate geometry "
-#~ "features (pay attention to categories!);rmdangle;remove dangles, "
-#~ "threshold ignored if < 0;chdangle;change the type of boundary dangle to "
-#~ "line, threshold ignored if < 0, input line type is ignored;rmbridge;"
-#~ "remove bridges connecting area and island or 2 islands;chbridge;change "
-#~ "the type of bridges connecting area and island or 2 islands from boundary "
-#~ "to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate "
-#~ "area centroids ('type' option ignored);bpol;break (topologically clean) "
-#~ "polygons (imported from non topological format, like ShapeFile). "
-#~ "Boundaries are broken on each point shared between 2 and more polygons "
-#~ "where angles of segments are different;prune;remove vertices in threshold "
-#~ "from lines and boundaries, boundary is pruned only if topology is not "
-#~ "damaged (new intersection, changed attachement of centroid), first and "
-#~ "last segment of the boundary is never changed;rmarea;remove small areas, "
-#~ "the longest boundary with adjacent area is removed;rmline;remove all "
-#~ "lines or boundaries of zero length, threshold is ignored;rmsa;remove "
-#~ "small angles between lines at nodes"
-#~ msgstr ""
-#~ "break;Teilt Linien an jeder Überschneidung;rmdupl;Entfernt doppelte "
-#~ "Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt "
-#~ "Überstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ändert "
-#~ "den Typ eines Überstands (dangle) zu einer Linie, Schwellwert wird "
-#~ "ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt "
-#~ "Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;"
-#~ "Ändert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln "
-#~ "verbindet von Grenze zu Linie;snap;Snapped Linien auf Vertices innerhalb "
-#~ "des Schwellwertes;rmdac;Entfernt doppelte Zentroide (Option 'type' wird "
-#~ "ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht "
-#~ "topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem "
-#~ "Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der "
-#~ "Segmente verschieden sind.;prune;Entfernt Vertices innerhalb des "
-#~ "Schwellwertes von Linien und Grenzen. Grenzen werden nur gesäubert, wenn "
-#~ "die Topologie nicht beschädigt wird ( neue Überschneidungen, veränderte "
-#~ "Zuordnung von Zentroiden); das erste und letzte Segment einer Grenze wird "
-#~ "nie geändert;rmarea;Entfernt kleine Flächen, die längste Grenze mit einer "
-#~ "benachbarten Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen "
-#~ "mit der Länge null, Schwellwert wird ignoriert;rmsa;Entfernt spitze "
-#~ "Winkel zwischen Linien an einem Knoten"
+#~ msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove smal
l areas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
+#~ msgstr "break;Teilt Linien an jeder Überschneidung;rmdupl;Entfernt doppelte Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt Überstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ändert den Typ eines Überstands (dangle) zu einer Linie, Schwellwert wird ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;Ändert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln verbindet von Grenze zu Linie;snap;Snapped Linien auf Vertices innerhalb des Schwellwertes;rmdac;Entfernt doppelte Zentroide (Option 'type' wird ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der Segmente verschieden sind.;prune;Entfernt Vertices innerhalb des Schwellwertes von Linien und Grenzen. Grenzen werden n
ur gesäubert, wenn die Topologie nicht beschädigt wird ( neue Überschneidungen, veränderte Zuordnung von Zentroiden); das erste und letzte Segment einer Grenze wird nie geändert;rmarea;Entfernt kleine Flächen, die längste Grenze mit einer benachbarten Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen mit der Länge null, Schwellwert wird ignoriert;rmsa;Entfernt spitze Winkel zwischen Linien an einem Knoten"
-#~ msgid ""
-#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#~ msgstr ""
-#~ "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug "
-#~ "(Standard: 0.0[,0.0,...])."
+#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: 0.0[,0.0,...])."
#~ msgid "Copying vector lines..."
#~ msgstr "Kopiere Vektorlinien..."
@@ -39710,13 +36208,10 @@
#~ "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
#~ msgstr ""
#~ "\n"
-#~ "%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, "
-#~ "z.B. %.2f %%"
+#~ "%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z.B. %.2f %%"
#~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#~ msgstr ""
-#~ "Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-"
-#~ "Vektoren)."
+#~ msgstr "Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
#~ msgid "Attribute table column with values to interpolate"
#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält."
@@ -39724,11 +36219,8 @@
#~ msgid "Required if layer > 0"
#~ msgstr "Erfordert wenn Layer >0"
-#~ msgid ""
-#~ "Power parameter; greater values assign greater influence to closer points"
-#~ msgstr ""
-#~ "Power-Parameter; größere Werte geben ein näheren Punkten ein stärkeres "
-#~ "Gewicht."
+#~ msgid "Power parameter; greater values assign greater influence to closer points"
+#~ msgstr "Power-Parameter; größere Werte geben ein näheren Punkten ein stärkeres Gewicht."
#~ msgid "No data points found"
#~ msgstr "Keine Datenpunkte gefunden."
@@ -39736,11 +36228,8 @@
#~ msgid "Create parallel line to input lines"
#~ msgstr "Erzeuge eine parallele Linie zu der eingegebenen Linie."
-#~ msgid ""
-#~ "Offset in map units, positive for right side, negative for left side."
-#~ msgstr ""
-#~ "Versatz in Karteneinheiten, positiv für die rechte und negativ für die "
-#~ "linke Seite."
+#~ msgid "Offset in map units, positive for right side, negative for left side."
+#~ msgstr "Versatz in Karteneinheiten, positiv für die rechte und negativ für die linke Seite."
#~ msgid "vector, geometry, buffer"
#~ msgstr "Vektor, Geometrie, Puffer"
@@ -39758,8 +36247,7 @@
#~ msgstr "Linien-Buffer... "
#~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr ""
-#~ "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
+#~ msgstr "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
#~ msgid "Areas buffers... "
#~ msgstr "Flächen-Buffer ..."
@@ -39768,12 +36256,10 @@
#~ msgstr "Vektor, Editieren, Geometrie"
#~ msgid "Creating new DB connection based on default mapset settings..."
-#~ msgstr ""
-#~ "Erzeuge neue DB-Verbindung, basierend auf den Mapset-Einstellungen..."
+#~ msgstr "Erzeuge neue DB-Verbindung, basierend auf den Mapset-Einstellungen..."
#~ msgid "Difference in x,y direction for moving feature or vertex"
-#~ msgstr ""
-#~ "Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
+#~ msgstr "Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
#~ msgid "Error reading ASCII file: '%s'"
#~ msgstr "Fehler beim Lesen der ASCII-Datei: '%s'."
@@ -39796,10 +36282,8 @@
#~ msgid "Print vector history instead of info"
#~ msgstr "Gebe den Werdegang anstelle einer Info aus."
-#~ msgid ""
-#~ "Print types/names of table columns for specified layer instead of info"
-#~ msgstr ""
-#~ "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
+#~ msgid "Print types/names of table columns for specified layer instead of info"
+#~ msgstr "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
#~ msgid "Print topology information only"
#~ msgstr "Gebe nur Informationen zur Topologie aus."
@@ -39889,22 +36373,10 @@
#~ msgstr "Vektor, Kategorie "
#~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr ""
-#~ "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+#~ msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
-#~ msgid ""
-#~ "add;add a new category;del;delete all categories of given layer;chlayer;"
-#~ "change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add "
-#~ "the value specified by cat option to the current category value;report;"
-#~ "print report (statistics), in shell style: layer type count min max;print;"
-#~ "print category values, more cats in the same layer are separated by '/'"
-#~ msgstr ""
-#~ "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines "
-#~ "gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert "
-#~ "von Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option "
-#~ "'cat' zu dem aktuellen Kategoriewert;report;Gebe einen Bericht "
-#~ "(Statistiken ) im Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe "
-#~ "Kategoriewerte aus, mehere cats im selben Layer werden durch '/' getrennt"
+#~ msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
+#~ msgstr "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert von Layer 3 auf Layer 1);sum;Addiert den Wert spezifiziert in der Option 'cat' zu dem aktuellen Kategoriewert;report;Gebe einen Bericht (Statistiken ) im Shell-Skript-Stil: Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, mehere cats im selben Layer werden durch '/' getrennt"
#~ msgid "Use z-coordinates (3D vector only)"
#~ msgstr "Verwende z-Koordinaten (nur bei 3D Vektorkarten)."
@@ -39928,8 +36400,7 @@
#~ msgstr "Ausgabekarte mit mittlerer Wölbung."
#~ msgid "Output cross-validation errors vector point file"
-#~ msgstr ""
-#~ "Gebe eine Vektor-Punktkarte mit den Fehlern der Kreuzvalidierung aus."
+#~ msgstr "Gebe eine Vektor-Punktkarte mit den Fehlern der Kreuzvalidierung aus."
#~ msgid "Output vector map showing quadtree segmentation"
#~ msgstr "Ausgabe-Vektorkarte mit der 'quadtree'-Segmentierung."
@@ -39937,22 +36408,14 @@
#~ msgid "Output vector map showing overlapping windows"
#~ msgstr "Ausgabe-Vektordatei, die die überlappenden Segmente beinhaltet."
-#~ msgid ""
-#~ "Name of the attribute column with values to be used for approximation (if "
-#~ "layer>0)"
-#~ msgstr ""
-#~ "Name der Attributspalte mit Werten, die für die Approximation verwendet "
-#~ "werden (wen der Layer >0)."
+#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
+#~ msgstr "Name der Attributspalte mit Werten, die für die Approximation verwendet werden (wen der Layer >0)."
#~ msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
-#~ msgstr ""
-#~ "z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist "
-#~ "erlaubt."
+#~ msgstr "z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist erlaubt."
#~ msgid "Only smoothing column defined, zcol or -z flag is missing"
-#~ msgstr ""
-#~ "Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z "
-#~ "fehlt."
+#~ msgstr "Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z fehlt."
#~ msgid ""
#~ "Processing all selected output files\n"
@@ -39962,9 +36425,7 @@
#~ "Werde %d Byte Plattenspeicher für temp-Dateien benötigen."
#~ msgid "Cannot write raster maps -- try to increase resolution"
-#~ msgstr ""
-#~ "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu "
-#~ "erhöhen."
+#~ msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
#~ msgid "vector, editing, digitization"
#~ msgstr "Vektor, Editiern, Digitalisieren"
@@ -39978,12 +36439,8 @@
#~ msgid "New empty map created."
#~ msgstr "Neue, leere Karte erstellt."
-#~ msgid ""
-#~ "Map <%s> does not exist in current mapset. Add flag -n to create a new "
-#~ "map."
-#~ msgstr ""
-#~ "Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den "
-#~ "Schalter -n, um eine neue Karte zu erzeugen."
+#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+#~ msgstr "Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den Schalter -n, um eine neue Karte zu erzeugen."
#~ msgid "Region restored to original extent."
#~ msgstr "Region auf die ursprünglich Ausdehnung zurückgesetzt."
@@ -39992,8 +36449,7 @@
#~ msgstr "Vektor, Netzwerk, Zentralitätsmaß"
#~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr ""
-#~ "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
+#~ msgstr "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
#~ msgid "When printing, limit to layer specified by the layer option"
#~ msgstr "Beim Druck auf die Layer in der Layer-Option beschränken"
@@ -40013,11 +36469,8 @@
#~ msgid "Layer is only used for WHERE SQL statement"
#~ msgstr "Layer wird nur für WHERE SQL Ausdrücke verwendet."
-#~ msgid ""
-#~ "No features drapped. Check Your computational region and input raster map."
-#~ msgstr ""
-#~ "Keine Feature wurden drapiert. Überprüfen Sie die aktuelle Region und die "
-#~ "Eingabe-Rasterkarte."
+#~ msgid "No features drapped. Check Your computational region and input raster map."
+#~ msgstr "Keine Feature wurden drapiert. Überprüfen Sie die aktuelle Region und die Eingabe-Rasterkarte."
#~ msgid "vector, raster, aggregation"
#~ msgstr "Vektor, Raster, Aggregation"
@@ -40070,49 +36523,26 @@
#~ msgid "postscript, map, printing"
#~ msgstr "Postscript, Karte, Drucken"
-#~ msgid ""
-#~ "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr ""
-#~ "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten"
-#~ "(Rand) )."
+#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
+#~ msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
-#~ msgid ""
-#~ "File containing mapping instructions (or use input=- to enter from "
-#~ "keyboard)"
-#~ msgstr ""
-#~ "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie "
-#~ "input=- für eine interaktive Eingabe über die Tastatur)."
+#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
+#~ msgstr "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie input=- für eine interaktive Eingabe über die Tastatur)."
#~ msgid "PostScript output file"
#~ msgstr "PostScript Ausgabedatei"
-#~ msgid ""
-#~ "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr ""
-#~ "Maßstab der Ausgabekarte, z.B. 1:25000 (standardmäßig: Anpassung an die "
-#~ "Seite)"
+#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
+#~ msgstr "Maßstab der Ausgabekarte, z.B. 1:25000 (standardmäßig: Anpassung an die Seite)"
-#~ msgid ""
-#~ "Using <%s> from the command line is depreciated. Please use the <%s> "
-#~ "mapping instruction instead. The parameter <%s> will be removed in future "
-#~ "versions of GRASS."
-#~ msgstr ""
-#~ "Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte "
-#~ "verwenden Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <%"
-#~ "s> wird in zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
+#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
+#~ msgstr "Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte verwenden Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <%s> wird in zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
#~ msgid "Current region cannot be set."
#~ msgstr "Aktuelle Region kann nicht gesetzt werden."
-#~ msgid ""
-#~ "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE "
-#~ "mapping instruction. This mapping instruction is superseded and will be "
-#~ "removed in future versions of GRASS. Please use --verbose instead."
-#~ msgstr ""
-#~ "Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der "
-#~ "Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt "
-#~ "und wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte "
-#~ "verwenden Sie stattdessen '--verbose'."
+#~ msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
+#~ msgstr "Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt und wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte verwenden Sie stattdessen '--verbose'."
#~ msgid "Cannot set GRASS_VERBOSE variable."
#~ msgstr "Kann die GRASS_VERBOSE Variable nicht setzen."
@@ -40142,16 +36572,10 @@
#~ msgstr "Datenbank, Attributtabelle, Verbindungseinstellungen"
#~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr ""
-#~ "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
-#~ "beendet sich."
+#~ msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
-#~ msgid ""
-#~ "Do not use this option if schemas are not supported by driver/database "
-#~ "server"
-#~ msgstr ""
-#~ "Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre "
-#~ "Datenbank / Server unterstützt werden."
+#~ msgid "Do not use this option if schemas are not supported by driver/database server"
+#~ msgstr "Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre Datenbank / Server unterstützt werden."
#~ msgid "database, SQL"
#~ msgstr "Datenbank, SQL"
@@ -40180,25 +36604,17 @@
#~ msgid "The password was stored in file"
#~ msgstr "Das Passwort wurde in einer Datei gespeichert."
-#~ msgid ""
-#~ "Divides active display into two frames & displays maps/executes commands "
-#~ "in each frame."
-#~ msgstr ""
-#~ "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt "
-#~ "Befehle in beiden Fenstern aus."
+#~ msgid "Divides active display into two frames & displays maps/executes commands in each frame."
+#~ msgstr "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt Befehle in beiden Fenstern aus."
#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr ""
-#~ "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden "
-#~ "soll."
+#~ msgstr "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden soll."
#~ msgid "Enter command to execute in 1st frame"
#~ msgstr "Geben Sie den Befehl an, der im 1. Rahmen ausgeführt werden soll."
#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr ""
-#~ "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden "
-#~ "soll."
+#~ msgstr "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden soll."
#~ msgid "Enter command to execute in 2nd frame"
#~ msgstr "Geben Sie den Befehl an, der im 2. Rahmen ausgeführt werden soll."
@@ -40224,24 +36640,17 @@
#~ msgid "Region sensitive output"
#~ msgstr "Regionsensitive Ausgabe"
-#~ msgid ""
-#~ "Creation option to the output format driver. Multiple options may be "
-#~ "listed"
-#~ msgstr ""
-#~ "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere "
-#~ "Optionen angegeben werden."
+#~ msgid "Creation option to the output format driver. Multiple options may be listed"
+#~ msgstr "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere Optionen angegeben werden."
#~ msgid "Metadata key passed on the output dataset if possible"
-#~ msgstr ""
-#~ "Metadaten werden, wen möglich, an den Ausgabedatensatz weitergegeben."
+#~ msgstr "Metadaten werden, wen möglich, an den Ausgabedatensatz weitergegeben."
#~ msgid "raster, elevation"
#~ msgstr "Raster, Höhenwerte"
#~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-#~ msgstr ""
-#~ "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs "
-#~ "Frontend)."
+#~ msgstr "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs Frontend)."
#~ msgid "miscellaneous, projection"
#~ msgstr "Verschiedenes, Projektion"
@@ -40249,20 +36658,14 @@
#~ msgid "Input coordinate file (omit to read from stdin)"
#~ msgstr "Eingabe-Koordinatendatei (auslassen für lesen von stdin)."
-#~ msgid ""
-#~ "Script style output in CSV format respecting the field separator settings"
-#~ msgstr ""
-#~ "Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-"
-#~ "Einstellungen."
+#~ msgid "Script style output in CSV format respecting the field separator settings"
+#~ msgstr "Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-Einstellungen."
#~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
-#~ msgstr ""
-#~ "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr "
-#~ "aus)."
+#~ msgstr "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr aus)."
#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr ""
-#~ "Speichert den Inhalte des aktiven Grafikfensters in einer Grafikdatei."
+#~ msgstr "Speichert den Inhalte des aktiven Grafikfensters in einer Grafikdatei."
#~ msgid "display, export"
#~ msgstr "Anzeige, Export"
@@ -40280,17 +36683,13 @@
#~ msgstr "Bilder"
#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr ""
-#~ "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der "
-#~ "Auflösung)."
+#~ msgstr "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der Auflösung)."
#~ msgid "Compression for PNG files"
#~ msgstr "Komprimierung für PNG-Dateien."
#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-#~ msgstr ""
-#~ "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. "
-#~ "Dateigröße)."
+#~ msgstr "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. Dateigröße)."
#~ msgid "File size/quality for JPEG files"
#~ msgstr "Dateigröße/-qualität für JPEG-Dateien."
@@ -40316,11 +36715,8 @@
#~ msgid "GeoTIFF metadata key(s) and value(s) to add"
#~ msgstr "GeoTIFF Metadaten Schlüsselwort(e) und Wert(e)"
-#~ msgid ""
-#~ "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-#~ msgstr ""
-#~ "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas "
-#~ "voneinander."
+#~ msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+#~ msgstr "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas voneinander."
#~ msgid "Set background color to black (white default)"
#~ msgstr "Setze die Hintergrundfarbe auf schwarz (Standard: weiß)."
@@ -40332,9 +36728,7 @@
#~ msgstr "Verwende der Cairo-Treiber um das Bild zu rendern."
#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr ""
-#~ "Stelle die Orientierung der Seite auf Querformat (für die PostScript-"
-#~ "Ausgabe)."
+#~ msgstr "Stelle die Orientierung der Seite auf Querformat (für die PostScript-Ausgabe)."
#~ msgid "Do not crop away margins"
#~ msgstr "Schneide die Ränder nicht ab."
@@ -40352,9 +36746,7 @@
#~ msgstr "Name der Eingabe-Rasterkarte (MIR; tm5 | qbird_red | spot3)."
#~ msgid "Tool to maintain GRASS extensions in local GRASS installation."
-#~ msgstr ""
-#~ "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu "
-#~ "verwalten."
+#~ msgstr "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
#~ msgid "general, extensions"
#~ msgstr "Allgemein, Erweiterungen"
@@ -40366,9 +36758,7 @@
#~ msgstr "Anzeige, Diagramm"
#~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr ""
-#~ "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *."
-#~ "mosaic-Karten."
+#~ msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
#~ msgid "raster, imagery, mosaicking"
#~ msgstr "Raster, Bildverarbeitung, Mosaikieren"
@@ -40400,12 +36790,8 @@
#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
#~ msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar)"
-#~ msgid ""
-#~ "Value to update the column with (varchar values have to be in single "
-#~ "quotes, e.g. 'grass')"
-#~ msgstr ""
-#~ "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in "
-#~ "einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
+#~ msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
+#~ msgstr "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
#~ msgid "Name of raster map to print in legend"
#~ msgstr "Name der Rasterkarte, wie er in der Legende erscheinen soll."
@@ -40414,8 +36800,7 @@
#~ msgstr "Position der vertikalen Legenden Trennelemente (in Prozent)."
#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr ""
-#~ "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
+#~ msgstr "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
#~ msgid "display, export, GPS"
#~ msgstr "Anzeige, Export, GPS"
@@ -40442,9 +36827,7 @@
#~ msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-#~ msgstr ""
-#~ "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 "
+#~ msgstr "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
#~ msgid "Create inverse MASK from specified 'maskcats' list"
#~ msgstr "Erzeuge eine inverse Maske aus der angegebenen 'maskcats' Liste."
@@ -40458,35 +36841,20 @@
#~ msgid "vector, export, GPS"
#~ msgstr "Vektor, Export, GPS"
-#~ msgid ""
-#~ "The database must be in form printed by v.db.connect -g, i.e. with "
-#~ "substituted variables"
-#~ msgstr ""
-#~ "Die Datenbank muß in der Form angegeben werden , wie sie von v.db.connect "
-#~ "-g ausgegeben wird, z.B mit ersetzten Variablen."
+#~ msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
+#~ msgstr "Die Datenbank muß in der Form angegeben werden , wie sie von v.db.connect -g ausgegeben wird, z.B mit ersetzten Variablen."
-#~ msgid ""
-#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-#~ "using gdalwarp."
-#~ msgstr ""
-#~ "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und "
-#~ "relative DGMs mit Hilfe von gdalwarp."
+#~ msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+#~ msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
#~ msgid "raster, imagery, import"
#~ msgstr "Raster, Bildverarbeitung, Import"
-#~ msgid ""
-#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-#~ "single band"
-#~ msgstr ""
-#~ "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein "
-#~ "einzelnen Kanal umrechnen."
+#~ msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
+#~ msgstr "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein einzelnen Kanal umrechnen."
-#~ msgid ""
-#~ "Set color rules for features in a vector using a numeric attribute column."
-#~ msgstr ""
-#~ "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
-#~ "numerischen Spalte der Attributtabelle."
+#~ msgid "Set color rules for features in a vector using a numeric attribute column."
+#~ msgstr "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
#~ msgid "vector, color table"
#~ msgstr "Vektor, Farbtabellen"
@@ -40504,8 +36872,7 @@
#~ msgstr "Zeichnen aller Fenster erneut."
#~ msgid "Do not preserve individual regions when redrawing all frames"
-#~ msgstr ""
-#~ "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
+#~ msgstr "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
#~ msgid "Slide show of GRASS raster/vector maps."
#~ msgstr "Diashow der GRASS Raster- / Vektorkarten."
@@ -40517,9 +36884,7 @@
#~ msgstr "Zeige eher Vektorkarten als Rasterkarten."
#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr ""
-#~ "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten "
-#~ "anzusehen."
+#~ msgstr "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten anzusehen."
#~ msgid "Map number show across the monitor"
#~ msgstr "Zeige die Kartenummer waagerecht im Grafikfenster."
@@ -40528,19 +36893,13 @@
#~ msgstr "Zeige die Kartenummer senkrecht im Grafikfenster."
#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr ""
-#~ "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt "
-#~ "an."
+#~ msgstr "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt an."
#~ msgid "Number of seconds to pause between slides"
#~ msgstr "Pause zwischen den Bildern in Sekunden."
-#~ msgid ""
-#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-#~ "vector map."
-#~ msgstr ""
-#~ "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine "
-#~ "Vektorkarte."
+#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+#~ msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine Vektorkarte."
#~ msgid "vector, import, GPS"
#~ msgstr "Vektor, Import, GPS"
@@ -40581,22 +36940,14 @@
#~ msgid "vector, import, gazetteer"
#~ msgstr "Vektor, Import, Gazetteer"
-#~ msgid ""
-#~ "Calculates univariate statistics from a raster map based on vector "
-#~ "polygons and uploads statistics to new attribute columns."
-#~ msgstr ""
-#~ "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
-#~ "und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+#~ msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
#~ msgid "Name of vector polygon map"
#~ msgstr "Name der Vektorkarte (Polygone)."
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use"
-#~ msgstr ""
-#~ "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
-#~ "sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
+#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
#~ msgid "Name of raster map to calculate statistics from"
#~ msgstr "Name der Rasterkarte für die Statistiken berechnet werden sollen."
@@ -40668,8 +37019,7 @@
#~ msgstr "Raster, Bildverarbeitung, Farben"
#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr ""
-#~ "Selektiert/Startet das angegebene Grafikfenster in der angegebenen Größe."
+#~ msgstr "Selektiert/Startet das angegebene Grafikfenster in der angegebenen Größe."
#~ msgid "Display monitor to start"
#~ msgstr "Grafikfensters, das gestartet werden soll."
@@ -40680,12 +37030,8 @@
#~ msgid "Height in pixels of new display monitor"
#~ msgstr "Höhe des neuen Grafikfensters in Pixel."
-#~ msgid ""
-#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-#~ "file into a vector map."
-#~ msgstr ""
-#~ "Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer "
-#~ "GPS-Download-Datei in eine Vektorkarte. "
+#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+#~ msgstr "Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer GPS-Download-Datei in eine Vektorkarte. "
#~ msgid "Import waypoints"
#~ msgstr "Importiere Wegpunkte"
@@ -40703,16 +37049,10 @@
#~ msgstr "Gerät oder Datei, von der Daten importiert werden sollen.ei."
#~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr ""
-#~ "Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte "
-#~ "Formate)."
+#~ msgstr "Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte Formate)."
-#~ msgid ""
-#~ "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is "
-#~ "assumed"
-#~ msgstr ""
-#~ "Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/"
-#~ "Lon WGS84 angenommen."
+#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+#~ msgstr "Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/Lon WGS84 angenommen."
#~ msgid "Folder to save downloaded data to"
#~ msgstr "Verzeichnis um heruntergeladene Daten zu speichern."
@@ -40775,9 +37115,7 @@
#~ msgstr "Name der Schummerungskarte."
#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr ""
-#~ "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im "
-#~ "Heimat-Verzeichnis."
+#~ msgstr "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im Heimat-Verzeichnis."
#~ msgid "Name of PNG file"
#~ msgstr "Name der PNG-Datei."
@@ -40856,15 +37194,13 @@
#~ msgstr "Fehler beim Schreiben der Zeile %d."
#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr ""
-#~ "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> "
-#~ "gespeichert."
+#~ msgstr "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> gespeichert."
#~ msgid "imagery, geometry"
#~ msgstr "Bildverarbeitung, Geometrie"
#~ msgid "Unable to allocate the input row buffer"
-#~ msgstr "Kann keinen Speicherplatz für den Eingabe-Zeilenbuffer belegen."
+#~ msgstr "Kann keinen Speicher für Eingabe-Zeilenbuffer reservieren."
#~ msgid "imagery, color transformation, RGB, HIS"
#~ msgstr "Bildverarbeitung, Farbtransformation, RGB, HIS"
@@ -40878,19 +37214,11 @@
#~ msgid "imagery, FFT"
#~ msgstr "Bildverarbeitung, FFT"
-#~ msgid ""
-#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
-#~ "probably wasn't created by i.fft"
-#~ msgstr ""
-#~ "Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte "
-#~ "wurde wahrscheinlich nicht mit i.fft erstellt."
+#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+#~ msgstr "Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte wurde wahrscheinlich nicht mit i.fft erstellt."
-#~ msgid ""
-#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
-#~ msgstr ""
-#~ "Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. "
-#~ "Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
+#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+#~ msgstr "Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
#~ msgid "Power 2 values: %d rows %d columns"
#~ msgstr "'hoch zwei'-Werte: %d Zeilen %d Spalten."
@@ -40924,13 +37252,8 @@
#~ msgid "imagery, orthorectify"
#~ msgstr "Bildverarbeitung, Orthorektifikation"
-#~ msgid ""
-#~ "Interactively creates or modifies entries in a camera initial exposure "
-#~ "station file for imagery group referenced by a sub-block."
-#~ msgstr ""
-#~ "Erzeugt oder ändert interaktiv Einträge in der Datei mit der "
-#~ "Anfangsposition der Kamera für die Bildgruppe referenziert durch "
-#~ "Unterblöcke."
+#~ msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
+#~ msgstr "Erzeugt oder ändert interaktiv Einträge in der Datei mit der Anfangsposition der Kamera für die Bildgruppe referenziert durch Unterblöcke."
#~ msgid "Name of imagery group for ortho-rectification"
#~ msgstr "Name der Bildgruppe für Orthorektifikation."
@@ -40938,22 +37261,17 @@
#~ msgid "Group [%s] not found"
#~ msgstr "Gruppe [%s] nicht gefunden."
-#~ msgid ""
-#~ "Interactively select and modify the imagery group camera reference file."
+#~ msgid "Interactively select and modify the imagery group camera reference file."
#~ msgstr "Wähle und ändere die Kamerareferenzdatei der Bildgruppe interaktiv."
#~ msgid "Name of camera reference file to use"
#~ msgstr "Name der zu verwendenden Kamerareferenzdatei."
#~ msgid "Enter a camera reference file to be used with this imagery group"
-#~ msgstr ""
-#~ "Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe "
-#~ "verwendet werden soll."
+#~ msgstr "Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe verwendet werden soll."
#~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-#~ msgstr ""
-#~ "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die "
-#~ "Kameradatei [%s]."
+#~ msgstr "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei [%s]."
#~ msgid "Interactively mark fiducial or reseau points on an image."
#~ msgstr "Markiere Rahmenmarken oder Reseaupunkte interaktiv in einem Bild."
@@ -40973,12 +37291,8 @@
#~ msgid "Could not open elevation raster"
#~ msgstr "Kann die Rasterkarte mit Höheninformationen nicht öffnen."
-#~ msgid ""
-#~ "Orthorectifies an image by using the image to photo coordinate "
-#~ "transformation matrix."
-#~ msgstr ""
-#~ "Orthorektifiziert ein Bild mittels der Foto zu Koordinaten "
-#~ "Transformationsmatrix."
+#~ msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
+#~ msgstr "Orthorektifiziert ein Bild mittels der Foto zu Koordinaten Transformationsmatrix."
#~ msgid "Raster map with camera angle relative to ground surface"
#~ msgstr "Rasterkarte mit Kamerawinkel relativ zur Oberfläche"
@@ -40993,8 +37307,7 @@
#~ msgstr "Schlechtes Format in der Kamerareferenzdatei der Gruppe <%s>."
#~ msgid "Bad format in initial exposure station file for group <%s>"
-#~ msgstr ""
-#~ "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe <%s>."
+#~ msgstr "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe <%s>."
#~ msgid "No target elevation model selected for group <%s>"
#~ msgstr "Kein Ziel-Höhenmodell ausgewählt für die Gruppe <%s>."
@@ -41083,28 +37396,19 @@
#~ msgstr "Bitte wählen Sie ein Ziel für die Gruppe"
#~ msgid "Creates control points on an image to be ortho-rectified."
-#~ msgstr ""
-#~ "Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden "
-#~ "soll."
+#~ msgstr "Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden soll."
-#~ msgid ""
-#~ "Name of image to be rectified which will be initially drawn on screen"
-#~ msgstr ""
-#~ "Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf "
-#~ "dem Bildschirm dargestellt."
+#~ msgid "Name of image to be rectified which will be initially drawn on screen"
+#~ msgstr "Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf dem Bildschirm dargestellt."
-#~ msgid ""
-#~ "Name of a map from target mapset which will be initially drawn on screen"
-#~ msgstr ""
-#~ "Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm "
-#~ "dargestellt wird."
+#~ msgid "Name of a map from target mapset which will be initially drawn on screen"
+#~ msgstr "Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm dargestellt wird."
#~ msgid "No initial camera exposure station for group [%s]"
#~ msgstr "Keine Anfangs-Kameraposition für die Gruppe [%s]."
#~ msgid "Bad format in initial camera exposure station for group [%s]"
-#~ msgstr ""
-#~ "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe [%s]."
+#~ msgstr "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe [%s]."
#~ msgid "No photo points for group [%s]"
#~ msgstr "Keine Bildpositionen für die Gruppe [%s]."
@@ -41184,8 +37488,7 @@
#~ "Berechne lokale Kamerawinkel? "
#~ msgid "Enter a name for the camera angle map:"
-#~ msgstr ""
-#~ "Geben Sie einen Namen für die Karte mit den Kamera-Winkelangaben ein:"
+#~ msgstr "Geben Sie einen Namen für die Karte mit den Kamera-Winkelangaben ein:"
#~ msgid "Map name <%s> is illegal"
#~ msgstr "Kartenname <%s> ist ein ungültiger Name."
@@ -41280,7 +37583,7 @@
#~ msgstr "Kann die Maske (MASK) der 'CELL'-Karte nicht öffnen."
#~ msgid "Unable to allocate the cell buffer in display_signature()."
-#~ msgstr "Kann den Zellbuffer in display_signature() nicht belegen."
+#~ msgstr "Kann keinen Speicher für Zellbuffer in display_signature() reservieren."
#~ msgid "Did not find input cell map MASK."
#~ msgstr "Kann die Maske (MASK) der Input-'CELL'-Karte nicht finden."
@@ -41326,8 +37629,7 @@
#~ "Sie müssen zumindest [north= south= east= west=] OR [r=\tc=] angeben."
#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr ""
-#~ "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
+#~ msgstr "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
#~ msgid "Illegal number of rows <%s>"
#~ msgstr "Ungültiger Zeilenanzahl <%s>."
@@ -41374,18 +37676,11 @@
#~ msgid "Unable to write row %d"
#~ msgstr "Kann die Zeile %d nicht schreiben."
-#~ msgid ""
-#~ "Unable to write raster map. You might want to check available disk space "
-#~ "and write permissions."
-#~ msgstr ""
-#~ "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren "
-#~ "Plattenplatz und die Schreibberechtigungen überprüfen."
+#~ msgid "Unable to write raster map. You might want to check available disk space and write permissions."
+#~ msgstr "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren Plattenplatz und die Schreibberechtigungen überprüfen."
-#~ msgid ""
-#~ "Please select the file(s) you wish to rectify by naming an output file"
-#~ msgstr ""
-#~ "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie "
-#~ "eine Ausgabedatei benennen."
+#~ msgid "Please select the file(s) you wish to rectify by naming an output file"
+#~ msgstr "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie eine Ausgabedatei benennen."
#~ msgid "%s@%s: projection doesn't match current settings"
#~ msgstr "%s@%s: Projektion passt nicht zu den aktuellen Einstellungen."
@@ -41409,8 +37704,7 @@
#~ msgstr "Mapset der Eingabe-Rasterkarte."
#~ msgid "You have to use a different location for input than the current"
-#~ msgstr ""
-#~ "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
+#~ msgstr "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
#~ msgid "Checking location <%s>, mapset <%s>..."
#~ msgstr "Prüfe Location <%s>, Mapset <%s>..."
@@ -41446,8 +37740,7 @@
#~ msgstr "Zero (0) ist eine reale Höhenangabe"
#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr ""
-#~ " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
+#~ msgstr " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
#~ msgid " long: %f, lat: %f, timezone: %f\n"
#~ msgstr "geogr. Länge: %f, geogr. Breite: %f, Zeitzone: %f\n"
@@ -41514,12 +37807,8 @@
#~ msgid "New MAPSET name"
#~ msgstr "Neuer Mapset Name."
-#~ msgid ""
-#~ "Displays and overlays raster map layers in the active display frame on "
-#~ "the graphics monitor."
-#~ msgstr ""
-#~ "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch "
-#~ "möglich."
+#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
+#~ msgstr "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch möglich."
#~ msgid "Displays vector data in the active frame on the graphics monitor."
#~ msgstr "Stellt GRASS Vektorkarten im aktiven Grafikfenster dar."
@@ -41533,11 +37822,8 @@
#~ msgid "Island size [%.1e], island not imported"
#~ msgstr "Inselgröße [%.1e], Insel nicht importiert."
-#~ msgid ""
-#~ "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr ""
-#~ "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1) für den "
-#~ "Punkt-Modus genutzt wird."
+#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
+#~ msgstr "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1) für den Punkt-Modus genutzt wird."
#~ msgid "Duplicate area centroids"
#~ msgstr "Doppelte Zentroide"
@@ -41548,14 +37834,8 @@
#~ msgid "Failed in attempt to open %s"
#~ msgstr "Fehlschlag beim Versuch '%s' zu öffnen."
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
-#~ "Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition "
-#~ "werden vom Osten gegen den Uhrzeigersinn berechnet."
+#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
+#~ msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition werden vom Osten gegen den Uhrzeigersinn berechnet."
#~ msgid "Raster elevation file name"
#~ msgstr "Rasterkarte mit Höheninformationen."
@@ -41570,12 +37850,10 @@
#~ msgstr "Dateiname für Ausgabekarte mit horizontaler Wölbung."
#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr ""
-#~ "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
+#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr ""
-#~ "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
+#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
#~ msgid "Output second order partial derivative dxx filename"
#~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dxx."
@@ -41622,14 +37900,8 @@
#~ msgid "DXY [%s] COMPLETE"
#~ msgstr "DXY [%s] KOMPLETT"
-#~ msgid ""
-#~ "Input raster map contains cells with NULL-value (no-data). The value %g "
-#~ "was used to represent no-data values in the input map. You can specify "
-#~ "nodata value by %s parameter."
-#~ msgstr ""
-#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
-#~ "Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu "
-#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
+#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
#~ msgid "raster, terrain analysis"
#~ msgstr "Raster, Geländeanalyse"
@@ -41650,9 +37922,7 @@
#~ msgstr "Kann die Maske (MASK) nicht öffnen."
#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr ""
-#~ "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer "
-#~ "Hülle zu erzeugen."
+#~ msgstr "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer Hülle zu erzeugen."
#~ msgid "Name of input vector points map"
#~ msgstr "Name der Eingabe-Vektorkarte mit Punkten."
@@ -41666,22 +37936,14 @@
#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
#~ msgstr "Kann <Auxiliar_outlier_table> nicht erzeugen"
-#~ msgid ""
-#~ "It was not possible to drop <%s> table. Nothing will be done. Try to drop "
-#~ "it manually."
-#~ msgstr ""
-#~ "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird "
-#~ "unternommen. Versuchen Sie die Tabelle manuell zu löschen."
+#~ msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
+#~ msgstr "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird unternommen. Versuchen Sie die Tabelle manuell zu löschen."
#~ msgid "Cross Validation was success!"
#~ msgstr "Die Kreuzvalidierung war erfolgreich."
-#~ msgid ""
-#~ "Interpolation: The region resolution is too high: %d cells. Consider to "
-#~ "change it."
-#~ msgstr ""
-#~ "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Überlegen "
-#~ "Sie die Auflösung zu ändern."
+#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
+#~ msgstr "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Überlegen Sie die Auflösung zu ändern."
#~ msgid "Creating auxiliar table for archiving overlapping zones"
#~ msgstr "Erstelle Hilfstabelle um überlappende Zonen zu archivieren"
@@ -41712,9 +37974,7 @@
#~ msgstr "Richtungskarte gefunden <%s>."
#~ msgid "All non-NULL and non-zero cells are considered as blocking terrain"
-#~ msgstr ""
-#~ "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als "
-#~ "echte Hindernis aufgefasst."
+#~ msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
#~ msgid "It was impossible to open table"
#~ msgstr "Es war unmöglich die Tabelle zu öffnen."
@@ -41722,40 +37982,23 @@
#~ msgid "Converts a 3D raster map layer into an ASCII text file."
#~ msgstr "Konvertiert eine 3D-Rasterkarte in eine ASCII-Datei"
-#~ msgid ""
-#~ "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr ""
-#~ "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-"
-#~ "Rasterkarte. "
+#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+#~ msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
-#~ msgid ""
-#~ "Creates cross section 2D raster map from 3D raster map based on 2D "
-#~ "elevation map."
-#~ msgstr ""
-#~ "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
-#~ "Rasterkarte basierend auf 2D-Höhenkarte."
+#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
+#~ msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
#~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr ""
-#~ "Falscher 3D Rasterkarten-Datentyp. Kann die Rasterkarte nicht erzeugen."
+#~ msgstr "Falscher 3D Rasterkarten-Datentyp. Kann die Rasterkarte nicht erzeugen."
-#~ msgid ""
-#~ "Use the same resolution as the input 3D raster map for the 2D outputmaps, "
-#~ "independent of the current region settings"
-#~ msgstr ""
-#~ "Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-"
-#~ "Ausgabekarten (unabhängig von der Auflösung der aktuellen Region). "
+#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
+#~ msgstr "Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-Ausgabekarten (unabhängig von der Auflösung der aktuellen Region). "
#~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr ""
-#~ "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
+#~ msgstr "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
-#~ msgid ""
-#~ "No 3D raster data, RGB or xyz-vector maps are provided. Will only write "
-#~ "the geometry"
-#~ msgstr ""
-#~ "Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die "
-#~ "Geometrien schreiben."
+#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
+#~ msgstr "Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die Geometrien schreiben."
#~ msgid "No RGB Data will be created"
#~ msgstr "RGB-Daten werden nicht erzeugt."
@@ -41782,9 +38025,7 @@
#~ msgstr "Kann die unterste Rasterzeile nicht lesen.\n"
#~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr ""
-#~ "Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 "
-#~ "liegen!\n"
+#~ msgstr "Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 liegen!\n"
#~ msgid ""
#~ "Calculate the groundwater distance velocity vector field \n"
@@ -41795,38 +38036,27 @@
#~ "schreibe die X, Y und Z Komponenten in die Karten name_[xyz].\n"
#~ "Name ist der gemeinsame Bestandteil der neuen 3D Rasterkarten."
-#~ msgid ""
-#~ "Calculates numerically transient, confined groundwater flow in three "
-#~ "dimensions."
-#~ msgstr ""
-#~ "Berechnet transienten, beschränkten Grundwasserflusses in drei "
-#~ "Dimensionen."
+#~ msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
+#~ msgstr "Berechnet transienten, beschränkten Grundwasserflusses in drei Dimensionen."
#~ msgid "The direct Cholesky solver do not work with sparse matrices"
-#~ msgstr ""
-#~ "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+#~ msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
-#~ msgid ""
-#~ "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and "
-#~ "1 time step)."
-#~ msgstr ""
-#~ "Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen "
-#~ "und 1 Zeitschritt)."
+#~ msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+#~ msgstr "Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen und 1 Zeitschritt)."
#~ msgid ""
#~ "Cannot create mask file: G3D_MASK already exists!\n"
#~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
#~ msgstr ""
#~ "Kann keine Maskendatei erzeugen: G3D_MASK existiert bereits.\n"
-#~ "Benutzen Sie 'g.remove rast3d=G3D_MASK' um die existierende Maske zu "
-#~ "löschen."
+#~ "Benutzen Sie 'g.remove rast3d=G3D_MASK' um die existierende Maske zu löschen."
#~ msgid "Name of base raster map"
#~ msgstr "Name der Basis-Rasterkarte."
#~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr ""
-#~ "Exportiert GRASS-Rasterkarte in ein nicht georeferenziertes PNG-Bild."
+#~ msgstr "Exportiert GRASS-Rasterkarte in ein nicht georeferenziertes PNG-Bild."
#~ msgid "Unable to read %s"
#~ msgstr "Kann <%s> nicht lesen."
@@ -41876,10 +38106,8 @@
#~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
#~ msgstr "Farbtabelle 'grey.eq' wird für Fließkomma-Karten nicht unterstützt."
-#~ msgid ""
-#~ "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr ""
-#~ "Farbtabelle 'grey.log' wird für Fließkomma-Karten nicht unterstützt."
+#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
+#~ msgstr "Farbtabelle 'grey.log' wird für Fließkomma-Karten nicht unterstützt."
#~ msgid "Color table for raster map <%s> set to '%s'"
#~ msgstr "Farbtabelle der Rasterkarte für <%s> ist auf '%s' gesetzt."
@@ -41915,16 +38143,13 @@
#~ msgstr "Kann auch verwendet werden, um GRASS Locations zu erzeugen."
#~ msgid "Print projection information (in conventional GRASS format)"
-#~ msgstr ""
-#~ "Gebe die Projektionsinformationen (im konventionellen GRASS-Format) aus."
+#~ msgstr "Gebe die Projektionsinformationen (im konventionellen GRASS-Format) aus."
#~ msgid "Georeferenced data file to read projection information from"
#~ msgstr "Datei mit den Projektionsinformationen."
#~ msgid "ASCII file containing a WKT projection description (- for stdin)"
-#~ msgstr ""
-#~ "ASCII-Datei die eine einzige Zeile mit WKT Projektionsinformationen "
-#~ "enthält. (- für stdin)."
+#~ msgstr "ASCII-Datei die eine einzige Zeile mit WKT Projektionsinformationen enthält. (- für stdin)."
#~ msgid "PROJ.4 projection description (- for stdin)"
#~ msgstr "PPROJ.4 Projektionsdefinition (- für Standardeingabe)."
@@ -41932,22 +38157,11 @@
#~ msgid "Unable to create location: %s"
#~ msgstr "Kann Location '%s' nicht erstellen."
-#~ msgid ""
-#~ "You must select the PERMANENT mapset before updating the current "
-#~ "location's projection. (Current mapset is %s)"
-#~ msgstr ""
-#~ "Das PERMANENT-Mapset muss anstelle des aktuellen Mapsets (%s) ausgewählt "
-#~ "werden, bevor Sie die Projektionsinformationen der Location aktualisieren "
-#~ "können."
+#~ msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
+#~ msgstr "Das PERMANENT-Mapset muss anstelle des aktuellen Mapsets (%s) ausgewählt werden, bevor Sie die Projektionsinformationen der Location aktualisieren können."
-#~ msgid ""
-#~ "N.B. The default region was updated to the new projection, but if you "
-#~ "have multiple mapsets g.region -d should be run in each to update the "
-#~ "region from the default."
-#~ msgstr ""
-#~ "N.B. Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn "
-#~ "Sie aber mehrere Mapsets haben g.region -d sollte in jedem ausgeführt "
-#~ "werden, um die Regionseinstellungen von der Standardregion zu übernehmen."
+#~ msgid "N.B. The default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default."
+#~ msgstr "N.B. Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie aber mehrere Mapsets haben g.region -d sollte in jedem ausgeführt werden, um die Regionseinstellungen von der Standardregion zu übernehmen."
#~ msgid "Projection information updated!"
#~ msgstr "Projektionsinformationen aktualisiert!"
@@ -41961,12 +38175,8 @@
#~ msgid "Changes current mapset."
#~ msgstr "Ändere aktuelles Mapset."
-#~ msgid ""
-#~ "%s is currently running GRASS in selected mapset or lock file cannot be "
-#~ "checked"
-#~ msgstr ""
-#~ "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei "
-#~ "kann nicht überprüft werden."
+#~ msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
+#~ msgstr "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann nicht überprüft werden."
#~ msgid "Remove base maps"
#~ msgstr "Entferne Basiskarten"
@@ -41975,9 +38185,7 @@
#~ msgstr "Die folgenden Karten würden gelöscht:"
#~ msgid "You must use the force flag to actually remove them. Exiting."
-#~ msgstr ""
-#~ "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. "
-#~ "Beende mich."
+#~ msgstr "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende mich."
#~ msgid "Launching '%s' GUI in the background, please wait ..."
#~ msgstr "Starte '%s' GUI im Hintergrund. Bitte warten Sie ..."
@@ -41985,11 +38193,8 @@
#~ msgid "display, raster"
#~ msgstr "Darstellung, Raster"
-#~ msgid ""
-#~ "Erase the contents of the active display frame with user defined color"
-#~ msgstr ""
-#~ "Löscht den Inhalte des aktiven Grafikfensters mit einer "
-#~ "benutzerdefinierten Farbe."
+#~ msgid "Erase the contents of the active display frame with user defined color"
+#~ msgstr "Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten Farbe."
#~ msgid "Don't add to list of commands in monitor"
#~ msgstr "Nicht zu der Kommandoliste im Monitor hinzufügen."
@@ -42024,10 +38229,8 @@
#~ msgid "Type of color table (for use with -z flag)"
#~ msgstr "Art der Farbtabelle (für die Verwendung mit dem Schalter -z)."
-#~ msgid ""
-#~ "Name of column for line widths (these values will be scaled by wscale)"
-#~ msgstr ""
-#~ "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
+#~ msgid "Name of column for line widths (these values will be scaled by wscale)"
+#~ msgstr "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
#~ msgid "Scale factor for wcolumn"
#~ msgstr "Skalierungsfaktor für wcolumn"
@@ -42036,8 +38239,7 @@
#~ msgstr "Hole die Farbe aus der Tabellenspalte (RRR:GGG:BBB)."
#~ msgid "Error in color definition column (%s), area %d with cat %d"
-#~ msgstr ""
-#~ "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
+#~ msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
#~ msgid "Symbol size column not specified."
#~ msgstr "Spalte für die Symbolgröße nicht angegeben."
@@ -42055,22 +38257,13 @@
#~ msgstr "Kann das Symbol nicht lesen; kann die Punkte nicht darstellen."
#~ msgid "Allocate subnets for nearest centres (direction from centre)."
-#~ msgstr "Allokiere Teilnetze für das nächste Zentrum (Richtung vom Zentrum)."
+#~ msgstr "Sammle Teilnetze für nächste Zentren (Richtung: vom Zentrum)."
-#~ msgid ""
-#~ "Centre node must be opened (costs >= 0). Costs of centre node are used in "
-#~ "calculation"
-#~ msgstr ""
-#~ "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen "
-#~ "Knoten gehen im die Berechnung mit ein."
+#~ msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
+#~ msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
-#~ msgid ""
-#~ "Categories of centres (points on nodes) to which net will be allocated, "
-#~ "layer for this categories is given by nlayer option"
-#~ msgstr ""
-#~ "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen "
-#~ "wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option "
-#~ "angegebn."
+#~ msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+#~ msgstr "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegeben."
#~ msgid "Number of centres: [%d] (nlayer: [%d])"
#~ msgstr "Zahl der Zentren: [%d] (nlayer: [%d])."
@@ -42105,12 +38298,8 @@
#~ msgid "Find centroids for layer: %s"
#~ msgstr "Finde Zentroide der Layer: %s"
-#~ msgid ""
-#~ "Input data contains 3D features. Created vector is 2D only, use -z flag "
-#~ "to import 3D vector"
-#~ msgstr ""
-#~ "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur "
-#~ "2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
+#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
+#~ msgstr "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur 2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
#~ msgid "Cannot read part of geometry"
#~ msgstr "Kann Teil der Geometrie nicht lesen."
@@ -42121,26 +38310,17 @@
#~ msgid "Cannot write part of geometry"
#~ msgstr "Kann Teil der Geometrie nicht schreiben."
-#~ msgid ""
-#~ "Selects vector objects from an existing vector map and creates a new map "
-#~ "containing only the selected objects."
-#~ msgstr ""
-#~ "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
-#~ "neue Karte nur mit den selektierten Objekten."
+#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+#~ msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
#~ msgid "Do not copy table (see also 'new' parameter)"
-#~ msgstr ""
-#~ "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
+#~ msgstr "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
#~ msgid "If new >= 0, table is not copied"
#~ msgstr "Wenn neu >= 0, wird die Tabelle nicht kopiert."
-#~ msgid ""
-#~ "List, file, where and random options are exclusive. Please specify only "
-#~ "one of them"
-#~ msgstr ""
-#~ "Die Optionen list, file, where und random schließen sich gegenseitig aus. "
-#~ "Bitte geben Sie nur eine von diesen an."
+#~ msgid "List, file, where and random options are exclusive. Please specify only one of them"
+#~ msgstr "Die Optionen list, file, where und random schließen sich gegenseitig aus. Bitte geben Sie nur eine von diesen an."
#~ msgid "Process file <%s> for category numbers"
#~ msgstr "Bearbeite Datei <%s> für Kategorienummern."
@@ -42148,39 +38328,23 @@
#~ msgid "%d categories loaded from table <%s>"
#~ msgstr "%d Kategorien von der Tabelle <%s> geladen."
-#~ msgid ""
-#~ "Random category count is larger or equal to uniq \"%s\" feature category "
-#~ "count %d"
-#~ msgstr ""
-#~ "Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der "
-#~ "eindeutigen \"%s\" Feature Kategorien %d."
+#~ msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
+#~ msgstr "Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der eindeutigen \"%s\" Feature Kategorien %d."
-#~ msgid ""
-#~ "Finds the shortest paths from a feature 'to' to every feature 'from' and "
-#~ "various information about this realtion are uploaded to the attribute "
-#~ "table."
-#~ msgstr ""
-#~ "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' "
-#~ "und zahlreiche Informationen über diese Beziehung wird in der "
-#~ "Attributtabelle abgespeichert"
+#~ msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
+#~ msgstr "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und zahlreiche Informationen über diese Beziehung wird in der Attributtabelle abgespeichert"
#~ msgid "No attribute table found"
#~ msgstr "Keine Attributtabelle gefunden."
#~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr ""
-#~ "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der "
-#~ "Schalter '-o' angegeben ist."
+#~ msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
#~ msgid "Name of input DXF file"
#~ msgstr "Name der Eingabe-DXF-Datei"
-#~ msgid ""
-#~ "Interpolates point data to a G3D grid volume using regularized spline "
-#~ "with tension (RST) algorithm."
-#~ msgstr ""
-#~ "Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des "
-#~ "regularized spline with tension (RST) Algorithmus."
+#~ msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
+#~ msgstr "Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
#~ msgid "Name of column name with route ids"
#~ msgstr "Spaltenname der Spalte mit den IDs der Route"
@@ -42260,12 +38424,8 @@
#~ msgid "Cannot grant privileges on table:\n"
#~ msgstr "Kann Privilegien für die Tabelle nicht zuweisen:\n"
-#~ msgid ""
-#~ "Cannot add database link to vector, link for given field probably already "
-#~ "exists."
-#~ msgstr ""
-#~ "Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht "
-#~ "schon eine Verknüpfung für das Feld."
+#~ msgid "Cannot add database link to vector, link for given field probably already exists."
+#~ msgstr "Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht schon eine Verknüpfung für das Feld."
#~ msgid "Cannot open driver"
#~ msgstr "Kann Treiber nicht öffnen."
@@ -42282,11 +38442,8 @@
#~ msgid "Cannot open select cursor"
#~ msgstr "Kann den Select-Cursor nicht öffnen."
-#~ msgid ""
-#~ "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#~ msgstr ""
-#~ "kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit "
-#~ "Treiber '%s'<BR>"
+#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+#~ msgstr "kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit Treiber '%s'<BR>"
#~ msgid "Cannot fetch next record"
#~ msgstr "Kann die nächste Zeile nicht holen."
@@ -42294,10 +38451,8 @@
#~ msgid "No database record"
#~ msgstr "Kein Datenbankeintrag"
-#~ msgid ""
-#~ "<HR> Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
-#~ msgstr ""
-#~ "<HR> Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
+#~ msgid "<HR> Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
+#~ msgstr "<HR> Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
#~ msgid "Split line:"
#~ msgstr "Teile Linie:"
@@ -42441,8 +38596,7 @@
#~ msgstr "Datenbankverbindung nicht definiert.<BR>"
#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr ""
-#~ "Treiber: %s<BR>Datenbank: %s<BR>Tabelle: %s<BR>Schlüsselspalte: %s<BR>"
+#~ msgstr "Treiber: %s<BR>Datenbank: %s<BR>Tabelle: %s<BR>Schlüsselspalte: %s<BR>"
#~ msgid "Line %d"
#~ msgstr "Linie %d"
@@ -42450,13 +38604,8 @@
#~ msgid "No categories"
#~ msgstr "Keine Kategorien"
-#~ msgid ""
-#~ "There are no more features with category %d (layer %d) in the map, but "
-#~ "there is record in the table. Delete this record?"
-#~ msgstr ""
-#~ "Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der "
-#~ "Karte, aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-"
-#~ "Einträge gelöscht werden?"
+#~ msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
+#~ msgstr "Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der Karte, aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-Einträge gelöscht werden?"
#~ msgid "Cannot delete record: %s"
#~ msgstr "Kann Eintrag nicht löschen: %s"
@@ -42471,11 +38620,8 @@
#~ "FEHLER: Benötigter Parameter <%s> wurde nicht angegeben:\n"
#~ "\t(%s).\n"
-#~ msgid ""
-#~ "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
-#~ msgstr ""
-#~ "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht "
-#~ "konvertiert."
+#~ msgid "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
+#~ msgstr "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht konvertiert."
#~ msgid "Database schema"
#~ msgstr "Datenbank-Schema"
@@ -42484,16 +38630,13 @@
#~ msgstr "Importiert eine E00-Datei in eine Vektorkarte."
#~ msgid "Output coordinate file (omit to send to stdout)"
-#~ msgstr ""
-#~ "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben "
-#~ "werden soll)."
+#~ msgstr "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden soll)."
#~ msgid "Prints a graph of the correlation between data layers (in pairs)."
#~ msgstr "Gibt eine Graphik der Korrelation zweier Karten (paarweise) aus."
#~ msgid "Base name for red, green and blue output maps containing the blend"
-#~ msgstr ""
-#~ "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
+#~ msgstr "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
#~ msgid "Column to be updated with the query result"
#~ msgstr "Spalte die mit den Abfrageergebnissen aktualisiert werden soll."
@@ -42505,15 +38648,10 @@
#~ msgstr "Name der Rasterkarte von der eine Legende erzeugt werden soll."
#~ msgid "Column on which to calculate statistics (must be numeric)"
-#~ msgstr ""
-#~ "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
+#~ msgstr "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
-#~ msgid ""
-#~ "Exports a vector map to a GPS receiver or file format supported by "
-#~ "GpsBabel."
-#~ msgstr ""
-#~ "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, "
-#~ "das von GpsBabel unterstützt wird."
+#~ msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+#~ msgstr "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das von GpsBabel unterstützt wird."
#~ msgid "GpsBabel supported output format"
#~ msgstr "GpsBabel unterstütze Ausgabeformate. "
@@ -42545,8 +38683,7 @@
#~ msgid "Name of the column"
#~ msgstr "Name der Spalte"
-#~ msgid ""
-#~ "Export a raster map to a text file as x,y,z values based on cell centers."
+#~ msgid "Export a raster map to a text file as x,y,z values based on cell centers."
#~ msgstr "."
#~ msgid "LANDSAT red channel"
@@ -42559,9 +38696,7 @@
#~ msgstr "LANDSAT blauer Kanal"
#~ msgid "Drapes a color raster over a shaded relief map using d.his"
-#~ msgstr ""
-#~ "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter "
-#~ "Verwendung von d.his."
+#~ msgstr "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter Verwendung von d.his."
#~ msgid "Name of shaded relief or aspect map"
#~ msgstr "Name der Schummerungs- oder Expositionskarte."
@@ -42569,20 +38704,14 @@
#~ msgid "Name of raster to drape over relief map"
#~ msgstr "Name der Rasterkarte die über das Relief drapiertwird."
-#~ msgid ""
-#~ "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-#~ msgstr ""
-#~ "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-"
-#~ "Interpolation"
+#~ msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+#~ msgstr "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-Interpolation"
#~ msgid "Name of column used to dissolve common boundaries"
-#~ msgstr ""
-#~ "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet "
-#~ "werden soll."
+#~ msgstr "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden soll."
#~ msgid "Join column in map table"
-#~ msgstr ""
-#~ "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
+#~ msgstr "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
#~ msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
#~ msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
@@ -42645,14 +38774,10 @@
#~ msgstr "Ausgabe des sonnenbeschienen Landschaftsmodells"
#~ msgid "Solar azimuth is necessary to calculate illumination terrain model"
-#~ msgstr ""
-#~ "Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu "
-#~ "berechnen."
+#~ msgstr "Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu berechnen."
#~ msgid "Reflectance maps are necessary to make topographic correction"
-#~ msgstr ""
-#~ "Reflektionskarten sind notwendig, um topographische Korrekturen zu "
-#~ "berechnen."
+#~ msgstr "Reflektionskarten sind notwendig, um topographische Korrekturen zu berechnen."
#~ msgid "Elevation raster map of unknown type"
#~ msgstr "Höhen-Rasterkarte unbekanntes Typs."
@@ -42661,8 +38786,7 @@
#~ msgstr "Beleuchtungsmodell ist vom Typ CELL."
#~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#~ msgstr ""
-#~ "Reflektion der Rasterkarte <%s> ist nicht vom Typ DCELL - ignoriert."
+#~ msgstr "Reflektion der Rasterkarte <%s> ist nicht vom Typ DCELL - ignoriert."
#~ msgid "Minnaert constant = %lf"
#~ msgstr "Minnaert Konstante = %lf"
@@ -42693,3 +38817,45 @@
#~ msgid "unable to open MASK"
+#~ msgid "Name of raster map for which to edit null file"
+#~ msgstr "Rasterkarte, deren NULL-Datei editiert werden soll."
+#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
+#~ msgstr "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. Derzeit werden nur Punkte unterstützt."
+#~ msgid "input= and source= are mutually exclusive"
+#~ msgstr "'input=' und 'source=' schließen sich gegenseitig aus."
+#~ msgid "Reports statistics for raster map layers."
+#~ msgstr "Gibt statistische Werte für eine Rasterkarte aus."
+#~ msgid "Name of an output file to hold the report"
+#~ msgstr "Name der Ausgabedatei zum Speichern des Reports."
+#~ msgid "If not given reads from standard input"
+#~ msgstr "Wenn nicht gegeben, lese von der Standardeingabe"
+#~ msgid "Removes a table from database."
+#~ msgstr "Entfernt eine Tabelle aus einer Datenbank."
+#~ msgid "database, connection settings"
+#~ msgstr "Datenbank, Verbindungseinstellungen"
+#~ msgid "Raster input maps"
+#~ msgstr "Eingabe-Rasterkarten"
+#~ msgid "Install system-wide using sudo"
+#~ msgstr "Systemweit installieren mit sudo"
+#~ msgid "Display the HTML man pages of GRASS"
+#~ msgstr "Zeige die HTML-Handbuchseite von GRASS."
+#~ msgid "Name of aspect raster map"
+#~ msgstr "Name der Expositions-Rasterkarte."
+#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
+#~ msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
+#~ msgid "Name of an existing raster map layer"
+#~ msgstr "Name einer existierenden Rasterkarte."
