[GRASS-SVN] r48779 - in grass/trunk/temporal: . t.info t.support t.topology tr.register tr3.register
Thu Oct 13 08:44:10 EDT 2011
Author: huhabla
Date: 2011-10-13 05:44:09 -0700 (Thu, 13 Oct 2011)
New Revision: 48779
Added:
   grass/trunk/temporal/t.support/
   grass/trunk/temporal/t.support/Makefile
   grass/trunk/temporal/t.support/t.support.html
   grass/trunk/temporal/t.support/t.support.py
   grass/trunk/temporal/t.support/test.t.support.sh
   grass/trunk/temporal/t.topology/
   grass/trunk/temporal/t.topology/Makefile
   grass/trunk/temporal/t.topology/t.topology.html
   grass/trunk/temporal/t.topology/t.topology.py
   grass/trunk/temporal/Makefile
   grass/trunk/temporal/t.info/t.info.py
   grass/trunk/temporal/tr.register/test.tr.register.sh
   grass/trunk/temporal/tr3.register/test.tr3.register.sh
New simple temporal support and topology modules
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile	2011-10-13 12:42:15 UTC (rev 48778)
+++ grass/trunk/temporal/Makefile	2011-10-13 12:44:09 UTC (rev 48779)
@@ -2,6 +2,8 @@
 SUBDIRS = \
 	t.create \
+	t.support \
+	t.topology \
 	t.list \
 	t.info \
 	t.remove \
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py	2011-10-13 12:42:15 UTC (rev 48778)
+++ grass/trunk/temporal/t.info/t.info.py	2011-10-13 12:44:09 UTC (rev 48779)
@@ -43,11 +43,6 @@
 #%end
 #%flag
-#% key: t
-#% description: Print temporal relation matrix for space time datasets
-#%end
-#%flag
 #% key: s
 #% description: Print information about the temporal DBMI interface and exit
 #%end
@@ -64,7 +59,6 @@
     name = options["input"]
     type = options["type"]
     shellstyle = flags['g']
-    tmatrix = flags['t']
     system = flags['s']
     # Make sure the temporal database exists
@@ -112,15 +106,6 @@
     # Insert content from db
     sp.select()
-    if tmatrix:
-        matrix = sp.get_temporal_relation_matrix()
-        for row in matrix:
-            for col in row:
-                print col,
-            print " "
-        print " "
     if shellstyle == True:
         sp.print_shell_info()
     else:
Added: grass/trunk/temporal/t.support/Makefile
--- grass/trunk/temporal/t.support/Makefile	                        (rev 0)
+++ grass/trunk/temporal/t.support/Makefile	2011-10-13 12:44:09 UTC (rev 48779)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.support
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.support/t.support.html
Added: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py	                        (rev 0)
+++ grass/trunk/temporal/t.support/t.support.py	2011-10-13 12:44:09 UTC (rev 48779)
@@ -0,0 +1,126 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	t.support
+# AUTHOR(S):	Soeren Gebbert
+# PURPOSE:	Modify the metadata of a space time dataset
+# COPYRIGHT:	(C) 2011 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (version 2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: Modify the metadata of a space time dataset
+#% keywords: spacetime
+#% keywords: dataset
+#% keywords: create
+#%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of the space time dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: granularity
+#% type: string
+#% description: The granularity of the space time dataset (NNN day, NNN week, NNN month)
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: semantictype
+#% type: string
+#% description: The semantic type of the space time dataset
+#% required: yes
+#% multiple: no
+#% options: event, const, continuous
+#% answer: event
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Type of the space time dataset, default is strds
+#% required: no
+#% options: strds, str3ds, stvds
+#% answer: strds
+#%end
+#%option
+#% key: title
+#% type: string
+#% description: Title of the space time dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: description
+#% type: string
+#% description: Description of the space time dataset
+#% required: yes
+#% multiple: no
+#%end
+#%flag
+#% key: u
+#% description: Update metadata information, temporal and spatial extent from registered maps
+#%end
+import grass.temporal as tgis
+import grass.script as grass
+def main():
+    # Get the options
+    name = options["input"]
+    type = options["type"]
+    title = options["title"]
+    descr = options["description"]
+    semantic = options["semantictype"]
+    gran = options["granularity"]
+    update = flags["u"]
+    # Make sure the temporal database exists
+    tgis.create_temporal_database()
+    #Get the current mapset to create the id of the space time dataset
+    mapset =  grass.gisenv()["MAPSET"]
+    id = name + "@" + mapset
+    if type == "strds":
+        sp = tgis.space_time_raster_dataset(id)
+    if type == "str3ds":
+        sp = tgis.space_time_raster3d_dataset(id)
+    if type == "stvds":
+        sp = tgis.space_time_vector_dataset(id)
+    if sp.is_in_db() == False:
+        grass.fatal(_("%s dataset <%s> not found in temporal database") % (ds.get_type(), name))
+    sp.select()
+    # Temporal type can not be changed
+    ttype= sp.get_temporal_type()
+    sp.set_initial_values(granularity=gran, temporal_type=ttype, semantic_type=semantic, title=title, description=descr)
+    # Update only non-null entries
+    sp.update()
+    if update:
+        sp.update_from_registered_maps()
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/temporal/t.support/t.support.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.support/test.t.support.sh
--- grass/trunk/temporal/t.support/test.t.support.sh	                        (rev 0)
+++ grass/trunk/temporal/t.support/test.t.support.sh	2011-10-13 12:44:09 UTC (rev 48779)
@@ -0,0 +1,15 @@
+# We create several space time raster datasets
+# A simple space ime raster datasets creation and unpdate @test with absolute time
+t.create --v --o type=strds temporaltype=absolute output=precip_abs1 gran="5 senconds" title="Test" descr="This is the 1 test strds" semantictype=event
+t.info type=strds input=precip_abs1
+t.support --v type=strds input=precip_abs1 gran="5 hours" title="Test support" descr="This is the support test strds" semantictype=const
+# A simple space ime raster datasets creation and update @test with relative time
+t.create --v --o type=strds temporaltype=relative output=precip_rel1 gran=5  title="Test" descr="This is the 1 test strds" semantictype=event
+t.info type=strds input=precip_rel1
+t.support --v type=strds input=precip_rel1 gran=3 title="Test support" descr="This is the support test strds" semantictype=continuous
+t.remove --v type=strds input=precip_abs1,precip_rel1
Added: grass/trunk/temporal/t.topology/Makefile
--- grass/trunk/temporal/t.topology/Makefile	                        (rev 0)
+++ grass/trunk/temporal/t.topology/Makefile	2011-10-13 12:44:09 UTC (rev 48779)
@@ -0,0 +1,7 @@
+PGM = t.topology
Added: grass/trunk/temporal/t.topology/t.topology.html
Added: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py	                        (rev 0)
+++ grass/trunk/temporal/t.topology/t.topology.py	2011-10-13 12:44:09 UTC (rev 48779)
@@ -0,0 +1,101 @@
+# MODULE:	t.topology
+# PURPOSE:	List and modify temporal topology of a space time dataset
+#		for details.
+#%module
+#% description: List and modify temporal topology of a space time dataset
+#% keywords: spacetime dataset
+#% keywords: remove
+#%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of an existing space time dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Type of the space time dataset, default is strds (space time raster dataset)
+#% required: no
+#% answer: strds
+#%end
+#%flag
+#% key: t
+#% description: Print temporal relation matrix for space time datasets
+#%end
+def main():
+    # Get the options
+    tmatrix = flags['t']
+    if name.find("@") >= 0:
+        id = name
+    else:
+    if type == "rast":
+        sp = tgis.raster_dataset(id)
+        tmatrix = False
+    if type == "rast3d":
+        sp = tgis.raster3d_dataset(id)
+        tmatrix = False
+    if type == "vect":
+        sp = tgis.vector_dataset(id)
+        tmatrix = False
+        grass.fatal("Dataset <" + name + "> not found in temporal database")
+    # Insert content from db
+    sp.select()
+    if tmatrix:
+        matrix = sp.get_temporal_relation_matrix()
+        for row in matrix:
+            for col in row:
+                print col,
+            print " "
+        print " "
+    main()
Property changes on: grass/trunk/temporal/t.topology/t.topology.py
Modified: grass/trunk/temporal/tr.register/test.tr.register.sh
--- grass/trunk/temporal/tr.register/test.tr.register.sh	2011-10-13 12:42:15 UTC (rev 48778)
+++ grass/trunk/temporal/tr.register/test.tr.register.sh	2011-10-13 12:44:09 UTC (rev 48779)
@@ -31,43 +31,53 @@
 tr.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
 tr.list input=precip_abs1
+t.topology -t input=precip_abs1
 tr.register -i input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 seconds, 5 minutes"
 t.info type=strds input=precip_abs2
 tr.list input=precip_abs2
+t.topology -t input=precip_abs2
 tr.register -i input=precip_abs3 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="8 hours"
 t.info type=strds input=precip_abs3
 tr.list input=precip_abs3
+t.topology -t input=precip_abs3
 tr.register input=precip_abs4 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 days"
 t.info type=strds input=precip_abs4
 tr.list input=precip_abs4
+t.topology -t input=precip_abs4
 tr.register input=precip_abs5 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="4 weeks"
 t.info type=strds input=precip_abs5
 tr.list input=precip_abs5
+t.topology -t input=precip_abs5
 tr.register input=precip_abs6 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-08-01" increment="2 months"
 t.info type=strds input=precip_abs6
 tr.list input=precip_abs6
+t.topology -t input=precip_abs6
 tr.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
 t.info type=strds input=precip_abs7
 tr.list input=precip_abs7
+t.topology -t input=precip_abs7
 # Register with different valid time again
 tr.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
 # Register with different valid time again creating an interval
 tr.register -i input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
 tr.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" end="2002-01-01"
-t.remove --v type=raster input=prec_1,prec_2,prec_3
+t.remove --v type=rast input=prec_1,prec_2,prec_3
 t.remove --v type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5,precip_abs6,precip_abs7,precip_abs7
-t.remove --v type=raster input=prec_4,prec_5,prec_6
+t.remove --v type=rast input=prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/tr3.register/test.tr3.register.sh
--- grass/trunk/temporal/tr3.register/test.tr3.register.sh	2011-10-13 12:42:15 UTC (rev 48778)
+++ grass/trunk/temporal/tr3.register/test.tr3.register.sh	2011-10-13 12:44:09 UTC (rev 48779)
@@ -1,11 +1,11 @@
 # This is a test to register and unregister raster3d maps in
-# space time raster3d input.
+# space time raster3d datasets
 # The raster3d maps will be registered in different space time raster3d
-# inputs
+# datasets
 # We need to set a specific region in the
 # @preprocess step of this test. We generate
-# 3d raster with r3.mapcalc and create two space time raster3d inputs
+# 3d raster with r3.mapcalc and create two space time raster3d datasets
 # with relative and absolute time
 # The region setting should work for UTM and LL test locations
 g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
@@ -18,7 +18,7 @@
 r3.mapcalc --o expr="volume_6 = rand(0, 650)"
 # The first @test
-# We create the space time raster3d inputs and register the raster3d maps with absolute time interval
+# We create the space time raster3d dataset and register the raster3d maps with absolute time interval
 t.create --v --o type=str3ds temporaltype=absolute output=volume_abs1 gran="1 senconds" title="A test" descr="A test"
 t.create --v --o type=str3ds temporaltype=absolute output=volume_abs2 gran="1 minutes" title="A test" descr="A test"
