[GRASS-SVN] r48787 - grass/trunk/temporal/t.topology
Thu Oct 13 18:36:08 EDT 2011
Author: huhabla
Date: 2011-10-13 15:36:08 -0700 (Thu, 13 Oct 2011)
New Revision: 48787
   grass/trunk/temporal/t.topology/t.topology.py
More temporal topology info
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py	2011-10-13 21:58:30 UTC (rev 48786)
+++ grass/trunk/temporal/t.topology/t.topology.py	2011-10-13 22:36:08 UTC (rev 48787)
@@ -31,7 +31,7 @@
 #%option
 #% key: type
 #% type: string
-#% description: Type of the space time dataset, default is strds (space time raster dataset)
+#% description: Type of the space time dataset, default is space time raster dataset (strds)
 #% required: no
 #% options: strds, str3ds, stvds
 #% answer: strds
@@ -39,9 +39,19 @@
 #%flag
 #% key: t
-#% description: Print temporal relation matrix for space time datasets
+#% description: Print temporal relation matrix and exit
 #%end
+#%flag
+#% key: r
+#% description: Print temporal relation count
+#%end
+#%flag
+#% key: m
+#% description: Print temporal map type count
+#%end
 import grass.script as grass
 import grass.temporal as tgis
@@ -53,6 +63,8 @@
     name = options["input"]
     type = options["type"]
     tmatrix = flags['t']
+    relation = flags['r']
+    map_types = flags['m']
     # Make sure the temporal database exists
     tgis.create_temporal_database()
@@ -70,15 +82,6 @@
         sp = tgis.space_time_raster3d_dataset(id)
     if type == "stvds":
         sp = tgis.space_time_vector_dataset(id)
-    if type == "rast":
-        sp = tgis.raster_dataset(id)
-        tmatrix = False
-    if type == "rast3d":
-        sp = tgis.raster3d_dataset(id)
-        tmatrix = False
-    if type == "vect":
-        sp = tgis.vector_dataset(id)
-        tmatrix = False
     if sp.is_in_db() == False:
         grass.fatal("Dataset <" + name + "> not found in temporal database")
@@ -86,15 +89,30 @@
     # Insert content from db
     sp.select()
+    maps = sp.get_registered_maps_as_objects()
     if tmatrix:
-        matrix = sp.get_temporal_relation_matrix()
+        matrix = sp.get_temporal_relation_matrix(maps)
         for row in matrix:
             for col in row:
                 print col,
             print " "
         print " "
+        return
+    if relation:
+        dict = sp.get_temporal_relations_count(maps)
+        for key in dict.keys():
+            print key, dict[key]
+    if map_types:
+        dict = sp.get_temporal_map_type_count(maps)
 if __name__ == "__main__":
     options, flags = grass.parser()
     main()
