[GRASS-SVN] r48828 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Oct 16 06:28:06 EDT 2011
Author: martinl
Date: 2011-10-16 03:28:06 -0700 (Sun, 16 Oct 2011)
New Revision: 48828
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI: attempt to fix #1463 (part 1 & 2)
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2011-10-16 09:53:20 UTC (rev 48827)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2011-10-16 10:28:06 UTC (rev 48828)
@@ -540,22 +540,22 @@
self.wind = event.GetString()
class DecorationDialog(wx.Dialog):
+ """!Controls setting options and displaying/hiding map overlay
+ decorations
- Controls setting options and displaying/hiding map overlay decorations
def __init__(self, parent, ovlId, title, cmd, name = None,
pos = wx.DefaultPosition, size = wx.DefaultSize, style = wx.DEFAULT_DIALOG_STYLE,
checktxt = '', ctrltxt = ''):
wx.Dialog.__init__(self, parent, wx.ID_ANY, title, pos, size, style)
self.ovlId = ovlId # PseudoDC id
self.cmd = cmd
self.name = name # overlay name
self.parent = parent # MapFrame
sizer = wx.BoxSizer(wx.VERTICAL)
box = wx.BoxSizer(wx.HORIZONTAL)
self.chkbox = wx.CheckBox(parent = self, id = wx.ID_ANY, label = checktxt)
if self.parent.Map.GetOverlay(self.ovlId) is None:
@@ -629,7 +629,7 @@
sizer.Fit(self)
# create overlay if doesn't exist
- self._CreateOverlay()
+ self._createOverlay()
if len(self.parent.MapWindow.overlays[self.ovlId]['cmd']) > 1:
if name == 'legend':
@@ -642,8 +642,9 @@
mapName)
- def _CreateOverlay(self):
- if not self.parent.Map.GetOverlay(self.ovlId):
+ def _createOverlay(self):
+ """!Creates overlay"""
+ if not self.parent.GetMap().GetOverlay(self.ovlId):
self.newOverlay = self.parent.Map.AddOverlay(id = self.ovlId, type = self.name,
command = self.cmd,
l_active = False, l_render = False, l_hidden = True)
@@ -660,15 +661,11 @@
else:
if self.parent.MapWindow.overlays[self.ovlId]['propwin'] == None:
return
self.parent.MapWindow.overlays[self.ovlId]['propwin'].get_dcmd = self.GetOptData
def OnOptions(self, event):
- """ self.SetSizer(sizer)
- sizer.Fit(self)
- Sets option for decoration map overlays
+ """!Sets option for decoration map overlays
if self.parent.MapWindow.overlays[self.ovlId]['propwin'] is None:
# build properties dialog
@@ -680,7 +677,7 @@
self.parent.MapWindow.overlays[self.ovlId]['propwin'].SetFocus()
else:
self.parent.MapWindow.overlays[self.ovlId]['propwin'].Show()
def OnResize(self, event):
if self.FindWindowByName('resize').GetValue():
self.parent.MapWindow.SetCursor(self.parent.cursors["cross"])
@@ -706,16 +703,16 @@
"""!Button 'OK' pressed"""
# enable or disable overlay
self.parent.Map.GetOverlay(self.ovlId).SetActive(self.chkbox.IsChecked())
# update map
if self.parent.IsPaneShown('3d'):
self.parent.MapWindow.UpdateOverlays()
self.parent.MapWindow.UpdateMap()
# close dialog
self.OnCancel(None)
def GetOptData(self, dcmd, layer, params, propwin):
"""!Process decoration layer data"""
# update layer data
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2011-10-16 09:53:20 UTC (rev 48827)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2011-10-16 10:28:06 UTC (rev 48828)
@@ -788,8 +788,8 @@
if not display or not display.IsAutoRendered():
return
mapLayers = map(lambda x: x.GetName(),
- display.GetRender().GetListOfLayers(l_type = 'raster') +
- display.GetRender().GetListOfLayers(l_type = 'vector'))
+ display.GetMap().GetListOfLayers(l_type = 'raster') +
+ display.GetMap().GetListOfLayers(l_type = 'vector'))
try:
task = menuform.GUI(show = None).ParseCommand(event.cmd)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-16 09:53:20 UTC (rev 48827)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-16 10:28:06 UTC (rev 48828)
@@ -234,13 +234,6 @@
return self.statusbarManager.GetProgressBar()
- def GetRender(self):
- """!Returns current instance of render.Map()
- @todo make this method obsolate (name GetMap is better)
- return self.Map
def GetMap(self):
"""!Returns current Map instance
@@ -1523,12 +1516,13 @@
return
id = 1 # index for overlay layer in render
cmd = ['d.legend', 'at=5,50,2,5']
- if self.tree.layer_selected and \
+ if self.tree and self.tree.layer_selected and \
self.tree.GetPyData(self.tree.layer_selected)[0]['type'] == 'raster':
cmd.append('map=%s' % self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
# Decoration overlay control dialog
self.dialogs['legend'] = \
gdialogs.DecorationDialog(parent = self, title = ('Legend'),
@@ -1539,13 +1533,13 @@
name = 'legend',
checktxt = _("Show/hide legend"),
ctrltxt = _("legend object"))
self.dialogs['legend'].CentreOnParent()
### dialog cannot be show as modal - in the result d.legend is not selectable
### self.dialogs['legend'].ShowModal()
self.dialogs['legend'].Show()
self.MapWindow.mouse['use'] = 'pointer'
def OnAddText(self, event):
"""!Handler for text decoration menu selection.
@@ -1620,7 +1614,11 @@
"""!Set display extents to match selected raster (including
NULLs) or vector map.
- self.MapWindow.ZoomToMap()
+ layers = None
+ if self.IsStandalone():
+ layers = self.MapWindow.GetMap().GetListOfLayers(l_active = False)
+ self.MapWindow.ZoomToMap(layers = layers)
def OnZoomToRaster(self, event):
"""!Set display extents to match selected raster map (ignore NULLs)
@@ -1747,6 +1745,7 @@
self.timer.Stop()
self.cmdTimeStamp = os.path.getmtime(monFile['cmd'])
self.mapFrm.OnDraw(None)
+ self.mapFrm.GetMap().GetLayersFromCmdFile()
self.timer.Start(mtime)
if __name__ == "__main__":
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-10-16 09:53:20 UTC (rev 48827)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-10-16 10:28:06 UTC (rev 48828)
@@ -1912,3 +1912,7 @@
dist = math.sqrt(math.pow((dEast), 2) + math.pow((dNorth), 2))
return (dist, (dEast, dNorth))
+ def GetMap(self):
+ """!Get render.Map() instance"""
+ return self.Map
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2011-10-16 09:53:20 UTC (rev 48827)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2011-10-16 10:28:06 UTC (rev 48828)
@@ -648,8 +648,8 @@
return
task = GUI(show = None).ParseCommand(cmd)
for p in task.get_options()['params']:
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2011-10-16 09:53:20 UTC (rev 48827)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2011-10-16 10:28:06 UTC (rev 48828)
@@ -833,13 +833,17 @@
return selected
- def _renderLayers(self, force, mapWindow):
+ def _renderLayers(self, force = False, mapWindow = None, overlaysOnly = False):
maps = list()
masks = list()
opacities = list()
# render map layers
ilayer = 1
- for layer in self.layers + self.overlays:
+ if overlaysOnly:
+ layers = self.overlays
+ else:
+ self. self.layers + self.overlays
+ for layer in layers:
# skip non-active map layers
if not layer or not layer.active:
continue
@@ -866,6 +870,36 @@
return maps, masks, opacities
+ def GetLayersFromCmdFile(self):
+ """!Get list of map layers from cmdfile
+ if not self.cmdfile:
+ return
+ nlayers = 0
+ try:
+ fd = open(self.cmdfile, 'r')
+ for line in fd.readlines():
+ cmd = utils.split(line.strip())
+ ltype = None
+ if cmd[0] == 'd.rast':
+ ltype = 'raster'
+ name = utils.GetLayerNameFromCmd(cmd, fullyQualified = True,
+ layerType = ltype)[0]
+ self.AddLayer(type = ltype, command = cmd, l_active = False, name = name)
+ nlayers += 1
+ except IOError, e:
+ grass.warning(_("Unable to read cmdfile '%(cmd)s'. Details: %(det)s") % \
+ { 'cmd' : self.cmdfile, 'det' : e })
+ return
+ fd.close()
+ Debug.msg(1, "Map.GetLayersFromCmdFile(): cmdfile=%s" % self.cmdfile)
+ Debug.msg(1, " nlayers=%d" % nlayers)
def _parseCmdFile(self):
"""!Parse cmd file for standalone application
@@ -876,14 +910,13 @@
cmdLines = fd.readlines()
gcmd.RunCommand('g.gisenv',
set = 'MONITOR_%s_CMDFILE=' % self.monitor)
for cmd in cmdLines:
- cmdStr = cmd.strip().split(' ')
+ cmdStr = utils.split(cmd.strip())
cmd = utils.CmdToTuple(cmdStr)
gcmd.RunCommand(cmd[0], **cmd[1])
nlayers += 1
set = 'MONITOR_%s_CMDFILE=%s' % (self.monitor, self.cmdfile))
except IOError, e:
@@ -895,7 +928,7 @@
Debug.msg(1, "Map.__parseCmdFile(): cmdfile=%s" % self.cmdfile)
return nlayers
def _renderCmdFile(self, force, windres):
@@ -914,6 +947,18 @@
grass.try_remove(self.mapfileCmd) # GRASS_PNG_READ is TRUE
nlayers = self._parseCmdFile()
+ if self.overlays:
+ gcmd.RunCommand('g.gisenv',
+ unset = 'MONITOR') # GRASS_RENDER_IMMEDIATE doesn't like monitors
+ driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
+ if driver == 'png':
+ os.environ["GRASS_RENDER_IMMEDIATE"] = "png"
+ else:
+ os.environ["GRASS_RENDER_IMMEDIATE"] = "cairo"
+ self._renderLayers(overlaysOnly = True)
+ del os.environ["GRASS_RENDER_IMMEDIATE"]
+ set = 'MONITOR=%s' % currMon)
if currMon != self.monitor:
@@ -1053,6 +1098,15 @@
return layer
+ def DeleteAllLayers(self, overlay = False):
+ """!Delete all layers
+ @param overlay True to delete also overlayes
+ self.layers = []
+ if overlay:
+ self.overlays = []
def DeleteLayer(self, layer, overlay = False):
"""!Removes layer from list of layers
