[GRASS-SVN] r48797 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Oct 14 11:57:45 EDT 2011
Author: annakrat
Date: 2011-10-14 08:57:45 -0700 (Fri, 14 Oct 2011)
New Revision: 48797
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxNviz: synchronize overlays in 2d and 3d (legend, text labels)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-14 15:22:54 UTC (rev 48796)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-14 15:57:45 UTC (rev 48797)
@@ -656,6 +656,12 @@
self.MapWindow3D.ResetViewHistory()
for page in ('view', 'light', 'fringe', 'constant', 'cplane'):
self._layerManager.nviz.UpdatePage(page)
+ self.MapWindow3D.overlays = self.MapWindow2D.overlays
+ self.MapWindow3D.textdict = self.MapWindow2D.textdict
+ # update overlays needs to be called after because getClientSize
+ # is called during update and it must give reasonable values
+ wx.CallAfter(self.MapWindow3D.UpdateOverlays)
self.SetStatusText("", 0)
self._mgr.Update()
@@ -680,6 +686,8 @@
# remove nviz notebook page
self._layerManager.RemoveNvizTools()
+ self.MapWindow2D.overlays = self.MapWindow3D.overlays
+ self.MapWindow2D.textdict = self.MapWindow3D.textdict
self.MapWindow.UpdateMap()
self._mgr.Update()
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-10-14 15:22:54 UTC (rev 48796)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-10-14 15:57:45 UTC (rev 48797)
@@ -251,7 +251,8 @@
def DrawImages(self):
"""!Draw overlay image"""
for texture in self.imagelist:
- texture.Draw()
+ if texture.IsActive():
+ texture.Draw()
def GetLegendRect(self):
"""!Estimates legend size for dragging"""
@@ -264,6 +265,8 @@
if size:
wSize = self.GetClientSizeTuple()
x, y = size[2]/100. * wSize[0], wSize[1] - (size[1]/100. * wSize[1])
+ x += self.overlays[1]['coords'][0]
+ y += self.overlays[1]['coords'][1]
w = (size[3] - size[2])/100. * wSize[0]
h = (size[1] - size[0])/100. * wSize[1]
@@ -307,39 +310,54 @@
self.Map.RenderOverlays(force = True)
# delete textures
- overlays = self.Map.GetListOfLayers(l_type = "overlay", l_active = True)
- if texture.id not in [o.id for o in overlays] + self.textdict.keys():
- self.imagelist.remove(texture)
- # update images (legend)
- for overlay in overlays:
- if os.path.isfile(overlay.mapfile) and os.path.getsize(overlay.mapfile):
- if overlay.id not in [t.id for t in self.imagelist]: # new
- self.CreateTexture(overlay)
+ # inactive overlays, remove text labels
+ if texture.GetId() < 100:
+ if not self.overlays[texture.GetId()]['layer'].IsActive():
+ texture.SetActive(False)
else:
- for t in self.imagelist: # check if it is the same
- if t.id == overlay.id and sorted(t.cmd) != sorted(self.overlays[overlay.id]['cmd']):
+ texture.SetActive(True)
+ else: # text label
+ if texture.GetId() not in self.textdict:
+ self.imagelist.remove(texture)
+ # update images (only legend so far)
+ for oid, overlay in self.overlays.iteritems():
+ layer = overlay['layer']
+ if not layer.IsActive() or oid == 0: # 0 for barscale
+ continue
+ if oid not in [t.GetId() for t in self.imagelist]: # new
+ self.CreateTexture(overlay = layer)
+ else:
+ for t in self.imagelist:
+ if t.GetId() == oid: # check if it is the same
+ if not t.Corresponds(layer):
self.imagelist.remove(t)
+ t = self.CreateTexture(overlay = layer)
+ # always set coordinates, needed for synchr. 2D and 3D modes
+ t.SetCoords(overlay['coords'])
# update text labels
for textId in self.textdict.keys():
- if textId not in [t.id for t in self.imagelist]:# new
+ if textId not in [t.GetId() for t in self.imagelist]:# new
self.CreateTexture(textId = textId)
else:
- for t in self.imagelist:# check if it is the same
- if not t.textDict:
- continue
- self.textdict[textId]['bbox'] = t.textDict['bbox'] # compare without bbox
- if t.id == textId and t.textDict and t.textDict != self.textdict[textId]:
- self.imagelist.remove(t)
- self.CreateTexture(textId = textId)
+ if t.GetId() == textId: # check if it is the same
+ self.textdict[textId]['bbox'] = t.textDict['bbox']
+ if not t.Corresponds(self.textdict[textId]):
+ self.imagelist.remove(t)
+ t = self.CreateTexture(textId = textId)
+ t.SetCoords(self.textdict[textId]['coords'])
def CreateTexture(self, overlay = None, textId = None):
"""!Create texture from overlay image or from textdict"""
if overlay: # legend
- texture = wxnviz.Texture(filepath = overlay.mapfile, overlayId = overlay.id,
- coords = list(self.overlays[overlay.id]['coords']),
- cmd = self.overlays[overlay.id]['cmd'])
+ texture = wxnviz.ImageTexture(filepath = overlay.mapfile, overlayId = overlay.id,
+ coords = list(self.overlays[overlay.id]['coords']),
+ cmd = overlay.GetCmd())
if overlay.id == 1: # legend
texture.SetBounds(self.GetLegendRect())
else: # text
@@ -347,8 +365,8 @@
self.textdict[textId]['coords'] = coords
self.textdict[textId]['bbox'] = bbox
file = self.DrawTextImage(self.textdict[textId], relCoords)
- texture = wxnviz.Texture(filepath = file, overlayId = textId,
- coords = coords, textDict = self.textdict[textId])
+ texture = wxnviz.TextTexture(filepath = file, overlayId = textId,
+ coords = coords, textDict = self.textdict[textId])
bbox.OffsetXY(*relCoords)
texture.SetBounds(bbox)
@@ -356,9 +374,12 @@
gcmd.GMessage(parent = self, message =
_("Image is too large, your OpenGL implementation "
"supports maximum texture size %d px.") % texture.maxSize)
- return
+ return texture
self.imagelist.append(texture)
+ return texture
def FindObjects(self, mouseX, mouseY, radius):
"""Find object which was clicked on"""
@@ -528,7 +549,15 @@
self.mouse['use'] = 'pointer'
self.SetCursor(self.cursors['default'])
elif self.mouse['use'] == 'pointer':
- if self.dragid > 0:
+ if self.dragid > 0:
+ dx = self.mouse['end'][0] - self.mouse['begin'][0]
+ dy = self.mouse['end'][1] - self.mouse['begin'][1]
+ if self.dragid < 99:
+ coords = self.overlays[self.dragid]['coords']
+ self.overlays[self.dragid]['coords'] = [coords[0] + dx, coords[1] + dy]
+ else: # text
+ coords = self.textdict[self.dragid]['coords']
+ self.textdict[self.dragid]['coords'] = [coords[0] + dx, coords[1] + dy]
self.dragid = -1
self.render['quick'] = False
self.Refresh(False)
@@ -642,6 +671,7 @@
if texture.id == id:
texture.MoveTexture(dx, dy)
self.render['quick'] = True
self.Refresh(False)
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-10-14 15:22:54 UTC (rev 48796)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-10-14 15:57:45 UTC (rev 48797)
@@ -1863,14 +1863,12 @@
class Texture(object):
"""!Class representing OpenGL texture"""
- def __init__(self, filepath, overlayId, coords, cmd = None, textDict = None):
+ def __init__(self, filepath, overlayId, coords):
"""!Load image to texture
@param filepath path to image file
@param overlayId id of overlay (1 for legend, 101 and more for text)
@param coords image coordinates
- @param cmd d.legend command (or None)
- @param textDict text info (or None)
self.path = filepath
self.image = wx.Image(filepath, wx.BITMAP_TYPE_ANY)
@@ -1879,8 +1877,7 @@
self.id = overlayId
self.coords = list(coords)
self.bounds = wx.Rect()
- self.cmd = cmd
- self.textDict = textDict
+ self.active = True
# alpha needs to be initialized
if not self.image.HasAlpha():
@@ -1965,4 +1962,69 @@
self.coords[0] += dx
self.coords[1] += dy
self.bounds.OffsetXY(dx, dy)
+ def SetCoords(self, coords):
+ """!Set coordinates"""
+ dx = coords[0] - self.coords[0]
+ dy = coords[1] - self.coords[1]
+ self.MoveTexture(dx, dy)
+ def GetId(self):
+ """!Returns image id."""
+ return self.id
+ def SetActive(self, active = True):
+ self.active = active
+ def IsActive(self):
+ return self.active
+class ImageTexture(Texture):
+ """!Class representing OpenGL texture as an overlay image"""
+ def __init__(self, filepath, overlayId, coords, cmd):
+ """!Load image to texture
+ @param filepath path to image file
+ @param overlayId id of overlay (1 for legend)
+ @param coords image coordinates
+ @param cmd d.legend command
+ Texture.__init__(self, filepath = filepath, overlayId = overlayId, coords = coords)
+ self.cmd = cmd
+ def GetCmd(self):
+ """!Returns overlay command."""
+ return self.cmd
+ def Corresponds(self, item):
+ return sorted(self.GetCmd()) == sorted(item.GetCmd())
+class TextTexture(Texture):
+ """!Class representing OpenGL texture as a text label"""
+ def __init__(self, filepath, overlayId, coords, textDict):
+ @param overlayId id of overlay (101 and more for text)
+ @param coords text coordinates
+ @param textDict text properties
+ self.textDict = textDict
+ def GetTextDict(self):
+ """!Returns text properties."""
+ return self.textDict
+ t = self.GetTextDict()
+ for prop in t.keys():
+ if prop in ('coords','bbox'): continue
+ if t[prop] != item[prop]:
+ return False
+ return True
