[GRASS-SVN] r48761 - in grass-addons/raster/r.pi: r.pi.corearea r.pi.csr.mw r.pi.energy r.pi.energy.iter r.pi.enn r.pi.enn.iter r.pi.export r.pi.fnn r.pi.graph r.pi.graph.dec r.pi.graph.iter r.pi.graph.red r.pi.grow r.pi.import r.pi.index r.pi.library r.pi.lm r.pi.neigh r.pi.nlm r.pi.nlm.circ r.pi.nlm.stats r.pi.odc r.pi.prob.mw r.pi.prox r.pi.searchtime r.pi.searchtime.iter r.pi.searchtime.mw
Wed Oct 12 09:52:55 EDT 2011
Author: neteler
Date: 2011-10-12 06:52:54 -0700 (Wed, 12 Oct 2011)
New Revision: 48761
   grass-addons/raster/r.pi/r.pi.corearea/local_proto.h
   grass-addons/raster/r.pi/r.pi.csr.mw/local_proto.h
   grass-addons/raster/r.pi/r.pi.energy.iter/local_proto.h
   grass-addons/raster/r.pi/r.pi.energy/local_proto.h
   grass-addons/raster/r.pi/r.pi.enn.iter/local_proto.h
   grass-addons/raster/r.pi/r.pi.enn/local_proto.h
   grass-addons/raster/r.pi/r.pi.export/local_proto.h
   grass-addons/raster/r.pi/r.pi.fnn/local_proto.h
   grass-addons/raster/r.pi/r.pi.graph.dec/local_proto.h
   grass-addons/raster/r.pi/r.pi.graph.iter/local_proto.h
   grass-addons/raster/r.pi/r.pi.graph.red/local_proto.h
   grass-addons/raster/r.pi/r.pi.graph/local_proto.h
   grass-addons/raster/r.pi/r.pi.grow/local_proto.h
   grass-addons/raster/r.pi/r.pi.import/local_proto.h
   grass-addons/raster/r.pi/r.pi.index/local_proto.h
   grass-addons/raster/r.pi/r.pi.library/r_pi.h
   grass-addons/raster/r.pi/r.pi.lm/local_proto.h
   grass-addons/raster/r.pi/r.pi.neigh/local_proto.h
   grass-addons/raster/r.pi/r.pi.nlm.circ/local_proto.h
   grass-addons/raster/r.pi/r.pi.nlm.stats/local_proto.h
   grass-addons/raster/r.pi/r.pi.nlm/local_proto.h
   grass-addons/raster/r.pi/r.pi.odc/local_proto.h
   grass-addons/raster/r.pi/r.pi.odc/main.c
   grass-addons/raster/r.pi/r.pi.odc/voronoi.c
   grass-addons/raster/r.pi/r.pi.prob.mw/local_proto.h
   grass-addons/raster/r.pi/r.pi.prox/local_proto.h
   grass-addons/raster/r.pi/r.pi.searchtime.iter/local_proto.h
   grass-addons/raster/r.pi/r.pi.searchtime.mw/local_proto.h
   grass-addons/raster/r.pi/r.pi.searchtime/local_proto.h
more cleanup
Modified: grass-addons/raster/r.pi/r.pi.corearea/local_proto.h
--- grass-addons/raster/r.pi/r.pi.corearea/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.corearea/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -16,7 +16,6 @@
 #define GLOBAL extern
 #endif
 typedef struct
     int x, y;
Modified: grass-addons/raster/r.pi/r.pi.csr.mw/local_proto.h
--- grass-addons/raster/r.pi/r.pi.csr.mw/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.csr.mw/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,20 +17,6 @@
 #endif
-#define TYPE_NOTHING -1
-#define RESOLUTION 10000
-#define MIN_DOUBLE -1000000
-#define MAX_DOUBLE 1000000
-typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
 typedef DCELL(*f_statmethod) (DCELL *, int);
 typedef void (*f_method) (DCELL * values, int *map, int *mask, int n,
 			  int size);
Modified: grass-addons/raster/r.pi/r.pi.energy/local_proto.h
--- grass-addons/raster/r.pi/r.pi.energy/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.energy/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,23 +17,9 @@
 #endif
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
     double dir;
     DCELL energy;
     int finished;
Modified: grass-addons/raster/r.pi/r.pi.energy.iter/local_proto.h
--- grass-addons/raster/r.pi/r.pi.energy.iter/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.energy.iter/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,23 +17,9 @@
 #endif
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
     double dir;
     DCELL energy;
     int finished;
Modified: grass-addons/raster/r.pi/r.pi.enn/local_proto.h
--- grass-addons/raster/r.pi/r.pi.enn/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.enn/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -16,15 +16,6 @@
 #endif
-#define MAX_DOUBLE 1000000.0
-typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
 typedef int (*f_func) (DCELL *, int, int *, int, f_statmethod);
Modified: grass-addons/raster/r.pi/r.pi.enn.iter/local_proto.h
--- grass-addons/raster/r.pi/r.pi.enn.iter/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.enn.iter/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,24 +17,9 @@
 #endif
-#define TYPE_NOTHING 0
-#define TYPE_NOGO -1
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
 } Point;
Modified: grass-addons/raster/r.pi/r.pi.export/local_proto.h
--- grass-addons/raster/r.pi/r.pi.export/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.export/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,23 +17,9 @@
 #endif
-#define NOTHING 0
 typedef struct
     int x, y;
-    int neighbors;
-    DCELL value;
-} Coords;
-typedef struct
-    int x, y;
 } Point;
 typedef struct
Modified: grass-addons/raster/r.pi/r.pi.fnn/local_proto.h
--- grass-addons/raster/r.pi/r.pi.fnn/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.fnn/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -16,18 +16,9 @@
 #endif
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
     DCELL f, g;
 } Path_Coords;
Modified: grass-addons/raster/r.pi/r.pi.graph/local_proto.h
--- grass-addons/raster/r.pi/r.pi.graph/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.graph/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -16,18 +16,9 @@
 #endif
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
 } Position;
 typedef void (*f_neighborhood) (DCELL max_dist);
Modified: grass-addons/raster/r.pi/r.pi.graph.dec/local_proto.h
--- grass-addons/raster/r.pi/r.pi.graph.dec/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.graph.dec/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -16,18 +16,8 @@
 #endif
-#define MAX_INT 0x7FFFFFFF
 typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
     Coords *first_cell;
     int count;
 } Patch;
Modified: grass-addons/raster/r.pi/r.pi.graph.iter/local_proto.h
--- grass-addons/raster/r.pi/r.pi.graph.iter/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.graph.iter/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -16,17 +16,8 @@
 #endif
 typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
     Coords *first_cell;
     int count;
 } Patch;
Modified: grass-addons/raster/r.pi/r.pi.graph.red/local_proto.h
--- grass-addons/raster/r.pi/r.pi.graph.red/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.graph.red/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -16,17 +16,8 @@
 #endif
 typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
     Coords *first_cell;
     int count;
 } Patch;
Modified: grass-addons/raster/r.pi/r.pi.grow/local_proto.h
--- grass-addons/raster/r.pi/r.pi.grow/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.grow/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,8 +17,6 @@
 #endif
 typedef struct
     int x, y;
Modified: grass-addons/raster/r.pi/r.pi.import/local_proto.h
--- grass-addons/raster/r.pi/r.pi.import/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.import/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -22,20 +22,6 @@
 #endif
-#define NOTHING 0
-typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
 /* helpers.c */
Modified: grass-addons/raster/r.pi/r.pi.index/local_proto.h
--- grass-addons/raster/r.pi/r.pi.index/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.index/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -7,15 +7,6 @@
 #endif
-typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
 extern void writeFrag(int row, int col, int nbr_cnt);
 extern int f_area(DCELL * vals, Coords ** frags, int);
Modified: grass-addons/raster/r.pi/r.pi.library/r_pi.h
--- grass-addons/raster/r.pi/r.pi.library/r_pi.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.library/r_pi.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -10,8 +10,13 @@
 #include <grass/stats.h>
+#define TYPE_NOGO -2
+/* TODO: we need to talk about these definitions... */
+#define MIN_DOUBLE -1000000
+#define MAX_INT 0x7FFFFFFF
+#define RESOLUTION 10000
 typedef struct
Modified: grass-addons/raster/r.pi/r.pi.lm/local_proto.h
--- grass-addons/raster/r.pi/r.pi.lm/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.lm/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -10,6 +10,4 @@
 #include "../r.pi.library/r_pi.h"
 #include <math.h>
 #endif /* LOCAL_PROTO_H */
Modified: grass-addons/raster/r.pi/r.pi.neigh/local_proto.h
--- grass-addons/raster/r.pi/r.pi.neigh/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.neigh/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -13,15 +13,6 @@
 #endif
-typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
 typedef DCELL(*f_func) (DCELL * values, int count);
 /* frag.c */
Modified: grass-addons/raster/r.pi/r.pi.nlm/local_proto.h
--- grass-addons/raster/r.pi/r.pi.nlm/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.nlm/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -11,14 +11,6 @@
 #include <math.h>
 #include <time.h>
 typedef struct
     int x, y;
Modified: grass-addons/raster/r.pi/r.pi.nlm.circ/local_proto.h
--- grass-addons/raster/r.pi/r.pi.nlm.circ/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.nlm.circ/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -11,9 +11,6 @@
 #include <math.h>
 #include <time.h>
-#define TYPE_NOGO -2
 typedef struct
     int x, y;
Modified: grass-addons/raster/r.pi/r.pi.nlm.stats/local_proto.h
--- grass-addons/raster/r.pi/r.pi.nlm.stats/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.nlm.stats/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,24 +17,9 @@
 #endif
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
 } Point;
Modified: grass-addons/raster/r.pi/r.pi.odc/local_proto.h
--- grass-addons/raster/r.pi/r.pi.odc/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.odc/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,24 +17,9 @@
 #endif
-#define NOGO -2
-#define NOTHING -1
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
 } Point;
 typedef struct
Modified: grass-addons/raster/r.pi/r.pi.odc/main.c
--- grass-addons/raster/r.pi/r.pi.odc/main.c	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.odc/main.c	2011-10-12 13:52:54 UTC (rev 48761)
@@ -332,10 +332,10 @@
 	    G_get_c_raster_row(in_fd, result, row);
 	    for (col = 0; col < sx; col++) {
 		if (result[col] == 1) {
-		    map[row * sx + col] = NOTHING;
+		    map[row * sx + col] = TYPE_NOTHING;
 		else {
-		    map[row * sx + col] = NOGO;
+		    map[row * sx + col] = TYPE_NOGO;
@@ -346,7 +346,7 @@
     else {
 	for (i = 0; i < sx * sy; i++) {
-	    map[i] = NOTHING;
+	    map[i] = TYPE_NOTHING;
Modified: grass-addons/raster/r.pi/r.pi.odc/voronoi.c
--- grass-addons/raster/r.pi/r.pi.odc/voronoi.c	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.odc/voronoi.c	2011-10-12 13:52:54 UTC (rev 48761)
@@ -26,7 +26,7 @@
     empty_count = 0;
     for (x = 0; x < sx; x++) {
 	for (y = 0; y < sy; y++) {
-	    if (map[x + y * sx] == NOTHING) {
+	    if (map[x + y * sx] == TYPE_NOTHING) {
 		empty_space[empty_count].x = x;
 		empty_space[empty_count].y = y;
 		empty_count++;
@@ -102,7 +102,7 @@
 	for (nx = l; nx <= r; nx++) {
 	    for (ny = t; ny <= b; ny++) {
 		val = map[nx + ny * sx];
-		if (val > NOTHING && checklist[val] == 0) {
+		if (val > TYPE_NOTHING && checklist[val] == 0) {
 		    checklist[val] = 1;
 		    res[count] = val;
 		    count++;
@@ -113,7 +113,7 @@
     else {
 	if (x > 0) {		// left
 	    val = map[x - 1 + y * sx];
 		checklist[val] = 1;
 		res[count] = val;
 		count++;
@@ -121,7 +121,7 @@
 	if (x < sx - 1) {	// right
 	    val = map[x + 1 + y * sx];
 		checklist[val] = 1;
 		res[count] = val;
 		count++;
@@ -129,7 +129,7 @@
 	if (y > 0) {		// up
 	    val = map[x + (y - 1) * sx];
 		checklist[val] = 1;
 		res[count] = val;
 		count++;
@@ -137,7 +137,7 @@
 	if (y < sy - 1) {	// left
 	    val = map[x + (y + 1) * sx];
 		checklist[val] = 1;
 		res[count] = val;
 		count++;
@@ -181,7 +181,7 @@
 	    /* add new edge point */
 	    new_edge[new_count].x = x;
 	    new_edge[new_count].y = y;
-	    new_edge[new_count].patch = neighb_cnt == 1 ? neighbors[0] : NOGO;
+	    new_edge[new_count].patch = neighb_cnt == 1 ? neighbors[0] : TYPE_NOGO;
 	    new_count++;
 	    /* add voronoi area to patches respectively */
@@ -199,7 +199,7 @@
 	patch = new_edge[i].patch;
 	map[x + y * sx] = patch;
-	if (patch > NOTHING) {
+	if (patch > TYPE_NOTHING) {
 	    /* test adjacency and mark adjacent patches in the matrix */
 	    neighb_cnt =
 		gather_neighbors(neighbors, map, x, y, sx, sy, diag_grow);
Modified: grass-addons/raster/r.pi/r.pi.prob.mw/local_proto.h
--- grass-addons/raster/r.pi/r.pi.prob.mw/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.prob.mw/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,20 +17,6 @@
 #endif
-typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
 /* helpers.c */
Modified: grass-addons/raster/r.pi/r.pi.prox/local_proto.h
--- grass-addons/raster/r.pi/r.pi.prox/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.prox/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -1,18 +1,9 @@
 #ifdef MAIN
 #define GLOBAL
 #else
 #endif
-typedef struct
-    int x, y;
-    int neighbors;
-    double value;
-} Coords;
 /* frag.c */
Modified: grass-addons/raster/r.pi/r.pi.searchtime/local_proto.h
--- grass-addons/raster/r.pi/r.pi.searchtime/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.searchtime/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,23 +17,9 @@
 #endif
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
     double dir;
     DCELL path;
     int finished;
Modified: grass-addons/raster/r.pi/r.pi.searchtime.iter/local_proto.h
--- grass-addons/raster/r.pi/r.pi.searchtime.iter/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.searchtime.iter/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,23 +17,9 @@
 #endif
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
     double dir;
     DCELL path;
     int finished;
Modified: grass-addons/raster/r.pi/r.pi.searchtime.mw/local_proto.h
--- grass-addons/raster/r.pi/r.pi.searchtime.mw/local_proto.h	2011-10-12 13:20:01 UTC (rev 48760)
+++ grass-addons/raster/r.pi/r.pi.searchtime.mw/local_proto.h	2011-10-12 13:52:54 UTC (rev 48761)
@@ -17,23 +17,9 @@
 #endif
 typedef struct
     int x, y;
-    int neighbors;
-    double value;
-} Coords;
-typedef struct
-    int x, y;
     double dir;
     DCELL path;
     int finished;
