[GRASS-SVN] r48822 - in grass/trunk/gui/wxpython: gui_modules icons
svn_grass at osgeo.org
Sun Oct 16 00:53:52 EDT 2011
Author: cmbarton
Date: 2011-10-15 21:53:51 -0700 (Sat, 15 Oct 2011)
New Revision: 48822
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/wxplot.py
grass/trunk/gui/wxpython/gui_modules/wxplot_dialogs.py
grass/trunk/gui/wxpython/icons/icon.py
wxgui: enhancements and fixes to analysis modules. Added scatterplot. Also added statistics displays for profile, histogram, and scatterplot.
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-10-15 20:12:47 UTC (rev 48821)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-10-16 04:53:51 UTC (rev 48822)
@@ -1258,7 +1258,7 @@
def _toolbarData(self):
"""!Toolbar data"""
- icons = Icons['profile']
+ icons = Icons['plot']
return self._getToolbarData((('addraster', Icons['layerManager']["addRast"],
self.parent.OnSelectRaster),
('transect', icons["transect"],
@@ -1275,6 +1275,8 @@
('unzoom', Icons['displayWindow']['zoomBack'],
self.parent.OnRedraw),
(None, ),
+ ('statistics', icons['statistics'],
+ self.parent.OnStats),
('datasave', icons["save"],
self.parent.SaveProfileToFile),
('image', Icons['displayWindow']["saveFile"],
@@ -1433,7 +1435,7 @@
"""!Toolbar data"""
(None, ),
@@ -1448,6 +1450,8 @@
(None, ),
self.parent.SaveToFile),
('print', Icons['displayWindow']["print"],
@@ -1472,7 +1476,8 @@
"""!Toolbar data"""
+# icons2 = Icons['modeler']
(None, ),
@@ -1487,6 +1492,8 @@
(None, ),
+ self.parent.OnRegression),
Modified: grass/trunk/gui/wxpython/gui_modules/wxplot.py
--- grass/trunk/gui/wxpython/gui_modules/wxplot.py 2011-10-15 20:12:47 UTC (rev 48821)
+++ grass/trunk/gui/wxpython/gui_modules/wxplot.py 2011-10-16 04:53:51 UTC (rev 48822)
@@ -722,8 +722,25 @@
self.SetGraphStyle()
p = self.CreatePlotList()
self.DrawPlot(p)
+ def OnStats(self, event):
+ """!Displays regression information in messagebox
+ message = []
+ title = _('Statistics for Map(s) Histogrammed')
+ for r in self.rasterList:
+ rast = r.split('@')[0]
+ ret = grass.read_command('r.univar', map = r, flags = 'e', quiet = True)
+ stats = _('Statistics for %s\n\n%s\n') % (rast, ret)
+ message.append(stats)
+ stats = dialogs.PlotStatsFrame(self, id = wx.ID_ANY, message = message,
+ title = title)
+ if stats.Show() == wx.ID_CLOSE:
+ stats.Destroy()
class ProfileFrame(AbstractPlotFrame):
"""!Mainframe for displaying profile of one or more raster maps. Uses wx.lib.plot.
@@ -808,8 +825,7 @@
# create list of coordinate points for r.profile
dist = 0
cumdist = 0
self.coordstr = ''
@@ -867,26 +883,26 @@
pass
- # create datalist for each raster map
+ # create datalist of dist/value pairs and y labels for each raster map
+ self.ylabel = ''
+ i = 0
for r in self.raster.iterkeys():
- self.raster[r]['datalist'] = []
- self.raster[r]['datalist'] = self.CreateDatalist(r, self.coordstr)
+ self.raster[r]['datalist'] = []
+ datalist = self.CreateDatalist(r, self.coordstr)
+ if len(datalist) > 0:
+ self.raster[r]['datalist'] = datalist
- # update title
- self.ptitle += ' %s ,' % r.split('@')[0]
+ # update ylabel to match units if they exist
+ if self.raster[r]['units'] != '':
+ self.ylabel += '%s (%d),' % (r['units'], i)
+ i += 1
+ # update title
+ self.ptitle += ' %s ,' % r.split('@')[0]
self.ptitle = self.ptitle.rstrip(',')
- # set ylabel to match units if they exist
- self.ylabel = ''
- i = 0
- for r in self.rasterList:
- if self.raster[r]['units'] != '':
- self.ylabel += '%s (%d),' % (r['units'], i)
- i += 1
if self.ylabel == '':
self.ylabel = _('Raster values')
@@ -921,8 +937,12 @@
for line in ret.splitlines():
dist, elev = line.strip().split(' ')
- if elev != 'nan':
- datalist.append((dist,elev))
+ if dist == None or dist == '' or dist == 'nan' or \
+ elev == None or elev == '' or elev == 'nan':
+ continue
+ dist = float(dist)
+ elev = float(elev)
+ datalist.append((dist,elev))
return datalist
@@ -1029,6 +1049,42 @@
dlg.Destroy()
+ message = []
+ title = _('Statistics for Profile(s)')
+ for r in self.raster.iterkeys():
+ try:
+ statstr = 'Profile of %s\n\n' % rast
+ iterable = (i[1] for i in self.raster[r]['datalist'])
+ a = numpy.fromiter(iterable, numpy.float)
+ statstr += 'n: %f\n' % a.size
+ statstr += 'minimum: %f\n' % numpy.amin(a)
+ statstr += 'maximum: %f\n' % numpy.amax(a)
+ statstr += 'range: %f\n' % numpy.ptp(a)
+ statstr += 'mean: %f\n' % numpy.mean(a)
+ statstr += 'standard deviation: %f\n' % numpy.std(a)
+ statstr += 'variance: %f\n' % numpy.var(a)
+ cv = numpy.std(a)/numpy.mean(a)
+ statstr += 'coefficient of variation: %f\n' % cv
+ statstr += 'sum: %f\n' % numpy.sum(a)
+ statstr += 'median: %f\n' % numpy.median(a)
+ statstr += 'distance along transect: %f\n\n' % self.transect_length
+ message.append(statstr)
+ except:
+ pass
+ title = title)
+ stats.Destroy()
class ScatterFrame(AbstractPlotFrame):
"""!Mainframe for displaying bivariate scatter plot of two raster maps. Uses wx.lib.plot.
@@ -1174,7 +1230,6 @@
quiet = True,
read = True)
if not ret:
return datalist
@@ -1230,4 +1285,34 @@
self.DrawPlot(p)
+ def OnRegression(self, event):
+ message = []
+ title = _('Regression Statistics for Scatterplot(s)')
+ for rpair in self.rasterList:
+ if isinstance(rpair, tuple) == False: continue
+ rast1, rast2 = rpair
+ rast1 = rast1.split('@')[0]
+ rast2 = rast2.split('@')[0]
+ ret = grass.parse_command('r.regression.line',
+ map1 = rast1,
+ map2 = rast2,
+ flags = 'g', quiet = True,
+ parse = (grass.parse_key_val, { 'sep' : '=' }))
+ eqtitle = _('Regression equation for %s vs. %s:\n\n') % (rast1, rast2)
+ eq = _(' %s = %s + %s(%s)\n\n') % (rast2, ret['a'], ret['b'], rast1)
+ num = _('N = %s\n') % ret['N']
+ rval = _('R = %s\n') % ret['R']
+ rsq = _('R-squared = %f\n') % pow(float(ret['R']), 2)
+ ftest = _('F = %s\n') % ret['F']
+ str = eqtitle + eq + num + rval + rsq + ftest
+ message.append(str)
+ title = title)
+ stats.Destroy()
\ No newline at end of file
Modified: grass/trunk/gui/wxpython/gui_modules/wxplot_dialogs.py
--- grass/trunk/gui/wxpython/gui_modules/wxplot_dialogs.py 2011-10-15 20:12:47 UTC (rev 48821)
+++ grass/trunk/gui/wxpython/gui_modules/wxplot_dialogs.py 2011-10-16 04:53:51 UTC (rev 48822)
@@ -24,6 +24,7 @@
import wx
import wx.lib.colourselect as csel
+import wx.lib.scrolledpanel as scrolled
import globalvar
import gcmd
@@ -219,7 +220,101 @@
def OnSetScattertypes(self, event):
self.scattertype = event.GetString()
+class PlotStatsFrame(wx.Frame):
+ def __init__(self, parent, id, message = '', title = '',
+ style = wx.DEFAULT_FRAME_STYLE, **kwargs):
+ """!Dialog to display and save statistics for plots
+ wx.Frame.__init__(self, parent, id, style = style, **kwargs)
+ self.SetLabel(_("Statistics"))
+ sp = scrolled.ScrolledPanel(self, -1, size=(400, 400),
+ style = wx.TAB_TRAVERSAL|wx.SUNKEN_BORDER, name="Statistics" )
+ # initialize variables
+ self.parent = parent
+ self.message = message
+ self.title = title
+ self.CenterOnParent()
+ # Display statistics
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ txtSizer = wx.BoxSizer(wx.VERTICAL)
+ statstitle = wx.StaticText(parent = self, id = wx.ID_ANY, label = self.title)
+ sizer.Add(item = statstitle, proportion = 0,
+ flag = wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, border = 3)
+ line = wx.StaticLine(parent = self, id = wx.ID_ANY, size = (20, -1), style = wx.LI_HORIZONTAL)
+ sizer.Add(item = line, proportion = 0,
+ for stats in self.message:
+ statstxt = wx.StaticText(parent = sp, id = wx.ID_ANY, label = stats)
+ statstxt.SetBackgroundColour("WHITE")
+ txtSizer.Add(item = statstxt, proportion = 1,
+ flag = wx.EXPAND|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border = 3)
+ line = wx.StaticLine(parent = sp, id = wx.ID_ANY, size = (20, -1), style = wx.LI_HORIZONTAL)
+ txtSizer.Add(item = line, proportion = 0,
+ sp.SetSizer(txtSizer)
+ sp.SetAutoLayout(1)
+ sp.SetupScrolling()
+ sizer.Add(item = sp, proportion = 1,
+ flag = wx.GROW | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 3)
+ flag = wx.GROW |wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border = 3)
+ # buttons
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btn_clipboard = wx.Button(self, id = wx.ID_COPY, label = _('C&opy'))
+ btn_clipboard.SetToolTipString(_("Copy regression statistics the clipboard (Ctrl+C)"))
+ btnSizer.Add(item = btn_clipboard, proportion = 0, flag = wx.ALIGN_LEFT | wx.ALL, border = 5)
+ btnCancel = wx.Button(self, wx.ID_CLOSE)
+ btnCancel.SetDefault()
+ btnSizer.Add(item = btnCancel, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ sizer.Add(item = btnSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ # bindings
+ btnCancel.Bind(wx.EVT_BUTTON, self.OnClose)
+ btn_clipboard.Bind(wx.EVT_BUTTON, self.OnCopy)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ def OnCopy(self, event):
+ """!Copy the regression stats to the clipboard
+ str = self.title + '\n'
+ for item in self.message:
+ str += item
+ rdata = wx.TextDataObject()
+ rdata.SetText(str)
+ if wx.TheClipboard.Open():
+ wx.TheClipboard.SetData(rdata)
+ wx.TheClipboard.Close()
+ wx.MessageBox(_("Regression statistics copied to clipboard"))
+ def OnClose(self, event):
+ """!Button 'Close' pressed
+ self.Close(True)
class HistRasterDialog(wx.Dialog):
def __init__(self, parent, id = wx.ID_ANY,
title = _("Select raster map or imagery group to histogram"),
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2011-10-15 20:12:47 UTC (rev 48821)
+++ grass/trunk/gui/wxpython/icons/icon.py 2011-10-16 04:53:51 UTC (rev 48822)
@@ -300,17 +300,19 @@
label = _('Undo'),
desc = _('Undo previous changes')),
- 'profile' : {
+ 'plot' : {
'draw' : MetaIcon(img = iconSet.get('show', wx.ART_ERROR),
- label = _('Draw/re-draw profile')),
+ label = _('Draw/re-draw plot')),
'transect' : MetaIcon(img = iconSet.get('layer-raster-profile', wx.ART_ERROR),
label = _('Draw transect in map display window to profile')),
'options' : MetaIcon(img = iconSet.get('settings', wx.ART_ERROR),
- label = _('Profile options')),
+ label = _('Plot options')),
+ 'statistics' : MetaIcon(img = iconSet.get('check', wx.ART_ERROR),
+ label = _('Plot statistics')),
'save' : MetaIcon(img = iconSet.get('save', wx.ART_ERROR),
label = _('Save profile data to CSV file')),
'quit' : MetaIcon(img = iconSet.get('quit', wx.ART_ERROR),
- label = _('Quit Profile Analysis Tool'))
+ label = _('Quit plot tool'))
'georectify' : {
'gcpSet' : MetaIcon(img = iconSet.get('gcp-create', wx.ART_ERROR),
