[GRASS-SVN] r48725 - grass/branches/develbranch_6/gui/wxpython
svn_grass at osgeo.org
Mon Oct 10 19:45:36 EDT 2011
Author: martinl
Date: 2011-10-10 16:45:36 -0700 (Mon, 10 Oct 2011)
New Revision: 48725
grass/branches/develbranch_6/gui/wxpython/gis_set.py
wxGUI: there is no UnicodeString in `utils`
(merge r48723 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gis_set.py
--- grass/branches/develbranch_6/gui/wxpython/gis_set.py 2011-10-10 23:43:44 UTC (rev 48724)
+++ grass/branches/develbranch_6/gui/wxpython/gis_set.py 2011-10-10 23:45:36 UTC (rev 48725)
@@ -224,9 +224,8 @@
force = True)
self.lblocations.EnsureVisible(self.listOfLocations.index(location))
except ValueError:
- print >> sys.stderr, _("ERROR: Location <%s> not found") % \
- (utils.UnicodeString(location))
+ print >> sys.stderr, _("ERROR: Location <%s> not found") % location
# list of mapsets
self.UpdateMapsets(os.path.join(self.gisdbase, location))
mapset = self.GetRCValue("MAPSET")
@@ -237,9 +236,8 @@
self.lbmapsets.EnsureVisible(self.listOfMapsets.index(mapset))
except ValueError:
self.lbmapsets.Clear()
- print >> sys.stderr, _("ERROR: Mapset <%s> not found") % \
- (utils.UnicodeString(mapset))
+ print >> sys.stderr, _("ERROR: Mapset <%s> not found") % mapset
def _do_layout(self):
label_style = wx.ADJUST_MINSIZE | wx.ALIGN_CENTER_HORIZONTAL
@@ -433,8 +431,8 @@
def RenameMapset(self):
"""!Rename selected mapset
- location = utils.UnicodeString(self.listOfLocations[self.lblocations.GetSelection()])
- mapset = utils.UnicodeString(self.listOfMapsets[self.lbmapsets.GetSelection()])
+ location = self.listOfLocations[self.lblocations.GetSelection()]
+ mapset = self.listOfMapsets[self.lbmapsets.GetSelection()]
if mapset == 'PERMANENT':
GMessage(parent = self,
message = _('Mapset <PERMANENT> is required for valid GRASS location.\n\n'
@@ -474,7 +472,7 @@
def RenameLocation(self):
"""!Rename selected location
dlg = wx.TextEntryDialog(parent = self,
message = _('Current name: %s\n\nEnter new name:') % location,
