[GRASS-SVN] r48706 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Mon Oct 10 14:55:58 EDT 2011
Author: huhabla
Date: 2011-10-10 11:55:57 -0700 (Mon, 10 Oct 2011)
New Revision: 48706
Added:
grass/trunk/lib/python/temporal/datetime_math.py
grass/trunk/lib/python/temporal/Makefile
grass/trunk/lib/python/temporal/__init__.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/space_time_datasets.py
New package to provide some datetime objects math
Modified: grass/trunk/lib/python/temporal/Makefile
--- grass/trunk/lib/python/temporal/Makefile 2011-10-10 15:49:21 UTC (rev 48705)
+++ grass/trunk/lib/python/temporal/Makefile 2011-10-10 18:55:57 UTC (rev 48706)
@@ -8,7 +8,7 @@
GDIR = $(PYDIR)/grass
DSTDIR = $(GDIR)/temporal
-MODULES = base core abstract_datasets space_time_datasets metadata spatial_extent temporal_extent
+MODULES = base core abstract_datasets space_time_datasets metadata spatial_extent temporal_extent datetime_math
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/temporal/__init__.py
--- grass/trunk/lib/python/temporal/__init__.py 2011-10-10 15:49:21 UTC (rev 48705)
+++ grass/trunk/lib/python/temporal/__init__.py 2011-10-10 18:55:57 UTC (rev 48706)
@@ -4,3 +4,4 @@
from spatial_extent import *
from metadata import *
from space_time_datasets import *
+from datetime_math import *
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2011-10-10 15:49:21 UTC (rev 48705)
+++ grass/trunk/lib/python/temporal/core.py 2011-10-10 18:55:57 UTC (rev 48706)
@@ -24,7 +24,7 @@
import copy
from datetime import datetime, date, time, timedelta
import grass.script.core as core
+# The import should be decided by grass environmental variables
import sqlite3 as dbmi
#import psycopg2 as dbmi
# Needed for dictionary like cursors
@@ -49,117 +49,6 @@
-def test_increment_datetime_by_string():
- dt = datetime(2001, 9, 1, 0, 0, 0)
- string = "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
- dt1 = datetime(2003,2,18,12,5,0)
- dt2 = increment_datetime_by_string(dt, string)
- delta = dt1 -dt2
- if delta.days != 0 or delta.seconds != 0:
- core.fatal("increment computation is wrong")
-def increment_datetime_by_string(mydate, increment, mult = 1):
- """Return a new datetime object incremented with the provided relative dates specified as string.
- Additional a multiplier can be specified to multiply the increment bevor adding to the provided datetime object.
- @param mydate A datetime object to incremented
- @param increment A string providing increment information:
- The string may include comma separated values of type seconds, minutes, hours, days, weeks, months and years
- Example: Increment the datetime 2001-01-01 00:00:00 with "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
- will result in the datetime 2003-02-18 12:05:00
- @param mult A multiplier, default is 1
- if increment:
- seconds = 0
- minutes = 0
- hours = 0
- days = 0
- weeks = 0
- months = 0
- years = 0
- inclist = []
- # Split the increment string
- incparts = increment.split(",")
- for incpart in incparts:
- inclist.append(incpart.strip().split(" "))
- for inc in inclist:
- if inc[1].find("seconds") >= 0:
- seconds = mult * int(inc[0])
- elif inc[1].find("minutes") >= 0:
- minutes = mult * int(inc[0])
- elif inc[1].find("hours") >= 0:
- hours = mult * int(inc[0])
- elif inc[1].find("days") >= 0:
- days = mult * int(inc[0])
- elif inc[1].find("weeks") >= 0:
- weeks = mult * int(inc[0])
- elif inc[1].find("months") >= 0:
- months = mult * int(inc[0])
- elif inc[1].find("years") >= 0:
- years = mult * int(inc[0])
- else:
- core.error(_("Wrong increment format: %s") % (increment))
- return None
- return increment_datetime(mydate, years, months, weeks, days, hours, minutes, seconds)
- return mydate
-def increment_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0, minutes=0, seconds=0):
- """Return a new datetime object incremented with the provided relative dates and times"""
- tdelta_seconds = timedelta(seconds=seconds)
- tdelta_minutes = timedelta(minutes=minutes)
- tdelta_hours = timedelta(hours=hours)
- tdelta_days = timedelta(days=days)
- tdelta_weeks = timedelta(weeks=weeks)
- tdelta_months = timedelta(0)
- tdelta_years = timedelta(0)
- if months > 0:
- # Compute the actual number of days in the month to add as timedelta
- year = mydate.year
- month = mydate.month
- all_months = int(months + month)
- years_to_add = int(all_months/12)
- residual_months = all_months%12
- # Make a deep copy of the datetime object
- dt1 = copy.copy(mydate)
- # Make sure the montha starts with a 1
- if residual_months == 0:
- residual_months = 1
- dt1 = dt1.replace(year = year + years_to_add, month = residual_months)
- tdelta_months = dt1 - mydate
- if years > 0:
- # Compute the number of days
- dt1 = dt1.replace(year=mydate.year + int(years))
- tdelta_years = dt1 - mydate
- return mydate + tdelta_seconds + tdelta_minutes + tdelta_hours + \
- tdelta_days + tdelta_weeks + tdelta_months + tdelta_years
def create_temporal_database():
"""This function creates the grass location database structure for raster, vector and raster3d maps
as well as for the space-time datasets strds, str3ds and stvds
Added: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py (rev 0)
+++ grass/trunk/lib/python/temporal/datetime_math.py 2011-10-10 18:55:57 UTC (rev 48706)
@@ -0,0 +1,396 @@
+"""!@package grass.temporal
+ at brief GRASS Python scripting module (temporal GIS functions)
+Temporal GIS datetime math functions to be used in Python sripts.
+Usage:
+ at code
+import grass.temporal as tgis
+tgis.increment_datetime_by_string(mydate, "3 month, 2 hours")
+ at endcode
+(C) 2008-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from datetime import datetime, date, time, timedelta
+import grass.script.core as core
+import copy
+def increment_datetime_by_string(mydate, increment, mult = 1):
+ """Return a new datetime object incremented with the provided relative dates specified as string.
+ Additional a multiplier can be specified to multiply the increment bevor adding to the provided datetime object.
+ @param mydate A datetime object to incremented
+ @param increment A string providing increment information:
+ The string may include comma separated values of type seconds, minutes, hours, days, weeks, months and years
+ Example: Increment the datetime 2001-01-01 00:00:00 with "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
+ will result in the datetime 2003-02-18 12:05:00
+ @param mult A multiplier, default is 1
+ if increment:
+ seconds = 0
+ minutes = 0
+ hours = 0
+ days = 0
+ weeks = 0
+ months = 0
+ years = 0
+ inclist = []
+ # Split the increment string
+ incparts = increment.split(",")
+ for incpart in incparts:
+ inclist.append(incpart.strip().split(" "))
+ for inc in inclist:
+ if inc[1].find("seconds") >= 0:
+ seconds = mult * int(inc[0])
+ elif inc[1].find("minutes") >= 0:
+ minutes = mult * int(inc[0])
+ elif inc[1].find("hours") >= 0:
+ hours = mult * int(inc[0])
+ elif inc[1].find("days") >= 0:
+ days = mult * int(inc[0])
+ elif inc[1].find("weeks") >= 0:
+ weeks = mult * int(inc[0])
+ elif inc[1].find("months") >= 0:
+ months = mult * int(inc[0])
+ elif inc[1].find("years") >= 0:
+ years = mult * int(inc[0])
+ else:
+ core.error(_("Wrong increment format: %s") % (increment))
+ return None
+ return increment_datetime(mydate, years, months, weeks, days, hours, minutes, seconds)
+ return mydate
+def test_increment_datetime_by_string():
+ # First test
+ print "# Test 1"
+ dt = datetime(2001, 9, 1, 0, 0, 0)
+ string = "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
+ dt1 = datetime(2003,2,18,12,5,0)
+ dt2 = increment_datetime_by_string(dt, string)
+ print dt
+ print dt2
+ delta = dt1 -dt2
+ if delta.days != 0 or delta.seconds != 0:
+ core.error("increment computation is wrong %s" % (delta))
+ # Second test
+ print "# Test 2"
+ dt = datetime(2001, 11, 1, 0, 0, 0)
+ string = "1 months"
+ dt1 = datetime(2001,12,1)
+ print dt
+ print dt2
+ delta = dt1 -dt2
+ # Third test
+ print "# Test 3"
+ string = "13 months"
+ dt1 = datetime(2002,12,1)
+ print dt
+ print dt2
+ delta = dt1 -dt2
+ # 4. test
+ print "# Test 4"
+ dt = datetime(2001, 1, 1, 0, 0, 0)
+ string = "72 months"
+ dt1 = datetime(2007,1,1)
+ print dt
+ print dt2
+ delta = dt1 -dt2
+def increment_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0, minutes=0, seconds=0):
+ """Return a new datetime object incremented with the provided relative dates and times"""
+ tdelta_seconds = timedelta(seconds=seconds)
+ tdelta_minutes = timedelta(minutes=minutes)
+ tdelta_hours = timedelta(hours=hours)
+ tdelta_days = timedelta(days=days)
+ tdelta_weeks = timedelta(weeks=weeks)
+ tdelta_months = timedelta(0)
+ tdelta_years = timedelta(0)
+ if months > 0:
+ # Compute the actual number of days in the month to add as timedelta
+ year = mydate.year
+ month = mydate.month
+ all_months = int(months) + int(month)
+ years_to_add = int(all_months/12.001)
+ residual_months = all_months - (years_to_add * 12)
+ # Make a deep copy of the datetime object
+ dt1 = copy.copy(mydate)
+ # Make sure the montha starts with a 1
+ if residual_months == 0:
+ residual_months = 1
+ dt1 = dt1.replace(year = year + years_to_add, month = residual_months)
+ tdelta_months = dt1 - mydate
+ if years > 0:
+ # Compute the number of days
+ dt1 = dt1.replace(year=mydate.year + int(years))
+ tdelta_years = dt1 - mydate
+ return mydate + tdelta_seconds + tdelta_minutes + tdelta_hours + \
+ tdelta_days + tdelta_weeks + tdelta_months + tdelta_years
+def adjust_datetime_to_granularity(mydate, granularity):
+ """Mofiy the datetime object to fit the given granularity """
+ if granularity:
+ has_seconds = False
+ has_minutes = False
+ has_hours = False
+ has_days = False
+ has_weeks = False
+ has_months = False
+ has_years = False
+ seconds = mydate.second
+ minutes = mydate.minute
+ hours = mydate.hour
+ days = mydate.day
+ weekday = mydate.weekday()
+ months = mydate.month
+ years = mydate.year
+ granlist = []
+ granparts = granularity.split(",")
+ for granpart in granparts:
+ granlist.append(granpart.strip().split(" "))
+ for inc in granlist:
+ has_seconds = True
+ has_minutes = True
+ has_hours = True
+ has_days = True
+ has_weeks = True
+ has_months = True
+ has_years = True
+ else:
+ core.error(_("Wrong granularity format: %s") % (granularity))
+ return None
+ if has_seconds:
+ pass
+ elif has_minutes: # Start at 0 seconds
+ seconds = 0
+ elif has_hours: # Start at 0 minutes and seconds
+ seconds = 0
+ minutes = 0
+ elif has_days: # Start at 0 hours, minuts and seconds
+ seconds = 0
+ minutes = 0
+ hours = 0
+ elif has_weeks: # Start at the first day of the week (monday) at 00:00:00
+ seconds = 0
+ minutes = 0
+ hours = 0
+ days = days - weekday
+ elif has_months: # Start at the first day of the month at 00:00:00
+ seconds = 0
+ minutes = 0
+ hours = 0
+ days = 1
+ elif has_years: # Start at the first day of the first month at 00:00:00
+ seconds = 0
+ minutes = 0
+ hours = 0
+ days = 1
+ months = 1
+ dt = copy.copy(mydate)
+ result = dt.replace(year=years, month=months, day=days, hour=hours, minute=minutes, second=seconds)
+ core.verbose(_("Adjust datetime from %s to %s with granularity %s") % (dt, result, granularity))
+ return result
+def test_adjust_datetime_to_granularity():
+ # First test
+ print "Test 1"
+ dt = datetime(2001, 8, 8, 12,30,30)
+ result = adjust_datetime_to_granularity(dt, "5 seconds")
+ correct = datetime(2001, 8, 8, 12,30,30)
+ delta = correct - result
+ core.error("Granularity adjustment computation is wrong %s" % (delta))
+ # Second test
+ print "Test 2"
+ result = adjust_datetime_to_granularity(dt, "20 minutes")
+ correct = datetime(2001, 8, 8, 12,30,00)
+ # Third test
+ print "Test 2"
+ # 4. test
+ print "Test 4"
+ result = adjust_datetime_to_granularity(dt, "3 hours")
+ correct = datetime(2001, 8, 8, 12,00,00)
+ # 5. test
+ print "Test 5"
+ result = adjust_datetime_to_granularity(dt, "5 days")
+ correct = datetime(2001, 8, 8, 00,00,00)
+ # 6. test
+ print "Test 6"
+ result = adjust_datetime_to_granularity(dt, "2 weeks")
+ correct = datetime(2001, 8, 6, 00,00,00)
+ # 7. test
+ print "Test 7"
+ result = adjust_datetime_to_granularity(dt, "6 months")
+ correct = datetime(2001, 8, 1, 00,00,00)
+ # 8. test
+ print "Test 8"
+ result = adjust_datetime_to_granularity(dt, "2 years")
+ correct = datetime(2001, 1, 1, 00,00,00)
+ # 9. test
+ print "Test 9"
+ result = adjust_datetime_to_granularity(dt, "2 years, 3 months, 5 days, 3 hours, 3 minutes, 2 seconds")
+ # 10. test
+ print "Test 10"
+ result = adjust_datetime_to_granularity(dt, "3 months, 5 days, 3 minutes")
+ # 11. test
+ print "Test 11"
+ result = adjust_datetime_to_granularity(dt, "3 weeks, 5 days")
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2011-10-10 15:49:21 UTC (rev 48705)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2011-10-10 18:55:57 UTC (rev 48706)
@@ -25,6 +25,7 @@
import grass.script.raster as raster
import grass.script.vector as vector
import grass.script.raster3d as raster3d
from abstract_datasets import *
