[GRASS-SVN] r48861 - in grass/branches/develbranch_6/gui: scripts wxpython/gui_modules
Wed Oct 19 16:39:37 EDT 2011
Author: martinl
Date: 2011-10-19 13:39:36 -0700 (Wed, 19 Oct 2011)
New Revision: 48861
Added:
   grass/branches/develbranch_6/gui/scripts/r.mapcalc_wrapper
   grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
add r.mapcalc_wrapper for GUI
Added: grass/branches/develbranch_6/gui/scripts/r.mapcalc_wrapper
--- grass/branches/develbranch_6/gui/scripts/r.mapcalc_wrapper	                        (rev 0)
+++ grass/branches/develbranch_6/gui/scripts/r.mapcalc_wrapper	2011-10-19 20:39:36 UTC (rev 48861)
@@ -0,0 +1,65 @@
+#!/bin/sh
+# MODULE:       r.mapcalc_wrapper
+# AUTHOR(S):    Martin Landa <landa.martin gmail.com>
+# PURPOSE:      Simulate standard g.parser interface for GUI
+# COPYRIGHT:    (C) 2011 by The GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%module
+#% description: Raster map calculator.
+#% keywords: raster, algebra
+#%end
+#%option
+#% key: expression
+#% type: string
+#% required: no
+#% multiple: no
+#% description: Expression to evaluate
+#% guisection: Expression
+#%end
+#%option
+#% key: file
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: File containing expression(s) to evaluate
+#% gisprompt: old,file,input
+#%end
+if  [ -z "$GISBASE" ] ; then
+   echo "You must be in GRASS GIS to run this program." 1>&2
+   exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+   exec g.parser "$0" "$@"
+fi
+if [ -n "$GIS_OPT_FILE" ] ; then
+    exec r.mapcalc < "$GIS_OPT_FILE"
+else
+    if [ -n "$GIS_OPT_EXPRESSION" ] ; then
+	exec r.mapcalc "$GIS_OPT_EXPRESSION"
+    else
+	exec g.message -e message="Either <expression> or <file> option must be given"
+	exit 1
+    fi
+fi
+exit 0
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py	2011-10-19 19:39:24 UTC (rev 48860)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py	2011-10-19 20:39:36 UTC (rev 48861)
@@ -152,7 +152,10 @@
     if gui_scripts:
         os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'gui', 'scripts')
         os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'wxpython', 'scripts')
-        cmd = cmd + os.listdir(os.path.join(gisbase, 'etc', 'gui', 'scripts'))
+        for script in os.listdir(os.path.join(gisbase, 'etc', 'gui', 'scripts')):
+            patt = "_wrapper"
+            if script[-len(patt):] != patt: # ignore wrappers
+                cmd.append(script)
     if addons and os.getenv('GRASS_ADDON_PATH'):
         path = os.getenv('GRASS_ADDON_PATH')
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py	2011-10-19 19:39:24 UTC (rev 48860)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py	2011-10-19 20:39:36 UTC (rev 48861)
@@ -1241,11 +1241,6 @@
         # add action to canvas
         width, height = self.canvas.GetSize()
-        if cmd[0] == 'r.mapcalc':
-            GMessage(parent = self,
-                     message = _("Module r.mapcalc cannot be used in the model. "
-                                 "Use r.mapcalculator instead."))
-            return
         action = ModelAction(self.model, cmd = cmd, x = width/2, y = height/2,
                              id = self.model.GetNextId())
@@ -1747,6 +1742,9 @@
             width = UserSettings.Get(group='modeler', key='action', subkey=('size', 'width'))
         if not height:
             height = UserSettings.Get(group='modeler', key='action', subkey=('size', 'height'))
+        if cmd[0] in ('r.mapcalc', 'v.type'):
+            cmd[0] += '_wrapper'
         if cmd:
             self.task = menuform.GUI(show = None).ParseCommand(cmd = cmd)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py	2011-10-19 19:39:24 UTC (rev 48860)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py	2011-10-19 20:39:36 UTC (rev 48861)
@@ -794,7 +794,11 @@
         cmd = text.strip().split(' ')[0]
         if not self.cmdDesc or cmd != self.cmdDesc.get_name():
-            if cmd in ('r.mapcalc', 'r3.mapcalc'):
+            if cmd in ('r.mapcalc', 'v.type'):
+                cmd = cmd + '_wrapper'
+            if cmd in ('r.mapcalc', 'r3.mapcalc') and \
+                    self.parent.parent.GetName() == 'LayerManager':
                 self.parent.parent.OnMapCalculator(event = None, cmd = [cmd])
                 # add command to history & clean prompt
                 self.UpdateCmdHistory([cmd])
